How can I activate the audio sound of locking and unlocking the car?
Thursday,20,March,2025,11:33:58:46973
VCDS Version: 25.3.0.4 (x64) HEX-NET CB: 0.4660.4
Data version: 20250311 DS365.0
Dealer/Shop Name: 14
VIN: WVGZZZ5NZJM104694 License Plate:
Chassis Type: 5N-VW37 (3Q0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 22 42 44 52 5F 6D A5
VIN: WVGZZZ5NZJM104694 Mileage: 155140km-96399miles
Address 01: Engine (J623-DFHA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 026 EJ HW: 04L 907 309 P
Component: R4 2.0l TDI H24 3916
Revision: B4H24--- CVN: D61F7E15F072CEA2
Coding: 0125001203671D082000
Shop #: WSC 00066 790 00455
ASAM Dataset: EV_ECM20TDI01104L906026EJ 004004
ROD: EV_ECM20TDI01104L906026EJ_004.rod
VCID: F6A0AF854970C02B6D-80A2
VINID: 9E65EAAAA15EA9A74100418910401F6E8F
4709 - No Communications with Cruise Control (Front) Distance Sensor
U0235 00 [00100000] - -
[Lost Communication WithCruise Control Front Distance Range Sensor]
Mileage: 155124 km
Date: 2025.03.18
Time: 20:15:23
Engine speed: 0.00 /min
Coolant temperature: 37 °C
Intake air temperature: 38 °C
Voltage terminal 30: 11.820 V
Drivetrain coordinator: brake fault status-Bits 0-7: 0
Acceleration: 0.000 m/s²
Part No SW: 0DL 300 012 N HW: 0GC 927 711 G
Component: GSG DQ500 H06 2112
Revision: 00H06V07 CVN: 897AC4DE
ROD: EV_TCMDQ500021.rod
VCID: B424558D1F8C923B93-80E0
Part No SW: 5Q0 614 517 CF HW: 5Q0 614 517 AD
Component: ESC H25 0513
Revision: 00000000 Serial number: 53427000000048
Coding: 0BEE939A54201B70477D070962C749D0C92AD8E2E046927D38625078C22A4200002864121A1C230935351919323200
Shop #: WSC 01383 790 50316
VCID: F7BEA2814E7AB92376-80A2
8192 - Databus
[FCAN: ACC_07 message is not received]
Reset counter: 78
Mileage: 155124 km
Date: 2025.03.18
Time: 20:15:24
8196 - Databus
[FCAN : ACC_10 message is not received]
Reset counter: 78
Mileage: 155124 km
Date: 2025.03.18
Time: 20:15:24
8260 - Databus
[FCAN: Pla_01 message is not received]
Reset counter: 78
Mileage: 155124 km
Date: 2025.03.18
Time: 20:15:28
8382 - Databus
[FCAN: HCA_01 not received]
Reset counter: 78
Mileage: 155124 km
Date: 2025.03.18
Time: 20:15:28
Address 08: Auto HVAC (E87) Labels:| 5G0-907-044.clb
Part No SW: 5NA 907 044 Q HW: 5NA 907 044 Q
Component: AC Automat H35 4401
Revision: 20K02000 Serial number: 00000D00086214
Coding: 0012010420211001110510000010142A
ASAM Dataset: EV_ACClimaPrehVW37X 002025
VCID: CDD220699C66E3F3FC-8098
Humidity sensor: exterior:
Subsystem 2 - Part No SW: 3G0 907 049 D HW: 3G0 907 049 D
Component: E265KlimaHeck H02 0201
Serial number: 04031501850571
263425 - Air Quality Sensor
B10AF 04 [00001000] - Internal System Fault
Reset counter: 79
Mileage: 155133 km
Date: 2025.03.19
Time: 16:04:01
Outside temperature: 10.5 °C
Voltage terminal 30: 14.7 V
System run time-Engine running time: 253 s
Air quality status: Malfunction
459024 - Databus
[Frontsensorik - kein Signal/Kommunikation]
Reset counter: 78
Mileage: 155124 km
Date: 2025.03.18
Time: 20:15:24
Part No SW: 5Q0 937 086 BK HW: 5Q0 937 086 BF
Component: BCM PQ37BOSCH 034 0245
Revision: -------- Serial number: C8641512170059 Dataset Number: V03935276LW 0001
ROD: EV_BCMBOSCH_018.rod
VCID: 8444C54D0FACE2BB63-80D0
Subsystem 1 - Part No SW: 5NN 955 119 A HW: 5NN 955 119 A Labels: 1KX-955-119.CLB
Component: 326 RL 171027 034 0373
Serial number: 17102521036750
Component: RLHS 047 0105
Serial number: S5Y17M12D13H11M00S25
Coding: 00A8DD
Serial number: 000000000ZY17338037U
Serial number: 00000000000039391763
Humidity sensor: interior:
U1400 00 [00001000] - -
[Funktionseinschränkung durch Unterspannung - unterer Grenzwert unterschritten >]
Reset counter: 78
Mileage: 155124 km
Date: 2025.03.19
Time: 15:06:40
Terminal 15 status: On
Terminal 50 status: OFF
CAN-Bus_aktiv: On
Status Bremslichtschalter (HW): On
Status Bremslichtschalter (CAN): On
OFF: operated
Position lamps: Not operated
Low beam: Not operated
Voltage: 9.0 V
534549 - Databus
[FLA_01 Datenbus fehlende Botschaft]
Reset counter: 78
Mileage: 155124 km
Date: 2025.03.18
Time: 20:15:28
CAN-Bus_aktiv: On
OFF: operated
last_wakeup: gültiges Funktelegramm
Voltage: 11.8 V
Outside temperature: 11.0 °C
66314 - Positioning Motors for Headlight Range
B1528 F1 [00001000] - Control Voltage Implausible
Reset counter: 78
Mileage: 155126 km
Date: 2025.03.19
Time: 15:56:32
CAN-Bus_aktiv: On
OFF: Not operated
Voltage: 14.6 V
Part No SW: 5QA 919 294 B HW: 5QA 919 294
Serial number: 000308418617307 Dataset Number: V03935265MW 0001
Coding: 0471451811
VCID: CBD62E716272EDC3E2-809E
Part No SW: 2Q0 907 572 M HW: 2Q0 907 572 B
Component: ACCCONTIMQB H02 0233
Dataset Number: V03935267BZ 0001
Coding: 320067C150FF8728749C8145804087
ROD: EV_ACCMRRCONTIVW376_002_VW37.rod
VCID: BE3077A521C0486B75-80EA
2111 - Databus
[FAULT_ESP_CONS_ACC]
Reset counter: 78
Mileage: 155124 km
Date: 2025.03.18
Time: 20:16:22
Voltage terminal 15: 11.7 V
Control Module temperature: 29 °C
Longitudinal_acceleration_vehicle_reference: -0.03 m/s²
2109 - Databus
[FAULT_AWV_CONSISTENCY_FAIL]
Reset counter: 78
Mileage: 155124 km
Date: 2025.03.18
Time: 20:16:22
2068 - Databus
[FAULT_TSK_IRREV_FAIL]
Reset counter: 78
Mileage: 155124 km
Date: 2025.03.18
Time: 20:16:22
Voltage terminal 15: 11.6 V
1389 - Function Restricted due to Insufficient Voltage
[FAULT_VBAT_BUSMON_LOW]
Reset counter: 78
Mileage: 155124 km
Date: 2025.03.18
Time: 20:30:52
Voltage terminal 15: 9.8 V
Control Module temperature: 52 °C
Part No SW: 5Q0 959 655 BJ HW: 5Q0 959 655 BJ
Component: AirbagVW21 005 0336
Serial number: 003VWM05MBMJ Dataset Number: V03935271PH 0001
Coding: 98CCC0C0000000005C5450CF008800000065
VCID: 895AD479288EBFD310-80DC
Left seat belt tensioner:
Serial number: 5NC857705C0324R01233
Coding: 80000D
Right seat belt tensioner:
Serial number: 5NC857706C0314R01316
Coding: 80000D
Subsystem 3 - Part No SW: ----------- HW: 480 002 511 17
Serial number: 35700000000EC438182O
Subsystem 4 - Part No SW: ----------- HW: 480 002 311 17
Serial number: 358000000001B03D882J
Subsystem 5 - Part No SW: ----------- HW: 480 401 211 17
Serial number: 3510001B5283EEF6357H
Subsystem 6 - Part No SW: ----------- HW: 480 402 511 17
Serial number: 3520001B52839D02F430
Subsystem 7 - Part No SW: ----------- HW: 480 400 912 17
Serial number: 3550001BB28637D45132
1054464 - Databus
[NWD: 0x117 ACC_10 Timeout]
Reset counter: 78
Mileage: 155124 km
Date: 2025.03.18
Time: 20:15:24
Part No SW: 5Q0 953 507 GK HW: 5Q0 953 549 E
Revision: -------- Serial number: 08121708490550
Coding: 0C10
ROD: EV_SMLSKLOMQB_018_VW37.rod
VCID: 8542D8490496DBB374-80D0
Part No SW: 5NA 920 951 B HW: 5NA 920 951 B
Component: KOMBI 380 0310
Coding: 27A40808E780060001886B031401000000000000
VCID: C0CC095D5B343E9B07-8094
16777010 - Function Restricted due to Interrupted Communications
U1110 00 [00001000] - -
[BAP_LDW_0x19 keine Kommunikation]
Reset counter: 78
Mileage: 155124 km
Date: 2025.03.18
Time: 20:15:28
16777028 - Function Restricted due to Interrupted Communications
[BAP_AWV_0x1B keine Kommunikation]
Reset counter: 78
Mileage: 155124 km
Date: 2025.03.18
Time: 20:15:28
16776960 - Databus
[ACC_02 keine Kommunikation]
Reset counter: 78
Mileage: 155124 km
Date: 2025.03.18
Time: 20:15:23
16776961 - Databus
[ACC_04 keine Kommunikation]
Reset counter: 78
Mileage: 155124 km
Date: 2025.03.18
Time: 20:15:23
16776969 - Databus
[LDW_02 keine Kommunikation]
Reset counter: 78
Mileage: 155124 km
Date: 2025.03.18
Time: 20:15:24
16776980 - Databus
[PLA_Status_01 keine Kommunikation]
Reset counter: 78
Mileage: 155124 km
Date: 2025.03.18
Time: 20:15:24
Part No SW: 3Q0 907 530 L HW: 3Q0 907 530 C
Component: GW MQB High 518 5323
Serial number: 02111700841603 Dataset Number: V03935276MG 0001
Coding: 030500045F087300FB07225C1E0F00010001070000000000000000000000
Shop #: WSC 00066 790 00442
GVL: 01D43C0008000000408C80000000C80000000000000000000000000000000000
ROD: EV_GatewNF_VW37.rod
VCID: B83C61BD03E4765BBF-80EC
Generator:
Subsystem 2 - Part No SW: 5TA 959 442 B HW: 5TA 959 442 B Labels: 3C8-959-537.CLB
Serial number: 3211702312200263AS2B
Coding: 2D0000
Subsystem 3 - Part No SW: 5QA 915 181 D HW: 5QA 915 181 D
Serial number: 4771495500
131594 - Parallel Parking Assistance Control Module
U104E 00 [00001000] - No communication
[Timeout Knoten 0x0A / 76 - Steuergerät für Parklenkassistent]
Reset counter: 78
Mileage: 155124 km
Date: 2025.03.18
Time: 20:15:26
Terminal 30 power supply: 11.8 V
Terminal 15: On
66054 - Extended CAN Bus (SAE Bus C)
U0047 00 [00001000] - Performance
[Globaler Timeout CAN-Extended]
Reset counter: 78
Mileage: 155124 km
Date: 2025.03.18
Time: 20:15:26
Terminal 30 power supply: 11.7 V
Terminal 15: On
Address 22: AWD (J492) Labels:| 0CQ-907-554-V1.clb
Part No SW: 0CQ 907 554 J HW: 0CQ 525 130
Serial number: HA1-00020.09.17 Dataset Number: v1260x015G0 0000
Coding: 0101
VCID: CCD42D6D677CEAFBEB-8098
Part No SW: 5Q4 959 593 E HW: 5Q4 959 593 B
Component: TSG FS 011 0032
Serial number: 5038734400414 Dataset Number: V03935269KM 0001
Coding: 00310A20D001028000001000
VCID: C7DE12417E1A09A3C6-8092
Subsystem 1 - Part No SW: TTT 959 812 G HW: TTT 959 812 G
Component: Fond FHSG DRV 010 0004
Serial number: 00000000000000095908
Coding: 0D0000
Component: EPS_MQB_ZFLS 128 1072
Dataset Number: V03935265ZN 0001
Coding: 9107
ROD: EV_SteerAssisMQB_013.rod
VCID: C5C2184944161BB334-8090
21760 - Databus
[HCA_01 Botschaft - CAN-Timeout]
Reset counter: 78
Mileage: 155124 km
Date: 2025.03.18
Time: 20:15:28
Motor status: 00
Supply voltage: 11.75 V
Temperature: 20.0 °C
KFC: 55
KFA: 00 00
Freeze frame conditions: 20
uioUdNotFilt_xdu16: 11.72 V
uAdSensI_SwitchedKl30_xdu16: 11.72 V
RP_VALCNTSAV: not activated
RP_DIAGJOB: not activated
RP_RPS: not activated
RP_STARTUP: not activated
RP_L2PLAUSI: not activated
RP_INDEXPLAUSI: not activated
RP_RUKUCNTR: not activated
RP_UNDERVOLT: not activated
RP_CNTERR: not activated
Part No SW: 5Q4 959 592 E HW: 5Q4 959 592 B
Component: TSG BFS 011 0032
Serial number: 6038734201126 Dataset Number: V03935269KN 0001
Coding: 00310220DE01028000001000
VCID: C6C01F45791010AB3D-8092
Subsystem 1 - Part No SW: TTT 959 811 G HW: TTT 959 811 G
Component: Fond FHSG PSG 010 0004
Serial number: 00000000000000099881
Coding: 050000
Part No SW: 3Q0 035 874 C HW: 3Q0 035 874 C
Component: MU-S-ND-ER 851 0867
Serial number: Dataset Number: V03935274HW 0001
Coding: 02730601FF00000051110101008808001F0500C601200100CF
ROD: EV_MUStd4CDELP_VW37.rod
VCID: B2285395E5989C0B81-80E6
Subsystem 1 - Part No SW: 5G6 919 605 B HW: 5G6 919 605 B
Component: ABT_Std-2_Nav H50 8130
Serial number: VWZ6ZHT3610716
Subsystem 2 - Part No SW: 3G0 919 866 BC HW: -----------
Component: ECE1 2017/18 --- 0820
8 Faults Found:
6917 - Function Restricted due to Missing Message(s)
U1111 00 [00001000] - -
[ACC (0x05) - function restriction due to communication error - BapErr_timeout: heartbeat]
Reset counter: 78
Mileage: 155124 km
Date: 2025.03.18
Time: 20:15:28
Voltage terminal 30: 11.8 V
6922 - Function Restricted due to Missing Message(s)
[Park assist OPS (0x0A) - function restriction due to communication error - BapErr_timeout: heartbeat]
Reset counter: 78
Mileage: 155124 km
Date: 2025.03.18
Time: 20:15:28
6937 - Function Restricted due to Missing Message(s)
[Lane departure warning: heading control (0x19) - function restriction due to communication error - BapErr_timeout: heartbeat]
Reset counter: 78
Mileage: 155124 km
Date: 2025.03.18
Time: 20:15:29
6939 - Function Restricted due to Missing Message(s)
[Brake assist system (0x1B) - function restriction due to communication error - BapErr_timeout: heartbeat]
Reset counter: 78
Mileage: 155124 km
Date: 2025.03.18
Time: 20:15:28
7173 - Function Restricted due to Missing Message(s)
[ACC (0x05) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 78
Mileage: 155124 km
Date: 2025.03.18
Time: 20:15:31
BAP-BAP_Function_ID: 02
7178 - Function Restricted due to Missing Message(s)
[Park assist OPS (0x0A) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 78
Mileage: 155124 km
Date: 2025.03.18
Time: 20:15:31
7193 - Function Restricted due to Missing Message(s)
[Lane departure warning: heading control (0x19) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 78
Mileage: 155124 km
Date: 2025.03.18
Time: 20:15:32
Voltage terminal 30: 11.7 V
7195 - Function Restricted due to Missing Message(s)
[Brake assist system (0x1B) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 78
Mileage: 155124 km
Date: 2025.03.18
Time: 20:15:31
Part No SW: 5Q0 959 107 L HW: 5Q0 959 107 J
Component: HDSG-Modul H13 0261
Revision: -------- Serial number: ÿÿÿÿÿÿÿÿÿÿÿÿÿÿ Dataset Number: V03935260AR 0001
Coding: 0A00
VCID: C1CA0C59503E379308-8094
Part No SW: 3QD 980 654 HW: 3Q0 980 654 A
Component: MQB_B_MFK H08 1272
Serial number: 20091741P22232 Dataset Number: V03935276DX 0001
Coding: 0003070601020401000213448150A90084000E000020
VCID: 885CD17D3384C6DB0F-80DC
End----------(Elapsed Time: 01:42, VBatt start/end: 13.3V/13.3V)-----------
------------------------------32 Faults Found------------------------------
;SW:5Q0-937-086-BK HW:5Q0-937-086-BF --- Cent. Elect.
