scan not related but just incase asked for Question Below scan
VCDS USE for fuel pressure checks
on some of the VCDS test it shows Fuel pressure 200000 Kpa Rel ? = 2000 Bar what does the rel stand for , is it regulated and is the 200000 figure correct as seems high
or should it be 20000.kpa
I also Noticed when the fuel pressure sensor is disconnected the fuel values change, i have data vag which says
The fuel pressure sender has open loop default run if the sender fails
the engine will still run at a lower Rpm leval Speed
Can anyone confirm this, or once the sensor fails is that it the engine wont run, i have no faults codes, i have checked the 1st two fuel pumps all good,and a good supply of fuel to the main high pressure pump more test tomorrow to confirm pump or injectors, i have checked the regulator, but as i mentioned can someone confirm the fuel pressure sensor whether it has a default for when it fails, as this engine wont Run,
Wednesday,26,March,2025,13:40:40:51242
VCDS Version: 24.7.1.0 (x64) HEX-NET2 CB: 0.4660.5
VIN: WV1ZZZ2KZDX08074 License Plate:
Mileage: 258470km-160605mi Repair Order:
Chassis Type: 2K-VN35 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 37 42 44 46 52 56 61
VIN: WV1ZZZ2KZDX080742 Mileage: 258470km-160605miles
Address 01: Engine (J623-CFHC) Labels:. 03L-906-018-CFF.clb
Part No SW: 03L 906 018 DD HW: 03L 907 309 AE
Component: R4 2.0l TDI H28 9979
Revision: 41H28--- Serial number: 00000000000000 CVN: 74A619D6
Coding: 00190012042501080000
Shop #: WSC 01286 386 08256
ASAM Dataset: EV_ECM20TDI01103L906018DD 003010
ROD: EV_ECM20TDI01103L906018DD.rod
VCID: 6FB0BC5697118ED2B61-803A
VINID: 9E606AAAA09BA94A002001C408422D2B3B
Readiness: 0 0 0 0 X
Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL
Revision: 00H31001
Coding: 433C600D092A03FAC21206E8901BC092310000
Shop #: WSC 35110 377 00146
VCID: 7DAC961ECDFDEC4234D-8028
Part No SW: 7N0 907 426 BN HW: 7N0 907 426 BN
Component: AC Manuell H20 0505
Revision: 00001018
Coding: 0010004003
Shop #: WSC 35110 790 50316
VCID: 0154EAEEB18588A2505-8054
10489856 - No Basic Setting
B2010 00 [00001001] - -
[Grundeinstellung - nicht durchgeführt]
Reset counter: 26
B10AB F0 [00001001] - Too Low
Reset counter: 26
Mileage: 258471 km
Date: 2025.03.26.
Time: 00:24:56
Part No SW: 5K0 937 085 R HW: 5K0 937 085 R
Component: BCM PQ35 B+ 021 0068
Revision: BB021001
Coding: 411A58328025186A08080082900000240301728842028060648087000041
VCID: 42D625E2F48353BA09F-8016
Subsystem 1 - Part No: 1T2 955 119 A Labels: 1KX-955-119.CLB
Component: Wischer 28111 26 0512
Coding: 009795
Reset counter: 26
Mileage: 258471 km
Date: 2019.08.17.
Time: 01:23:04
Voltage: 11.40 V
Address 10: Park/Steer Assist (J446) Labels:| 1Q0-919-475.clb
Part No SW: 2K0 919 475 HW: 1Q0 919 475
Component: PARKHILFE 4K H03 0004
Revision: -------- Serial number: 32961233502889
Coding: 108001
ASAM Dataset: EV_EPHVA14VN3370000 001006
ROD: EV_EPHVA14VN3370000.rod
VCID: 70B2BF2A8A2F912AAFB-8024
Part No SW: 7E0 959 655 B HW: 7E0 959 655 B
Component: VW10Airbag02B H07 0013
Revision: -------- Serial number: 003HL00F7RSW Dataset Number: 2KC003v____ 0260
Coding: 000000000000000000000000000000003242
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 353C4E3EB5CDF402BCD-8060
Part No SW: 1K5 953 507 T HW: 5K0 953 549 B
Revision: -------- Serial number: 90422LAP000AR Dataset Number: 1K5953507T D005
Coding: 0882140000
Shop #: WSC 00040 040 00014
ROD: EV_SMLSNGKUDS_A05.rod
VCID: 42D625E2F40353BA09F-8016
Subsystem 1 - Part No SW: 5K0 959 542 C HW: 5K0 959 542 C Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H31 0037
Serial number: 0997440
Coding: 820000
0516 - Databus
Fault Frequency: 21
Reset counter: 26
Mileage: 258471 km
Date: 2025.03.26.
Time: 00:24:52
49675 - Control Circuit for Ignition Key Lock Solenoid
B114A 13 [00001001] - Open Circuit
Reset counter: 26
Mileage: 258471 km
Date: 2025.03.26.
Time: 00:24:52
Part No SW: 2K0 920 975 L HW: 2K0 920 975 L
Component: KOMBI H06 0705
Coding: 481A01
VCID: 3924420E99D51062585-806C
Part No SW: 7N0 907 530 AG HW: 7N0 907 530 AG
Component: J533 Gateway H53 1634
Revision: H53 Serial number: 161112F1000112
Coding: 357401
VCID: 75BC8E3EF5CDB4027CD-8020
Component: IMMO H06 0705
VCID: 6A86AD42ACF36BFAE1F-803E
Part No SW: 3C8 035 279 A HW: 3C8 035 279 A
Component: RNS315-EU H59 0319
Serial number: VWZAZ2M5558336
Coding: 000002110200130000029002
ROD: EV_RNS315EUV2UDS_VW25.rod
VCID: 2904924E6975A0E2285-807C
Component: EUR_W_V4 0050
1048597 - Front Left Treble Speaker
B1061 13 [00001001] - Open Circuit
[tweeter front left open load]
Reset counter: 26
Mileage: 258471 km
Date: 2025.03.26.
Time: 00:24:54
1048632 - Antenna 1 for Radio
B1119 13 [00001001] - Open Circuit
Reset counter: 26
Mileage: 258471 km
Date: 2025.03.26.
Time: 00:24:53
Part No SW: 1T0 959 701 T HW: 1T0 959 701 T
Component: Tuer-SG 009 2110
Coding: 0131632
VCID: 48C237CADEBF79EAD7B-801C
01706 - Switch for Mirror-Adjust (E43)
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 140 3305
Revision: 00H22000
VCID: 37204436A3410612AE1-8062
000 - - - MIL ON
Fault Status: 11100000
Mileage: 258471 km
Date: 2019.08.17.
Time: 00:24:52
Battery Volts: 11.8 V
DD
Temperature: 19.0°C
Count: 2
Steering Angle: 0.00°
SteerAng n.Init
Part No SW: 1T0 959 702 R HW: 1T0 959 702 R
Coding: 0131632
VCID: 47C034F6D3A17692DE1-8012
Part No SW: 7N0 907 534 HW: 7N0 907 530 AG
Component: Batt.regelung H53 1634
Coding: 030F1859
VCID: 71B4BA2E81A59822A05-8024
Component: J367-BDM H07 0180
Serial number: 00000000001490682998
End----(Elapsed Time: 00:59, VBatt start/end: 11.4V/11.6V. VIgn 11.6V)-----
