ID4 2024
WestyRID4
Blainville, QC, Canada
C?ID=35758
ID4 2024 Full autoscan below
Address 10 Park/steer assist code 12587099
U110F 00 [00100000] - I'm sorry Dave; I'm afraid I can't do that!
Car behaves even with 46 DTCs. ( in non agressived mode - 106 in agressive mode). The one above made me smile. Any ideas ?
Cheers
Saturday,29,March,2025,17:38:44:27092
VCDS Version: 25.3.0.4 (x64)  HEX-NET2 CB: 0.4660.5
Data version: 20250311 DS365.0
VIN: 1V29SPE81RC022530   License Plate: ID4
Mileage: 4759km-2957mi   Repair Order:
Chassis Type: E8-VWE3 (1EE)
Scan: 01 03 05 06 08 09 10 13 15 16 19 23 2B 36 3C 42 44 47 51 52
          5F 69 6C 6D 75 7E 8C A5 BB BC C0 C6 CE D6 D7 8116 8123 8124 8125 8128
          C002 C003
VIN: 1V29SPE81RC022530   Mileage: 4759km-2957miles
51-Electric Drive -- Status: Malfunction 0010
7E-Ctrl Head Dash -- Status: OK 0000
BB-Door Rear Drv -- Status: Malfunction 0010
CE-Drive Motor 2 -- Status: Malfunction 0010
8116-Snd enhanct 2 -- Status: OK 0000
8123-App server 1 system 1 adaptive -- Status: Malfunction 0010
8124-App server 1 system 2 Java -- Status: Malfunction 0010
8125-App server 3 system 1 infotaint. -- Status: Malfunction 0010
8128-Light line display -- Status: OK 0000
Address 01: Engine (J623----A)       Labels: 0EA-907-425-V2.clb
   Part No SW: 0EA 906 014 DR    HW: 0EA 907 425 K
   Component: E-Vehicle     H80 3630
   CVN: F0AF5F3B
   Coding: 410209034C0E2C0226000100000000000000000000000000
   ASAM Dataset: EV_VCU00XXX0200EA906014DR 003004
   ROD: EV_VCU00XXX0200EA906014DR.rod
   VCID: 0052E9457A859E4A8F7-8054-R SFD
   VINID: 0660898E05480624C008214300468D183A
   Radiator shutter:
   Subsystem 1 - Part No SW: 1EA 965 501 B    HW: 1EA 965 501 B
   Component: V711           023 0008
   Serial number: 20231124060604080786
19854 - Steering Column Control Module
          U0212 00 [00100000] - No Communications
37944 - DC-DC Converter 1 for Electric Drive
          U0599 00 [00101000] - Implausible Signal
                    Fault Frequency: 83
                    Mileage: 37 km
                    Date: 2024.12.24
                    Time: 16:42:42
                    Engine speed: 16383.75 /min
                    Normed load value: 100.0 %
                    Coolant temperature: 215  C
                    Intake air temperature: 215  C
                    Ambient air pressure: 2550 mbar
                    Voltage terminal 30: 15.097 V
                    LF_MVB_PDU_INTC_DIAG_1: 0
                    LF_MVB_PDU_INTC_DIAG_2: 0
                    LF_MVB_PDU_INTC_DIAG_8: 0
                    LF_MVB_PDU_INTC_DIAG_22: 4096
                    LF_MVB_PDU_INTC_DIAG_23: 0
                    LF_MVB_PDU_INTC_DIAG_24: 0
                    LF_MVB_BUS_INTC_DIAG: 0
46740 - Body Control Module (Central Electric)
          U0140 00 [00101110] - No Communications
          [Lost Communication With Body Control Module]
                    Mileage: 37 km
                    Date: 2024.12.24
                    Time: 16:24:09
                    Voltage terminal 30: 13.125 V
                    LF_MVB_PDU_INTC_DIAG_9: 0
                    LF_MVB_PDU_INTC_DIAG_10: 480
                    LF_MVB_PDU_INTC_DIAG_11: 352
                    LF_MVB_PDU_INTC_DIAG_18: 0
                    LF_MVB_PDU_INTC_DIAG_19: 0
17176 - Databus
          U1123 00 [00100000] - Received Error Message
Address 03: ABS Brakes (J104)       Labels: 1EA-614-517-V2.clb
   Part No SW: 1EA 614 517 BP    HW: 1EA 614 517 M
   Component: ESC-ZF_EBC470 H18 0740
   Serial number: 0000000         Dataset Number: V03935415LA 0001 CVN: A611F3
   Coding: 6890438402415902420B990000B78C00250070614000
   ASAM Dataset: EV_BrakeZFESCMEBUNECE 001028
   ROD: EV_BrakeZFESCMEBUNECE_001_VWE3.rod
   VCID: 0154EC41718F9742809-8054-R SFD
9478182 - Diagnostic Gateway Module
          U0447 00 [00100000] - Implausible Signal
          [MSG_KBI_AUSSEN_TEMP_GEF_INVALID]
16401 - Tire Pressure Warning
          C102D 00 [01100100] - -
          [RKA_DEM_MON_P_WARN]
                    Mileage: 3996 km
                    Date: 2025.03.15
                    Time: 21:28:14
Address 05: Acc/Start Auth. (J518)       Labels: 5WA-959-436.clb
   Part No SW: 5WA 959 436 N    HW: 5WA 959 436 N
   Component: Kessy IOBOX   122 0757
   Serial number: --------------- Dataset Number: V03935377PY 0001
   ASAM Dataset: EV_Kessy37w 005030
   ROD: EV_Kessy37w.rod
   VCID: 5F90CA39A7BB01B2D6D-800A-R
   Part No SW: 1N3 959 760 H    HW: 1N3 959 760 H
   Component: MEM-BFS       011 0571
   Serial number: 2470101KA01597
   Coding: 0118BA4000012A008803010101010000000000000000000000000000211000
   ASAM Dataset: EV_SCMPasseSideCONTIAU736 006013
   ROD: EV_SCMPasseSideCONTIAU736_VW38.rod
   VCID: 3E2E57BD40F128BABDB-806A-R
Address 08: Auto HVAC (J979)       Labels:* None
   Part No SW: 1EE 907 007 B    HW: 1EE 907 007 B
   Component: Climatronic   H01 0146
   Serial number: 201072416590960 Dataset Number: V03935427ZS 0001
   Coding: 60202204A010120011101010110001102000103111201101000000000000
   ASAM Dataset: EV_ACClimaBHBE3ADV 002032
   ROD: EV_ACClimaBHBE3ADV_VW49.rod
   VCID: 343A75957EBDF2EA5BF-8060-R SFD
   Interior temperature sensor:
   Subsystem 1 - Part No SW: 5WA 907 527 A    HW: 5WA 907 527 A
   Component: E857           H01 0103
   Serial number: 00002200524100911510
   Air quality sensor:
   Subsystem 2 - Part No SW: 5Q0 907 659 D    HW: 5Q0 907 659 D
   Component: G238 _AQS      H02 0003
