- Jul 26, 2024
- 186
- 18
- Fresno, CA, USA
- C?ID=566690
How would I confirm if it corresponds to the PODS?And does this coding correspond to the PODS system?
If you want to use VCDS to build a new module 15 coding, does VDS offer you certain options? And if so, is there something like "seat occupancy monitor" among these options?How would I confirm if it corresponds to the PODS?
Is this before replacing the module 15 unit?Here is the first auto scan from February. J706 was already a problem albeit I see it said intermittent and now it doesn't say intermittent. At the time, I assumed that J706 error was due to the J234 being defective.
It's possible I missed a step. I remember replacing a J234 last year and I had to program it to the car. I will look into it.If you want to use VCDS to build a new module 15 coding, does VDS offer you certain options? And if so, is there something like "seat occupancy monitor" among these options?
These Airbag modules do not work that way. They use "Index Coding", were there is exactly one coding that matches their Index, which is determined by a factory-installed dataset. They will only accept the coding that's correct for the index/dataset.If you want to use VCDS to build a new module 15 coding, does VDS offer you certain options? And if so, is there something like "seat occupancy monitor" among these options?
The scan you took during the second repair (but it lacks coding). The question is whether it means anything.Address 15: Airbags Labels: 1T0-909-605.lbl Part No: 6Q0 909 605 AF Component: 01 AIRBAG VW71 0609 Coding: 0012337 Shop #: WSC 00066 000 00000 VCID: 7BA3E7C5CFF4BE020A9-513C
Unfortunately, the diagram for your convertible that I have does not use pin number 33 on the J234 unit. But pin 47 is used. I am sure that there must be a voltage on this pin that is equal to the battery voltage. If in your case there is a difference in the battery voltage and T10r\8, then for the purpose of investigation I would bring the battery voltage to pin T10r\8 and see if VCDS no longer records an error. If you do not notice a change, then the defect is probably in the J706 unit itself (even if it is changed from another used donor part). I assume that T10r\1,2 and 9 are properly grounded. If you would like to send the wiring diagram that I have for your car, send an Email. I have them in PDF format. But I am sure that your diagram from Erwin corresponds to the reality on your real car.Address 15: Airbags Labels: 1T0-909-605.lbl Part No: 6Q0 909 605 AF Component: 01 AIRBAG VW71 0609 Shop #: WSC 00066 000 00000 VCID: 7BA3E7C5CFF4BE02DA5-5160
This information is not true. In the case of PODS for the USA, many things are really different. Therefore, here is information on the assembly of PODS parts:I have a feeling that there is no space for basic settings in module 15. The shortcut is not the reason.
No worries, I will retest the wiring and the voltage on the lead T10r/8 as you suggested. I have another one I am picking up today, a 2006 convertible beetle, so I may not have time until tomorrow to retest. My wife also owns a convertible beetle 2008 but she won't like me using it for comparative testing.Uwe's post explained the functionality of the US version well enough for me. You won't find it in European cars. So I apologize for my insufficient knowledge.
scan you took before the first repair:
Please post these scans. Perhaps from these scans it will be possible to identify the reason why it is not possible to do the basic settings on the 2005.I have the initial scans for both beetles.
Hi there. Here are the original scans from both vehicles. When I transferred the seat from the 2006 to the 2005, I get the same error J706 no signal. When i return the donor seat back to the 2006, I have to clear the code, cycle the ignition and it accepts the seat no problem. Like I said before, I have swapped seats over the last two years to replace worn out seats that I have never had this problem until now. I have checked the wiring for continuity between the Airbag modul and the J706.Please post these scans. Perhaps from these scans it will be possible to identify the reason why it is not possible to do the basic settings on the 2005.
But if the 2006 unit can do the basic settings, then with what result? And please answer what is the status when you return the 2006 seat to the 2006. Can we say that after returning this unit back to the donor, it is accepted without problems and without storing an error? Or can the recording of the faults be deleted?
