Golf 6 central electronic module (BCM)
TommyK82
Wiltshire. UK
Hi Guys,
Raw newbie here, although I have been lurking and reading related posts a lot.
Used my new Hex V2 to scan my 2011 golf 6 1.6tdi.
I’m trying to diagnose a boot lock fault (here we go again!) I understand that even though module 46 convenience is listed, it’s not fitted to the car. It’s module 9 central electronics or BCM.
Having failed to connect to 46 I assume that’s the case.
Module 9 had no stored or active DTC’s but the boot lock won’t function from ANY input. Be it the handle, key fobs or drivers door button.
So would the module show codes if it was knackered, would it show a broken wire if it couldn’t reach the switches or actuator itself?
I’ve peeled back the rubber boot seal over the body to hatch loom and the wires all appear intact at least externally.
Anything else I can do with VCDS to diagnose this issue? I don’t want to start messing with looms and modules without knowing which is at fault. Everything else works on the central electronics. Just the boot latch, which has been replaced with a genuine brand new part, so I’m ruling out the actuator and switch assembly.
My multimeter reads no voltage at the boot handle plug or pins 1-4 on the actuator plug even when the switch and or key are operated. Although the lock may have been in the open position at this point.
Why can’t these things be simple?!
Cheers
Tom
TommyK82
Wiltshire. UK
Hi Uwe,
Okay! It’s dark here now but will post one tomorrow. Thanks.
This is why you buy a genuine cable 👍
TommyK82
Wiltshire. UK
First scan below...
Please bear in mind, the car battery was low voltage aabd trickle charging, the fuel lines were full of air prior to bleeding, there are numerous faults (the car wwas £600!)
Trying to just get the boot working! I'll work through everything else as I go.
Wednesday,26,March,2025,13:46:15:02366
VCDS Version: 25.3.0.4 (x64)  HEX-V2 CB: 0.4660.5
Data version: 20250311 DS365.0
VIN: WVWZZZ1KZBP165738   License Plate:
Chassis Type: 1K-VW36 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 2E 42 44 46 52 56 62 72 77
VIN: WVWZZZ1KZBP165738   Mileage: 218560km-135806miles
   Part No SW: 03L 997 557 P    HW: 03L 907 425 C
   Component: R4 1.6l TDI   H43 9982
   Revision: --H43---    Serial number: 00000000000000 CVN: 8F1FD0C4
   Coding: 08114014032500080000
   Shop #: WSC 00028 028 00024
   ASAM Dataset: EV_ECM16TDI02103L997557P 003003
   ROD: EV_ECM16TDI02103L997557A.rod
   VCID: 49C882E8893991A2189-801C
   VINID: 9E69EAAAA05BA928011851C3202CD82DE2
10119 - High Pressure Fuel Rail
          P00C6 00 [01100100] - Minimum Pressure Not Reached
                    Mileage: 218560 km
                    Date: 2025.03.21.
                    Time: 23:14:27
                    Engine speed: 330.50 /min
                    Normed load value: 10.6 %
                    Coolant temperature: 28 °C
                    Intake air temperature: 20 °C
                    Voltage terminal 30: 9.600 V
                    Fuel high-pressure: actual value-FUP_FIL: 0.110 MPa
                    Fuel pressure regulator valve: specified value rail pressure-LV_PCV_CTL: 00000001
                    Fuel level-FTL_CAN: 52 l
                    Time since engine start: 0 s
                    Fuel Metering Valve-VCV: 26.741 %
                    Fuel Pressure Regulator Valve-PCV: 48.952 %
                    Fuel high pressure commanded value_1-FUP_SP_KPA_ENVD: 27752.686 kPa
   Revision: 00H31001
   Coding: 133B200D092800FFC81204E790210081310000
   Shop #: WSC 00028 028 00001
   VCID: 76B23914A8C7AE5AA5B-8022
                    Reset counter: 34
                    Mileage: 217814 km
                    Date: 2025.04.12.