   Serial number: 00000000010000379319
   Subsystem 3 - Part No SW: 3G0 963 345 C    HW: 3G0 963 345 C
   Component: SysNameFanLin  016 0103
   Serial number: ESEYSKC0037001
   Subsystem 4 - Part No SW: 3G0 963 345 D    HW: 3G0 963 345 D
   Serial number: ESEYSKD0049639
   Subsystem 5 - Part No SW: 3G0 963 345 C    HW: 3G0 963 345 C
   Serial number: ESEYSKC0043809
   Subsystem 6 - Part No SW: 3G0 963 345 D    HW: 3G0 963 345 D
   Serial number: ESEYSKD0044159
   Blower 2 for left front seat cushion:
   Blower 2 for right front seat cushion:
   A/C compressor sub:
   Subsystem 9 - Part No SW: 1EA 816 797 G    HW: 1EA 816 797 G
   Component: J842 eKK       H09 0005
   Serial number: 1EA816797G05032410CC
   Auxiliary Heater Control Module/PTC 2:
   Subsystem 10 - Part No SW: 1EA 963 581 E    HW: 1EA 963 581 E
   Component: 0123456789012  020 0172
   Serial number: T745647BA24169000311
   Subsystem 11 - Part No SW: 1EA 820 021 B    HW: 1EA 820 021 B
   Component: J126 J126      001 0001
   Serial number: 00000000000000000535
   Expansion valve 1 for refrigerant:
   Subsystem 12 - Part No SW: 1EA 816 590 A    HW: 1EA 816 590 A
   Component: N636 EV1_KaMi  H17 0020
   Serial number: 01500387240622120302
   Subsystem 13 - Part No SW: 4M0 959 603 F    HW: 4M0 959 603 F
   Component: G395 pT-Sens1  H15 0015
   Subsystem 14 - Part No SW: 11A 907 049 B    HW: 11A 907 049 B
   Component: E265 KPH SH    H02 0184
   Serial number: G07S21.05.2400971640
1001273 - A/C Compressor
          B1453 F2 [00100000] - Internal Shut-Down Required
          [A/C Compressor HV Operating Temperature too low]
5245444 - Fan 2 for Left Seat Cushion
          B14CC 31 [00101111] - No Signal
          [Left_front_seat_cushion_fan_2_no_signal]
                    Mileage: 37 km
                    Date: 2024.12.24
                    Time: 12:19:03
5246468 - Fan 2 for Right Seat Cushion
          B14D0 31 [00101111] - No Signal
          [Right_front_seat_cushion_fan_2_no_signal]
                    Mileage: 37 km
                    Date: 2024.12.24
                    Time: 12:19:03
Address 09: Cent. Elect. (J519)       Labels: 1EA-937-BCM-V1.clb
   Part No SW: 1EE 937 089 D    HW: 1EE 937 089
   Component: SAM_H         H08 0530
   Serial number: 01102415202268 Dataset Number: V03935428YW 0001
   ASAM Dataset: EV_SAMVW31x 005001
   ROD: EV_SAMVW31x_005_VWE3.rod
   VCID: 43D826492B134552D25-8016-R SFD
   Subsystem 1 - Part No SW: 11K 955 113     HW: 11K 955 113
   Component: WISCHER_MYJTL  006 0052
   Serial number: VALSLP10072401002684
   Subsystem 2 - Part No SW: 89A 955 555     HW: 89A 955 555
   Component: G397_RLFSS     003 0002
   Serial number: MRO71318042400011941
   Subsystem 3 - Part No SW: 10A 941 193 M    HW: 10A 941 193 M
   Component: LiSi           H04 0515
   Serial number: YSJ61910072400030084
   Subsystem 4 - Part No SW: 11A 953 509     HW: 11A 953 509
   Component: DiETa          H06 0026
   Serial number: LZH 8BS00106384
   Subsystem 5 - Part No SW: 5H0 959 561 BM    HW: 5H0 959 561 BM
   Component: -VW----LINDA-  504 0831
   Serial number: K5JLND24072400000480
1074806 - Databus
          U1123 00 [00101100] - Received Error Message
          [ICAS1_Gateway Datenbus empfangener Fehlerwert]
                    Reset counter: 28
                    Mileage: 4196 km
                    Date: 2025.03.20
                    Time: 04:59:13
                    Terminal 15 status: OFF
                    Terminal 50 status: OFF
                    Status drive readiness: not ready to drive
                    Status of brake lamp switch: discrete: OFF
                    Brake lamp switch via CAN: status: OFF
                    Operating condition: Normal mode
                    Voltage: 12.4 V
                    Outside temperature: 13.0  C
                    Light switch position: automatic
15401472 - Secure Onboard Communication
          U14FF 00 [01100100] - Signature Generation Failed
          [Sichere on-board Kommunikation: Signaturerstellung fehlgeschlagen]
                    Reset counter: 17
                    Mileage: 3825 km
                    Date: 2025.03.14
                    Time: 00:48:10
                    Voltage: 13.1 V
                    Outside temperature: 4.5  C
8667507 - Databus
          U1121 00 [00101100] - Missing Message
          [BMS_07 Datenbus fehlende Botschaft]
                    Mileage: 469 km
                    Date: 2025.01.05
                    Time: 20:22:48
                    Voltage: 12.7 V
                    Outside temperature: -8.0  C
   Part No SW: 1EE 919 300 C    HW: 1EE 919 300
   Component: RPA12K        H01 0514
   Serial number: 000024042494560 Dataset Number: V03935421CM 0001
   Coding: 0230066101
   ASAM Dataset: EV_EPHBO3CVW4130000 001014
   ROD: EV_EPHBO3CVW4130000_VWE3.rod
13 Faults Found:
1080304 - Parking Sensor(s); Rear
          B107B F0 [00100000] - Function Limitation due to External Factors
1113328 - Parking Sensor(s); Front
          B10FC F0 [00100000] - Function Limitation due to External Factors
          [Geber f r Einparkhilfe vorne - Funktionseinschr nkung durch Umwelteinfl sse]
10494466 - Parking Sensor; Front Left
          B10F7 F5 [01100000] - Ice or Dirt Detection
          [Geber f r Einparkhilfe vorne links - Schmutz bzw. Eisbildung]
10494467 - Parking Sensor; Front Left Center
          B10F8 F5 [01100000] - Ice or Dirt Detection
