VW Polo 1.2 6r Fault codes
Sparky2804
Bristol, UK
Any help is appreciated!
Full Scan:
VIN: WVWZZZ6RZBU096627   License Plate: MR03BMB
Mileage: 170160km-105732mi   Repair Order: 001
Chassis Type: 6R-VW25 (6N0)
Scan: 01 03 04 08 09 15 17 19 25 2E 44 56
VIN: WVWZZZ6RZBU096627   Mileage: 170160km-105732miles
Address 01: Engine (J623-CGPB)       Labels:. 03E-906-019-CGP.clb
   Part No SW: 03E 906 019 M    HW: 03E 906 019 B
   Component: SIMOS11.1     H03 8949
   Revision: --------    Serial number:                CVN: 719A09A0
   Coding: 00110016000400080000
   Shop #: WSC 31414 790 50316
   ASAM Dataset: EV_ECM12MPI02103E906019M 001007
   ROD: EV_ECM12MPI02103E906019A.rod
   VCID: 2E04F8AE3092ECCAFD7-807A
   VINID: 9E69EAAAA1A2A929402461821C6BA1AF49
6319 - MAP/MAF <-> Throttle Position Correlation
          P0068 00 [11101101] - -
                    Mileage: 170120 km
                    Date: 2025.01.31.
                    Time: 17:10:48
                    Engine RPM: 1295.00 /min
                    Normed load value: 44.7 %
                    Vehicle speed: 27 km/h
                    Coolant temperature: 59 °C
                    Intake air temperature: 32 °C
                    Voltage terminal 30: 13.609 V
                    Absolute intake pressure: 48 kPa abs
                    Intake manifold pressure: specified value-MAP_SP: 455.63 hPa
                    Reduced throttle valve surface active total correction-AR_RED_SUM_COR_ACT_REL: 49.998 %
                    Throttle valve position: actual value-Throttle valve angle: 3.851 °
16908 - Oxygen (Lambda) Sensor B1 S1
          P0134 00 [01100000] - No Activity
                    Mileage: 170149 km
                    Date: 2025.01.31.
                    Time: 14:45:49
                    Engine RPM: 915.00 /min
                    Normed load value: 20.4 %
                    Coolant temperature: 42 °C
                    Intake air temperature: 26 °C
                    Voltage terminal 30: 13.913 V
                    Time since engine start: 40 s
                    Oxygen sensor B1: sensor 1: voltage-Lambda probe voltage: bank 1: probe 1 (broadband probe): 0.225 V
                    Heated oxygen sensor bank 1: sensor 1: resistance-Lambda probe heater: resistance: bank 1: probe 1: 12889 Ohm
                    Exhaust gas temperature before catalytic converter-TEG_DYN_LS_UP[1]: 390.53751 °C
16912 - Oxygen (Lambda) Sensor B1 S1
          P3211 00 [01100101] - Heater Return Coupling
                    Mileage: 170150 km
                    Date: 2025.01.31.
                    Time: 14:50:47
                    Engine RPM: 1089.00 /min
                    Normed load value: 10.2 %
                    Vehicle speed: 8 km/h
                    Coolant temperature: 68 °C
                    Voltage terminal 30: 13.812 V
                    Heated oxygen sensor bank 1: sensor 1: resistance-Lambda probe heater: resistance: bank 1: probe 1: 321 Ohm
                    Exhaust gas temperature before catalytic converter-TEG_DYN_LS_UP[1]: 597.60001 °C
                    Cold start counter: dew point end of front lambda probe-CTR_COLD_ST_LS_UP: 0
Readiness: 0100 0101
   Part No SW: 6R0 907 379 AK    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 230224E3217600B8C42B24E484D800801300
   Shop #: WSC 31414 790 31414
   VCID: 074A6D0AFF689D821E1-8052
                    Fault Status: 00101101
                    Reset counter: 222
                    Mileage: 170120 km
                    Date: 2019.06.24.
