Maps 2025 ID Buzz (NAR) 1st edition
Maps
Jef
HQ
AutoScan: WVG5WVEB2SH017765
Tuesday,25,March,2025,12:43:57:58926
VCDS Version: 25.3.0.5 (x64)  HEX-NET2 CB: 0.4660.5
Data version: 20250311 DS365.0
VIN: WVG5WVEB2SH017765   License Plate:
Chassis Type: EB-VNE4 (1EE)
Scan: 01 03 05 06 08 09 10 13 15 16 19 23 2B 36 3C 42 44 47 51 52
          5F 6C 6D 75 7E 8C A5 BE BF C0 C6 CA D6 D7 DE 8116 8123 8124 8125 8128
          C002 C003
VIN: WVG5WVEB2SH017765   Mileage: 209km-129miles
51-Electric Drive -- Status: Malfunction 0010
7E-Ctrl Head Dash -- Status: OK 0000
BE-Slid. Door Rear Left -- Status: OK 0000
BF-Slid. Door Rear Right -- Status: OK 0000
C0-Act. for Ext. Noise -- Status: Malfunction 0010
CA-Sunroof -- Status: OK 0000
D6-Light Ctrl Left 2 -- Status: Malfunction 0010
D7-Light Ctrl Right 2 -- Status: Malfunction 0010
8116-Snd enhanct 2 -- Status: OK 0000
8123-App server 1 system 1 adaptive -- Status: Malfunction 0010
8124-App server 1 system 2 Java -- Status: Malfunction 0010
8125-App server 3 system 1 infotaint. -- Status: Malfunction 0010
8128-Light line display -- Status: OK 0000
Address 01: Engine (J623----B)       Labels: None
   Part No SW: 0EA 906 014 GG    HW: 0EA 907 425 K
   Component: E-Vehicle     H80 3875
   Dataset Number: V03935424SD 0001 CVN: 31279148
   Coding: 4102000350042C0236000800000000000000000000000000
   ASAM Dataset: EV_VCU00XXX0200EA906014GG 003002
   ROD: EV_VCU00XXX020_VNE4.rod
   VCID: 78A286F6525D292AB76-802C-R SFD+SFD2
   VINID: 9E65C59E65520A36000471C6142C9BD626
   Radiator shutter:
   Subsystem 1 - Part No SW: 1EA 965 501 B    HW: 1EA 965 501 B
   Component: V711           023 0008
   Serial number: 20241026060604067056
19854 - Steering Column Control Module
          U0212 00 {00100110} - No Communications
                    Mileage: 209 km
                    Date: 2025.03.25
                    Time: 16:12:17
                    Engine speed: 16383.75 /min
                    Normed load value: 100.0 %
                    Coolant temperature: 215 °C
                    Intake air temperature: 215 °C
                    Ambient air pressure: 2550 mbar
                    Voltage terminal 30: 14.882 V
                    LF_MVB_PDU_INTC_DIAG_8: 1
                    LF_MVB_PDU_INTC_DIAG_9: 0
                    LF_MVB_PDU_INTC_DIAG_10: 0
                    LF_MVB_PDU_INTC_DIAG_11: 0
                    LF_MVB_PDU_INTC_DIAG_18: 0
                    LF_MVB_PDU_INTC_DIAG_19: 0
                    LF_MVB_BUS_INTC_DIAG: 256
37944 - DC-DC Converter 1 for Electric Drive
          U0599 00 {00100000} - Implausible Signal
                    Reset counter: 36
                    Mileage: 20 km
                    Date: 2025.02.21
                    Time: 17:05:49
                    Voltage terminal 30: 13.144 V
                    Unlearning counter according OBD: 36
                    LF_MVB_PDU_INTC_DIAG_1: 0
                    LF_MVB_PDU_INTC_DIAG_2: 0
                    LF_MVB_PDU_INTC_DIAG_8: 0
                    LF_MVB_PDU_INTC_DIAG_22: 4096
                    LF_MVB_PDU_INTC_DIAG_23: 0
                    LF_MVB_PDU_INTC_DIAG_24: 0
                    LF_MVB_BUS_INTC_DIAG: 0
43491 - Communication Authentication
          U3035 00 {00100000} - Invalid Signal
          {Communication Authentication Signal Invalid Data}
                    Reset counter: 36
                    Mileage: 38 km
                    Date: 2025.02.24
                    Time: 19:34:33
                    Voltage terminal 30: 13.339 V
                    Driver intention torque: 0.0 Nm
                    PV: 0.00 %
                    LV_IGK: 00000000
                    Outside temperature: 21.0 °C
                    Driving position: P
                    Brake light switch status-actuated__activated: Not operated
                    Brake light switch status-Ident_32: 0
                    Hybrid batt charge cond act val standardized: 76.50 %
   Part No SW: 1EA 907 379 BQ    HW: 1EA 614 517 M
   Component: ESC-ZF_EBC470 H18 0754
   Serial number: 0000000         Dataset Number: V03935447PA 0001 CVN: CEBFB6
   Coding: 481044A8004159024217990000B79840250070614000
   ASAM Dataset: EV_BrakeZFESCMEBUNECE 001035
   ROD: EV_BrakeZFESCMEBUNECE_001_VWE3.rod
   VCID: 0D4CC7224DDF3C82F40-8058-R SFD+SFD2
Address 05: Acc/Start Auth. (J518)       Labels: 5WA-959-436.clb
   Part No SW: 5WA 959 436 N    HW: 5WA 959 436 N
   Component: Kessy IOBOX   122 0757
   Serial number: --------------- Dataset Number: V03935385FF 0001
   ASAM Dataset: EV_Kessy37w 005030
   ROD: EV_Kessy37w.rod
   VCID: 5F90CD6AD7B3FE12D6C-800A-R
   Part No SW: 1N3 959 760 H    HW: 1N3 959 760 H
   Component: MEM-BFS       011 0571
   Serial number: 24B0501KA02040 Dataset Number: V03935362VW 0001
   Coding: 0118B24000012A008803010121010000000000000000000000000000211000
   Shop #: WSC 00000 790 00032
   ASAM Dataset: EV_SCMPasseSideCONTIAU736 006013
   ROD: EV_SCMPasseSideCONTIAU736_VW42.rod
   VCID: 3E2E50EE30F9D71ABDA-806A-R
Address 08: Auto HVAC (J979)       Labels:* Redir Fail!
   Part No SW: 1N3 907 007 D    HW: 1N3 907 007 C
   Component: Climatronic   H01 0247
   Serial number: 222102400423250 Dataset Number: V03935439QZ 0001
   Coding: 013022207010120051102110111001102000102100201171000010000000
   ASAM Dataset: EV_ACClimaBHBE3ADV 002051
   ROD: EV_ACClimaBHBE3ADV_AUE3.rod
   VCID: 2D0C67A2ED9F5C82140-8078-R SFD+SFD2
   Interior temperature sensor:
   Subsystem 1 - Part No SW: 5WA 907 527 A    HW: 5WA 907 527 A
   Component: E857           H01 0103
   Serial number: 00001141024121929510
   Air quality sensor:
   Subsystem 2 - Part No SW: 5Q0 907 659 D    HW: 5Q0 907 659 D
   Component: G238 _AQS      H02 0003
   Serial number: 00000000000003685127
   Subsystem 3 - Part No SW: 3G0 963 345 C    HW: 3G0 963 345 C
   Component: SysNameFanLin  016 0103
   Serial number: ESEYSKC0136003
   Subsystem 4 - Part No SW: 3G0 963 345 D    HW: 3G0 963 345 D
   Serial number: ESEYSKD0073026
   Subsystem 5 - Part No SW: 3G0 963 345 C    HW: 3G0 963 345 C
   Serial number: ESEYSKC0126264
   Subsystem 6 - Part No SW: 3G0 963 345 D    HW: 3G0 963 345 D
   Serial number: ESEYSKD0073842
   A/C compressor sub:
   Subsystem 7 - Part No SW: 1N3 816 797 C    HW: 1N3 816 797 C
   Component: J842 EKK       H71 1411
   Serial number: 02200002103001
   Auxiliary Heater Control Module/PTC 2:
   Subsystem 8 - Part No SW: 1EA 963 581 E    HW: 1EA 963 581 E
   Component: 0123456789012  020 0172
   Serial number: T745647BA24320000170
   Subsystem 9 - Part No SW: 1EA 820 021 B    HW: 1EA 820 021 B
   Component: J126 J126      001 0001
   Serial number: 00000000000000002042
   Expansion valve 1 for refrigerant:
   Subsystem 10 - Part No SW: 1EA 816 590 B    HW: 1EA 816 590 B
   Component: N636 EV1_KaMi  H05 0002
   Serial number: 1575977
   Subsystem 11 - Part No SW: 4M0 959 603 J    HW: 4M0 959 603 J
   Component: G395 pT-Sens1  H20 0020
   Subsystem 12 - Part No SW: 7T0 907 049 A    HW: 7T0 907 049 A
   Component: E265 KPH GB    H02 0220
   Serial number: G08S01.10.2400970659
   Control module for heating element 1:
   Subsystem 13 - Part No SW: 1T3 959 772 A    HW: 1T3 959 772 A
   Component: LHR            H02 0107
   Serial number: 0245
   A/C control head right rear:
   Subsystem 14 - Part No SW: 7T0 907 049 A    HW: 7T0 907 049 A
   Serial number: G08S01.10.2400970665
   Auxiliary Heater Control Module/PTC 3:
   Subsystem 15 - Part No SW: 1N3 963 581     HW: 1N3 963 581
   Component: IDBUZZPTC      H04 0007
   Serial number: PR653007180724022401
523522 - Airbag Control Module
          C12D1 F3 {00100000} - Received Malfunction Value
          {Airbag control module Received malfunction value 2}
                    Mileage: 65 km
                    Date: 2025.02.27
                    Time: 20:16:05
   Part No SW: 1EE 937 089 C    HW: 1EE 937 089 A
   Component: SAM_H+        H08 0555
   Serial number: 01102422200796- Dataset Number: V03935462MK 0001
   ASAM Dataset: EV_SAMVW31x 006001
   ROD: EV_SAMVW31x_006_VWE3.rod
   VCID: 42D6241E4401B3FAD92-8016-R SFD
   Subsystem 1 - Part No SW: 1T3 955 119     HW: 1T3 955 119
   Component: FWISCHER_MYJT  003 0017
   Serial number: 909453F0302423603567
   Wiper motor control unit 2:
   Subsystem 2 - Part No SW: 1T3 955 120     HW: 1T3 955 120
   Component: FWISCHER_SL02  003 0017
   Serial number: 909353F0402423400890
   Subsystem 3 - Part No SW: 89A 955 555 C    HW: 89A 955 555 C
   Component: G397_RLFSS     004 0008
   Serial number: TTZ53529092400030071
   Subsystem 4 - Part No SW: 10A 941 193 N    HW: 10A 941 193 N
   Component: LiSi           H04 0515
   Serial number: RRB71525092400026425
   Subsystem 5 - Part No SW: 1T3 953 235 A    HW: 1T3 953 235 A
   Component: DiETa          H11 0029
   Serial number: LZH 8BS00142182XXXXX
   Subsystem 6 - Part No SW: 7T0 959 569 C    HW: 7T0 959 569 C
   Component: DACHKONSOLE    007 0013
   Serial number: 000000092661XJI00022
   Valve block 1 in front seat driver side:
   Subsystem 7 - Part No SW: 14A 881 643 A    HW: 14A 881 643 A
   Component: J873 MKS_FSv   H02 0353
   Serial number: 7009362241C243703458
   Valve block 1 in front seat passenger side:
   Subsystem 8 - Part No SW: 14A 881 643 A    HW: 14A 881 643 A
   Component: J872 MKS_BFSv  H02 0353
   Serial number: 7009362241C243900090
   Subsystem 9 - Part No SW: 2Q0 959 407     HW: 2Q0 959 163
   Component: FOND_FHSG_DRV  001 0007
   Serial number: 03020118411406240233
   Subsystem 10 - Part No SW: 2Q0 959 408     HW: 2Q0 959 164
   Component: FOND_FHSG_PSG  001 0007
   Serial number: 03020101341805240016
1074806 - Databus
          U1123 00 {00100000} - Received Error Message
          {ICAS1_Gateway Datenbus empfangener Fehlerwert}
                    Mileage: 179 km
                    Date: 2025.03.15
                    Time: 15:05:04
                    Terminal 15 status: OFF
                    Terminal 50 status: OFF
                    Status drive readiness: not ready to drive
                    Status of brake lamp switch: discrete: OFF
                    Brake lamp switch via CAN: status: OFF
                    Operating condition: Normal mode
                    Voltage: 13.1 V
                    Outside temperature: 15.5 °C
                    Light switch position: automatic
15401472 - Secure Onboard Communication
          U14FF 00 {01101100} - Signature Generation Failed
          {Sichere on-board Kommunikation: Signaturerstellung fehlgeschlagen}
                    Mileage: 22 km
                    Date: 2025.02.21
                    Time: 19:54:47
                    Voltage: 12.0 V
                    Outside temperature: 1.0 °C
8667507 - Databus
          U1121 00 {00101000} - Missing Message
          {BMS_07 Datenbus fehlende Botschaft}
                    Fault Frequency: 115
                    Mileage: 21 km
                    Date: 2025.02.21
                    Time: 18:25:39
                    Voltage: 12.4 V
                    Outside temperature: 12.0 °C
8667442 - Charging Socket Flap Contact Switch
          B1CEF 86 {00101000} - Signal Invalid
          {Ladeklappenkontaktschalter Signal unplausibel}
                    Fault Frequency: 102
                    Mileage: 21 km
                    Date: 2025.02.21
                    Time: 18:25:40
                    Voltage: 12.4 V
589829 - Window Regulator; Rear Driver Side
          B131F 54 {00101000} - Missing Calibration / Basic Setting
          {Driver side rear window regulator motor No basic setting}
                    Fault Frequency: 78
                    Mileage: 20 km
                    Date: 2025.02.21
                    Time: 17:06:24
                    Operating condition: Idle condition
                    Voltage: 0.0 V
                    Outside temperature: -50.0 °C
590341 - Window Regulator; Front Passenger Side
          B1320 54 {00101000} - Missing Calibration / Basic Setting
          {Passenger side rear window regulator motor No basic setting}
                    Fault Frequency: 78
                    Mileage: 20 km
                    Date: 2025.02.21
                    Time: 17:06:24
                    Voltage: 13.1 V
                    Outside temperature: 2.5 °C
   Part No SW: 1EE 919 300 B    HW: 1EE 919 300
   Component: RPA12K        H01 0630
   Serial number: 000020102494630 Dataset Number: V03935447DQ 0001
   Coding: 0230026041
   ASAM Dataset: EV_EPHBO3CVW4130000 001014
   ROD: EV_EPHBO3CVW4130000_VWE3.rod
   VCID: 333871DA0BBB0A72424-8066-R
1113328 - Parking Sensor(s); Front
          B10FC F0 {00100000} - Function Limitation due to External Factors
          {Geber für Einparkhilfe vorne - Funktionseinschränkung durch Umwelteinflüsse}
   Part No SW: 1EA 907 567 B    HW: 1EA 907 819
   Component: ARS512VW13    H05 0232
   Dataset Number: V03935436WW 0001
   Coding: 06230AE24071C04412574000008040052F4020000000000000000000000000
   ASAM Dataset: EV_FRONTRADARCONTIVW310 004013
   ROD: EV_FRONTRADARCONTIVW310_004_VWE3.rod
   VCID: 3B2859FA23EBC2329A4-806E-R SFD+SFD2
2092 - Databus
          U1122 00 {00101110} - Implausible Message
          {FAULT_QDISACC_FAIL}
                    Mileage: 209 km
                    Date: 2025.03.25
                    Time: 16:10:50
2068 - Databus
          U1123 00 {10101111} - Received Error Message
          {FAULT_TSK_IRREV_ERROR}
                    Mileage: 209 km
                    Date: 2025.03.25
                    Time: 16:12:17
1076 - Databus
          U1121 00 {00101110} - Missing Message
          {FAULT_TIMEOUT_GRA_ACC_01}
                    Mileage: 209 km
                    Date: 2025.03.25
                    Time: 16:10:42
Address 15: Airbags (J234)       Labels:* 3WA-959-655.clb
   Part No SW: 3WA 959 655 AA    HW: 3WA 959 655 AA
   Component: Airbag VW50   006 0151
   Revision: --------    Serial number: 003C0T5CNPYJD3 Dataset Number: V03935445XP 0001
   Coding: 8CCC0C0000FCC0000000002000000000A15450008100A200830036F8102B0065
   ASAM Dataset: EV_AirbaVW50TS6VW49X 001001
   ROD: EV_AirbaVW50TS6VW49X_VWE3.rod
   VCID: 147AD2466EF5ED4A3BE-8040-R SFD+SFD2
   Component: BF-Gewichtss.  H17 0022
   Serial number: IBH0000D24000NEBW30J
   Subsystem 2 - Part No SW: -----------    HW: 654 001 608 24
   Component: SideSensor_Df  010 0887
   Serial number: 3570000F55890D578A5J
   Subsystem 3 - Part No SW: -----------    HW: 654 002 307 24
   Component: SideSensor_Pf  010 0887
   Serial number: 3580000F1689422A623+
   Subsystem 4 - Part No SW: -----------    HW: 654 002 202 24
   Component: SideSensor_Dr  020 0148
   Serial number: 35100506AC9F6A96070I
   Subsystem 5 - Part No SW: -----------    HW: 654 002 202 24
   Component: SideSensor_Pr  020 0148
   Serial number: 35200507AC6BF796CA0Y
   Subsystem 6 - Part No SW: -----------    HW: 654 001 310 24
   Component: FrontSensor_D  030 010A
   Serial number: 3550050B4C74BE56C57U
   Subsystem 7 - Part No SW: -----------    HW: 654 001 310 24
   Component: FrontSensor_P  030 010A
   Serial number: 356005098C86459008BD
   Rear end impact crash sensor:
   Subsystem 8 - Part No SW: -----------    HW: 654 001 410 24
   Component: RearSensor_C_  030 010A
   Serial number: 3530050B4C74BE48648N
   Crash sensor for side airbag: B-pillar: driver side:
   Subsystem 9 - Part No SW: -----------    HW: 654 002 202 24
   Component: Side_Sens_B_D  020 0108
   Serial number: I0P005094C6BF79A47CP
   Crash sensor for side airbag: B-pillar: passenger side:
   Subsystem 10 - Part No SW: -----------    HW: 654 002 202 24
   Component: Side_Sens_B_P  020 0108
   Serial number: I0Q005074C9F6A89A6BR
   Seat occupancy detection 1:
   Subsystem 11 - Part No SW: 2K7 959 760 D    HW: 2K7 959 760 D
   Component: wSBR F-SG      037 0200
   Serial number:         94DC4E169F55
Address 16: Steering wheel (J527)       Labels: 1EE-953-507.clb
   Part No SW: 1EE 953 507 CH    HW: 1EE 953 507 CH
   Component: GSMMEB        005 0067
   Serial number: 000000301024477
   ASAM Dataset: EV_SMLSKLOGEN2 009005
   ROD: EV_SMLSKLOGEN2_009_VW41.rod
   VCID: 0358E11A1B9B7AF2924-8056-R SFD
Address 19: CAN Gateway (J533)       Labels: 1EE-937-012.clb
   Part No SW: 1EE 937 012 A    HW: 1EE 937 012
   Component: ICAS1 Host-SG 031 0254
   Serial number: SMERBG161024007 Dataset Number: V03935446DK 0001
   GVL: 2D0008001E0850FC806290C248181050C000200000000000000200000000C057
   ASAM Dataset: EV_GatewICAS1MEBUNECE 001004
   ROD: EV_GatewICAS1MEBUNECE_VWE3.rod
   VCID: 323674DEF4A1037A492-8066 SFD+SFD2
   Subsystem 1 - Part No SW: 1N3 915 181 A    HW: 1N3 915 181 A
   Component: J367-BDMConti  H05 1076
   Serial number: 7856800100240929020A
   Inverter for electrical outlet:
   Subsystem 2 - Part No SW: 5H0 907 155 A    HW: 5H0 907 155 A
   Component: Inverter       H05 0050
   Serial number: 5ZJSHFT1806240000375
   Subsystem 3 - Part No SW: 3G0 959 542 B    HW: 3G0 959 542 B
   Component: J IEEHOD1ZONE  251 0303
   Serial number: 00000000230601293947
   left tail lamp 1:
   Subsystem 4 - Part No SW: 1T3 945 207 F    HW: 1T3 945 207 F
   Component: SHLli1         040 5222
   Serial number: L0000202410311843328
   left tail lamp 2:
   Subsystem 5 - Part No SW: 1T3 945 307 F    HW: 1T3 945 307 F
   Component: SHLli2         071 5222
   Serial number: L0000202411150845054
   Right rear tail lamp 1:
   Subsystem 6 - Part No SW: 1T3 945 208 F    HW: 1T3 945 208 F
   Component: SHLre1         040 5222
   Serial number: R0000202410312052489
   Right rear tail lamp 2:
   Subsystem 7 - Part No SW: 1T3 945 307 F    HW: 1T3 945 307 F
   Component: SHLre2         071 5222
   Serial number: R0000202411150845067
   Virtual pedal door opening: rear driver side:
   Subsystem 8 - Part No SW: 3G0 962 243 F    HW: 3G0 962 243 F
   Component: VIP_SBT_FS     H18 0910
   Serial number: 67102990
   Virtual pedal door opening: rear passenger side:
   Subsystem 9 - Part No SW: 3G0 962 243 F    HW: 3G0 962 243 F
   Component: VIP_SBT_BFS    H18 0910
   Serial number: 67106224
   Subsystem 10 - Part No SW: 3G0 962 243 F    HW: 3G0 962 243 F
   Component: GEB.F.Heckoef  H18 0910
   Serial number: 67119830
8491266 - Secure Onboard Communication
          U14FE 00 {00101100} - Signature Verification Failed
          {SOK_signature_verification_failed}
                    Fault Frequency: 95
                    Mileage: 21 km
                    Date: 2025.02.21
                    Time: 18:15:07
8491267 - Secure Onboard Communication
          U14FF 00 {00100000} - Signature Generation Failed
          {SOK_signature_creation_failed}
                    Mileage: 20 km
                    Date: 2025.02.21
                    Time: 16:16:29
8511745 - Occupant Detection
          U173E 00 {00101000} - Function Restriction due to Implausible Message
          {Occupant_Presence_Service_Restriction}
                    Fault Frequency: 14
                    Mileage: 183 km
                    Date: 2025.03.19
                    Time: 15:52:56
90382 - Databus
          {Leistungsmodul für LED-Scheinwerfer rechts - Abblendlicht defekt}
                    Mileage: 188 km
                    Date: 2025.03.21
                    Time: 13:18:32
                    Terminal 15 status: On
                    Engine run: OFF
                    Voltage: 14.8 V
                    Outside temperature: 4.0 °C
8516873 - Charging Socket Flap A
          B1CA2 F1 {01100100} - Locking Activation Error
          {HVLM_control_flap_lock_locking_a}
                    Reset counter: 37
                    Mileage: 39 km
                    Date: 2025.02.27
                    Time: 17:27:51
8830976 - Databus for Virtual Remote Control Key
          U1A2F 00 {00101000} - Single Wire Mode
          {Data_bus_mdk_single_wire_mode}
                    Mileage: 22 km
                    Date: 2025.02.22
                    Time: 08:05:12
   Part No SW: 1N3 909 059 AA    HW: 1N3 909 059
   Component: EBB-ZF-Gen1   H47 0853
   Serial number: 0000000         Dataset Number: V03935435CY 0001
   Coding: A0404080600028
   ASAM Dataset: EV_BrakeBoostZFMEBUNECE 001034
   ROD: EV_BrakeBoostZFMEBUNECE.rod
   VCID: 74BAB2C64E354D4A9BE-8020-R SFD+SFD2
Address 2B: Steer. Col. Lock (J764)       Labels:. 3WA-905-861.clb
   Part No SW: 3WA 905 861     HW: 3WA 905 861
   Component: ELV-MQB_UNECE H05 0063
   Serial number: 24000262799015 Dataset Number: V03935384XW 0001
   Coding: 8880000000000000
   Shop #: WSC 00000 790 00532
   ASAM Dataset: EV_ELVMarqUNECE 003006
   ROD: EV_ELVMarqUNECE_003_VW27.rod
   VCID: 0842F63622BD59AAC76-805C-R SFD+SFD2
   Component: MEM-FS        011 0571
   Serial number: 24B0501KA02039 Dataset Number: V03935362VP 0001
   Coding: 0118BA4000013A008803010121010000000000000000000000000000215000
   ROD: EV_SCMDriveSideCONTIAU736_VW42.rod
Address 3C: Lane Change (J1086)       Labels:* Redir Fail!
   Part No SW: 2Q0 907 686 H    HW: 2Q0 907 686 H
   Component: HRE_Master    H26 0320
   Serial number: 14520059654591  Dataset Number: V03935416KP 0001
   Coding: 5A954750
   ASAM Dataset: EV_HREHellaGen3MstrUNECE 001001
   ROD: EV_HREHellaGen3MstrUNECE_VW27.rod
   VCID: 3FD02DEA37F3DE12B6C-806A-R
   Subsystem 1 - Part No SW: 2Q0 907 685 H    HW: 2Q0 907 685 H
   Component: HRE_Slave      H26 0320
   Serial number: 14520060253336
   Part No SW: 1EA 959 593 F    HW: 1EA 959 593 F
   Component: TSG FS        009 0563
   Serial number: 0000542453170  Dataset Number: V03935421ZA 0001
   Coding: 0035DB20D200028044000020
   ASAM Dataset: EV_DCU3DriveSideMAXHCONT 001004
   ROD: EV_DCU3DriveSideMAXHCONT_VWE3.rod
   VCID: 45DC3F02552F84C2FC0-8010-R
   Door operating panel: driver side:
   Subsystem 1 - Part No SW: 11A 959 862 C    HW: 11A 959 862 C
   Component: EX36 TBF_FS    H23 0116
   Serial number: 1383-23.10.24-------
   Part No SW: 1N3 907 144 Q    HW: 1N3 907 144 L
   Component: BASGEN1MQB37  131 7341
   Serial number: 01765164 Dataset Number: V03935435WK 0001
   Coding: 00000000000002010000020101000100000001000101
   ASAM Dataset: EV_SteerAssisBASGEN1MQB37 017078
   ROD: EV_SteerAssisBASGEN1MQB37.rod
   VCID: 3C2A5AE626E5C50A93E-8068-R SFD+SFD2
   Part No SW: 3G0 035 466 F    HW: 3G0 035 466 F
   Component: AMPeth16CDoIP H03 7012
   Serial number: A1130N00028514  Dataset Number: V03935433MB 0001
   Coding: 24090100000000000000000000000000000000000000000000
   ASAM Dataset: EV_AMPEthMQB37w 001005
   ROD: EV_AMPEthMQB37w_VW38.rod
   VCID: 280296B6C27D79AAE76-807C-R SFD+SFD2
Address 51: Electric Drive (J841-ECN-)       Labels: 0ET-907-INV-V1.clb
   Part No SW: 0ET 907 121 G    HW: 0ET 907 121 G
   Component: MEB INV6.0    H10 7260
   Dataset Number: V03935396ZE 0001
   ASAM Dataset: EV_DMCM21000110ET907121G 001001
   ROD: EV_DMCM21000110ET907121G.rod
   VCID: 44DA22065E15BDCAEBE-8010-R SFD+SFD2
41631 - No Communication with ESP (Vehicle Dynamics) Control Module
          U0122 00 {00100000} - -
          {Lost Communication With Vehicle Dynamics Control Module}
41665 - No Communication with Engine Control Module (SAE ECM/PCM)
          U0100 00 {00101000} - -
          {Lost Communication with ECM/PCM}
                    Mileage: 21 km
                    Date: 2025.02.21
                    Time: 18:45:58
43408 - Online Remote Update
          U192A 00 {00101110} - No Signal
          {Online Remote UpdateNo signal}
                    Fault Frequency: 136
                    Mileage: 20 km
                    Date: 2025.02.21
                    Time: 17:06:25
   Part No SW: 1EA 959 592 F    HW: 1EA 959 592 F
   Component: TSG BFS       009 0563
   Serial number: 0000542154577  Dataset Number: V03935435GJ 0001
   Coding: 00355320DE00028040800020
   ASAM Dataset: EV_DCU3PasseSideMAXHCONT 001004
   ROD: EV_DCU3PasseSideMAXHCONT_VWE3.rod
   Part No SW: 10C 035 842 A    HW: 10C 035 842
   Component: IC3GSF--US    H09 3626
   Dataset Number: V03935418SE 0001
   Coding: 64101030000000000000000000000000000000000000000000
   ASAM Dataset: EV_MUICASSAFEPart 002001
   ROD: EV_MUICASSAFEPart_002_VNE4.rod
   VCID: 1B68B97A832BA2327A4-804E-R SFD+SFD2
   Subsystem 1 - Part No SW: 1T3 919 605 M    HW: 1T3 919 605 D
   Component: ABT-E3_13      H43 4045
   Serial number: CKS00718082411550163
   Part No SW: 1EE 907 556 A    HW: 5WA 907 556 D
   Component: TV eEntry     H32 0605
   Serial number: FZ6ESP231024000 Dataset Number: V03935441LX 0001
   Coding: 060300003F140000
   ASAM Dataset: EV_CamSysTVFicosUNECE 002004
   ROD: EV_CamSysTVFicosUNECE_VWE3.rod
   Front peripheral camera slave:
   Subsystem 1 - Part No SW: 5WA 980 546 E    HW: 5WA 980 546 D
   Component: R243 UmfKamSV  H23 0070
   Serial number: FCLMAR141024010822C1
   Peripheral camera slave: left:
   Subsystem 2 - Part No SW: 5WA 980 546 E    HW: 5WA 980 546 D
   Component: R244 UmfKamSL  H23 0070
   Serial number: FCLMAR30092400073E6D
   Right peripheral camera slave:
   Subsystem 3 - Part No SW: 5WA 980 546 E    HW: 5WA 980 546 D
   Component: R245 UmfKamSR  H23 0070
   Serial number: FCLMAR06102401045B8D
   Rear peripheral camera slave:
   Subsystem 4 - Part No SW: 5WA 980 546 E    HW: 5WA 980 546 D
   Component: R246 UmfKamSH  H23 0070
   Serial number: FCLMAR28102401070425
   Part No SW: 4KE 959 107 B    HW: 4KE 959 107 B
   Component: HDSG-Modul    H08 0342
   Revision: --------    Serial number: A2-C765-4922-2 Dataset Number: V03935420NU 0001
   Coding: 6208
   ASAM Dataset: EV_DeckLidCONTIAU536 001006
   ROD: EV_DeckLidCONTIAU536_001_VWE3.rod
   Part No SW: 14A 035 285 A    HW: 14A 035 285
   Component: OCU4MEB_UNECE H11 0554
   Serial number: 0000000407VIHJJ Dataset Number: V03935436CE 0001
   Coding: 06020700010000000000010013000000101112111012000010
   ASAM Dataset: EV_OCUGen4UNECE 001050
   ROD: EV_OCUGen4UNECE_VWE3.rod
   VCID: 1E6EB06E9039B71A9DA-804A-R SFD+SFD2
0082 - Databus
          U1121 00 {00100110} - Missing Message
          {Ethernet Databus missing message - Gateway}
                    Mileage: 209 km
                    Date: 2025.03.25
                    Time: 16:12:22
                    Voltage terminal 30: 14.6 V
1375744 - Secure Onboard Communication
          U14FE 00 {00100000} - Signature Verification Failed
                    Reset counter: 37
                    Mileage: 204 km
                    Date: 2025.03.22
                    Time: 19:00:20
1375488 - Secure Onboard Communication
          U14FD 00 {00101100} - Time Server not Available
          {SOK_timeserver_not_available}
Address 7E: Ctrl Head Dash (J1254)       Labels:| 10A-920-320.clb
   Part No SW: 10A 920 320 D    HW: 10A 920 320 D
   Component: FAHRERDISPLAY 031 0650
   Serial number: 4G1XF446-D05622 Dataset Number: V03935392XE 0001
   Coding: 267001
   ASAM Dataset: EV_DashBoardLGMEB 002032
   ROD: EV_DashBoardLGMEB_002_VWE3.rod
   VCID: 167EA84E7809FF5A45A-8042-R SFD
Address 8C: HV Battery (J840)       Labels: 0Z1-915-184.clb
   Part No SW: 0Z1 915 184 AE    HW: 0Z1 915 184 D
   Component: J840 K8C  BMC 010 1141
   Dataset Number: V03935430CT 0001
   ASAM Dataset: EV_BMCeVWBSMEB 003018
   ROD: EV_BMCeVWBSMEB_003_VWE3.rod
   VCID: 7DAC97E27D7F0C02E40-8028-R
   Cell module control module 1:
   Subsystem 1 - Part No SW: 0Z1 915 140 BL    HW: 0Z1 915 140 BC
   Component: SX6  X74  CMC  005 1140
   Serial number: 00000008102401020010
   Cell module control module 5:
   Subsystem 2 - Part No SW: 0Z1 915 140 M    HW: 0Z1 915 140 D
   Serial number: 00000018102401032858
   Cell module control module 9:
   Subsystem 3 - Part No SW: 0Z1 915 140 M    HW: 0Z1 915 140 D
   Serial number: 00000018102401032846
   Cell module control module 13:
   Subsystem 4 - Part No SW: 0Z1 915 140 M    HW: 0Z1 915 140 D
   Serial number: 00000018102401032849
   Coolant heating:
   Subsystem 5 - Part No SW: 1EE 963 231     HW: 1EE 963 231
   Component: J848 HV-PTC    H04 0026
   Serial number: 1EE96323124298001896
Address A5: Frt Sens. Drv. Assist (R242)       Labels:* 1EA-980-65X-V2.clb
   Part No SW: 1EA 980 653 E    HW: 1EA 980 653 A
   Component: MEB MFK 4.1   H08 5556
   Dataset Number: V03935445AY 0001
   Coding: 010A302E1F4500F83724301C4000000000000000000000000000000000000000
   ASAM Dataset: EV_MFK41ValeoMEB 001080
   ROD: EV_MFK41ValeoMEB_VWE3.rod
1124497 - Databus
          U1123 00 {00101111} - Received Error Message
          {ACC_18_ACC_Status_ACC_irreversibel_ERROR}
                    Mileage: 209 km
                    Date: 2025.03.25
                    Time: 16:12:18
1124496 - Databus
          U1123 00 {00101110} - Received Error Message
          {ACC_18_ACC_Status_ACC_reversibel_ERROR}
                    Mileage: 209 km
                    Date: 2025.03.25
                    Time: 16:10:43
1126421 - Databus
          {FAS_Anzeigen_01_KBI_Anzeigefehler_LDW_Anzeigefehler_ERROR}
                    Mileage: 209 km
                    Date: 2025.03.25
                    Time: 16:10:47
1126487 - Databus
          U1123 00 {00101000} - Received Error Message
          {Airbag_02_AB_Gurtschloss_Reihe3_FA_ERROR}
                    Mileage: 65 km
                    Date: 2025.02.27
                    Time: 20:16:05
Address BE: Slid. Door Rear Left (J926)       Labels:| 1N3-959-244.clb
   Part No SW: 1N3 959 244 B    HW: 1N3 959 244 B
   Component: Slidingdoor_d H04 0028
   Serial number: 97100269 Dataset Number: V03935426PK 1510
   Coding: D600
   ASAM Dataset: EV_SlideDoorDriveHufIDBuz 002110
   ROD: EV_SlideDoorDriveHufIDBuz_002.rod
   VCID: 353C4FC205CF14426C0-8060-R
32793 - Automatic Sliding Door Arrester
          B1BAC 19 {01100000} - Current Too High
          {Arrester_over_current}
32785 - Automatic Sliding Door Arrester
          B1BAC 11 {01100000} - Short to Ground
          {Arrester_short_circuit_to_ground}
Address BF: Slid. Door Rear Right (J927)       Labels:| 1N3-959-244.clb
   Component: Slidingdoor_p H04 0028
   Serial number: 97100519 Dataset Number: V03935426PL 1510
   Coding: D600
   ASAM Dataset: EV_SlideDoorPasseHufIDBuz 002110
   ROD: EV_SlideDoorPasseHufIDBuz_002.rod
37460 - Control Module for Sliding Door
          B1307 54 {01100000} - Missing Calibration / Basic Setting
          {Door_window_not_normalized}
Address C0: Act. for Ext. Noise (J943)       Labels: 1EA-035-335.clb
   Part No SW: 1T3 035 335 A    HW: 1EA 035 335
   Component: E_SOUND_SG    H06 0006
   Serial number: JTK072281024953
   ASAM Dataset: EV_ESounHarmaMEBUNECE 001006
   ROD: EV_ESounHarmaMEBUNECE_VWE3.rod
   VCID: 2C0A6AA6D685558A03E-8078-R
4194306 - Databus
          U1201 00 {00101110} - No Communications
          {data_bus_drivetrain_no_communication}
                    Mileage: 209 km
                    Date: 2025.03.25
                    Time: 16:12:41
Address C6: Batt. Chrg. (J1050)       Labels:| 1EA-915-692.clb
   Part No SW: 1EK 915 692 J    HW: 1EK 915 692 H
   Component: OCDC Gen4+    H03 2207
   Revision: 00H03000
   Coding: 308010
   ASAM Dataset: EV_OCDCXPHASERB8MEBB 002001
   ROD: EV_OCDCXPHASERB8MEBB_002_VWE3.rod
   VCID: 4BC8093A734B72B22A4-801E-R SFD+SFD2
Address CA: Sunroof (J245)       Labels:* None
   Part No SW: 14A 907 594 A    HW: 4K0 907 594
   Component: SAD_STG_1     011 0030
   Dataset Number: V03935394MS 0001
   Coding: 01000374180F
   ASAM Dataset: EV_SunRoofCONTIPO513 002004
   ROD: EV_SunRoofCONTIPO513.rod
   VCID: 290493B2D97740A2F88-807C-R
   Windshield tinting control module:
   Subsystem 1 - Part No SW: 85F 907 594 A    HW: 85F 907 594
   Component: J1288_SGD1CON  007 0030
   Serial number: 000009865610440
   Part No SW: 992 941 572 AG    HW: 992 941 572 A
   Component: LED1L         H17 9104
   ASAM Dataset: EV_LLPGen3LKEBODPO68X 002003
   ROD: EV_LLPGen3LKEBODPO68X_002_VW27.rod
   VCID: 6882D6B602FDB9AA276-803C-R
131329 - Databus
          U1201 00 {10101100} - No Communications
          {can data bus - no communication}
                    Mileage: 209 km
                    Date: 2025.03.25
                    Time: 16:12:35
131332 - Databus
          U1121 00 {10101100} - Missing Message
          {can message LED_Soll_Fkt2 missing}
                    Mileage: 209 km
                    Date: 2025.03.25
                    Time: 16:10:42
131347 - Databus
          {CAN message ESP_21 missing}
                    Mileage: 209 km
                    Date: 2025.03.25
                    Time: 16:10:42
131353 - Databus
          {CAN message Klemmen_Status_01 missing}
                    Mileage: 209 km
                    Date: 2025.03.25
                    Time: 16:10:42
   Component: LED1R         H17 9104
   ASAM Dataset: EV_LLPGen3RKEBODPO68X 002003
   ROD: EV_LLPGen3RKEBODPO68X_002_VW27.rod
131329 - Databus
                    Mileage: 209 km
                    Date: 2025.03.25
                    Time: 16:12:17
131332 - Databus
                    Mileage: 209 km
                    Date: 2025.03.25
                    Time: 16:10:42
131347 - Databus
                    Mileage: 209 km
                    Date: 2025.03.25
                    Time: 16:10:42
131353 - Databus
                    Mileage: 209 km
                    Date: 2025.03.25
                    Time: 16:10:42
139268 - Bulb for Low-Beam Headlamp
          C1198 FA {00101000} - Short Circuit
          {low beam - electric malfunction SC}
                    Reset counter: 34
                    Mileage: 188 km
                    Date: 2025.03.21
                    Time: 13:18:26
Address DE: Charger 1 for mobile dev (J0000)       Labels:* None
   Part No SW: 3P0 035 502 B    HW: 3P0 035 502
   Component: COUPLING BOX  004 0170
   Serial number: 324000000000059 Dataset Number: V03935426MT 0001
   Coding: 400080
   ASAM Dataset: EV_DualCouplBoxSK336 001006
   ROD: EV_DualCouplBoxSK336.rod
   VCID: 241A8286BE559DCACBE-8070-R SFD+SFD2
Address 8116: Snd enhanct 2 (J943)       Labels: None
   Part No SW: 1T3 035 335 B    HW: 1EA 035 335
   Component: E_SOUND_SG    H06 0007
   Serial number: JTK072291024953
   ASAM Dataset: EV_ESoun2HarmaMEBUNECE 001003
   ROD: EV_ESoun2HarmaMEBUNECE.rod
Address 8123: App server 1 system 1 adaptive (SWC4)       Labels: V04-007-XXX-SWC4.clb
   Part No: V04 007 003 LE
   Component: ICAS1 Sys_Ada 0254
   Dataset Number: V03935439BB 0001
   ASAM Dataset: EV_AppServ1Sys1ICAS1UNECE 001002
   ROD: EV_AppServ1Sys1ICAS1UNECE_VWE3.rod
   VCID: 75BC8FC2454F5442AC0-8020-R SFD+SFD2
Address 8124: App server 1 system 2 Java (SWC5)       Labels: V04-007-XXX-SWC5.clb
   Part No: V04 007 003 LF
   Component: ICAS1 Sys_Jav 0254
   Dataset Number: V03935439BA 0001
   ASAM Dataset: EV_AppServ1Sys2ICAS1UNECE 001002
   ROD: EV_AppServ1Sys2ICAS1UNECE_VWE3.rod
   VCID: 76BE88CE58495F5AA5A-8022-R SFD+SFD2
Address 8125: App server 3 system 1 infotaint. (SWC6)       Labels:| V04-007-XXX-SWC6.clb
   Part No: V04 007 003 RH
   Component: IC3GIVI-S--US 3626
   Dataset Number: V03935442BN 0001
   ASAM Dataset: EV_MUICASIVIPart 003001
   ROD: EV_MUICASIVIPart_003_VWE3.rod
   VCID: 7EAE90EE7079171AFDA-802A-R SFD+SFD2
Address 8128: Light line display (J145)       Labels: 1T3-919-451.clb
   Part No SW: 1T3 919 451 G    HW: 1T3 919 451 G
   Component: ID_Light_GA   033 0074
   ASAM Dataset: EV_SmartLight1MEBGA 001014
   ROD: EV_SmartLight1MEBGA.rod
Address C002: SW Cluster Embedded (SWC2)       Labels: V04-007-XXX-SWC2.clb
   Part No: V04 007 003 LG
   Component: ICAS1 SWCL_Em 0254
   Dataset Number: V03935439BG 0001
   ASAM Dataset: EV_SWCLEmbed1ICAS1UNECE 001002
   ROD: EV_SWCLEmbed1ICAS1UNECE_VWE3.rod
   VCID: 77A085CA5F432652BEC-8022-R SFD+SFD2
0268 - Software Cluster Embedded 1
          U1775 00 {00100110} - Software Error Detected
          {R7_Illegal_memory_access}
                    Date: 2025.03.25
8516625 - Expanded Charging Functions
          U15E9 00 {01101100} - Charging Plan Programming Error
                    Mileage: 179 km
                    Date: 2025.03.15
                    Time: 12:03:49
Address C003: SW Cluster Housekeeping (SWC3)       Labels: V04-007-XXX-SWC3.clb
   Part No: V04 007 003 LH
   Component: ICAS1 SWCL_HK 0254
   ASAM Dataset: EV_SWCLHouse1ICAS1UNECE 001002
   ROD: EV_SWCLHouse1ICAS1UNECE.rod
End----------(Elapsed Time: 31:27, VBatt start/end: 14.9V/14.8V)-----------
------------------------------43 Faults Found------------------------------
blockmap-01-0EA-906-014-GG_WVG5WVEB2SH017765-20250325-1218.CSV
;SW:0EA-906-014-GG   HW:0EA-907-425-K ---  Engine
;Component:E-Vehicle     H80 3875, Coding:4102000350042C0236000800000000000000000000000000
;EV_VCU00XXX0200EA906014GG,003002,EV_VCU00XXX020_VNE4.rod
;Tuesday,25,March,2025,12:18:06:58926
;VCDS Version: Release 25.3.0 (x64)  Data version: 20250311 DS365.0
;VCID: 78A286F6525D292AB76-802C-R SFD+SFD2
Group,Description,Actual
IDE00011,Vehicle Identification Number (VIN),||WVG5WVEB2SH017765|,
IDE00019,Voltage terminal 30,14.902, V
IDE00086,Accelerator pedal position,14.5, %
IDE00089,Driving position,d,
IDE00097,OBD - requirements for which this vehicle is designed,None,
IDE00102,Control Module temperature,40.0, °C
IDE00150,Pressure in brake servo unit,0.000, bar
IDE00252,Brake system vacuum pump,Pump off,
IDE00380,Coolant fan 1: activation,30.08, %
IDE00392,Accelerator pedal: sensor voltage 1,0.720, V
IDE00393,Accelerator pedal: sensor voltage 2,0.360, V
IDE00451,Currently running routine,Unknown (0)
IDE00541,Acceleration,0.000, m/s²
IDE00601,Monitoring status since erasing DTC memory,
IDE00973,Outside temperature,20.0, °C
IDE01021,Current of H-V / hybrid battery,-1.5, A
IDE01714,Status reverse gear,not selected,
IDE01922,Vehicle distance driven,210, km
IDE02656,System condition of parking brake,Open,
IDE02832,Coolant circulation pump: activation,65.36, %
IDE03767,Engine status,Stop,
IDE04885,Hybrid batt charge cond act val standardized,75.50, %
IDE04913,Current speed of electric motor,0.0, /min
IDE05679-MAS19394,Accelerator monitoring level-Accelerator pedal position,Not operated,
IDE06703-IDE12714,Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration,No,
IDE06703-MAS14977,Drivetrain coordinator: ACC fault status-ACC active: although TSK passive,No,
IDE06703-MAS14978,Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set,No,
IDE06703-MAS14979,Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously,No,
IDE06703-MAS14980,Drivetrain coordinator: ACC fault status-ACC active: although limiter active,No,
IDE06703-MAS14981,Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking,No,
IDE06703-MAS14982,Drivetrain coordinator: ACC fault status-ACC sends undefined signals,No,
IDE06703-MAS14983,Drivetrain coordinator: ACC fault status-ACC active although main switch off,No,
IDE06703-MAS14984,Drivetrain coordinator: ACC fault status-ACC is active despite driver braking,No,
IDE06703-MAS14985,Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling,No,
IDE06704-MAS14986,Drivetrain coordinator: brake fault status-Deceleration sensor not available,No,
IDE06704-MAS14987,Drivetrain coordinator: brake fault status-Deceleration sensor malfunction,No,
IDE06704-MAS14988,Drivetrain coordinator: brake fault status-ESP system error,No,
IDE06704-MAS14989,Drivetrain coordinator: brake fault status-ESP system malfunction due to inaccurate engine torque,No,
IDE06704-MAS14990,Drivetrain coordinator: brake fault status-ESP indicates TSK message consistency error,No,
IDE06704-MAS14991,Drivetrain coordinator: brake fault status-TSK/ESP handshake error,No,
IDE06704-MAS14992,Drivetrain coordinator: brake fault status-ESP automatic engagement malfunction,No,
IDE06704-MAS14993,Drivetrain coordinator: brake fault status-Brake light implausible,No,
IDE06705-MAS05179,Drivetrain coordinator: brake function status-ABS intervention,No,
IDE06705-MAS05180,Drivetrain coordinator: brake function status-ESP intervention,No,
IDE06705-MAS05181,Drivetrain coordinator: brake function status-EDL intervention,No,
IDE06705-MAS05186,Drivetrain coordinator: brake function status-ASR intervention,No,
IDE06705-MAS05187,Drivetrain coordinator: brake function status-MSR intervention,No,
IDE06705-MAS05192,Drivetrain coordinator: brake function status-Driver braking,Yes,
IDE06705-MAS05195,Drivetrain coordinator: brake function status-HDC active,No,
IDE06705-MAS15001,Drivetrain coordinator: brake function status-ESP invokes TSK braking,No,
IDE06705-MAS15002,Drivetrain coordinator: brake function status-EPB active,No,
IDE06705-MAS15003,Drivetrain coordinator: brake function status-ASP intervention,No,
IDE06705-MAS15004,Drivetrain coordinator: brake function status-ADS intervention,No,
IDE06705-MAS15006,Drivetrain coordinator: brake function status-Stopping distance reduction2 warning jolt,No,
IDE06705-MAS15007,Drivetrain coordinator: brake function status-ESP sampled passive (ESP off),No,
IDE06705-MAS15008,Drivetrain coordinator: brake function status-ASR sampled passive (ASR off),No,
IDE06705-MAS15009,Drivetrain coordinator: brake function status-ESP recognizes vehicle at rest,Yes,
IDE06705-MAS15010,Drivetrain coordinator: brake function status-ACC stopping distance control active,No,
IDE06706,ACC variants,ACC with Stop & Go,
IDE06707,CCS Switch,ACC operating unit,
IDE06709,ACC variants (coding),ACC with braking until at standstill/Stop & Go,
IDE07543,Vehicle speed,0.00, km/h
IDE07575,Driver intention torque,0.0, Nm
IDE07598-MAS00320,Cruise control switch actuation-Main switch,operated,
IDE07598-MAS00325,Cruise control switch actuation-Set,Not operated,
IDE07598-MAS00326,Cruise control switch actuation-Resume,Not operated,
IDE07598-MAS01632,Cruise control switch actuation-Status,OK,
IDE07598-MAS02309,Cruise control switch actuation-Accelerate,Not operated,
IDE07598-MAS02310,Cruise control switch actuation-DELAY,Not operated,
IDE07598-MAS05172,Cruise control switch actuation-Cancel,Not operated,
IDE07598-MAS05806,Cruise control switch actuation-Main switch hardware,operated,
IDE07598-MAS05807,Cruise control switch actuation-Coding,plausible,
IDE07598-MAS05809,Cruise control switch actuation-Limit function,not selected,
IDE07598-MAS05812,Cruise control switch actuation-Limit button,Not operated,
IDE07598-MAS05813,Cruise control switch actuation-Main switch CAN,operated,
IDE07598-MAS05842,Cruise control switch actuation-Large increment,Not operated,
IDE07598-MAS05843,Cruise control switch actuation-Control component verified,Yes,
IDE07605,Cruise control system: temporary deactivation,No switch-off,
IDE07608,Standard test of current section,0,
IDE07904-ENG118117,Brake test switch status-actuated__activated,operated,
IDE07904-ENG114825,Brake test switch status-Ident_32,1,
IDE07905-ENG118117,Brake light switch status-actuated__activated,operated,
IDE07905-ENG114825,Brake light switch status-Ident_32,1,
IDE08998-MAS05117,Driver info-Driver,not installed,
IDE09098,E-machine electrical power,290.688, kW
IDE09099,E-machine mechanical power,245.408, kW
IDE09116,Power electronics: traction network voltage,412.3, V
IDE10300,OBD Driving Cycle detected,active,
IDE10710-ENG125936,Exhaust warning light: triggering contr. module-Blinking_MIL_due_to_misfire_is_causing_catalyst_damage,No,
IDE10710-ENG130107,Exhaust warning light: triggering contr. module-MIL Request from Transmission Control Module,No,
IDE10710-ENG355207,Exhaust warning light: triggering contr. module-MIL_Request_from_BCCM,No,
IDE10710-ENG353763,Exhaust warning light: triggering contr. module-MIL_Request_from_DCDC,No,
IDE10710-ENG125937,Exhaust warning light: triggering contr. module-MIL_request_register_ident,0,
IDE10710-ENG420335,Exhaust warning light: triggering contr. module-MIL-Request from Battery Diagnostic Control Module,No,
IDE10710-ENG130102,Exhaust warning light: triggering contr. module-MIL-Request from Battery Energy Control Module,No,
IDE10710-ENG137566,Exhaust warning light: triggering contr. module-MIL-Request from Battery Energy Control Module 48V,No,
IDE10710-ENG130110,Exhaust warning light: triggering contr. module-MIL-Request from Brake System Control Module,No,
IDE10710-ENG130100,Exhaust warning light: triggering contr. module-MIL-Request from Brake System Control Module 2,No,
IDE10710-ENG130103,Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module,No,
IDE10710-ENG130109,Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module 2,No,
IDE10710-ENG137567,Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module 48V,No,
IDE10710-ENG130105,Exhaust warning light: triggering contr. module-MIL-Request from Engine Control Module,No,
IDE10710-ENG130106,Exhaust warning light: triggering contr. module-MIL-Request from Engine Control Module 2,No,
IDE10710-ENG130111,Exhaust warning light: triggering contr. module-MIL-Request from HVAC Control Module,No,
IDE10710-ENG130108,Exhaust warning light: triggering contr. module-MIL-Request from Transmission Control Module 2,No,
IDE11663-IDE06673,H-V energy management mode-Initialization status,not active,
IDE11663-IDE12475,H-V energy management mode-Input status,OK,
IDE11663-MAS01458,H-V energy management mode-Operating condition,not active,
IDE13301-MAS06606,Drivetrain coordinator: brake fault status-Brake under pressure too low,No,
IDE13301-MAS14986,Drivetrain coordinator: brake fault status-Deceleration sensor not available,No,
IDE13301-MAS14987,Drivetrain coordinator: brake fault status-Deceleration sensor malfunction,No,
IDE13301-MAS14988,Drivetrain coordinator: brake fault status-ESP system error,No,
IDE13301-MAS14989,Drivetrain coordinator: brake fault status-ESP system malfunction due to inaccurate engine torque,No,
IDE13301-MAS14990,Drivetrain coordinator: brake fault status-ESP indicates TSK message consistency error,No,
IDE13301-MAS14991,Drivetrain coordinator: brake fault status-TSK/ESP handshake error,No,
IDE13301-MAS14992,Drivetrain coordinator: brake fault status-ESP automatic engagement malfunction,No,
IDE13301-MAS14993,Drivetrain coordinator: brake fault status-Brake light implausible,No,
IDE13301-MAS16114,Drivetrain coordinator: brake fault status-Deceleration management error,No,
IDE13301-MAS16115,Drivetrain coordinator: brake fault status-Deceleration management: restricted performance,No,
IDE13301-MAS16116,Drivetrain coordinator: brake fault status-Deceleration management not available,No,
IDE13336-MAS04795,Drive train coordinator reversible switch off conditions-main switch off,No,
IDE13336-MAS05192,Drive train coordinator reversible switch off conditions-Driver braking,Yes,
IDE13336-MAS05823,Drive train coordinator reversible switch off conditions-Speed signal error during initialization,No,
IDE13336-MAS05824,Drive train coordinator reversible switch off conditions-Emer. engine operation,No,
IDE13336-MAS05836,Drive train coordinator reversible switch off conditions-Acceleration monitoring error,No,
IDE13336-MAS05901,Drive train coordinator reversible switch off conditions-Trans. emerg. operation,No,
IDE13336-MAS12585,Drive train coordinator reversible switch off conditions-Speed threshold for reversible ACC shut-off,No,
IDE13336-MAS12586,Drive train coordinator reversible switch off conditions-Speed threshold for ending the brake torque shut-off ramp,No,
IDE13336-MAS12588,Drive train coordinator reversible switch off conditions-Speed cut-off active,No,
IDE13336-MAS12590,Drive train coordinator reversible switch off conditions-Reversible brake system error,No,
IDE13336-MAS12591,Drive train coordinator reversible switch off conditions-Engine off or drive is not ready,No,
IDE13336-MAS15049,Drive train coordinator reversible switch off conditions-Drive train open or no gear selected,No,
IDE13336-MAS16227,Drive train coordinator reversible switch off conditions-Stopping distance reduction 3 interventions,No,
IDE13336-MAS16228,Drive train coordinator reversible switch off conditions-Tracking system interface shutdown,No,
IDE13336-MAS16230,Drive train coordinator reversible switch off conditions-ESP safety-related message condition,No,
IDE13336-MAS16231,Drive train coordinator reversible switch off conditions-ACC switch off because of driver braking,No,
IDE13336-MAS16232,Drive train coordinator reversible switch off conditions-PCC sensor: reversible error,No,
IDE13336-MAS16235,Drive train coordinator reversible switch off conditions-Intelligent parking assistant reversible error,No,
IDE13336-MAS16246,Drive train coordinator reversible switch off conditions-ACC breaking only possible because of CAN bus,No,
IDE13336-MAS16247,Drive train coordinator reversible switch off conditions-Diagnostics fadeout due to identified malfunction,No,
IDE13336-MAS16248,Drive train coordinator reversible switch off conditions-Safety computer detects crash,No,
IDE13336-MAS16249,Drive train coordinator reversible switch off conditions-Electrical parking brake: braking,No,
IDE13336-MAS16253,Drive train coordinator reversible switch off conditions-GRA breaking intervention: switch off due to brake disc temperature,No,
IDE13336-MAS16254,Drive train coordinator reversible switch off conditions-Hill descent assistant active,No,
IDE13336-MAS16255,Drive train coordinator reversible switch off conditions-Locking by trailer shunting assistant,No,
IDE13336-MAS16256,Drive train coordinator reversible switch off conditions-Blocking by parking assistant,No,
IDE13337-MAS05814,Drive train coordinator irreversible switch off conditions-CAN communication error,No,
IDE13337-MAS05815,Drive train coordinator irreversible switch off conditions-CAN signal error,No,
IDE13337-MAS05818,Drive train coordinator irreversible switch off conditions-Transmission coding not plausible,No,
IDE13337-MAS05820,Drive train coordinator irreversible switch off conditions-ACC error,No,
IDE13337-MAS05821,Drive train coordinator irreversible switch off conditions-Braking intervention too weak,No,
IDE13337-MAS05824,Drive train coordinator irreversible switch off conditions-Emer. engine operation,No,
IDE13337-MAS05825,Drive train coordinator irreversible switch off conditions-Engine control module fault,No,
IDE13337-MAS05829,Drive train coordinator irreversible switch off conditions-Brake light fault,No,
IDE13337-MAS05830,Drive train coordinator irreversible switch off conditions-CCS deactivated due to fault in control component,No,
IDE13337-MAS05831,Drive train coordinator irreversible switch off conditions-ACC deactivated due to fault in control component,No,
IDE13337-MAS05832,Drive train coordinator irreversible switch off conditions-Coding error,No,
IDE13337-MAS05833,Drive train coordinator irreversible switch off conditions-ESC error,No,
IDE13337-MAS05835,Drive train coordinator irreversible switch off conditions-Clutch pedal fault,No,
IDE13337-MAS05836,Drive train coordinator irreversible switch off conditions-Acceleration monitoring error,No,
IDE13337-MAS15052,Drive train coordinator irreversible switch off conditions-Brake light actuation malfunction,No,
IDE13337-MAS16257,Drive train coordinator irreversible switch off conditions-Brake pedal implausible,No,
IDE13337-MAS16258,Drive train coordinator irreversible switch off conditions-Transport mode active,No,
IDE13337-MAS16259,Drive train coordinator irreversible switch off conditions-GRA looking due to software as product,No,
IDE13337-MAS16260,Drive train coordinator irreversible switch off conditions-Emergency assistant: actual acceleration error,No,
IDE13337-MAS16262,Drive train coordinator irreversible switch off conditions-Vehicle speed determination: substitute value,No,
IDE13337-MAS16263,Drive train coordinator irreversible switch off conditions-Intelligent parking assistant irreversible error,No,
IDE13835-MAS17093,VKMS: relevant VIN number for last data supply-Status of vehicle identification number,valid,
IDE13835-MAS17094,VKMS: relevant VIN number for last data supply-Vehicle identification number output,WVG5WVEB2SH017765,
IDE13836-MAS17095,VKMS: adaption counter-Adaptation counter status,valid,
IDE13836-MAS17096,VKMS: adaption counter-Adaptation counter output,00 01,
IDE13837-MAS17097,VKMS: overview missing keys-Key status,valid,
IDE13837-MAS17099,VKMS: overview missing keys-Number of missing keys,0,
IDE13837-MAS17100,VKMS: overview missing keys-Missing key,00 00,
IDE13842-MAS17101,VKMS: retrieval of information list of the stored VKMS keys-VKMS key status,valid,
IDE13842-MAS17103,VKMS: retrieval of information list of the stored VKMS keys-VKMS type ID,00 15,
IDE13842-MAS17104,VKMS: retrieval of information list of the stored VKMS keys-VKMS type adaptation counter,00 01,
IDE13842-MAS18318,VKMS: retrieval of information list of the stored VKMS keys-Number of VKMS keys,8,
IDE13845,Production mode status,not active,
IDE14051,Parking lock actuator: actual position as a percentage,0, %
IDE14052,Parking lock actuator: actual position,Initialization,
IDE14054,Parking lock actuator: current,0.0, A
IDE14055,Parking lock actuator: supply voltage,5, V
IDE14056,Parking lock actuator: temperature,-40, °C
IDE14492-MAS18388,Secure Onboard Communication: verification failed-Failed verification status,valid,
IDE14492-MAS18389,Secure Onboard Communication: verification failed-Number of failed verifications,1,
IDE14492-MAS18390,Secure Onboard Communication: verification failed-Verification failed,00 D8,
IDE14492-MAS28619,Secure Onboard Communication: verification failed-currently failed,not failed,
IDE14493-MAS18360,Secure Onboard Communication: signatures failed-failed signature creation,00 00,
IDE14493-MAS18391,Secure Onboard Communication: signatures failed-Failed signature creation status,valid,
IDE14493-MAS18392,Secure Onboard Communication: signatures failed-Number of failed signature creations,0,
IDE14494-MAS18361,Secure Onboard Communication: general information-Status of general information,valid,
IDE14494-MAS18362,Secure Onboard Communication: general information-ECU function,SOC participant,
IDE14494-MAS18367,Secure Onboard Communication: general information-Main function call period,5,
IDE14495-MAS18369,Secure Onboard Communication: information about internal time-Internal SOC time status,valid,
IDE14495-MAS18370,Secure Onboard Communication: information about internal time-Validity of internal SOC time,Valid SOC time,
IDE14495-MAS18374,Secure Onboard Communication: information about internal time-Internal time,00 0D C0 1D 12 CA 6B 1D,
IDE14495-MAS18375,Secure Onboard Communication: information about internal time-Jitter test status,Jitter not exceeded,
IDE14496-MAS18378,Secure Onboard Communication: Freshness Values information-Freshness status,valid,
IDE14496-MAS18379,Secure Onboard Communication: Freshness Values information-Number of Freshness IDs,9,
IDE14496-MAS18380,Secure Onboard Communication: Freshness Values information-SOC PDU ID to which this freshness information is assigned,00 0A,
IDE14496-MAS18381,Secure Onboard Communication: Freshness Values information-Freshness Value query status,Freshness Value was not queried,
IDE14496-MAS18384,Secure Onboard Communication: Freshness Values information-SOC time of last successful verification,FF FF FF FF FF FF FF FF,
IDE14496-MAS18385,Secure Onboard Communication: Freshness Values information-Current value of message counter,255,
IDE14496-MAS18386,Secure Onboard Communication: Freshness Values information-Bitfield with used counter values,11111111 11111111 ,
IDE14497-MAS17099,Secure Onboard Communication: missing key-Number of missing keys,0,
IDE14497-MAS17100,Secure Onboard Communication: missing key-Missing key,00 00,
IDE14497-MAS18387,Secure Onboard Communication: missing key-Missing key status,valid,
IDE15328,Status of electrical system converter: high-voltage system maintenance connector,Terminal 30c not interrupted,
IDE15329,Status of high-voltage battery management system maintenance plug,Terminal 30c not interrupted,
IDE15573,High-voltage contactors: error status,no contactor was detected as worn,
IDE15578,High-voltage de-energization: electrical system converter status,High-voltage components not de-energized,
IDE15596,High-voltage charging plug: status,no plug detected,
IDE15597,Detection status: open high-voltage wire on chargers,no open high-voltage wire detected,
IDE15781,VW Trustcenter Project ID,1044,
IDE16005,Drive train coordinator: acceleration request target value,0.13, m/s²
IDE16006-MAS00086,Drive train coordinator current status-active,No,
IDE16006-MAS00087,Drive train coordinator current status-passive,No,
IDE16006-MAS00342,Drive train coordinator current status-Initialization,not active,
IDE16006-MAS00519,Drive train coordinator current status-Condition violated,not active,
IDE16006-MAS04795,Drive train coordinator current status-main switch off,not active,
IDE16006-MAS21866,Drive train coordinator current status-Braking on shutdown Assistant system,not active,
IDE16006-MAS21867,Drive train coordinator current status-Assistant system shutdown: reversible,No,
IDE16006-MAS21868,Drive train coordinator current status-irreversible off,Yes,
IDE16007-MAS01102,Drive train coordinator: Acceleration Requester Status-Cruise control system,No,
IDE16007-MAS05189,Drive train coordinator: Acceleration Requester Status-Speed limiter active,No,
IDE16007-MAS09193,Drive train coordinator: Acceleration Requester Status-PLA,No,
IDE16007-MAS09331,Drive train coordinator: Acceleration Requester Status-no function,Yes,
IDE16007-MAS12321,Drive train coordinator: Acceleration Requester Status-Trailer positioning assistant,No,
IDE16007-MAS12422,Drive train coordinator: Acceleration Requester Status-intelligent parking assistant,No,
IDE16007-MAS14343,Drive train coordinator: Acceleration Requester Status-Predictive efficiency assistant,No,
IDE16007-MAS18082,Drive train coordinator: Acceleration Requester Status-Emergency assistant,No,
IDE16008-MAS03758,Drive Train Coordinator: Embassies Status-Not assigned,no error in message,
IDE16008-MAS22018,Drive Train Coordinator: Embassies Status-Error in ESP message,no error in message,
IDE16008-MAS22019,Drive Train Coordinator: Embassies Status-Error in ESP message (preliminary),no error in message,
IDE16008-MAS22020,Drive Train Coordinator: Embassies Status-Error in message electric parking brake (EPB),no error in message,
IDE16008-MAS22021,Drive Train Coordinator: Embassies Status-Error in ACC message,no error in message,
IDE16008-MAS22022,Drive Train Coordinator: Embassies Status-Error in ACC message (preliminary),no error in message,
IDE16008-MAS22023,Drive Train Coordinator: Embassies Status-Error in message control unit (SMLS),no error in message,
IDE16008-MAS22024,Drive Train Coordinator: Embassies Status-Error in message control panel (SMLS) (preliminary),no error in message,
IDE16008-MAS22025,Drive Train Coordinator: Embassies Status-Error in message transmission,no error in message,
IDE16008-MAS22026,Drive Train Coordinator: Embassies Status-Error in message Instrument cluster,no error in message,
IDE16008-MAS22027,Drive Train Coordinator: Embassies Status-Error in message rear light,no error in message,
IDE16008-MAS22028,Drive Train Coordinator: Embassies Status-Error in message trailer,no error in message,
IDE16008-MAS22029,Drive Train Coordinator: Embassies Status-Error in message airbag,no error in message,
IDE16008-MAS22030,Drive Train Coordinator: Embassies Status-Error in message Satellite Tracking System (STS),no error in message,
IDE16008-MAS22031,Drive Train Coordinator: Embassies Status-Error in message steering (LWI/SCU),no error in message,
IDE16008-MAS22032,Drive Train Coordinator: Embassies Status-Error in message gateway,no error in message,
IDE16008-MAS22033,Drive Train Coordinator: Embassies Status-Error in message all wheel drive,no error in message,
IDE16008-MAS22034,Drive Train Coordinator: Embassies Status-Error in message chassis,no error in message,
IDE16008-MAS22035,Drive Train Coordinator: Embassies Status-Error in message Trailer Shunting Assistant (TSA),no error in message,
IDE16008-MAS22036,Drive Train Coordinator: Embassies Status-Error in Message Parking Steering Assistant (PLA),no error in message,
IDE16008-MAS22037,Drive Train Coordinator: Embassies Status-Error in message Intelligent Park Assistant (IPA),no error in message,
IDE16008-MAS22038,Drive Train Coordinator: Embassies Status-Error in message Emergency Assist (EA),no error in message,
IDE16008-MAS22039,Drive Train Coordinator: Embassies Status-Error in message maximum speed for spoiler,no error in message,
IDE16008-MAS22040,Drive Train Coordinator: Embassies Status-Error in message traffic congestion pilot,no error in message,
IDE16008-MAS22041,Drive Train Coordinator: Embassies Status-Error in message predictive fuel consumption display,no error in message,
IDE16008-MAS22042,Drive Train Coordinator: Embassies Status-Error in message specific function control unit (KFG),no error in message,
IDE16008-MAS22044,Drive Train Coordinator: Embassies Status-Error in message from active chassis (EML),no error in message,
IDE16009-MAS05087,Drivetrain coordinator: proximity control type-ACC,installed,
IDE16009-MAS05088,Drivetrain coordinator: proximity control type-ACC with braking until at standstill,installed,
IDE16009-MAS05089,Drivetrain coordinator: proximity control type-ACC with Stop & Go,not installed,
IDE16009-MAS05205,Drivetrain coordinator: proximity control type-Basic ACC (without braking until at standstill),installed,
IDE16010-MAS00320,Driver assistance systems: control panel actuations-Main switch,not engaged,
IDE16010-MAS00325,Driver assistance systems: control panel actuations-Set,Not operated,
IDE16010-MAS00326,Driver assistance systems: control panel actuations-Resume,Not operated,
IDE16010-MAS02321,Driver assistance systems: control panel actuations-Cancel,On,
IDE16010-MAS05168,Driver assistance systems: control panel actuations-Control malfunction,No,
IDE16010-MAS05846,Driver assistance systems: control panel actuations-up,Not operated,
IDE16010-MAS07156,Driver assistance systems: control panel actuations-down,Not operated,
IDE16010-MAS10720,Driver assistance systems: control panel actuations-Speed limiter,not active,
IDE16010-MAS21855,Driver assistance systems: control panel actuations-CCS type control panel b0,Yes,
IDE16010-MAS21856,Driver assistance systems: control panel actuations-CCS type control panel b1,Yes,
IDE16010-MAS21857,Driver assistance systems: control panel actuations-CCS type control panel b2,No,
IDE16010-MAS21858,Driver assistance systems: control panel actuations-CCS limiter button available,not installed,
IDE16010-MAS21859,Driver assistance systems: control panel actuations-Tap in stage 2,Not operated,
IDE16010-MAS21860,Driver assistance systems: control panel actuations-Adjustment time gap down,Not operated,
IDE16010-MAS21861,Driver assistance systems: control panel actuations-Adjustment time gap up,Not operated,
IDE16010-MAS21862,Driver assistance systems: control panel actuations-Main switch type,engaged,
IDE16011-MAS05168,Drive train coordinator: blocking reasons of CCS and limiter-Control malfunction,No malfunction,
IDE16011-MAS14948,Drive train coordinator: blocking reasons of CCS and limiter-Irreversible brake malfunction relevant for limiter,No malfunction,
IDE16011-MAS21900,Drive train coordinator: blocking reasons of CCS and limiter-Implausible behavior of the display,No malfunction,
IDE16011-MAS21901,Drive train coordinator: blocking reasons of CCS and limiter-Blocking request CCS and limiter,No malfunction,
IDE16011-MAS21902,Drive train coordinator: blocking reasons of CCS and limiter-Vehicle speed or ESP message errors,No malfunction,
IDE16011-MAS21903,Drive train coordinator: blocking reasons of CCS and limiter-Monitoring function error,No malfunction,
IDE16011-MAS21904,Drive train coordinator: blocking reasons of CCS and limiter-Control panel messages,No malfunction,
IDE16024-MAS15052,Drive train coordinator: blocking reasons-Brake light actuation malfunction,No,
IDE16024-MAS16258,Drive train coordinator: blocking reasons-Transport mode active,No,
IDE16024-MAS21932,Drive train coordinator: blocking reasons-Error message of the brake system,No,
IDE16024-MAS21933,Drive train coordinator: blocking reasons-Variant error ACC type,No,
IDE16024-MAS21934,Drive train coordinator: blocking reasons-Intelligent Park Assistant error message,No,
IDE16024-MAS21935,Drive train coordinator: blocking reasons-Control panel error ACC and CCS,No,
IDE16024-MAS21936,Drive train coordinator: blocking reasons-Control panel error CCS,No,
IDE16024-MAS21937,Drive train coordinator: blocking reasons-Defective brake light,No,
IDE16024-MAS21938,Drive train coordinator: blocking reasons-Driver's wish no longer discernible,No,
IDE16024-MAS21939,Drive train coordinator: blocking reasons-Engine emergency run: power limitation,No,
IDE16024-MAS21940,Drive train coordinator: blocking reasons-Speed signal substitute value,No,
IDE16024-MAS21941,Drive train coordinator: blocking reasons-Error of the Emergency Assist Target acceleration,No,
IDE16024-MAS21942,Drive train coordinator: blocking reasons-Monitoring of control deviation Brakes,No,
IDE16024-MAS21943,Drive train coordinator: blocking reasons-Implausible coding of the gearbox variant,No,
IDE16024-MAS21944,Drive train coordinator: blocking reasons-CCS lock condition software as product,No,
IDE16024-MAS21945,Drive train coordinator: blocking reasons-ACC system error,No,
IDE16024-MAS21946,Drive train coordinator: blocking reasons-Error Monitoring Actual acceleration / control deviation,No,
IDE16024-MAS21947,Drive train coordinator: blocking reasons-Error clutch switch,No,
IDE16024-MAS21948,Drive train coordinator: blocking reasons-Plausibility error brake pedal,No,
IDE16024-MAS21949,Drive train coordinator: blocking reasons-Substitute values for relevant input signals,No,
IDE16024-MAS21950,Drive train coordinator: blocking reasons-Error relevant CAN messages,No,
IDE16076,Front axle: minimum mechanical power,0.0, kW
IDE16077,Front axle: maximum mechanical power,0.0, kW
IDE16078,Rear axle: maximum mechanical power,245.4, kW
IDE16079,Rear axle: minimum mechanical performance,-172.4, kW
IDE16080,All wheel drive: electric front axle drive nominal torque,0, Nm
IDE16081,All-wheel drive: electric rear axle drive Nominal torque,0.250004, Nm
IDE16082,All wheel drive: longitudinal torque controller system status,3, no unit
IDE16083,All wheel drive: torque limitation front axle,0, Nm
IDE16084,All wheel drive: torque limitation rear axle,5100, Nm
IDE16085,All wheel drive: electric front axle drive actual torque,0, Nm
IDE16086,All-wheel drive: electric rear axle drive actual torque,0, Nm
IDE16087,All-wheel drive: differential torque target value,0, Nm
IDE16088,All wheel drive: electric front axle drive operating mode,15, no unit
IDE16089,All-wheel drive: electric rear axle drive Operating mode,8, no unit
IDE16090,All-wheel drive: electronic torque control Error status,0, no unit
IDE16091,All-wheel drive: electronic torque control System status,3, no unit
IDE16092,All wheel drive: safety function intervention status,0, no unit
IDE16093,All-wheel drive: longitudinal function System status,3, no unit
IDE16094,All wheel drive: error value,0, no unit
IDE16095,All-wheel drive: error status of signals,23, no unit
IDE16096,All-wheel drive: error status ESP,0, no unit
IDE16097,All-wheel drive: validity of input signals,1, no unit
IDE16098,All wheel drive: vehicle speed is zero,1, no unit
IDE16099,All-wheel drive: vehicle speed between 0 and 20 m/s,0, no unit
IDE16100,All wheel drive: vehicle speed is negative,0, no unit
IDE16101,All wheel drive: vehicle speed greater than 20 m/s,0, no unit
IDE16102,All-wheel drive: nominal torque is negative,0, no unit
IDE16103,All wheel drive: nominal torque is greater than 1000 Nm,0, no unit
IDE16104,All wheel drive: nominal torque is greater than 100 Nm,0, no unit
IDE16105,All-wheel drive: nominal torque is zero,1, no unit
IDE16106,All-wheel drive: rear axle Maximum torque below limit value,0, no unit
IDE16107,All-wheel drive: rear axle Maximum torque is invalid,0, no unit
IDE16108,All wheel drive: front axle maximum torque below limit value,1, no unit
IDE16109,All-wheel drive: front axle Maximum torque is invalid,1, no unit
IDE16110,All wheel drive: yaw rate is invalid,0, no unit
IDE16111,All-wheel drive: steering wheel angle is invalid,0, no unit
IDE16112,All-wheel drive: steering wheel angle,2.1, °
IDE16130,Acceleration: signal,0.000, m/s²
IDE16164,High voltage coordinator: DC charging status,Deactivated,
IDE16189-MAS22194,High-voltage coordinator: high-voltage stabilization operating status-High-voltage stabilization: initialization phase,not active,
IDE16189-MAS22195,High-voltage coordinator: high-voltage stabilization operating status-High-voltage stabilization,active,
IDE16190,High-voltage auxiliary users: total current,2.41, A
IDE60001,Environmental condition 1,0, no unit
IDE60002,Environmental condition 2,0, no unit
IDE60003,Environmental condition 3,0, no unit
IDE60004,Environmental condition 4,0, no unit
IDE60005,Environmental condition 5,0, no unit
IDE60006,Environmental condition 6,0, no unit
IDE60007,Environmental condition 7,0, no unit
IDE60008,Environmental condition 8,0, no unit
IDE60009,Environmental condition 9,0, no unit
IDE60010,Environmental condition 10,0, no unit
IDE60011,Environmental condition 11,0, no unit
IDE60012,Environmental condition 12,0, no unit
IDE60013,Environmental condition 13,0, no unit
IDE60014,Environmental condition 14,0, no unit
IDE60015,Environmental condition 15,0, no unit
IDE60016,Environmental condition 16,0, no unit
IDE60017,Environmental condition 17,0, no unit
IDE60018,Environmental condition 18,0, no unit
IDE60019,Environmental condition 19,0, no unit
IDE60020,Environmental condition 20,0, no unit
IDE60021,Environmental condition 21,0, no unit
IDE60022,Environmental condition 22,0, no unit
IDE60023,Environmental condition 23,0, no unit
IDE60024,Environmental condition 24,0, no unit
IDE60025,Environmental condition 25,0, no unit
IDE60026,Environmental condition 26,0, no unit
IDE60027,Environmental condition 27,0, no unit
IDE60028,Environmental condition 28,0, no unit
IDE60029,Environmental condition 29,0, no unit
IDE60030,Environmental condition 30,0, no unit
IDE60031,Environmental condition 31,0, no unit
IDE60032,Environmental condition 32,0, no unit
IDE60033,Environmental condition 33,0, no unit
IDE60034,Environmental condition 34,0, no unit
IDE60035,Environmental condition 35,0, no unit
IDE80258,Immobilizer status,Authentication successful,
MAS00370,Vehicle speed,0.00, km/h
MAS13362,Calculated coolant temperature DCDC converter,15.4, °C
MAS17268,Functions which can be activated: connection error counter,00 00,
MAS17521-MAS17839,Unlockable functions: activation status-Number of functions which can be activated,2,
MAS17521-MAS17983,Unlockable functions: activation status-Last state,not active,
MAS17521,Unlockable functions: activation status,|ID number,Release code for a SWaP function
MAS18157-MAS18158,SFD activated status-Role of vehicle diagnostic to be protected,No activation active,
MAS18157-MAS18161,SFD activated status-Status of vehicle diagnostic to be protected,SFD individualization feature set,
MAS18157-MAS18164,SFD activated status-Duration of vehicle diagnostic to be protected,No activation active,
MAS18157-MAS18165,SFD activated status-Type of vehicle diagnostic to be protected,No activation active,
MAS20396,SFD protection procedure,SFD access protection and SFD end-to-end protection,
MAS20471,High-voltage battery de-energization status,High-voltage components not de-energized,
MAS20481,Detection status of open high-voltage wire on battery heater,no open high-voltage wire on battery heater detected,
MAS20513,De-energization status of entire high-voltage system,Initialization/function not active,
MAS20515,Charger de-energization status,High-voltage components not de-energized,
MAS20517,High-voltage interlock status,High-voltage interlock closed,
MAS20518,Electric machine 2: de-energization status,Initialization/no diagnostic results,
MAS20519,Electric machine: de-energization status,High-voltage components not de-energized,
MAS20529,Detection status of open high-voltage wire - e-machine 2,Detection initialization for open high-voltage wire: e-machine 2,
MAS20530,Detection status of open high-voltage wire - e-machine,no open high-voltage wire detected - e-machine,
MAS20600,High-voltage system: emergency shut-off status,no high-voltage system emergency shut-off,
MAS20607,High-voltage battery heater: installation status,High-voltage heater installed,
MAS20614,High-voltage system: warning light,no warning lamp,
MAS20620,Overall status of function high-voltage shut-off in crash,No crash recognized,
MAS20625,Overall status of high-voltage interlock (pilot line),Pilot line OK,
MAS20629,High-voltage system: detection status of open high-voltage wire,no open high-voltage wire detected,
MAS20635,Detection status: open high-voltage wire on the A/C compressor,no open high-voltage wire detected,
MAS20636,High-voltage network 1 status,High-voltage off,
MAS20637,Detection status: open high-voltage wire on electrical system converter,no open high-voltage wire detected,
MAS20639,Insulation resistance in high-voltage network 1,Insulation resistance higher threshold 1,
MAS20647,Detection status: open high-voltage wire on A/C system heater,no open high-voltage wire detected,
MAS20662,Insulation resistance measurement locked by charging function,Insulation resistance measurement locked,
MAS20664,Insulation resistance measurement locked by diagnostic tester,Insulation resistance measurement unlocked,
MAS20667,E-machine 2 installation status,not installed,
MAS20776,Adaptation of radiator blind result,2069.99, °
MAS20777,Activation of radiator blind result,32.9412, %
MAS20778,Radiator blind: actual position,32.9412, %
MAS20779,Adaptation of radiator blind status,Function was successfully ended,
MAS20786,Electrical system converter: installation status,Electrical system converter installed,
MAS21928-MAS00320,Drive train coordinator: longitudinal dynamics control: functionalities-Main switch,engaged,
MAS21928-MAS21929,Drive train coordinator: longitudinal dynamics control: functionalities-CCS/LIM switch available,No,
MAS21928-MAS21930,Drive train coordinator: longitudinal dynamics control: functionalities-Combi indicates setting value for speed limiter,Yes,
MAS21928-MAS21931,Drive train coordinator: longitudinal dynamics control: functionalities-Combi indicates setting value for CCS,Yes,
MAS22005-MAS01632,High-voltage Coordinator: operating status High-voltage stabilization-Status,no request,
MAS22083,Electric machine 2: de-energization status: masked,High voltage component voltage free,
MAS22084,Voltage-free status of the entire high-voltage system: masked,High voltage component not voltage free,
MAS22146,High voltage coordinator: low voltage DC charging status,active,
MAS22160,High-voltage auxiliary consumer: maximum permissible power,1.95200, kW
MAS22161,High-voltage auxiliary consumer: current power,1.0, kW
MAS22162,High voltage coordinator: active discharge status,not active,
MAS23372-MAS23383,Cancellation status of version coding: short-Number of rejected activation IDs,0, no unit
MAS23372-MAS23385,Cancellation status of version coding: short-Cluster index (FoD),0, no unit
MAS23372-MAS23386,Cancellation status of version coding: short-Row coding combination condition,0, no unit
MAS23372-MAS23387,Cancellation status of version coding: short-Rejection by coding cell number,0, no unit
MAS23372-MAS23388,Cancellation status of version coding: short-Delivery status: reset by immobilizer,Release,
MAS23372-MAS23389,Cancellation status of version coding: short-No code word received in D-Flash,Release,
MAS23372-MAS23390,Cancellation status of version coding: short-Rejection due to missing FoD release,Release,
MAS23372-MAS23391,Cancellation status of version coding: short-Rejection due to invalid coding combinations,Release,
MAS23372-MAS23392,Cancellation status of version coding: short-Rejection due to data status approval,Release,
MAS23374-MAS23383,Cancellation status of version coding: long-Number of rejected activation IDs,0, no unit
MAS23374-MAS23385,Cancellation status of version coding: long-Cluster index (FoD),0, no unit
MAS23374-MAS23386,Cancellation status of version coding: long-Row coding combination condition,0, no unit
MAS23374-MAS23387,Cancellation status of version coding: long-Rejection by coding cell number,0, no unit
MAS23374-MAS23388,Cancellation status of version coding: long-Delivery status: reset by immobilizer,Release,
MAS23374-MAS23389,Cancellation status of version coding: long-No code word received in D-Flash,Release,
MAS23374-MAS23390,Cancellation status of version coding: long-Rejection due to missing FoD release,Release,
MAS23374-MAS23391,Cancellation status of version coding: long-Rejection due to invalid coding combinations,Release,
MAS23374-MAS23392,Cancellation status of version coding: long-Rejection due to data status approval,Release,
MAS23374-MAS23393,Cancellation status of version coding: long-Activation ID 1,0, no unit
MAS23374-MAS23394,Cancellation status of version coding: long-Activation ID 2,0, no unit
MAS23374-MAS23395,Cancellation status of version coding: long-Activation ID 3,0, no unit
MAS23374-MAS23396,Cancellation status of version coding: long-Activation ID 4,0, no unit
MAS23374-MAS23397,Cancellation status of version coding: long-Activation ID 5,0, no unit
MAS27212,Drive cooling: coolant temperature,15.00, °
MAS27213,Drive cooling: target volume flow of inverter drive 1,3.0, l/min
MAS27214,Drive cooling: target volume flow of inverter drive 2,0.0, l/min
MAS27215,Drive cooling: actual volume flow of drive 2,25.5, l/min
MAS27216,Drive cooling: actual volume flow of drive 1,2.9, l/min
MAS27217,Drive cooling: target volume flow of electric drive motor 1,3.0, l/min
MAS27218,Drive cooling: target volume flow of electric drive motor 2,0.0, l/min
MAS27219,Drive cooling: target volume flow of heat pump,0.00, l/min
MAS27220,Drive cooling: radiator fan request for brake cooling,0, %
MAS27221,Drive cooling: target volume flow of battery charger/vehicle electrical system converter,1.0, l/min
MAS27222,Drive cooling: radiator fan request for air conditioning,26, %
MAS27234,Differential pressure of battery charger/vehicle electrical system converter cooling system: actual value,1.5, kPa
MAS27235,Drive cooling: target volume flow of battery charger,0.0, l/min
MAS27236,Drive cooling: radiator fan request,0, %
ENG138673,Bypasstool_a2l_name,SE1780,
ENG138672,Bypasstool_manipulation_bit,not active,
ENG101413,Calibration Identification,||0EA014GG3875EzJ6|,
ENG99697,Calibration Verification Numbers,||31 27 91 48|,
ENG249134,CUR_CHA_MAX_DYN_2,0.0, A
ENG249135,CUR_DCHA_MAX_DYN_2,0.0, A
ENG100131,ECU_STATE,ENG_STOP,
ENG100152,ECUNAME,|ECU,ECUNAME|PCM
ENG103644,FRF_IMMO_SNAPSHOT_BYTE1,0,
ENG102892,FRF_IMMO_SNAPSHOT_BYTE2,0,
ENG100521,FRF_IMMO_SNAPSHOT_BYTE3,0,
ENG101852,FRF_IMMO_SNAPSHOT_BYTE4,0,
ENG99312,FRF_IMMO_SNAPSHOT_BYTE5,0,
ENG103956,FRF_IMMO_SNAPSHOT_BYTE6,0,
ENG138674,LF_MVB_BUS_INTC_DIAG,256,
ENG138675,LF_MVB_PDU_INTC_DIAG_1,1,
ENG138676,LF_MVB_PDU_INTC_DIAG_10,0,
ENG168842,LF_MVB_PDU_INTC_DIAG_11,0,
ENG168843,LF_MVB_PDU_INTC_DIAG_12,0,
ENG138677,LF_MVB_PDU_INTC_DIAG_13,0,
ENG138679,LF_MVB_PDU_INTC_DIAG_15,0,
ENG138680,LF_MVB_PDU_INTC_DIAG_16,0,
ENG138681,LF_MVB_PDU_INTC_DIAG_17,0,
ENG138682,LF_MVB_PDU_INTC_DIAG_18,0,
ENG168844,LF_MVB_PDU_INTC_DIAG_19,0,
ENG138683,LF_MVB_PDU_INTC_DIAG_2,0,
ENG168845,LF_MVB_PDU_INTC_DIAG_20,0,
ENG168846,LF_MVB_PDU_INTC_DIAG_22,0,
ENG168847,LF_MVB_PDU_INTC_DIAG_23,0,
ENG168848,LF_MVB_PDU_INTC_DIAG_24,0,
ENG168849,LF_MVB_PDU_INTC_DIAG_25,0,
ENG168850,LF_MVB_PDU_INTC_DIAG_26,0,
ENG168851,LF_MVB_PDU_INTC_DIAG_27,0,
ENG138684,LF_MVB_PDU_INTC_DIAG_3,0,
ENG138685,LF_MVB_PDU_INTC_DIAG_4,0,
ENG138686,LF_MVB_PDU_INTC_DIAG_5,0,
ENG138687,LF_MVB_PDU_INTC_DIAG_6,0,
ENG138689,LF_MVB_PDU_INTC_DIAG_8,1,
ENG138690,LF_MVB_PDU_INTC_DIAG_9,0,
ENG112471,LV_IGK,00000001 ,
ENG249159,N_EM_3,0.0, /min
ENG249160,N_EM_6,16383.5, /min
ENG128797,PV,0.00, %
ENG249203,STATE_REQ_ENG_HVS,0,
ENG112494,T_AST_SAE,467, s
ENG128802,T_IGK,481.07, s
ENG249209,TQ_EM_1,0.00000, Nm
ENG249210,TQ_EM_2,0.00000, Nm
ENG249211,TQ_EM_3,0.00000, Nm
ENG252424,Vehicle Operation Data - Distance/Fuel Used,|Total Distance Traveled (Recent),Total Distance Traveled (Lifetime)
ENG249216,VS_DIR_CUS,0.00, km/h
Elapsed Time: 00:28
blockmap-03-1EA-907-379-BQ_WVG5WVEB2SH017765-20250325-1218.CSV
;SW:1EA-907-379-BQ   HW:1EA-614-517-M ---  ABS Brakes
;Component:ESC-ZF_EBC470 H18 0754, Coding:481044A8004159024217990000B79840250070614000
;EV_BrakeZFESCMEBUNECE,001035,EV_BrakeZFESCMEBUNECE_001_VWE3.rod
;Tuesday,25,March,2025,12:18:44:58926
;VCID: 0D4CC7224DDF3C82F40-8058-R SFD+SFD2
IDE00019,Voltage terminal 30,14.96, V
IDE00021,Engine speed,0.00, /min
IDE00025,Coolant temperature,-1, °C
IDE00085,Normed load value,24.71, %
IDE00086,Accelerator pedal position,14.12, %
IDE00602-ENG161054,Monitoring status in current driving cycle-Diagnostic_approval_and_Readiness_code_continous_diagnostics,00000100 ,
IDE00602-ENG161055,Monitoring status in current driving cycle-Diagnostic_approval_and_Readiness_code_non_continous_diagnostics,00000000 ,
IDE00602-ENG161141,Monitoring status in current driving cycle-Readiness_Code,00000000 ,
IDE02270-IDE02713,CAN input signal(s) status-Brake lamp switch,operated,
IDE02270-IDE05726,CAN input signal(s) status-Dimmer terminal 58xd,0,
IDE02270-MAS02357,CAN input signal(s) status-Vehicle identification,WVG5WVEB2SH017765,
IDE02270-MAS15790,CAN input signal(s) status-Setting for clear error memory,locked,
IDE02271-IDE02070,CAN output signal(s) status-Wake-up cause,Bus communication,
IDE04082-MAS00580,Instrument cluster text output-Electromechanical parking brake text 1,0,
IDE04082-MAS03359,Instrument cluster text output-Text,0,
IDE06422-ENG103176,IUMPR_1-General Denominator,0,
IDE06422-ENG102823,IUMPR_1-Ignition Cycle Counter,0,
IDE06422-ENG100120,IUMPR_1-Milage,0,
IDE06422-ENG101622,IUMPR_1-Record Number,0,
IDE06423-ENG101817,IUMPR_2-Denominator,0,
IDE06423-ENG103772,IUMPR_2-DFCC Value,0,
IDE06423-ENG99150,IUMPR_2-Numerator,0,
IDE06423-ENG101622,IUMPR_2-Record Number,1,
IDE06424-ENG101817,IUMPR_3-Denominator,0,
IDE06424-ENG103772,IUMPR_3-DFCC Value,0,
IDE06424-ENG99150,IUMPR_3-Numerator,0,
IDE06424-ENG101622,IUMPR_3-Record Number,0,
IDE07159-MAS05583,Control module switch-off: counter-Data bus,1,
IDE13842-MAS18318,VKMS: retrieval of information list of the stored VKMS keys-Number of VKMS keys,6,
IDE14227-IDE02955,modular vehicle dynamic controller-System status,Available,
IDE14227-MAS18086,modular vehicle dynamic controller-Dynamic Chassis Control function status,mFDR_active_DCC_not_configured,
IDE14227-ENG370765,modular vehicle dynamic controller-mFDR Offset DCC HL,Initialization,
IDE14227-ENG370766,modular vehicle dynamic controller-mFDR Offset DCC HR,Initialization,
IDE14227-ENG370767,modular vehicle dynamic controller-mFDR Offset DCC VL,Initialization,
IDE14227-ENG370768,modular vehicle dynamic controller-mFDR Offset DCC VR,Initialization,
IDE14227-ENG370769,modular vehicle dynamic controller-mFDR_Active_DCC,Init,
IDE14227-ENG370771,modular vehicle dynamic controller-mFDR_FPA_value_actual,4,
IDE14227-ENG370772,modular vehicle dynamic controller-mFDR_FPA_value_nominal,4,
IDE14227-ENG370773,modular vehicle dynamic controller-mFDR_target_delta_moment_brake_torque_front_axle,0.00, Nm
IDE14227-ENG370774,modular vehicle dynamic controller-mFDR_target_delta_moment_brake_torque_rear_axle,0.00, Nm
IDE14227-ENG370855,modular vehicle dynamic controller-System_state_FPA,Available,
IDE14492-MAS18389,Secure Onboard Communication: verification failed-Number of failed verifications,0,
IDE14492-MAS18390,Secure Onboard Communication: verification failed-Verification failed,00 00,
IDE14495-MAS18374,Secure Onboard Communication: information about internal time-Internal time,00 0D C0 1D 12 CA 6C A0,
IDE14496-MAS18379,Secure Onboard Communication: Freshness Values information-Number of Freshness IDs,4,
IDE14496-MAS18380,Secure Onboard Communication: Freshness Values information-SOC PDU ID to which this freshness information is assigned,00 0E,
IDE14623,Commutation test status,not active,
MAS26780-MAS26781,Distance safety-Total of average distance pulses from rear wheels,00 00 78 B3 8E,
ENG99697-ENG110852,Calibration Verification Numbers-Calibration Verification Number,3C CE BF B6,
ENG100152,ECUNAME,BSCM-BrakeSystem----,
ENG264447-ENG135743,Entwicklermesswert_11-Left_Brake_Full_Clamping_Force,0,
ENG264447-ENG135741,Entwicklermesswert_11-Right_Brake_Full_Clamping_Force,0,
ENG264448,Entwicklermesswert_12,ÿV",
ENG370243-MAS00106,valve_calibration-Year,2064,
ENG370243-MAS00107,valve_calibration-Month,12,
ENG370243-MAS00108,valve_calibration-Day,7,
ENG370243-MAS00109,valve_calibration-Hours,1,
ENG370243-MAS00110,valve_calibration-Minutes,4,
ENG370243-MAS00111,valve_calibration-Seconds,44,
ENG370243-ENG370529,valve_calibration-absiso_fl,15062.2, mA
ENG370243-ENG370530,valve_calibration-absiso_fr,3812.49, mA
ENG370243-ENG370531,valve_calibration-absiso_rl,12499.7, mA
ENG370243-ENG370532,valve_calibration-absiso_rr,13812.2, mA
ENG370243-ENG370560,valve_calibration-calibration_ign_count,57344,
ENG370243-ENG370561,valve_calibration-calibration_mileage,2852126720, km
ENG370243-ENG98502,valve_calibration-Data,29,
ENG370243-ENG370857,valve_calibration-tc_iso_circuit_1,1999.99, mA
ENG370243-ENG370858,valve_calibration-tc_iso_circuit_2,1999.99, mA
Elapsed Time: 00:15
blockmap-05-5WA-959-436-N_WVG5WVEB2SH017765-20250325-1219.CSV
;SW:5WA-959-436-N   HW:5WA-959-436-N ---  Acc/Start Auth.
