Maybe a cracked DPF? after only 10 months since an OEM replacement... ack!
cgtoronto
Toronto, Canada
C?ID=592759
Same 2002 and 0401 as I had last spring before replacing DPF and EGR filter.
To help me understand a little more I've been looking for an exhaust diagram. Something that includes the DPF and EGR systems. etc.
I've seen pictures of exhaust components but nothing so far that shows the flow diagram from exhaust -> turbo -> DPF -> EGR loopback -> exhaust flapper... if there was an associated description of when various components were activated under what circumstances it would be excellent.
The reason is that I've noticed occasionally and more lately the exhaust pressure jumping up to 8-10 psi even at highway speeds when most of the time it's less than 1PSI. Is that because the exhaust flapper is closing? I didn't think that happened at highway speeds and would like to understand.
Tuesday,01,April,2025,17:28:27:22998
VCDS Version: 25.3.0.4 (x64)  HEX-V2 CB: 0.4660.5
Data version: 20250311 DS365.0
VIN: 3VWPL7AJ4DM682953   License Plate:
Mileage: 269930km-167726mi   Repair Order:
Chassis Type: AJ-VW36 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 2E 37 42 44 46 4F 52 56 62 72
VIN: 3VWPL7AJ4DM682953   Mileage: 269930km-167726miles
   Part No SW: 03L 997 030 E    HW: 03L 907 309 AA
   Component: R4 2.0l TDI G000AG  9983
   Revision: 12H15---    Serial number:
   Coding: 0050078
   Shop #: WSC 42405 001 1048576
   VCID: 303EC90E1626CEEA3F7-8064
   VINID: 0E69E070745A1147462022450CA1C5B18A
001025 - EGR System
               P0401 - 001 - Insufficient Flow - Intermittent
                    Fault Status: 00100001
                    Mileage: 269854 km
                    Date: 2019.08.23.
                    Time: 15:04:49
                    RPM: 2254 /min
                    Speed: 114.0 km/h
                    Voltage: 14.21 V
                    Load: 81.2 %
                    Load: 100.0 %
                    Mass Air / Rev.: 335.0 mg/str
                    Mass Air / Rev.: 350.0 mg/str
008194 - Particulate Trap Bank 1
               P2002 - 007 - Efficiency Below Threshold
                    Fault Status: 01100111
                    Mileage: 269879 km
                    Date: 2019.08.23.
                    Time: 15:18:13
                    RPM: 2231 /min
                    Speed: 114.0 km/h
                    (no units): 76.5
                    (no units): 25.5
                    (no units): 2.25
                    Pressure: 164 mbar
                    Pressure: 33 mbar
005078 - Cylinder 3 Internal Pressure Sensor
               P13D6 - 001 - Implausible Signal
                    Fault Status: 01100001
                    Mileage: 269907 km
                    Date: 2019.08.23.
                    Time: 15:32:51
                    RPM: 2162 /min
                    Speed: 111.0 km/h
                    Bin. Bits: 00100000
                    Absolute Pres.: 49.0 bar
                    (no units): -0.90
                    Ign. Timing: 0.5 °BTDC
                    (no units): 18.40
   Component: GSG DSG AG6     512 9430
   Revision: 05651213    Serial number: 00001212101797
   Shop #: WSC 00066 000 00000
   VCID: 1476659E827E12CA3BF-8040
   Revision: 00H31001
   Coding: 114B600C492A00FC881406E9921C0042310000
   VCID: 7DA0203A9DF4F382E41-8028
   Part No SW: 5K0 907 044 GR    HW: 5K0 907 044 GR
   Component: Climatronic   H19 1313
   Revision: 00001004
   Coding: 0010004002
   Shop #: WSC 00066 000 00118
   VCID: 01585CCAE18C9762809-8054
   Part No SW: 5K0 937 086 N    HW: 5K0 937 086 N
   Component: BCM PQ35 M    021 0064
   Revision: BJ021001
   Coding: 25380E1F802F3EC4008800C17000054449000086535D0560648020200040