;Component:BCM PQ37BOSCH 034 0245, Coding:
;EV_BodyContrModul1UDSBosc,018001,EV_BCMBOSCH_018.rod
;Thursday,20,March,2025,11:39:22:46973
;VCDS Version: Release 25.3.0 (x64) Data version: 20250311 DS365.0
;VCID: 8444C54D0FACE2BB63-80D0
Group,Description,Actual
IDE00356-IDE00355,Cruise Control System (CCS): switch position-Cruise Control System (CCS): status,not coded/not installed,
IDE00356-MAS00125,Cruise Control System (CCS): switch position-Cruise control system,not coded/not installed,
IDE00356-MAS00128,Cruise Control System (CCS): switch position-Distance Regulation,not coded/not installed,
IDE00356-MAS00320,Cruise Control System (CCS): switch position-Main switch,not coded/not installed,
IDE00356-MAS00323,Cruise Control System (CCS): switch position-Tap delay,not coded/not installed,
IDE00356-MAS00325,Cruise Control System (CCS): switch position-Set,not coded/not installed,
IDE00356-MAS00326,Cruise Control System (CCS): switch position-Resume,not coded/not installed,
IDE00356-MAS02321,Cruise Control System (CCS): switch position-Cancel,NOT-DEFINED,
IDE00356-MAS02343,Cruise Control System (CCS): switch position-Station coding,not coded/not installed,
IDE00356-MAS03758,Cruise Control System (CCS): switch position-Not assigned,not coded/not installed,
IDE00356-MAS05138,Cruise Control System (CCS): switch position-Operating part,not coded/not installed,
IDE00374-MAS05377,Electric auxiliary heater: relay activation-Low heat output relay,not coded/not installed,
IDE00374-MAS05378,Electric auxiliary heater: relay activation-High heat output relay,not coded/not installed,
IDE00550-IDE00047,Identification of parameterization-Parameter set version,11 41,
IDE00844-MAS07314,Switch for engine hood-Status engine hood contact,closed,
IDE00844-ENG122175,Switch for engine hood-Bonnet_Magnetic_Lock,not coded/not installed,
IDE00973,Outside temperature,12.00, °C
IDE01066-IDE02092,Convertible top status-Tailgate condition,not coded/not installed,
IDE01066,Convertible top status,not coded/not installed,
IDE01464-IDE04741,Rear window defogger-Rear window defogger button,Not operated,
IDE01464-IDE04744,Rear window defogger-Rear window defogger indicator lamp,OFF,
IDE01537-IDE04742,Windshield defogger-Windshield defogger button,not coded/not installed,
IDE01537-IDE04743,Windshield defogger-Windshield defogger indicator lamp,not coded/not installed,
IDE01537-MAS01580,Windshield defogger-Activation,not coded/not installed,
IDE01943,Turn signal lamp,|Connector number,Connector terminal number,Duty cycle,Signal state,Diagnosis|Connector B,36,0.0,not active,normal|Connector B,20,0.0,not active,normal|Connector A,60,0.0,not active,normal|Plug C,31,0.0,not active,normal|,
IDE02092-IDE02093,Tailgate condition-Status of rear lid lock,not coded/not installed,
IDE02092-IDE02133,Tailgate condition-Activation using rear lid unlocking button,OFF,
IDE02092-MAS01872,Tailgate condition-Rear lid remote release button,Not operated,
IDE02092-MAS02405,Tailgate condition-Pre-engagement contact for rotary latch,Closed,
IDE02092-MAS02447,Tailgate condition-Release,Enabled,
IDE02092-MAS06265,Tailgate condition-Release button in rear lid handle,Not operated,
IDE02092-MAS06430,Tailgate condition-Main notch contact of rotary latch,Closed,
IDE02488-MAS01632,Anti-theft system interior monitoring-Status,not active,
IDE02488-MAS04508,Anti-theft system interior monitoring-Alarm detected,No,
IDE02515,Low beam,|Connector number,Connector terminal number,Duty cycle,Signal state,Diagnosis|Plug C,5,98.0,active,normal|Connector B,1,96.5,active,normal|,
IDE02588-IDE00020,Terminal signals and start release-Terminal 15 status,active,
IDE02588-IDE00773,Terminal signals and start release-Terminal 15 status via CAN,active,
IDE02588-IDE01351,Terminal signals and start release-Terminal 75 status,On,
IDE02588-IDE01715,Terminal signals and start release-Status terminal S,active,
IDE02588-IDE01716,Terminal signals and start release-Terminal 50 status,OFF,
IDE02588-IDE06027,Terminal signals and start release-Terminal S status via CAN,active,
IDE02588-MAS12787,Terminal signals and start release-Terminal 15 ignition switch signal 1,active,
IDE02588-MAS12788,Terminal signals and start release-Terminal 15 ignition switch signal 2,active,
IDE02614-MAS02788,Reversing light switch-CAN,not active,
IDE02614-MAS05360,Reversing light switch-Discreet wire,not active,
IDE02711,Rear wiper,not active,
IDE02743,High Beam,|Connector number,Connector terminal number,Duty cycle,Signal state,Diagnosis|Connector B,39,0.0,not active,normal|Connector B,2,0.0,not active,normal|,
IDE02744-MAS01632,Steering wheel heating-Status,not coded/not installed,
IDE02744-MAS02311,Steering wheel heating-Steering wheel heating button,not coded/not installed,
IDE02744-MAS04136,Steering wheel heating-Current,0.00, A
IDE02744-MAS09758,Steering wheel heating-Temperature sensor,188, °C
IDE02857-IDE03111,Activation current-Interior lighting,490, mA
IDE02857-IDE05533,Activation current-Heater for nozzles,0, mA
IDE02857-IDE06012,Activation current-Background lighting,70, mA
IDE02857-MAS01554,Activation current-Left heated seat,0, mA
IDE02857-MAS01556,Activation current-Right heated seat,0, mA
IDE02857-ENG128454,Activation current-Cockpittaster_1,0, mA
IDE02857-ENG128455,Activation current-Cockpittaster_2,65532, mA
IDE02857-ENG128456,Activation current-Cockpittaster_3,65532, mA
IDE02857-ENG128457,Activation current-Cockpittaster_4,65532, mA
IDE02857-ENG128458,Activation current-DWA_Einfachhorn,65532, mV
IDE02857-ENG126436,Activation current-signal_horn,65533, mV
IDE02957,Ambient lighting,|Channel,Connector number,Connector terminal number,Duty cycle,Signal state,Diagnosis|Not available,not coded/not installed,0,0.00,NOT-DEFINED,not coded/not installed|,
IDE03111,Interior lighting,|Connector number,Connector terminal number,Duty cycle,Signal state,Diagnosis|Plug C,12,98.50,active,normal|,
IDE03195-IDE03854,High values for automatic vertical headlight aim-Left front level control system sensor: height value current,0.0,
IDE03195-IDE04144,High values for automatic vertical headlight aim-Left rear level control system sensor: height value current,0.0,
IDE03195-IDE07143,High values for automatic vertical headlight aim-Vehicle level sensor: supply voltage,13.0, V
IDE03195-MAS13964,High values for automatic vertical headlight aim-Spec. value: activation vehicle level sensor,15.0,
IDE03195-MAS13965,High values for automatic vertical headlight aim-Vehicle level sensor: control voltage,11.0, V
IDE03310,Brake lamp,|Connector number,Connector terminal number,Duty cycle,Signal state,Diagnosis|Connector A,71,10.0,active,normal|Plug C,8,10.0,active,normal|Connector A,57,0.0,not active,normal|,
IDE03388-IDE01217,Left front heated seat: status-Left heated seat stage,not coded/not installed,
IDE03388-MAS02201,Left front heated seat: status-Temperature,not installed,
IDE03389-IDE01218,Right front heated seat: status-Right heated seat stage,not coded/not installed,
IDE03389-MAS02201,Right front heated seat: status-Temperature,not installed,
IDE03504,Personalized settings,|profile,Comfort opening,Sunroof,Electrical rear lid,Manual door unlock,Rain closure,Mirror adjustment,Mirror lowering,Automatic mirror fold-in,Activation sound: theft warning system,Auto lock,Auto unlock,Virtual pedal,Automatic rear window wiper,Tourist light,Status Coming Home,Status Leaving Home,Coming Home set point,Leaving Home set point,Light intensity,Comfort flasher,Comfort flasher set point,Adaptive light functions,High beam assistant: status,Sliding beam range,Masked continuous high beam,Rain light,Touristenlicht Einstellwert|1,All windows,not active,not active,Unlock. indiv. doors,not active,synchronous,active,active,not active,active,not active,not active,active,not active,active,active,5,5,normal,active,3,not active,active,active,active,active,not active|,
IDE03638,Stationary cornering lamp,|Connector number,Connector terminal number,Duty cycle,Signal state,Diagnosis|Connector B,45,0.0,not active,normal|Connector B,5,97.0,active,normal|,
IDE04213,Central locking button,not coded/not installed,
IDE04213-IDE07357,Central locking button-Indicator lamp for central locking,not coded/not installed,
IDE04254-MAS06517,Play protection for central locking-Rear spoiler counter,not active,
IDE04347-IDE00104,Expanded freeze frame conditions-DTC,00 00 00,
IDE04347-IDE07836,Expanded freeze frame conditions-Log data,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE04925,Daytime running lights,|Connector number,Connector terminal number,Duty cycle,Signal state,Diagnosis|not coded/not installed,0,0.0,Measuring value not available,not coded/not installed|,
IDE05042-MAS03873,Emergency flasher button-Duty cycle,25.50, %
IDE05045-IDE05183,Front wiper module-Malfunction left,No malfunction,
IDE05045-IDE05184,Front wiper module-Malfunction right,No malfunction,
IDE05045-MAS03638,Front wiper module-Wipe speed,0, /min
IDE05045-MAS05057,Front wiper module-Number of wiper cycles,633200,
IDE05045-MAS05878,Front wiper module-Stage,not coded/not installed,
IDE05323,Fog lamp,|Connector number,Connector terminal number,Duty cycle,Signal state,Diagnosis|Connector B,10,25.5,active,normal|Connector B,21,25.5,active,normal|Connector B,45,0.0,not active,normal|Connector B,5,97.0,active,normal|,
IDE05434,Rear entry light,|Connector number,Side,Connector terminal number,Duty cycle,Signal state,Diagnosis|not coded/not installed,Unknown (0),0,0.00,Measuring value not available,not coded/not installed|,
IDE05533,Heater for nozzles,not coded/not installed,
IDE05719-IDE05534,Window washer system-Headlamp washer system,not coded/not installed,
IDE05719-MAS02341,Window washer system-Rear window washer system,not active,
IDE05720-IDE02589,Front driver side door status-Rotary latch status,closed,
IDE05720-IDE04213,Front driver side door status-Central locking button,Not operated,
IDE05722-IDE02589,Door status: driver side rear-Rotary latch status,closed,
IDE05722-IDE04213,Door status: driver side rear-Central locking button,not coded/not installed,
IDE05722-MAS06256,Door status: driver side rear-Status door lock,Signal from door lock: released,
IDE05727-IDE04213,Front passenger side door status-Central locking button,Not operated,
IDE05727-IDE04214,Front passenger side door status-Key switch in door lock,Not operated,
IDE05729-IDE02589,Door status: frt. pass. side rear-Rotary latch status,Open,
IDE05729-IDE04213,Door status: frt. pass. side rear-Central locking button,not coded/not installed,
IDE05729-MAS06256,Door status: frt. pass. side rear-Status door lock,Signal from door lock: released,
IDE05730,Luggage compartment light,|Connector number,Connector terminal number,Duty cycle,Signal state,Diagnosis|not coded/not installed,0,0.00,Measuring value not available,not coded/not installed|,
IDE05739,Footwell lamp,|Connector number,Connector terminal number,Duty cycle,Signal state,Diagnosis|Plug C,72,61.0,active,normal|,
IDE05742-IDE02515,Light switch position-Low beam,Not operated,
IDE05742-IDE05323,Light switch position-Fog lamp,Not operated,
IDE05742-IDE07956,Light switch position-redundant signal line,OFF,
IDE05742-MAS00063,Light switch position-OFF,Not operated,
IDE05742-MAS02462,Light switch position-Automatic high beam assist,operated,
IDE05742-MAS03835,Light switch position-Position lamps,Not operated,
IDE05742-MAS03836,Light switch position-Rear fog lamp,Not operated,
IDE05822-MAS01632,Anti-theft alarm system vehicle inclination sensor-Status,not active,
IDE05822-MAS04508,Anti-theft alarm system vehicle inclination sensor-Alarm detected,No,
IDE05824-MAS04583,DWA Vehicle inclination sensor: angle-Reference angle: X-axis,-19.40, °
IDE05824-MAS04584,DWA Vehicle inclination sensor: angle-Reference angle: Y-axis,Implausible,
IDE05824-MAS04585,DWA Vehicle inclination sensor: angle-Reference angle: Z-axis,1.60, °
IDE05824-MAS04586,DWA Vehicle inclination sensor: angle-Angle difference: X-axis,0.00, °
IDE05824-MAS04587,DWA Vehicle inclination sensor: angle-Angle difference: Y-axis,Implausible,
IDE05824-MAS04588,DWA Vehicle inclination sensor: angle-Angle difference: Z-axis,0.00, °
IDE05825-MAS02594,DWA Interior monitoring/vehicle inclination sensor button-Indicator light in switch,not coded/not installed,
IDE05825-MAS04247,DWA Interior monitoring/vehicle inclination sensor button-Button,not coded/not installed,
IDE05826-MAS01632,DWA Sirens / alarm horn for anti-theft warning system-Status,not active,
IDE05826-MAS04508,DWA Sirens / alarm horn for anti-theft warning system-Alarm detected,No,
IDE05826-MAS04509,DWA Sirens / alarm horn for anti-theft warning system-Alarm activated,No,
IDE05827,Horn for anti-theft warning system,not coded/not installed,
IDE05828-MAS06608,DWA History data for alarm triggering-Cause for last alarm activation,Alarm trigger via anti-theft alarm system master,