;Component:Kessy IOBOX   122 0757, Coding:
;EV_Kessy37w,005030,EV_Kessy37w.rod
;Tuesday,25,March,2025,12:19:19:58926
;VCID: 5F90CD6AD7B3FE12D6C-800A-R
IDE00019,Voltage terminal 30,14.855, V
IDE02413,Door handle touch sensor: last operation,Driver door,
IDE02414-MAS00080,Driver exterior door handle touch sensor-Coding information,coded,
IDE02414-MAS02176,Driver exterior door handle touch sensor-Approach to the inside,not active,
IDE02414-MAS02177,Driver exterior door handle touch sensor-Actuation to the inside,not active,
IDE02414-MAS02178,Driver exterior door handle touch sensor-Approach to the outside,not active,
IDE02414-MAS02179,Driver exterior door handle touch sensor-Actuation to the outside,not active,
IDE02414-MAS02451,Driver exterior door handle touch sensor-Pulling actuation: outside door handle,not active,
IDE02415-MAS00080,Front passenger exterior door handle touch sensor-Coding information,coded,
IDE02415-MAS02176,Front passenger exterior door handle touch sensor-Approach to the inside,not active,
IDE02415-MAS02177,Front passenger exterior door handle touch sensor-Actuation to the inside,not active,
IDE02415-MAS02178,Front passenger exterior door handle touch sensor-Approach to the outside,not active,
IDE02415-MAS02179,Front passenger exterior door handle touch sensor-Actuation to the outside,not active,
IDE02415-MAS02451,Front passenger exterior door handle touch sensor-Pulling actuation: outside door handle,not active,
IDE02416-MAS00080,Left rear outside door handle touch sensor-Coding information,Not coded,
IDE02416-MAS02176,Left rear outside door handle touch sensor-Approach to the inside,not active,
IDE02416-MAS02177,Left rear outside door handle touch sensor-Actuation to the inside,not active,
IDE02416-MAS02178,Left rear outside door handle touch sensor-Approach to the outside,not active,
IDE02416-MAS02179,Left rear outside door handle touch sensor-Actuation to the outside,not active,
IDE02416-MAS02451,Left rear outside door handle touch sensor-Pulling actuation: outside door handle,not active,
IDE02417-MAS00080,Right rear outside door handle touch sensor-Coding information,Not coded,
IDE02417-MAS02176,Right rear outside door handle touch sensor-Approach to the inside,not active,
IDE02417-MAS02177,Right rear outside door handle touch sensor-Actuation to the inside,not active,
IDE02417-MAS02178,Right rear outside door handle touch sensor-Approach to the outside,not active,
IDE02417-MAS02179,Right rear outside door handle touch sensor-Actuation to the outside,not active,
IDE02417-MAS02451,Right rear outside door handle touch sensor-Pulling actuation: outside door handle,not active,
IDE02418,Proximity sensor driver door: number of triggers,303,
IDE02419,Proximity sensor frt.pass. door: number of triggers,136,
IDE02420,Proximity sensor left rear door: number of triggers,0,
IDE02421,Proximity sensor right rear door: number of triggers,0,
IDE02422-MAS01482,Driver door handle: version information-Hardware version,33,
IDE02422-MAS01483,Driver door handle: version information-Software version,49,
IDE02422-MAS04065,Driver door handle: version information-EEPROM,36,
IDE02422,Driver door handle: version information,2F 00 10 D3 AB,
IDE02423-MAS01482,ass. door handle: version information-Hardware version,33,
IDE02423-MAS01483,ass. door handle: version information-Software version,49,
IDE02423-MAS04065,ass. door handle: version information-EEPROM,36,
IDE02423,ass. door handle: version information,2F 00 12 CB 54,
IDE02424-MAS01482,Left rear door handle: version information-Hardware version,0,
IDE02424-MAS01483,Left rear door handle: version information-Software version,0,
IDE02424-MAS04065,Left rear door handle: version information-EEPROM,0,
IDE02424,Left rear door handle: version information,00 00 00 00 00,
IDE02425-MAS01482,Right rear door handle: version information-Hardware version,0,
IDE02425-MAS01483,Right rear door handle: version information-Software version,0,
IDE02425-MAS04065,Right rear door handle: version information-EEPROM,0,
IDE02425,Right rear door handle: version information,00 00 00 00 00,
IDE02466,Play protection activation counter driver door,not active,
IDE02466,Play protection activation counter driver door,0,
IDE02467,Play protection activation counter frt.pass. door,0,
IDE02467,Play protection activation counter frt.pass. door,not active,
IDE02468,Play protection activation counter left rear door,0,
IDE02468,Play protection activation counter left rear door,not active,
IDE02469,Play protection activation counter right rear door,0,
IDE02469,Play protection activation counter right rear door,not active,
IDE02482,72h-Signaling counter driver door,0,
IDE02483,72-hour signaling counter frt.pass. door,0,
IDE02486,Data logger triggering,not initialized,
IDE04347-IDE00020,Expanded freeze frame conditions-Terminal 15 status,On,
IDE04347-MAS04121,Expanded freeze frame conditions-Voltage,14.8, V
IDE07359,Dimming of starter button lighting,10000,
IDE14837-MAS19401,Outer door handle switch: status-Driver Side Exterior Door Handle Switch: status,Not operated,
IDE14837-MAS19402,Outer door handle switch: status-Front Passenger Exterior Door Handle Switch: status,Not operated,
IDE14837-MAS19403,Outer door handle switch: status-Rear Passenger Exterior Door Handle Switch: status,Not operated,
IDE14837-MAS19404,Outer door handle switch: status-Rear Driver Side Exterior Door Handle Switch: status,Not operated,
IDE14837-MAS19612,Outer door handle switch: status-Rear Exterior Door Handle Switch: status,Not operated,
IDE14837-MAS19613,Outer door handle switch: status-Tank Exterior Door Handle Switch: status,Not operated,
IDE14924-MAS00218,Status of release conditions Passive Entry-Driver door,not enabled,
IDE14924-MAS00219,Status of release conditions Passive Entry-Front Passenger Door,not enabled,
IDE14924-MAS00220,Status of release conditions Passive Entry-Rear left door,not enabled,
IDE14924-MAS00221,Status of release conditions Passive Entry-Rear right door,not enabled,
IDE14924-MAS19581,Status of release conditions Passive Entry-Rear,not enabled,
IDE14924-MAS19611,Status of release conditions Passive Entry-Tank,not enabled,
IDE14925-MAS00218,Status of release conditions Passive Exit-Driver door,Enabled,
IDE14925-MAS00219,Status of release conditions Passive Exit-Front Passenger Door,Enabled,
IDE14925-MAS00220,Status of release conditions Passive Exit-Rear left door,not enabled,
IDE14925-MAS00221,Status of release conditions Passive Exit-Rear right door,not enabled,
IDE14925-MAS19581,Status of release conditions Passive Exit-Rear,not enabled,
IDE14925-MAS19611,Status of release conditions Passive Exit-Tank,not enabled,
IDE14926,Status of release conditions for key search,Key search: release activated,
IDE14927-MAS19605,History of range limiter for automatic functions-Reduction level,|Level_of_reduction,Year
IDE14928-MAS00080,Sensor for control section-Coding information,Not coded,
IDE14928-MAS02176,Sensor for control section-Approach to the inside,not active,
IDE14928-MAS02177,Sensor for control section-Actuation to the inside,not active,
IDE14928-MAS02178,Sensor for control section-Approach to the outside,not active,
IDE14928-MAS02179,Sensor for control section-Actuation to the outside,not active,
IDE14928-MAS02451,Sensor for control section-Pulling actuation: outside door handle,not active,
IDE14929-MAS00080,Sensor for fuel filler flap control section-Coding information,Not coded,
IDE14929-MAS02176,Sensor for fuel filler flap control section-Approach to the inside,not active,
IDE14929-MAS02177,Sensor for fuel filler flap control section-Actuation to the inside,not active,
IDE14929-MAS02178,Sensor for fuel filler flap control section-Approach to the outside,not active,
IDE14929-MAS02179,Sensor for fuel filler flap control section-Actuation to the outside,not active,
IDE14929-MAS02451,Sensor for fuel filler flap control section-Pulling actuation: outside door handle,not active,
IDE14930,Sensor fuel filler flap control section: number of triggers,0,
IDE14931,Sensor control section trunk: number of triggers,0,
IDE14932,Fuel filler flap control section: play protection,not active,
IDE14932,Fuel filler flap control section: play protection,0,
IDE14933,Trunk control section: play protection counter,0,
IDE14933,Trunk control section: play protection counter,not active,
IDE14934-MAS01482,Trunk control section: version information-Hardware version,0,
IDE14934-MAS01483,Trunk control section: version information-Software version,0,
IDE14934-MAS04065,Trunk control section: version information-EEPROM,0,
IDE14934,Trunk control section: version information,00 00 00 00 00,
IDE14935-MAS01482,Fuel filler cap control section: version information-Hardware version,0,
IDE14935-MAS01483,Fuel filler cap control section: version information-Software version,0,
IDE14935-MAS04065,Fuel filler cap control section: version information-EEPROM,0,
IDE14935,Fuel filler cap control section: version information,00 00 00 00 00,
ENG129040-ENG129151,History_of_last _reset_reason-Last_1_reset_reason,Power_On_Reset,
ENG129040-ENG129152,History_of_last _reset_reason-Last_2_reset_reason,Power_On_Reset,
ENG129040-ENG129153,History_of_last _reset_reason-Last_3_reset_reason,Power_On_Reset,
ENG129040-ENG129154,History_of_last _reset_reason-Last_4_reset_reason,Power_On_Reset,
ENG129040-ENG129155,History_of_last _reset_reason-Last_5_reset_reason,Power_On_Reset,
ENG129040-ENG129156,History_of_last _reset_reason-Last_6_reset_reason,Power_On_Reset,
ENG129040-ENG129157,History_of_last _reset_reason-Last_7_reset_reason,Default,
ENG129040-ENG129158,History_of_last _reset_reason-Last_8_reset_reason,Default,
ENG129040-ENG129159,History_of_last _reset_reason-Last_9_reset_reason,Default,
ENG129040-ENG124545,History_of_last _reset_reason-Last_reset_reason,Software_Request_Flashbootloader,
ENG254757-MAS00106,Lf_antenna_eight_detune_counter-Year,2000,
ENG254757-MAS00107,Lf_antenna_eight_detune_counter-Month,0,
ENG254757-MAS00108,Lf_antenna_eight_detune_counter-Day,0,
ENG254757-MAS00109,Lf_antenna_eight_detune_counter-Hours,0,
ENG254757-MAS00110,Lf_antenna_eight_detune_counter-Minutes,0,
ENG254757-MAS00111,Lf_antenna_eight_detune_counter-Seconds,0,
ENG254757-ENG255615,Lf_antenna_eight_detune_counter-Detune_counter,0,
ENG254758-MAS00106,Lf_antenna_five_detune_counter-Year,2000,
ENG254758-MAS00107,Lf_antenna_five_detune_counter-Month,0,
ENG254758-MAS00108,Lf_antenna_five_detune_counter-Day,0,
ENG254758-MAS00109,Lf_antenna_five_detune_counter-Hours,0,
ENG254758-MAS00110,Lf_antenna_five_detune_counter-Minutes,0,
ENG254758-MAS00111,Lf_antenna_five_detune_counter-Seconds,0,
ENG254758-ENG255615,Lf_antenna_five_detune_counter-Detune_counter,0,
ENG254759-MAS00106,Lf_antenna_four_detune_counter-Year,2000,
ENG254759-MAS00107,Lf_antenna_four_detune_counter-Month,0,
ENG254759-MAS00108,Lf_antenna_four_detune_counter-Day,0,
ENG254759-MAS00109,Lf_antenna_four_detune_counter-Hours,0,
ENG254759-MAS00110,Lf_antenna_four_detune_counter-Minutes,0,
ENG254759-MAS00111,Lf_antenna_four_detune_counter-Seconds,0,
ENG254759-ENG255615,Lf_antenna_four_detune_counter-Detune_counter,0,
ENG254760-MAS00106,Lf_antenna_one_detune_counter-Year,2000,
ENG254760-MAS00107,Lf_antenna_one_detune_counter-Month,0,
ENG254760-MAS00108,Lf_antenna_one_detune_counter-Day,0,
ENG254760-MAS00109,Lf_antenna_one_detune_counter-Hours,0,
ENG254760-MAS00110,Lf_antenna_one_detune_counter-Minutes,0,
ENG254760-MAS00111,Lf_antenna_one_detune_counter-Seconds,0,
ENG254760-ENG255615,Lf_antenna_one_detune_counter-Detune_counter,0,
ENG254761-MAS00106,Lf_antenna_seven_detune_counter-Year,2000,
ENG254761-MAS00107,Lf_antenna_seven_detune_counter-Month,0,
ENG254761-MAS00108,Lf_antenna_seven_detune_counter-Day,0,
ENG254761-MAS00109,Lf_antenna_seven_detune_counter-Hours,0,
ENG254761-MAS00110,Lf_antenna_seven_detune_counter-Minutes,0,
ENG254761-MAS00111,Lf_antenna_seven_detune_counter-Seconds,0,
ENG254761-ENG255615,Lf_antenna_seven_detune_counter-Detune_counter,0,
ENG254762-MAS00106,Lf_antenna_six_detune_counter-Year,2000,
ENG254762-MAS00107,Lf_antenna_six_detune_counter-Month,0,
ENG254762-MAS00108,Lf_antenna_six_detune_counter-Day,0,
ENG254762-MAS00109,Lf_antenna_six_detune_counter-Hours,0,
ENG254762-MAS00110,Lf_antenna_six_detune_counter-Minutes,0,
ENG254762-MAS00111,Lf_antenna_six_detune_counter-Seconds,0,
ENG254762-ENG255615,Lf_antenna_six_detune_counter-Detune_counter,0,
ENG254763-MAS00106,Lf_antenna_three_detune_counter-Year,2000,
ENG254763-MAS00107,Lf_antenna_three_detune_counter-Month,0,
ENG254763-MAS00108,Lf_antenna_three_detune_counter-Day,0,
ENG254763-MAS00109,Lf_antenna_three_detune_counter-Hours,0,
ENG254763-MAS00110,Lf_antenna_three_detune_counter-Minutes,0,
ENG254763-MAS00111,Lf_antenna_three_detune_counter-Seconds,0,
ENG254763-ENG255615,Lf_antenna_three_detune_counter-Detune_counter,0,
ENG254764-MAS00106,Lf_antenna_two_detune_counter-Year,2000,
ENG254764-MAS00107,Lf_antenna_two_detune_counter-Month,0,
ENG254764-MAS00108,Lf_antenna_two_detune_counter-Day,0,
ENG254764-MAS00109,Lf_antenna_two_detune_counter-Hours,0,
ENG254764-MAS00110,Lf_antenna_two_detune_counter-Minutes,0,
ENG254764-MAS00111,Lf_antenna_two_detune_counter-Seconds,0,
ENG254764-ENG255615,Lf_antenna_two_detune_counter-Detune_counter,0,
ENG254789-MAS00106,Over_temperature_counter_lf_driver-Year,2000,
ENG254789-MAS00107,Over_temperature_counter_lf_driver-Month,0,
ENG254789-MAS00108,Over_temperature_counter_lf_driver-Day,0,
ENG254789-MAS00109,Over_temperature_counter_lf_driver-Hours,0,
ENG254789-MAS00110,Over_temperature_counter_lf_driver-Minutes,0,
ENG254789-MAS00111,Over_temperature_counter_lf_driver-Seconds,0,
ENG254789-MAS27962,Over_temperature_counter_lf_driver-Excessive temperature counter for Kessy OK box,0, counts
ENG108452,Reset_counter,7,
ENG108925-ENG103300,Service_Key_Data_Current_Page-Service_Data,00 07 00 00 00 00 00 00 00 00 FF FF 00 FF FF FF FF FF 00 FF FF FF FF FF 00 FF FF FF FF FF 00 FF FF FF FF FF 00 FF FF FF FF FF 00 FF FF FF FF FF 00 FF FF FF FF FF 00 FF FF FF FF FF,
ENG108926-ENG103300,Service_Key_Data_Previous_Page-Service_Data,00 07 00 00 00 00 00 00 00 00 FF FF 00 FF FF FF FF FF 00 FF FF FF FF FF 00 FF FF FF FF FF 00 FF FF FF FF FF 00 FF FF FF FF FF 00 FF FF FF FF FF 00 FF FF FF FF FF 00 FF FF FF FF FF,
ENG119884-ENG119837,Service_Key_Mileage_Date-Date_Day_Secure_Total_Distance_Block_0,0, d
ENG119884-ENG119867,Service_Key_Mileage_Date-Date_Day_Secure_Total_Distance_Block_1,0, d
ENG119884-ENG119868,Service_Key_Mileage_Date-Date_Day_Secure_Total_Distance_Block_2,31, d
ENG119884-ENG119866,Service_Key_Mileage_Date-Date_Day_Secure_Total_Distance_Block_3,31, d
ENG119884-ENG119870,Service_Key_Mileage_Date-Date_Month_Secure_Total_Distance_Block_0,0,
ENG119884-ENG119836,Service_Key_Mileage_Date-Date_Month_Secure_Total_Distance_Block_1,0,
ENG119884-ENG119850,Service_Key_Mileage_Date-Date_Month_Secure_Total_Distance_Block_2,15,
ENG119884-ENG119851,Service_Key_Mileage_Date-Date_Month_Secure_Total_Distance_Block_3,7,
ENG119884-ENG119869,Service_Key_Mileage_Date-Date_Year_Secure_Total_Distance_Block_0,2000,
ENG119884-ENG119835,Service_Key_Mileage_Date-Date_Year_Secure_Total_Distance_Block_1,2000,
ENG119884-ENG119845,Service_Key_Mileage_Date-Date_Year_Secure_Total_Distance_Block_2,2127,
ENG119884-ENG119846,Service_Key_Mileage_Date-Date_Year_Secure_Total_Distance_Block_3,2000,
ENG119884-ENG119834,Service_Key_Mileage_Date-Secure_Total_Distance_Km_Block_0,1792, km
ENG119884-ENG119839,Service_Key_Mileage_Date-Secure_Total_Distance_Km_Block_1,0, km
ENG119884-ENG119840,Service_Key_Mileage_Date-Secure_Total_Distance_Km_Block_2,16776960, km
ENG119884-ENG119841,Service_Key_Mileage_Date-Secure_Total_Distance_Km_Block_3,16777215, km
ENG108929-ENG99961,Service_Key_Pointer-Current_Bank,key_not_readable,
ENG108929-ENG161255,Service_Key_Pointer-Write_Pointer_Adr_160,Write_Pointer_Adr,
ENG108929-ENG161256,Service_Key_Pointer-Write_Pointer_Adr_184,Write_Pointer_Adr,
ENG108929-ENG161257,Service_Key_Pointer-Write_Pointer_Adr_208,Write_Pointer_Adr,
ENG254855,WUP_measurement_historie,|Learned wake pattern,Mileage|2661281330
Elapsed Time: 00:07
blockmap-06-1N3-959-760-H_WVG5WVEB2SH017765-20250325-1219.CSV
;SW:1N3-959-760-H   HW:1N3-959-760-H ---  Seat Mem. Pass
;Component:MEM-BFS       011 0571, Coding:0118B24000012A008803010121010000000000000000000000000000211000
;EV_SCMPasseSideCONTIAU736,006013,EV_SCMPasseSideCONTIAU736_VW42.rod
;Tuesday,25,March,2025,12:19:40:58926
;VCDS Version: Release 25.3.0 (x64)  Data version: 20250311 DS365.0
;VCID: 3E2E50EE30F9D71ABDA-806A-R
Group,Description,Actual
IDE00019-MAS00043,Voltage terminal 30-Terminal 30 power supply,14.80, V
IDE00102,Control Module temperature,37,
IDE00787,Cause for cancellation,none,
IDE01277-IDE09268,Counter of compressor activations-Switch on occurrences of compressor,0, counts
IDE01277-MAS06166,Counter of compressor activations-Current operation time,0, s
IDE01457,Energy management deactivation stage,Deactivation stage 0,
IDE05738-MAS12801,Subssystem diagnosis classes-DK0 systems supported,DK0 systems not supported,
IDE05738-MAS12803,Subssystem diagnosis classes-DK1 systems supported,DK1 systems not supported,
IDE05738-MAS12805,Subssystem diagnosis classes-DK2/DK2F systems supported,DK2/DK2F systems not supported,
IDE05738-MAS12807,Subssystem diagnosis classes-DK3 or DK4 high/low systems supported,DK3 or DK4 high/low systems not supported,
IDE06510-MAS01390,Adjustment for backrest angle-Block 1,34051,
IDE06510-MAS01391,Adjustment for backrest angle-Block 2,32468,
IDE06510-MAS02282,Adjustment for backrest angle-Position,32877,
IDE06510-MAS02955,Adjustment for backrest angle-Engine temperature,25, °C
IDE06510-MAS03129,Adjustment for backrest angle-Reset counter,17,
IDE06510-MAS04160,Adjustment for backrest angle-Load change,21,
IDE06510-MAS04337,Adjustment for backrest angle-Engine current,0, A
IDE06510-MAS05370,Adjustment for backrest angle-Direction of movement,Not operated,
IDE06510-MAS05563,Adjustment for backrest angle-Norming,standardized,
IDE06510-MAS05719,Adjustment for backrest angle-Maximum travel,1583,
IDE06510-MAS12838,Adjustment for backrest angle-Standardization flag,standardized,
IDE06511-MAS01390,Seat height adjustment-Block 1,33269,
IDE06511-MAS01391,Seat height adjustment-Block 2,32768,
IDE06511-MAS02282,Seat height adjustment-Position,33268,
IDE06511-MAS02955,Seat height adjustment-Engine temperature,25, °C
IDE06511-MAS03129,Seat height adjustment-Reset counter,16,
IDE06511-MAS04160,Seat height adjustment-Load change,18,
IDE06511-MAS04337,Seat height adjustment-Engine current,0, A
IDE06511-MAS05370,Seat height adjustment-Direction of movement,Not operated,
IDE06511-MAS05563,Seat height adjustment-Norming,standardized,
IDE06511-MAS05719,Seat height adjustment-Maximum travel,501,
IDE06511-MAS12838,Seat height adjustment-Standardization flag,standardized,
IDE06512-MAS01390,Adjustment for seat forward/back position-Block 1,33104,
IDE06512-MAS01391,Adjustment for seat forward/back position-Block 2,32552,
IDE06512-MAS02282,Adjustment for seat forward/back position-Position,32828,
IDE06512-MAS02955,Adjustment for seat forward/back position-Engine temperature,25, °C
IDE06512-MAS03129,Adjustment for seat forward/back position-Reset counter,125,
IDE06512-MAS04160,Adjustment for seat forward/back position-Load change,128,
IDE06512-MAS04337,Adjustment for seat forward/back position-Engine current,0, A
IDE06512-MAS05370,Adjustment for seat forward/back position-Direction of movement,Not operated,
IDE06512-MAS05563,Adjustment for seat forward/back position-Norming,standardized,
IDE06512-MAS05719,Adjustment for seat forward/back position-Maximum travel,552,
IDE06512-MAS12838,Adjustment for seat forward/back position-Standardization flag,standardized,
IDE06614-IDE06842,Memory seat adjustment control head-Status - Button 1,not active,
IDE06614-IDE06843,Memory seat adjustment control head-Status - Button 2,not active,
IDE06614-IDE06844,Memory seat adjustment control head-Status - Button 3,not active,
IDE06614-IDE06845,Memory seat adjustment control head-Status - Button 4,not active,
IDE06614-MAS01601,Memory seat adjustment control head-storing,not active,
IDE06683-MAS01390,Seat inclination adjustment-Block 1,33030,
IDE06683-MAS01391,Seat inclination adjustment-Block 2,32768,
IDE06683-MAS02282,Seat inclination adjustment-Position,33030,
IDE06683-MAS02955,Seat inclination adjustment-Engine temperature,25, °C
IDE06683-MAS03129,Seat inclination adjustment-Reset counter,0,
IDE06683-MAS04160,Seat inclination adjustment-Load change,8,
IDE06683-MAS04337,Seat inclination adjustment-Engine current,0, A
IDE06683-MAS05370,Seat inclination adjustment-Direction of movement,Not operated,
IDE06683-MAS05563,Seat inclination adjustment-Norming,standardized,
IDE06683-MAS05719,Seat inclination adjustment-Maximum travel,262,
IDE06683-MAS12838,Seat inclination adjustment-Standardization flag,standardized,
IDE06684-MAS01390,Lumbar support height adjustment-Block 1,0,
IDE06684-MAS01391,Lumbar support height adjustment-Block 2,0,
IDE06684-MAS02282,Lumbar support height adjustment-Position,0,
IDE06684-MAS02955,Lumbar support height adjustment-Engine temperature,0, °C
IDE06684-MAS03129,Lumbar support height adjustment-Reset counter,0,
IDE06684-MAS04160,Lumbar support height adjustment-Load change,0,
IDE06684-MAS04337,Lumbar support height adjustment-Engine current,0, A
IDE06684-MAS05370,Lumbar support height adjustment-Direction of movement,Not operated,
IDE06684-MAS05563,Lumbar support height adjustment-Norming,not normed,
IDE06684-MAS05719,Lumbar support height adjustment-Maximum travel,0,
IDE06684-MAS12838,Lumbar support height adjustment-Standardization flag,never normed,
IDE06685-MAS01390,Lumbar support longitudinal position adjustment-Block 1,0,
IDE06685-MAS01391,Lumbar support longitudinal position adjustment-Block 2,0,
IDE06685-MAS02282,Lumbar support longitudinal position adjustment-Position,0,
IDE06685-MAS02955,Lumbar support longitudinal position adjustment-Engine temperature,0, °C
IDE06685-MAS03129,Lumbar support longitudinal position adjustment-Reset counter,0,
IDE06685-MAS04160,Lumbar support longitudinal position adjustment-Load change,0,
IDE06685-MAS04337,Lumbar support longitudinal position adjustment-Engine current,0, A
IDE06685-MAS05370,Lumbar support longitudinal position adjustment-Direction of movement,Not operated,
IDE06685-MAS05563,Lumbar support longitudinal position adjustment-Norming,not normed,
IDE06685-MAS05719,Lumbar support longitudinal position adjustment-Maximum travel,0,
IDE06685-MAS12838,Lumbar support longitudinal position adjustment-Standardization flag,never normed,
IDE06871-IDE06510,Seat adjustment control head-Adjustment for backrest angle,Not operated,
IDE06871-IDE06511,Seat adjustment control head-Seat height adjustment,Not operated,
IDE06871-IDE06512,Seat adjustment control head-Adjustment for seat forward/back position,Not operated,
IDE06871-IDE06683,Seat adjustment control head-Seat inclination adjustment,Not operated,
IDE06871-IDE06684,Seat adjustment control head-Lumbar support height adjustment,Not operated,
IDE06871-IDE06685,Seat adjustment control head-Lumbar support longitudinal position adjustment,Not operated,
IDE06871-IDE08989,Seat adjustment control head-Seat depth adjustment,Not operated,
IDE06871-IDE08990,Seat adjustment control head-Backrest top adjustment,Not operated,
IDE06871-IDE08991,Seat adjustment control head-Belt height adjustment,Not operated,
IDE06871-IDE11024,Seat adjustment control head-Headrest height adjustment,Not operated,
IDE06871-IDE11025,Seat adjustment control head-Headrest length adjustment,Not operated,
IDE07159,Control module switch-off: counter,0,
IDE07347-IDE06510,Memory setting 1 for seat adjustment-Adjustment for backrest angle,0,
IDE07347-IDE06511,Memory setting 1 for seat adjustment-Seat height adjustment,0,
IDE07347-IDE06512,Memory setting 1 for seat adjustment-Adjustment for seat forward/back position,0,
IDE07347-IDE06683,Memory setting 1 for seat adjustment-Seat inclination adjustment,0,
IDE07347-IDE06684,Memory setting 1 for seat adjustment-Lumbar support height adjustment,0,
IDE07347-IDE06685,Memory setting 1 for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07347-IDE08989,Memory setting 1 for seat adjustment-Seat depth adjustment,0,
IDE07347-IDE08990,Memory setting 1 for seat adjustment-Backrest top adjustment,0,
IDE07347-IDE08991,Memory setting 1 for seat adjustment-Belt height adjustment,0,
IDE07347-IDE11024,Memory setting 1 for seat adjustment-Headrest height adjustment,0,
IDE07348-IDE06510,Memory setting 2 for seat adjustment-Adjustment for backrest angle,0,
IDE07348-IDE06511,Memory setting 2 for seat adjustment-Seat height adjustment,0,
IDE07348-IDE06512,Memory setting 2 for seat adjustment-Adjustment for seat forward/back position,0,
IDE07348-IDE06683,Memory setting 2 for seat adjustment-Seat inclination adjustment,0,
IDE07348-IDE06684,Memory setting 2 for seat adjustment-Lumbar support height adjustment,0,
IDE07348-IDE06685,Memory setting 2 for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07348-IDE08989,Memory setting 2 for seat adjustment-Seat depth adjustment,0,
IDE07348-IDE08990,Memory setting 2 for seat adjustment-Backrest top adjustment,0,
IDE07348-IDE08991,Memory setting 2 for seat adjustment-Belt height adjustment,0,
IDE07348-IDE11024,Memory setting 2 for seat adjustment-Headrest height adjustment,0,
IDE07349-IDE06510,Memory setting 3 for seat adjustment-Adjustment for backrest angle,0,
IDE07349-IDE06511,Memory setting 3 for seat adjustment-Seat height adjustment,0,
IDE07349-IDE06512,Memory setting 3 for seat adjustment-Adjustment for seat forward/back position,0,
IDE07349-IDE06683,Memory setting 3 for seat adjustment-Seat inclination adjustment,0,
IDE07349-IDE06684,Memory setting 3 for seat adjustment-Lumbar support height adjustment,0,
IDE07349-IDE06685,Memory setting 3 for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07349-IDE08989,Memory setting 3 for seat adjustment-Seat depth adjustment,0,
IDE07349-IDE08990,Memory setting 3 for seat adjustment-Backrest top adjustment,0,
IDE07349-IDE08991,Memory setting 3 for seat adjustment-Belt height adjustment,0,
IDE07349-IDE11024,Memory setting 3 for seat adjustment-Headrest height adjustment,0,
IDE07350-IDE06510,Memory setting 4 for seat adjustment-Adjustment for backrest angle,0,
IDE07350-IDE06511,Memory setting 4 for seat adjustment-Seat height adjustment,0,
IDE07350-IDE06512,Memory setting 4 for seat adjustment-Adjustment for seat forward/back position,0,
IDE07350-IDE06683,Memory setting 4 for seat adjustment-Seat inclination adjustment,0,
IDE07350-IDE06684,Memory setting 4 for seat adjustment-Lumbar support height adjustment,0,
IDE07350-IDE06685,Memory setting 4 for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07350-IDE08989,Memory setting 4 for seat adjustment-Seat depth adjustment,0,
IDE07350-IDE08990,Memory setting 4 for seat adjustment-Backrest top adjustment,0,
IDE07350-IDE08991,Memory setting 4 for seat adjustment-Belt height adjustment,0,
IDE07350-IDE11024,Memory setting 4 for seat adjustment-Headrest height adjustment,0,
IDE07351-IDE06510,Memory setting 1: remote master key for seat adjustment-Adjustment for backrest angle,0,
IDE07351-IDE06511,Memory setting 1: remote master key for seat adjustment-Seat height adjustment,0,
IDE07351-IDE06512,Memory setting 1: remote master key for seat adjustment-Adjustment for seat forward/back position,0,
IDE07351-IDE06683,Memory setting 1: remote master key for seat adjustment-Seat inclination adjustment,0,
IDE07351-IDE06684,Memory setting 1: remote master key for seat adjustment-Lumbar support height adjustment,0,
IDE07351-IDE06685,Memory setting 1: remote master key for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07351-IDE08989,Memory setting 1: remote master key for seat adjustment-Seat depth adjustment,0,
IDE07351-IDE08990,Memory setting 1: remote master key for seat adjustment-Backrest top adjustment,0,
IDE07351-IDE08991,Memory setting 1: remote master key for seat adjustment-Belt height adjustment,0,
IDE07351-IDE11024,Memory setting 1: remote master key for seat adjustment-Headrest height adjustment,0,
IDE07352-IDE06510,Memory setting 2: remote master key for seat adjustment-Adjustment for backrest angle,0,
IDE07352-IDE06511,Memory setting 2: remote master key for seat adjustment-Seat height adjustment,0,
IDE07352-IDE06512,Memory setting 2: remote master key for seat adjustment-Adjustment for seat forward/back position,0,
IDE07352-IDE06683,Memory setting 2: remote master key for seat adjustment-Seat inclination adjustment,0,
IDE07352-IDE06684,Memory setting 2: remote master key for seat adjustment-Lumbar support height adjustment,0,
IDE07352-IDE06685,Memory setting 2: remote master key for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07352-IDE08989,Memory setting 2: remote master key for seat adjustment-Seat depth adjustment,0,
IDE07352-IDE08990,Memory setting 2: remote master key for seat adjustment-Backrest top adjustment,0,
IDE07352-IDE08991,Memory setting 2: remote master key for seat adjustment-Belt height adjustment,0,
IDE07352-IDE11024,Memory setting 2: remote master key for seat adjustment-Headrest height adjustment,0,
IDE07353-IDE06510,Memory setting 3: remote master key for seat adjustment-Adjustment for backrest angle,0,
IDE07353-IDE06511,Memory setting 3: remote master key for seat adjustment-Seat height adjustment,0,
IDE07353-IDE06512,Memory setting 3: remote master key for seat adjustment-Adjustment for seat forward/back position,0,
IDE07353-IDE06683,Memory setting 3: remote master key for seat adjustment-Seat inclination adjustment,0,
IDE07353-IDE06684,Memory setting 3: remote master key for seat adjustment-Lumbar support height adjustment,0,
IDE07353-IDE06685,Memory setting 3: remote master key for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07353-IDE08989,Memory setting 3: remote master key for seat adjustment-Seat depth adjustment,0,
IDE07353-IDE08990,Memory setting 3: remote master key for seat adjustment-Backrest top adjustment,0,
IDE07353-IDE08991,Memory setting 3: remote master key for seat adjustment-Belt height adjustment,0,
IDE07353-IDE11024,Memory setting 3: remote master key for seat adjustment-Headrest height adjustment,0,
IDE07354-IDE06510,Memory setting 4: remote master key for seat adjustment-Adjustment for backrest angle,0,
IDE07354-IDE06511,Memory setting 4: remote master key for seat adjustment-Seat height adjustment,0,
IDE07354-IDE06512,Memory setting 4: remote master key for seat adjustment-Adjustment for seat forward/back position,0,
IDE07354-IDE06683,Memory setting 4: remote master key for seat adjustment-Seat inclination adjustment,0,
IDE07354-IDE06684,Memory setting 4: remote master key for seat adjustment-Lumbar support height adjustment,0,
IDE07354-IDE06685,Memory setting 4: remote master key for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07354-IDE08989,Memory setting 4: remote master key for seat adjustment-Seat depth adjustment,0,
IDE07354-IDE08990,Memory setting 4: remote master key for seat adjustment-Backrest top adjustment,0,
IDE07354-IDE08991,Memory setting 4: remote master key for seat adjustment-Belt height adjustment,0,
IDE07354-IDE11024,Memory setting 4: remote master key for seat adjustment-Headrest height adjustment,0,
IDE08988-MAS01390,Head restraint adjustment-Block 1,0,
IDE08988-MAS01391,Head restraint adjustment-Block 2,0,
IDE08988-MAS02282,Head restraint adjustment-Position,0,
IDE08988-MAS02955,Head restraint adjustment-Engine temperature,0, °C
IDE08988-MAS03129,Head restraint adjustment-Reset counter,0,
IDE08988-MAS04160,Head restraint adjustment-Load change,0,
IDE08988-MAS04337,Head restraint adjustment-Engine current,0, A
IDE08988-MAS05370,Head restraint adjustment-Direction of movement,Not operated,
IDE08988-MAS05563,Head restraint adjustment-Norming,not normed,
IDE08988-MAS05719,Head restraint adjustment-Maximum travel,0,
IDE08988-MAS12838,Head restraint adjustment-Standardization flag,never normed,
IDE08989-MAS01390,Seat depth adjustment-Block 1,0,
IDE08989-MAS01391,Seat depth adjustment-Block 2,0,
IDE08989-MAS02282,Seat depth adjustment-Position,0,
IDE08989-MAS02955,Seat depth adjustment-Engine temperature,0, °C
IDE08989-MAS03129,Seat depth adjustment-Reset counter,0,
IDE08989-MAS04160,Seat depth adjustment-Load change,0,
IDE08989-MAS04337,Seat depth adjustment-Engine current,0, A
IDE08989-MAS05370,Seat depth adjustment-Direction of movement,Not operated,
IDE08989-MAS05563,Seat depth adjustment-Norming,not normed,
IDE08989-MAS05719,Seat depth adjustment-Maximum travel,0,
IDE08989-MAS12838,Seat depth adjustment-Standardization flag,never normed,
IDE08990-MAS01390,Backrest top adjustment-Block 1,0,
IDE08990-MAS01391,Backrest top adjustment-Block 2,0,
IDE08990-MAS02282,Backrest top adjustment-Position,0,
IDE08990-MAS02955,Backrest top adjustment-Engine temperature,0, °C
IDE08990-MAS03129,Backrest top adjustment-Reset counter,0,
IDE08990-MAS04160,Backrest top adjustment-Load change,0,
IDE08990-MAS04337,Backrest top adjustment-Engine current,0, A
IDE08990-MAS05370,Backrest top adjustment-Direction of movement,Not operated,
IDE08990-MAS05563,Backrest top adjustment-Norming,not normed,
IDE08990-MAS05719,Backrest top adjustment-Maximum travel,0,
IDE08990-MAS12838,Backrest top adjustment-Standardization flag,never normed,
IDE08991-MAS01390,Belt height adjustment-Block 1,0,
IDE08991-MAS01391,Belt height adjustment-Block 2,0,
IDE08991-MAS02282,Belt height adjustment-Position,0,
IDE08991-MAS02955,Belt height adjustment-Engine temperature,0, °C
IDE08991-MAS03129,Belt height adjustment-Reset counter,0,
IDE08991-MAS04160,Belt height adjustment-Load change,0,
IDE08991-MAS04337,Belt height adjustment-Engine current,0, A
IDE08991-MAS05370,Belt height adjustment-Direction of movement,Not operated,
IDE08991-MAS05563,Belt height adjustment-Norming,not normed,
IDE08991-MAS05719,Belt height adjustment-Maximum travel,0,
IDE08991-MAS12838,Belt height adjustment-Standardization flag,never normed,
IDE09081-MAS08291,Seat switch module-Plate: vertical actuation direction,Not operated,
IDE09081-MAS08292,Seat switch module-Plate: horizontal actuation direction,Not operated,
IDE09081-MAS08293,Seat switch module-Rocker,Not operated,
IDE09082,Massage button,Not operated,
IDE09083-MAS08294,Entry assistance button-Entry assistance button: actuation direction forward,Not operated,
IDE09083-MAS08295,Entry assistance button-Entry assistance button: actuation direction backward,Not operated,
IDE09084-MAS08296,Backrest lock switch-Switch state normally closed,operated,
IDE09084-MAS08297,Backrest lock switch-Switch state normally open,Not operated,
IDE09085,Backrest limit switch,Not operated,
IDE10995-IDE06510,Calibrating the motors: status-Adjustment for backrest angle,standardized,
IDE10995-IDE06511,Calibrating the motors: status-Seat height adjustment,standardized,
IDE10995-IDE06512,Calibrating the motors: status-Adjustment for seat forward/back position,standardized,
IDE10995-IDE06683,Calibrating the motors: status-Seat inclination adjustment,standardized,
IDE10995-IDE06684,Calibrating the motors: status-Lumbar support height adjustment,not normed,
IDE10995-IDE06685,Calibrating the motors: status-Lumbar support longitudinal position adjustment,not normed,
IDE10995-IDE08988,Calibrating the motors: status-Head restraint adjustment,not normed,
IDE10995-IDE08989,Calibrating the motors: status-Seat depth adjustment,not normed,
IDE10995-IDE08990,Calibrating the motors: status-Backrest top adjustment,not normed,
IDE10995-IDE08991,Calibrating the motors: status-Belt height adjustment,not normed,
IDE10995-IDE11957,Calibrating the motors: status-Display unit adjustment,not normed,
IDE10995-IDE11969,Calibrating the motors: status-Adjustment of foot rest,not normed,
IDE10995-IDE11986,Calibrating the motors: status-Adjustment 2 of visual display unit,not normed,
IDE10995-MAS11869,Calibrating the motors: status-Headrest adjustment: horizontal,not normed,
IDE10995-MAS11890,Calibrating the motors: status-Headrest adjustment: vertical,not normed,
IDE10996-MAS11891,Excessive force limit: status-Seat forward/back position adjustment: forwards,Adapted,
IDE10996-MAS11892,Excessive force limit: status-Seat forward/back position adjustment: backwards,Adapted,
IDE10996-MAS11895,Excessive force limit: status-Backrest inclination adjustment: forwards,Not adapted,
IDE10996-MAS11896,Excessive force limit: status-Backrest inclination adjustment: backwards,Not adapted,
IDE10996-MAS11959,Excessive force limit: status-Seat height adjustment higher,Not adapted,
IDE10996-MAS11960,Excessive force limit: status-Seat height adjustment lower,Not adapted,
IDE11024-MAS01390,Headrest height adjustment-Block 1,0,
IDE11024-MAS01391,Headrest height adjustment-Block 2,0,
IDE11024-MAS02282,Headrest height adjustment-Position,0,
IDE11024-MAS02955,Headrest height adjustment-Engine temperature,0, °C
IDE11024-MAS03129,Headrest height adjustment-Reset counter,0,
IDE11024-MAS04160,Headrest height adjustment-Load change,0,
IDE11024-MAS04337,Headrest height adjustment-Engine current,0, A
IDE11024-MAS05370,Headrest height adjustment-Direction of movement,Not operated,
IDE11024-MAS05563,Headrest height adjustment-Norming,not normed,
IDE11024-MAS05719,Headrest height adjustment-Maximum travel,0,
IDE11024-MAS12838,Headrest height adjustment-Standardization flag,never normed,
IDE11025-MAS01390,Headrest length adjustment-Block 1,0,
IDE11025-MAS01391,Headrest length adjustment-Block 2,0,
IDE11025-MAS02282,Headrest length adjustment-Position,0,
IDE11025-MAS02955,Headrest length adjustment-Engine temperature,0, °C
IDE11025-MAS03129,Headrest length adjustment-Reset counter,0,
IDE11025-MAS04160,Headrest length adjustment-Load change,0,
IDE11025-MAS04337,Headrest length adjustment-Engine current,0, A
IDE11025-MAS05370,Headrest length adjustment-Direction of movement,Not operated,
IDE11025-MAS05563,Headrest length adjustment-Norming,not normed,
IDE11025-MAS05719,Headrest length adjustment-Maximum travel,0,
IDE11025-MAS12838,Headrest length adjustment-Standardization flag,never normed,
IDE11957-MAS01390,Display unit adjustment-Block 1,0,
IDE11957-MAS01391,Display unit adjustment-Block 2,0,
IDE11957-MAS02282,Display unit adjustment-Position,0,
IDE11957-MAS02955,Display unit adjustment-Engine temperature,0, °C
IDE11957-MAS03129,Display unit adjustment-Reset counter,0,
IDE11957-MAS04160,Display unit adjustment-Load change,0,
IDE11957-MAS04337,Display unit adjustment-Engine current,0, A
IDE11957-MAS05370,Display unit adjustment-Direction of movement,Not operated,
IDE11957-MAS05563,Display unit adjustment-Norming,not normed,
IDE11957-MAS05719,Display unit adjustment-Maximum travel,0,
IDE11957-MAS12838,Display unit adjustment-Standardization flag,never normed,
IDE11969-MAS01390,Adjustment of foot rest-Block 1,0,
IDE11969-MAS01391,Adjustment of foot rest-Block 2,0,
IDE11969-MAS02282,Adjustment of foot rest-Position,0,
IDE11969-MAS02955,Adjustment of foot rest-Engine temperature,0, °C
IDE11969-MAS03129,Adjustment of foot rest-Reset counter,0,
IDE11969-MAS04160,Adjustment of foot rest-Load change,0,
IDE11969-MAS04337,Adjustment of foot rest-Engine current,0, A
IDE11969-MAS05370,Adjustment of foot rest-Direction of movement,Not operated,
IDE11969-MAS05563,Adjustment of foot rest-Norming,not normed,
IDE11969-MAS05719,Adjustment of foot rest-Maximum travel,0,
IDE11969-MAS12838,Adjustment of foot rest-Standardization flag,never normed,
IDE11986-MAS01390,Adjustment 2 of visual display unit-Block 1,0,
IDE11986-MAS01391,Adjustment 2 of visual display unit-Block 2,0,
IDE11986-MAS02282,Adjustment 2 of visual display unit-Position,0,
IDE11986-MAS02955,Adjustment 2 of visual display unit-Engine temperature,0, °C
IDE11986-MAS03129,Adjustment 2 of visual display unit-Reset counter,0,
IDE11986-MAS04160,Adjustment 2 of visual display unit-Load change,0,
IDE11986-MAS04337,Adjustment 2 of visual display unit-Engine current,0, A
IDE11986-MAS05370,Adjustment 2 of visual display unit-Direction of movement,Not operated,
IDE11986-MAS05563,Adjustment 2 of visual display unit-Norming,not normed,
IDE11986-MAS05719,Adjustment 2 of visual display unit-Maximum travel,0,
IDE11986-MAS12838,Adjustment 2 of visual display unit-Standardization flag,never normed,
IDE12083-MAS13890,Switch for lateral backrest support adjustment-Adjustment for lateral support backrest,Not operated,
IDE12083-MAS13891,Switch for lateral backrest support adjustment-Adjustment for lateral support seat cushion,Not operated,
MAS12838-IDE06510,Standardization flag-Adjustment for backrest angle,standardized,
MAS12838-IDE06511,Standardization flag-Seat height adjustment,standardized,
MAS12838-IDE06512,Standardization flag-Adjustment for seat forward/back position,standardized,
MAS12838-IDE06683,Standardization flag-Seat inclination adjustment,standardized,
MAS12838-IDE06684,Standardization flag-Lumbar support height adjustment,never normed,
MAS12838-IDE06685,Standardization flag-Lumbar support longitudinal position adjustment,never normed,
MAS12838-IDE08988,Standardization flag-Head restraint adjustment,never normed,
MAS12838-IDE08989,Standardization flag-Seat depth adjustment,never normed,
MAS12838-IDE08990,Standardization flag-Backrest top adjustment,never normed,
MAS12838-IDE08991,Standardization flag-Belt height adjustment,never normed,
MAS12838-IDE11957,Standardization flag-Display unit adjustment,never normed,
MAS12838-IDE11969,Standardization flag-Adjustment of foot rest,never normed,
MAS12838-IDE11986,Standardization flag-Adjustment 2 of visual display unit,never normed,
MAS12838-MAS11869,Standardization flag-Headrest adjustment: horizontal,never normed,
MAS12838-MAS11890,Standardization flag-Headrest adjustment: vertical,never normed,
ENG139951-IDE06510,Account_1-Adjustment for backrest angle,0,
ENG139951-IDE06511,Account_1-Seat height adjustment,0,
ENG139951-IDE06512,Account_1-Adjustment for seat forward/back position,0,
ENG139951-IDE06683,Account_1-Seat inclination adjustment,0,
ENG139951-IDE06684,Account_1-Lumbar support height adjustment,0,
ENG139951-IDE06685,Account_1-Lumbar support longitudinal position adjustment,0,
ENG139951-IDE08989,Account_1-Seat depth adjustment,0,
ENG139951-IDE08990,Account_1-Backrest top adjustment,0,
ENG139951-IDE08991,Account_1-Belt height adjustment,0,
ENG139951-IDE11024,Account_1-Headrest height adjustment,0,
ENG139952-IDE06510,Account_2-Adjustment for backrest angle,0,
ENG139952-IDE06511,Account_2-Seat height adjustment,0,
ENG139952-IDE06512,Account_2-Adjustment for seat forward/back position,0,
ENG139952-IDE06683,Account_2-Seat inclination adjustment,0,
ENG139952-IDE06684,Account_2-Lumbar support height adjustment,0,
ENG139952-IDE06685,Account_2-Lumbar support longitudinal position adjustment,0,
ENG139952-IDE08989,Account_2-Seat depth adjustment,0,
ENG139952-IDE08990,Account_2-Backrest top adjustment,0,
ENG139952-IDE08991,Account_2-Belt height adjustment,0,
ENG139952-IDE11024,Account_2-Headrest height adjustment,0,
ENG139953-IDE06510,Account_3-Adjustment for backrest angle,0,
ENG139953-IDE06511,Account_3-Seat height adjustment,0,
ENG139953-IDE06512,Account_3-Adjustment for seat forward/back position,0,
ENG139953-IDE06683,Account_3-Seat inclination adjustment,0,
ENG139953-IDE06684,Account_3-Lumbar support height adjustment,0,
ENG139953-IDE06685,Account_3-Lumbar support longitudinal position adjustment,0,
ENG139953-IDE08989,Account_3-Seat depth adjustment,0,
ENG139953-IDE08990,Account_3-Backrest top adjustment,0,
ENG139953-IDE08991,Account_3-Belt height adjustment,0,
ENG139953-IDE11024,Account_3-Headrest height adjustment,0,
ENG139954-IDE06510,Account_4-Adjustment for backrest angle,0,
ENG139954-IDE06511,Account_4-Seat height adjustment,0,
ENG139954-IDE06512,Account_4-Adjustment for seat forward/back position,0,
ENG139954-IDE06683,Account_4-Seat inclination adjustment,0,
ENG139954-IDE06684,Account_4-Lumbar support height adjustment,0,
ENG139954-IDE06685,Account_4-Lumbar support longitudinal position adjustment,0,
ENG139954-IDE08989,Account_4-Seat depth adjustment,0,
ENG139954-IDE08990,Account_4-Backrest top adjustment,0,
ENG139954-IDE08991,Account_4-Belt height adjustment,0,
ENG139954-IDE11024,Account_4-Headrest height adjustment,0,
ENG139955-IDE06510,Account_5-Adjustment for backrest angle,0,
ENG139955-IDE06511,Account_5-Seat height adjustment,0,
ENG139955-IDE06512,Account_5-Adjustment for seat forward/back position,0,
ENG139955-IDE06683,Account_5-Seat inclination adjustment,0,
ENG139955-IDE06684,Account_5-Lumbar support height adjustment,0,
ENG139955-IDE06685,Account_5-Lumbar support longitudinal position adjustment,0,
ENG139955-IDE08989,Account_5-Seat depth adjustment,0,
ENG139955-IDE08990,Account_5-Backrest top adjustment,0,
ENG139955-IDE08991,Account_5-Belt height adjustment,0,
ENG139955-IDE11024,Account_5-Headrest height adjustment,0,
ENG139956-IDE06510,Account_6-Adjustment for backrest angle,0,
ENG139956-IDE06511,Account_6-Seat height adjustment,0,
ENG139956-IDE06512,Account_6-Adjustment for seat forward/back position,0,
ENG139956-IDE06683,Account_6-Seat inclination adjustment,0,
ENG139956-IDE06684,Account_6-Lumbar support height adjustment,0,
ENG139956-IDE06685,Account_6-Lumbar support longitudinal position adjustment,0,
ENG139956-IDE08989,Account_6-Seat depth adjustment,0,
ENG139956-IDE08990,Account_6-Backrest top adjustment,0,
ENG139956-IDE08991,Account_6-Belt height adjustment,0,
ENG139956-IDE11024,Account_6-Headrest height adjustment,0,
ENG139957-IDE06510,Account_7-Adjustment for backrest angle,0,
ENG139957-IDE06511,Account_7-Seat height adjustment,0,
ENG139957-IDE06512,Account_7-Adjustment for seat forward/back position,0,
ENG139957-IDE06683,Account_7-Seat inclination adjustment,0,
ENG139957-IDE06684,Account_7-Lumbar support height adjustment,0,
ENG139957-IDE06685,Account_7-Lumbar support longitudinal position adjustment,0,
ENG139957-IDE08989,Account_7-Seat depth adjustment,0,
ENG139957-IDE08990,Account_7-Backrest top adjustment,0,
ENG139957-IDE08991,Account_7-Belt height adjustment,0,
ENG139957-IDE11024,Account_7-Headrest height adjustment,0,
ENG139950-IDE06510,BAP_Seat_Adjustment_Button_Status-Adjustment for backrest angle,Not operated,
ENG139950-IDE06511,BAP_Seat_Adjustment_Button_Status-Seat height adjustment,Not operated,
ENG139950-IDE06512,BAP_Seat_Adjustment_Button_Status-Adjustment for seat forward/back position,Not operated,
ENG139950-IDE06683,BAP_Seat_Adjustment_Button_Status-Seat inclination adjustment,Not operated,
ENG139950-IDE06684,BAP_Seat_Adjustment_Button_Status-Lumbar support height adjustment,Not operated,
ENG139950-IDE06685,BAP_Seat_Adjustment_Button_Status-Lumbar support longitudinal position adjustment,Not operated,
ENG139950-IDE08989,BAP_Seat_Adjustment_Button_Status-Seat depth adjustment,Not operated,
ENG139950-IDE08990,BAP_Seat_Adjustment_Button_Status-Backrest top adjustment,Not operated,
ENG139950-IDE08991,BAP_Seat_Adjustment_Button_Status-Belt height adjustment,Not operated,
ENG139950-IDE11024,BAP_Seat_Adjustment_Button_Status-Headrest height adjustment,Not operated,
ENG139950-IDE11025,BAP_Seat_Adjustment_Button_Status-Headrest length adjustment,Not operated,
ENG139950-IDE11957,BAP_Seat_Adjustment_Button_Status-Display unit adjustment,Not operated,
ENG139950-IDE11969,BAP_Seat_Adjustment_Button_Status-Adjustment of foot rest,Not operated,
ENG139950-IDE11986,BAP_Seat_Adjustment_Button_Status-Adjustment 2 of visual display unit,Not operated,
ENG139950-ENG140668,BAP_Seat_Adjustment_Button_Status-backrest_side_bolster,Not operated,
ENG139950-ENG140669,BAP_Seat_Adjustment_Button_Status-footmat,Not operated,
ENG139950-ENG140667,BAP_Seat_Adjustment_Button_Status-side_bolster,Not operated,
ENG136330-ENG136340,Cause of de-normalization-Axis_1,Normierroutine,
ENG136330-ENG136349,Cause of de-normalization-Axis_10,Achse decodiert,
ENG136330-ENG136341,Cause of de-normalization-Axis_2,Normierroutine,
ENG136330-ENG136342,Cause of de-normalization-Axis_3,Normierroutine,
ENG136330-ENG136343,Cause of de-normalization-Axis_4,Normierroutine,
ENG136330-ENG136344,Cause of de-normalization-Axis_5,Achse decodiert,
ENG136330-ENG136345,Cause of de-normalization-Axis_6,Achse decodiert,
ENG136330-ENG136346,Cause of de-normalization-Axis_7,Achse decodiert,
ENG136330-ENG136347,Cause of de-normalization-Axis_8,Achse decodiert,
ENG136330-ENG136348,Cause of de-normalization-Axis_9,Achse decodiert,
ENG136325-ENG101098,crash_precrash-Crash,not active,
ENG136325-ENG131963,crash_precrash-Precrash,not active,
ENG247801-ENG248126,info_developer-ax_da,80 3C 7F 28 81 50 00 07 80 6D 7E D4 85 03 00 07 81 F4 80 00 81 F5 00 07 81 06 80 00 81 06 00 07 80 00 00 00 FF FF 01 0A 80 00 00 00 FF FF 01 0A 80 00 00 00 FF FF 01 0A 80 00 00 00 FF FF 01 0A 80 00 00 00 FF FF 01 0A 80 00 00 00 FF FF 01 0A,
ENG247801-ENG248078,info_developer-gl_lo,31 4E 33 39 35 39 37 36 30 48 20 00 00 00 00 00 54 30 37 35 00 00 00 00 32 35 33 39 00 00 00 00 53 43 42 55 5A 5A 50 45 4F 50 4C 45 00 00 00 00 0D 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG247801-ENG247947,info_developer-gl_pr,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0B 00 04 03 03 03 00 03 04 04 00 00 00 00,
ENG247801-ENG248107,info_developer-pne,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG247801-ENG248040,info_developer-so_deb,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG136350-ENG136426,key_memory_activated-mmi_key_memory_activated,not active,
ENG157282-ENG161450,Maximum travel-Axis_1_current,552,
ENG157282-ENG161451,Maximum travel-Axis_1_last,0,
ENG157282-ENG161452,Maximum travel-Axis_10_current,65535,
ENG157282-ENG161453,Maximum travel-Axis_10_last,0,
ENG157282-ENG161454,Maximum travel-Axis_2_current,1583,
ENG157282-ENG161455,Maximum travel-Axis_2_last,0,
ENG157282-ENG161456,Maximum travel-Axis_3_current,501,
ENG157282-ENG161457,Maximum travel-Axis_3_last,0,
ENG157282-ENG161458,Maximum travel-Axis_4_current,262,
ENG157282-ENG161459,Maximum travel-Axis_4_last,0,
ENG157282-ENG161460,Maximum travel-Axis_5_current,65535,
ENG157282-ENG161461,Maximum travel-Axis_5_last,0,
ENG157282-ENG161462,Maximum travel-Axis_6_current,65535,
ENG157282-ENG161463,Maximum travel-Axis_6_last,0,
ENG157282-ENG161464,Maximum travel-Axis_7_current,65535,
ENG157282-ENG161465,Maximum travel-Axis_7_last,0,
ENG157282-ENG161466,Maximum travel-Axis_8_current,65535,
ENG157282-ENG161467,Maximum travel-Axis_8_last,0,
ENG157282-ENG161468,Maximum travel-Axis_9_current,65535,
ENG157282-ENG161469,Maximum travel-Axis_9_last,0,
ENG136323-IDE06842,Memory_ID_CAN_1-Status - Button 1,not active,
ENG136323-IDE06843,Memory_ID_CAN_1-Status - Button 2,not active,
ENG136323-IDE06844,Memory_ID_CAN_1-Status - Button 3,not active,
ENG136323-IDE06845,Memory_ID_CAN_1-Status - Button 4,not active,
ENG136323-ENG123088,Memory_ID_CAN_1-FFB_Close_Button,not active,
ENG136323-ENG123087,Memory_ID_CAN_1-FFB_Open_Button,not active,
ENG136323-ENG123089,Memory_ID_CAN_1-FT_lock,not active,
ENG136323-ENG123090,Memory_ID_CAN_1-FT_locked,not active,
ENG136324-MAS03679,Memory_ID_CAN_2-Terminal 15 status,active,
ENG136324-ENG123091,Memory_ID_CAN_2-DoorContact_more_than_10min_opened,not active,
ENG136324-ENG123092,Memory_ID_CAN_2-DoorContact_NotActive_Active,not active,
ENG136324-ENG140350,Memory_ID_CAN_2-FFB_HDF_Button,not active,
ENG136324-ENG136335,Memory_ID_CAN_2-Hardware_onoff,active,
ENG136324-ENG123093,Memory_ID_CAN_2-Memory_Adjustment,not active,
ENG136324-ENG123094,Memory_ID_CAN_2-MemoryButton_Pressed,not active,
ENG136324-ENG248058,Memory_ID_CAN_2-v_signal_less_v_threshold,active,
ENG158048-MAS03760,missing_pre_conditions-Wind deflector position,not active,
ENG158048-ENG161471,missing_pre_conditions-backrest_locked,active,
ENG158048-ENG161472,missing_pre_conditions-backrest_unlocked,active,
ENG158048-ENG161506,missing_pre_conditions-button_pressed,not active,
ENG158048-ENG161716,missing_pre_conditions-coded_axes_not_normalized,not active,
ENG158048-ENG163288,missing_pre_conditions-other_adjustment_already_active,not active,
ENG158048-ENG98864,missing_pre_conditions-Reserved,0,
ENG158048-ENG310748,missing_pre_conditions-reserviert_01,0,
ENG158048-ENG163523,missing_pre_conditions-reset_problem,not active,
ENG158048-ENG163733,missing_pre_conditions-speed_above_5kmh,not active,
ENG158048-ENG159469,missing_pre_conditions-Voltage_supply,not active,
ENG158102-ENG161674,personalization_last_function-cause_of_termination,0,
ENG158102,personalization_last_function,none,
ENG158102-ENG99298,personalization_last_function-State,none,
ENG136328-ENG136337,pwm_generator-pwm_generator_group_1_overload,not active,
ENG136328-ENG136338,pwm_generator-pwm_generator_group_2_overload,not active,
ENG136326-ENG99389,Resets-Resetcounter,11,
ENG136329-ENG136339,sbc-sbc_overload,not active,
ENG136351-ENG136438,Seat_Actual_Positions-Current_Position_fsv,32768,
ENG136351-ENG136434,Seat_Actual_Positions-Current_Position_ghv,32768,
ENG136351-ENG136441,Seat_Actual_Positions-Current_Position_kks,32768,
ENG136351-ENG136437,Seat_Actual_Positions-Current_Position_ksv_x,32768,
ENG136351-ENG136431,Seat_Actual_Positions-Current_Position_ksv_z,32768,
ENG136351-ENG136436,Seat_Actual_Positions-Current_Position_ldh,32768,
ENG136351-ENG136435,Seat_Actual_Positions-Current_Position_ldw,32768,
ENG136351-ENG136433,Seat_Actual_Positions-Current_Position_lkv,32768,
ENG136351-ENG136428,Seat_Actual_Positions-Current_Position_lnv,32877,
ENG136351-ENG136439,Seat_Actual_Positions-Current_Position_rse1,32768,
ENG136351-ENG136440,Seat_Actual_Positions-Current_Position_rse2,32768,
ENG136351-ENG136429,Seat_Actual_Positions-Current_Position_shv,33268,
ENG136351-ENG136427,Seat_Actual_Positions-Current_Position_slv,32828,
ENG136351-ENG136430,Seat_Actual_Positions-Current_Position_snv,33030,
ENG136351-ENG136432,Seat_Actual_Positions-Current_Position_stv,32768,
ENG123054-ENG136421,Seat_Adjustment_Memory_Info_CAN-Mem_Taster_1,not active,
ENG123054-ENG136422,Seat_Adjustment_Memory_Info_CAN-Mem_Taster_2,not active,
ENG123054-ENG136423,Seat_Adjustment_Memory_Info_CAN-Mem_Taster_3,not active,
ENG123054-ENG136424,Seat_Adjustment_Memory_Info_CAN-Mem_Taster_4,not active,
ENG123054-ENG136425,Seat_Adjustment_Memory_Info_CAN-Mem_Taster_SET,not active,
ENG123054-ENG123084,Seat_Adjustment_Memory_Info_CAN-MMB_glob_Stop,not active,
ENG123054-ENG123077,Seat_Adjustment_Memory_Info_CAN-MMB_storage_0,not active,
ENG123054-ENG123078,Seat_Adjustment_Memory_Info_CAN-MMB_storage_1,not active,
ENG123054-ENG123079,Seat_Adjustment_Memory_Info_CAN-MMB_storage_2,not active,
ENG123054-ENG123080,Seat_Adjustment_Memory_Info_CAN-MMB_storage_3,not active,
ENG123054-ENG123083,Seat_Adjustment_Memory_Info_CAN-MMB_store,not active,
ENG123054-ENG123082,Seat_Adjustment_Memory_Info_CAN-MMB_tast,not active,
ENG123054-ENG123081,Seat_Adjustment_Memory_Info_CAN-MMB_tipp,not active,
ENG123055-ENG123086,Seat_Adjustment_Remote_Control_Locking_Info_CAN-Active_Remote_Control_Key,not active,
ENG123055-ENG123085,Seat_Adjustment_Remote_Control_Locking_Info_CAN-Remote_Control_Key_Signal,No_signal,
ENG123053-ENG136417,Seat_Adjustment_State_Info_CAN-FSM_Backrest_Head_Movement,not active,
ENG123053-ENG136412,Seat_Adjustment_State_Info_CAN-FSM_Backrest_Inclination_Movement,not active,
ENG123053-ENG136418,Seat_Adjustment_State_Info_CAN-FSM_Belt_Height_Movement,not active,
ENG123053-ENG136415,Seat_Adjustment_State_Info_CAN-FSM_Headrest_Movement,not active,
ENG123053-ENG123076,Seat_Adjustment_State_Info_CAN-FSM_KD_Error,not active,
ENG123053-ENG136420,Seat_Adjustment_State_Info_CAN-FSM_Lumbar_Height_Movement,not active,
ENG123053-ENG136419,Seat_Adjustment_State_Info_CAN-FSM_Lumbar_Longitudial_Movement,not active,
ENG123053-ENG136416,Seat_Adjustment_State_Info_CAN-FSM_Seat_Depth_Movement,not active,
ENG123053-ENG136413,Seat_Adjustment_State_Info_CAN-FSM_Seat_Height_Movement,not active,
ENG123053-ENG136414,Seat_Adjustment_State_Info_CAN-FSM_Seat_Inclination_Movement,not active,
ENG123053-ENG136411,Seat_Adjustment_State_Info_CAN-FSM_Seat_Longitudial_Movement,not active,
ENG123053-ENG123075,Seat_Adjustment_State_Info_CAN-FSM_SeatMovement,not active,
ENG158188-IDE06510,Seat_Position_Memory_Remote_Control_5-Adjustment for backrest angle,0,
ENG158188-IDE06511,Seat_Position_Memory_Remote_Control_5-Seat height adjustment,0,
ENG158188-IDE06512,Seat_Position_Memory_Remote_Control_5-Adjustment for seat forward/back position,0,
ENG158188-IDE06683,Seat_Position_Memory_Remote_Control_5-Seat inclination adjustment,0,
ENG158188-IDE06684,Seat_Position_Memory_Remote_Control_5-Lumbar support height adjustment,0,
ENG158188-IDE06685,Seat_Position_Memory_Remote_Control_5-Lumbar support longitudinal position adjustment,0,
ENG158188-IDE08989,Seat_Position_Memory_Remote_Control_5-Seat depth adjustment,0,
ENG158188-IDE08990,Seat_Position_Memory_Remote_Control_5-Backrest top adjustment,0,
ENG158188-IDE08991,Seat_Position_Memory_Remote_Control_5-Belt height adjustment,0,
ENG158188-IDE11024,Seat_Position_Memory_Remote_Control_5-Headrest height adjustment,0,
ENG158189-IDE06510,Seat_Position_Memory_Remote_Control_6-Adjustment for backrest angle,0,
ENG158189-IDE06511,Seat_Position_Memory_Remote_Control_6-Seat height adjustment,0,
ENG158189-IDE06512,Seat_Position_Memory_Remote_Control_6-Adjustment for seat forward/back position,0,
ENG158189-IDE06683,Seat_Position_Memory_Remote_Control_6-Seat inclination adjustment,0,
ENG158189-IDE06684,Seat_Position_Memory_Remote_Control_6-Lumbar support height adjustment,0,
ENG158189-IDE06685,Seat_Position_Memory_Remote_Control_6-Lumbar support longitudinal position adjustment,0,
ENG158189-IDE08989,Seat_Position_Memory_Remote_Control_6-Seat depth adjustment,0,
ENG158189-IDE08990,Seat_Position_Memory_Remote_Control_6-Backrest top adjustment,0,
ENG158189-IDE08991,Seat_Position_Memory_Remote_Control_6-Belt height adjustment,0,
ENG158189-IDE11024,Seat_Position_Memory_Remote_Control_6-Headrest height adjustment,0,
ENG158190-IDE06510,Seat_Position_Memory_Remote_Control_7-Adjustment for backrest angle,0,
ENG158190-IDE06511,Seat_Position_Memory_Remote_Control_7-Seat height adjustment,0,
ENG158190-IDE06512,Seat_Position_Memory_Remote_Control_7-Adjustment for seat forward/back position,0,
ENG158190-IDE06683,Seat_Position_Memory_Remote_Control_7-Seat inclination adjustment,0,
ENG158190-IDE06684,Seat_Position_Memory_Remote_Control_7-Lumbar support height adjustment,0,
ENG158190-IDE06685,Seat_Position_Memory_Remote_Control_7-Lumbar support longitudinal position adjustment,0,
ENG158190-IDE08989,Seat_Position_Memory_Remote_Control_7-Seat depth adjustment,0,
ENG158190-IDE08990,Seat_Position_Memory_Remote_Control_7-Backrest top adjustment,0,
ENG158190-IDE08991,Seat_Position_Memory_Remote_Control_7-Belt height adjustment,0,
ENG158190-IDE11024,Seat_Position_Memory_Remote_Control_7-Headrest height adjustment,0,
ENG136327-ENG116986,Source_Last_Reset-Low_Voltage,not active,
ENG136327-ENG123073,Source_Last_Reset-Low_Voltage_At_Run_Up,not active,
ENG136327-ENG123072,Source_Last_Reset-Power_On_Reset,active,
ENG136327-ENG123071,Source_Last_Reset-Software_Reset_by_diagnosis,not active,
ENG136327-ENG110107,Source_Last_Reset-Watchdog_reset,not active,
ENG136327-ENG123074,Source_Last_Reset-Watchdog_Reset_At_Run_Up,not active,
Elapsed Time: 00:23
blockmap-08-1N3-907-007-D_WVG5WVEB2SH017765-20250325-1220.CSV
;SW:1N3-907-007-D   HW:1N3-907-007-C ---  Auto HVAC
;Component:Climatronic   H01 0247, Coding:013022207010120051102110111001102000102100201171000010000000
;EV_ACClimaBHBE3ADV,002051,EV_ACClimaBHBE3ADV_AUE3.rod
;Tuesday,25,March,2025,12:20:31:58926
;VCID: 2D0C67A2ED9F5C82140-8078-R SFD+SFD2
IDE00019,Voltage terminal 30,14.70, V
IDE00198,Refrigerant pressure,6.60, bar
IDE00767,No. of unscheduled ECU resets,0,
IDE00965,Compressor shut-off condition,Compressor active: no shut-off condition is present,
IDE00968,Compressor speed,300.0, /min
IDE00969,Compressor load,0.0, Nm
IDE00970,Coolant fan activation: actual value,12.00, %
IDE00971,Coolant fan activation: specified value,55.2, %
IDE00973,Outside temperature,20.50, °C
IDE00974,Outside air temperature internally calculated,17.50, °C
IDE00976,Left front vent temperature,16.00, °C
IDE00977,Right front vent temperature,15.50, °C
IDE00979,Left footwell vent temperature,17.00, °C
IDE00980,Right footwell vent temperature,15.00, °C
IDE00982,Temperature downstream of evaporator,10.00, °C
IDE00983,Inside temperature,27.40, °C
IDE00984,Sun intensity left,450.00, W/m²
IDE00985,Sun intensity right,130.00, W/m²
IDE00992,Recirculation flap specified value,Unknown (13)
IDE00994,Actual value for fresh air/recirculation air flow flap,861,
IDE00994,Actual value for fresh air/recirculation air flow flap,100.0, %
IDE00995,Fresh air/recirculating air/back pressure door specified value,873,
IDE00996,Fresh air stop for fresh air/recirculation air flow flap,157,
IDE00997,Recirculated air stop for fresh air/recirc air flow flap,853,
IDE00998,Left temperature flap - actual value,761,
IDE00998,Left temperature flap - actual value,91.0, %
IDE00999,Temperature door left - Specified value,760,
IDE01040,Left Temperature Control Door - cold stop,194,
IDE01041,Left temperature flap: warm stop,817,
IDE01042,Right temperature flap: actual value,318,
IDE01042,Right temperature flap: actual value,18.5, %
IDE01043,Temperature door right - Specified value,319,
IDE01044,Right temperature flap: cold stop,200,
IDE01045,Right temperature flap: warm stop,831,
IDE01054,Defroster flap: actual value,0.0, %
IDE01054,Defroster flap: actual value,173,
IDE01055,Defrost door - Specified value,172,
IDE01056,Defroster flap: stop open,192,
IDE01057,Defroster flap: stop closed,813,
IDE01061,Rear air distribution flap: actual value,0.0, %
IDE01061,Rear air distribution flap: actual value,209,
IDE01062,Rear air distribution flap: specified value,209,
IDE01063,Status of recirculation air,Wipe wash,
IDE01065,Rear vent temperature,23.00, °C
IDE01068,Rear blower voltage: actual value,3.70, V
IDE01076,Time since ignition off,240, min
IDE01092,Rear air distribution flap: vent stop,229,
IDE01093,Rear air distribution flap: footwell stop,799,
IDE01227,Blower current,0.00, A
IDE01229,Blower current of rear fresh air blower,18.75, A
IDE01232,Supply voltage for external components,5.00, V
IDE01419,Compressor shut-off condition: last,Compressor activation: malfunction in activation path,
IDE01420,Compressor shut-off requirement: penultimate,Compressor activation: malfunction in activation path,
IDE01421,Compressor shut-off requirement: antepenultimate,Compressor activation: malfunction in activation path,
IDE01433,Air quality status,Clean air,
IDE01448,Actual value of heated front window,not coded/not installed,
IDE01464,Rear window defogger,OFF,
IDE01540-MAS06913,Left front heated seat-Backrest heating: activation,255, %
IDE01540-MAS06914,Left front heated seat-Seat cushion heating: activation,0, %
IDE01540-MAS07048,Left front heated seat-Target temperature backrest,6503.00, °C
IDE01540-MAS07049,Left front heated seat-Target temperature seat cushion,6502.90, °C
IDE01540-MAS07050,Left front heated seat-Actual temperature backrest,6503.00, °C
IDE01540-MAS07051,Left front heated seat-Actual temperature seat cushion,20.70, °C
IDE01540-MAS07052,Left front heated seat-Setting,OFF,
IDE01540-MAS07071,Left front heated seat-Temperature sensor for seat cushion: resistance value,655.35, kOhm
IDE01540-MAS07072,Left front heated seat-Temperature sensor for backrest: resistance value,655.35, kOhm
IDE01540-MAS07921,Left front heated seat-Balance setting,Neutral,
IDE01540-MAS07929,Left front heated seat-Power quota setting by energy management,99.00, %
IDE01540-MAS07945,Left front heated seat-Spec temp: backrest with active overheating function,6503.00, °C
IDE01540-MAS07946,Left front heated seat-Spec temp: seat cushion with active overheating function,6503.00, °C
IDE01540-MAS07947,Left front heated seat-Backrest heater: status,not coded/not installed,
IDE01540-MAS07950,Left front heated seat-Seat cushion heater: status,not active,
IDE01540-MAS07951,Left front heated seat-Automatic down-shift,not active,
IDE01540-MAS07968,Left front heated seat-Temp sensor offset in chassis ground,55.54, V
IDE01540-MAS12630,Left front heated seat-Backrest heater: current draw (effective value),25.50, A
IDE01540-MAS12631,Left front heated seat-Seat cushion: current draw (effective value),0.00, A
IDE01541-MAS06913,Right front heated seat-Backrest heating: activation,255, %
IDE01541-MAS06914,Right front heated seat-Seat cushion heating: activation,0, %
IDE01541-MAS07048,Right front heated seat-Target temperature backrest,6503.00, °C
IDE01541-MAS07049,Right front heated seat-Target temperature seat cushion,6502.90, °C
IDE01541-MAS07050,Right front heated seat-Actual temperature backrest,6503.00, °C
IDE01541-MAS07051,Right front heated seat-Actual temperature seat cushion,19.20, °C
IDE01541-MAS07052,Right front heated seat-Setting,OFF,
IDE01541-MAS07071,Right front heated seat-Temperature sensor for seat cushion: resistance value,655.35, kOhm
IDE01541-MAS07072,Right front heated seat-Temperature sensor for backrest: resistance value,655.35, kOhm
IDE01541-MAS07921,Right front heated seat-Balance setting,Neutral,
IDE01541-MAS07929,Right front heated seat-Power quota setting by energy management,99.00, %
IDE01541-MAS07945,Right front heated seat-Spec temp: backrest with active overheating function,6503.00, °C
IDE01541-MAS07946,Right front heated seat-Spec temp: seat cushion with active overheating function,6503.00, °C
IDE01541-MAS07947,Right front heated seat-Backrest heater: status,not coded/not installed,
IDE01541-MAS07950,Right front heated seat-Seat cushion heater: status,not active,
IDE01541-MAS07951,Right front heated seat-Automatic down-shift,not coded/not installed,
IDE01541-MAS07968,Right front heated seat-Temp sensor offset in chassis ground,55.54, V
IDE01541-MAS12630,Right front heated seat-Backrest heater: current draw (effective value),25.50, A
IDE01541-MAS12631,Right front heated seat-Seat cushion: current draw (effective value),0.00, A
IDE01622,Fresh air blower: speed,1220, /min
IDE01694-MAS01767,Left rear seat heater-Left rear seat heater stage,0,
IDE01694-MAS01768,Left rear seat heater-Left rear seat heater specified temperature,0.0, °C
IDE01694-MAS01769,Left rear seat heater-Left rear seat heater actual temperature,0.0, °C
IDE01694-MAS01770,Left rear seat heater-Left rear seat heater current,0.00, A
IDE01695-MAS01771,Right rear seat heater-Right rear seat heater stage,0,
IDE01695-MAS01772,Right rear seat heater-Right rear seat heater specified temperature,0.0, °C
IDE01695-MAS01773,Right rear seat heater-Right rear seat heater actual temperature,0.0, °C
IDE01695-MAS01774,Right rear seat heater-Right rear seat heater current,0.00, A
IDE01708-MAS01632,Rear refrigerant shut-off valve-Status,closed,
IDE02270-IDE01268,CAN input signal(s) status-Windshield wiper,OFF,
IDE02270-IDE01457,CAN input signal(s) status-Energy management deactivation stage,Deactivation stage 0,
IDE02270-MAS01281,CAN input signal(s) status-Back-up lamp,OFF,
IDE02270-MAS01283,CAN input signal(s) status-Actual value of windshield heater,OFF,
IDE02744-IDE15944,Steering wheel heating-Energy management approval,Release,
IDE02744-IDE15945,Steering wheel heating-Heater parameter set,n/a,
IDE02744-MAS01632,Steering wheel heating-Status,switched off,
IDE02744-MAS02311,Steering wheel heating-Steering wheel heating button,Stage 1,
IDE02744-MAS02311,Steering wheel heating-Steering wheel heating button,operated,
IDE02744-MAS09022,Steering wheel heating-PWM value,0, %
IDE02744-MAS09758,Steering wheel heating-Temperature sensor,31, °C
IDE03488,Driving time remaining for basic setting of compressor run in,0, s
IDE03538-MAS01632,Ionizer: diagnosis-Status,No malfunction,
IDE03538-MAS02830,Ionizer: diagnosis-Ionizer button,not coded/not installed,
IDE03538-MAS02831,Ionizer: diagnosis-Ionizer check light,not coded/not installed,
IDE03538-MAS13074,Ionizer: diagnosis-Error validity status,not coded/not installed,
IDE04312-IDE04095,System run time-Engine running time,255, s
IDE04312-MAS00084,System run time-Terminal 15 on,255, s
IDE04805-IDE02955,Driving profile selection-System status,Available,
IDE04805-MAS01447,Driving profile selection-Act.val.,2,
IDE04805-MAS01448,Driving profile selection-Specified value,2,
IDE04805-MAS05058,Driving profile selection-Compatibility,No,
IDE05533,Heater for nozzles,OFF,
IDE05738-ENG124653,Subssystem diagnosis classes-DC0_systems,Yes,
IDE05738-ENG124652,Subssystem diagnosis classes-DC1_systems,Yes,
IDE05738-ENG124651,Subssystem diagnosis classes-DC2/DC2F_systems,Yes,
IDE05738-ENG124650,Subssystem diagnosis classes-DC3_systems,No,
IDE06091-IDE01440,Humidity sensor: interior-Front windshield temperature,39.50, °C
IDE06091-MAS04629,Humidity sensor: interior-Sensor temperature,39.50, °C
IDE06091-MAS04630,Humidity sensor: interior-Relative humidity,12.00, %
IDE06091-MAS04647,Humidity sensor: interior-Dew point,4.90, °C
IDE06163-MAS04628,Humidity sensor: exterior-Air temperature,62.10, °C
IDE06163-MAS04629,Humidity sensor: exterior-Sensor temperature,164.50, °C
IDE06163-MAS04630,Humidity sensor: exterior-Relative humidity,126.50, %
IDE06163-MAS04647,Humidity sensor: exterior-Dew point,62.10, °C
IDE06201,Blower reduction,Unknown (0)
IDE06545,Blower voltage for production routines,6.00, V
IDE06546,Interior specified temperature for production routines,22, °C
IDE06547,Air distribution for production routines,Air distribution top and footwell,
IDE06593,Air recirculation for production routines,Fresh air,
IDE06976,Right front air distribution flap motor: actual value,127.50,
IDE06976,Right front air distribution flap motor: actual value,65535,
IDE06977,Right front air distribution flap motor: spec. value,777,
IDE06979,Left front air distribution flap motor: actual value,93,
IDE06979,Left front air distribution flap motor: actual value,0.00,
IDE06980,Left front air distribution flap motor: spec. value,80,
IDE07133,Fresh air blower motor: temperature,24.00, °C
IDE07968,Air distribution flap motor: actual value,16464,
IDE07969,Air distribution flap motor: specified value,16464,
IDE07970,Air distribution flap motor: dynamic,16464,
IDE08372,Fresh air blower: target speed,1220, /min
IDE08442-MAS01580,Wiper storage and spray nozzle heater-Activation,OFF,
IDE08442-MAS07000,Wiper storage and spray nozzle heater-Switch-on current,0,
IDE08442-MAS12621,Wiper storage and spray nozzle heater-Current draw (effective value),0,
IDE08774-MAS01453,Fresh air blower: error status-Blocking detection,not active,
IDE08774-MAS01478,Fresh air blower: error status-insufficient voltage,not active,
IDE08774-MAS01479,Fresh air blower: error status-Excessive voltage,not active,
IDE08774-MAS01480,Fresh air blower: error status-excessive temperature,not active,
IDE08774-MAS01575,Fresh air blower: error status-Internal malfunction,not active,
IDE08774-MAS01807,Fresh air blower: error status-Short circuit,not active,
IDE08774-MAS07627,Fresh air blower: error status-Over current string,not active,
IDE08774-MAS07628,Fresh air blower: error status-Over current phase,not active,
IDE08774-MAS07629,Fresh air blower: error status-Error current offset,not active,
IDE08774-MAS07630,Fresh air blower: error status-error temperature sensor,not active,
IDE08774-MAS07631,Fresh air blower: error status-Error bridge driver,not active,
IDE08774-MAS07632,Fresh air blower: error status-Excess temp. bridge driver,not active,
IDE08961-MAS01554,Installation info: seat heater-Left heated seat,Parallel activation of backrest and seat cushion,
IDE08961-MAS01556,Installation info: seat heater-Right heated seat,Parallel activation of backrest and seat cushion,
IDE09168-MAS01632,Shut-off valve 1 for refrigerant-Status,Open,
IDE09203,HV heater shut-off condition,none,
IDE10300,OBD Driving Cycle detected,active,
IDE10942-MAS00788,Expansion valve 1 for refrigerant-LIN node- address,Shut-off valve 1 for refrigerant,
IDE10942-MAS01447,Expansion valve 1 for refrigerant-Act.val.,0, %
IDE10942-MAS01448,Expansion valve 1 for refrigerant-Specified value,0, %
IDE10942-MAS02201,Expansion valve 1 for refrigerant-Temperature,36, °C
IDE10942-MAS10469,Expansion valve 1 for refrigerant-Raw value,65534,
IDE10943-MAS00788,Expansion valve 2 for refrigerant-LIN node- address,not coded/not installed,
IDE10943-MAS01447,Expansion valve 2 for refrigerant-Act.val.,65533, %
IDE10943-MAS01448,Expansion valve 2 for refrigerant-Specified value,65533, %
IDE10943-MAS02201,Expansion valve 2 for refrigerant-Temperature,203, °C
IDE10943-MAS10469,Expansion valve 2 for refrigerant-Raw value,65533,
IDE10944-MAS00788,Expansion valve 3 for refrigerant-LIN node- address,not coded/not installed,
IDE10944-MAS01447,Expansion valve 3 for refrigerant-Act.val.,65533, %
IDE10944-MAS01448,Expansion valve 3 for refrigerant-Specified value,65533, %
IDE10944-MAS02201,Expansion valve 3 for refrigerant-Temperature,203, °C
IDE10944-MAS10469,Expansion valve 3 for refrigerant-Raw value,65533,
IDE10945-MAS00788,Shut-off valve 1 for refrigerant-LIN node- address,not coded/not installed,
IDE10945-MAS01447,Shut-off valve 1 for refrigerant-Act.val.,65533, %
IDE10945-MAS01448,Shut-off valve 1 for refrigerant-Specified value,65533, %
IDE10945-MAS02201,Shut-off valve 1 for refrigerant-Temperature,203, °C
IDE10945-MAS10469,Shut-off valve 1 for refrigerant-Raw value,65533,
IDE10946-MAS00788,Shut-off valve 2 for refrigerant-LIN node- address,not coded/not installed,
IDE10946-MAS01447,Shut-off valve 2 for refrigerant-Act.val.,65533, %
IDE10946-MAS01448,Shut-off valve 2 for refrigerant-Specified value,65533, %
IDE10946-MAS02201,Shut-off valve 2 for refrigerant-Temperature,203, °C
IDE10946-MAS10469,Shut-off valve 2 for refrigerant-Raw value,65533,
IDE10947-MAS00788,Shut-off valve 3 for refrigerant-LIN node- address,not coded/not installed,
IDE10947-MAS01447,Shut-off valve 3 for refrigerant-Act.val.,65533, %
IDE10947-MAS01448,Shut-off valve 3 for refrigerant-Specified value,65533, %
IDE10947-MAS02201,Shut-off valve 3 for refrigerant-Temperature,203, °C
IDE10947-MAS10469,Shut-off valve 3 for refrigerant-Raw value,65533,
IDE10948-MAS00788,Shut-off valve 4 for refrigerant-LIN node- address,not coded/not installed,
IDE10948-MAS01447,Shut-off valve 4 for refrigerant-Act.val.,65533, %
IDE10948-MAS01448,Shut-off valve 4 for refrigerant-Specified value,65533, %
IDE10948-MAS02201,Shut-off valve 4 for refrigerant-Temperature,203, °C
IDE10948-MAS10469,Shut-off valve 4 for refrigerant-Raw value,65533,
IDE10949-MAS00788,Shut-off valve 5 for refrigerant-LIN node- address,not coded/not installed,
IDE10949-MAS01447,Shut-off valve 5 for refrigerant-Act.val.,65533, %
IDE10949-MAS01448,Shut-off valve 5 for refrigerant-Specified value,65533, %
IDE10949-MAS02201,Shut-off valve 5 for refrigerant-Temperature,203, °C
IDE10949-MAS10469,Shut-off valve 5 for refrigerant-Raw value,65533,
IDE10951-IDE00198,A/C pressure/temperature sensor 1-Refrigerant pressure,4.4792, bar
IDE10951-MAS00073,A/C pressure/temperature sensor 1-Communication,OK,
IDE10951-MAS02832,A/C pressure/temperature sensor 1-Malfunction status,OK,
IDE10951-MAS07055,A/C pressure/temperature sensor 1-Response error,OK,
IDE10951-MAS09641,A/C pressure/temperature sensor 1-Inside temperature,19.50, °C
IDE10951-MAS10764,A/C pressure/temperature sensor 1-Test Result,Tested in current operating cycle,
IDE10951-MAS11295,A/C pressure/temperature sensor 1-Refrigerant temperature,11.70, °C
IDE10976-MAS02201,Coolant expansion valve 1: internal status-Temperature,36, °C
IDE10976-MAS02282,Coolant expansion valve 1: internal status-Position,0,
IDE10977-MAS02201,Coolant expansion valve 2: internal status-Temperature,129, °C
IDE10977-MAS02282,Coolant expansion valve 2: internal status-Position,65010,
IDE10978-MAS02201,Coolant expansion valve 3: internal status-Temperature,129, °C
IDE10978-MAS02282,Coolant expansion valve 3: internal status-Position,65010,
IDE10979-MAS02201,Coolant shut-off valve 1: internal status-Temperature,129, °C
IDE10979-MAS02282,Coolant shut-off valve 1: internal status-Position,65010,
IDE10980-MAS02201,Coolant shut-off valve 2: internal status-Temperature,129, °C
IDE10980-MAS02282,Coolant shut-off valve 2: internal status-Position,65010,
IDE10981-MAS02201,Coolant shut-off valve 3: internal status-Temperature,129, °C
IDE10981-MAS02282,Coolant shut-off valve 3: internal status-Position,65010,
IDE10982-MAS02201,Coolant shut-off valve 4: internal status-Temperature,129, °C
IDE10982-MAS02282,Coolant shut-off valve 4: internal status-Position,65010,
IDE10983-MAS02201,Coolant shut-off valve 5: internal status-Temperature,129, °C
IDE10983-MAS02282,Coolant shut-off valve 5: internal status-Position,65010,
IDE11430,Rear blower reduction,Unknown (0)
IDE11431,Rear blower status,active,
IDE11432,Temp. dwn. strm. of rear evaporator,6513.50, °C
IDE11455-MAS11114,Range consumption forecast-Time to transition from dynamic to steady-state operation,0, min
IDE11455-MAS11115,Range consumption forecast-Change in the prediction initiated by customer action,1,
IDE11455-MAS11116,Range consumption forecast-Dynamic power for heating/cooling,0.00, W
IDE11455-MAS11117,Range consumption forecast-Steady-state power for heating/cooling,370.00, W
IDE11455-MAS11118,Range consumption forecast-Consumption for heating and cooling of the components,0, Ws
IDE11455-MAS11119,Range consumption forecast-Overflow-bit component consumption,no overflow,
IDE11455-MAS11120,Range consumption forecast-Consumption for heating and cooling of the interior,5059, Ws
IDE11455-MAS13274,Range consumption forecast-Overflow-bit interior consumption,Overflow,
IDE11698-MAS09216,Instrument panel temperature sensor-Sun intensity,50.00, W/m²
IDE11698-MAS13115,Instrument panel temperature sensor-Sunlight sensor: voltage,655.35, V
IDE11698-MAS13116,Instrument panel temperature sensor-Temperature sensor 1: temperature,27.600, °C
IDE11698-MAS13117,Instrument panel temperature sensor-Temperature sensor 1: resistance value,655.35, kOhm
IDE11698-MAS13118,Instrument panel temperature sensor-Temperature sensor 2: temperature,4045.938, °C
IDE11698-MAS13119,Instrument panel temperature sensor-Temperature sensor 2: resistance value,655.35, kOhm
IDE11698-MAS13179,Instrument panel temperature sensor-Temperature sensor 3: temperature,4045.938, °C
IDE11698-MAS13180,Instrument panel temperature sensor-Temperature sensor 3: resistance value,655.35, kOhm
IDE11790,Carbon dioxide content in the interior,Malfunction,
IDE11791,Particulate matter content in air,65010, µg/m³
IDE11836,Query of the supported PIDs (0x01 - 0x20),135790593,
IDE11837,Query of the supported PIDs (0x21 - 0x40),1,
IDE11838,Query of the supported PIDs (0x41 - 0x60),0,
IDE11839,Query of the supported InfoTypes (0x01 - 0x20),0,
IDE12499-IDE08704,A/C compressor initial running in: start prevention-Load management,not active,
IDE12499-MAS01250,A/C compressor initial running in: start prevention-Malfunction on fresh air blower,not active,
IDE12499-MAS01493,A/C compressor initial running in: start prevention-Engine running,Yes,
IDE12499-MAS10030,A/C compressor initial running in: start prevention-Adapt. of run-in time: compressor initial operation: written,Yes,
IDE12499-MAS14625,A/C compressor initial running in: start prevention-High-voltage vehicle electrical system,not active,
IDE12499-MAS14626,A/C compressor initial running in: start prevention-High-voltage current limitations,not active,
IDE12499-MAS14891,A/C compressor initial running in: start prevention-Flaps not calibrated,not active,
IDE12500-IDE08704,A/C compressor initial running in: interruption conditions-Load management,not active,
IDE12500-MAS01250,A/C compressor initial running in: interruption conditions-Malfunction on fresh air blower,not active,
IDE12500-MAS01254,A/C compressor initial running in: interruption conditions-AC button off,not active,
IDE12500-MAS01256,A/C compressor initial running in: interruption conditions-Outside temperature too low,not active,
IDE12500-MAS01261,A/C compressor initial running in: interruption conditions-Evaporator temperature ice-up danger,not active,
IDE12500-MAS01263,A/C compressor initial running in: interruption conditions-Compressor activation: malfunction in activation path,not active,
IDE12500-MAS01264,A/C compressor initial running in: interruption conditions-Malfunction at refrigerant pressure sensor,not active,
IDE12500-MAS01265,A/C compressor initial running in: interruption conditions-Speed shut-off,not active,
IDE12500-MAS01504,A/C compressor initial running in: interruption conditions-Supply voltage too high,not active,
IDE12500-MAS01508,A/C compressor initial running in: interruption conditions-High pressure event,not active,
IDE12500-MAS01509,A/C compressor initial running in: interruption conditions-Low pressure event,not active,
IDE12500-MAS14625,A/C compressor initial running in: interruption conditions-High-voltage vehicle electrical system,not active,
IDE12500-MAS14626,A/C compressor initial running in: interruption conditions-High-voltage current limitations,not active,
IDE12500-MAS14892,A/C compressor initial running in: interruption conditions-Pressure test not successful,not active,
IDE12500-MAS14893,A/C compressor initial running in: interruption conditions-Fault on the evaporator temperature sensor,not active,
IDE13835-MAS17093,VKMS: relevant VIN number for last data supply-Status of vehicle identification number,valid,
IDE13835-MAS17094,VKMS: relevant VIN number for last data supply-Vehicle identification number output,WVG5WVEB2SH017765,
IDE13836-MAS17095,VKMS: adaption counter-Adaptation counter status,valid,
IDE13836-MAS17096,VKMS: adaption counter-Adaptation counter output,00 01,
IDE13837-MAS17097,VKMS: overview missing keys-Key status,valid,
IDE13837-MAS17099,VKMS: overview missing keys-Number of missing keys,0,
IDE13837-MAS17100,VKMS: overview missing keys-Missing key,00 00,
IDE13842-MAS17101,VKMS: retrieval of information list of the stored VKMS keys-VKMS key status,valid,
IDE13842-MAS17103,VKMS: retrieval of information list of the stored VKMS keys-VKMS type ID,00 01,
IDE13842-MAS17104,VKMS: retrieval of information list of the stored VKMS keys-VKMS type adaptation counter,00 01,
IDE13842-MAS18318,VKMS: retrieval of information list of the stored VKMS keys-Number of VKMS keys,3,
IDE13845,Production mode status,not active,
IDE14095,Wiper park position heater,not coded/not installed,
IDE14492-MAS18388,Secure Onboard Communication: verification failed-Failed verification status,valid,
IDE14492-MAS18389,Secure Onboard Communication: verification failed-Number of failed verifications,0,
IDE14492-MAS18390,Secure Onboard Communication: verification failed-Verification failed,00 00,
IDE14493-MAS18360,Secure Onboard Communication: signatures failed-failed signature creation,00 00,
IDE14493-MAS18391,Secure Onboard Communication: signatures failed-Failed signature creation status,valid,
IDE14493-MAS18392,Secure Onboard Communication: signatures failed-Number of failed signature creations,0,
IDE14494-MAS18361,Secure Onboard Communication: general information-Status of general information,valid,
IDE14494-MAS18362,Secure Onboard Communication: general information-ECU function,SOC participant (challenge response only),
IDE14494-MAS18367,Secure Onboard Communication: general information-Main function call period,5,
IDE14496-MAS18378,Secure Onboard Communication: Freshness Values information-Freshness status,valid,
IDE14496-MAS18379,Secure Onboard Communication: Freshness Values information-Number of Freshness IDs,2,
IDE14496-MAS18380,Secure Onboard Communication: Freshness Values information-SOC PDU ID to which this freshness information is assigned,00 28,
IDE14496-MAS18381,Secure Onboard Communication: Freshness Values information-Freshness Value query status,Freshness Value was not queried,
IDE14496-MAS18384,Secure Onboard Communication: Freshness Values information-SOC time of last successful verification,FF FF FF FF FF FF FF FF,
IDE14496-MAS18385,Secure Onboard Communication: Freshness Values information-Current value of message counter,255,
IDE14496-MAS18386,Secure Onboard Communication: Freshness Values information-Bitfield with used counter values,11111111 11111111 ,
IDE14497-MAS17099,Secure Onboard Communication: missing key-Number of missing keys,0,
IDE14497-MAS17100,Secure Onboard Communication: missing key-Missing key,00 00,
IDE14497-MAS18387,Secure Onboard Communication: missing key-Missing key status,valid,
IDE14804-MAS19258,A/C Compressor compatibility monitor-Activated numbers of error screen in climate control module,31,
IDE14804-MAS19259,A/C Compressor compatibility monitor-Number of A/C Compressor error display from last routine,31,
IDE14804-MAS19260,A/C Compressor compatibility monitor-Number of error display for A/C Compressor: actual value,31,
IDE14804-MAS19261,A/C Compressor compatibility monitor-Activated error display in climate control module: status,Qualified,
IDE14804-MAS19262,A/C Compressor compatibility monitor-Number of disrupted standard comparisons,0,
IDE15120-IDE01233,A/C Compressor EKK4 system monitor-Compressor motor current,0.00, A
IDE15120-IDE05237,A/C Compressor EKK4 system monitor-A/C compressor power consumption: actual value,65535, W
IDE15120-IDE05241,A/C Compressor EKK4 system monitor-A/C compressor release status,transmitted,
IDE15120-IDE06336,A/C Compressor EKK4 system monitor-A/C compressor: target speed,0, /min
IDE15120-IDE06337,A/C Compressor EKK4 system monitor-A/C compressor: actual speed,0, /min
IDE15120-MAS04770,A/C Compressor EKK4 system monitor-A/C compressor: function status,Air conditioner compressor off,
IDE15120-MAS05974,A/C Compressor EKK4 system monitor-A/C compressor error indicator,not active,
IDE15120-MAS05976,A/C Compressor EKK4 system monitor-A/C compressor: inverter temperature,20.00, °C
IDE15120-MAS05978,A/C Compressor EKK4 system monitor-High voltage supply voltage,410, V
IDE15120-MAS12658,A/C Compressor EKK4 system monitor-HV release,transmitted,
IDE16374-ENG378374,Seat Heating status: 2nd row passenger side-ClimateModes,Not available,
IDE16375-ENG378374,Seat Heating status: 3rd row passenger side-ClimateModes,Not available,
IDE16376-ENG378374,Seat Heating status: 2nd row driver side-ClimateModes,installed,
IDE16377-ENG378374,Seat Heating status: 3rd row driver side-ClimateModes,Not available,
IDE16609-MAS00073,A/C pressure/temperature sensor 1  R744-Communication,Unknown (210)
IDE16609-MAS01441,A/C pressure/temperature sensor 1  R744-Refrigerant pressure,320.10,
IDE16609-MAS02832,A/C pressure/temperature sensor 1  R744-Malfunction status,Unknown (210)
IDE16609-MAS07055,A/C pressure/temperature sensor 1  R744-Response error,Unknown (210)
IDE16609-MAS09641,A/C pressure/temperature sensor 1  R744-Inside temperature,3201.00, °C
IDE16609-MAS10764,A/C pressure/temperature sensor 1  R744-Test Result,Unknown (210)
IDE16609-MAS11295,A/C pressure/temperature sensor 1  R744-Refrigerant temperature,3201.00, °C
IDE16797,Pre-ventilation: total elapsed time of the function,16777215, s
IDE16798,Pre-ventilation: number of functions performed,65535,
IDE16799,Pre-ventilation: remaining time,65535,
IDE17034-MAS00073,A/C pressure/temperature sensor 2  R744-Communication,Unknown (210)
IDE17034-MAS01441,A/C pressure/temperature sensor 2  R744-Refrigerant pressure,320.10, bar
IDE17034-MAS02832,A/C pressure/temperature sensor 2  R744-Malfunction status,Unknown (210)
IDE17034-MAS07055,A/C pressure/temperature sensor 2  R744-Response error,Unknown (210)
IDE17034-MAS09641,A/C pressure/temperature sensor 2  R744-Inside temperature,3201.00, °C
IDE17034-MAS10764,A/C pressure/temperature sensor 2  R744-Test Result,Unknown (210)
IDE17034-MAS11295,A/C pressure/temperature sensor 2  R744-Refrigerant temperature,3201.00, °C
IDE17035-MAS00073,A/C pressure/temperature sensor 3  R744-Communication,Unknown (210)
IDE17035-MAS01441,A/C pressure/temperature sensor 3  R744-Refrigerant pressure,320.10, bar
IDE17035-MAS02832,A/C pressure/temperature sensor 3  R744-Malfunction status,Unknown (210)
IDE17035-MAS07055,A/C pressure/temperature sensor 3  R744-Response error,Unknown (210)
IDE17035-MAS09641,A/C pressure/temperature sensor 3  R744-Inside temperature,3201.00, °C
IDE17035-MAS10764,A/C pressure/temperature sensor 3  R744-Test Result,Unknown (210)
IDE17035-MAS11295,A/C pressure/temperature sensor 3  R744-Refrigerant temperature,3201.00, °C
IDE17036-MAS00073,A/C pressure/temperature sensor 4  R744-Communication,Unknown (210)
IDE17036-MAS01441,A/C pressure/temperature sensor 4  R744-Refrigerant pressure,320.10, bar
IDE17036-MAS02832,A/C pressure/temperature sensor 4  R744-Malfunction status,Unknown (210)
IDE17036-MAS07055,A/C pressure/temperature sensor 4  R744-Response error,Unknown (210)
IDE17036-MAS09641,A/C pressure/temperature sensor 4  R744-Inside temperature,3201.00, °C
IDE17036-MAS10764,A/C pressure/temperature sensor 4  R744-Test Result,Unknown (210)
IDE17036-MAS11295,A/C pressure/temperature sensor 4  R744-Refrigerant temperature,3201.00, °C
IDE17037-MAS00073,A/C pressure/temperature sensor 5  R744-Communication,Unknown (210)
IDE17037-MAS01441,A/C pressure/temperature sensor 5  R744-Refrigerant pressure,320.10, bar
IDE17037-MAS02832,A/C pressure/temperature sensor 5  R744-Malfunction status,Unknown (210)
IDE17037-MAS07055,A/C pressure/temperature sensor 5  R744-Response error,Unknown (210)
IDE17037-MAS09641,A/C pressure/temperature sensor 5  R744-Inside temperature,3201.00, °C
IDE17037-MAS10764,A/C pressure/temperature sensor 5  R744-Test Result,Unknown (210)
IDE17037-MAS11295,A/C pressure/temperature sensor 5  R744-Refrigerant temperature,3201.00, °C
IDE17038-MAS00073,A/C pressure/temperature sensor 6  R744-Communication,OK,
IDE17038-MAS01441,A/C pressure/temperature sensor 6  R744-Refrigerant pressure,320.10,
IDE17038-MAS02832,A/C pressure/temperature sensor 6  R744-Malfunction status,OK,
IDE17038-MAS07055,A/C pressure/temperature sensor 6  R744-Response error,OK,
IDE17038-MAS09641,A/C pressure/temperature sensor 6  R744-Inside temperature,-40.00, °C
IDE17038-MAS10764,A/C pressure/temperature sensor 6  R744-Test Result,Tested in current operating cycle,
IDE17038-MAS11295,A/C pressure/temperature sensor 6  R744-Refrigerant temperature,3201.00, °C
IDE18268-IDE18264,Humidity/temperature sensor for seat: left front-Seat cushion humidity,255, %
IDE18268-IDE18265,Humidity/temperature sensor for seat: left front-Seat cushion temperature,127.50, °C
IDE18268-IDE18266,Humidity/temperature sensor for seat: left front-Backrest humidity,255, %
IDE18268-IDE18267,Humidity/temperature sensor for seat: left front-Temperature seat backrest,77.00, °C
IDE18269-IDE18264,Humidity/temperature sensor for seat: right front-Seat cushion humidity,255, %
IDE18269-IDE18265,Humidity/temperature sensor for seat: right front-Seat cushion temperature,127.50, °C
IDE18269-IDE18266,Humidity/temperature sensor for seat: right front-Backrest humidity,255, %
IDE18269-IDE18267,Humidity/temperature sensor for seat: right front-Temperature seat backrest,127.50, °C
IDE18270-IDE18264,Humidity/temperature sensor for seat: left rear-Seat cushion humidity,255, %
IDE18270-IDE18265,Humidity/temperature sensor for seat: left rear-Seat cushion temperature,127.50, °C
IDE18270-IDE18266,Humidity/temperature sensor for seat: left rear-Backrest humidity,255, %
IDE18270-IDE18267,Humidity/temperature sensor for seat: left rear-Temperature seat backrest,127.50, °C
IDE18271-IDE18264,Humidity/temperature sensor for seat: right rear-Seat cushion humidity,255, %
IDE18271-IDE18265,Humidity/temperature sensor for seat: right rear-Seat cushion temperature,127.50, °C
IDE18271-IDE18266,Humidity/temperature sensor for seat: right rear-Backrest humidity,255, %
IDE18271-IDE18267,Humidity/temperature sensor for seat: right rear-Temperature seat backrest,127.50, °C
MAS00464-MAS00106,Standard - ambient data 1-Year,2025,
MAS00464-MAS00107,Standard - ambient data 1-Month,3,
MAS00464-MAS00108,Standard - ambient data 1-Day,25,
MAS00464-MAS00109,Standard - ambient data 1-Hours,16,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,21,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,3,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,2,
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,209, km
MAS11297-MAS01379,Standstilll A/C: customer setting-Operating time,0, min
MAS17268,Functions which can be activated: connection error counter,0,
MAS17521-IDE04332,Unlockable functions: activation status-Release code for a SWaP function,Available,
MAS17521-IDE05814,Unlockable functions: activation status-Individualization characteristic,invalid,
MAS17521-IDE06260,Unlockable functions: activation status-ID number,10 05 03 00,
MAS17521-MAS01340,Unlockable functions: activation status-Functions,Available,
MAS17521-MAS01903,Unlockable functions: activation status-Configuration,OK,
MAS17521-MAS02934,Unlockable functions: activation status-Preconditions met,Condition not met,
MAS17521-MAS05616,Unlockable functions: activation status-Cancellation,No,
MAS17521-MAS05617,Unlockable functions: activation status-Authentication,Condition met,
MAS17521-MAS17839,Unlockable functions: activation status-Number of functions which can be activated,5,
MAS17521-MAS17983,Unlockable functions: activation status-Last state,not active,
MAS18157-MAS18158,SFD activated status-Role of vehicle diagnostic to be protected,No activation active,
MAS18157-MAS18161,SFD activated status-Status of vehicle diagnostic to be protected,SFD individualization feature set,
MAS18157-MAS18164,SFD activated status-Duration of vehicle diagnostic to be protected,No activation active,
MAS18157-MAS18165,SFD activated status-Type of vehicle diagnostic to be protected,No activation active,
MAS20376-MAS01634,High-voltage air heater status: internal-Supply voltage,OK,
MAS20376-MAS02246,High-voltage air heater status: internal-Timeout,OK,
MAS20376-MAS03746,High-voltage air heater status: internal-Current: actual value,0.00, A
MAS20376-MAS05978,High-voltage air heater status: internal-High voltage supply voltage,418, V
MAS20376-MAS07055,High-voltage air heater status: internal-Response error,OK,
MAS20376-MAS09468,High-voltage air heater status: internal-Vehicle high voltage system,OK,
MAS20376-MAS09469,High-voltage air heater status: internal-HV heater: status,Power restriction due to software,
MAS20376-MAS10074,High-voltage air heater status: internal-Supply voltage: actual value,16.40, V
MAS20376-MAS21216,High-voltage air heater status: internal-Heater electronics and circuit board temperature (PCB),23, °C
MAS20376-MAS21217,High-voltage air heater status: internal-Heating circuit 1 status,OK,
MAS20376-MAS21218,High-voltage air heater status: internal-Heating circuit 2 status,OK,
MAS20376-MAS21219,High-voltage air heater status: internal-Heating circuit 3 status,Power reduction due to excessive temperature,
MAS20376-MAS21221,High-voltage air heater status: internal-Heating circuit 4 status,Power reduction due to excessive temperature,
MAS20376-MAS21222,High-voltage air heater status: internal-Current flow with heating circuit not activated,OK,
MAS20376-MAS21223,High-voltage air heater status: internal-Total current over long period of time too high,OK,
MAS20376-MAS21224,High-voltage air heater status: internal-Circuit board temperature: shut-off value,OK,
MAS20376-MAS21225,High-voltage air heater status: internal-Internal error (other),OK,
MAS20377-MAS08432,High-voltage air heater status: global-Requirement,active,
MAS20377-MAS21209,High-voltage air heater status: global-Specified value: left,0, %
MAS20377-MAS21210,High-voltage air heater status: global-Specified value: right,8, %
MAS20377-MAS21211,High-voltage air heater status: global-Center target value,0, %
MAS20377-MAS21212,High-voltage air heater status: global-Number of heat zones,2 zones,
MAS20377-MAS21213,High-voltage air heater status: global-Heating system used,Basic system,
MAS20396,SFD protection procedure,SFD access protection and SFD end-to-end protection,
MAS20802,Front right air distribution door- defrost end stop,100,
MAS20809,Front left air distribution door - defrost end stop,100,
MAS20817,Front right air distribution door - Mann end stop,926,
MAS20818,Front left air distribution door - Mann end stop,932,
MAS23045-MAS01634,High-voltage air heater 2 status: internal-Supply voltage,OK,
MAS23045-MAS02246,High-voltage air heater 2 status: internal-Timeout,OK,
MAS23045-MAS03746,High-voltage air heater 2 status: internal-Current: actual value,0.00, A
MAS23045-MAS05978,High-voltage air heater 2 status: internal-High voltage supply voltage,410, V
MAS23045-MAS07055,High-voltage air heater 2 status: internal-Response error,OK,
MAS23045-MAS09468,High-voltage air heater 2 status: internal-Vehicle high voltage system,OK,
MAS23045-MAS09469,High-voltage air heater 2 status: internal-HV heater: status,OK,
MAS23045-MAS10074,High-voltage air heater 2 status: internal-Supply voltage: actual value,16.60, V
MAS23045-MAS21216,High-voltage air heater 2 status: internal-Heater electronics and circuit board temperature (PCB),24,
MAS23045-MAS21217,High-voltage air heater 2 status: internal-Heating circuit 1 status,OK,
MAS23045-MAS21218,High-voltage air heater 2 status: internal-Heating circuit 2 status,OK,
MAS23045-MAS21219,High-voltage air heater 2 status: internal-Heating circuit 3 status,OK,
MAS23045-MAS21221,High-voltage air heater 2 status: internal-Heating circuit 4 status,OK,
MAS23045-MAS21222,High-voltage air heater 2 status: internal-Current flow with heating circuit not activated,OK,
MAS23045-MAS21223,High-voltage air heater 2 status: internal-Total current over long period of time too high,OK,
MAS23045-MAS21224,High-voltage air heater 2 status: internal-Circuit board temperature: shut-off value,OK,
MAS23045-MAS21225,High-voltage air heater 2 status: internal-Internal error (other),OK,
MAS23052-MAS08432,High-voltage air heater 2 status: global-Requirement,active,
MAS23052-MAS21209,High-voltage air heater 2 status: global-Specified value: left,0, %
MAS23052-MAS21210,High-voltage air heater 2 status: global-Specified value: right,0, %
MAS23052-MAS21211,High-voltage air heater 2 status: global-Center target value,0, %
MAS23052-MAS21212,High-voltage air heater 2 status: global-Number of heat zones,2 zones,
MAS23052-MAS21213,High-voltage air heater 2 status: global-Heating system used,Basic system,
MAS23053,Carbon dioxide concentration in the rear vehicle interior,Malfunction,
MAS24099-MAS02201,Coolant expansion valve 4: internal status-Temperature,129.00, °C
MAS24099-MAS02282,Coolant expansion valve 4: internal status-Position,65010,
SFT272229-MAS00788,Expansion valve 4 for refrigerant-LIN node- address,not coded/not installed,
SFT272229-MAS01447,Expansion valve 4 for refrigerant-Act.val.,65533, %
SFT272229-MAS01448,Expansion valve 4 for refrigerant-Specified value,65533, %
SFT272229-MAS02201,Expansion valve 4 for refrigerant-Temperature,203, °C
SFT272229-MAS10469,Expansion valve 4 for refrigerant-Raw value,65533,
ENG181012,FoD_slave_state,2,
ENG254718-IDE04332,Function_On_Demand_Unlock_ID_Status_Dev-Release code for a SWaP function,Available,
ENG254718-IDE05814,Function_On_Demand_Unlock_ID_Status_Dev-Individualization characteristic,invalid,
ENG254718-IDE06260,Function_On_Demand_Unlock_ID_Status_Dev-ID number,268763904,
ENG254718-MAS01340,Function_On_Demand_Unlock_ID_Status_Dev-Functions,Available,
ENG254718-MAS01903,Function_On_Demand_Unlock_ID_Status_Dev-Configuration,OK,
ENG254718-MAS02934,Function_On_Demand_Unlock_ID_Status_Dev-Preconditions met,Condition not met,
ENG254718-MAS05616,Function_On_Demand_Unlock_ID_Status_Dev-Cancellation,not_canceled,
ENG254718-MAS05617,Function_On_Demand_Unlock_ID_Status_Dev-Authentication,Condition met,
ENG254718-MAS17839,Function_On_Demand_Unlock_ID_Status_Dev-Number of functions which can be activated,5,
ENG254718-MAS17983,Function_On_Demand_Unlock_ID_Status_Dev-Last state,not active,
Elapsed Time: 00:36
blockmap-09-1EE-937-089-C_WVG5WVEB2SH017765-20250325-1221.CSV
;SW:1EE-937-089-C   HW:1EE-937-089-A ---  Cent. Elect.
