Audi A5 B9 Boost Gauge Activation?
Browny_37
C?ID=610536
Hi all,
I've enabled the lap timer and oil temp function (non virtual cockpit) Analogue Clocks with Digital Inlay.
I was surprised to see that there's also a Boost Gauge Feature present, however it doesn't function.
Is there a specific part of the long coding required to enable this specific function also? Or is it just not a feature for the given profile for my car?
Which makes me wonder if utilising an S5 profile would enable this feature?
Any guidance on this matter would be interesting to hear :)
sportmotor
Czech Republic
C?ID=14747
How did You enable this on non virtual cockpit?
Please post an Auto-Scan so people can see how the car is equipped and configured.
sportmotor
Czech Republic
C?ID=14747
I did find it by myself, just change ECU 17, coding
[LN]_derivative: add 1 (S model), or add 2 (RS model)
Browny_37
C?ID=610536
Apologies for the long time replying. Other things took precedent over the car.
In regard to 'Sportmotors' post. I did try swapping the coding over for the S5 screen. Whilst I can see the term "Boost" on the screen with both Derivative 9 (A5) Derivative 10 (S5) the gauge doesn't function.
Must add that I've retrofitted and coded the Highline Reverse Camera to the car (No issues). And tweaked the Auto High Beam function, Lap Time (Oil Temp Reading), Dual Flash with High Beam since purchasing the car.
Chassis Type: F5-AU49 (8W5)
Scan: 01 02 03 08 09 15 16 17 19 29 2B 39 42 44 46 52 5F 6C 6D 81
          A5 AC BB BC CA D6 D7
VIN: WAUZZZF56HA015707   Mileage: 131532km-81730miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-DETA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 AD    HW: 04L 907 309 L
   Component: R4 2.0l TDI   H34 1970
   Revision: B1H34---    CVN: C3E601E7FF90CA17B866C2AD
   Coding: 0A254032232405083408
   Shop #: WSC 06314 790 00001
   ASAM Dataset: EV_ECM20TDI01104L906026AD 001006
   ROD: EV_ECM20TDI01104L906026AD_001.rod
   VCID: 6C861B609609194A42B-8038
   VINID: 9D196AAAA5851984400451C01CB4B7B0C1
   Part No SW: 8W0 927 155 G    HW: 0CJ 927 156
   Component: 0CK 20TDI RdW H03 0008
   Revision: --H03---    Serial number: 0000001090 CVN: 38C68E89
   ASAM Dataset: EV_TCMDL382021 002024
   ROD: EV_TCMDL382021_AU49.rod
   VCID: 43D490DCDB173632D31-8016
   MTF pump:
   Subsystem 1 - Part No SW: 0CK 927 152 AA    HW: 0CK 321 281 K
   Component: V553 MTFP  002 0572
   Serial number: 75117071170019001088
Address 03: ABS Brakes (J104)       Labels: 8W0-907-379-V1.clb
   Part No SW: 8W0 907 379 G    HW: 8W0 907 379 J
   Component: ESP9 Plus     H06 0719
   Dataset Number: 8W2909504B  0003 CVN: B085950A
   Coding: 0CAA489A10A30A9B11A5489100845292E6A592301208508812004A4967A549
   Shop #: WSC 06334 790 00001
   ASAM Dataset: EV_ESP9BOSCHCMP 001001
   ROD: EV_ESP9BOSCHCMP_001.rod
   VCID: 49C882F4F93BEC6219D-801C
Address 08: Auto HVAC (E87)       Labels:* Redir Fail!
   Part No SW: 8W0 820 043 G    HW: 8W0 820 043 G
   Component: Klima Zone 3  H32 0082
   Coding: 141804295544440D02000100880000000000000000000000000000000000
   Shop #: WSC 06335 790 00001
   ROD: EV_AirCondiBHTCAU491.rod
   VCID: 372CF40C9FCF6A927F9-8062
   Subsystem 1 - Part No SW: 4M2 820 021     HW: 4M2 820 021
   Component: J216 FLuftV  H05 0003
   Serial number: 00000000000001253562
   Humidity sensor: exterior:
   Component: AQ_Hum_Sensor  H01 0006
   Serial number: BC780C8880PAG0MUFU02
   Subsystem 3 - Part No SW: 8W0 919 158     HW: 8W0 919 158
   Component: Klima Heck  H40 0073
Address 09: Cent. Elect. (J519)       Labels:* Redir Fail!