IDE05828-MAS06609,DWA History data for alarm triggering-Cause for second-to-last alarm activation,Alarm trigger via anti-theft alarm system master,
IDE05828-MAS06610,DWA History data for alarm triggering-Cause for third-to-last alarm activation,Alarm trigger via anti-theft alarm system master,
IDE05828-MAS06611,DWA History data for alarm triggering-Cause for fourth-to-last alarm activation,Alarm trigger via anti-theft alarm system master,
IDE05828-MAS06613,DWA History data for alarm triggering-Number of alarm activations,9,
IDE05829,Rear spoiler history data,|Spoiler_Activation_Trigger,Spoiler_Activation_Trigger_Date,Spoiler_Activation_Trigger_Time,Spoiler_Activation_Trigger_Milage|NoEntry,0,0,0|NoEntry,0,0,0|NoEntry,0,0,0|NoEntry,0,0,0|NoEntry,0,0,0|NoEntry,0,0,0|NoEntry,0,0,0|NoEntry,0,0,0|NoEntry,0,0,0|NoEntry,0,0,0|, km
IDE05830-MAS02282,Rear Spoiler-Position,not coded/not installed,
IDE05830-ENG115793,Rear Spoiler-Spoiler_Button,not coded/not installed,
IDE05830-ENG115792,Rear Spoiler-Spoiler_Cycle_Protection,not coded/not installed,
IDE05830-ENG115794,Rear Spoiler-Spoiler_Indication_Light,not coded/not installed,
IDE05830-ENG115791,Rear Spoiler-Spoiler_Position,not coded/not installed,
IDE05832,DWA Number of alarms triggered in anti-theft warn.system sensor,10,
IDE05833,Anti-theft warning system: history data,|Cause for alarm activation,Odometer reading,Year,Month,Day,Hours,Minutes,Seconds|Interior monitoring alarm (windows / roof closed),154665,2025,3,1,14,50,41|Interior monitoring alarm (windows / roof closed),154665,2025,3,1,14,45,50|Interior monitoring alarm (windows / roof closed),137561,2024,8,15,15,12,28|Interior monitoring alarm (windows / roof closed),122527,2024,3,30,14,34,33|Interior monitoring alarm (windows / roof closed),122527,2024,3,30,14,31,51|Interior monitoring alarm (windows / roof closed),104371,2023,9,22,13,26,27|Interior monitoring alarm (windows / roof closed),104371,2023,9,22,13,24,9|Interior monitoring alarm (windows / roof partly open),41,2011,9,30,10,50,26|unauthorised ignition,26,2011,9,10,9,4,11|No alarm,0,2000,0,0,0,0,0|,
IDE05834-IDE01718,Driver info-Crash signal,not active,
IDE05834-MAS00212,Driver info-Insufficient washer fluid,not active,
IDE05834-MAS00214,Driver info-Brake pad wear,not active,
IDE05836-MAS03637,Rain recognition sensor-Rain quantity,0,
IDE05838-MAS02248,Light recognition sensor-Signal state,active,
IDE05838-MAS02475,Light recognition sensor-Brightness infrared,800, lx
IDE05838-MAS02851,Light recognition sensor-Brightness,390, lx
IDE05838-MAS04809,Light recognition sensor-Darkness,On,
IDE05838-MAS04810,Light recognition sensor-Request for light activation,On,
IDE05839,Parking lamps,|Connector number,Connector terminal number,Duty cycle,Signal state,Diagnosis|Connector B,10,25.5,active,normal|Connector B,21,25.5,active,normal|Connector B,4,100.0,active,normal|Connector B,32,100.0,active,normal|Connector A,71,10.0,active,normal|Plug C,8,10.0,active,normal|Plug C,10,100.0,active,normal|Connector A,65,100.0,active,normal|,
IDE05841,Central locking history data,|Control-section / cause,command_direction_locking,command_direction_unlocking,Command,Additional information|Auto unlock,Lock door,no_unlocking,Unlocking of entire vehicle,Measuring value not available|Auto lock,No_locking,no_unlocking,lock,Measuring value not available|Remote control,Lock door,no_unlocking,Unlocking of entire vehicle,Rem. ctrl. no. 2|Remote control,Lock door,no_unlocking,Unlock. indiv. doors,Rem. ctrl. no. 2|Remote control,Lock door,no_unlocking,Unlock. indiv. doors,Rem. ctrl. no. 2|Remote radio control: button for luggage compartment unlocking,Lock door,no_unlocking,Individual rear unlock.,Rem. ctrl. no. 2|Remote radio control: button for luggage compartment unlocking,Lock door,no_unlocking,Individual rear unlock.,Rem. ctrl. no. 2|Remote control,No_locking,no_unlocking,safe,Rem. ctrl. no. 2|Auto unlock,Lock door,no_unlocking,Unlock. indiv. doors,Measuring value not available|Auto lock,No_locking,no_unlocking,lock,Measuring value not available|,
IDE05842,Comfort function history data,|Control-section / cause,Operating command,convertible top,Sun roof/tilt roof,Driver door,Front Passenger Door,Rear left door,Rear right door|radio remote control number_2,Close,not active,not active,not active,active,not active,not active|radio remote control number_1,Close,not active,not active,active,not active,not active,not active|radio remote control number_1,Close,not active,not active,not active,not active,not active,active|tab for electric window: driver door,Close,not active,not active,active,not active,not active,not active|radio remote control number_1,Close,not active,not active,active,not active,not active,not active|radio remote control number_1,Close,not active,not active,active,active,active,active|radio remote control number_1,Open,not active,not active,active,active,active,active|keine Bedienstelle,Open,not active,not active,not active,not active,not active,not active|keine Bedienstelle,Open,not active,not active,not active,not active,not active,not active|keine Bedienstelle,Open,not active,not active,not active,not active,not active,not active|,
IDE06012,Background lighting,|Connector number,terminal,Connector terminal number,Duty cycle,Signal state,Diagnosis|Plug C,Variant A,62,98.0,active,normal|,
IDE06091-IDE01440,Humidity sensor: interior-Front windshield temperature,-38.7, °C
IDE06091-MAS04629,Humidity sensor: interior-Sensor temperature,22.0, °C
IDE06091-MAS04630,Humidity sensor: interior-Relative humidity,44.0, %
IDE06091-MAS04647,Humidity sensor: interior-Dew point,-38.9, °C
IDE06096-IDE03111,Interior lights-Interior lighting,100, %
IDE06096-IDE05724,Interior lights-Dimmer terminal 58xt,100.0, %
IDE06096-IDE05725,Interior lights-Dimmer terminal 58xs,100.0, %
IDE06096-IDE05726,Interior lights-Dimmer terminal 58xd,100.0, %
IDE06096-MAS01634,Interior lights-Supply voltage,98.0, %
IDE06096-MAS04528,Interior lights-Instrument panel and switch illumination dimmer switch,100, %
IDE06324-IDE04217,Tank cap lock-Fuel filler door release button,not coded/not installed,
IDE06324-MAS01580,Tank cap lock-Activation,not active,
IDE06324-MAS06251,Tank cap lock-Contact switch,not coded/not installed,
IDE06470,Periphery lighting,|Connector number,Connector terminal number,Duty cycle,Signal state,Diagnosis|not coded/not installed,0,0.0,Measuring value not available,not coded/not installed|,
IDE06507-MAS13127,Button in center console-Status of button 1,Not operated,
IDE06507-MAS13128,Button in center console-Indicator lamp button 1,OFF,
IDE06507-MAS13130,Button in center console-Status of button 2,not coded/not installed,
IDE06507-MAS13131,Button in center console-Indicator lamp button 2,not coded/not installed,
IDE06507-MAS13133,Button in center console-Status of button 3,not coded/not installed,
IDE06507-MAS13134,Button in center console-Indicator lamp button 3,not coded/not installed,
IDE06507-MAS13136,Button in center console-Indicator lamp button 4,not coded/not installed,
IDE06507-MAS13137,Button in center console-Status of button 4,not coded/not installed,
IDE06644-IDE06864,Vehicle positioning system-Daytime running lights,not coded/not installed,
IDE06644-MAS01288,Vehicle positioning system-Horn,not coded/not installed,
IDE06644-MAS03834,Vehicle positioning system-Emergency signal flashing,not coded/not installed,
IDE06644-MAS03835,Vehicle positioning system-Position lamps,not coded/not installed,
IDE06695,Energy management: last critical state,|Energy management heat output control status,Maximum switch-off priority while driving,Number of critical operation cycles,min_prio_Tab_K,min_prio_Tab_M,Anz_krit_Betriebszyklen,min_prio_Tab_NQ,Bedingung_Tab_NQ,Anz_erreichte_Max_Freigaben,Year,Month,Day|0,0,0,0,0,0,0,0,0,2000,0,0|0,0,0,0,0,0,0,0,0,2000,0,0|0,0,0,0,0,0,0,0,0,2000,0,0|,
IDE06864,Daytime running lights,|Connector number,Connector terminal number,Duty cycle,Signal state,Diagnosis|Connector B,10,25.5,active,normal|Connector B,21,25.5,active,normal|Connector B,4,100.0,active,normal|Connector B,32,100.0,active,normal|,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,00,
IDE07187-MAS06538,Level control system sensor-Left Front Level Control System Sensor: PWM signal,655.35, %
IDE07187-MAS06539,Level control system sensor-Left Rear Level Control System Sensor: PWM signal,655.35, %
IDE07187-MAS06540,Level control system sensor-Left front level control system sensor: frequency,6553.5, Hz
IDE07187-MAS06541,Level control system sensor-Left Rear Left Control System Sensor: frequency,6553.5, Hz
IDE07187-MAS06542,Level control system sensor-Vehicle level sensor: supply voltage,65.535, V
IDE07344-IDE00542,Sunroof shade-Excessive temperature protection,not active,
IDE07344-IDE03114,Sunroof shade-Comfort function,not active,
IDE07344-MAS01979,Sunroof shade-Adapting,Not adapted,
IDE07344-MAS02282,Sunroof shade-Position,0, %
IDE07344-MAS02447,Sunroof shade-Release,not active,
IDE07344-MAS03656,Sunroof shade-Reverse,not active,
IDE07344-MAS05563,Sunroof shade-Norming,not normed,
IDE07345-MAS07997,Sunroof front closed position switch-Rotary switch activation,Implausible,
IDE07345,Sunroof front closed position switch,Not operated,
IDE07345-ENG122183,Sunroof front closed position switch-rotary_switch_position,Closed,
IDE07346,Sunroof shade switches,Not operated,
IDE08125-MAS01458,Left head area heater-Operating condition,not coded/not installed,
IDE08125-MAS06651,Left head area heater-PTC heater element: current consumption,not coded/not installed,
IDE08125-MAS06652,Left head area heater-Blower motor: speed,not coded/not installed,
IDE08125-MAS06653,Left head area heater-Indicator light for head area heater,not coded/not installed,
IDE08126-MAS01458,Right head area heater-Operating condition,not coded/not installed,
IDE08126-MAS06651,Right head area heater-PTC heater element: current consumption,not coded/not installed,
IDE08126-MAS06652,Right head area heater-Blower motor: speed,not coded/not installed,
IDE08126-MAS06653,Right head area heater-Indicator light for head area heater,not coded/not installed,
IDE08177-MAS06456,Central locking-Auto lock,not active,
IDE08177-MAS06740,Central locking-Release button in rear lid handle locked,not active,
IDE08177-MAS09894,Central locking-Status exterior skin,Open,
IDE08177-MAS09896,Central locking-Act. condition: Status central locking internal locked,not active,
IDE08177-MAS09897,Central locking-Act. condition: Status central locking external locked,not active,
IDE08177-MAS09898,Central locking-Act. condition: Status central locking safe,not active,
IDE08177-MAS09900,Central locking-Spec. condition: Status central lock,Signal from door lock: released,
IDE08177-ENG140257,Central locking-Load_compartment_closing,not coded/not installed,
IDE08211-MAS00106,History data control module reset-Year,2000,
IDE08211-MAS00107,History data control module reset-Month,0,
IDE08211-MAS00108,History data control module reset-Day,0,
IDE08211-MAS00109,History data control module reset-Hours,0,
IDE08211-MAS00110,History data control module reset-Minutes,0,
IDE08211-MAS03129,History data control module reset-Reset counter,8,
IDE08211-MAS06734,History data control module reset-last cause of reset,Knockouttimer_abgelaufen,
IDE08343,Immobilizer Challenge,9B 7C 4B AF,
IDE08949-MAS07869,Operating current: light driver-Conn. pin 2,0, mA
IDE08949-MAS07870,Operating current: light driver-Conn. pin 3,10, mA
IDE08949-MAS07871,Operating current: light driver-Conn. pin 4,210, mA
IDE08949-MAS07872,Operating current: light driver-Conn. pin 5,220, mA
IDE08949-MAS07873,Operating current: light driver-Conn. pin 6,4390, mA
IDE08949-MAS07874,Operating current: light driver-Conn. pin 7,4290, mA
IDE08949-MAS07875,Operating current: light driver-Conn. pin 8,10, mA
IDE08949-MAS07876,Operating current: light driver-Conn. pin 9,0, mA
IDE08949-MAS07877,Operating current: light driver-Conn. pin 10,1190, mA
IDE08949-MAS07878,Operating current: light driver-Conn. pin 11,1210, mA
IDE08949-MAS07879,Operating current: light driver-Conn. pin 12,0, mA
IDE08949-MAS07880,Operating current: light driver-Conn. pin 13,3050, mA
IDE08949-MAS07887,Operating current: light driver-Conn. pin 20,250, mA
IDE08949-MAS07888,Operating current: light driver-Conn. pin 21,230, mA
IDE08949-MAS07890,Operating current: light driver-Conn. pin 23,90, mA
IDE08949-MAS07891,Operating current: light driver-Conn. pin 24,90, mA
IDE08949-MAS07892,Operating current: light driver-Conn. pin 25,120, mA
IDE08949-MAS07897,Operating current: light driver-Conn. pin 30,40, mA
IDE09065-MAS07964,Status: remote start-Engine run time after remote start,0, s
IDE09065-MAS16464,Status: remote start-Number of RemoteStarts carried out,0,
IDE09850-MAS07146,Garage door opener control head-Button 1,not coded/not installed,