;Component:SAM_H+        H08 0555, Coding:
;EV_SAMVW31x,006001,EV_SAMVW31x_006_VWE3.rod
;Tuesday,25,March,2025,12:21:40:58926
;VCDS Version: Release 25.3.0 (x64)  Data version: 20250311 DS365.0
;VCID: 42D6241E4401B3FAD92-8016-R SFD
Group,Description,Actual
IDE00001,Production mode,not active,
IDE00324-MAS20322,Programming preconditions-Number of programming requirements,4,
IDE00324,Programming preconditions,|Programming Precondition|Vehicle speed is not zero|Supply voltage too low|Sub data bus system in diagnosis|Active function not ended|,
IDE00356-IDE00355,Cruise Control System (CCS): switch position-Cruise Control System (CCS): status,not coded/not installed,
IDE00356-MAS00125,Cruise Control System (CCS): switch position-Cruise control system,not coded/not installed,
IDE00356-MAS00128,Cruise Control System (CCS): switch position-Distance Regulation,not coded/not installed,
IDE00356-MAS00320,Cruise Control System (CCS): switch position-Main switch,not coded/not installed,
IDE00356-MAS00323,Cruise Control System (CCS): switch position-Tap delay,not coded/not installed,
IDE00356-MAS00325,Cruise Control System (CCS): switch position-Set,not coded/not installed,
IDE00356-MAS00326,Cruise Control System (CCS): switch position-Resume,not coded/not installed,
IDE00356-MAS02321,Cruise Control System (CCS): switch position-Cancel,NOT-DEFINED,
IDE00356-MAS02343,Cruise Control System (CCS): switch position-Station coding,not coded/not installed,
IDE00356-MAS03758,Cruise Control System (CCS): switch position-Not assigned,not coded/not installed,
IDE00356-MAS05138,Cruise Control System (CCS): switch position-Operating part,not coded/not installed,
IDE00973,Outside temperature,20.5, °C
IDE01164-MAS10094,Parking aid button-Rear outside door handle sensor: frt. pass. side,not coded/not installed,
IDE02260-IDE00773,Supply voltage for door control module: rear: left-Terminal 15 status via CAN,active,
IDE02260-IDE01715,Supply voltage for door control module: rear: left-Status terminal S,active,
IDE02260-IDE05835,Supply voltage for door control module: rear: left-Supply voltage for central locking,14.70, V
IDE02261-IDE00773,Supply voltage for door control module: rear: frt.pass. side-Terminal 15 status via CAN,active,
IDE02261-IDE01715,Supply voltage for door control module: rear: frt.pass. side-Status terminal S,active,
IDE02261-IDE05835,Supply voltage for door control module: rear: frt.pass. side-Supply voltage for central locking,14.80, V
IDE02266,Passenger side rear power window button,Not operated,
IDE02711-IDE05228,Rear wiper-Operating hour counter,00 00 00 00 0E 00 00 00 48 45 52 5F 4D 59 4A 54 01 6E 46 57 49 53 43 48 45 52 5F 53 4C 30 32 00,
IDE02711-MAS01632,Rear wiper-Status,not active,
IDE02711-MAS20299,Rear wiper-Wiper level: steering column switch module,switched off,
IDE02711-MAS20300,Rear wiper-Actual wiper level,not active,
IDE02744-MAS01632,Steering wheel heating-Status,not coded/not installed,
IDE02744-MAS02311,Steering wheel heating-Steering wheel heating button,not coded/not installed,
IDE02744-MAS09758,Steering wheel heating-Temperature sensor,205, °C
IDE02857-IDE03111,Activation current-Interior lighting,0, mA
IDE02857-IDE06012,Activation current-Background lighting,0, mA
IDE02857-MAS01288,Activation current-Horn,No malfunction,
IDE02857-ENG128458,Activation current-DWA_Einfachhorn,Measuring value not available,
IDE04347-IDE00020,Expanded freeze frame conditions-Terminal 15 status,On,
IDE04347-IDE01716,Expanded freeze frame conditions-Terminal 50 status,OFF,
IDE04347-IDE05742,Expanded freeze frame conditions-Light switch position,automatic,
IDE04347-MAS01458,Expanded freeze frame conditions-Operating condition,Normal mode,
IDE04347-MAS01957,Expanded freeze frame conditions-Outside temperature,20.5, °C
IDE04347-MAS04121,Expanded freeze frame conditions-Voltage,14.8, V
IDE04347-MAS15304,Expanded freeze frame conditions-Status drive readiness,Drive readiness,
IDE04347-MAS19766,Expanded freeze frame conditions-Status of brake lamp switch: discrete,On,
IDE04347-MAS19768,Expanded freeze frame conditions-Brake lamp switch via CAN: status,On,
IDE04639,Last wake-up cause,Terminal 15 ignition switch signal 1,
IDE05045-IDE05183,Front wiper module-Malfunction left,No malfunction,
IDE05045-IDE05184,Front wiper module-Malfunction right,No malfunction,
IDE05045-MAS01364,Front wiper module-Stage 1,not active,
IDE05045-MAS01365,Front wiper module-Stage 2,not active,
IDE05045-MAS03638,Front wiper module-Wipe speed,0 revolutions per minute,
IDE05045-MAS05057,Front wiper module-Number of wiper cycles,100,
IDE05045-MAS05878,Front wiper module-Stage,not coded/not installed,
IDE05719-IDE05534,Window washer system-Headlamp washer system,not coded/not installed,
IDE05719-MAS02341,Window washer system-Rear window washer system,not active,
IDE05834-MAS00212,Driver info-Insufficient washer fluid,not active,
IDE05836-MAS03637,Rain recognition sensor-Rain quantity,0,
IDE05838-MAS02248,Light recognition sensor-Signal state,active,
IDE05838-MAS02475,Light recognition sensor-Brightness infrared,100400, lx
IDE05838-MAS02851,Light recognition sensor-Brightness,6126, lx
IDE05838-MAS04809,Light recognition sensor-Darkness,OFF,
IDE05838-MAS04810,Light recognition sensor-Request for light activation,OFF,
IDE06091-IDE01440,Humidity sensor: interior-Front windshield temperature,39.6, °C
IDE06091-MAS04629,Humidity sensor: interior-Sensor temperature,39.5, °C
IDE06091-MAS04630,Humidity sensor: interior-Relative humidity,12.0, %
IDE06091-MAS04647,Humidity sensor: interior-Dew point,5.0, °C
IDE06208-MAS01453,Rear window regulator status: driver side-Blocking detection,not active,
IDE06208-MAS02039,Rear window regulator status: driver side-Force limitation,not active,
IDE06208-MAS02097,Rear window regulator status: driver side-Window position,0.00, %
IDE06208-MAS02098,Rear window regulator status: driver side-Window regulator standardized,Yes,
IDE06208-MAS03548,Rear window regulator status: driver side-Motor current,0, A
IDE06208-MAS04642,Rear window regulator status: driver side-Before upper stop,not active,
IDE06208-MAS05370,Rear window regulator status: driver side-Direction of movement,Position top,
IDE06209-MAS01453,Rear window regulator status: frt.pass. side-Blocking detection,not active,
IDE06209-MAS02039,Rear window regulator status: frt.pass. side-Force limitation,not active,
IDE06209-MAS02097,Rear window regulator status: frt.pass. side-Window position,0.00, %
IDE06209-MAS02098,Rear window regulator status: frt.pass. side-Window regulator standardized,Yes,
IDE06209-MAS03548,Rear window regulator status: frt.pass. side-Motor current,0, A
IDE06209-MAS04642,Rear window regulator status: frt.pass. side-Before upper stop,not active,
IDE06209-MAS05370,Rear window regulator status: frt.pass. side-Direction of movement,Position top,
IDE06621,Driver side rear power window button,Not operated,
IDE06931-MAS01159,Ident. of rear window regulator programming: driver side-Version number,5722,
IDE06932-MAS01159,Ident. of rear window regulator programming: frt.pass. side-Version number,5722,
IDE06935,Rear window regulator relay: driver side,Open,
IDE06936,Rear window regulator relay: frt.pass. side,Open,
IDE06939-MAS02545,Rear window regulator reversing position: driver side-Last,7.50, %
IDE06939-MAS02546,Rear window regulator reversing position: driver side-Second to last,127.50, %
IDE06939-MAS02547,Rear window regulator reversing position: driver side-Third to last,127.50, %
IDE06939-MAS02548,Rear window regulator reversing position: driver side-Fourth to last,127.50, %
IDE06939-MAS05380,Rear window regulator reversing position: driver side-fifth to last,127.50, %
IDE06940,Rear window regulator child lock: driver side,not active,
IDE06941,Rear window regulator child lock: frt.pass. side,not active,
IDE07407-IDE03114,Enable driver-side rear window regulator-Comfort function,No,
IDE07407-MAS02447,Enable driver-side rear window regulator-Release,Yes,
IDE07408-IDE03114,Enable frt.pass.-side rear window regulator-Comfort function,No,
IDE07408-MAS02447,Enable frt.pass.-side rear window regulator-Release,Yes,
IDE07411-MAS01632,Excess.temp.disconnect: rear window regulator: driver side-Status,not active,
IDE07411-MAS02955,Excess.temp.disconnect: rear window regulator: driver side-Engine temperature,33, °C
IDE07412-MAS01632,Excess.temp.disconnect for rear window regulator: frt.pass.side-Status,not active,
IDE07412-MAS02955,Excess.temp.disconnect for rear window regulator: frt.pass.side-Engine temperature,29, °C
IDE07415,Comfort function for rear window regulator: driver side,not active,
IDE07416,Comfort function for rear window regulator: frt.pass. side,not active,
IDE07417-MAS02545,Rear window regulator reversing position: frt.pass. side-Last,127.50, %
IDE07417-MAS02546,Rear window regulator reversing position: frt.pass. side-Second to last,127.50, %
IDE07417-MAS02547,Rear window regulator reversing position: frt.pass. side-Third to last,127.50, %
IDE07417-MAS02548,Rear window regulator reversing position: frt.pass. side-Fourth to last,127.50, %
IDE07417-MAS05380,Rear window regulator reversing position: frt.pass. side-fifth to last,127.50, %
IDE08185,Counter for play protection of central locking,not active,
IDE08211-MAS03129,History data control module reset-Reset counter,5,
IDE08211,History data control module reset,|last cause of reset,Year
IDE08949-MAS07867,Operating current: light driver-Conn. pin 0,not coded/not installed,
IDE08949-MAS07868,Operating current: light driver-Conn. pin 1,not coded/not installed,
IDE08949-MAS07869,Operating current: light driver-Conn. pin 2,not coded/not installed,
IDE08949-MAS07870,Operating current: light driver-Conn. pin 3,not coded/not installed,
IDE08949-MAS07871,Operating current: light driver-Conn. pin 4,not coded/not installed,
IDE08949-MAS07872,Operating current: light driver-Conn. pin 5,not coded/not installed,
IDE08949-MAS07873,Operating current: light driver-Conn. pin 6,not coded/not installed,
IDE08949-MAS07874,Operating current: light driver-Conn. pin 7,not coded/not installed,
IDE08949-MAS07875,Operating current: light driver-Conn. pin 8,not coded/not installed,
IDE08949-MAS07876,Operating current: light driver-Conn. pin 9,not coded/not installed,
IDE08949-MAS07877,Operating current: light driver-Conn. pin 10,not coded/not installed,
IDE08949-MAS07878,Operating current: light driver-Conn. pin 11,not coded/not installed,
IDE08949-MAS07879,Operating current: light driver-Conn. pin 12,not coded/not installed,
IDE08949-MAS07880,Operating current: light driver-Conn. pin 13,not coded/not installed,
IDE08949-MAS07881,Operating current: light driver-Conn. pin 14,not coded/not installed,
IDE08949-MAS07882,Operating current: light driver-Conn. pin 15,not coded/not installed,
IDE08949-MAS07883,Operating current: light driver-Conn. pin 16,not coded/not installed,
IDE08949-MAS07884,Operating current: light driver-Conn. pin 17,not coded/not installed,
IDE08949-MAS07886,Operating current: light driver-Conn. pin 19,15, mA
IDE08949-MAS07887,Operating current: light driver-Conn. pin 20,135, mA
IDE08949-MAS07888,Operating current: light driver-Conn. pin 21,137, mA
IDE08949-MAS07889,Operating current: light driver-Conn. pin 22,232, mA
IDE08949-MAS07890,Operating current: light driver-Conn. pin 23,15, mA
IDE08949-MAS07891,Operating current: light driver-Conn. pin 24,0, mA
IDE08949-MAS07892,Operating current: light driver-Conn. pin 25,0, mA
IDE08949-MAS07894,Operating current: light driver-Conn. pin 27,not coded/not installed,
IDE08949-MAS07895,Operating current: light driver-Conn. pin 28,15, mA
IDE08949-MAS07897,Operating current: light driver-Conn. pin 30,0, mA
IDE08949-MAS07898,Operating current: light driver-Conn. pin 31,4, mA
IDE08949-MAS07899,Operating current: light driver-Conn. pin 32,4, mA
IDE08949-MAS07900,Operating current: light driver-Conn. pin 33,4, mA
IDE08949-MAS07901,Operating current: light driver-Conn. pin 34,4, mA
IDE08949-MAS20146,Operating current: light driver-Conn. pin 35,not coded/not installed,
IDE08949-MAS20147,Operating current: light driver-Conn. pin 36,not coded/not installed,
IDE08949-MAS20148,Operating current: light driver-Conn. pin 37,not coded/not installed,
IDE08949-MAS20149,Operating current: light driver-Conn. pin 38,not coded/not installed,
IDE08949-MAS20150,Operating current: light driver-Conn. pin 39,not coded/not installed,
IDE08949-MAS20151,Operating current: light driver-Conn. pin 40,30, mA
IDE08949-MAS20152,Operating current: light driver-Conn. pin 41,22, mA
IDE08949-MAS21233,Operating current: light driver-Conn. pin 42,not coded/not installed,
IDE08949-MAS21234,Operating current: light driver-Conn. pin 43,not coded/not installed,
IDE08949-MAS21235,Operating current: light driver-Conn. pin 45,0, mA
IDE08949-MAS21236,Operating current: light driver-Conn. pin 44,70, mA
IDE10300,OBD Driving Cycle detected,not active,
IDE10345-IDE00673,Roof electronics control module: button-Information Service Button -E450-,Not operated,
IDE10345-MAS08884,Roof electronics control module: button-Sunroof button,Not operated,
IDE10345-MAS08932,Roof electronics control module: button-Sunroof shade button,Not operated,
IDE10345-MAS10417,Roof electronics control module: button-Door contact switching button,Not operated,
IDE10345-MAS10426,Roof electronics control module: button-Roadside Assistance Button,Not operated,
IDE11350-MAS12597,Sunlight photo sensor-Sun intensity left,460, W/m²
IDE11350-MAS12598,Sunlight photo sensor-Sun intensity right,130, W/m²
IDE11551-MAS03619,Status of identification data query on LIN-Bus-complete,Yes,
IDE11551-MAS11095,Status of identification data query on LIN-Bus-cause:,Terminal 15 on,
IDE11551-MAS12667,Status of identification data query on LIN-Bus-Specified installation of sub-bus users,10,
IDE11551-MAS12668,Status of identification data query on LIN-Bus-Actual installation of sub-bus users,11,
IDE11551-ENG303032,Status of identification data query on LIN-Bus-complete_config_hash,Yes,
IDE11551-ENG303033,Status of identification data query on LIN-Bus-complete_programming_hash,Yes,
IDE11551-ENG303064,Status of identification data query on LIN-Bus-slave_hash_valid,Yes,
IDE12940-IDE01268,Lever functions of the steering column electronics-Windshield wiper,not coded/not installed,
IDE12940-IDE02335,Lever functions of the steering column electronics-Signal light switch position,not coded/not installed,
IDE12940-IDE02711,Lever functions of the steering column electronics-Rear wiper,not coded/not installed,
IDE12940-MAS00232,Lever functions of the steering column electronics-MFI button UP,not coded/not installed,
IDE12940-MAS00233,Lever functions of the steering column electronics-MFI button DOWN,not coded/not installed,
IDE12940-MAS00234,Lever functions of the steering column electronics-MFI button RESET / OK,not coded/not installed,
IDE12940-MAS00242,Lever functions of the steering column electronics-Driver assistance systems button,not coded/not installed,
IDE12940-MAS00243,Lever functions of the steering column electronics-Buttons for driver assistance systems: status,not coded/not installed,
IDE12940-MAS01288,Lever functions of the steering column electronics-Horn,not coded/not installed,
IDE12940-MAS02338,Lever functions of the steering column electronics-Windshield wiper: intermittent stage,not coded/not installed,
IDE12940-MAS02339,Lever functions of the steering column electronics-Windshield washer system,not coded/not installed,
IDE12940-MAS02341,Lever functions of the steering column electronics-Rear window washer system,not coded/not installed,
IDE12940,Lever functions of the steering column electronics,not coded/not installed,
IDE13750-IDE02572,Input signals: control of terminal-Starter button: status,not active,
IDE13750-IDE13954,Input signals: control of terminal-Starter button: status redundant,not active,
IDE13751-IDE00020,Output signals: control of terminal-Terminal 15 status,active,
IDE13751-ENG256402,Output signals: control of terminal-Status_Terminal_Startwunsch_BCM,not active,
IDE13842-MAS17103,VKMS: retrieval of information list of the stored VKMS keys-VKMS type ID,00 15,
IDE13842-MAS18318,VKMS: retrieval of information list of the stored VKMS keys-Number of VKMS keys,6,
IDE13956-MAS03679,Key position replication: input signals-Terminal 15 status,On,
IDE13956-MAS03679,Key position replication: input signals-Terminal 15 status,OFF,
IDE13956-MAS07719,Key position replication: input signals-Terminal 50 status,OFF,
IDE13956-ENG129036,Key position replication: input signals-To_block_terminal_upshift,not active,
IDE13956-ENG416689,Key position replication: input signals-To_block_terminal_upshift_by_ORU,not active,
IDE14238-MAS02282,Wiper arm position-Position,0.0, °
IDE14238-MAS19580,Wiper arm position-Alternating park position,Alternating park position 1,
IDE14328-MAS19447,Back flash safety version of software blocks-Versioning,01,
IDE14328,Back flash safety version of software blocks,|Rear flash protection: minimal version,Rear flash protection: current version|0002
IDE14495-MAS18369,Secure Onboard Communication: information about internal time-Internal SOC time status,valid,
IDE14495-MAS18370,Secure Onboard Communication: information about internal time-Validity of internal SOC time,Invalid status,
IDE14495-MAS18374,Secure Onboard Communication: information about internal time-Internal time,05 30 32 30 30 30 32 30,
IDE14495-MAS18375,Secure Onboard Communication: information about internal time-Jitter test status,Invalid status,
IDE14496-MAS18379,Secure Onboard Communication: Freshness Values information-Number of Freshness IDs,7,
IDE14496-MAS18380,Secure Onboard Communication: Freshness Values information-SOC PDU ID to which this freshness information is assigned,00 32,
IDE14958-SFT00002,Recognized actual fitting list: adapt-Transmission Electronics,not detected,
IDE14958-SFT00005,Recognized actual fitting list: adapt-Access/start authorization,not detected,
IDE14958-SFT00006,Recognized actual fitting list: adapt-Seat adjustment: passenger's side,not detected,
IDE14958-SFT00008,Recognized actual fitting list: adapt-Climate Control Module,detected,
IDE14958-SFT00023,Recognized actual fitting list: adapt-Instrument cluster,not detected,
IDE14958-SFT00025,Recognized actual fitting list: adapt-Data Bus OBD Interface,detected,
IDE14958-SFT00038,Recognized actual fitting list: adapt-Convertible top operation,not detected,
IDE14958-SFT00043,Recognized actual fitting list: adapt-Steering column lock,not detected,
IDE14958-SFT00054,Recognized actual fitting list: adapt-Seat adjustment: driver side,not detected,
IDE14958-SFT00061,Recognized actual fitting list: adapt-Special Function,not detected,
IDE14958-SFT00096,Recognized actual fitting list: adapt-Trip recorder,not detected,
IDE14958-SFT00105,Recognized actual fitting list: adapt-Trailer Function,not detected,
IDE14958-SFT00106,Recognized actual fitting list: adapt-Automatic door: rear driver side,detected,
IDE14958-SFT00109,Recognized actual fitting list: adapt-Rear lid electronics,not detected,
IDE14958-SFT00122,Recognized actual fitting list: adapt-Automatic door: rear passenger side,detected,
IDE14958-SFT00165,Recognized actual fitting list: adapt-Front sensor for drivers assistant systems,not detected,
IDE14958-SFT00202,Recognized actual fitting list: adapt-Sunroof control module,not detected,
IDE14958-SFT00214,Recognized actual fitting list: adapt-Light Control Left 2,not detected,
IDE14958-SFT00215,Recognized actual fitting list: adapt-Light Control Right 2,not detected,
IDE14958-SFT33031,Recognized actual fitting list: adapt-Antenna module,not detected,
IDE14958-SFT33054,Recognized actual fitting list: adapt-Burglary Protection Control Module FL,not detected,
IDE14958-SFT33055,Recognized actual fitting list: adapt-Burglary Protection Control Module FR,not detected,
IDE14958-SFT33056,Recognized actual fitting list: adapt-Burglary Protection Control Module RL,not detected,
IDE14958-SFT33057,Recognized actual fitting list: adapt-Burglary Protection Control Module RR,not detected,
IDE14958-SFT33058,Recognized actual fitting list: adapt-Burglary Protection Control Module interior,not detected,
IDE14958-SFT271890,Recognized actual fitting list: adapt-Driver door control module,not detected,
IDE14958-SFT271891,Recognized actual fitting list: adapt-Front passenger door control module,not detected,
IDE14958-SFT271948,Recognized actual fitting list: adapt-Rear Driver Side Door Control Module,not detected,
IDE14958-SFT271949,Recognized actual fitting list: adapt-Rear Passenger Door Control Module,not detected,
IDE14958-SFT272107,Recognized actual fitting list: adapt-Antenna for short-range communication,not detected,
IDE14958-SFT272139,Recognized actual fitting list: adapt-Antenna 2 for short-range communication,not detected,
IDE14993-MAS19447,Software composition list identification data-Versioning,01,
IDE14993-MAS20341,Software composition list identification data-Number of software composition,00 00,
IDE14993,Software composition list identification data,|Software Composition ID,System designation
IDE15364-MAS20454,Historical memory: coolant defect display-Frequency counter: absolute,6,
IDE15364,Historical memory: coolant defect display,|Frequency Counter,Odometer reading
IDE15417-MAS06904,Predictive brake pad wear indicator-Brake lining wear warning,not active,
IDE15417-MAS20562,Predictive brake pad wear indicator-Relative kilometer status,0, km
IDE15417-MAS20563,Predictive brake pad wear indicator-Remaining kilometers until warning light turns on,0, km
IDE15417-MAS20564,Predictive brake pad wear indicator-Kilometers since wear sensor was disconnected,0, km
IDE15417,Predictive brake pad wear indicator,not installed,
IDE17551-ENG298469,Rear driver's side sliding door status: second block-Sliding_Door_Inside_actuate_Button,Not operated,
IDE17551-ENG249501,Rear driver's side sliding door status: second block-Sliding_Door_Inside_Close_Release_Button,Not operated,
IDE17552-ENG298469,Rear passenger's side sliding door status: second block-Sliding_Door_Inside_actuate_Button,Not operated,
IDE17552-ENG249501,Rear passenger's side sliding door status: second block-Sliding_Door_Inside_Close_Release_Button,Not operated,
MAS00043-IDE00019,Terminal 30 power supply-Voltage terminal 30,14.90, V
MAS00043-IDE05835,Terminal 30 power supply-Supply voltage for central locking,14.80, V
MAS00043-IDE05967,Terminal 30 power supply-Voltage terminal 30 left,14.90, V
MAS00043-IDE05968,Terminal 30 power supply-Voltage terminal 30 right,14.90, V
MAS00043-IDE08734,Terminal 30 power supply-Supply voltage for anti-theft alarm system,5.00, V
MAS00464-MAS00110,Standard - ambient data 1-Minutes,22,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,7,
MAS12666-SFT271873,SubSystemNodeAddress of sub bus participant-Wiper motor control module,0x0001,
MAS12666-SFT271874,SubSystemNodeAddress of sub bus participant-Rain/Light Recognition Sensor,0x0002,
MAS12666-SFT271875,SubSystemNodeAddress of sub bus participant-Light switch,0x0003,
MAS12666-SFT271876,SubSystemNodeAddress of sub bus participant-Garage door opener control module,0x0004,
MAS12666-SFT271894,SubSystemNodeAddress of sub bus participant-Anti-theft alarm system sensor,0x0016,
MAS12666-SFT271896,SubSystemNodeAddress of sub bus participant-Alarm horn,0x0018,
MAS12666-SFT271909,SubSystemNodeAddress of sub bus participant-left tail lamp 1,0x0025,
MAS12666-SFT271910,SubSystemNodeAddress of sub bus participant-Roof electronics control module,0x0026,
MAS12666-SFT271947,SubSystemNodeAddress of sub bus participant-Humidity sensor: interior,0x004B,
MAS12666-SFT271948,SubSystemNodeAddress of sub bus participant-Rear Driver Side Door Control Module,0x004C,
MAS12666-SFT271949,SubSystemNodeAddress of sub bus participant-Rear Passenger Door Control Module,0x004D,
MAS12666-SFT271950,SubSystemNodeAddress of sub bus participant-Rear lid opener control module,0x004E,
MAS12666-SFT271966,SubSystemNodeAddress of sub bus participant-Left head area heater,0x005E,
MAS12666-SFT271967,SubSystemNodeAddress of sub bus participant-Right head area heater,0x005F,
MAS12666-SFT272009,SubSystemNodeAddress of sub bus participant-Steering Column Switch,0x0089,
MAS12666-SFT272014,SubSystemNodeAddress of sub bus participant-Control head for driving and comfort functions,0x008E,
MAS12666-SFT272057,SubSystemNodeAddress of sub bus participant-Valve block 1 in front seat driver side,0x00B9,
MAS12666-SFT272061,SubSystemNodeAddress of sub bus participant-Valve block 1 in front seat passenger side,0x00BD,
MAS12666-SFT272065,SubSystemNodeAddress of sub bus participant-Blower 1 for left front backrest,0x00C1,
MAS12666-SFT272067,SubSystemNodeAddress of sub bus participant-Blower 1 for left front seat cushion,0x00C3,
MAS12666-SFT272069,SubSystemNodeAddress of sub bus participant-Blower 1 for right front backrest,0x00C5,
MAS12666-SFT272071,SubSystemNodeAddress of sub bus participant-Blower 1 for right front seat cushion,0x00C7,
MAS12666-SFT272107,SubSystemNodeAddress of sub bus participant-Antenna for short-range communication,0x00EB,
MAS12666-SFT272121,SubSystemNodeAddress of sub bus participant-Control unit 2 for driving and convenience functions,0x00F9,
MAS12666-SFT272139,SubSystemNodeAddress of sub bus participant-Antenna 2 for short-range communication,0x010B,
MAS12666-SFT272142,SubSystemNodeAddress of sub bus participant-left tail lamp 2,0x010E,
MAS12666-SFT272143,SubSystemNodeAddress of sub bus participant-Right rear tail lamp 1,0x010F,
MAS12666-SFT272144,SubSystemNodeAddress of sub bus participant-Right rear tail lamp 2,0x0110,
MAS12666-SFT272221,SubSystemNodeAddress of sub bus participant-Radio receiver for remote start,0x015D,
MAS12666-SFT272238,SubSystemNodeAddress of sub bus participant-Wiper motor control unit 2,0x016E,
MAS12666-SFT272272,SubSystemNodeAddress of sub bus participant-Virtual pedal door opening: rear driver side,0x0190,
MAS12666-SFT272286,SubSystemNodeAddress of sub bus participant-Virtual pedal door opening: rear passenger side,0x019E,
MAS12667-SFT271873,Specified installation of sub-bus users-Wiper motor control module,Available,
MAS12667-SFT271874,Specified installation of sub-bus users-Rain/Light Recognition Sensor,Available,
MAS12667-SFT271875,Specified installation of sub-bus users-Light switch,Available,
MAS12667-SFT271876,Specified installation of sub-bus users-Garage door opener control module,Not available,
MAS12667-SFT271894,Specified installation of sub-bus users-Anti-theft alarm system sensor,Not available,
MAS12667-SFT271896,Specified installation of sub-bus users-Alarm horn,Not available,
MAS12667-SFT271909,Specified installation of sub-bus users-left tail lamp 1,Not available,
MAS12667-SFT271910,Specified installation of sub-bus users-Roof electronics control module,Available,
MAS12667-SFT271947,Specified installation of sub-bus users-Humidity sensor: interior,Not available,
MAS12667-SFT271948,Specified installation of sub-bus users-Rear Driver Side Door Control Module,Available,
MAS12667-SFT271949,Specified installation of sub-bus users-Rear Passenger Door Control Module,Available,
MAS12667-SFT271950,Specified installation of sub-bus users-Rear lid opener control module,Not available,
MAS12667-SFT271966,Specified installation of sub-bus users-Left head area heater,Not available,
MAS12667-SFT271967,Specified installation of sub-bus users-Right head area heater,Not available,
MAS12667-SFT272009,Specified installation of sub-bus users-Steering Column Switch,Not available,
MAS12667-SFT272014,Specified installation of sub-bus users-Control head for driving and comfort functions,Available,
MAS12667-SFT272057,Specified installation of sub-bus users-Valve block 1 in front seat driver side,Available,
MAS12667-SFT272061,Specified installation of sub-bus users-Valve block 1 in front seat passenger side,Available,
MAS12667-SFT272065,Specified installation of sub-bus users-Blower 1 for left front backrest,Not available,
MAS12667-SFT272067,Specified installation of sub-bus users-Blower 1 for left front seat cushion,Not available,
MAS12667-SFT272069,Specified installation of sub-bus users-Blower 1 for right front backrest,Not available,
MAS12667-SFT272071,Specified installation of sub-bus users-Blower 1 for right front seat cushion,Not available,
MAS12667-SFT272107,Specified installation of sub-bus users-Antenna for short-range communication,Not available,
MAS12667-SFT272121,Specified installation of sub-bus users-Control unit 2 for driving and convenience functions,Not available,
MAS12667-SFT272139,Specified installation of sub-bus users-Antenna 2 for short-range communication,Not available,
MAS12667-SFT272142,Specified installation of sub-bus users-left tail lamp 2,Not available,
MAS12667-SFT272143,Specified installation of sub-bus users-Right rear tail lamp 1,Not available,
MAS12667-SFT272144,Specified installation of sub-bus users-Right rear tail lamp 2,Not available,
MAS12667-SFT272221,Specified installation of sub-bus users-Radio receiver for remote start,Not available,
MAS12667-SFT272238,Specified installation of sub-bus users-Wiper motor control unit 2,Available,
MAS12667-SFT272272,Specified installation of sub-bus users-Virtual pedal door opening: rear driver side,Not available,
MAS12667-SFT272286,Specified installation of sub-bus users-Virtual pedal door opening: rear passenger side,Not available,
MAS12668-SFT271873,Actual installation of sub-bus users-Wiper motor control module,Available,
MAS12668-SFT271874,Actual installation of sub-bus users-Rain/Light Recognition Sensor,Available,
MAS12668-SFT271875,Actual installation of sub-bus users-Light switch,Available,
MAS12668-SFT271876,Actual installation of sub-bus users-Garage door opener control module,Not available,
MAS12668-SFT271894,Actual installation of sub-bus users-Anti-theft alarm system sensor,Not available,
MAS12668-SFT271896,Actual installation of sub-bus users-Alarm horn,Not available,
MAS12668-SFT271909,Actual installation of sub-bus users-left tail lamp 1,Not available,
MAS12668-SFT271910,Actual installation of sub-bus users-Roof electronics control module,Available,
MAS12668-SFT271947,Actual installation of sub-bus users-Humidity sensor: interior,Available,
MAS12668-SFT271948,Actual installation of sub-bus users-Rear Driver Side Door Control Module,Available,
MAS12668-SFT271949,Actual installation of sub-bus users-Rear Passenger Door Control Module,Available,
MAS12668-SFT271950,Actual installation of sub-bus users-Rear lid opener control module,Not available,
MAS12668-SFT271966,Actual installation of sub-bus users-Left head area heater,Not available,
MAS12668-SFT271967,Actual installation of sub-bus users-Right head area heater,Not available,
MAS12668-SFT272009,Actual installation of sub-bus users-Steering Column Switch,Not available,
MAS12668-SFT272014,Actual installation of sub-bus users-Control head for driving and comfort functions,Available,
MAS12668-SFT272057,Actual installation of sub-bus users-Valve block 1 in front seat driver side,Available,
MAS12668-SFT272061,Actual installation of sub-bus users-Valve block 1 in front seat passenger side,Available,
MAS12668-SFT272065,Actual installation of sub-bus users-Blower 1 for left front backrest,Not available,
MAS12668-SFT272067,Actual installation of sub-bus users-Blower 1 for left front seat cushion,Not available,
MAS12668-SFT272069,Actual installation of sub-bus users-Blower 1 for right front backrest,Not available,
MAS12668-SFT272071,Actual installation of sub-bus users-Blower 1 for right front seat cushion,Not available,
MAS12668-SFT272107,Actual installation of sub-bus users-Antenna for short-range communication,Not available,
MAS12668-SFT272121,Actual installation of sub-bus users-Control unit 2 for driving and convenience functions,Not available,
MAS12668-SFT272139,Actual installation of sub-bus users-Antenna 2 for short-range communication,Not available,
MAS12668-SFT272142,Actual installation of sub-bus users-left tail lamp 2,Not available,
MAS12668-SFT272143,Actual installation of sub-bus users-Right rear tail lamp 1,Not available,
MAS12668-SFT272144,Actual installation of sub-bus users-Right rear tail lamp 2,Not available,
MAS12668-SFT272221,Actual installation of sub-bus users-Radio receiver for remote start,Not available,
MAS12668-SFT272238,Actual installation of sub-bus users-Wiper motor control unit 2,Available,
MAS12668-SFT272272,Actual installation of sub-bus users-Virtual pedal door opening: rear driver side,Not available,
MAS12668-SFT272286,Actual installation of sub-bus users-Virtual pedal door opening: rear passenger side,Not available,
MAS12669-SFT271873,Bus identification of sub-bus users-Wiper motor control module,Local data bus,
MAS12669-SFT271874,Bus identification of sub-bus users-Rain/Light Recognition Sensor,Local data bus,
MAS12669-SFT271875,Bus identification of sub-bus users-Light switch,Local data bus 11,
MAS12669-SFT271876,Bus identification of sub-bus users-Garage door opener control module,Local data bus 4,
MAS12669-SFT271894,Bus identification of sub-bus users-Anti-theft alarm system sensor,Local data bus 3,
MAS12669-SFT271896,Bus identification of sub-bus users-Alarm horn,Local data bus 2,
MAS12669-SFT271909,Bus identification of sub-bus users-left tail lamp 1,Local data bus 8,
MAS12669-SFT271910,Bus identification of sub-bus users-Roof electronics control module,Local data bus 3,
MAS12669-SFT271947,Bus identification of sub-bus users-Humidity sensor: interior,Local data bus,
MAS12669-SFT271948,Bus identification of sub-bus users-Rear Driver Side Door Control Module,Local data bus 12,
MAS12669-SFT271949,Bus identification of sub-bus users-Rear Passenger Door Control Module,Local data bus 12,
MAS12669-SFT271950,Bus identification of sub-bus users-Rear lid opener control module,Local data bus 8,
MAS12669-SFT271966,Bus identification of sub-bus users-Left head area heater,Local data bus 4,
MAS12669-SFT271967,Bus identification of sub-bus users-Right head area heater,Local data bus 4,
MAS12669-SFT272009,Bus identification of sub-bus users-Steering Column Switch,Local data bus 6,
MAS12669-SFT272014,Bus identification of sub-bus users-Control head for driving and comfort functions,Local data bus 11,
MAS12669-SFT272057,Bus identification of sub-bus users-Valve block 1 in front seat driver side,Local data bus 4,
MAS12669-SFT272061,Bus identification of sub-bus users-Valve block 1 in front seat passenger side,Local data bus 4,
MAS12669-SFT272065,Bus identification of sub-bus users-Blower 1 for left front backrest,Local data bus 4,
MAS12669-SFT272067,Bus identification of sub-bus users-Blower 1 for left front seat cushion,Local data bus 4,
MAS12669-SFT272069,Bus identification of sub-bus users-Blower 1 for right front backrest,Local data bus 4,
MAS12669-SFT272071,Bus identification of sub-bus users-Blower 1 for right front seat cushion,Local data bus 4,
MAS12669-SFT272107,Bus identification of sub-bus users-Antenna for short-range communication,Data bus subCAN 1,
MAS12669-SFT272121,Bus identification of sub-bus users-Control unit 2 for driving and convenience functions,Local data bus 11,
MAS12669-SFT272139,Bus identification of sub-bus users-Antenna 2 for short-range communication,Data bus subCAN 1,
MAS12669-SFT272142,Bus identification of sub-bus users-left tail lamp 2,Local data bus 8,
MAS12669-SFT272143,Bus identification of sub-bus users-Right rear tail lamp 1,Local data bus 8,
MAS12669-SFT272144,Bus identification of sub-bus users-Right rear tail lamp 2,Local data bus 8,
MAS12669-SFT272221,Bus identification of sub-bus users-Radio receiver for remote start,Local data bus 6,
MAS12669-SFT272238,Bus identification of sub-bus users-Wiper motor control unit 2,Local data bus,
MAS12669-SFT272272,Bus identification of sub-bus users-Virtual pedal door opening: rear driver side,Local data bus 4,
MAS12669-SFT272286,Bus identification of sub-bus users-Virtual pedal door opening: rear passenger side,Local data bus 4,
MAS13141,Test voltage,0.00, V
MAS17521-IDE06260,Unlockable functions: activation status-ID number,10 02 0E 00,
MAS17521-MAS17839,Unlockable functions: activation status-Number of functions which can be activated,3,
MAS18919-MAS17454,Engine hood contacts-Engine hood contact 2,active,
MAS18919-MAS18918,Engine hood contacts-Engine hood contact 1,not active,
MAS25022,Anti-play: electronic child safety lock: counter status,not active,
MAS26259-ENG370528,Charging socket flap contact switch-Charging_flap_switch,closed,
ENG277599-IDE01651,ASIL_relevante_RDIDs-Status of adaptation,Adaptations have been changed,
ENG277599-IDE05319,ASIL_relevante_RDIDs-Adapted values/adaptation,5008,
ENG277599-MAS18508,ASIL_relevante_RDIDs-Number of nodes,7,
ENG277599-ENG352898,ASIL_relevante_RDIDs-RDID_2,2674,
ENG277599-ENG354790,ASIL_relevante_RDIDs-RDID_3,4579,
ENG277599-ENG356716,ASIL_relevante_RDIDs-RDID_4,4581,
ENG277599-ENG353343,ASIL_relevante_RDIDs-RDID_5,4157,
ENG277599-ENG354949,ASIL_relevante_RDIDs-RDID_6,4609,
ENG277599-ENG356274,ASIL_relevante_RDIDs-Status_3,Adaptations have been changed,
ENG277599-ENG352650,ASIL_relevante_RDIDs-Status_RDID_2,Adaptations have been changed,
ENG277599-ENG354936,ASIL_relevante_RDIDs-Status_RDID_4,Adaptations have been changed,
ENG277599-ENG355882,ASIL_relevante_RDIDs-Status_RDID_5,Adaptations have been changed,
ENG277599-ENG352419,ASIL_relevante_RDIDs-Status_RDID_6,Adaptations have been changed,
ENG117285-ENG115840,Cycle_Protection_Counter-general_cycle_protection_counter,1,
ENG117285-ENG124947,Cycle_Protection_Counter-last_wake_up,Pin A44 Klemme 15,
ENG281289-MAS06423,Dataset_download__rdids_changed_by_adaption-Data set ID,Write only channel,
ENG281289-ENG354946,Dataset_download__rdids_changed_by_adaption-dataset_id_10,Write only channel,
ENG281289-ENG355903,Dataset_download__rdids_changed_by_adaption-dataset_id_2,Write only channel,
ENG281289-ENG355486,Dataset_download__rdids_changed_by_adaption-dataset_id_3,Write only channel,
ENG281289-ENG355877,Dataset_download__rdids_changed_by_adaption-dataset_id_4,Write only channel,
ENG281289-ENG354005,Dataset_download__rdids_changed_by_adaption-dataset_id_5,Write only channel,
ENG281289-ENG354629,Dataset_download__rdids_changed_by_adaption-dataset_id_6,Write only channel,
ENG281289-ENG354338,Dataset_download__rdids_changed_by_adaption-dataset_id_7,Write only channel,
ENG281289-ENG351859,Dataset_download__rdids_changed_by_adaption-dataset_id_8,Write only channel,
ENG281289-ENG356970,Dataset_download__rdids_changed_by_adaption-dataset_id_9,Write only channel,
ENG116908-ENG115775,Ecu_Intern_Meas._Values_2-Hours_of_operation_front_window_wiper,0.0000, H
ENG116908-ENG115776,Ecu_Intern_Meas._Values_2-Number of_the_wisp_cycles_front_window_wiper,100,
ENG116908-ENG115777,Ecu_Intern_Meas._Values_2-Number of_the_wisp_cycles_rear_window_wiper,0,
ENG116813,Entwicklermesswerte_CONTI,|KurzSchlussZaehler|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|,
ENG179581-ENG181012,FoD_slave_operating_state-FoD_slave_state,02,
ENG179902-IDE06260,Function_On_Demand_Freischalt_ID_Status_Dev-ID number,10 02 0E 00,
ENG179902-MAS17839,Function_On_Demand_Freischalt_ID_Status_Dev-Number of functions which can be activated,3,
ENG179902-MAS17983,Function_On_Demand_Freischalt_ID_Status_Dev-Last state,not_active,
ENG179902,Function_On_Demand_Freischalt_ID_Status_Dev,|Authentication,Functions
ENG406183-ENG406311,Kampagnen_ergebnisse_G1_ECU_Data_Summary-ORUGuard1_G1_Summary_AAG,01,
ENG406183-ENG406312,Kampagnen_ergebnisse_G1_ECU_Data_Summary-ORUGuard1_G1_Summary_ACC,00,
ENG406183-ENG406313,Kampagnen_ergebnisse_G1_ECU_Data_Summary-ORUGuard1_G1_Summary_Airbag,00,
ENG406183-ENG406314,Kampagnen_ergebnisse_G1_ECU_Data_Summary-ORUGuard1_G1_Summary_ASG,00,
ENG406183-ENG406315,Kampagnen_ergebnisse_G1_ECU_Data_Summary-ORUGuard1_G1_Summary_BMCE,00,
ENG406183-ENG406316,Kampagnen_ergebnisse_G1_ECU_Data_Summary-ORUGuard1_G1_Summary_DCDC,00,
ENG406183-ENG406317,Kampagnen_ergebnisse_G1_ECU_Data_Summary-ORUGuard1_G1_Summary_EBKV,00,
ENG406183-ENG406318,Kampagnen_ergebnisse_G1_ECU_Data_Summary-ORUGuard1_G1_Summary_ESC,00,
ENG406183-ENG406319,Kampagnen_ergebnisse_G1_ECU_Data_Summary-ORUGuard1_G1_Summary_Gateway,00,
ENG406183-ENG406320,Kampagnen_ergebnisse_G1_ECU_Data_Summary-ORUGuard1_G1_Summary_HUD,00,
ENG406183-ENG406321,Kampagnen_ergebnisse_G1_ECU_Data_Summary-ORUGuard1_G1_Summary_IID_FID,00,
ENG406183-ENG406322,Kampagnen_ergebnisse_G1_ECU_Data_Summary-ORUGuard1_G1_Summary_iSMLS,00,
ENG406183-ENG406323,Kampagnen_ergebnisse_G1_ECU_Data_Summary-ORUGuard1_G1_Summary_KFG,00,
ENG406183-ENG406324,Kampagnen_ergebnisse_G1_ECU_Data_Summary-ORUGuard1_G1_Summary_LE1,00,
ENG406183-ENG406325,Kampagnen_ergebnisse_G1_ECU_Data_Summary-ORUGuard1_G1_Summary_LE2,00,
ENG406183-ENG406326,Kampagnen_ergebnisse_G1_ECU_Data_Summary-ORUGuard1_G1_Summary_LED_LM_L,01,
ENG406183-ENG406327,Kampagnen_ergebnisse_G1_ECU_Data_Summary-ORUGuard1_G1_Summary_LED_LM_R,01,
ENG406183-ENG406328,Kampagnen_ergebnisse_G1_ECU_Data_Summary-ORUGuard1_G1_Summary_Lenkung,01,
ENG406183-ENG406329,Kampagnen_ergebnisse_G1_ECU_Data_Summary-ORUGuard1_G1_Summary_MFK,00,
ENG406183-ENG406330,Kampagnen_ergebnisse_G1_ECU_Data_Summary-ORUGuard1_G1_Summary_MFL,00,
ENG406183-ENG406331,Kampagnen_ergebnisse_G1_ECU_Data_Summary-ORUGuard1_G1_Summary_OCC_OCDC,00,
ENG406183-ENG406332,Kampagnen_ergebnisse_G1_ECU_Data_Summary-ORUGuard1_G1_Summary_PDC,00,
ENG406183-ENG406333,Kampagnen_ergebnisse_G1_ECU_Data_Summary-ORUGuard1_G1_Summary_SAM,07,
ENG406183-ENG406334,Kampagnen_ergebnisse_G1_ECU_Data_Summary-ORUGuard1_G1_Summary_Sitz_FS,01,
ENG406183-ENG406335,Kampagnen_ergebnisse_G1_ECU_Data_Summary-ORUGuard1_G1_Summary_Sitz_HBFS,01,
ENG406183-ENG406336,Kampagnen_ergebnisse_G1_ECU_Data_Summary-ORUGuard1_G1_Summary_Sitz_HFS,01,
ENG406183-ENG406337,Kampagnen_ergebnisse_G1_ECU_Data_Summary-ORUGuard1_G1_Summary_SitzBFS,01,
ENG406183-ENG406338,Kampagnen_ergebnisse_G1_ECU_Data_Summary-ORUGuard1_G1_Summary_STSG_HBFS,00,
ENG406183-ENG406339,Kampagnen_ergebnisse_G1_ECU_Data_Summary-ORUGuard1_G1_Summary_STSG_HFS,00,
ENG406183-ENG406340,Kampagnen_ergebnisse_G1_ECU_Data_Summary-ORUGuard1_G1_Summary_TsgBFS,00,
ENG406183-ENG406341,Kampagnen_ergebnisse_G1_ECU_Data_Summary-ORUGuard1_G1_Summary_TsgFS,00,
ENG406183-ENG406342,Kampagnen_ergebnisse_G1_ECU_Data_Summary-ORUGuard1_G1_Summary_TsgHBFS,00,
ENG406183-ENG406343,Kampagnen_ergebnisse_G1_ECU_Data_Summary-ORUGuard1_G1_Summary_TsgHFS,00,
ENG310456-IDE10283,key_fob-Key identification: transponder ID,E8 1C 9B B1,
ENG310456-ENG331600,key_fob-key_fob_battery_level,2.80, V
ENG310456-ENG331607,key_fob-key_fob_button,no_UHF_message,
ENG310456-ENG331605,key_fob-key_fob_error_state,no_UHF_message,
ENG310456-ENG331606,key_fob-key_fob_number,Key_fob_1,
ENG310456-ENG331603,key_fob-LF_range_limitation,Unknown (13)
ENG310456-ENG331601,key_fob-number_of_adapted_key_fobs,2,
ENG310456-ENG331602,key_fob-rolling_code_synchronisation,no_UHF_message,
ENG116909-ENG107391,LIN activity-LIN 1,Communication,
ENG116909-ENG256023,LIN activity-LIN 10,Communication,
ENG116909-ENG256024,LIN activity-LIN 11,Communication,
ENG116909-ENG256025,LIN activity-LIN 12,Communication,
ENG116909-ENG256026,LIN activity-LIN 13,not coded/not installed,
ENG116909-ENG256027,LIN activity-LIN 14,not coded/not installed,
ENG116909-ENG107392,LIN activity-LIN 2,not coded/not installed,
ENG116909-ENG114948,LIN activity-LIN 3,Communication,
ENG116909-ENG114949,LIN activity-LIN 4,Communication,
ENG116909-ENG114950,LIN activity-LIN 5,Communication,
ENG116909-ENG114951,LIN activity-LIN 6,Bus sleep mode,
ENG116909-ENG256030,LIN activity-LIN 7,not coded/not installed,
ENG116909-ENG256031,LIN activity-LIN 8,not coded/not installed,
ENG116909-ENG256032,LIN activity-LIN 9,Communication,
ENG122922-ENG121684,misc_wiper_values_1-wiper_counter_block,0,
ENG122922-ENG121680,misc_wiper_values_1-wiper_counter_cycles,100,
ENG122922-ENG121681,misc_wiper_values_1-wiper_counter_operating_h,26.5053, H
ENG122922-ENG121682,misc_wiper_values_1-wiper_errors,00000000 00000000 ,
ENG122922-ENG121683,misc_wiper_values_1-wiper_speed_real,40, /min
ENG122924-ENG115787,misc_wiper_values_2-wiper_angle,655.32, °
ENG122924-ENG115788,misc_wiper_values_2-wiper_angle_corr_OWL,655.32, °
ENG122924-ENG115789,misc_wiper_values_2-wiper_angle_corr_UWL,655.32, °
ENG122924-ENG115790,misc_wiper_values_2-wiper_power_supply_Ubat,14.97, V
ENG116793,Monitor 1,FF FF FF FF FF FF FF FF,
ENG116802,Monitor 10,FF FF FF FF FF FF FF FF,
ENG116794,Monitor 2,FF FF FF FF FF FF FF FF,
ENG116795,Monitor 3,FF FF FF FF FF FF FF FF,
ENG116796,Monitor 4,FF FF FF FF FF FF FF FF,
ENG116797,Monitor 5,FF FF FF FF FF FF FF FF,
ENG116798,Monitor 6,FF FF FF FF FF FF FF FF,
ENG116799,Monitor 7,FF FF FF FF FF FF FF FF,
ENG116800,Monitor 8,FF FF FF FF FF FF FF FF,
ENG116801,Monitor 9,FF FF FF FF FF FF FF FF,
ENG116792,Power up history,|Funktionsanforderung|1|1|1|1|10|1|1|1|1|1|,
ENG254813,Set_value_for_headlight_range_controls_regulating_unit,Initialization,
ENG122923-ENG115672,shadow_error_table-wiper_error_1_code,51,
ENG122923-ENG115673,shadow_error_table-wiper_error_1_count,11,
ENG122923-ENG115677,shadow_error_table-wiper_error_1_data_ec4,254,
ENG122923-ENG115678,shadow_error_table-wiper_error_1_data_ec5,0,
ENG122923-ENG115676,shadow_error_table-wiper_error_1_power_supply,13.2, V
ENG122923-ENG115675,shadow_error_table-wiper_error_1_temp,14, °C
ENG122923-ENG115674,shadow_error_table-wiper_error_1_timestamp,21.8246, min
ENG122923-ENG256664,shadow_error_table-wiper_error_10_code,0,
ENG122923-ENG256665,shadow_error_table-wiper_error_10_count,0,
ENG122923-ENG256666,shadow_error_table-wiper_error_10_data_ec4,0,
ENG122923-ENG256667,shadow_error_table-wiper_error_10_data_ec5,0,
ENG122923-ENG256668,shadow_error_table-wiper_error_10_power_supply,0.0, V
ENG122923-ENG256669,shadow_error_table-wiper_error_10_temp,0, °C
ENG122923-ENG256671,shadow_error_table-wiper_error_10_timestamp,0.0000, min
ENG122923-ENG115679,shadow_error_table-wiper_error_2_code,50,
ENG122923-ENG115680,shadow_error_table-wiper_error_2_count,1,
ENG122923-ENG115684,shadow_error_table-wiper_error_2_data_ec4,66,
ENG122923-ENG115685,shadow_error_table-wiper_error_2_data_ec5,1,
ENG122923-ENG115683,shadow_error_table-wiper_error_2_power_supply,12.6, V
ENG122923-ENG115682,shadow_error_table-wiper_error_2_temp,17, °C
ENG122923-ENG115681,shadow_error_table-wiper_error_2_timestamp,0.0000, min
ENG122923-ENG115686,shadow_error_table-wiper_error_3_code,47,
ENG122923-ENG115687,shadow_error_table-wiper_error_3_count,1,
ENG122923-ENG115691,shadow_error_table-wiper_error_3_data_ec4,1,
ENG122923-ENG115692,shadow_error_table-wiper_error_3_data_ec5,0,
ENG122923-ENG115690,shadow_error_table-wiper_error_3_power_supply,12.6, V
ENG122923-ENG115689,shadow_error_table-wiper_error_3_temp,17, °C
ENG122923-ENG115688,shadow_error_table-wiper_error_3_timestamp,0.0000, min
ENG122923-ENG115693,shadow_error_table-wiper_error_4_code,31,
ENG122923-ENG115694,shadow_error_table-wiper_error_4_count,1,
ENG122923-ENG115698,shadow_error_table-wiper_error_4_data_ec4,66,
ENG122923-ENG115699,shadow_error_table-wiper_error_4_data_ec5,255,
ENG122923-ENG115697,shadow_error_table-wiper_error_4_power_supply,12.6, V
ENG122923-ENG115695,shadow_error_table-wiper_error_4_temp,9, °C
ENG122923-ENG115696,shadow_error_table-wiper_error_4_timestamp,0.0000, min
ENG122923-ENG115700,shadow_error_table-wiper_error_5_code,0,
ENG122923-ENG115701,shadow_error_table-wiper_error_5_count,0,
ENG122923-ENG115705,shadow_error_table-wiper_error_5_data_ec4,0,
ENG122923-ENG115706,shadow_error_table-wiper_error_5_data_ec5,0,
ENG122923-ENG115704,shadow_error_table-wiper_error_5_power_supply,0.0, V
ENG122923-ENG115703,shadow_error_table-wiper_error_5_temp,0, °C
ENG122923-ENG115702,shadow_error_table-wiper_error_5_timestamp,0.0000, min
ENG122923-ENG256676,shadow_error_table-wiper_error_6_code,0,
ENG122923-ENG256677,shadow_error_table-wiper_error_6_count,0,
ENG122923-ENG256678,shadow_error_table-wiper_error_6_data_ec4,0,
ENG122923-ENG256679,shadow_error_table-wiper_error_6_data_ec5,0,
ENG122923-ENG256680,shadow_error_table-wiper_error_6_power_supply,0.0, V
ENG122923-ENG256681,shadow_error_table-wiper_error_6_temp,0, °C
ENG122923-ENG256683,shadow_error_table-wiper_error_6_timestamp,0.0000, min
ENG122923-ENG256684,shadow_error_table-wiper_error_7_code,0,
ENG122923-ENG256685,shadow_error_table-wiper_error_7_count,0,
ENG122923-ENG256686,shadow_error_table-wiper_error_7_data_ec4,0,
ENG122923-ENG256687,shadow_error_table-wiper_error_7_data_ec5,0,
ENG122923-ENG256688,shadow_error_table-wiper_error_7_power_supply,0.0, V
ENG122923-ENG256689,shadow_error_table-wiper_error_7_temp,0, °C
ENG122923-ENG256691,shadow_error_table-wiper_error_7_timestamp,0.0000, min
ENG122923-ENG256692,shadow_error_table-wiper_error_8_code,0,
ENG122923-ENG256693,shadow_error_table-wiper_error_8_count,0,
ENG122923-ENG256694,shadow_error_table-wiper_error_8_data_ec4,0,
ENG122923-ENG256695,shadow_error_table-wiper_error_8_data_ec5,0,
ENG122923-ENG256696,shadow_error_table-wiper_error_8_power_supply,0.0, V
ENG122923-ENG256697,shadow_error_table-wiper_error_8_temp,0, °C
ENG122923-ENG256699,shadow_error_table-wiper_error_8_timestamp,0.0000, min
ENG122923-ENG256700,shadow_error_table-wiper_error_9_code,0,
ENG122923-ENG256701,shadow_error_table-wiper_error_9_count,0,
ENG122923-ENG256702,shadow_error_table-wiper_error_9_data_ec4,0,
ENG122923-ENG256703,shadow_error_table-wiper_error_9_data_ec5,0,
ENG122923-ENG256704,shadow_error_table-wiper_error_9_power_supply,0.0, V
ENG122923-ENG256705,shadow_error_table-wiper_error_9_temp,0, °C
ENG122923-ENG256707,shadow_error_table-wiper_error_9_timestamp,0.0000, min
ENG250298-IDE00104,Specific_ambient_conditions-DTC,00 00 00,
ENG250298-IDE07836,Specific_ambient_conditions-Log data,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG406204-ENG406303,Sperrzustand_ORU_Guard_1_G1_Fixation_State-ORUGuard1_G1_FixationState,Idle,
ENG406205-ENG406306,Status_Metadaten_ORU_Guard_1_G1_MetaDataState-ORUGuard1_G1_Metadata_State,Initial value,
ENG254825,steuergeraetinterne_Messwert,00 01 00 01 02 20 15 01 1E 00 00 00 00 00 00 00 00 00 00 00 00 00 30 30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03 04 00 00 00 00 00 00 00 00 00 00 00 04 00 0A 00 00 00 00 04 00 00 00 00 12 00 00 00 01 00 00 00 E5 C0 00 00 40 11 00 30 38 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0D 00 00 00 02 04 00 00 00 03 E2 0F 05 7F E2 11 1C E7 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 01 00 02 4C 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 02 46 00 00 44 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116790-MAS00711,Supply voltage history-Odometer reading,14, km
ENG116790-ENG115814,Supply voltage history-highest voltage ever measured,15.4, V
ENG116790-ENG115815,Supply voltage history-hoechste im letzten Fahrzyklus gemessen Batteriespannung,14.9, V
ENG116790-ENG115816,Supply voltage history-voltage measurement: intern,5.0, V
ENG122921-ENG121628,values_motorloads-mod_temp_fast,22, °C
ENG122921-ENG121627,values_motorloads-mod_temp_slow,28, °C
ENG122921-ENG121629,values_motorloads-temp_pcb,23, °C
ENG122921-ENG121631,values_motorloads-wiper_energymodel_load,0,
ENG122921-ENG121632,values_motorloads-wiper_energymodel_status,0,
ENG122921-ENG121633,values_motorloads-wiper_power_supply_PWM,0, %
ENG122921-ENG121630,values_motorloads-wiper_thermomodel_status,0,
ENG117315-ENG163906,Window_Regulator_Driver_Side_Rear_VW_Workshop_System_Name-System_short_sign,J326 ,
ENG117316-ENG163906,Window_Regulator_Passenger_Side_Rear_VW_Workshop_System_Name-System_short_sign,J327 ,
ENG254854-ENG161480,Wischer_Flash_Historie-Betriebsstundenzaehler_1,0.000000, s
ENG254854-ENG161481,Wischer_Flash_Historie-Betriebsstundenzaehler_2,0.000000, s
ENG254854-ENG161482,Wischer_Flash_Historie-Betriebsstundenzaehler_3,0.000000, s
ENG254854-ENG161483,Wischer_Flash_Historie-Betriebsstundenzaehler_4,0.000000, s
ENG254854-ENG161484,Wischer_Flash_Historie-Betriebsstundenzaehler_5,0.000000, s
ENG254854-ENG162659,Wischer_Flash_Historie-geflashte_SW_Version_2,0,
ENG254854-ENG162660,Wischer_Flash_Historie-geflashte_SW_Version_3,0,
ENG254854-ENG162661,Wischer_Flash_Historie-geflashte_SW_Version_4,0,
ENG254854-ENG162662,Wischer_Flash_Historie-geflashte_SW_Version_5,0,
ENG254854-ENG162663,Wischer_Flash_Historie-geflashte_SW_Version1,0,
ENG254854-ENG163410,Wischer_Flash_Historie-Programmierdatum_1_Jahr,0,
ENG254854-ENG163411,Wischer_Flash_Historie-Programmierdatum_1_Monat,0,
ENG254854-ENG163412,Wischer_Flash_Historie-Programmierdatum_1_Tag,0,
ENG254854-ENG163413,Wischer_Flash_Historie-Programmierdatum_2_Jahr,0,
ENG254854-ENG163414,Wischer_Flash_Historie-Programmierdatum_2_Monat,0,
ENG254854-ENG163415,Wischer_Flash_Historie-Programmierdatum_2_Tag,0,
ENG254854-ENG163416,Wischer_Flash_Historie-Programmierdatum_3_Jahr,0,
ENG254854-ENG163417,Wischer_Flash_Historie-Programmierdatum_3_Monat,0,
ENG254854-ENG163418,Wischer_Flash_Historie-Programmierdatum_3_Tag,0,
ENG254854-ENG163419,Wischer_Flash_Historie-Programmierdatum_4_Jahr,0,
ENG254854-ENG163420,Wischer_Flash_Historie-Programmierdatum_4_Monat,0,
ENG254854-ENG163421,Wischer_Flash_Historie-Programmierdatum_4_Tag,0,
ENG254854-ENG163422,Wischer_Flash_Historie-Programmierdatum_5_Jahr,0,
ENG254854-ENG163423,Wischer_Flash_Historie-Programmierdatum_5_Monat,0,
ENG254854-ENG163424,Wischer_Flash_Historie-Programmierdatum_5_Tag,0,
ENG254854-ENG164205,Wischer_Flash_Historie-Tester_Seriennummer_1,00 00 00 00 00 00,
ENG254854-ENG164206,Wischer_Flash_Historie-Tester_Seriennummer_2,00 00 00 00 00 00,
ENG254854-ENG164207,Wischer_Flash_Historie-Tester_Seriennummer_3,00 00 00 00 00 00,
ENG254854-ENG164208,Wischer_Flash_Historie-Tester_Seriennummer_4,00 00 00 00 00 00,
ENG254854-ENG164209,Wischer_Flash_Historie-Tester_Seriennummer_5,00 00 00 00 00 00,
ENG254854-ENG164431,Wischer_Flash_Historie-Wischzyklenzaehler_1,0,
ENG254854-ENG164432,Wischer_Flash_Historie-Wischzyklenzaehler_2,0,
ENG254854-ENG164433,Wischer_Flash_Historie-Wischzyklenzaehler_3,0,
ENG254854-ENG164434,Wischer_Flash_Historie-Wischzyklenzaehler_4,0,
ENG254854-ENG164435,Wischer_Flash_Historie-Wischzyklenzaehler_5,0,
ENG133751-ENG124960,Wischermesswerte 1-aktuelle Schwelle (kalt oder warm),0,
ENG133751-ENG161419,Wischermesswerte 1-Anzahl Wischzyklen(aktueller Wert),117,
ENG133751-ENG98439,Wischermesswerte 1-Battery voltage,14.9696, V
ENG133751-ENG124957,Wischermesswerte 1-Energiemodell Daten 1 gerechneter Wert,0,
ENG133751-ENG124958,Wischermesswerte 1-Energiemodell Daten 2 gerechneter Wert,0,
ENG133751-ENG124959,Wischermesswerte 1-Energiemodell Daten 3 gerechneter Wert,0,
ENG133751-ENG98786,Wischermesswerte 1-Engine angle,6553.5, °
ENG133751-ENG124964,Wischermesswerte 1-Motor PWM,0.000, %
ENG133751-ENG115795,Wischermesswerte 1-Operating Hours,95505.395, s
ENG133751-ENG115650,Wischermesswerte 1-PCB-Temperatur,61078.119, °C
ENG133751-ENG124961,Wischermesswerte 1-Schwellwert 'kalt',1347443310,
ENG133751-ENG124962,Wischermesswerte 1-Schwellwert 'warm',1687603450,
ENG133751-ENG147706,Wischermesswerte 1-Schwellwert zum loeschen,200,
ENG133751-ENG99062,Wischermesswerte 1-Wipe speed,0.00, /min
ENG133752-ENG124978,Wischermesswerte 2-aktuelle obere Wendelage,6553.5, °
ENG133752-ENG124973,Wischermesswerte 2-aktueller Wischwinkel des Wischerarmes Beifahrerseite,0.6210, °
ENG133752-ENG124972,Wischermesswerte 2-aktueller Wischwinkel des Wischerarmes Fahrerseite,0.5260, °
ENG133752-ENG255292,Wischermesswerte 2-aktueller_Motor_kurbelwinkel,6553.5, °
ENG133752-ENG124984,Wischermesswerte 2-Anstehende Wischmodus,51,
ENG133752-ENG124981,Wischermesswerte 2-Arbeitswinkel der Motorabtriebswelle bei Fehlereintritt,0.0, °
ENG133752-ENG147708,Wischermesswerte 2-Blockzaehler (Ueberlast),0,
ENG133752-ENG147709,Wischermesswerte 2-Fehlerzustaende (Errorstate),0,
ENG133752-ENG124982,Wischermesswerte 2-Funktion bei Fehlereintritt 1,0,
ENG133752-ENG124983,Wischermesswerte 2-Funktion bei Fehlereintritt 2,0,
ENG133752-ENG124976,Wischermesswerte 2-Ist-Wischgeschwindigkeit,0, /min
ENG133752-ENG124985,Wischermesswerte 2-Master-Botschaft,00 00 00 00 00 00 00 00,
ENG133752-ENG121977,Wischermesswerte 2-No. of wisher cycles,0,
ENG133752-ENG98396,Wischermesswerte 2-Operating time,79054.863, s
ENG133752-ENG124970,Wischermesswerte 2-OWL Obere Wendelage,156.9, °
ENG133752-ENG124986,Wischermesswerte 2-RLS-Botschaft,00 00 00 00 00 00 00 00,
ENG133752-ENG124975,Wischermesswerte 2-Soll-Wischgeschwindigkeit,0, /min
ENG133752-ENG99020,Wischermesswerte 2-Supply voltage,13.1848, V
ENG133752-ENG98969,Wischermesswerte 2-Temperature,14.009, °C
ENG133752-ENG124971,Wischermesswerte 2-UWL Untere Wendelage,18.3, °
ENG133743-ENG125002,Wischermesswerte 3-Chip number,00 00 00 00 00 00 00 00,
ENG133743-ENG255531,Wischermesswerte 3-Chip number Infineon,74 EF D4 18 61 6B 56 26 AF EF 84 13,
ENG133743-ENG125000,Wischermesswerte 3-EOL number,30,
ENG133743-ENG125001,Wischermesswerte 3-Error state,0,
ENG133743-ENG124999,Wischermesswerte 3-ICT (NG) measurement value,0,
ENG133743-ENG124998,Wischermesswerte 3-ICT (OK) measurement value,0,
ENG133743-ENG98897,Wischermesswerte 3-Serial number,39 30 39 34 35 33 46 30 33 30 32 34 32 33 36 30 33 35 36 37,
ENG254856-ENG255353,WWS Historie-Anzahl Wischzyklen max MCU Temperatur,112,
ENG254856-ENG255354,WWS Historie-Anzahl Wischzyklen max. LIN Temperatur,97,
ENG254856-ENG255356,WWS Historie-Anzahl Wischzyklen max. UBatt,96,
ENG254856-ENG263779,WWS Historie-Anzahl_Wischzyklen_RS_Stufe_0,16,
ENG254856-ENG263780,WWS Historie-Anzahl_Wischzyklen_RS_Stufe_1,99,
ENG254856-ENG263781,WWS Historie-Anzahl_Wischzyklen_RS_Stufe_2,0,
ENG254856-ENG263782,WWS Historie-Anzahl_Wischzyklen_RS_Stufe_3,0,
ENG254856-ENG263783,WWS Historie-Anzahl_Wischzyklen_RS_Stufe_4,0,
ENG254856-ENG263784,WWS Historie-Anzahl_Wischzyklen_RS_Stufe_5,0,
ENG254856-ENG263785,WWS Historie-Anzahl_Wischzyklen_RS_Stufe_6,0,
ENG254856-ENG263786,WWS Historie-Anzahl_Wischzyklen_RS_Stufe_7,2,
ENG254856-ENG255393,WWS Historie-Betriebsstunden max MCU Temperatur,774.990209, s
ENG254856-ENG255394,WWS Historie-Betriebsstunden max. LIN Temperatur,555.738178, s
ENG254856-ENG255396,WWS Historie-Betriebsstunden max. UBatt,372.035660, s
ENG254856-ENG289707,WWS Historie-extern_Temp,0, °C
ENG254856-ENG255812,WWS Historie-Kl_15_Zyklenzaehler,240,
ENG254856-ENG255813,WWS Historie-Kl_X_Zyklenzaehler,3,
ENG254856-ENG289722,WWS Historie-LIN_Signal_max_Exterior_Temp,-94, °C
ENG254856-ENG289704,WWS Historie-max_Intern_Temp,103, °C
ENG254856-ENG256046,WWS Historie-max_power_supply,15.4, V
ENG254856-ENG256320,WWS Historie-Sleep_Counter,441,
ENG254856-ENG256640,WWS Historie-Wakeup_Counter,441,
ENG406211-ENG406296,Zielsteuergeraete_Informationen_G1_ECU_Data-ORUGuard1_G1_ECUData_DiagAddress,00 00,
ENG406211-ENG406297,Zielsteuergeraete_Informationen_G1_ECU_Data-ORUGuard1_G1_ECUData_HwPartNo,00 00 00 00 00 00 00 00 00 00 00,
ENG406211-ENG406298,Zielsteuergeraete_Informationen_G1_ECU_Data-ORUGuard1_G1_ECUData_HwVerNo,00 00 00,
ENG406211-ENG406299,Zielsteuergeraete_Informationen_G1_ECU_Data-ORUGuard1_G1_ECUData_IVDP,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG406211-ENG406300,Zielsteuergeraete_Informationen_G1_ECU_Data-ORUGuard1_G1_ECUData_SwVerNo,00 00 00 00,
ENG406212-ENG406304,Zustand_ORU_Guard_1_G1_State-ORUGuard1_G1_Guard_State,ready,
Elapsed Time: 00:51
blockmap-10-1EE-919-300-B_WVG5WVEB2SH017765-20250325-1225.CSV
;SW:1EE-919-300-B   HW:1EE-919-300 ---  Park/Steer Assist
;Component:RPA12K        H01 0630, Coding:0230026041
;EV_EPHBO3CVW4130000,001014,EV_EPHBO3CVW4130000_VWE3.rod
;Tuesday,25,March,2025,12:25:39:58926
;VCDS Version: Release 25.3.0 (x64)  Data version: 20250311 DS365.0
;VCID: 333871DA0BBB0A72424-8066-R
Group,Description,Actual
IDE00018,Voltage terminal 15,14.7, V
IDE00957-MAS01632,Resulting distance of front sensors-Status,infinite,
IDE00958-MAS01632,Resulting distance of rear sensors-Status,55, cm
IDE00973,Outside temperature,20.50, °
IDE00974,Outside air temperature internally calculated,17.50, °
IDE01123-MAS01632,Distance of left rear park assist sensor-Status,55, cm
IDE01124-MAS01632,Distance of left rear center park assist sensors-Status,55, cm
IDE01125-MAS01632,Distance of right rear center park assist sensors-Status,266, cm
IDE01126-MAS01632,Distance of right rear park assist sensor-Status,infinite,
IDE01127-MAS01632,Distance sensor for left front park assist-Status,infinite,
IDE01128-MAS01632,Distance sensor for left front center park assist-Status,infinite,
IDE01129-MAS01632,Distance sensor for right front center park assist-Status,infinite,
IDE01130-MAS01632,Distance of right front park assist sensors-Status,infinite,
IDE01131-MAS01632,Oscillating time of left rear park assist sensors-Status,Malfunction,
IDE01132-MAS01632,Oscillating time of left rear center park assist sensors-Status,0.512, ms
IDE01133-MAS01632,Oscillating time of right rear center park assist sensors-Status,0.560, ms
IDE01134-MAS01632,Oscillating time of right rear park assist sensors-Status,0.480, ms
IDE01135-MAS01632,Decay time for left front park assist sensor-Status,0.480, ms
IDE01136-MAS01632,Decay time for left front center park assist sensor-Status,0.480, ms
IDE01137-MAS01632,Decay time for right front center park assist sensors-Status,0.512, ms
IDE01138-MAS01632,Decay time for right front park assist sensors-Status,0.512, ms
IDE01165,Park assist activation tone,OFF,
IDE01166,Supply voltage for park assist sensor,14.7, V
IDE01167,Convertible offset for volume level 1,1,
IDE01169,Audio lowering request,No,
IDE01175-MAS01632,Distance of side left rear parking aid sensors-Status,infinite,
IDE01176-MAS01632,Distance of side right rear parking aid sensors-Status,88, cm
IDE01177-MAS01632,Oscillating time of side left rear parking aid sensors-Status,0.480, ms
IDE01178-MAS01632,Oscillating time of side right rear parking aid sensors-Status,0.560, ms
IDE01185-MAS01632,Distance sensor for left front parking aid-Status,infinite,
IDE01186-MAS01632,Distance sensor for right front parking aid-Status,infinite,
IDE01187-MAS01632,Decay time for side left front parking aid sensor-Status,0.480, ms
IDE01188-MAS01632,Decay time for right side front parking aid sensor-Status,0.512, ms
IDE01588,Driving direction,not detected,
IDE03684,Vehicle stopped,Yes,
IDE07543,Vehicle speed,0.00, km/h
IDE11152-MAS12261,Wheel circumferences-Right front wheel circumference,896, mm
IDE11152-MAS12262,Wheel circumferences-Left front wheel circumference,1997, mm
IDE11152-MAS12263,Wheel circumferences-Right rear wheel circumference,0, mm
IDE11152-MAS12264,Wheel circumferences-Left rear wheel circumference,252, mm
IDE12038,Brake requirements (ring buffer),|Year,Month
IDE13546,Remote controlled parking: ID of the connected device,0,
IDE13574,remote-controlled parking: X coordinate of request,0,
IDE13575,remote-controlled parking: Y coordinate of request,0,
IDE13576,remote controlled parking: status of the authentication,0,
IDE13577,remote control parking: inverse drive request,0,
IDE13579,remote control parking: driver request,0,
IDE13580,remote control parking: status of the stored devices,0,
IDE17906,Park Assist with remote control: touch screen diagnostics status,0,
IDE17907,Park Assist with remote control: function status,0,
IDE17908,Smartphone connection components: main version,0,
IDE17909,Smartphone connection components: ancillary version,0,
IDE17910,Data record: main version,0,
IDE17911,Data record: ancillary version,0,
IDE17912,Cause of malfunction at smartphone connection,0,
ENG377871-IDE18659,IPA_RPA_abort_ring_buffer-Intelligent parking assistant: reason for cancellation,|Year,Month
Elapsed Time: 00:05
blockmap-13-1EA-907-567-B_WVG5WVEB2SH017765-20250325-1225.CSV
;SW:1EA-907-567-B   HW:1EA-907-819 ---  Auto Dist. Reg
;Component:ARS512VW13    H05 0232, Coding:06230AE24071C04412574000008040052F4020000000000000000000000000
;EV_FRONTRADARCONTIVW310,004013,EV_FRONTRADARCONTIVW310_004_VWE3.rod
;Tuesday,25,March,2025,12:25:58:58926
;VCID: 3B2859FA23EBC2329A4-806E-R SFD+SFD2
IDE00002,Transport mode,OFF,
IDE00019,Voltage terminal 30,14.9, V
IDE00102,Control Module temperature,40, °C
IDE00310,Outside temperature,21.0, °C
IDE00391,Adaptive distance regulation: status,ACC_irreversible error,
IDE00924,Steering angle,9.600, °
IDE00925,Yaw rate,0.000, rad/s
IDE01268-MAS02506,Windshield wiper-Wiper active,not active,
IDE01794-ENG161032,ACC operating lever signal-ACC_main_switch,operated,
IDE01794-ENG255266,ACC operating lever signal-ACC_main_switch_status,On,
IDE01794-ENG98480,ACC operating lever signal-Cancel,Not operated,
IDE01794-ENG161043,ACC operating lever signal-Control_lever_coding,ACC,
IDE01794-ENG161044,ACC operating lever signal-Control_lever_error,No malfunction,
IDE01794-ENG255629,ACC operating lever signal-distance_toggle,Not operated,
IDE01794-ENG161132,ACC operating lever signal-part_control_lever,control_lever_8_positions,
IDE01794-ENG159615,ACC operating lever signal-Resume,Not operated,
IDE01794-ENG98911,ACC operating lever signal-Set,Not operated,
IDE01794-ENG109453,ACC operating lever signal-TIP_DOWN,Not operated,
IDE01794-ENG256530,ACC operating lever signal-tip_level_button,Not operated,
IDE01794-ENG109454,ACC operating lever signal-TIP_UP,Not operated,
IDE01985-MAS06855,FAZIT identification test sum-Test sum,41 E6 41 C0,
IDE02068-MAS00106,Time stamp-Year,2025,
IDE02068-MAS00107,Time stamp-Month,3,
IDE02068-MAS00108,Time stamp-Day,25,
IDE02068-MAS00109,Time stamp-Hours,16,
IDE02068-MAS00110,Time stamp-Minutes,26,
IDE02068-MAS00111,Time stamp-Seconds,1,
IDE03660,Longitudinal acceleration,0.00, m/s²
IDE04805-IDE02955,Driving profile selection-System status,Not available,
IDE04805-MAS01447,Driving profile selection-Act.val.,0,
IDE04805-MAS01448,Driving profile selection-Specified value,1,
IDE07145-MAS06773,Component protection properties-KS Standard software main version nummer,03,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,07,
IDE07145-MAS06785,Component protection properties-GFA key,Not Used,
IDE07145-MAS09609,Component protection properties-Status IKA start key,Unknown (128)
IDE08343,Immobilizer Challenge,F8 C5 02 61,
IDE08936,Misalignment angle: horiz,0.210, °
IDE09906,Vertical deadjustment,-0.232, °
IDE10902-IDE00102,Expanded ambient data 1-Control Module temperature,40, °C
IDE10902-IDE00310,Expanded ambient data 1-Outside temperature,21.0, °C
IDE10902-IDE00391,Expanded ambient data 1-Adaptive distance regulation: status,ACC_irreversible error,
IDE10902-IDE03660,Expanded ambient data 1-Longitudinal acceleration,0.00, m/s²
IDE10902-MAS00370,Expanded ambient data 1-Vehicle speed,0.00, m/s
IDE10902-MAS02324,Expanded ambient data 1-Voltage at sensor,14.9, V
IDE10903-IDE00924,Expanded ambient data 2-Steering angle,9.600, °
IDE10903-IDE00925,Expanded ambient data 2-Yaw rate,0.000, rad/s
IDE10903-IDE01268,Expanded ambient data 2-Windshield wiper,not active,
IDE10903-IDE08936,Expanded ambient data 2-Misalignment angle: horiz,0.210, °
IDE10903-IDE09906,Expanded ambient data 2-Vertical deadjustment,-0.232, °
IDE10903-MAS00106,Expanded ambient data 2-Year,2025,
IDE10903-MAS00107,Expanded ambient data 2-Month,3,
IDE10903-MAS00108,Expanded ambient data 2-Day,25,
IDE10903-MAS00109,Expanded ambient data 2-Hours,16,
IDE10903-MAS00110,Expanded ambient data 2-Minutes,26,
IDE10903-MAS00111,Expanded ambient data 2-Seconds,2,
IDE10903-MAS00711,Expanded ambient data 2-Odometer reading,209, km
IDE10903-MAS13429,Expanded ambient data 2-Horizontal correction angle: currently,0.210, °
IDE10903-MAS13430,Expanded ambient data 2-Vertical correction angle: currently,-0.230, °
IDE10903-ENG255471,Expanded ambient data 2-Blindness_combined,0, %
IDE10903-ENG255476,Expanded ambient data 2-Blindness_indicator_1,0, %
IDE10903-ENG255477,Expanded ambient data 2-Blindness_indicator_2,0, %
IDE10903-ENG255478,Expanded ambient data 2-Blindness_indicator_3,0, %
IDE10903-ENG255479,Expanded ambient data 2-Blindness_indicator_4,0, %
IDE10903-ENG255480,Expanded ambient data 2-Blindness_indicator_5,0, %
IDE10903-ENG255481,Expanded ambient data 2-Blindness_indicator_6,0, %
IDE10903-ENG255628,Expanded ambient data 2-Distance_index,0.00, m
IDE10903-ENG256311,Expanded ambient data 2-Sensor_FRKL,0,
IDE11753-MAS14855,IP network: IPv6-multicast-addresses-IPv6 Multicast address,|IPv6 Multicast address|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 05|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 02|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 71|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 07|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 FE|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 1B|,
IDE11755-MAS14856,IP network: VLANs-VLAN,|VLAN|2|0|0|,
IDE11756,IP network: counter messages with inadmissible VLANs,15566,
IDE11757,IP network: counter messages with inadmissible IPv6-addresses,12,
IDE11760,IP network: counter messages with inadmissible UDP ports,0,
IDE11761-IDE09467,IP network: MAC addresses-MAC address,|MAC address|02 7D FA 00 57 00|,
IDE11869,IP network: NDP cache,|MAC address,IPv6 address
IDE12062,Counter for terminal 15 reset,287,
IDE12238,I network: discarded messages counter,12,
IDE12625,IP network: current link deceleration: branch 1,3072, µs
IDE12633,IP Network maximum correction of the synchronized clock,12, µs
IDE13845,Production mode status,not active,
IDE14997,Number of events: sensor blind,0,
IDE14998,Number of events: misalignment,0,
IDE15000-IDE08936,History data sensor calibration-Misalignment angle: horiz,0.000, °
IDE15000-IDE09906,History data sensor calibration-Vertical deadjustment,0.000, °
IDE15000-IDE14999,History data sensor calibration-Duration of calibration,2.30, s
IDE15000-IDE15022,History data sensor calibration-Result of calibration,OK,
IDE15000-MAS00106,History data sensor calibration-Year,2024,
IDE15000-MAS00107,History data sensor calibration-Month,11,
IDE15000-MAS00108,History data sensor calibration-Day,22,
IDE15000-MAS00109,History data sensor calibration-Hours,15,
IDE15000-MAS00110,History data sensor calibration-Minutes,6,
IDE15000-MAS00111,History data sensor calibration-Seconds,56,
IDE15000-MAS00711,History data sensor calibration-Odometer reading,0, km
IDE15000-MAS02356,History data sensor calibration-Type of calibration,static,
IDE15000-MAS13429,History data sensor calibration-Horizontal correction angle: currently,0.210, °
IDE15000-MAS13430,History data sensor calibration-Vertical correction angle: currently,-0.230, °
IDE15001,History data sensor calibration 01,00 62 EC F1 B8 00 00 05 75 64 73 55 75 64 54 23 25 34 83 03 13 73 73 63 50 00 00 00 00 00 00 00 00 00 2B FF D2 00 2E,
IDE15002,History data sensor calibration 02,00 00 42 00 00 00 00 0F FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF F0 00 00 00 00 00 00 00 00 00 00 00 00 00 01,
IDE15003,History data sensor calibration 03,00 00 42 00 00 00 00 0F FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF F0 00 00 00 00 00 00 00 00 00 00 00 00 00 01,
IDE15004,History data sensor calibration 04,00 00 42 00 00 00 00 0F FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF F0 00 00 00 00 00 00 00 00 00 00 00 00 00 01,
IDE15005,History data sensor calibration 05,00 00 42 00 00 00 00 0F FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF F0 00 00 00 00 00 00 00 00 00 00 00 00 00 01,
IDE15006,History data sensor 01,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15007,History data sensor 02,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15008,History data sensor 03,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15009,History data sensor 04,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15010,History data sensor 05,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15011,History data sensor 06,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15012,History data sensor 07,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15013,History data sensor 08,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15014,History data sensor 09,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15015,History data sensor 10,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15016,History data sensor 11,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15017,History data sensor 12,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15018,History data sensor 13,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15019,History data sensor 14,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15020,History data sensor 15,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE17075-MAS06854,Functions that can be enabled: FoD slave enhanced status-Version,11,
IDE17075-ENG298547,Functions that can be enabled: FoD slave enhanced status-Extended_state_payload,00 01 00 D6 02 03 00 02 00 00 03 03 00 00 00 00 00 00 00 DD 00 00 00 00 03 00 00 00 0A 00 00 00 00 00 00 75 30 00 05 7E 40 00 00 03 E8 00 0A 02 0A 23 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE17075-ENG298612,Functions that can be enabled: FoD slave enhanced status-Payload_length,53,
MAS00370,Vehicle speed,0.00, m/s
MAS17268,Functions which can be activated: connection error counter,0,
MAS17521-IDE04332,Unlockable functions: activation status-Release code for a SWaP function,Available,
MAS17521-IDE05814,Unlockable functions: activation status-Individualization characteristic,invalid,
MAS17521-IDE06260,Unlockable functions: activation status-ID number,10 01 01 00,
MAS17521-MAS01340,Unlockable functions: activation status-Functions,Available,
MAS17521-MAS01903,Unlockable functions: activation status-Configuration,not OK,
MAS17521-MAS02934,Unlockable functions: activation status-Preconditions met,Condition not met,
MAS17521-MAS05616,Unlockable functions: activation status-Cancellation,No,
MAS17521-MAS05617,Unlockable functions: activation status-Authentication,Condition met,
MAS17521-MAS17839,Unlockable functions: activation status-Number of functions which can be activated,10,
MAS17521-MAS17983,Unlockable functions: activation status-Last state,not active,
MAS18157-MAS18158,SFD activated status-Role of vehicle diagnostic to be protected,No activation active,
MAS18157-MAS18161,SFD activated status-Status of vehicle diagnostic to be protected,SFD individualization feature set,
MAS18157-MAS18164,SFD activated status-Duration of vehicle diagnostic to be protected,No activation active,
MAS18157-MAS18165,SFD activated status-Type of vehicle diagnostic to be protected,No activation active,
MAS20396,SFD protection procedure,SFD access protection and SFD end-to-end protection,
MAS26502,Traffic sense,Unknown,
ENG282476-ENG282622,ACC_invalid_states-ErrorIdentCode,00 00 00 00,
ENG282476-ENG282616,ACC_invalid_states-LineNumber,00 00 00 00,
ENG282476-ENG282621,ACC_invalid_states-SourceFileID,00 00 00 00,
ENG282477-ENG104031,ACTLNumber-Number,03,
ENG282493-ENG282622,AWV_invalid_states-ErrorIdentCode,00 00 00 00,
ENG282493-ENG282616,AWV_invalid_states-LineNumber,00 00 00 00,
ENG282493-ENG282621,AWV_invalid_states-SourceFileID,00 00 00 00,
ENG282503,ECU_monitoring_states,00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG254718-MAS17839,Function_On_Demand_Unlock_ID_Status_Dev-Number of functions which can be activated,10,
ENG254718-MAS17983,Function_On_Demand_Unlock_ID_Status_Dev-Last state,not active,
ENG254718-ENG299129,Function_On_Demand_Unlock_ID_Status_Dev-FoD_function_state,|ID number,Authentication
ENG139759-ENG98375,Supplier_sw_block_version-Application,02 20 05 10,
ENG139759-ENG140150,Supplier_sw_block_version-Bootloader,01 01 21 10,
ENG139832,Sw_version_supplier,002032005 240206,
Elapsed Time: 00:19
blockmap-15-3WA-959-655-AA_WVG5WVEB2SH017765-20250325-1226.CSV
;SW:3WA-959-655-AA   HW:3WA-959-655-AA ---  Airbags
;Component:Airbag VW50   006 0151, Coding:8CCC0C0000FCC0000000002000000000A15450008100A200830036F8102B0065
;EV_AirbaVW50TS6VW49X,001001,EV_AirbaVW50TS6VW49X_VWE3.rod
;Tuesday,25,March,2025,12:26:30:58926
;VCID: 147AD2466EF5ED4A3BE-8040-R SFD+SFD2
IDE00821-MAS01632,Seat belt switch 2nd row driver's side-Status,not connected,
IDE00821-MAS04136,Seat belt switch 2nd row driver's side-Current,no measured value present,
IDE00821-MAS05030,Seat belt switch 2nd row driver's side-Resistance,384.0, Ohm
IDE00822-MAS01632,Safety belt switch 2nd row frt.passenger side-Status,not connected,
IDE00822-MAS04136,Safety belt switch 2nd row frt.passenger side-Current,no measured value present,
IDE00822-MAS05030,Safety belt switch 2nd row frt.passenger side-Resistance,388.0, Ohm
IDE00823-MAS01632,Seat belt switch 2nd row center-Status,not connected,
IDE00823-MAS04136,Seat belt switch 2nd row center-Current,no measured value present,
IDE00823-MAS05030,Seat belt switch 2nd row center-Resistance,388.0, Ohm
IDE00824-MAS01632,Seat belt switch 3rd row driver's side-Status,connected,
IDE00824-MAS04136,Seat belt switch 3rd row driver's side-Current,no measured value present,
IDE00824-MAS05030,Seat belt switch 3rd row driver's side-Resistance,824.0, Ohm
IDE00825-MAS01632,Passenger side 3rd row seat belt switch-Status,connected,
IDE00825-MAS04136,Passenger side 3rd row seat belt switch-Current,no measured value present,
IDE00825-MAS05030,Passenger side 3rd row seat belt switch-Resistance,824.0, Ohm
IDE00826-MAS01632,Seat belt switch 3rd row center-Status,not installed,
IDE00826-MAS04136,Seat belt switch 3rd row center-Current,no measured value present,
IDE00826-MAS05030,Seat belt switch 3rd row center-Resistance,no measured value present,
IDE00947-MAS01632,Driver side rear curtain airbag igniter-Status,no measured value present,
IDE00947-MAS05030,Driver side rear curtain airbag igniter-Resistance,no measured value present,
IDE00948-MAS01632,Frt.passenger side rear curtain airbag igniter-Status,no measured value present,
IDE00948-MAS05030,Frt.passenger side rear curtain airbag igniter-Resistance,no measured value present,
IDE00956,Occupation status: frt.passenger seat,Empty or child or child safety seat,
IDE01097-MAS01167,Front passenger airbag -disabled- indicator lamp-Actuation time,1 second,
IDE01097-MAS01168,Front passenger airbag -disabled- indicator lamp-Start parameter,On,
IDE01097-ENG102225,Front passenger airbag -disabled- indicator lamp-Input Output Control Parameter,Brief actuation,
IDE01357-MAS01632,Left pedestrian protection igniter-Status,no measured value present,
IDE01357-MAS05030,Left pedestrian protection igniter-Resistance,no measured value present,
IDE01358-MAS01632,Right pedestrian protection igniter-Status,no measured value present,
IDE01358-MAS05030,Right pedestrian protection igniter-Resistance,no measured value present,
IDE01359-MAS01632,Front pedestrian protection trigger-Status,no measured value present,
IDE01359-MAS05030,Front pedestrian protection trigger-Resistance,no measured value present,
IDE01552-MAS01167,Activation of active head restraint-Actuation time,1 second,
IDE01552-MAS01168,Activation of active head restraint-Start parameter,OFF,
IDE01552-ENG102225,Activation of active head restraint-Input Output Control Parameter,Brief actuation,
IDE01554-MAS01143,Workshop code for last rollover bar deployment-Device number,0,
IDE01554-MAS01144,Workshop code for last rollover bar deployment-Importer number,0,
IDE01554-MAS01145,Workshop code for last rollover bar deployment-Dealership number,0,
IDE01555,Number of frontal crashes,0,
IDE02255,Malfunction text output,Malfunction text 1,
IDE02255-MAS01167,Malfunction text output-Actuation time,1 second,
IDE02255-MAS01168,Malfunction text output-Start parameter,On,
IDE02255-ENG102225,Malfunction text output-Input Output Control Parameter,Brief actuation,
IDE02256-MAS01167,Seat belt tensioner: activation-Actuation time,1 second,
IDE02256-MAS01168,Seat belt tensioner: activation-Start parameter,On,
IDE02256-MAS01340,Seat belt tensioner: activation-Functions,Tighten seat-belt slack characteristic 1,
IDE02256-MAS04150,Seat belt tensioner: activation-Side,Left,
IDE02256-ENG102225,Seat belt tensioner: activation-Input Output Control Parameter,Brief actuation,
IDE02486,Data logger triggering,not initialized,
IDE02852-MAS01632,Battery Interrupt Igniter High-Voltage Battery-Status,correct,
IDE02852-MAS05030,Battery Interrupt Igniter High-Voltage Battery-Resistance,3.3, Ohm
IDE03800-MAS01632,Driver airbag release valve igniter-Status,no measured value present,
IDE03800-MAS05030,Driver airbag release valve igniter-Resistance,no measured value present,
IDE03801-MAS01632,Frt.pass. airbag release valve igniter-Status,not installed,
IDE03801-MAS05030,Frt.pass. airbag release valve igniter-Resistance,no measured value present,
IDE03870,Seat occupied recognition malfunction status,|
IDE03870,Seat occupied recognition malfunction status,0,
IDE04805-IDE02955,Driving profile selection-System status,Initialization,
IDE04805-MAS01448,Driving profile selection-Specified value,0,
IDE04805-MAS05058,Driving profile selection-Compatibility,No,
IDE05726-MAS09976,Dimmer terminal 58xd-Dim. value indicator lamp for airbag 'off': frt. pass. side,no measured value present,
IDE05726-MAS09977,Dimmer terminal 58xd-Dim. value indicator lamp for airbag 'on': frt. pass. side,no measured value present,
IDE05726-MAS09978,Dimmer terminal 58xd-Dim. value indicator lamp for airbag 'text': frt. pass. side,no measured value present,
IDE06032-MAS01167,Vehicle conditioning-Actuation time,1 second,
IDE06032-MAS01168,Vehicle conditioning-Start parameter,On,
IDE06032-MAS01340,Vehicle conditioning-Functions,Close windows,
IDE06032-ENG102225,Vehicle conditioning-Input Output Control Parameter,Brief actuation,
IDE06034-MAS01632,Rollover protection trigger: driver side-Status,no measured value present,
IDE06034-MAS05030,Rollover protection trigger: driver side-Resistance,no measured value present,
IDE06035-MAS01632,Rollover protection trigger: front passenger side-Status,no measured value present,
IDE06035-MAS05030,Rollover protection trigger: front passenger side-Resistance,no measured value present,
IDE06959,Seat occupant detection: diagnosis signal,24.5, %
IDE06960,Seat occupant detection: msmt. signal,2.5, %
IDE06961,Seat occupant detection: ref. signal,0.5, %
IDE07190-MAS01632,Igniter for battery open circuit 2nd battery-Status,no measured value present,
IDE07190-MAS05030,Igniter for battery open circuit 2nd battery-Resistance,no measured value present,
IDE07192-MAS01632,Thorax airbag igniter-Status,no measured value present,
IDE07192-MAS05030,Thorax airbag igniter-Resistance,no measured value present,
IDE08436-MAS01632,Driver side seat belt tensioner igniter 3-Status,no measured value present,
IDE08436-MAS05030,Driver side seat belt tensioner igniter 3-Resistance,no measured value present,
IDE08437-MAS01632,Front passenger side third row seat belt tensioner igniter-Status,no measured value present,
IDE08437-MAS05030,Front passenger side third row seat belt tensioner igniter-Resistance,no measured value present,
IDE09598-MAS01167,Triggering crash shutoff: high voltage system (Bus signal)-Actuation time,1 second,
IDE09598-MAS01168,Triggering crash shutoff: high voltage system (Bus signal)-Start parameter,On,
IDE09598-MAS05705,Triggering crash shutoff: high voltage system (Bus signal)-Shutdown request,No switch-off,
IDE09598-ENG102225,Triggering crash shutoff: high voltage system (Bus signal)-Input Output Control Parameter,Brief actuation,
IDE09599-IDE09624,Accident severity management-Crash severity,No result,
IDE09599-IDE09625,Accident severity management-Collision pos. - front drvr. side,not active,
IDE09599-IDE09626,Accident severity management-Collision pos. - front pass. side,not active,
IDE09599-IDE09627,Accident severity management-Collision pos. - side drvr. side,not active,
IDE09599-IDE09628,Accident severity management-Collision pos. - side frt. pass. side,not active,
IDE09599-IDE09629,Accident severity management-Collision pos. - rear of drvr. side,not active,
IDE09599-IDE09630,Accident severity management-Collision pos. - rear of frt. pass. side,not active,
IDE09599-IDE09631,Accident severity management-Collision position - rollover crash,not active,
IDE09599-IDE09632,Accident severity management-Collision pos. - pedestr. protect.,not active,
IDE09599-MAS01167,Accident severity management-Actuation time,1 second,
IDE09599-MAS01168,Accident severity management-Start parameter,On,
IDE09599-ENG102225,Accident severity management-Input Output Control Parameter,Brief actuation,
IDE10300,OBD Driving Cycle detected,not active,
IDE11715-MAS01632,Igniter 2 f. seat belt tensioner: 2nd row: front passenger side-Status,no measured value present,
IDE11715-MAS05030,Igniter 2 f. seat belt tensioner: 2nd row: front passenger side-Resistance,no measured value present,
IDE11716-MAS01632,Igniter 2 for seat belt tensioner: 2nd row: driver side-Status,no measured value present,
IDE11716-MAS05030,Igniter 2 for seat belt tensioner: 2nd row: driver side-Resistance,no measured value present,
IDE12056-MAS01632,Igniter for interaction airbag 2nd row: driver side-Status,not installed,
IDE12056-MAS05030,Igniter for interaction airbag 2nd row: driver side-Resistance,no measured value present,
IDE12057-MAS01632,Igniter for interaction airbag 2nd row: driver side-Status,no measured value present,
IDE12057-MAS05030,Igniter for interaction airbag 2nd row: driver side-Resistance,no measured value present,
IDE12158-MAS01632,Front pedestrian protection trigger 2-Status,no measured value present,
IDE12158-MAS05030,Front pedestrian protection trigger 2-Resistance,no measured value present,
IDE12208-MAS01632,Igniter for deactivation of A/C system 1-Status,not installed,
IDE12208-MAS05030,Igniter for deactivation of A/C system 1-Resistance,no measured value present,
IDE12209-MAS01632,Igniter for deactivation of A/C system 2-Status,not installed,
IDE12209-MAS05030,Igniter for deactivation of A/C system 2-Resistance,no measured value present,
IDE12257-IDE00821,Extended belts witch diagnostic-Seat belt switch 2nd row driver's side,255,
IDE12257-IDE00822,Extended belts witch diagnostic-Safety belt switch 2nd row frt.passenger side,255,
IDE12257-IDE00823,Extended belts witch diagnostic-Seat belt switch 2nd row center,255,
IDE12257-IDE00824,Extended belts witch diagnostic-Seat belt switch 3rd row driver's side,255,
IDE12257-IDE00825,Extended belts witch diagnostic-Passenger side 3rd row seat belt switch,255,
IDE12257-IDE00826,Extended belts witch diagnostic-Seat belt switch 3rd row center,255,
IDE12257-IDE14842,Extended belts witch diagnostic-Center seat belt switch,255,
IDE12257-IDE14843,Extended belts witch diagnostic-Seat belt switch: 4th row driver side,255,
IDE12257-IDE14844,Extended belts witch diagnostic-Seat belt switch: 4th row passenger side,255,
IDE12257-IDE14845,Extended belts witch diagnostic-Seat belt switch: 4th row center,255,
IDE12257-MAS00025,Extended belts witch diagnostic-Driver seat belt switch,0,
IDE12257-MAS00025,Extended belts witch diagnostic-Driver seat belt switch,5,
IDE12257-MAS00026,Extended belts witch diagnostic-Front passenger side safety belt switch,255,
IDE12257-MAS00478,Extended belts witch diagnostic-Reserved,15,
IDE12257-MAS00478,Extended belts witch diagnostic-Reserved,0,
IDE12257-MAS01632,Extended belts witch diagnostic-Status,not installed,
IDE12257-MAS01632,Extended belts witch diagnostic-Status,connected,
IDE12257-MAS09326,Extended belts witch diagnostic-Function,not active,
IDE12257-MAS09326,Extended belts witch diagnostic-Function,active,
IDE13284-MAS01632,Seat-occupied recognition: 3rd row driver side-Status,no measured value present,
IDE13284-MAS05030,Seat-occupied recognition: 3rd row driver side-Resistance,no measured value present,
IDE13586-MAS01632,Seat-occupied recognition: 3rd row front passenger side-Status,no measured value present,
IDE13586-MAS05030,Seat-occupied recognition: 3rd row front passenger side-Resistance,no measured value present,
IDE13835-MAS17093,VKMS: relevant VIN number for last data supply-Status of vehicle identification number,valid,
IDE13835-MAS17094,VKMS: relevant VIN number for last data supply-Vehicle identification number output,WVG5WVEB2SH017765,
IDE13836-MAS17095,VKMS: adaption counter-Adaptation counter status,valid,
IDE13836-MAS17096,VKMS: adaption counter-Adaptation counter output,00 01,
IDE13837-MAS17097,VKMS: overview missing keys-Key status,valid,
IDE13837-MAS17099,VKMS: overview missing keys-Number of missing keys,0,
IDE13837-MAS17100,VKMS: overview missing keys-Missing key,00 00,
IDE13842-MAS17101,VKMS: retrieval of information list of the stored VKMS keys-VKMS key status,valid,
IDE13842-MAS17103,VKMS: retrieval of information list of the stored VKMS keys-VKMS type ID,00 15,
IDE13842-MAS17104,VKMS: retrieval of information list of the stored VKMS keys-VKMS type adaptation counter,00 01,
IDE13842-MAS18318,VKMS: retrieval of information list of the stored VKMS keys-Number of VKMS keys,5,
IDE14239-MAS01632,Igniter for high-voltage battery 2 open circuit-Status,no measured value present,
IDE14239-MAS05030,Igniter for high-voltage battery 2 open circuit-Resistance,no measured value present,
IDE14240-MAS01632,Driver side seat occupancy detection-Status,assigned,
IDE14240-MAS05030,Driver side seat occupancy detection-Resistance,84.0, Ohm
IDE14492-MAS18388,Secure Onboard Communication: verification failed-Failed verification status,valid,
IDE14492-MAS18389,Secure Onboard Communication: verification failed-Number of failed verifications,0,
IDE14492-MAS18390,Secure Onboard Communication: verification failed-Verification failed,00 00,
IDE14493-MAS18360,Secure Onboard Communication: signatures failed-failed signature creation,00 00,
IDE14493-MAS18391,Secure Onboard Communication: signatures failed-Failed signature creation status,valid,
IDE14493-MAS18392,Secure Onboard Communication: signatures failed-Number of failed signature creations,0,
IDE14494-MAS18361,Secure Onboard Communication: general information-Status of general information,valid,
IDE14494-MAS18362,Secure Onboard Communication: general information-ECU function,SOC participant,
IDE14494-MAS18367,Secure Onboard Communication: general information-Main function call period,5,
IDE14495-MAS18369,Secure Onboard Communication: information about internal time-Internal SOC time status,valid,
IDE14495-MAS18370,Secure Onboard Communication: information about internal time-Validity of internal SOC time,Valid SOC time,
IDE14495-MAS18374,Secure Onboard Communication: information about internal time-Internal time,00 0D C0 1D 12 CA 7E E4,
IDE14495-MAS18375,Secure Onboard Communication: information about internal time-Jitter test status,Jitter not exceeded,
IDE14496-MAS18378,Secure Onboard Communication: Freshness Values information-Freshness status,valid,
IDE14496-MAS18379,Secure Onboard Communication: Freshness Values information-Number of Freshness IDs,3,
IDE14496-MAS18380,Secure Onboard Communication: Freshness Values information-SOC PDU ID to which this freshness information is assigned,00 06,
IDE14496-MAS18381,Secure Onboard Communication: Freshness Values information-Freshness Value query status,Freshness Value was not queried,
IDE14496-MAS18384,Secure Onboard Communication: Freshness Values information-SOC time of last successful verification,FF FF FF FF FF FF FF FF,
IDE14496-MAS18385,Secure Onboard Communication: Freshness Values information-Current value of message counter,255,
IDE14496-MAS18386,Secure Onboard Communication: Freshness Values information-Bitfield with used counter values,11111111 11111111 ,
IDE14497-MAS17099,Secure Onboard Communication: missing key-Number of missing keys,0,
IDE14497-MAS17100,Secure Onboard Communication: missing key-Missing key,00 00,
IDE14497-MAS18387,Secure Onboard Communication: missing key-Missing key status,valid,
IDE14662-IDE13284,Expanded diagnosis of seat occupancy detection-Seat-occupied recognition: 3rd row driver side,255,
IDE14662-IDE13586,Expanded diagnosis of seat occupancy detection-Seat-occupied recognition: 3rd row front passenger side,255,
IDE14662-IDE14240,Expanded diagnosis of seat occupancy detection-Driver side seat occupancy detection,0,
IDE14662-IDE14240,Expanded diagnosis of seat occupancy detection-Driver side seat occupancy detection,5,
IDE14662-IDE14846,Expanded diagnosis of seat occupancy detection-Seat occupancy detection: center,255,
IDE14662-IDE14847,Expanded diagnosis of seat occupancy detection-Seat-occupied recognition: 4th row driver side,255,
IDE14662-IDE14848,Expanded diagnosis of seat occupancy detection-Seat-occupied recognition: 4th row front passenger side,255,
IDE14662-IDE14849,Expanded diagnosis of seat occupancy detection-Seat-occupied recognition: 4th row center,255,
IDE14662-MAS00038,Expanded diagnosis of seat occupancy detection-Seat occupied recognition: driver side: rear,255,
IDE14662-MAS00039,Expanded diagnosis of seat occupancy detection-Seat occupied recognition: passenger side: rear,255,
IDE14662-MAS00040,Expanded diagnosis of seat occupancy detection-Seat occupied recognition: center: rear,255,
IDE14662-MAS00231,Expanded diagnosis of seat occupancy detection-Seat occupied recognition passenger side,255,
IDE14662-MAS00478,Expanded diagnosis of seat occupancy detection-Reserved,15,
IDE14662-MAS00478,Expanded diagnosis of seat occupancy detection-Reserved,0,
IDE14662-MAS01632,Expanded diagnosis of seat occupancy detection-Status,not installed,
IDE14662-MAS01632,Expanded diagnosis of seat occupancy detection-Status,assigned,
IDE14662-MAS09326,Expanded diagnosis of seat occupancy detection-Function,not active,
IDE14662-MAS09326,Expanded diagnosis of seat occupancy detection-Function,active,
IDE14662-MAS18987,Expanded diagnosis of seat occupancy detection-Seat occupancy detection: 3rd row center,255,
IDE14740-IDE13284,Wireless seat occupancy detection-Seat-occupied recognition: 3rd row driver side,Not assigned,
IDE14740-IDE13586,Wireless seat occupancy detection-Seat-occupied recognition: 3rd row front passenger side,Not assigned,
IDE14740-IDE14240,Wireless seat occupancy detection-Driver side seat occupancy detection,assigned,
IDE14740-IDE14846,Wireless seat occupancy detection-Seat occupancy detection: center,not installed,
IDE14740-IDE14847,Wireless seat occupancy detection-Seat-occupied recognition: 4th row driver side,not installed,
IDE14740-IDE14848,Wireless seat occupancy detection-Seat-occupied recognition: 4th row front passenger side,not installed,
IDE14740-IDE14849,Wireless seat occupancy detection-Seat-occupied recognition: 4th row center,not installed,
IDE14740-MAS00038,Wireless seat occupancy detection-Seat occupied recognition: driver side: rear,not installed,
IDE14740-MAS00039,Wireless seat occupancy detection-Seat occupied recognition: passenger side: rear,not installed,
IDE14740-MAS00040,Wireless seat occupancy detection-Seat occupied recognition: center: rear,not installed,
IDE14740-MAS00231,Wireless seat occupancy detection-Seat occupied recognition passenger side,not installed,
IDE14740-MAS18987,Wireless seat occupancy detection-Seat occupancy detection: 3rd row center,not installed,
IDE14741-IDE00821,Wireless belt buckle query-Seat belt switch 2nd row driver's side,not installed,
IDE14741-IDE00822,Wireless belt buckle query-Safety belt switch 2nd row frt.passenger side,not installed,
IDE14741-IDE00823,Wireless belt buckle query-Seat belt switch 2nd row center,not installed,
IDE14741-IDE00824,Wireless belt buckle query-Seat belt switch 3rd row driver's side,not connected,
IDE14741-IDE00825,Wireless belt buckle query-Passenger side 3rd row seat belt switch,not connected,
IDE14741-IDE00826,Wireless belt buckle query-Seat belt switch 3rd row center,not installed,
IDE14741-IDE14842,Wireless belt buckle query-Center seat belt switch,not installed,
IDE14741-IDE14843,Wireless belt buckle query-Seat belt switch: 4th row driver side,not installed,
IDE14741-IDE14844,Wireless belt buckle query-Seat belt switch: 4th row passenger side,not installed,
IDE14741-IDE14845,Wireless belt buckle query-Seat belt switch: 4th row center,not installed,
IDE14741-MAS00025,Wireless belt buckle query-Driver seat belt switch,connected,
IDE14741-MAS00026,Wireless belt buckle query-Front passenger side safety belt switch,not connected,
IDE14842-MAS01632,Center seat belt switch-Status,not installed,
IDE14842-MAS04136,Center seat belt switch-Current,no measured value present,
IDE14842-MAS05030,Center seat belt switch-Resistance,no measured value present,
IDE14843-MAS01632,Seat belt switch: 4th row driver side-Status,not installed,
IDE14843-MAS04136,Seat belt switch: 4th row driver side-Current,no measured value present,
IDE14843-MAS05030,Seat belt switch: 4th row driver side-Resistance,no measured value present,
IDE14844-MAS01632,Seat belt switch: 4th row passenger side-Status,not installed,
IDE14844-MAS04136,Seat belt switch: 4th row passenger side-Current,no measured value present,
IDE14844-MAS05030,Seat belt switch: 4th row passenger side-Resistance,no measured value present,
IDE14845-MAS01632,Seat belt switch: 4th row center-Status,not installed,
IDE14845-MAS04136,Seat belt switch: 4th row center-Current,no measured value present,
IDE14845-MAS05030,Seat belt switch: 4th row center-Resistance,no measured value present,
IDE14846-MAS01632,Seat occupancy detection: center-Status,not installed,
IDE14846-MAS05030,Seat occupancy detection: center-Resistance,no measured value present,
IDE14847-MAS01632,Seat-occupied recognition: 4th row driver side-Status,not installed,
IDE14847-MAS05030,Seat-occupied recognition: 4th row driver side-Resistance,no measured value present,
IDE14848-MAS01632,Seat-occupied recognition: 4th row front passenger side-Status,not installed,
IDE14848-MAS05030,Seat-occupied recognition: 4th row front passenger side-Resistance,no measured value present,
IDE14849-MAS01632,Seat-occupied recognition: 4th row center-Status,not installed,
IDE14849-MAS05030,Seat-occupied recognition: 4th row center-Resistance,no measured value present,
IDE15772-MAS14174,Wireless belt request/seat occupancy detection status-2nd Row Center,not configured,
IDE15772-MAS20984,Wireless belt request/seat occupancy detection status-1st Row Driver Side,not configured,
IDE15772-MAS20985,Wireless belt request/seat occupancy detection status-1st Row Passenger Side,not configured,
IDE15772-MAS20986,Wireless belt request/seat occupancy detection status-1st Row Center,not configured,
IDE15772-MAS20987,Wireless belt request/seat occupancy detection status-3rd Row Center,not configured,
IDE15772-MAS20988,Wireless belt request/seat occupancy detection status-4th Row Center,not configured,
IDE15772-MAS20989,Wireless belt request/seat occupancy detection status-4th Row Passenger Side,not configured,
IDE15772-MAS20990,Wireless belt request/seat occupancy detection status-3rd Row Passenger Side,correct,
IDE15772-MAS20991,Wireless belt request/seat occupancy detection status-2nd Row Passenger Side,not configured,
IDE15772-MAS20992,Wireless belt request/seat occupancy detection status-2nd Row Driver Side,not configured,
IDE15772-MAS20993,Wireless belt request/seat occupancy detection status-3rd Row Driver Side,correct,
IDE15772-MAS20994,Wireless belt request/seat occupancy detection status-4th Row Driver Side,not configured,
IDE15776-MAS01632,Deactivation igniter: DC/DC converter-Status,no measured value present,
IDE15776-MAS05030,Deactivation igniter: DC/DC converter-Resistance,no measured value present,
IDE16063-MAS01632,Igniter for high-voltage battery 3 open circuit-Status,no measured value present,
IDE16063-MAS05030,Igniter for high-voltage battery 3 open circuit-Resistance,no measured value present,
IDE16064-MAS01632,Driver Head Curtain Airbag Igniter 2-Status,correct,
IDE16064-MAS05030,Driver Head Curtain Airbag Igniter 2-Resistance,2.6, Ohm
IDE16065-MAS01632,Front Passenger Head Curtain Airbag Igniter 2-Status,correct,
IDE16065-MAS05030,Front Passenger Head Curtain Airbag Igniter 2-Resistance,2.6, Ohm
IDE16304-IDE02241,Inertial sensors-Lateral acceleration sensor 1,0.0, m/s²
IDE16304-IDE02245,Inertial sensors-Lateral acceleration sensor 2,-163.8, m/s²
IDE16304-IDE02538,Inertial sensors-Longitude Acceleration Sensor,0.1, m/s²
IDE16304-IDE02546,Inertial sensors-Roll rate sensor,-0.3, °/s
IDE16304-IDE02549,Inertial sensors-Pitch rate sensor,-327.7, °/s
IDE16304-IDE02552,Inertial sensors-Yaw rate sensor,0.1, °/s
IDE16304-IDE02555,Inertial sensors-Yaw rate sensor 2,-327.7, °/s
IDE16304-IDE16337,Inertial sensors-Longitudinal Acceleration Sensor 2,-163.8, m/s²
IDE16304-MAS04460,Inertial sensors-Validity,OK,
IDE16304-MAS04460,Inertial sensors-Validity,Not installed due to specific system,
IDE16304-MAS22296,Inertial sensors-Vertical Motion Sensor,9.8, m/s²
IDE16304-MAS22298,Inertial sensors-Vertical Motion Sensor 2,-163.8, m/s²
IDE17275-MAS01632,Igniter for deactivation of A/C system 3-Status,not installed,
IDE17275-MAS05030,Igniter for deactivation of A/C system 3-Resistance,no measured value present,
MAS00001-MAS01632,Driver airbag igniter-Status,correct,
MAS00001-MAS05030,Driver airbag igniter-Resistance,3.0, Ohm
MAS00002-MAS01632,Driver's Airbag Igniter 2-Status,no measured value present,
MAS00002-MAS05030,Driver's Airbag Igniter 2-Resistance,no measured value present,
MAS00003-MAS01632,Front passenger airbag igniter-Status,correct,
MAS00003-MAS05030,Front passenger airbag igniter-Resistance,2.1, Ohm
MAS00004-MAS01632,Front passenger airbag igniter 2-Status,correct,
MAS00004-MAS05030,Front passenger airbag igniter 2-Resistance,2.1, Ohm
MAS00005-MAS01632,Driver thorax airbag igniter-Status,correct,
MAS00005-MAS05030,Driver thorax airbag igniter-Resistance,2.5, Ohm
MAS00006-MAS01632,Front passenger side airbag igniter-Status,correct,
MAS00006-MAS05030,Front passenger side airbag igniter-Resistance,2.5, Ohm
MAS00007-MAS01632,Driver side rear thorax airbag igniter-Status,no measured value present,
MAS00007-MAS05030,Driver side rear thorax airbag igniter-Resistance,no measured value present,
MAS00008-MAS01632,Passenger side rear thorax airbag igniter-Status,no measured value present,
MAS00008-MAS05030,Passenger side rear thorax airbag igniter-Resistance,no measured value present,
MAS00009-MAS01632,Driver head curtain airbag igniter-Status,correct,
MAS00009-MAS05030,Driver head curtain airbag igniter-Resistance,2.4, Ohm
MAS00010-MAS01632,Front passenger head curtain airbag igniter-Status,correct,
MAS00010-MAS05030,Front passenger head curtain airbag igniter-Resistance,2.5, Ohm
MAS00011-MAS01632,Driver knee airbag igniter-Status,no measured value present,
MAS00011-MAS05030,Driver knee airbag igniter-Resistance,no measured value present,
MAS00012-MAS01632,Front passenger knee airbag igniter-Status,not installed,
MAS00012-MAS05030,Front passenger knee airbag igniter-Resistance,no measured value present,
MAS00013-MAS01632,Driver side seat belt tension igniter-Status,correct,
MAS00013-MAS05030,Driver side seat belt tension igniter-Resistance,2.4, Ohm
MAS00014-MAS01632,Front passenger side seat belt tension igniter-Status,correct,
MAS00014-MAS05030,Front passenger side seat belt tension igniter-Resistance,2.4, Ohm
MAS00015-MAS01632,Driver seat belt tensioner igniter 2-Status,correct,
MAS00015-MAS05030,Driver seat belt tensioner igniter 2-Resistance,2.4, Ohm
MAS00016-MAS01632,Front passenger seat belt tensioner igniter 2-Status,correct,
MAS00016-MAS05030,Front passenger seat belt tensioner igniter 2-Resistance,2.4, Ohm
MAS00017-MAS01632,Driver's Belt Force Limiter-Status,correct,
MAS00017-MAS05030,Driver's Belt Force Limiter-Resistance,2.4, Ohm
MAS00018-MAS01632,Front passenger side belt force limiter igniter-Status,correct,
MAS00018-MAS05030,Front passenger side belt force limiter igniter-Resistance,2.4, Ohm
MAS00019-MAS01632,Driver side rear safety belt tension igniter-Status,correct,
MAS00019-MAS05030,Driver side rear safety belt tension igniter-Resistance,2.6, Ohm
MAS00020-MAS01632,Passenger side rear seat belt tensioner igniter-Status,correct,
MAS00020-MAS05030,Passenger side rear seat belt tensioner igniter-Resistance,2.7, Ohm
MAS00021-MAS01632,Center rear seat belt tensioner igniter-Status,no measured value present,
MAS00021-MAS05030,Center rear seat belt tensioner igniter-Resistance,no measured value present,
MAS00022-MAS01632,Battery Interrupt Igniter-Status,no measured value present,
MAS00022-MAS05030,Battery Interrupt Igniter-Resistance,no measured value present,
MAS00023-MAS01632,Driver side active head restraint igniter-Status,no measured value present,
MAS00023-MAS05030,Driver side active head restraint igniter-Resistance,no measured value present,
MAS00024-MAS01632,Igniter for active head restraint on frt. passenger side-Status,no measured value present,
MAS00024-MAS05030,Igniter for active head restraint on frt. passenger side-Resistance,no measured value present,
MAS00025-MAS01632,Driver seat belt switch-Status,connected,
MAS00025-MAS04136,Driver seat belt switch-Current,no measured value present,
MAS00025-MAS05030,Driver seat belt switch-Resistance,96.0, Ohm
MAS00026-MAS01632,Front passenger side safety belt switch-Status,not connected,
MAS00026-MAS04136,Front passenger side safety belt switch-Current,no measured value present,
MAS00026-MAS05030,Front passenger side safety belt switch-Resistance,396.0, Ohm
MAS00031,Airbag deactivation status,OFF,
MAS00032-MAS01632,Key switch terminal 1-Status,not installed,