          [Geber f r Einparkhilfe vorne links mitte - Schmutz bzw. Eisbildung]
10494468 - Parking Sensor; Front Right Center
          B10F9 F5 [01100000] - Ice or Dirt Detection
          [Geber f r Einparkhilfe vorne rechts mitte - Schmutz bzw. Eisbildung]
10494469 - Parking Sensor; Front Right
          B10FA F5 [01100000] - Ice or Dirt Detection
          [Geber f r Einparkhilfe vorne rechts - Schmutz bzw. Eisbildung]
10494473 - Parking Sensor; Rear Left Center
          B1077 F6 [01100000] - Ice or Dirt Detection
          [Geber f r Einparkhilfe hinten links mitte - Schmutz bzw. Eisbildung]
10494480 - Parking Sensor; Rear Right Center
          B1078 F6 [01100000] - Ice or Dirt Detection
          [Geber f r Einparkhilfe hinten rechts mitte - Schmutz bzw. Eisbildung]
10494482 - Parking Sensor; Rear Right Side
          B107E F6 [01100000] - Ice or Dirt Detection
          [Geber f r Einparkhilfe hinten rechts seite - Schmutz bzw. Eisbildung]
12587099 - Control Module
          [Funktion Triebstrangkoordinator im Motorsteuerger t f r Park Assist im Fehler]
12587177 - Control Module
          [TPA_failure_on_MFK]
13959178 - Front Parking Aid Sensor(s)
          B10FC F1 [00100000] - Ice or Dirt Detection
          [Geber f r Einparkhilfe vorn - Schmutz bzw. Eisbildung]
13959179 - Parking Sensor(s); Rear
          B107B F1 [00100000] - Ice or Dirt Detection
          [Geber f r Einparkhilfe hinten - Schmutz bzw. Eisbildung]
   Part No SW: 1EA 907 567 C    HW: 1EA 907 819
   Component: ARS512VW13    H05 0099
   Dataset Number: V03935416QG 0001
   Coding: 06830AE24071C0441257400000C040052E4020000000000000000000000000
   ASAM Dataset: EV_FRONTRADARCONTIVW310 004013
   ROD: EV_FRONTRADARCONTIVW310_004_VWE3.rod
   VCID: 3C2A5DB556ED3AAA93F-8068-R SFD
209054 - Databus
          [FAULT_BV_BLINDNESS_ERROR]
2092 - Databus
          U1122 00 [00100000] - Implausible Message
          [FAULT_QDISACC_FAIL]
1538 - Sensor for Automatic Distance Control
          C110B F0 [01100000] - Limited Visibility
          [FAULT_SENSOR_BLINDNESS]
1396 - Sensor for Automatic Distance Control
          [FAULT_SENSOR_NO_FREE_SIGHT]
2068 - Databus
          U1123 00 [01101000] - Received Error Message
          [FAULT_TSK_IRREV_ERROR]
                    Mileage: 740 km
                    Date: 2025.01.12
                    Time: 23:20:52
1076 - Databus
          U1121 00 [00100000] - Missing Message
          [FAULT_TIMEOUT_GRA_ACC_01]
Address 15: Airbags (J234)       Labels:* 3WA-959-655.clb
   Part No SW: 3WA 959 655 P    HW: 3WA 959 655 P
   Component: Airbag VW50   006 0141
   Revision: --------    Serial number: 003C0RQC92WJDQ Dataset Number: V03935421QA 0001
   Coding: 8CCC000000FCC00000000020000000009100000081000000800036F8002B0065
   Shop #: WSC 06050 062 00200
   ASAM Dataset: EV_AirbaVW50TS6VW49X 001001
   ROD: EV_AirbaVW50TS6VW49X_VWE3.rod
   VCID: 6296C3CD94C92C5AF93-8036-R SFD
   Component: BF-Gewichtss.  H17 0022
   Serial number: IBH0000D24000MXZH202
   Subsystem 2 - Part No SW: -----------    HW: 654 003 110 23
   Component: SideSensor_Df  010 0887
   Serial number: 3570000693815C43166-
   Subsystem 3 - Part No SW: -----------    HW: 654 000 211 23
   Component: SideSensor_Pf  010 0887
   Serial number: 35800005438D254E2C57
   Subsystem 4 - Part No SW: -----------    HW: 654 002 803 24
   Component: SideSensor_Dr  080 0149
   Serial number: 35100507CC6BF7904AAV
   Subsystem 5 - Part No SW: -----------    HW: 654 002 601 24
   Component: SideSensor_Pr  080 0149
   Serial number: 35200507AC25750CE8FQ
   Subsystem 6 - Part No SW: -----------    HW: 654 001 802 24
   Component: FrontSensor_D  030 010A
   Serial number: 355005094C6BF787E6D1
   Subsystem 7 - Part No SW: -----------    HW: 654 001 802 24
   Component: FrontSensor_P  030 010A
   Serial number: 356005068C257558C8EP
   Crash sensor for side airbag: B-pillar: driver side:
   Subsystem 8 - Part No SW: -----------    HW: 654 002 703 24
   Component: Side_Sens_B_D  080 0149
   Serial number: I0P00508CC6BF7944ABS
   Crash sensor for side airbag: B-pillar: passenger side:
   Subsystem 9 - Part No SW: -----------    HW: 654 002 601 24
   Component: Side_Sens_B_P  080 0149
   Serial number: I0Q005074C7CEBDAA6E/
Address 16: Steering wheel (J527)       Labels: 1EE-953-507.clb
   Part No SW: 1EE 953 507 BP    HW: 1EE 953 507 BP
   Component: GSMMEB        005 0060
   Serial number: 000000220524260
   ASAM Dataset: EV_SMLSKLOGEN2 007004
   ROD: EV_SMLSKLOGEN2_007.rod
   VCID: 0A46CB6D4CB9D41AD13-805E-R SFD
Address 19: CAN Gateway (J533)       Labels: 1EE-937-012.clb
   Part No SW: 1EE 937 012 D    HW: 1EE 937 012
   Component: ICAS1 Host-SG 021 0411
   Serial number: SMERBG240524007 Dataset Number: V03935420NB 0001
   GVL: 2D00080006C8D0FC806290C248180050C400400000010000000200000000C057
   ASAM Dataset: EV_GatewICAS1MEBUNECE 001013
   ROD: EV_GatewICAS1MEBUNECE_VWE3.rod
   VCID: 353C489175C7EBE26C1-8060 SFD
   Subsystem 1 - Part No SW: 1EA 915 181 C    HW: 1EA 915 181 C
   Component: J367-BDMConti  H05 1076
   Serial number: 7856790000240503050C
   Subsystem 2 - Part No SW: 3G0 959 542 B    HW: 3G0 959 542 B
   Component: J IEEHOD1ZONE  251 0303
   Serial number: 00000000230501040599
   Subsystem 3 - Part No SW: 3G0 962 243 C    HW: 3G0 962 243 C
   Serial number: 24932111
20 Faults Found:
1049259 - Ethernet Databus; Branch 11
          U14A8 00 [00100100] - No Communication
2502759 - Ethernet Module for Emergency Call
