Coding question - SEAT Leon 5F power fold mirror retrofit
mikeholroyd
C?ID=98585
Quick question on coding please
I recently fully retrofitted power fold mirrors to my 2019 Leon ST with power mirrors and door controllers sourced from the same 2019 donor vehicle.
Everything works absolutely fine, with the mirrors folding and unfolding without issue on both the mirror control switch and when locking/unlocking the car with the keyfob.
However, a recurrent fault keeps cropping up on VCDS - Drivers door module 42, 196726 Motor for mirror fold in - open circuit - intermittent
If the mirrors are folded with the switch and a new autoscan is done, no fault is thrown up, but it's when the mirrors are UNFOLDED with either the switch or by unlocking the car that the fault shows immediately and every time. All wiring has been checked and re-checked.
I've searched and searched on VAG forums and on Ross Tech's website, and can't find much anything other than it seems many folk having done this retrofit find the same issue on VCDS autoscans.
Screenshot of the fault attached
As said, everything is working fine, but my OCD is in overdrive! Really want to resolve this if I can.
Many thanks
Sunday,30,March,2025,17:00:58:51012
VCDS Version: 25.3.0.4 (x64)  HEX-V2 CB: 0.4660.4
Data version: 20250311 DS365.0
Dealer/Shop Name: Brookdale
VIN: VSSZZZ5FZKR******  License Plate: *****
Mileage: 51602km-32063mi   Repair Order:
Chassis Type: 5F-SE37 (3Q0)
Scan: 01 02 03 08 09 10 13 15 17 19 42 44 52 5F 6C BB BC
VIN: VSSZZZ5FZKR******  Mileage: 51602km-32063miles
Address 01: Engine (J623-DFGA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 NF    HW: 04L 907 309 P
   Component: R4 2.0l TDI   H25 6380
   Revision: B4H25---    CVN: EC4069A55D3F3C3E5D3F3C3E
   Coding: 01250812032401082000
   Shop #: WSC 00049 770 00180
   ASAM Dataset: EV_ECM20TDI01104L906026NF 004007
   ROD: EV_ECM20TDI01104L906026NF.rod
   VCID: 7BA3E5CEC3691492DA5-802E
   VINID: 9A38EAAAA156A9B8802440800018450D8B
   Part No SW: 0GC 300 044 E    HW: 0GC 927 711 H
   Component: GSG DQ381     H06 2403
   Revision: 00H06V08    CVN: 27291857
   ROD: EV_TCMDQ381061.rod
   VCID: 2A0D108A7C735D1AF13-807E
   No subsystems:
   Part No SW: 5Q0 614 517 EH    HW: 5Q0 614 517 BR
   Component: ESC           H82 0107
   Revision: 00000000    Serial number: 60789000001274
   Coding: 19EE8A92202909708779060060C32498510490E1600624733062F074D2024B0B0000000012121212B835351919323200
   Shop #: WSC 00049 770 00203
   ROD: EV_Brake1UDSContiMK100IPB_038.rod
   Part No SW: 5F0 907 426 AB    HW: 5F0 907 426 AB
   Component: AC Manuell    H03 1601
   Revision: 00001K09
   Coding: 02100104200110001000000000001000
   ASAM Dataset: EV_ACManueBHBVW37X 004132
   ROD: EV_ACManueBHBVW37X_004_VW37.rod
   VCID: 6A8DD08ABCF39D1A313-803E
   Part No SW: 5Q0 937 084 DB    HW: 5Q0 937 084 CE
   Component: BCM MQBAB M   H38 0273
   Serial number: 00001908000257 Dataset Number: V03935293LQ 0001
   Coding: 000000000080000000000000000000000008000000000000000000000000
   ROD: EV_BCMBOSCH_019_VW37.rod
   Subsystem 1 - Part No SW: 5F2 955 119 A    HW: 5F2 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS370 190207  041 0574
   Serial number:         190220045657
   Coding: 0BC5DD
   Subsystem 2 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Serial number: 000000000ZY183065DRU
   Subsystem 3 - Part No SW: 5Q0 951 605 B    HW: 5Q0 951 605 B
   Component: Sirene, DWA  004 0007
   Serial number: 00000000000000367927
   Steering Column Switch:
   Subsystem 4 - Part No SW: 5Q1 953 507 B    HW: 5Q1 953 549
   Component: J527 SMLS MQB  004 0060
   Serial number: 00000024031904221682
   Part No SW: 5QA 919 294 C    HW: 5QA 919 294
   Component: PDC 8 KanalH07 0050
   Serial number: 000308418019077 Dataset Number: V03935268GT 0002
   Coding: 0471151011
   Shop #: WSC 12345 123 61029
   ASAM Dataset: EV_EPHVA18AU3700000 009039
   VCID: 4CC17612D647632A23F-8018
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-572-V2.clb
   Part No SW: 5Q0 907 572 P    HW: 5Q0 907 572 J
   Dataset Number: V03935269FJ 0001
   Coding: 3505000151FF8428949C814500300400000000000000000000
   VCID: 44D15E32FE17AB6AEBF-8010
   Part No SW: 3Q0 959 655 CM    HW: 3Q0 959 655 CM
   Component: Airbag VW21   006 0720
   Revision: --------    Serial number: 003Z2P4MH6L6 Dataset Number: V03935263XZ 0001
   Coding: 98CCC000000000005C0000CC008800000065
   VCID: 0B43B50E93C92412EA5-805E
   Subsystem 1 - Part No SW: -----------    HW: 454 000 903 19
   Serial number: 357000000009F5804A3Q
   Subsystem 2 - Part No SW: -----------    HW: 454 001 003 19
   Serial number: 358000000004D669E93.