                    Time: 14:40:09
                    Count: 7
                    Count: 3
                    Count: 4608
                    Count: 128
                    Count: 28928
                    Count: 1
                    Count: 256
   Part No SW: 7N0 907 426 K    HW: 7N0 907 426 K
   Component: AC Manuell    H17 0202
   Revision: 00012001
   Coding: 0000000002
   ROD: EV_ClimaBasis_VW36.rod
   VCID: 3C26EB3CD6EB340A93F-8068
13635840 - Supply voltage
          U1011 00 [00001000] - Voltage too Low
          [Versorgungsspannung - unterer Grenzwert unterschritten]
                    Reset counter: 34
                    Mileage: 217814 km
                    Date: 2025.04.12.
                    Time: 14:40:26
   Part No SW: 1K0 937 084 D    HW: 1K0 937 084 D
   Component: BCM PQ35  B   103 0615
   Revision: 00103 AE
   Coding: 48180A3A8825F1C040080080340000E443510088536D8160648000200040
   VCID: 2F3CCC70171DDF9226D-807A
   Subsystem 1 - Part No: 5K2 955 119
   Component: Wischer 25031  26  0512
   Coding: 009795
   Component: RLS 170411 05  54  0403
   Coding: 0330AD
7 Faults Found:
                    Reset counter: 34
                    Mileage: 217814 km
                    Date: 2025.04.12.
                    Time: 14:32:53
                    Voltage: 8.75 V
                        Term 50 Off
00153 - Windshield Wiper Motor;  Driver Side (V216)
                    Reset counter: 34
                    Mileage: 217814 km
                    Date: 2025.04.12.
                    Time: 14:33:11
                    Voltage: 8.60 V
                        Term 50 Off
                    Reset counter: 34
                    Mileage: 217814 km
                    Date: 2025.04.12.
                    Time: 14:40:24
                    Voltage: 7.95 V
                        Term 50 Off
                    Reset counter: 34
                    Mileage: 217814 km
                    Date: 2025.04.12.
                    Time: 14:40:31
                    Voltage: 7.90 V
                        Term 50 Off
                    Reset counter: 34
                    Mileage: 217814 km
                    Date: 2025.04.12.
                    Time: 14:55:33
                    Voltage: 12.15 V
                        Term 50 Off
                    Fault Status: 00101110
                    Reset counter: 34
                    Mileage: 217816 km
                    Date: 2025.04.12.
                    Time: 15:54:49
                    Voltage: 13.80 V
                        Term 50 Off
                    Fault Status: 00101011
                    Reset counter: 34
                    Mileage: 218202 km
                    Date: 2025.04.27.
                    Time: 09:09:56
                        Term 15 Off
                    Voltage: 12.55 V
                        Term 50 Off
Address 10: Park/Steer Assist (J446)       Labels:. 3C8-919-475.clb
   Part No SW: 5K0 919 475 E    HW: 5K0 919 475 E
   Component: PARKHILFE 8K  H01 0012
   Revision: --------    Serial number: 12501108800749
   Coding: 108001
   VCID: 382EF72CE253182A777-806C
                    Reset counter: 34
                    Mileage: 217814 km
                    Date: 2025.04.12.
                    Time: 14:33:10
                    Temperature: 12.0°C
                    Reset counter: 34
                    Mileage: 217814 km
                    Date: 2025.04.12.
                    Time: 14:32:20
                    Temperature: 12.0°C
   Part No SW: 5C0 959 655 B    HW: 5C0 959 655 B
   Component: AirbagVW10    013 0613
   Serial number: 003G5RA3L6EJ   Dataset Number: 5K0003v____ 0142
   Coding: 00003948
   Shop #: WSC 00028 028 00057
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 3138CA0801A9C962309-8064
   Serial number: 3572MSME6838635DZZZ2
   Serial number: 3582MSME3876635DZZZ2
   Serial number: 3512QSME783D060CZZZ/
   Serial number: 3522QSME024B7F36ZZZ/
          [Powersupply  lower threshold fall short of]
                    Reset counter: 34
                    Mileage: 217814 km
                    Date: 2025.04.12.