          U1642 00 [00100000] - No Communication
          [Emergency-call_module_no_communication_vlan]
8397571 - LV Energy Management
          B1802 F1 [00101100] - Warning Triggered
                    Reset counter: 24
                    Mileage: 2805 km
                    Date: 2025.02.18
                    Time: 20:08:04
                    6
8540417 - EgoMaster
          U15FA 00 [00101110] - Input Data Error
                    Fault Frequency: 38
                    Mileage: 83 km
                    Date: 2024.12.29
                    Time: 01:21:58
                    Suchbeleuchtung_KL_58xt_Bus_Kennlinie-x0: 0.0
                    Suchbeleuchtung_KL_58xt_Bus_Kennlinie-X1: 0.0
                    Suchbeleuchtung_KL_58xt_Bus_Kennlinie-X2: 0.0
                    Suchbeleuchtung_KL_58xt_Bus_Kennlinie-X3: 0.0
                    Suchbeleuchtung_KL_58xt_Bus_Kennlinie-X4: 0.0
                    Suchbeleuchtung_KL_58xt_Bus_Kennlinie-y0: 0.0 %
                    Suchbeleuchtung_KL_58xt_Bus_Kennlinie-Y1: 0.0 %
                    Suchbeleuchtung_KL_58xt_Bus_Kennlinie-Y2: 0.0 %
                    Suchbeleuchtung_KL_58xt_Bus_Kennlinie-Y3: 0.0 %
                    Suchbeleuchtung_KL_58xt_Bus_Kennlinie-Y4: 0.0 %
                    Suchbeleuchtung_KL_58xt_Bus_Kennlinie-x0: 1.0
8491266 - Secure Onboard Communication
          U14FE 00 [00101100] - Signature Verification Failed
          [SOK_signature_verification_failed]
                    Fault Frequency: 247
                    Mileage: 37 km
                    Date: 2024.12.24
                    Time: 16:28:15
9371914 - Predictive Route Data
          B1630 02 [01101101] - Signal Failure
                    Mileage: 37 km
                    Date: 2024.12.24
                    Time: 12:36:35
9371915 - Predictive Route Data
          B1630 02 [00101100] - Signal Failure
                    Fault Frequency: 117
                    Mileage: 37 km
                    Date: 2024.12.24
                    Time: 20:09:38
8557057 - Realtime Clock
          U15E8 00 [00100100] - Improper Memory Access
          [ZM_RTC_Fault_Internal_Communication]
                    Reset counter: 2
                    Mileage: 3269 km
                    Date: 2025.02.24
                    Time: 00:20:06
8515633 - Charging Connector Lock
          B17E0 F0 [01100100] - Plug not Locked
          [HVLM_limp_home_plug_locking]
8515841 - Heater Coolant Shut-Off Valve
          P1BF1 00 [01101100] - Input Voltage Fault
          [HVLM_timeout_grid_voltage]
                    Reset counter: 37
                    Mileage: 4655 km
                    Date: 2025.03.25
                    Time: 02:21:13
8515865 - HV Charge Monitoring
          P1CAF 00 [01100100] - Charging Current at Zero for too Long
          [HVLM_zero_current_time_exceeded_AC]
8516608 - Expanded Charging Function
          P1BFE 00 [00101111] - Sequence Error
                    Fault Frequency: 62
                    Mileage: 121 km
                    Date: 2024.12.29
                    Time: 05:15:44
2240615 - No Communications with Emergency Call Module
          U10E1 00 [00100000] - -
2244873 - Display Module in Dashboard
          U1660 00 [00100000] - No Communications
          [Dash_board_display_unit_no_communication]
8515671 - High-Voltage Safety
          B18C6 F0 [01100100] - Emergency Shutdown Requested
          [HVLM_emergency_shut_down_hv_safety]
8516869 - External Charging Infrastructure
          P1DCB 00 [01100100] - Not Ready for Charging Socket 1
          [HVLM_unknown_cp_communication_a]
8516883 - Charging Socket 1
          P1DD5 00 [01100100] - Connector Locking Activation Fault
          [HVLM_control_plug_lock_locking_a]
1048918 - Local Databus 6
          U1501 00 [00101100] - Electrical malfunction
          [Local_data_bus_6_electrical_malfunction]
                    Fault Frequency: 9
                    Reset counter: 37
                    Mileage: 740 km
                    Date: 2025.01.14
                    Time: 19:04:19
8417280 - Diagnostic Filter
          U17A0 00 [01100100] - Not Activated
          [Filter_is_not_active]
8667137 - Mileage
          U1679 00 [00100100] - Calculation Faulty
          [Berechnungsgrundlage Wegstrecke fehlerhaft]
Address 23: Brake Booster (J539)       Labels: Redir Fail!
   Part No SW: 1EA 909 059 BE    HW: 1EA 909 059 Q
   Component: EBB-ZF-Gen1   H33 0840
   Serial number:                 Dataset Number: V03935415UK 0001
   Coding: 40302040300028
   ASAM Dataset: EV_BrakeBoostZFMEBUNECE 001031
   ROD: EV_BrakeBoostZFMEBUNECE.rod
   VCID: 7EAE97BD0071E8BAFDB-802A-R SFD
Address 2B: Steer. Col. Lock (J764)       Labels:. 3WA-905-861.clb
   Part No SW: 3WA 905 861     HW: 3WA 905 861
   Component: ELV-MQB_UNECE H05 0063
   Serial number: 24000139434001
   Coding: 8880000000000000
   ASAM Dataset: EV_ELVMarqUNECE 003006
   ROD: EV_ELVMarqUNECE_003_VW27.rod
   VCID: 0842F16552B5A60AC77-805C-R SFD
   Component: MEM-FS        011 0571
   Serial number: 2470101KA01637
   Coding: 0118BA4000012A008803010101010000000000000000000000000000215000
9655636 - Motor for Seat Fore/Aft Adjustment
          B1355 54 [00101001] - Missing Calibration / Basic Setting
                    Reset counter: 89
                    Mileage: 3757 km
                    Date: 2025.03.09
                    Time: 19:33:29
Address 3C: Lane Change (J1086)       Labels:* Redir Fail!