IDE09850-MAS07147,Garage door opener control head-Button 2,not coded/not installed,
IDE09850-MAS07148,Garage door opener control head-Button 3,not coded/not installed,
IDE11134-IDE01943,Light sequence HU test result-Turn signal lamp,Installed: not active,
IDE11134-IDE02515,Light sequence HU test result-Low beam,Installed: not active,
IDE11134-IDE02614,Light sequence HU test result-Reversing light switch,Installed: not active,
IDE11134-IDE02743,Light sequence HU test result-High Beam,Installed: not active,
IDE11134-IDE03310,Light sequence HU test result-Brake lamp,Installed: not active,
IDE11134-IDE03638,Light sequence HU test result-Stationary cornering lamp,Installed: not active,
IDE11134-IDE05323,Light sequence HU test result-Fog lamp,Installed: not active,
IDE11134-IDE05839,Light sequence HU test result-Parking lamps,Installed: not active,
IDE11134-IDE06470,Light sequence HU test result-Periphery lighting,not installed / not active,
IDE11134-IDE06864,Light sequence HU test result-Daytime running lights,Installed: not active,
IDE11134-MAS02354,Light sequence HU test result-Headlamp flasher,Installed: not active,
IDE11134-MAS03835,Light sequence HU test result-Position lamps,Installed: not active,
IDE11134-MAS03836,Light sequence HU test result-Rear fog lamp,Installed: not active,
IDE11134-MAS11025,Light sequence HU test result-Status,no restriction,
IDE11350-MAS12597,Sunlight photo sensor-Sun intensity left,327670, W/m²
IDE11350-MAS12598,Sunlight photo sensor-Sun intensity right,327670, W/m²
IDE11668-MAS06256,Driver side rear sliding door: central locking signals-Status door lock,not coded/not installed,
IDE11668-MAS06431,Driver side rear sliding door: central locking signals-Door contact switch,not coded/not installed,
IDE11668-MAS06433,Driver side rear sliding door: central locking signals-Door lock: safe status,not coded/not installed,
IDE11669-MAS06256,Passenger side rear sliding door: central locking signals-Status door lock,not coded/not installed,
IDE11669-MAS06431,Passenger side rear sliding door: central locking signals-Door contact switch,not coded/not installed,
IDE11669-MAS06433,Passenger side rear sliding door: central locking signals-Door lock: safe status,not coded/not installed,
IDE11670-MAS06256,Rear wing door: central locking signals-Status door lock,not coded/not installed,
IDE11670-MAS06431,Rear wing door: central locking signals-Door contact switch,not coded/not installed,
IDE11670-MAS06433,Rear wing door: central locking signals-Door lock: safe status,not coded/not installed,
IDE11727-IDE04806,Function of the central console button-Driving profile selection button,LED installed,
IDE11727-MAS13125,Function of the central console button-Function of button 1,Start-stop,
IDE11727-MAS13129,Function of the central console button-Function of button 2,not coded/not installed,
IDE11727-MAS13132,Function of the central console button-Function of button 3,not coded/not installed,
IDE11727-MAS13135,Function of the central console button-Function of button 4,not coded/not installed,
IDE11943,Signature lamp,|Connector number,Connector terminal number,Duty cycle,Signal state,Diagnosis|not coded/not installed,0,0.0,Measuring value not available,not coded/not installed|,
IDE11999-IDE03853,High values of headlight range adjustment: basic setting-Left front level control system sensor: height value adapted,-100.0,
IDE11999-IDE04143,High values of headlight range adjustment: basic setting-Left rear level control system sensor: height value adapted,-100.0,
IDE12060,Headlight range adjustment counter,A0 00 00 02,
IDE12212,Cause control module incorrectly coded,not installed,
IDE12940-IDE01268,Lever functions of the steering column electronics-Windshield wiper,not coded/not installed,
IDE12940-IDE02335,Lever functions of the steering column electronics-Signal light switch position,not coded/not installed,
IDE12940-IDE02711,Lever functions of the steering column electronics-Rear wiper,not coded/not installed,
IDE12940-MAS00232,Lever functions of the steering column electronics-MFI button UP,NOT-DEFINED,
IDE12940-MAS00233,Lever functions of the steering column electronics-MFI button DOWN,NOT-DEFINED,
IDE12940-MAS00234,Lever functions of the steering column electronics-MFI button RESET / OK,NOT-DEFINED,
IDE12940-MAS00242,Lever functions of the steering column electronics-Driver assistance systems button,not coded/not installed,
IDE12940-MAS00243,Lever functions of the steering column electronics-Buttons for driver assistance systems: status,not coded/not installed,
IDE12940-MAS01288,Lever functions of the steering column electronics-Horn,not coded/not installed,
IDE12940-MAS02338,Lever functions of the steering column electronics-Windshield wiper: intermittent stage,not coded/not installed,
IDE12940-MAS02339,Lever functions of the steering column electronics-Windshield washer system,not coded/not installed,
IDE12940-MAS02341,Lever functions of the steering column electronics-Rear window washer system,not coded/not installed,
IDE12940,Lever functions of the steering column electronics,not coded/not installed,
IDE80251-MAS06439,Head area heater-Crash status,not coded/not installed,
IDE80251-MAS06646,Head area heater-Head area heater left: specified level,not coded/not installed,
IDE80251-MAS06647,Head area heater-Head area heater right: specified level,not coded/not installed,
IDE80251-MAS06648,Head area heater-Continuation at terminal 15 on,not coded/not installed,
IDE80251-MAS06649,Head area heater-Left front seat occupation status,not coded/not installed,
IDE80251-MAS06650,Head area heater-Right front occupation status,not coded/not installed,
MAS00043-IDE00019,Terminal 30 power supply-Voltage terminal 30,13.25, V
MAS00043-IDE05835,Terminal 30 power supply-Supply voltage for central locking,13.25, V
MAS00043-IDE05967,Terminal 30 power supply-Voltage terminal 30 left,13.20, V
MAS00043-IDE05968,Terminal 30 power supply-Voltage terminal 30 right,13.20, V
MAS00043-IDE08734,Terminal 30 power supply-Supply voltage for anti-theft alarm system,5.00, V
MAS00043-IDE08735,Terminal 30 power supply-Supply voltage for seat heater,5.00, V
MAS00043-MAS00362,Terminal 30 power supply-Battery voltage,5.00, V
MAS00043-MAS07472,Terminal 30 power supply-Battery voltage BEM,13.30, V
MAS00043-MAS07473,Terminal 30 power supply-Test voltage rear window defogger,0.00, V
MAS00043-MAS07474,Terminal 30 power supply-Test voltage windshield defogger,0.00, V
MAS00179-MAS04422,Brake lamp switch-Brake light signal via CAN,OFF,
MAS00179-MAS07313,Brake lamp switch-Brake light signal via HW,OFF,
MAS00464-MAS00106,Standard - ambient data 1-Year,2025,
MAS00464-MAS00107,Standard - ambient data 1-Month,3,
MAS00464-MAS00108,Standard - ambient data 1-Day,20,
MAS00464-MAS00109,Standard - ambient data 1-Hours,11,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,39,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,44,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,39,
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,155140, km
MAS00829-MAS00244,Access/start authorization-Prompt wire,not coded/not installed,
MAS00829-MAS01763,Access/start authorization-Signal Strength,0,
MAS00829-MAS07866,Access/start authorization-Duration: last awakening wire actua.,0, ms
MAS01281,Back-up lamp,|Connector number,Connector terminal number,Duty cycle,Signal state,Diagnosis|Plug C,11,0.0,not active,normal|,
MAS01431-IDE01442,Vehicle key with remote control-Pressing a button,Not operated,
MAS01431-IDE01839,Vehicle key with remote control-Battery charge level,Not available,
MAS01431-MAS00077,Vehicle key with remote control-Immobilizer,OK,
MAS01431-MAS01551,Vehicle key with remote control-Key number,255,
MAS01431-MAS05048,Vehicle key with remote control-Number of transmitters adapted,2,
MAS01431-MAS06362,Vehicle key with remote control-Code in catch area,Not available,
MAS01490-IDE02744,Energy management-Steering wheel heating,Enabled,
MAS01490-IDE04216,Energy management-Mirror heater,Enabled,
MAS01490-IDE80251,Energy management-Head area heater,not coded/not installed,
MAS01490-MAS01535,Energy management-Rear window defogger,Enabled,
MAS01490-MAS01563,Energy management-Auxiliary Air Heater,not coded/not installed,
MAS01490-MAS01564,Energy management-Windshield defogger,not coded/not installed,
MAS01490-MAS01632,Energy management-Status,not active,
MAS01490-MAS02390,Energy management-Shutoff,8701,
MAS01490-MAS05795,Energy management-Rear seat heater,not coded/not installed,
MAS01490-MAS05796,Energy management-Emergency shut-down,0,
MAS01490-MAS05887,Energy management-Battery cut out relay 2,not enabled,
MAS01490-MAS06551,Energy management-Seat ventilation,not coded/not installed,
MAS01490-MAS06552,Energy management-Front seat heating,not coded/not installed,
MAS01490-MAS06553,Energy management-Display consumer switch-off,not active,
MAS01490-MAS06554,Energy management-Switch-off priority while driving,0,
MAS01490-MAS06555,Energy management-Maximum switch-off priority while driving,10,
MAS01490-MAS06556,Energy management-Switch-off with voltage drops,0,
MAS01490-MAS06557,Energy management-Switch-off priority with vehicle crash,0,
MAS01490-MAS06558,Energy management-Current negative charge balance,0, %
MAS01490-MAS06559,Energy management-Switch-off priority with engine off,0,
MAS01490-MAS06560,Energy management-Short distance driving,0,
MAS01597-IDE00542,Sunroof-Excessive temperature protection,not active,
MAS01597-IDE03114,Sunroof-Comfort function,not active,
MAS01597-MAS01979,Sunroof-Adapting,Not adapted,
MAS01597-MAS02282,Sunroof-Position,0, %
MAS01597-MAS02447,Sunroof-Release,not active,
MAS01597-MAS03656,Sunroof-Reverse,not active,
MAS01597-MAS05563,Sunroof-Norming,not normed,
MAS01597-MAS05737,Sunroof-Position,Tilt out posi.,
MAS03835,Position lamps,|Connector number,Connector terminal number,Duty cycle,Signal state,Diagnosis|Connector B,10,25.5,active,normal|Connector B,21,25.5,active,normal|Connector B,4,100.0,active,normal|Connector B,32,100.0,active,normal|Connector A,71,10.0,active,normal|Plug C,8,10.0,active,normal|Plug C,10,100.0,active,normal|Connector A,65,100.0,active,normal|Connector A,59,100.0,active,normal|,
MAS03836,Rear fog lamp,|Connector number,Connector terminal number,Duty cycle,Signal state,Diagnosis|Connector A,72,0.0,not active,normal|,
MAS07959,Remote start history data,|Stop or cancel cause,Cause for cancellation,Month,Day,Hours,Minutes|No reason for prevention,no reason for cancellation,15,31,31,63|No reason for prevention,no reason for cancellation,15,31,31,63|No reason for prevention,no reason for cancellation,15,31,31,63|No reason for prevention,no reason for cancellation,15,31,31,63|No reason for prevention,no reason for cancellation,15,31,31,63|No reason for prevention,no reason for cancellation,15,31,31,63|No reason for prevention,no reason for cancellation,15,31,31,63|No reason for prevention,no reason for cancellation,15,31,31,63|,
MAS08228-MAS01632,Light sensor-Status,not coded/not installed,
MAS08228-MAS02851,Light sensor-Brightness,22860, lx
MAS08228-MAS04121,Light sensor-Voltage,25.4, V
MAS13141,Test voltage,0, V
ENG116910,Control unit internal measured value (supplier),31 36 30 34 30 30 30 32 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG117285-ENG115840,Cycle_Protection_Counter-general_cycle_protection_counter,0,
ENG117285-ENG124947,Cycle_Protection_Counter-last_wake_up,keine Stoerschutzursache,
ENG116908-ENG115779,Ecu_Intern_Meas._Values_2-Betriebsstunden_Abblendlicht_an,0, H
ENG116908-ENG115778,Ecu_Intern_Meas._Values_2-Hours_of_operation,0, H
ENG116908-ENG115775,Ecu_Intern_Meas._Values_2-Hours_of_operation_front_window_wiper,0,
ENG116908-ENG115776,Ecu_Intern_Meas._Values_2-Number of_the_wisp_cycles_front_window_wiper,0,
ENG116908-ENG115777,Ecu_Intern_Meas._Values_2-Number of_the_wisp_cycles_rear_window_wiper,0,
ENG117286-ENG116724,Kopfraumheizung_Entwicklung-KRH_l_Error,not coded/not installed,
ENG117286-ENG116725,Kopfraumheizung_Entwicklung-KRH_l_Error_Gueltigkeit,not coded/not installed,
ENG117286-ENG116723,Kopfraumheizung_Entwicklung-KRH_l_Luefter_Error,not coded/not installed,
ENG117286-ENG116727,Kopfraumheizung_Entwicklung-KRH_l_PTC_Error,not coded/not installed,
ENG117286-ENG116726,Kopfraumheizung_Entwicklung-KRH_l_ResponseError,not coded/not installed,
ENG117286-ENG116730,Kopfraumheizung_Entwicklung-KRH_r_Error,not coded/not installed,
ENG117286-ENG116731,Kopfraumheizung_Entwicklung-KRH_r_Error_Gueltigkeit,not coded/not installed,
ENG117286-ENG116728,Kopfraumheizung_Entwicklung-KRH_r_Luefter_Error,not coded/not installed,
ENG117286-ENG116729,Kopfraumheizung_Entwicklung-KRH_r_PTC_Error,not coded/not installed,
ENG117286-ENG116732,Kopfraumheizung_Entwicklung-KRH_r_ResponseError,not coded/not installed,
ENG116909-ENG107391,LIN activity-LIN 1,active,
