01826 Sensor For Steering Angle (G85) Supply Voltage Terminal 30 (Touareg2)
carboncow
Central Ohio
C?ID=266014
Newbie here but been around the Volvo world with Vida Dice for some time...so not a total idiot. Although this short/long code (Hex-a-what?) has my head spinning still.
A few weeks back I had a no start situations that had the car stuck in a Home Depot parking lot for a day (no VCDS yet) and eventually unhooking the battery for a few minutes had it starting right up. Push button 2008 T2 and nothing would happen, no relays kicking...good battery...just unresponsive.
I finally got to pulling the codes and although I knew about a few things (from a friends scan) about HVAC servos and stereo stuff I had a new code that may very well be the reason for the no start. I did trip over a post somewhere on the general intertubes about Steering Angle Sensors being one of the few issues with T2 and non-starts. Now I cannot find the article, but I digress...
Anyone got any working knowledge of this error? Intermittent or symptom of bad things to come? Or was this Supply voltage due to me taking the battery offline?
Also...looking at the detailed info from the VCDS-Mobile what are the four count fields about? As a matter of fact what are the all the values there about or if this is a 101 question can you point me to the post or manual chapter that explains these. See screenshot of what I"m discussing as well as the full scan code below.
DTC Code
#hndoc:?docid=00001467&xt=hnh:AF52752AA3FC94F4B3D03CC07C798DC0E2770C7921A038DF7548B0E0FA4573AA
Thu,Dec,17,2015,21:42:59  VCDS Mobile 0.4231.0.4
Address 03: ABS Brakes	Labels:7L0-907-379-MK25E1.clb
	Part Number SW: 7L0-907-379-L	HW: 7L0907379L
	Component: ESP ALLRAD MK25E1    0303
	Revision: 00H53001
	Coding: 0004354
	Shop #: WSC 31414 790 00001
	VCID: 42C7D90B4BFEC5514D875E-8017
Full Scan:
VIN: WVGBE77L68D051974
Scan: 01 02 03 05 08 09 0F 15 16 17 19 1C 22 28 46 47 55 56 65 68
	 69 6D 6E 76
68-Wiper Electr. -- Status: OK 0000
6E-Ctrl Head Roof -- Status: OK 0000
Address 01: Engine	Labels: 03H-906-032-BLV.lbl
	Part No SW: 03H 906 032 CB	HW: 03H906032S
	Component: T-GP LEV2       G    1667
	Revision: 5FH04---	Serial Number: VWX3Z0G6694445
	Coding: 0001175
	VCID: 648B3F93F12AAE619FFBC8-5184
001110 - EVAP System
	P0456 - 001 - Very Small Leak Detected
Address 02: Auto Trans	Labels: 09D-927-750.lbl
	Part No SW: 09D 927 750 GD	HW: 09D927750GD
	Component: AL 750 6A            1093
	Revision: 00H61000	Serial Number:
	Coding: 0004216
	VCID: 76AF75DB57B62CF1318F92-5184
No fault codes found.
Address 03: ABS Brakes	Labels: 7L0-907-379-MK25E1.clb
	Part No SW: 7L0 907 379 L	HW: 7L0907379L
	Revision: 00H53001
	Coding: 0004354
Address 05: Acc/Start Auth.	Labels: None
	Part No SW: 7L0 909 137 B	HW: 5WK48517�X
	Component: 11 Kessy             6840
	Revision: 68406620	Serial Number: VWX3Z0G6694445
	Coding: 0147688
	VCID: 322789CBFB5E75D1DDE7AE-8067
	Subsystem 1 - 	Part No SW: XXX-XXX-XXX-XX
	Component: ELV                  XXXX
Address 08: Auto HVAC	Labels: 7L6-907-044.clb
	Part No SW: 7L6 907 044 AF
	Component: CLIMAtronic 2+2      4331
	Coding: 0020030
	VCID: 78B37BE35DA25F8123A3AC-802D
	Subsystem 1 - 	Part No SW: 7L6-907-049-F
	Component: CLIMAtronic FOND     0503
02379 - Positioning Motor for Left Side Vent (V299)
02600 - Rear Right Temperature Flap Motor (V314)
Address 09: Cent. Elect.	Labels: 7Lx-937-049-V2.clb
	Part No SW: 7L6 937 049 AF	HW: 7L6937049AF
	Component: 2000J519
	Serial Number: --------------
	Shop #: WSC 00000 000
	VCID: 80439303857297419B1304-80D5
Address 0F: Digital Radio	Labels: 8E0-035-593-SIR.lbl
	Part No SW: 8E0 035 593 M	HW: 8E0035593M
	Component: SDAR SIRIUS     H07  0150
	Revision: 00000000	Serial Number: AUZ4Z7G0222169
	Coding: 0000100
	VCID: 33298CCF044478D9D611B3-8066
Address 15: Airbags	Labels: 7L0-959-655.lbl
	Part No SW: 7L0 959 655	HW: 7L0959339F
	Component: J234  3A VW8T        0250
	Revision: 92011025	Serial Number: 0039P003P54V
	Coding: 0013121
	VCID: FAB7E1EBE3AECD91D5D746-80AF
	Subsystem 1 - 	Part No SW: 7L0-959-339-F
	Component: BF-Gewichtsens. 007  0010
	Serial Number: 3PQT1
Address 16: Steering wheel	Labels: 7L6-953-549.lbl
	Part No SW: 7L6 953 549 F
	Component: J527                 3601
	Coding: 0010011
Address 17: Instruments	Labels: 7L6-920-xxx-7L6.lbl
	Part No SW: 7L6 920 975 L	HW: 7L6920975L