Kind regards
Wednesday,12,February,2025,12:37:59:07661
VCDS Version: 24.7.1.0 (x64) HEX-V2 CB: 0.4643.4
VIN: 3VWCD31Y85M316819 License Plate: 2005 BEIGE
Mileage: 117800km-73197mi Repair Order:
Chassis Type: 1Y (1Y - VW New Beetle Cab (2003 > 2010))
Scan: 01 02 03 08 15 17 19 25 26 29 35 37 39 46 54 56 65 75
VIN: 3VWCD31Y85M316819 Mileage: 117800km-73197miles
Address 01: Engine Labels: 06A-906-032-BKF.lbl
Part No: 06A 906 032 QS
Component: 1.8l 5VT NBC AG6G 6481
Coding: 00004
Shop #: WSC 00066
VCID: 7F5B13D5DEECA222261-5160
3VWCD31Y85M316819 VWZ5Z0D9051151
18693 - Boost Pressure Control Valve (N249)
P2261 - 35-10 - Mechanical Malfunction - Intermittent
16555 - Fuel Trim; Bank 1
P0171 - 35-10 - System Too Lean - Intermittent
16384 - SAE - Reserved by Document ISO/SAE J2012-2018
P0000 - 35-10 - - Intermittent
Readiness: 0110 1101
Part No: 09G 927 750 AN
Component: AQ 250 6F 0609
Coding: 0000008
VCID: 7DA7E9DDD1E0B03234D-5160
01045 - Tiptronic Switch (F189)
Address 03: ABS Brakes Labels: 1C0-907-37x-ESP-F.lbl
Part No: 1C0 907 379 M
Coding: 0019970
VCID: 34310CF9A22AB17A8B3-5160
Part No: 6Q0 909 605 AL
Component: 01 AIRBAG VW71 0811
Coding: 0012337
Shop #: WSC 26118 444 84949
VCID: 015F952DAD18D4D2505-5160
Subsystem 1 - Part No: 1C0 959 339 G
Component: BF-Gewichtsens. 007 0009
02511 - Control Module for Seat Occupied Recognition (J706)
014 - Defective
Address 17: Instruments Labels: 1C0-920-x4x.lbl
Part No: 1C0 920 951 N
Component: KOMBI+WEGFAHRS. M73 V02
Coding: 11234
VCID: 2C0114997F1AE9BAD33-4B1E
Address 19: CAN Gateway Labels: 6N0-909-901-19.clb
Part No: 6N0 909 901
Component: Gateway K<->CAN V022
Coding: 00006
Shop #: WSC 00066
VCID: 70B9C0E993B2CD5AAFB-4B1E
Address 26: Auto Roof Labels: 1Y0-959-255-HYD.lbl
Part No: 1Y0 959 255
Component: VSG NBC
VCID: 7DA7E9DDD1E0B03234D-513C
02000 - Switch Position
Part No: 1C0 959 799 G
Component: 6J Komfortger t HLO 0004
Coding: 00256
Shop #: WSC 00066
VCID: 3B2327C58A747E024A9-4B00
Subsystem 1 - Part No: 1Y1959801C
Component: 6J T rsteuer.FS KLO 0005
Subsystem 2 - Part No: 1Y1959802D
Component: 6J T rsteuer.BF KLO 0005
Subsystem 3 - Part No: 1Y0959811
Component: T rsteuer.HL KLO 0005
Subsystem 4 - Part No: 1Y0959812
Component: 6J T rsteuer.HR KLO 0001
7 Faults Found:
01358 - Internal Central Locking Switch; Driver Side (E150)
27-00 - Implausible Signal
62-00 - No or Incorrect Adjustment
00935 - Electric Window Motor; Rear Right (V27)
62-10 - No or Incorrect Adjustment - Intermittent
37-00 - Faulty
End----------(Elapsed Time: 04:04, VBatt start/end: 13.9V/13.7V)-----------
Address 01: DTCs cleared
Address 02: DTCs cleared
Address 03: DTCs cleared
Address 15: DTCs cleared
Address 17: DTCs cleared
Address 19: DTCs cleared
Address 25: DTCs cleared
Address 26: DTCs cleared
Address 46: DTCs cleared
Tuesday,08,April,2025,18:13:59:07661
VCDS Version: 25.3.0.4 (x64) HEX-V2 CB: 0.4660.4
Data version: 20250311 DS365.0
VIN: 3VWSF31Y96M303780 License Plate: LIGHT BLUE 2006
Mileage: 229990km-142909mi Repair Order:
VIN: 3VWSF31Y96M303780 Mileage: 229990km-142909miles
Address 01: Engine Labels: 06A-906-032-BGP.lbl
Part No SW: 07K 906 032 B HW: Hardware No
Component: NB/C R5 AT G 7615
Revision: -------- Serial number: VWZ5Z0E7248079