                    Time: 17:10:49
                    Hex Value: 0x0000
                    Hex Value: 0x0000
                    Hex Value: 0x1207
                    Hex Value: 0x13B2
                    Hex Value: 0x1A8D
                    Hex Value: 0x8C79
                    Hex Value: 0x8000
Address 08: Auto HVAC (J301)       Labels: 6R0-820-045-9AB.clb
   Part No SW: 6R0 820 045 G    HW: 6R0 820 045 G
   Component: Man AC         02 0101
   Revision: 0002S 02
   VCID: 323CECDE242AC82A99F-8066
   Part No SW: 6R0 937 087 H    HW: 6R0 937 087
   Component: BCM PQ25 H+4  H46 0230
   Revision: BF046001    Serial number: 0394 161110074
   Coding: 24B02BBF08A10000003808003D2B0CD00040410F60060000200000000000
   VCID: 42DCBC1E948A78AA09F-8016
   Subsystem 1 - Part No SW: 6R0 959 802 AB    HW: 6R0 959 802 AB  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  007 1611
   Serial number: KU0KU029041100014643
   Coding: 18BC30
   Subsystem 2 - Part No SW: 6R0 959 801 AD    HW: 6R0 959 801 AD  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  007 1611
   Serial number: KU0KU004041100012866
   Coding: 08BC30
   Subsystem 3 - Part No SW: 5K0 959 542 A    HW: 5K0 959 542 A  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS  H07 0013
   Serial number: 0215911
   Coding: 020000
   Subsystem 4 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
   Component: J388__TSG_HL  007 1611
   Serial number: KU0KU013041100017115
   Coding: 08BC32
   Subsystem 5 - Part No SW: 6R0 959 812 G    HW: 6R0 959 812 G
   Component: J389__TSG_HR  007 1611
   Serial number: KU0KU028041100013272
   Coding: 08BC32
   Part No SW: 6R0 959 655 K    HW: 6R0 959 655 K
   Component: VW10Airbag027 H09 0020
   Revision: --------    Serial number: 003GX00M9EFQ Dataset Number: v00307436R0 0001
   Coding: 003237
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 4ACC943EAC3AA0EAC1F-801E
   Serial number: 3575HRB404V0HJHGBGHC
   Serial number: 3585HRB405J0HM767887
   Serial number: 3515RRB404T0I4AG78NU
   Serial number: 3525RRB405P0I70ICH5J
   Part No SW: 6R0 920 960 F    HW: 6R0 920 960 F
   Component: KOMBI         H05 0304
   Coding: 440A00
   ROD: EV_Kombi_UDS_VDD_RM09_004_VW23.rod
   VCID: 3828DEF6C2D6227AA7B-806C
   Part No SW: 6N0 909 901     HW: 6R0 937 087
   Component: GW-K-CAN TP20 0230
   Coding: 002300
   VCID: 70B826D6EAA6BA3AAFB-8024
   Component: IMMO          H05 0304
   VCID: 6A8C34BECCFA40EAE1F-803E
   Part No SW: 5N0 035 342 D    HW: 5N0 035 342 D
   Revision: A1001003    Serial number: 7669958101
   VCID: 28080EB612F6B2FA37B-807C
03138 - Input AUX IN
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 182
                    Mileage: 170160 km
                    Date: 2019.06.24.
                    Time: 16:05:10
   Part No: 6R0 423 156 B
   Coding: 11250
   Shop #: WSC 31414
   VCID: 2F3AE5AA3E58E5C2F61-807A
   Part No SW: 6RD 035 187 B    HW: 6RD 035 187 B
   Component: Radio         541 5538
   Revision: --------    Serial number: VWZZZ4H6290655
   Coding: 0E000440040005
   Shop #: WSC 127395 840 08317
   VCID: 46D4A00EB8A2448A257-8012
                    Reset counter: 180
                    Mileage: 170113 km
                    Date: 2019.06.24.
                    Time: 17:25:41
00877 - Treble Speaker Rear Right (R16)
                    Fault Status: 00111011
                    Reset counter: 180
                    Mileage: 170113 km
                    Date: 2019.06.24.
                    Time: 17:25:41
                    Reset counter: 180
                    Mileage: 170113 km
                    Date: 2019.06.24.
                    Time: 17:25:44
                    Fault Status: 00110100
                    Reset counter: 180
                    Mileage: 170113 km
                    Date: 2019.06.24.
                    Time: 07:25:27
End----------(Elapsed Time: 01:22, VBatt start/end: 12.3V/12.2V)
Address 56: DTCs cleared
Address 56,6RD 035 187 B,recoded (Long Coding),from,0E000440040005,to,0E000400040005,(127395/840/08317),
The ECM fault will come on when my engine is cold and as soon as the accelerator is used. Once the engine is warm the sensor will often not come back once the engine is re-started. However there is no rough idle/ misfire or loss of power.
The MAP/O2 fault codes tend to show up simultaneously. However, I am puzzled as to how there can be “No activity detected” yet the car runs fine?
I have checked all of the Wheel speed sensors (which are fine)
(I have Replaced MAP/MAF sensor)
The fuses are all fine and I have also cleaned up the metal plate that holds the fuses on the battery.
I have disconnected the battery and ECU
I have cleaned and re seated all ground wires in the engine bay.
I have fitted a lambda to replace the existing one and replaced throttle body (which needed replacing anyway)
The only other thing I can think to check is the wiring loom that goes to the ECU for any wire breaks etc. Figure out if the CAT is faulty, or test for air leaks.
Any help regarding this issue or pointers would be greatly appreciated! I’m pulling my hair out trying to think of different solutions to this problem.
Westbury, UK
That's not the fault you need to concentrate on, that's a sympathy fault.
Look at sorting out the 3 faults in the engine ECU - 6319, 16908 and 16912.
  • Agree
Sparky2804
Bristol, UK
Thank you for your response. The car is booked into the garage next week as I cannot seem to figure the fault with the O2 and MAP sensors, I have replaced both, checked wiring and fuses, with a multimeter, which all seem fine. Figure it is an air leak somewhere, or a faulty catalytic converter after temperature testing it.
