- Jul 26, 2024
- 231
- 20
- Fresno, CA, USA
- C?ID=566690
I'm not sure what you mean by drag testing?
Please consider the information about the connection to J393 as just my guess. Because I simply cannot find the J706 unit in my diagrams. The only thing I can find is that this unit is part of a system called PODS (passive occupant detection system) and that it concerns the passenger seat only. The numbering of your diagrams from Erwin is not the same as the numbering of my diagrams from the Elsa system. In order for me to understand exactly what you are working with, you need to insert a picture. Maybe like the one I sent you.I see on the diagram J393 and how it is interconnected.
This value is strange. What is the battery voltage value at the time of this measurement? (measured with the same multimeter). I think the voltage on BR/BL should be the same as the battery.Brn/Blue 10.6v
This value is still strange. But what is the voltage of the charged battery?Brn/Blue 11.6v
does this mean that your problem occurred after replacing J234?I do remember replacing the J234 because it was defective.
This:What do you mean by see #33?
And does this coding correspond to the PODS system?In module 15, I see soft coding 0012337
Here is the first auto scan from February. J706 was already a problem albeit I see it said intermittent and now it doesn't say intermittent. At the time, I assumed that J706 error was due to the J234 being defective.This:
Sunday,02,February,2025,17:19:38:07661
VCDS Version: 24.7.1.0 (x64) HEX-V2 CB: 0.4643.4
VIN: 3VWCD31Y85M316819 License Plate:
Chassis Type: 1Y (1Y - VW New Beetle Cab (2003 > 2010))
Scan: 01 02 03 08 15 17 19 25 26 29 35 37 39 46 54 56 65 75
VIN: 3VWCD31Y85M316819 Mileage: 117790km-73191miles
Address 01: Engine Labels: 06A-906-032-BKF.lbl
Part No: 06A 906 032 QS
Component: 1.8l 5VT NBC AG6G 6481
Coding: 00004
Shop #: WSC 00066
VCID: 7F5B13D5DEECA222261-513C
3VWCD31Y85M316819 VWZ5Z0D9051151
18693 - Boost Pressure Control Valve (N249)
P2261 - 35-00 - Mechanical Malfunction
18711 - Leak in Air Intake System
P2279 - 35-00 -
Readiness: 0000 1000
Part No: 09G 927 750 AN
Component: AQ 250 6F 0609
Coding: 0000008
VCID: 7DA7E9DDD1E0B03234D-513C
01045 - Tiptronic Switch (F189)
Address 03: ABS Brakes Labels: 1C0-907-37x-ESP-F.lbl
Part No: 1C0 907 379 M
Coding: 0019970
Shop #: WSC 00066 000 00000
VCID: 34310CF9A22AB17A8B3-5160
Address 15: Airbags Labels: 1T0-909-605.lbl
Part No: 6Q0 909 605 AF
Component: 01 AIRBAG VW71 0609
Coding: 0012337
VCID: 7BA3E7C5CFF4BE020A9-513C
Subsystem 1 - Component: BF-Gewichtsens.
02511 - Control Module for Seat Occupied Recognition (J706)
00003 - Control Module
014 - Defective
02513 - Belt Force Sensor for Seat Occupied Recognition (G453)
Address 17: Instruments Labels: 1C0-920-x4x.lbl
Part No: 1C0 920 951 N
Component: KOMBI+WEGFAHRS. M73 V02
Coding: 11234
VCID: 2C0114997F1AE9BAD33-4B00
Address 19: CAN Gateway Labels: 6N0-909-901-19.clb
Part No: 6N0 909 901
Component: Gateway K<->CAN V022
Coding: 00006
Shop #: WSC 00066
VCID: 70B9C0E993B2CD5AAFB-4B00
Address 26: Auto Roof Labels: 1Y0-959-255-HYD.lbl
Part No: 1Y0 959 255
Component: VSG NBC
02000 - Switch Position
Part No: 1C0 959 799 G
Component: 6J Komfortger t HLO 0004
Coding: 00256
Shop #: WSC 00066
VCID: 3B2327C58A747E024A9-4B00
Subsystem 1 - Part No: 1Y1959801C
Component: 6J T rsteuer.FS KLO 0005
Subsystem 2 - Part No: 1Y1959802D
Component: 6J T rsteuer.BF KLO 0005
Subsystem 3 - Part No: 1Y0959811
Component: T rsteuer.HL KLO 0005
Subsystem 4 - Part No: 1Y0959812
Component: T rsteuer.HR KLO 0005
01358 - Internal Central Locking Switch; Driver Side (E150)
00935 - Electric Window Motor; Rear Right (V27)
62-10 - No or Incorrect Adjustment - Intermittent
Address 56: Radio Labels: 1J0-035-18x-56.clb
Part No: 1C0 035 196 M
Component: RADIO DE2 0003
Coding: 06031
Shop #: WSC 00066
VCID: 290FED8D70E8FC92285-51A8
00-10 - - - Intermittent
End----------(Elapsed Time: 03:59, VBatt start/end: 12.3V/12.2V)-----------