   Part No SW: 2Q0 907 686 H    HW: 2Q0 907 686 H
   Component: HRE_Master    H26 0320
   Serial number: 11230079196188  Dataset Number: V03935401QQ 0001
   Coding: 66954750
   ASAM Dataset: EV_HREHellaGen3MstrUNECE 001001
   ROD: EV_HREHellaGen3MstrUNECE_VW27.rod
   VCID: 3FD02AB947FB21B2B6D-806A-R
   Subsystem 1 - Part No SW: 2Q0 907 685 H    HW: 2Q0 907 685 H
   Component: HRE_Slave      H26 0320
   Serial number: 11230076790562
   Part No SW: 1EA 959 593 C    HW: 1EA 959 593 C
   Component: TSG FS        007 0561
   Serial number: 0000528244092  Dataset Number: V03935411PP 0001
   Coding: 0014DB2080000480E6008000
   ASAM Dataset: EV_DCU3DriveSideMAXHCONT 001004
   ROD: EV_DCU3DriveSideMAXHCONT_VWE3.rod
   VCID: 42D6234D34094C5AD93-8016-R
   Door operating panel: driver side:
   Subsystem 1 - Part No SW: 10A 959 862 AP    HW: 10A 959 862 AP
   Component: EX36 TBF_FS    H22 0110
   Serial number: 0128-27.06.24-------
   Part No SW: 1EE 907 144 K    HW: 1EE 907 144 B
   Component: BASGEN1MQB37  247 5122
   Serial number: 03381981 Dataset Number: V03935417BZ 0001
   Coding: 00000000000002010000020101000100000001000101
   ASAM Dataset: EV_SteerAssisBASGEN1MQB37 017078
   ROD: EV_SteerAssisBASGEN1MQB37.rod
   VCID: 3FD02AB947FB21B2B6D-806A-R SFD
   Part No SW: 5H0 035 456 E    HW: 5H0 035 456 E
   Component: AMPeth12CDoIP H03 7012
   Serial number: A1129J00030163  Dataset Number: V03935405PY 0001
   Coding: 23000000000000000000000000000000000000000000000000
   ASAM Dataset: EV_AMPEthMQB37w 001005
   ROD: EV_AMPEthMQB37w_VW38.rod
   VCID: 290494E1A97FBF02F89-807C-R SFD
Address 51: Electric Drive (J841)       Labels: 0ET-907-INV-V1.clb
   Part No SW: 0ET 907 121 D    HW: 0ET 907 121 G
   Component: MEB INV6.0    H10 7246
   ASAM Dataset: EV_DMCM21000110ET907121D 001047
   ROD: EV_DMCM21000110ET907121D.rod
   VCID: 41D42C41310F5742C09-8014-R SFD
41631 - No Communication with ESP (Vehicle Dynamics) Control Module
          U0122 00 [00101110] - -
          [Lost Communication With Vehicle Dynamics Control Module]
                    Fault Frequency: 136
41665 - No Communication with Engine Control Module (SAE ECM/PCM)
          U0100 00 [00101110] - -
          [Lost Communication with ECM/PCM]
                    Fault Frequency: 202
                    Mileage: 37 km
                    Date: 2024.12.24
                    Time: 16:23:15
43408 - Online Remote Update
          U192A 00 [00101110] - No Signal
          [Online Remote UpdateNo signal]
                    Mileage: 37 km
                    Date: 2024.12.24
                    Time: 16:24:04
   Part No SW: 1EA 959 592 C    HW: 1EA 959 592 C
   Component: TSG BFS       007 0561
   Serial number: 0000528171639  Dataset Number: V03935411ZR 0001
   Coding: 0014532080000480E2808000
   ASAM Dataset: EV_DCU3PasseSideMAXHCONT 001004
   ROD: EV_DCU3PasseSideMAXHCONT_VWE3.rod
524317 - Databus
          [Message ORUG01_01 missing]
                    Fault Frequency: 13
                    Reset counter: 145
                    Mileage: 44 km
                    Date: 2024.12.27
                    Time: 21:38:21
   Part No SW: 10C 035 842     HW: 10C 035 842
   Component: IC3GSF--US    H09 3343
   Dataset Number: V03935389ZP 0001
   Coding: 23166030000000000000000000000000000000000000000000
   ASAM Dataset: EV_MUICASSAFEPart 002001
   ROD: EV_MUICASSAFEPart_002_VWE3.rod
   VCID: 5AE6FB2DBC99E49AA13-800E-R SFD
   Subsystem 1 - Part No SW: 1T3 919 605 D    HW: 1T3 919 605 D
   Component: ABT-E3_13      H43 4043
   Serial number: CKS00711052411550186
Address 69: Trailer (J345)       Labels:| 5H0-907-383.clb
   Part No SW: 5H0 907 383 D    HW: 5H0 907 383
   Component: Anhaenger     H12 0204
   Serial number: 000000000006460 Dataset Number: V03935340SK 0001
   Coding: 0200000200001400
   ASAM Dataset: EV_TrailFunctG3MPFMHella 001009
   ROD: EV_TrailFunctG3MPFMHella_VW27.rod
   VCID: 2F307AF9979BD13226D-807A-R SFD
Address 6C: Back-up Cam. (J772)       Labels:* None
   Part No SW: 1EA 980 556 G    HW: 5WA 980 556 C
   Component: RV eCompact   H52 0464
   Serial number: FCLK20280724010 Dataset Number: V03935414CP 0001
   Coding: 0202C40027140000
   ASAM Dataset: EV_CamSysRVCeCFicosUNECE 003007
   ROD: EV_CamSysRVCeCFicosUNECE.rod
282656 - Cable for Video Signal to Display
          C135B 01 [00100000] - Electrical Failure
          [Video link to display unit - connection error]
13705738 - Databus
          [Value range-monitoring of PaCo_01.PaCo_VPS_TargetCarOverlay]
                    Reset counter: 24
                    Mileage: 4634 km
                    Date: 2025.03.25
                    Time: 01:43:16
   Part No SW: 4KE 959 107 B    HW: 4KE 959 107 B
   Component: HDSG-Modul    H08 0342
   Revision: --------    Serial number: A2-C765-4921-9 Dataset Number: V03935411PE 0001
   Coding: 5088
   ASAM Dataset: EV_DeckLidCONTIAU536 001006
   ROD: EV_DeckLidCONTIAU536_001_VWE3.rod
   VCID: 45DC385125277B62FC1-8010-R
   Part No SW: 14A 035 285     HW: 14A 035 285
   Component: OCU4MEB_UNECE H11 0288
   Serial number: 0000000407VICLH Dataset Number: V03935417TC 0001
   Coding: 02020700020000000000010013000000101112111012000010
   ASAM Dataset: EV_OCUGen4UNECE 001045
   ROD: EV_OCUGen4UNECE_VWE3.rod
   VCID: 5DECF031ADB713A2C41-8008-R SFD
Address 7E: Ctrl Head Dash (J1254)       Labels:| 10A-920-320.clb
   Part No SW: 10A 920 320 D    HW: 10A 920 320 D
   Component: FAHRERDISPLAY 031 0650
   Serial number: 4H1X8010-165574
   Coding: 2E7301
   ASAM Dataset: EV_DashBoardLGMEB 002032
   ROD: EV_DashBoardLGMEB_002_VWE3.rod
   VCID: 167EAF1D080100FA45B-8042-R SFD
Address 8C: HV Battery (J840)       Labels: 0Z1-915-184.clb
   Part No SW: 0Z1 915 184 AG    HW: 0Z1 915 184 D
   Component: J840 K8C  BMC 010 1122