   Shop #: WSC 00066 123 12345
   VCID: 3FDC9A32D7782192B6D-806A
   Subsystem 1 - Part No: 5K1 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer 22041  26  0512
   Coding: 009795
   Part No SW: 5C0 959 655 M    HW: 5C0 959 655 M
   Component: AirbagVW10G   014 0726
   Serial number: 003L4R01HM2B   Dataset Number: 1KM003v__B_ 0048
   Coding: 00004E43
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 3C26ED3EC6EE3A8A93F-8068
   Subsystem 1 - Part No SW: 1KM 955 557     HW: 1KM 955 557
   Serial number: 3572MSME54006578ZZZS
   Subsystem 2 - Part No SW: 1KM 955 557     HW: 1KM 955 557
   Serial number: 3582MSME1E796478ZZZ7
   Serial number: 3511HSME0C45392FZZZV
   Serial number: 3521HSME0F30362FZZZQ
   Serial number: 35527SME7E58272FZZZ-
   Serial number: 35627SME0D5A272FZZZV
   Component: Lenks.Modul   008 0090
   Revision: --------    Serial number:  90440MBP001H0 Dataset Number: 5K0953507AH D005
   Coding: 188A140000
   Shop #: WSC 00066 000 00187
   ROD: EV_SMLSNGKUDS_A05_VW32.rod
   VCID: 76B23F16B842A0DAA5B-8022
   Serial number: 0123876 FLE 20130301
   Coding: 820000
   Part No SW: 5K0 920 873 A    HW: 5K0 920 873 A
   Component: KOMBI         H05 0705
   Coding: 370F00
   VCID: 2E02D7760092D81A2DB-807A
   Part No SW: 7N0 907 530 AH    HW: 7N0 907 530 AH
   Component: J533  Gateway H50 1634
   Revision:   H50       Serial number: 09041303291099
   Coding: 352002
   VCID: 76B23F16B8C2A0DAA5B-8022
   Component: IMMO          H05 0705
   VCID: 6A8A1B66FCFA743A313-803E
   Component: SG EXT.PLAYER H19 0550
   Revision: A1001003    Serial number: 7664148169
   Coding: 020100
   VCID: 2A0ADB663CFAB43AF13-807E
   Part No SW: 1K0 035 274 D    HW: 1K0 035 274 D
   Component: RNS315-NAR    H58 0319
   Serial number: VWZAZ2N0088584
   Coding: 04000401040007000000100A
   Shop #: WSC 01383 790 50316
   ROD: EV_RNS315NARV2UDS_VW32.rod
   VCID: 2510285A55649B42DC1-8070
   Component: NAR_V3_(0037)  0037
                    Reset counter: 57
                    Mileage: 269671 km
                    Date: 2025.04.01.
                    Time: 09:38:02
   Component: TUER-SG FT    002 0501
   Revision: 13110009    Serial number: 0006537490
   Coding: 0004B5
   VCID: 5BE44EA223A01DB2BA5-800E
   Slave Driver:
   Subsystem 1 - Part No SW: 3C0 959 703 C    HW: 3C0 959 795 D  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  008 1509
   Serial number: 00000007687088
   Coding: 000490
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 70     3305
   Revision: 00H22000
   Shop #: WSC 02069 000 90108
   VCID: 372CF212F34819D27ED-8062
   Part No SW: 7N0 907 532     HW: 7N0 907 530 AH
   Component: EZE_2         H50 1634
   Coding: 050B0500
   VCID: 6FBC0A72C798911266D-803A
   Component: J245EE20SKB13  H05 0220
   Component: J394EE20SKB13  H05 0220
   Component: TUER-SG BT    002 0501
   Revision: 15110009    Serial number: 0006544475
   Coding: 0004B4
   VCID: 5CE64DBE26AE1A8AB3F-8008
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C0 959 704 C    HW: 3C0 959 794 D  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  008 1509
   Serial number: 00000007669192
   Coding: 000490
End----------(Elapsed Time: 01:21, VBatt start/end: 14.1V/14.1V)-----------
------------------------------4 Faults Found-------------------------------
Dr Sheldon
Windsor UK
C?ID=334979
001025 - EGR System
Fix the EGR and the Pressure Sensor first !!
  • Agree
Spend a little and get the official manuals.....
Or search a little and read the SSPs pertaining to your vehicle.
Your EGR faults (broken system) are not allowing active regeneration to take place.
You're still ok, but won't be for long if it doesn't get rectified.