   Part No SW: 8W0 907 063 CG    HW: 8W0 907 063 BG
   Component: BCM1 MLBevo   H13 0266
   Dataset Number: 8W2909514C  0028
   Coding: 87503343E17900CD054551181BAC80B9110B3108000000000000000020001A810A450122025605
   VCID: 025A55D8848DFF3A987-8056
   Subsystem 1 - Part No SW: 8W6 955 119 A    HW: 8W6 955 119 A
   Component: 494 RL 161222  036 0471
   Serial number: 00000001612200485314
   Coding: 5FC7F7
   Serial number: 20202104X81A955555A0
   Coding: 02005D
   Subsystem 3 - Part No SW: 4M0 941 531 AA    HW: 4M0 941 531 AA
   Component: E1 - LDS  H06 0008
   Serial number: 04 07 2016  00559803
   Serial number: GX1CE112101611521572
   Coding: 230000
   Interior Light Module:
   Subsystem 5 - Part No SW: 8W0 947 135 CN    HW: 8W0 947 135
   Component: J528-Dachele  H14 0130
   Serial number: B10463388
   Subsystem 6 - Part No SW: 8W0 925 301 BC    HW: 8W0 925 301 BC
   Component: SL-B9/Q5NF  H17 0010
   Serial number: 2616000158629001
Address 15: Airbags (J234)       Labels:| 8W0-959-655.clb
   Part No SW: 8W0 959 655 F    HW: 8W0 959 655 F
   Component: Airbag10.44   H03 0103
   Serial number: 003UP001GDCE Dataset Number: 8W2909602AC 0003
   Coding: AACCF0C00C800000585400F3D0CC00000000
   ASAM Dataset: EV_AirbaAU10BPAAU736 005013
   ROD: EV_AirbaAU10BPAAU736_005.rod
   VCID: 4CC6BBE0F649F94A22B-8018
   Subsystem 1 - Part No SW: -----------    HW: 442 061 101 17
   Serial number: 3577Y00A920AE223023R
   Subsystem 2 - Part No SW: -----------    HW: 442 061 101 17
   Serial number: 3587Y00A920AE22192E3
   Subsystem 3 - Part No SW: -----------    HW: 442 0B1 101 17
   Serial number: 3517700242A5192A48C6
   Subsystem 4 - Part No SW: -----------    HW: 442 0B1 101 17
   Serial number: 35277001829E16762666
   Subsystem 5 - Part No SW: -----------    HW: 442 0C0 701 17
   Serial number: 35575009B21C1D6621CF
   Subsystem 6 - Part No SW: -----------    HW: 442 0C0 701 17
   Serial number: 35675009B21C1D65D37N
   Subsystem 7 - Part No SW: -----------    HW: 442 0C0 701 17
   Serial number: 23075009B21C1D64413+
   Subsystem 8 - Part No SW: -----------    HW: 442 432 301 17
   Component: PedPSensor_D2  256 0887
   Serial number: I0M9M00B5204C343524/
   Subsystem 9 - Part No SW: -----------    HW: 442 432 301 17
   Component: PedPSensor_P2  256 0887
   Serial number: I0N9M00B5204C342029/
   Part No SW: 4M0 907 129 HA    HW: 4M0 907 129 HA
   ROD: EV_SMLSKLOAU736_006.rod
   VCID: 76B23908D845D39AA4F-8022
   Part No SW: 8W6 920 971     HW: 8W6 920 971
   Component: TDIeGB        H08 0523
   Coding: 24AC40D6288006000120EB601000000000000000
   ASAM Dataset: EV_DashBoardAU736 001022
   VCID: 01585AD4818BE42281D-8054
   Part No SW: 8W5 907 468 D    HW: 8W5 907 468 C
   Component: Gateway       H30 0308
   Revision: 5A010004    Serial number: 0485A258017122 Dataset Number: 8W2909515B  0027
   Coding: 03010001000086404107000000590012C8100007000000000175078E10000000