   Serial number: 000000170224010 Dataset Number: V03935423SF 0001 CVN: BED4975200000000000000000000000000000000
   ASAM Dataset: EV_BMCeVWBSMEB 003016
   ROD: EV_BMCeVWBSMEB_003_VWE3.rod
   VCID: 7F506AB9077BE1B2F6D-802A-R
   Cell module control module 1:
   Subsystem 1 - Part No SW: 0Z1 915 140 K    HW: 0Z1 915 140 D
   Component: SX6  X74  CMC  005 1112
   Serial number: 00000009072401020644
   Cell module control module 5:
   Subsystem 2 - Part No SW: 0Z1 915 140 K    HW: 0Z1 915 140 D
   Serial number: 00000009072401010535
   Cell module control module 9:
   Subsystem 3 - Part No SW: 0Z1 915 140 K    HW: 0Z1 915 140 D
   Serial number: 00000009072401020442
   Coolant heating:
   Subsystem 4 - Part No SW: 1EE 963 231     HW: 1EE 963 231
   Component: J848 HV-PTC    H04 0020
   Serial number: 1EE9632312415000606
Address A5: Frt Sens. Drv. Assist (R242)       Labels:* 1EA-980-65X-V2.clb
   Part No SW: 1EA 980 653 B    HW: 1EA 980 653 A
   Component: MEB MFK 4.1   H08 5510
   Dataset Number: V03935428AH 0001
   Coding: 000B306E1FC500F83F24301C4000000000000000000000000000000000000000
   ASAM Dataset: EV_MFK41ValeoMEB 001077
   ROD: EV_MFK41ValeoMEB_VWE3.rod
   VCID: 382241A562D5168A777-806C-R SFD
7 Faults Found:
1124497 - Databus
          [ACC_18_ACC_Status_ACC_irreversibel_ERROR]
1124496 - Databus
          U1123 00 [00101000] - Received Error Message
          [ACC_18_ACC_Status_ACC_reversibel_ERROR]
                    Reset counter: 9
                    Mileage: 2463 km
                    Date: 2025.02.09
                    Time: 22:50:00
1126416 - Development code 1
          B2F01 00 [01100000] - -
          [TPA_Error]
1126421 - Databus
          [FAS_Anzeigen_01_KBI_Anzeigefehler_LDW_Anzeigefehler_ERROR]
                    Reset counter: 3
                    Mileage: 3475 km
                    Date: 2025.03.01
                    Time: 22:36:11
1124659 - Databus
          U1121 00 [00101000] - Missing Message
          [POS_GNSS_05_Position_TIMEOUT]
                    Fault Frequency: 45
                    Reset counter: 36
                    Mileage: 83 km
                    Date: 2024.12.29
                    Time: 01:21:57
1126434 - Module for Camera
          C110A F7 [00100000] - Lane Detection View Restricted
          [Temporary_blindness_of_lane_detection]
1126504 - Databus
          [RDR1_Header_Eth_RDR1_relevante_Nichtverfuegbarkeit_ERROR]
                    Reset counter: 9
                    Mileage: 2463 km
                    Date: 2025.02.09
                    Time: 22:50:00
   Part No SW: 1EA 959 597 C    HW: 1EA 959 597 C
   Component: TSG HFS       007 0561
   Serial number: 0000527541470  Dataset Number: V03935411PV 0001
   Coding: 0001D12001000480E2008000
   ASAM Dataset: EV_DCU3RearDriveMAXHCONT 001004
   ROD: EV_DCU3RearDriveMAXHCONT_VWE3.rod
   VCID: 46DE3F5D1821707AF5B-8012-R
524317 - Databus
                    Reset counter: 143
                    Mileage: 1964 km
                    Date: 2025.02.07
                    Time: 19:24:15
524318 - Databus
          U1122 00 [00001000] - Implausible Message
          [Message ORUG01_01 implausible message: counter]
                    Reset counter: 122
                    Mileage: 463 km
                    Date: 2025.01.05
                    Time: 19:59:49
   Part No SW: 1EA 959 596 C    HW: 1EA 959 596 C
   Component: TSG HBFS      007 0561
   Serial number: 0000528369571  Dataset Number: V03935411PT 0001
   Coding: 0001D12000000480E2008000
   ASAM Dataset: EV_DCU3RearPasseMAXHCONT 001004
   ROD: EV_DCU3RearPasseMAXHCONT_VWE3.rod
524318 - Databus
                    Reset counter: 132
                    Mileage: 3989 km
                    Date: 2025.03.15
                    Time: 21:20:39
Address C0: Act. for Ext. Noise (J943)       Labels: 1EA-035-335.clb
   Part No SW: 11K 035 335 D    HW: 1EA 035 335
   Component: E_SOUND_SG    H06 0012
   Serial number: JTK072100524319
   ASAM Dataset: EV_ESounHarmaMEBUNECE 001006
   ROD: EV_ESounHarmaMEBUNECE_VWE3.rod
   VCID: 241A85D5CE5D626ACBF-8070-R
Address C6: Batt. Chrg. (J1050)       Labels:| 1EA-915-692.clb
   Part No SW: 1EK 915 692 H    HW: 1EK 915 692 H
   Component: OCDC Gen4+    H03 5206
   Revision: 00H03000
   Coding: 308010
   ASAM Dataset: EV_OCDCXPHASERB8MEBB 001017
   ROD: EV_OCDCXPHASERB8MEBB_001_VWE3.rod
   VCID: 49C43461093F9F02189-801C-R SFD
13 Faults Found:
135175 - HV Battery Charge Management
          U1148 00 [00100000] - No Communications
          [HVLM_13_TimeOut]
135177 - HV Battery Charge Management
          [HVLM_GBT_01_TimeOut]
151563 - HV Battery Charge Management
          [HVLM_PLC_01_TimeOut]
151564 - HV Battery Charge Management
          [HVLM_PLC_02_TimeOut]
135181 - Diagnostic Interface for Data Bus
          U17C0 00 [00100000] - No Communication
          [ORUG01_01_TimeOut]
                    Reset counter: 36
                    Mileage: 4 km
                    Date: 2000.01.13
                    Time: 09:38:21
397331 - Battery Charger; Charging Module 1
          P1D6E 00 [10101110] - Malfunction
          [AC_voltage_sensor_L1_SCG]
                    Mileage: 37 km
                    Date: 2024.12.24
                    Time: 16:22:32
397343 - Intermediate Circuit Voltage Sensor
          B193D 21 [10101110] - Signal Amplitude Too Low
          [DC_link_voltage_sensor_ORL]
                    Mileage: 37 km
                    Date: 2024.12.24
                    Time: 16:22:32
405557 - Control Circuit for Battery Charger Coupling Locking
          P0D94 00 [00100000] - Malfunction
          [plug_interlock_unlock_without_command]
3401785 - Charging Socket A; Charging Plug Lock
          P33E8 00 [00100000] - Mechanical Malfunction