(no units): 25.5
(no units): 2.25
Here are some breadcrumbs for you..... google "Self Study Program 826803 2.0 Liter TDI Common Rail BIN5 ULEV Engine"
Also look here 2014 Jetta & GLI Quick Reference Specification Book
cgtoronto
Toronto, Canada
C?ID=592759
Thank You. I just read the SSP you suggested and it's EXACTLY what I've been looking for, and yes, I've been looking.
volkswagenclub.net is an incredible source of information.
Maybe a sticky for newbies of various sites would save many unnecessary questions that clog the forums.
Just sayin'
When you scroll up and click the how to, you are told where to obtain the official manuals. That same source will have all the pertinent SSPs, etc.
cgtoronto
Toronto, Canada
C?ID=592759
I've waited to respond until I had reviewed some more information pointers provided by SaVAGeSoot.
The 3 errors were registered (as shown on my dump above) with VAG-COM but hadn't resulted in a CEL. My ELM327 which I use frequently to see the regen status showed that the errors were "pending" not "confirmed".
The P13D6 has reared it's ugly head periodically over the past few years. Replacing the Glow Plug / Pressure sensor worked for a while. Swapping the injectors 3<->4 had cleared it up for the last 6 months or so until now.
I wasn't sure if the P13D6 was related to the other errors or just a timing coincidence so I focused on analyzing the other 2 errors (P0401 and P2002), which matched the errors I had last spring and resulted in replacing the DPF, EGR filter and exhaust flap.
The 3 codes popped up as "pending" all within a few minutes in the middle of a highway drive as per the freeze frames.
However, still no CEL after several more hundred Ks of highway driving.
I haven't done any resets of any kind yet.
Yesterday the ELM327 now only showed P2002 as "pending". No other codes.
Still no CEL and a new scan on VAG-COM verifies that only P2002 is registered as an error.
More investigation to follow.
Post updated scan.
Learn how to read the FF data.
There are counters for self resets, but not all codes will reset on their own.
Reading\interpreting readiness is also critical.
Use your Amazon tool as you please, but not for actual diagnostics.... especially when you have a proper diag tool\software.
cgtoronto
Toronto, Canada
C?ID=592759
I just use the ELM while I'm bored driving... not for diagnostics... agreed.
The learning curve is very steep with all the capability of VAG-COM. I'm working on it.
yesterday afternoon ... with no CEL
Thursday,03,April,2025,14:47:17:22998
Mileage: 269970km-167751mi   Repair Order:
VIN: 3VWPL7AJ4DM682953   Mileage: 269970km-167751miles
   Coding: 0050078
                    Mileage: 269879 km
                    Date: 2019.08.25.
                    Time: 15:18:13
                    RPM: 2231 /min
                    Speed: 114.0 km/h
                    (no units): 76.5
                    (no units): 25.5
                    (no units): 2.25
                    Pressure: 164 mbar
                    Pressure: 33 mbar
   Revision: 00H31001
   Revision: 00001004
   Coding: 0010004002
   Revision: BJ021001
   Coding: 009795
   Coding: 00004E43
   Coding: 188A140000
   Coding: 820000
   Coding: 370F00
   Coding: 352002
   Coding: 020100
                    Reset counter: 57
                    Mileage: 269671 km
                    Date: 2025.04.03.
                    Time: 09:38:02
   Coding: 0004B5
   Slave Driver:
   Coding: 000490
   Revision: 00H22000
   Coding: 050B0500
   Coding: 0004B4
   Slave Passenger:
   Coding: 000490
End----------(Elapsed Time: 01:22, VBatt start/end: 13.9V/13.9V)-----------
This Morning (with CEL ON... sigh)
Friday,04,April,2025,10:40:52:22998
Mileage: 269990km-167764mi   Repair Order:
                Address 01: Engine       Labels: 03L-906-022-CBE.clb
Control Module Part Number: 03L 997 030 E    HW: 03L 907 309 AA
  Component and/or Version: R4 2.0l TDI G000AG  9983
           Software Coding: 0050078
            Work Shop Code: WSC 42405 001 1048576
               P2002 - 007 - Efficiency Below Threshold - MIL ON
                    Fault Status: 11100111
                    Mileage: 269879 km
                    Date: 2019.08.26.