MAS00032-MAS05030,Key switch terminal 1-Resistance,no measured value present,
MAS00033-MAS01632,Key switch terminal 2-Status,not installed,
MAS00033-MAS05030,Key switch terminal 2-Resistance,no measured value present,
MAS00035-MAS01632,Seat position sensor: driver side-Status,Rear,
MAS00035-MAS04136,Seat position sensor: driver side-Current,5.6, mA
MAS00036-MAS01632,Seat position sensor: front passenger side-Status,Rear,
MAS00036-MAS04136,Seat position sensor: front passenger side-Current,5.8, mA
MAS00037,Calibration status,0,
MAS00038-MAS01632,Seat occupied recognition: driver side: rear-Status,no measured value present,
MAS00038-MAS05030,Seat occupied recognition: driver side: rear-Resistance,no measured value present,
MAS00039-MAS01632,Seat occupied recognition: passenger side: rear-Status,no measured value present,
MAS00039-MAS05030,Seat occupied recognition: passenger side: rear-Resistance,no measured value present,
MAS00040-MAS01632,Seat occupied recognition: center: rear-Status,no measured value present,
MAS00040-MAS05030,Seat occupied recognition: center: rear-Resistance,no measured value present,
MAS00083-IDE05251,Deploying crash signal-Crash direction,No crash direction,
MAS00083-IDE05258,Deploying crash signal-Crash intensity,Stage 1,
MAS00083-MAS01167,Deploying crash signal-Actuation time,1 second,
MAS00083-MAS01168,Deploying crash signal-Start parameter,On,
MAS00083-ENG102225,Deploying crash signal-Input Output Control Parameter,Brief actuation,
MAS00231-MAS01632,Seat occupied recognition passenger side-Status,not installed,
MAS00231-MAS05030,Seat occupied recognition passenger side-Resistance,no measured value present,
MAS01634-IDE00020,Supply voltage-Terminal 15 status,On,
MAS01634-IDE00773,Supply voltage-Terminal 15 status via CAN,On,
MAS01634-IDE02537,Supply voltage-Terminal 30 status,correct,
MAS01634-MAS06489,Supply voltage-Terminal 15 signal,14.5, V
MAS01634-MAS06982,Supply voltage-Terminal 15 status signal,On,
MAS01634-MAS15175,Supply voltage-Terminal 30,14.8, V
MAS18987-MAS01632,Seat occupancy detection: 3rd row center-Status,not installed,
MAS18987-MAS05030,Seat occupancy detection: 3rd row center-Resistance,no measured value present,
Elapsed Time: 00:20
Jef
HQ
blockmap-16-1EE-953-507-CH_WVG5WVEB2SH017765-20250325-1227.CSV
;SW:1EE-953-507-CH   HW:1EE-953-507-CH ---  Steering wheel
;Component:GSMMEB        005 0067, Coding:
;EV_SMLSKLOGEN2,009005,EV_SMLSKLOGEN2_009_VW41.rod
;Tuesday,25,March,2025,12:27:11:58926
;VCID: 0358E11A1B9B7AF2924-8056-R SFD
IDE00019,Voltage terminal 30,14.7, V
IDE00020,Terminal 15 status,On,
IDE02693-IDE02335,Turn signals and parking lights-Signal light switch position,Not operated,
IDE02694-MAS01288,Signal horn activation-Horn,Not operated,
IDE02695-IDE01268,Front wiping: front washing-Windshield wiper,Not operated,
IDE02695-MAS02338,Front wiping: front washing-Windshield wiper: intermittent stage,Stage 2,
IDE02695-MAS02339,Front wiping: front washing-Windshield washer system,Not operated,
IDE02696-IDE02711,Rear wiping: rear washing-Rear wiper,Not operated,
IDE02696-MAS02341,Rear wiping: rear washing-Rear window washer system,Not operated,
IDE02743,High Beam,Not operated,
IDE02744-MAS01447,Steering wheel heating-Act.val.,0, %
IDE02744-MAS01448,Steering wheel heating-Specified value,0, %
IDE02744-MAS01632,Steering wheel heating-Status,OFF,
IDE02744-MAS04121,Steering wheel heating-Voltage,0.0, V
IDE02744-MAS04136,Steering wheel heating-Current,0.00, A
IDE03393,Selector lever position,Basic setting X,
IDE05724,Dimmer terminal 58xt,100, %
IDE09492-ENG274503,Temperatures-Internal ECU Temperature,36, °C
IDE10342-MAS00468,Standard - ambient data 1: status-Unlearning counter,2,
IDE10342-MAS00711,Standard - ambient data 1: status-Odometer reading,209, km
IDE10342-MAS10409,Standard - ambient data 1: status-Time stamp,00 64 F3 06 CE,
IDE11401,Selec. range display: spec. val.,Not operated,
IDE11411-IDE15366,Button for park. lock-Selector lever P button status,not coded/not installed,
IDE13824,Monitoring network diagnosis valid,active,
MAS20396,SFD protection procedure,SFD access protection,
Elapsed Time: 00:02
blockmap-19-1EE-937-012-A_WVG5WVEB2SH017765-20250325-1212.CSV
;SW:1EE-937-012-A   HW:1EE-937-012 ---  CAN Gateway
;Component:ICAS1 Host-SG 031 0254, Coding:
;EV_GatewICAS1MEBUNECE,001004,EV_GatewICAS1MEBUNECE_VWE3.rod
;Tuesday,25,March,2025,12:12:58:58926
;VCID: 323674DEF4A1037A492-8066 SFD+SFD2
IDE00019,Voltage terminal 30,14.8, V
IDE00056,History data 1,00 00 00 00 00 00 00 00 00 00 00,
IDE00056,History data 1,69 0F 06 1F 01 19 01 00 00 05 00 00 00,
IDE00056,History data 1,F2 10 37 18 03 19 01 4E 00 00 00,
IDE00056,History data 1,F6 10 09 19 03 19 01 61 00 C0 26 00 00,
IDE00056,History data 1,F2 08 16 18 03 19 01 83 00 00 00,
IDE00056,History data 1,65 0C 2E 1E 01 19 01 05 00 00 00,
IDE00056,History data 1,65 16 35 1D 01 19 01 00 00 00 00,
IDE00056,History data 1,00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE00057,History data 2,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE00057,History data 2,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE00059,History data 4,00 0C 36 16 0B 18 01 3A 4A 43 42 32 34 31 31 31 32 43 30 35 57 01 BD 05 00 00 00 00 00 00 00 00 00 00,
IDE00059,History data 4,00 00 00 01 01 00 00 FE FF 00 00 FF 00 00 00 00 00 00 00 00 00 0F 14 00 00 00 00 00 00 00 00 00 00 00,
IDE00059,History data 4,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE00060,History data 5,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE00061,History data 6,F4 17 0F 18 03 19 00 08 01 00 34 4D 4F 3D 3D 88 00 00 94 01 00 00,
IDE00061,History data 6,F3 10 38 18 03 19 00 00 00 00 20 46 46 38 38 81 00 00 94 00 00 00,
IDE00061,History data 6,F6 10 09 19 03 19 00 03 01 00 70 47 48 34 34 87 00 00 94 00 00 00,
IDE00061,History data 6,F3 10 38 18 03 19 00 14 02 00 65 46 4C 38 39 81 00 00 94 01 00 00,
IDE00061,History data 6,F6 17 14 18 03 19 00 03 01 00 35 4F 4F 3D 3D 88 00 00 94 01 00 00,
IDE00061,History data 6,F2 14 07 16 03 19 00 02 01 00 25 50 50 36 37 96 00 00 94 01 00 00,
IDE00061,History data 6,F6 10 09 19 03 19 01 00 00 00 14 47 47 34 34 88 00 00 94 01 00 00,
IDE00061,History data 6,EF 14 06 16 03 19 00 00 00 00 3C 50 50 36 36 96 00 00 94 01 00 00,
IDE00061,History data 6,F6 10 09 19 03 19 00 00 00 00 10 47 47 34 34 88 00 00 94 00 00 00,
IDE00061,History data 6,F0 14 06 16 03 19 00 00 00 00 34 50 50 36 36 96 00 00 94 01 00 00,
IDE00062,History data 7,F0 14 06 16 03 19 00 00 25 06 00 50 17 00 00 36 01 00 01 92 01 00 00 03 00 08 00 40 00 00 00 00 00 00,
IDE00062,History data 7,ED 11 3A 15 03 19 00 00 1E 06 00 4F 15 00 00 36 01 00 00 00 00 00 00 03 00 08 00 40 00 00 00 00 00 00,
IDE00062,History data 7,F2 14 07 16 03 19 00 00 26 06 00 50 17 00 00 36 01 00 01 B6 01 00 00 03 00 08 00 40 00 00 00 00 00 00,
IDE00062,History data 7,F3 11 0B 18 03 19 82 02 70 01 00 4D 14 00 00 3D 00 00 01 04 00 00 00 00 00 08 00 00 00 00 00 00 00 00,
IDE00062,History data 7,F6 17 14 18 03 19 00 00 75 01 00 4F 17 00 00 3D 00 00 01 34 01 00 00 00 00 08 00 00 00 00 00 00 00 00,
IDE00062,History data 7,EF 14 06 16 03 19 00 00 25 06 00 50 17 00 00 36 01 00 01 7F 01 00 00 03 00 08 00 40 00 00 00 00 00 00,
IDE00062,History data 7,F6 17 19 18 03 19 00 00 66 05 00 47 11 00 00 34 00 00 00 00 00 00 00 00 00 08 00 00 00 00 00 00 00 00,
IDE00062,History data 7,EB 0E 2A 15 03 19 00 00 B3 00 00 4C 14 00 00 31 00 00 01 01 00 00 00 00 00 08 00 00 00 00 00 00 00 00,
IDE00062,History data 7,F2 14 0D 16 03 19 00 00 A5 10 00 46 10 00 00 38 00 00 01 04 00 00 00 00 00 08 00 00 00 00 00 00 00 00,
IDE00062,History data 7,EC 11 2D 15 03 19 00 00 07 00 00 4E 15 00 00 32 00 00 01 03 00 00 00 00 00 08 00 00 00 00 00 00 00 00,
IDE00063,History data 8,00 00 00 00 00 00 00 00 00 00 00 00 00 28 00 00 00 00 00 00,
IDE00063,History data 8,09 0E 04 16 0B 18 00 01 00 00 00 00 5F 41 83 2A 00 00 78 01,
IDE00063,History data 8,05 0D 2A 16 0B 18 00 01 00 00 00 00 48 3E F9 4C 00 00 78 01,
IDE00064,History data 9,B4 10 28 19 02 19 01 00 50 50 24 06 26 06 01 00 01 00 00 00 32 00 00,
IDE00064,History data 9,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE00065,History data 10,D9 11 1D 0E 03 19 5D 00 00 00 42 00 00 00 00 00 00 00 00 00,
IDE00065,History data 10,E7 12 1F 13 03 19 5D 00 00 00 38 00 00 00 00 00 00 00 00 00,
IDE00065,History data 10,DB 14 2B 0E 03 19 5D 00 00 00 45 00 00 00 00 00 00 00 00 00,
IDE00068,History data 13,82 0F 0B 15 02 19 04 00 01 00 00 00 00 01 00 00 00,
IDE00068,History data 13,83 0F 0D 15 02 19 06 00 01 00 00 00 00 01 00 00 00,
IDE00068,History data 13,82 13 22 14 02 19 02 00 01 00 00 00 00 01 00 00 00,
IDE00068,History data 13,84 0F 1D 15 02 19 03 00 01 00 00 00 00 01 00 00 00,
IDE00071,History data 16,00 00 00 00 01 00 0C 00,
IDE00071,History data 16,43 05 13 02 61 00 09 00 00 00,
IDE00071,History data 16,6F 00 30 00 1E 00 00 00 00 00,
IDE00071,History data 16,00 00 00 00 00 00 00 00 00 00 00 00,
IDE00071,History data 16,00 00 00 00 01 00 97 00,
IDE00071,History data 16,00 00 00 00 00 00 00 00 1E 00,
IDE00071,History data 16,ED 00 3B 00 0C 00 00 00,
IDE00071,History data 16,D1 00 00 00 00 00 00,
IDE00071,History data 16,34 01 15 00 08 00 03 00 00 00,
IDE00071,History data 16,00 00 00 00 03 00 AB 00,
IDE00071,History data 16,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE00301,Distance,209, km
IDE00316-MAS00106,Time-Year,2025,
IDE00316-MAS00107,Time-Month,3,
IDE00316-MAS00108,Time-Day,25,
IDE00316-MAS00109,Time-Hours,12,
IDE00316-MAS00110,Time-Minutes,13,
IDE00316-MAS00111,Time-Seconds,6,
IDE00356,Cruise Control System (CCS): switch position,OFF,
IDE00356-IDE15905,Cruise Control System (CCS): switch position-Travel Assist,Not operated,
IDE00356-MAS00128,Cruise Control System (CCS): switch position-Distance Regulation,Not operated,
IDE00356-MAS00323,Cruise Control System (CCS): switch position-Tap delay,Not operated,
IDE00356-MAS00324,Cruise Control System (CCS): switch position-Tap acceleration,Not operated,
IDE00356-MAS00325,Cruise Control System (CCS): switch position-Set,Not operated,
IDE00356-MAS00326,Cruise Control System (CCS): switch position-Resume,Not operated,
IDE00356-MAS02321,Cruise Control System (CCS): switch position-Cancel,Not operated,
IDE00356-MAS02343,Cruise Control System (CCS): switch position-Station coding,0,
IDE00356-MAS03758,Cruise Control System (CCS): switch position-Not assigned,Not operated,
IDE00356-MAS04522,Cruise Control System (CCS): switch position-Tap deceleration stage 2,Not operated,
IDE00356-MAS05138,Cruise Control System (CCS): switch position-Operating part,none,
IDE00356-MAS05812,Cruise Control System (CCS): switch position-Limit button,not installed,
IDE00356-MAS06029,Cruise Control System (CCS): switch position-MFL message counter,0,
IDE00356-MAS06879,Cruise Control System (CCS): switch position-Checksum,0,
IDE00634,Vehicle electrical system current,25, A
IDE00767-ENG279518,No. of unscheduled ECU resets-Number of Destructive Resets,0,
IDE00767-ENG279519,No. of unscheduled ECU resets-Number of External Watchdog Resets,0,
IDE00767-ENG279520,No. of unscheduled ECU resets-Number of Functional Resets,0,
IDE00767-ENG279521,No. of unscheduled ECU resets-Number of RL78 Resets,0,
IDE01803,History data 17,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE01803,History data 17,00 00 00 00 00 00 00 00 00 28 00 00 00 B8 0B 00 00 00 00 00,
IDE01803,History data 17,01 0C 36 16 0B 18 A0 3F 5A 3C 0B 3D 03 A3 0B 2E 68 CE 01 00,
IDE01803,History data 17,00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00,
IDE01807-IDE07142,History data 21-Time since terminal 15 off,3.8, H
IDE01807-MAS00106,History data 21-Year,2025,
IDE01807-MAS00107,History data 21-Month,3,
IDE01807-MAS00108,History data 21-Day,15,
IDE01807-MAS00109,History data 21-Hours,15, H
IDE01807-MAS00110,History data 21-Minutes,55, min
IDE01807-MAS14375,History data 21-Cycle counter,227,
IDE01807-MAS14376,History data 21-ECU 1,00 76,
IDE01807-MAS14377,History data 21-Alert maintenance time for ECU 1,3.8, H
IDE01807-MAS14378,History data 21-Repetition counter for ECU 1,0,
IDE01807-MAS14379,History data 21-ECU 2,00 7C,
IDE01807-MAS14380,History data 21-Alert maintenance time for ECU 2,3.8, H
IDE01807-MAS14381,History data 21-Repetition counter for ECU 2,0,
IDE01807-MAS14382,History data 21-ECU 3,00 00,
IDE01807-MAS14383,History data 21-Alert maintenance time for ECU 3,0.0, H
IDE01807-MAS14384,History data 21-Repetition counter for ECU 3,0,
IDE01807-MAS14385,History data 21-ECU 4,00 00,
IDE01807-MAS14386,History data 21-Alert maintenance time for ECU 4,0.0, H
IDE01807-MAS14387,History data 21-Repetition counter for ECU 4,0,
IDE01807-MAS14388,History data 21-ECU 5,00 00,
IDE01807-MAS14389,History data 21-Alert maintenance time for ECU 5,0.0, H
IDE01807-MAS14390,History data 21-Repetition counter for ECU 5,0,
IDE01807-MAS28454,History data 21-Data bus to ECU 1,Powertrain data bus,
IDE01807-MAS28455,History data 21-Data bus to ECU 2,Powertrain data bus,
IDE01807-MAS28456,History data 21-Data bus to ECU 3,Unknown,
IDE01807-MAS28457,History data 21-Data bus to ECU 4,Unknown,
IDE01807-MAS28458,History data 21-Data bus to ECU 5,Unknown,
IDE01808-MAS03173,History data 22-Powertrain data bus,0.1, H
IDE01808-MAS03174,History data 22-Comfort data bus,0.0, H
IDE01808-MAS03176,History data 22-Display and control head databus,0.1, H
IDE01808-MAS03178,History data 22-Suspension data bus,0.0, H
IDE01808-MAS03179,History data 22-Local data bus 2,0.0, H
IDE01808-MAS03180,History data 22-Local data bus,0.0, H
IDE01808-MAS05686,History data 22-Data bus diagnostics,0.0, H
IDE01808-MAS05972,History data 22-Local data bus 3,0.0, H
IDE01808-MAS06525,History data 22-Local data bus 4,0.0, H
IDE01808-MAS06526,History data 22-Local data bus 5,0.0, H
IDE01808-MAS06527,History data 22-Local data bus 6,0.0, H
IDE01808-MAS12183,History data 22-Comfort CAN bus 2,0.0, H
IDE01808-MAS12186,History data 22-AFS/From light data bus,0.0, H
IDE01808-MAS14373,History data 22-All BUS systems,0.2, H
IDE01808-MAS14771,History data 22-Local data bus 7,0.0, H
IDE01808-MAS16909,History data 22-Data bus driver assistance systems,0.0, H
IDE01808-MAS16912,History data 22-VLAN_FAS,0.0, H
IDE01808-MAS16913,History data 22-VLAN_Infotainment,0.1, H
IDE01808-MAS16915,History data 22-VLAN_Komfort,0.0, H
IDE01808-MAS16916,History data 22-VLAN_Powertrain,0.0, H
IDE01808-MAS16917,History data 22-VLAN_Diagnose,0.0, H
IDE01808-MAS17153,History data 22-Data bus connect,0.0, H
IDE01808-MAS18934,History data 22-VLAN Connect,0.2, H
IDE01808-MAS20472,History data 22-VLAN Connect 2,0.0, H
IDE01808-MAS20475,History data 22-Data bus multifunction steering wheel,0.0, H
IDE01808-MAS20476,History data 22-Data bus electrification,0.1, H
IDE01808-MAS20957,History data 22-VLAN_charging,0.0, H
IDE01808-MAS21728,History data 22-VLAN_light,0.0, H
IDE01808-MAS22817,History data 22-Data bus driver assistance systems 2,0.0, H
IDE01808-MAS28451,History data 22-Virtual remote control vehicle key data bus,0.0, H
IDE01809-IDE07142,History data 23-Time since terminal 15 off,0.0, H
IDE01809-MAS00106,History data 23-Year,2000,
IDE01809-MAS00107,History data 23-Month,1,
IDE01809-MAS00108,History data 23-Day,1,
IDE01809-MAS00109,History data 23-Hours,0, H
IDE01809-MAS00110,History data 23-Minutes,0, min
IDE01809-MAS14375,History data 23-Cycle counter,0,
IDE01809-MAS14395,History data 23-Bus with maximum number of post alarms,Unknown,
IDE01809-MAS14396,History data 23-Post alerts in current cycle,0,
IDE01809-MAS14397,History data 23-Rousing ECU 1,00 00,
IDE01809-MAS14398,History data 23-Number of post alerts for control module 1,0,
IDE01809-MAS14399,History data 23-CarWakeUp bit 1,0,
IDE01809-MAS14400,History data 23-Rousing ECU 2,00 00,
IDE01809-MAS14401,History data 23-Number of post alerts for control module 2,0,
IDE01809-MAS14402,History data 23-CarWakeUp bit 2,0,
IDE01809-MAS14403,History data 23-Rousing ECU 3,00 00,
IDE01809-MAS14404,History data 23-Number of post alerts for control module 3,0,
IDE01809-MAS14405,History data 23-CarWakeUp bit 3,0,
IDE01809-MAS14406,History data 23-Rousing ECU 4,00 00,
IDE01809-MAS14407,History data 23-Number of post alerts for control module 4,0,
IDE01809-MAS14408,History data 23-CarWakeUp bit 4,0,
IDE01809-MAS14409,History data 23-Rousing ECU 5,00 00,
IDE01809-MAS14410,History data 23-Number of post alerts for control module 5,0,
IDE01809-MAS14411,History data 23-CarWakeUp bit 5,0,
IDE01809-MAS28454,History data 23-Data bus to ECU 1,Unknown,
IDE01809-MAS28455,History data 23-Data bus to ECU 2,Unknown,
IDE01809-MAS28456,History data 23-Data bus to ECU 3,Unknown,
IDE01809-MAS28457,History data 23-Data bus to ECU 4,Unknown,
IDE01809-MAS28458,History data 23-Data bus to ECU 5,Unknown,
IDE01810-IDE07142,History data 24-Time since terminal 15 off,0.0, H
IDE01810-MAS00106,History data 24-Year,2000,
IDE01810-MAS00107,History data 24-Month,1,
IDE01810-MAS00108,History data 24-Day,1,
IDE01810-MAS00109,History data 24-Hours,0, H
IDE01810-MAS00110,History data 24-Minutes,0, min
IDE01810-MAS14375,History data 24-Cycle counter,0,
IDE01810-MAS14392,History data 24-CarWakeUp Bit,0,
IDE01810-MAS14393,History data 24-ID of the alerting message,00 00 00 00,
IDE01810-MAS14394,History data 24-Bus of the alerting message,Unknown,
IDE01810-MAS14412,History data 24-Bus with maximum number of alerts,Unknown,
IDE01810-MAS14413,History data 24-Alert events in current cycle,0,
IDE01810-MAS20473,History data 24-Alerting message counter,0,
IDE01812-MAS01468,History data 26-Terminal 15,251,
IDE01812-MAS03173,History data 26-Powertrain data bus,1,
IDE01812-MAS03174,History data 26-Comfort data bus,52,
IDE01812-MAS03176,History data 26-Display and control head databus,4,
IDE01812-MAS03178,History data 26-Suspension data bus,7,
IDE01812-MAS03180,History data 26-Local data bus,59,
IDE01812-MAS05686,History data 26-Data bus diagnostics,0,
IDE01812-MAS12183,History data 26-Comfort CAN bus 2,0,
IDE01812-MAS12186,History data 26-AFS/From light data bus,224,
IDE01812-MAS14374,History data 26-Totals,664,
IDE01812-MAS16909,History data 26-Data bus driver assistance systems,2,
IDE01812-MAS16917,History data 26-VLAN_Diagnose,0,
IDE01812-MAS17153,History data 26-Data bus connect,145,
IDE01812-MAS20475,History data 26-Data bus multifunction steering wheel,140,
IDE01812-MAS20476,History data 26-Data bus electrification,5,
IDE01812-MAS22817,History data 26-Data bus driver assistance systems 2,3,
IDE01812-MAS28451,History data 26-Virtual remote control vehicle key data bus,0,
IDE01813-MAS03173,History data 27-Powertrain data bus,196,
IDE01813-MAS03174,History data 27-Comfort data bus,849,
IDE01813-MAS03176,History data 27-Display and control head databus,65,
IDE01813-MAS03178,History data 27-Suspension data bus,134,
IDE01813-MAS12183,History data 27-Comfort CAN bus 2,272,
IDE01813-MAS12186,History data 27-AFS/From light data bus,2,
IDE01813-MAS14374,History data 27-Totals,2462,
IDE01813-MAS16909,History data 27-Data bus driver assistance systems,3,
IDE01813-MAS16912,History data 27-VLAN_FAS,0,
IDE01813-MAS16913,History data 27-VLAN_Infotainment,168,
IDE01813-MAS16915,History data 27-VLAN_Komfort,0,
IDE01813-MAS16916,History data 27-VLAN_Powertrain,0,
IDE01813-MAS17153,History data 27-Data bus connect,290,
IDE01813-MAS18934,History data 27-VLAN Connect,157,
IDE01813-MAS20472,History data 27-VLAN Connect 2,0,
IDE01813-MAS20475,History data 27-Data bus multifunction steering wheel,30,
IDE01813-MAS20476,History data 27-Data bus electrification,295,
IDE01813-MAS20957,History data 27-VLAN_charging,0,
IDE01813-MAS21728,History data 27-VLAN_light,0,
IDE01813-MAS22817,History data 27-Data bus driver assistance systems 2,1,
IDE01813-MAS28451,History data 27-Virtual remote control vehicle key data bus,0,
IDE01814-MAS03173,History data 28-Powertrain data bus,0,
IDE01814-MAS03174,History data 28-Comfort data bus,792,
IDE01814-MAS03176,History data 28-Display and control head databus,0,
IDE01814-MAS03178,History data 28-Suspension data bus,75,
IDE01814-MAS12183,History data 28-Comfort CAN bus 2,187,
IDE01814-MAS12186,History data 28-AFS/From light data bus,0,
IDE01814-MAS14374,History data 28-Totals,1069,
IDE01814-MAS16909,History data 28-Data bus driver assistance systems,0,
IDE01814-MAS16912,History data 28-VLAN_FAS,0,
IDE01814-MAS16913,History data 28-VLAN_Infotainment,0,
IDE01814-MAS16915,History data 28-VLAN_Komfort,0,
IDE01814-MAS16916,History data 28-VLAN_Powertrain,0,
IDE01814-MAS17153,History data 28-Data bus connect,0,
IDE01814-MAS18934,History data 28-VLAN Connect,0,
IDE01814-MAS20472,History data 28-VLAN Connect 2,0,
IDE01814-MAS20475,History data 28-Data bus multifunction steering wheel,0,
IDE01814-MAS20476,History data 28-Data bus electrification,0,
IDE01814-MAS20957,History data 28-VLAN_charging,0,
IDE01814-MAS21728,History data 28-VLAN_light,0,
IDE01814-MAS22817,History data 28-Data bus driver assistance systems 2,0,
IDE01814-MAS28451,History data 28-Virtual remote control vehicle key data bus,0,
IDE01816-IDE07142,History data 30-Time since terminal 15 off,4.1, H
IDE01816-MAS00106,History data 30-Year,2025,
IDE01816-MAS00107,History data 30-Month,2,
IDE01816-MAS00108,History data 30-Day,24,
IDE01816-MAS00109,History data 30-Hours,18, H
IDE01816-MAS00110,History data 30-Minutes,6, min
IDE01816-MAS14375,History data 30-Cycle counter,172,
IDE01816-MAS28463,History data 30-Data bus 1,Powertrain data bus,
IDE01816-MAS28464,History data 30-Data bus 2,VLAN Connect,
IDE01816-MAS28465,History data 30-Data bus 3,VLAN_Infotainment,
IDE01816-MAS28467,History data 30-Data bus 4,Display and control head databus,
IDE01816-MAS28470,History data 30-Data bus 5,Data bus connect,
IDE01816-MAS28474,History data 30-Active time for data bus 1,4.1, H
IDE01816-MAS28475,History data 30-Active time for data bus 2,0.3, H
IDE01816-MAS28476,History data 30-Active time for data bus 3,0.3, H
IDE01816-MAS28477,History data 30-Active time for data bus 4,0.2, H
IDE01816-MAS28478,History data 30-Active time for data bus 5,0.1, H
IDE01817-IDE07142,History data 31-Time since terminal 15 off,3.8, H
IDE01817-MAS00106,History data 31-Year,2025,
IDE01817-MAS00107,History data 31-Month,3,
IDE01817-MAS00108,History data 31-Day,15,
IDE01817-MAS00109,History data 31-Hours,15, H
IDE01817-MAS00110,History data 31-Minutes,55, min
IDE01817-MAS14375,History data 31-Cycle counter,227,
IDE01817-MAS14376,History data 31-ECU 1,00 76,
IDE01817-MAS14377,History data 31-Alert maintenance time for ECU 1,3.8, H
IDE01817-MAS14378,History data 31-Repetition counter for ECU 1,0,
IDE01817-MAS14379,History data 31-ECU 2,00 7C,
IDE01817-MAS14380,History data 31-Alert maintenance time for ECU 2,3.8, H
IDE01817-MAS14381,History data 31-Repetition counter for ECU 2,0,
IDE01817-MAS14382,History data 31-ECU 3,00 00,
IDE01817-MAS14383,History data 31-Alert maintenance time for ECU 3,0.0, H
IDE01817-MAS14384,History data 31-Repetition counter for ECU 3,0,
IDE01817-MAS14385,History data 31-ECU 4,00 00,
IDE01817-MAS14386,History data 31-Alert maintenance time for ECU 4,0.0, H
IDE01817-MAS14387,History data 31-Repetition counter for ECU 4,0,
IDE01817-MAS14388,History data 31-ECU 5,00 00,
IDE01817-MAS14389,History data 31-Alert maintenance time for ECU 5,0.0, H
IDE01817-MAS14390,History data 31-Repetition counter for ECU 5,0,
IDE01817-MAS28454,History data 31-Data bus to ECU 1,Powertrain data bus,
IDE01817-MAS28455,History data 31-Data bus to ECU 2,Powertrain data bus,
IDE01817-MAS28456,History data 31-Data bus to ECU 3,Unknown,
IDE01817-MAS28457,History data 31-Data bus to ECU 4,Unknown,
IDE01817-MAS28458,History data 31-Data bus to ECU 5,Unknown,
IDE01818-IDE07142,History data 32-Time since terminal 15 off,0.0, H
IDE01818-MAS00106,History data 32-Year,2000,
IDE01818-MAS00107,History data 32-Month,1,
IDE01818-MAS00108,History data 32-Day,1,
IDE01818-MAS00109,History data 32-Hours,0, H
IDE01818-MAS00110,History data 32-Minutes,0, min
IDE01818-MAS14375,History data 32-Cycle counter,0,
IDE01818-MAS14391,History data 32-Alerting ECU,00 00,
IDE01818-MAS14392,History data 32-CarWakeUp Bit,0,
IDE01818-MAS20474,History data 32-Cluster,00 00 00,
IDE01819-IDE07142,History data 33-Time since terminal 15 off,0.0, H
IDE01819-MAS00106,History data 33-Year,2000,
IDE01819-MAS00107,History data 33-Month,1,
IDE01819-MAS00108,History data 33-Day,1,
IDE01819-MAS00109,History data 33-Hours,0, H
IDE01819-MAS00110,History data 33-Minutes,0, min
IDE01819-MAS14375,History data 33-Cycle counter,0,
IDE01819-MAS14393,History data 33-ID of the alerting message,00 00 00 00,
IDE01819-MAS14394,History data 33-Bus of the alerting message,Unknown,
IDE01819-MAS20474,History data 33-Cluster,00 00 00,
IDE01820-IDE07142,History data 34-Time since terminal 15 off,16.8, H
IDE01820-MAS00106,History data 34-Year,2025,
IDE01820-MAS00107,History data 34-Month,3,
IDE01820-MAS00108,History data 34-Day,25,
IDE01820-MAS00109,History data 34-Hours,16, H
IDE01820-MAS00110,History data 34-Minutes,9, min
IDE01820-MAS14375,History data 34-Cycle counter,250,
IDE01820-MAS14393,History data 34-ID of the alerting message,1B 00 00 4C,
IDE01823-IDE07142,History data 37-Time since terminal 15 off,0.0, H
IDE01823-MAS00106,History data 37-Year,2000,
IDE01823-MAS00107,History data 37-Month,1,
IDE01823-MAS00108,History data 37-Day,1,
IDE01823-MAS00109,History data 37-Hours,0, H
IDE01823-MAS00110,History data 37-Minutes,0, min
IDE01823-MAS01632,History data 37-Status,activated,
IDE01823-MAS14375,History data 37-Cycle counter,251,
IDE01823-MAS14429,History data 37-Time in current cycle,0.0, H
IDE01848,Energy balance of last driving cycle,0.3, Ah
IDE01848-IDE01849,Energy balance of last driving cycle-Previous journey duration,0.1, H
IDE01995-ENG103538,Control module protocol information-ECUs DiagProt,|ISO-TP,TP 2.0
IDE03527-MAS05102,CAN signals-Driver information: emergency shutdown,not active,
IDE03527-MAS10895,CAN signals-Driver information key position copy workshop,not active,
IDE04329-ENG118721,Status of all SWaP functions-SWaP_function_state array,|ID number,Release code for a SWaP function
IDE04332-ENG117770,Release code for a SWaP function-fsc,Not available,
IDE04343-ENG299091,Bus identification-ECU_databus_identification,|bus_number,bus_type|0
IDE04806-ENG137100,Driving profile selection button-Driving_Profile_Selection_Button_1,Not operated,
IDE04806-ENG137101,Driving profile selection button-Driving_Profile_Selection_Button_2,Not operated,
IDE04806-ENG137102,Driving profile selection button-Driving_Profile_Selection_Button_3,Not operated,
IDE04806-ENG137103,Driving profile selection button-Driving_Profile_Selection_Button_4,Not operated,
IDE04806-ENG137104,Driving profile selection button-Driving_Profile_Selection_Button_5,Not operated,
IDE04806-ENG137105,Driving profile selection button-Driving_Profile_Selection_Button_6,Not operated,
IDE04806-ENG137106,Driving profile selection button-Driving_Profile_Selection_Button_7,Not operated,
IDE04806-ENG137107,Driving profile selection button-Driving_Profile_Selection_Button_8,Not operated,
IDE05740-MAS05376,Driving profile selection: system status-Coordinator status,active,
IDE05740-ENG256034,Driving profile selection: system status-link_state,not engaged,
IDE05740-ENG256107,Driving profile selection: system status-operation_state,engaged,
IDE05740-ENG255187,Driving profile selection: system status-profile_state,engaged,
IDE05814,Individualization characteristic,44 D7 85 9F A2,
IDE06011-ENG118665,Selected driving profile-driving_profile,Comfort,
IDE06011-ENG256033,Selected driving profile-link_profile,link_profile_1,
IDE06011-ENG157286,Selected driving profile-Operation_mode,Unknown (0)
IDE06165-MAS06193,Driving profile selection statistics-Profile 1,1996685312, min
IDE06165-MAS06194,Driving profile selection statistics-Profile 2,0, min
IDE06165-MAS06195,Driving profile selection statistics-Profile 3,150994944, min
IDE06165-MAS06196,Driving profile selection statistics-Profile 4,0, min
IDE06165-MAS06197,Driving profile selection statistics-Profile 5,0, min
IDE06165-MAS06198,Driving profile selection statistics-Profile 6,0, min
IDE06165-MAS06199,Driving profile selection statistics-Profile 7,0, min
IDE06165-MAS06200,Driving profile selection statistics-Profile 8,0, min
IDE06165-MAS08875,Driving profile selection statistics-Profile 9,0, min
IDE06165-MAS08876,Driving profile selection statistics-Profile 10,0, min
IDE06165-MAS08877,Driving profile selection statistics-Profile 11,0, min
IDE06165-MAS08878,Driving profile selection statistics-Profile 12,0, min
IDE06592-MAS18012,Status: special functions-Vehicle locking and unlocking via mobile online service,lock,
IDE06592-MAS18013,Status: special functions-Deactivation of extended start authentication,OFF,
IDE07145-MAS06773,Component protection properties-KS Standard software main version nummer,03,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,07,
IDE07145-MAS06776,Component protection properties-Komponent protection role,KS Master,
IDE07145-MAS06789,Component protection properties-KSB Config Status 2,80,
IDE07145-MAS18014,Component protection properties-Supported SHE download versions,Up to download version 6,
IDE07184-MAS06023,MFL button for freely assignable function-Parameter actuation of Joker FPA button,Not operated,
IDE07184-MAS06024,MFL button for freely assignable function-Parameter programming of Joker FPA button,not active,
IDE07628-IDE07629,Status power receptacle-Function release power receptacle,Enabled,
IDE07628-IDE07630,Status power receptacle-Pre-warning power receptacle,not active,
IDE07628-MAS01581,Status power receptacle-Power consumption,0, W
IDE07628-MAS06331,Status power receptacle-Enabling self-contained operation,locked,
IDE07628-MAS06332,Status power receptacle-Status function readiness,Enabled,
IDE07628-MAS06333,Status power receptacle-Status function,OFF,
IDE07628-MAS06334,Status power receptacle-Status overtemperature,in correct range,
IDE07628-MAS06341,Status power receptacle-After-run for power receptacle,not active,
IDE07636-MAS03001,Status hybrid DC/DC converter-Mode,2,
IDE07636-MAS04063,Status hybrid DC/DC converter-Malfunction in D/C-D/C converter,0,
IDE07636-MAS06335,Status hybrid DC/DC converter-Voltage low voltage side DCDC - converter,15.1, V
IDE07636-MAS06336,Status hybrid DC/DC converter-Current current DCDC - converter,29, A
IDE07636-MAS06337,Status hybrid DC/DC converter-DCDC converter reserve current,212, A
IDE08164-MAS06256,TSG driver side rear: signals for central locking-Status door lock,unlocked,
IDE08164-MAS06431,TSG driver side rear: signals for central locking-Door contact switch,closed,
IDE08164-MAS06432,TSG driver side rear: signals for central locking-Button for interior lock,Not operated,
IDE08164-MAS06433,TSG driver side rear: signals for central locking-Door lock: safe status,Door lock: not safe,
IDE08165-MAS06256,TSG frt.pass. side rear: signals for central locking-Status door lock,unlocked,
IDE08165-MAS06431,TSG frt.pass. side rear: signals for central locking-Door contact switch,closed,
IDE08165-MAS06432,TSG frt.pass. side rear: signals for central locking-Button for interior lock,Not operated,
IDE08165-MAS06433,TSG frt.pass. side rear: signals for central locking-Door lock: safe status,Door lock: not safe,
IDE08235-MAS00084,Status of immobilizer participant-Terminal 15 on,Yes,
IDE08235-MAS06798,Status of immobilizer participant-Key / terminal status,1C,
IDE08235-MAS06799,Status of immobilizer participant-Immobiliser status,00,
IDE08235-MAS06800,Status of immobilizer participant-Status MSG 1,00,
IDE08235-MAS06801,Status of immobilizer participant-Status MSG 2,00,
IDE08235-MAS06802,Status of immobilizer participant-Status MSG 3,00,
IDE08235-MAS06803,Status of immobilizer participant-Status MSG 4,F8,
IDE08235-MAS06804,Status of immobilizer participant-Status TCM,00,
IDE08235-MAS06805,Status of immobilizer participant-Status ESCL,F8,
IDE08235-MAS06806,Status of immobilizer participant-Status OCU,00,
IDE08235-MAS06807,Status of immobilizer participant-Status VTS,00,
IDE08235-MAS10135,Status of immobilizer participant-Terminal 15 on via login,No,
IDE08235-MAS10136,Status of immobilizer participant-Key in position terminal 15,Yes,
IDE08235-MAS10137,Status of immobilizer participant-Key in position S,Yes,
IDE08235-MAS10138,Status of immobilizer participant-Key locked,No,
IDE08235-MAS10139,Status of immobilizer participant-Key adapted,No,
IDE08235-MAS10140,Status of immobilizer participant-Key authorized,No,
IDE08235-MAS10141,Status of immobilizer participant-Immobilizer status bit 0,0,
IDE08235-MAS10142,Status of immobilizer participant-Immobilizer status bit 1,0,
IDE08235-MAS10143,Status of immobilizer participant-Debug mode,not active,
IDE08235-MAS10144,Status of immobilizer participant-Immobilizer status bit 3,0,
IDE08235-MAS10145,Status of immobilizer participant-Immobilizer status bit 4,0,
IDE08235-MAS10146,Status of immobilizer participant-Immobilizer status bit 5,0,
IDE08235-MAS10147,Status of immobilizer participant-Immobilizer status bit 6,0,
IDE08235-MAS10148,Status of immobilizer participant-Immobilizer status bit 7,0,
IDE08236-MAS06808,Status locking periods immobilizer-Lock time download,0, min
IDE08236-MAS06809,Status locking periods immobilizer-Reset lock time passwords,0, min
IDE08236-MAS06810,Status locking periods immobilizer-Lock time login terminal 15 on,0, min
IDE08236-MAS06811,Status locking periods immobilizer-Lock time login learn keys,0, min
IDE08236-MAS06812,Status locking periods immobilizer-Lock time login leave learn keys,0, min
IDE08236-MAS06813,Status locking periods immobilizer-Lock time login special functions,0, min
IDE08237-MAS06814,Status Secure Hardware Extension-SHE counter,00 00 00 02,
IDE08237-MAS06815,Status Secure Hardware Extension-SHE key number,06,
IDE08238,Transponder ID current Key,00 00 00 00,
IDE08239,Transponder ID Key 1,CD 1C 9B B1,
IDE08240,Transponder ID Key 2,E8 1C 9B B1,
IDE08251-IDE80258,Configuration immobilizer-Immobilizer status,00 00,
IDE08251-MAS01159,Configuration immobilizer-Version number,00,
IDE08251-MAS01483,Configuration immobilizer-Software version,00 00 00,
IDE08251-MAS06847,Configuration immobilizer-Snapshot,00 00 00 00 00 00 00 00,
IDE08251-MAS06848,Configuration immobilizer-Power class 2,00,
IDE08251-MAS06849,Configuration immobilizer-Supported power classes,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE08251-MAS11095,Configuration immobilizer-cause:,00 00 00,
IDE08252-MAS06854,Test sum of adapted transponder-Version,81,
IDE08252-MAS06855,Test sum of adapted transponder-Test sum,F3 07 3E 7B,
IDE08343,Immobilizer Challenge,07 BC A3 6C,
IDE09058-IDE01845,Energy management: consumer releases-Reduce internal fan request,no request,
IDE09058-IDE06233,Energy management: consumer releases-Auxiliary heater: controlled,0, W
IDE09058-IDE06234,Energy management: consumer releases-Auxiliary heater: in stages,not enabled,
IDE09058-IDE80251,Energy management: consumer releases-Head area heater,Enabling stage 3,
IDE09058-MAS01490,Energy management: consumer releases-Energy management,not active,
IDE09058-MAS01535,Energy management: consumer releases-Rear window defogger,Enabled,
IDE09058-MAS01564,Energy management: consumer releases-Windshield defogger,1240, W
IDE09058-MAS05213,Energy management: consumer releases-Mirror heater,Enabled,
IDE09058-MAS05214,Energy management: consumer releases-Steering wheel heating,Enabled,
IDE09058-MAS05795,Energy management: consumer releases-Rear seat heater,Enabling stage 3,
IDE09058-MAS06552,Energy management: consumer releases-Front seat heating,Enabling stage 3,
IDE09058-MAS06553,Energy management: consumer releases-Display consumer switch-off,not active,
IDE09058-MAS14071,Energy management: consumer releases-Seat ventilation: rear,Enabling stage 3,
IDE09058-MAS20117,Energy management: consumer releases-Front seat ventilation,Enabling stage 3,
IDE09058-MAS21177,Energy management: consumer releases-Shut-off status,not active,
IDE09074-MAS01078,Vehicle properties-Vehicle model,Electric vehicle,
IDE09074-MAS08256,Vehicle properties-Max energy content,86450, Wh
IDE09074-MAS08262,Vehicle properties-Vehicle type recognition,performed without error,
IDE09075-MAS08266,Calculation: basic average values-Average consumption:BMS electrical (prognosis limit),22.5, kWh/100 km
IDE09075-MAS08267,Calculation: basic average values-Range average consumption: combustion engine,0.0, l/100km
IDE09075-MAS08268,Calculation: basic average values-Range average consumption: electrical,18.9, kWh/100 km
IDE09075-MAS08269,Calculation: basic average values-Calculated average speed: electrical trip,46.6, km/h
IDE09075-MAS08271,Calculation: basic average values-Calculated power: component A/C,0, W
IDE09075-MAS08272,Calculation: basic average values-Calculated power: low voltage basic consumer,100, W
IDE09075-MAS09165,Calculation: basic average values-medium forecast error performance air-conditioning interior,0, W
IDE09075-MAS10152,Calculation: basic average values-Range average consumption CNG,0.0, l/100km
IDE09075-MAS10153,Calculation: basic average values-Range average consumption LPG,0.0, kWh/100 km
IDE09076-MAS08273,Calculated filtered remaining ranges (internal)-Calculated and filtered remaining the range: combustion engine,0, km
IDE09076-MAS08274,Calculated filtered remaining ranges (internal)-Calculated and filtered electrical remaining range,326, km
IDE09076-MAS08275,Calculated filtered remaining ranges (internal)-Average current load profile provided by battery,45, A
IDE09076-MAS10154,Calculated filtered remaining ranges (internal)-Calculated and filtered remaining range: CNG,0, km
IDE09076-MAS10155,Calculated filtered remaining ranges (internal)-Calculated and filtered remaining range: LPG,0, km
IDE09077-MAS08276,Calculated filtered remaining ranges (CAN)-Total remaining range,326, km
IDE09077-MAS08277,Calculated filtered remaining ranges (CAN)-Filtered remaining range: combustion engine,0, km
IDE09077-MAS08278,Calculated filtered remaining ranges (CAN)-Filtered remaining range: electric motor,326, km
IDE09077-MAS10156,Calculated filtered remaining ranges (CAN)-Filtered remaining range CNG,0, km
IDE09077-MAS10157,Calculated filtered remaining ranges (CAN)-Filtered remaining range LPG,0, km
IDE09078-MAS08279,Calculated remaining ranges (display values)-Total remaining range: displayed value,203,
IDE09078-MAS08280,Calculated remaining ranges (display values)-Remaining range: displayed value: primary drive,203,
IDE09078-MAS08281,Calculated remaining ranges (display values)-Remaining range: displayed value: secondary drive,0,
IDE09078-MAS08282,Calculated remaining ranges (display values)-Remaining range display value units,miles,
IDE09079-MAS10158,Calculated street class consumptions-Average fuel consumption on street class 0,0.0, l/100km
IDE09079-MAS10159,Calculated street class consumptions-Average fuel consumption on street class 1,0.0, l/100km
IDE09079-MAS10160,Calculated street class consumptions-Average fuel consumption on street class 2,0.0, l/100km
IDE09079-MAS10161,Calculated street class consumptions-Average fuel consumption on street class 3,0.0, l/100km
IDE09079-MAS10162,Calculated street class consumptions-Average fuel consumption on street class 4,0.0, l/100km
IDE09079-MAS10163,Calculated street class consumptions-Average fuel consumption on street class 5,0.0, l/100km
IDE09079-MAS10164,Calculated street class consumptions-Average fuel consumption on street class 6,0.0, l/100km
IDE09079-MAS10165,Calculated street class consumptions-Electrical average consumption on Street Class 0,19.5, kWh/100 km
IDE09079-MAS10166,Calculated street class consumptions-Electrical average consumption on Street Class 1,15.9, kWh/100 km
IDE09079-MAS10167,Calculated street class consumptions-Electrical average consumption on Street Class 2,17.6, kWh/100 km
IDE09079-MAS10168,Calculated street class consumptions-Electrical average consumption on Street Class 3,17.9, kWh/100 km
IDE09079-MAS10169,Calculated street class consumptions-Electrical average consumption on Street Class 4,18.0, kWh/100 km
IDE09079-MAS10170,Calculated street class consumptions-Electrical average consumption on Street Class 5,20.1, kWh/100 km
IDE09079-MAS10171,Calculated street class consumptions-Electrical average consumption on Street Class 6,0.0, kWh/100 km
IDE09080-MAS08264,Energy storage unit-Tank contents: conventional fuel including RWB-internal deduct,0.0, l
IDE09080-MAS08265,Energy storage unit-Energy content of HV battery:  RWB-internal deduction,65100, Wh
IDE09080-MAS10150,Energy storage unit-CNG tank volume incl. RWB inter. deduct. value,0.0, kg
IDE09080-MAS10151,Energy storage unit-LPG tank volume incl. RWB inter. deduct. value,0.0, l
IDE09841-MAS04394,CU for tailgate opener: sensor status-Connection status,Yes,
IDE09841-MAS09384,CU for tailgate opener: sensor status-Proximity detected: sensor 1,No,
IDE09841-MAS09385,CU for tailgate opener: sensor status-Proximity detected: sensor 2,No,
IDE10300,OBD Driving Cycle detected,active,
IDE10739-IDE04447,Status: driving profile selection for oper. mode selection-Function status,engaged,
IDE10739-IDE06260,Status: driving profile selection for oper. mode selection-ID number,9,
IDE10739-MAS01156,Status: driving profile selection for oper. mode selection-Communication status,OK,
IDE10739-MAS01447,Status: driving profile selection for oper. mode selection-Act.val.,0,
IDE10779-IDE15221,Ethernet signal quality-Number of signal quality measured values,12,
IDE10779-MAS01159,Ethernet signal quality-Version number,00,
IDE10779,Ethernet signal quality,|Ethernet interface,|2
IDE10780,Ethernet counter connection interruptions,12,
IDE10780-MAS01159,Ethernet counter connection interruptions-Version number,00,
IDE10780,Ethernet counter connection interruptions,|Ethernet interface,|2
IDE10781-MAS01159,Ethernet counter checksum malfunction-Version number,00,
IDE10781-MAS11933,Ethernet counter checksum malfunction-Counter CRC error,12,
IDE10781,Ethernet counter checksum malfunction,|Ethernet interface,|2
IDE11127-IDE04332,Error-causing FS ID with status-Release code for a SWaP function,Not available,
IDE11127-IDE05814,Error-causing FS ID with status-Individualization characteristic,invalid,
IDE11127-IDE06260,Error-causing FS ID with status-ID number,00 00 00 00,
IDE11127-MAS01340,Error-causing FS ID with status-Functions,Not available,
IDE11127-MAS01903,Error-causing FS ID with status-Configuration,not OK,
IDE11127-MAS02934,Error-causing FS ID with status-Preconditions met,Condition not met,
IDE11127-MAS05616,Error-causing FS ID with status-Cancellation,Yes,
IDE11127-MAS05617,Error-causing FS ID with status-Authentication,Condition not met,
IDE11752-IDE09469,IP network: IPv6-addresses-IPv6 address,|IPv6 address|FD 53 7C B8 03 83 00 04 00 00 00 00 00 00 00 10|FD 53 7C B8 03 83 00 0B 00 00 00 00 00 00 00 10|FD 53 7C B8 03 83 00 02 00 00 00 00 00 00 00 10|FD 53 7C B8 03 83 00 03 00 00 00 00 00 00 00 10|,
IDE11753-MAS14855,IP network: IPv6-multicast-addresses-IPv6 Multicast address,|IPv6 Multicast address|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 05|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 6B|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 09|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 0F|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 61|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 17|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 47|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 45|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 0D|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 63|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 59|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 13|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 58|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 6E|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 6F|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 37|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 FE|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 82|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 50|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 6A|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 08|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 42|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 0E|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 77|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 7F|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 55|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 03|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 67|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 5B|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 3B|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 10|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 1A|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 0C|FF 02 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 09|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 03|FF 14 00 00 00 00 00 00 00 00 00 00 00 04 00 00|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 02|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 45|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 70|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 78|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 9C|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 2F|FF 14 00 00 00 00 00 00 00 00 00 00 00 05 00 00|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 16|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 11|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 05|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 1B|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 19|,
IDE11755-MAS14856,IP network: VLANs-VLAN,|VLAN|2|4|11|3|,
IDE11756,IP network: counter messages with inadmissible VLANs,0,
IDE11757,IP network: counter messages with inadmissible IPv6-addresses,43207,
IDE11759,IP network: counter messages with inadmissible TCP ports,0,
IDE11760,IP network: counter messages with inadmissible UDP ports,0,
IDE11761-IDE09467,IP network: MAC addresses-MAC address,|MAC address|02 7D FA 00 10 00|,
IDE11869,IP network: NDP cache,|MAC address,IPv6 address
IDE11989-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 2-MAC address,|MAC address|02 7D FA 00 10 02|,
IDE11990-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 3-MAC address,|MAC address|02 7D FA 00 10 03|,
IDE11991-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 4-MAC address,|MAC address|02 7D FA 00 10 03|,
IDE11993-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 6-MAC address,|MAC address|02 7D FA 00 10 02|,
IDE11994-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 7-MAC address,|MAC address|02 7D FA 00 10 03|,
IDE11995-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 8-MAC address,|MAC address|02 7D FA 00 10 03|,
IDE12084-IDE02185,Component protection participant status-IKA key,not stored,
IDE12084-IDE10163,Component protection participant status-Authorization status,valid authentication,
IDE12084-MAS06772,Component protection participant status-Component protection generation,internal,
IDE12084-MAS13795,Component protection participant status-Node address,00 00,
IDE12084-MAS16977,Component protection participant status-Shut-off of the start authentication,not locked,
IDE12084-MAS16978,Component protection participant status-Start authentication,switched on,
IDE12084-MAS18011,Component protection participant status-Query message,Not sent,
IDE12084-ENG157306,Component protection participant status-Status_of_component_protection_slaves,|Node address,IKA key
IDE12231-MAS14856,IP network: VLANs of Ethernet switch ports branch 2-VLAN,|VLAN|2|,
IDE12232-MAS14856,IP network: VLANs of Ethernet switch ports branch 3-VLAN,|VLAN|2|,
IDE12233-MAS14856,IP network: VLANs of Ethernet switch ports branch 4-VLAN,|VLAN|2|,
IDE12235-MAS14856,IP network: VLANs of Ethernet switch ports branch 6-VLAN,|VLAN|3|,
IDE12236-MAS14856,IP network: VLANs of Ethernet switch ports branch 7-VLAN,|VLAN|2|,
IDE12237-MAS14856,IP network: VLANs of Ethernet switch ports branch 8-VLAN,Write only channel,
IDE12238,I network: discarded messages counter,37834,
IDE12239,IP network: test feedback value of communications relationships,|IPv6 address,Result|FD 53 7C B8 03 83 00 02 00 00 00 00 00 00 00 69
IDE12262-MAS14182,Virtual radio key: status-Master key coded,No,
IDE12262-MAS14183,Virtual radio key: status-Virtual radio key active,No,
IDE12262-MAS14184,Virtual radio key: status-Number of secure elements in the ticket table,31,
IDE12264-MAS14185,Virtual radio key: ticket table-Ticket 1,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14186,Virtual radio key: ticket table-Ticket 2,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14187,Virtual radio key: ticket table-Ticket 3,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14188,Virtual radio key: ticket table-Ticket 4,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14189,Virtual radio key: ticket table-Ticket 5,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14190,Virtual radio key: ticket table-Ticket 6,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14191,Virtual radio key: ticket table-Ticket 7,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14192,Virtual radio key: ticket table-Ticket 8,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14193,Virtual radio key: ticket table-Ticket 9,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14194,Virtual radio key: ticket table-Ticket 10,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14195,Virtual radio key: ticket table-Ticket 11,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14196,Virtual radio key: ticket table-Ticket 12,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14197,Virtual radio key: ticket table-Ticket 13,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14198,Virtual radio key: ticket table-Ticket 14,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14199,Virtual radio key: ticket table-Ticket 15,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14200,Virtual radio key: ticket table-Ticket 16,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12609-MAS02832,Steering wheel touch recognition: status-Malfunction status,No malfunction detected,
IDE12609-MAS14836,Steering wheel touch recognition: status-Touch intensity sensor 1,34,
IDE12609-MAS14837,Steering wheel touch recognition: status-Touch intensity sensor 2,42,
IDE12609-MAS14838,Steering wheel touch recognition: status-Touch intensity sensor 3,49,
IDE12609-MAS14839,Steering wheel touch recognition: status-Touch status,not touching,
IDE12633,IP Network maximum correction of the synchronized clock,0, µs
IDE12806-ENG299124,Diagnostic capability of the bus interface-Diag_paths,|Diag_path Bit 0,Diag_path Bit 1
IDE12807-ENG299127,Participant authenticity-Ecu_authentications,|Ecu_authentication Bit 0,Ecu_authentication Bit 1
IDE12844-ENG299092,Installation list of the 10 bit node addresses-Node_addresses,|Node address,ECM name
IDE12939-MAS02643,Public key for SWaP function (3072)-Key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
IDE13345-MAS16268,Current Secure Element-Secure Element,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE13345-MAS16269,Current Secure Element-Secure Element is contained in ticket table,No,
IDE13345-MAS16270,Current Secure Element-Secure element is authenticated,No,
IDE13551,EgoMaster tire circumference estimation utility,80, %
IDE13552,EgoMaster system status,AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBB,
IDE13679-MAS06117,Power generator status-Specified voltage,15.050, V
IDE13679-MAS09777,Power generator status-Target current,0, A
IDE13679-MAS14362,Power generator status-Voltage limit boost mode,12.4,
IDE13751-IDE00773,Output signals: control of terminal-Terminal 15 status via CAN,active,
IDE13751-IDE06027,Output signals: control of terminal-Terminal S status via CAN,active,
IDE13751-MAS07386,Output signals: control of terminal-Terminal 50 on CAN,not active,
IDE13752-IDE09059,Electrical Steering Column Lock-Request terminal release,not active,
IDE13752-MAS06711,Electrical Steering Column Lock-Terminal release,not active,
IDE13752-MAS17234,Electrical Steering Column Lock-Steering column lock locked,not active,
IDE13754-IDE04447,Diagnosis filter: status-Function status,Function active: SFD protected,
IDE13754-MAS16866,Diagnosis filter: status-Odometer,0, km
IDE13754-MAS16867,Diagnosis filter: status-Reason for deactivation,Not deactivated,
IDE13754-MAS16875,Diagnosis filter: status-Filter status,Filter active,
IDE13755-IDE00056,Diagnosis filter: history data-History data 1,00000209*2025-03-25-16:09:25*0*,
IDE13755-IDE00057,Diagnosis filter: history data-History data 2,00000209*2025-03-24-23:11:24*0*,
IDE13755-IDE00058,Diagnosis filter: history data-History data 3,00000209*2025-03-24-18:01:03*0*,
IDE13755-IDE00059,Diagnosis filter: history data-History data 4,00000209*2025-03-24-16:55:16*0*,
IDE13755-IDE00060,Diagnosis filter: history data-History data 5,00000209*2025-03-24-08:33:01*0*,
IDE13756,Diagnosis filter: activation,active,
IDE13782-MAS00106,History data of the last 25 charges-Year,2025,
IDE13782-MAS00106,History data of the last 25 charges-Year,2000,
IDE13782-MAS00107,History data of the last 25 charges-Month,0,
IDE13782-MAS00107,History data of the last 25 charges-Month,3,
IDE13782-MAS00107,History data of the last 25 charges-Month,2,
IDE13782-MAS00108,History data of the last 25 charges-Day,0,
IDE13782-MAS00108,History data of the last 25 charges-Day,25,
IDE13782-MAS00108,History data of the last 25 charges-Day,24,
IDE13782-MAS00108,History data of the last 25 charges-Day,15,
IDE13782-MAS00108,History data of the last 25 charges-Day,21,
IDE13782-MAS00109,History data of the last 25 charges-Hours,0,
IDE13782-MAS00109,History data of the last 25 charges-Hours,8,
IDE13782-MAS00109,History data of the last 25 charges-Hours,16,
IDE13782-MAS00109,History data of the last 25 charges-Hours,13,
IDE13782-MAS00109,History data of the last 25 charges-Hours,9,
IDE13782-MAS00109,History data of the last 25 charges-Hours,11,
IDE13782-MAS00109,History data of the last 25 charges-Hours,15,
IDE13782-MAS00110,History data of the last 25 charges-Minutes,0,
IDE13782-MAS00110,History data of the last 25 charges-Minutes,58,
IDE13782-MAS00110,History data of the last 25 charges-Minutes,36,
IDE13782-MAS00110,History data of the last 25 charges-Minutes,59,
IDE13782-MAS00110,History data of the last 25 charges-Minutes,22,
IDE13782-MAS00110,History data of the last 25 charges-Minutes,39,
IDE13782-MAS00110,History data of the last 25 charges-Minutes,13,
IDE13782-MAS00110,History data of the last 25 charges-Minutes,47,
IDE13782-MAS00110,History data of the last 25 charges-Minutes,2,
IDE13782-MAS00110,History data of the last 25 charges-Minutes,3,
IDE13782-MAS00478,History data of the last 25 charges-Reserved,00000000 ,
IDE13782-MAS08747,History data of the last 25 charges-Charging plug connected,00000000 ,
IDE13782-MAS08747,History data of the last 25 charges-Charging plug connected,00000001 ,
IDE13782-ENG279300,History data of the last 25 charges-AC 1Phase,00000000 ,
IDE13782-ENG279300,History data of the last 25 charges-AC 1Phase,00000001 ,
IDE13782-ENG279301,History data of the last 25 charges-AC 2Phase,00000000 ,
IDE13782-ENG279302,History data of the last 25 charges-AC 3Phase,00000000 ,
IDE13782-ENG250730,History data of the last 25 charges-AWC,00000000 ,
IDE13782-ENG255392,History data of the last 25 charges-Berechneter Energiebedarf,170,
IDE13782-ENG255392,History data of the last 25 charges-Berechneter Energiebedarf,0,
IDE13782-ENG255392,History data of the last 25 charges-Berechneter Energiebedarf,87,
IDE13782-ENG255392,History data of the last 25 charges-Berechneter Energiebedarf,154,
IDE13782-ENG255392,History data of the last 25 charges-Berechneter Energiebedarf,52,
IDE13782-ENG279316,History data of the last 25 charges-Charging start or Error,00000001 ,
IDE13782-ENG279316,History data of the last 25 charges-Charging start or Error,00000000 ,
IDE13782-ENG123224,History data of the last 25 charges-DC,00000000 ,
IDE13782-ENG279324,History data of the last 25 charges-Derating AC Notladen,not active,
IDE13782-ENG279325,History data of the last 25 charges-Derating AC Temp Abschaltung,not active,
IDE13782-ENG279326,History data of the last 25 charges-Derating DC begrenzt,not active,
IDE13782-ENG279327,History data of the last 25 charges-Derating DC reduziert,not active,
IDE13782-ENG279328,History data of the last 25 charges-Derating DC Temp Abschaltung,not active,
IDE13782-ENG279329,History data of the last 25 charges-Derating Fehler Temp AC,not active,
IDE13782-ENG279330,History data of the last 25 charges-Derating Fehler Temp DC,not active,
IDE13782-ENG279336,History data of the last 25 charges-DTC Fehler Crash Detektiert,not active,
IDE13782-ENG279337,History data of the last 25 charges-DTC Fehler FuSi Absch,not active,
IDE13782-ENG279338,History data of the last 25 charges-DTC Fehler Fzg Verrollsicher,not active,
IDE13782-ENG279339,History data of the last 25 charges-DTC Fehler Keine CP Komm,not active,
IDE13782-ENG279340,History data of the last 25 charges-DTC Fehler Ladebereit HV Koord,not active,
IDE13782-ENG279341,History data of the last 25 charges-DTC Fehler Ladebereit Ls,not active,
IDE13782-ENG279342,History data of the last 25 charges-DTC Fehler Ladebereit OCC,not active,
IDE13782-ENG279343,History data of the last 25 charges-DTC Fehler Lv Nicht Stby,not active,
IDE13782-ENG279344,History data of the last 25 charges-DTC Fehler Not Abschaltung,not active,
IDE13782-ENG279345,History data of the last 25 charges-DTC Fehler Remote Update On,not active,
IDE13782-ENG279346,History data of the last 25 charges-DTC Fehler Stecker Nicht Verr,not active,
IDE13782-ENG279409,History data of the last 25 charges-Event Entry HVL HDS 600by RAW,19 2A AE 4C 01 5C 59 B8 32 09 00 0F 2A 80 0F F0 BB 80 00 0B 00 00 00 00 19 2C 23 A8 00 00 A1 40 00 00 00 0F 00 00 0F F0 00 00 00 00 00 00 00 00 19 2C 23 B4 05 20 A4 D8 32 08 00 0F 26 80 0F F0 BB 80 00 03 00 00 00 00 19 2C A5 68 00 02 6C D0 00 00 00 0F 00 00 0F F0 00 00 00 00 00 00 00 00 19 2C A5 64 02 32 6E 48 32 0D 00 0F 0D 20 0F F0 BB 80 00 03 00 00 00 00 19 2C B6 F8 00 03 FE 40 00 05 00 0F 00 20 0F F0 00 00 00 08 00 00 00 00 19 2C BE 78 00 03 FE 40 00 05 00 0F 00 20 0F F0 00 00 00 08 00 00 00 00 19 2C C0 D8 00 03 FE 40 00 05 00 0F 00 00 0F F0 00 00 00 00 00 00 00 00 19 37 A0 28 00 01 CB 90 00 00 00 0F 00 00 0F F0 00 00 00 00 00 00 00 00 19 37 A0 34 03 9D CD 78 32 09 00 0F 15 C0 0F F0 BB 80 00 03 00 00 00 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE13782-ENG255755,History data of the last 25 charges-Grund für Ladeende,Ladeende durch Kunde an der LS,
IDE13782-ENG255755,History data of the last 25 charges-Grund für Ladeende,Ladeabbruch durch Fehler Fahrzeug,
IDE13782-ENG255755,History data of the last 25 charges-Grund für Ladeende,Ladeabbruch durch Fehler nicht zuordenbar,
IDE13782-ENG255755,History data of the last 25 charges-Grund für Ladeende,Ladeende_Ziel_SOC,
IDE13782-ENG255756,History data of the last 25 charges-Grundladeplan Abweichung,00,
IDE13782-ENG255801,History data of the last 25 charges-Indikator geäernderter Ziel_SOC,00000000 ,
IDE13782-ENG255801,History data of the last 25 charges-Indikator geäernderter Ziel_SOC,00000001 ,
IDE13782-ENG279486,History data of the last 25 charges-Indikator_01,00000000 ,
IDE13782-ENG279487,History data of the last 25 charges-Indikator_02,00000000 ,
IDE13782-ENG279488,History data of the last 25 charges-Indikator_03,00000000 ,
IDE13782-ENG279489,History data of the last 25 charges-Indikator_04,00000000 ,
IDE13782-ENG279490,History data of the last 25 charges-Indikator_05,00000000 ,
IDE13782-ENG279491,History data of the last 25 charges-Indikator_06,00000000 ,
IDE13782-ENG279492,History data of the last 25 charges-Indikator_07,00000000 ,
IDE13782-ENG279493,History data of the last 25 charges-Indikator_08,00000000 ,
IDE13782-ENG279494,History data of the last 25 charges-Indikator_09,00000000 ,
IDE13782-ENG279495,History data of the last 25 charges-Indikator_10,00000000 ,
IDE13782-ENG279496,History data of the last 25 charges-Indikator_11,00000001 ,
IDE13782-ENG279497,History data of the last 25 charges-Indikator_12,00000000 ,
IDE13782-ENG279498,History data of the last 25 charges-Indikator_13,00000000 ,
IDE13782-ENG279499,History data of the last 25 charges-Indikator_14,00000000 ,
IDE13782-ENG279500,History data of the last 25 charges-Indikator_15,00000000 ,
IDE13782-ENG279501,History data of the last 25 charges-Indikator_16,00000000 ,
IDE13782-ENG279502,History data of the last 25 charges-Indikator_17,00000000 ,
IDE13782-ENG279503,History data of the last 25 charges-Indikator_18,00000000 ,
IDE13782-ENG279504,History data of the last 25 charges-Indikator_19,00000000 ,
IDE13782-ENG279505,History data of the last 25 charges-Indikator_20,00000000 ,
IDE13782-ENG279506,History data of the last 25 charges-Indikator_21,00000000 ,
IDE13782-ENG279507,History data of the last 25 charges-Indikator_22,00000000 ,
IDE13782-ENG279508,History data of the last 25 charges-Indikator_23,00000000 ,
IDE13782-ENG279509,History data of the last 25 charges-Indikator_24,00000000 ,
IDE13782-ENG279510,History data of the last 25 charges-Indikator_25,00000000 ,
IDE13782-ENG279513,History data of the last 25 charges-Kein Derating,not active,
IDE13782-ENG279513,History data of the last 25 charges-Kein Derating,active,
IDE13782-ENG255832,History data of the last 25 charges-Ladeanlauf Zustaende,0,
IDE13782-ENG255832,History data of the last 25 charges-Ladeanlauf Zustaende,48,
IDE13782-ENG255832,History data of the last 25 charges-Ladeanlauf Zustaende,128,
IDE13782-ENG255832,History data of the last 25 charges-Ladeanlauf Zustaende,176,
IDE13782-ENG255833,History data of the last 25 charges-Ladedauer zu Ladebeginn,0, min
IDE13782-ENG255833,History data of the last 25 charges-Ladedauer zu Ladebeginn,3000, min
IDE13782-ENG255834,History data of the last 25 charges-Ladedauer_HVL_HDS,140, min
IDE13782-ENG255834,History data of the last 25 charges-Ladedauer_HVL_HDS,0, min
IDE13782-ENG255834,History data of the last 25 charges-Ladedauer_HVL_HDS,231, min
IDE13782-ENG255834,History data of the last 25 charges-Ladedauer_HVL_HDS,328, min
IDE13782-ENG255834,History data of the last 25 charges-Ladedauer_HVL_HDS,87, min
IDE13782-ENG255835,History data of the last 25 charges-Ladedosen Temperatur max,255,
IDE13782-ENG255835,History data of the last 25 charges-Ladedosen Temperatur max,0,
IDE13782-ENG255836,History data of the last 25 charges-Ladestrategie,15,
IDE13782-ENG255836,History data of the last 25 charges-Ladestrategie,0,
IDE13782-ENG279526,History data of the last 25 charges-Reserve 1,not active,
IDE13782-ENG279268,History data of the last 25 charges-Reserve 2,not active,
IDE13782-ENG160434,History data of the last 25 charges-soc_end,57, %
IDE13782-ENG160434,History data of the last 25 charges-soc_end,0, %
IDE13782-ENG160434,History data of the last 25 charges-soc_end,77, %
IDE13782-ENG160434,History data of the last 25 charges-soc_end,100, %
IDE13782-ENG160434,History data of the last 25 charges-soc_end,20, %
IDE13782-ENG160434,History data of the last 25 charges-soc_end,87, %
IDE13782-ENG160434,History data of the last 25 charges-soc_end,27, %
IDE13782-ENG160433,History data of the last 25 charges-soc_start,77, %
IDE13782-ENG160433,History data of the last 25 charges-soc_start,0, %
IDE13782-ENG160433,History data of the last 25 charges-soc_start,127, %
IDE13782-ENG160433,History data of the last 25 charges-soc_start,11, %
IDE13782-ENG160433,History data of the last 25 charges-soc_start,57, %
IDE13782-ENG160433,History data of the last 25 charges-soc_start,20, %
IDE13782-ENG256324,History data of the last 25 charges-SOC_Ziel,0, %
IDE13782-ENG256324,History data of the last 25 charges-SOC_Ziel,100, %
IDE13782-ENG256395,History data of the last 25 charges-Status Grundladen,Sofortladen Standby,
IDE13782-ENG279538,History data of the last 25 charges-stream,19 2C A5 68 00 02 6C D0 00 00 00 0F 00 00 0F F0 00 00 00 00 00 00 00 00,
IDE13782-ENG279538,History data of the last 25 charges-stream,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE13782-ENG279538,History data of the last 25 charges-stream,19 2C A5 64 02 32 6E 48 32 0D 00 0F 0D 20 0F F0 BB 80 00 03 00 00 00 00,
IDE13782-ENG279538,History data of the last 25 charges-stream,19 2A AE 4C 01 5C 59 B8 32 09 00 0F 2A 80 0F F0 BB 80 00 0B 00 00 00 00,
IDE13782-ENG279538,History data of the last 25 charges-stream,19 2C 23 A8 00 00 A1 40 00 00 00 0F 00 00 0F F0 00 00 00 00 00 00 00 00,
IDE13782-ENG279538,History data of the last 25 charges-stream,19 37 A0 28 00 01 CB 90 00 00 00 0F 00 00 0F F0 00 00 00 00 00 00 00 00,
IDE13782-ENG279538,History data of the last 25 charges-stream,80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE13782-ENG279538,History data of the last 25 charges-stream,19 2C BE 78 00 03 FE 40 00 05 00 0F 00 20 0F F0 00 00 00 08 00 00 00 00,
IDE13782-ENG279538,History data of the last 25 charges-stream,19 2C 23 B4 05 20 A4 D8 32 08 00 0F 26 80 0F F0 BB 80 00 03 00 00 00 00,
IDE13782-ENG279538,History data of the last 25 charges-stream,19 2C C0 D8 00 03 FE 40 00 05 00 0F 00 00 0F F0 00 00 00 00 00 00 00 00,
IDE13782-ENG279538,History data of the last 25 charges-stream,19 37 A0 34 03 9D CD 78 32 09 00 0F 15 C0 0F F0 BB 80 00 03 00 00 00 00,
IDE13782-ENG279538,History data of the last 25 charges-stream,19 2C B6 F8 00 03 FE 40 00 05 00 0F 00 20 0F F0 00 00 00 08 00 00 00 00,
IDE13782-ENG256532,History data of the last 25 charges-Tracking DTC (10),not active,
IDE13782-ENG256533,History data of the last 25 charges-Tracking DTC (11),not active,
IDE13782-ENG256534,History data of the last 25 charges-Tracking DTC (12),not active,
IDE13782-ENG256535,History data of the last 25 charges-Tracking DTC (13),not active,
IDE13782-ENG256546,History data of the last 25 charges-Tracking DTC (9),not active,
IDE13782-ENG256721,History data of the last 25 charges-Zaehler_Bit,stored,
IDE13782-ENG256721,History data of the last 25 charges-Zaehler_Bit,Current,
IDE13835-MAS17093,VKMS: relevant VIN number for last data supply-Status of vehicle identification number,valid,
IDE13835-MAS17094,VKMS: relevant VIN number for last data supply-Vehicle identification number output,WVG5WVEB2SH017765,
IDE13836-MAS17095,VKMS: adaption counter-Adaptation counter status,valid,
IDE13836-MAS17096,VKMS: adaption counter-Adaptation counter output,00 01,
IDE13837-MAS17097,VKMS: overview missing keys-Key status,valid,
IDE13837-MAS17099,VKMS: overview missing keys-Number of missing keys,0,
IDE13837-MAS17100,VKMS: overview missing keys-Missing key,00 00,
IDE13842-MAS17101,VKMS: retrieval of information list of the stored VKMS keys-VKMS key status,valid,
IDE13842-MAS17103,VKMS: retrieval of information list of the stored VKMS keys-VKMS type ID,00 15,
IDE13842-MAS17104,VKMS: retrieval of information list of the stored VKMS keys-VKMS type adaptation counter,00 01,
IDE13842-MAS18318,VKMS: retrieval of information list of the stored VKMS keys-Number of VKMS keys,55,
IDE13845,Production mode status,not active,
IDE13873-MAS01159,Ethernet status electrical error-Version number,01,
IDE13873-MAS20288,Ethernet status electrical error-Number of status electrical error,2,
IDE13873,Ethernet status electrical error,|Ethernet interface,|2
IDE13956-IDE01715,Key position replication: input signals-Status terminal S,On,
IDE13956-IDE80258,Key position replication: input signals-Immobilizer status,Electronic steering locking device installed,
IDE13956-MAS01493,Key position replication: input signals-Engine running,active,
IDE13956-MAS03679,Key position replication: input signals-Terminal 15 status,On,
IDE13956-MAS05104,Key position replication: input signals-Driver request: start engine,not active,
IDE13956-MAS06711,Key position replication: input signals-Terminal release,not active,
IDE13956-MAS07719,Key position replication: input signals-Terminal 50 status,OFF,
IDE13956-MAS08136,Key position replication: input signals-Enabling Steering Column Lock,Condition not met,
IDE13956,Key position replication: input signals,0, s
IDE13956-ENG255532,Key position replication: input signals-clampcoordinator_approval,OFF,
IDE13956-ENG281503,Key position replication: input signals-clampcoordinator_diagnostic_approval,OFF,
IDE13956-ENG255625,Key position replication: input signals-diag_trigger_clampcoordinator_intern,OFF,
IDE13956-ENG281580,Key position replication: input signals-Number_Of_Start_Requests_In_Terminal15_Cycle,0,
IDE13956-ENG129033,Key position replication: input signals-s_anf_klemmenfreigabe_wfs,not requested,
IDE13956-ENG126972,Key position replication: input signals-s_klemmenfreigabe_wfs,No enabling,
IDE13956-ENG281606,Key position replication: input signals-Terminal15_deactivation_via_Timeout,not active,
IDE13956-ENG129036,Key position replication: input signals-To_block_terminal_upshift,not active,
IDE13956-ENG256549,Key position replication: input signals-trigger_clampcoordinator_intern_for_ignition_off,OFF,
IDE13956-ENG256550,Key position replication: input signals-trigger_clampkoordinator_intern_for_ignition_on,OFF,
IDE13956-ENG129038,Key position replication: input signals-Valid_time_control_section_diagnostics,0, s
IDE14151-MAS13098,Route-based range calculation-Power drawn by thermal management,0, W
IDE14151-MAS14375,Route-based range calculation-Cycle counter,6,
IDE14151-MAS17899,Route-based range calculation-Route-based range calculation status,not active,
IDE14151-MAS17900,Route-based range calculation-Classified consumption,16.3, kWh/100 km
IDE14151-MAS17901,Route-based range calculation-Classified consumption 2,12.2, kWh/100 km
IDE14151-MAS17902,Route-based range calculation-Classified consumption 3,14.6, kWh/100 km
IDE14151-MAS17903,Route-based range calculation-Classified consumption 4,17.5, kWh/100 km
IDE14151-MAS17904,Route-based range calculation-Classified consumption 5,17.1, kWh/100 km
IDE14151-MAS17905,Route-based range calculation-Classified consumption 6,17.1, kWh/100 km
IDE14151-MAS17906,Route-based range calculation-Classified consumption 7,18.1, kWh/100 km
IDE14151-MAS17907,Route-based range calculation-Classified consumption 8,20.2, kWh/100 km
IDE14151-MAS17908,Route-based range calculation-Classified consumption 9,20.9, kWh/100 km
IDE14151-MAS17909,Route-based range calculation-Classified consumption 10,20.9, kWh/100 km
IDE14151-MAS17910,Route-based range calculation-Calculated consumption,18.6, kWh/100 km
IDE14151-MAS17911,Route-based range calculation-Calculated consumption 2,14.9, kWh/100 km
IDE14151-MAS17912,Route-based range calculation-Calculated consumption 3,18.9, kWh/100 km
IDE14151-MAS17913,Route-based range calculation-Calculated consumption 4,10.7, kWh/100 km
IDE14151-MAS17914,Route-based range calculation-Calculated consumption 5,17.9, kWh/100 km
IDE14151-MAS17915,Route-based range calculation-Calculated consumption 6,18.5, kWh/100 km
IDE14151-MAS17916,Route-based range calculation-Calculated consumption 7,18.5, kWh/100 km
IDE14151-MAS17917,Route-based range calculation-Calculated consumption 8,18.5, kWh/100 km
IDE14151-MAS17918,Route-based range calculation-Calculated consumption 9,18.5, kWh/100 km
IDE14151-MAS17919,Route-based range calculation-Calculated consumption 10,20.0, kWh/100 km
IDE14151-MAS17921,Route-based range calculation-Comfort consumers power consumption,0, W
IDE14151-MAS17922,Route-based range calculation-Route-based range raw value with comfort consumers,0,
IDE14151-MAS17923,Route-based range calculation-Route-based range raw value without comfort consumers,0,
IDE14151-MAS17924,Route-based range calculation-Residual energy content without comfort consumers,0.00,
IDE14151-MAS17925,Route-based range calculation-Residual energy content with comfort consumers,0.00,
IDE14151-MAS17926,Route-based range calculation-Type of route,OFF,
IDE14151-MAS17927,Route-based range calculation-Range reference,65533,
IDE14151-MAS17928,Route-based range calculation-Maximum range,65533,
IDE14151-MAS17929,Route-based range calculation-Total coverage,2046,
IDE14151-MAS17930,Route-based range calculation-Range from destination,2046,
IDE14151-MAS17931,Route-based range calculation-Route-based range,2046,
IDE14151-MAS17932,Route-based range calculation-Recalculation status,not performed,
IDE14169-IDE08660,Autonomous recharging-Recharging the NV battery,8,
IDE14169-MAS02832,Autonomous recharging-Malfunction status,Malfunction,
IDE14169-MAS07409,Autonomous recharging-Status automatic recharging of low-voltage battery,possible,
IDE14169-ENG334094,Autonomous recharging-Comfort_limits,Not reached,
IDE14169-ENG334226,Autonomous recharging-HV_off_timer_status,Enabled,
IDE14169-ENG334227,Autonomous recharging-HV_power_supply_status,No malfunction,
IDE14169-ENG98676,Autonomous recharging-Init,not active,
IDE14169-ENG334254,Autonomous recharging-Limits_of_hv_battery,Not reached,
IDE14219,Component protection challenge,AD 1B 01 14,
IDE14221-MAS06854,FAZIT identification component protection checksum-Version,81,
IDE14221-MAS06855,FAZIT identification component protection checksum-Test sum,52 D9 A1 4D,
IDE14236-MAS00106,Authentic time: last confirmed time-Year,2025,
IDE14236-MAS00107,Authentic time: last confirmed time-Month,3,
IDE14236-MAS00108,Authentic time: last confirmed time-Day,25,
IDE14236-MAS00109,Authentic time: last confirmed time-Hours,16,
IDE14236-MAS00110,Authentic time: last confirmed time-Minutes,13,
IDE14236-MAS00111,Authentic time: last confirmed time-Seconds,44,
IDE14237-MAS00106,Authentic time: actual time-Year,2025,
IDE14237-MAS00107,Authentic time: actual time-Month,3,
IDE14237-MAS00108,Authentic time: actual time-Day,25,
IDE14237-MAS00109,Authentic time: actual time-Hours,16,
IDE14237-MAS00110,Authentic time: actual time-Minutes,14,
IDE14237-MAS00111,Authentic time: actual time-Seconds,33,
IDE14262-MAS12984,12V lead battery test pulse: high-voltage energy management-Reason for rejection,7,
IDE14262-MAS21182,12V lead battery test pulse: high-voltage energy management-Bad counter,233,
IDE14262-MAS22196,12V lead battery test pulse: high-voltage energy management-Test pulse prompt: low-voltage EM to high-voltage EM,Initialization,
IDE14262-MAS22197,12V lead battery test pulse: high-voltage energy management-Test pulse activation: high-voltage EM to low-voltage EM,No enabling,
IDE14265,Battery display: source of initiation,0,
IDE14268-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 10-MAC address,|MAC address|02 7D FA 00 10 02|,
IDE14269-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 11-MAC address,|MAC address|02 7D FA 00 10 02|,
IDE14271-MAS14856,IP network: VLANs of Ethernet switch ports branch 10-VLAN,|VLAN|11|,
IDE14272-MAS14856,IP network: VLANs of Ethernet switch ports branch 11-VLAN,|VLAN|4|,
IDE14334,Authentic time: number of maximum deviation exceeded,0,
IDE14492-MAS18388,Secure Onboard Communication: verification failed-Failed verification status,valid,
IDE14492-MAS18389,Secure Onboard Communication: verification failed-Number of failed verifications,2,
IDE14492-MAS18390,Secure Onboard Communication: verification failed-Verification failed,00 4B,
IDE14493-MAS18360,Secure Onboard Communication: signatures failed-failed signature creation,00 00,
IDE14493-MAS18391,Secure Onboard Communication: signatures failed-Failed signature creation status,valid,
IDE14493-MAS18392,Secure Onboard Communication: signatures failed-Number of failed signature creations,0,
IDE14494-MAS18361,Secure Onboard Communication: general information-Status of general information,valid,
IDE14494-MAS18362,Secure Onboard Communication: general information-ECU function,SOC time server,
IDE14494-MAS18367,Secure Onboard Communication: general information-Main function call period,5,
IDE14495-MAS18369,Secure Onboard Communication: information about internal time-Internal SOC time status,valid,
IDE14495-MAS18370,Secure Onboard Communication: information about internal time-Validity of internal SOC time,Valid SOC time,
IDE14495-MAS18374,Secure Onboard Communication: information about internal time-Internal time,00 0D C0 1D 12 CA 62 79,
IDE14495-MAS18375,Secure Onboard Communication: information about internal time-Jitter test status,Jitter not exceeded,
IDE14496-MAS18378,Secure Onboard Communication: Freshness Values information-Freshness status,valid,
IDE14496-MAS18379,Secure Onboard Communication: Freshness Values information-Number of Freshness IDs,41,
IDE14496-MAS18380,Secure Onboard Communication: Freshness Values information-SOC PDU ID to which this freshness information is assigned,00 44,
IDE14496-MAS18381,Secure Onboard Communication: Freshness Values information-Freshness Value query status,Freshness Value was not queried,
IDE14496-MAS18384,Secure Onboard Communication: Freshness Values information-SOC time of last successful verification,FF FF FF FF FF FF FF FF,
IDE14496-MAS18385,Secure Onboard Communication: Freshness Values information-Current value of message counter,255,
IDE14496-MAS18386,Secure Onboard Communication: Freshness Values information-Bitfield with used counter values,11111111 11111111 ,
IDE14497-MAS17099,Secure Onboard Communication: missing key-Number of missing keys,0,
IDE14497-MAS17100,Secure Onboard Communication: missing key-Missing key,00 00,
IDE14497-MAS18387,Secure Onboard Communication: missing key-Missing key status,valid,
IDE14665-MAS03834,Control unit for driving and comfort functions: status-Emergency signal flashing,Not operated,
IDE14665-MAS18691,Control unit for driving and comfort functions: status-Emergency signal flashing: function lighting,OFF,
IDE14771,EgoMaster: input data,,
IDE14959,Tailgate opening: reason for non-availability,Terminal 15 active,
IDE14993-IDE00007,Software composition list identification data-VW/Audi part number,000000000  ,
IDE14993-IDE00013,Software composition list identification data-System designation,Comp Prot    ,
IDE14993-MAS03962,Software composition list identification data-Primary version number,0003,
IDE14993-MAS03963,Software composition list identification data-Secondary version number,0007,
IDE14993-MAS15135,Software composition list identification data-Supplier ID,00 01,
IDE14993-MAS19447,Software composition list identification data-Versioning,01,
IDE14993-MAS20341,Software composition list identification data-Number of software composition,00 33,
IDE14993-MAS21065,Software composition list identification data-Software Composition ID,00 00 00 00 00 00 00 14,
IDE14993-MAS21066,Software composition list identification data-Patch version number,0001,
IDE15047-MAS00106,UTC time (universal time)-Year,2025,
IDE15047-MAS00107,UTC time (universal time)-Month,3,
IDE15047-MAS00108,UTC time (universal time)-Day,25,
IDE15047-MAS00109,UTC time (universal time)-Hours,16,
IDE15047-MAS00110,UTC time (universal time)-Minutes,14,
IDE15047-MAS00111,UTC time (universal time)-Seconds,42,
IDE15333-MAS12519,EgoMaster: display speed calculation-Pre-run,0.00, %
IDE15333-MAS21326,EgoMaster: display speed calculation-Tire size data set,2282, mm
IDE15333-MAS21751,EgoMaster: display speed calculation-Data set for tire circumference: status,0,
IDE15333-MAS21752,EgoMaster: display speed calculation-Display speed,0, km/h
IDE15333-MAS21753,EgoMaster: display speed calculation-Display speed: status,1,
IDE15333-MAS21754,EgoMaster: display speed calculation-Front left wheel speed: status,0,
IDE15333-MAS21755,EgoMaster: display speed calculation-Right front wheel speed: status,0,
IDE15333-MAS21756,EgoMaster: display speed calculation-Rear left wheel speed: status,0,
IDE15333-MAS21757,EgoMaster: display speed calculation-Right rear wheel speed: status,0,
IDE15333-MAS21758,EgoMaster: display speed calculation-Tire circumference: ESP data,2282, mm
IDE15333-MAS21759,EgoMaster: display speed calculation-ESP data for tire circumference: status,0,
IDE15406-MAS03001,Tire circumference estimator-Mode,0,
IDE15406-MAS20916,Tire circumference estimator-Speed range 4: factor,1.00,
IDE15406-MAS20917,Tire circumference estimator-Speed range 3: status,0, %
IDE15406-MAS20918,Tire circumference estimator-Speed range 2: factor,1.00,
IDE15406-MAS20919,Tire circumference estimator-Speed range 1: factor,1.00,
IDE15406-MAS20921,Tire circumference estimator-Speed range 3: factor,1.00,
IDE15406-MAS20922,Tire circumference estimator-Speed range 5: factor,1.00,
IDE15406-MAS20923,Tire circumference estimator-Speed range 6: factor,1.00,
IDE15406-MAS20924,Tire circumference estimator-Speed range 0: factor,1.00,
IDE15406-MAS20925,Tire circumference estimator-Speed range 7: factor,1.00,
IDE15406-MAS20926,Tire circumference estimator-Speed range 7: status,0, %
IDE15406-MAS20927,Tire circumference estimator-Speed range 1: lower limit,34, km/h
IDE15406-MAS20928,Tire circumference estimator-Speed range 5: lower limit,129, km/h
IDE15406-MAS20929,Tire circumference estimator-Speed range 3: lower limit,90, km/h
IDE15406-MAS20930,Tire circumference estimator-Speed range 2: lower limit,60, km/h
IDE15406-MAS20931,Tire circumference estimator-Speed range 4: lower limit,110, km/h
IDE15406-MAS20932,Tire circumference estimator-Speed range 7: lower limit,200, km/h
IDE15406-MAS20933,Tire circumference estimator-Speed range 0: lower limit,0, km/h
IDE15406-MAS20934,Tire circumference estimator-Speed range 6: status,0, %
IDE15406-MAS20935,Tire circumference estimator-Speed range 6: lower limit,159, km/h
IDE15406-MAS20936,Tire circumference estimator-Speed range 5: status,0, %
IDE15406-MAS20937,Tire circumference estimator-Speed range 4: status,0, %
IDE15406-MAS20938,Tire circumference estimator-Speed synchronization: status,1,
IDE15406-MAS20939,Tire circumference estimator-Speed range 2: status,0, %
IDE15406-MAS20940,Tire circumference estimator-Speed range 1: status,0, %
IDE15406-MAS20948,Tire circumference estimator-Speed range 0: status,0, %
IDE15406-MAS20970,Tire circumference estimator-Terminal cycle estimator: status,0,
IDE15406-MAS20971,Tire circumference estimator-Tolerance adjustment: status,0,
IDE15406-MAS21746,Tire circumference estimator-Geometric precision status,0,
IDE15406-MAS21747,Tire circumference estimator-Satellite number: status,0,
IDE15406-MAS21748,Tire circumference estimator-GPS Position: Status,0,
IDE15406-MAS21749,Tire circumference estimator-Navigation speed: status,0,
IDE15406-MAS21750,Tire circumference estimator-Navigation speed,0, km/h
IDE15471,High-voltage charging manager: status of charging plan monitoring,not active,
IDE15472,High-voltage charging manager: energy deviation from charging plan,0.00, kWh
IDE15482-MAS14856,IP network: VLANs of Ethernet switch ports branch 12-VLAN,|VLAN|3|,
IDE15483-MAS14856,IP network: VLANs of Ethernet switch ports branch 13-VLAN,Write only channel,
IDE15484-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 12-MAC address,|MAC address|02 7D FA 00 10 02|,
IDE15485-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 13-MAC address,|MAC address|02 7D FA 00 10 03|,
IDE15499-MAS13088,High-voltage charging manager: active charging profile-Preconditioning of the interior,not activated,
IDE15499-MAS20823,High-voltage charging manager: active charging profile-Target SoC,1, %
IDE15499-MAS20824,High-voltage charging manager: active charging profile-Minimum SoC,Initialization,
IDE15499-MAS20825,High-voltage charging manager: active charging profile-Charging current reduction,Initialization,
IDE15499-MAS20826,High-voltage charging manager: active charging profile-Domestic current usage,not activated,
IDE15502-MAS03084,High-voltage charging manager: target current presetting-Phase 1,0.00, A
IDE15502-MAS03085,High-voltage charging manager: target current presetting-Phase 2,0.00, A
IDE15502-MAS03086,High-voltage charging manager: target current presetting-Phase 3,0.00, A
IDE15503,High-voltage charging manager: use of target current presetting,not activated,
IDE15504,High-voltage charging manager: target performance of expanded charging function,6.1965e+006, W
IDE15505,High-voltage charging manager: charging strategy of expanded charging function,Unknown (12)
IDE15506,High-voltage charging manager: status of extended charging functions,not active,
IDE15513-ENG279311,High-voltage charging manager: plug type and plug status-Byte to EOP,01 02 01 00 06 0F 00 04 00 00,
IDE15521,High-voltage charging manager: charging process visualization,OFF,
IDE15522-MAS21677,DC charging: charging station statistics for charge process-DC charging: total energy turnover supply,0.00, kWh
IDE15522-MAS21678,DC charging: charging station statistics for charge process-DC charging: total charging time,0, min
IDE15523-MAS21679,DC charging: vehicle statistics for charge process-DC charging: high-voltage battery maximum cell temperature,0, °C
IDE15523-MAS21680,DC charging: vehicle statistics for charge process-DC charging: high-voltage battery minimum cell temperature,0, °C
IDE15523-MAS21681,DC charging: vehicle statistics for charge process-DC charging: high-voltage battery maximum cell voltage,0.00, V
IDE15523-MAS21682,DC charging: vehicle statistics for charge process-DC charging: high-voltage battery minimum cell voltage,0.00, V
IDE15524-MAS07479,DC charging: maximum output of charging station-Max. charge voltage DC charge station,0.00, V
IDE15524-MAS21408,DC charging: maximum output of charging station-DC charging: maximum current charging station,-400, A
IDE15524-MAS21409,DC charging: maximum output of charging station-DC charging: minimum charging station voltage,0.00, V
IDE15524-MAS21410,DC charging: maximum output of charging station-DC charging: minimum current charging station,-400, A
IDE15525-ENG279311,DC charging: request parameters for high-voltage battery-Byte to EOP,00 00 0F A0 02,
IDE15526-IDE08969,DC charging: high-voltage battery charging parameters-HV battery: available capacity,0.00, kWh
IDE15526-MAS09113,DC charging: high-voltage battery charging parameters-Maximum temperature,0, °C
IDE15526-MAS21681,DC charging: high-voltage battery charging parameters-DC charging: high-voltage battery maximum cell voltage,0.00, V
IDE15527,DC charging: high-voltage battery status,normal,
IDE15527,DC charging: high-voltage battery status,0, °C
IDE15527,DC charging: high-voltage battery status,tbd,
IDE15528-IDE06954,DC charging: charging station status-Actual HV charge current,-400, A
IDE15528-IDE13628,DC charging: charging station status-HV charging voltage: current value,0.00, V
IDE15528-IDE15530,DC charging: charging station status-DC charging: charging station readiness,Pause,
IDE15528-MAS21678,DC charging: charging station status-DC charging: total charging time,0, min
IDE15529,DC charging: charging status of high-voltage battery,0,
IDE15529,DC charging: charging status of high-voltage battery,0.00, V
IDE15529,DC charging: charging status of high-voltage battery,0, min
IDE15529,DC charging: charging status of high-voltage battery,-400, A
IDE15530,DC charging: charging station readiness,Not ready,
IDE15531-MAS21360,Activation of tailgate locking-Charge socket A: loading hatch request status,Initialization,
IDE15531-MAS21361,Activation of tailgate locking-Charge socket B: loading hatch request status,Initialization,
IDE15532-MAS21358,Activation of charger plug lock-Charge socket A: charging connector requirement status,no request,
IDE15532-MAS21359,Activation of charger plug lock-Charge socket B: charging connector request status,no request,
IDE15533,DC charging: controlled by charging station,not locked,
IDE15533,DC charging: controlled by charging station,normal_operating_status,
IDE15533,DC charging: controlled by charging station,no request,
IDE15533,DC charging: controlled by charging station,Not permitted,
IDE15533,DC charging: controlled by charging station,active,
IDE15536,DC charging: vehicle charging readiness,tbd,
IDE15537-ENG279311,DC charging: charging station detection-Byte to EOP,00 00 00 00 00,
IDE15538-ENG279311,DC charging: parameters for vehicle charging components-Byte to EOP,00 00 00 00,
IDE15539-ENG279311,DC charging: charging station protocol version-Byte to EOP,00 00 00,
IDE15540,DC charging: maximum vehicle charging voltage,0.00, V
IDE15541,DC charging: control module internal charging process control,no request,
IDE15541,DC charging: control module internal charging process control,Standby,
IDE15541,DC charging: control module internal charging process control,0.00, A
IDE15542,DC charging: charging process control across control modules,Norm_from_Year_2011,
IDE15542,DC charging: charging process control across control modules,no request,
IDE15542,DC charging: charging process control across control modules,not detected,
IDE15542,DC charging: charging process control across control modules,Send_cyclic_message_fast_cycle,
IDE15543,DC charging: charging station status (Chademo),Standby,
IDE15543,DC charging: charging station status (Chademo),tbd,
IDE15545,DC charging: vehicle status,not operational,
IDE15545,DC charging: vehicle status,Selector lever in position P,
IDE15545,DC charging: vehicle status,Open,
IDE15550,DC charging: vehicle control,no request,
IDE15550,DC charging: vehicle control,tbd,
IDE15550,DC charging: vehicle control,0, A
IDE15550,DC charging: vehicle control,not requested,
IDE15550,DC charging: vehicle control,Standby,
IDE15551-ENG279311,Power line communication: charging station status-Byte to EOP,00 00 00 00 00 3E 00 0E FF FE 03 03 03 03 FE 03 FE 03 FE 00 03 FE 03 FE 03 FE,
IDE15552,Power line communication: vehicle status,no warning,
IDE15552,Power line communication: vehicle status,no request,
IDE15552,Power line communication: vehicle status,No_connection,
IDE15552,Power line communication: vehicle status,No malfunction,
IDE15552,Power line communication: vehicle status,not operational,
IDE15553,Power line communication: transfer and authentication,Contract not active,
IDE15553,Power line communication: transfer and authentication,Do_not_use_transport_layer_security,
IDE15554,Power line communication: process and manipulated variables,no request,
IDE15554,Power line communication: process and manipulated variables,0.00, A
IDE15554,Power line communication: process and manipulated variables,1000.00, V
IDE15555,Power line communication boundary conditions,400.00, A
IDE15555,Power line communication boundary conditions,1.50, A
IDE15555,Power line communication boundary conditions,1000.00, V
IDE15555,Power line communication boundary conditions,Initialization,
IDE15555,Power line communication boundary conditions,447.00, V
IDE15555,Power line communication boundary conditions,500.00, A
IDE15555,Power line communication boundary conditions,0.00, A
IDE15556,Power line communication: communication and process control,not specified,
IDE15556,Power line communication: communication and process control,no request,
IDE15557,Charger input: maximum charging current permitted per phase,0.00, A
IDE15558,Charger output: maximum charging capacity: and maximum charge current,145400, W
IDE15558,Charger output: maximum charging capacity: and maximum charge current,371.60, A
IDE15559-ENG279311,Actual voltage: current: and charging status of high-voltage battery-Byte to EOP,06 72 3F 9E 05 E3,
IDE15561,Calculated charge time remaining,0, min
IDE15562,Status of charge time calculation,Initialization,
IDE15563,Calculated charging speed,0,
IDE15563,Calculated charging speed,0, km
IDE15563,Calculated charging speed,kilometers_per_minute,
IDE15564,Calculated total charging time for one charge process,0.00, min
IDE15566,Deviation from actual calculated charging time,Unknown (0)
IDE15567,Calculated charge time based on temperature,0.00, min
IDE15568,Average total charging time over multiple values,0.00, min
IDE15570,DC charging: charge process control,no request,
IDE15571-ENG279311,Charge process status information-Byte to EOP,02 00 00 0F A0,
IDE15572,AC charging: adjacent phase voltage on charger rectifier,not detected,
IDE15574,Activation of charger rectifier,0.00, A
IDE15574,Activation of charger rectifier,447, V
IDE15574,Activation of charger rectifier,Standby,
IDE15575,Requested charging type and charge initiation,No enabling,
IDE15575,Requested charging type and charge initiation,not requested,
IDE15576,Charging subsystem status information,0, %
IDE15576,Charging subsystem status information,77.00, %
IDE15576,Charging subsystem status information,no request,
IDE15576,Charging subsystem status information,0, min
IDE15576,Charging subsystem status information,Standby,
IDE15577,Charging initiated by high-voltage coordinator,Ready_for_charging,
IDE15579,High-voltage charging manager: hold management status information,No malfunction,
IDE15579,High-voltage charging manager: hold management status information,No function active,
IDE15580,High-voltage charging management: accidental rolling preventing request,no request,
IDE15580,High-voltage charging management: accidental rolling preventing request,Leave standstill,
IDE15581,Control pilot activation,Close,
IDE15581,Control pilot activation,Open,
IDE15582-ENG279311,Charging readiness control: status information-Byte to EOP,00 01 01 07 00 FF 00,
IDE15583,Charging mode detected by control pilot evaluation,Unknown,
IDE15584-ENG279311,Control pilot signal evaluation-Byte to EOP,01 08,
IDE15585-MAS02949,Control Pilot charging socket A: input variables-Frequency,not detected,
IDE15585-MAS02952,Control Pilot charging socket A: input variables-Control voltage,0.00, V
IDE15585-MAS03873,Control Pilot charging socket A: input variables-Duty cycle,0.00, %
IDE15586-MAS02949,Control Pilot charging socket B: input variables-Frequency,880, Hz
IDE15586-MAS02952,Control Pilot charging socket B: input variables-Control voltage,Initialization,
IDE15586-MAS03873,Control Pilot charging socket B: input variables-Duty cycle,Initialization,
IDE15587,Status of charging plug lock,unlocked,
IDE15587,Status of charging plug lock,activated,
IDE15587,Status of charging plug lock,not completed,
IDE15588-MAS21352,Connector lock: operating status: door key cylinder-Central Locking System: lock triggered by door lock,Not operated,
IDE15588-MAS21353,Connector lock: operating status: door key cylinder-Central Locking System: unlock request triggered by door lock,Not operated,
IDE15589-MAS21441,Connector lock: operating status: radio key signal-Central Locking System: unlock triggered by remote key,Not operated,
IDE15589-MAS21442,Connector lock: operating status: radio key signal-Central Locking System: lock triggered by remote key,Not operated,
IDE15750,Visible status in charging plan processing,not active,
IDE15752,Charging requirement for expanded charging functions of basic charging,Unknown (4)
IDE15989-ENG279311,High voltage charging manager: next charging start-Byte to EOP,0D 09 E9 07 03 19,
IDE16497-MAS27312,12V vehicle electrical system activation-12-V vehicle electrical system information,0,
IDE16497-MAS27313,12V vehicle electrical system activation-12-V Li-Ion cooling information,0,
IDE16497-MAS27314,12V vehicle electrical system activation-12-V consumer information,0,
IDE16936-IDE01834,Low-voltage energy management: key figures of the lead battery-Battery voltage,14.93, V
IDE16936-IDE01836,Low-voltage energy management: key figures of the lead battery-Battery current,4, A
IDE16936-IDE12072,Low-voltage energy management: key figures of the lead battery-Warning displays,no warning,
IDE16936-IDE17292,Low-voltage energy management: key figures of the lead battery-Charge indicator,46.290,
IDE16936-MAS04059,Low-voltage energy management: key figures of the lead battery-Battery temperature,15, °C
IDE16936-MAS05030,Low-voltage energy management: key figures of the lead battery-Resistance,4.2,
IDE16936-MAS23197,Low-voltage energy management: key figures of the lead battery-Reason for warning display,0,
IDE16936-MAS23866,Low-voltage energy management: key figures of the lead battery-Limit resistance,8.6,
IDE16936-MAS23867,Low-voltage energy management: key figures of the lead battery-Escalation counter for battery alerts,0,
IDE16936-MAS26492,Low-voltage energy management: key figures of the lead battery-Duration of vehicle electrical system warning,0, H
IDE19082-MAS04649,Localization information from connected mobile end devices-Cell 1,00000000 ,
IDE19082-MAS04650,Localization information from connected mobile end devices-Cell 2,00000000 ,
IDE19082-MAS04651,Localization information from connected mobile end devices-Cell 3,00000000 ,
IDE19082-MAS04652,Localization information from connected mobile end devices-Cell 4,00000000 ,
IDE19082-MAS04653,Localization information from connected mobile end devices-Cell 5,00000000 ,
IDE19082-MAS04654,Localization information from connected mobile end devices-Cell 6,00000000 ,
IDE19082-MAS04655,Localization information from connected mobile end devices-Cell 7,00000000 ,
IDE19082-MAS04656,Localization information from connected mobile end devices-Cell 8,00000000 ,
IDE19082-MAS04657,Localization information from connected mobile end devices-Cell 9,00000000 ,
IDE19082-MAS04658,Localization information from connected mobile end devices-Cell 10,00000000 ,
IDE19082-MAS04659,Localization information from connected mobile end devices-Cell 11,00000000 ,
IDE19082-MAS04660,Localization information from connected mobile end devices-Cell 12,00000000 ,
IDE19082-MAS04661,Localization information from connected mobile end devices-Cell 13,00000000 ,
IDE19082-MAS04662,Localization information from connected mobile end devices-Cell 14,00000000 ,
IDE19082-MAS04663,Localization information from connected mobile end devices-Cell 15,00000000 ,
IDE19082-MAS04664,Localization information from connected mobile end devices-Cell 16,00000000 ,
IDE19082-MAS04665,Localization information from connected mobile end devices-Cell 17,00000000 ,
IDE19082-MAS04666,Localization information from connected mobile end devices-Cell 18,00000000 ,
IDE19082-MAS04667,Localization information from connected mobile end devices-Cell 19,00000000 ,
IDE19082-MAS04668,Localization information from connected mobile end devices-Cell 20,00000000 ,
IDE19082-MAS04669,Localization information from connected mobile end devices-Cell 21,00000000 ,
IDE19082-MAS04670,Localization information from connected mobile end devices-Cell 22,00000000 ,
IDE19082-MAS04671,Localization information from connected mobile end devices-Cell 23,00000000 ,
IDE19082-MAS04672,Localization information from connected mobile end devices-Cell 24,00000000 ,
IDE19082-MAS04673,Localization information from connected mobile end devices-Cell 25,00000000 ,
IDE19082-MAS04674,Localization information from connected mobile end devices-Cell 26,00000000 ,
IDE19082-MAS04675,Localization information from connected mobile end devices-Cell 27,00000000 ,
IDE19082-MAS04676,Localization information from connected mobile end devices-Cell 28,00000000 ,
IDE19082-MAS04677,Localization information from connected mobile end devices-Cell 29,00000000 ,
IDE19082-MAS04678,Localization information from connected mobile end devices-Cell 30,00000000 ,
IDE19082-MAS04679,Localization information from connected mobile end devices-Cell 31,00000000 ,
IDE19082-MAS04680,Localization information from connected mobile end devices-Cell 32,00000000 ,
IDE19082-MAS04681,Localization information from connected mobile end devices-Cell 33,00000000 ,
IDE19082-MAS04682,Localization information from connected mobile end devices-Cell 34,00000000 ,
IDE19082-MAS04683,Localization information from connected mobile end devices-Cell 35,00000000 ,
IDE19082-MAS04684,Localization information from connected mobile end devices-Cell 36,00000000 ,
IDE19082-MAS04685,Localization information from connected mobile end devices-Cell 37,00000000 ,
IDE19082-MAS04686,Localization information from connected mobile end devices-Cell 38,00000000 ,
IDE19082-MAS04687,Localization information from connected mobile end devices-Cell 39,00000000 ,
IDE19082-MAS04688,Localization information from connected mobile end devices-Cell 41,00000000 ,
IDE19082-MAS04689,Localization information from connected mobile end devices-Cell 42,00000000 ,
IDE19082-MAS04690,Localization information from connected mobile end devices-Cell 43,00000000 ,
IDE19082-MAS04691,Localization information from connected mobile end devices-Cell 44,00000000 ,
IDE19082-MAS04692,Localization information from connected mobile end devices-Cell 45,00000000 ,
IDE19082-MAS04693,Localization information from connected mobile end devices-Cell 46,00000000 ,
IDE19082-MAS04694,Localization information from connected mobile end devices-Cell 47,00000000 ,
IDE19082-MAS04695,Localization information from connected mobile end devices-Cell 48,00000000 ,
IDE19082-MAS04696,Localization information from connected mobile end devices-Cell 49,00000000 ,
IDE19082-MAS04697,Localization information from connected mobile end devices-Cell 50,00000000 ,
IDE19082-MAS04698,Localization information from connected mobile end devices-Cell 51,00000000 ,
IDE19082-MAS04699,Localization information from connected mobile end devices-Cell 52,00000000 ,
IDE19082-MAS04700,Localization information from connected mobile end devices-Cell 53,00000000 ,
IDE19082-MAS04701,Localization information from connected mobile end devices-Cell 54,00000000 ,
IDE19082-MAS04702,Localization information from connected mobile end devices-Cell 55,00000000 ,
IDE19082-MAS04703,Localization information from connected mobile end devices-Cell 56,00000000 ,
IDE19082-MAS04704,Localization information from connected mobile end devices-Cell 57,00000000 ,
IDE19082-MAS04705,Localization information from connected mobile end devices-Cell 58,00000000 ,
IDE19082-MAS04706,Localization information from connected mobile end devices-Cell 59,00000000 ,
IDE19082-MAS04707,Localization information from connected mobile end devices-Cell 60,00000000 ,
IDE19082-MAS04708,Localization information from connected mobile end devices-Cell 61,00000000 ,
IDE19082-MAS04709,Localization information from connected mobile end devices-Cell 62,00000000 ,
IDE19082-MAS04710,Localization information from connected mobile end devices-Cell 63,00000000 ,
IDE19082-MAS04711,Localization information from connected mobile end devices-Cell 64,00000000 ,
IDE19082-MAS04720,Localization information from connected mobile end devices-Cell 40,00000000 ,
IDE19082-ENG352135,Localization information from connected mobile end devices-Executed_job,0,
IDE19082-ENG356009,Localization information from connected mobile end devices-Job_1,0,
IDE19082-ENG353431,Localization information from connected mobile end devices-Job_2,0,
IDE19082-ENG355812,Localization information from connected mobile end devices-Job_3,0,
IDE19082-ENG356015,Localization information from connected mobile end devices-Job_4,0,
IDE19082-ENG352311,Localization information from connected mobile end devices-Job_5,0,
IDE19082-ENG353615,Localization information from connected mobile end devices-Job_6,0,
IDE19082-ENG355077,Localization information from connected mobile end devices-Job_7,0,
IDE19082-ENG352675,Localization information from connected mobile end devices-SD1_authentication_last_result,Initialization,
IDE19082-ENG352873,Localization information from connected mobile end devices-SD1_failed_authentication_counter,0,
IDE19082-ENG355345,Localization information from connected mobile end devices-SD1_Lock_authentication_status,not authenticated,
IDE19082-ENG353650,Localization information from connected mobile end devices-SD1_Other_authentication_status,not authenticated,
IDE19082-ENG355980,Localization information from connected mobile end devices-SD1_Unlock_authentication_status,not authenticated,
IDE19082-ENG356501,Localization information from connected mobile end devices-SD2_authentication_last_result,Initialization,
IDE19082-ENG353164,Localization information from connected mobile end devices-SD2_failed_authentication_counter,0,
IDE19082-ENG355729,Localization information from connected mobile end devices-SD2_Lock_authentication_status,not authenticated,
IDE19082-ENG354577,Localization information from connected mobile end devices-SD2_Other_authentication_status,not authenticated,
IDE19082-ENG352820,Localization information from connected mobile end devices-SD2_Unlock_authentication_status,not authenticated,
IDE19082-ENG352946,Localization information from connected mobile end devices-SD3_authentication_last_result,Initialization,
IDE19082-ENG354404,Localization information from connected mobile end devices-SD3_failed_authentication_counter,0,
IDE19082-ENG354733,Localization information from connected mobile end devices-SD3_Lock_authentication_status,not authenticated,
IDE19082-ENG353762,Localization information from connected mobile end devices-SD3_Other_authentication_status,not authenticated,
IDE19082-ENG355910,Localization information from connected mobile end devices-SD3_Unlock_authentication_status,not authenticated,
IDE19082-ENG354140,Localization information from connected mobile end devices-SD4_authentication_last_result,Initialization,