   GVL: 01503C0008040200408C08000002C80010080000000000000000000000000000
   ASAM Dataset: EV_CGateCONTIAU491 002040
   ROD: EV_CGateCONTIAU491_002_AU49.rod
   VCID: 4ACABDF8FC3DE77A107-801E
   Subsystem 1 - Part No SW: 8W0 951 523 F    HW: 8W0 951 523 F
   Component: J453 MFL  H04 0002
   Serial number: 20161221173442 21725
   Serial number: 0521152504
   Part No SW: 4M0 907 397 AB    HW: 4M0 907 397 B
   Component: LCM_MLBevoH05 0024
   Dataset Number: 8W2909519A  0002
   VCID: 77AC340CDF4FAA92BF9-8022
   Part No SW: 3Q0 905 861 A    HW: 3Q0 905 861 A
   Component: ELV-MLBevo    H05 0032
   Serial number: 16000333714017
   Coding: 8800000000000000
   ROD: EV_ELVMarquMQBB_VW37.rod
   VCID: 323AC51874AD8FBA487-8066
   Dataset Number: 8W2909520A  0002
   Part No SW: 8W0 959 593 E    HW: 8W0 959 593
   Component: TSG FS        005 0057
   Serial number: 0000235278686  Dataset Number: 8W2909872A  0017
   Coding: 001DCA625001000000001482
Address 44: Steering Assist (J500)       Labels:| 8W0-909-144-V1.clb
   Part No SW: 8W0 909 144 G    HW: 8W0 909 144 B
   Component: EPS_MLBEVO_ZF H08 0409
   Dataset Number: 8W2909852N  0026
   Coding: 09000380008000
   ASAM Dataset: EV_EPSZFAU49X 003018
   ROD: EV_EPSZFAU49X_003.rod
   VCID: 41D89AD4C10B2422C1D-8014
   Part No SW: 8W0 907 064 CB    HW: 8W0 907 064 B
   Component: BCM2 MLBevo   018 0344
   Dataset Number: 8W2909501B  0025
   Coding: 013500002F9100406309A0006600080231020010004306502F04000000040030001F0001000000
   ASAM Dataset: EV_BCM2HellaAU736 012013
   ROD: EV_BCM2HellaAU736_012_AU49.rod
   VCID: 7EA22128F0759BDAFCF-802A
   Subsystem 1 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
   Serial number: 000000000ZY163232GGQ
   Subsystem 2 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Serial number: 00000000000068294001
   Part No SW: 8W0 959 592 E    HW: 8W0 959 592
   Component: TSG BFS       005 0057
   Serial number: 0000233190749  Dataset Number: 8W2909873A  0017
   Coding: 001DCA225C01000000001480
   VCID: 4BC4B8FCF347FE722B1-801E
Address 5F: Information Electr. (J794)       Labels:* 8W0-035-MIB-HGS2.clb
   Part No SW: 8W0 035 192 E    HW: 8W0 035 192 A
   Component: MU-HS-LND-EU  045 0170
   Serial number:                Dataset Number: 8W2909545E  0031
   Coding: 01940301FF0A000053111101000A00102F000DE601F00100CE
   ROD: EV_MUHigScl6C3DELP.rod
   VCID: 382EF73092D165EA763-806C
   Subsystem 1 - Part No SW: 8W0 919 866 M    HW: -----------
   Component: ECE 2017  --- 0024
   Multimedia display unit 1:
   Subsystem 2 - Part No SW: 8W2 919 604     HW: 8W2 919 604
   Component: AU49x_DU_STD  H40 0008
   Serial number: AUZ8Z9GBH00PS3
   Subsystem 3 - Part No SW: 8W0 919 614 N    HW: 8W0 919 614 N
   Component: ControlUnit_B  H22 0134
   Serial number: APVAK110081900020635
3084 - GSM antenna 2
          B1533 13 [00001001] - Open Circuit
