Control Module Incorrectly Coded U1014 00 [00001001]
giovy94
Pirate
Walking the Plank
Italy
I have already looked in the forum and there are problems similar to mine but I noticed some differences in the encoding to solve the error. here is the vcds scan
Address 5F: Information Electr. Labels: 5G0-035-MIB-ENT2.CLB
Control Module Part Number: 6C0 035 867 B HW: 6C0 035 867 B
Component and/or Version: MU-E--ER 820 6230
 Codifica software: 02620000BEFF00004011000100000000000000840000010004
U1014 00 [00001001] - -
Reset counter: 3
Mileage: 247342 km
Date: 2025.03.29
Time: 00:23:57
Voltage terminal 30: 12.4 V
Byte_Coding_Condition-byte_5_condition: ERROR
giovy94
Pirate
Walking the Plank
Italy
1543 - Modulo di controllo codificato in modo errato
Confermato - Testato da Cancellazione della memoria
Fermo immagine:
Priorità di errore: 4
Frequenza di errore: 1
Azzera contatore: 3
Chilometraggio: 247342 km
Data: 29/03/2025
Tempo: 00:23:57
Tensione terminale 30: 12,4 V
Westbury, UK
We need to know what vehicle you have and how it's configured, to do that you need to post an Auto-Scan
Westbury, UK
The language of this forum is English, please post only in English and include an Auto-Scan made with the English version of VCDS
giovy94
Pirate
Walking the Plank
Italy
Here is the scan with vcds vag.
VW polo 6r 1.4 tdi 75 hp cusa
Saturday,29,March,2025,09:19:49:16365
VCDS Version: Release 25.3.0 Running on Windows 10 x64
Reset counter: 3
Mileage: 247342 km
Date: 2025.03.29
Time: 00:23:57
So you would like us to tell you why this MIB is incorrectly coded without being able to see how the whole car is equipped and configured?
giovy94
Pirate
Walking the Plank
Italy
Thanks for the replies, it was my mistake I could not copy the error scan results and copy them. Here now everything should be there. I must point out that after bringing all the bits to the 0 state, it only finds one fault code namely 1543 - Control Module Incorrectly Coded
Pirated copy/clone of VCDS is not acceptable here
  • Disagree
Boki Ar
Arandjelovac, Serbia
C?ID=57300
Pirate copy/clone of VCDS.
If you bought this recently, the best advice is to return it and ask for a refund.
giovy94
Pirate
Walking the Plank
Italy
, I'm publishing what I found from MIB2 SCREEN SETUP WITH THE FOLLOWING FEATURES WHICH DO NOT SEEM ORIGINAL.
Hardware 830
Software 6230
Copyright
GPL 2.0 version 2 , June 1991 .
I would appreciate it if you could give me information to solve the problem at reasonable prices.