IDE19082-ENG355213,Localization information from connected mobile end devices-SD4_failed_authentication_counter,0,
IDE19082-ENG352955,Localization information from connected mobile end devices-SD4_Lock_authentication_status,not authenticated,
IDE19082-ENG355081,Localization information from connected mobile end devices-SD4_Other_authentication_status,not authenticated,
IDE19082-ENG356728,Localization information from connected mobile end devices-SD4_Unlock_authentication_status,not authenticated,
IDE19082-ENG354761,Localization information from connected mobile end devices-SD5_authentication_last_result,Initialization,
IDE19082-ENG354357,Localization information from connected mobile end devices-SD5_failed_authentication_counter,0,
IDE19082-ENG353084,Localization information from connected mobile end devices-SD5_Lock_authentication_status,not authenticated,
IDE19082-ENG357090,Localization information from connected mobile end devices-SD5_Other_authentication_status,not authenticated,
IDE19082-ENG354764,Localization information from connected mobile end devices-SD5_Unlock_authentication_status,not authenticated,
IDE19082-ENG357385,Localization information from connected mobile end devices-SD6_authentication_last_result,Initialization,
IDE19082-ENG352284,Localization information from connected mobile end devices-SD6_failed_authentication_counter,0,
IDE19082-ENG354691,Localization information from connected mobile end devices-SD6_Lock_authentication_status,not authenticated,
IDE19082-ENG355970,Localization information from connected mobile end devices-SD6_Other_authentication_status,not authenticated,
IDE19082-ENG352927,Localization information from connected mobile end devices-SD6_Unlock_authentication_status,not authenticated,
IDE19082-ENG357550,Localization information from connected mobile end devices-SD7_authentication_last_result,Initialization,
IDE19082-ENG356475,Localization information from connected mobile end devices-SD7_failed_authentication_counter,0,
IDE19082-ENG355735,Localization information from connected mobile end devices-SD7_Lock_authentication_status,not authenticated,
IDE19082-ENG355363,Localization information from connected mobile end devices-SD7_Other_authentication_status,not authenticated,
IDE19082-ENG352685,Localization information from connected mobile end devices-SD7_Unlock_authentication_status,not authenticated,
IDE19082-ENG352978,Localization information from connected mobile end devices-SD8_authentication_last_result,Initialization,
IDE19082-ENG352272,Localization information from connected mobile end devices-SD8_failed_authentication_counter,0,
IDE19082-ENG355483,Localization information from connected mobile end devices-SD8_Lock_authentication_status,not authenticated,
IDE19082-ENG355444,Localization information from connected mobile end devices-SD8_Other_authentication_status,not authenticated,
IDE19082-ENG354344,Localization information from connected mobile end devices-SD8_Unlock_authentication_status,not authenticated,
IDE19082-ENG416579,Localization information from connected mobile end devices-Smartdevice_1,00 00 00 00,
IDE19082-ENG416580,Localization information from connected mobile end devices-Smartdevice_2,00 00 00 00,
IDE19082-ENG416581,Localization information from connected mobile end devices-Smartdevice_3,00 00 00 00,
IDE19082-ENG416582,Localization information from connected mobile end devices-Smartdevice_4,00 00 00 00,
IDE19082-ENG416583,Localization information from connected mobile end devices-Smartdevice_5,00 00 00 00,
IDE19082-ENG416584,Localization information from connected mobile end devices-Smartdevice_6,00 00 00 00,
IDE19082-ENG416585,Localization information from connected mobile end devices-Smartdevice_7,00 00 00 00,
IDE19082-ENG416586,Localization information from connected mobile end devices-Smartdevice_8,00 00 00 00,
IDE19099-ENG370721,Virtual key: deactivation by over-the-air update-Field for Iteration,|Deactivation duration,Year
IDE19126-ENG370721,Lock vehicle history data after automatic closing-Field for Iteration,|Year,Month
IDE19127-ENG370721,Unlock/lock keyless history data-Field for Iteration,|Year,Month
IDE19129,Status of antennas for burglary protection,not active,
IDE19130-MAS07151,Field strength of ultra-wide band antennas-RSSI value,0,
IDE19132-ENG370721,Keyless start authorization for mobile end devices history data-Field for Iteration,|Year,Month
IDE19134-ENG370721,History data of locked mobile end devices-Field for Iteration,|Year,Month
IDE19135-ENG370721,Historical data of assigned identifications of mobile end devices-Field for Iteration,|Year,Month
IDE19136-ENG370721,History data of failed search for mobile end devices-Field for Iteration,|Year,Month
IDE20152-ENG370721,History data: keyless entry/exit-Field for Iteration,|Reason for low pressure,Year
MAS00077-MAS02345,Immobilizer-Current condition,02,
MAS00077-MAS06790,Immobilizer-Identity counter,01,
MAS00077-MAS06791,Immobilizer-Mark detection,03,
MAS00077-MAS06792,Immobilizer-P class,E8,
MAS00077-MAS06793,Immobilizer-Number of adapted keys,02,
MAS00077-MAS06794,Immobilizer-Number of keys to be adapted via service download,00,
MAS00077-MAS06795,Immobilizer-Number of keys to be adapted adapt service keys,00,
MAS00077-MAS06796,Immobilizer-Remaining time to switch on terminal 15,0, min
MAS00077-MAS06797,Immobilizer-Status configuration,17 00,
MAS00077-MAS10131,Immobilizer-Status Download 3,invalid,
MAS00077-ENG299121,Immobilizer-Configuration_status_(interpreted),|Configuration Kessy coded,Configuration E vehicle
MAS00464-MAS00106,Standard - ambient data 1-Year,2032,
MAS00464-MAS00107,Standard - ambient data 1-Month,3,
MAS00464-MAS00108,Standard - ambient data 1-Day,22,
MAS00464-MAS00109,Standard - ambient data 1-Hours,0,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,3,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,48,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,0,
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,209, km
MAS00769-IDE02717,Multifunction steering wheel control module-Tiptronic upshift,Not operated,
MAS00769-IDE02718,Multifunction steering wheel control module-Tiptronic downshift,Not operated,
MAS00769-IDE07668,Multifunction steering wheel control module-MFL Variant code,0,
MAS00769-MAS01065,Multifunction steering wheel control module-Brand,VW,
MAS00769-MAS01288,Multifunction steering wheel control module-Horn,Not operated,
MAS00769-MAS02317,Multifunction steering wheel control module-Button code 1,Not operated,
MAS00769-MAS02318,Multifunction steering wheel control module-Button code 2,Not operated,
MAS00769-MAS02319,Multifunction steering wheel control module-Event code 1,No result,
MAS00769-MAS02320,Multifunction steering wheel control module-Event code 2,No result,
MAS00769-MAS06029,Multifunction steering wheel control module-MFL message counter,0,
MAS00769-MAS06030,Multifunction steering wheel control module-MFL Toggle Bit,0,
MAS00769-MAS06034,Multifunction steering wheel control module-MFL Local active,not active,
MAS00769-MAS06035,Multifunction steering wheel control module-MFL M button,Not operated,
MAS11771-ENG370721,Incorrect task-Field for Iteration,|Reason for access,Odometer reading|Reading data record
MAS12666-ENG299104,SubSystemNodeAddress of sub bus participant-SubSystem Node Addresses,|SubSystem Node Address,Subsystem designation|00 37
MAS12668-ENG299105,Actual installation of sub-bus users-SubSystems present,|SubSystem present Bit 0,SubSystem present Bit 1
MAS12669-ENG299103,Bus identification of sub-bus users-SubSystem Bus IDs,|Bus ID|81|81|0|0|0|0|0|0|82|0|82|0|0|0|0|0|83|83|83|83|0|0|0|0|84|84|0|0|0|0|0|0|0|0|0|0|0|0|0|0|86|86|86|0|0|0|0|0|35|0|0|0|0|0|0|0|41|0|0|0|0|0|0|0|,
MAS16427-MAS17003,Online data acquisition configuration-Locking time for change of condition,0.0, s
MAS16427-MAS19090,Online data acquisition configuration-Configuration version,00 00 00 00,
MAS16428-MAS00106,Online data acquisition and analysis-Year,2000,
MAS16428-MAS00107,Online data acquisition and analysis-Month,0,
MAS16428-MAS00108,Online data acquisition and analysis-Day,0,
MAS16428-MAS00109,Online data acquisition and analysis-Hours,0,
MAS16428-MAS00110,Online data acquisition and analysis-Minutes,0,
MAS16428-MAS00111,Online data acquisition and analysis-Seconds,0,
MAS16428-MAS16995,Online data acquisition and analysis-Downloads data set number,0,
MAS16428-MAS19089,Online data acquisition and analysis-Emergency Call Module recognition and communication unit or navigation,none,
MAS16744-IDE01836,12V battery-Battery current,4.248, A
MAS16744-IDE01837,12V battery-Temperature of battery sensor,15, °C
MAS16744-IDE01838,12V battery-Battery temperature,12, °C
MAS16744-IDE01839,12V battery-Battery charge level,73, %
MAS16744-IDE01841,12V battery-Battery internal resistance,4.2, mOhm
MAS16744-IDE01842,12V battery-Usable battery charge,18, Ah
MAS16744-IDE01948,12V battery-Battery internal resistance not normed,4.2, mOhm
MAS16744-IDE04186,12V battery-Battery terminal recognition,connected,
MAS16744-IDE08347,12V battery-adapted battery capacity,58, Ah
MAS16744-MAS00362,12V battery-Battery voltage,14.926, V
MAS16744-MAS06086,12V battery-Total re-charge,140.4, Ah
MAS16744-MAS06087,12V battery-Entire energy throughput,144.9, Ah
MAS16744-MAS22232,12V battery-Battery aging: charge-related,92, %
MAS16744-MAS22233,12V battery-Battery aging: performance-related,92, %
MAS16745-IDE01839,Quiescent current management-Battery charge level,60, %
MAS16745-IDE01843,Quiescent current management-Battery voltage at rest,12.4, V
MAS16745-IDE01846,Quiescent current management-Static current shut-off stage,Deactivation stage 0,
MAS16745-IDE01852,Quiescent current management-Static current measurement: result,Measurement,
MAS16745-IDE01853,Quiescent current management-Static current measurement: status,Initialization,
MAS16745-IDE07907,Quiescent current management-Bus communication,active,
MAS16745-IDE09561,Quiescent current management-Static current last LIN sleep phase,-0.026, A
MAS17522-IDE04332,Unlockable functions: central activation status-Release code for a SWaP function,Available,
MAS17522-IDE05814,Unlockable functions: central activation status-Individualization characteristic,valid,
MAS17522-IDE06260,Unlockable functions: central activation status-ID number,10 13 14 00,
MAS17522-MAS01340,Unlockable functions: central activation status-Functions,Available,
MAS17522-MAS01903,Unlockable functions: central activation status-Configuration,OK,
MAS17522-MAS02934,Unlockable functions: central activation status-Preconditions met,Condition met,
MAS17522-MAS05616,Unlockable functions: central activation status-Cancellation,No,
MAS17522-MAS05617,Unlockable functions: central activation status-Authentication,Condition met,
MAS17522-MAS17839,Unlockable functions: central activation status-Number of functions which can be activated,50,
MAS17522-MAS17965,Unlockable functions: central activation status-Maximum at receiver control module per activation ID,8,
MAS17522-MAS17967,Unlockable functions: central activation status-Type of customization feature,03,
MAS17522-MAS18610,Unlockable functions: central activation status-Control module to be activated 1,00 19,
MAS17522-MAS18611,Unlockable functions: central activation status-Control module to be activated 2,00 00,
MAS17522-MAS18612,Unlockable functions: central activation status-Control module to be activated 3,00 00,
MAS17522-MAS18613,Unlockable functions: central activation status-Control module to be activated 4,00 00,
MAS17522-MAS18614,Unlockable functions: central activation status-Control module to be activated 5,00 00,
MAS17522-MAS18615,Unlockable functions: central activation status-Control module to be activated 6,00 00,
MAS17522-MAS18616,Unlockable functions: central activation status-Control module to be activated 7,00 00,
MAS17522-MAS18617,Unlockable functions: central activation status-Control module to be activated 8,00 00,
MAS17522-MAS18618,Unlockable functions: central activation status-Activation of SWaP function for control module 1,Not available,
MAS17522-MAS18619,Unlockable functions: central activation status-Activation of SWaP function for control module 2,Not available,
MAS17522-MAS18620,Unlockable functions: central activation status-Activation of SWaP function for control module 3,Not available,
MAS17522-MAS18621,Unlockable functions: central activation status-Activation of SWaP function for control module 4,Not available,
MAS17522-MAS18622,Unlockable functions: central activation status-Activation of SWaP function for control module 5,Not available,
MAS17522-MAS18623,Unlockable functions: central activation status-Activation of SWaP function for control module 6,Not available,
MAS17522-MAS18624,Unlockable functions: central activation status-Activation of SWaP function for control module 7,Not available,
MAS17522-MAS18625,Unlockable functions: central activation status-Activation of SWaP function for control module 8,Not available,
MAS17522-MAS18626,Unlockable functions: central activation status-Cancellation for control module 1,Yes,
MAS17522-MAS18627,Unlockable functions: central activation status-Cancellation for control module 2,Yes,
MAS17522-MAS18628,Unlockable functions: central activation status-Cancellation for control module 3,Yes,
MAS17522-MAS18629,Unlockable functions: central activation status-Cancellation for control module 4,Yes,
MAS17522-MAS18630,Unlockable functions: central activation status-Cancellation for control module 5,Yes,
MAS17522-MAS18631,Unlockable functions: central activation status-Cancellation for control module 6,Yes,
MAS17522-MAS18632,Unlockable functions: central activation status-Cancellation for control module 7,Yes,
MAS17522-MAS18633,Unlockable functions: central activation status-Cancellation for control module 8,Yes,
MAS17522-MAS18634,Unlockable functions: central activation status-Individualization feature for control module 1,invalid,
MAS17522-MAS18635,Unlockable functions: central activation status-Individualization feature for control module 2,invalid,
MAS17522-MAS18636,Unlockable functions: central activation status-Individualization feature for control module 3,invalid,
MAS17522-MAS18637,Unlockable functions: central activation status-Individualization feature for control module 4,invalid,
MAS17522-MAS18638,Unlockable functions: central activation status-Individualization feature for control module 5,invalid,
MAS17522-MAS18639,Unlockable functions: central activation status-Individualization feature for control module 6,invalid,
MAS17522-MAS18640,Unlockable functions: central activation status-Individualization feature for control module 7,invalid,
MAS17522-MAS18641,Unlockable functions: central activation status-Individualization feature for control module 8,invalid,
MAS17522-MAS18642,Unlockable functions: central activation status-Conditions met for control module 1,Condition not met,
MAS17522-MAS18643,Unlockable functions: central activation status-Conditions met for control module 2,Condition not met,
MAS17522-MAS18644,Unlockable functions: central activation status-Conditions met for control module 3,Condition not met,
MAS17522-MAS18645,Unlockable functions: central activation status-Conditions met for control module 4,Condition not met,
MAS17522-MAS18646,Unlockable functions: central activation status-Conditions met for control module 5,Condition not met,
MAS17522-MAS18647,Unlockable functions: central activation status-Conditions met for control module 6,Condition not met,
MAS17522-MAS18648,Unlockable functions: central activation status-Conditions met for control module 7,Condition not met,
MAS17522-MAS18649,Unlockable functions: central activation status-Conditions met for control module 8,Condition not met,
MAS17522-MAS18650,Unlockable functions: central activation status-Configuration for control module 1,OK,
MAS17522-MAS18651,Unlockable functions: central activation status-Configuration for control module 2,not OK,
MAS17522-MAS18652,Unlockable functions: central activation status-Configuration for control module 3,not OK,
MAS17522-MAS18653,Unlockable functions: central activation status-Configuration for control module 4,not OK,
MAS17522-MAS18654,Unlockable functions: central activation status-Configuration for control module 5,not OK,
MAS17522-MAS18655,Unlockable functions: central activation status-Configuration for control module 6,not OK,
MAS17522-MAS18656,Unlockable functions: central activation status-Configuration for control module 7,not OK,
MAS17522-MAS18657,Unlockable functions: central activation status-Configuration for control module 8,not OK,
MAS17522-MAS18658,Unlockable functions: central activation status-Functions in control module 1,Available,
MAS17522-MAS18659,Unlockable functions: central activation status-Functions in control module 2,Not available,
MAS17522-MAS18660,Unlockable functions: central activation status-Functions in control module 3,Not available,
MAS17522-MAS18661,Unlockable functions: central activation status-Functions in control module 4,Not available,
MAS17522-MAS18662,Unlockable functions: central activation status-Functions in control module 5,Not available,
MAS17522-MAS18663,Unlockable functions: central activation status-Functions in control module 6,Not available,
MAS17522-MAS18664,Unlockable functions: central activation status-Functions in control module 7,Not available,
MAS17522-MAS18665,Unlockable functions: central activation status-Functions in control module 8,Not available,
MAS17522-MAS18666,Unlockable functions: central activation status-Authentication for control module 1,Condition not met,
MAS17522-MAS18667,Unlockable functions: central activation status-Authentication for control module 2,Condition not met,
MAS17522-MAS18668,Unlockable functions: central activation status-Authentication for control module 3,Condition not met,
MAS17522-MAS18669,Unlockable functions: central activation status-Authentication for control module 4,Condition not met,
MAS17522-MAS18670,Unlockable functions: central activation status-Authentication for control module 5,Condition not met,
MAS17522-MAS18671,Unlockable functions: central activation status-Authentication for control module 6,Condition not met,
MAS17522-MAS18672,Unlockable functions: central activation status-Authentication for control module 7,Condition not met,
MAS17522-MAS18673,Unlockable functions: central activation status-Authentication for control module 8,Condition not met,
MAS17522,Unlockable functions: central activation status,44 D7 85 9F A2 00 00 00,
MAS17523-MAS17968,Unlockable functions: date of last activation-Date of last function activation,67 40 46 DF,
MAS17523-MAS17969,Unlockable functions: date of last activation-Date of last key exchange,00 00 00 00,
MAS17523-MAS17970,Unlockable functions: date of last activation-Date of last reset,00 00 00 00,
MAS17524-MAS17977,Unlockable functions: version info-Supported activation version,Support from FSC version 0x12,
MAS17524-MAS17978,Unlockable functions: version info-Supported encryption procedure,RSA3072 Exp. 17,
MAS17524-MAS18453,Unlockable functions: version info-FoD metadata version,No version of FoD metadata is supported,
MAS17524-MAS18456,Unlockable functions: version info-KeyIdent (Key project identification),1702,
MAS17524-MAS18457,Unlockable functions: version info-Generation of function activation,Activation via FoD,
MAS17524-MAS18460,Unlockable functions: version info-FoD partner diagnostic address,81 24,
MAS17526-MAS17971,Unlockable functions: status of transfer-Transfer status,Valid transmission,
MAS17526-MAS17972,Unlockable functions: status of transfer-Number of slave control modules,8,
MAS17526-MAS17973,Unlockable functions: status of transfer-Transfer status in slave control module,Valid transmission,
MAS17526-MAS17974,Unlockable functions: status of transfer-Slave number,0,
MAS17526-MAS17975,Unlockable functions: status of transfer-Slave node address,118,
MAS17526-MAS17976,Unlockable functions: status of transfer-Slave diagnostic address,00 01,
MAS17833,Remaining period of test activation,4294967295, s
MAS18157-MAS18158,SFD activated status-Role of vehicle diagnostic to be protected,No activation active,
MAS18157-MAS18161,SFD activated status-Status of vehicle diagnostic to be protected,SFD individualization feature set,
MAS18157-MAS18164,SFD activated status-Duration of vehicle diagnostic to be protected,No activation active,
MAS18157-MAS18165,SFD activated status-Type of vehicle diagnostic to be protected,No activation active,
MAS20396,SFD protection procedure,SFD access protection and SFD end-to-end protection,
MAS23345,Production mode: 12 V recharging status,not active,
MAS24928-IDE06956,Secure presence detection-Driver-side belt buckle status,plausible,
MAS24928-IDE06956,Secure presence detection-Driver-side belt buckle status,closed,
MAS24928-IDE13428,Secure presence detection-Accelerator pedal value,Measured value not available or parameter outside measur.range,
MAS24928-IDE13428,Secure presence detection-Accelerator pedal value,Not operated,
MAS24928-MAS00218,Secure presence detection-Driver door,plausible,
MAS24928-MAS00218,Secure presence detection-Driver door,closed,
MAS24928-MAS00370,Secure presence detection-Vehicle speed,plausible,
MAS24928-MAS00635,Secure presence detection-Available,Available,
MAS24928-MAS03554,Secure presence detection-Clutch pedal operation,Implausible,
MAS24928-MAS03554,Secure presence detection-Clutch pedal operation,Not operated,
MAS24928-MAS05192,Secure presence detection-Driver braking,plausible,
MAS24928-MAS05192,Secure presence detection-Driver braking,Braking,
MAS24928-MAS07200,Secure presence detection-Multi-function steering wheel,Implausible,
MAS24928-MAS07200,Secure presence detection-Multi-function steering wheel,not around,
MAS24928-MAS07652,Secure presence detection-Vehicle movement,Standstill,
MAS24928-MAS15366,Secure presence detection-Incorrect height values,Not operated,
MAS24928-MAS15366,Secure presence detection-Incorrect height values,plausible,
MAS24928-MAS17288,Secure presence detection-Driver seat occupant detection,plausible,
MAS24928-MAS17288,Secure presence detection-Driver seat occupant detection,assigned,
MAS24928-MAS22006,Secure presence detection-Start request recognition: status,Not operated,
MAS24928-MAS22963,Secure presence detection-Starter button actuated,Not operated,
MAS24928-MAS25016,Secure presence detection-Electronic parking brake: switch position,plausible,
MAS24928-MAS25017,Secure presence detection-Shift mechanism,Not operated,
MAS24928-MAS25017,Secure presence detection-Shift mechanism,plausible,
MAS24928-MAS25018,Secure presence detection-Driver request: switch position,Not operated,
MAS24928-MAS25020,Secure presence detection-Presence detection: status,Secure presence detection,
MAS24928-SFT33114,Secure presence detection-Multifunction interior camera,Implausible,
MAS24928-SFT33114,Secure presence detection-Multifunction interior camera,not detected,
MAS24971,Low-voltage energy management: energy charging balance,10010, Ah
MAS25221,Virtual remote control vehicle key: online configuration,|Config_profileid,Engine_start_and_driving_unlimited
MAS25221-ENG353386,Virtual remote control vehicle key: online configuration-Config_owner_pairing_passwort_max_attempts,00,
MAS25221-ENG356831,Virtual remote control vehicle key: online configuration-Config_servicecard_activation_mode,simple,
MAS25221-ENG353252,Virtual remote control vehicle key: online configuration-Config_sharing_password_length,00,
MAS25221-ENG356838,Virtual remote control vehicle key: online configuration-Config_sharing_password_required,No,
MAS25221-ENG353410,Virtual remote control vehicle key: online configuration-Config_sharing_passwort_max_attempts,00,
MAS25221-ENG354762,Virtual remote control vehicle key: online configuration-Config_slotid_1,00 00 00 00,
MAS25221-ENG353562,Virtual remote control vehicle key: online configuration-Config_slotid_10,00 00 00 00,
MAS25221-ENG352068,Virtual remote control vehicle key: online configuration-Config_slotid_11,00 00 00 00,
MAS25221-ENG355132,Virtual remote control vehicle key: online configuration-Config_slotid_12,00 00 00 00,
MAS25221-ENG352767,Virtual remote control vehicle key: online configuration-Config_slotid_13,00 00 00 00,
MAS25221-ENG354931,Virtual remote control vehicle key: online configuration-Config_slotid_14,00 00 00 00,
MAS25221-ENG354420,Virtual remote control vehicle key: online configuration-Config_slotid_15,00 00 00 00,
MAS25221-ENG351951,Virtual remote control vehicle key: online configuration-Config_slotid_16,00 00 00 00,
MAS25221-ENG355037,Virtual remote control vehicle key: online configuration-Config_slotid_2,00 00 00 00,
MAS25221-ENG355160,Virtual remote control vehicle key: online configuration-Config_slotid_3,00 00 00 00,
MAS25221-ENG354052,Virtual remote control vehicle key: online configuration-Config_slotid_4,00 00 00 00,
MAS25221-ENG356953,Virtual remote control vehicle key: online configuration-Config_slotid_5,00 00 00 00,
MAS25221-ENG353832,Virtual remote control vehicle key: online configuration-Config_slotid_6,00 00 00 00,
MAS25221-ENG355202,Virtual remote control vehicle key: online configuration-Config_slotid_7,00 00 00 00,
MAS25221-ENG352864,Virtual remote control vehicle key: online configuration-Config_slotid_8,00 00 00 00,
MAS25221-ENG356858,Virtual remote control vehicle key: online configuration-Config_slotid_9,00 00 00 00,
MAS25222-ENG352542,Near-field service card: information-Current_overlying_servicecard_corresponds_to_the_trained_service_card,No,
MAS25222-ENG353668,Near-field service card: information-Electronic_type_label_of_the_trained_servicecard,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
MAS25222-ENG353958,Near-field service card: information-Id_of_the_trained_servicecard,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
MAS25222-ENG352639,Near-field service card: information-Nfc_servicecard_learned,No,
MAS26682,Distance of storage error,00,
MAS26683,Distance of calculation error,00,
MAS27660,12-V battery display: trip reason,0,
MAS27748-IDE02068,Distance data with electronic stabilization program information-Time stamp,00 00 42 00 68,
MAS27748-MAS00106,Distance data with electronic stabilization program information-Year,2000, yr
MAS27748-MAS00107,Distance data with electronic stabilization program information-Month,1, Months
MAS27748-MAS00108,Distance data with electronic stabilization program information-Day,1, d
MAS27748-MAS00109,Distance data with electronic stabilization program information-Hours,0, H
MAS27748-MAS00110,Distance data with electronic stabilization program information-Minutes,1, min
MAS27748-MAS00111,Distance data with electronic stabilization program information-Seconds,40, s
MAS27748-MAS27735,Distance data with electronic stabilization program information-ESC distance pulses,209898, m
MAS27748-MAS27749,Distance data with electronic stabilization program information-Distance pulses: number of jumps,0,
MAS27748-MAS27750,Distance data with electronic stabilization program information-Distance pulses: largest positive jump,0, m
MAS27748-MAS27751,Distance data with electronic stabilization program information-Distance pulses: largest negative jump,0, m
MAS27748-MAS27752,Distance data with electronic stabilization program information-Distance pulses: total jumps,0, m
MAS27748-MAS27753,Distance data with electronic stabilization program information-Distance pulses: jump balance,0, m
MAS27748-MAS27754,Distance data with electronic stabilization program information-Electronic stabilization program communication failures: number,2,
MAS27748-MAS27755,Distance data with electronic stabilization program information-Electronic stabilization program communication failures: total duration,132, s
MAS27748-MAS27756,Distance data with electronic stabilization program information-Longest electronic stabilization program communication failure,3, min
MAS28172,Status of automatic cyclical search function,not activated,
MAS31238-IDE09250,Can_signals_mdk_icas-Key search in vehicle interior,0,
MAS31238-MAS06118,Can_signals_mdk_icas-ID sensor not found,0,
MAS31238-MAS28651,Can_signals_mdk_icas-Kessy faulty,0,
MAS31238-MAS28652,Can_signals_mdk_icas-Key in mobile end device faulty,0,
UNK00000,0_Basis,
ENG250331-ENG250595,Condition_check_1-State_info_1,05,
ENG250331-ENG250481,Condition_check_1-State_info_2,01,
ENG250331-ENG250687,Condition_check_1-Transponder_Identification,00 00 00 00,
ENG250332-ENG250595,Condition_check_2-State_info_1,05,
ENG250332-ENG250481,Condition_check_2-State_info_2,01,
ENG250332-ENG250687,Condition_check_2-Transponder_Identification,00 00 00 00,
ENG254614-IDE09469,DNH_someip_data_bus_service_error_value_received-IPv6 address,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG254614-MAS05767,DNH_someip_data_bus_service_error_value_received-port,00 00,
ENG254614-MAS20533,DNH_someip_data_bus_service_error_value_received-Service Id,00 00,
ENG254614-MAS20961,DNH_someip_data_bus_service_error_value_received-Method ID,00 00,
ENG254614-MAS20968,DNH_someip_data_bus_service_error_value_received-Number of services,5,
ENG254615-IDE09469,DNH_someip_data_bus_service_implausible-IPv6 address,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG254615-MAS05767,DNH_someip_data_bus_service_implausible-port,00 00,
ENG254615-MAS20533,DNH_someip_data_bus_service_implausible-Service Id,00 00,
ENG254615-MAS20961,DNH_someip_data_bus_service_implausible-Method ID,00 00,
ENG254615-MAS20968,DNH_someip_data_bus_service_implausible-Number of services,31,
ENG254616-IDE09469,DNH_someip_data_bus_service_not_available-IPv6 address,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG254616-MAS05767,DNH_someip_data_bus_service_not_available-port,00 00,
ENG254616-MAS20533,DNH_someip_data_bus_service_not_available-Service Id,00 00,
ENG254616-MAS20968,DNH_someip_data_bus_service_not_available-Number of services,0,
ENG118786-ENG137129,Driv._Prof._Sel._Dr._Op.-Drehsteller_Ist_Modus,0,
ENG118786-ENG137130,Driv._Prof._Sel._Dr._Op.-Drehsteller_Modus,0,
ENG118786-ENG137133,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_HVEM,0,
ENG118786-ENG137135,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_Mo_BZS,0,
ENG118786-ENG137134,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_Step_Reduction,0,
ENG118786-ENG137132,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_Trailer,0,
ENG118786-ENG137131,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_New_Driverwish_Modus,not detected,
ENG118786-ENG118748,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_New_Driverwish_Profile,not detected,
ENG118783-ENG118728,Driv._Prof._Sel._Sys._Subst.-Driving_Profile_Selection_Coordinator_Sub_State_Value,5,
ENG118783-ENG118729,Driv._Prof._Sel._Sys._Subst.-Driving_Profile_Selection_Startup_State,active,
ENG286562-ENG121879,drivers_site_sliding_door_Opening_Sender_Cycle_Data-trace_1,10,
ENG286562-ENG121888,drivers_site_sliding_door_Opening_Sender_Cycle_Data-trace_10,10,
ENG286562-ENG121889,drivers_site_sliding_door_Opening_Sender_Cycle_Data-trace_11,10,
ENG286562-ENG121890,drivers_site_sliding_door_Opening_Sender_Cycle_Data-trace_12,10,
ENG286562-ENG121891,drivers_site_sliding_door_Opening_Sender_Cycle_Data-trace_13,10,
ENG286562-ENG121892,drivers_site_sliding_door_Opening_Sender_Cycle_Data-trace_14,10,
ENG286562-ENG121893,drivers_site_sliding_door_Opening_Sender_Cycle_Data-trace_15,10,
ENG286562-ENG121894,drivers_site_sliding_door_Opening_Sender_Cycle_Data-trace_16,10,
ENG286562-ENG121895,drivers_site_sliding_door_Opening_Sender_Cycle_Data-trace_17,10,
ENG286562-ENG121896,drivers_site_sliding_door_Opening_Sender_Cycle_Data-trace_18,10,
ENG286562-ENG121897,drivers_site_sliding_door_Opening_Sender_Cycle_Data-trace_19,10,
ENG286562-ENG121880,drivers_site_sliding_door_Opening_Sender_Cycle_Data-trace_2,10,
ENG286562-ENG121898,drivers_site_sliding_door_Opening_Sender_Cycle_Data-trace_20,10,
ENG286562-ENG121881,drivers_site_sliding_door_Opening_Sender_Cycle_Data-trace_3,10,
ENG286562-ENG121882,drivers_site_sliding_door_Opening_Sender_Cycle_Data-trace_4,10,
ENG286562-ENG121883,drivers_site_sliding_door_Opening_Sender_Cycle_Data-trace_5,10,
ENG286562-ENG121884,drivers_site_sliding_door_Opening_Sender_Cycle_Data-trace_6,10,
ENG286562-ENG121885,drivers_site_sliding_door_Opening_Sender_Cycle_Data-trace_7,10,
ENG286562-ENG121886,drivers_site_sliding_door_Opening_Sender_Cycle_Data-trace_8,10,
ENG286562-ENG121887,drivers_site_sliding_door_Opening_Sender_Cycle_Data-trace_9,10,
ENG286564,Easy_open_HBFS_unavailable_reason,Terminal 15 active,
ENG286565,Easy_open_HFS_unavailable_reason,Terminal 15 active,
ENG137077-ENG137157,EHR_pool_load-ehr_attribute_pool_load,0.0, %
ENG137077-ENG137156,EHR_pool_load-ehr_segment_pool_load,0.0, %
ENG137077-ENG255696,EHR_pool_load-ehr_speedlimit_pool_load,0.0, %
ENG254720-ENG255783,High_voltage_charging_information-High_voltage_charging_state,Standby_charging_precondition_not_fulfilled,
ENG254720-ENG255784,High_voltage_charging_information-High_voltage_type_of_charging_request,charging_not_requested,
ENG254720-ENG334265,High_voltage_charging_information-Maximum_by_drive_enabled_power,2000, W
ENG370317,History_of_zdc_writing_operations,|Parameter set part number,Parameter set version|56 30 33 39 33 35 34 34 36 44 4B
ENG310450-ENG334072,HV-EM_Autonomous_bidi_charging-Bidi_actual_performance,25600, W
ENG310450-ENG334074,HV-EM_Autonomous_bidi_charging-Bidi_charge_mode,No_bidi_charge,
ENG310450-ENG334229,HV-EM_Autonomous_bidi_charging-Hvem_bidi_specification,0, W
ENG254725-ENG334194,HV-EM_consumer_contingent-Enabling_battery_heater,Release,
ENG254725-ENG255697,HV-EM_consumer_contingent-Enabling_climate_aggregates,Release,
ENG254725-ENG334243,HV-EM_consumer_contingent-Hvem_wake_up,active,
ENG254727-ENG354387,HV-EM_energy_specification-Energy_content_set_point_powertrain,65075, Wh
ENG254727-ENG152032,HV-EM_energy_specification-HV-EM_high_voltage_battery_energy_information,59050, Wh
ENG254728-ENG255786,HV-EM_high_voltage_activation-HV-EM_activation_requirement_by_NVEM,Requirement,
ENG254728-ENG370745,HV-EM_high_voltage_activation-Hvem_battery_conditioning_voko,not active,
ENG254728-ENG370746,HV-EM_high_voltage_activation-Hvem_independent_air_conditioning,not active,
ENG254728-ENG334233,HV-EM_high_voltage_activation-Hvem_ops_hv_presence,Requirement,
ENG254728-ENG152036,HV-EM_high_voltage_activation-HV-EM_recharging_requirement,no request,
ENG254728-ENG334241,HV-EM_high_voltage_activation-Hvem_request_by_hv_charging,not active,
ENG254728-ENG395988,HV-EM_high_voltage_activation-Hvem_request_independent_low_voltage,no request,
ENG254729-ENG255533,HV-EM_operation_data-climate_power,800, W
ENG254729-ENG255581,HV-EM_operation_data-dcdc_power,630, W
ENG254729-ENG125881,HV-EM_operation_data-HV-EM_operation_mode,ready_to_drive,
ENG254730-ENG353491,HV-EM_operation_limitation-Charge_state_hv_battery_display_soc,77.0, %
ENG254730-ENG263259,HV-EM_operation_limitation-HV-EM_approval_dcdc_converter,Release,
ENG254730-ENG152034,HV-EM_operation_limitation-HV-EM_NV_power_limitation,4550, W
ENG254730-ENG152035,HV-EM_operation_limitation-HV-EM_power_limitation,0, W
ENG310451-ENG334228,HV-EM_Power_contingent-Hvem_actual_performance_auxiliary_consumers,1400, W
ENG310451-ENG334236,HV-EM_Power_contingent-Hvem_power_specification_air_conditioner,1550, W
ENG310451-ENG334238,HV-EM_Power_contingent-Hvem_power_specification_battery_heater,0, W
ENG310452-ENG334231,HV-EM_Power_request-Hvem_minimum_power,0, W
ENG310452-ENG334234,HV-EM_Power_request-Hvem_power_intention,1600, W
ENG310452-ENG334293,HV-EM_Power_request-Power_demand_air_conditioner,1600, W
ENG310452-ENG334295,HV-EM_Power_request-Power_demand_battery_heater,0, W
ENG277522-MAS20968,IAA_PSO_Master_someip_data_bus_service_error_value_received-Number of services,1,
ENG277522,IAA_PSO_Master_someip_data_bus_service_error_value_received,|Service Id,Method ID
ENG277567-MAS20968,IAA_PSO_Master_someip_data_bus_service_implausible-Number of services,15,
ENG277567,IAA_PSO_Master_someip_data_bus_service_implausible,|Service Id,Method ID
ENG277550-MAS20968,IAA_PSO_Master_someip_data_bus_service_not_available-Number of services,56,
ENG277550,IAA_PSO_Master_someip_data_bus_service_not_available,|Service Id,IPv6 address
ENG286616,Last_LIN_Message_BCM_VIP_HBFS,00 00 02 00 00 C8 FF FF,
ENG286617,Last_LIN_Message_BCM_VIP_HFS,00 00 3E 00 00 E8 FF FF,
ENG121906,Last_LIN_Message_Kessy,00 00 3E 00 00 E0 FF FF,
ENG121907,Last_LIN_Message_LIN,00 00 00 00 80 01 00 00,
ENG286618,Last_LIN_Message_VIP_HBFS,00 00 00 00 80 01 00 00,
ENG286619,Last_LIN_Message_VIP_HFS,00 00 00 00 80 01 00 00,
ENG347941,Legislated_obd-requirement_plausible,NO OBD,
ENG254782-IDE09469,MSP-OD_someip_data_bus_service_not_available-IPv6 address,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG254782-MAS05767,MSP-OD_someip_data_bus_service_not_available-port,00 00,
ENG254782-MAS20533,MSP-OD_someip_data_bus_service_not_available-Service Id,18 00,
ENG254782-MAS20968,MSP-OD_someip_data_bus_service_not_available-Number of services,142,
ENG310457-ENG334195,NVEM_12V_autonome_Funktionen-Energieinhalt_Primärseite,59050,
ENG310457-ENG334211,NVEM_12V_autonome_Funktionen-functional_requirement_NVEM,8,
ENG310457-ENG334297,NVEM_12V_autonome_Funktionen-Qe_auf_Basis_SOC,18, Ah
ENG310457-ENG334298,NVEM_12V_autonome_Funktionen-Qe_Batterie,24, Ah
ENG310457-ENG334299,NVEM_12V_autonome_Funktionen-QKomfort,25, Ah
ENG310457-ENG334442,NVEM_12V_autonome_Funktionen-Zaehler_Haeufigkeit_autonomes_Nachladen,0,
ENG310458-ENG334272,Nvem_12V_recognized_battery_data-Nvem_12V_recognized_battery_capacity,58, Ah
ENG310458-ENG334273,Nvem_12V_recognized_battery_data-Nvem_12V_recognized_battery_technology,1,
ENG310459-MAS06344,NVEM_crank_voltage_analysis-Minimum voltage at last engine start,14.65, V
ENG310459-MAS06345,NVEM_crank_voltage_analysis-Minimum voltage at last engine start recognized,not detected,
ENG310459-MAS06346,NVEM_crank_voltage_analysis-Voltage drop through engine start recognized,not detected,
ENG310459-MAS06347,NVEM_crank_voltage_analysis-Current voltage drop last start,12.65, V
ENG310459-MAS06348,NVEM_crank_voltage_analysis-Normed voltage drop,12.65, V
ENG310459-MAS11064,NVEM_crank_voltage_analysis-Current last engine start,1, A
ENG310459-MAS11065,NVEM_crank_voltage_analysis-Current delta last engine start,1, A
ENG310460-MAS11001,NVEM_Grund_falsch_codiert-Reason,0,
ENG310461-ENG255780,NVEM_idle_speed_increase-Heizleistungskontingent_Stufe,Stage 1,
ENG310462-IDE06339,NVEM_mode_operation-Hybrid readiness: status,active,
ENG310462-MAS03679,NVEM_mode_operation-Terminal 15 status,active,
ENG310462-ENG278695,NVEM_mode_operation-Comfort_Ready_Status,active,
ENG310462-ENG157286,NVEM_mode_operation-Operation_mode,12,
ENG310462-ENG334324,NVEM_mode_operation-safety_drivestate,3,
ENG310463-MAS06117,NVEM_Sollvorgaben-Specified voltage,14.900, V
ENG310463-MAS09777,NVEM_Sollvorgaben-Target current,174.0, A
ENG310463-ENG334355,NVEM_Sollvorgaben-Sollleistung,6250, W
ENG310463-ENG334356,NVEM_Sollvorgaben-Sollleistung_grund,0,
ENG310463-ENG334357,NVEM_Sollvorgaben-Sollleistung_vorgabe,4550, W
ENG310463-ENG334358,NVEM_Sollvorgaben-Spannung_soll_grund,6,
ENG310463-ENG334370,NVEM_Sollvorgaben-Strom_soll_grund,0,
ENG310464-MAS00978,NVEM_VST_Zustand-Priority,0,
ENG310464-ENG334316,NVEM_VST_Zustand-Reason_consumer_cutoff,2,
ENG310464-ENG334423,NVEM_VST_Zustand-Trigger_consumer_cutoff,0,
ENG121946-MAS06517,Rear_Lid_Opening_Sender_Counter-Rear spoiler counter,91,
ENG121946-MAS12705,Rear_Lid_Opening_Sender_Counter-Number of detected proximities,2,
ENG121946-MAS12706,Rear_Lid_Opening_Sender_Counter-Number of detected kick movements,0,
ENG121946-MAS12707,Rear_Lid_Opening_Sender_Counter-Number of transmitter activations,125,
ENG121948-ENG121879,Rear_Lid_Opening_Sender_Cycle_Data-trace_1,10,
ENG121948-ENG121888,Rear_Lid_Opening_Sender_Cycle_Data-trace_10,10,
ENG121948-ENG121889,Rear_Lid_Opening_Sender_Cycle_Data-trace_11,70,
ENG121948-ENG121890,Rear_Lid_Opening_Sender_Cycle_Data-trace_12,10,
ENG121948-ENG121891,Rear_Lid_Opening_Sender_Cycle_Data-trace_13,10,
ENG121948-ENG121892,Rear_Lid_Opening_Sender_Cycle_Data-trace_14,70,
ENG121948-ENG121893,Rear_Lid_Opening_Sender_Cycle_Data-trace_15,10,
ENG121948-ENG121894,Rear_Lid_Opening_Sender_Cycle_Data-trace_16,10,
ENG121948-ENG121895,Rear_Lid_Opening_Sender_Cycle_Data-trace_17,10,
ENG121948-ENG121896,Rear_Lid_Opening_Sender_Cycle_Data-trace_18,10,
ENG121948-ENG121897,Rear_Lid_Opening_Sender_Cycle_Data-trace_19,10,
ENG121948-ENG121880,Rear_Lid_Opening_Sender_Cycle_Data-trace_2,10,
ENG121948-ENG121898,Rear_Lid_Opening_Sender_Cycle_Data-trace_20,10,
ENG121948-ENG121881,Rear_Lid_Opening_Sender_Cycle_Data-trace_3,70,
ENG121948-ENG121882,Rear_Lid_Opening_Sender_Cycle_Data-trace_4,10,
ENG121948-ENG121883,Rear_Lid_Opening_Sender_Cycle_Data-trace_5,10,
ENG121948-ENG121884,Rear_Lid_Opening_Sender_Cycle_Data-trace_6,10,
ENG121948-ENG121885,Rear_Lid_Opening_Sender_Cycle_Data-trace_7,10,
ENG121948-ENG121886,Rear_Lid_Opening_Sender_Cycle_Data-trace_8,10,
ENG121948-ENG121887,Rear_Lid_Opening_Sender_Cycle_Data-trace_9,10,
ENG121949,Rear_Lid_Opening_Sender_ROM-Parameter_Version,593920,
ENG254841-ENG255534,User State Server-Comfort Ready Status,active,
ENG254841-ENG255633,User State Server-Driver Presence Status,driver_present_verified,
ENG254841-ENG255634,User State Server-Driver Presence_Qbit,gueltiger_Wert,
ENG254841-ENG255639,User State Server-DTC OccupantPresenceService Error,no error,
ENG254841-ENG255640,User State Server-DTC OccupantPresenceService Restriction,no restriction,
ENG254841-ENG255787,User State Server-HV_Anwesenheit,HV request,
ENG254841-ENG256105,User State Server-Occupant Presence Status,OccupantPresentVerified,
ENG254841-ENG256557,User State Server-USS CAN Nachlauf,NM Level 2,
ENG286726-MAS06517,Vip_sliding_door_driver_side_power_opening_control_unit_counter_values-Rear spoiler counter,0,
ENG286726-MAS12705,Vip_sliding_door_driver_side_power_opening_control_unit_counter_values-Number of detected proximities,25,
ENG286726-MAS12706,Vip_sliding_door_driver_side_power_opening_control_unit_counter_values-Number of detected kick movements,0,
ENG286726-MAS12707,Vip_sliding_door_driver_side_power_opening_control_unit_counter_values-Number of transmitter activations,0,
ENG286727-MAS04394,Vip_sliding_door_driver_side_power_openingcontrol_unit_sender_status-Connection status,Yes,
ENG286727-MAS09384,Vip_sliding_door_driver_side_power_openingcontrol_unit_sender_status-Proximity detected: sensor 1,No,
ENG286727-MAS09385,Vip_sliding_door_driver_side_power_openingcontrol_unit_sender_status-Proximity detected: sensor 2,No,
ENG286728-ENG121879,Vip_sliding_door_passenger_door_opening_sender_cycle_data-trace_1,10,
ENG286728-ENG121888,Vip_sliding_door_passenger_door_opening_sender_cycle_data-trace_10,10,
ENG286728-ENG121889,Vip_sliding_door_passenger_door_opening_sender_cycle_data-trace_11,10,
ENG286728-ENG121890,Vip_sliding_door_passenger_door_opening_sender_cycle_data-trace_12,70,
ENG286728-ENG121891,Vip_sliding_door_passenger_door_opening_sender_cycle_data-trace_13,70,
ENG286728-ENG121892,Vip_sliding_door_passenger_door_opening_sender_cycle_data-trace_14,10,
ENG286728-ENG121893,Vip_sliding_door_passenger_door_opening_sender_cycle_data-trace_15,70,
ENG286728-ENG121894,Vip_sliding_door_passenger_door_opening_sender_cycle_data-trace_16,10,
ENG286728-ENG121895,Vip_sliding_door_passenger_door_opening_sender_cycle_data-trace_17,10,
ENG286728-ENG121896,Vip_sliding_door_passenger_door_opening_sender_cycle_data-trace_18,70,
ENG286728-ENG121897,Vip_sliding_door_passenger_door_opening_sender_cycle_data-trace_19,10,
ENG286728-ENG121880,Vip_sliding_door_passenger_door_opening_sender_cycle_data-trace_2,10,
ENG286728-ENG121898,Vip_sliding_door_passenger_door_opening_sender_cycle_data-trace_20,10,
ENG286728-ENG121881,Vip_sliding_door_passenger_door_opening_sender_cycle_data-trace_3,10,
ENG286728-ENG121882,Vip_sliding_door_passenger_door_opening_sender_cycle_data-trace_4,10,
ENG286728-ENG121883,Vip_sliding_door_passenger_door_opening_sender_cycle_data-trace_5,10,
ENG286728-ENG121884,Vip_sliding_door_passenger_door_opening_sender_cycle_data-trace_6,10,
ENG286728-ENG121885,Vip_sliding_door_passenger_door_opening_sender_cycle_data-trace_7,10,
ENG286728-ENG121886,Vip_sliding_door_passenger_door_opening_sender_cycle_data-trace_8,10,
ENG286728-ENG121887,Vip_sliding_door_passenger_door_opening_sender_cycle_data-trace_9,10,
ENG286731-MAS06517,Vip_sliding_door_passenger_side_power_opening_control_unit_counter_values-Rear spoiler counter,16,
ENG286731-MAS12705,Vip_sliding_door_passenger_side_power_opening_control_unit_counter_values-Number of detected proximities,16,
ENG286731-MAS12706,Vip_sliding_door_passenger_side_power_opening_control_unit_counter_values-Number of detected kick movements,16,
ENG286731-MAS12707,Vip_sliding_door_passenger_side_power_opening_control_unit_counter_values-Number of transmitter activations,16,
ENG286732-MAS04394,Vip_sliding_door_passenger_side_power_opening_control_unit_sender_status-Connection status,Yes,
ENG286732-MAS09384,Vip_sliding_door_passenger_side_power_opening_control_unit_sender_status-Proximity detected: sensor 1,No,
ENG286732-MAS09385,Vip_sliding_door_passenger_side_power_opening_control_unit_sender_status-Proximity detected: sensor 2,No,
Elapsed Time: 02:55
Jef
HQ
blockmap-23-1N3-909-059-AA_WVG5WVEB2SH017765-20250325-1227.CSV
;SW:1N3-909-059-AA   HW:1N3-909-059 ---  Brake Booster
;Component:EBB-ZF-Gen1   H47 0853, Coding:A0404080600028
;EV_BrakeBoostZFMEBUNECE,001034,EV_BrakeBoostZFMEBUNECE.rod
;Tuesday,25,March,2025,12:27:33:58926
;VCDS Version: Release 25.3.0 (x64)  Data version: 20250311 DS365.0
;VCID: 74BAB2C64E354D4A9BE-8020-R SFD+SFD2
Group,Description,Actual
IDE06422-ENG103176,IUMPR_1-General Denominator,12320,
IDE06422-ENG102823,IUMPR_1-Ignition Cycle Counter,12336,
IDE06422-ENG100120,IUMPR_1-Milage,123360, km
IDE06422-ENG102846,IUMPR_1-Number of IUMPR Records,48,
IDE06423-ENG101817,IUMPR_2-Denominator,12320,
IDE06423-ENG103772,IUMPR_2-DFCC Value,12336,
IDE06423-ENG99150,IUMPR_2-Numerator,12336,
IDE06423-ENG101622,IUMPR_2-Record Number,48,
IDE06424-ENG101817,IUMPR_3-Denominator,12320,
IDE06424-ENG103772,IUMPR_3-DFCC Value,12336,
IDE06424-ENG99150,IUMPR_3-Numerator,12336,
IDE06424-ENG101622,IUMPR_3-Record Number,48,
IDE07159-MAS05583,Control module switch-off: counter-Data bus,1,
IDE08586-IDE02955,Status: electromechanical power brake-System status,ready,
IDE10300,OBD Driving Cycle detected,active,
IDE13138-MAS03034,Sluggishness test-Pressure,0.00, bar
IDE13138-MAS10346,Sluggishness test-Engine torque,0.00, Nm
IDE13138-MAS19863,Sluggishness test-Status of parking brake: electromechanical,0,
IDE13138-MAS19866,Sluggishness test-Travel pressure rod,0.000000, mm
IDE13845,Production mode status,not active,
IDE14696-MAS03458,Leak test-Differential pressure,0.00, bar
IDE14696-MAS19863,Leak test-Status of parking brake: electromechanical,0,
IDE14696-MAS19864,Leak test-Brake pressure 1,0, bar
IDE14696-MAS19865,Leak test-Brake pressure 2,0, bar
Elapsed Time: 00:03
blockmap-2B-3WA-905-861_WVG5WVEB2SH017765-20250325-1227.CSV
;SW:3WA-905-861   HW:3WA-905-861 ---  Steer. Col. Lock
;Component:ELV-MQB_UNECE H05 0063, Coding:8880000000000000
;EV_ELVMarqUNECE,003006,EV_ELVMarqUNECE_003_VW27.rod
;Tuesday,25,March,2025,12:27:49:58926
;VCID: 0842F63622BD59AAC76-805C-R SFD+SFD2
IDE00019,Voltage terminal 30,15.1,
IDE00021,Engine speed,128.00, /min
IDE00021-MAS00058,Engine speed-Implausible,No,
IDE00021-MAS00103,Engine speed-invalid,No,
IDE00021-MAS02239,Engine speed-outdated,No,
IDE00021-MAS02246,Engine speed-Timeout,No,
IDE00075-MAS00058,Vehicle speed-Implausible,No,
IDE00075-MAS00103,Vehicle speed-invalid,No,
IDE00075-MAS02246,Vehicle speed-Timeout,No,
IDE00096-MAS02239,Selector lever position-outdated,No,
IDE00096-MAS02246,Selector lever position-Timeout,No,
IDE00096,Selector lever position,not OK.,
IDE00660-MAS02246,Drive readiness-Timeout,No,
IDE00660,Drive readiness,not active,
IDE01766-MAS03714,Distance impulses-Left front wheel,0,
IDE01766-MAS03715,Distance impulses-Right front wheel,0,
IDE01766-MAS03716,Distance impulses-Left rear wheel,0,
IDE01766-MAS03717,Distance impulses-Right rear wheel,0,
IDE01766-MAS11907,Distance impulses-Left front wheel signal state timeout,No,
IDE01766-MAS11908,Distance impulses-Right front wheel signal state timeout,No,
IDE01766-MAS11909,Distance impulses-Left rear wheel signal state timeout,No,
IDE01766-MAS11910,Distance impulses-Right rear wheel signal state timeout,No,
IDE01766-MAS11911,Distance impulses-Left front wheel invalid signal state,No,
IDE01766-MAS11912,Distance impulses-Right front wheel invalid signal state,No,
IDE01766-MAS11913,Distance impulses-Left rear wheel invalid signal state,No,
IDE01766-MAS11914,Distance impulses-Right rear wheel invalid signal state,No,
IDE02569-MAS02242,Terminal S: line status-Electronic central electric actual value,On,
IDE02569-MAS02246,Terminal S: line status-Timeout,No,
IDE02570-MAS02242,Terminal 15: line status-Electronic central electric actual value,On,
IDE02570-MAS02246,Terminal 15: line status-Timeout,No,
IDE02573,End switch for steering column: unlocked: status,operated,
IDE02574,End switch for steering column: locked: status,Not operated,
IDE02575,Unlocking motor: activation status,not activated,
IDE02576,Locking motor: activation status,not activated,
IDE02577,Steering column twisting: status,not twisted,
IDE02579-MAS02246,Park selector lever position-Timeout,No,
IDE02579,Park selector lever position,locked,
IDE02580,Number of unlocks,129,
IDE02588,Terminal signals and start release,not enabled,
IDE02589-MAS02246,Rotary latch status-Timeout,No,
IDE02589,Rotary latch status,Closed,
IDE02590-MAS02246,External vehicle locking: SPECIFIED condition-Timeout,No,
IDE02590-MAS02257,External vehicle locking: SPECIFIED condition-SPECIFIED condition of fuse per remote/key,Vehicle not secured,
IDE02590,External vehicle locking: SPECIFIED condition,unlocked,
IDE02759-MAS02345,Steering column lock current condition/learn mode-Current condition,Immobilizer download obtained,
IDE02759-MAS02349,Steering column lock current condition/learn mode-Learn mode,Adapted,
IDE03527-IDE03411,CAN signals-Red warning lamp,not active,
IDE03527-MAS04444,CAN signals-Wake-up,not active,
IDE03527-MAS05099,CAN signals-Driver information: steering column lock defective,not active,
IDE03527-MAS05100,CAN signals-Driver information: steering column lock: workshop,not active,
IDE03527-MAS05101,CAN signals-Driver information: move steering,not active,
IDE06746-IDE00020,Locking requirements-Terminal 15 status,Condition not met,
IDE06746-IDE00021,Locking requirements-Engine speed,Condition not met,
IDE06746-IDE00075,Locking requirements-Vehicle speed,Condition met,
IDE06746-IDE00660,Locking requirements-Drive readiness,Condition not met,
IDE06746-IDE01715,Locking requirements-Status terminal S,Condition not met,
IDE06746-IDE01766,Locking requirements-Distance impulses,Condition met,
IDE06746-IDE02052,Locking requirements-Malfunction message in instrument panel,Condition met,
IDE06746-IDE02579,Locking requirements-Park selector lever position,Condition not met,
IDE06746-MAS02349,Locking requirements-Learn mode,Adapted,
IDE06746-MAS08251,Locking requirements-Vehicle speed signals: communication status,Condition met,
IDE06746-MAS08252,Locking requirements-Terminal status signal: communication status,Condition met,
IDE06746-MAS08441,Locking requirements-Test of locking requirements,not active,
IDE06746-MAS08791,Locking requirements-Vehicle speed signals: cyclical reception,Condition met,
IDE06746-MAS08792,Locking requirements-Signals for distance pulses: cyclical reception,Condition met,
IDE06746-MAS08794,Locking requirements-Terminal status signal: cyclical reception,Condition met,
IDE06746-MAS11697,Locking requirements-Signals for distance pulses: communication status,Condition met,
IDE09059-MAS02246,Request terminal release-Timeout,No,
IDE09059,Request terminal release,No,
IDE09064,Status: unlock trigger,No,
IDE09065-MAS02246,Status: remote start-Timeout,No,
IDE09065,Status: remote start,not active,
IDE09066-MAS02246,ID sensor exiting vehicle-Timeout,No,
IDE09066,ID sensor exiting vehicle,No,
ENG111213-ENG128873,Activated_Fault_Reactions-Locking disabled,No,
ENG128821-ENG111184,Errorcounter lifetime-AD-Converter corrupt,0,
ENG128821-ENG128856,Errorcounter lifetime-AD-Converter corrupt unlocking cycle,No,
ENG128821-ENG128851,Errorcounter lifetime-Areacheck highside,0,
ENG128821-ENG128852,Errorcounter lifetime-Areacheck highside unlocking cycle,No,
ENG128821-ENG128853,Errorcounter lifetime-Areacheck lowside,0,
ENG128821-ENG128854,Errorcounter lifetime-Areacheck lowside unlocking cycle,No,
ENG128821-ENG111176,Errorcounter lifetime-CoCo RAM-Check,0,
ENG128821-ENG128846,Errorcounter lifetime-CoCo RAM-Check unlocking cycle,No,
ENG128821-ENG111177,Errorcounter lifetime-CoCo ROM-Check,0,
ENG128821-ENG128847,Errorcounter lifetime-CoCo ROM-Check unlocking cycle,No,
ENG128821-ENG111194,Errorcounter lifetime-CPU-Test CoCo,0,
ENG128821-ENG128848,Errorcounter lifetime-CPU-Test CoCo unlocking cycle,No,
ENG128821-ENG111192,Errorcounter lifetime-CPU-Test HaCo,0,
ENG128821-ENG128844,Errorcounter lifetime-CPU-Test HaCo unlocking cycle,No,
ENG128821-ENG111187,Errorcounter lifetime-Enable CoCo incorrect active locking,0,
ENG128821-ENG128858,Errorcounter lifetime-Enable CoCo incorrect active locking unlocking cycle,No,
ENG128821-ENG111181,Errorcounter lifetime-Endposition switches implausible,0,
ENG128821-ENG128855,Errorcounter lifetime-Endposition switches implausible unlocking cycle,No,
ENG128821-ENG128872,Errorcounter lifetime-Endposition_Button_Unlocked_Change_To_Not_Activated_While_Driving,0,
ENG128821-ENG128870,Errorcounter lifetime-Endposition_Locked_Not_Reached,0,
ENG128821-ENG128871,Errorcounter lifetime-Endposition_Locked_Not_Reached unlocking cycle,No,
ENG128821-ENG162685,Errorcounter lifetime-HaCo CAN-Cell-Check,0,
ENG128821-ENG162686,Errorcounter lifetime-HaCo CAN-Cell-Check unlocking cycle,No,
ENG128821-ENG111185,Errorcounter lifetime-HaCo CoCo communication disturbed,0,
ENG128821-ENG128857,Errorcounter lifetime-HaCo CoCo communication disturbed unlocking cycle,No,
ENG128821-ENG352066,Errorcounter lifetime-HaCo ECC Flash Check,0,
ENG128821-ENG352780,Errorcounter lifetime-HaCo ECC Flash-Check unlocking cycle,No,
ENG128821-ENG356279,Errorcounter lifetime-HaCo ECC SRAM Check,0,
ENG128821-ENG355067,Errorcounter lifetime-HaCo ECC SRAM-Check unlocking cycle,No,
ENG128821-ENG111175,Errorcounter lifetime-HaCo EEPROM-Check,0,
ENG128821-ENG128845,Errorcounter lifetime-HaCo EEPROM-Check unlocking cycle,No,
ENG128821-ENG111173,Errorcounter lifetime-HaCo RAM-Check,0,
ENG128821-ENG128842,Errorcounter lifetime-HaCo RAM-Check unlocking cycle,No,
ENG128821-ENG111174,Errorcounter lifetime-HaCo ROM-Check,0,
ENG128821-ENG128843,Errorcounter lifetime-HaCo ROM-Check unlocking cycle,No,
ENG128821-ENG353074,Errorcounter lifetime-Hardfault HaCo Check,0,
ENG128821-ENG352312,Errorcounter lifetime-Hardfault HaCo unlocking cycle,No,
ENG128821-ENG128868,Errorcounter lifetime-Invalid eeprom data immobilizer,0,
ENG128821-ENG128869,Errorcounter lifetime-Invalid eeprom data immobilizer unlocking cycle,No,
ENG128821-ENG357002,Errorcounter lifetime-Memory Management HaCo Check,0,
ENG128821-ENG355666,Errorcounter lifetime-Memory Management HaCo unlocking cycle,No,
ENG128821-ENG111189,Errorcounter lifetime-No CoCo enable locking,0,
ENG128821-ENG128859,Errorcounter lifetime-No CoCo enable locking unlocking cycle,No,
ENG128821-ENG111195,Errorcounter lifetime-Program sequence CoCo,0,
ENG128821-ENG128863,Errorcounter lifetime-Program sequence CoCo unlocking cycle,No,
ENG128821-ENG111193,Errorcounter lifetime-Program sequence HaCo,0,
ENG128821-ENG128862,Errorcounter lifetime-Program sequence HaCo unlocking cycle,No,
ENG128821-ENG111190,Errorcounter lifetime-Reset HaCo CoCo failed,0,
ENG128821-ENG128860,Errorcounter lifetime-Reset HaCo CoCo failed unlocking cycle,No,
ENG128821-ENG111191,Errorcounter lifetime-Reset SBC HaCo failed,0,
ENG128821-ENG128861,Errorcounter lifetime-Reset SBC HaCo failed unlocking cycle,No,
ENG128821-ENG119956,Errorcounter lifetime-Return address,00 00 00 00,
ENG128821-ENG128866,Errorcounter lifetime-SDA-Error CoCo,0,
ENG128821-ENG128867,Errorcounter lifetime-SDA-Error CoCo unlocking cycle,No,
ENG128821-ENG128864,Errorcounter lifetime-SDA-Error HaCo,0,
ENG128821-ENG128865,Errorcounter lifetime-SDA-Error HaCo unlocking cycle,No,
ENG128821-ENG111179,Errorcounter lifetime-Shortcut motor driver highside,0,
ENG128821-ENG128849,Errorcounter lifetime-Shortcut motor driver highside unlocking cycle,No,
ENG128821-ENG111180,Errorcounter lifetime-Shortcut motor driver lowside,0,
ENG128821-ENG128850,Errorcounter lifetime-Shortcut motor driver lowside unlocking cycle,No,
ENG128821-ENG353840,Errorcounter lifetime-Usage Fault HaCo Check,0,
ENG128821-ENG354256,Errorcounter lifetime-Usage Fault HaCo unlocking cycle,No,
ENG128820,Free_Releases_Numbers,256,
ENG128822-MAS02538,functional_check-End of assembly line OK,Confirmed,
ENG128822-ENG128823,functional_check-functional_check_manufacturer,Confirmed,
ENG128822-ENG128824,functional_check-functional_check_steering_column_supplier,Not confirmed,
Elapsed Time: 00:05
blockmap-36-1N3-959-760-H_WVG5WVEB2SH017765-20250325-1228.CSV
;SW:1N3-959-760-H   HW:1N3-959-760-H ---  Seat Mem. Drvr
;Component:MEM-FS        011 0571, Coding:0118BA4000013A008803010121010000000000000000000000000000215000
;EV_SCMDriveSideCONTIAU736,006013,EV_SCMDriveSideCONTIAU736_VW42.rod
;Tuesday,25,March,2025,12:28:02:58926
;VCID: 3E2E50EE30F9D71ABDA-806A-R
IDE00019-MAS00043,Voltage terminal 30-Terminal 30 power supply,14.70, V
IDE00102,Control Module temperature,40,
IDE00787,Cause for cancellation,none,
IDE01277-IDE09268,Counter of compressor activations-Switch on occurrences of compressor,0, counts
IDE01277-MAS06166,Counter of compressor activations-Current operation time,0, s
IDE01457,Energy management deactivation stage,Deactivation stage 0,
IDE05738-MAS12801,Subssystem diagnosis classes-DK0 systems supported,DK0 systems not supported,
IDE05738-MAS12803,Subssystem diagnosis classes-DK1 systems supported,DK1 systems not supported,
IDE05738-MAS12805,Subssystem diagnosis classes-DK2/DK2F systems supported,DK2/DK2F systems not supported,
IDE05738-MAS12807,Subssystem diagnosis classes-DK3 or DK4 high/low systems supported,DK3 or DK4 high/low systems not supported,
IDE06510-MAS01390,Adjustment for backrest angle-Block 1,34058,
IDE06510-MAS01391,Adjustment for backrest angle-Block 2,32475,
IDE06510-MAS02282,Adjustment for backrest angle-Position,32735,
IDE06510-MAS02955,Adjustment for backrest angle-Engine temperature,25, °C
IDE06510-MAS03129,Adjustment for backrest angle-Reset counter,33,
IDE06510-MAS04160,Adjustment for backrest angle-Load change,34,
IDE06510-MAS04337,Adjustment for backrest angle-Engine current,0, A
IDE06510-MAS05370,Adjustment for backrest angle-Direction of movement,Not operated,
IDE06510-MAS05563,Adjustment for backrest angle-Norming,standardized,
IDE06510-MAS05719,Adjustment for backrest angle-Maximum travel,1583,
IDE06510-MAS12838,Adjustment for backrest angle-Standardization flag,standardized,
IDE06511-MAS01390,Seat height adjustment-Block 1,33270,
IDE06511-MAS01391,Seat height adjustment-Block 2,32769,
IDE06511-MAS02282,Seat height adjustment-Position,33173,
IDE06511-MAS02955,Seat height adjustment-Engine temperature,25, °C
IDE06511-MAS03129,Seat height adjustment-Reset counter,15,
IDE06511-MAS04160,Seat height adjustment-Load change,26,
IDE06511-MAS04337,Seat height adjustment-Engine current,0, A
IDE06511-MAS05370,Seat height adjustment-Direction of movement,Not operated,
IDE06511-MAS05563,Seat height adjustment-Norming,standardized,
IDE06511-MAS05719,Seat height adjustment-Maximum travel,501,
IDE06511-MAS12838,Seat height adjustment-Standardization flag,standardized,
IDE06512-MAS01390,Adjustment for seat forward/back position-Block 1,33104,
IDE06512-MAS01391,Adjustment for seat forward/back position-Block 2,32552,
IDE06512-MAS02282,Adjustment for seat forward/back position-Position,32931,
IDE06512-MAS02955,Adjustment for seat forward/back position-Engine temperature,25, °C
IDE06512-MAS03129,Adjustment for seat forward/back position-Reset counter,250,
IDE06512-MAS04160,Adjustment for seat forward/back position-Load change,321,
IDE06512-MAS04337,Adjustment for seat forward/back position-Engine current,0, A
IDE06512-MAS05370,Adjustment for seat forward/back position-Direction of movement,Not operated,
IDE06512-MAS05563,Adjustment for seat forward/back position-Norming,standardized,
IDE06512-MAS05719,Adjustment for seat forward/back position-Maximum travel,552,
IDE06512-MAS12838,Adjustment for seat forward/back position-Standardization flag,standardized,
IDE06614-IDE06842,Memory seat adjustment control head-Status - Button 1,not active,
IDE06614-IDE06843,Memory seat adjustment control head-Status - Button 2,not active,
IDE06614-IDE06844,Memory seat adjustment control head-Status - Button 3,not active,
IDE06614-IDE06845,Memory seat adjustment control head-Status - Button 4,not active,
IDE06614-MAS01601,Memory seat adjustment control head-storing,not active,
IDE06683-MAS01390,Seat inclination adjustment-Block 1,33040,
IDE06683-MAS01391,Seat inclination adjustment-Block 2,32771,
IDE06683-MAS02282,Seat inclination adjustment-Position,33024,
IDE06683-MAS02955,Seat inclination adjustment-Engine temperature,25, °C
IDE06683-MAS03129,Seat inclination adjustment-Reset counter,1,
IDE06683-MAS04160,Seat inclination adjustment-Load change,13,
IDE06683-MAS04337,Seat inclination adjustment-Engine current,0, A
IDE06683-MAS05370,Seat inclination adjustment-Direction of movement,Not operated,
IDE06683-MAS05563,Seat inclination adjustment-Norming,standardized,
IDE06683-MAS05719,Seat inclination adjustment-Maximum travel,269,
IDE06683-MAS12838,Seat inclination adjustment-Standardization flag,standardized,
IDE06684-MAS01390,Lumbar support height adjustment-Block 1,0,
IDE06684-MAS01391,Lumbar support height adjustment-Block 2,0,
IDE06684-MAS02282,Lumbar support height adjustment-Position,0,
IDE06684-MAS02955,Lumbar support height adjustment-Engine temperature,0, °C
IDE06684-MAS03129,Lumbar support height adjustment-Reset counter,0,
IDE06684-MAS04160,Lumbar support height adjustment-Load change,0,
IDE06684-MAS04337,Lumbar support height adjustment-Engine current,0, A
IDE06684-MAS05370,Lumbar support height adjustment-Direction of movement,Not operated,
IDE06684-MAS05563,Lumbar support height adjustment-Norming,not normed,
IDE06684-MAS05719,Lumbar support height adjustment-Maximum travel,0,
IDE06684-MAS12838,Lumbar support height adjustment-Standardization flag,never normed,
IDE06685-MAS01390,Lumbar support longitudinal position adjustment-Block 1,0,
IDE06685-MAS01391,Lumbar support longitudinal position adjustment-Block 2,0,
IDE06685-MAS02282,Lumbar support longitudinal position adjustment-Position,0,
IDE06685-MAS02955,Lumbar support longitudinal position adjustment-Engine temperature,0, °C
IDE06685-MAS03129,Lumbar support longitudinal position adjustment-Reset counter,0,
IDE06685-MAS04160,Lumbar support longitudinal position adjustment-Load change,0,
IDE06685-MAS04337,Lumbar support longitudinal position adjustment-Engine current,0, A
IDE06685-MAS05370,Lumbar support longitudinal position adjustment-Direction of movement,Not operated,
IDE06685-MAS05563,Lumbar support longitudinal position adjustment-Norming,not normed,
IDE06685-MAS05719,Lumbar support longitudinal position adjustment-Maximum travel,0,
IDE06685-MAS12838,Lumbar support longitudinal position adjustment-Standardization flag,never normed,
IDE06871-IDE06510,Seat adjustment control head-Adjustment for backrest angle,Not operated,
IDE06871-IDE06511,Seat adjustment control head-Seat height adjustment,Not operated,
IDE06871-IDE06512,Seat adjustment control head-Adjustment for seat forward/back position,Not operated,
IDE06871-IDE06683,Seat adjustment control head-Seat inclination adjustment,Not operated,
IDE06871-IDE06684,Seat adjustment control head-Lumbar support height adjustment,Not operated,
IDE06871-IDE06685,Seat adjustment control head-Lumbar support longitudinal position adjustment,Not operated,
IDE06871-IDE08989,Seat adjustment control head-Seat depth adjustment,Not operated,
IDE06871-IDE08990,Seat adjustment control head-Backrest top adjustment,Not operated,
IDE06871-IDE08991,Seat adjustment control head-Belt height adjustment,Not operated,
IDE06871-IDE11024,Seat adjustment control head-Headrest height adjustment,Not operated,
IDE06871-IDE11025,Seat adjustment control head-Headrest length adjustment,Not operated,
IDE07159,Control module switch-off: counter,0,
IDE07347-IDE06510,Memory setting 1 for seat adjustment-Adjustment for backrest angle,0,
IDE07347-IDE06511,Memory setting 1 for seat adjustment-Seat height adjustment,0,
IDE07347-IDE06512,Memory setting 1 for seat adjustment-Adjustment for seat forward/back position,0,
IDE07347-IDE06683,Memory setting 1 for seat adjustment-Seat inclination adjustment,0,
IDE07347-IDE06684,Memory setting 1 for seat adjustment-Lumbar support height adjustment,0,
IDE07347-IDE06685,Memory setting 1 for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07347-IDE08989,Memory setting 1 for seat adjustment-Seat depth adjustment,0,
IDE07347-IDE08990,Memory setting 1 for seat adjustment-Backrest top adjustment,0,
IDE07347-IDE08991,Memory setting 1 for seat adjustment-Belt height adjustment,0,
IDE07347-IDE11024,Memory setting 1 for seat adjustment-Headrest height adjustment,0,
IDE07348-IDE06510,Memory setting 2 for seat adjustment-Adjustment for backrest angle,0,
IDE07348-IDE06511,Memory setting 2 for seat adjustment-Seat height adjustment,0,
IDE07348-IDE06512,Memory setting 2 for seat adjustment-Adjustment for seat forward/back position,0,
IDE07348-IDE06683,Memory setting 2 for seat adjustment-Seat inclination adjustment,0,
IDE07348-IDE06684,Memory setting 2 for seat adjustment-Lumbar support height adjustment,0,
IDE07348-IDE06685,Memory setting 2 for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07348-IDE08989,Memory setting 2 for seat adjustment-Seat depth adjustment,0,
IDE07348-IDE08990,Memory setting 2 for seat adjustment-Backrest top adjustment,0,
IDE07348-IDE08991,Memory setting 2 for seat adjustment-Belt height adjustment,0,
IDE07348-IDE11024,Memory setting 2 for seat adjustment-Headrest height adjustment,0,
IDE07349-IDE06510,Memory setting 3 for seat adjustment-Adjustment for backrest angle,0,
IDE07349-IDE06511,Memory setting 3 for seat adjustment-Seat height adjustment,0,
IDE07349-IDE06512,Memory setting 3 for seat adjustment-Adjustment for seat forward/back position,0,
IDE07349-IDE06683,Memory setting 3 for seat adjustment-Seat inclination adjustment,0,
IDE07349-IDE06684,Memory setting 3 for seat adjustment-Lumbar support height adjustment,0,
IDE07349-IDE06685,Memory setting 3 for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07349-IDE08989,Memory setting 3 for seat adjustment-Seat depth adjustment,0,
IDE07349-IDE08990,Memory setting 3 for seat adjustment-Backrest top adjustment,0,
IDE07349-IDE08991,Memory setting 3 for seat adjustment-Belt height adjustment,0,
IDE07349-IDE11024,Memory setting 3 for seat adjustment-Headrest height adjustment,0,
IDE07350-IDE06510,Memory setting 4 for seat adjustment-Adjustment for backrest angle,0,
IDE07350-IDE06511,Memory setting 4 for seat adjustment-Seat height adjustment,0,
IDE07350-IDE06512,Memory setting 4 for seat adjustment-Adjustment for seat forward/back position,0,
IDE07350-IDE06683,Memory setting 4 for seat adjustment-Seat inclination adjustment,0,
IDE07350-IDE06684,Memory setting 4 for seat adjustment-Lumbar support height adjustment,0,
IDE07350-IDE06685,Memory setting 4 for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07350-IDE08989,Memory setting 4 for seat adjustment-Seat depth adjustment,0,
IDE07350-IDE08990,Memory setting 4 for seat adjustment-Backrest top adjustment,0,
IDE07350-IDE08991,Memory setting 4 for seat adjustment-Belt height adjustment,0,
IDE07350-IDE11024,Memory setting 4 for seat adjustment-Headrest height adjustment,0,
IDE07351-IDE06510,Memory setting 1: remote master key for seat adjustment-Adjustment for backrest angle,32735,
IDE07351-IDE06511,Memory setting 1: remote master key for seat adjustment-Seat height adjustment,33173,
IDE07351-IDE06512,Memory setting 1: remote master key for seat adjustment-Adjustment for seat forward/back position,32708,
IDE07351-IDE06683,Memory setting 1: remote master key for seat adjustment-Seat inclination adjustment,33024,
IDE07351-IDE06684,Memory setting 1: remote master key for seat adjustment-Lumbar support height adjustment,0,
IDE07351-IDE06685,Memory setting 1: remote master key for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07351-IDE08989,Memory setting 1: remote master key for seat adjustment-Seat depth adjustment,0,
IDE07351-IDE08990,Memory setting 1: remote master key for seat adjustment-Backrest top adjustment,0,
IDE07351-IDE08991,Memory setting 1: remote master key for seat adjustment-Belt height adjustment,0,
IDE07351-IDE11024,Memory setting 1: remote master key for seat adjustment-Headrest height adjustment,0,
IDE07352-IDE06510,Memory setting 2: remote master key for seat adjustment-Adjustment for backrest angle,0,
IDE07352-IDE06511,Memory setting 2: remote master key for seat adjustment-Seat height adjustment,0,
IDE07352-IDE06512,Memory setting 2: remote master key for seat adjustment-Adjustment for seat forward/back position,0,
IDE07352-IDE06683,Memory setting 2: remote master key for seat adjustment-Seat inclination adjustment,0,
IDE07352-IDE06684,Memory setting 2: remote master key for seat adjustment-Lumbar support height adjustment,0,
IDE07352-IDE06685,Memory setting 2: remote master key for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07352-IDE08989,Memory setting 2: remote master key for seat adjustment-Seat depth adjustment,0,
IDE07352-IDE08990,Memory setting 2: remote master key for seat adjustment-Backrest top adjustment,0,
IDE07352-IDE08991,Memory setting 2: remote master key for seat adjustment-Belt height adjustment,0,
IDE07352-IDE11024,Memory setting 2: remote master key for seat adjustment-Headrest height adjustment,0,
IDE07353-IDE06510,Memory setting 3: remote master key for seat adjustment-Adjustment for backrest angle,0,
IDE07353-IDE06511,Memory setting 3: remote master key for seat adjustment-Seat height adjustment,0,
IDE07353-IDE06512,Memory setting 3: remote master key for seat adjustment-Adjustment for seat forward/back position,0,
IDE07353-IDE06683,Memory setting 3: remote master key for seat adjustment-Seat inclination adjustment,0,
IDE07353-IDE06684,Memory setting 3: remote master key for seat adjustment-Lumbar support height adjustment,0,
IDE07353-IDE06685,Memory setting 3: remote master key for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07353-IDE08989,Memory setting 3: remote master key for seat adjustment-Seat depth adjustment,0,
IDE07353-IDE08990,Memory setting 3: remote master key for seat adjustment-Backrest top adjustment,0,
IDE07353-IDE08991,Memory setting 3: remote master key for seat adjustment-Belt height adjustment,0,
IDE07353-IDE11024,Memory setting 3: remote master key for seat adjustment-Headrest height adjustment,0,
IDE07354-IDE06510,Memory setting 4: remote master key for seat adjustment-Adjustment for backrest angle,0,
IDE07354-IDE06511,Memory setting 4: remote master key for seat adjustment-Seat height adjustment,0,
IDE07354-IDE06512,Memory setting 4: remote master key for seat adjustment-Adjustment for seat forward/back position,0,
IDE07354-IDE06683,Memory setting 4: remote master key for seat adjustment-Seat inclination adjustment,0,
IDE07354-IDE06684,Memory setting 4: remote master key for seat adjustment-Lumbar support height adjustment,0,
IDE07354-IDE06685,Memory setting 4: remote master key for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07354-IDE08989,Memory setting 4: remote master key for seat adjustment-Seat depth adjustment,0,
IDE07354-IDE08990,Memory setting 4: remote master key for seat adjustment-Backrest top adjustment,0,
IDE07354-IDE08991,Memory setting 4: remote master key for seat adjustment-Belt height adjustment,0,
IDE07354-IDE11024,Memory setting 4: remote master key for seat adjustment-Headrest height adjustment,0,
IDE08989-MAS01390,Seat depth adjustment-Block 1,0,
IDE08989-MAS01391,Seat depth adjustment-Block 2,0,
IDE08989-MAS02282,Seat depth adjustment-Position,0,
IDE08989-MAS02955,Seat depth adjustment-Engine temperature,0, °C
IDE08989-MAS03129,Seat depth adjustment-Reset counter,0,
IDE08989-MAS04160,Seat depth adjustment-Load change,0,
IDE08989-MAS04337,Seat depth adjustment-Engine current,0, A
IDE08989-MAS05370,Seat depth adjustment-Direction of movement,Not operated,
IDE08989-MAS05563,Seat depth adjustment-Norming,not normed,
IDE08989-MAS05719,Seat depth adjustment-Maximum travel,0,
IDE08989-MAS12838,Seat depth adjustment-Standardization flag,never normed,
IDE08990-MAS01390,Backrest top adjustment-Block 1,0,
IDE08990-MAS01391,Backrest top adjustment-Block 2,0,
IDE08990-MAS02282,Backrest top adjustment-Position,0,
IDE08990-MAS02955,Backrest top adjustment-Engine temperature,0, °C
IDE08990-MAS03129,Backrest top adjustment-Reset counter,0,
IDE08990-MAS04160,Backrest top adjustment-Load change,0,
IDE08990-MAS04337,Backrest top adjustment-Engine current,0, A
IDE08990-MAS05370,Backrest top adjustment-Direction of movement,Not operated,
IDE08990-MAS05563,Backrest top adjustment-Norming,not normed,
IDE08990-MAS05719,Backrest top adjustment-Maximum travel,0,
IDE08990-MAS12838,Backrest top adjustment-Standardization flag,never normed,
IDE08991-MAS01390,Belt height adjustment-Block 1,0,
IDE08991-MAS01391,Belt height adjustment-Block 2,0,
IDE08991-MAS02282,Belt height adjustment-Position,0,
IDE08991-MAS02955,Belt height adjustment-Engine temperature,0, °C
IDE08991-MAS03129,Belt height adjustment-Reset counter,0,
IDE08991-MAS04160,Belt height adjustment-Load change,0,
IDE08991-MAS04337,Belt height adjustment-Engine current,0, A
IDE08991-MAS05370,Belt height adjustment-Direction of movement,Not operated,
IDE08991-MAS05563,Belt height adjustment-Norming,not normed,
IDE08991-MAS05719,Belt height adjustment-Maximum travel,0,
IDE08991-MAS12838,Belt height adjustment-Standardization flag,never normed,
IDE09081-MAS08291,Seat switch module-Plate: vertical actuation direction,Not operated,
IDE09081-MAS08292,Seat switch module-Plate: horizontal actuation direction,Not operated,
IDE09081-MAS08293,Seat switch module-Rocker,Not operated,
IDE09082,Massage button,Not operated,
IDE09083-MAS08294,Entry assistance button-Entry assistance button: actuation direction forward,Not operated,
IDE09083-MAS08295,Entry assistance button-Entry assistance button: actuation direction backward,Not operated,
IDE09084-MAS08296,Backrest lock switch-Switch state normally closed,operated,
IDE09084-MAS08297,Backrest lock switch-Switch state normally open,Not operated,
IDE09085,Backrest limit switch,Not operated,
IDE10995-IDE06510,Calibrating the motors: status-Adjustment for backrest angle,standardized,
IDE10995-IDE06511,Calibrating the motors: status-Seat height adjustment,standardized,
IDE10995-IDE06512,Calibrating the motors: status-Adjustment for seat forward/back position,standardized,
IDE10995-IDE06683,Calibrating the motors: status-Seat inclination adjustment,standardized,
IDE10995-IDE06684,Calibrating the motors: status-Lumbar support height adjustment,not normed,
IDE10995-IDE06685,Calibrating the motors: status-Lumbar support longitudinal position adjustment,not normed,
IDE10995-IDE08988,Calibrating the motors: status-Head restraint adjustment,not normed,
IDE10995-IDE08989,Calibrating the motors: status-Seat depth adjustment,not normed,
IDE10995-IDE08990,Calibrating the motors: status-Backrest top adjustment,not normed,
IDE10995-IDE08991,Calibrating the motors: status-Belt height adjustment,not normed,
IDE10995-IDE11957,Calibrating the motors: status-Display unit adjustment,not normed,
IDE10995-IDE11969,Calibrating the motors: status-Adjustment of foot rest,not normed,
IDE10995-IDE11986,Calibrating the motors: status-Adjustment 2 of visual display unit,not normed,
IDE10995-MAS11869,Calibrating the motors: status-Headrest adjustment: horizontal,not normed,
IDE10995-MAS11890,Calibrating the motors: status-Headrest adjustment: vertical,not normed,
IDE10996-MAS11891,Excessive force limit: status-Seat forward/back position adjustment: forwards,Adapted,
IDE10996-MAS11892,Excessive force limit: status-Seat forward/back position adjustment: backwards,Adapted,
IDE10996-MAS11895,Excessive force limit: status-Backrest inclination adjustment: forwards,Not adapted,
IDE10996-MAS11896,Excessive force limit: status-Backrest inclination adjustment: backwards,Not adapted,
IDE10996-MAS11959,Excessive force limit: status-Seat height adjustment higher,Not adapted,
IDE10996-MAS11960,Excessive force limit: status-Seat height adjustment lower,Not adapted,
IDE11024-MAS01390,Headrest height adjustment-Block 1,0,
IDE11024-MAS01391,Headrest height adjustment-Block 2,0,
IDE11024-MAS02282,Headrest height adjustment-Position,0,
IDE11024-MAS02955,Headrest height adjustment-Engine temperature,0, °C
IDE11024-MAS03129,Headrest height adjustment-Reset counter,0,
IDE11024-MAS04160,Headrest height adjustment-Load change,0,
IDE11024-MAS04337,Headrest height adjustment-Engine current,0, A
IDE11024-MAS05370,Headrest height adjustment-Direction of movement,Not operated,
IDE11024-MAS05563,Headrest height adjustment-Norming,not normed,
IDE11024-MAS05719,Headrest height adjustment-Maximum travel,0,
IDE11024-MAS12838,Headrest height adjustment-Standardization flag,never normed,
IDE11025-MAS01390,Headrest length adjustment-Block 1,0,
IDE11025-MAS01391,Headrest length adjustment-Block 2,0,
IDE11025-MAS02282,Headrest length adjustment-Position,0,
IDE11025-MAS02955,Headrest length adjustment-Engine temperature,0, °C
IDE11025-MAS03129,Headrest length adjustment-Reset counter,0,
IDE11025-MAS04160,Headrest length adjustment-Load change,0,
IDE11025-MAS04337,Headrest length adjustment-Engine current,0, A
IDE11025-MAS05370,Headrest length adjustment-Direction of movement,Not operated,
IDE11025-MAS05563,Headrest length adjustment-Norming,not normed,
IDE11025-MAS05719,Headrest length adjustment-Maximum travel,0,
IDE11025-MAS12838,Headrest length adjustment-Standardization flag,never normed,
IDE11957-MAS01390,Display unit adjustment-Block 1,0,
IDE11957-MAS01391,Display unit adjustment-Block 2,0,
IDE11957-MAS02282,Display unit adjustment-Position,0,
IDE11957-MAS02955,Display unit adjustment-Engine temperature,0, °C
IDE11957-MAS03129,Display unit adjustment-Reset counter,0,
IDE11957-MAS04160,Display unit adjustment-Load change,0,
IDE11957-MAS04337,Display unit adjustment-Engine current,0, A
IDE11957-MAS05370,Display unit adjustment-Direction of movement,Not operated,
IDE11957-MAS05563,Display unit adjustment-Norming,not normed,
IDE11957-MAS05719,Display unit adjustment-Maximum travel,0,
IDE11957-MAS12838,Display unit adjustment-Standardization flag,never normed,
IDE11969-MAS01390,Adjustment of foot rest-Block 1,0,
IDE11969-MAS01391,Adjustment of foot rest-Block 2,0,
IDE11969-MAS02282,Adjustment of foot rest-Position,0,
IDE11969-MAS02955,Adjustment of foot rest-Engine temperature,0, °C
IDE11969-MAS03129,Adjustment of foot rest-Reset counter,0,
IDE11969-MAS04160,Adjustment of foot rest-Load change,0,
IDE11969-MAS04337,Adjustment of foot rest-Engine current,0, A
IDE11969-MAS05370,Adjustment of foot rest-Direction of movement,Not operated,
IDE11969-MAS05563,Adjustment of foot rest-Norming,not normed,
IDE11969-MAS05719,Adjustment of foot rest-Maximum travel,0,
IDE11969-MAS12838,Adjustment of foot rest-Standardization flag,never normed,
IDE11986-MAS01390,Adjustment 2 of visual display unit-Block 1,0,
IDE11986-MAS01391,Adjustment 2 of visual display unit-Block 2,0,
IDE11986-MAS02282,Adjustment 2 of visual display unit-Position,0,
IDE11986-MAS02955,Adjustment 2 of visual display unit-Engine temperature,0, °C
IDE11986-MAS03129,Adjustment 2 of visual display unit-Reset counter,0,
IDE11986-MAS04160,Adjustment 2 of visual display unit-Load change,0,
IDE11986-MAS04337,Adjustment 2 of visual display unit-Engine current,0, A
IDE11986-MAS05370,Adjustment 2 of visual display unit-Direction of movement,Not operated,
IDE11986-MAS05563,Adjustment 2 of visual display unit-Norming,not normed,
IDE11986-MAS05719,Adjustment 2 of visual display unit-Maximum travel,0,
IDE11986-MAS12838,Adjustment 2 of visual display unit-Standardization flag,never normed,
IDE12083-MAS13890,Switch for lateral backrest support adjustment-Adjustment for lateral support backrest,Not operated,
IDE12083-MAS13891,Switch for lateral backrest support adjustment-Adjustment for lateral support seat cushion,Not operated,
MAS12838-IDE06510,Standardization flag-Adjustment for backrest angle,standardized,
MAS12838-IDE06511,Standardization flag-Seat height adjustment,standardized,
MAS12838-IDE06512,Standardization flag-Adjustment for seat forward/back position,standardized,
MAS12838-IDE06683,Standardization flag-Seat inclination adjustment,standardized,
MAS12838-IDE06684,Standardization flag-Lumbar support height adjustment,never normed,
MAS12838-IDE06685,Standardization flag-Lumbar support longitudinal position adjustment,never normed,
MAS12838-IDE08988,Standardization flag-Head restraint adjustment,never normed,
MAS12838-IDE08989,Standardization flag-Seat depth adjustment,never normed,
MAS12838-IDE08990,Standardization flag-Backrest top adjustment,never normed,
MAS12838-IDE08991,Standardization flag-Belt height adjustment,never normed,
MAS12838-IDE11957,Standardization flag-Display unit adjustment,never normed,
MAS12838-IDE11969,Standardization flag-Adjustment of foot rest,never normed,
MAS12838-IDE11986,Standardization flag-Adjustment 2 of visual display unit,never normed,
MAS12838-MAS11869,Standardization flag-Headrest adjustment: horizontal,never normed,
MAS12838-MAS11890,Standardization flag-Headrest adjustment: vertical,never normed,
ENG139951-IDE06510,Account_1-Adjustment for backrest angle,32735,
ENG139951-IDE06511,Account_1-Seat height adjustment,33173,
ENG139951-IDE06512,Account_1-Adjustment for seat forward/back position,32708,
ENG139951-IDE06683,Account_1-Seat inclination adjustment,33024,
ENG139951-IDE06684,Account_1-Lumbar support height adjustment,0,
ENG139951-IDE06685,Account_1-Lumbar support longitudinal position adjustment,0,
ENG139951-IDE08989,Account_1-Seat depth adjustment,0,
ENG139951-IDE08990,Account_1-Backrest top adjustment,0,
ENG139951-IDE08991,Account_1-Belt height adjustment,0,
ENG139951-IDE11024,Account_1-Headrest height adjustment,0,
ENG139952-IDE06510,Account_2-Adjustment for backrest angle,0,
ENG139952-IDE06511,Account_2-Seat height adjustment,0,
ENG139952-IDE06512,Account_2-Adjustment for seat forward/back position,0,
ENG139952-IDE06683,Account_2-Seat inclination adjustment,0,
ENG139952-IDE06684,Account_2-Lumbar support height adjustment,0,
ENG139952-IDE06685,Account_2-Lumbar support longitudinal position adjustment,0,
ENG139952-IDE08989,Account_2-Seat depth adjustment,0,
ENG139952-IDE08990,Account_2-Backrest top adjustment,0,
ENG139952-IDE08991,Account_2-Belt height adjustment,0,
ENG139952-IDE11024,Account_2-Headrest height adjustment,0,
ENG139953-IDE06510,Account_3-Adjustment for backrest angle,0,
ENG139953-IDE06511,Account_3-Seat height adjustment,0,
ENG139953-IDE06512,Account_3-Adjustment for seat forward/back position,0,
ENG139953-IDE06683,Account_3-Seat inclination adjustment,0,
ENG139953-IDE06684,Account_3-Lumbar support height adjustment,0,
ENG139953-IDE06685,Account_3-Lumbar support longitudinal position adjustment,0,
ENG139953-IDE08989,Account_3-Seat depth adjustment,0,
ENG139953-IDE08990,Account_3-Backrest top adjustment,0,
ENG139953-IDE08991,Account_3-Belt height adjustment,0,
ENG139953-IDE11024,Account_3-Headrest height adjustment,0,
ENG139954-IDE06510,Account_4-Adjustment for backrest angle,0,
ENG139954-IDE06511,Account_4-Seat height adjustment,0,
ENG139954-IDE06512,Account_4-Adjustment for seat forward/back position,0,
ENG139954-IDE06683,Account_4-Seat inclination adjustment,0,
ENG139954-IDE06684,Account_4-Lumbar support height adjustment,0,
ENG139954-IDE06685,Account_4-Lumbar support longitudinal position adjustment,0,
ENG139954-IDE08989,Account_4-Seat depth adjustment,0,
ENG139954-IDE08990,Account_4-Backrest top adjustment,0,
ENG139954-IDE08991,Account_4-Belt height adjustment,0,
ENG139954-IDE11024,Account_4-Headrest height adjustment,0,
ENG139955-IDE06510,Account_5-Adjustment for backrest angle,0,
ENG139955-IDE06511,Account_5-Seat height adjustment,0,
ENG139955-IDE06512,Account_5-Adjustment for seat forward/back position,0,
ENG139955-IDE06683,Account_5-Seat inclination adjustment,0,
ENG139955-IDE06684,Account_5-Lumbar support height adjustment,0,
ENG139955-IDE06685,Account_5-Lumbar support longitudinal position adjustment,0,
ENG139955-IDE08989,Account_5-Seat depth adjustment,0,
ENG139955-IDE08990,Account_5-Backrest top adjustment,0,
ENG139955-IDE08991,Account_5-Belt height adjustment,0,
ENG139955-IDE11024,Account_5-Headrest height adjustment,0,
ENG139956-IDE06510,Account_6-Adjustment for backrest angle,0,
ENG139956-IDE06511,Account_6-Seat height adjustment,0,
ENG139956-IDE06512,Account_6-Adjustment for seat forward/back position,0,
ENG139956-IDE06683,Account_6-Seat inclination adjustment,0,
ENG139956-IDE06684,Account_6-Lumbar support height adjustment,0,
ENG139956-IDE06685,Account_6-Lumbar support longitudinal position adjustment,0,
ENG139956-IDE08989,Account_6-Seat depth adjustment,0,
ENG139956-IDE08990,Account_6-Backrest top adjustment,0,
ENG139956-IDE08991,Account_6-Belt height adjustment,0,
ENG139956-IDE11024,Account_6-Headrest height adjustment,0,
ENG139957-IDE06510,Account_7-Adjustment for backrest angle,0,
ENG139957-IDE06511,Account_7-Seat height adjustment,0,
ENG139957-IDE06512,Account_7-Adjustment for seat forward/back position,0,
ENG139957-IDE06683,Account_7-Seat inclination adjustment,0,
ENG139957-IDE06684,Account_7-Lumbar support height adjustment,0,
ENG139957-IDE06685,Account_7-Lumbar support longitudinal position adjustment,0,
ENG139957-IDE08989,Account_7-Seat depth adjustment,0,
ENG139957-IDE08990,Account_7-Backrest top adjustment,0,
ENG139957-IDE08991,Account_7-Belt height adjustment,0,
ENG139957-IDE11024,Account_7-Headrest height adjustment,0,
ENG139950-IDE06510,BAP_Seat_Adjustment_Button_Status-Adjustment for backrest angle,Not operated,
ENG139950-IDE06511,BAP_Seat_Adjustment_Button_Status-Seat height adjustment,Not operated,
ENG139950-IDE06512,BAP_Seat_Adjustment_Button_Status-Adjustment for seat forward/back position,Not operated,
ENG139950-IDE06683,BAP_Seat_Adjustment_Button_Status-Seat inclination adjustment,Not operated,
ENG139950-IDE06684,BAP_Seat_Adjustment_Button_Status-Lumbar support height adjustment,Not operated,
ENG139950-IDE06685,BAP_Seat_Adjustment_Button_Status-Lumbar support longitudinal position adjustment,Not operated,
ENG139950-IDE08989,BAP_Seat_Adjustment_Button_Status-Seat depth adjustment,Not operated,
ENG139950-IDE08990,BAP_Seat_Adjustment_Button_Status-Backrest top adjustment,Not operated,
ENG139950-IDE08991,BAP_Seat_Adjustment_Button_Status-Belt height adjustment,Not operated,
ENG139950-IDE11024,BAP_Seat_Adjustment_Button_Status-Headrest height adjustment,Not operated,
ENG139950-IDE11025,BAP_Seat_Adjustment_Button_Status-Headrest length adjustment,Not operated,
ENG139950-IDE11957,BAP_Seat_Adjustment_Button_Status-Display unit adjustment,Not operated,
ENG139950-IDE11969,BAP_Seat_Adjustment_Button_Status-Adjustment of foot rest,Not operated,
ENG139950-IDE11986,BAP_Seat_Adjustment_Button_Status-Adjustment 2 of visual display unit,Not operated,
ENG139950-ENG140668,BAP_Seat_Adjustment_Button_Status-backrest_side_bolster,Not operated,
ENG139950-ENG140669,BAP_Seat_Adjustment_Button_Status-footmat,Not operated,
ENG139950-ENG140667,BAP_Seat_Adjustment_Button_Status-side_bolster,Not operated,
ENG136330-ENG136340,Cause of de-normalization-Axis_1,Normierroutine,
ENG136330-ENG136349,Cause of de-normalization-Axis_10,Achse decodiert,
ENG136330-ENG136341,Cause of de-normalization-Axis_2,Normierroutine,
ENG136330-ENG136342,Cause of de-normalization-Axis_3,Normierroutine,
ENG136330-ENG136343,Cause of de-normalization-Axis_4,Normierroutine,
ENG136330-ENG136344,Cause of de-normalization-Axis_5,Achse decodiert,
ENG136330-ENG136345,Cause of de-normalization-Axis_6,Achse decodiert,
ENG136330-ENG136346,Cause of de-normalization-Axis_7,Achse decodiert,
ENG136330-ENG136347,Cause of de-normalization-Axis_8,Achse decodiert,
ENG136330-ENG136348,Cause of de-normalization-Axis_9,Achse decodiert,
ENG136325-ENG101098,crash_precrash-Crash,not active,
ENG136325-ENG131963,crash_precrash-Precrash,not active,
ENG247801-ENG248126,info_developer-ax_da,80 A3 7F 28 81 50 00 07 7F DF 7E DB 85 0A 00 07 81 95 80 01 81 F6 00 07 81 00 80 03 81 10 00 07 80 00 00 00 FF FF 01 0A 80 00 00 00 FF FF 01 0A 80 00 00 00 FF FF 01 0A 80 00 00 00 FF FF 01 0A 80 00 00 00 FF FF 01 0A 80 00 00 00 FF FF 01 0A,
ENG247801-ENG248078,info_developer-gl_lo,31 4E 33 39 35 39 37 36 30 48 20 00 00 00 00 00 54 30 37 35 00 00 00 00 32 35 33 39 00 00 00 00 53 43 42 55 5A 5A 50 45 4F 50 4C 45 00 00 00 00 0D 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG247801-ENG247947,info_developer-gl_pr,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0C 00 04 03 03 00 03 01 04 04 02 01 00 00,
ENG247801-ENG248107,info_developer-pne,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG247801-ENG248040,info_developer-so_deb,00 00 00 00 00 00 00 00 69 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG136350-ENG136426,key_memory_activated-mmi_key_memory_activated,active,
ENG157282-ENG161450,Maximum travel-Axis_1_current,552,
ENG157282-ENG161451,Maximum travel-Axis_1_last,0,
ENG157282-ENG161452,Maximum travel-Axis_10_current,65535,
ENG157282-ENG161453,Maximum travel-Axis_10_last,0,
ENG157282-ENG161454,Maximum travel-Axis_2_current,1583,
ENG157282-ENG161455,Maximum travel-Axis_2_last,0,
ENG157282-ENG161456,Maximum travel-Axis_3_current,501,
ENG157282-ENG161457,Maximum travel-Axis_3_last,0,
ENG157282-ENG161458,Maximum travel-Axis_4_current,269,
ENG157282-ENG161459,Maximum travel-Axis_4_last,0,
ENG157282-ENG161460,Maximum travel-Axis_5_current,65535,
ENG157282-ENG161461,Maximum travel-Axis_5_last,0,
ENG157282-ENG161462,Maximum travel-Axis_6_current,65535,
ENG157282-ENG161463,Maximum travel-Axis_6_last,0,
ENG157282-ENG161464,Maximum travel-Axis_7_current,65535,
ENG157282-ENG161465,Maximum travel-Axis_7_last,0,
ENG157282-ENG161466,Maximum travel-Axis_8_current,65535,
ENG157282-ENG161467,Maximum travel-Axis_8_last,0,
ENG157282-ENG161468,Maximum travel-Axis_9_current,65535,
ENG157282-ENG161469,Maximum travel-Axis_9_last,0,
ENG136323-IDE06842,Memory_ID_CAN_1-Status - Button 1,not active,
ENG136323-IDE06843,Memory_ID_CAN_1-Status - Button 2,not active,
ENG136323-IDE06844,Memory_ID_CAN_1-Status - Button 3,not active,
ENG136323-IDE06845,Memory_ID_CAN_1-Status - Button 4,not active,
ENG136323-ENG123088,Memory_ID_CAN_1-FFB_Close_Button,not active,
ENG136323-ENG123087,Memory_ID_CAN_1-FFB_Open_Button,not active,
ENG136323-ENG123089,Memory_ID_CAN_1-FT_lock,not active,
ENG136323-ENG123090,Memory_ID_CAN_1-FT_locked,not active,
ENG136324-MAS03679,Memory_ID_CAN_2-Terminal 15 status,active,
ENG136324-ENG123091,Memory_ID_CAN_2-DoorContact_more_than_10min_opened,not active,
ENG136324-ENG123092,Memory_ID_CAN_2-DoorContact_NotActive_Active,not active,
ENG136324-ENG140350,Memory_ID_CAN_2-FFB_HDF_Button,not active,
ENG136324-ENG136335,Memory_ID_CAN_2-Hardware_onoff,active,
ENG136324-ENG123093,Memory_ID_CAN_2-Memory_Adjustment,not active,
ENG136324-ENG123094,Memory_ID_CAN_2-MemoryButton_Pressed,not active,
ENG136324-ENG248058,Memory_ID_CAN_2-v_signal_less_v_threshold,active,
ENG158048-MAS03760,missing_pre_conditions-Wind deflector position,not active,
ENG158048-ENG161471,missing_pre_conditions-backrest_locked,active,
ENG158048-ENG161472,missing_pre_conditions-backrest_unlocked,active,
ENG158048-ENG161506,missing_pre_conditions-button_pressed,not active,
ENG158048-ENG161716,missing_pre_conditions-coded_axes_not_normalized,not active,
ENG158048-ENG163288,missing_pre_conditions-other_adjustment_already_active,not active,
ENG158048-ENG98864,missing_pre_conditions-Reserved,0,
ENG158048-ENG310748,missing_pre_conditions-reserviert_01,0,
ENG158048-ENG163523,missing_pre_conditions-reset_problem,not active,
ENG158048-ENG163733,missing_pre_conditions-speed_above_5kmh,not active,
ENG158048-ENG159469,missing_pre_conditions-Voltage_supply,not active,
ENG158102-ENG161674,personalization_last_function-cause_of_termination,0,
ENG158102,personalization_last_function,none,
ENG158102-ENG99298,personalization_last_function-State,none,
ENG136328-ENG136337,pwm_generator-pwm_generator_group_1_overload,not active,
ENG136328-ENG136338,pwm_generator-pwm_generator_group_2_overload,not active,
ENG136326-ENG99389,Resets-Resetcounter,12,
ENG136329-ENG136339,sbc-sbc_overload,not active,
ENG136351-ENG136438,Seat_Actual_Positions-Current_Position_fsv,32768,
ENG136351-ENG136434,Seat_Actual_Positions-Current_Position_ghv,32768,
ENG136351-ENG136441,Seat_Actual_Positions-Current_Position_kks,32768,
ENG136351-ENG136437,Seat_Actual_Positions-Current_Position_ksv_x,32768,
ENG136351-ENG136431,Seat_Actual_Positions-Current_Position_ksv_z,32768,
ENG136351-ENG136436,Seat_Actual_Positions-Current_Position_ldh,32768,
ENG136351-ENG136435,Seat_Actual_Positions-Current_Position_ldw,32768,
ENG136351-ENG136433,Seat_Actual_Positions-Current_Position_lkv,32768,
ENG136351-ENG136428,Seat_Actual_Positions-Current_Position_lnv,32735,
ENG136351-ENG136439,Seat_Actual_Positions-Current_Position_rse1,32768,
ENG136351-ENG136440,Seat_Actual_Positions-Current_Position_rse2,32768,
ENG136351-ENG136429,Seat_Actual_Positions-Current_Position_shv,33173,
ENG136351-ENG136427,Seat_Actual_Positions-Current_Position_slv,32931,
ENG136351-ENG136430,Seat_Actual_Positions-Current_Position_snv,33024,
ENG136351-ENG136432,Seat_Actual_Positions-Current_Position_stv,32768,
ENG123054-ENG136421,Seat_Adjustment_Memory_Info_CAN-Mem_Taster_1,not active,
ENG123054-ENG136422,Seat_Adjustment_Memory_Info_CAN-Mem_Taster_2,not active,
ENG123054-ENG136423,Seat_Adjustment_Memory_Info_CAN-Mem_Taster_3,not active,
ENG123054-ENG136424,Seat_Adjustment_Memory_Info_CAN-Mem_Taster_4,not active,
ENG123054-ENG136425,Seat_Adjustment_Memory_Info_CAN-Mem_Taster_SET,not active,
ENG123054-ENG123084,Seat_Adjustment_Memory_Info_CAN-MMB_glob_Stop,not active,
ENG123054-ENG123077,Seat_Adjustment_Memory_Info_CAN-MMB_storage_0,not active,
ENG123054-ENG123078,Seat_Adjustment_Memory_Info_CAN-MMB_storage_1,not active,
ENG123054-ENG123079,Seat_Adjustment_Memory_Info_CAN-MMB_storage_2,not active,
ENG123054-ENG123080,Seat_Adjustment_Memory_Info_CAN-MMB_storage_3,not active,
ENG123054-ENG123083,Seat_Adjustment_Memory_Info_CAN-MMB_store,not active,
ENG123054-ENG123082,Seat_Adjustment_Memory_Info_CAN-MMB_tast,not active,
ENG123054-ENG123081,Seat_Adjustment_Memory_Info_CAN-MMB_tipp,not active,
ENG123055-ENG123086,Seat_Adjustment_Remote_Control_Locking_Info_CAN-Active_Remote_Control_Key,Key 2,
ENG123055-ENG123085,Seat_Adjustment_Remote_Control_Locking_Info_CAN-Remote_Control_Key_Signal,No_signal,
ENG123053-ENG136417,Seat_Adjustment_State_Info_CAN-FSM_Backrest_Head_Movement,not active,
ENG123053-ENG136412,Seat_Adjustment_State_Info_CAN-FSM_Backrest_Inclination_Movement,not active,
ENG123053-ENG136418,Seat_Adjustment_State_Info_CAN-FSM_Belt_Height_Movement,not active,
ENG123053-ENG136415,Seat_Adjustment_State_Info_CAN-FSM_Headrest_Movement,not active,
ENG123053-ENG123076,Seat_Adjustment_State_Info_CAN-FSM_KD_Error,not active,
ENG123053-ENG136420,Seat_Adjustment_State_Info_CAN-FSM_Lumbar_Height_Movement,not active,
ENG123053-ENG136419,Seat_Adjustment_State_Info_CAN-FSM_Lumbar_Longitudial_Movement,not active,
ENG123053-ENG136416,Seat_Adjustment_State_Info_CAN-FSM_Seat_Depth_Movement,not active,
ENG123053-ENG136413,Seat_Adjustment_State_Info_CAN-FSM_Seat_Height_Movement,not active,
ENG123053-ENG136414,Seat_Adjustment_State_Info_CAN-FSM_Seat_Inclination_Movement,not active,
ENG123053-ENG136411,Seat_Adjustment_State_Info_CAN-FSM_Seat_Longitudial_Movement,not active,
ENG123053-ENG123075,Seat_Adjustment_State_Info_CAN-FSM_SeatMovement,not active,
ENG158188-IDE06510,Seat_Position_Memory_Remote_Control_5-Adjustment for backrest angle,0,
ENG158188-IDE06511,Seat_Position_Memory_Remote_Control_5-Seat height adjustment,0,
ENG158188-IDE06512,Seat_Position_Memory_Remote_Control_5-Adjustment for seat forward/back position,0,
ENG158188-IDE06683,Seat_Position_Memory_Remote_Control_5-Seat inclination adjustment,0,
ENG158188-IDE06684,Seat_Position_Memory_Remote_Control_5-Lumbar support height adjustment,0,
ENG158188-IDE06685,Seat_Position_Memory_Remote_Control_5-Lumbar support longitudinal position adjustment,0,
ENG158188-IDE08989,Seat_Position_Memory_Remote_Control_5-Seat depth adjustment,0,
ENG158188-IDE08990,Seat_Position_Memory_Remote_Control_5-Backrest top adjustment,0,
ENG158188-IDE08991,Seat_Position_Memory_Remote_Control_5-Belt height adjustment,0,
ENG158188-IDE11024,Seat_Position_Memory_Remote_Control_5-Headrest height adjustment,0,
ENG158189-IDE06510,Seat_Position_Memory_Remote_Control_6-Adjustment for backrest angle,0,
ENG158189-IDE06511,Seat_Position_Memory_Remote_Control_6-Seat height adjustment,0,
ENG158189-IDE06512,Seat_Position_Memory_Remote_Control_6-Adjustment for seat forward/back position,0,
ENG158189-IDE06683,Seat_Position_Memory_Remote_Control_6-Seat inclination adjustment,0,
ENG158189-IDE06684,Seat_Position_Memory_Remote_Control_6-Lumbar support height adjustment,0,
ENG158189-IDE06685,Seat_Position_Memory_Remote_Control_6-Lumbar support longitudinal position adjustment,0,
ENG158189-IDE08989,Seat_Position_Memory_Remote_Control_6-Seat depth adjustment,0,
ENG158189-IDE08990,Seat_Position_Memory_Remote_Control_6-Backrest top adjustment,0,
ENG158189-IDE08991,Seat_Position_Memory_Remote_Control_6-Belt height adjustment,0,
ENG158189-IDE11024,Seat_Position_Memory_Remote_Control_6-Headrest height adjustment,0,
ENG158190-IDE06510,Seat_Position_Memory_Remote_Control_7-Adjustment for backrest angle,0,
ENG158190-IDE06511,Seat_Position_Memory_Remote_Control_7-Seat height adjustment,0,
ENG158190-IDE06512,Seat_Position_Memory_Remote_Control_7-Adjustment for seat forward/back position,0,
ENG158190-IDE06683,Seat_Position_Memory_Remote_Control_7-Seat inclination adjustment,0,
ENG158190-IDE06684,Seat_Position_Memory_Remote_Control_7-Lumbar support height adjustment,0,
ENG158190-IDE06685,Seat_Position_Memory_Remote_Control_7-Lumbar support longitudinal position adjustment,0,
ENG158190-IDE08989,Seat_Position_Memory_Remote_Control_7-Seat depth adjustment,0,
ENG158190-IDE08990,Seat_Position_Memory_Remote_Control_7-Backrest top adjustment,0,
ENG158190-IDE08991,Seat_Position_Memory_Remote_Control_7-Belt height adjustment,0,
ENG158190-IDE11024,Seat_Position_Memory_Remote_Control_7-Headrest height adjustment,0,
ENG136327-ENG116986,Source_Last_Reset-Low_Voltage,not active,
ENG136327-ENG123073,Source_Last_Reset-Low_Voltage_At_Run_Up,not active,
ENG136327-ENG123072,Source_Last_Reset-Power_On_Reset,not active,
ENG136327-ENG123071,Source_Last_Reset-Software_Reset_by_diagnosis,not active,
ENG136327-ENG110107,Source_Last_Reset-Watchdog_reset,active,
ENG136327-ENG123074,Source_Last_Reset-Watchdog_Reset_At_Run_Up,not active,
Elapsed Time: 00:23
blockmap-3C-2Q0-907-686-H_WVG5WVEB2SH017765-20250325-1228.CSV
;SW:2Q0-907-686-H   HW:2Q0-907-686-H ---  Lane Change
;Component:HRE_Master    H26 0320, Coding:5A954750
;EV_HREHellaGen3MstrUNECE,001001,EV_HREHellaGen3MstrUNECE_VW27.rod
;Tuesday,25,March,2025,12:28:51:58926
;VCID: 3FD02DEA37F3DE12B6C-806A-R
IDE00018,Voltage terminal 15,14.40, V
IDE00020,Terminal 15 status,On,
IDE00102,Control Module temperature,40.0, °C
IDE00925,Yaw rate,0.02, °/s
IDE01441,Back-up lamp,OFF,
IDE01766-MAS01853,Distance impulses-Left front,0,
IDE01766-MAS01854,Distance impulses-Right front,0,
IDE01766-MAS01855,Distance impulses-Left rear,0,
IDE01766-MAS01856,Distance impulses-Right rear,0,
IDE01985-MAS06855,FAZIT identification test sum-Test sum,74 59 33 39,
IDE02049,Trailer detected,not detected,
IDE02057-MAS10062,Dynamic calibration: status-Auto. calibration: distance travelled,62.00, km
IDE02057-MAS10063,Dynamic calibration: status-Auto. calibration: percent. progress Master,100, %
IDE02057-MAS10064,Dynamic calibration: status-Auto. calibration: percent. progress Slave,100, %
IDE02057,Dynamic calibration: status,OFF,
IDE02219-MAS02471,Steering wheel angle: sign-Sign,Positive,
IDE02219,Steering wheel angle: sign,0.00, °
IDE02486,Data logger triggering,not initialized,
IDE03619,System condition,On,
IDE05064,lane change assist. 2: supply voltage,14.40, V
IDE05065,lane change assist. 2: temperature,48.0, °C
IDE05067-MAS03385,Functional status of lane change assist.-Lane change assistance,passive,
IDE05067-MAS08213,Functional status of lane change assist.-Blind spot detection,OFF,
IDE05067-MAS10332,Functional status of lane change assist.-Parking assistant,passive,
IDE05067-MAS15693,Functional status of lane change assist.-Exit warning,active,
IDE05070,Curve radius,14848.0, m
IDE05077-MAS02475,Rain/light recognition sensor via data bus-Brightness infrared,Unknown (253)
IDE05077-MAS02475,Rain/light recognition sensor via data bus-Brightness infrared,253,
IDE05077-MAS02477,Rain/light recognition sensor via data bus-Front brightness,numerical value: no text,
IDE05077-MAS02477,Rain/light recognition sensor via data bus-Front brightness,1021,
IDE05077,Rain/light recognition sensor via data bus,installed,
IDE05078-MAS04108,Distance of object 1-Distance in X-direction,25.25, m
IDE05078-MAS04109,Distance of object 1-Distance in Y-direction,15.88, m
IDE05079-MAS02465,Relative speed of object 1-Speed in y-direction,8.03, m/s
IDE05079-MAS02469,Relative speed of object 1-Speed in x-direction,90.25, m/s
IDE05080-MAS04108,Distance of object 2-Distance in X-direction,25.25, m
IDE05080-MAS04109,Distance of object 2-Distance in Y-direction,15.88, m
IDE05081-MAS02465,Relative speed of object 2-Speed in y-direction,8.03, m/s
IDE05081-MAS02469,Relative speed of object 2-Speed in x-direction,90.25, m/s
IDE05082-MAS04108,Distance of object 3-Distance in X-direction,25.25, m
IDE05082-MAS04109,Distance of object 3-Distance in Y-direction,15.88, m
IDE05083-MAS02465,Relative speed of object 3-Speed in y-direction,8.03, m/s
IDE05083-MAS02469,Relative speed of object 3-Speed in x-direction,90.25, m/s
IDE05084,Closest object left lane,0,
IDE05084,Closest object left lane,No object recognized,
IDE05085,Closest object right lane,No object recognized,
IDE05085,Closest object right lane,0,
IDE05086,Closest object lane used,No object recognized,
IDE05086,Closest object lane used,0,
IDE05087,Dynamic angle offset lane change assist. 1,-0.50, °
IDE05088,Dynamic angle offset lane change assist. 2,0.00, °
IDE05090,Measured receiving power lane change assist. 1,0, %
IDE05091,Measured receiving power lane change assist. 2,0, %
IDE05092,Measured angle lane change assist. 1,-20.48, °
IDE05093,Measured angle lane change assist. 2,-20.48, °
IDE05094,Static angle offset lane change assist. 1,10.24, °
IDE05095,Static angle offset lane change assist. 2,10.24, °
IDE06199-MAS01167,Indicator light for lane change assist. in instrument cluster-Actuation time,no control,
IDE06199-ENG170421,Indicator light for lane change assist. in instrument cluster-IoReached Status,Output diagnostic test not active,
IDE07145-MAS06773,Component protection properties-KS Standard software main version nummer,03,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,05,
IDE07145-MAS06785,Component protection properties-GFA key,Not Used,
IDE07145-MAS09610,Component protection properties-Status GFA Key,invalid,
IDE07145-MAS09611,Component protection properties-Status Master ECU Key,not stored,
IDE07145-MAS18014,Component protection properties-Supported SHE download versions,Up to download version 01,
IDE10102,Right warning light flashing cycle,OFF,
IDE10103,Left warning light flashing cycle,OFF,
IDE10104,Left warning light status,OFF,
IDE10106,Right warning light status,OFF,
IDE10107,Dimming value of left warning light: warning algorithm,0, %
IDE10108,Status of left warning light: warning algorithm,---,
IDE10109,Dimming value of right warning light: warning algorithm,0, %
IDE10110,Status of right warning light: warning algorithm,---,
IDE10229-IDE10101,Warning light for blind spot assistant in left exterior mirror-Dimming value of left warning light,0, %
IDE10229-MAS01167,Warning light for blind spot assistant in left exterior mirror-Actuation time,no control,
IDE10229-ENG170421,Warning light for blind spot assistant in left exterior mirror-IoReached Status,Output diagnostic test not active,
