Initial Fuel Filling VW
senna1
C?ID=231631
just a question i went to bleed the fuel system on Vw 2.0 TDI 2012 engine code CFHC & the vcds screen showed
Initial fuel filling IDE00470-ENG98891 & Go, but below there are 4 boxes 2 white and 2 blue one in white box, has filling time, blue box has a small s then white box has fuel level, then the last box blue has a small l in it,
When i select GO it prompts to add in total 3 dijits i tried all sorts, even just 1 then 2 then 3 digits plus tried adding decimal point i could not get it to work,
Normally for example Vw Golf it has a different screen first time i have seen this, in the end i had to use another scanner to get the job done, but there will be another time i need to use it The scan is unrelated just to post.
Friday,28,March,2025,13:16:54:51242
VCDS Version: 25.3.0.4 (x64) HEX-NET2 CB: 0.4660.5
Data version: 20250311 DS365.0
VIN: WV1ZZZ2KZDX08074 License Plate: LOG FUEL PRESSURE
Address 01: Engine (03L 906 018 DD)
13:16:34
IDE00021 Engine speed 0 /min
IDE00188 Fuel high-pressure: actual value 350000 hPa
IDE00201 High fuel pressure: specified value 350000 hPa
IDE00405 Crankshaft speed (RPM) 0.0 /min
senna1
C?ID=231631
Wednesday,26,March,2025,13:40:40:51242
VCDS Version: 24.7.1.0 (x64)  HEX-NET2 CB: 0.4660.5
VIN: WV1ZZZ2KZDX080742   License Plate: FULL SCAN AFTER DELPHI WED
Mileage: 258470km-160605mi   Repair Order:
Chassis Type: 2K-VN35 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 37 42 44 46 52 56 61
VIN: WV1ZZZ2KZDX080742   Mileage: 258470km-160605miles
Address 01: Engine (J623-CFHC)       Labels:. 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 DD    HW: 03L 907 309 AE
   Component: R4 2.0l TDI   H28 9979
   Revision: 41H28---    Serial number: 00000000000000 CVN: 74A619D6
   Coding: 00190012042501080000
   Shop #: WSC 01286 386 08256
   ASAM Dataset: EV_ECM20TDI01103L906018DD 003010
   ROD: EV_ECM20TDI01103L906018DD.rod
   VCID: 6FB0BC5697118ED2B61-803A
   VINID: 9E606AAAA09BA94A002001C408422D2B3B
Readiness: 0 0 0 0 X
   Revision: 00H31001
   Coding: 433C600D092A03FAC21206E8901BC092310000
   Shop #: WSC 35110 377 00146
   VCID: 7DAC961ECDFDEC4234D-8028
   Part No SW: 7N0 907 426 BN    HW: 7N0 907 426 BN
   Component: AC Manuell    H20 0505
   Revision: 00001018
   Coding: 0010004003
   Shop #: WSC 35110 790 50316
   VCID: 0154EAEEB18588A2505-8054
10489856 - No Basic Setting
          B2010 00 [00001001] - -
          [Grundeinstellung - nicht durchgeführt]
                    Reset counter: 26
          B10AB F0 [00001001] - Too Low
                    Reset counter: 26
                    Mileage: 258471 km
                    Date: 2025.03.26.
                    Time: 00:24:56
   Part No SW: 5K0 937 085 R    HW: 5K0 937 085 R
   Component: BCM PQ35 B+   021 0068
   Revision: BB021001
   Coding: 411A58328025186A08080082900000240301728842028060648087000041
   VCID: 42D625E2F48353BA09F-8016
   Subsystem 1 - Part No: 1T2 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer 28111  26  0512
   Coding: 009795
                    Reset counter: 26
                    Mileage: 258471 km
                    Date: 2019.08.17.
                    Time: 01:23:04
                    Voltage: 11.40 V
Address 10: Park/Steer Assist (J446)       Labels:| 1Q0-919-475.clb
   Part No SW: 2K0 919 475     HW: 1Q0 919 475
   Component: PARKHILFE 4K  H03 0004
   Revision: --------    Serial number: 32961233502889
   Coding: 108001
   ASAM Dataset: EV_EPHVA14VN3370000 001006
   ROD: EV_EPHVA14VN3370000.rod
   VCID: 70B2BF2A8A2F912AAFB-8024
   Component: VW10Airbag02B H07 0013
   Revision: --------    Serial number: 003HL00F7RSW Dataset Number: 2KC003v____ 0260
   Coding: 000000000000000000000000000000003242
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 353C4E3EB5CDF402BCD-8060
   Part No SW: 1K5 953 507 T    HW: 5K0 953 549 B
   Revision: --------    Serial number:  90422LAP000AR Dataset Number: 1K5953507T  D005
   Coding: 0882140000
   Shop #: WSC 00040 040 00014
   ROD: EV_SMLSNGKUDS_A05.rod
   VCID: 42D625E2F40353BA09F-8016
   Serial number: 0997440
   Coding: 820000
0516 - Databus
                    Fault Frequency: 21
                    Reset counter: 26
                    Mileage: 258471 km
                    Date: 2025.03.26.