ENG116909-ENG107392,LIN activity-LIN 2,active,
ENG116909-ENG114948,LIN activity-LIN 3,active,
ENG116909-ENG114949,LIN activity-LIN 4,not coded/not installed,
ENG116909-ENG114950,LIN activity-LIN 5,not coded/not installed,
ENG116909-ENG114951,LIN activity-LIN 6,not coded/not installed,
ENG128380,Parametermonitor_0,82 14 64 64 A0 00 00 00 00 00 00 00 00 00 00 00 50 50 32 32 00 50 50 50 50 3E 3E 62 62 00 00 64 3C 01 21 21 0A 04 00 00 1E 0A 1E 1E 03 07 00 00 06 06 28 00 3C 03 1E 22 00 04 19 05 00 01 01 28 00 02 00 02 1E 64 05 B4 1E 00 00 00 00 00 26 1D 5A 96 02 05 0A 6E 96 05 00 00 00 00 00 00 00 00 0A 1E 3C 42 0F 00 00 00 00 00 00 00 00 00 00 00 64 0A 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1E 5A 19 E1 32 01 0A 00 00 00 00 00 A0 00 00 00 A0 00 00 00 A0 06 0C 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116806,Parametermonitor_1,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 64 64 64 64 64 64 00 64 64 64 64 64 64 64 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 14 00 46 7E 7F 46 46 7E 46 46 46 7F 46 46 46 46 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 01 00 00 00 00 00 00 00 00 00 00 00 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG130145,Parametermonitor_10,00 5A 00 F0 05 05 05 2D 0F 32 32 0A 01 2C 14 01 03 0A 0A 05 01 02 05 01 09 00 9E 02 BC 5F 4B 41 06 9A A7 00 32 00 01 00 01 02 08 04 05 05 05 06 03 09 0A 07 07 FF FF FF 01 02 02 03 03 04 05 05 05 FF 01 01 01 01 01 01 01 01 01 FF 01 01 01 01 01 01 01 01 01 FF 02 01 03 03 04 06 07 05 FF FF 01 02 03 03 03 04 05 06 07 FF 00 00 00 00 00 00 28 12 10 0E 0C 0A 06 04 00 00 19 16 15 18 16 1D 15 16 14 14 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116807,Parametermonitor_2,0F 05 0A 00 16 00 00 14 28 14 00 14 32 5A 32 0A 1E 12 00 4B 0A 01 1E 5A 0F 3C 3C 05 0A 01 0A 78 00 FA 01 1C 00 0F 00 05 0A 14 03 02 00 19 64 00 64 1E 32 18 18 7D 28 05 28 28 7D 3C 3C 7D 7D 0A 19 3C 7D 2B 00 00 02 00 00 01 28 0A 28 19 0A 23 04 C8 FA 17 16 88 00 1E 05 00 01 C8 32 C8 14 00 5A 03 00 03 03 00 00 04 01 05 32 32 32 64 03 00 00 00 00 00 22 00 00 00 00 00 00 00 00 00 00 00 0F 14 50 78 32 3C 02 58 00 00 0A 6E 05 64 28 00 0A 06 05 02 0A 28 00 00 00 00 00 00 00 00 00 00 14 14 14 00 32 00 00 00 00 28 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116808-ENG115827,Parametermonitor_3-parameter_monitor_3_climatic,FF 02 32 00 3C FF 80 05 05 00 00 00 00 00 00 00 80 FF 02 32 3C 00 05 00 00 00 00 00 00 00 00 00 00 00 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 0A 28 0F 1E 06 1E 0A 34 0B 01 64 64 03 0A 05 01 0A 46 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116808-ENG115828,Parametermonitor_3-parameter_monitor_3_wiper,0A 00 00 19 19 00 03 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1E 50 46 00 58 8B FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0A 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116809,Parametermonitor_4,04 04 14 1E 03 B4 00 0A 05 05 0A 4B 4B 32 0A 03 00 1E 32 05 14 00 00 00 00 00 00 00 00 00 00 00 01 02 02 01 0A 28 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 04 0C 78 04 04 0C 01 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 2A 3E 00 00 00 00 00 00 00 00 00 00 00 05 03 00 00 00 00 00 00 00 00 00 00 00 00 00 0A FF 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03 03 0A 00 00 00 00 00 04 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 32 28 00 00 00 00 00 05 05 3C 04 01 01 01 01 96 01 01 C8 01 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FF FE FD FF 00 00 00 00 00 00 00 00 00 00 00 00 3C 14 37 28 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116810,Parametermonitor_5,0A 00 0C 08 09 0A 05 0A 0A 14 08 0A 03 00 0A 00 00 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00 04 00 04 00 00 1E 0A 05 01 01 00 00 00 00 00 00 00 00 00 00 00 00 00 46 00 03 09 01 05 00 00 00 00 00 00 0A 0F 0F 00 00 60 06 16 06 19 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116811,Parametermonitor_6,00 46 32 FA 3C 00 1E 32 05 04 3C 00 08 05 01 00 01 00 00 00 05 0A 50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116911,Parametermonitor_7,00 0A 00 0A 00 0A FF FF 00 0A 00 0A FF FF FF FF 0F A0 00 32 00 32 00 32 00 32 00 32 00 0A 00 0A 00 32 FF FE 00 0A 00 32 00 32 00 00 00 0A 00 0A 00 00 FF FF 00 00 00 00 FF FF 00 00 00 00 00 00 00 00 00 0A 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116812,Parametermonitor_FF,00 00 05 30 30 00 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG126653,Personalized_Account_Key_History,|Account,Key number,Month,Day,Hours,Minutes|1,2,0,0,0,0|1,1,0,0,0,0|1,2,0,0,0,0|1,1,0,0,0,0|1,2,0,0,0,0|1,1,0,0,0,0|1,2,0,0,0,0|1,1,0,0,0,0|,
ENG126652-MAS03692,Personalized_key__Setting-Key 1,1,
ENG126652-MAS03693,Personalized_key__Setting-Key 2,1,
ENG126652-MAS03694,Personalized_key__Setting-Key 3,0,
ENG126652-MAS03695,Personalized_key__Setting-Key 4,0,
ENG126652-MAS03696,Personalized_key__Setting-Key 5,0,
ENG126652-MAS03697,Personalized_key__Setting-Key 6,0,
ENG126652-MAS03698,Personalized_key__Setting-Key 7,0,
ENG126654,Personalized_Signals,|Perso_Konto,Perso_Steuerung,Perso_Steuerungs_parameter,Perso_Status,Perso_Bedienstelle,Perso_Freigabe_Verstellung,Perso_Aktiv,Month,Day,Hours,Minutes|1,0,0,1,0,0,1,5,7,14,29|1,1,0,1,0,0,1,5,7,14,29|1,3,1,1,0,0,1,5,7,14,29|1,0,0,1,0,0,1,0,0,0,0|0,0,0,0,0,0,0,0,0,0,0|0,0,0,0,0,0,0,0,0,0,0|,
ENG116792-ENG115817,Power up history-Funktionsanforderung,|Funktionsanforderung|10|10|10|10|10|10|7|1|10|1|,
ENG130589-MAS16304,Remotestart_Monitor-Number of driver takeovers from RemoteStart,0,
ENG130589-MAS16305,Remotestart_Monitor-Number of duplicate activations,0,
ENG130589-MAS16306,Remotestart_Monitor-Number of incorrect takeovers,0,
ENG130589-MAS16307,Remotestart_Monitor-Average running time: group 1,0,
ENG130589-MAS16308,Remotestart_Monitor-Average running time: group 2,0,
ENG130589-MAS16309,Remotestart_Monitor-Average running time: group 3,0,
ENG130589-MAS16333,Remotestart_Monitor-Number of RemoteStarts,0,
ENG130589-MAS16334,Remotestart_Monitor-RemoteStart cancellations counter,0,
ENG116790-MAS00711,Supply voltage history-Odometer reading,4630, km
ENG116790-ENG115814,Supply voltage history-highest voltage ever measured,15.3, V
ENG116790-ENG115815,Supply voltage history-hoechste im letzten Fahrzyklus gemessen Batteriespannung,14.8, V
ENG116790-ENG115816,Supply voltage history-voltage measurement: intern,13.2, V
ENG116791,Temperatures,12.00, °C
ENG116907-IDE00020,Zusaetzliche Umgebungsdaten-Terminal 15 status,On,
ENG116907-IDE01716,Zusaetzliche Umgebungsdaten-Terminal 50 status,OFF,
ENG116907-IDE02515,Zusaetzliche Umgebungsdaten-Low beam,Not operated,
ENG116907-IDE04639,Zusaetzliche Umgebungsdaten-Last wake-up cause,keine Stoerschutzursache,
ENG116907-IDE07956,Zusaetzliche Umgebungsdaten-redundant signal line,infinite,
ENG116907-MAS01957,Zusaetzliche Umgebungsdaten-Outside temperature,12.0, °C
ENG116907-MAS02462,Zusaetzliche Umgebungsdaten-Automatic high beam assist,operated,
ENG116907-MAS02788,Zusaetzliche Umgebungsdaten-CAN,On,
ENG116907-MAS03835,Zusaetzliche Umgebungsdaten-Position lamps,Not operated,
ENG116907-MAS04121,Zusaetzliche Umgebungsdaten-Voltage,13.2, V
ENG116907-MAS06466,Zusaetzliche Umgebungsdaten-Parking light left,Not operated,
ENG116907-MAS06467,Zusaetzliche Umgebungsdaten-Parking light right,Not operated,
ENG116907-MAS14232,Zusaetzliche Umgebungsdaten-Light switch: zero setting,Not operated,
ENG116907-MAS19766,Zusaetzliche Umgebungsdaten-Status of brake lamp switch: discrete,OFF,
ENG116907-MAS19768,Zusaetzliche Umgebungsdaten-Brake lamp switch via CAN: status,OFF,
Elapsed Time: 00:41
;Thursday,20,March,2025,11:40:04:46973
IDE01550-Service position,178.999822 °,2
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking,DELAY ,10
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn,short ,10
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen,active ,10
IDE02488-Anti-theft system interior monitoring,100 %,1
IDE02711-ENG112304-Rear wiper-Heckwischer,logikgesteuert ,8
IDE02711-ENG116691-Rear wiper-Traenenwischen Heck,active ,8
IDE02711-ENG154831-Rear wiper-Zeit_wasch_min_heck,0 ms,8
IDE03638-IDE04231-Stationary cornering lamp-Steering wheel angle: offset,0.3 °,16
IDE03638-ENG116677-Stationary cornering lamp-Abdimmgeschwindigkeit,50.0 %/s,16
IDE03638-ENG116673-Stationary cornering lamp-bei Rueckwaertsfahrt,both sides ,16
IDE03638-ENG116675-Stationary cornering lamp-Lower speed threshold,0.0 km/h,16
IDE03638-ENG116682-Stationary cornering lamp-Maximaltemperatur,100.0 °C,16
IDE03638-ENG116679-Stationary cornering lamp-obere Grenztemperatur,95.0 °C,16
IDE03638-ENG116681-Stationary cornering lamp-Oberer Lenkradwinkel,120 °,16
IDE03638-ENG116680-Stationary cornering lamp-untere Grenztemperatur,80.0 °C,16
IDE03638-ENG116678-Stationary cornering lamp-Unterer Lenkradwinkel,80 °,16
IDE03638-ENG116676-Stationary cornering lamp-Upper speed threshold,40.0 km/h,16
IDE03638-ENG116674-Stationary cornering lamp-Vorschrift,ECE R119 ,16
IDE03638-ENG115830-Stationary cornering lamp-Zeitwert Einschaltzeit Abbiegelicht,15 min,16
IDE04927-IDE01446-Window heater-Running time of heated front window,240 s,11
IDE04927-ENG126845-Window heater-FSH Automatik,active ,11
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert,320 s,11
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH,active ,11
IDE04927-ENG141962-Window heater-Waschduesenheizung,not installed ,11
IDE04927-ENG154810-Window heater-window heating front activation time pause,0 s,11
IDE04928-MAS01577-Anti-theft protection-Parking heater,not installed ,8
IDE04928-ENG115867-Anti-theft protection-Akustischer Alarm Signalhorn,not active ,8
IDE04928-ENG115864-Anti-theft protection-Alarmsignal,frequency modulated ,8
IDE04928-ENG141960-Anti-theft protection-Anti-theft alarm system,active ,8
IDE04928-ENG154588-Anti-theft protection-Deaktivierung DWA-Sensoren via Doppelklick,not_active ,8
IDE04928-ENG154589-Anti-theft protection-Deaktivierung_DWA_Sensoren_HMI,activ ,8
IDE04928-ENG115865-Anti-theft protection-DWA Alarmverzoegerung,not active ,8
IDE04928-ENG115812-Anti-theft protection-DWA Camper Modus,not active ,8
IDE04928-ENG142007-Anti-theft protection-DWA_Einfachhorn_oder_Sounder,Sounder_verbaut ,8
IDE04928-ENG141961-Anti-theft protection-Heckscheibenbruchsensor,not installed ,8
IDE04928-ENG142006-Anti-theft protection-IRUE_NGS_Deaktivierungstaster_direkt_am BCM_verdrahtet,No ,8
IDE04928-ENG142249-Anti-theft protection-OBD Alarm,activ ,8
IDE04928-ENG154722-Anti-theft protection-RHF_Panikalarm,not_active ,8
IDE04928-ENG142009-Anti-theft protection-Schliesszylinder in_Richtung Oeffnen_aktiv (Thatcham inaktiv),No ,8
IDE04928-ENG142010-Anti-theft protection-Sensor_fuer_Innenraumueberwachung,Yes ,8
IDE04928-ENG115866-Anti-theft protection-Sirenen Alarmzahl,10 Alarme ,8
IDE04928-ENG142008-Anti-theft protection-tilt_sensor,Yes ,8
IDE04928-ENG126842-Anti-theft protection-Ueberwachung Innenentriegelungshebel,not active ,8
IDE04928-ENG115868-Anti-theft protection-Verzoegerung Panikalarm,2 sekunden verzoegerung ,8
IDE05143-MAS02985-Writing parameter-Value,130 ,5
IDE05143-MAS04381-Writing parameter-Parameter address,FE 00 00 ,5
IDE05144-Read parameter address,FE 00 00 ,3
IDE05145-Light configuration,0C 34 00 14 02 00 64 00 00 00 00 00 00 00 00 00 0C 3E 00 15 04 00 64 00 00 00 00 00 00 00 00 00 04 48 00 4A 14 00 64 08 09 1A 12 06 9A 00 00 00 04 4C 00 4C 14 00 64 08 0A 1A 13 07 9A 00 00 00 01 3A 00 49 14 00 7F 08 09 7F 00 00 00 00 00 00 01 44 00 4B 14 00 7F 08 0A 7F 00 00 00 00 00 00 0B 36 00 1A 0B 00 64 00 00 00 00 00 00 00 00 00 0B 40 00 1B 0C 00 64 00 00 00 00 00 00 00 00 00 0A 37 00 1C 0D 0F 64 00 00 00 00 00 00 00 00 00 0A 41 00 1D 0E 0F 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0A 38 00 22 12 16 64 00 00 00 00 00 00 00 00 00 0A 42 00 23 13 17 64 00 00 00 00 00 00 00 00 00 ,224
IDE05822-Anti-theft alarm system vehicle inclination sensor,100 %,1
IDE05823-DWA Interior monitoring parameter set,01 0A 00 08 43 53 0A C6 01 14 0A 03 81 33 0C 00 00 00 01 CD D6 06 00 0F 1E 00 85 0F 39 F7 64 23 45 42 57 9B 25 44 3F 3A 69 58 95 2E 09 A3 02 7A 06 56 00 0F 17 00 89 10 2F F7 69 0F E3 42 87 9B 05 34 3F 3A 69 58 93 08 09 A3 03 44 46 2A 00 0F 1C 00 88 0E 2F E7 69 1E 65 42 77 9B 05 24 3F 3A 69 47 93 08 09 A3 04 FF F6 46 00 0F 1E 00 85 1E 32 F7 44 0C 42 20 57 94 05 24 3F 3A 69 58 92 05 09 A3 05 34 26 19 15 0C 12 18 88 06 26 33 66 23 45 42 57 9B 25 24 0C FA 0A 34 95 2E 09 A3 21 03 00 02 02 02 02 02 02 B1 11 41 2A FC ,172
IDE06089-ENG141976-Seat heater level current consumption allocation-Sitzheitzung_CAN,not_installed ,30
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss,0 s,30
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle,0.00 °C,30
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle,0.00 °C,30
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle,0.00 °C,30
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle,0.00 °C,30