IDE10230-IDE10105,Warning light for blind spot assistant in right exterior mirror-Dimming value of right warning light,0, %
IDE10230-MAS01167,Warning light for blind spot assistant in right exterior mirror-Actuation time,no control,
IDE10230-ENG170421,Warning light for blind spot assistant in right exterior mirror-IoReached Status,Output diagnostic test not active,
IDE10235-IDE10233,Status night design-Night design,not activated,
IDE10235-IDE10234,Status night design-Day design,activated,
IDE10235,Status night design,OFF,
IDE10236-MAS10041,Lane keeping warning system-Distance to lane,1.25, m
IDE10236-MAS10042,Lane keeping warning system-Time to lane crossing,3.0, s
IDE10236-MAS10043,Lane keeping warning system-Vehicle side,Right,
IDE11133-MAS01167,Output of parking assistant warning-Actuation time,no control,
IDE11133-ENG170421,Output of parking assistant warning-IoReached Status,Output diagnostic test not active,
IDE13096,Rear cross traffic assistant: left warning level,cannot be assessed,
IDE13107,Rear cross traffic assistant: right warning level,cannot be assessed,
IDE13626-MAS01167,Output of exit assistant warning-Actuation time,no control,
IDE13626-ENG170421,Output of exit assistant warning-IoReached Status,Output diagnostic test not active,
IDE13845,Production mode status,not active,
IDE80001,Analysis 1,No display,
IDE80002,Analysis 2,keine_Anzeige,
IDE80003,Analysis 3,No display,
IDE80004,Analysis 4,keine_Anzeige,
MAS00370,Vehicle speed,0.00, km/h
MAS05108-MAS10050,ESP-Delay regulation,Feedback: delay regulation not available,
MAS05108-MAS10059,ESP-Blind spot warning: message,consistent,
MAS05108-MAS10669,ESP-Delay regulation: brake jolt,Not available,
MAS08785-IDE02679,Parking aid-Tone sensor,Measuring value not available,
MAS08785-IDE03619,Parking aid-System condition,active,
MAS10065-MAS04108,Distance of object 4-Distance in X-direction,25.25, m
MAS10065-MAS04109,Distance of object 4-Distance in Y-direction,15.88, m
MAS10066-MAS04108,Distance of object 5-Distance in X-direction,25.25, m
MAS10066-MAS04109,Distance of object 5-Distance in Y-direction,15.88, m
MAS10067-MAS02465,Relative speed of object 4-Speed in y-direction,8.03, m/s
MAS10067-MAS02469,Relative speed of object 4-Speed in x-direction,90.25, m/s
MAS10068-MAS02465,Relative speed of object 5-Speed in y-direction,8.03, m/s
MAS10068-MAS02469,Relative speed of object 5-Speed in x-direction,90.25, m/s
MAS18838,Auto-calibration: adaptive angle correction characteristic curve (slave),0, %
MAS18839,Auto-calibration: adaptive angle correction characteristic curve,0, %
MAS18840-MAS04108,Distance of object 6-Distance in X-direction,25.25, m
MAS18840-MAS04109,Distance of object 6-Distance in Y-direction,15.88, m
MAS18841-MAS02465,Relative speed of object 6-Speed in y-direction,8.03, m/s
MAS18841-MAS02469,Relative speed of object 6-Speed in x-direction,90.25, m/s
ENG347801-MAS13892,CAN_Autodetect_Platform_Version-Platform,Unknown,
ENG347982,OffsetCorrectionState_S0,100,
ENG347983,OffsetCorrectionState_S1,100,
Elapsed Time: 00:09
blockmap-42-1EA-959-593-F_WVG5WVEB2SH017765-20250325-1229.CSV
;SW:1EA-959-593-F   HW:1EA-959-593-F ---  Door Elect, Driver
;Component:TSG FS        009 0563, Coding:0035DB20D200028044000020
;EV_DCU3DriveSideMAXHCONT,001004,EV_DCU3DriveSideMAXHCONT_VWE3.rod
;Tuesday,25,March,2025,12:29:12:58926
;VCDS Version: Release 25.3.0 (x64)  Data version: 20250311 DS365.0
;VCID: 45DC3F02552F84C2FC0-8010-R
Group,Description,Actual
IDE02262,synchronous mirror adjustment,active,
IDE02267-IDE05835,Supply voltage for door control module: front: driver side-Supply voltage for central locking,14.70, V
IDE04215-MAS02428,Mirror adjustment switch-Switch positions,Neutral,
IDE04216-MAS01458,Mirror heater-Operating condition,not active,
IDE04216-MAS02965,Mirror heater-Performance percentage,0, %
IDE04216-MAS04247,Mirror heater-Button,Not operated,
IDE04217,Fuel filler door release button,not installed,
IDE04218,Turn signal in exterior rear-view mirror,not active,
IDE04219-IDE02266,Window regulator control unit: driver side-Passenger side rear power window button,Not operated,
IDE04219-IDE04220,Window regulator control unit: driver side-Driver power window button,Not operated,
IDE04219-IDE06621,Window regulator control unit: driver side-Driver side rear power window button,Not operated,
IDE04219-IDE06872,Window regulator control unit: driver side-Front passenger power window button,Not operated,
IDE04220,Driver power window button,Not operated,
IDE04411,Child safety button,not installed,
IDE04539-MAS01634,Mirror memory-Supply voltage,active,
IDE04539-MAS02228,Mirror memory-X coordinate,30, %
IDE04539-MAS02229,Mirror memory-Y coordinate,51, %
IDE04539-MAS02476,Mirror memory-installed,installed,
IDE04540,Mirror adjustment (X/Y direction),Position center,
IDE04580,Dimming of inside door handle lighting,Not available,
IDE04581,Dimming for interior ambient lighting,0, %
IDE04586,Mirror fold-in activation,not active,
IDE05071-MAS02594,Lane change assistance button-Indicator light in switch,not installed,
IDE05071-MAS07693,Lane change assistance button-Button Status,not installed,
IDE05720-IDE02589,Front driver side door status-Rotary latch status,closed,
IDE05720-IDE04213,Front driver side door status-Central locking button,Not operated,
IDE05725,Dimmer terminal 58xs,0, %
IDE05726,Dimmer terminal 58xd,100, %
IDE05825-MAS02594,DWA Interior monitoring/vehicle inclination sensor button-Indicator light in switch,not coded/not installed,
IDE05825-MAS04247,DWA Interior monitoring/vehicle inclination sensor button-Button,not coded/not installed,
IDE06206-MAS01453,Front window regulator status: driver side-Blocking detection,not active,
IDE06206-MAS02097,Front window regulator status: driver side-Window position,0.00, %
IDE06206-MAS02098,Front window regulator status: driver side-Window regulator standardized,Yes,
IDE06206-MAS04642,Front window regulator status: driver side-Before upper stop,active,
IDE06206-MAS05370,Front window regulator status: driver side-Direction of movement,Position top,
IDE06469,Ambient illumination for speaker,Not available,
IDE06614-IDE06842,Memory seat adjustment control head-Status - Button 1,not installed,
IDE06614-IDE06843,Memory seat adjustment control head-Status - Button 2,not installed,
IDE06614-IDE06844,Memory seat adjustment control head-Status - Button 3,not installed,
IDE06614-IDE06845,Memory seat adjustment control head-Status - Button 4,not installed,
IDE06937-MAS02545,Front window regulator reversing position: driver side-Last,127.50, %
IDE06937-MAS02546,Front window regulator reversing position: driver side-Second to last,127.50, %
IDE06937-MAS02547,Front window regulator reversing position: driver side-Third to last,127.50, %
IDE06937-MAS02548,Front window regulator reversing position: driver side-Fourth to last,127.50, %
IDE06937-MAS05380,Front window regulator reversing position: driver side-fifth to last,127.50, %
IDE07159-MAS05583,Control module switch-off: counter-Data bus,1,
IDE07405-MAS02447,Enable driver front window regulator relay-Release,Yes,
IDE07409-MAS02955,Excessive temper. disconnect: front window regulator: driv.side-Engine temperature,27, °C
IDE07543,Vehicle speed,0.00, km/h
IDE08061,Child safety lock button 2,Not operated,
IDE08697-MAS07302,Number of driving cycles without opening door-Max. number of driving cycles without opening door,0,
IDE09335,Mirror fold-in: current consumption,0.00, A
IDE09798,Play protection: mirror fold-in,not active,
IDE10158,Window lift: switch-over from front to rear,not installed,
IDE10164-MAS01632,Automatically dimming exterior mirrors-Status,not installed,
IDE10164-MAS03691,Automatically dimming exterior mirrors-Dimming,255, %
IDE13865-MAS02099,Exterior door handle actuator-Switch for inside door handle,not installed,
IDE13865-MAS02100,Exterior door handle actuator-Switch for outside door handle,not installed,
IDE13865-MAS09598,Exterior door handle actuator-Request on CAN,Not available,
IDE13865-MAS11741,Exterior door handle actuator-CAN Status,Initialization,
IDE13865-MAS17088,Exterior door handle actuator-Contact: exterior door handle retracted,not installed,
IDE13865-MAS17089,Exterior door handle actuator-Contact: exterior door handle extended,not installed,
IDE13865-MAS17090,Exterior door handle actuator-Actuator activation status,not installed,
IDE15336,Light output 1 pin D8 target brightness on front driver side,Not available,
IDE15338,Light output 3 pin C1/B3 target brightness on front driver side,0, %
IDE15339,Light output 4 pin D16 target brightness on front driver side,0, %
IDE15636,Light output 2 pin D3 target brightness on front driver side,Not available,
MAS01872,Rear lid remote release button,Not operated,
MAS02099,Switch for inside door handle,Not operated,
MAS02100,Switch for outside door handle,Not operated,
MAS02101,Child safety,not active,
MAS06010,Ambient light,Not available,
Elapsed Time: 00:08
blockmap-44-1N3-907-144-Q_WVG5WVEB2SH017765-20250325-1229.CSV
;SW:1N3-907-144-Q   HW:1N3-907-144-L ---  Steering Assist
;Component:BASGEN1MQB37  131 7341, Coding:00000000000002010000020101000100000001000101
;EV_SteerAssisBASGEN1MQB37,017078,EV_SteerAssisBASGEN1MQB37.rod
;Tuesday,25,March,2025,12:29:32:58926
;VCID: 3C2A5AE626E5C50A93E-8068-R SFD+SFD2
IDE00019,Voltage terminal 30,14.82, V
IDE00021,Engine speed,65535, /min
IDE00323-IDE01022,Security Access: Number of invalid keys-Counter: incorrect inputs of key-code,45,
IDE00323-MAS01155,Security Access: Number of invalid keys-Control module,Unknown (45)
IDE00323-MAS02913,Security Access: Number of invalid keys-Remaining running time,11565,
IDE02202,End stage temperature,23, °C
IDE02955,System status,Driving mode,
IDE03214,Engine stop using start-stop function,Unknown (255)
IDE03682-IDE04457,motor position sensor-Electric motor speed,-18000.1, /min
IDE03682-MAS02961,motor position sensor-Engine angle,1, °
IDE03726-IDE02955,Parallel Parking Assistance-System status,not active,
IDE03726-IDE05159,Parallel Parking Assistance-Steering angle: target value,1.93715e-005, °
IDE03726-IDE05160,Parallel Parking Assistance-Steering angle: target-actual deviation,5401.6, °
IDE03726-MAS03095,Parallel Parking Assistance-Function status,not active,
IDE03735,Steering torque,0.0, Nm
IDE04118-IDE05157,Straight line running correction-Long term learning condition,Condition not met,
IDE04118-IDE05158,Straight line running correction-Short term learning condition,Condition not met,
IDE04118-MAS02998,Straight line running correction-Angle value offset,0.3, °
IDE04118-MAS03095,Straight line running correction-Function status,active,
IDE04118-MAS03528,Straight line running correction-Long term adaptation value,0.3, °
IDE04118-MAS03529,Straight line running correction-Short term adaptation value,0.0, °
IDE04119-MAS03095,Active default-Function status,active,
IDE04119-MAS03738,Active default-Restoring force: setpoint,-1, N
IDE04183,Steering assistance: target engine torque,0.0, Nm
IDE04184,Steering assistance: engine output,100, %
IDE04448,Steering angle sensor: angle,1.10001, °
IDE04454,Steering angle sensor: angle speed,0, °/s
IDE04458,Steering angle sensor: mechanical steering stroke,180.3, mm
IDE04459,Steering angle sensor: offset index mark mechanical middle,235, mm
IDE04460,Steering angle sensor: offset straight line running,0.6, °
IDE04510-MAS03732,Steering angle sensor: slope detection index-Steering angle speed negative dropping slope on curve,detected,
IDE04510-MAS03733,Steering angle sensor: slope detection index-Steering angle speed negative rising slope on curve,detected,
IDE04510-MAS03734,Steering angle sensor: slope detection index-Steering angle speed positive dropping slope on curve,detected,
IDE04510-MAS03735,Steering angle sensor: slope detection index-Steering angle speed positive rising slope on curve,detected,
IDE04510-MAS03736,Steering angle sensor: slope detection index-Index mark,detected,
IDE04765-IDE02955,Counter steer support-System status,Function is not active,
IDE04765-MAS02974,Counter steer support-Target force,0, N
IDE04765-MAS03739,Counter steer support-Steering torque request: brake electronics,6533.5, Nm
IDE04765-MAS14021,Counter steer support-Steering recommendation: correcting torque offset,0.0, Nm
IDE04805-IDE02955,Driving profile selection-System status,01,
IDE04805-IDE06011,Driving profile selection-Selected driving profile,02,
IDE04805-IDE06419,Driving profile selection-Driving profile switchover,will be performed.,
IDE04805-MAS01447,Driving profile selection-Act.val.,automatic,
IDE04805-MAS01448,Driving profile selection-Specified value,automatic,
IDE04805-MAS03095,Driving profile selection-Function status,01,
IDE04805-MAS05058,Driving profile selection-Compatibility,01,
IDE05155,Power steering current consumption,0.0, A
IDE05162-IDE03723,Software end stop-End stops for steering,Adapted,
IDE05162-MAS03095,Software end stop-Function status,active,
IDE05162-MAS11513,Software end stop-End stop left,89.96, mm
IDE05162-MAS11514,Software end stop-End stop right,-90.41, mm
IDE05162-MAS12179,Software end stop-Validation of end stops: left and right,Condition met,
IDE05162-MAS12180,Software end stop-Validation of end stops: steering stroke,Condition not met,
IDE05162-MAS12181,Software end stop-Validation of end stops: center,Condition not met,
IDE05713-IDE01864,Network diagnosis-Status of current bus communication,active,
IDE05713-MAS04460,Network diagnosis-Validity,No,
IDE05713-MAS06528,Network diagnosis-Release status,No,
IDE05993-ENG120753,Steering wheel angle load-0_to_50_degrees,4294967295,
IDE05993-ENG120755,Steering wheel angle load-100_to_150_degrees,4294967295,
IDE05993-ENG120751,Steering wheel angle load--100_to_-50_degrees,4294967295,
IDE05993-ENG120750,Steering wheel angle load--150_to_-100_degrees,4294967295,
IDE05993-ENG120756,Steering wheel angle load-150_to_200_degrees,4294967295,
IDE05993-ENG120749,Steering wheel angle load--200_to_-150_degrees,4294967295,
IDE05993-ENG120757,Steering wheel angle load-200_to_250_degrees,4294967295,
IDE05993-ENG120748,Steering wheel angle load--250_to_-200_degrees,4294967295,
IDE05993-ENG120758,Steering wheel angle load-250_to_300_degrees,4294967295,
IDE05993-ENG120747,Steering wheel angle load--300_to_-250_degrees,4294967295,
IDE05993-ENG120759,Steering wheel angle load-300_to_350_degrees,4294967295,
IDE05993-ENG120746,Steering wheel angle load--350_to_-300_degrees,4294967295,
IDE05993-ENG120760,Steering wheel angle load-350_to_400_degrees,4294967295,
IDE05993-ENG120745,Steering wheel angle load--400_to_-350_degrees,4294967295,
IDE05993-ENG120761,Steering wheel angle load-400_to_450_degrees,4294967295,
IDE05993-ENG120744,Steering wheel angle load--450_to_-400_degrees,4294967295,
IDE05993-ENG120762,Steering wheel angle load-450_to_500_degrees,4294967295,
IDE05993-ENG120752,Steering wheel angle load--50_to_0_degrees,4294967295,
IDE05993-ENG120754,Steering wheel angle load-50_to_100_degrees,4294967295,
IDE05993-ENG120743,Steering wheel angle load--500_to_-450_degrees,4294967295,
IDE05993-ENG120763,Steering wheel angle load-500_to_550_degrees,4294967295,
IDE05993-ENG120742,Steering wheel angle load--550_to_500_degrees,4294967295,
IDE05993-ENG120764,Steering wheel angle load-above_550_degrees,4294967295,
IDE05993-ENG120741,Steering wheel angle load-below_-550_degrees,4294967295,
IDE05994-ENG120729,Engine specified torque load-0_to_1_kilo_newton,4294967295,
IDE05994-ENG120728,Engine specified torque load--1_to_0_kilo_newton,4294967295,
IDE05994-ENG120730,Engine specified torque load-1_to_2_kilo_newton,4294967295,
IDE05994-ENG139218,Engine specified torque load-10_to_11_kilo_newton,4294967295,
IDE05994-ENG120719,Engine specified torque load--10_to_-9_kilo_newton,4294967295,
IDE05994-ENG139219,Engine specified torque load--11_to_-10_kilo_newton,4294967295,
IDE05994-ENG120727,Engine specified torque load--2_to_-1_kilo_newton,4294967295,
IDE05994-ENG120731,Engine specified torque load-2_to_3_kilo_newton,4294967295,
IDE05994-ENG120726,Engine specified torque load--3_to_-2_kilo_newton,4294967295,
IDE05994-ENG120732,Engine specified torque load-3_to_4_kilo_newton,4294967295,
IDE05994-ENG120725,Engine specified torque load--4_to_-3_kilo_newton,4294967295,
IDE05994-ENG120733,Engine specified torque load-4_to_5_kilo_newton,4294967295,
IDE05994-ENG120724,Engine specified torque load--5_to_-4_kilo_newton,4294967295,
IDE05994-ENG120734,Engine specified torque load-5_to_6_kilo_newton,4294967295,
IDE05994-ENG120723,Engine specified torque load--6_to_-5_kilo_newton,4294967295,
IDE05994-ENG120735,Engine specified torque load-6_to_7_kilo_newton,4294967295,
IDE05994-ENG120722,Engine specified torque load--7_to_-6_kilo_newton,4294967295,
IDE05994-ENG120736,Engine specified torque load-7_to_8_kilo_newton,4294967295,
IDE05994-ENG120721,Engine specified torque load--8_to_-7_kilo_newton,4294967295,
IDE05994-ENG120737,Engine specified torque load-8_to_9_kilo_newton,4294967295,
IDE05994-ENG120738,Engine specified torque load-9_to_10_kilo_newton,4294967295,
IDE05994-ENG120720,Engine specified torque load--9_to_-8_kilo_newton,4294967295,
IDE05994-ENG161314,Engine specified torque load-above_11_kilo_newton,4294967295,
IDE05994-ENG161479,Engine specified torque load-below_-11_kilo_newton,4294967295,
IDE05995-ENG120703,ECU temperature load-0_to_10_degrees_celsius,4294967295,
IDE05995-ENG120702,ECU temperature load--10_to_0_degrees_celsius,4294967295,
IDE05995-ENG120704,ECU temperature load-10_to_20_degrees_celsius,4294967295,
IDE05995-ENG120713,ECU temperature load-100_to_110_degrees_celsius,4294967295,
IDE05995-ENG120714,ECU temperature load-110_to_120_degrees_celsius,4294967295,
IDE05995-ENG120701,ECU temperature load--20_to_-10_degrees_celsius,4294967295,
IDE05995-ENG120705,ECU temperature load-20_to_30_degrees_celsius,4294967295,
IDE05995-ENG120700,ECU temperature load--30_to_-20_degrees_celsius,4294967295,
IDE05995-ENG120706,ECU temperature load-30_to_40_degrees_celsius,4294967295,
IDE05995-ENG120699,ECU temperature load--40_to_-30_degrees_celsius,4294967295,
IDE05995-ENG120707,ECU temperature load-40_to_50_degrees_celsius,4294967295,
IDE05995-ENG120708,ECU temperature load-50_to_60_degrees_celsius,4294967295,
IDE05995-ENG120709,ECU temperature load-60_to_70_degrees_celsius,4294967295,
IDE05995-ENG120710,ECU temperature load-70_to_80_degrees_celsius,4294967295,
IDE05995-ENG120711,ECU temperature load-80_to_90_degrees_celsius,4294967295,
IDE05995-ENG120712,ECU temperature load-90_to_100_degrees_celsius,4294967295,
IDE05995-ENG120715,ECU temperature load-above_120_degrees_celsius,4294967295,
IDE05995-ENG120698,ECU temperature load-below_-40_degrees_celsius,4294967295,
IDE05996-ENG120766,Steering wheel angle speed load-360_to_600_degrees_per_second,4294967295,
IDE05996-ENG120765,Steering wheel angle speed load-50_to_360_degrees_per_second,4294967295,
IDE05996-ENG120767,Steering wheel angle speed load-600_to_800_degrees_per_second,4294967295,
IDE05996-ENG120768,Steering wheel angle speed load-above_800_degrees_per_second,4294967295,
IDE06678-MAS03000,Pull compensation-Adaptation value,-1200, N
IDE06678-MAS03095,Pull compensation-Function status,not active,
IDE07543,Vehicle speed,0, km/h
IDE10300,OBD Driving Cycle detected,not active,
IDE11591-IDE11629,Result of basic setting of steering angle-Status of the active routine,Finish routine: routine OK,
IDE11591-MAS05584,Result of basic setting of steering angle-Result,Preconditions met,
IDE11591-MAS14036,Result of basic setting of steering angle-Number of iterations,2,
IDE11591-MAS14037,Result of basic setting of steering angle-RESTRICTION,no restriction,
IDE11591-MAS14038,Result of basic setting of steering angle-Type of restriction,Precondition,
IDE11602-IDE11629,Result of steering angle sensor: initialization-Status of the active routine,Finish routine: routine OK,
IDE11602-MAS05584,Result of steering angle sensor: initialization-Result,Preconditions met,
IDE11602-MAS14036,Result of steering angle sensor: initialization-Number of iterations,2,
IDE11602-MAS14037,Result of steering angle sensor: initialization-RESTRICTION,no restriction,
IDE11602-MAS14038,Result of steering angle sensor: initialization-Type of restriction,Precondition,
IDE11603-IDE11629,Result of steering angle sensor: move to mechanical center-Status of the active routine,Finish routine: routine OK,
IDE11603-MAS05584,Result of steering angle sensor: move to mechanical center-Result,Preconditions met,
IDE11603-MAS14036,Result of steering angle sensor: move to mechanical center-Number of iterations,2,
IDE11603-MAS14037,Result of steering angle sensor: move to mechanical center-RESTRICTION,no restriction,
IDE11603-MAS14038,Result of steering angle sensor: move to mechanical center-Type of restriction,Precondition,
IDE11604-IDE11629,Result of steer.angle sens.: zero calibr.steer.wheel balance-Status of the active routine,Finish routine: routine OK,
IDE11604-MAS05584,Result of steer.angle sens.: zero calibr.steer.wheel balance-Result,Preconditions met,
IDE11604-MAS14036,Result of steer.angle sens.: zero calibr.steer.wheel balance-Number of iterations,2,
IDE11604-MAS14037,Result of steer.angle sens.: zero calibr.steer.wheel balance-RESTRICTION,no restriction,
IDE11604-MAS14038,Result of steer.angle sens.: zero calibr.steer.wheel balance-Type of restriction,Precondition,
IDE11605-IDE11629,Result of resetting of all adaptation values-Status of the active routine,Finish routine: routine OK,
IDE11605-MAS05584,Result of resetting of all adaptation values-Result,Preconditions met,
IDE11605-MAS14036,Result of resetting of all adaptation values-Number of iterations,2,
IDE11605-MAS14037,Result of resetting of all adaptation values-RESTRICTION,no restriction,
IDE11605-MAS14038,Result of resetting of all adaptation values-Type of restriction,Precondition,
IDE11606-IDE11629,Result of resetting of all adjustments-Status of the active routine,Finish routine: routine OK,
IDE11606-MAS05584,Result of resetting of all adjustments-Result,Preconditions met,
IDE11606-MAS14036,Result of resetting of all adjustments-Number of iterations,2,
IDE11606-MAS14037,Result of resetting of all adjustments-RESTRICTION,no restriction,
IDE11606-MAS14038,Result of resetting of all adjustments-Type of restriction,Precondition,
IDE11607-IDE11629,Result of resetting all software end-stops-Status of the active routine,Finish routine: routine OK,
IDE11607-MAS05584,Result of resetting all software end-stops-Result,Preconditions met,
IDE11607-MAS14036,Result of resetting all software end-stops-Number of iterations,2,
IDE11607-MAS14037,Result of resetting all software end-stops-RESTRICTION,no restriction,
IDE11607-MAS14038,Result of resetting all software end-stops-Type of restriction,Precondition,
IDE11608-IDE11629,Result of resetting to factory setting-Status of the active routine,Finish routine: routine OK,
IDE11608-MAS05584,Result of resetting to factory setting-Result,Preconditions met,
IDE11608-MAS14036,Result of resetting to factory setting-Number of iterations,2,
IDE11608-MAS14037,Result of resetting to factory setting-RESTRICTION,no restriction,
IDE11608-MAS14038,Result of resetting to factory setting-Type of restriction,Precondition,
IDE11609-IDE11629,Result of steering angle sensor: software end-stops-Status of the active routine,Finish routine: routine OK,
IDE11609-MAS05584,Result of steering angle sensor: software end-stops-Result,Preconditions met,
IDE11609-MAS14036,Result of steering angle sensor: software end-stops-Number of iterations,2,
IDE11609-MAS14037,Result of steering angle sensor: software end-stops-RESTRICTION,no restriction,
IDE11609-MAS14038,Result of steering angle sensor: software end-stops-Type of restriction,Precondition,
IDE11863,Support power reduction,100.0, %
IDE11865-IDE00021,Reason for engagement steering support-Engine speed,not met,
IDE11865-IDE00075,Reason for engagement steering support-Vehicle speed,not met,
IDE11865-MAS01737,Reason for engagement steering support-Diagnosis,not met,
IDE11865-MAS08112,Reason for engagement steering support-Drive readiness,not met,
MAS01172-MAS01156,Development messages-Communication status,Stop,
MAS01172-MAS03095,Development messages-Function status,not active,
MAS01891-IDE02955,Lane assist-System status,not active,
MAS01891-MAS03095,Lane assist-Function status,not active,
MAS01891-MAS03368,Lane assist-Steering wheel vibration,not active,
MAS01891-MAS05054,Lane assist-Steering torque request: lane retention assistant,6543.5, Nm
MAS01891-MAS12816,Lane assist-Lane assistant: direct access power,0, N
MAS01891-MAS12817,Lane assist-Lane assistant: steering wheel vibration force,0, N
MAS01891-MAS12818,Lane assist-Lane assistant: overlay torque,0.0, Nm
MAS02126-IDE05744,Steering angle sensor: status-Steering angle sensor: initialization,initialized,
MAS02126-MAS01632,Steering angle sensor: status-Status,active,
MAS02126-MAS02247,Steering angle sensor: status-CAN message,invalid,
MAS02126-MAS10118,Steering angle sensor: status-Steering angle sensor: status of calibration,calibrated,
MAS08112,Drive readiness,active,
MAS18157-MAS18158,SFD activated status-Role of vehicle diagnostic to be protected,No activation active,
MAS18157-MAS18161,SFD activated status-Status of vehicle diagnostic to be protected,SFD individualization feature set,
MAS18157-MAS18164,SFD activated status-Duration of vehicle diagnostic to be protected,No activation active,
MAS18157-MAS18165,SFD activated status-Type of vehicle diagnostic to be protected,No activation active,
MAS20396,SFD protection procedure,SFD access protection and SFD end-to-end protection,
ENG157548-MAS00976,Angle_estimator-Counter,0,
ENG157548-ENG163894,Angle_estimator-Symmetry_angle_a,1.52588e-005, °
ENG157548-ENG163895,Angle_estimator-Symmetry_angle_b,0.300015, °
ENG157548-ENG163896,Angle_estimator-Symmetry_angle_offset,0.300015, °
ENG157548-ENG163897,Angle_estimator-Symmetry_calculated_angle,-1024, °
ENG157548-ENG163898,Angle_estimator-Symmetry_learning_status,Not adapted,
ENG157712,Current_gradient_limiting,12.0, %
ENG157713,Current_limiting,0.1, %
Elapsed Time: 00:08
blockmap-47-3G0-035-466-F_WVG5WVEB2SH017765-20250325-1229.CSV
;SW:3G0-035-466-F   HW:3G0-035-466-F ---  Sound System
;Component:AMPeth16CDoIP H03 7012, Coding:24090100000000000000000000000000000000000000000000
;EV_AMPEthMQB37w,001005,EV_AMPEthMQB37w_VW38.rod
;Tuesday,25,March,2025,12:29:54:58926
;VCID: 280296B6C27D79AAE76-807C-R SFD+SFD2
IDE00019,Voltage terminal 30,14.50, V
IDE00021,Engine speed,0.00, /min
IDE00767,No. of unscheduled ECU resets,0,
IDE01285-ENG101364,Counter of component protection malfunctions-Theft Protection Error Counter,0,
IDE01351,Terminal 75 status,not detected,
IDE01716,Terminal 50 status,OFF,
IDE01985-MAS06855,FAZIT identification test sum-Test sum,4C BE 37 D6,
IDE02475-MAS01167,Acoustic check of loudspeakers-Actuation time,0 seconds,
IDE02475-ENG170421,Acoustic check of loudspeakers-IoReached Status,Output diagnostic test not active,
IDE02476-MAS01167,Electrical test of speakers-Actuation time,0 seconds,
IDE02476-ENG170421,Electrical test of speakers-IoReached Status,Output diagnostic test not active,
IDE04640,Over-temperature protection for amplifier,0,
IDE05713-MAS01632,Network diagnosis-Status,Enabled,
IDE06517-MAS01424,Temperature: audio amplifier-max.value,21, °C
IDE06517-MAS01425,Temperature: audio amplifier-min.value,8, °C
IDE06517-MAS02238,Temperature: audio amplifier-Current,21, °C
IDE08343,Immobilizer Challenge,88 BD 91 AF,
IDE10779,Ethernet signal quality,good: link available,
IDE10780,Ethernet counter connection interruptions,0,
IDE10781,Ethernet counter checksum malfunction,0,
IDE11752-IDE09469,IP network: IPv6-addresses-IPv6 address,|IPv6 address|FD 53 7C B8 03 83 00 03 00 00 00 00 00 00 00 6F|,
IDE11753-MAS14855,IP network: IPv6-multicast-addresses-IPv6 Multicast address,|IPv6 Multicast address|FF 02 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 05|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 06|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 08|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 2D|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 02|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 05|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 10|,
IDE11755-MAS14856,IP network: VLANs-VLAN,|VLAN|3|,
IDE11756,IP network: counter messages with inadmissible VLANs,0,
IDE11757,IP network: counter messages with inadmissible IPv6-addresses,0,
IDE11759,IP network: counter messages with inadmissible TCP ports,0,
IDE11760,IP network: counter messages with inadmissible UDP ports,0,
IDE11761-IDE09467,IP network: MAC addresses-MAC address,|MAC address|34 32 E6 5B 18 5F|,
IDE11869,IP network: NDP cache,|MAC address,IPv6 address
IDE12238,I network: discarded messages counter,0,
IDE12239,IP network: test feedback value of communications relationships,|IPv6 address,Result|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
IDE12633,IP Network maximum correction of the synchronized clock,0, ns
IDE13344-MAS01167,Acoustic check of loudspeakers: sequential analysis-Actuation time,0 seconds,
IDE13344-ENG170421,Acoustic check of loudspeakers: sequential analysis-IoReached Status,Output diagnostic test not active,
IDE13845-ENG255234,Production mode status-Status_productionmode,No_function_controlled,
ENG117872-ENG117778,Byte_Coding_Condition-byte_0_condition,dont care,
ENG117872-ENG117779,Byte_Coding_Condition-byte_1_condition,dont care,
ENG117872-ENG117788,Byte_Coding_Condition-byte_10_condition,dont care,
ENG117872-ENG117789,Byte_Coding_Condition-byte_11_condition,dont care,
ENG117872-ENG117790,Byte_Coding_Condition-byte_12_condition,dont care,
ENG117872-ENG117791,Byte_Coding_Condition-byte_13_condition,dont care,
ENG117872-ENG117792,Byte_Coding_Condition-byte_14_condition,dont care,
ENG117872-ENG117793,Byte_Coding_Condition-byte_15_condition,dont care,
ENG117872-ENG117794,Byte_Coding_Condition-byte_16_condition,dont care,
ENG117872-ENG117795,Byte_Coding_Condition-byte_17_condition,dont care,
ENG117872-ENG117796,Byte_Coding_Condition-byte_18_condition,dont care,
ENG117872-ENG117797,Byte_Coding_Condition-byte_19_condition,dont care,
ENG117872-ENG117780,Byte_Coding_Condition-byte_2_condition,dont care,
ENG117872-ENG117798,Byte_Coding_Condition-byte_20_condition,dont care,
ENG117872-ENG117799,Byte_Coding_Condition-byte_21_condition,dont care,
ENG117872-ENG117800,Byte_Coding_Condition-byte_22_condition,dont care,
ENG117872-ENG117801,Byte_Coding_Condition-byte_23_condition,dont care,
ENG117872-ENG117802,Byte_Coding_Condition-byte_24_condition,dont care,
ENG117872-ENG117803,Byte_Coding_Condition-byte_25_condition,dont care,
ENG117872-ENG117804,Byte_Coding_Condition-byte_26_condition,dont care,
ENG117872-ENG117805,Byte_Coding_Condition-byte_27_condition,dont care,
ENG117872-ENG117781,Byte_Coding_Condition-byte_3_condition,dont care,
ENG117872-ENG117782,Byte_Coding_Condition-byte_4_condition,dont care,
ENG117872-ENG117783,Byte_Coding_Condition-byte_5_condition,dont care,
ENG117872-ENG117784,Byte_Coding_Condition-byte_6_condition,dont care,
ENG117872-ENG117785,Byte_Coding_Condition-byte_7_condition,dont care,
ENG117872-ENG117786,Byte_Coding_Condition-byte_8_condition,dont care,
ENG117872-ENG117787,Byte_Coding_Condition-byte_9_condition,dont care,
Elapsed Time: 00:06
blockmap-51-0ET-907-121-G_WVG5WVEB2SH017765-20250325-1230.CSV
;SW:0ET-907-121-G   HW:0ET-907-121-G ---  Electric Drive
;Component:MEB INV6.0    H10 7260, Coding:
;EV_DMCM21000110ET907121G,001001,EV_DMCM21000110ET907121G.rod
;Tuesday,25,March,2025,12:30:17:58926
;VCID: 44DA22065E15BDCAEBE-8010-R SFD+SFD2
IDE00019,Voltage terminal 30,14.666, V
IDE00024,ATF temperature,15.55, °C
IDE00601,Monitoring status since erasing DTC memory,
IDE00619,RPM of electric machine,0, /min
IDE00628,Specified value of intermediate circuit voltage,0.00, V
IDE00635,Intermediate circuit current,0.00, A
IDE00637,Intermediate circuit voltage,412.38, V
IDE00643,Minimum torque of electric machine,-0.25, Nm
IDE00644,Maximum torque of electric machine,-0.25, Nm
IDE00645,Specified torque of electric machine,0.00, Nm
IDE00651,Specified RPM of electric machine,0, /min
IDE00773,Terminal 15 status via CAN,1,
IDE00938,Calculated actual torque of electric machine,-0.25, Nm
IDE05246,Power electronics heat sink temperature,16.67, °C
IDE05249,Regulation due to excessive temperature,0,
IDE05250,Drive control condition,wait on command,
IDE05419,Intermediate circuit current maximum limit,800.00, A
IDE05420,Intermediate circuit current minimum threshold,-369.00, A
IDE05421,Torque: current value,-0.25, Nm
IDE06502,Offset angle adaptation: status,Precise,
IDE06552,Time since terminal 15 ON,1172, s
IDE06553,Electrical drive control module: operating status,Unknown (2048)
IDE06805,Status of voltage freedom,2,
IDE09095,CAN signal battery management sys: traction network voltage,0.00, V
IDE09096,CAN signal battery management system high voltage protection: status,closed,
IDE09097,E-machine electrical rotor frequency,0.0, Hz
IDE09098,E-machine electrical power,0, W
IDE09099,E-machine mechanical power,0, W
IDE09100,E-machine free-run status,Enabled,
IDE09102,E-machine effective current,0.50, A
IDE09103,E-machine stator temperature,15.81, °C
IDE09104,E-machine stator temperature characteristic,0,
IDE09109,Power electronics voltage terminal 30: channel 1,14.664, V
IDE09111,Power electronics gate driver status,Free run,
IDE09113,Power Electronics IGBT-Module Temperature Phase U,16.69, °C
IDE09114,Power Electronics IGBT-Module Temperature Phase V,16.72, °C
IDE09115,Power Electronics IGBT-Module Temperature Phase W,16.59, °C
IDE09118,Magnetic flow calibration: status,0,
IDE09119,Position offset calibration: diagnostic status,NotTested__E,
IDE09126,Vehicle switch-off time,2, s
IDE09210,Phase current phase U unrestricted,1.06, A
IDE09211,Phase current phase V unrestricted,1.75, A
IDE09212,Phase current phase W unrestricted,1.00, A
IDE10300,OBD Driving Cycle detected,active,
IDE13835-MAS17093,VKMS: relevant VIN number for last data supply-Status of vehicle identification number,valid,
IDE13835-MAS17094,VKMS: relevant VIN number for last data supply-Vehicle identification number output,WVG5WVEB2SH017765,
IDE13836-MAS17095,VKMS: adaption counter-Adaptation counter status,valid,
IDE13836-MAS17096,VKMS: adaption counter-Adaptation counter output,00 01,
IDE13837-MAS17097,VKMS: overview missing keys-Key status,valid,
IDE13837-MAS17099,VKMS: overview missing keys-Number of missing keys,0,
IDE13837-MAS17100,VKMS: overview missing keys-Missing key,00 00,
IDE13842-MAS17101,VKMS: retrieval of information list of the stored VKMS keys-VKMS key status,valid,
IDE13842-MAS17103,VKMS: retrieval of information list of the stored VKMS keys-VKMS type ID,00 15,
IDE13842-MAS17104,VKMS: retrieval of information list of the stored VKMS keys-VKMS type adaptation counter,00 01,
IDE13842-MAS18318,VKMS: retrieval of information list of the stored VKMS keys-Number of VKMS keys,4,
IDE14017,Operating mode: actual value,operational,
IDE14181,Transmission sump temperature,15.56, °C
IDE14182,Film capacitor temperature of the DC/DC converter,17.17, °C
IDE14382,Rotor temperature calculated,13.58, °C
IDE14492-MAS18388,Secure Onboard Communication: verification failed-Failed verification status,valid,
IDE14492-MAS18389,Secure Onboard Communication: verification failed-Number of failed verifications,0,
IDE14492-MAS18390,Secure Onboard Communication: verification failed-Verification failed,00 00,
IDE14493-MAS18360,Secure Onboard Communication: signatures failed-failed signature creation,00 00,
IDE14493-MAS18391,Secure Onboard Communication: signatures failed-Failed signature creation status,valid,
IDE14493-MAS18392,Secure Onboard Communication: signatures failed-Number of failed signature creations,0,
IDE14494-MAS18361,Secure Onboard Communication: general information-Status of general information,valid,
IDE14494-MAS18362,Secure Onboard Communication: general information-ECU function,SOC participant,
IDE14494-MAS18367,Secure Onboard Communication: general information-Main function call period,5,
IDE14495-MAS18369,Secure Onboard Communication: information about internal time-Internal SOC time status,valid,
IDE14495-MAS18370,Secure Onboard Communication: information about internal time-Validity of internal SOC time,Valid SOC time,
IDE14495-MAS18374,Secure Onboard Communication: information about internal time-Internal time,00 0D C0 1D 12 CA 87 86,
IDE14495-MAS18375,Secure Onboard Communication: information about internal time-Jitter test status,Jitter not exceeded,
IDE14496-MAS18378,Secure Onboard Communication: Freshness Values information-Freshness status,valid,
IDE14496-MAS18379,Secure Onboard Communication: Freshness Values information-Number of Freshness IDs,2,
IDE14496-MAS18380,Secure Onboard Communication: Freshness Values information-SOC PDU ID to which this freshness information is assigned,00 0B,
IDE14496-MAS18381,Secure Onboard Communication: Freshness Values information-Freshness Value query status,Freshness Value was not queried,
IDE14496-MAS18384,Secure Onboard Communication: Freshness Values information-SOC time of last successful verification,FF FF FF FF FF FF FF FF,
IDE14496-MAS18385,Secure Onboard Communication: Freshness Values information-Current value of message counter,255,
IDE14496-MAS18386,Secure Onboard Communication: Freshness Values information-Bitfield with used counter values,11111111 11111111 ,
IDE14497-MAS17099,Secure Onboard Communication: missing key-Number of missing keys,0,
IDE14497-MAS17100,Secure Onboard Communication: missing key-Missing key,00 00,
IDE14497-MAS18387,Secure Onboard Communication: missing key-Missing key status,valid,
IDE16766,Type of discharge,No discharge,
IDE16768,Position offset angle: status,Precise,
IDE16930,High voltage in the intermediate circuit,0.00, V
IDE16931,Gate driver of power electronics: status,short circuit to Ground (GND),
IDE16993,Type of discharge: target mode,No discharge,
IDE18185,Offset angle of rotor positions,124.261, DegreElect
IDE80256,Rotor pos. sensor: sine offset,2.66, V
IDE80257,Rotor pos. sensor: cosine offset,0.00, V
MAS06254,Supply voltage Terminal 30 - 2,14.658, V
MAS07826,Request emergency discharge HV intermittent circuit condenser,no discharge request,
MAS13360,Discharge current HV intermediate circuit power electronics,0.00, A
MAS13363,Redundant intermediate circuit voltage power electronics,412.44, V
MAS13431,Low-voltage fuse: current,0.289, A
MAS13802,Rotor position sensor 2: cosine amplitude,0.00, V
MAS13803,Rotor position sensor 2: sine amplitude,2.69, V
MAS13804,Rotor position sensor 2: exciter amplitude,0.45877,
MAS20914,E-machine torque limitation,1,
MAS28035,Power electronics: requested level 2 target mode,8,
MAS28036,Power electronics: phase current difference fault status,0,
MAS28046,Power electronics: synchronized traction network,412.22, V
MAS28302,Power electronics: filtered phase current effective value,0.50, A
MAS28638,Power electronics temperature busbar: calculated value,18.70, °C
ENG286535,AC_phase_current_level_2_filtered_amplitude,0.44, A
ENG286536,AC_phase_current_level_2_filtered_amplitude_quality,OK,
ENG286544,Buck_boost_converter_input_current_filtered,0.297, A
ENG286545,Calibrated_level_2_rotor_offset_angle,124.964, DegreElect
ENG286546,CAN_network_management_status,1,
ENG286547,Check_sum_error_counter_motor_56_frame,0,
ENG390337,Cntr Ary Knk Out Rec 10ms pp rbe Bsw Adpr Cust 10ms rbe Bsw Adpr Cust,0,
ENG286548,Communication_status_motor_56_frame,rbe_CmnGlbMon_StCom_Norm_e,
ENG286548-ENG286905,Communication_status_motor_56_frame-Test_Program_Rbe Cdd Mon Fct Com Enum rbe Cmn Glb Mon St Com UBYTE,2,
ENG105721,Current_DC_Link_power,0, W
ENG286553,DC_link_filtered_voltage_with_sensor_tolerance,414.66, V
ENG286554,DC_link_voltage_1_V2,412.47, V
ENG286555,DC_Link_voltage_lower threshold_value,260.00, V
ENG286556,DC_Link_voltage_upper_threshold_value,442.00, V
ENG105799,Desired_torque,0.00, Nm
ENG286558,Diodes_overall_average_power_loss_value,0.0, W
ENG286559,Diodes_temperature_modelled_value,16.70, °C
ENG286561,Drive_motor_speed_difference_ASR_MSR_speed_limits,-860, /min
ENG286566,Emergency_discharge_request_quality_fault_status,OK,
ENG286580,Excitation_flux_filtered_value,0.051701, Wb
ENG286581,External_watchdog_error_counter,1,
ENG106482,Failure_emergency_shut_off,0,
ENG106483,Failure_free_wheeling,0,
ENG157343,Failure_inverter_limited_prfmnc,0,
ENG106485,Failure_inverter_shut_off,0,
ENG157344,Field_weakening_active,0,
ENG286586,Gate_driver_high_side_supply_status,step-up-operation,
ENG286587,Gate_driver_low_side_supply_status,not active,
ENG286588,Gate_driver_lowside_supply_desired_status,not active,
ENG286592,HV_flyback_converter_input_current,0.0071, A
ENG286593,HV_MCU_desired_operation_mode,rbe_CddHvMcu_StMod_NormMod_e,
ENG286593-ENG145775,HV_MCU_desired_operation_mode-Test_Program_Rbe Cdd Hv Mcu Enum rbe Cdd Hv Mcu St Mod UBYTE,0,
ENG286594,HV_MCU_operation_mode,Normal mode,
ENG286595,HV_MCU_reference_voltage_external_value,4.100, V
ENG286596,IGBT_phase_UVW_maximum_temperature_selection,0.00, °C
ENG286597,IGBT_temperature_modelled_value,16.70, °C
ENG286601,Intermediate_circuit_lowside_voltage_filtered_value,18.375, V
ENG144277,Internal_supply_voltage_15_inverter_IGBT,16.707, V
ENG274516,Inverter_current_in_d-direction_actual_value,-0.19, A
ENG274518,Inverter_current_in_q-direction_actual_value,-0.38, A
ENG286608,Inverter_gate_driver_safe_state_status,0,
ENG331380,Inverter_pwm_ratio_acquisition_error_state,0,
ENG286609,Irreversible_amplitude_difference_error,0,
ENG286610,Irreversible_amplitude_range_check_error,0,
ENG286611,Irreversible_normal_mode_check_error,0,
ENG286612,Irreversible_permanent_range_check_error,0,
ENG286613,Irreversible_phase_current_check_error,0,
ENG286614,Irreversible_plug_mode_check_error,0,
ENG286620,Last_received_query_from_external_watchdog,2021161080,
ENG286621,Last_sent_answer_to_external_watchdog,2641203810,
ENG157388,Load_moment_auxiliary,0.00, Nm
ENG107585,Maximal_torque_hybrid_controller,1023.50, Nm
ENG107589,Maximum_power_limit,230016, W
ENG107590,Maximum_torque_derating_reason,Unknown (512)
ENG286628,MCU_error_counter,0,
ENG107623,Minimal_torque_hybrid_controller,-1023.00, Nm
ENG107625,Minimum_power_limit,-172704, W
ENG107626,Minimum_torque_derating_reason,Unknown (512)
ENG286629,Monitoring_desired_operating_mode_received_signal_quality,OK,
ENG286630,Monitoring_desired_torque_received_signal_quality,OK,
ENG286631,Monitoring_motor_maximum_mechanical_torque_signal_quallity,OK,
ENG286632,Monitoring_motor_maximum_speed_signal_quallity,OK,
ENG286633,Monitoring_motor_minimum_mechanical_torque_signal_quallity,OK,
ENG286634,Monitoring_motor_minimum_speed_signal_quallity,OK,
ENG286635,Monitoring_reinitialisation_end_to_end_communication_status,0,
ENG286636,Monitoring_state_shutoff_path_first_debug_word,0,
ENG286638-ENG188621,MPU_address_of_program_that_caused_trap-Bits 0-7,0,
ENG286639-ENG188621,MPU_bus_master_ID_which_caused_trap-Bits 0-7,0,
ENG286640-ENG188621,MPU_core_ID_stopped_by_trap-Bits 0-7,0,
ENG286641-ENG188621,MPU_error_type-Bits 0-7,0,
ENG286642-ENG188621,MPU_memory_address_to_trap-Bits 0-7,0,
ENG286643,Offset_angle_calibration_status,not tested,
ENG144276,Periodic_time_gate_driver,0.00010000, s
ENG286648,Powermodule_phase_1_temperature_characteristic_curve_status,1,
ENG286649,Powermodule_phase_2_temperature_characteristic_curve_status,1,
ENG286650,Powermodule_phase_3_temperature_characteristic_curve_status,1,
ENG286651,PWM_frequency,10000, Hz
ENG286659,Resolver_cosine_signal_filtered_amplitude,0.44748,
ENG286660,Resolver_cosine_signal_filtered_offset_derivation,0.00153,
ENG286661,Resolver_minimum_maximum_relative_amplitude_difference_to_average_amplitude_value,0.00256,
ENG286664,Resolver_sine_cosine_relative_amplitude_difference,0.00259,
ENG286665,Resolver_sine_cosine_relative_amplitude_difference_corrected_value,0.02466,
ENG286666,Resolver_sine_cosine_relative_amplitude_difference_estimated_value,0.02469,
ENG286667,Resolver_sine_signal_filtered_amplitude,0.45197,
ENG286668,Resolver_sine_signal_filtered_offset_derivation,0.00162,
ENG286669,Resolver_voltage_cosine_signal,-2.19, V
ENG286670,Resolver_voltage_sine_signal,1.53, V
ENG286682,Shut_off_path_test_permission_status,idle_mode,
ENG286684,SPI_communication_error_counter,0,
ENG390526,St Bit Fie Knk Out Tmr Rec 10ms pp rbe Bsw Adpr Cust 10ms rbe Bsw Adpr Cust,16255,
ENG390527,St Test Mod Knk Out Rec 10ms pp rbe Bsw Adpr Cust 10ms rbe Bsw Adpr Cust,0,
ENG286690,Status_communication_failure_motor_frame_56,0,
ENG286691,Status_CPLD_Hardware_faults,3438346239,
ENG286694,Status_end_to_end_motor_56_frame,No timeout/checksum/alive counter errors,
ENG286704,Status_value_check_motor_56_frame,0,
ENG286705,Sum_of_filtered_phase_currents,2.00, A
ENG286707,Switch_power_loss_modelled,0.0, W
ENG286709,Torque_calculated_from_power,0.00, Nm
ENG286711,Torque_electric_drive_motor_minimum_available_value,-560.44, Nm
ENG286712,Torque_filtered_desired_value,0.00, Nm
ENG286713,Torque_internal_desired_comparison_value,0.00, Nm
ENG286714,Torque_level_2_estimated_filtered_value,0.00, Nm
ENG286715,Torque_limited_damping_value,0.00, Nm
ENG286717,Torque_maximum_desired_negative_value,0.00, Nm
ENG286718,Torque_maximum_desired_positive_value,0.00, Nm
ENG286719,Torque_maximum_value,560.44, Nm
ENG286720,Traction_line_voltage_incremental_change_value,-0.03, V
ENG286722,Vehicle_downtime_valid_state_V2,Unknown (256)
ENG286723,Vehicle_velocity_signal_quality,OK,
ENG286734,Voltage_regulator_input_voltage_filtered_value,14.162, V
Elapsed Time: 00:16
blockmap-52-1EA-959-592-F_WVG5WVEB2SH017765-20250325-1230.CSV
;SW:1EA-959-592-F   HW:1EA-959-592-F ---  Door Elect, Pass.
;Component:TSG BFS       009 0563, Coding:00355320DE00028040800020
;EV_DCU3PasseSideMAXHCONT,001004,EV_DCU3PasseSideMAXHCONT_VWE3.rod
;Tuesday,25,March,2025,12:30:55:58926
IDE02268-IDE00773,Supply voltage for door control module: front: frt.pass. side-Terminal 15 status via CAN,active,
IDE02268-IDE01715,Supply voltage for door control module: front: frt.pass. side-Status terminal S,active,
IDE02268-IDE05835,Supply voltage for door control module: front: frt.pass. side-Supply voltage for central locking,14.80, V
IDE04216-MAS04247,Mirror heater-Button,not installed,
IDE04539-MAS02228,Mirror memory-X coordinate,43, %
IDE04539-MAS02229,Mirror memory-Y coordinate,57, %
IDE04540,Mirror adjustment (X/Y direction),not installed,
IDE05727-IDE04213,Front passenger side door status-Central locking button,Not operated,
IDE05727-IDE04214,Front passenger side door status-Key switch in door lock,not installed,
IDE06207-MAS01453,Front window regulator status: frt.pass. side-Blocking detection,active,
IDE06207-MAS02039,Front window regulator status: frt.pass. side-Force limitation,not active,
IDE06207-MAS02097,Front window regulator status: frt.pass. side-Window position,0.00, %
IDE06207-MAS02098,Front window regulator status: frt.pass. side-Window regulator standardized,Yes,
IDE06207-MAS03548,Front window regulator status: frt.pass. side-Motor current,0, A
IDE06207-MAS04642,Front window regulator status: frt.pass. side-Before upper stop,active,
IDE06207-MAS05370,Front window regulator status: frt.pass. side-Direction of movement,Position top,
IDE06872,Front passenger power window button,Not operated,
IDE06934,Front window regulator relay: frt.pass. side,Open,
IDE06938-MAS02545,Front window regulator reversing position: frt. pass. side-Last,51.50, %
IDE06938-MAS02546,Front window regulator reversing position: frt. pass. side-Second to last,37.00, %
IDE06938-MAS02547,Front window regulator reversing position: frt. pass. side-Third to last,127.50, %
IDE06938-MAS02548,Front window regulator reversing position: frt. pass. side-Fourth to last,127.50, %
IDE06938-MAS05380,Front window regulator reversing position: frt. pass. side-fifth to last,127.50, %
IDE07223,Window regulator child lock: frt.pass. side,Not available,
IDE07406-IDE03114,Enable front passenger window regulator relay-Comfort function,No,
IDE07406-MAS02447,Enable front passenger window regulator relay-Release,Yes,
IDE07410-MAS01632,Excess.temp. disconnect: front window regulator: frt.pass. side-Status,not active,
IDE07410-MAS02955,Excess.temp. disconnect: front window regulator: frt.pass. side-Engine temperature,27, °C
IDE07414,Comfort function for front window regulator: frt.pass. side,not active,
IDE15340,Light output 1 pin D8 target brightness on front passenger side,Not available,
IDE15341,Light output 2 pin D3 target brightness on front passenger side,Not available,
IDE15342,Light output 3 pin C1/B3 target brightness on front passenger side,0, %
IDE15343,Light output 4 pin D16 target brightness on front passenger side,0, %
Elapsed Time: 00:07
blockmap-5F-10C-035-842-A_WVG5WVEB2SH017765-20250325-1231.CSV
;SW:10C-035-842-A   HW:10C-035-842 ---  Information Electr.
;Component:IC3GSF--US    H09 3626, Coding:64101030000000000000000000000000000000000000000000
;EV_MUICASSAFEPart,002001,EV_MUICASSAFEPart_002_VNE4.rod
;Tuesday,25,March,2025,12:31:14:58926
;VCID: 1B68B97A832BA2327A4-804E-R SFD+SFD2
IDE00019,Voltage terminal 30,14.90, V
IDE04312-MAS00109,System run time-Hours,0, H
IDE04312-MAS00110,System run time-Minutes,21, min
IDE07589-IDE07590,Update programming: status-Currently processed module,0,
IDE07589-IDE07591,Update programming: status-Number of modules to be programmed,0,
IDE07589-MAS01632,Update programming: status-Status,not active,
IDE07589-MAS10948,Update programming: status-control,Diagnosis,
IDE11752-IDE09469,IP network: IPv6-addresses-IPv6 address,|IPv6 address|FD 53 7C B8 03 83 00 03 00 00 00 00 00 00 00 73|,
IDE11753-MAS14855,IP network: IPv6-multicast-addresses-IPv6 Multicast address,|IPv6 Multicast address|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 05|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 06|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 70|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 8F|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 B4|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 06|FF 14 00 00 00 00 00 00 00 00 00 00 00 04 00 00|FF 14 00 00 00 00 00 00 00 00 00 00 00 05 00 00|,
IDE11756,IP network: counter messages with inadmissible VLANs,65535,
IDE11757,IP network: counter messages with inadmissible IPv6-addresses,2,
IDE11761-IDE09467,IP network: MAC addresses-MAC address,|MAC address|02 7D FA 00 73 00|,
IDE12238,I network: discarded messages counter,4,
IDE12633,IP Network maximum correction of the synchronized clock,-12589, µs
IDE12980-ENG297751,Inspection: distance driven since the last inspection-FIX_Read_mileage_since_last_mileage_based_service_event,100, km
IDE12981-ENG303026,Inspection: time since the last inspection-FIX_Read_time_since_last_time_based_service_event,32, d
IDE13842-MAS17103,VKMS: retrieval of information list of the stored VKMS keys-VKMS type ID,00 01,
IDE13842-MAS18318,VKMS: retrieval of information list of the stored VKMS keys-Number of VKMS keys,28,
IDE15495-MAS00976,Filtered data package due to firewall control at layer 3 and up-Counter,00 02 00 00 00 00 00 00,
IDE15495-MAS05767,Filtered data package due to firewall control at layer 3 and up-port,1,
IDE15496-MAS00976,Filtered data package due to firewall control up to layer 3-Counter,00 02 00 00 00 00 00 00,
IDE15496-MAS05767,Filtered data package due to firewall control up to layer 3-port,1,
MAS00778-IDE03619,Multimedia display unit 1-System condition,On,
MAS00778-IDE05228,Multimedia display unit 1-Operating hour counter,19, H
MAS00778-MAS00110,Multimedia display unit 1-Minutes,10, min
MAS00778-MAS01634,Multimedia display unit 1-Supply voltage,14.70, V
MAS00778-MAS02200,Multimedia display unit 1-Highest measured temperature,67, °C
MAS00778-MAS02201,Multimedia display unit 1-Temperature,49, °C
MAS00778-MAS03691,Multimedia display unit 1-Dimming,100, %
MAS26570-ENG334268,Distance of safety error-mileage_error_security_AR2_value,00 00,
MAS27747-MAS00106,Distance data with onboard supply control unit and electronic stabilization program information-Year,2019, yr
MAS27747-MAS00107,Distance data with onboard supply control unit and electronic stabilization program information-Month,1, Months
MAS27747-MAS00108,Distance data with onboard supply control unit and electronic stabilization program information-Day,1, d
MAS27747-MAS00109,Distance data with onboard supply control unit and electronic stabilization program information-Hours,0, H
MAS27747-MAS00110,Distance data with onboard supply control unit and electronic stabilization program information-Minutes,0, min
MAS27747-MAS00111,Distance data with onboard supply control unit and electronic stabilization program information-Seconds,5, s
MAS27747-MAS27735,Distance data with onboard supply control unit and electronic stabilization program information-ESC distance pulses,00 00 00 00 00 78 B3 80,
MAS27747-MAS27749,Distance data with onboard supply control unit and electronic stabilization program information-Distance pulses: number of jumps,1,
MAS27747-MAS27750,Distance data with onboard supply control unit and electronic stabilization program information-Distance pulses: largest positive jump,1237856,
MAS27747-MAS27751,Distance data with onboard supply control unit and electronic stabilization program information-Distance pulses: largest negative jump,0,
MAS27747-MAS27752,Distance data with onboard supply control unit and electronic stabilization program information-Distance pulses: total jumps,00 00 00 00 00 12 E3 60,
MAS27747-MAS27753,Distance data with onboard supply control unit and electronic stabilization program information-Distance pulses: jump balance,0,
MAS27747-MAS27754,Distance data with onboard supply control unit and electronic stabilization program information-Electronic stabilization program communication failures: number,2,
MAS27747-MAS27755,Distance data with onboard supply control unit and electronic stabilization program information-Electronic stabilization program communication failures: total duration,41, s
MAS27747-MAS27756,Distance data with onboard supply control unit and electronic stabilization program information-Longest electronic stabilization program communication failure,1, min
MAS27747-MAS27757,Distance data with onboard supply control unit and electronic stabilization program information-Longest onboard supply control unit communication failure,1, min
MAS27747-MAS27758,Distance data with onboard supply control unit and electronic stabilization program information-Onboard supply control unit communication failures: total duration,42, s
MAS27747-MAS27759,Distance data with onboard supply control unit and electronic stabilization program information-Onboard supply control unit distance: number of jumps,4,
MAS27747-MAS27760,Distance data with onboard supply control unit and electronic stabilization program information-Onboard supply control unit distance: jump balance,178806, m
MAS27747-MAS27761,Distance data with onboard supply control unit and electronic stabilization program information-Onboard supply control unit distance: total jumps,290567, m
MAS27747-MAS27762,Distance data with onboard supply control unit and electronic stabilization program information-Onboard supply control unit distance: largest negative jump,0, m
MAS27747-MAS27763,Distance data with onboard supply control unit and electronic stabilization program information-Onboard supply control unit distance: largest positive jump,178806, m
MAS27747-MAS27764,Distance data with onboard supply control unit and electronic stabilization program information-Onboard supply control unit communication failures: number,2,
MAS27747-MAS27765,Distance data with onboard supply control unit and electronic stabilization program information-Total distance: status,209, km
ENG117872-ENG117778,Byte_Coding_Condition-byte_0_condition,OK,
ENG274022-ENG256370,Display_speed_instrument_cluster-speed_warning_tire_isActive,false,
ENG274022-ENG256371,Display_speed_instrument_cluster-speed_warning_tire_threshold,30, km/h
ENG274022-ENG256372,Display_speed_instrument_cluster-speed_warning_user_isActive,false,
ENG274022-ENG256373,Display_speed_instrument_cluster-speed_warning_user_threshold,30, km/h
ENG274022-ENG256374,Display_speed_instrument_cluster-speed_warning_user2_isActive,false,
ENG274022-ENG256375,Display_speed_instrument_cluster-speed_warning_user2_threshold,30, km/h
ENG254819-ENG98988,startup_timer-Timer,1315, s
ENG254835-ENG258372,Unit_master-consumption_electric,Miles per kWh,
ENG254835-ENG274108,Unit_master-consumption_gas,mpg equivalent (US),
ENG254835-ENG274107,Unit_master-consumption_petrol_or_diesel,Miles per gallon (US),
ENG254835-ENG171158,Unit_master-Date,mm_dd_yy,
ENG254835-ENG144693,Unit_master-Distance,miles,
ENG254835-ENG180343,Unit_master-Pressure,psi,
ENG254835-ENG98926,Unit_master-Speed,Miles per hour,
ENG254835-ENG98971,Unit_master-Temperature,Degrees Fahrenheit,
ENG254835-ENG98987,Unit_master-Time,12h AM_PM,
ENG254835-ENG253460,Unit_master-Towing_capacity_mass,Pounds (lbs),
ENG254835-ENG274074,Unit_master-Volume,gallons (US),
Elapsed Time: 00:13
blockmap-6C-1EE-907-556-A_WVG5WVEB2SH017765-20250325-1232.CSV
;SW:1EE-907-556-A   HW:5WA-907-556-D ---  Back-up Cam.
;Component:TV eEntry     H32 0605, Coding:060300003F140000
;EV_CamSysTVFicosUNECE,002004,EV_CamSysTVFicosUNECE_VWE3.rod
;Tuesday,25,March,2025,12:32:02:58926
IDE00019,Voltage terminal 30,14.6, V
IDE00303-MAS00218,Status: doors/lids 1-Driver door,closed,
IDE00303-MAS00219,Status: doors/lids 1-Front Passenger Door,closed,
IDE00303-MAS00220,Status: doors/lids 1-Rear left door,closed,
IDE00303-MAS00221,Status: doors/lids 1-Rear right door,closed,
IDE00303-MAS00222,Status: doors/lids 1-Rear lid,closed,
IDE00303-MAS01374,Status: doors/lids 1-Trailer,Measuring value not available,
IDE00924-IDE08941,Steering angle-Rack position,1295.98, °
IDE00924-MAS02471,Steering angle-Sign,Positive,
IDE00924-MAS02983,Steering angle-Steering wheel angle,1.0, °
IDE00924,Steering angle,0.1250, °
IDE00924-MAS10998,Steering angle-Rear-wheel drive: steering angle,647.99, °
IDE00924-MAS10999,Steering angle-Rear-wheel drive: sign,Positive,
IDE00924-MAS11000,Steering angle-Rack: sign,Positive,
IDE01164,Parking aid button,Not operated,
IDE02322,Parking aid indicator light,not active,
IDE04515-MAS10857,Supply voltage for camera-Front camera,14.4, V
IDE04515-MAS10858,Supply voltage for camera-Rear camera,14.4, V
IDE04515-MAS10859,Supply voltage for camera-Camera left,14.4, V
IDE04515-MAS10860,Supply voltage for camera-Camera right,14.4, V
IDE07402-MAS10857,External activation-Front camera,not active,
IDE07402-MAS10858,External activation-Rear camera,active,
IDE10589-MAS10857,Temperature of the camera-Front camera,49, °C
IDE10589-MAS10858,Temperature of the camera-Rear camera,48, °C
IDE10589-MAS10859,Temperature of the camera-Camera left,54, °C
IDE10589-MAS10860,Temperature of the camera-Camera right,47, °C
IDE10740-IDE03619,System state area view-System condition,active,
IDE11010-MAS00106,Rear camera: calibration time-Year,2024,
IDE11010-MAS00107,Rear camera: calibration time-Month,11,
IDE11010-MAS00108,Rear camera: calibration time-Day,22,
IDE11010-MAS00109,Rear camera: calibration time-Hours,15,
IDE11010-MAS00110,Rear camera: calibration time-Minutes,8,
IDE11010-MAS00111,Rear camera: calibration time-Seconds,48,
IDE11012-MAS00106,Left camera: calibration time-Year,2024,
IDE11012-MAS00107,Left camera: calibration time-Month,11,
IDE11012-MAS00108,Left camera: calibration time-Day,22,
IDE11012-MAS00109,Left camera: calibration time-Hours,15,
IDE11012-MAS00110,Left camera: calibration time-Minutes,8,
IDE11012-MAS00111,Left camera: calibration time-Seconds,48,
IDE11013-MAS00106,Right camera: calibration time-Year,2024,
IDE11013-MAS00107,Right camera: calibration time-Month,11,
IDE11013-MAS00108,Right camera: calibration time-Day,22,
IDE11013-MAS00109,Right camera: calibration time-Hours,15,
IDE11013-MAS00110,Right camera: calibration time-Minutes,8,
IDE11013-MAS00111,Right camera: calibration time-Seconds,48,
IDE11728,Ethernet signal quality: branch 1,good: link available,
IDE11729,Ethernet signal quality: branch 2,good: link available,
IDE11730,Ethernet signal quality: branch 3,good: link available,
IDE11731,Ethernet signal quality: branch 4,good: link available,
IDE11732,Ethernet signal quality: branch 5,good: link available,
IDE11733,Ethernet signal quality: branch 6,good: link available,
IDE11736-MAS11932,Ethernet counter connection interruptions: branch 1-Counter open circuit,0,
IDE11737-MAS11932,Ethernet counter connection interruptions: branch 2-Counter open circuit,0,
IDE11738-MAS11932,Ethernet counter connection interruptions: branch 3-Counter open circuit,0,
IDE11739-MAS11932,Ethernet counter connection interruptions: branch 4-Counter open circuit,0,
IDE11740-MAS11932,Ethernet counter connection interruptions: branch 5-Counter open circuit,0,
IDE11741-MAS11932,Ethernet counter connection interruptions: branch 6-Counter open circuit,0,
IDE11744-MAS11933,Ethernet counter checksum error: branch 1-Counter CRC error,0,
IDE11745-MAS11933,Ethernet counter checksum error: branch 2-Counter CRC error,0,
IDE11746-MAS11933,Ethernet counter checksum error: branch 3-Counter CRC error,0,
IDE11747-MAS11933,Ethernet counter checksum error: branch 4-Counter CRC error,0,
IDE11748-MAS11933,Ethernet counter checksum error: branch 5-Counter CRC error,0,
IDE11749-MAS11933,Ethernet counter checksum error: branch 6-Counter CRC error,1,
IDE11752-IDE09469,IP network: IPv6-addresses-IPv6 address,|IPv6 address|FD 53 7C B8 03 83 00 02 00 00 00 00 00 00 00 69|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|,
IDE11753-MAS14855,IP network: IPv6-multicast-addresses-IPv6 Multicast address,|IPv6 Multicast address|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 05|FF 02 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 02|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 0B|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 0C|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 0D|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|,
IDE11755-MAS14856,IP network: VLANs-VLAN,|VLAN|512|0|0|0|0|0|0|0|0|0|,
IDE11757,IP network: counter messages with inadmissible IPv6-addresses,3,
IDE11761-IDE09467,IP network: MAC addresses-MAC address,|MAC address|60 26 02 FE C8 7C|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|,
IDE11988-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 1-MAC address,|MAC address|02 7D FA 00 57 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|,
IDE11989-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 2-MAC address,|MAC address|44 3C 88 72 F2 38|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|,
IDE11990-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 3-MAC address,|MAC address|44 3C 88 73 75 D8|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|,
IDE11991-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 4-MAC address,|MAC address|44 3C 88 77 C9 59|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|,
IDE11992-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 5-MAC address,|MAC address|44 3C 88 75 D0 8D|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|,
IDE11993-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 6-MAC address,|MAC address|60 26 02 FE C8 7C|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|,
IDE12230-MAS14856,IP network: VLANs of Ethernet switch ports branch 1-VLAN,|VLAN|512|0|0|0|0|0|0|0|0|0|,
IDE12231-MAS14856,IP network: VLANs of Ethernet switch ports branch 2-VLAN,|VLAN|512|0|0|0|0|0|0|0|0|0|,
IDE12232-MAS14856,IP network: VLANs of Ethernet switch ports branch 3-VLAN,|VLAN|512|0|0|0|0|0|0|0|0|0|,
IDE12233-MAS14856,IP network: VLANs of Ethernet switch ports branch 4-VLAN,|VLAN|512|0|0|0|0|0|0|0|0|0|,
IDE12234-MAS14856,IP network: VLANs of Ethernet switch ports branch 5-VLAN,|VLAN|512|0|0|0|0|0|0|0|0|0|,
IDE12235-MAS14856,IP network: VLANs of Ethernet switch ports branch 6-VLAN,|VLAN|512|0|0|0|0|0|0|0|0|0|,
IDE12238,I network: discarded messages counter,3,
IDE12239,IP network: test feedback value of communications relationships,|IPv6 address,Result|FD 53 7C B8 03 83 00 02 00 00 00 00 00 01 01 6A
IDE12625,IP network: current link deceleration: branch 1,2500, ns
IDE12626,IP network: current link deceleration: branch 2,2500, ns
IDE12627,IP network: current link deceleration: branch 3,2500, ns
IDE12628,IP network: current link deceleration: branch 4,2500, ns
IDE12629,IP network: current link deceleration: branch 5,2500, ns
IDE12630,IP network: current link deceleration: branch 6,2500, ns
IDE13223-IDE11194,TopView: status of line calibration-Calibration: status,is not running,
IDE13223-MAS04041,TopView: status of line calibration-Calibration ended,completed successfully,
IDE13223-MAS14456,TopView: status of line calibration-Error in the algorithm,No malfunction,
IDE13223-MAS14458,TopView: status of line calibration-maximum acceptable deviation,Not exceeded,
IDE13223-MAS14459,TopView: status of line calibration-Maximum number of iterations,Not reached,
IDE13223-MAS14460,TopView: status of line calibration-Line recognition,No malfunction,
IDE13224-MAS12219,TopView: line calibration error-Left front Range,detected,
IDE13224-MAS12220,TopView: line calibration error-Right front Range,detected,
IDE13224-MAS12221,TopView: line calibration error-Left rear range,detected,
IDE13224-MAS12222,TopView: line calibration error-Right rear range,detected,
IDE13224-MAS12223,TopView: line calibration error-Left horizontal range,detected,
IDE13224-MAS12224,TopView: line calibration error-Left vertical range,detected,
IDE13224-MAS12225,TopView: line calibration error-Right horizontal range,detected,
IDE13224-MAS12226,TopView: line calibration error-Right vertical range,detected,
IDE13227,TopView: autonomous line calibration phases,not requested,
IDE13279-MAS00106,Front peripheral camera: calibration time-Year,2024,
IDE13279-MAS00107,Front peripheral camera: calibration time-Month,11,
IDE13279-MAS00108,Front peripheral camera: calibration time-Day,22,
IDE13279-MAS00109,Front peripheral camera: calibration time-Hours,15,
IDE13279-MAS00110,Front peripheral camera: calibration time-Minutes,8,
IDE13279-MAS00111,Front peripheral camera: calibration time-Seconds,48,
IDE13845,Production mode status,No function restriction,
IDE14292,Ethernet status: electrical error: branch 1,No malfunction,
IDE14293,Ethernet status: electrical error: branch 2,No malfunction,
IDE14294,Ethernet status: electrical error: branch 3,No malfunction,
IDE14295,Ethernet status: electrical error: branch 4,No malfunction,
IDE14296,Ethernet status: electrical error: branch 5,No malfunction,
IDE14297,Ethernet status: electrical error: branch 6,No malfunction,
MAS02356-MAS10857,Type of calibration-Front camera,TopView: calibration with line pattern,
MAS02356-MAS10858,Type of calibration-Rear camera,TopView: calibration with line pattern,
MAS02356-MAS10859,Type of calibration-Camera left,TopView: calibration with line pattern,
MAS02356-MAS10860,Type of calibration-Camera right,TopView: calibration with line pattern,
ENG276442-ENG274898,Front_camera_calibration_tolerance-Pitch_tolerance,-2.16, °
ENG276442-ENG274946,Front_camera_calibration_tolerance-Roll_tolerance,0.52, °
ENG276442-ENG275122,Front_camera_calibration_tolerance-Viewpoint_position_x_tolerance,0, mm
ENG276442-ENG275123,Front_camera_calibration_tolerance-Viewpoint_position_y_tolerance,0, mm
ENG276442-ENG275124,Front_camera_calibration_tolerance-Viewpoint_position_z_tolerance,-10, mm
ENG276442-ENG275138,Front_camera_calibration_tolerance-Yaw_tolerance,0.36, °
ENG276443-ENG274231,Front_camera_intrinsic_parameter-Affine_scale_horizontal,331, mm
ENG276443-ENG274232,Front_camera_intrinsic_parameter-Affine_scale_vertical,331, mm
ENG276443-ENG274904,Front_camera_intrinsic_parameter-Polynomial_coefficient_k1,0.98,
ENG276443-ENG274905,Front_camera_intrinsic_parameter-Polynomial_coefficient_k2,0.06,
ENG276443-ENG274906,Front_camera_intrinsic_parameter-Polynomial_coefficient_k3,0.024,
ENG276443-ENG274907,Front_camera_intrinsic_parameter-Polynomial_coefficient_k4,-0.013,
ENG276443-ENG274908,Front_camera_intrinsic_parameter-Polynomial_coefficient_k5,0.0014,
ENG276443-ENG274172,Front_camera_intrinsic_parameter-Principal_point_x,666, mm
ENG276443-ENG274175,Front_camera_intrinsic_parameter-Principal_point_y,479, mm
ENG276444-ENG261525,Front_Camera_Position-Pitch,12.17, °
ENG276444-ENG261524,Front_Camera_Position-Roll,-0.53, °
ENG276444-ENG164378,Front_Camera_Position-viewpoint_position_x,4048, mm
ENG276444-ENG164380,Front_Camera_Position-viewpoint_position_y,0, mm
ENG276444-ENG164382,Front_Camera_Position-viewpoint_position_z,615, mm
ENG276444-ENG261515,Front_Camera_Position-YAW,-0.37, °
ENG308355-MAS10857,Internal_calibration_state-Front camera,Basic_state,
ENG308355-MAS10858,Internal_calibration_state-Rear camera,Basic_state,
ENG308355-MAS10859,Internal_calibration_state-Camera left,Basic_state,
ENG308355-MAS10860,Internal_calibration_state-Camera right,Basic_state,
ENG276455-ENG274231,Left_camera_intrinsic_parameter-Affine_scale_horizontal,331, mm
ENG276455-ENG274232,Left_camera_intrinsic_parameter-Affine_scale_vertical,331, mm
ENG276455-ENG274904,Left_camera_intrinsic_parameter-Polynomial_coefficient_k1,0.97,
ENG276455-ENG274905,Left_camera_intrinsic_parameter-Polynomial_coefficient_k2,0.07,
ENG276455-ENG274906,Left_camera_intrinsic_parameter-Polynomial_coefficient_k3,0.019,
ENG276455-ENG274907,Left_camera_intrinsic_parameter-Polynomial_coefficient_k4,-0.011,
ENG276455-ENG274908,Left_camera_intrinsic_parameter-Polynomial_coefficient_k5,0.0012,
ENG276455-ENG274172,Left_camera_intrinsic_parameter-Principal_point_x,663, mm
ENG276455-ENG274175,Left_camera_intrinsic_parameter-Principal_point_y,482, mm
ENG276456-ENG261525,Left_Camera_Position-Pitch,57.72, °
ENG276456-ENG261524,Left_Camera_Position-Roll,-7.21, °
ENG276456-ENG164378,Left_Camera_Position-viewpoint_position_x,2541, mm
ENG276456-ENG164380,Left_Camera_Position-viewpoint_position_y,1119, mm
ENG276456-ENG164382,Left_Camera_Position-viewpoint_position_z,1293, mm
ENG276456-ENG261515,Left_Camera_Position-YAW,81.04, °
ENG276569-ENG274898,Right_camera_calibration_tolerance-Pitch_tolerance,0.43, °
ENG276569-ENG274946,Right_camera_calibration_tolerance-Roll_tolerance,1.13, °
ENG276569-ENG275122,Right_camera_calibration_tolerance-Viewpoint_position_x_tolerance,-2, mm
ENG276569-ENG275123,Right_camera_calibration_tolerance-Viewpoint_position_y_tolerance,5, mm
ENG276569-ENG275124,Right_camera_calibration_tolerance-Viewpoint_position_z_tolerance,-5, mm
ENG276569-ENG275138,Right_camera_calibration_tolerance-Yaw_tolerance,-0.34, °
ENG276570-ENG274231,Right_camera_intrinsic_parameter-Affine_scale_horizontal,330, mm
ENG276570-ENG274232,Right_camera_intrinsic_parameter-Affine_scale_vertical,330, mm
ENG276570-ENG274904,Right_camera_intrinsic_parameter-Polynomial_coefficient_k1,0.97,
ENG276570-ENG274905,Right_camera_intrinsic_parameter-Polynomial_coefficient_k2,0.06,
ENG276570-ENG274906,Right_camera_intrinsic_parameter-Polynomial_coefficient_k3,0.022,
ENG276570-ENG274907,Right_camera_intrinsic_parameter-Polynomial_coefficient_k4,-0.012,
ENG276570-ENG274908,Right_camera_intrinsic_parameter-Polynomial_coefficient_k5,0.0014,
ENG276570-ENG274172,Right_camera_intrinsic_parameter-Principal_point_x,665, mm
ENG276570-ENG274175,Right_camera_intrinsic_parameter-Principal_point_y,481, mm
ENG276571-ENG261525,Right_Camera_Position-Pitch,57.33, °
ENG276571-ENG261524,Right_Camera_Position-Roll,-172.64, °
ENG276571-ENG164378,Right_Camera_Position-viewpoint_position_x,2543, mm
ENG276571-ENG164380,Right_Camera_Position-viewpoint_position_y,-1088, mm
ENG276571-ENG164382,Right_Camera_Position-viewpoint_position_z,1281, mm
ENG276571-ENG261515,Right_Camera_Position-YAW,-79.66, °
Elapsed Time: 00:36
blockmap-6D-4KE-959-107-B_WVG5WVEB2SH017765-20250325-1232.CSV
;SW:4KE-959-107-B   HW:4KE-959-107-B ---  Trunk Elect.
;Component:HDSG-Modul    H08 0342, Coding:6208
;EV_DeckLidCONTIAU536,001006,EV_DeckLidCONTIAU536_001_VWE3.rod
;Tuesday,25,March,2025,12:32:47:58926
;VCDS Version: Release 25.3.0 (x64)  Data version: 20250311 DS365.0
;VCID: 45DC3F02552F84C2FC0-8010-R
Group,Description,Actual
IDE00019,Voltage terminal 30,14.76, V
IDE00542,Excessive temperature protection,not active,
IDE02019-MAS08993,Position programmable opening stop-Upper end pos.: relative,99, %
IDE02019-MAS08994,Position programmable opening stop-Upper end pos.: absolute,4717,
IDE02049,Trailer detected,Not available,
IDE02093-MAS09014,Status of rear lid lock-pre-latch,closed,
IDE02093-MAS09015,Status of rear lid lock-Main latch,closed,
IDE02093-MAS09016,Status of rear lid lock-Rear lid lock,closed,
IDE02094-MAS09057,Status of closing assist-Limit switch for pull-shut assist.,operated,
IDE02095-MAS01947,Status of pinch protection-Clamping strip 1,Not operated,
IDE02095-MAS01948,Status of pinch protection-Clamping strip 2,Not operated,
IDE02095-MAS01949,Status of pinch protection-Clamping strip 3,Not operated,
IDE02095-MAS01950,Status of pinch protection-Clamping strip 4,Not operated,
IDE03427-MAS08995,Upper end stop: maximum value-Max. upper end position,4762,
IDE03615-MAS02672,Variant-Start-stop,1,
IDE03906-MAS01947,Pinch protection voltage supply status-Clamping strip 1,OFF,
IDE03906-MAS01948,Pinch protection voltage supply status-Clamping strip 2,OFF,
IDE03906-MAS01949,Pinch protection voltage supply status-Clamping strip 3,OFF,
IDE03906-MAS01950,Pinch protection voltage supply status-Clamping strip 4,On,
IDE05229-MAS09002,Reason for cancellation of rear lid procedure-Last reason,END,
IDE05229-MAS09003,Reason for cancellation of rear lid procedure-second last reasons,END,
IDE05229-MAS09004,Reason for cancellation of rear lid procedure-third last reason,END,
IDE05229-MAS09005,Reason for cancellation of rear lid procedure-fourth last reason,END,
IDE05229-MAS09006,Reason for cancellation of rear lid procedure-fifth last reason,Lock malfunction,
IDE09491-IDE03434,Lock-in area-Detection area lower,300,
IDE09491-IDE03435,Lock-in area-Detection area upper,80,
IDE09492-MAS06165,Temperatures-Processor,-3276.00, °C
IDE09492-MAS08858,Temperatures-Outside air temperature on CAN,Initialization,
IDE09492-MAS08996,Temperatures-Internal temp. on CAN,27.50, °C
IDE09492-MAS08997,Temperatures-Output stage for tailgate motor,36.00, °C
IDE09492-MAS08998,Temperatures-Tailgate motor left,17.00, °C
IDE09492-MAS08999,Temperatures-Tailgate motor right,17.00, °C
IDE09492-MAS09001,Temperatures-Closing Assist Motor,Not available,
IDE09492-MAS09051,Temperatures-Output stage for tailgate motor: calculated,170.00, °C
IDE09492-MAS09053,Temperatures-Output stage for pull-shut assist.: calc.,Not available,
IDE09492-MAS11205,Temperatures-Luggage compartment cover motor,120.00, °C
IDE09492-MAS11206,Temperatures-Output stage for luggage comp. cover: calc.,170.00, °C
IDE09493,Status of basic tailgate setting,Basic setting ended,
IDE09494-MAS09002,Cancellation reason of basic tailgate setting-Last reason,Unknown (0)
IDE09494-MAS09003,Cancellation reason of basic tailgate setting-second last reasons,Unknown (0)
IDE09494-MAS09004,Cancellation reason of basic tailgate setting-third last reason,Unknown (0)
IDE09494-MAS09005,Cancellation reason of basic tailgate setting-fourth last reason,Unknown (0)
IDE09494-MAS09006,Cancellation reason of basic tailgate setting-fifth last reason,Unknown (0)
IDE09495,Status of tailgate initialization,initialized,
IDE09496-MAS09002,Reason for loss of tailgate initialization-Last reason,Reset,
IDE09496-MAS09003,Reason for loss of tailgate initialization-second last reasons,Supply voltage error,
IDE09496-MAS09004,Reason for loss of tailgate initialization-third last reason,Reset,
IDE09496-MAS09005,Reason for loss of tailgate initialization-fourth last reason,Reset,
IDE09496-MAS09006,Reason for loss of tailgate initialization-fifth last reason,Reset,
IDE09498-MAS01871,Status of control points-Rear lid lock button in luggage compartment,Not operated,
IDE09498-MAS01872,Status of control points-Rear lid remote release button,Not operated,
IDE09498-MAS06265,Status of control points-Release button in rear lid handle,Not operated,
IDE09498-MAS06446,Status of control points-Remote radio control: button for luggage compartment unlocking,Not operated,
IDE09498-MAS09010,Status of control points-Sensor for rear lid opening,Not operated,
IDE09498-MAS09072,Status of control points-Locking mechanism button in the rear lid,Malfunction,
IDE09498-MAS13753,Status of control points-Button 2 for rear lid remote release,Malfunction,
IDE09498-MAS27006,Status of control points-Actuations for the rear lid opener in the virtual remote control vehicle key,Not operated,
IDE09499-IDE01991,Motors for tailgate: activation-Motor 1 for tailgate: status,OFF,
IDE09499-IDE02012,Motors for tailgate: activation-Motor 2 for tailgate: status,OFF,
IDE09499-MAS09001,Motors for tailgate: activation-Closing Assist Motor,OFF,
IDE09499-MAS11205,Motors for tailgate: activation-Luggage compartment cover motor,not installed,
IDE09500-MAS09012,Motors for tailgate: RPM-Rear lid motor 1,0.00, Hz
IDE09500-MAS09013,Motors for tailgate: RPM-Rear lid motor 2,0.00, Hz
IDE09500-MAS11205,Motors for tailgate: RPM-Luggage compartment cover motor,0.00, Hz
IDE09501-MAS09001,Motors for tailgate: elec. current-Closing Assist Motor,0.00, A
IDE09501-MAS09012,Motors for tailgate: elec. current-Rear lid motor 1,0.00, A
IDE09501-MAS09013,Motors for tailgate: elec. current-Rear lid motor 2,0.00, A
IDE09501-MAS11205,Motors for tailgate: elec. current-Luggage compartment cover motor,0.00, A
IDE09502-IDE02097,Tailgate angle sensor: absolute value-Position Sensor 1,0,
IDE09502-IDE02098,Tailgate angle sensor: absolute value-Position sensor 2,0,
IDE09502-IDE10697,Tailgate angle sensor: absolute value-Luggage compartment cover: position,0,
IDE09503-IDE02017,Tailgate angle sensor: relative value-Rear lid position: relative,0, %
IDE09503-MAS11205,Tailgate angle sensor: relative value-Luggage compartment cover motor,0, %
IDE09504,Status of clutch test,not active,
IDE09505-IDE02078,Tailgate actuation counter-Activations of rear lid closing button,36,
IDE09505-IDE02079,Tailgate actuation counter-Activations of rear lid unlocking button,33,
IDE09505-IDE02080,Tailgate actuation counter-Activations of rear lid remote unlocking switch,3,
IDE09505-IDE02081,Tailgate actuation counter-Activation of remote key button rid lid opening,1,
IDE09505-IDE02082,Tailgate actuation counter-Opening cycle counter,35,
IDE09505-IDE02083,Tailgate actuation counter-Closing cycle counter,34,
IDE09505-IDE02084,Tailgate actuation counter-Counter obstruction detected,7,
IDE09505-IDE02085,Tailgate actuation counter-Counter of selectable opening stop adapted,0,
IDE09505-IDE02087,Tailgate actuation counter-Counter for function limitation due to insufficient voltage,0,
IDE09505-IDE02088,Tailgate actuation counter-Counter for function limitation due to excessive voltage,0,
IDE09505-IDE02090,Tailgate actuation counter-Counter for function limitation due to excessive temperature,0,
IDE09505-IDE02174,Tailgate actuation counter-Counter of flap opening angle basic settings,1,
IDE09505-IDE03774,Tailgate actuation counter-Counter for closing operations canceled by lock-up,0,
IDE09505-MAS08873,Tailgate actuation counter-Resets to hardware watchdog,0,
IDE09505-MAS08874,Tailgate actuation counter-Resets due to software watchdog,1,
IDE09505-MAS09017,Tailgate actuation counter-Counter tailgate lock: implausible,0,
IDE09505-MAS09018,Tailgate actuation counter-Counter pull-shut asst. implausible,0,
IDE09505-MAS09019,Tailgate actuation counter-Play protection counter active,0,
IDE09505-MAS09058,Tailgate actuation counter-Counter Hall sensor in motor 1 for tailgate implausible,0,
IDE09505-MAS09059,Tailgate actuation counter-Counter Hall sensor in motor 2 for tailgate implausible,0,
IDE09505-MAS09060,Tailgate actuation counter-Wake-up events button for closing rear lid in lugg.compartment,1,
IDE09505-MAS09061,Tailgate actuation counter-Wake-up events Hall sensor in motor for tailgate,0,
IDE09505-MAS09062,Tailgate actuation counter-Wake-up events in data bus,432,
IDE09505-MAS09076,Tailgate actuation counter-Activating tailgate button for locking,0,
IDE09505-MAS09077,Tailgate actuation counter-Activating sensor for tailgate opening,0,
IDE09505-MAS09078,Tailgate actuation counter-Wake-up events button for unlocking tailgate,0,
IDE09505-MAS09482,Tailgate actuation counter-Current limitation active,0,
IDE09505-MAS10783,Tailgate actuation counter-Closing assist.counter: aborted by operating unit,0,
IDE09505-MAS11977,Tailgate actuation counter-Emergency running counter after terminal 30 reset,16,
IDE09505-MAS11978,Tailgate actuation counter-Play protection counter for closing aid active,0,
IDE09505-MAS12517,Tailgate actuation counter-Reset via timeout monitoring watchdog,0,
IDE09505-MAS12518,Tailgate actuation counter-Reset via network management monitoring watchdog,0,
IDE09505-MAS13753,Tailgate actuation counter-Button 2 for rear lid remote release,0,
IDE09505-MAS27006,Tailgate actuation counter-Actuations for the rear lid opener in the virtual remote control vehicle key,0,
IDE09506,Rear lid anti-play protection,not active,
IDE09519-MAS09054,Status of hall sensor in motor for tailgate-Motor 1 for tailgate: Hall sensor voltage supply,On,
IDE09519-MAS09055,Status of hall sensor in motor for tailgate-Motor 2 for tailgate: Hall sensor voltage supply,On,
IDE09519-MAS09066,Status of hall sensor in motor for tailgate-Motor 1: Sensor 1,00000001 ,
IDE09519-MAS09067,Status of hall sensor in motor for tailgate-Motor 1: Sensor 2,00000001 ,
IDE09519-MAS09068,Status of hall sensor in motor for tailgate-Motor 2: Sensor 1,00000001 ,
IDE09519-MAS09069,Status of hall sensor in motor for tailgate-Motor 2: Sensor 2,00000001 ,
IDE09519-MAS11207,Status of hall sensor in motor for tailgate-Motor for luggage comp. cover: sensor 1,00000000 ,
IDE09519-MAS11209,Status of hall sensor in motor for tailgate-Motor for luggage compartment cover: Hall sensor voltage supply,OFF,
IDE10697-MAS01471,Luggage compartment cover: position-lower stop,0,
IDE10697-MAS01472,Luggage compartment cover: position-upper stop,-8960,
IDE10697-MAS02282,Luggage compartment cover: position-Position,33,
IDE10698-IDE03774,Luggage compartment cover: counter-Counter for closing operations canceled by lock-up,0,
IDE10698-MAS09020,Luggage compartment cover: counter-Down adjustment,0,
IDE10698-MAS09021,Luggage compartment cover: counter-Up adjustment,0,
IDE10698-MAS09023,Luggage compartment cover: counter-Total number of adjustments,0,
IDE10698-MAS09024,Luggage compartment cover: counter-Shutdowns by excess force limiter,0,
IDE10698-MAS09025,Luggage compartment cover: counter-Blocking bottom mechan. stop,0,
IDE10698-MAS09026,Luggage compartment cover: counter-Blocking upper mechan. stop,0,
IDE10698-MAS09027,Luggage compartment cover: counter-Re-initializationn in bottom mechan. stop,0,
IDE10698-MAS09028,Luggage compartment cover: counter-Re-initialization in upper mechan. stop,0,
IDE10698-MAS09029,Luggage compartment cover: counter-Number of re-initializations,0,
IDE10699-MAS00342,Status of luggage compartment cover initialization-Initialization,not initialized,
IDE10700-MAS09002,Reason for loss of luggage compartment cover initialization-Last reason,Not yet initialized,
IDE10700-MAS09003,Reason for loss of luggage compartment cover initialization-second last reasons,Not yet initialized,
IDE10700-MAS09004,Reason for loss of luggage compartment cover initialization-third last reason,Not yet initialized,
IDE10700-MAS09005,Reason for loss of luggage compartment cover initialization-fourth last reason,Not yet initialized,
IDE10700-MAS09006,Reason for loss of luggage compartment cover initialization-fifth last reason,Not yet initialized,
IDE10804,Easing of rear lid,not active,
IDE11033,Motor for luggage compart. cover: excess. temp: protection,active,
IDE11036,Pull-shut asst.: play protec.,not active,
IDE11868,Indicator lamp for delayed closing,not installed,
IDE13157,Partial network operation counter not available,0,
MAS00972,Decoration variant,2,
Elapsed Time: 00:06
blockmap-75-14A-035-285-A_WVG5WVEB2SH017765-20250325-1233.CSV
;SW:14A-035-285-A   HW:14A-035-285 ---  Telematics
;Component:OCU4MEB_UNECE H11 0554, Coding:06020700010000000000010013000000101112111012000010
;EV_OCUGen4UNECE,001050,EV_OCUGen4UNECE_VWE3.rod
;Tuesday,25,March,2025,12:33:07:58926
;VCID: 1E6EB06E9039B71A9DA-804A-R SFD+SFD2
IDE00020,Terminal 15 status,On,
IDE00102,Control Module temperature,39, °C
IDE00608,Fuel type,Battery / electric,
IDE00672,Roadside Assistance Button,Not available,
IDE00673,Information Service Button -E450-,Not available,
IDE00767,No. of unscheduled ECU resets,1,
IDE01215-ENG391557,Dimmer terminal 58d-dimmimg terminal 58d mux1,100.44, %
IDE01216,Dimmer terminal 58s,100, %
IDE01588,Driving direction,256, °
IDE01588-MAS01632,Driving direction-Status,Available,
IDE01625,Muting of radio/radio navigation system via control wire,not active,
IDE01630-MAS01167,Key illumination in telephone operating unit-Actuation time,0 s,
IDE01630-ENG170421,Key illumination in telephone operating unit-IoReached Status,Output diagnostic test not active,
IDE01631-MAS01167,Output of variable test tones via radio/radio navigation system-Actuation time,0 s,
IDE01631-ENG170421,Output of variable test tones via radio/radio navigation system-IoReached Status,Output diagnostic test not active,
IDE01712-IDE06673,GPS Position-Initialization status,initialized,
IDE01712-MAS01779,GPS Position-Length,Redacted by Ross-Tech for User Privacy,
IDE01712-MAS01780,GPS Position-Width,Redacted by Ross-Tech for User Privacy,
IDE01712-MAS02230,GPS Position-Height,294, m
IDE01713-MAS01632,Status GPS reception-Status,GPS data is being received: position completely determined,
IDE01713-MAS01785,Status GPS reception-Number of visible satellites,15,
IDE01713-MAS01786,Status GPS reception-Number of tracked satellites,13,
IDE01718,Crash signal,No crash recognized,
IDE01770-MAS01632,Status of GPS antenna-Status,OK,
IDE01770-MAS01808,Status of GPS antenna-Antenna current,26, mA
IDE01971,Lowest recorded control module temperature,-5, °C
IDE01972,Highest recorded control module temperature,48, °C
IDE02067-IDE00690,Antenna for telephone status-Connection to antenna,electrically OK,
IDE02067-MAS01808,Antenna for telephone status-Antenna current,38, µA
IDE02067-MAS03991,Antenna for telephone status-Reception level antenna 1,100, %
IDE02326-ENG117459,GPS signal strength-ID_GPS_satellite_no_1,1,
IDE02326-ENG117461,GPS signal strength-ID_GPS_satellite_no_2,2,
IDE02326-ENG117463,GPS signal strength-ID_GPS_satellite_no_3,7,
IDE02326-ENG117465,GPS signal strength-ID_GPS_satellite_no_4,8,
IDE02326-ENG117460,GPS signal strength-S/N_GPS_satellite_no_1,52, dBµV
IDE02326-ENG117462,GPS signal strength-S/N_GPS_satellite_no_2,50, dBµV
IDE02326-ENG117464,GPS signal strength-S/N_GPS_satellite_no_3,48, dBµV
IDE02326-ENG117466,GPS signal strength-S/N_GPS_satellite_no_4,44, dBµV
IDE03477-MAS00106,GPS time-Year,2025,
IDE03477-MAS00107,GPS time-Month,3,
IDE03477-MAS00108,GPS time-Day,25,
IDE03477-MAS00109,GPS time-Hours,16,
IDE03477-MAS00110,GPS time-Minutes,33,
IDE03477-MAS00111,GPS time-Seconds,11,
IDE03477-MAS01632,GPS time-Status,valid,
IDE04293,Operating state for emer call module,registerstate_not_searching,
IDE04750-MAS03876,SIM card-active SIM card,internal,
IDE04750-MAS03878,SIM card-SIM IMSI,311480904675594,
IDE04750-MAS04226,SIM card-Telephone number,15213066874    ,
IDE04750-MAS08401,SIM card-SIM intern,operational,
IDE04750-MAS08402,SIM card-SIM extern,Unknown,
IDE04750-MAS11003,SIM card-ICCID,89148000011459200539,
IDE04750-MAS11004,SIM card-UICCID,89033023312150000000037793045532,
IDE04790,Call for help button,Not operated,
IDE05430,Telephone serial number,353804420526269,
IDE07589-IDE07590,Update programming: status-Currently processed module,27,
IDE07589-IDE07591,Update programming: status-Number of modules to be programmed,28,
IDE07589-MAS00106,Update programming: status-Year,2024,
IDE07589-MAS00107,Update programming: status-Month,3,
IDE07589-MAS00108,Update programming: status-Day,20,
IDE07589-MAS00109,Update programming: status-Hours,9,
IDE07589-MAS00110,Update programming: status-Minutes,28,
IDE07589-MAS00111,Update programming: status-Seconds,55,
IDE07911-MAS01167,Microphone signal via audio output-Actuation time,0 s,
IDE07911-ENG170421,Microphone signal via audio output-IoReached Status,Output diagnostic test not active,
IDE08235-MAS06798,Status of immobilizer participant-Key / terminal status,04,
IDE08235-MAS06799,Status of immobilizer participant-Immobiliser status,00,
IDE08235-MAS06800,Status of immobilizer participant-Status MSG 1,00,
IDE08235-MAS06801,Status of immobilizer participant-Status MSG 2,00,
IDE08235-MAS06802,Status of immobilizer participant-Status MSG 3,00,
IDE08235-MAS06803,Status of immobilizer participant-Status MSG 4,00,
IDE08235-MAS06804,Status of immobilizer participant-Status TCM,00,
IDE08235-MAS06805,Status of immobilizer participant-Status ESCL,00,
IDE08235-MAS06806,Status of immobilizer participant-Status OCU,00,
IDE08235-MAS06807,Status of immobilizer participant-Status VTS,00,
IDE08236-MAS06808,Status locking periods immobilizer-Lock time download,00,
IDE08236-MAS06809,Status locking periods immobilizer-Reset lock time passwords,00,
IDE08236-MAS06810,Status locking periods immobilizer-Lock time login terminal 15 on,00,
IDE08236-MAS06811,Status locking periods immobilizer-Lock time login learn keys,00,
IDE08236-MAS06812,Status locking periods immobilizer-Lock time login leave learn keys,00,
IDE08236-MAS06813,Status locking periods immobilizer-Lock time login special functions,00,
IDE08237-MAS06814,Status Secure Hardware Extension-SHE counter,00 00 01 01,
IDE08237-MAS06815,Status Secure Hardware Extension-SHE key number,6, s
IDE08251-MAS06847,Configuration immobilizer-Snapshot,53 00 00 00 00 00 00 00 05 E8 00 00 00 00 00 10 03 00 3C,
IDE08343,Immobilizer Challenge,58 AA 02 05,
IDE09293-IDE00690,Status of antenna 2 for phone-Connection to antenna,electrically OK,
IDE09293-MAS01808,Status of antenna 2 for phone-Antenna current,38, µA
IDE09293-MAS03991,Status of antenna 2 for phone-Reception level antenna 1,100, %
IDE10300,OBD Driving Cycle detected,not active,
IDE10779,Ethernet signal quality,good: link available,
IDE10780,Ethernet counter connection interruptions,2,
IDE10781,Ethernet counter checksum malfunction,00,
IDE11282-IDE00704,Battery for emergency call module-State of Charge (SOC),87,
IDE11282-MAS00362,Battery for emergency call module-Battery voltage,7844,
IDE11282-MAS02201,Battery for emergency call module-Temperature,25, °C
IDE11282-MAS02476,Battery for emergency call module-installed,installed,
IDE11282-MAS02476,Battery for emergency call module-installed,was not charged,
IDE11282-MAS08415,Battery for emergency call module-Battery condition,Battery OK,
IDE11307-IDE01839,eCall battery status-Battery charge level,87, %
IDE11307-MAS08415,eCall battery status-Battery condition,normal,
IDE11752-IDE09469,IP network: IPv6-addresses-IPv6 address,|IPv6 address|FD 53 7C B8 03 83 00 04 00 00 00 00 00 00 00 67|,
IDE11753-MAS14855,IP network: IPv6-multicast-addresses-IPv6 Multicast address,|IPv6 Multicast address|FF 02 00 00 00 00 00 00 00 00 00 00 00 00 00 02|FF 02 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 01 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 09|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 05|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 16|FF 14 00 00 00 00 00 00 00 00 00 00 00 04 00 00|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 03|FF 14 00 00 00 00 00 00 00 00 00 00 00 05 00 00|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 02|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 0D|FF 02 00 00 00 00 00 00 00 00 00 01 FF 00 00 00|FF 02 00 00 00 00 00 00 00 00 00 01 FF 00 00 67|,
IDE11755-MAS14856,IP network: VLANs-VLAN,|VLAN|4|,
IDE11756,IP network: counter messages with inadmissible VLANs,0,
IDE11757,IP network: counter messages with inadmissible IPv6-addresses,0,
IDE11759,IP network: counter messages with inadmissible TCP ports,0,
IDE11760,IP network: counter messages with inadmissible UDP ports,0,
IDE11761-IDE09467,IP network: MAC addresses-MAC address,|MAC address|B4 E3 D0 12 04 5F|,
IDE11869,IP network: NDP cache,|MAC address,IPv6 address
IDE12238,I network: discarded messages counter,0,
IDE12239,IP network: test feedback value of communications relationships,|IPv6 address,Result|FD 53 7C B8 03 83 00 03 00 00 00 00 00 00 01 08
IDE12625,IP network: current link deceleration: branch 1,5856, µs
IDE12633,IP Network maximum correction of the synchronized clock,-6736, ns
IDE12732,Button for ERA/Glonass test,Not available,
IDE13159-MAS01167,Loudspeaker test for emergency call module-Actuation time,0 s,
IDE13159-ENG170421,Loudspeaker test for emergency call module-IoReached Status,Output diagnostic test not active,
IDE13593-MAS07135,Emergency call SIM profile-Activation status,not activated,
IDE13593-MAS07967,Emergency call SIM profile-profile,Not available,
IDE13593-MAS11003,Emergency call SIM profile-ICCID,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE13835-MAS17093,VKMS: relevant VIN number for last data supply-Status of vehicle identification number,valid,
IDE13835-MAS17094,VKMS: relevant VIN number for last data supply-Vehicle identification number output,WVG5WVEB2SH017765,
IDE13836-MAS17095,VKMS: adaption counter-Adaptation counter status,valid,
IDE13836-MAS17096,VKMS: adaption counter-Adaptation counter output,00 01,
IDE13837-MAS17097,VKMS: overview missing keys-Key status,valid,
IDE13837-MAS17099,VKMS: overview missing keys-Number of missing keys,0,
IDE13837-MAS17100,VKMS: overview missing keys-Missing key,00 00,
IDE13842-MAS17101,VKMS: retrieval of information list of the stored VKMS keys-VKMS key status,valid,
IDE13842-MAS17104,VKMS: retrieval of information list of the stored VKMS keys-VKMS type adaptation counter,00 01,
IDE13842-MAS18318,VKMS: retrieval of information list of the stored VKMS keys-Number of VKMS keys,21,
IDE13845-ENG255234,Production mode status-Status_productionmode,No_function_controlled,
IDE13957-MAS00106,Mobile Online Service: connection status-Year,2025, yr
IDE13957-MAS00107,Mobile Online Service: connection status-Month,2, Months
IDE13957-MAS00108,Mobile Online Service: connection status-Day,21, d
IDE13957-MAS00109,Mobile Online Service: connection status-Hours,15, H
IDE13957-MAS00110,Mobile Online Service: connection status-Minutes,43, min
IDE13957-MAS00111,Mobile Online Service: connection status-Seconds,8, s
IDE13957-MAS00976,Mobile Online Service: connection status-Counter,0,
IDE13957-MAS07131,Mobile Online Service: connection status-ID steps,0,
IDE13957-MAS07132,Mobile Online Service: connection status-Code status,30,
IDE13957-MAS16770,Mobile Online Service: connection status-Year (UTC: universal time coordinated),2025, yr
IDE13957-MAS16772,Mobile Online Service: connection status-Month (UTC: universal time coordinated),2, Months
IDE13957-MAS16773,Mobile Online Service: connection status-Day (UTC: universal time coordinated),21, d
IDE13957-MAS16774,Mobile Online Service: connection status-Hour (UTC: universal time coordinated),15, H
IDE13957-MAS16775,Mobile Online Service: connection status-Minute (UTC: universal time coordinated),43, min
IDE13957-MAS16776,Mobile Online Service: connection status-Seconds (UTC: universal time coordinated),8, s
IDE13957-ENG151979,Mobile Online Service: connection status-Server_HTTP_Status_Code_Textual,Data connection established,
IDE13958-MAS00106,Mobile Online Service: service status-Year,2255, yr
IDE13958-MAS00107,Mobile Online Service: service status-Month,255, Months
IDE13958-MAS00108,Mobile Online Service: service status-Day,255, d
IDE13958-MAS00109,Mobile Online Service: service status-Hours,255, H
IDE13958-MAS00110,Mobile Online Service: service status-Minutes,255, min
IDE13958-MAS00111,Mobile Online Service: service status-Seconds,255, s
IDE13958-MAS07134,Mobile Online Service: service status-ID services,cc_breakdown_v2,
IDE13958-MAS07135,Mobile Online Service: service status-Activation status,Not available,
IDE13958-MAS07136,Mobile Online Service: service status-Exp. year,2000, yr
IDE13958-MAS07137,Mobile Online Service: service status-Exp. month,1, Months
IDE13958-MAS07138,Mobile Online Service: service status-Exp. day,1, d
IDE13958-MAS16770,Mobile Online Service: service status-Year (UTC: universal time coordinated),2255, yr
IDE13958-MAS16772,Mobile Online Service: service status-Month (UTC: universal time coordinated),255, Months
IDE13958-MAS16773,Mobile Online Service: service status-Day (UTC: universal time coordinated),255, d
IDE13958-MAS16774,Mobile Online Service: service status-Hour (UTC: universal time coordinated),255, H
IDE13958-MAS16775,Mobile Online Service: service status-Minute (UTC: universal time coordinated),255, min
IDE13958-MAS16776,Mobile Online Service: service status-Seconds (UTC: universal time coordinated),255, s
IDE13958-ENG246084,Mobile Online Service: service status-status_last_fail,65535,
IDE13958-ENG246255,Mobile Online Service: service status-status_last_ok,65535,
IDE13958-ENG246120,Mobile Online Service: service status-status_second_last_fail,65535,
IDE13958-ENG246279,Mobile Online Service: service status-status_second_last_ok,65535,
IDE14344-MAS18506,Automotive audio bus (A2B): status-Node name,Microphone module in roof,
IDE14344-MAS18507,Automotive audio bus (A2B): status-Node number,0,
IDE14344-MAS18509,Automotive audio bus (A2B): status-Node status,electrically OK,
IDE14492-MAS18388,Secure Onboard Communication: verification failed-Failed verification status,valid,
IDE14492-MAS18389,Secure Onboard Communication: verification failed-Number of failed verifications,0,
IDE14492-MAS18390,Secure Onboard Communication: verification failed-Verification failed,00 00,
IDE14493-MAS18360,Secure Onboard Communication: signatures failed-failed signature creation,00 00,
IDE14493-MAS18391,Secure Onboard Communication: signatures failed-Failed signature creation status,valid,
IDE14493-MAS18392,Secure Onboard Communication: signatures failed-Number of failed signature creations,0,
IDE14494-MAS18361,Secure Onboard Communication: general information-Status of general information,valid,
IDE14494-MAS18362,Secure Onboard Communication: general information-ECU function,SOC participant,
IDE14494-MAS18367,Secure Onboard Communication: general information-Main function call period,5,
IDE14495-MAS18369,Secure Onboard Communication: information about internal time-Internal SOC time status,valid,
IDE14495-MAS18370,Secure Onboard Communication: information about internal time-Validity of internal SOC time,Valid SOC time,
IDE14495-MAS18374,Secure Onboard Communication: information about internal time-Internal time,00 0D C0 1D 12 CA 8E 97,
IDE14495-MAS18375,Secure Onboard Communication: information about internal time-Jitter test status,Jitter not exceeded,
IDE14496-MAS18378,Secure Onboard Communication: Freshness Values information-Freshness status,valid,
IDE14496-MAS18379,Secure Onboard Communication: Freshness Values information-Number of Freshness IDs,12,
IDE14496-MAS18380,Secure Onboard Communication: Freshness Values information-SOC PDU ID to which this freshness information is assigned,00 03,
IDE14496-MAS18381,Secure Onboard Communication: Freshness Values information-Freshness Value query status,Freshness Value was not queried,
IDE14496-MAS18384,Secure Onboard Communication: Freshness Values information-SOC time of last successful verification,FF FF FF FF FF FF FF FF,
IDE14496-MAS18385,Secure Onboard Communication: Freshness Values information-Current value of message counter,255,
IDE14496-MAS18386,Secure Onboard Communication: Freshness Values information-Bitfield with used counter values,11111111 11111111 ,
IDE14497-MAS17099,Secure Onboard Communication: missing key-Number of missing keys,0,
IDE14497-MAS17100,Secure Onboard Communication: missing key-Missing key,00 00,
IDE14497-MAS18387,Secure Onboard Communication: missing key-Missing key status,valid,
IDE14878,IP network: counter - rejected ethernet frames: layer 2,65535,
IDE14879,IP network: counter - rejected IPv6 packets: layer 3,0,
IDE14880,IP network: counter - rejected UDP/TCP packets: layer 4,0,
MAS00077-MAS02345,Immobilizer-Current condition,02,
MAS00077-MAS06790,Immobilizer-Identity counter,01,
MAS00077-MAS06791,Immobilizer-Mark detection,03,
MAS00077-MAS06792,Immobilizer-P class,E8,
MAS00077-MAS06793,Immobilizer-Number of adapted keys,00,
MAS00077-MAS06794,Immobilizer-Number of keys to be adapted via service download,00,
MAS00077-MAS06795,Immobilizer-Number of keys to be adapted adapt service keys,00,
MAS00077-MAS06796,Immobilizer-Remaining time to switch on terminal 15,00,
MAS00077-MAS06797,Immobilizer-Status configuration,04,
MAS00464-MAS00106,Standard - ambient data 1-Year,2025,
MAS00464-MAS00107,Standard - ambient data 1-Month,3,
MAS00464-MAS00108,Standard - ambient data 1-Day,25,
MAS00464-MAS00109,Standard - ambient data 1-Hours,16,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,33,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,27,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,2,
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,209, km
MAS01490-IDE08800,Energy management-Battery capacity - current value,100, %
MAS01490-IDE16437,Energy management-Filling,00 00,
MAS01490-MAS08405,Energy management-Wake up cycles counter,270,
MAS01490-MAS27080,Energy management-High-voltage battery accepted,not transmitted,
MAS01490-ENG319453,Energy management-energy_release_12V_or_HV,12V battery,
MAS03615-MAS01167,Connection setup-Actuation time,0 s,
MAS03615-ENG170421,Connection setup-IoReached Status,Output diagnostic test not active,
MAS04394-IDE03580,Connection status-Country recognition for mobile network,311,
MAS04394-IDE07699,Connection status-Mobile network operator,480,
MAS04394-MAS03991,Connection status-Reception level antenna 1,100, %
MAS04394-MAS04460,Connection status-Validity,invalid,
MAS04394-MAS08406,Connection status-Network type,LTE,
MAS04394-MAS08407,Connection status-Data connection,active,
MAS04394-ENG123307,Connection status-Radio_Cell_Number,118528790,
MAS04394-ENG123308,Connection status-TCP_Connection_State,active,
MAS08178-IDE05253,Crash information-Front crash,No,
MAS08178-IDE05254,Crash information-Side crash on driver side,No,
MAS08178-IDE05255,Crash information-Side crash on frt.pass.side,No,
MAS08178-IDE05256,Crash information-Rear crash,No,
MAS08178-IDE05257,Crash information-Rollover crash,No,
MAS08178-MAS08636,Crash information-Automatic emergency call activated:Accident sensor,No,
MAS08200,Emergency call speaker status,electrically OK,
MAS10430,Indicator light for emerg. call,Emergency call function available,
MAS13076-MAS12732,Error valid: error path traversed-Dataset download,full working order,
MAS13076,Error valid: error path traversed,Active diagnosis,
MAS16678-MAS01167,Test mode for emergency call-Actuation time,0 s,
MAS16678-ENG170421,Test mode for emergency call-IoReached Status,Output diagnostic test not active,
MAS18157-MAS18158,SFD activated status-Role of vehicle diagnostic to be protected,No activation active,
MAS18157-MAS18161,SFD activated status-Status of vehicle diagnostic to be protected,SFD individualization feature set,
MAS18157-MAS18164,SFD activated status-Duration of vehicle diagnostic to be protected,No activation active,
MAS18157-MAS18165,SFD activated status-Type of vehicle diagnostic to be protected,No activation active,
MAS18799-MAS01167,Radio / radio navigation system muting test-Actuation time,0 s,
MAS18799-ENG170421,Radio / radio navigation system muting test-IoReached Status,Output diagnostic test not active,
MAS18800,Version of audio dataset used,U140,
MAS20396,SFD protection procedure,SFD access protection and SFD end-to-end protection,
MAS21340-ENG391363,PWM signal: duty cycle-pwm_duty_cycle_factor_terminal_xtxs,100, %
MAS24962,Partition synchronization,Synchronized,
ENG123206,Antenna_Switch,LTE antenna 1,
ENG186123-ENG187319,Authentic_time_last_client_response-Counter_kl15_since_last_sync,0,
ENG186123-ENG187669,Authentic_time_last_client_response-Current_time_used,2025-03-25T16:33:25Z,
ENG186123-ENG186739,Authentic_time_last_client_response-Last_valid_timestamp_from_Backend,2025-03-25T16:13:44Z,
ENG254564-ENG255490,Backup_Battery_SoH-BUB_ci,79.550,
ENG254564-ENG256057,Backup_Battery_SoH-mcharge_time,0, s
ENG254564-ENG256085,Backup_Battery_SoH-mSoH,100,
ENG254564-ENG256302,Backup_Battery_SoH-rSoH,98,
ENG123205,Incoming_call_line_state,Idle,
ENG117422,IP_Address,100.78.117.224,
ENG123203-ENG123321,Network_Statistics-CRC_Errors,11568,
ENG123203-ENG123320,Network_Statistics-DNS_Resolution,12853,
ENG123203-ENG123324,Network_Statistics-DNS_Resolution_Error,No malfunction,
ENG123203-ENG124655,Network_Statistics-Duration_Of_Voice_Calls,4278211072, min