                    Time: 15:18:13
                    RPM: 2231 /min
                    Speed: 114.0 km/h
                    (no units): 76.5
                    (no units): 25.5
                    (no units): 2.25
                    Pressure: 164 mbar
                    Pressure: 33 mbar
                    Mileage: 269981 km
                    Date: 2019.08.26.
                    Time: 15:44:04
                    RPM: 1863 /min
                    Speed: 96.0 km/h
                    Bin. Bits: 00100000
                    Absolute Pres.: 44.0 bar
                    (no units): -1.50
                    (no units): 18.40
Readiness: 1 1 0 0 0
Friday,04,April,2025,10:57:38:22998
VIN: 3VWPL7AJ4DM682953   Mileage: 269990km-167764miles
   Coding: 0050078
                    Mileage: 269879 km
                    Date: 2019.08.26.
                    Time: 15:18:13
                    RPM: 2231 /min
                    Speed: 114.0 km/h
                    (no units): 76.5
                    (no units): 25.5
                    (no units): 2.25
                    Pressure: 164 mbar
                    Pressure: 33 mbar
                    Mileage: 269981 km
                    Date: 2019.08.26.
                    Time: 15:44:04
                    RPM: 1863 /min
                    Speed: 96.0 km/h
                    Bin. Bits: 00100000
                    (no units): -1.50
                    (no units): 18.40
   Revision: 00H31001
   Revision: 00001004
   Coding: 0010004002
   Revision: BJ021001
   Coding: 009795
   Coding: 00004E43
   Coding: 188A140000
   Coding: 820000
   Coding: 370F00
   Coding: 352002
   Coding: 020100
                    Reset counter: 57
                    Mileage: 269671 km
                    Date: 2025.04.04.
                    Time: 09:38:02
   Coding: 0004B5
   Slave Driver:
   Coding: 000490
   Revision: 00H22000
   Coding: 050B0500
   Coding: 0004B4
   Slave Passenger:
   Coding: 000490
End----------(Elapsed Time: 01:21, VBatt start/end: 14.2V/14.2V)-----------
------------------------------3 Faults Found-------------------------------
Rich (BB code):
   Coding: 0050078
                    Mileage: 269879 km
                    Date: 2019.08.26.
                    Time: 15:18:13
                    RPM: 2231 /min
                    Speed: 114.0 km/h
                    (no units): 76.5
                    (no units): 25.5
                    (no units): 2.25
                    Pressure: 164 mbar
                    Pressure: 33 mbar
                    Mileage: 269981 km
                    Date: 2019.08.26.
                    Time: 15:44:04
                    RPM: 1863 /min
                    Speed: 96.0 km/h
                    Bin. Bits: 00100000
                    (no units): -1.50
                    (no units): 18.40
I've added some BOLD to your FF data so you can start looking at it.
See how your DPF fault hasn't repeated? That's good.
See how the ODO reading from when the fault occurred is the the past? That's also good.
See how the resent counter isn't going down? That's not good.
This means, that even if your DFP is regenerating (you haven't offered any evidence or data that it is), the code won't go away until you blow it away.
So, you MVBs or Advanced Measuring Values to look up the stats on your DPF... see what your soot values are at, when the last regen took place, etc.
The GP sensor issue has also only happened once thus far... so let's ignore that for now until we know more about the DPF status.
avf383
Australia
C?ID=515146
Savage, where can you find other quick reference books for other models on that site?
On the same site.
Or you can even search here.
Or you can learn how to customize your search query when using Google.
Choose your poison
I just logged into a computer and seen your location.... slightly confused why you'd be interested in a site dedicated to a completely different market.
National Highway Traffic Safety Administration, part of the U.S. Department of Transportation
What do you mean by “OEM replacement” DPF?
avf383
Australia
C?ID=515146
Because something is better than nothing as Erwin is locked for Aussie users now
avf383
Australia
C?ID=515146
Ever hear of VPN?
Yes and haven’t tried yet, anyhow apologies for asking my original question, just trying to learn from anywhere I can
Then you should read post #3 in the same link you provided me with which tells you to use VPN to get around the problem.
Like I said, the info that I linked you to is from the NaR market, and the RoW market has very different vehicle and and engine models, so it's borderline useless for your down under.
avf383
Australia
C?ID=515146
Yep, even with vpn can’t get specifics on Australian delivered vehicles so totally useless now