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle,0.00 °C,30
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle,0.00 °C,30
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle,0.00 °C,30
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle,0.00 °C,30
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle,0.00 °C,30
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle,0.00 °C,30
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle,0.00 °C,30
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle,0.00 °C,30
IDE06089-ENG154774-Seat heater level current consumption allocation-Sitzheizung.Aufheizphase HI,Keine_Spannungsanforderung ,30
IDE06089-ENG154785-Seat heater level current consumption allocation-Spannungsoffset SIH_75,15.0 V,30
IDE06507-MAS13132-Button in center console-Function of button 3,NOT-DEFINED ,8
IDE07007-ENG142253-Air conditioning/heating function via remote control-Abbruch_d_Warnblinker_moeglich,active ,8
IDE07007-ENG142252-Air conditioning/heating function via remote control-Abbruch_Hupen_RSt,not active ,8
IDE07007-ENG142255-Air conditioning/heating function via remote control-Aktivierung_Drehzahlanzeige,active ,8
IDE07007-ENG142254-Air conditioning/heating function via remote control-Kombi_Fahrerhinweis_m_Akustik,active ,8
IDE07356-Position during interval mode,40.999959 °,2
IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs,not active ,6
IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit,255 min,6
IDE07470-ENG126843-After-run for park light-ZV verriegeln bei Klemme 15 Ein,active ,6
IDE08786-ENG124476-Assistance light functions-Sunlight photo sensor,not installed ,9
IDE09731-ENG154511-Int. light: 2nd generation-Ambiente_Fahrprofil_Individual,7 ,19
IDE09731-ENG154512-Int. light: 2nd generation-Ambiente_Farbliste_HMI_mit_Farbtransformation,not active ,19
IDE09731-ENG154513-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung,not active ,19
IDE09731-ENG154514-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung_Status_hmi_default,active ,19
IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit,0.10 s,19
IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1,2 ,19
IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2,3 ,19
IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3,1 ,19
IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach,0 %,19
IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe,2 ,19
IDE09731-ENG115822-Int. light: 2nd generation-Defaultwert Ambienteprofil Fussraum,30 %,19
IDE09731-ENG116685-Int. light: 2nd generation-Defaultwert Ambienteprofil Tuer,30 %,19
IDE09731-ENG115823-Int. light: 2nd generation-Defaultwert Ambienteprofil Vorn,10 %,19
IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen,not active ,19
IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen,not active ,19
IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen,not active ,19
IDE09731-ENG125635-Int. light: 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnen,not active ,19
IDE09731-ENG116596-Int. light: 2nd generation-Innenlicht bei offenem Heckdeckel einschalten,active ,19
IDE09731-ENG98648-Int. light: 2nd generation-Interior lighting,Keine_Spannungsanforderung ,19
IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig,active ,19
IDE09731-ENG142184-Int. light: 2nd generation-Weckfaehigkeit_klemme_30G,installed ,19
IDE09732-ENG154509-Interior light: light configuration-Ambience_light_colorlist_default,0 ,5
IDE09732-ENG133384-Interior light: light configuration-Ambient_Farbliste_HMI,not active ,5
IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel,not installed ,5
IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen,not active ,5
IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus,not active ,5
IDE09732-ENG114629-Interior light: light configuration-Footwell lighting,installed ,5
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz,30 %,17
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz,30 %,17
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne,50 %,17
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz,50 %,17
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne,50 %,17
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz,50 %,17
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne,75 %,17
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz,75 %,17
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne,80 %,17
IDE09761-ENG142025-Seat fan charac. curve-Seat pneumatics,not installed ,17
IDE09761-ENG142183-Seat fan charac. curve-Sitzlueftung_reduzierbar,installed ,17
IDE10298-Alternating park position 1,19.999980 °,2
IDE10299-Alternating park position 2,34.999965 °,2
IDE11477-ENG128619-Interior lighting: parameter-p_adaption_kundenwunsch_dach,1.00 ,256
IDE11477-ENG128539-Interior lighting: parameter-p_adaption_kundenwunsch_fussraum,0.20 ,256
IDE11477-ENG128571-Interior lighting: parameter-p_adaption_kundenwunsch_itafel,1.00 ,256
IDE11477-ENG128635-Interior lighting: parameter-p_adaption_kundenwunsch_psd,0.00 ,256
IDE11477-ENG128523-Interior lighting: parameter-p_adaption_kundenwunsch_tuer,0.00 ,256
IDE11477-ENG128659-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI,00000000 ,256
IDE11477-ENG128660-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_2,00000000 ,256
IDE11477-ENG128661-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_3,00000000 ,256
IDE11477-ENG128655-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI,00000000 ,256
IDE11477-ENG128656-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_2,00000000 ,256
IDE11477-ENG128657-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_3,00000000 ,256
IDE11477-ENG128658-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_4,00000000 ,256
IDE11477-ENG128654-Interior lighting: parameter-p_farbauswahl_HMI,00000000 ,256
IDE11477-ENG128628-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_dach,100 %,256
IDE11477-ENG128548-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_fussraum,70 %,256
IDE11477-ENG128580-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_itafel,100 %,256
IDE11477-ENG128644-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_psd,0 %,256
IDE11477-ENG128532-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_tueren,0 %,256
IDE11477-ENG128625-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_dach,100 %,256
IDE11477-ENG128545-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_fussraum,70 %,256
IDE11477-ENG128577-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_itafel,100 %,256
IDE11477-ENG128641-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_psd,0 %,256
IDE11477-ENG128529-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_tueren,0 %,256
IDE11477-ENG128627-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_dach,100 %,256
IDE11477-ENG128547-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_fussraum,70 %,256
IDE11477-ENG128579-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_itafel,100 %,256
IDE11477-ENG128643-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_psd,0 %,256
IDE11477-ENG128531-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_tueren,0 %,256
IDE11477-ENG128624-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_dach,100 %,256
IDE11477-ENG128544-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_fussraum,70 %,256
IDE11477-ENG128576-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_itafel,100 %,256
IDE11477-ENG128640-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_psd,0 %,256
IDE11477-ENG128528-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_tueren,0 %,256
IDE11477-ENG128629-Interior lighting: parameter-p_helligkeit_einausstieg_dach,100 %,256
IDE11477-ENG128549-Interior lighting: parameter-p_helligkeit_einausstieg_fussraum,70 %,256
IDE11477-ENG128581-Interior lighting: parameter-p_helligkeit_einausstieg_itafel,100 %,256
IDE11477-ENG128645-Interior lighting: parameter-p_helligkeit_einausstieg_psd,0 %,256
IDE11477-ENG128533-Interior lighting: parameter-p_helligkeit_einausstieg_tueren,0 %,256
IDE11477-ENG128620-Interior lighting: parameter-p_helligkeit_entriegelt_dach,100 %,256
IDE11477-ENG128572-Interior lighting: parameter-p_helligkeit_entriegelt_itafel,100 %,256
IDE11477-ENG128636-Interior lighting: parameter-p_helligkeit_entriegelt_psd,0 %,256
IDE11477-ENG128524-Interior lighting: parameter-p_helligkeit_entriegelt_tueren,0 %,256
IDE11477-ENG128634-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_dach,100 %,256
IDE11477-ENG128554-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_fussraum,70 %,256
IDE11477-ENG128586-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_itafel,100 %,256
IDE11477-ENG128650-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_psd,0 %,256
IDE11477-ENG128538-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_tueren,0 %,256
IDE11477-ENG128630-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_dach,100 %,256
IDE11477-ENG128582-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_itafel,100 %,256
IDE11477-ENG128646-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_psd,0 %,256
IDE11477-ENG128534-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_tueren,0 %,256
IDE11477-ENG128626-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_dach,126 %,256
IDE11477-ENG128642-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_psd,0 %,256
IDE11477-ENG128530-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_tueren,0 %,256
IDE11477-ENG128623-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_dach,100 %,256
IDE11477-ENG128575-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_itafel,100 %,256
IDE11477-ENG128639-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_psd,0 %,256
IDE11477-ENG128527-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_tueren,0 %,256
IDE11477-ENG128622-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_dach,100 %,256
IDE11477-ENG128542-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_fussraum,126 %,256
IDE11477-ENG128574-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_itafel,100 %,256
IDE11477-ENG128638-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_psd,0 %,256
IDE11477-ENG128526-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_tueren,0 %,256
IDE11477-ENG128621-Interior lighting: parameter-p_helligkeit_max_dach,100 %,256
IDE11477-ENG128541-Interior lighting: parameter-p_helligkeit_max_fussraum,70 %,256
IDE11477-ENG128573-Interior lighting: parameter-p_helligkeit_max_itafel,100 %,256
IDE11477-ENG128637-Interior lighting: parameter-p_helligkeit_max_psd,0 %,256
IDE11477-ENG128525-Interior lighting: parameter-p_helligkeit_max_tueren,0 %,256
IDE11477-ENG128631-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_dach,100 %,256
IDE11477-ENG128551-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_fussraum,70 %,256
IDE11477-ENG128583-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_itafel,100 %,256
IDE11477-ENG128647-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_psd,0 %,256
IDE11477-ENG128535-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_tueren,0 %,256
IDE11477-ENG128632-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_dach,100 %,256
IDE11477-ENG128552-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_fussraum,70 %,256
IDE11477-ENG128584-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_itafel,100 %,256
IDE11477-ENG128648-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_psd,0 %,256
IDE11477-ENG128536-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_tueren,0 %,256
IDE11477-ENG128633-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_dach,100 %,256
IDE11477-ENG128553-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_fussraum,70 %,256
IDE11477-ENG128585-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_itafel,100 %,256
IDE11477-ENG128649-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_psd,0 %,256
IDE11477-ENG128537-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_tueren,0 %,256
IDE11477-ENG128480-Interior lighting: parameter-p_t_verzoegerung_einstieg_fussraum,0.0 s,256
IDE11714-ENG126827-Ambient light color list-Blauwert Farbe 1,0 ,30
IDE11714-ENG133432-Ambient light color list-Blauwert Farbe 10,0 ,30
IDE11714-ENG126830-Ambient light color list-Blauwert Farbe 2,0 ,30
IDE11714-ENG126833-Ambient light color list-Blauwert Farbe 3,0 ,30
IDE11714-ENG133414-Ambient light color list-Blauwert Farbe 4,0 ,30
IDE11714-ENG133417-Ambient light color list-Blauwert Farbe 5,0 ,30
IDE11714-ENG133420-Ambient light color list-Blauwert Farbe 6,0 ,30
IDE11714-ENG133426-Ambient light color list-Blauwert Farbe 8,0 ,30
IDE11714-ENG126826-Ambient light color list-Gruenwert Farbe 1,0 ,30
IDE11714-ENG133431-Ambient light color list-Gruenwert Farbe 10,0 ,30
IDE11714-ENG126829-Ambient light color list-Gruenwert Farbe 2,0 ,30