@Pascal
South Africa
C?ID=383825
Thursday,17,April,2025,11:28:41:10923
VCDS Version: 25.3.1.0 (x64)  HEX-V2 CB: 0.4671.4
Data version: 20250408 DS365.0
Chassis Type: 6R-VW25 (6RU)
Scan: 01 03 04 09 15 17 19 25 44 56
VIN: AAVZZZ6RZPU021601   Mileage: 28470km-17690miles
Address 01: Engine (J623-CLPB)       Labels: None
   Part No SW: 03C 906 014 GN    HW: 03C 906 014
   Component: CLPB-MM7GV    H02 4035
   Revision: --H02---    Serial number:
   Coding: 00110012020400000000
   Shop #: WSC 31414 790 00200
   VCID: 6FBA2909D78FA6C2661-51CE
   VINID: 4519AAAAA1A2AA094008118004AFFFBE96
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP90.clb
   Part No SW: 6R0 907 379 CB    HW: 6R0 907 379 AS
   Component: ESP9.0i front H04 0003
   Serial number: --------------
   Coding: 000000000000000000000000000000000000
   ASAM Dataset: EV_Brake1ESP90iBOSCH 003031
   ROD: EV_Brake1ESP90iBOSCH_003_VW23.rod
   VCID: 00587AB5FA81A9BA8FB-8054
0943 - ABS/ESP Control Module
          U10C5 00 [10001001] - No or Incorrect Basic Setting
          [IISOEMCalibrationError]
                    Reset counter: 108
0887 - Control Module
          C104A F0 [00011000] - Incorrect VIN
                    Reset counter: 148
                    Mileage: 28479 km
                    Date: 2015.05.07
                    Time: 00:01:44
0883 - Control module not coded
          U1013 00 [00011000] - -
          [VehicleConfigUncoded]
                    Reset counter: 148
   Serial number: 20042313470596
   Coding: 01
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EA4044D8075DF4AFD7-802A
   Part No SW: 6RU 937 086 S    HW: 6RU 937 086 S
   Component: BCM IM M+4    H43 0471
   Revision: BY043001    Serial number: 4103 018230097
   Coding: 3AB02BBF08A12400100000002C2904800040600F60040100220000000A00
   VCID: 71BE2F71C1ABB032705-8024
   Subsystem 1 - Part No: 5Z0 947 105 E
   Component: DWA-Sensor 00  003 0008
Address 15: Airbags (J234)       Labels:| 6C0-959-655.clb
   Part No SW: 6C0 959 655 AM    HW: 6C0 959 655 AM
   Component: Airbag VW12   002 0607
   Revision: --------    Serial number: 0030191A0BH3AM Dataset Number: V03935349EA 0001
   Coding: 8800C0000000000040000000008000000065
   ASAM Dataset: EV_AirbaVW12TS6VW25X 001510
   ROD: EV_AirbaVW12TS6VW25X_VW25.rod
   Part No SW: 6RF 920 861 E    HW: 6RF 920 861 E
   Component: KOMBI         H01 0225
   Coding: 1102010000
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05735
   VCID: 4DC693817D53B4D234D-8018
   Part No SW: 6RU 909 901     HW: 6RU 937 086 S
   Component: GW-K-CAN TP20 H43 0471
   Revision: BY043001
   Coding: 002300
   VCID: 196E37D1799B1872685-804C
   Component: IMMO          H01 0225
   VCID: 6A8C381DECFD43EA31F-803E
Address 44: Steering Assist (J500)       Labels:| 1Sx-909-144-44.clb
   Part No SW: 1S2 909 144 P    HW: 1S2 909 144 P
   Component: EPS_ECU       H61 1702
   Dataset Number: V03935248XE 0001
   Coding: 0101010100000000
   ASAM Dataset: EV_SteerAssisNSK 014008
   ROD: EV_SteerAssisNSK_014_VW12.rod
   VCID: 41DEBFB1B10B60B2C05-8014
   Part No SW: 6RG 035 181     HW: 6RG 035 181
   Component: Radio         023 0135
   Revision: --------    Serial number: VWZGZ1X3070088
   Coding: 0000022002000F
   VCID: 015E7FB1F10BA0B2805-8054
00856 - Radio Antenna
            007 - Short to Ground
                    Fault Status: 01100111
                    Reset counter: 110
                    Mileage: 28479 km
                    Date: 2015.05.10
                    Time: 01:47:49
                    Reset counter: 110
                    Mileage: 28479 km
                    Date: 2015.05.10
                    Time: 01:47:42
                    Bin. Bits:      010
End----------(Elapsed Time: 00:50, VBatt start/end: 14.1V/14.1V)-----------
------------------------------5 Faults Found-------------------------------
@Pascal
South Africa
C?ID=383825
Good day
can i please have abs long coding