ENG123203-ENG123319,Network_Statistics-Established_TCP_Connections,12848,
ENG123203-ENG123326,Network_Statistics-HTTP_Transmission_Error,Malfunction,
ENG123203-ENG123317,Network_Statistics-Interrupted_TCP_Connections,14900,
ENG123203-ENG123323,Network_Statistics-Network_Timeout_Error,Malfunction,
ENG123203-ENG123315,Network_Statistics-Number_Of_Events,12852,
ENG123203-ENG123330,Network_Statistics-Number_Of_Failed_DNS_Requests,12598,
ENG123203-ENG123332,Network_Statistics-Number_Of_Failed_HTTP_Requests,13114,
ENG123203-ENG123331,Network_Statistics-Number_Of_Failed_PDP_Connections,14899,
ENG123203-ENG123333,Network_Statistics-Number_Of_Failed_Secure_Connections,12853,
ENG123203-ENG123328,Network_Statistics-Number_Of_Failed_Transport_Protocol_Connections,11570,
ENG123203-ENG123314,Network_Statistics-Number_Of_Jobs,11826,
ENG123203-ENG123329,Network_Statistics-Number_Of_Network_Timeouts,13652,
ENG123203-ENG123316,Network_Statistics-Number_Of_Packet_Data_Connection_Failures,51,
ENG123203-ENG123311,Network_Statistics-Number_Of_Voice_Calls,12592,
ENG123203-ENG123325,Network_Statistics-PDP_Connection_Error,No malfunction,
ENG123203-ENG123318,Network_Statistics-Rejected_TCP_Connections,13402,
ENG123203-ENG123334,Network_Statistics-Round_Trip_Time,23040, ms
ENG123203-ENG123327,Network_Statistics-Secure_Connection_Error,Malfunction,
ENG123203-ENG123313,Network_Statistics-Service_Data_Volume,774975799, B
ENG123203-ENG123335,Network_Statistics-SMS_Counter,255,
ENG123203-ENG123312,Network_Statistics-Total_Data_Volume,808335160, B
ENG123203-ENG123322,Network_Statistics-Transport_Protocol_Connection_Error,Malfunction,
ENG245690,OCU_Internal_Status_Field,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG123204,Outgoing_call_line_state,Idle,
ENG247809,Position_Confidence,36, m
ENG377979-ENG391842,Pwm_duty_cycle_factor_terminal_58d-pwm_duty_cycle_value_Green,100, %
ENG377979-ENG391106,Pwm_duty_cycle_factor_terminal_58d-pwm_duty_cycle_value_Red,0, %
ENG247812-ENG159329,Second_Last_Position-Latitude, 35°54'22.3"N,
ENG247812-ENG159328,Second_Last_Position-Longitude, 84° 6'41.3"W ,
ENG247822-ENG159329,Third_Last_Position-Latitude, 35°54'23.9"N,
ENG247822-ENG159328,Third_Last_Position-Longitude, 84° 6'41.7"W ,
Elapsed Time: 00:22
blockmap-7E-10A-920-320-D_WVG5WVEB2SH017765-20250325-1233.CSV
;SW:10A-920-320-D   HW:10A-920-320-D ---  Ctrl Head Dash
;Component:FAHRERDISPLAY 031 0650, Coding:267001
;EV_DashBoardLGMEB,002032,EV_DashBoardLGMEB_002_VWE3.rod
;Tuesday,25,March,2025,12:33:53:58926
;VCID: 167EA84E7809FF5A45A-8042-R SFD
IDE07159-MAS01155,Control module switch-off: counter-Control module,00,
IDE07159-MAS05583,Control module switch-off: counter-Data bus,00,
IDE14129-IDE04290,Segment test status-Color code,White,
IDE14129-MAS01167,Segment test status-Actuation time,OFF,
IDE14129-ENG261531,Segment test status-IO Reached Status,Output diagnostic test not active,
IDE14130-MAS01167,Test image in center display status-Actuation time,OFF,
IDE14130-MAS01168,Test image in center display status-Start parameter,not defined,
IDE14130-ENG261531,Test image in center display status-IO Reached Status,Output diagnostic test not active,
IDE14132-MAS01167,Indicator lamp status-Actuation time,OFF,
IDE14132-MAS01168,Indicator lamp status-Start parameter,OFF,
IDE14132-ENG261531,Indicator lamp status-IO Reached Status,Output diagnostic test not active,
IDE15133-IDE04798,LED activation-Left turn signal,OFF,
IDE15133-IDE04799,LED activation-Right turn signal,OFF,
IDE15133-MAS00170,LED activation-OBD,OFF,
IDE15133-MAS00988,LED activation-Reverse gear,OFF,
IDE15133-MAS01167,LED activation-Actuation time,OFF,
IDE15133-MAS01712,LED activation-Neutral,OFF,
IDE15133-MAS01736,LED activation-Driving,OFF,
IDE15133-MAS03834,LED activation-Emergency signal flashing,OFF,
IDE15133-MAS12723,LED activation-Arrow symbol,OFF,
IDE15133-MAS18688,LED activation-Parking,OFF,
IDE15133-MAS20558,LED activation-Jump symbol,OFF,
IDE15133-MAS20559,LED activation-Slash,OFF,
IDE15133-UNK00014,LED activation-B,OFF,
IDE15133-ENG261531,LED activation-IO Reached Status,Output diagnostic test not active,
MAS18157-MAS20207,SFD activated status-SFD roll,No activation active,
ENG105830-ENG261526,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_functional_lighting_for_gear_selection_red,1000,
ENG105830-ENG261527,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_functional_lighting_for_gear_selection_white,1000,
ENG105830-ENG261528,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_functional_lighting_for_gear_selection_yellow,1000,
ENG105830-ENG100477,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_indicator_lights,1000,
ENG105830-ENG103803,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_middle_display_main_field,1000,
ENG105830-ENG261529,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_search_lighting_for_gear_selection_white,1000,
ENG105830-ENG261530,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_internal characteristic_phototransistor,254,
Elapsed Time: 00:01
blockmap-8C-0Z1-915-184-AE_WVG5WVEB2SH017765-20250325-1234.CSV
;SW:0Z1-915-184-AE   HW:0Z1-915-184-D ---  HV Battery
;Component:J840 K8C  BMC 010 1141, Coding:
;EV_BMCeVWBSMEB,003018,EV_BMCeVWBSMEB_003_VWE3.rod
;Tuesday,25,March,2025,12:34:12:58926
;VCID: 7DAC97E27D7F0C02E40-8028-R
IDE00010,Serial number,00000020102403031231,
IDE00019,Voltage terminal 30,14.195, V
IDE00021,Engine speed,0, /min
IDE00056,History data 1,12,
IDE00056,History data 1,7,
IDE00056,History data 1,||00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 01 43 57|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 35 B1 F3|00 03 AE C9|00 01 31 77|00 04 BB ED|00 00 00 00|00 00 00 00|00 00 00 00|00 1B 21 7F|00 04 BC 5C|00 04 BF 58|00 04 14 8A|00 00 56 6E|00 00 99 26|00 00 00 00|00 1E BD 53|00 03 34 58|00 02 E3 0F|00 03 6D 3C|00 00 58 2F|00 01 75 25|00 00 00 00|00 09 FB 3B|00 01 27 45|00 00 00 00|00 00 7F 89|00 00 00 00|00 00 00 00|00 00 00 00|00 00 0E 10|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|,
IDE00056,History data 1,0,
IDE00057,History data 2,8,
IDE00057,History data 2,||00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 4C|00 00 00 49|00 00 02 FA|00 00 04 DB|00 00 02 02|00 00 00 00|00 00 00 00|00 00 00 00|00 00 03 F0|00 00 05 92|00 00 47 66|00 00 3B FC|00 00 0A 33|00 00 00 00|00 00 00 00|00 00 00 00|00 00 02 EC|00 00 04 93|00 00 2D 65|00 00 1F F8|00 00 06 62|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|,
IDE00057,History data 2,0,
IDE00058,History data 3,||00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 07 93|00 00 0A 0C|00 00 05 F4|00 00 15 66|00 00 10 2C|00 00 00 00|00 00 00 00|00 00 00 00|00 00 2B 4D|00 00 1A A7|00 00 38 17|00 01 66 C9|00 00 31 72|00 00 1D 99|00 00 00 00|00 00 00 00|00 00 33 62|00 00 0B 73|00 00 20 8F|00 00 98 F2|00 00 18 99|00 00 0D 5D|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|,
IDE00058,History data 3,0,
IDE00059,History data 4,64,
IDE00059,History data 4,||00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 0A|00 00 00 2C|00 03 20 AD|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 04|00 00 FF DB|00 00 11 AA|00 00 00 00|00 00 00 00|00 00 09 54|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|,
IDE00059,History data 4,0,
IDE00060,History data 5,||00 00 00 00|00 00 97 E7|00 00 33 C5|00 00 2A 8C|00 00 58 90|00 00 14 C2|,
IDE00060,History data 5,0,
IDE00061,History data 6,10,
IDE00061,History data 6,20,
IDE00061,History data 6,2,
IDE00061,History data 6,||00 00 03 8A|00 00 00 02|00 00 00 01|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 02 11|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|,
IDE00062,History data 7,6,
IDE00062,History data 7,||00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 01|00 00|00 01|00 00|00 00|00 00|00 00|00 00|00 00|00 01|00 00|00 00|00 01|00 00|,
IDE00062,History data 7,0,
IDE00063,History data 8,6,
IDE00063,History data 8,42,
IDE00063,History data 8,||00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 01|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|,
IDE00063,History data 8,0,
IDE00064,History data 9,108,
IDE00064,History data 9,||00 00 6B 58|00 00 A6 68|00 00 AE D8|00 00 A4 C4|00 00 82 14|00 00 8B EC|00 00 00 00|00 00 6B 58|00 01 06 BC|00 01 11 C0|00 01 4A 78|00 01 09 50|00 01 09 C8|00 01 33 F8|00 00 BB 08|00 01 28 40|00 00 77 10|00 00 EA 24|00 01 13 DC|00 01 44 60|00 01 38 30|00 01 33 80|00 00 F8 70|00 00 E6 DC|00 00 FD 5C|00 01 62 24|00 01 78 2C|00 01 4A F0|00 01 03 74|00 00 9D 08|00 00 BB 08|00 01 1A A8|00 00 89 1C|00 00 89 1C|00 00 E6 64|00 00 C2 C4|00 00 DA AC|00 00 78 78|00 00 47 04|00 00 6B 58|00 00 00 00|00 00 07 44|00 00 07 44|00 00 00 00|00 00 15 54|00 00 2B 20|00 00 1D 10|00 00 00 00|00 00 BC 70|00 00 9D 08|00 00 A7 D0|00 00 D9 44|00 01 59 00|00 00 BB 08|00 00 E7 90|00 00 CD 8C|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 07 44|00 00 00 00|00 00 00 00|00 00 89 1C|00 00 E0 C4|00 00 AA A0|00 01 1A A8|00 00 D5 C0|00 00 E9 AC|00 00 E1 78|00 00 E0 C4|00 00 FC E4|00 01 D5 B0|00 01 7C A0|00 01 92 A8|00 01 75 D4|00 01 4A 00|00 00 DE A8|00 00 A7 1C|00 00 D5 48|00 00 D3 2C|00 00 D0 20|00 01 0D C4|00 01 14 CC|00 00 BD D8|00 00 E1 78|00 00 E0 C4|00 00 CD 8C|00 01 1C 88|00 01 1F D0|00 01 37 F4|00 00 EE 20|00 00 7F 44|00 00 9D 08|00 00 89 1C|00 00 E1 78|00 00 F4 38|00 00 FF 3C|00 00 BD D8|00 01 08 24|00 00 F4 EC|00 00 CD 8C|00 01 03 B0|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|,
IDE00065,History data 10,||00 02 C0 29|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|,
IDE00065,History data 10,0,
IDE00066,History data 11,2,
IDE00066,History data 11,16,
IDE00066,History data 11,||00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|,
IDE00066,History data 11,0,
IDE00067,History data 12,||00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|,
IDE00067,History data 12,0,
IDE00068,History data 13,8,
IDE00068,History data 13,||00 00 02 0A|00 00 00 02|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 01|,
IDE00069,History data 14,108,
IDE00069,History data 14,5D C0,
IDE00069,History data 14,||2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|00 00|00 00|00 00|00 00|,
IDE00070,History data 15,9,
IDE00070,History data 15,36,
IDE00070,History data 15,||00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|,
IDE00070,History data 15,0,
IDE00071,History data 16,6B,
IDE00071,History data 16,01 7C,
IDE00071,History data 16,1,
IDE00071,History data 16,95,
IDE00071,History data 16,00 58,
IDE00071,History data 16,00 01,
IDE00961-MAS05695,Malfunction Indicator Lamp-Start request,not active,
IDE01021,Current of H-V / hybrid battery,16, °C
IDE01021,Current of H-V / hybrid battery,-1.220, A
IDE01028-MAS01422,Air temperature of H-V / hybrid battery-Intake,16.000, °C
IDE01028-MAS01423,Air temperature of H-V / hybrid battery-Exhaust,16.000, °C
IDE01036-MAS01375,High voltage / Hybrid Battery history data 1-Counter for amp hour charge,342.202, Ah
IDE01036-MAS01376,High voltage / Hybrid Battery history data 1-Counter for amp hour discharge,-233.457, Ah
IDE01036-MAS01377,High voltage / Hybrid Battery history data 1-Counter for kilowatt hour charge,137.779, kWh
IDE01036-MAS01378,High voltage / Hybrid Battery history data 1-Counter for kilowatt hour discharge,-91.008, kWh
IDE01718,Crash signal,not active,
IDE01803,History data 17,||00 88|00 00|00 00|00 03|00 00|00 00|,
IDE01803,History data 17,0,
IDE01804,History data 18,||00 00 F9 0A|00 00 64 FF|00 03 89 CD|00 01 5F 4B|00 04 32 05|00 01 AE A8|00 00 09 55|00 00 03 AB|00 00 00 02|00 00 00 00|,
IDE01804,History data 18,0,
IDE01805,History data 19,7,
IDE01805,History data 19,||00 10 34 BB|00 0F EB F2|00 00 23 83|00 00 12 6B|00 00 00 06|00 00 11 DD|00 00 00 F8|,
IDE01806,History data 20,7,
IDE01806,History data 20,||00 BF 24 E0|00 BB 69 6B|00 01 CB 88|00 00 E9 3D|00 00 00 64|00 00 F4 E2|00 00 11 6A|,
IDE01807,History data 21,00 00,
IDE01807,History data 21,00,
IDE01807,History data 21,FF,
IDE01808,History data 22,FF,
IDE01808,History data 22,C8,
IDE01809,History data 23,00,
IDE01809,History data 23,00 00,
IDE01809,History data 23,00 00 00 00,
IDE01810,History data 24,00 00,
IDE01810,History data 24,00,
IDE01810,History data 24,00 00 00 00,
IDE01811,History data 25,||00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 0B|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 09|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|,
IDE01811,History data 25,0,
IDE01812,History data 26,64,
IDE01812,History data 26,8,
IDE01812,History data 26,||00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 01|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 09 54|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|,
IDE01813,History data 27,||00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 09 55|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|,
IDE01813,History data 27,0,
IDE01814,History data 28,00 00 00 07,
IDE01814,History data 28,05,
IDE01814,History data 28,00 00 00 00,
IDE01814,History data 28,64,
IDE01814,History data 28,00 00 00 9B,
IDE01814,History data 28,00,
IDE01814,History data 28,03,
IDE01814,History data 28,6B,
IDE01814,History data 28,65,
IDE01814,History data 28,04,
IDE01814,History data 28,14,
IDE01814,History data 28,98,
IDE01814,History data 28,63,
IDE01814,History data 28,66,
IDE01814,History data 28,00 40 E0 79,
IDE01814,History data 28,50,
IDE01814,History data 28,6A,
IDE01814,History data 28,71,
IDE01814,History data 28,67,
IDE01814,History data 28,00 9E 5F 09,
IDE01814,History data 28,00 8F EB 9E,
IDE01814,History data 28,75,
IDE01814,History data 28,70,
IDE01814,History data 28,72,
IDE01814,History data 28,00 00 00 CC,
IDE01814,History data 28,7F,
IDE01814,History data 28,9B,
IDE01814,History data 28,68,
IDE01814,History data 28,6D,
IDE01814,History data 28,6E,
IDE01814,History data 28,6C,
IDE01814,History data 28,76,
IDE01814,History data 28,00 00 00 11,
IDE01814,History data 28,6F,
IDE01814,History data 28,00 00 3A 63,
IDE01838,Battery temperature,13.500, °C
IDE01839,Battery charge level,74.800, %
IDE01985-MAS06855,FAZIT identification test sum-Test sum,37 36 40 0F,
IDE03410-MAS05695,Yellow warning lamp-Start request,not active,
IDE03411-MAS05695,Red warning lamp-Start request,not active,
IDE05416,H-V battery insulation measurement test voltage,500, V
IDE05417,Serial number of H-V / hybrid battery,288 VWHT4BI034X,
IDE05545,Battery disconnect relay actuation,closed,
IDE05963,ASSY part number,1EB915914DJ ,
IDE06346,H-V battery voltage,412.000, V
IDE06404,Pilot line,not active,
IDE06673,Initialization status,not active,
IDE06805,Status of voltage freedom,High voltage power off not recognized,
IDE06948,High-volt. battery mode: spec. value,Driving mode,
IDE06973,Power reduction status,not active,
IDE07045-MAS01420,Dynamic limit for charge current-Limit for charge current,379.000, A
IDE07145-MAS06773,Component protection properties-KS Standard software main version nummer,03,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,05,
IDE07145-MAS06785,Component protection properties-GFA key,Not Used,
IDE07145-MAS06789,Component protection properties-KSB Config Status 2,00,
IDE07227-IDE01024,Voltage in H-V system-Voltage of hybrid battery after protection,411.500, V
IDE08215,Current 2 of H-V / hybrid battery,-1.490, A
IDE08217-MAS01234,maximum voltage for battery cells-Index 1,2,
IDE08217-MAS02985,maximum voltage for battery cells-Value,3.964, V
IDE08218-MAS01234,minimum voltage for battery cells-Index 1,7,
IDE08218-MAS02985,minimum voltage for battery cells-Value,3.959, V
IDE08228,Positive voltage of high volt battery after load protection,-0.031, V
IDE08230-MAS01421,Dynamic limit for discharge current-Limit for discharge current,900.000, A
IDE08343,Immobilizer Challenge,A8 44 DF F3,
IDE09588-ENG106773,In use monitor performance ratio 1-General_Denominator,0,
IDE09588-ENG106916,In use monitor performance ratio 1-Ignition_Cycle_Counter,142,
IDE09588-ENG100120,In use monitor performance ratio 1-Milage,200, km
IDE09588-ENG128699,In use monitor performance ratio 1-Number_of_IUMPR_Records,5,
IDE09589-ENG128703,In use monitor performance ratio 2-Denominator_to_DFCC_ID2_2,0,
IDE09589-ENG128701,In use monitor performance ratio 2-DFCC_Value_to_Record_ID2_1,42039,
IDE09589-ENG128702,In use monitor performance ratio 2-Numerator_to_DFCC_ID2_2,142,
IDE09589-ENG128700,In use monitor performance ratio 2-Recordnumber_uneven,1,
IDE09590-ENG128707,In use monitor performance ratio 3-Denominator_to_DFCC_ID3_2,0,
IDE09590-ENG128705,In use monitor performance ratio 3-DFCC_value_of_record_ID_3_2,42050,
IDE09590-ENG128706,In use monitor performance ratio 3-Numerator_to_DFCC_ID3_2,142,
IDE09590-ENG128704,In use monitor performance ratio 3-Recordnumber_even,2,
IDE11799,Minimum discharge voltage,260, V
IDE11801,Maximum charging voltage,442, V
IDE14477,Traction battery: China serial number,ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ,
IDE15098-MAS00106,Time stamp of last DTC memory entry deletion trigger-Year,2000,
IDE15098-MAS00107,Time stamp of last DTC memory entry deletion trigger-Month,0,
IDE15098-MAS00108,Time stamp of last DTC memory entry deletion trigger-Day,0,
IDE16765-MAS22458,Counter for falling below the insulation thresholds-Counter for positive terminal threshold 1,0,
IDE16765-MAS22474,Counter for falling below the insulation thresholds-Counter for negative terminal threshold 1,0,
IDE16765-MAS22475,Counter for falling below the insulation thresholds-Counter for negative terminal threshold 2,0,
IDE16765-MAS22476,Counter for falling below the insulation thresholds-Counter for positive terminal threshold 2,0,
IDE20040,High-voltage battery usable percentage of certified energy capacity,100.000, %
IDE80252,History data 0,HDM070706****,
IDE80253,Voltage terminal 30C,13.920, V
MAS00464-MAS00110,Standard - ambient data 1-Minutes,34,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,59,
MAS01302,Protection of posit. terminal of high voltage / hybrid battery,closed,
MAS01303,Protection of neg. terminal of high voltage / hybrid battery,closed,
MAS01481,Temperature in control module,29, °C
MAS01634,Supply voltage,14.800, V
MAS02194,Temperature 1,24, °C
MAS02195,Temperature 2,25, °C
MAS02199-MAS01966,Lowest measured temperature-Temperature sensor,5,
MAS02199-MAS02985,Lowest measured temperature-Value,13.750, °C
MAS02200-MAS01966,Highest measured temperature-Temperature sensor,4,
MAS02200-MAS02985,Highest measured temperature-Value,14.750, °C
MAS04266,Temperature sensor 1,14.000, °C
MAS04267,Temperature sensor 2,14.375, °C
MAS04268,Temperature sensor 3,14.000, °C
MAS04269,Temperature sensor 4,14.625, °C
MAS04270,Temperature sensor 5,13.875, °C
MAS04271,Temperature sensor 6,14.125, °C
MAS04272,Temperature sensor 7,14.125, °C
MAS04273,Temperature sensor 8,14.625, °C
MAS04291,Positive voltage of high volt battery after protection,411.938, V
MAS04293-MAS01632,Entire HV system positive terminal insulation resistance-Status,valid,
MAS04293,Entire HV system positive terminal insulation resistance,4310, kOhm
MAS04294-MAS01632,HV battery positive terminal insulation resistance-Status,invalid,
MAS04294,HV battery positive terminal insulation resistance,10000, kOhm
MAS04295-MAS01632,Entire HV system minus terminal insulation resistance-Status,valid,
MAS04295,Entire HV system minus terminal insulation resistance,4270, kOhm
MAS04296-MAS01632,HV battery minus terminal insulation resistance-Status,invalid,
MAS04296,HV battery minus terminal insulation resistance,10000, kOhm
MAS04649,Cell 1,3.963, V
MAS04650,Cell 2,3.964, V
MAS04651,Cell 3,3.963, V
MAS04652,Cell 4,3.963, V
MAS04653,Cell 5,3.964, V
MAS04654,Cell 6,3.964, V
MAS04655,Cell 7,3.959, V
MAS04656,Cell 8,3.963, V
MAS04657,Cell 9,3.963, V
MAS04658,Cell 10,3.962, V
MAS04659,Cell 11,3.963, V
MAS04660,Cell 12,3.962, V
MAS04661,Cell 13,3.963, V
MAS04662,Cell 14,3.963, V
MAS04663,Cell 15,3.963, V
MAS04664,Cell 16,3.963, V
MAS04665,Cell 17,3.964, V
MAS04666,Cell 18,3.963, V
MAS04667,Cell 19,3.962, V
MAS04668,Cell 20,3.962, V
MAS04669,Cell 21,3.962, V
MAS04670,Cell 22,3.962, V
MAS04671,Cell 23,3.963, V
MAS04672,Cell 24,3.963, V
MAS04673,Cell 25,3.963, V
MAS04674,Cell 26,3.962, V
MAS04675,Cell 27,3.962, V
MAS04676,Cell 28,3.963, V
MAS04677,Cell 29,3.964, V
MAS04678,Cell 30,3.963, V
MAS04679,Cell 31,3.963, V
MAS04680,Cell 32,3.962, V
MAS04681,Cell 33,3.963, V
MAS04682,Cell 34,3.963, V
MAS04683,Cell 35,3.963, V
MAS04684,Cell 36,3.963, V
MAS04685,Cell 37,3.963, V
MAS04686,Cell 38,3.963, V
MAS04687,Cell 39,3.963, V
MAS04688,Cell 41,3.962, V
MAS04689,Cell 42,3.964, V
MAS04690,Cell 43,3.964, V
MAS04691,Cell 44,3.963, V
MAS04692,Cell 45,3.963, V
MAS04693,Cell 46,3.963, V
MAS04694,Cell 47,3.963, V
MAS04695,Cell 48,3.962, V
MAS04696,Cell 49,3.963, V
MAS04697,Cell 50,3.963, V
MAS04698,Cell 51,3.964, V
MAS04699,Cell 52,3.963, V
MAS04700,Cell 53,3.962, V
MAS04701,Cell 54,3.964, V
MAS04702,Cell 55,3.963, V
MAS04703,Cell 56,3.963, V
MAS04704,Cell 57,3.962, V
MAS04705,Cell 58,3.962, V
MAS04706,Cell 59,3.962, V
MAS04707,Cell 60,3.962, V
MAS04708,Cell 61,3.962, V
MAS04709,Cell 62,3.963, V
MAS04710,Cell 63,3.962, V
MAS04711,Cell 64,3.962, V
MAS04712,Cell 65,3.963, V
MAS04713,Cell 66,3.964, V
MAS04714,Cell 67,3.963, V
MAS04715,Cell 68,3.963, V
MAS04716,Cell 69,3.964, V
MAS04717,Cell 70,3.963, V
MAS04718,Cell 71,3.964, V
MAS04719,Cell 72,3.964, V
MAS04720,Cell 40,3.963, V
MAS04721-MAS01234,Minimum charge level-Index 1,7,
MAS04721-MAS02985,Minimum charge level-Value,74.440, %
MAS04722-MAS01234,Maximum charge level-Index 1,42,
MAS04722-MAS02985,Maximum charge level-Value,75.040, %
MAS06746,Temperature sensor 9,13.875, °C
MAS06747,Temperature sensor 10,14.000, °C
MAS06748,Temperature sensor 11,14.000, °C
MAS06749,Temperature sensor 12,14.500, °C
MAS06750,Temperature sensor 13,13.750, °C
MAS06751,Temperature sensor 14,13.750, °C
MAS06752,Temperature sensor 15,14.000, °C
MAS06753,Temperature sensor 16,14.500, °C
MAS06754,Positive voltage of high volt battery before protection,412.063, V
MAS06761,Sum of voltage of all battery cells,412.187, V
MAS07429,Status loader positive terminal,Open,
MAS07430,Status loader negative terminal,Open,
MAS07735,Cell 73,3.964, V
MAS07736,Cell 74,3.962, V
MAS07737,Cell 75,3.963, V
MAS07738,Cell 76,3.963, V
MAS07739,Cell 77,3.963, V
MAS07740,Cell 78,3.964, V
MAS07741,Cell 79,3.964, V
MAS07742,Cell 80,3.963, V
MAS07743,Cell 81,3.964, V
MAS07744,Cell 82,3.964, V
MAS07745,Cell 83,3.964, V
MAS07746,Cell 84,3.964, V
MAS07747,Cell 85,3.963, V
MAS07748,Cell 86,3.964, V
MAS07749,Cell 87,3.963, V
MAS07750,Cell 88,3.963, V
MAS07751,Cell 89,3.964, V
MAS07752,Cell 90,3.964, V
MAS07753,Cell 91,3.964, V
MAS07754,Cell 92,3.964, V
MAS07755,Cell 93,3.964, V
MAS07756,Cell 94,3.963, V
MAS07757,Cell 95,3.964, V
MAS07758,Cell 96,3.964, V
MAS07759,Cell 97,3.964, V
MAS07760,Cell 98,3.964, V
MAS07761,Cell 99,3.963, V
MAS07762,Cell 100,3.963, V
MAS07763,Cell 101,3.964, V
MAS07764,Cell 102,3.963, V
MAS07765,Cell 103,3.964, V
MAS07766,Cell 104,3.964, V
MAS07767,Cell 105,Initialization,
MAS07768,Cell 106,Initialization,
MAS07769,Cell 107,Initialization,
MAS07770,Cell 108,Initialization,
MAS07773,Temperature sensor 17,13.750, °C
MAS07774,Temperature sensor 18,14.000, °C
MAS07775,Temperature sensor 19,14.000, °C
MAS07776,Temperature sensor 20,14.375, °C
MAS07777,Temperature sensor 21,13.750, °C
MAS07778,Temperature sensor 22,14.000, °C
MAS07779,Temperature sensor 23,14.000, °C
MAS07780,Temperature sensor 24,14.375, °C
MAS07781,Temperature sensor 25,13.875, °C
MAS07782,Temperature sensor 26,14.125, °C
MAS07792,Expanded battery limits,not active,
MAS07804,Pump for HV battery coolant: specified speed value,0, %
MAS07815,Cooling status BMS,Settled_low_load,
MAS07823,Current: PTC heater HV batt.,0.000, A
MAS07826,Request emergency discharge HV intermittent circuit condenser,not active,
MAS07827,Mode HV battery actual value,Driving mode,
MAS09283,HV interlock detector voltage,0.858, V
MAS09284,HV interlock source voltage,0.872, V
MAS09285,HV interlock detector current,10.975, mA
MAS09286,HV interlock source current,11.112, mA
MAS24224,Developer messages,00,
MAS24224,Developer messages,01,
MAS24224,Developer messages,CC,
MAS24224,Developer messages,BB,
MAS24224,Developer messages,06,
MAS24224,Developer messages,AA,
MAS24224,Developer messages,DD,
MAS24224,Developer messages,0A,
MAS24224,Developer messages,13,
MAS24224,Developer messages,07,
MAS24224,Developer messages,02,
MAS28019,High-voltage battery self-discharge status,||62|FA|01|03|00|7D|63|02|00|A1|2E|22|00|00|00|00|39|3B|3F|2F|00|00|18|13|00|00|18|13|00|00|17|BC|00|00|17|66|00|00|0D|AB|00|00|11|0B|00|00|0F|B1|00|00|0F|B1|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|39|39|39|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|3B|3B|3B|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|3F|3F|3F|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|2F|2F|2F|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|1E|2C|1E|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|20|,
Elapsed Time: 01:06
Jef
HQ
blockmap-A5-1EA-980-653-E_WVG5WVEB2SH017765-20250325-1235.CSV
;SW:1EA-980-653-E   HW:1EA-980-653-A ---  Frt Sens. Drv. Assist
;Component:MEB MFK 4.1   H08 5556, Coding:010A302E1F4500F83724301C4000000000000000000000000000000000000000
;EV_MFK41ValeoMEB,001080,EV_MFK41ValeoMEB_VWE3.rod
;Tuesday,25,March,2025,12:35:48:58926
;VCDS Version: Release 25.3.0 (x64)  Data version: 20250311 DS365.0
;VCID: 3B2859FA23EBC2329A4-806E-R SFD+SFD2
Group,Description,Actual
IDE00019,Voltage terminal 30,14.90, V
IDE00030-ENG261886,Status of actuator test-State_of_output_control,not active,
IDE00767,No. of unscheduled ECU resets,7,
IDE00973,Outside temperature,21.00, °C
IDE01968,Dynamic calibration: yaw angle offset,-0.0390, °
IDE01969,Dynamic calibration: pitch angle offset,0.1570, °
IDE01970,Dynamic calibration: roll angle offset,-0.1200, °
IDE01971,Lowest recorded control module temperature,-1, °C
IDE01972,Highest recorded control module temperature,83, °C
IDE01974-MAS01167,Steering wheel vibration-Actuation time,Unknown (0)
IDE01974-MAS08863,Steering wheel vibration-Status of actuator test,Output diagnostic test not active,
IDE01985-MAS06854,FAZIT identification test sum-Version,129,
IDE01985-MAS06855,FAZIT identification test sum-Test sum,3748067611,
IDE02007-MAS01167,Yellow indicator light for directional stabilization assistance-Actuation time,Unknown (0)
IDE02007-MAS08863,Yellow indicator light for directional stabilization assistance-Status of actuator test,Output diagnostic test not active,
IDE02008-MAS01167,Green indicator light for directional stabilization assistance-Actuation time,Unknown (0)
IDE02008-MAS08863,Green indicator light for directional stabilization assistance-Status of actuator test,Output diagnostic test not active,
IDE02009-MAS01167,Directional stabilization assistance display-Actuation time,Unknown (0)
IDE02009-MAS08863,Directional stabilization assistance display-Status of actuator test,Output diagnostic test not active,
IDE02057,Dynamic calibration: status,Passive values stored,
IDE02608-MAS01167,Window defogger for front sensor system-Actuation time,0 s,
IDE02608-MAS08863,Window defogger for front sensor system-Status of actuator test,Output diagnostic test not active,
IDE03222-MAS02534,Blindness detection-Clear view,Yes,
IDE03222-MAS03365,Blindness detection-Blind vehicle detection during darkness,No,
IDE03222-MAS03366,Blindness detection-Blind traffic sign detection,No,
IDE03222-MAS09886,Blindness detection-Blind during pedestrian recognition,No,
IDE03222-MAS09887,Blindness detection-Blind during object recognition,No,
IDE03222-MAS09888,Blindness detection-Blind during lane recognition,No,
IDE03222-MAS10690,Blindness detection-Activation condition,activated,
IDE03222-MAS11902,Blindness detection-Blind DTC memory entry,No,
IDE03222-MAS17450,Blindness detection-Blindness: space detection,No,
IDE03222-MAS17452,Blindness detection-Windshield heater blindness request,No,
IDE03222-MAS17453,Blindness detection-Clear view currently detected,No,
IDE03354-MAS01632,Dynamic calibration: details-Status,No calibration relevant malfunction,
IDE03354-MAS02552,Dynamic calibration: details-Distance traveled with active dynamic calibration,49, km
IDE04227,Directional stab. asst w/ pwr steering asst: steering status,Lane assist deactivated in steering,
IDE04229,Directional stab. asst w/ pwr steering asst: steering torque,-0.0000, Nm
IDE04904-MAS01167,Traffic sign display in instrument cluster-Actuation time,Unknown (0)
IDE04904-MAS08863,Traffic sign display in instrument cluster-Status of actuator test,Output diagnostic test not active,
IDE07145-MAS06772,Component protection properties-Component protection generation,2,
IDE07145-MAS06773,Component protection properties-KS Standard software main version nummer,3,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,8,
IDE07145-MAS06775,Component protection properties-KS Standard software correct number,1,
IDE07145-MAS07187,Component protection properties-KS Data version,1,
IDE07145-MAS18014,Component protection properties-Supported SHE download versions,NOT-DEFINED,
IDE07214,Dynamic calibration: camera height offset,-37, mm
IDE07543,Vehicle speed,0.000, km/h
IDE09492-MAS11790,Temperatures-Control Module temperature,72, °C
IDE09492-MAS17447,Temperatures-Temperature of the EyeQ chip,76, °C
IDE09492-MAS17448,Temperatures-Temperature of the memory in the EyeQ chip,73, °C
IDE09492-MAS17449,Temperatures-High temperature shutdown,OFF,
IDE10220,Initial online calibration active,not active,
IDE10300,OBD Driving Cycle detected,active,
IDE10403,Current initial calibration: status,Initial static calibration EOL OK.,
IDE10404-MAS10704,Dynamic calibration: quality-Dynamic calibration: yaw angle offset quality,0.00000,
IDE10404-MAS10705,Dynamic calibration: quality-Dynamic calibration: pitch angle offset quality,0.00000,
IDE10404-MAS10706,Dynamic calibration: quality-Dynamic calibration: roll angle offset quality,0.00000,
IDE10404-MAS10707,Dynamic calibration: quality-Dynamic calibration: camera height offset quality,0.00000,
IDE10405-MAS10708,Initial dynamic calibration: details-Initial dynamic calibration: roll angle,0.0000, °
IDE10405-MAS10709,Initial dynamic calibration: details-Initial dynamic calibration: roll angle quality,0.00000,
IDE10405-MAS10710,Initial dynamic calibration: details-Initial dynamic calibration: pitch angle,0.0000, °
IDE10405-MAS10711,Initial dynamic calibration: details-Initial dynamic calibration: pitch angle quality,0.00000,
IDE10405-MAS10712,Initial dynamic calibration: details-Initial dynamic calibration: yaw angle,0.0000, °
IDE10405-MAS10713,Initial dynamic calibration: details-Initial dynamic calibration: yaw angle quality,0.00000,
IDE10405-MAS10714,Initial dynamic calibration: details-Initial dynamic calibration: Camera height,1200, mm
IDE10405-MAS10715,Initial dynamic calibration: details-Initial dynamic calibration: Camera height quality,0.00000,
IDE10405-MAS10716,Initial dynamic calibration: details-Distance traveled with active initial calibration,0, m
IDE10406-MAS00106,Last initial calibrations: details-Year,24,
IDE10406-MAS00107,Last initial calibrations: details-Month,11,
IDE10406-MAS00108,Last initial calibrations: details-Day,22,
IDE10406-MAS00109,Last initial calibrations: details-Hours,15,
IDE10406-MAS00110,Last initial calibrations: details-Minutes,7,
IDE10406-MAS00111,Last initial calibrations: details-Seconds,7,
IDE10406-MAS10994,Last initial calibrations: details-Last initial calibration: error code,No calibration relevant malfunction,
IDE10547,Status of camera,Camera operating,
IDE10664-MAS00106,Current initial calibration: details-Year,24,
IDE10664-MAS00107,Current initial calibration: details-Month,11,
IDE10664-MAS00108,Current initial calibration: details-Day,22,
IDE10664-MAS00109,Current initial calibration: details-Hours,15,
IDE10664-MAS00110,Current initial calibration: details-Minutes,7,
IDE10664-MAS00111,Current initial calibration: details-Seconds,7,
IDE10664-MAS00711,Current initial calibration: details-Odometer reading,0,
IDE10664-MAS01632,Current initial calibration: details-Status,No calibration relevant malfunction,
IDE10664-MAS02541,Current initial calibration: details-Rear projection fault,0,
IDE10664-MAS02542,Current initial calibration: details-Calibration marks,00111111 ,
IDE10664-MAS02543,Current initial calibration: details-VIN determined during calibration,WVG5WVEB2SH017765,
IDE10664,Current initial calibration: details,00110011 ,
IDE10664,Current initial calibration: details,00111111 ,
IDE10780,Ethernet counter connection interruptions,0,
IDE10781,Ethernet counter checksum malfunction,0,
IDE10924-MAS02479,Initial calibration: result-Yaw angle,0.6540, °
IDE10924-MAS05286,Initial calibration: result-Roll angle,-0.0100, °
IDE10924-MAS05287,Initial calibration: result-Pitch angle,-0.9360, °
IDE10924-MAS10678,Initial calibration: result-Camera height,1286, mm
IDE11752-IDE09469,IP network: IPv6-addresses-IPv6 address,|IPv6 address|FD 53 7C B8 03 83 00 02 00 00 00 00 00 00 00 4F|,
IDE11753-MAS14855,IP network: IPv6-multicast-addresses-IPv6 Multicast address,|IPv6 Multicast address|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 5B|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 02|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0B|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 18|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 61|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 09|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 21|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 19|FF 02 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 05|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 2E|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 FE|,
IDE11755-MAS14856,IP network: VLANs-VLAN,|VLAN|2|,
IDE11757,IP network: counter messages with inadmissible IPv6-addresses,7657,
IDE11760,IP network: counter messages with inadmissible UDP ports,6,
IDE11761-IDE09467,IP network: MAC addresses-MAC address,|MAC address|74 90 50 00 00 00|,
IDE11988-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 1-MAC address,|MAC address|74 90 50 00 00 00|,
IDE12230-ENG277505,IP network: VLANs of Ethernet switch ports branch 1-Ip_vlans_list,|VLAN|2|0|0|0|0|0|0|0|0|0|,
IDE12238,I network: discarded messages counter,7667,
IDE12239,IP network: test feedback value of communications relationships,|IPv6 address,Result|FD 53 7C B8 03 83 00 02 00 00 00 00 00 00 00 10
IDE12625,IP network: current link deceleration: branch 1,0, µs
IDE12633,IP Network maximum correction of the synchronized clock,0, µs
IDE13845,Production mode status,not active,
IDE13994-MAS17458,Intrinsic calibration: result-Main point x,644.09, px
IDE13994-MAS17463,Intrinsic calibration: result-Main point y,538.05,
IDE13994-MAS17464,Intrinsic calibration: result-Focal length x,1460.24, px
IDE13994-MAS17465,Intrinsic calibration: result-Focal length y,1460.24, px
IDE13994-MAS17466,Intrinsic calibration: result-Distortion in k1,-0.0004688910,
IDE13994-MAS17467,Intrinsic calibration: result-Distortion in k2,-0.0003636790,
IDE13994-MAS17468,Intrinsic calibration: result-Distortion in k3,-0.0006388480,
IDE13994-MAS17469,Intrinsic calibration: result-Distortion in t1,-0.0000000000,
IDE13994-MAS17470,Intrinsic calibration: result-Distortion in t2,-0.0000000000,
IDE13994-MAS17471,Intrinsic calibration: result-Gamma,1.0000,
IDE13994-MAS17472,Intrinsic calibration: result-Incline,0.00, px
IDE13995-MAS08824,Calibration target position: stored values-Target 1: calibration mark 1: x-coordinate,2400.0000, mm
IDE13995-MAS08825,Calibration target position: stored values-Target 1: calibration mark 1: y-coordinate,642.5000, mm
IDE13995-MAS08826,Calibration target position: stored values-Target 1: calibration mark 1: z-coordinate,1456.0000, mm
IDE13995-MAS08827,Calibration target position: stored values-Target 1: calibration mark 2: x-coordinate,2400.0000, mm
IDE13995-MAS08828,Calibration target position: stored values-Target 1: calibration mark 2: y-coordinate,-642.5000, mm
IDE13995-MAS08829,Calibration target position: stored values-Target 1: calibration mark 2: z-coordinate,1456.0000, mm
IDE13995-MAS08830,Calibration target position: stored values-Target 1: calibration mark 3: x-coordinate,2400.0000, mm
IDE13995-MAS08831,Calibration target position: stored values-Target 1: calibration mark 3: y-coordinate,642.5000, mm
IDE13995-MAS08832,Calibration target position: stored values-Target 1: calibration mark 3: z-coordinate,944.0000, mm
IDE13995-MAS08833,Calibration target position: stored values-Target 1: calibration mark 4: x-coordinate,2400.0000, mm
IDE13995-MAS08834,Calibration target position: stored values-Target 1: calibration mark 4: y-coordinate,-642.5000, mm
IDE13995-MAS08835,Calibration target position: stored values-Target 1: calibration mark 4: z-coordinate,944.0000, mm
IDE13996-IDE05717,Axle offset: stored values-Front axle transverse position,-0.10, mm
IDE13996-IDE05718,Axle offset: stored values-Rear axle transverse position,4.70, mm
IDE13997-IDE02001,Body height to wheel house edge: stored values-Body height left front wheel house edge,808.000, mm
IDE13997-IDE02002,Body height to wheel house edge: stored values-Body height right front wheel house edge,807.000, mm
IDE13997-IDE02003,Body height to wheel house edge: stored values-Body height left rear wheel house edge,807.000, mm
IDE13997-IDE02004,Body height to wheel house edge: stored values-Body height right rear wheel house edge,806.000, mm
IDE13998,Distance to calibration field: stored values,1500.000, mm
IDE14000,Windshield defogger camera: activation status,OFF,
IDE17075-ENG298547,Functions that can be enabled: FoD slave enhanced status-Extended_state_payload,00 01 00 D6 02 03 00 02 00 00 03 03 00 00 00 00 00 00 00 4C 00 00 00 00 03 00 00 00 0A 00 00 00 00 00 00 75 30 00 05 7E 40 00 00 03 E8 00 0A 06 14 22 00 00 00,
IDE17075-ENG298612,Functions that can be enabled: FoD slave enhanced status-Payload_length,53,
IDE17075-ENG99027,Functions that can be enabled: FoD slave enhanced status-Version,11,
MAS01634-MAS09193,Supply voltage-PLA,14.9, V
MAS01634-MAS17440,Supply voltage-Supply voltage 1V0,1.0, V
MAS01634-MAS17441,Supply voltage-Supply voltage 1V1,1.1, V
MAS01634-MAS17442,Supply voltage-Supply voltage 1V2,0.0, V
MAS01634-MAS17443,Supply voltage-Supply voltage 1V25,1.2, V
MAS01634-MAS17444,Supply voltage-Supply voltage 1V8,1.8, V
MAS01634-MAS17445,Supply voltage-Supply voltage 3V3,3.2, V
MAS01634-MAS17446,Supply voltage-Supply voltage 5V0,5.0, V
MAS11502-MAS10691,Self-glare recognition-Self-glare quality,0, %
MAS11502-MAS11503,Self-glare recognition-Self-glare status,active,
MAS11502-MAS15965,Self-glare recognition-Glare detected,No,
MAS17268,Functions which can be activated: connection error counter,0,
MAS17473,Functional state and lane boundary information,0,
MAS17521-IDE04332,Unlockable functions: activation status-Release code for a SWaP function,Available,
MAS17521-IDE05814,Unlockable functions: activation status-Individualization characteristic,invalid,
MAS17521-IDE06260,Unlockable functions: activation status-ID number,10 0E 0F 00,
MAS17521-MAS01340,Unlockable functions: activation status-Functions,Available,
MAS17521-MAS01903,Unlockable functions: activation status-Configuration,OK,
MAS17521-MAS02934,Unlockable functions: activation status-Preconditions met,Condition not met,
MAS17521-MAS05616,Unlockable functions: activation status-Cancellation,No,
MAS17521-MAS05617,Unlockable functions: activation status-Authentication,Condition met,
MAS17521-MAS17839,Unlockable functions: activation status-Number of functions which can be activated,5,
MAS17521-MAS17983,Unlockable functions: activation status-Last state,not active,
MAS22239-ENG299116,Trained parking: prevention reasons (ring memory)-TPA_storing_prevention_ring_buffer,|Year,Month
MAS22249,Recorded distance: actual,0.00, m
MAS22250-MAS22346,Trained parking: card memory-Memory block 1 and 2,        ,
MAS22250-MAS22347,Trained parking: card memory-Memory block 5 and 6,        ,
MAS22250-MAS22348,Trained parking: card memory-Memory block 7 and 8,        ,
MAS22250-MAS22352,Trained parking: card memory-Memory block 3 and 4,        ,
MAS22250-MAS22354,Trained parking: card memory-Memory block 9 and 10,        ,
MAS22261,Trained parking: cause of error,no_error_detected,
ENG347809,Current_ELKS_Failure_State,ELKS_no_Failure,
ENG297739-MAS06855,Dataset_Patch-Test sum,15 C8 23 22,
ENG297739-MAS24941,Dataset_Patch-Internal dataset applied,not_applied,
ENG179581-ENG181012,FoD_slave_operating_state-FoD_slave_state,2,
ENG254718-MAS17839,Function_On_Demand_Unlock_ID_Status_Dev-Number of functions which can be activated,5,
ENG254718-MAS17983,Function_On_Demand_Unlock_ID_Status_Dev-Last state,not active,
ENG254718-ENG247044,Function_On_Demand_Unlock_ID_Status_Dev-Function_On_Demand_Freischalt_ID_Status,|ID number,Authentication
ENG370384-MAS00106,Programming_precondition_history-Year,0,
ENG370384-MAS00107,Programming_precondition_history-Month,0,
ENG370384-MAS00108,Programming_precondition_history-Day,0,
ENG370384-MAS00109,Programming_precondition_history-Hours,0,
ENG370384-MAS00110,Programming_precondition_history-Minutes,0,
ENG370384-MAS00111,Programming_precondition_history-Seconds,0,
ENG370384-ENG103063,Programming_precondition_history-Mileage,0,
ENG370384-ENG370522,Programming_precondition_history-Programming_precondition,unused,
ENG370384-ENG144705,Programming_precondition_history-Supply_voltage,0,
ENG370384-ENG119265,Programming_precondition_history-Velocity,Value,
ENG261867,Status_connection_to_mfk,inactive,
Elapsed Time: 00:55
blockmap-BE-1N3-959-244-B_WVG5WVEB2SH017765-20250325-1237.CSV
;SW:1N3-959-244-B   HW:1N3-959-244-B ---  Slid. Door Rear Left
;Component:Slidingdoor_d H04 0028, Coding:D600
;EV_SlideDoorDriveHufIDBuz,002110,EV_SlideDoorDriveHufIDBuz_002.rod
;Tuesday,25,March,2025,12:37:01:58926
;VCID: 353C4FC205CF14426C0-8060-R
IDE00019,Voltage terminal 30,14.70, V
IDE00029-IDE11960,Status of input signals 1-Fuel filler door positioner,Not operated,
IDE00029-MAS02032,Status of input signals 1-Front button for automatic sliding door,Not operated,
IDE00029-MAS02033,Status of input signals 1-Rear button for automatic sliding door,Not operated,
IDE00029-MAS02036,Status of input signals 1-Pinch protection sensor,Not operated,
IDE00029-MAS02103,Status of input signals 1-Signal from door lock: catch,operated,
IDE00029-MAS04194,Status of input signals 1-Driver side,Yes,
IDE00029-MAS04195,Status of input signals 1-Front passenger side,No,
IDE00029-ENG264512,Status of input signals 1-Deactivation_switch,Not operated,
IDE00056-ENG264528,History data 1-Fourth_revers_position,627,
IDE00056-ENG264529,History data 1-Fourth_revers_reason,19,
IDE00056-ENG264553,History data 1-Last_revers_position,691,
IDE00056-ENG264554,History data 1-Last_revers_reason,19,
IDE00056-ENG264654,History data 1-Second_revers_position,290,
IDE00056-ENG264655,History data 1-Second_revers_reason,18,
IDE00056-ENG264683,History data 1-Third_revers_position,177,
IDE00056-ENG264684,History data 1-Third_revers_reason,18,
IDE00057-IDE00056,History data 2-History data 1,6,
IDE00057-ENG264527,History data 2-Fourth_operator_unit,6,
IDE00057-ENG264653,History data 2-Second_operator_unit,6,
IDE00057-ENG264682,History data 2-Third_operator_unit,5,
IDE00058-ENG264530,History data 3-Fourth_stop_position,1052,
IDE00058-ENG264531,History data 3-Fourth_stop_reason,2,
IDE00058-ENG264555,History data 3-Last_stop_position,1,
IDE00058-ENG264556,History data 3-Last_stop_reason,3,
IDE00058-ENG264656,History data 3-Second_stop_position,1052,
IDE00058-ENG264657,History data 3-Second_stop_reason,2,
IDE00058-ENG264685,History data 3-Third_stop_position,0,
IDE00058-ENG264686,History data 3-Third_stop_reason,3,
IDE00320-MAS02111,Consistency of EEPROM data-Data consistency,Valid EEPROM Data,
IDE00320-MAS04299,Consistency of EEPROM data-Error during last data record download,No malfunction,
IDE00320-MAS04434,Consistency of EEPROM data-Data record modification,Data record not changed,
IDE00320-MAS06349,Consistency of EEPROM data-Dataset download possible,Not parameterizable,
IDE00330,Transverse slope,0, °
IDE00331,Longitudinal slope,0, °
IDE00609,Communication status of data bus 1,active,
IDE00767,No. of unscheduled ECU resets,5,
IDE02270-IDE00002,CAN input signal(s) status-Transport mode,not active,
IDE02270-IDE00020,CAN input signal(s) status-Terminal 15 status,On,
IDE02270-IDE01211,CAN input signal(s) status-Static current measuring mode,not active,
IDE02270-IDE01715,CAN input signal(s) status-Status terminal S,On,
IDE02270-IDE01716,CAN input signal(s) status-Terminal 50 status,OFF,
IDE02270-IDE01718,CAN input signal(s) status-Crash signal,No crash recognized,
IDE02270-IDE05713,CAN input signal(s) status-Network diagnosis,active,
IDE02270-IDE07856,CAN input signal(s) status-Terminal status,OFF,
IDE02270-IDE11279,CAN input signal(s) status-eCall operating state,not active,
IDE02270-MAS00215,CAN input signal(s) status-Fuel filler lid,Open,
IDE02270-MAS02034,CAN input signal(s) status-Installed on left side,Yes,
IDE02270-MAS02035,CAN input signal(s) status-Installed on right side,No,
IDE02270-MAS02097,CAN input signal(s) status-Window position,0.00, %
IDE02270-MAS02098,CAN input signal(s) status-Window regulator standardized,Yes,
IDE02270-MAS02099,CAN input signal(s) status-Switch for inside door handle,Not operated,
IDE02270-MAS02100,CAN input signal(s) status-Switch for outside door handle,Not operated,
IDE02270-MAS02101,CAN input signal(s) status-Child safety,Not operated,
IDE02270-MAS02102,CAN input signal(s) status-Signal from door lock: detent,Not operated,
IDE02270-MAS02103,CAN input signal(s) status-Signal from door lock: catch,Not operated,
IDE02270-MAS02104,CAN input signal(s) status-Door lock: safe,not active,
IDE02270-MAS02105,CAN input signal(s) status-Signal from door lock: engaged,not active,
IDE02270-MAS02106,CAN input signal(s) status-Request through vehicle key with remote control,Not operated,
IDE02270-MAS02108,CAN input signal(s) status-Signal vehicle speed (alt bit),not active,
IDE02270-MAS06524,CAN input signal(s) status-Status of closing assist,not active,
IDE02270-MAS07983,CAN input signal(s) status-Virtual pedal,Not operated,
IDE02270-MAS08781,CAN input signal(s) status-Connection state of charging plug,no plug detected,
IDE02270-MAS10510,CAN input signal(s) status-Kessy,not active,
IDE02270-MAS19085,CAN input signal(s) status-Tailgate position,closed,
IDE02270-MAS21240,CAN input signal(s) status-Network diagnostic approval: central activation,Network diagnostic approval: supported,
IDE02271-IDE18030,CAN output signal(s) status-Charging socket flap collision protection,Initialization,
IDE02271-MAS00478,CAN output signal(s) status-Reserved,-1,
IDE02271-MAS00542,CAN output signal(s) status-Indicator lamp for safety belt warning,Not operated,
IDE02271-MAS02036,CAN output signal(s) status-Pinch protection sensor,Not operated,
IDE02271-MAS02037,CAN output signal(s) status-Automatic sliding door moving: opening,not active,
IDE02271-MAS02038,CAN output signal(s) status-Automatic sliding door moving: closing,not active,
IDE02271-MAS02039,CAN output signal(s) status-Force limitation,Not operated,
IDE02271-MAS02502,CAN output signal(s) status-Customer service,No malfunction,
IDE02271-ENG264504,CAN output signal(s) status-Co_clamping_protection_seal_defect_IO,No malfunction,
IDE02272-MAS00976,Play protection: motor for automatic sliding door-Counter,0,
IDE02272-MAS02040,Play protection: motor for automatic sliding door-Anti-play protection,not active,
IDE02272-MAS02041,Play protection: motor for automatic sliding door-Activation limitation,180,
IDE02272-MAS02042,Play protection: motor for automatic sliding door-Deactivation limitation,120,
IDE02275-MAS01424,Position of automatic sliding door-max.value,04 61,
IDE02275-MAS01447,Position of automatic sliding door-Act.val.,00 00,
IDE02276,Number of driving cycles for automatic sliding door,65,
IDE02278-MAS02043,Status of output signals-Automatic sliding door acoustic,not active,
IDE02278-MAS02044,Status of output signals-Activation: motor for automatic sliding door,not activated,
IDE02278-MAS02045,Status of output signals-Motor activation for enabling ratchet release,not activated,
IDE02278-MAS02047,Status of output signals-Sliding door indicator lamp,not active,
IDE02278-MAS02048,Status of output signals-Sliding door indicator lamp 2,not active,
IDE02278-MAS09001,Status of output signals-Closing Assist Motor,not activated,
IDE02278-MAS21245,Status of output signals-Sliding door indicator lamp 3,not active,
IDE02278-MAS25771,Status of output signals-Activation of the automatic sliding door arrester,not activated,
IDE02486,Data logger triggering,not initialized,
IDE02578-MAS00976,Play protection status-Counter,0, °
IDE02578-MAS02040,Play protection status-Anti-play protection,not activated,
IDE02578-MAS02041,Play protection status-Activation limitation,200, °
IDE02578-MAS02042,Play protection status-Deactivation limitation,5,
IDE02856-MAS02283,Basic setting of opening width-Condition,calibrated,
IDE02856-MAS02402,Basic setting of opening width-Standardization value,1121,
IDE02856-MAS12981,Basic setting of opening width-Number of requested tests,1,
IDE02857-MAS02036,Activation current-Pinch protection sensor,6.90, V
IDE02857-MAS02044,Activation current-Activation: motor for automatic sliding door,0.00, A
IDE02857-MAS02045,Activation current-Motor activation for enabling ratchet release,0.00, A
IDE02857-MAS25778,Activation current-Door arrester: current consumption,0.00, A
IDE05999,Basic setting: position,00 00 00 01 45 88 03 00 00 02 04 1C 00 00 00 00 00 00 00 00 49 44 42 75 7A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE06001,Basic setting: maximum value during opening,00 00 00 01 45 88 03 00 00 02 04 1C 00 00 00 00 00 00 00 00 49 44 42 75 7A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE06002,Basic setting: current value during opening,00 00 00 01 45 88 03 00 00 02 04 1C 00 00 00 00 00 00 00 00 49 44 42 75 7A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE06003,Basic setting: maximum value during closing,00 00 00 01 45 88 03 00 00 02 04 1C 00 00 00 00 00 00 00 00 49 44 42 75 7A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE06004,Basic setting: current value during closing,00 00 00 01 45 88 03 00 00 02 04 1C 00 00 00 00 00 00 00 00 49 44 42 75 7A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE07543,Vehicle speed,0.00, km/h
IDE11036-MAS00976,Pull-shut asst.: play protec.-Counter,0, °
IDE11036-MAS02040,Pull-shut asst.: play protec.-Anti-play protection,not active,
IDE11036-MAS02041,Pull-shut asst.: play protec.-Activation limitation,63, °
IDE11036-MAS02042,Pull-shut asst.: play protec.-Deactivation limitation,42,
MAS00398-IDE00019,Read ambient data-Voltage terminal 30,14.7, V
MAS00398-IDE00330,Read ambient data-Transverse slope,0, °
MAS00398-IDE00331,Read ambient data-Longitudinal slope,0, °
MAS00398-IDE02272,Read ambient data-Play protection: motor for automatic sliding door,not active,
MAS00398-IDE02273,Read ambient data-Play protection: motor for enabling ratchet release,not active,
MAS00398-IDE02578,Read ambient data-Play protection status,not activated,
MAS00398-IDE10155,Read ambient data-Status door arrester,Open,
MAS00398-IDE17018,Read ambient data-Measured value container,No crash recognized,
MAS00398-MAS01424,Read ambient data-max.value,1121,
MAS00398-MAS01447,Read ambient data-Act.val.,0,
MAS00398-MAS02032,Read ambient data-Front button for automatic sliding door,Not operated,
MAS00398-MAS02033,Read ambient data-Rear button for automatic sliding door,Not operated,
MAS00398-MAS02036,Read ambient data-Pinch protection sensor,Not operated,
MAS00398-MAS02043,Read ambient data-Automatic sliding door acoustic,not active,
MAS00398-MAS02044,Read ambient data-Activation: motor for automatic sliding door,not active,
MAS00398-MAS02045,Read ambient data-Motor activation for enabling ratchet release,0.0, A
MAS00398-MAS02047,Read ambient data-Sliding door indicator lamp,not active,
MAS00398-MAS02048,Read ambient data-Sliding door indicator lamp 2,not active,
MAS00398-MAS02103,Read ambient data-Signal from door lock: catch,operated,
MAS00398-MAS02405,Read ambient data-Pre-engagement contact for rotary latch,Not operated,
MAS00398-MAS03403,Read ambient data-Parameter 3,closed,
MAS00398-MAS03548,Read ambient data-Motor current,0.0, A
MAS00398-MAS04194,Read ambient data-Driver side,Yes,
MAS00398-MAS04195,Read ambient data-Front passenger side,No,
MAS00398-MAS09001,Read ambient data-Closing Assist Motor,not active,
MAS00398-MAS21245,Read ambient data-Sliding door indicator lamp 3,not active,
MAS00398-MAS21251,Read ambient data-Pinch protection strip signal,6968,
MAS00398-MAS21252,Read ambient data-Sliding door position,Sliding door in main notch,
MAS00398-MAS25771,Read ambient data-Activation of the automatic sliding door arrester,not activated,
MAS00398-MAS25778,Read ambient data-Door arrester: current consumption,0.0, A
MAS00464-MAS00106,Standard - ambient data 1-Year,2025,
MAS00464-MAS00107,Standard - ambient data 1-Month,3,
MAS00464-MAS00108,Standard - ambient data 1-Day,25,
MAS00464-MAS00109,Standard - ambient data 1-Hours,16,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,37,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,8,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,2,
MAS00464-MAS00478,Standard - ambient data 1-Reserved,-1,
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,209, km
MAS04894-IDE00002,Operating mode-Transport mode,not active,
MAS04894-IDE01211,Operating mode-Static current measuring mode,not active,
MAS04894-IDE06000,Operating mode-Customer service mode,not active,
MAS04894-MAS01790,Operating mode-Crash recognized,not active,
MAS04894-MAS02034,Operating mode-Installed on left side,active,
MAS04894-MAS02035,Operating mode-Installed on right side,not active,
MAS04894-MAS09595,Operating mode-Production mode,not active,
MAS04894-MAS25777,Operating mode-Control module status: door arrester,activated,
MAS21249,Sliding door opening: reason for obstruction,0, °
MAS21250,Sliding door close: reason for obstruction,0, °
Elapsed Time: 00:07
blockmap-BF-1N3-959-244-B_WVG5WVEB2SH017765-20250325-1237.CSV
;SW:1N3-959-244-B   HW:1N3-959-244-B ---  Slid. Door Rear Right
;Component:Slidingdoor_p H04 0028, Coding:D600
;EV_SlideDoorPasseHufIDBuz,002110,EV_SlideDoorPasseHufIDBuz_002.rod
;Tuesday,25,March,2025,12:37:16:58926
IDE00029-MAS04194,Status of input signals 1-Driver side,No,
IDE00029-MAS04195,Status of input signals 1-Front passenger side,Yes,
IDE00056-ENG264528,History data 1-Fourth_revers_position,667,
IDE00056-ENG264553,History data 1-Last_revers_position,516,
IDE00056-ENG264554,History data 1-Last_revers_reason,27,
IDE00056-ENG264654,History data 1-Second_revers_position,650,
IDE00056-ENG264655,History data 1-Second_revers_reason,19,
IDE00056-ENG264683,History data 1-Third_revers_position,616,
IDE00056-ENG264684,History data 1-Third_revers_reason,19,
IDE00057-IDE00056,History data 2-History data 1,2,
IDE00057-ENG264527,History data 2-Fourth_operator_unit,4,
IDE00057-ENG264653,History data 2-Second_operator_unit,4,
IDE00057-ENG264682,History data 2-Third_operator_unit,6,
IDE00058-ENG264530,History data 3-Fourth_stop_position,1056,
IDE00058-ENG264555,History data 3-Last_stop_position,65531,
IDE00058-ENG264656,History data 3-Second_stop_position,1056,
IDE00058-ENG264685,History data 3-Third_stop_position,65532,
IDE00767,No. of unscheduled ECU resets,4,
IDE02270-IDE05713,CAN input signal(s) status-Network diagnosis,not active,
IDE02270-IDE11279,CAN input signal(s) status-eCall operating state,active,
IDE02270-MAS00215,CAN input signal(s) status-Fuel filler lid,closed,
IDE02270-MAS06524,CAN input signal(s) status-Status of closing assist,active,
IDE02271-IDE18030,CAN output signal(s) status-Charging socket flap collision protection,safe,
IDE02275-MAS01424,Position of automatic sliding door-max.value,04 65,
IDE02278-MAS02043,Status of output signals-Automatic sliding door acoustic,active,
IDE02278-MAS02047,Status of output signals-Sliding door indicator lamp,active,
IDE02278-MAS02048,Status of output signals-Sliding door indicator lamp 2,active,
IDE02278-MAS21245,Status of output signals-Sliding door indicator lamp 3,active,
IDE02856-MAS02402,Basic setting of opening width-Standardization value,1125,
IDE05999,Basic setting: position,00 00 00 01 45 88 03 FF FC 02 04 20 00 00 00 00 00 00 00 00 49 44 42 75 7A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE06001,Basic setting: maximum value during opening,00 00 00 01 45 88 03 FF FC 02 04 20 00 00 00 00 00 00 00 00 49 44 42 75 7A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE06002,Basic setting: current value during opening,00 00 00 01 45 88 03 FF FC 02 04 20 00 00 00 00 00 00 00 00 49 44 42 75 7A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE06003,Basic setting: maximum value during closing,00 00 00 01 45 88 03 FF FC 02 04 20 00 00 00 00 00 00 00 00 49 44 42 75 7A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE06004,Basic setting: current value during closing,00 00 00 01 45 88 03 FF FC 02 04 20 00 00 00 00 00 00 00 00 49 44 42 75 7A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
MAS00398-MAS01424,Read ambient data-max.value,1125,
MAS00398-MAS04194,Read ambient data-Driver side,No,
MAS00398-MAS04195,Read ambient data-Front passenger side,Yes,
MAS00398-MAS21251,Read ambient data-Pinch protection strip signal,6934,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,25,
MAS04894-MAS02034,Operating mode-Installed on left side,not active,
MAS04894-MAS02035,Operating mode-Installed on right side,active,
Elapsed Time: 00:08
blockmap-C0-1T3-035-335-A_WVG5WVEB2SH017765-20250325-1237.CSV
;SW:1T3-035-335-A   HW:1EA-035-335 ---  Act. for Ext. Noise
;Component:E_SOUND_SG    H06 0006, Coding:
;EV_ESounHarmaMEBUNECE,001006,EV_ESounHarmaMEBUNECE_VWE3.rod
;Tuesday,25,March,2025,12:37:33:58926
;VCID: 2C0A6AA6D685558A03E-8078-R
IDE00019,Voltage terminal 30,15.4, V
IDE00102-ENG127110,Control Module temperature-ecu_internal_temperature,29.0, °C
IDE00916-MAS09310,Speaker status-Channel 1,OK,
IDE12026-MAS01447,Status of charisma participant-Act.val.,0,
IDE12026-MAS01448,Status of charisma participant-Specified value,0,
IDE12026-MAS01632,Status of charisma participant-Status,0,
Elapsed Time: 00:00
blockmap-C6-1EK-915-692-J_WVG5WVEB2SH017765-20250325-1237.CSV
;SW:1EK-915-692-J   HW:1EK-915-692-H ---  Batt. Chrg.
;Component:OCDC Gen4+    H03 2207, Coding:308010
;EV_OCDCXPHASERB8MEBB,002001,EV_OCDCXPHASERB8MEBB_002_VWE3.rod
;Tuesday,25,March,2025,12:37:42:58926
;VCID: 4BC8093A734B72B22A4-801E-R SFD+SFD2
IDE00008,Software version,2207,
IDE00019,Voltage terminal 30,0.000, V
IDE00025,Coolant temperature,215, °C
IDE00085,Normed load value,100.0, %
IDE00086,Accelerator pedal position,14.5, %
IDE00601-MAS00317,Monitoring status since erasing DTC memory-Malfunction Indicator Lamp,OFF,
IDE00601-MAS00329,Monitoring status since erasing DTC memory-Monitoring of fuel system,not activated,
IDE00601-MAS00330,Monitoring status since erasing DTC memory-Overall system monitoring,activated,
IDE00601-MAS00332,Monitoring status since erasing DTC memory-Fuel system test,Unknown (2)
IDE00601-MAS00333,Monitoring status since erasing DTC memory-Overall system test,completed successfully,
IDE00601-MAS00503,Monitoring status since erasing DTC memory-Number of emission-relevant DTC memory entries,0,
IDE00601-MAS04092,Monitoring status since erasing DTC memory-Monitoring of compression ignition,Not supported,
IDE00601-MAS04097,Monitoring status since erasing DTC memory-Intermittent monitoring,not activated,
IDE00601-MAS04098,Monitoring status since erasing DTC memory-Status not contin. monitoring since erasing event memory,not activated,
IDE00601-ENG151554,Monitoring status since erasing DTC memory-Completion status of all supported non-continuous monitors since DTCs cleared,00,
IDE00602-MAS04092,Monitoring status in current driving cycle-Monitoring of compression ignition,Not supported,
IDE00602-MAS04139,Monitoring status in current driving cycle-Activation status of intermittent monitoring,not activated,
IDE00602-MAS04140,Monitoring status in current driving cycle-Implementation status of intermittent monitoring,not activated,
IDE00602-ENG151471,Monitoring status in current driving cycle-Completion status of all supported non-continuous monitors this monitoring cycle,Yes,
IDE00602-ENG151579,Monitoring status in current driving cycle-Comprehensive component monitoring completed,completed successfully,
IDE00602-ENG151519,Monitoring status in current driving cycle-Comprehensive component monitoring enabled,activated,
IDE00602-ENG151568,Monitoring status in current driving cycle-Fuel system monitoring completed,Unknown (2)
IDE00602-ENG151497,Monitoring status in current driving cycle-Fuel system monitoring enabled,not activated,
IDE07543,Vehicle speed,0, km/h
IDE08423-MAS02949,Control signal for power outlet A for battery charging-Frequency,1133, Hz
IDE08423-MAS02952,Control signal for power outlet A for battery charging-Control voltage,0.0, V
IDE08423-MAS03873,Control signal for power outlet A for battery charging-Duty cycle,0.00, %
IDE13835-MAS17093,VKMS: relevant VIN number for last data supply-Status of vehicle identification number,valid,
IDE13835-MAS17094,VKMS: relevant VIN number for last data supply-Vehicle identification number output,WVG5WVEB2SH017765,
IDE13836-MAS17095,VKMS: adaption counter-Adaptation counter status,valid,
IDE13836-MAS17096,VKMS: adaption counter-Adaptation counter output,00 01,
IDE13837-MAS17097,VKMS: overview missing keys-Key status,valid,
IDE13837-MAS17099,VKMS: overview missing keys-Number of missing keys,0,
IDE13837-MAS17100,VKMS: overview missing keys-Missing key,00 00,
IDE13842-MAS17101,VKMS: retrieval of information list of the stored VKMS keys-VKMS key status,valid,
IDE13842-MAS17103,VKMS: retrieval of information list of the stored VKMS keys-VKMS type ID,00 15,
IDE13842-MAS17104,VKMS: retrieval of information list of the stored VKMS keys-VKMS type adaptation counter,00 01,
IDE13842-MAS18318,VKMS: retrieval of information list of the stored VKMS keys-Number of VKMS keys,6,
IDE14492-MAS18388,Secure Onboard Communication: verification failed-Failed verification status,valid,
IDE14492-MAS18389,Secure Onboard Communication: verification failed-Number of failed verifications,1,
IDE14492-MAS18390,Secure Onboard Communication: verification failed-Verification failed,00 09,
IDE14493-MAS18360,Secure Onboard Communication: signatures failed-failed signature creation,00 00,
IDE14493-MAS18391,Secure Onboard Communication: signatures failed-Failed signature creation status,valid,
IDE14493-MAS18392,Secure Onboard Communication: signatures failed-Number of failed signature creations,0,
IDE14494-MAS18361,Secure Onboard Communication: general information-Status of general information,valid,
IDE14494-MAS18362,Secure Onboard Communication: general information-ECU function,SOC participant,
IDE14494-MAS18367,Secure Onboard Communication: general information-Main function call period,5,
IDE14495-MAS18369,Secure Onboard Communication: information about internal time-Internal SOC time status,valid,
IDE14495-MAS18370,Secure Onboard Communication: information about internal time-Validity of internal SOC time,Valid SOC time,
IDE14495-MAS18374,Secure Onboard Communication: information about internal time-Internal time,00 0D C0 1D 12 CA 98 DF,
IDE14495-MAS18375,Secure Onboard Communication: information about internal time-Jitter test status,Jitter not exceeded,
IDE14496-MAS18378,Secure Onboard Communication: Freshness Values information-Freshness status,valid,
IDE14496-MAS18379,Secure Onboard Communication: Freshness Values information-Number of Freshness IDs,18,
IDE14496-MAS18380,Secure Onboard Communication: Freshness Values information-SOC PDU ID to which this freshness information is assigned,00 09,
IDE14496-MAS18381,Secure Onboard Communication: Freshness Values information-Freshness Value query status,Freshness Value was not queried,
IDE14496-MAS18384,Secure Onboard Communication: Freshness Values information-SOC time of last successful verification,FF FF FF FF FF FF FF FF,
IDE14496-MAS18385,Secure Onboard Communication: Freshness Values information-Current value of message counter,255,
IDE14496-MAS18386,Secure Onboard Communication: Freshness Values information-Bitfield with used counter values,11111111 11111111 ,
IDE14497-MAS17099,Secure Onboard Communication: missing key-Number of missing keys,0,
IDE14497-MAS17100,Secure Onboard Communication: missing key-Missing key,00 00,
IDE14497-MAS18387,Secure Onboard Communication: missing key-Missing key status,valid,
IDE15502,High-voltage charging manager: target current presetting,0.00, A
IDE16661,Drive system status,not active,
IDE17437,OBD: IUMPR lock,IUMPR_calculation_released,
IDE17437-ENG331508,OBD: IUMPR lock-OBD_blocking_cold_start_denom,EVAP_calculation_released,
IDE17437-ENG331433,OBD: IUMPR lock-OBD_cold_start_denominator,Condition_for_incrementation_of_cold_start_denom_neccessary,
IDE17640,Battery charger: warning lamp request (MIL),not active,
IDE18346-MAS26789,Actual phase angle-Actual phase angle L1  L2,262.958, °
IDE18346-MAS26790,Actual phase angle-Actual phase angle L1  L3,67.4396, °
IDE18346-MAS26791,Actual phase angle-Actual phase angle L2  L3,164.482, °
MAS00194-ENG104003,----ECU,OCDC,
MAS00194-ENG100152,----ECUNAME,OCDCConvCtrl,
MAS00711,Odometer reading,209, km
MAS03679,Terminal 15 status,active,
MAS05076-MAS00106,Time-Year,2025,
MAS05076-MAS00107,Time-Month,3,
MAS05076-MAS00108,Time-Day,25,
MAS05076-MAS00109,Time-Hours,16,
MAS05076-MAS00110,Time-Minutes,37,
MAS05076-MAS00111,Time-Seconds,49,
MAS07220-MAS02832,Status connect. recognition-Malfunction status,No malfunction,
MAS07220-MAS04136,Status connect. recognition-Current,not installed,
MAS07220,Status connect. recognition,not installed,
MAS07220-MAS27852,Status connect. recognition-Locking status,not installed,
MAS07558,Spec. charger operating condition,Standby,
MAS12566-MAS18264,Charge sensor temperature sensor DC-DC charging socket temperature (sensor 1),21.0, °C
MAS12566-MAS18265,Charge sensor temperature sensor DC-DC charging socket temperature (sensor 2),21.3, °C
MAS14473-ENG378333,OBD Normed Trip-OBD_Normed_Trip,No_Normed_Trip,
MAS14474-ENG378332,OBD Minimum Trip-OBD_Minimum_Trip,No_Normed_Min_Trip,
MAS18157-MAS18158,SFD activated status-Role of vehicle diagnostic to be protected,No activation active,
MAS18157-MAS18161,SFD activated status-Status of vehicle diagnostic to be protected,SFD individualization feature set,
MAS18157-MAS18164,SFD activated status-Duration of vehicle diagnostic to be protected,No activation active,
MAS18157-MAS18165,SFD activated status-Type of vehicle diagnostic to be protected,No activation active,
MAS20396,SFD protection procedure,SFD access protection and SFD end-to-end protection,
MAS25034,low load,1EK692J+2207+O++,
MAS25604,High-voltage central box: maximum possible output current,0.0, A
MAS29156,High-voltage system deactivation status via airbag in the event of a crash,No Deactivation,
MAS29170,Transformer primary side: temperature,18.7, °C
MAS29484,DC/DC converter: specified voltage for pre-charging,0.00, V
ENG406162,actual_obd_market,active,
ENG377722,Calibration_Verification_Numbers,99 82 CB 11,
ENG286131,MAC address,Not available,
ENG406194,retry number of plug lock emergency unlock,Not available,
ENG406195,retry number of plug lock normal operation,Not available,
ENG153687,VW Data Set Version Number,50,
Elapsed Time: 00:10
blockmap-CA-14A-907-594-A_WVG5WVEB2SH017765-20250325-1238.CSV
;SW:14A-907-594-A   HW:4K0-907-594 ---  Sunroof
;Component:SAD_STG_1     011 0030, Coding:01000374180F
;EV_SunRoofCONTIPO513,002004,EV_SunRoofCONTIPO513.rod
;Tuesday,25,March,2025,12:38:07:58926
;VCID: 290493B2D97740A2F88-807C-R
IDE09427-MAS08536,Control module counter readings-Excessive temperature protection,0,
IDE09427-MAS08872,Control module counter readings-Resets due to interruption of supply voltage,8,
IDE09427-MAS08873,Control module counter readings-Resets to hardware watchdog,7,
IDE09427-MAS08874,Control module counter readings-Resets due to software watchdog,0,
IDE09492-MAS01155,Temperatures-Control module,36.00, °C
IDE09492-MAS06997,Temperatures-Outside temperature: filtered,17.50, °C
IDE09492-MAS09033,Temperatures-Motor for sunroof,not installed,
IDE09492-MAS09047,Temperatures-Roof shade motor,36.00, °C
IDE09517-IDE00075,Control module-Vehicle speed,0.00, km/h
IDE09517-MAS02447,Control module-Release,present,
IDE09517-MAS07376,Control module-Terminal 58xd,Not available,
IDE09517-MAS07720,Control module-Terminal 15 via CAN,On,
IDE09517-MAS08536,Control module-Excessive temperature protection,not active,
IDE09517-MAS09820,Control module-Terminal 58xt,100, %
IDE09517-MAS11498,Control module-Search illumination for control elements,not installed,
IDE09517-MAS11499,Control module-Indicator lamp for rear sunroof,not installed,
IDE09518-MAS01634,Voltages and currents-Supply voltage,14.60, V
IDE09518-MAS09048,Voltages and currents-Motor current consumption for sun roof,not installed,
IDE09518-MAS09049,Voltages and currents-Motor current consumption for roof blind,0.00, A
IDE11840-MAS13333,Operating signals for sunroof/tilt roof and roof blind-Operating signals of roof shade,Not operated,
IDE11840-MAS13334,Operating signals for sunroof/tilt roof and roof blind-Front operating signals: rear roof shade,Not operated,
IDE11840-MAS13335,Operating signals for sunroof/tilt roof and roof blind-Rear operating signals: rear roof shade,Unknown (255)
IDE11840-MAS13364,Operating signals for sunroof/tilt roof and roof blind-Operating signal sliding/tilting roof,Not operated,
IDE17731-IDE00322,PDLC control module-Status of basic setting,not active,
IDE17731-IDE09056,PDLC control module-Last operating state,active,
IDE17731-IDE13845,PDLC control module-Production mode status,not active,
IDE17731-IDE17070,PDLC control module-Operating status stand-alone mode,not active,
IDE17731-MAS01866,PDLC control module-System test,not active,
IDE17731-MAS02282,PDLC control module-Position,0, %
IDE17731-MAS04190,PDLC control module-Basic setting started,not accomplished,
IDE17731-MAS09979,PDLC control module-Basic setting,not active,
IDE17731-MAS23579,PDLC control module-active system test,not active,
IDE17731-MAS24955,PDLC control module-Pattern,0, %
IDE17732-IDE01718,PDLC control module fault status-Crash signal,not active,
IDE17732-IDE13961,PDLC control module fault status-Active short circuit,not active,
IDE17732-MAS00060,PDLC control module fault status-Open circuit,not active,
IDE17732-MAS01478,PDLC control module fault status-insufficient voltage,not active,
IDE17732-MAS01479,PDLC control module fault status-Excessive voltage,not active,
IDE17732-MAS04329,PDLC control module fault status-Faulty control module entered in event memory,not active,
IDE17732-MAS07055,PDLC control module fault status-Response error,not active,
IDE17732-MAS08536,PDLC control module fault status-Excessive temperature protection,not active,
IDE17733-IDE00322,PDLC control module receiving signal-Status of basic setting,OFF,
IDE17733-IDE00983,PDLC control module receiving signal-Inside temperature,28.00, °C
IDE17733-IDE01718,PDLC control module receiving signal-Crash signal,OFF,
IDE17733-IDE13845,PDLC control module receiving signal-Production mode status,OFF,
IDE17733-IDE17070,PDLC control module receiving signal-Operating status stand-alone mode,OFF,
IDE17733-IDE17925,PDLC control module receiving signal-Data Type,Segment,
IDE17733-MAS01468,PDLC control module receiving signal-Terminal 15,On,
IDE17733-MAS02282,PDLC control module receiving signal-Position,0, %
IDE17733-MAS02447,PDLC control module receiving signal-Release,present,
IDE17733-MAS06997,PDLC control module receiving signal-Outside temperature: filtered,17.50, °C
IDE17733-MAS20880,PDLC control module receiving signal-Data,0,
IDE17733-MAS24957,PDLC control module receiving signal-Dimmer control,0, ms
IDE17733-MAS24958,PDLC control module receiving signal-Front screen runner control,0, ms
IDE17734-MAS24865,PDLC control module segments-Segment 1,not active,
IDE17734-MAS24866,PDLC control module segments-Segment 2,Not available,
IDE17734-MAS24867,PDLC control module segments-Segment 3,Not available,
IDE17734-MAS24868,PDLC control module segments-Segment 4,Not available,
IDE17734-MAS24869,PDLC control module segments-Segment 5,Not available,
IDE17734-MAS24870,PDLC control module segments-Segment 6,Not available,
IDE17734-MAS24871,PDLC control module segments-Segment 7,Not available,
IDE17734-MAS24872,PDLC control module segments-Segment 8,Not available,
IDE17734-MAS24873,PDLC control module segments-Segment 9,Not available,
IDE17735-MAS24865,PDLC control module status of segments-Segment 1,not active,
IDE17735-MAS24866,PDLC control module status of segments-Segment 2,Not available,
IDE17735-MAS24867,PDLC control module status of segments-Segment 3,Not available,
IDE17735-MAS24868,PDLC control module status of segments-Segment 4,Not available,
IDE17735-MAS24869,PDLC control module status of segments-Segment 5,Not available,
IDE17735-MAS24870,PDLC control module status of segments-Segment 6,Not available,
IDE17735-MAS24871,PDLC control module status of segments-Segment 7,Not available,
IDE17735-MAS24872,PDLC control module status of segments-Segment 8,Not available,
IDE17735-MAS24873,PDLC control module status of segments-Segment 9,Not available,
Elapsed Time: 00:02
blockmap-D6-992-941-572-AG_WVG5WVEB2SH017765-20250325-1238.CSV
;SW:992-941-572-AG   HW:992-941-572-A ---  Light Ctrl Left 2
;Component:LED1L         H17 9104, Coding:
;EV_LLPGen3LKEBODPO68X,002003,EV_LLPGen3LKEBODPO68X_002_VW27.rod
;Tuesday,25,March,2025,12:38:18:58926
;VCID: 6882D6B602FDB9AA276-803C-R
IDE00102-MAS02201,Control Module temperature-Temperature,36, °C
IDE08742-MAS07015,Operating time-Running light,0.00, H
IDE08742-MAS07234,Operating time-Eco mode 1,0.00, H
IDE08742-MAS07235,Operating time-Eco mode 2,0.00, H
IDE08742-MAS13654,Operating time-Auxiliary high beam,0.00, H
IDE08742-MAS14159,Operating time-Coming Home,0.00, H
IDE08742-MAS14160,Operating time-Leaving Home,0.00, H
IDE08742-MAS18763,Operating time-Headlight contour light,0.00, H
IDE08742,Operating time,0.15, H
IDE08742,Operating time,0.00, H
IDE08742,Operating time,20.28, H
IDE08742,Operating time,0.11, H
IDE08742,Operating time,3.92, H
IDE08742,Operating time,7.01, H
IDE08742-ENG187666,Operating time-cornerlight,0.29, H
IDE08742-ENG255609,Operating time-designlight 2,0.00, H
IDE08742-ENG274345,Operating time-designlight 3,0.00, H
IDE08742-ENG351726,Operating time-designlight 4,0.00, H
IDE08742-ENG351657,Operating time-designlight 5,0.00, H
IDE08742-ENG247934,Operating time-Express light,0.00, H
IDE08742-ENG186523,Operating time-Highbeam,0.00, H
IDE08742-ENG186491,Operating time-Low beam,3.63, H
IDE08742-ENG166761,Operating time-Sidemarker,3.92, H
IDE08742-ENG166116,Operating time-Turn_indicator,0.57, H
IDE09770-MAS04136,High side channel 1-Current,6, mA
IDE09770-MAS09022,High side channel 1-PWM value,0.0, %
IDE09770-MAS09326,High side channel 1-Function,no function,
IDE09770-ENG186571,High side channel 1-Output,FAN 1,
IDE09771-MAS04136,High side channel 2-Current,0, mA
IDE09771-MAS09022,High side channel 2-PWM value,0.0, %
IDE09771-MAS09326,High side channel 2-Function,no function,
IDE09771-ENG186571,High side channel 2-Output,ERROR,
IDE09772-MAS04136,High side channel 3-Current,6, mA
IDE09772-MAS09022,High side channel 3-PWM value,0.0, %
IDE09772-MAS09326,High side channel 3-Function,Sidemarker,
IDE09772-ENG186571,High side channel 3-Output,LIN LED,
IDE09774-MAS02923,Number of activations-Highway light,0,
IDE09774-MAS07015,Number of activations-Running light,0,
IDE09774-MAS07234,Number of activations-Eco mode 1,0,
IDE09774-MAS07235,Number of activations-Eco mode 2,0,
IDE09774-MAS13654,Number of activations-Auxiliary high beam,0,
IDE09774-MAS14159,Number of activations-Coming Home,0,
IDE09774-MAS14160,Number of activations-Leaving Home,0,
IDE09774-ENG186684,Number of activations-All weather light,0,
IDE09774-ENG108961,Number of activations-Camera lock,0,
IDE09774-ENG186410,Number of activations-City light,0,
IDE09774-ENG186757,Number of activations-daytimerunning light,225,
IDE09774-ENG187759,Number of activations-design light,1,
IDE09774-ENG255609,Number of activations-designlight 2,0,
IDE09774-ENG274345,Number of activations-designlight 3,0,
IDE09774-ENG351726,Number of activations-designlight 4,0,
IDE09774-ENG351657,Number of activations-designlight 5,0,
IDE09774-ENG247934,Number of activations-Express light,0,
IDE09774-ENG187761,Number of activations-higbeam,4,
IDE09774-ENG186491,Number of activations-Low beam,128,
IDE09774-ENG186411,Number of activations-Parking light,0,
IDE09774-ENG186853,Number of activations-position light,122,
IDE09774-ENG166761,Number of activations-Sidemarker,121,
IDE09774-ENG186659,Number of activations-Static cornering light,123,
IDE09774-ENG186553,Number of activations-Tourist light,0,
IDE09774-ENG187378,Number of activations-turn indicator,388,
IDE09828,Head lamp variant,E1,
IDE09828-MAS16183,Head lamp variant-Headlamp coding variant via bus,E1,
IDE09828-MAS18770,Head lamp variant-Country version via data bus,SAE,
IDE09828-MAS18771,Head lamp variant-Headlamp coding variant 2 via bus,AA,
IDE09828-MAS18772,Head lamp variant-Headlamp coding variant 2 via control module,AA,
IDE09828-MAS23141,Head lamp variant-Country version via data record,SAE,
IDE09828-MAS30455,Head lamp variant-Variant comparison status,Finished and OK,
IDE10048-IDE00019,Supply information-Voltage terminal 30,14.6, V
IDE10048-MAS18767,Supply information-Voltage terminal 30G,0.0, V
IDE10165-MAS02201,LED channel 1: Master 1-Temperature,27, °C
IDE10165-MAS04121,LED channel 1: Master 1-Voltage,0.00, V
IDE10165-MAS04136,LED channel 1: Master 1-Current,0, mA
IDE10165-MAS04625,LED channel 1: Master 1-Power: actual value,0, W
IDE10165-MAS09022,LED channel 1: Master 1-PWM value,0.0, %
IDE10165-MAS09326,LED channel 1: Master 1-Function,cornerlight,
IDE10165-MAS09327,LED channel 1: Master 1-LED brightness class,LK4,
IDE10165-ENG186571,LED channel 1: Master 1-Output,LED,
IDE10167-MAS02201,LED channel 1: Slave-Temperature,200, °C
IDE10167-MAS04121,LED channel 1: Slave-Voltage,0.00, V
IDE10167-MAS04136,LED channel 1: Slave-Current,0, mA
IDE10167-MAS04625,LED channel 1: Slave-Power: actual value,0, W
IDE10167-MAS09022,LED channel 1: Slave-PWM value,0.0, %
IDE10167-MAS09326,LED channel 1: Slave-Function,no function,
IDE10167-MAS09327,LED channel 1: Slave-LED brightness class,Not Used,
IDE10167-ENG186571,LED channel 1: Slave-Output,ERROR,
IDE10168-MAS02201,LED channel 2: Master-Temperature,25, °C
IDE10168-MAS04121,LED channel 2: Master-Voltage,0.00, V
IDE10168-MAS04136,LED channel 2: Master-Current,0, mA
IDE10168-MAS04625,LED channel 2: Master-Power: actual value,0, W
IDE10168-MAS09022,LED channel 2: Master-PWM value,0.0, %
IDE10168-MAS09326,LED channel 2: Master-Function,Highbeam,
IDE10168-MAS09327,LED channel 2: Master-LED brightness class,LK4,
IDE10168-ENG186571,LED channel 2: Master-Output,LED,
IDE10169-MAS02201,LED channel 2: Slave-Temperature,200, °C
IDE10169-MAS04121,LED channel 2: Slave-Voltage,0.00, V
IDE10169-MAS04136,LED channel 2: Slave-Current,0, mA
IDE10169-MAS04625,LED channel 2: Slave-Power: actual value,0, W
IDE10169-MAS09022,LED channel 2: Slave-PWM value,0.0, %
IDE10169-MAS09326,LED channel 2: Slave-Function,no function,
IDE10169-MAS09327,LED channel 2: Slave-LED brightness class,Not Used,
IDE10169-ENG186571,LED channel 2: Slave-Output,ERROR,
IDE10170-MAS02201,LED channel 3: Master-Temperature,50, °C
IDE10170-MAS04121,LED channel 3: Master-Voltage,6.67, V
IDE10170-MAS04136,LED channel 3: Master-Current,930, mA
IDE10170-MAS04625,LED channel 3: Master-Power: actual value,6, W
IDE10170-MAS09022,LED channel 3: Master-PWM value,100.0, %
IDE10170-MAS09326,LED channel 3: Master-Function,DRL & PO,
IDE10170-MAS09327,LED channel 3: Master-LED brightness class,LK1,
IDE10170-ENG186571,LED channel 3: Master-Output,LED,
IDE10171-MAS02201,LED channel 3: Slave-Temperature,50, °C
IDE10171-MAS04121,LED channel 3: Slave-Voltage,9.33, V
IDE10171-MAS04136,LED channel 3: Slave-Current,846, mA
IDE10171-MAS04625,LED channel 3: Slave-Power: actual value,8, W
IDE10171-MAS09022,LED channel 3: Slave-PWM value,91.2, %
IDE10171-MAS09326,LED channel 3: Slave-Function,DRL & PO,
IDE10171-MAS09327,LED channel 3: Slave-LED brightness class,LK2,
IDE10171-ENG186571,LED channel 3: Slave-Output,LED,
IDE10173,Operating times in temperature ranges,20.28, H
IDE10173,Operating times in temperature ranges,0.00, H
IDE10205,Control module version,MAX_MQB,
IDE11123-MAS04136,High side channel 4-Current,0, mA
IDE11123-MAS09022,High side channel 4-PWM value,0.0, %
IDE11123-MAS09326,High side channel 4-Function,no function,
IDE11123-ENG186571,High side channel 4-Output,ERROR,
IDE11124-ENG188404,Headlamp Range Control Motor-LWR__speed_adjustment,warm,
IDE11124-ENG188356,Headlamp Range Control Motor-LWR_fault_position,not active,
IDE11124-ENG187101,Headlamp Range Control Motor-LWR_motor_position_in_mm,-6.00, mm
IDE11124-ENG187107,Headlamp Range Control Motor-LWR_motor_position_in_percent,67.0, %
IDE11124-ENG188443,Headlamp Range Control Motor-LWR_reference_run,erfolgt,
IDE11125-ENG188375,Adaptive Cornering Lamp Motor-DKL_fault_position,not active,
IDE11125-ENG248062,Adaptive Cornering Lamp Motor-DKL_motor_position_in_degree,0, °
IDE11125-ENG187407,Adaptive Cornering Lamp Motor-DKL_motor_position_in_percent,51.0, %
IDE11125-ENG188280,Adaptive Cornering Lamp Motor-DKL_reference_run,erfolgt,
IDE11125-ENG188233,Adaptive Cornering Lamp Motor-DKL_speed_adjustment,warm,
IDE11918-MAS03378,Headlights production data-Supplier,              ,
IDE11918-ENG187298,Headlights production data-partnumber headlamp,              ,
IDE11918-ENG186473,Headlights production data-production date,              ,
IDE11918-ENG98897,Headlights production data-Serial number,              ,
IDE13678-MAS02201,LED channel 4: Master-Temperature,27, °C
IDE13678-MAS04121,LED channel 4: Master-Voltage,2.00, V
IDE13678-MAS04136,LED channel 4: Master-Current,0, mA
IDE13678-MAS04625,LED channel 4: Master-Power: actual value,0, W
IDE13678-MAS09022,LED channel 4: Master-PWM value,0.0, %
IDE13678-MAS09326,LED channel 4: Master-Function,lowbeam,
IDE13678-MAS09327,LED channel 4: Master-LED brightness class,LK1,
IDE13678-ENG186571,LED channel 4: Master-Output,LED,
IDE13897-MAS18765,Headlamp identification-Identification,LMM EEPROM Error,
IDE13898-MAS02201,LED channel 5: Master-Temperature,50, °C
IDE13898-MAS04121,LED channel 5: Master-Voltage,2.00, V
IDE13898-MAS04136,LED channel 5: Master-Current,0, mA
IDE13898-MAS04625,LED channel 5: Master-Power: actual value,0, W
IDE13898-MAS09022,LED channel 5: Master-PWM value,0.0, %
IDE13898-MAS09326,LED channel 5: Master-Function,turn indicator,
IDE13898-MAS09327,LED channel 5: Master-LED brightness class,LK1,
IDE13898-ENG186571,LED channel 5: Master-Output,LED,
IDE13899-MAS02201,LED channel 6: Master-Temperature,52, °C
IDE13899-MAS04121,LED channel 6: Master-Voltage,35.00, V
IDE13899-MAS04136,LED channel 6: Master-Current,78, mA
IDE13899-MAS04625,LED channel 6: Master-Power: actual value,3, W
IDE13899-MAS09022,LED channel 6: Master-PWM value,57.6, %
IDE13899-MAS09326,LED channel 6: Master-Function,DRL & PO,
IDE13899-MAS09327,LED channel 6: Master-LED brightness class,LK2,
IDE13899-ENG186571,LED channel 6: Master-Output,LED,
IDE13900-MAS02201,LED channel 7: Master-Temperature,200, °C
IDE13900-MAS04121,LED channel 7: Master-Voltage,2.00, V
IDE13900-MAS04136,LED channel 7: Master-Current,0, mA
IDE13900-MAS04625,LED channel 7: Master-Power: actual value,0, W
IDE13900-MAS09022,LED channel 7: Master-PWM value,0.0, %
IDE13900-MAS09326,LED channel 7: Master-Function,PO,
IDE13900-MAS09327,LED channel 7: Master-LED brightness class,LK1,
IDE13900-ENG186571,LED channel 7: Master-Output,LED,
IDE13901-MAS02201,LED channel 8: Master-Temperature,27, °C
IDE13901-MAS04121,LED channel 8: Master-Voltage,0.00, V
IDE13901-MAS04136,LED channel 8: Master-Current,0, mA
IDE13901-MAS04625,LED channel 8: Master-Power: actual value,0, W
IDE13901-MAS09022,LED channel 8: Master-PWM value,0.0, %
IDE13901-MAS09326,LED channel 8: Master-Function,Highbeam,
IDE13901-MAS09327,LED channel 8: Master-LED brightness class,LK1,
IDE13901-ENG186571,LED channel 8: Master-Output,MXB,
IDE13902-MAS02201,LED channel 9: Master-Temperature,200, °C
IDE13902-MAS04121,LED channel 9: Master-Voltage,0.00, V
IDE13902-MAS04136,LED channel 9: Master-Current,0, mA
IDE13902-MAS04625,LED channel 9: Master-Power: actual value,0, W
IDE13902-MAS09022,LED channel 9: Master-PWM value,0.0, %
IDE13902-MAS09326,LED channel 9: Master-Function,no function,
IDE13902-MAS09327,LED channel 9: Master-LED brightness class,Not Used,
IDE13902-ENG186571,LED channel 9: Master-Output,ERROR,
IDE13903-MAS02201,LED channel 10: Master-Temperature,200, °C
IDE13903-MAS04121,LED channel 10: Master-Voltage,0.00, V
IDE13903-MAS04136,LED channel 10: Master-Current,0, mA
IDE13903-MAS04625,LED channel 10: Master-Power: actual value,0, W
IDE13903-MAS09022,LED channel 10: Master-PWM value,0.0, %
IDE13903-MAS09326,LED channel 10: Master-Function,no function,
IDE13903-MAS09327,LED channel 10: Master-LED brightness class,Not Used,
IDE13903-ENG186571,LED channel 10: Master-Output,ERROR,
IDE13904-MAS02201,LED channel 11: Master-Temperature,200, °C
IDE13904-MAS04121,LED channel 11: Master-Voltage,0.00, V
IDE13904-MAS04136,LED channel 11: Master-Current,0, mA
IDE13904-MAS04625,LED channel 11: Master-Power: actual value,0, W
IDE13904-MAS09022,LED channel 11: Master-PWM value,0.0, %
IDE13904-MAS09326,LED channel 11: Master-Function,no function,
IDE13904-MAS09327,LED channel 11: Master-LED brightness class,Not Used,
IDE13904-ENG186571,LED channel 11: Master-Output,ERROR,
IDE13905-MAS02201,LED channel 12: Master-Temperature,200, °C
IDE13905-MAS04121,LED channel 12: Master-Voltage,0.00, V
IDE13905-MAS04136,LED channel 12: Master-Current,0, mA
IDE13905-MAS04625,LED channel 12: Master-Power: actual value,0, W
IDE13905-MAS09022,LED channel 12: Master-PWM value,0.0, %
IDE13905-MAS09326,LED channel 12: Master-Function,no function,
IDE13905-MAS09327,LED channel 12: Master-LED brightness class,Not Used,
IDE13905-ENG186571,LED channel 12: Master-Output,ERROR,
IDE13906-MAS09833,PWM values channel 1-LED 1,0.0, %
IDE13906-MAS09834,PWM values channel 1-LED 2,0.0, %
IDE13906-MAS09835,PWM values channel 1-LED 3,0.0, %
IDE13906-MAS09836,PWM values channel 1-LED 4,0.0, %
IDE13906-MAS09837,PWM values channel 1-LED 5,0.0, %
IDE13906-MAS09838,PWM values channel 1-LED 6,0.0, %
IDE13906-MAS09839,PWM values channel 1-LED 7,0.0, %
IDE13906-MAS09840,PWM values channel 1-LED 8,0.0, %
IDE13906-MAS09841,PWM values channel 1-LED 9,0.0, %
IDE13906-MAS09842,PWM values channel 1-LED 10,0.0, %
IDE13906-MAS09843,PWM values channel 1-LED 11,0.0, %
IDE13906-MAS09844,PWM values channel 1-LED 12,0.0, %
IDE13907-MAS09833,PWM values channel 2-LED 1,0.0, %
IDE13907-MAS09834,PWM values channel 2-LED 2,0.0, %
IDE13907-MAS09835,PWM values channel 2-LED 3,0.0, %
IDE13907-MAS09836,PWM values channel 2-LED 4,0.0, %
IDE13907-MAS09837,PWM values channel 2-LED 5,0.0, %
IDE13907-MAS09838,PWM values channel 2-LED 6,0.0, %
IDE13907-MAS09839,PWM values channel 2-LED 7,0.0, %
IDE13907-MAS09840,PWM values channel 2-LED 8,0.0, %
IDE13907-MAS09841,PWM values channel 2-LED 9,0.0, %
IDE13907-MAS09842,PWM values channel 2-LED 10,0.0, %
IDE13907-MAS09843,PWM values channel 2-LED 11,0.0, %
IDE13907-MAS09844,PWM values channel 2-LED 12,0.0, %
IDE13908-MAS09833,PWM values channel 3-LED 1,0.0, %
IDE13908-MAS09834,PWM values channel 3-LED 2,0.0, %
IDE13908-MAS09835,PWM values channel 3-LED 3,0.0, %
IDE13908-MAS09836,PWM values channel 3-LED 4,0.0, %
IDE13908-MAS09837,PWM values channel 3-LED 5,0.0, %
IDE13908-MAS09838,PWM values channel 3-LED 6,0.0, %
IDE13908-MAS09839,PWM values channel 3-LED 7,0.0, %
IDE13908-MAS09840,PWM values channel 3-LED 8,0.0, %
IDE13908-MAS09841,PWM values channel 3-LED 9,0.0, %
IDE13908-MAS09842,PWM values channel 3-LED 10,0.0, %
IDE13908-MAS09843,PWM values channel 3-LED 11,0.0, %
IDE13908-MAS09844,PWM values channel 3-LED 12,0.0, %
IDE13909-MAS09833,PWM values channel 4-LED 1,0.0, %
IDE13909-MAS09834,PWM values channel 4-LED 2,0.0, %
IDE13909-MAS09835,PWM values channel 4-LED 3,0.0, %
IDE13909-MAS09836,PWM values channel 4-LED 4,0.0, %
IDE13909-MAS09837,PWM values channel 4-LED 5,0.0, %
IDE13909-MAS09838,PWM values channel 4-LED 6,0.0, %
IDE13909-MAS09839,PWM values channel 4-LED 7,0.0, %
IDE13909-MAS09840,PWM values channel 4-LED 8,0.0, %
IDE13909-MAS09841,PWM values channel 4-LED 9,0.0, %
IDE13909-MAS09842,PWM values channel 4-LED 10,0.0, %
IDE13909-MAS09843,PWM values channel 4-LED 11,0.0, %
IDE13909-MAS09844,PWM values channel 4-LED 12,0.0, %
IDE13910-MAS09833,PWM values channel 5-LED 1,0.0, %
IDE13910-MAS09834,PWM values channel 5-LED 2,0.0, %
IDE13910-MAS09835,PWM values channel 5-LED 3,0.0, %
IDE13910-MAS09836,PWM values channel 5-LED 4,0.0, %
IDE13910-MAS09837,PWM values channel 5-LED 5,0.0, %
IDE13910-MAS09838,PWM values channel 5-LED 6,0.0, %
IDE13910-MAS09839,PWM values channel 5-LED 7,0.0, %
IDE13910-MAS09840,PWM values channel 5-LED 8,0.0, %
IDE13910-MAS09841,PWM values channel 5-LED 9,0.0, %
IDE13910-MAS09842,PWM values channel 5-LED 10,0.0, %
IDE13910-MAS09843,PWM values channel 5-LED 11,0.0, %
IDE13910-MAS09844,PWM values channel 5-LED 12,0.0, %
IDE13911-MAS09833,PWM values channel 6-LED 1,0.0, %
IDE13911-MAS09834,PWM values channel 6-LED 2,0.0, %
IDE13911-MAS09835,PWM values channel 6-LED 3,0.0, %
IDE13911-MAS09836,PWM values channel 6-LED 4,0.0, %
IDE13911-MAS09837,PWM values channel 6-LED 5,0.0, %
IDE13911-MAS09838,PWM values channel 6-LED 6,0.0, %
IDE13911-MAS09839,PWM values channel 6-LED 7,0.0, %
IDE13911-MAS09840,PWM values channel 6-LED 8,0.0, %
IDE13911-MAS09841,PWM values channel 6-LED 9,0.0, %
IDE13911-MAS09842,PWM values channel 6-LED 10,0.0, %
IDE13911-MAS09843,PWM values channel 6-LED 11,0.0, %
IDE13911-MAS09844,PWM values channel 6-LED 12,0.0, %
IDE13912-MAS09833,PWM values channel 7-LED 1,0.0, %
IDE13912-MAS09834,PWM values channel 7-LED 2,0.0, %
IDE13912-MAS09835,PWM values channel 7-LED 3,0.0, %
IDE13912-MAS09836,PWM values channel 7-LED 4,0.0, %
IDE13912-MAS09837,PWM values channel 7-LED 5,0.0, %
IDE13912-MAS09838,PWM values channel 7-LED 6,0.0, %
IDE13912-MAS09839,PWM values channel 7-LED 7,0.0, %
IDE13912-MAS09840,PWM values channel 7-LED 8,0.0, %
IDE13912-MAS09841,PWM values channel 7-LED 9,0.0, %
IDE13912-MAS09842,PWM values channel 7-LED 10,0.0, %
IDE13912-MAS09843,PWM values channel 7-LED 11,0.0, %
IDE13912-MAS09844,PWM values channel 7-LED 12,0.0, %
IDE13913-MAS09833,PWM values channel 8-LED 1,0.0, %
IDE13913-MAS09834,PWM values channel 8-LED 2,0.0, %
IDE13913-MAS09835,PWM values channel 8-LED 3,0.0, %
IDE13913-MAS09836,PWM values channel 8-LED 4,0.0, %
IDE13913-MAS09837,PWM values channel 8-LED 5,0.0, %
IDE13913-MAS09838,PWM values channel 8-LED 6,0.0, %
IDE13913-MAS09839,PWM values channel 8-LED 7,0.0, %
IDE13913-MAS09840,PWM values channel 8-LED 8,0.0, %
IDE13913-MAS09841,PWM values channel 8-LED 9,0.0, %
IDE13913-MAS09842,PWM values channel 8-LED 10,0.0, %
IDE13913-MAS09843,PWM values channel 8-LED 11,0.0, %
IDE13913-MAS09844,PWM values channel 8-LED 12,0.0, %
IDE13914-MAS09833,PWM values channel 9-LED 1,0.0, %
IDE13914-MAS09834,PWM values channel 9-LED 2,0.0, %
IDE13914-MAS09835,PWM values channel 9-LED 3,0.0, %
IDE13914-MAS09836,PWM values channel 9-LED 4,0.0, %
IDE13914-MAS09837,PWM values channel 9-LED 5,0.0, %
IDE13914-MAS09838,PWM values channel 9-LED 6,0.0, %
IDE13914-MAS09839,PWM values channel 9-LED 7,0.0, %
IDE13914-MAS09840,PWM values channel 9-LED 8,0.0, %
IDE13914-MAS09841,PWM values channel 9-LED 9,0.0, %
IDE13914-MAS09842,PWM values channel 9-LED 10,0.0, %
IDE13914-MAS09843,PWM values channel 9-LED 11,0.0, %
IDE13914-MAS09844,PWM values channel 9-LED 12,0.0, %
IDE13915-MAS09833,PWM values channel 10-LED 1,0.0, %
IDE13915-MAS09834,PWM values channel 10-LED 2,0.0, %
IDE13915-MAS09835,PWM values channel 10-LED 3,0.0, %
IDE13915-MAS09836,PWM values channel 10-LED 4,0.0, %
IDE13915-MAS09837,PWM values channel 10-LED 5,0.0, %
IDE13915-MAS09838,PWM values channel 10-LED 6,0.0, %
IDE13915-MAS09839,PWM values channel 10-LED 7,0.0, %
IDE13915-MAS09840,PWM values channel 10-LED 8,0.0, %
IDE13915-MAS09841,PWM values channel 10-LED 9,0.0, %
IDE13915-MAS09842,PWM values channel 10-LED 10,0.0, %
IDE13915-MAS09843,PWM values channel 10-LED 11,0.0, %
IDE13915-MAS09844,PWM values channel 10-LED 12,0.0, %
IDE13916-MAS09833,PWM values channel 11-LED 1,0.0, %
IDE13916-MAS09834,PWM values channel 11-LED 2,0.0, %
IDE13916-MAS09835,PWM values channel 11-LED 3,0.0, %
IDE13916-MAS09836,PWM values channel 11-LED 4,0.0, %
IDE13916-MAS09837,PWM values channel 11-LED 5,0.0, %
IDE13916-MAS09838,PWM values channel 11-LED 6,0.0, %
IDE13916-MAS09839,PWM values channel 11-LED 7,0.0, %
IDE13916-MAS09840,PWM values channel 11-LED 8,0.0, %
IDE13916-MAS09841,PWM values channel 11-LED 9,0.0, %
IDE13916-MAS09842,PWM values channel 11-LED 10,0.0, %
IDE13916-MAS09843,PWM values channel 11-LED 11,0.0, %
IDE13916-MAS09844,PWM values channel 11-LED 12,0.0, %
IDE13917-MAS09833,PWM values channel 12-LED 1,0.0, %
IDE13917-MAS09834,PWM values channel 12-LED 2,0.0, %
IDE13917-MAS09835,PWM values channel 12-LED 3,0.0, %
IDE13917-MAS09836,PWM values channel 12-LED 4,0.0, %
IDE13917-MAS09837,PWM values channel 12-LED 5,0.0, %
IDE13917-MAS09838,PWM values channel 12-LED 6,0.0, %
IDE13917-MAS09839,PWM values channel 12-LED 7,0.0, %
IDE13917-MAS09840,PWM values channel 12-LED 8,0.0, %
IDE13917-MAS09841,PWM values channel 12-LED 9,0.0, %
IDE13917-MAS09842,PWM values channel 12-LED 10,0.0, %
IDE13917-MAS09843,PWM values channel 12-LED 11,0.0, %
IDE13917-MAS09844,PWM values channel 12-LED 12,0.0, %
MAS00468,Unlearning counter,2,
Elapsed Time: 00:10
blockmap-D7-992-941-572-AG_WVG5WVEB2SH017765-20250325-1238.CSV
;SW:992-941-572-AG   HW:992-941-572-A ---  Light Ctrl Right 2
;Component:LED1R         H17 9104, Coding:
;EV_LLPGen3RKEBODPO68X,002003,EV_LLPGen3RKEBODPO68X_002_VW27.rod
;Tuesday,25,March,2025,12:38:37:58926
;VCDS Version: Release 25.3.0 (x64)  Data version: 20250311 DS365.0
Group,Description,Actual
IDE00102-MAS02201,Control Module temperature-Temperature,32, °C
IDE08742,Operating time,7.02, H
IDE08742-ENG187666,Operating time-cornerlight,0.23, H
IDE08742-ENG166116,Operating time-Turn_indicator,0.42, H
IDE09771-ENG186571,High side channel 2-Output,16,
IDE09774-IDE03638,Number of activations-Stationary cornering lamp,115,
IDE09774-IDE05723,Number of activations-Clearance light,124,
IDE09774-MAS07249,Number of activations-High Beam,4,
IDE09774-MAS09325,Number of activations-Daytime running lights,218,
IDE09774-MAS25532,Number of activations-Headlights: contour lighting,1,
IDE09774-ENG186491,Number of activations-Low beam,129,
IDE09774-ENG166761,Number of activations-Sidemarker,123,
IDE09774-ENG187378,Number of activations-turn indicator,375,
IDE09828-MAS16182,Head lamp variant-Headlamp coding variant via control module,E1,
IDE10048-IDE00019,Supply information-Voltage terminal 30,14.5, V
IDE10165-MAS02201,LED channel 1: Master 1-Temperature,22, °C
IDE10167-ENG186571,LED channel 1: Slave-Output,16,
IDE10168-MAS02201,LED channel 2: Master-Temperature,21, °C
IDE10169-ENG186571,LED channel 2: Slave-Output,16,
IDE10170-MAS02201,LED channel 3: Master-Temperature,48, °C
IDE10170-MAS04121,LED channel 3: Master-Voltage,7.00, V
IDE10170-MAS04625,LED channel 3: Master-Power: actual value,7, W
IDE10171-MAS02201,LED channel 3: Slave-Temperature,48, °C
IDE11123-ENG186571,High side channel 4-Output,16,
IDE11124-ENG188255,Headlamp Range Control Motor-LWR_speed_adjustment,warm,
IDE11125-ENG187407,Adaptive Cornering Lamp Motor-DKL_motor_position_in_percent,48.0, %
IDE13678-MAS02201,LED channel 4: Master-Temperature,21, °C
IDE13898-MAS02201,LED channel 5: Master-Temperature,48, °C
IDE13899-MAS02201,LED channel 6: Master-Temperature,48, °C
IDE13899-MAS04121,LED channel 6: Master-Voltage,34.67, V
IDE13900-MAS04121,LED channel 7: Master-Voltage,1.67, V
IDE13901-MAS02201,LED channel 8: Master-Temperature,21, °C
IDE13902-ENG186571,LED channel 9: Master-Output,16,
IDE13903-ENG186571,LED channel 10: Master-Output,16,
IDE13904-ENG186571,LED channel 11: Master-Output,16,
IDE13905-ENG186571,LED channel 12: Master-Output,16,
Elapsed Time: 00:10
blockmap-DE-3P0-035-502-B_WVG5WVEB2SH017765-20250325-1238.CSV
;SW:3P0-035-502-B   HW:3P0-035-502 ---  Charger 1 for mobile dev
;Component:COUPLING BOX  004 0170, Coding:400080
;EV_DualCouplBoxSK336,001006,EV_DualCouplBoxSK336.rod
;Tuesday,25,March,2025,12:38:54:58926
;VCID: 241A8286BE559DCACBE-8070-R SFD+SFD2
IDE10300,OBD Driving Cycle detected,active,
IDE13845,Production mode status,not active,
Elapsed Time: 00:01
blockmap-8116-1T3-035-335-B_WVG5WVEB2SH017765-20250325-1239.CSV
;SW:1T3-035-335-B   HW:1EA-035-335 ---  Snd enhanct 2
;Component:E_SOUND_SG    H06 0007, Coding:
;EV_ESoun2HarmaMEBUNECE,001003,EV_ESoun2HarmaMEBUNECE.rod
;Tuesday,25,March,2025,12:39:04:58926
;VCID: 2D0C67A2ED9F5C82140-8078-R
IDE00102-ENG127110,Control Module temperature-ecu_internal_temperature,30.0, °C
IDE00322,Status of basic setting,0,
IDE13845,Production mode status,0,
Elapsed Time: 00:00
blockmap-8123-V04-007-003-LE_WVG5WVEB2SH017765-20250325-1239.CSV
;SW:V04-007-003-LE   HW: ---  App server 1 system 1 adaptive
;Component:ICAS1 Sys_Ada 0254, Coding:
;EV_AppServ1Sys1ICAS1UNECE,001002,EV_AppServ1Sys1ICAS1UNECE_VWE3.rod
;Tuesday,25,March,2025,12:39:14:58926
;VCID: 75BC8FC2454F5442AC0-8020-R SFD+SFD2
IDE00767,No. of unscheduled ECU resets,|SCID,last_reason_for_defective_application
IDE00767-ENG279318,No. of unscheduled ECU resets-Count_of_defective_applications,0,
IDE14911-MAS00976,Mobile Online Service message memory: active messages-Counter,0,
IDE14911-MAS06854,Mobile Online Service message memory: active messages-Version,1,
IDE14911-MAS19595,Mobile Online Service message memory: active messages-ID,00 00,
IDE14912-MAS00976,Mobile Online Service message memory: filtered messages-Counter,0,
IDE14912-MAS06854,Mobile Online Service message memory: filtered messages-Version,1,
IDE14912-MAS19595,Mobile Online Service message memory: filtered messages-ID,00 00,
IDE14913-MAS00106,Mobile Online services history memory for messages-Year,2025,
IDE14913-MAS00107,Mobile Online services history memory for messages-Month,2,
IDE14913-MAS00108,Mobile Online services history memory for messages-Day,21,
IDE14913-MAS00109,Mobile Online services history memory for messages-Hours,15,
IDE14913-MAS00110,Mobile Online services history memory for messages-Minutes,11,
IDE14913-MAS00111,Mobile Online services history memory for messages-Seconds,53,
IDE14913-MAS00976,Mobile Online services history memory for messages-Counter,10,
IDE14913-MAS06854,Mobile Online services history memory for messages-Version,1,
IDE14913-MAS19595,Mobile Online services history memory for messages-ID,A6 B3,
MAS03617,Time zone,UTC-04:00,
ENG282101-MAS20968,BDP_someip_data_bus_service_error_value_received-Number of services,0,
ENG282101,BDP_someip_data_bus_service_error_value_received,|Service Id,Method ID
ENG282102-MAS20968,BDP_someip_data_bus_service_implausible-Number of services,0,
ENG282102,BDP_someip_data_bus_service_implausible,|Service Id,Method ID
ENG282103-MAS20968,BDP_someip_data_bus_service_not_available-Number of services,0,
ENG282103,BDP_someip_data_bus_service_not_available,|Service Id,IPv6 address
ENG254614-IDE09469,DNH_someip_data_bus_service_error_value_received-IPv6 address,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG254614-MAS05767,DNH_someip_data_bus_service_error_value_received-port,00 00,
ENG254614-MAS20533,DNH_someip_data_bus_service_error_value_received-Service Id,00 00,
ENG254614-MAS20961,DNH_someip_data_bus_service_error_value_received-Method ID,00 00,
ENG254614-MAS20968,DNH_someip_data_bus_service_error_value_received-Number of services,0,
ENG254615-IDE09469,DNH_someip_data_bus_service_implausible-IPv6 address,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG254615-MAS05767,DNH_someip_data_bus_service_implausible-port,00 00,
ENG254615-MAS20533,DNH_someip_data_bus_service_implausible-Service Id,00 00,
ENG254615-MAS20961,DNH_someip_data_bus_service_implausible-Method ID,00 00,
ENG254615-MAS20968,DNH_someip_data_bus_service_implausible-Number of services,0,
ENG254616-IDE09469,DNH_someip_data_bus_service_not_available-IPv6 address,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG254616-MAS05767,DNH_someip_data_bus_service_not_available-port,00 00,
ENG254616-MAS20533,DNH_someip_data_bus_service_not_available-Service Id,00 00,
ENG254616-MAS20968,DNH_someip_data_bus_service_not_available-Number of services,0,
ENG279101-ENG279317,eMMC_budget_exceedance-Count_of_applications,Yes,
ENG279102,eMMC_statistics_adaptive,|SCID,Bytes_in_application_budget
ENG279102-ENG279317,eMMC_statistics_adaptive-Count_of_applications,0,
ENG277670-IDE09469,TM_SP_someip_data_bus_service_error_value_received-IPv6 address,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG277670-MAS05767,TM_SP_someip_data_bus_service_error_value_received-port,00 00,
ENG277670-MAS20533,TM_SP_someip_data_bus_service_error_value_received-Service Id,00 00,
ENG277670-MAS20961,TM_SP_someip_data_bus_service_error_value_received-Method ID,00 00,
ENG277670-ENG255550,TM_SP_someip_data_bus_service_error_value_received-Count_of_services,0,
ENG277541-IDE09469,TM_SP_someip_data_bus_service_implausible-IPv6 address,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG277541-MAS05767,TM_SP_someip_data_bus_service_implausible-port,00 00,
ENG277541-MAS20533,TM_SP_someip_data_bus_service_implausible-Service Id,80 01,
ENG277541-MAS20961,TM_SP_someip_data_bus_service_implausible-Method ID,00 02,
ENG277541-ENG255550,TM_SP_someip_data_bus_service_implausible-Count_of_services,1,
ENG277711-IDE09469,TM_SP_someip_data_bus_service_not_available-IPv6 address,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG277711-MAS05767,TM_SP_someip_data_bus_service_not_available-port,00 00,
ENG277711-MAS20533,TM_SP_someip_data_bus_service_not_available-Service Id,00 00,
ENG277711-ENG255550,TM_SP_someip_data_bus_service_not_available-Count_of_services,0,
Elapsed Time: 00:12
blockmap-8124-V04-007-003-LF_WVG5WVEB2SH017765-20250325-1239.CSV
;SW:V04-007-003-LF   HW: ---  App server 1 system 2 Java
;Component:ICAS1 Sys_Jav 0254, Coding:
;EV_AppServ1Sys2ICAS1UNECE,001002,EV_AppServ1Sys2ICAS1UNECE_VWE3.rod
;Tuesday,25,March,2025,12:39:40:58926
;VCID: 76BE88CE58495F5AA5A-8022-R SFD+SFD2
IDE16044-IDE14236,Authentic time last transmission to client-Authentic time: last confirmed time,2025-03-25T16:13:44Z,
IDE16044-IDE14237,Authentic time last transmission to client-Authentic time: actual time,2025-03-25T16:39:44Z,
IDE16044-MAS15286,Authentic time last transmission to client-Number of terminal 15 cycles,0,
MAS17524-MAS17977,Unlockable functions: version info-Supported activation version,Support from FSC version 0x12,
MAS17524-MAS17978,Unlockable functions: version info-Supported encryption procedure,RSA3072 Exp. 17,
MAS17524-MAS18453,Unlockable functions: version info-FoD metadata version,Support from metadata version 0x10,
MAS17524-MAS18456,Unlockable functions: version info-KeyIdent (Key project identification),1702,
MAS17524-MAS18457,Unlockable functions: version info-Generation of function activation,Activation via FoD,
MAS17524-MAS18460,Unlockable functions: version info-FoD partner diagnostic address,00 19,
MAS18461-MAS18462,FoD product list-Number of function IDs,0,
MAS18461-MAS18463,FoD product list-Product number,0,
MAS18461-MAS18464,FoD product list-Function ID,
MAS18461-MAS18465,FoD product list-Import regulation,No Info,
MAS18461-MAS18471,FoD product list-Product regulation,No Info,
MAS18461-MAS18474,FoD product list-Change information regulation,No Info,
MAS18461-MAS18477,FoD product list-Notification control,No Info,
MAS18461-MAS18481,FoD product list-Activate regulation,No Info,
MAS18461-MAS18484,FoD product list-Deactivate regulation,No Info,
MAS18461-MAS18487,FoD product list-Warning interval,0,
MAS18461-MAS18488,FoD product list-additional meta info 1,00,
MAS18461-MAS18489,FoD product list-additional meta info 2,00,
MAS18490-IDE06260,Read FoD assignment products on FSIDs-ID number,00 00 00 00,
MAS18490-MAS18463,Read FoD assignment products on FSIDs-Product number,0,
MAS18490-MAS18491,Read FoD assignment products on FSIDs-Number of assignments,0,
MAS19270,Parameter list,|Parameter ID,Data description
ENG297277,BAP historical memory,|Year,Month
ENG297278,Metadata_Shadow_Copy,|User ID,Year
Elapsed Time: 00:31
blockmap-8125-V04-007-003-RH_WVG5WVEB2SH017765-20250325-1240.CSV
;SW:V04-007-003-RH   HW: ---  App server 3 system 1 infotaint.