                    Reset counter: 201
                    Mileage: 131532 km
                    Date: 2025.09.30
                    Time: 19:39:28
                    Voltage terminal 30: 12.1 V
   Component: RVC Compact   H19 0250
   Dataset Number: 8W2909460H  0014
   Coding: 0294030102002001400040
   ROD: EV_CamSysRVRVCPANAMLBEv_005.rod
   VCID: 3334C01C8BB786B2431-8066
   Part No SW: 8W8 959 107 B    HW: 8W8 959 107
   Component: HDSG-Modul    H13 0161
   Revision: --------    Serial number: 31146730400000 Dataset Number: 8W2909541B  0004
   Coding: 0610
   VCID: 48CE87F0E231156A063-801C
   Part No SW: 8W2 713 041 J    HW: 8W2 713 041 J
   Component: GSM-LL        H09 0073
   Revision: 0L0D5012    Serial number: 20170109000710
   ASAM Dataset: EV_GSMWaehlZFAU736 001016
   ROD: EV_GSMWaehlZFAU736.rod
   VCID: 3B24E83CA3E74EF29B1-806E
Address A5: Frt Sens. Drv. Assist (R242)       Labels:* Redir Fail!
   Part No SW: 8W6 907 217     HW: 8W6 907 217
   Component: BVS           H14 0042
   Dataset Number: 8W2909466A  0015
   Coding: 0404090300000403024023A0A50000FC00F0C020C020
   ROD: EV_BVSMLBevKOSTAAU736_002_AU49.rod
   VCID: 7F5CDC2CF77F92D2F79-802A
Address AC: Reductant Control (J880)       Labels: 4M0-907-355.clb
   Part No SW: 4M0 907 355 H    HW: 4M0 907 355 B
   Component: SCR-Stg-G3H05 0010
   Dataset Number: 8W2909571H  0002
   ASAM Dataset: EV_RDCMINERGAU736 005014
   ROD: EV_RDCMINERGAU736.rod
   VCID: 3632F90898C5939A64F-8062
   Part No SW: 8W0 959 595 E    HW: 8W0 959 595
   Component: TSG HFS       005 0057
   Serial number: 0000236602204  Dataset Number: 8W2909897A  0014
   Coding: 000DC8220001000000001080
   ROD: EV_DCU2RearDriveMAXHCONT_VW37.rod
   VCID: 4EC2B1E80055CB5A4CF-801A
   Component: TSG HBFS      005 0057
   Serial number: 0000236602588  Dataset Number: 8W2909896A  0014
   ROD: EV_DCU2RearPasseMAXHCONT_VW37.rod
   Part No SW: 4M0 907 594 J    HW: 4M0 907 594
   Component: SAD_STG_1     013 0005
   Dataset Number: 8W2909469B  0007
   Coding: 528000049301
   ROD: EV_SunRoofCONTIAU736_006_VW37.rod
   VCID: 3D20E624BDF340C2A55-8068
   Dataset Number: 8W2909471A  0008
   VCID: 176C148CFF0F4A925F9-8042
   Dataset Number: 8W2909472A  0008
End----------(Elapsed Time: 01:55, VBatt start/end: 12.3V/12.3V)-----------
-------------------------------1 Fault Found-------------------------------
[CODE/]
Browny_37
C?ID=610536
Browny_37
C?ID=610536
BUMP
MasterTommy
Amsterdam
C?ID=295586
Wont function without tweaking the engine ECU software, since the engine ECU is responsible for sharing the data that the boost gauge displays. If the boost gauge stays at zero, it means there is nothing to display. As far as I know, no tuner has figured out how, probably since it also isn't really worth the effort for tuners.
Dr Sheldon
Windsor UK
C?ID=334979
Ever thought about a smart watch ?