   Subsystem 3 - Part No SW: -----------    HW: 454 802 503 19
   Serial number: 3510010238718000000$
   Subsystem 4 - Part No SW: -----------    HW: 454 802 303 19
   Serial number: 35200EFD18318000000U
   Subsystem 5 - Part No SW: -----------    HW: 454 800 203 19
   Serial number: 355006FF06017000000K
   Part No SW: 5F0 920 951 F    HW: 5F0 920 951 F
   Component: KOMBI         312 2720
   Coding: 27A512082380060001887A011001000080000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009069
   VCID: 2B03158E738944120A5-807E
   Serial number: 26031910804385 Dataset Number: V03935279TD 0003
   Coding: 030100F40F086A00EA000040140F00010001070000000000000000000000
   GVL: 01443C0000000000400C80000002C80000000000000000000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 6E85DC9A801B713A6DB-803A
   Generator:
   Component: 0-01-13-01-04
   Subsystem 2 - Part No SW: 5F0 959 537 E    HW: 5F0 959 537 E
   Serial number: 000000000H2255090319
   Coding: 002000
   Serial number: 75886003001902221C69
   Part No SW: 5Q4 959 593 K    HW: 5Q4 959 593 K
   Component: TSG FS        007 0485
   Serial number: 0000403198134  Dataset Number: V03935298XN 0001
   Coding: 001402205001020000001000
   VCID: 4DC77B162D5D6A22341-8018
   Subsystem 1 - Part No SW: 5Q0 959 812 E    HW: 5Q0 959 812 E  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000028542997
   Coding: 2D0000
196726 - Motor for mirror fold-in
          B11F6 13 [00001000] - Open Circuit
                    Reset counter: 210
                    Mileage: 51564 km
                    Date: 2025.03.30
                    Time: 13:20:25
   Part No SW: 5Q0 909 144 AB    HW: 5Q0 909 144 AA
   Component: EPS_MQB_ZFLS  131 1082
   Dataset Number: V03935283CZ 0001
   Coding: 01170000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 74B1CEF2EE375BEA9BF-8020
   Part No SW: 5Q4 959 592 K    HW: 5Q4 959 592 K
   Component: TSG BFS       007 0485
   Serial number: 0000403374606  Dataset Number: V03935298XQ 0001
   Coding: 001400205E01020000001000
   Subsystem 1 - Part No SW: 5Q0 959 811 E    HW: 5Q0 959 811 E  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000028575652
   Coding: 350000
Address 5F: Information Electr. (J794)       Labels:| 5F0-035-MIB-STD2.clb
   Part No SW: 5F0 035 877 A    HW: 5F0 035 877 A
   Component: MU-S-ND-ER    H50 0514
   Serial number: SEZAZ2W0303661 Dataset Number: V03935289FR 0001
   Coding: 04738201D70A000011110101008808002F0200C601200500CE
   ASAM Dataset: EV_MUStd6C1TSAT 001015
   ROD: EV_MUStd6C1TSAT_SE37.rod
   Subsystem 1 - Part No SW: 5F0 919 606     HW: 5F0 919 606
   Component: ABTm-2_8-CR  H41 1042
   Serial number: SEZ8Z9W6C06TMV
   Subsystem 2 - Part No SW: V03 959 821 PF    HW: -----------
   Component: ECE DL2 2025  --- 2310
   Part No SW: 5Q0 980 556 B    HW: 4M0 980 556 A
   Dataset Number: 3VD525D____ 0003
   Coding: 04840101A600201F000040
   VCID: 392F3FC689D5E682889-806C
End----------(Elapsed Time: 01:17, VBatt start/end: 12.3V/12.3V)-----------
------------------------------1 Fault Found-------------------------------
JeniCzech92
Prague, Czech Republic
C?ID=594546
Intermittent errors like this one (or short to ground) are caused by either motor being stuck, or a poor connection somewhere. the door control unit measures the motor during its operation, if the current going through is out of range in either direction, it will throw. Chances are the motors from donor have their best years already passed. If everything works, I'd suggest you live with it as it is until it stops working. Most of the parts such as this one are waterproofed and sealed shut, with no way to disassemble - spraying WD40 all over it often don't have any effect and attempts to disassemble and get the grease where it needs to be often ends up with an order of a new part :)
I've tried lubing seizing locks many times for many folks, ultimately the new locks were ordered anyway within a month or two.
downtime
Finland
C?ID=280813
Also the switch might be faulty