IDE11714-ENG126832-Ambient light color list-Gruenwert Farbe 3,0 ,30
IDE11714-ENG133416-Ambient light color list-Gruenwert Farbe 5,0 ,30
IDE11714-ENG133419-Ambient light color list-Gruenwert Farbe 6,0 ,30
IDE11714-ENG133422-Ambient light color list-Gruenwert Farbe 7,0 ,30
IDE11714-ENG133425-Ambient light color list-Gruenwert Farbe 8,0 ,30
IDE11714-ENG133428-Ambient light color list-Gruenwert Farbe 9,0 ,30
IDE11714-ENG126825-Ambient light color list-Rotwert Farbe 1,0 ,30
IDE11714-ENG133430-Ambient light color list-Rotwert Farbe 10,0 ,30
IDE11714-ENG126828-Ambient light color list-Rotwert Farbe 2,0 ,30
IDE11714-ENG126831-Ambient light color list-Rotwert Farbe 3,0 ,30
IDE11714-ENG133412-Ambient light color list-Rotwert Farbe 4,0 ,30
IDE11714-ENG133415-Ambient light color list-Rotwert Farbe 5,0 ,30
IDE11714-ENG133418-Ambient light color list-Rotwert Farbe 6,0 ,30
IDE11714-ENG133424-Ambient light color list-Rotwert Farbe 8,0 ,30
IDE11944-ENG142014-Keyless access and start authorization-Elektische_Lenkradverriegelung,not installed ,3
IDE11944-ENG141948-Keyless access and start authorization-Kessy,not installed ,3
IDE11944-ENG116626-Keyless access and start authorization-Oeffnung Heckdeckel bei Wiederentriegelung,not active ,3
IDE12412-ENG154557-LIN Ambient light color list-Blauwert_Farbe_3_lin,0 ,30
IDE12412-ENG154560-LIN Ambient light color list-Blauwert_Farbe_4_lin,0 ,30
IDE12412-ENG154561-LIN Ambient light color list-Blauwert_Farbe_5_lin,0 ,30
IDE12412-ENG154562-LIN Ambient light color list-Blauwert_Farbe_6_lin,0 ,30
IDE12412-ENG154656-LIN Ambient light color list-Gruenwert_Farbe_2_lin,0 ,30
IDE12412-ENG154676-LIN Ambient light color list-Gruenwert_Farbe_3_lin,0 ,30
IDE12412-ENG154679-LIN Ambient light color list-Gruenwert_Farbe_4_lin,0 ,30
IDE12412-ENG154680-LIN Ambient light color list-Gruenwert_Farbe_5_lin,0 ,30
IDE12412-ENG154681-LIN Ambient light color list-Gruenwert_Farbe_6_lin,0 ,30
IDE12412-ENG154682-LIN Ambient light color list-Gruenwert_Farbe_7_lin,0 ,30
IDE12412-ENG154683-LIN Ambient light color list-Gruenwert_Farbe_8_lin,0 ,30
IDE12412-ENG154733-LIN Ambient light color list-Rotwert_Farbe_1_lin,0 ,30
IDE12412-ENG154744-LIN Ambient light color list-Rotwert_Farbe_2_lin,0 ,30
IDE12412-ENG154767-LIN Ambient light color list-Rotwert_Farbe_4_lin,0 ,30
IDE12412-ENG154768-LIN Ambient light color list-Rotwert_Farbe_5_lin,0 ,30
IDE12412-ENG154769-LIN Ambient light color list-Rotwert_Farbe_6_lin,0 ,30
IDE12412-ENG154771-LIN Ambient light color list-Rotwert_Farbe_8_lin,0 ,30
MAS05055-lower turn position,42.999957 °,2
MAS05056-upper turn position,178.999822 °,2
MAS08228-ENG133444-Light sensor-ECE_Lichteinschaltschwelle,2512 lx,24
MAS08228-ENG133436-Light sensor-Helligkeitsgrenze_sehr_hell,2000 lx,24
MAS08228-ENG133442-Light sensor-Maximale_Ausgangsspannung,4500 mV,24
MAS08228-ENG133441-Light sensor-Minimale_Ausgangsspannung,2000 mV,24
ENG141683-ENG116672-Allwetterlicht_Spoiler-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren,not active ,4
ENG141683-ENG116671-Allwetterlicht_Spoiler-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT,not active ,4
ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1,00 ,60
ENG153712-ENG154510-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Ambiente,Keine_Spannungsanforderung ,23
ENG153712-ENG154603-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_1,1 ,23
ENG153712-ENG154604-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_10,1 ,23
ENG153712-ENG154611-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_3,1 ,23
ENG153712-ENG154612-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_4,1 ,23
ENG153712-ENG154613-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_5,1 ,23
ENG141649-ENG122211-Außenlicht_Blinker-Richtungs_blinken_links,not active ,10
ENG141649-ENG122210-Außenlicht_Blinker-Richtungs_blinken_rechts,not active ,10
ENG141649-ENG122214-Außenlicht_Blinker-Warnblinken_Zuendung_AUS,not active ,10
ENG141649-ENG122213-Außenlicht_Blinker-Warnblinken_Zuendung_EIN,not active ,10
ENG141647-ENG115861-Außenlicht_Front-Lichthupe bei Zuendung aus moeglich,active ,9
ENG141648-ENG115782-Aussenlicht_Heck-Nebelschlusslicht Warngeschwindigkeit,0 km/h,5
ENG141656-ENG142020-Außenlicht_uebergreifend-All-weather light,not installed ,18
ENG141656-ENG116601-Außenlicht_uebergreifend-Coming Home Verbaustatus,manual ,18
ENG141656-ENG130581-Außenlicht_uebergreifend-Fahrlicht_Hinweis_mehrfach,active ,18
ENG141656-ENG154619-Außenlicht_uebergreifend-Fernlicht_LH,Sollspannungsanforderung 13.5 ,18
ENG141656-ENG154177-Außenlicht_uebergreifend-Fog lamp,Sollspannungsanforderung 13.5 ,18
ENG141656-ENG116608-Außenlicht_uebergreifend-Helligkeitsschwelle Forward-Messung,46400 lx,18
ENG141656-ENG142185-Außenlicht_uebergreifend-LCM_blinker,true ,18
ENG141656-ENG142034-Außenlicht_uebergreifend-Light_Control_Module,not installed ,18
ENG141656-ENG98354-Außenlicht_uebergreifend-Low beam,Sollspannungsanforderung 13.5 ,18
ENG141656-ENG116603-Außenlicht_uebergreifend-Menueeinstellung Cominghome,10 seconds ,18
ENG141656-ENG116607-Außenlicht_uebergreifend-Menueeinstellung Leaving-home Zeit per BAP,10 seconds ,18
ENG141656-ENG154174-Außenlicht_uebergreifend-Turn signal lamp,Sollspannungsanforderung 13.5 ,18
ENG141650-ENG141973-Fernlicht_assistent-Erweiterte_Fernlichtsteuerung,Basis: FLA ,6
ENG141650-ENG116637-Fernlicht_assistent-Menuesteuerung Fernlichtassistent,not installed ,6
ENG141682-ENG115770-Front_wiper-Variable Regensensoraktivierung,not active ,6
ENG141660-ENG115658-Kennlinie_sLWR_Soll-x0,100.00 %,30
ENG141660-ENG101574-Kennlinie_sLWR_Soll-X1,100.00 %,30
ENG141660-ENG99557-Kennlinie_sLWR_Soll-X2,100.00 %,30
ENG141660-ENG102140-Kennlinie_sLWR_Soll-X3,100.00 %,30
ENG141660-ENG102936-Kennlinie_sLWR_Soll-X4,83.00 %,30
ENG141660-ENG103548-Kennlinie_sLWR_Soll-X5,67.00 %,30
ENG141660-ENG113992-Kennlinie_sLWR_Soll-X6,50.00 %,30
ENG141660-ENG115661-Kennlinie_sLWR_Soll-x7,33.00 ,30
ENG141660-ENG115662-Kennlinie_sLWR_Soll-x8,17.00 %,30
ENG141660-ENG115663-Kennlinie_sLWR_Soll-x9,-0.00 %,30
ENG141660-ENG115659-Kennlinie_sLWR_Soll-y0,64.0 %,30
ENG141660-ENG99777-Kennlinie_sLWR_Soll-Y1,64.0 %,30
ENG141660-ENG100480-Kennlinie_sLWR_Soll-Y2,64.0 %,30
ENG141660-ENG100773-Kennlinie_sLWR_Soll-Y3,64.0 %,30
ENG141660-ENG100631-Kennlinie_sLWR_Soll-Y4,57.0 %,30
ENG141660-ENG102174-Kennlinie_sLWR_Soll-Y5,50.0 %,30
ENG141660-ENG113993-Kennlinie_sLWR_Soll-Y6,42.0 %,30
ENG141660-ENG115665-Kennlinie_sLWR_Soll-y7,27.0 %,30
ENG141660-ENG115666-Kennlinie_sLWR_Soll-y8,22.0 %,30
ENG141660-ENG115667-Kennlinie_sLWR_Soll-y9,15.0 %,30
ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0,100 ,16
ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0,14 ,16
ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0,34 ,16
ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0,12 - Blinkleuchten ,16
ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0,Blinken links Hellphase ,16
ENG141657-ENG116159-Leuchte 35 LED Warnblinktaster C48-Fehlerort mittleres Byte DTC-DFCC 15,63 ,16
ENG141657-ENG116160-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion A 15,Unknown (76),16
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12,10 - allgemeine Scheinwerfer ,16
ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12,Abbiegelicht links ,16
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13,10 - allgemeine Scheinwerfer ,16
ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13,Abbiegelicht rechts ,16
ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16,0 ,16
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16,00 ,16
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16,00 ,16
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16,not active ,16
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16,not active ,16
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17,0 ,16
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17,00 ,16
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17,00 ,16
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17,not active ,16
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17,not active ,16
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18,100 ,16
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18,12 - Blinkleuchten ,16
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19,100 ,16
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19,12 - Blinkleuchten ,16
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1,100 ,16
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1,15 ,16
ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1,3E ,16
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1,12 - Blinkleuchten ,16
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1,Blinken rechts Hellphase ,16
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20,10 ,16
ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20,127 ,16
ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20,39 ,16
ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20,10 ,16
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20,43 - allgemeine LED ,16
ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116956-ENG116256-Leuchte20BR LA71-Lichtfunktion B 20,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20,Brake lamp ,16
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21,10 ,16
ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21,127 ,16
ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21,3A ,16
ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21,20 ,16
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21,43 - allgemeine LED ,16
ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116957-ENG116275-Leuchte21BR RC8-Lichtfunktion B 21,Parking light right ,16
ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21,Brake lamp ,16
ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22,127 ,16
ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22,Quittierungsfunktion 1 ,16
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23,127 ,16
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23,0 ,16
ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23,35 ,16
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23,32 - allgemeine LED bis 12W ,16
ENG116959-ENG116315-Leuchte23SL HLC10-Lichtansteuerung HD AB 23,only_if_closed ,16
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23,not active ,16
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24,0 ,16
ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24,36 ,16
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24,32 - allgemeine LED bis 12W ,16
ENG116960-ENG116334-Leuchte24SL HRA65-Lichtansteuerung HD AB 24,only_if_closed ,16
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24,Parking light right ,16
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24,not active ,16
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26,127 ,16
ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26,2F ,16
ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26,1C ,16
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26,43 - allgemeine LED ,16
ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26,only_if_closed ,16
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26,Nebelschlusslicht wenn kein Anhaenger gesteckt und Linksverkehr ,16
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27,0 ,16
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27,00 ,16
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27,00 ,16
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27,not active ,16
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27,not active ,16
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28,32 - allgemeine LED bis 12W ,16
ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28,only_if_closed ,16
ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29,0 ,16
ENG116965-ENG116425-Leuchte29RFL RA64-Fehlerort mittleres Byte DTC-DFCC 29,00 ,16
ENG116965-ENG116581-Leuchte29RFL RA64-Lampendefektbitposition 29,00 ,16
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29,not active ,16
ENG116965-ENG116426-Leuchte29RFL RA64-Lichtfunktion A 29,not active ,16
ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2,minimize ,16
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2,100 ,16
ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2,26 ,16
ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2,26 ,16
ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2,4A ,16
ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2,48 ,16
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2,4 - LED Tagfahrlichtmodul Signal ,16
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2,Daytime running lights ,16
ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2,Nebellicht links ,16
ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2,Blinken links aktiv (beide Phasen) ,16
ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30,89 ,16
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30,36 - LED Kleinleistung ,16
ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3,minimize ,16
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3,100 ,16
ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3,26 ,16
ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3,26 ,16
ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3,4C ,16
ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3,4C ,16
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3,4 - LED Tagfahrlichtmodul Signal ,16
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3,Daytime running lights ,16
ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3,Parking light right ,16
ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3,Nebellicht rechts ,16
ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3,Blinken rechts aktiv (beide Phasen) ,16
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4,127 ,16
ENG116940-ENG115957-Leuchte4TFL LB4-Dimmwert CD 4,127 ,16
ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4,49 ,16
ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4,3A ,16
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4,1 - LED Tagfahrlichtmodul Versorgung ,16
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4,Daytime running lights ,16
ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116940-ENG115956-Leuchte4TFL LB4-Lichtfunktion D 4,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5,127 ,16
ENG116941-ENG115976-Leuchte5 TFL RB32-Dimmwert CD 5,127 ,16
ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5,4B ,16
ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5,44 ,16
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5,1 - LED Tagfahrlichtmodul Versorgung ,16
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5,Daytime running lights ,16
ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116941-ENG115975-Leuchte5 TFL RB32-Lichtfunktion D 5,Parking light right ,16
ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6,100 ,16
ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6,0 ,16
ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6,11 - Abblendlicht ,16
ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6,not active ,16
ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7,100 ,16
ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7,0 ,16
ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7,11 - Abblendlicht ,16
ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7,not active ,16
ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8,100 ,16
ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8,0 ,16
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8,1C ,16
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8,37 ,16
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8,10 - allgemeine Scheinwerfer ,16
ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8,Left high beam ,16
ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8,Lichthupe generell ,16
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8,not active ,16
ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9,100 ,16
ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9,0 ,16
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9,1D ,16
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9,41 ,16
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9,10 - allgemeine Scheinwerfer ,16
ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9,Right high beam ,16
ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9,Lichthupe generell ,16
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9,not active ,16
ENG141661-Leuchtenkonfiguration_Aussenlich_Heck,0C 08 00 16 02 00 64 00 00 00 00 00 00 00 00 00 0C 18 00 18 04 00 64 00 00 00 00 00 00 00 00 00 2B 10 00 39 08 09 0A 18 00 7F 00 00 00 00 00 00 2B 20 00 3A 08 0A 0A 18 00 7F 00 00 00 00 00 00 2A 29 00 2C 18 24 7F 00 00 00 00 00 00 00 00 00 20 0A 00 35 08 09 FF 00 00 00 00 00 00 00 00 00 20 1A 00 36 08 0A FF 00 00 00 00 00 00 00 00 00 2B 28 00 30 08 00 7F 00 00 00 00 00 00 00 00 00 2B 1C 00 2F 1C 00 FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 20 0B 00 31 19 00 FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,192
ENG141662-Leuchtenkonfiguration_Sonstiges,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 24 00 00 02 2B 00 59 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 29 00 00 63 4C 00 64 00 00 00 00 00 00 00 00 00 ,128
ENG141658-ENG142219-Leuchtweitenregulierung-Achsabstand_des_Fahrzeuges,0 mm,62
ENG141658-ENG142211-Leuchtweitenregulierung-Ansteuerung_obere_grenze,100.0 %,62
ENG141658-ENG142210-Leuchtweitenregulierung-Ansteuerung_untere_grenze,0.0 %,62
ENG141658-ENG154591-Leuchtweitenregulierung-Delay_DC_Motor_Versorgung,-101.5 ms,62
ENG141658-ENG142214-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_1,-8.00 mm/%,62
ENG141658-ENG142216-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_2,-8.00 mm/%,62
ENG141658-ENG154599-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_3,-8.00 mm/%,62
ENG141658-ENG142213-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_1,-8.00 mm/%,62
ENG141658-ENG142215-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_2,-8.00 mm/%,62
ENG141658-ENG154600-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_3,-8.00 mm/%,62
ENG141658-ENG142204-Leuchtweitenregulierung-Fail_Safe_sLWR,0.0 %,62
ENG141658-ENG142223-Leuchtweitenregulierung-fFiltEinf,0.00 Hz,62
ENG141658-ENG142212-Leuchtweitenregulierung-Lineare_Abbildung,Inverted ,62
ENG141658-ENG142220-Leuchtweitenregulierung-lwr_lFzg_Sw_Abstand,0 mm,62
ENG141658-ENG142221-Leuchtweitenregulierung-lwr_lFzg_Sw_Hoehe,0 mm,62
ENG141658-ENG142225-Leuchtweitenregulierung-lwr_pwm_untere_schwelle,2.5 %,62
ENG141658-ENG142227-Leuchtweitenregulierung-max_v_slwr,255 km/h,62
ENG141658-ENG142224-Leuchtweitenregulierung-pa_fFiltSwNeigung,0.00 Hz,62
ENG141658-ENG142042-Leuchtweitenregulierung-sensor_headlight_range_control_installed,not installed ,62
ENG141658-ENG142199-Leuchtweitenregulierung-sLWR_bei_Abblendlicht,active ,62
ENG141658-ENG142208-Leuchtweitenregulierung-sLWR_Hysterese,1.0 %,62
ENG141658-ENG142207-Leuchtweitenregulierung-sLWR_SW_Grad,10.0 %/s,62
ENG141658-ENG142206-Leuchtweitenregulierung-sLWR_Touristenlicht,-100.0 %,62
ENG141658-ENG142196-Leuchtweitenregulierung-sLWR_verbaut,HIM ,62
ENG141658-ENG142205-Leuchtweitenregulierung-Zyklus_sLWR,1.00 s,62
ENG141659-ENG115658-lwr_ofs_RSw_Ah1S-x0,-5.00 %,20
ENG141659-ENG101574-lwr_ofs_RSw_Ah1S-X1,-5.00 %,20
ENG141659-ENG99557-lwr_ofs_RSw_Ah1S-X2,-5.00 %,20
ENG141659-ENG102140-lwr_ofs_RSw_Ah1S-X3,-5.00 %,20
ENG141659-ENG102936-lwr_ofs_RSw_Ah1S-X4,-5.00 %,20
ENG141659-ENG115659-lwr_ofs_RSw_Ah1S-y0,-5.00 ,20
ENG141659-ENG99777-lwr_ofs_RSw_Ah1S-Y1,-5.00 ,20
ENG141659-ENG100480-lwr_ofs_RSw_Ah1S-Y2,-5.00 ,20
ENG141659-ENG100773-lwr_ofs_RSw_Ah1S-Y3,-5.00 ,20
ENG141659-ENG100631-lwr_ofs_RSw_Ah1S-Y4,-5.00 ,20
ENG124714-ENG142044-OCU-DWA_push,active ,8
ENG124714-ENG142260-OCU-Honk DWA_Ausgabe_Fanfare,active ,8
ENG98831-ENG126849-Personalization-Aktivierungsoption_im_HMI-Menue_sichtbar,active ,16
ENG98831-ENG133401-Personalization-Anzahl_Benutzerkonten,4 ,16
ENG98831-ENG126850-Personalization-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar,active ,16
ENG98831-ENG126848-Personalization-Personalisierung_aktiv,active ,16
ENG98831-ENG141994-Personalization-Personalisierung_Profilfunkion,profiles_active ,16
ENG98831-ENG126851-Personalization-Personalisierungsfunktionen_in_HMI-Menue_sichtbar,active ,16
ENG98831-ENG142030-Personalization-Profil_Variante,Konto (v. 1.x) ,16
ENG98831-ENG133404-Personalization-PSO_FSG_Setup2_Bit_1,active ,16
ENG98831-ENG133405-Personalization-PSO_FSG_Setup2_Bit_2,active ,16
ENG141646-MAS01065-Querschnitts_funktionen-Brand,VW ,5
ENG141646-ENG154685-Querschnitts_funktionen-Hupe,Sollspannungsanforderung 13.5 ,5
ENG141646-ENG141964-Querschnitts_funktionen-Steering alignment,Right ,5
ENG141646-ENG141965-Querschnitts_funktionen-Traffic side,Left ,5
ENG115729-ENG116609-Scheinwerferreinigung-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,0 ,10
ENG115729-ENG141949-Scheinwerferreinigung-Headlamp washer system,not installed ,10
ENG115729-ENG115767-Scheinwerferreinigung-SRA Einweichpausenzeit,0 ms,10
ENG115729-ENG115768-Scheinwerferreinigung-SRA Nachwaschzeit,0 ms,10
ENG115729-ENG115766-Scheinwerferreinigung-SRA Waschzeit,0 ms,10
ENG141684-SFT271873-Slave_systems_identification-Wiper motor control module,Not available ,6
ENG141684-SFT271874-Slave_systems_identification-Rain/Light Recognition Sensor,Not available ,6
ENG141684-SFT271877-Slave_systems_identification-Garage door opener control head,Not available ,6
ENG141684-SFT271894-Slave_systems_identification-Anti-theft alarm system sensor,Not available ,6
ENG141684-SFT271904-Slave_systems_identification-Sunroof control module,Not available ,6
ENG141684-SFT271910-Slave_systems_identification-Roof electronics control module,Not available ,6
ENG141684-SFT271928-Slave_systems_identification-Roof shade control module,Not available ,6
ENG141684-SFT271947-Slave_systems_identification-Humidity sensor: interior,Not available ,6
ENG141684-SFT271966-Slave_systems_identification-Left head area heater,Not available ,6
ENG141684-SFT271967-Slave_systems_identification-Right head area heater,Not available ,6
ENG141684-SFT272065-Slave_systems_identification-Blower 1 for left front backrest,Not available ,6
ENG141684-SFT272067-Slave_systems_identification-Blower 1 for left front seat cushion,Not available ,6
ENG141684-SFT272069-Slave_systems_identification-Blower 1 for right front backrest,Not available ,6
ENG141684-SFT272071-Slave_systems_identification-Blower 1 for right front seat cushion,Not available ,6
ENG116588-ENG116589-Sonderfunktionen-Signalprioritaet fuer Blinker,MFG ,4
ENG141635-ENG116659-Spiegelverstellung-Menuesteuerung synchrone Spiegelverstellung,active ,5
ENG141635-ENG126841-Spiegelverstellung-Profilfunktion fuer Anklappung der Aussenspiegel,active ,5
ENG141635-ENG116656-Spiegelverstellung-Spiegelverstellung Synchron,active ,5
ENG153700-ENG154803-Steering Column Switch-Verbauort_Lenkstockschalter,CAN ,10
ENG153700-ENG154828-Steering Column Switch-Zeit_erkennung_fahrt_für_P_plausibel,10.0 min,10
ENG141663-ENG142242-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Abdimmen,20.0 s,21
ENG141663-ENG142241-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Aufdimmen,3.0 s,21
ENG141663-ENG142243-Suchbeleuchtung_allgemein-pa_Hysterese_RLS,2 ,21
ENG141663-ENG115820-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Grundwert,10.0 %,21
ENG141677-ENG99557-Suchbeleuchtung_KL_58xd_PWM-X2,50 ,12
ENG141677-ENG102140-Suchbeleuchtung_KL_58xd_PWM-X3,100 ,12
ENG141677-ENG115659-Suchbeleuchtung_KL_58xd_PWM-y0,2.0 %,12
ENG141677-ENG99777-Suchbeleuchtung_KL_58xd_PWM-Y1,2.0 %,12
ENG141677-ENG100480-Suchbeleuchtung_KL_58xd_PWM-Y2,6.0 %,12
ENG141677-ENG100773-Suchbeleuchtung_KL_58xd_PWM-Y3,10.0 %,12
ENG141677-ENG100631-Suchbeleuchtung_KL_58xd_PWM-Y4,80.0 %,12
ENG141680-ENG101574-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X1,10 lx,12
ENG141680-ENG99557-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X2,100 lx,12
ENG141680-ENG102140-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X3,500 lx,12
ENG141680-ENG99777-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y1,20 ,12
ENG141680-ENG100480-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y2,80 ,12
ENG141680-ENG100773-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y3,180 ,12
ENG141680-ENG100631-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y4,300 ,12
ENG141632-ENG116646-Sunroof-SAD Komfort schliessen,not active ,4
ENG141634-ENG125652-Verdecksteuergeraet-Servoheck Schlossansteuerung,nur wenn mind. 1 Raste zu ,9
ENG141634-ENG142011-Verdecksteuergeraet-trunk_lid_conrol_unit,installed ,9
ENG141634-ENG142258-Verdecksteuergeraet-Virtuelles_Pedal_HMI_einstellba,not active ,9
ENG141651-ENG141996-ZV allgemein-ZV_ohne_Safe_Funktion,not installed ,7
ENG141654-ENG115756-ZV Autolock-automatisches Verriegeln bei Geschwindigkeit,not active ,3
ENG141655-ENG116661-ZV Crash-SAD PreCrash Konturschliessen,active ,4
ENG141655-ENG116635-ZV Crash-ZV-Entriegelung nach Seitencrash,active ,4
ENG141653-ENG142016-ZV Heck-Heckdeckelentriegelung_HDF_Innentaster,via_CAN ,7
ENG141653-ENG141995-ZV Heck-Heckschloss_Steuerung,Kontaktsteuerung mit Mindestansteuerzeit ,7
ENG141681-IDE02022-ZV Komfort-Comfort opening,not active ,8
ENG141681-ENG116664-ZV Komfort-Fahrertuerbedienung Fensterheber schliessen,active ,8
ENG141681-ENG116643-ZV Komfort-Schliesszylinder Komfort oeffnen,not active ,8
ENG141681-ENG116644-ZV Komfort-Schliesszylinder Komfort schliessen,not active ,8
ENG141652-ENG142000-ZV Türkonfiguration-Schlosstyp_NAR,No ,5
Elapsed Time: 01:51