          [plug_interlock_stiffness_detection]
405522 - Charging Socket 1; Plug Connector Lock
          P1CF4 00 [00100000] - Blocked
          [Plug_locking_blocked_open]
851969 - Communication Authentication
          U3035 00 [00101110] - Invalid Signal
                    Fault Frequency: 55
                    Mileage: 16 km
                    Date: 2024.10.12
                    Time: 07:16:54
397376 - Intermediate Circuit Voltage Warning
          P195C 00 [00100000] - -
          [Monitoring_HV_dcdc_suspected_overcurrent]
401459 - LV Energy Management
          B1802 F1 [00100000] - Warning Triggered
          [Monitoring_hv_dcdc_suspected_negative_over_current]
Address CE: Drive Motor 2 (J841)       Labels: 1EA-907-121.clb
   Part No SW: 1EA 907 121 BF    HW: 1EA 907 230 G
   Component: MEB INV4.1    H09 8122
   Serial number: VES/S4003359710
   ASAM Dataset: EV_DMCM08000F11EA907121BF 001022
   ROD: EV_DMCM08000F11EA907121AM.rod
   VCID: 73B8B6893B33B5D2825-8026-R SFD
41735 - Databus
          [Databus error value received]
                    Reset counter: 33
                    Mileage: 3269 km
                    Date: 2025.02.26
                    Time: 21:21:53
                    Inverter_operating_state: FREEWHEEL_MODE
                    Actual_mechanical_torque_calculated: -0.001 Nm
                    Actual_mechanical_torque_commanded_value: 0.000
                    Temperature_IGBT_phase_U: 8.295  C
                    Temperature_IGBT_phase_V: 7.689  C
                    Temperature_IGBT_phase_W: 9.015  C
                    CAN_operation_mode_HV_battery_module_control: Fahren_HV_aktiv
                    Voltage_Terminal_15: 13.289 V
                    DC_link_voltage: 378.440 V
                    Freewheel_active: Fehler__EM_im_Freilauf
                    Actual_possible_maximum_torque: 135.000 Nm
                    Actual_possible_minimum_torque: -135.000 Nm
                    Absolut_value_RPM_e_machine: -0.030 /min
                    Inverter_damping_control_gear_ratio: 11.344
                    Inverter_damping_control_tooth_number: 43
                    Expected_model_type: 0
                    Inverter_sbc_unexpected_reset_counter: 0
                    Inverter_smu_unexpected_reset_counter: 0
                    Inverter_trapcore_0_unexpected_reset_counter: 0
                    Inverter_trapcore_1_unexpected_reset_counter: 0
                    Inverter_trapcore_2_unexpected_reset_counter: 0
                    Inverter_alvcntrcore_0_unexpected_reset_counter: 0
                    Inverter_alvcntrcore_1_unexpected_reset_counter: 0
                    Inverter_alvcntrcore_2_unexpected_reset_counter: 0
                    Inverter_safetLib_unexpected_reset_counter: 0
                    Inverter_initcore_1_unexpected_reset_counter: 0
                    Inverter_sbcerrcfg_unexpected_reset_counter: 0
                    Inverter_Kl30_unexpected_reset_counter: 0
                    Inverter_seriesswtover_unexpected_reset_counter: 0
                    Inverter_hsmerr_unexpected_reset_counter: 0
42815 - Secure Onboard Communication
          U14FE 00 [00100000] - Signature Verification Failed
          [Secure Onboard Communication Signature inspection failed]
                    Reset counter: 33
                    Mileage: 3427 km
                    Date: 2025.03.01
                    Time: 17:55:48
43400 - Online Remote Update
          [Online Remote Update No signal]
                    Mileage: 37 km
                    Date: 2024.12.24
                    Time: 16:24:04
                    Inverter_operating_state: NACHLAUF_MODE
                    Actual_mechanical_torque_calculated: 0.000 Nm
                    Temperature_IGBT_phase_U: 3.655  C
                    Temperature_IGBT_phase_V: 2.941  C
                    Temperature_IGBT_phase_W: 4.160  C
                    Voltage_Terminal_15: 0.021 V
                    DC_link_voltage: 376.252 V
                    Freewheel_active: Init
                    Actual_possible_maximum_torque: 0.000 Nm
                    Actual_possible_minimum_torque: -0.000 Nm
                    Absolut_value_RPM_e_machine: 0.007 /min
   Part No SW: 992 941 572 AG    HW: 992 941 572 A
   Component: LED1L         H17 9104
   ASAM Dataset: EV_LLPGen3LKEBODPO68X 002003
   ROD: EV_LLPGen3LKEBODPO68X_002_VW27.rod
   VCID: 6882D1E572F5460A277-803C-R
131329 - Databus
          U1201 00 [00100000] - No Communications
          [can data bus - no communication]
131332 - Databus
          [can message LED_Soll_Fkt2 missing]
131347 - Databus
          [CAN message ESP_21 missing]
131353 - Databus
          [CAN message Klemmen_Status_01 missing]
   Component: LED1R         H17 9104
   ASAM Dataset: EV_LLPGen3RKEBODPO68X 002003
   ROD: EV_LLPGen3RKEBODPO68X_002_VW27.rod
131329 - Databus
131332 - Databus
131347 - Databus
131353 - Databus
Address 8116: Snd enhanct 2 (J943)       Labels: 1EA-035-335.clb
   Part No SW: 11K 035 335 E    HW: 1EA 035 335
   Component: E_SOUND_SG    H06 0010
   Serial number: JTK072090524953
   ASAM Dataset: EV_ESoun2HarmaMEBUNECE 001003
   ROD: EV_ESoun2HarmaMEBUNECE.rod
   VCID: 251C98D1C5679B62DC1-8070-R
Address 8123: App server 1 system 1 adaptive (SWC4)       Labels: V04-007-XXX-SWC4.clb
   Part No: V04 007 000 SS
   Component: ICAS1 Sys_Ada 0411
   Dataset Number: V03935410G  0001
   ASAM Dataset: EV_AppServ1Sys1ICAS1UNECE 001003
   ROD: EV_AppServ1Sys1ICAS1UNECE_VWE3.rod
   VCID: 0740F2595FABA972CED-8052-R SFD
8638721 - Databus
          U1121 00 [00101110] - Missing Message
          [POS_Input_GNSS]
                    Fault Frequency: 131
                    Mileage: 4501 km
                    Date: 2025.03.23
                    Time: 16:17:52
8638723 - Databus