                    Time: 14:32:26
   Part No SW: 5K0 953 507 BC    HW: 5K0 953 549 E
   Revision: --------    Serial number:  90440KDB001LD Dataset Number: 5K0953507BC D005
   Coding: 1082140000
   ROD: EV_SMLSNGKUDS_A05_VW32.rod
   VCID: 72BA0504C42FB27A893-8026
   Serial number: 40000000000000320939
   Coding: E20000
114178 - Function Restricted due to Insufficient Voltage
          U1400 00 [00001000] - -
                    Reset counter: 34
                    Mileage: 217814 km
                    Date: 2025.04.12.
                    Time: 14:40:59
136194 - Supply voltage
                    Reset counter: 34
                    Mileage: 217814 km
                    Date: 2025.04.12.
                    Time: 14:33:17
365080 - Controls in Steering Wheel
          U108E 00 [00001000] - No Communications
                    Reset counter: 35
530190 - Local Databus
          U1030 00 [00001000] - Electrical Malfunction
                    Reset counter: 35
                    Mileage: 218467 km
                    Date: 2025.03.17.
                    Time: 02:18:57
   Part No SW: 5K0 920 971 A    HW: 5K0 920 971 A
   Coding: 470B00
   VCID: 2D00D6781D91AD82141-8078
          [Supply voltage too low]
                    Reset counter: 34
                    Mileage: 217814 km
                    Date: 2025.04.12.
                    Time: 14:34:37
   Part No SW: 7N0 907 530 C    HW: 1K0 907 951
   Component: J533  Gateway H37 0614
   Revision:   H37       Serial number: 150411F6001190
   Coding: 350003
   VCID: 303ECF0C0A23C06A3F7-8064
   Component: IMMO          H20 0420
   VCID: 6A8A1D64ECFF7ABA313-803E
   Part No SW: 5N0 035 342 D    HW: 5N0 035 342 D
   Revision: A1001003    Serial number: 7669784068
   VCID: 280E276C32F388AAE77-807C
                    Reset counter: 34
                    Mileage: 217814 km
                    Date: 2025.04.12.
                    Time: 14:32:43
                    Reset counter: 34
                    Mileage: 217814 km
                    Date: 2025.04.12.
                    Time: 14:37:39
   Part No SW: 5K0 959 701 D    HW: 5K0 959 701 D
   Component: Tuer-SG         009 2152
   Coding: 0000692
   VCID: 3334C000F735FB72425-8066
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 69     3201
   Revision: 00H20000
   VCID: 3436C31CF23BFC4A5BF-8060
   Part No SW: 5K0 959 702 E    HW: 5K0 959 702 E
   Coding: 0000948
   VCID: 3530FE18F941E5426C1-8060
00110 - Right Mirror Turn Signal Lamp (L132)
Address 56: Radio (J0503)       Labels:. 5M0-035-1xx-56.clb
   Part No SW: 3C8 035 195 A    HW: 3C8 035 195 A
   Component: Radio RCD510  041 0166
   Revision: 00000001    Serial number: VWZ1Z3L0742593
   Coding: 0100040004
   VCID: 2612295438E79EDAD5B-8072
                    Reset counter: 34
                    Mileage: 217814 km
                    Date: 2025.04.12.
                    Time: 14:32:08
                    Reset counter: 249
                    Mileage: 217814 km
                    Date: 2025.04.12.