Coding: 0000003
VCID: 2809E8896EE2C59AE77-513C
VINID: 0E69E35830692467430031C80042D560E0
005696 - Internal Control Module
P1640 - 008 - EEPROM Error - Intermittent
Temperature: -40.0 C
Absolute Pres.: 0.0 mbar
Voltage: 0.000 V
049489 - No Communications with Airbag Control Module
U0151 - 008 - - Intermittent
Mileage: 229992 km
RPM: 1410 /min
Load: 34.9 %
Temperature: 24.0 C
Temperature: 30.0 C
Absolute Pres.: 1000.0 mbar
Voltage: 11.938 V
049409 - No Communication with Transmission Control Module
U0101 - 008 -
Fault Status: 01101000
Mileage: 229992 km
RPM: 1410 /min
Load: 34.9 %
Temperature: 24.0 C
Temperature: 30.0 C
Voltage: 11.938 V
Part No: 1C0 907 379 Q
Component: ESP FRONT MK60 0101
Coding: 0019978
VCID: 382938C9BE42551A777-5160
Component: 01 AIRBAG VW71 0711
Coding: 0012337
VCID: 015F952DAD18D4D2809-513C
Subsystem 1 - Part No: 1C0 959 339 F
Component: BF-Gewichtsens. 006 0007
02513 - Belt Force Sensor for Seat Occupied Recognition (G453)
01739 - Crash Sensor for Front Airbag; Pass. Side (G284)
Address 17: Instruments Labels: None
Part No: 1C0 920 501 P
Coding: 11234
Shop #: WSC 22539
VCID: 2517E1BD1CF0D8F2DC1-4B00
49-00 - No Communications
Coding: 00006
Shop #: WSC 09149
VCID: 70B9C0E993B2CD5A7F7-4B00
Address 25: Immobilizer Labels: 1C0-920-xxx-25.clb
Part No SW: 1C0 920 501 P HW: 1C0 920 501 P
Component: IMMO X007
Revision: xxxxxxxx Serial number: VWZ5Z0E7248079
Shop #: WSC 41876 001 1048576
VCID: 2517E1BD19F0D8F2DC1-513C
Part No: 1Y0 959 255 C
Component: VSG NBC 3601
VCID: 40D95029E6921DDACF7-513C
00003 - Control Module
014 - Defective
Coding: 00256
Shop #: WSC 00066
VCID: 3B2327C58A747E029A5-4B00
Component: 6J T rsteuer.HL KLO 0005
Component: 6J T rsteuer.HR KLO 0005
01359 - Internal Central Locking Switch; Passenger Side (E198)
End----------(Elapsed Time: 04:03, VBatt start/end: 12.5V/12.5V)-----------
------------------------------17 Faults Found------------------------------
Friday,18,April,2025,16:45:32:07661
VCDS Version: 25.3.1.0 (x64) HEX-V2 CB: 0.4671.4
Data version: 20250408 DS365.0
VIN: 3VWSF31Y96M303780 License Plate: LT BLUE 2006
Coding: 0000003
VCID: 2809E8896EE2C59AE7B-513C
Part No SW: 09G 927 750 CG HW: 09G 927 750 CG
Component: AQ 250 6F 0759
Revision: 00H27000 Serial number:
Coding: 0000008
VCID: 78A9F8C9FEC2951AB7B-513C
Coding: 0019978
VCID: 382938C9BE42551A77B-5160
Coding: 0012337
VCID: 015F952DAD18D4D2805-5160
Coding: 11234
Shop #: WSC 22539
VCID: 2517E1BD1CF0D8F2DCD-4B00
Coding: 00006
Shop #: WSC 09149
VCID: 70B9C0E993B2CD5A7FB-4B00
VCID: 2517E1BD19F0D8F2DCD-513C
VCID: 40D95029E6921DDACFB-513C
Coding: 00256
Shop #: WSC 00066
VCID: 3B2327C58A747E029A9-4B00
End----(Elapsed Time: 04:10, VBatt start/end: 11.9V/11.8V. VIgn 0.1V)------
Please Uwe, or anyone else, is this information about the module index\dataset? (I think 0811)These Airbag modules do not work that way. They use "Index Coding", were there is exactly one coding that matches their Index, which is determined by a factory-installed dataset. They will only accept the coding that's correct for the index/dataset.
Thanks!
2006 Lt blue
Yellow 10v
Brn/blue 11.4v
Battery 12.39v
2005 beige
Yellow 10.5v
Brn/blue 11.5v
Battery 12.47v