          [POS_Output_MapMatched]
                    Mileage: 4501 km
                    Date: 2025.03.23
                    Time: 16:17:51
8638724 - Databus
          [POS_Output_DeadReckoning]
                    Mileage: 4501 km
                    Date: 2025.03.23
                    Time: 16:17:52
Address 8124: App server 1 system 2 Java (SWC5)       Labels: V04-007-XXX-SWC5.clb
   Part No: V04 007 000 ST
   Component: ICAS1 Sys_Jav 0411
   ASAM Dataset: EV_AppServ1Sys2ICAS1UNECE 001005
   ROD: EV_AppServ1Sys2ICAS1UNECE_VWE3.rod
Address 8125: App server 3 system 1 infotaint. (SWC6)       Labels:| V04-007-XXX-SWC6.clb
   Part No: V04 007 003 D
   Component: IC3GIVI-S--US 3343
   Dataset Number: V03935407ZB 0001
   ASAM Dataset: EV_MUICASIVIPart 003001
   ROD: EV_MUICASIVIPart_003_VWE3.rod
   VCID: 280291E5B275860AE77-807C-R SFD
0021 - Functional Limitation due to Energy Management
          B10CD 00 [00001000] - -
          [Function restriction via shutoff stage Q2]
                    Fault Priority: 9
                    Fault Frequency: 208
                    Mileage: 37 km
                    Date: 2024.12.27
                    Time: 13:09:16
                    Voltage terminal 30: 11.7 V
1872 - Automotive Audio Bus (A2B)
          B1994 F4 [00001000] - Microphone Module Defective
          [a2b_bus_micro_defect]
                    Reset counter: 27
                    Mileage: 4146 km
                    Date: 2025.03.18
                    Time: 23:37:03
                    Voltage terminal 30: 15.0 V
                    amount_of_nodes: 3
                    Node number: 1
                    Node name: External sound amplifier
                    Node status: OK
7170 - Function Restricted due to Interrupted Communications
          U1110 00 [00001000] - -
          [A/C system (0x02) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 19
                    Mileage: 3766 km
                    Date: 2025.03.11
                    Time: 17:21:43
                    BAP: 00
                    Voltage terminal 30: 14.0 V
6914 - Function Restricted due to Interrupted Communications
          [A/C system (0x02) - function restriction due to communication error - BapErr_timeout: heartbeat]
                    Reset counter: 19
                    Mileage: 3766 km
                    Date: 2025.03.11
                    Time: 17:21:40
                    Voltage terminal 30: 13.8 V
Address 8128: Light line display (J145)       Labels: 10B-919-451.clb
   Part No SW: 11B 919 451 C    HW: 11B 919 451 C
   Component: Lichtlinie1   004 0107
   ASAM Dataset: EV_SmartLight1MEB 002001
   ROD: EV_SmartLight1MEB.rod
Address C002: SW Cluster Embedded (SWC2)       Labels: V04-007-XXX-SWC2.clb
   Part No: V04 007 000 TA
   Component: ICAS1 SWCL_Em 0411
   Dataset Number: V03935415DY 0001
   ASAM Dataset: EV_SWCLEmbed1ICAS1UNECE 001008
   ROD: EV_SWCLEmbed1ICAS1UNECE_VWE3.rod
   VCID: 76BE8F9D2841A0FAA5B-8022-R SFD
13706049 - Databus
          [WLA_Blindheit received error value]
0268 - Software Cluster Embedded 1
          U1775 00 [01100101] - Software Error Detected
          [R7_Illegal_memory_access]
                    Date: 2025.01.12
8491267 - Secure Onboard Communication
          U14FF 00 [01101101] - Signature Generation Failed
          [SOK_signature_creation_failed]
                    Mileage: 1084 km
                    Date: 2025.01.20
                    Time: 02:58:59
8516625 - Expanded Charging Functions
          U15E9 00 [01101100] - Charging Plan Programming Error
                    Fault Frequency: 178
                    Mileage: 4655 km
                    Date: 2025.03.25
                    Time: 02:02:51
8516632 - Expanded Charging Functions
          U15EB 00 [01101100] - Battery Management Counter Error
                    Fault Frequency: 75
                    Mileage: 4655 km
                    Date: 2025.03.25
                    Time: 03:07:32
Address C003: SW Cluster Housekeeping (SWC3)       Labels: V04-007-XXX-SWC3.clb
   Part No: V04 007 000 TB
   Component: ICAS1 SWCL_HK 0411
   ASAM Dataset: EV_SWCLHouse1ICAS1UNECE 001007
   ROD: EV_SWCLHouse1ICAS1UNECE.rod
   VCID: 77A082992F4BD9F2BED-8022-R SFD
End----------(Elapsed Time: 03:07, VBatt start/end: 15.0V/15.1V)-----------
-----------------------------104 Faults Found------------------------------
The original text is, "(Sub) function cannot be performed", but many moons ago, I decided to have some fun with that one. :cool:
Those cars are always chock-a-block full of DTCs. I doubt you'll ever see a clean scan from one.
But it could be worse. You could have a PPE or B10 chassis car:
And here we see why the 12V batteries in them fail so regularly. I'm not sure what VW was thinking when they programmed these cars to "charge" the 12V battery at ~15V most of the time. :rolleyes:
WestyRID4
C?ID=35758
yep that value got my attention. I would have expected a max of 14.7. Wonder if I could add a regulator to beam it down. In any case, We have the dc-dc converter recall to deal with. BTW I have been using vcds to stay ahead of troubles on my fleet of VW for years ( kids cars + ours) . Thanks for all the work !.
What's absurd is that this has been going on since the introduction of the MEB chassis. You'd think they'd have figured it out after one or two model years, no?
And let's not forget that the voltage shown by VCDS is measured at the data port. There's always some voltage drop between the battery and there, so the actual battery voltage is somewhat higher.
WestyRID4
C?ID=35758
It will be interesting to see what the replacement Dc-dc is pushing out for charge voltage. if it's lower, then the recall based on condensation on the board is just a smoke screen.