	Component: J285 KOMBI-INST.     7320
	Revision: KHH05V03
	Coding: 0007201
	VCID: 45CDC2175AD0F66968A57D-8010
Address 19: CAN Gateway	Labels: 6N0-909-901-19.lbl
	Part No SW: 6N0 909 901	HW: 7L6920975L
	Component: J533  GW-K-CAN TP20  7320
	Coding: 77E2F7BB63066002
	VCID: F0A3C3C3B5D283C16B73D4-80A5
Address 1C: Position Sensing	Labels: 7L6-919-879.lbl
	Part No SW: 7L6 919 879 B	HW: 7L6919879B
	Component: Kompass         001  0001
	Revision: 00001000	Serial Number: 1439802T0QXC02
	VCID: 46CFC51B67D6FD7161AF82-8013
Address 22: AWD	Labels: None
	Part No SW: 0AD 927 755 BG
	Component: TRANSFERCASE         0126
	VCID: 814596078E789B49941D09-5184
Address 28: Failed to respond
Address 46: Central Conv.	Labels: 7L0-959-933.lbl
	Part No SW: 7L6 959 933 A
	Component: 19 HSG               0600
	Coding: 0000085
	VCID: 40C3D30345F2D2415B9344-4B1E
	Subsystem 1 - 	Part No SW: 7L0-959-701-P
	Component: Tuersteuergeraet FS  6302
	Subsystem 2 - 	Part No SW: 7L0-959-702-P
	Component: Tuersteuergeraet BF  6302
	Subsystem 3 - 	Part No SW: 7L0-959-703-D
	Component: Tuersteuergeraet HL  0201
	Subsystem 4 - 	Part No SW: 7L0-959-704-D
	Component: Tuersteuergeraet HR  0201
Address 47: Sound System	Labels: 7Lx-035-4xx-47.lbl
	Part No SW: 7L6 035 466 A	HW: 7L6035466A
	Component: DSP 10 Kanal         0003
	Revision: 00001000	Serial Number: 00000000006024
	VCID: 322789CBFB5E71D1DDE7AE-8067
00871 - Bass Speaker Front Right (R23)
Address 55: Xenon Range	Labels: 7L6-907-357-A.lbl
	Part No SW: 7L6 907 357 A	HW: 7L6941329B
	Component: AFS-Steuergeraet     0001
	Revision:   H02   	Serial Number:
	Coding: 1290371
	VCID: 3935BEE7262886891C2DF1-806C
	Subsystem 1 - 	Part No SW: 7L6-941-329-B
	Component: AFS-Lst.-Modul l     X008
	Coding: 0000019
	Subsystem 2 - 	Part No SW: 7L6-941-329-B
	Component: AFS-Lst.-Modul r     X008
	Coding: 0000019
Address 56: Radio	Labels: 7L6-035-180-56.lbl
	Part No SW: 7L6 035 180 C	HW: 7L6035180C
	Component: Radio DE2            0008
	Revision: 00005000	Serial Number: VWZ4Z4GN014647
	Coding: 0001010
	VCID: 2D1D9AB7E2602E2980D575-8078
Address 65: Tire Pressure	Labels: 7L6-907-273.lbl
	Part No SW: 7L6 907 273 E	HW: 7L6907273E
	Component: J0502 RDK            0006
	Revision: 00004006	Serial Number: 00000600009536
	Coding: 0040008D8D0000000000000000
	VCID: 3A37A1EB232E8D91155706-806F
Address 68: Wiper Electr.	Labels: 7L0-955-119-V2.clb
	Part No SW: 7L6 955 119 B
	Component: J400__ Front Wiper   5301
	Coding: 0001397
	VCID: 3935BEE7262882891C2DF1-806C
Address 69: Trailer	Labels: 7L0-907-383-1D2.lbl
	Part No SW: 7L0 907 383 L	HW: 7L0907383L
	Component: J345  Anhaenger      0080
	Revision: 4A014001	Serial Number: 00000108387306
	Coding: 0002050
	VCID: 3D3DAAF73200BAA9307525-8068
Address 6D: Trunk Elect.	Labels: None
	Part No SW: 7L6 959 107 A	HW: 7L6959107A
	Component: J605  HECKKLAPPE     1210
	Revision: --H05---	Serial Number: --------026281
	Coding: 0122110
Address 6E: Ctrl Head Roof	Labels: 7L6-919-044.lbl
	Part No SW: 7L6 919 044 Q	HW: 7L6919044Q
	Component: J702  Dachdisplay    0400
	Revision: --30004S	Serial Number: 00000000052304
Address 76: Park Assist	Labels: None
	Part No SW: 7L0 919 283 F
	Component: 0E Einparkhilfe      1107
End-------------------------(Elapsed Time: 03:51)--------------------------
I don't see anything there that explains your no-start.
As for the "Count" fields, I don't see an example of that in your scan, but I suspect you're referring to freeze-frame data from some scan, and not all the freeze-frame data is documented.
carboncow
Central Ohio
C?ID=266014
Oops...I did post the wrong thing. Here is the screenshot to what I am referencing. I couldn't figure out how attach and made my error by adding the log which didn't have this data.
Can you explain from this what the counts refer to or is this stuff only Vw knows?
PS. Am I missing where to attach images or do I have to host my own screenshots?
screenshot here: http://d.pr/i/181W or if expired look here: https://www.dropbox.com/s/09tdjt8w7y5vxlf/IMG_0078.jpeg?dl=0
NEtech
Denmark
C?ID=56995
Fault 01826, Intermittent.
Not so good Battery or low capacity some times (during start).
carboncow
Central Ohio
C?ID=266014
very good battery. Wouldn't one expect lockout to go away once bsttery is retuned to proper voltage or does this condition lock out system module until voltage is returned.