                    Time: 00:24:52
49675 - Control Circuit for Ignition Key Lock Solenoid
          B114A 13 [00001001] - Open Circuit
                    Reset counter: 26
                    Mileage: 258471 km
                    Date: 2025.03.26.
                    Time: 00:24:52
   Part No SW: 2K0 920 975 L    HW: 2K0 920 975 L
   Component: KOMBI         H06 0705
   Coding: 481A01
   VCID: 3924420E99D51062585-806C
   Part No SW: 7N0 907 530 AG    HW: 7N0 907 530 AG
   Component: J533  Gateway H53 1634
   Revision:   H53       Serial number: 161112F1000112
   Coding: 357401
   VCID: 75BC8E3EF5CDB4027CD-8020
   Component: IMMO          H06 0705
   VCID: 6A86AD42ACF36BFAE1F-803E
   Part No SW: 3C8 035 279 A    HW: 3C8 035 279 A
   Component: RNS315-EU   H59 0319
   Serial number: VWZAZ2M5558336
   Coding: 000002110200130000029002
   ROD: EV_RNS315EUV2UDS_VW25.rod
   VCID: 2904924E6975A0E2285-807C
   Component: EUR_W_V4  0050
1048597 - Front Left Treble Speaker
          B1061 13 [00001001] - Open Circuit
          [tweeter front left open load]
                    Reset counter: 26
                    Mileage: 258471 km
                    Date: 2025.03.26.
                    Time: 00:24:54
1048632 - Antenna 1 for Radio
          B1119 13 [00001001] - Open Circuit
                    Reset counter: 26
                    Mileage: 258471 km
                    Date: 2025.03.26.
                    Time: 00:24:53
   Part No SW: 1T0 959 701 T    HW: 1T0 959 701 T
   Component: Tuer-SG         009 2110
   Coding: 0131632
   VCID: 48C237CADEBF79EAD7B-801C
01706 - Switch for Mirror-Adjust (E43)
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 140    3305
   Revision: 00H22000
   VCID: 37204436A3410612AE1-8062
            000 - - - MIL ON
                    Fault Status: 11100000
                    Mileage: 258471 km
                    Date: 2019.08.17.
                    Time: 00:24:52
                    Battery Volts: 11.8 V
                        DD
                    Temperature: 19.0°C
                    Count: 2
                    Steering Angle: 0.00°
                        SteerAng n.Init
   Part No SW: 1T0 959 702 R    HW: 1T0 959 702 R
   Coding: 0131632
   VCID: 47C034F6D3A17692DE1-8012
   Part No SW: 7N0 907 534     HW: 7N0 907 530 AG
   Component: Batt.regelung H53 1634
   Coding: 030F1859
   VCID: 71B4BA2E81A59822A05-8024
   Component: J367-BDM  H07 0180
   Serial number: 00000000001490682998
End----(Elapsed Time: 00:59, VBatt start/end: 11.4V/11.6V. VIgn 11.6V)-----
Jef
HQ
If you are needing to purge air out of the fuel system, then I would suggest Basic Settings IDE00459-Test of transfer fuel pump.
You may want to have a battery charger hooked up when you do this. Some ECMs as I recall will run the test until you stop it, others will run the test for say 45 to 60 second blocks, so may need to the Basic Settings step a few times in a row to be sure all air is purged out.
Depending on the engine and how "dry" of a fuel system you're dealing with, it is suggested for up to 3 minutes of total run time. Having said that, I did maybe 1 minute for simple things like 2.0 fuel filter swaps. But when I had the pleasure of doing a complete fuel system (fuel cap to injectors), I ran it a whole lot before I cranked the engine over.
senna1
C?ID=231631
Hi Thanks for your reply but i expected vcds to reply to their format i mentioned, this is the first time i have seen this, other vag strait forward procedure.
i used my other scanner to bleed the system i ran it a few time to be sure no air,
senna1
C?ID=231631
That is the Norm i have used it before on other vag vehicles but for this vw caddy not the same that is why i posted the question about the 3 digits there are 4 boxes 2 blue two white and you cant go any further as it keeps prompting for 3 digits, so i dont think anyone has come across this what i am seeing,
thanks for your reply anyway, but no problem as i used my other scanner,
Westbury, UK
I believe that was a bug in the released VCDS which was withdrawn and replaced a few hours later, to correct this you need to update your VCDS.
senna1
C?ID=231631
you could be right i have recently had a prompt for a newer update not yet installed, the 4 boxes you are shown when you select Basic settings
has Filling time above it, then a blue box with a small letter s in it, then another white box & above says Fuel level then the last box blue has a small letter l , but no matter what you do with the digits, it rejects it,
senna1
C?ID=231631
Hi i recently had another vag with when it came to bleeding the fuel system intial fuel filling with this same chart, anyway i got it to work so it's not a bug
if you type in the first field box for time,, example 120 then in the other i put 25, which works out say 2mins, and 1/4 tank of fuel and it works, just thought id mention it if anyone else has a problem with it,