                    Time: 14:06:11
   Coding: 0000144
   Shop #: WSC 00028 028 1012545
   Coding: 0000144
   VCID: 3632F914E447EE5A65B-8062
   Part No SW: 5K0 035 730 B    HW: 5K0 035 730 B
   Component: TELEFON       H09 1020
   Revision: 1B001001    Serial number: 00007669711540 Dataset Number: 5K0035730B  0001
   Coding: 0A01000000010101
   ASAM Dataset: UHVNA A01009
   ROD: UHVNA.rod
   VCID: 2416335C4E5B6CCACBF-8070
9457425 - Left audio channel for speech/telephone
          B104F 11 [00000001] - Short to GND
9457169 - Right audio channel for speech/telephone
          B104E 11 [00000001] - Short to GND
          [Terminal 30: lower limit value not reached]
                    Reset counter: 34
                    Mileage: 217814 km
                    Date: 2025.04.12.
                    Time: 14:33:15
                    Reset counter: 34
                    Mileage: 217814 km
                    Date: 2025.04.12.
                    Time: 14:33:05
End----------(Elapsed Time: 01:20, VBatt start/end: 12.3V/12.2V)-----------
------------------------------27 Faults Found------------------------------
TommyK82
Wiltshire. UK
Once battery was charged and DTC's cleared....
Wednesday,26,March,2025,14:13:55:02366
                    Mileage: 218560 km
                    Date: 2025.03.21.
                    Time: 23:14:27
   Revision: 00H31001
   Revision: 00012001
   Coding: 0000000002
   Revision: 00103 AE
   Coding: 009795
   Coding: 0330AD
   Coding: 108001
   Coding: 00003948
   Coding: 1082140000
   Coding: E20000
   Coding: 470B00
   Coding: 350003
   Coding: 0000692
   Revision: 00H20000
   Coding: 0000948
   Coding: 0100040004
                    Reset counter: 251
                    Mileage: 218560 km
                    Date: 2025.03.26.
                    Time: 22:57:44
   Coding: 0000144
   Coding: 0000144
   ROD: UHVNA.rod
End----------(Elapsed Time: 01:10, VBatt start/end: 12.1V/12.1V)-----------
------------------------------2 Faults Found-------------------------------
TommyK82
Wiltshire. UK
Anyone? @Uwe ?
Any ideas why the module is throwing no codes for the boot lock but it's inoperative via keyfob, handle and driver's door button.
I can't see damaged wiring in the rubber boot, brand new Febi Bilstein boot lock unit fitted, matching part number to original.
Is there anything I can do with VCDS to further diagnose the issue? Like a live scan of module 9 to see if the various input and output signals are there?
Or is the unit coded incorrectly? The car is a bit of a shed, it wouldn't surprise me if the last owner had the thing in pieces.
Not off the top of my head.
There are some rear lid variant bits in Byte 1, but I don't know what's correct for this particular car. More rear lid stuff in Byte 2, but again, I don't know what's correct for this car.
TommyK82
Wiltshire. UK
Thanks Uwe, I’ll scan the module again and see if I can test it in any more depth.
After that I suppose I’m looking at a long test lead and going pin to pin to test the plugs and wiring harness! Deep joy awaits!
TommyK82
Wiltshire. UK
Hi guys, I thought I’d return to conclude this episode incase anyone is searching for the same issue down the line.
Thankfully, BCM module 9 seems to be behaving but in the golf mk6 I’ve had multiple hardware and wiring failures making diagnosis a nightmare.
The wiring from the VW boot lid (trunk) handle had failed at the switch output pin and looked a little burned out inside. Needed some TLC!
The switch itself was also full of crud (ancient water ingress?!) and was an open circuit too.
I also had the OG of boot lock failures, a dud actuator.
None of this threw any codes, so sometimes it’s an old skool process of elimination.
Thanks to all for the input. Hopefully the new boot handle will just work and I can move onto the next minor fault! 😂
TommyK82
Wiltshire. UK
Working on it! I’m trying to cut down on forum ‘lurking’ I now only frequent 2 or 3, the rehab is kinda working.
Besides, now I have to get involved and stay illuminated, I have a cable and software that does more than I fully understand 😂.
All I know is that my £600 golf is getting all the faults ironed out because it can tell me what’s up!
Reactions: JMR