;Component:IC3GIVI-S--US 3626, Coding:64101030000000000000000000000000000000000000000000
;EV_MUICASIVIPart,003001,EV_MUICASIVIPart_003_VWE3.rod
;Tuesday,25,March,2025,12:40:32:58926
;VCID: 7EAE90EE7079171AFDA-802A-R SFD+SFD2
IDE01285-ENG101364,Counter of component protection malfunctions-Theft Protection Error Counter,0,
IDE01985-MAS06855,FAZIT identification test sum-Test sum,A9 2B B6 AB,
IDE03471-MAS00802,Vehicle configuration-Control module for distance control,Correct coding,
IDE03471-MAS01891,Vehicle configuration-Lane assist,Correct coding,
IDE07145-MAS06773,Component protection properties-KS Standard software main version nummer,03,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,06,
IDE07145-MAS06775,Component protection properties-KS Standard software correct number,03,
IDE07145-MAS06785,Component protection properties-GFA key,Not Used,
IDE11034-MAS01482,Satellite radio: module information-Hardware version,
IDE11034-MAS11961,Satellite radio: module information-Serial number,S9C555CC9376,
IDE11034-MAS11962,Satellite radio: module information-Pre-activation key,53 39 43 00 35 35 35 43 43 39 33 37 36 A0 01 00 98 0B 10 00 00 00 02 BB 0C D6 87 05 C9 DD 28 AD A6 37 A1 B6 41 1E 00 03 FF FF 00 00 00 00 FF FF FF FF,
IDE11034-MAS11963,Satellite radio: module information-Firmware version,6.30.0,
IDE11034-MAS11964,Satellite radio: module information-Satellite Module Services Version,
IDE11034-MAS11965,Satellite radio: module information-SiriusXM Interconnect Version,
IDE11034-MAS11966,Satellite radio: module information-Database Version,599,
IDE11034-ENG249454,Satellite radio: module information-apogee_traffic,
IDE11034-ENG249326,Satellite radio: module information-canadian_fuel,
IDE11034-ENG249344,Satellite radio: module information-channel_arts,
IDE11034-ENG249291,Satellite radio: module information-ev_stations,
IDE11034-ENG249490,Satellite radio: module information-fuel_stations,
IDE11034-ENG249493,Satellite radio: module information-internal_sxm,1.21.3.5,
IDE11034-ENG249368,Satellite radio: module information-movies,
IDE11034-ENG249268,Satellite radio: module information-Parking,
IDE11034-ENG249458,Satellite radio: module information-phonetics,
IDE11034-ENG249496,Satellite radio: module information-safety_alerts,
IDE11034-ENG176820,Satellite radio: module information-States,
IDE11034-ENG249463,Satellite radio: module information-stocks,
IDE11034-ENG249431,Satellite radio: module information-sxm_pics,
IDE11034-ENG249499,Satellite radio: module information-tabular_weather,
IDE11034-ENG249467,Satellite radio: module information-weather_alerts,
IDE14492-MAS18390,Secure Onboard Communication: verification failed-Verification failed,00 7C,
IDE14495-MAS18374,Secure Onboard Communication: information about internal time-Internal time,00 0D C0 1D 12 CA 9F E9,
IDE14496-MAS18379,Secure Onboard Communication: Freshness Values information-Number of Freshness IDs,5,
IDE14496-MAS18380,Secure Onboard Communication: Freshness Values information-SOC PDU ID to which this freshness information is assigned,00 05,
MAS17268,Functions which can be activated: connection error counter,0,
MAS17521-IDE04332,Unlockable functions: activation status-Release code for a SWaP function,Available,
MAS17521-IDE05814,Unlockable functions: activation status-Individualization characteristic,invalid,
MAS17521-IDE06260,Unlockable functions: activation status-ID number,00 06 01 00,
MAS17521-MAS01340,Unlockable functions: activation status-Functions,Available,
MAS17521-MAS01903,Unlockable functions: activation status-Configuration,OK,
MAS17521-MAS02934,Unlockable functions: activation status-Preconditions met,Condition not met,
MAS17521-MAS05616,Unlockable functions: activation status-Cancellation,No,
MAS17521-MAS05617,Unlockable functions: activation status-Authentication,Condition met,
MAS17521-MAS17839,Unlockable functions: activation status-Number of functions which can be activated,7,
MAS17521-MAS17983,Unlockable functions: activation status-Last state,not active,
ENG186123-ENG187319,Authentic_time_last_client_response-Counter_kl15_since_last_sync,0,
ENG186123-ENG255560,Authentic_time_last_client_response-Current_time_ used,
ENG186123-ENG186739,Authentic_time_last_client_response-Last_valid_timestamp_from_Backend,
ENG298236-MAS06854,FoD_slave_extended_state-Version,11,
ENG298236-ENG298547,FoD_slave_extended_state-Extended_state_payload,00 01 00 D6 03 03 00 02 00 00 03 03 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0A 00 00 00 C8 00 00 75 30 00 05 7E 40 00 00 13 88 00 0A 07 0A 22 02 00 00,
ENG298236-ENG298612,FoD_slave_extended_state-Payload_length,53,
ENG179581-ENG181012,FoD_slave_operating_state-FoD_slave_state,02,
ENG179902-IDE04332,Function_On_Demand_Freischalt_ID_Status_Dev-Release code for a SWaP function,Available,
ENG179902-IDE05814,Function_On_Demand_Freischalt_ID_Status_Dev-Individualization characteristic,invalid,
ENG179902-IDE06260,Function_On_Demand_Freischalt_ID_Status_Dev-ID number,00 06 01 00,
ENG179902-MAS01340,Function_On_Demand_Freischalt_ID_Status_Dev-Functions,Available,
ENG179902-MAS01903,Function_On_Demand_Freischalt_ID_Status_Dev-Configuration,OK,
ENG179902-MAS02934,Function_On_Demand_Freischalt_ID_Status_Dev-Preconditions met,Condition not met,
ENG179902-MAS05616,Function_On_Demand_Freischalt_ID_Status_Dev-Cancellation,No,
ENG179902-MAS05617,Function_On_Demand_Freischalt_ID_Status_Dev-Authentication,Condition met,
ENG179902-MAS17839,Function_On_Demand_Freischalt_ID_Status_Dev-Number of functions which can be activated,7,
ENG179902-MAS17983,Function_On_Demand_Freischalt_ID_Status_Dev-Last state,not active,
ENG254819-ENG98988,startup_timer-Timer,1886, s
ENG274023-ENG111823,Warping_matrix_AR_normal-Block_1,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG274023-ENG274098,Warping_matrix_AR_normal-Block_10,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG274023-ENG274117,Warping_matrix_AR_normal-Block_11,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG274023-ENG274118,Warping_matrix_AR_normal-Block_12,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG274023-ENG274119,Warping_matrix_AR_normal-Block_13,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG274023-ENG274120,Warping_matrix_AR_normal-Block_14,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG274023-ENG274121,Warping_matrix_AR_normal-Block_15,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG274023-ENG263219,Warping_matrix_AR_normal-Block_16,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG274023-ENG274126,Warping_matrix_AR_normal-Block_17,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG274023-ENG274127,Warping_matrix_AR_normal-Block_18,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG274023-ENG274128,Warping_matrix_AR_normal-Block_19,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG274023-ENG274090,Warping_matrix_AR_normal-Block_2,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG274023-ENG274142,Warping_matrix_AR_normal-Block_20,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG274023-ENG274265,Warping_matrix_AR_normal-Block_21,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG274023-ENG274266,Warping_matrix_AR_normal-Block_22,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG274023-ENG274267,Warping_matrix_AR_normal-Block_23,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG274023-ENG274268,Warping_matrix_AR_normal-Block_24,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG274023-ENG274269,Warping_matrix_AR_normal-Block_25,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG274023-ENG274270,Warping_matrix_AR_normal-Block_26,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG274023-ENG274271,Warping_matrix_AR_normal-Block_27,00 00 00 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG274023-ENG274272,Warping_matrix_AR_normal-Block_28,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG274023-ENG274273,Warping_matrix_AR_normal-Block_29,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG274023-ENG274091,Warping_matrix_AR_normal-Block_3,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG274023-ENG274274,Warping_matrix_AR_normal-Block_30,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG274023-ENG274275,Warping_matrix_AR_normal-Block_31,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG274023-ENG274276,Warping_matrix_AR_normal-Block_32,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG274023-ENG274277,Warping_matrix_AR_normal-Block_33,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG274023-ENG274278,Warping_matrix_AR_normal-Block_34,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG274023-ENG274279,Warping_matrix_AR_normal-Block_35,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG274023-ENG274280,Warping_matrix_AR_normal-Block_36,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG274023-ENG274281,Warping_matrix_AR_normal-Block_37,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG274023-ENG274282,Warping_matrix_AR_normal-Block_38,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG274023-ENG274283,Warping_matrix_AR_normal-Block_39,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG274023-ENG274092,Warping_matrix_AR_normal-Block_4,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG274023-ENG274284,Warping_matrix_AR_normal-Block_40,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG274023-ENG274285,Warping_matrix_AR_normal-Block_41,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG274023-ENG274286,Warping_matrix_AR_normal-Block_42,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG274023-ENG274287,Warping_matrix_AR_normal-Block_43,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG274023-ENG274288,Warping_matrix_AR_normal-Block_44,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG274023-ENG274289,Warping_matrix_AR_normal-Block_45,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG274023-ENG274093,Warping_matrix_AR_normal-Block_5,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG274023-ENG274094,Warping_matrix_AR_normal-Block_6,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG274023-ENG274095,Warping_matrix_AR_normal-Block_7,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG274023-ENG274096,Warping_matrix_AR_normal-Block_8,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG274023-ENG274097,Warping_matrix_AR_normal-Block_9,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG274028-ENG111823,Warping_matrix_static_tall-Block_1,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG274028-ENG274098,Warping_matrix_static_tall-Block_10,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG274028-ENG274117,Warping_matrix_static_tall-Block_11,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG274028-ENG274118,Warping_matrix_static_tall-Block_12,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG274028-ENG274119,Warping_matrix_static_tall-Block_13,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG274028-ENG274120,Warping_matrix_static_tall-Block_14,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG274028-ENG274121,Warping_matrix_static_tall-Block_15,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG274028-ENG263219,Warping_matrix_static_tall-Block_16,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG274028-ENG274126,Warping_matrix_static_tall-Block_17,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG274028-ENG274127,Warping_matrix_static_tall-Block_18,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG274028-ENG274128,Warping_matrix_static_tall-Block_19,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG274028-ENG274090,Warping_matrix_static_tall-Block_2,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG274028-ENG274142,Warping_matrix_static_tall-Block_20,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG274028-ENG274265,Warping_matrix_static_tall-Block_21,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG274028-ENG274266,Warping_matrix_static_tall-Block_22,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG274028-ENG274267,Warping_matrix_static_tall-Block_23,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG274028-ENG274268,Warping_matrix_static_tall-Block_24,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG274028-ENG274269,Warping_matrix_static_tall-Block_25,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG274028-ENG274270,Warping_matrix_static_tall-Block_26,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG274028-ENG274271,Warping_matrix_static_tall-Block_27,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG274028-ENG274272,Warping_matrix_static_tall-Block_28,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG274028-ENG274273,Warping_matrix_static_tall-Block_29,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG274028-ENG274091,Warping_matrix_static_tall-Block_3,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG274028-ENG274274,Warping_matrix_static_tall-Block_30,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG274028-ENG274275,Warping_matrix_static_tall-Block_31,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG274028-ENG274276,Warping_matrix_static_tall-Block_32,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG274028-ENG274277,Warping_matrix_static_tall-Block_33,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG274028-ENG274278,Warping_matrix_static_tall-Block_34,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG274028-ENG274279,Warping_matrix_static_tall-Block_35,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG274028-ENG274280,Warping_matrix_static_tall-Block_36,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG274028-ENG274281,Warping_matrix_static_tall-Block_37,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG274028-ENG274282,Warping_matrix_static_tall-Block_38,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG274028-ENG274283,Warping_matrix_static_tall-Block_39,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG274028-ENG274092,Warping_matrix_static_tall-Block_4,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG274028-ENG274284,Warping_matrix_static_tall-Block_40,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG274028-ENG274285,Warping_matrix_static_tall-Block_41,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG274028-ENG274286,Warping_matrix_static_tall-Block_42,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG274028-ENG274287,Warping_matrix_static_tall-Block_43,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG274028-ENG274288,Warping_matrix_static_tall-Block_44,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG274028-ENG274289,Warping_matrix_static_tall-Block_45,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG274028-ENG274093,Warping_matrix_static_tall-Block_5,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG274028-ENG274094,Warping_matrix_static_tall-Block_6,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG274028-ENG274095,Warping_matrix_static_tall-Block_7,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG274028-ENG274096,Warping_matrix_static_tall-Block_8,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG274028-ENG274097,Warping_matrix_static_tall-Block_9,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
Elapsed Time: 00:34
blockmap-8128-1T3-919-451-G_WVG5WVEB2SH017765-20250325-1242.CSV
;SW:1T3-919-451-G   HW:1T3-919-451-G ---  Light line display
;Component:ID_Light_GA   033 0074, Coding:
;EV_SmartLight1MEBGA,001014,EV_SmartLight1MEBGA.rod
;Tuesday,25,March,2025,12:42:26:58926
;VCID: 3C2A5AE626E5C50A93E-8068-R SFD+SFD2
MAS18157-MAS18158,SFD activated status-Role of vehicle diagnostic to be protected,No activation active,
MAS18157-MAS18161,SFD activated status-Status of vehicle diagnostic to be protected,SFD individualization feature set,
MAS18157-MAS18164,SFD activated status-Duration of vehicle diagnostic to be protected,No activation active,
MAS18157-MAS18165,SFD activated status-Type of vehicle diagnostic to be protected,No activation active,
MAS20396,SFD protection procedure,SFD access protection and SFD end-to-end protection,
ENG310453-ENG310794,Integrity_data_animations-Checksum_movie_bundle_calculated_value,CE 29,
ENG310453-ENG310780,Integrity_data_animations-Checksum_movie_bundle_required_value,00 00,
Elapsed Time: 00:01
blockmap-C002-V04-007-003-LG_WVG5WVEB2SH017765-20250325-1242.CSV
;SW:V04-007-003-LG   HW: ---  SW Cluster Embedded
;Component:ICAS1 SWCL_Em 0254, Coding:
;EV_SWCLEmbed1ICAS1UNECE,001002,EV_SWCLEmbed1ICAS1UNECE_VWE3.rod
;Tuesday,25,March,2025,12:42:39:58926
;VCID: 77A085CA5F432652BEC-8022-R SFD+SFD2
IDE13835-MAS17093,VKMS: relevant VIN number for last data supply-Status of vehicle identification number,valid,
IDE13835-MAS17094,VKMS: relevant VIN number for last data supply-Vehicle identification number output,WVG5WVEB2SH017765,
IDE13836-MAS17095,VKMS: adaption counter-Adaptation counter status,valid,
IDE13836-MAS17096,VKMS: adaption counter-Adaptation counter output,00 01,
IDE13837-MAS17097,VKMS: overview missing keys-Key status,valid,
IDE13837-MAS17099,VKMS: overview missing keys-Number of missing keys,0,
IDE13837-MAS17100,VKMS: overview missing keys-Missing key,00 00,
IDE13842-MAS17101,VKMS: retrieval of information list of the stored VKMS keys-VKMS key status,valid,
IDE13842-MAS17103,VKMS: retrieval of information list of the stored VKMS keys-VKMS type ID,00 01,
IDE13842-MAS17104,VKMS: retrieval of information list of the stored VKMS keys-VKMS type adaptation counter,00 01,
IDE13842-MAS18318,VKMS: retrieval of information list of the stored VKMS keys-Number of VKMS keys,8,
IDE14492-MAS18388,Secure Onboard Communication: verification failed-Failed verification status,valid,
IDE14492-MAS18389,Secure Onboard Communication: verification failed-Number of failed verifications,0,
IDE14492-MAS18390,Secure Onboard Communication: verification failed-Verification failed,00 00,
IDE14493-MAS18360,Secure Onboard Communication: signatures failed-failed signature creation,00 00,
IDE14493-MAS18391,Secure Onboard Communication: signatures failed-Failed signature creation status,valid,
IDE14493-MAS18392,Secure Onboard Communication: signatures failed-Number of failed signature creations,0,
IDE14494-MAS18361,Secure Onboard Communication: general information-Status of general information,valid,
IDE14494-MAS18362,Secure Onboard Communication: general information-ECU function,SOC participant,
IDE14494-MAS18367,Secure Onboard Communication: general information-Main function call period,5,
IDE14495-MAS18369,Secure Onboard Communication: information about internal time-Internal SOC time status,valid,
IDE14495-MAS18370,Secure Onboard Communication: information about internal time-Validity of internal SOC time,Valid SOC time,
IDE14495-MAS18374,Secure Onboard Communication: information about internal time-Internal time,00 0D C0 1D 12 CA A4 86,
IDE14495-MAS18375,Secure Onboard Communication: information about internal time-Jitter test status,Jitter not exceeded,
IDE14496-MAS18378,Secure Onboard Communication: Freshness Values information-Freshness status,valid,
IDE14496-MAS18379,Secure Onboard Communication: Freshness Values information-Number of Freshness IDs,15,
IDE14496-MAS18380,Secure Onboard Communication: Freshness Values information-SOC PDU ID to which this freshness information is assigned,00 65,
IDE14496-MAS18381,Secure Onboard Communication: Freshness Values information-Freshness Value query status,Freshness Value was not queried,
IDE14496-MAS18384,Secure Onboard Communication: Freshness Values information-SOC time of last successful verification,FF FF FF FF FF FF FF FF,
IDE14496-MAS18385,Secure Onboard Communication: Freshness Values information-Current value of message counter,255,
IDE14496-MAS18386,Secure Onboard Communication: Freshness Values information-Bitfield with used counter values,11111111 11111111 ,
IDE14497-MAS17099,Secure Onboard Communication: missing key-Number of missing keys,0,
IDE14497-MAS17100,Secure Onboard Communication: missing key-Missing key,00 00,
IDE14497-MAS18387,Secure Onboard Communication: missing key-Missing key status,valid,
IDE15470-ENG279311,High-voltage charging manager: electricity rate price/performance tables-Byte to EOP,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 20,
IDE15476-MAS20827,High-voltage charging manager: preferred charging time 4-Preferred charging time active,not activated,
IDE15477-MAS20819,High-voltage charging manager: total energy requirement for charging planning-Target energy requirement,0.00, kWh
IDE15477-MAS20820,High-voltage charging manager: total energy requirement for charging planning-Minimum energy requirement,0.00, kWh
IDE15477-MAS20821,High-voltage charging manager: total energy requirement for charging planning-Maximum energy requirement,0.00, kWh
IDE15498-MAS00106,High-voltage charging manager: active charging timer-Year,0, yr
IDE15498-MAS00107,High-voltage charging manager: active charging timer-Month,0, Months
IDE15498-MAS00108,High-voltage charging manager: active charging timer-Day,Initialization,
IDE15498-MAS00109,High-voltage charging manager: active charging timer-Hours,0, H
IDE15498-MAS00110,High-voltage charging manager: active charging timer-Minutes,0, min
IDE15500,High-voltage charging manager: time slots of current charging plan,|Planned charging performance,duration|6.1965e+006
IDE15501,High-voltage charging manager: status of current charging plan creation,no request,
IDE15751-ENG279477,Energy requirement of individual components for charge planning-Hvlm_battery_power_demand,0.00, kWh
IDE15751-ENG279478,Energy requirement of individual components for charge planning-Hvlm_hv_components_power_demand,0.00, kWh
IDE15751-ENG279479,Energy requirement of individual components for charge planning-Hvlm_leakage_power_demand,0.00, kWh
IDE15751-ENG279480,Energy requirement of individual components for charge planning-Hvlm_nvem_power_demand,0.00, kWh
IDE15751-ENG279481,Energy requirement of individual components for charge planning-Hvlm_thermo_power_demand,0.00, kWh
MAS19234,Status of user-related refresh tokens,valid,
MAS19236-MAS00106,Expiration date of user-related refresh tokens-Year,2106,
MAS19236-MAS00107,Expiration date of user-related refresh tokens-Month,2,
MAS19236-MAS00108,Expiration date of user-related refresh tokens-Day,6,
MAS22353-MAS19235,Identify Authorize Authenticate - status-Back end (MBB) active user ID,Unknown (1869511021)
MAS22353-MAS19237,Identify Authorize Authenticate - status-Status of user-related safety pin in vehicle,Not assigned,
MAS22353-MAS19238,Identify Authorize Authenticate - status-Image reference value,00 00,
MAS22353-MAS19246,Identify Authorize Authenticate - status-Safety mode status,OFF,
MAS22353-MAS19256,Identify Authorize Authenticate - status-User-related instantaneous authentication stage,2,
MAS22353-MAS19257,Identify Authorize Authenticate - status-User role for active user,Anonymous guest user,
ENG279101-ENG279317,eMMC_budget_exceedance-Count_of_applications,No,
ENG279103-ENG395935,eMMC_statistics_classic-Count_of_partitions,3,
ENG279103,eMMC_statistics_classic,|ECU-ID,Bytes_in_partition_budget
ENG279103-ENG279522,eMMC_statistics_classic-Number_of_power_cycles,12583680,
ENG279103-ENG159701,eMMC_statistics_classic-operation_time,21,
Elapsed Time: 00:28
blockmap-C003-V04-007-003-LH_WVG5WVEB2SH017765-20250325-1243.CSV
;SW:V04-007-003-LH   HW: ---  SW Cluster Housekeeping
;Component:ICAS1 SWCL_HK 0254, Coding:
;EV_SWCLHouse1ICAS1UNECE,001002,EV_SWCLHouse1ICAS1UNECE.rod
;Tuesday,25,March,2025,12:43:32:58926
;VCID: 78A286F6525D292AB76-802C-R SFD+SFD2
IDE13842-MAS18318,VKMS: retrieval of information list of the stored VKMS keys-Number of VKMS keys,28,
Elapsed Time: 00:04
blockmap-OBD_WVG5WVEB2SH017765-20250325-1243.CSV
;33-OBD2
;Tuesday,25,March,2025,12:43:47:58926
04,Calculated load value,99.6 %,100.0 %
05,Engine coolant temperature,215 °C,215 °C
0C,Engine RPM,0 /min,0 /min
0D,Vehicle speed,0 km/h,0 km/h
1C,OBD Requirements Met,None
42,Control module voltage,14.804 V,14.757 V
49,Accelerator Pedal Position D,14.5 %,14.1 %
5B,Battery Pack Remain. Life,74.5 %
9A,Hybrid/EV data,---,BATT_V: 412.00 V
Type 02 - VIN : WVG5WVEB2SH017765 (Address 01)
Type 04 - Calibration ID : 0EA014GG3875EzJ6 (Address 01)
Type 04 - Calibration ID : N3059AA0853 (Address 03)
Type 04 - Calibration ID : 0Z1184AE11410000????????????????0Z1140BL1140BE6f0Z1140M 1140BE6e0Z1140M 1140BE6e0Z1140M 1140BE6e (Address 05)
Type 06 - Calibration Verification Number : 31279148 (Address 01)
Type 06 - Calibration Verification Number : F21EFB00 (Address 03)
Type 06 - Calibration Verification Number : 00000000 (Address 03)
Type 06 - Calibration Verification Number : 7AA92BF6 (Address 05)
Type 06 - Calibration Verification Number : 00000000 (Address 05)
Type 06 - Calibration Verification Number : 976986D0 (Address 05)
Type 06 - Calibration Verification Number : 453CFE57 (Address 05)
Type 0A - Controller Name : PCM-PowertrainCtrl (Address 01)
Type 0A - Controller Name : BBC--lecBrkBstCtrl- (Address 03)
Type 0A - Controller Name : BECM-B+EnergyCtrl (Address 05)
Type 17 - Vehicle Operation Data - Distance-Fuel Used, Recent/Lifetime:
         Total Distance Traveled : 189.3 km / 209.8 km
         Total Fuel Consumed : -0.01 L / -0.01 L
Jef
HQ
AutoScan: WVG5WVEB2SH017765
Tuesday,25,March,2025,12:43:57:58926
VCDS Version: 25.3.0.5 (x64)  HEX-NET2 CB: 0.4660.5
VIN: WVG5WVEB2SH017765   License Plate:
Chassis Type: EB-VNE4 (1EE)
Scan: 01 03 05 06 08 09 10 13 15 16 19 23 2B 36 3C 42 44 47 51 52
          5F 6C 6D 75 7E 8C A5 BE BF C0 C6 CA D6 D7 DE 8116 8123 8124 8125 8128
          C002 C003
VIN: WVG5WVEB2SH017765   Mileage: 209km-129miles
51-Electric Drive -- Status: Malfunction 0010
7E-Ctrl Head Dash -- Status: OK 0000
BE-Slid. Door Rear Left -- Status: OK 0000
BF-Slid. Door Rear Right -- Status: OK 0000
C0-Act. for Ext. Noise -- Status: Malfunction 0010
CA-Sunroof -- Status: OK 0000
D6-Light Ctrl Left 2 -- Status: Malfunction 0010
D7-Light Ctrl Right 2 -- Status: Malfunction 0010
8116-Snd enhanct 2 -- Status: OK 0000
8123-App server 1 system 1 adaptive -- Status: Malfunction 0010
8124-App server 1 system 2 Java -- Status: Malfunction 0010
8125-App server 3 system 1 infotaint. -- Status: Malfunction 0010
8128-Light line display -- Status: OK 0000
Address 01: Engine (J623----B)       Labels: None
   Part No SW: 0EA 906 014 GG    HW: 0EA 907 425 K
   Component: E-Vehicle     H80 3875
   Dataset Number: V03935424SD 0001 CVN: 31279148
   Coding: 4102000350042C0236000800000000000000000000000000
   ASAM Dataset: EV_VCU00XXX0200EA906014GG 003002
   ROD: EV_VCU00XXX020_VNE4.rod
   VINID: 9E65C59E65520A36000471C6142C9BD626
   Radiator shutter:
   Subsystem 1 - Part No SW: 1EA 965 501 B    HW: 1EA 965 501 B
   Component: V711           023 0008
   Serial number: 20241026060604067056
19854 - Steering Column Control Module
          U0212 00 {00100110} - No Communications
                    Mileage: 209 km
                    Date: 2025.03.25
                    Time: 16:12:17
                    Engine speed: 16383.75 /min
                    Normed load value: 100.0 %
                    Coolant temperature: 215 °C
                    Intake air temperature: 215 °C
                    Ambient air pressure: 2550 mbar
                    Voltage terminal 30: 14.882 V
                    LF_MVB_PDU_INTC_DIAG_8: 1
                    LF_MVB_PDU_INTC_DIAG_9: 0
                    LF_MVB_PDU_INTC_DIAG_10: 0
                    LF_MVB_PDU_INTC_DIAG_11: 0
                    LF_MVB_PDU_INTC_DIAG_18: 0
                    LF_MVB_PDU_INTC_DIAG_19: 0
                    LF_MVB_BUS_INTC_DIAG: 256
37944 - DC-DC Converter 1 for Electric Drive
          U0599 00 {00100000} - Implausible Signal
                    Reset counter: 36
                    Mileage: 20 km
                    Date: 2025.02.21
                    Time: 17:05:49
                    Voltage terminal 30: 13.144 V
                    Unlearning counter according OBD: 36
                    LF_MVB_PDU_INTC_DIAG_1: 0
                    LF_MVB_PDU_INTC_DIAG_2: 0
                    LF_MVB_PDU_INTC_DIAG_8: 0
                    LF_MVB_PDU_INTC_DIAG_22: 4096
                    LF_MVB_PDU_INTC_DIAG_23: 0
                    LF_MVB_PDU_INTC_DIAG_24: 0
                    LF_MVB_BUS_INTC_DIAG: 0
43491 - Communication Authentication
          U3035 00 {00100000} - Invalid Signal
          {Communication Authentication Signal Invalid Data}
                    Reset counter: 36
                    Mileage: 38 km
                    Date: 2025.02.24
                    Time: 19:34:33
                    Voltage terminal 30: 13.339 V
                    Driver intention torque: 0.0 Nm
                    PV: 0.00 %
                    LV_IGK: 00000000
                    Outside temperature: 21.0 °C
                    Driving position: P
                    Brake light switch status-actuated__activated: Not operated
                    Brake light switch status-Ident_32: 0
                    Hybrid batt charge cond act val standardized: 76.50 %
   Part No SW: 1EA 907 379 BQ    HW: 1EA 614 517 M
   Component: ESC-ZF_EBC470 H18 0754
   Serial number: 0000000         Dataset Number: V03935447PA 0001 CVN: CEBFB6
   Coding: 481044A8004159024217990000B79840250070614000
   ASAM Dataset: EV_BrakeZFESCMEBUNECE 001035
   ROD: EV_BrakeZFESCMEBUNECE_001_VWE3.rod
   VCID: 0D4CC7224DDF3C82F40-8058-R SFD+SFD2
Address 05: Acc/Start Auth. (J518)       Labels: 5WA-959-436.clb
   Part No SW: 5WA 959 436 N    HW: 5WA 959 436 N
   Component: Kessy IOBOX   122 0757
   Serial number: --------------- Dataset Number: V03935385FF 0001
   ASAM Dataset: EV_Kessy37w 005030
   ROD: EV_Kessy37w.rod
   VCID: 5F90CD6AD7B3FE12D6C-800A-R
   Part No SW: 1N3 959 760 H    HW: 1N3 959 760 H
   Component: MEM-BFS       011 0571
   Serial number: 24B0501KA02040 Dataset Number: V03935362VW 0001
   Coding: 0118B24000012A008803010121010000000000000000000000000000211000
   Shop #: WSC 00000 790 00032
   ASAM Dataset: EV_SCMPasseSideCONTIAU736 006013
   ROD: EV_SCMPasseSideCONTIAU736_VW42.rod
   VCID: 3E2E50EE30F9D71ABDA-806A-R
Address 08: Auto HVAC (J979)       Labels:* Redir Fail!
   Part No SW: 1N3 907 007 D    HW: 1N3 907 007 C
   Component: Climatronic   H01 0247
   Serial number: 222102400423250 Dataset Number: V03935439QZ 0001
   Coding: 013022207010120051102110111001102000102100201171000010000000
   ASAM Dataset: EV_ACClimaBHBE3ADV 002051
   ROD: EV_ACClimaBHBE3ADV_AUE3.rod
   VCID: 2D0C67A2ED9F5C82140-8078-R SFD+SFD2
   Interior temperature sensor:
   Subsystem 1 - Part No SW: 5WA 907 527 A    HW: 5WA 907 527 A
   Component: E857           H01 0103
   Serial number: 00001141024121929510
   Air quality sensor:
   Subsystem 2 - Part No SW: 5Q0 907 659 D    HW: 5Q0 907 659 D
   Component: G238 _AQS      H02 0003
   Serial number: 00000000000003685127
   Subsystem 3 - Part No SW: 3G0 963 345 C    HW: 3G0 963 345 C
   Component: SysNameFanLin  016 0103
   Serial number: ESEYSKC0136003
   Subsystem 4 - Part No SW: 3G0 963 345 D    HW: 3G0 963 345 D
   Serial number: ESEYSKD0073026
   Subsystem 5 - Part No SW: 3G0 963 345 C    HW: 3G0 963 345 C
   Serial number: ESEYSKC0126264
   Subsystem 6 - Part No SW: 3G0 963 345 D    HW: 3G0 963 345 D
   Serial number: ESEYSKD0073842
   A/C compressor sub:
   Subsystem 7 - Part No SW: 1N3 816 797 C    HW: 1N3 816 797 C
   Component: J842 EKK       H71 1411
   Serial number: 02200002103001
   Auxiliary Heater Control Module/PTC 2:
   Subsystem 8 - Part No SW: 1EA 963 581 E    HW: 1EA 963 581 E
   Component: 0123456789012  020 0172
   Serial number: T745647BA24320000170
   Subsystem 9 - Part No SW: 1EA 820 021 B    HW: 1EA 820 021 B
   Component: J126 J126      001 0001
   Serial number: 00000000000000002042
   Expansion valve 1 for refrigerant:
   Subsystem 10 - Part No SW: 1EA 816 590 B    HW: 1EA 816 590 B
   Component: N636 EV1_KaMi  H05 0002
   Serial number: 1575977
   Subsystem 11 - Part No SW: 4M0 959 603 J    HW: 4M0 959 603 J
   Component: G395 pT-Sens1  H20 0020
   Subsystem 12 - Part No SW: 7T0 907 049 A    HW: 7T0 907 049 A
   Component: E265 KPH GB    H02 0220
   Serial number: G08S01.10.2400970659
   Control module for heating element 1:
   Subsystem 13 - Part No SW: 1T3 959 772 A    HW: 1T3 959 772 A
   Component: LHR            H02 0107
   Serial number: 0245
   A/C control head right rear:
   Subsystem 14 - Part No SW: 7T0 907 049 A    HW: 7T0 907 049 A
   Serial number: G08S01.10.2400970665
   Auxiliary Heater Control Module/PTC 3:
   Subsystem 15 - Part No SW: 1N3 963 581     HW: 1N3 963 581
   Component: IDBUZZPTC      H04 0007
   Serial number: PR653007180724022401
523522 - Airbag Control Module
          C12D1 F3 {00100000} - Received Malfunction Value
          {Airbag control module Received malfunction value 2}
                    Mileage: 65 km
                    Date: 2025.02.27
                    Time: 20:16:05
   Part No SW: 1EE 937 089 C    HW: 1EE 937 089 A
   Component: SAM_H+        H08 0555
   Serial number: 01102422200796- Dataset Number: V03935462MK 0001
   ASAM Dataset: EV_SAMVW31x 006001
   ROD: EV_SAMVW31x_006_VWE3.rod
   VCID: 42D6241E4401B3FAD92-8016-R SFD
   Subsystem 1 - Part No SW: 1T3 955 119     HW: 1T3 955 119
   Component: FWISCHER_MYJT  003 0017
   Serial number: 909453F0302423603567
   Wiper motor control unit 2:
   Subsystem 2 - Part No SW: 1T3 955 120     HW: 1T3 955 120
   Component: FWISCHER_SL02  003 0017
   Serial number: 909353F0402423400890
   Subsystem 3 - Part No SW: 89A 955 555 C    HW: 89A 955 555 C
   Component: G397_RLFSS     004 0008
   Serial number: TTZ53529092400030071
   Subsystem 4 - Part No SW: 10A 941 193 N    HW: 10A 941 193 N
   Component: LiSi           H04 0515
   Serial number: RRB71525092400026425
   Subsystem 5 - Part No SW: 1T3 953 235 A    HW: 1T3 953 235 A
   Component: DiETa          H11 0029
   Serial number: LZH 8BS00142182XXXXX
   Subsystem 6 - Part No SW: 7T0 959 569 C    HW: 7T0 959 569 C
   Component: DACHKONSOLE    007 0013
   Serial number: 000000092661XJI00022
   Valve block 1 in front seat driver side:
   Subsystem 7 - Part No SW: 14A 881 643 A    HW: 14A 881 643 A
   Component: J873 MKS_FSv   H02 0353
   Serial number: 7009362241C243703458
   Valve block 1 in front seat passenger side:
   Subsystem 8 - Part No SW: 14A 881 643 A    HW: 14A 881 643 A
   Component: J872 MKS_BFSv  H02 0353
   Serial number: 7009362241C243900090
   Subsystem 9 - Part No SW: 2Q0 959 407     HW: 2Q0 959 163
   Component: FOND_FHSG_DRV  001 0007
   Serial number: 03020118411406240233
   Subsystem 10 - Part No SW: 2Q0 959 408     HW: 2Q0 959 164
   Component: FOND_FHSG_PSG  001 0007
   Serial number: 03020101341805240016
1074806 - Databus
          U1123 00 {00100000} - Received Error Message
          {ICAS1_Gateway Datenbus empfangener Fehlerwert}
                    Mileage: 179 km
                    Date: 2025.03.15
                    Time: 15:05:04
                    Terminal 15 status: OFF
                    Terminal 50 status: OFF
                    Status drive readiness: not ready to drive
                    Status of brake lamp switch: discrete: OFF
                    Brake lamp switch via CAN: status: OFF
                    Operating condition: Normal mode
                    Voltage: 13.1 V
                    Outside temperature: 15.5 °C
                    Light switch position: automatic
15401472 - Secure Onboard Communication
          U14FF 00 {01101100} - Signature Generation Failed
          {Sichere on-board Kommunikation: Signaturerstellung fehlgeschlagen}
                    Mileage: 22 km
                    Date: 2025.02.21
                    Time: 19:54:47
                    Voltage: 12.0 V
                    Outside temperature: 1.0 °C
8667507 - Databus
          U1121 00 {00101000} - Missing Message
          {BMS_07 Datenbus fehlende Botschaft}
                    Fault Frequency: 115
                    Mileage: 21 km
                    Date: 2025.02.21
                    Time: 18:25:39
                    Voltage: 12.4 V
                    Outside temperature: 12.0 °C
8667442 - Charging Socket Flap Contact Switch
          B1CEF 86 {00101000} - Signal Invalid
          {Ladeklappenkontaktschalter Signal unplausibel}
                    Fault Frequency: 102
                    Mileage: 21 km
                    Date: 2025.02.21
                    Time: 18:25:40
                    Voltage: 12.4 V
589829 - Window Regulator; Rear Driver Side
          B131F 54 {00101000} - Missing Calibration / Basic Setting
          {Driver side rear window regulator motor No basic setting}
                    Fault Frequency: 78
                    Mileage: 20 km
                    Date: 2025.02.21
                    Time: 17:06:24
                    Operating condition: Idle condition
                    Voltage: 0.0 V
                    Outside temperature: -50.0 °C
590341 - Window Regulator; Front Passenger Side
          B1320 54 {00101000} - Missing Calibration / Basic Setting
          {Passenger side rear window regulator motor No basic setting}
                    Fault Frequency: 78
                    Mileage: 20 km
                    Date: 2025.02.21
                    Time: 17:06:24
                    Voltage: 13.1 V
                    Outside temperature: 2.5 °C
   Part No SW: 1EE 919 300 B    HW: 1EE 919 300
   Component: RPA12K        H01 0630
   Serial number: 000020102494630 Dataset Number: V03935447DQ 0001
   Coding: 0230026041
   ASAM Dataset: EV_EPHBO3CVW4130000 001014
   ROD: EV_EPHBO3CVW4130000_VWE3.rod
   VCID: 333871DA0BBB0A72424-8066-R
1113328 - Parking Sensor(s); Front
          B10FC F0 {00100000} - Function Limitation due to External Factors
          {Geber für Einparkhilfe vorne - Funktionseinschränkung durch Umwelteinflüsse}
   Part No SW: 1EA 907 567 B    HW: 1EA 907 819
   Component: ARS512VW13    H05 0232
   Dataset Number: V03935436WW 0001
   Coding: 06230AE24071C04412574000008040052F4020000000000000000000000000
   ASAM Dataset: EV_FRONTRADARCONTIVW310 004013
   ROD: EV_FRONTRADARCONTIVW310_004_VWE3.rod
   VCID: 3B2859FA23EBC2329A4-806E-R SFD+SFD2
2092 - Databus
          U1122 00 {00101110} - Implausible Message
          {FAULT_QDISACC_FAIL}
                    Mileage: 209 km
                    Date: 2025.03.25
                    Time: 16:10:50
2068 - Databus
          U1123 00 {10101111} - Received Error Message
          {FAULT_TSK_IRREV_ERROR}
                    Mileage: 209 km
                    Date: 2025.03.25
                    Time: 16:12:17
1076 - Databus
          U1121 00 {00101110} - Missing Message
          {FAULT_TIMEOUT_GRA_ACC_01}
                    Mileage: 209 km
                    Date: 2025.03.25
                    Time: 16:10:42
Address 15: Airbags (J234)       Labels:* 3WA-959-655.clb
   Part No SW: 3WA 959 655 AA    HW: 3WA 959 655 AA
   Component: Airbag VW50   006 0151
   Revision: --------    Serial number: 003C0T5CNPYJD3 Dataset Number: V03935445XP 0001
   Coding: 8CCC0C0000FCC0000000002000000000A15450008100A200830036F8102B0065
   ASAM Dataset: EV_AirbaVW50TS6VW49X 001001
   ROD: EV_AirbaVW50TS6VW49X_VWE3.rod
   VCID: 147AD2466EF5ED4A3BE-8040-R SFD+SFD2
   Component: BF-Gewichtss.  H17 0022
   Serial number: IBH0000D24000NEBW30J
   Subsystem 2 - Part No SW: -----------    HW: 654 001 608 24
   Component: SideSensor_Df  010 0887
   Serial number: 3570000F55890D578A5J
   Subsystem 3 - Part No SW: -----------    HW: 654 002 307 24
   Component: SideSensor_Pf  010 0887
   Serial number: 3580000F1689422A623+
   Subsystem 4 - Part No SW: -----------    HW: 654 002 202 24
   Component: SideSensor_Dr  020 0148
   Serial number: 35100506AC9F6A96070I
   Subsystem 5 - Part No SW: -----------    HW: 654 002 202 24
   Component: SideSensor_Pr  020 0148
   Serial number: 35200507AC6BF796CA0Y
   Subsystem 6 - Part No SW: -----------    HW: 654 001 310 24
   Component: FrontSensor_D  030 010A
   Serial number: 3550050B4C74BE56C57U
   Subsystem 7 - Part No SW: -----------    HW: 654 001 310 24
   Component: FrontSensor_P  030 010A
   Serial number: 356005098C86459008BD
   Rear end impact crash sensor:
   Subsystem 8 - Part No SW: -----------    HW: 654 001 410 24
   Component: RearSensor_C_  030 010A
   Serial number: 3530050B4C74BE48648N
   Crash sensor for side airbag: B-pillar: driver side:
   Subsystem 9 - Part No SW: -----------    HW: 654 002 202 24
   Component: Side_Sens_B_D  020 0108
   Serial number: I0P005094C6BF79A47CP
   Crash sensor for side airbag: B-pillar: passenger side:
   Subsystem 10 - Part No SW: -----------    HW: 654 002 202 24
   Component: Side_Sens_B_P  020 0108
   Serial number: I0Q005074C9F6A89A6BR
   Seat occupancy detection 1:
   Subsystem 11 - Part No SW: 2K7 959 760 D    HW: 2K7 959 760 D
   Component: wSBR F-SG      037 0200
   Serial number:         94DC4E169F55
Address 16: Steering wheel (J527)       Labels: 1EE-953-507.clb
   Part No SW: 1EE 953 507 CH    HW: 1EE 953 507 CH
   Component: GSMMEB        005 0067
   Serial number: 000000301024477
   ASAM Dataset: EV_SMLSKLOGEN2 009005
   ROD: EV_SMLSKLOGEN2_009_VW41.rod
   VCID: 0358E11A1B9B7AF2924-8056-R SFD
Address 19: CAN Gateway (J533)       Labels: 1EE-937-012.clb
   Part No SW: 1EE 937 012 A    HW: 1EE 937 012
   Component: ICAS1 Host-SG 031 0254
   Serial number: SMERBG161024007 Dataset Number: V03935446DK 0001
   GVL: 2D0008001E0850FC806290C248181050C000200000000000000200000000C057
   ASAM Dataset: EV_GatewICAS1MEBUNECE 001004
   ROD: EV_GatewICAS1MEBUNECE_VWE3.rod
   VCID: 323674DEF4A1037A492-8066 SFD+SFD2
   Subsystem 1 - Part No SW: 1N3 915 181 A    HW: 1N3 915 181 A
   Component: J367-BDMConti  H05 1076
   Serial number: 7856800100240929020A
   Inverter for electrical outlet:
   Subsystem 2 - Part No SW: 5H0 907 155 A    HW: 5H0 907 155 A
   Component: Inverter       H05 0050
   Serial number: 5ZJSHFT1806240000375
   Subsystem 3 - Part No SW: 3G0 959 542 B    HW: 3G0 959 542 B
   Component: J IEEHOD1ZONE  251 0303
   Serial number: 00000000230601293947
   left tail lamp 1:
   Subsystem 4 - Part No SW: 1T3 945 207 F    HW: 1T3 945 207 F
   Component: SHLli1         040 5222
   Serial number: L0000202410311843328
   left tail lamp 2:
   Subsystem 5 - Part No SW: 1T3 945 307 F    HW: 1T3 945 307 F
   Component: SHLli2         071 5222
   Serial number: L0000202411150845054
   Right rear tail lamp 1:
   Subsystem 6 - Part No SW: 1T3 945 208 F    HW: 1T3 945 208 F
   Component: SHLre1         040 5222
   Serial number: R0000202410312052489
   Right rear tail lamp 2:
   Subsystem 7 - Part No SW: 1T3 945 307 F    HW: 1T3 945 307 F
   Component: SHLre2         071 5222
   Serial number: R0000202411150845067
   Virtual pedal door opening: rear driver side:
   Subsystem 8 - Part No SW: 3G0 962 243 F    HW: 3G0 962 243 F
   Component: VIP_SBT_FS     H18 0910
   Serial number: 67102990
   Virtual pedal door opening: rear passenger side:
   Subsystem 9 - Part No SW: 3G0 962 243 F    HW: 3G0 962 243 F
   Component: VIP_SBT_BFS    H18 0910
   Serial number: 67106224
   Subsystem 10 - Part No SW: 3G0 962 243 F    HW: 3G0 962 243 F
   Component: GEB.F.Heckoef  H18 0910
   Serial number: 67119830
8491266 - Secure Onboard Communication
          U14FE 00 {00101100} - Signature Verification Failed
          {SOK_signature_verification_failed}
                    Fault Frequency: 95
                    Mileage: 21 km
                    Date: 2025.02.21
                    Time: 18:15:07
8491267 - Secure Onboard Communication
          U14FF 00 {00100000} - Signature Generation Failed
          {SOK_signature_creation_failed}
                    Mileage: 20 km
                    Date: 2025.02.21
                    Time: 16:16:29
8511745 - Occupant Detection
          U173E 00 {00101000} - Function Restriction due to Implausible Message
          {Occupant_Presence_Service_Restriction}
                    Fault Frequency: 14
                    Mileage: 183 km
                    Date: 2025.03.19
                    Time: 15:52:56
90382 - Databus
          {Leistungsmodul für LED-Scheinwerfer rechts - Abblendlicht defekt}
                    Mileage: 188 km
                    Date: 2025.03.21
                    Time: 13:18:32
                    Terminal 15 status: On
                    Engine run: OFF
                    Voltage: 14.8 V
                    Outside temperature: 4.0 °C
8516873 - Charging Socket Flap A
          B1CA2 F1 {01100100} - Locking Activation Error
          {HVLM_control_flap_lock_locking_a}
                    Reset counter: 37
                    Mileage: 39 km
                    Date: 2025.02.27
                    Time: 17:27:51
8830976 - Databus for Virtual Remote Control Key
          U1A2F 00 {00101000} - Single Wire Mode
          {Data_bus_mdk_single_wire_mode}
                    Mileage: 22 km
                    Date: 2025.02.22
                    Time: 08:05:12
   Part No SW: 1N3 909 059 AA    HW: 1N3 909 059
   Component: EBB-ZF-Gen1   H47 0853
   Serial number: 0000000         Dataset Number: V03935435CY 0001
   Coding: A0404080600028
   ASAM Dataset: EV_BrakeBoostZFMEBUNECE 001034
   ROD: EV_BrakeBoostZFMEBUNECE.rod
   VCID: 74BAB2C64E354D4A9BE-8020-R SFD+SFD2
Address 2B: Steer. Col. Lock (J764)       Labels:. 3WA-905-861.clb
   Part No SW: 3WA 905 861     HW: 3WA 905 861
   Component: ELV-MQB_UNECE H05 0063
   Serial number: 24000262799015 Dataset Number: V03935384XW 0001
   Coding: 8880000000000000
   Shop #: WSC 00000 790 00532
   ASAM Dataset: EV_ELVMarqUNECE 003006
   ROD: EV_ELVMarqUNECE_003_VW27.rod
   VCID: 0842F63622BD59AAC76-805C-R SFD+SFD2
   Component: MEM-FS        011 0571
   Serial number: 24B0501KA02039 Dataset Number: V03935362VP 0001
   Coding: 0118BA4000013A008803010121010000000000000000000000000000215000
   ROD: EV_SCMDriveSideCONTIAU736_VW42.rod
Address 3C: Lane Change (J1086)       Labels:* Redir Fail!
   Part No SW: 2Q0 907 686 H    HW: 2Q0 907 686 H
   Component: HRE_Master    H26 0320
   Serial number: 14520059654591  Dataset Number: V03935416KP 0001
   Coding: 5A954750
   ASAM Dataset: EV_HREHellaGen3MstrUNECE 001001
   ROD: EV_HREHellaGen3MstrUNECE_VW27.rod
   VCID: 3FD02DEA37F3DE12B6C-806A-R
   Subsystem 1 - Part No SW: 2Q0 907 685 H    HW: 2Q0 907 685 H
   Component: HRE_Slave      H26 0320
   Serial number: 14520060253336
   Part No SW: 1EA 959 593 F    HW: 1EA 959 593 F
   Component: TSG FS        009 0563
   Serial number: 0000542453170  Dataset Number: V03935421ZA 0001
   Coding: 0035DB20D200028044000020
   ASAM Dataset: EV_DCU3DriveSideMAXHCONT 001004
   ROD: EV_DCU3DriveSideMAXHCONT_VWE3.rod
   VCID: 45DC3F02552F84C2FC0-8010-R
   Door operating panel: driver side:
   Subsystem 1 - Part No SW: 11A 959 862 C    HW: 11A 959 862 C
   Component: EX36 TBF_FS    H23 0116
   Serial number: 1383-23.10.24-------
   Part No SW: 1N3 907 144 Q    HW: 1N3 907 144 L
   Component: BASGEN1MQB37  131 7341
   Serial number: 01765164 Dataset Number: V03935435WK 0001
   Coding: 00000000000002010000020101000100000001000101
   ASAM Dataset: EV_SteerAssisBASGEN1MQB37 017078
   ROD: EV_SteerAssisBASGEN1MQB37.rod
   Part No SW: 3G0 035 466 F    HW: 3G0 035 466 F
   Component: AMPeth16CDoIP H03 7012
   Serial number: A1130N00028514  Dataset Number: V03935433MB 0001
   Coding: 24090100000000000000000000000000000000000000000000
   ASAM Dataset: EV_AMPEthMQB37w 001005
   ROD: EV_AMPEthMQB37w_VW38.rod
   VCID: 280296B6C27D79AAE76-807C-R SFD+SFD2
Address 51: Electric Drive (J841-ECN-)       Labels: 0ET-907-INV-V1.clb
   Part No SW: 0ET 907 121 G    HW: 0ET 907 121 G
   Component: MEB INV6.0    H10 7260
   Dataset Number: V03935396ZE 0001
   ASAM Dataset: EV_DMCM21000110ET907121G 001001
   ROD: EV_DMCM21000110ET907121G.rod
   VCID: 44DA22065E15BDCAEBE-8010-R SFD+SFD2
41631 - No Communication with ESP (Vehicle Dynamics) Control Module
          U0122 00 {00100000} - -
          {Lost Communication With Vehicle Dynamics Control Module}
41665 - No Communication with Engine Control Module (SAE ECM/PCM)
          U0100 00 {00101000} - -
          {Lost Communication with ECM/PCM}
                    Mileage: 21 km
                    Date: 2025.02.21
                    Time: 18:45:58
43408 - Online Remote Update
          U192A 00 {00101110} - No Signal
          {Online Remote UpdateNo signal}
                    Fault Frequency: 136
                    Mileage: 20 km
                    Date: 2025.02.21
                    Time: 17:06:25
   Part No SW: 1EA 959 592 F    HW: 1EA 959 592 F
   Component: TSG BFS       009 0563
   Serial number: 0000542154577  Dataset Number: V03935435GJ 0001
   Coding: 00355320DE00028040800020
   ASAM Dataset: EV_DCU3PasseSideMAXHCONT 001004
   ROD: EV_DCU3PasseSideMAXHCONT_VWE3.rod
   Part No SW: 10C 035 842 A    HW: 10C 035 842
   Component: IC3GSF--US    H09 3626
   Dataset Number: V03935418SE 0001
   Coding: 64101030000000000000000000000000000000000000000000
   ASAM Dataset: EV_MUICASSAFEPart 002001
   ROD: EV_MUICASSAFEPart_002_VNE4.rod
   VCID: 1B68B97A832BA2327A4-804E-R SFD+SFD2
   Subsystem 1 - Part No SW: 1T3 919 605 M    HW: 1T3 919 605 D
   Component: ABT-E3_13      H43 4045
   Serial number: CKS00718082411550163
   Part No SW: 1EE 907 556 A    HW: 5WA 907 556 D
   Component: TV eEntry     H32 0605
   Serial number: FZ6ESP231024000 Dataset Number: V03935441LX 0001
   Coding: 060300003F140000
   ASAM Dataset: EV_CamSysTVFicosUNECE 002004
   ROD: EV_CamSysTVFicosUNECE_VWE3.rod
   Front peripheral camera slave:
   Subsystem 1 - Part No SW: 5WA 980 546 E    HW: 5WA 980 546 D
   Component: R243 UmfKamSV  H23 0070
   Serial number: FCLMAR141024010822C1
   Peripheral camera slave: left:
   Subsystem 2 - Part No SW: 5WA 980 546 E    HW: 5WA 980 546 D
   Component: R244 UmfKamSL  H23 0070
   Serial number: FCLMAR30092400073E6D
   Right peripheral camera slave:
   Subsystem 3 - Part No SW: 5WA 980 546 E    HW: 5WA 980 546 D
   Component: R245 UmfKamSR  H23 0070
   Serial number: FCLMAR06102401045B8D
   Rear peripheral camera slave:
   Subsystem 4 - Part No SW: 5WA 980 546 E    HW: 5WA 980 546 D
   Component: R246 UmfKamSH  H23 0070
   Serial number: FCLMAR28102401070425
   Part No SW: 4KE 959 107 B    HW: 4KE 959 107 B
   Component: HDSG-Modul    H08 0342
   Revision: --------    Serial number: A2-C765-4922-2 Dataset Number: V03935420NU 0001
   Coding: 6208
   ASAM Dataset: EV_DeckLidCONTIAU536 001006
   ROD: EV_DeckLidCONTIAU536_001_VWE3.rod
   Part No SW: 14A 035 285 A    HW: 14A 035 285
   Component: OCU4MEB_UNECE H11 0554
   Serial number: 0000000407VIHJJ Dataset Number: V03935436CE 0001
   Coding: 06020700010000000000010013000000101112111012000010
   ASAM Dataset: EV_OCUGen4UNECE 001050
   ROD: EV_OCUGen4UNECE_VWE3.rod
   VCID: 1E6EB06E9039B71A9DA-804A-R SFD+SFD2
0082 - Databus
          U1121 00 {00100110} - Missing Message
          {Ethernet Databus missing message - Gateway}
                    Mileage: 209 km
                    Date: 2025.03.25
                    Time: 16:12:22
                    Voltage terminal 30: 14.6 V
1375744 - Secure Onboard Communication
          U14FE 00 {00100000} - Signature Verification Failed
                    Reset counter: 37
                    Mileage: 204 km
                    Date: 2025.03.22
                    Time: 19:00:20
1375488 - Secure Onboard Communication
          U14FD 00 {00101100} - Time Server not Available
          {SOK_timeserver_not_available}
Address 7E: Ctrl Head Dash (J1254)       Labels:| 10A-920-320.clb
   Part No SW: 10A 920 320 D    HW: 10A 920 320 D
   Component: FAHRERDISPLAY 031 0650
   Serial number: 4G1XF446-D05622 Dataset Number: V03935392XE 0001
   Coding: 267001
   ASAM Dataset: EV_DashBoardLGMEB 002032
   ROD: EV_DashBoardLGMEB_002_VWE3.rod
   VCID: 167EA84E7809FF5A45A-8042-R SFD
Address 8C: HV Battery (J840)       Labels: 0Z1-915-184.clb
   Part No SW: 0Z1 915 184 AE    HW: 0Z1 915 184 D
   Component: J840 K8C  BMC 010 1141
   Dataset Number: V03935430CT 0001
   ASAM Dataset: EV_BMCeVWBSMEB 003018
   ROD: EV_BMCeVWBSMEB_003_VWE3.rod
   VCID: 7DAC97E27D7F0C02E40-8028-R
   Cell module control module 1:
   Subsystem 1 - Part No SW: 0Z1 915 140 BL    HW: 0Z1 915 140 BC
   Component: SX6  X74  CMC  005 1140
   Serial number: 00000008102401020010
   Cell module control module 5:
   Subsystem 2 - Part No SW: 0Z1 915 140 M    HW: 0Z1 915 140 D
   Serial number: 00000018102401032858
   Cell module control module 9:
   Subsystem 3 - Part No SW: 0Z1 915 140 M    HW: 0Z1 915 140 D
   Serial number: 00000018102401032846
   Cell module control module 13:
   Subsystem 4 - Part No SW: 0Z1 915 140 M    HW: 0Z1 915 140 D
   Serial number: 00000018102401032849
   Coolant heating:
   Subsystem 5 - Part No SW: 1EE 963 231     HW: 1EE 963 231
   Component: J848 HV-PTC    H04 0026
   Serial number: 1EE96323124298001896
Address A5: Frt Sens. Drv. Assist (R242)       Labels:* 1EA-980-65X-V2.clb
   Part No SW: 1EA 980 653 E    HW: 1EA 980 653 A
   Component: MEB MFK 4.1   H08 5556
   Dataset Number: V03935445AY 0001
   Coding: 010A302E1F4500F83724301C4000000000000000000000000000000000000000
   ASAM Dataset: EV_MFK41ValeoMEB 001080
   ROD: EV_MFK41ValeoMEB_VWE3.rod
1124497 - Databus
          U1123 00 {00101111} - Received Error Message
          {ACC_18_ACC_Status_ACC_irreversibel_ERROR}
                    Mileage: 209 km
                    Date: 2025.03.25
                    Time: 16:12:18
1124496 - Databus
          U1123 00 {00101110} - Received Error Message
          {ACC_18_ACC_Status_ACC_reversibel_ERROR}
                    Mileage: 209 km
                    Date: 2025.03.25
                    Time: 16:10:43
1126421 - Databus
          {FAS_Anzeigen_01_KBI_Anzeigefehler_LDW_Anzeigefehler_ERROR}
                    Mileage: 209 km
                    Date: 2025.03.25
                    Time: 16:10:47
1126487 - Databus
          U1123 00 {00101000} - Received Error Message
          {Airbag_02_AB_Gurtschloss_Reihe3_FA_ERROR}
                    Mileage: 65 km
                    Date: 2025.02.27
                    Time: 20:16:05
Address BE: Slid. Door Rear Left (J926)       Labels:| 1N3-959-244.clb
   Part No SW: 1N3 959 244 B    HW: 1N3 959 244 B
   Component: Slidingdoor_d H04 0028
   Serial number: 97100269 Dataset Number: V03935426PK 1510
   Coding: D600
   ASAM Dataset: EV_SlideDoorDriveHufIDBuz 002110
   ROD: EV_SlideDoorDriveHufIDBuz_002.rod
   VCID: 353C4FC205CF14426C0-8060-R
32793 - Automatic Sliding Door Arrester
          B1BAC 19 {01100000} - Current Too High
          {Arrester_over_current}
32785 - Automatic Sliding Door Arrester
          B1BAC 11 {01100000} - Short to Ground
          {Arrester_short_circuit_to_ground}
Address BF: Slid. Door Rear Right (J927)       Labels:| 1N3-959-244.clb
   Component: Slidingdoor_p H04 0028
   Serial number: 97100519 Dataset Number: V03935426PL 1510
   Coding: D600
   ASAM Dataset: EV_SlideDoorPasseHufIDBuz 002110
   ROD: EV_SlideDoorPasseHufIDBuz_002.rod
37460 - Control Module for Sliding Door
          B1307 54 {01100000} - Missing Calibration / Basic Setting
          {Door_window_not_normalized}
Address C0: Act. for Ext. Noise (J943)       Labels: 1EA-035-335.clb
   Part No SW: 1T3 035 335 A    HW: 1EA 035 335
   Component: E_SOUND_SG    H06 0006
   Serial number: JTK072281024953
   ASAM Dataset: EV_ESounHarmaMEBUNECE 001006
   ROD: EV_ESounHarmaMEBUNECE_VWE3.rod
   VCID: 2C0A6AA6D685558A03E-8078-R
4194306 - Databus
          U1201 00 {00101110} - No Communications
          {data_bus_drivetrain_no_communication}
                    Mileage: 209 km
                    Date: 2025.03.25
                    Time: 16:12:41
Address C6: Batt. Chrg. (J1050)       Labels:| 1EA-915-692.clb
   Part No SW: 1EK 915 692 J    HW: 1EK 915 692 H
   Component: OCDC Gen4+    H03 2207
   Revision: 00H03000
   Coding: 308010
   ASAM Dataset: EV_OCDCXPHASERB8MEBB 002001
   ROD: EV_OCDCXPHASERB8MEBB_002_VWE3.rod
   VCID: 4BC8093A734B72B22A4-801E-R SFD+SFD2
Address CA: Sunroof (J245)       Labels:* None
   Part No SW: 14A 907 594 A    HW: 4K0 907 594
   Component: SAD_STG_1     011 0030
   Dataset Number: V03935394MS 0001
   Coding: 01000374180F
   ASAM Dataset: EV_SunRoofCONTIPO513 002004
   ROD: EV_SunRoofCONTIPO513.rod
   VCID: 290493B2D97740A2F88-807C-R
   Windshield tinting control module:
   Subsystem 1 - Part No SW: 85F 907 594 A    HW: 85F 907 594
   Component: J1288_SGD1CON  007 0030
   Serial number: 000009865610440
   Part No SW: 992 941 572 AG    HW: 992 941 572 A
   Component: LED1L         H17 9104
   ASAM Dataset: EV_LLPGen3LKEBODPO68X 002003
   ROD: EV_LLPGen3LKEBODPO68X_002_VW27.rod
   VCID: 6882D6B602FDB9AA276-803C-R
131329 - Databus
          U1201 00 {10101100} - No Communications
          {can data bus - no communication}
                    Mileage: 209 km
                    Date: 2025.03.25
                    Time: 16:12:35
131332 - Databus
          U1121 00 {10101100} - Missing Message
          {can message LED_Soll_Fkt2 missing}
                    Mileage: 209 km
                    Date: 2025.03.25
                    Time: 16:10:42
131347 - Databus
          {CAN message ESP_21 missing}
                    Mileage: 209 km
                    Date: 2025.03.25
                    Time: 16:10:42
131353 - Databus
          {CAN message Klemmen_Status_01 missing}
                    Mileage: 209 km
                    Date: 2025.03.25
                    Time: 16:10:42
   Component: LED1R         H17 9104
   ASAM Dataset: EV_LLPGen3RKEBODPO68X 002003
   ROD: EV_LLPGen3RKEBODPO68X_002_VW27.rod
131329 - Databus
                    Mileage: 209 km
                    Date: 2025.03.25
                    Time: 16:12:17
131332 - Databus
                    Mileage: 209 km
                    Date: 2025.03.25
                    Time: 16:10:42
131347 - Databus
                    Mileage: 209 km
                    Date: 2025.03.25
                    Time: 16:10:42
131353 - Databus
                    Mileage: 209 km
                    Date: 2025.03.25
                    Time: 16:10:42
139268 - Bulb for Low-Beam Headlamp
          C1198 FA {00101000} - Short Circuit
          {low beam - electric malfunction SC}
                    Reset counter: 34
                    Mileage: 188 km
                    Date: 2025.03.21
                    Time: 13:18:26
Address DE: Charger 1 for mobile dev (J0000)       Labels:* None
   Part No SW: 3P0 035 502 B    HW: 3P0 035 502
   Component: COUPLING BOX  004 0170
   Serial number: 324000000000059 Dataset Number: V03935426MT 0001
   Coding: 400080
   ASAM Dataset: EV_DualCouplBoxSK336 001006
   ROD: EV_DualCouplBoxSK336.rod
   VCID: 241A8286BE559DCACBE-8070-R SFD+SFD2
Address 8116: Snd enhanct 2 (J943)       Labels: None
   Part No SW: 1T3 035 335 B    HW: 1EA 035 335
   Component: E_SOUND_SG    H06 0007
   Serial number: JTK072291024953
   ASAM Dataset: EV_ESoun2HarmaMEBUNECE 001003
   ROD: EV_ESoun2HarmaMEBUNECE.rod
Address 8123: App server 1 system 1 adaptive (SWC4)       Labels: V04-007-XXX-SWC4.clb
   Part No: V04 007 003 LE
   Component: ICAS1 Sys_Ada 0254
   Dataset Number: V03935439BB 0001
   ASAM Dataset: EV_AppServ1Sys1ICAS1UNECE 001002
   ROD: EV_AppServ1Sys1ICAS1UNECE_VWE3.rod
   VCID: 75BC8FC2454F5442AC0-8020-R SFD+SFD2
Address 8124: App server 1 system 2 Java (SWC5)       Labels: V04-007-XXX-SWC5.clb
   Part No: V04 007 003 LF
   Component: ICAS1 Sys_Jav 0254
   Dataset Number: V03935439BA 0001
   ASAM Dataset: EV_AppServ1Sys2ICAS1UNECE 001002
   ROD: EV_AppServ1Sys2ICAS1UNECE_VWE3.rod
   VCID: 76BE88CE58495F5AA5A-8022-R SFD+SFD2
Address 8125: App server 3 system 1 infotaint. (SWC6)       Labels:| V04-007-XXX-SWC6.clb
   Part No: V04 007 003 RH
   Component: IC3GIVI-S--US 3626
   Dataset Number: V03935442BN 0001
   ASAM Dataset: EV_MUICASIVIPart 003001
   ROD: EV_MUICASIVIPart_003_VWE3.rod
   VCID: 7EAE90EE7079171AFDA-802A-R SFD+SFD2
Address 8128: Light line display (J145)       Labels: 1T3-919-451.clb
   Part No SW: 1T3 919 451 G    HW: 1T3 919 451 G
   Component: ID_Light_GA   033 0074
   ASAM Dataset: EV_SmartLight1MEBGA 001014
   ROD: EV_SmartLight1MEBGA.rod
Address C002: SW Cluster Embedded (SWC2)       Labels: V04-007-XXX-SWC2.clb
   Part No: V04 007 003 LG
   Component: ICAS1 SWCL_Em 0254
   Dataset Number: V03935439BG 0001
   ASAM Dataset: EV_SWCLEmbed1ICAS1UNECE 001002
   ROD: EV_SWCLEmbed1ICAS1UNECE_VWE3.rod
0268 - Software Cluster Embedded 1
          U1775 00 {00100110} - Software Error Detected
          {R7_Illegal_memory_access}
                    Date: 2025.03.25
8516625 - Expanded Charging Functions
          U15E9 00 {01101100} - Charging Plan Programming Error
                    Mileage: 179 km
                    Date: 2025.03.15
                    Time: 12:03:49
Address C003: SW Cluster Housekeeping (SWC3)       Labels: V04-007-XXX-SWC3.clb
   Part No: V04 007 003 LH
   Component: ICAS1 SWCL_HK 0254
   ASAM Dataset: EV_SWCLHouse1ICAS1UNECE 001002
   ROD: EV_SWCLHouse1ICAS1UNECE.rod
End----------(Elapsed Time: 31:27, VBatt start/end: 14.9V/14.8V)-----------
------------------------------43 Faults Found------------------------------
adpmap-01-0EA-906-014-GG_WVG5WVEB2SH017765-20250325-1218.CSV
;SW:0EA-906-014-GG   HW:0EA-907-425-K ---  Engine
;Component:E-Vehicle     H80 3875, Coding:4102000350042C0236000800000000000000000000000000
;EV_VCU00XXX0200EA906014GG,003002,EV_VCU00XXX020_VNE4.rod
;Tuesday,25,March,2025,12:18:34:58926
;VCDS Version: Release 25.3.0 (x64)  Data version: 20250311 DS365.0
IDE02248-Individually adjustable top speed limit,250.0 km/h,2
IDE06922-MAS00478-No-voltage display-Reserved,0 ,1
IDE06922-No-voltage display-,OFF ,1
IDE07159-MAS01155-Control module switch-off: counter-Control module,0 ,2
IDE07159-MAS05583-Control module switch-off: counter-Data bus,0 ,2
IDE07160-IDE15110-Control module switch-off: switch-off time-Coupling shut-off time: data bus with low-voltage energy management,Low-voltage energy management: coupling not available ,2
IDE07160-MAS00478-Control module switch-off: switch-off time-Reserved,0 ,2
IDE07160-MAS01155-Control module switch-off: switch-off time-Control module,Unknown (0),2
IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,15 min ,2
IDE07160-ENG99458-Control module switch-off: switch-off time-Reserved_2,0 ,2
MAS18081-MAS00478-Test Mode-Reserved,0 ,1
MAS18081-MAS21993-Test Mode-Return value idle bus,not active ,1
MAS18081-MAS21994-Test Mode-Veto,not active ,1
MAS18081-MAS21995-Test Mode-Suppress veto,not active ,1
MAS20849-IDE05560-Production mode: support-Wheel torque limitation,0 Nm,4
MAS20849-MAS01896-Production mode: support-Free run,not activated ,4
MAS20849-MAS07358-Production mode: support-Electric drive-readiness,Not blocked ,4
MAS20849-MAS14608-Production mode: support-speed limitation,0 km/h,4
Elapsed Time: 00:03
adpmap-03-1EA-907-379-BQ_WVG5WVEB2SH017765-20250325-1218.CSV
;SW:1EA-907-379-BQ   HW:1EA-614-517-M ---  ABS Brakes
;Component:ESC-ZF_EBC470 H18 0754, Coding:481044A8004159024217990000B79840250070614000
;EV_BrakeZFESCMEBUNECE,001035,EV_BrakeZFESCMEBUNECE_001_VWE3.rod
;Tuesday,25,March,2025,12:18:59:58926
;VCID: 0D4CC7224DDF3C82F40-8058-R SFD+SFD2
IDE00001-IDE01211-Production mode-Static current measuring mode,Deactivating ,3
IDE00001-IDE09543-Production mode-Vehicle holding function,Deactivating ,3
IDE00001-MAS18521-Production mode-Production mode: recuperation,Deactivating ,3
IDE00001-MAS24092-Production mode-Electromechanical parking brake button: long push,Deactivating ,3
IDE00001-MAS24093-Production mode-Switching off the control and sensor plausibility,Deactivating ,3
IDE00001-Production mode-,not active ,3
IDE00820-ENG376450-Activating and deactivating all development messages-Activation of Development Message Dynamischer Inhalt_1,not activated ,3
IDE00820-ENG376451-Activating and deactivating all development messages-Activation of Development Message Dynamischer Inhalt_2,not activated ,3
IDE00820-ENG376452-Activating and deactivating all development messages-Activation of Development Message Dynamischer Inhalt_3,not activated ,3
IDE00820-ENG376426-Activating and deactivating all development messages-Activation of Development Message EB_Basisdienste_01,not activated ,3
IDE00820-ENG264054-Activating and deactivating all development messages-Activation of Development Message EPB01,not activated ,3
IDE00820-ENG264055-Activating and deactivating all development messages-Activation of Development Message EPB02,not activated ,3
IDE00820-ENG264056-Activating and deactivating all development messages-Activation of Development Message ESC00,not activated ,3
IDE00820-ENG264057-Activating and deactivating all development messages-Activation of Development Message ESC01,not activated ,3
IDE00820-ENG264058-Activating and deactivating all development messages-Activation of Development Message ESC02,not activated ,3
IDE00820-ENG264059-Activating and deactivating all development messages-Activation of Development Message ESC03,not activated ,3
IDE00820-ENG264060-Activating and deactivating all development messages-Activation of Development Message ESC04,not activated ,3
IDE00820-ENG264061-Activating and deactivating all development messages-Activation of Development Message ESC05,not activated ,3
IDE00820-ENG264065-Activating and deactivating all development messages-Activation of Development Message ESC10,not activated ,3
IDE00820-ENG376462-Activating and deactivating all development messages-Activation of Development Message FDR_01,not activated ,3
IDE00820-ENG376463-Activating and deactivating all development messages-Activation of Development Message PBC_VDA_01,not activated ,3
IDE00820-ENG376464-Activating and deactivating all development messages-Activation of Development Message RKA_01,not activated ,3
IDE04456-Brake disk drying,Medium ,1
IDE04643-Overboost in brake system,activated ,1
IDE05055-Hydraulic brake assistant,normal ,1
IDE05057-Brake prefill,activated ,1
IDE07159-MAS05583-Control module switch-off: counter-Data bus,1 ,2
IDE07160-MAS01155-Control module switch-off: switch-off time-Control module,15 min ,2
IDE07292-Brake pre-filling,ended ,1
IDE11985-Expected OBD requirements,NO OBD ,1
IDE14225-IDE07280-Delay management-Multiple collision brake,activated ,2
IDE14225-IDE08968-Delay management-HV charge management,activated ,2
IDE14225-IDE11421-Delay management-Leaving concept,activated ,2
IDE14225-IDE11447-Delay management-electro-mechanical brake booster,activated ,2
IDE14225-IDE18029-Delay management-Rush Hour Pilot,not activated ,2
IDE14225-MAS00919-Delay management-Pedestrian protection,not activated ,2
IDE14225-MAS01090-Delay management-Transmission,not activated ,2
IDE14225-MAS05087-Delay management-ACC,activated ,2
IDE14225-MAS05129-Delay management-Motor,activated ,2
IDE14225-MAS05506-Delay management-Stopping distance reduction,activated ,2
IDE14225-MAS12321-Delay management-Trailer positioning assistant,not activated ,2
IDE14225-MAS15696-Delay management-Rear cross traffic assistant,activated ,2
IDE14225-MAS15806-Delay management-Parking assistant,activated ,2
IDE14225-MAS18082-Delay management-Emergency assistant,activated ,2
IDE14225-MAS18083-Delay management-Developer function imaginary participant 1,not activated ,2
IDE14225-MAS18084-Delay management-Developer function imaginary participant 2,not activated ,2
IDE16364-IDE16536-List of identifiers and data record numbers-Identifier,00 00 ,2
IDE16364-MAS25708-List of identifiers and data record numbers-Number Of Identifiers,0 ,2
MAS02080-XCP calibration protocol,not activated ,1
MAS03691-Dimming,not activated ,1
MAS14035-Precondition,Security access required,1
MAS22462-Drive shaft load counter,activated ,1
ENG264022-Developer_Function_01,00 00 ,2
ENG264035-Developer_Function_03-,not activated ,2
ENG264035-ENG264163-Developer_Function_03-Developer_Function_03_Bremsdrucksensor,not activated ,2
ENG264025-Developer_Function_04,5 ,1
ENG264021-Developer_Function_10,activated ,1
ENG122619-ENG135842-Developer_Function_109-HMS_Driver_Door_closed,Security access required,1
ENG122619-ENG135841-Developer_Function_109-HMS_Seatbelt_closed,Security access required,1
ENG125054-Developer_Function_110,Security access required,1
ENG139530-Developer_Function_111,Security access required,1
ENG281048-ENG281085-Developer_Function_114-Autohold_dimming_norminal_voltage,Security access required,1
ENG281048-ENG281086-Developer_Function_114-Autohold_dimmung_normalization_status,Security access required,1
ENG281048-ENG281073-Developer_Function_114-Electronic_park_brake_dimming_norminal_voltage,Security access required,1
ENG281048-ENG281082-Developer_Function_114-Electronic_park_brake_dimmung_normalization_status,Security access required,1
ENG364521-Developer_Function_115,Security access required,1
ENG122844-ENG264130-dimming_characteristic_1-Daempfung_Abdimmen_KL_58xD_PWM,0.10 s,23
ENG122844-ENG154584-dimming_characteristic_1-Daempfung_Aufdimmen_KL_58xd_PWM,0.20 s,23
ENG122844-ENG101574-dimming_characteristic_1-X1,0 ,23
ENG122844-ENG99557-dimming_characteristic_1-X2,10 ,23
ENG122844-ENG102140-dimming_characteristic_1-X3,50 ,23
ENG122844-ENG102936-dimming_characteristic_1-X4,100 ,23
ENG122844-ENG103548-dimming_characteristic_1-X5,150 ,23
ENG122844-ENG113992-dimming_characteristic_1-X6,220 ,23
ENG122844-ENG115661-dimming_characteristic_1-x7,253 ,23
ENG122844-ENG99777-dimming_characteristic_1-Y1,1.00 %,23
ENG122844-ENG100480-dimming_characteristic_1-Y2,1.00 %,23
ENG122844-ENG100773-dimming_characteristic_1-Y3,6.00 %,23
ENG122844-ENG100631-dimming_characteristic_1-Y4,10.00 %,23
ENG122844-ENG102174-dimming_characteristic_1-Y5,20.00 %,23
ENG122844-ENG113993-dimming_characteristic_1-Y6,60.00 %,23
ENG122844-ENG115665-dimming_characteristic_1-y7,100.00 %,23
ENG122845-ENG264130-dimming_characteristic_2-Daempfung_Abdimmen_KL_58xD_PWM,0.10 s,23
ENG122845-ENG154584-dimming_characteristic_2-Daempfung_Aufdimmen_KL_58xd_PWM,0.20 s,23
ENG122845-ENG101574-dimming_characteristic_2-X1,0 ,23
ENG122845-ENG99557-dimming_characteristic_2-X2,10 ,23
ENG122845-ENG102140-dimming_characteristic_2-X3,50 ,23
ENG122845-ENG102936-dimming_characteristic_2-X4,100 ,23
ENG122845-ENG103548-dimming_characteristic_2-X5,150 ,23
ENG122845-ENG113992-dimming_characteristic_2-X6,220 ,23
ENG122845-ENG115661-dimming_characteristic_2-x7,253 ,23
ENG122845-ENG99777-dimming_characteristic_2-Y1,1.00 %,23
ENG122845-ENG100480-dimming_characteristic_2-Y2,1.00 %,23
ENG122845-ENG100773-dimming_characteristic_2-Y3,6.00 %,23
ENG122845-ENG100631-dimming_characteristic_2-Y4,10.00 %,23
ENG122845-ENG102174-dimming_characteristic_2-Y5,20.00 %,23
ENG122845-ENG113993-dimming_characteristic_2-Y6,60.00 %,23
ENG122845-ENG115665-dimming_characteristic_2-y7,100.00 %,23
ENG264029-Dynamic_Developer_Function_01,General reject,23
ENG264027-Dynamic_Developer_Function_02,General reject,23
ENG264028-Dynamic_Developer_Function_03,General reject,23
ENG153885-MAS21993-Knockout_test_mode-Return value idle bus,not active ,1
ENG153885-MAS21994-Knockout_test_mode-Veto,not active ,1
ENG153885-MAS21995-Knockout_test_mode-Suppress veto,not active ,1
Elapsed Time: 00:13
adpmap-05-5WA-959-436-N_WVG5WVEB2SH017765-20250325-1219.CSV
;SW:5WA-959-436-N   HW:5WA-959-436-N ---  Acc/Start Auth.
;Component:Kessy IOBOX   122 0757, Coding:
;EV_Kessy37w,005030,EV_Kessy37w.rod
;Tuesday,25,March,2025,12:19:27:58926
;VCID: 5F90CD6AD7B3FE12D6C-800A-R
ENG253038-ENG258893-DevCod_ Search lights-Suchbeleuchtung_ZAT_bei_KL58_aktiv,activated ,5
ENG253038-ENG258265-DevCod_ Search lights-Suchbeleuchtung_ZAT_Beleuchtung_SES_Variante_aktiv,not activated ,5
ENG253038-ENG260629-DevCod_ Search lights-Suchbeleuchtung_ZAT_Normierung_aktiv,not activated ,5
ENG253038-ENG259779-DevCod_ Search lights-Suchbeleuchtung_ZAT_OpenLoadErkennung_aktiv,not activated ,5
ENG253038-ENG260681-DevCod_ Search lights-Suchbeleuchtung_ZAT_SES_Mode,not activated ,5
ENG253096-DevCod_AutomatischeFunktionen,activated ,6
ENG253395-ENG141964-DevCod_Fahrzeugkonfiguration-Steering alignment,Left ,5
ENG253395-ENG273785-DevCod_Fahrzeugkonfiguration-Transponding_Antennen_Strom_reduziert_aktiv,not active ,5
ENG253143-ENG258965-DevCod_Passive_EntryExit-Toggle-Datalogging_LFDebug_aktiv,not activated ,5
ENG253143-ENG258844-DevCod_Passive_EntryExit-Toggle-Gleichzeitiges_Senden_Innenraumantennen_aktiv,activated ,5
ENG129029-ENG259801-Easy_close_alignment-VIT_AktivTasteB,2.0 s,6
ENG129029-ENG259793-Easy_close_alignment-VIT_AktivTasteB_Zyklus,1.0 s,6
ENG253331-ENG258816-Par_Automatische_Funktionen-AutomatikFunktionen_Timeout,4320 min,10
ENG253331-ENG260182-Par_Automatische_Funktionen-AutomatikFunktionen_Zyklus_IDGeber_Anwesenheit,300 ms,10
ENG253220-IDE15282-Par_Bedienstellen-Door: driver control section: installation variant,0 ,36
ENG253220-IDE15283-Par_Bedienstellen-Door: front passenger control section: installation variant,0 ,36
ENG253220-IDE15284-Par_Bedienstellen-5th control section: installation variant,5 ,36
ENG253220-IDE15285-Par_Bedienstellen-Fuel filler cap control section: installation variant,5 ,36
ENG253220-IDE15286-Par_Bedienstellen-Rear driver side control section: installation variant,5 ,36
ENG253220-IDE15287-Par_Bedienstellen-Rear passenger side control section: installation variant,5 ,36
ENG253220-ENG259190-Par_Bedienstellen-Bedienstelle_Abschaltung_Timeout_5teT,4320 min,36
ENG253220-ENG259838-Par_Bedienstellen-Bedienstelle_Abschaltung_Timeout_BT,4320 min,36
ENG253220-ENG260574-Par_Bedienstellen-Bedienstelle_Abschaltung_Timeout_FT,0 min,36
ENG253220-ENG261264-Par_Bedienstellen-Bedienstelle_Abschaltung_Timeout_HBFS,4320 min,36
ENG253220-ENG258369-Par_Bedienstellen-Bedienstelle_Abschaltung_Timeout_HFS,4320 min,36
ENG253220-ENG258148-Par_Bedienstellen-Bedienstelle_Abschaltung_Timeout_Tank,3600 min,36
ENG253220-ENG261229-Par_Bedienstellen-Bedienstelle_Aktivierungsschwelle_Spielschutzzaehler,80 ,36
ENG253220-ENG259917-Par_Bedienstellen-Bedienstelle_Ausschaltzeit_Spielschutz_aktiv,1800 s,36
ENG253220-ENG261227-Par_Bedienstellen-Bedienstelle_Deaktivierung_SchwelleFahrendesFzg,20 km/h,36
ENG253220-ENG261134-Par_Bedienstellen-Bedienstelle_Deaktivierungsschwelle_Spielschutzzaehler,60 ,36
ENG253220-ENG258448-Par_Bedienstellen-Bedienstelle_MaxBetaetigung,120 s,36
ENG253220-ENG259922-Par_Bedienstellen-Bedienstelle_MaxKomfortUnterbrechung,10 ms,36
ENG253220-ENG261271-Par_Bedienstellen-Bedienstelle_MinAbschaltzeit_Reset_5teT,500 ms,36
ENG253220-ENG259320-Par_Bedienstellen-Bedienstelle_MinAbschaltzeit_Reset_BT,500 ms,36
ENG253220-ENG259918-Par_Bedienstellen-Bedienstelle_MinAbschaltzeit_Reset_FT,1500 ms,36
ENG253220-ENG260179-Par_Bedienstellen-Bedienstelle_MinAbschaltzeit_Reset_HBFS,500 ms,36
ENG253220-ENG260090-Par_Bedienstellen-Bedienstelle_MinAbschaltzeit_Reset_HFS,500 ms,36
ENG253220-ENG260565-Par_Bedienstellen-Bedienstelle_MinAbschaltzeit_Reset_Tank,500 ms,36
ENG253220-ENG261322-Par_Bedienstellen-Bedienstelle_MinBetaetigung_ToggleTaster,140 ms,36
ENG253220-ENG259707-Par_Bedienstellen-Bedienstelle_MinBetaetigung_Verriegelungssensor,140 ms,36
ENG253220-ENG258814-Par_Bedienstellen-Bedienstelle_Reaktivierung_SchwelleStehendesFzg,10 km/h,36
ENG253220-ENG258395-Par_Bedienstellen-Bedienstelle_Reduzierung_Zaehlerstand_Spielschutzzaehler,60 s,36
ENG253190-ENG258772-Par_Näherungssensoren-Naeherungssensor_MaxImpulslaenge_Diagnose,70 ms,35
ENG253190-ENG258701-Par_Näherungssensoren-Naeherungssensor_MaxImpulslaenge_Entry,10000 µs,35
ENG253190-ENG261026-Par_Näherungssensoren-Naeherungssensor_MaxImpulslaenge_Exit,40000 µs,35
ENG253190-ENG258968-Par_Näherungssensoren-Naeherungssensor_MaxImpulslaenge_Naeherung,20000 µs,35
ENG253190-ENG259906-Par_Näherungssensoren-Naeherungssensor_MaxPausenlaenge,10 ms,35
ENG253190-ENG260803-Par_Näherungssensoren-Naeherungssensor_MinImpulslaenge_Diagnose,42 ms,35
ENG253190-ENG259643-Par_Näherungssensoren-Naeherungssensor_MinImpulslaenge_Entry,6000 µs,35
ENG253190-ENG259840-Par_Näherungssensoren-Naeherungssensor_MinImpulslaenge_Exit,24000 µs,35
ENG253190-ENG259205-Par_Näherungssensoren-Naeherungssensor_MinImpulslaenge_Naeherung,12000 µs,35
ENG253190-ENG260098-Par_Näherungssensoren-Verzoegerung_PowerOn_Reset,1960 ms,35
ENG253285-ENG260495-Par_PassiveKomfort-Delay_Reichweitenbegrenzung_Start,0 ms,10
ENG253285-ENG260385-Par_PassiveKomfort-KomfortReichweitenbegr_Timout,75 s,10
ENG253285-ENG261013-Par_PassiveKomfort-PassiveKomfortFunktionen_MaxSignalisierungsdauer,60 s,10
ENG253285-ENG263587-Par_PassiveKomfort-PassiveKomfortFunktionen_Zeitfenster_fuer_Bedienhandlung,800 ms,10
ENG253285-ENG261279-Par_PassiveKomfort-Reichweitenbegrenzung_Zyklus,90 ms,10
ENG253106-ENG258919-Par_ScanStrategie_RetryHandling-anz_RetriesRegistering,1 Num,22
ENG253106-ENG259329-Par_ScanStrategie_RetryHandling-Erste_Warnschwelle_thermische_Überlast,45 °C,22
ENG253106-ENG259473-Par_ScanStrategie_RetryHandling-P2_Pause_zwischen_Transponding_Telegrammen,200 ms,22
ENG253106-ENG259392-Par_ScanStrategie_RetryHandling-Sperrzeit_LFTreiber_nach_thermischer_Ueberlast,5.0 s,22
ENG253106-ENG263515-Par_ScanStrategie_RetryHandling-t_CANSignalDelayAfterSleep,30 ms,22
ENG253106-ENG258479-Par_ScanStrategie_RetryHandling-t_LFDebug_Nachsignaslisierung,100 ms,22
ENG253106-ENG263591-Par_ScanStrategie_RetryHandling-Temperaturschaltschwelle_LF_Wavetable,100 °C,22
ENG253106-ENG276176-Par_ScanStrategie_RetryHandling-Timeout_Grundwert_RetryRegistering,57 ms,22
ENG253106-ENG276194-Par_ScanStrategie_RetryHandling-Timeout_Inkrementwert_RetryRegistering,7 ms,22
ENG253106-ENG261110-Par_ScanStrategie_RetryHandling-Verzoegerung_LFSenden_nach_Weckleitungziehen,0 ms,22
ENG253106-ENG260133-Par_ScanStrategie_RetryHandling-Zweite_Warnschwelle_thermische_Überlast,65 °C,22
ENG253086-MAS18911-Passive_Komfort-Convenience closing by locking using door handle active,activated ,5
ENG253086-ENG280093-Passive_Komfort-Noise_filter_aktiv,activated ,5
ENG253086-ENG261176-Passive_Komfort-Passive_Komfort_Oeffnen_aktiv,not activated ,5
ENG253086-ENG259864-Passive_Komfort-Passive_Komfort_Togglen_aktiv,not activated ,5
ENG253352-ENG259594-Suchbeleuchtung_StartStop_Taster-PWM_Daempfung_Abdimmen,1.0 ,30
ENG253352-ENG259617-Suchbeleuchtung_StartStop_Taster-PWM_Daempfung_Aufdimmen,2.0 ,30
ENG253352-ENG261228-Suchbeleuchtung_StartStop_Taster-Suchbeleuchtung_ZAT_ausschalten_KL15,10 min,30
ENG253352-ENG258605-Suchbeleuchtung_StartStop_Taster-Suchbeleuchtung_ZAT_ErsteStuetzstelle_0Prozent_Dimmkurve,0.0 %,30
ENG253352-ENG258785-Suchbeleuchtung_StartStop_Taster-Suchbeleuchtung_ZAT_ErsteStuetzstelle_Deltawert_50Prozent_Dimmkurve,50.0 %,30
ENG253352-ENG263542-Suchbeleuchtung_StartStop_Taster-Suchbeleuchtung_ZAT_Fehlerdimmwert,80 %,30
ENG253352-ENG260556-Suchbeleuchtung_StartStop_Taster-Suchbeleuchtung_ZAT_Nennspannung,13.0 V,30
ENG253352-ENG258781-Suchbeleuchtung_StartStop_Taster-Suchbeleuchtung_ZAT_OffsetDimmwert,1.0 ,30
ENG253352-ENG259791-Suchbeleuchtung_StartStop_Taster-Suchbeleuchtung_ZAT_ZweiteStuetzstelle_Deltawert_100Prozent_Dimmkurve,100.0 %,30
ENG253287-ENG261242-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_DritteStuetzstelle_Wert50_Dimmkurve_SES1,10.0 %,32
ENG253287-ENG260274-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_DritteStuetzstelle_Wert50_Dimmkurve_SES2,3.0 %,32
ENG253287-ENG258981-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_ErsteStuetzstelle_Wert1_Dimmkurve_SES1,5.0 %,32
ENG253287-ENG260137-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_ErsteStuetzstelle_Wert1_Dimmkurve_SES2,2.0 %,32
ENG253287-ENG259846-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_FuenfteStuetzstelle_Wert220_Dimmkurve_SES1,80.0 %,32
ENG253287-ENG261362-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_FuenfteStuetzstelle_Wert220_Dimmkurve_SES2,20.0 %,32
ENG253287-ENG258809-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_Offset_1,0 %,32
ENG253287-ENG258501-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_Offset_2,0 %,32
ENG253287-ENG260497-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_Peak_Max_1,80 %,32
ENG253287-ENG258157-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_Peak_Max_2,100 %,32
ENG253287-ENG261138-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_SechsteStuetzstelle_Wert253_Dimmkurve_SES1,100.0 %,32
ENG253287-ENG258211-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_SechsteStuetzstelle_Wert253_Dimmkurve_SES2,30.0 %,32
ENG253287-ENG261183-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_SEs_2_faktor,0.1 ,32
ENG253287-ENG259175-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_SEs_2_Offset,2.0 Num,32
ENG253287-ENG261051-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_t1_Fall_OFF,740 ms,32
ENG253287-ENG260479-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_t1_Pause_OFF,0 ms,32
ENG253287-ENG258704-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_t1_Pause_ON,0 ms,32
ENG253287-ENG260922-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_t1_Rise_ON,100 ms,32
ENG253287-ENG260304-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_t2_Fall_OFF,1600 ms,32
ENG253287-ENG258413-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_t2_Pause_OFF,0 ms,32
ENG253287-ENG260729-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_t2_Pause_ON,0 ms,32
ENG253287-ENG258296-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_t2_Rise_ON,100 ms,32
ENG253287-ENG258477-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_VierteStuetzstelle_Wert100_Dimmkurve_SES1,15.0 %,32
ENG253287-ENG259506-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_VierteStuetzstelle_Wert100_Dimmkurve_SES2,4.0 %,32
ENG253287-ENG258902-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_ZweiteStuetzstelle_Wert10_Dimmkurve_SES1,5.0 %,32
ENG253287-ENG260830-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_ZweiteStuetzstelle_Wert10_Dimmkurve_SES2,2.0 %,32
Elapsed Time: 00:06
adpmap-06-1N3-959-760-H_WVG5WVEB2SH017765-20250325-1220.CSV
;SW:1N3-959-760-H   HW:1N3-959-760-H ---  Seat Mem. Pass
;Component:MEM-BFS       011 0571, Coding:0118B24000012A008803010121010000000000000000000000000000211000
;EV_SCMPasseSideCONTIAU736,006013,EV_SCMPasseSideCONTIAU736_VW42.rod
;Tuesday,25,March,2025,12:20:03:58926
;VCID: 3E2E50EE30F9D71ABDA-806A-R
IDE00001-MAS10850-Production mode-Deactivate massage function,not active ,3
IDE00001-MAS18842-Production mode-Assembly mode,not active ,3
IDE00820-MAS02165-Activating and deactivating all development messages-Group 1,not active ,1
IDE00820-MAS02166-Activating and deactivating all development messages-Group 2,not active ,1
IDE00820-MAS05859-Activating and deactivating all development messages-Group 3,not active ,1
IDE00820-MAS05860-Activating and deactivating all development messages-Group 4,not active ,1
IDE00820-MAS05861-Activating and deactivating all development messages-Group 5,not active ,1
IDE00820-MAS05862-Activating and deactivating all development messages-Group 6,not active ,1
IDE00820-MAS05863-Activating and deactivating all development messages-Group 7,not active ,1
IDE00820-MAS05864-Activating and deactivating all development messages-Group 8,not active ,1
IDE02854-Reset standardization,all ,3
IDE03066-Reset counter for compressor for multicontour seat,Activate ,1
IDE06869-installation position,Front passenger side memory seat ,1
ENG309783-slp_logging,not active ,1
ENG123066-vehicle_velocity_monitoring,active ,1
Elapsed Time: 00:18
adpmap-08-1N3-907-007-D_WVG5WVEB2SH017765-20250325-1221.CSV
;SW:1N3-907-007-D   HW:1N3-907-007-C ---  Auto HVAC
;Component:Climatronic   H01 0247, Coding:013022207010120051102110111001102000102100201171000010000000
;EV_ACClimaBHBE3ADV,002051,EV_ACClimaBHBE3ADV_AUE3.rod
;Tuesday,25,March,2025,12:21:07:58926
;VCID: 2D0C67A2ED9F5C82140-8078-R SFD+SFD2
IDE00001-ENG128289-Production mode-Air_condition_compressor_deactivate,not active ,3
IDE00001-ENG128290-Production mode-Battery_cooling_and_heating_deactivate,not active ,3
IDE00001-ENG128291-Production mode-ClearResetEmissionRelated-DiagnosticInformation_Mode$04,not active ,3
IDE00001-ENG369640-Production mode-ProductionByte_0,0 ,3
IDE00001-ENG369641-Production mode-ProductionByte_2,0 ,3
IDE00036-Vehicle equipment code,Variant 1 ,1
IDE01067-Retention of driver's seat heater level,active for 10 minutes ,1
IDE01476-Store air recirculation setting with terminal 15 OFF,Service life-dependent store ,1
IDE01479-Gear ratio of engine - A/C compressor,1.62 ,1
IDE01482-After-run of parking heater or parking ventilation,activated ,1
IDE01483-Blower voltage with voice control,not activated ,1
IDE01488-Auxiliary heating retrofit without CAN,not installed ,1
IDE01493-Sensitivity of air quality sensor,Medium ,1
IDE01503-Running time of basic setting for compressor break-in,60 s,1
IDE01536-Post heating of auxiliary heating,10 ,1
IDE02371-Time until seat heating performance is reduced from stage 3 to stage 2,0 min,1
IDE02372-Time until seat heating performance is reduced from stage 2 to stage 1,0 min,1
IDE02744-IDE15865-Steering wheel heating-NTC target temperature stage 1 (Steering Wheel: Heated),45 °C,10
IDE02744-IDE15866-Steering wheel heating-NTC target temperature stage 2 (Steering Wheel: Heated),50 °C,10
IDE02744-IDE15867-Steering wheel heating-NTC target temperature stage 3 (Steering Wheel: Heated),60 °C,10
IDE02744-IDE15868-Steering wheel heating-PI controller I factor (Steering Wheel: Heated),0.50 ,10
IDE02744-IDE15869-Steering wheel heating-PI controller P factor (Steering Wheel: Heated),25 ,10
IDE02744-IDE15870-Steering wheel heating-Offset I controller target temperature (Steering Wheel: Heated),5 °C,10
IDE02744-IDE15871-Steering wheel heating-Maximum temperature (Steering Wheel: Heated),65 °C,10
IDE02744-IDE15872-Steering wheel heating-NTC static timeout (Steering Wheel: Heated),10 min,10
IDE02744-IDE15873-Steering wheel heating-Load mode timeout (Steering Wheel: Heated),10 min,10
IDE02744-IDE15874-Steering wheel heating-Automatic heating pad configuration (Steering Wheel: Heated),1 ms,10
IDE02744-IDE20215-Steering wheel heating-LIN SCSM installed,not activated ,10
IDE03176-Duration of compressor run in,40 s,1
IDE04074-Driving program,installed ,1
IDE04927-IDE01446-Window heater-Running time of heated front window,0 s,10
IDE04927-MAS12610-Window heater-Activation of wiper arm heater,4.0 °C,10
IDE04927-ENG263527-Window heater-Config_heating_voltage_request,No_set_point_voltage ,10
IDE04927-ENG263525-Window heater-Heating_rear_window_activation_time,320 s,10
IDE04927-ENG263512-Window heater-Heating_rear_window_cutoff_temperature,35.00 °C,10
IDE04927-ENG263556-Window heater-Heating_rear_window_temperature_activation_time,active ,10
IDE04927-ENG263570-Window heater-Window_heating_front_activation_time_pause,320 s,10
IDE04927-ENG263505-Window heater-Window_heating_front_cutoff_temperature,-50.00 °C,10
IDE04927-ENG263589-Window heater-Window_heating_front_maximum_temperature_activation_time,1800 s,10
IDE04927-ENG263529-Window heater-Window_heating_front_temperature_activation_time,not active ,10
IDE06089-ENG263584-Seat heater level current consumption allocation-Config_seat_heating_high_voltage_request,Sollspannungsanforderung 14.7 ,17
IDE06089-ENG263533-Seat heater level current consumption allocation-Config_seat_heating_low_voltage_request,Keine Spannungsanforderung ,17
IDE06089-ENG263526-Seat heater level current consumption allocation-Seat_heating_correction_of_temperature_regulation_on_heat_flow,0.0 °C,17
IDE06089-ENG263552-Seat heater level current consumption allocation-Seat_heating_filter_constant_for_heat_flow,1 s,17
IDE06089-ENG263578-Seat heater level current consumption allocation-Seat_heating_offset_voltage,15.7 V,17
IDE06089-ENG263544-Seat heater level current consumption allocation-Seat_heating_stage_1_lower_threshold,22.0 °C,17
IDE06089-ENG263507-Seat heater level current consumption allocation-Seat_heating_stage_1_upper_threshold,23.00 °C,17
IDE06089-ENG263592-Seat heater level current consumption allocation-Seat_heating_stage_2_lower_threshold,22.00 °C,17
IDE06089-ENG263559-Seat heater level current consumption allocation-Seat_heating_stage_2_upper_threshold,23.00 °C,17
IDE06089-ENG263539-Seat heater level current consumption allocation-Seat_heating_stage_3_lower_threshold,35.50 °C,17
IDE06089-ENG263554-Seat heater level current consumption allocation-Seat_heating_stage_3_upper_threshold,36.00 °C,17
IDE06089-ENG263536-Seat heater level current consumption allocation-Seat_heating_stage_4_lower_threshold,35.50 °C,17
IDE06089-ENG263549-Seat heater level current consumption allocation-Seat_heating_stage_4_upper_threshold,36.00 ,17
IDE06089-ENG263566-Seat heater level current consumption allocation-Seat_heating_stage_5_lower_threshold,52.50 ,17
IDE06089-ENG263597-Seat heater level current consumption allocation-Seat_heating_stage_5_upper_threshold,53.00 ,17
IDE06089-ENG263562-Seat heater level current consumption allocation-Seat_heating_stage_6_lower_threshold,52.50 °C,17
IDE06089-ENG263524-Seat heater level current consumption allocation-Seat_heating_stage_6_upper_threshold,53.00 ,17
IDE06544-Speed shut-off threshold for compressor break-in (engine speed),3000 l/min,1
IDE06545-Blower voltage for production routines,6.00 V,1
IDE06547-Air distribution for production routines,Air distribution top and footwell ,1
IDE06593-Air recirculation for production routines,Fresh air ,1
IDE07108-A/C styles,No display ,1
IDE07160-MAS01155-Control module switch-off: switch-off time-Control module,15 s,2
IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,15 s,2
IDE07398-Blower logic with manual adjustment,Fan setting: absolute ,1
IDE07418-Additional filter,not installed ,1
IDE07585-Hand heater function during cold start,active ,1
IDE07865-Automatic activation of front windshield defroster at MAX-Defrost,active ,1
IDE07948-Retention of frt.pass. seat heater level,active for 10 minutes ,1
IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne,30 %,12
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz,30 %,12
IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne,30 %,12
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz,30 %,12
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne,50 %,12
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz,50 %,12
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne,50 %,12
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz,50 %,12
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne,75 %,12
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz,75 %,12
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne,85 %,12
IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz,80 %,12
IDE10118-Fan speed reduction for telephony,activated ,1
IDE11425-Rear blower logic: for manual adjustment,Matching coding ,1
IDE11426-Rear blower voltage: for voice activation,not activated ,1
IDE11427-Rear blower voltage: for production routines,6.00 V,1
IDE11428-Rear air distribution: for production routines,No effect ,1
IDE11631-MAS13043-Remaining run-time of the cooling circuit deaeration-Circuit 1,1200.0 s,2
IDE11631-MAS13044-Remaining run-time of the cooling circuit deaeration-Circuit 2,1200.0 s,2
IDE11935-Personalization,activated ,1
IDE12110-ENG154832-Rear seat fan: characteristic curve-Level_1_seat_backrest,0 %,12
IDE12110-ENG154833-Rear seat fan: characteristic curve-Level_1_seat_cushion,0 %,12
IDE12110-ENG154834-Rear seat fan: characteristic curve-Level_2_seat_backrest,0 %,12
IDE12110-ENG154835-Rear seat fan: characteristic curve-Level_2_seat_cushion,0 %,12
IDE12110-ENG154836-Rear seat fan: characteristic curve-Level_3_seat_backrest,0 %,12
IDE12110-ENG154837-Rear seat fan: characteristic curve-Level_3_seat_cushion,0 %,12
IDE12110-ENG154838-Rear seat fan: characteristic curve-Level_4_seat_backrest,0 %,12
IDE12110-ENG154839-Rear seat fan: characteristic curve-Level_4_seat_cushion,0 %,12
IDE12110-ENG154840-Rear seat fan: characteristic curve-Level_5_seat_backrest,0 %,12
IDE12110-ENG154841-Rear seat fan: characteristic curve-Level_5_seat_cushion,0 %,12
IDE12110-ENG154842-Rear seat fan: characteristic curve-Level_6_seat_backrest,0 %,12
IDE12110-ENG154843-Rear seat fan: characteristic curve-Level_6_seat_cushion,0 %,12
IDE12229-Filtering of interior air: store,Service life-dependent store ,1
IDE13371-Interior humidity sensor: sensitivity,Medium ,1
IDE14087-Time until seat heat recovery within the maximum level,0 min,1
IDE15635-Number of interruptions permitted during compressor run-in,10 ,1
IDE16364-IDE16536-List of identifiers and data record numbers-Identifier,0 ,2
IDE16800-Pre-ventilation: coding override,not active ,1
IDE17680-IDE16487-Coolant: fill level detection-CO2 overfill detection,not active ,1
IDE17680-MAS14106-Coolant: fill level detection-CO2: low fill level detection,not active ,1
IDE18112-Auxiliary heater: runtime,short ,1
IDE18376-MAS03179-Adjustment of the schedule table-Local data bus 2,2 s,4
IDE18376-MAS03180-Adjustment of the schedule table-Local data bus,3 s,4
IDE18376-MAS05972-Adjustment of the schedule table-Local data bus 3,2 s,4
IDE18376-MAS06525-Adjustment of the schedule table-Local data bus 4,3 s,4
IDE18376-MAS06526-Adjustment of the schedule table-Local data bus 5,0 ,4
IDE18376-MAS06527-Adjustment of the schedule table-Local data bus 6,1 s,4
IDE18376-MAS14771-Adjustment of the schedule table-Local data bus 7,2 s,4
IDE18376-MAS19909-Adjustment of the schedule table-Local data bus 8,0 s,4
IDE19964-ENG387656-Assignment of current consumption for rear seat heating stages-Seat_heating_rear_stage_1_lower_threshold,22.00 °C,17
IDE19964-ENG387657-Assignment of current consumption for rear seat heating stages-Seat_heating_rear_stage_1_upper_threshold,23.00 °C,17
IDE19964-ENG387658-Assignment of current consumption for rear seat heating stages-Seat_heating_rear_stage_2_lower_threshold,22.00 °C,17
IDE19964-ENG387659-Assignment of current consumption for rear seat heating stages-Seat_heating_rear_stage_2_upper_threshold,23.00 °C,17
IDE19964-ENG387660-Assignment of current consumption for rear seat heating stages-Seat_heating_rear_stage_3_lower_threshold,35.50 °C,17
IDE19964-ENG387661-Assignment of current consumption for rear seat heating stages-Seat_heating_rear_stage_3_upper_threshold,36.00 °C,17
IDE19964-ENG387662-Assignment of current consumption for rear seat heating stages-Seat_heating_rear_stage_4_lower_threshold,36.00 °C,17
IDE19964-ENG387663-Assignment of current consumption for rear seat heating stages-Seat_heating_rear_stage_4_upper_threshold,52.50 °C,17
IDE19964-ENG387664-Assignment of current consumption for rear seat heating stages-Seat_heating_rear_stage_5_lower_threshold,52.50 °C,17
IDE19964-ENG387665-Assignment of current consumption for rear seat heating stages-Seat_heating_rear_stage_5_upper_threshold,53.00 °C,17
IDE19964-ENG387666-Assignment of current consumption for rear seat heating stages-Seat_heating_rear_stage_6_lower_threshold,52.50 °C,17
IDE19964-ENG387667-Assignment of current consumption for rear seat heating stages-Seat_heating_rear_stage_6_upper_threshold,53.00 °C,17
IDE80009-Analysis 9,not activated ,1
IDE80010-Analysis 10,not activated ,1
IDE80011-Analysis 11,not activated ,1
MAS01651-Display and control unit: rear,Temperature ,1
MAS05214-Steering wheel heating,long_push ,1
MAS06414-Temperature tuning,colder tuning cooling operation ,1
MAS06415-Blower adjustment,Tuning with more air in cooling operation ,1
MAS06416-Blower display in auto operation,not activated ,1
MAS06417-Amplified overshoots heater operation,not activated ,1
MAS19886-Interior temperature sensor: after-run time,180 s,2
MAS22844-Hill descent mode,active ,1
SFT00117-Emergency call module and communication unit,installed ,1
ENG263483-AC_evaporator_temperature_offset,-0.50 K,1
ENG276128-air_recirculation_deactivate_at_open_sunroof,not activated ,1
ENG316722-AP_Clima_Master_FL_Setup,87 10 20 00 A7 10 A4 0C 07 00 02 00 00 00 37 0D 07 00 02 00 00 00 37 0D ,24
ENG316723-AP_Clima_Zone1_FL_Setup,15 04 20 09 17 3C 20 0B 07 00 00 C0 74 56 07 07 00 00 C0 74 56 07 00 00 00 00 00 00 7E 01 00 00 00 00 00 00 00 00 00 00 ,40
ENG316724-AP_Clima_Zone2_FL_Setup,00 00 00 00 15 14 20 00 00 00 00 00 00 00 00 06 00 00 C0 74 55 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,40
ENG316725-AP_SIH_FL_Setup,05 00 03 00 00 00 00 00 00 C5 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,25
ENG316726-AP_Steering_wheel_heating,03 25 25 00 00 00 00 00 00 00 ,10
ENG316727-AP_Windowheater,C0 00 00 00 00 00 00 00 00 00 00 00 00 ,13
ENG263479-Auto-Toggle,not activated ,1
ENG263474-ENG263585-Development_Messages_Mode_Activation-General_Messages,0 ,18
ENG263474-ENG263519-Development_Messages_Mode_Activation-LIN_1_Messages,0 ,18
ENG263474-ENG263517-Development_Messages_Mode_Activation-LIN_2_Messages,0 ,18
ENG263474-ENG263537-Development_Messages_Mode_Activation-LIN_3_Messages,0 ,18
ENG263474-ENG263573-Development_Messages_Mode_Activation-LIN_4_Messages,0 ,18
ENG263474-ENG263548-Development_Messages_Mode_Activation-LIN_5_Messages,0 ,18
ENG263474-ENG263518-Development_Messages_Mode_Activation-LIN_6_Messages,0 ,18
ENG263474-ENG263550-Development_Messages_Mode_Activation-LIN_7_Messages,0 ,18
ENG263474-ENG263508-Development_Messages_Mode_Activation-LIN_8_Messages,0 ,18
ENG263440-Entwicklungs-ID für Entwicklungszwecke freischalten,0 ,2
ENG153885-Knockout_test_mode,0 ,1
ENG263490-manuel_air_recirculation_deacivate_AUTO_mode,activated ,1
ENG263452-OnBoardDiagnose für Entwicklungszwecke freischalten,not activated ,1
ENG279929-ENG280096-pms_data_to_hmi-papam_pms_inside,No display ,2
ENG279929-ENG280097-pms_data_to_hmi-papam_pms_outside,No display ,2
ENG263450-seat_dependent_climatisation,activated_with_responce ,1
ENG263443-seatheatin_function_switch,AUTO_seatheating_function ,1
ENG263458-winterfunction,not installed ,1
Elapsed Time: 00:23
adpmap-09-1EE-937-089-C_WVG5WVEB2SH017765-20250325-1222.CSV
;SW:1EE-937-089-C   HW:1EE-937-089-A ---  Cent. Elect.
;Component:SAM_H+        H08 0555, Coding:
;EV_SAMVW31x,006001,EV_SAMVW31x_006_VWE3.rod
;Tuesday,25,March,2025,12:22:32:58926
;VCID: 42D6241E4401B3FAD92-8016-R SFD
UNK286125-Headlight beam adjusting motors,front_and_rear ,1
IDE00001-ENG116710-Production mode-Frontwischer deaktivieren,not active ,3
IDE00001-ENG302747-Production mode-P_Mode_FH_Kl15_aus_aktiv,not active ,3
IDE00001-ENG302748-Production mode-P_Mode_FH_Reversierschwelle,not active ,3
IDE00001-ENG259333-Production mode-pa_ambiente_aussenlicht_pmode,not active ,3
IDE00001-ENG258242-Production mode-pa_auto_abschaltung_pmode,not active ,3
IDE00001-ENG260387-Production mode-pa_sitzpneumatik_pmode,not active ,3
IDE01550-Service position,156.999844 °,2
IDE02711-ENG112304-Rear wiper-Heckwischer,1Draht_Heckwischer ,8
IDE02711-ENG258487-Rear wiper-Heckwischer_Kaltstart,Heckwischerstopp bei Wiederstart und Erststart ,8
IDE02711-ENG289598-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall LSS AUS,10 s,8
IDE02711-ENG261056-Rear wiper-Modus_Heckintervall,statische Intervallpausenzeit ,8
IDE02711-ENG259069-Rear wiper-Rueckfahrwischen_Temp,OFF ,8
IDE02711-ENG116691-Rear wiper-Traenenwischen Heck,active ,8
IDE05534-ENG116609-Headlamp washer system-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,5 ,7
IDE05534-ENG115769-Headlamp washer system-SRA bei Waschwassermangel,active ,7
IDE05534-ENG115767-Headlamp washer system-SRA Einweichpausenzeit,0 ms,7
IDE05534-ENG115768-Headlamp washer system-SRA Nachwaschzeit,0 ms,7
IDE05534-ENG116611-Headlamp washer system-SRA Pausenzeit,10000 ms,7
IDE05534-ENG258416-Headlamp washer system-SRA Untersetzung Init,0 ,7
IDE05534-ENG116610-Headlamp washer system-SRA Verzoegerungszeit,0 ms,7
IDE05534-ENG115766-Headlamp washer system-SRA Waschzeit,2000 ms,7
IDE07160-MAS01155-Control module switch-off: switch-off time-Control module,70 min,2
IDE07356-Position during interval mode,6.703290 °,2
IDE08577-Garage door opener: use of GPS data,No Response From Subnet Component,2
IDE08578-Garage door opener: bi-directional communic.,No Response From Subnet Component,2
IDE08579-Garage door opener: drift adapt.,No Response From Subnet Component,2
IDE08580-Garage door opener: increasing transm. power,No Response From Subnet Component,2
IDE08583-Garage door opener: no. of channels,No Response From Subnet Component,2
IDE08584-MAS07165-Garage door opener: freq. selection-Frequency range A,No Response From Subnet Component,2
IDE08584-MAS07166-Garage door opener: freq. selection-Frequency range B,No Response From Subnet Component,2
IDE08584-MAS07167-Garage door opener: freq. selection-Frequency range C,No Response From Subnet Component,2
IDE08584-MAS07168-Garage door opener: freq. selection-Frequency range D,No Response From Subnet Component,2
IDE08584-MAS07169-Garage door opener: freq. selection-Frequency range E,No Response From Subnet Component,2
IDE08584-MAS07170-Garage door opener: freq. selection-Frequency range F,No Response From Subnet Component,2
IDE08584-MAS07171-Garage door opener: freq. selection-Frequency range G,No Response From Subnet Component,2
IDE08584-MAS07172-Garage door opener: freq. selection-Frequency range H,No Response From Subnet Component,2
IDE08584-MAS07173-Garage door opener: freq. selection-Frequency range I,No Response From Subnet Component,2
IDE08584-MAS07174-Garage door opener: freq. selection-Frequency range J,No Response From Subnet Component,2
IDE08584-MAS07175-Garage door opener: freq. selection-Frequency range K,No Response From Subnet Component,2
IDE08584-MAS09302-Garage door opener: freq. selection-Frequency range US-I,No Response From Subnet Component,2
IDE08584-MAS09303-Garage door opener: freq. selection-Frequency range US-II,No Response From Subnet Component,2
IDE08584-MAS09304-Garage door opener: freq. selection-Frequency range US-III,No Response From Subnet Component,2
IDE08584-MAS09305-Garage door opener: freq. selection-Frequency range US-IV,No Response From Subnet Component,2
IDE08584-MAS10461-Garage door opener: freq. selection-Frequency range AB,No Response From Subnet Component,2
IDE08585-Garage door opener: activation via remote key,No Response From Subnet Component,2
IDE08778-Garage door opener: surround. target area,No Response From Subnet Component,2
IDE09377-IDE00761-Multi contour seat driver's side-Run-on time,600 s,5
IDE09377-IDE03006-Multi contour seat driver's side-Running time of massage function,0 s,5
IDE09377-IDE03007-Multi contour seat driver's side-Component location,Driver side ,5
IDE09377-IDE03099-Multi contour seat driver's side-Characteristics for manual seat adjustment,Open circuit ,5
IDE09377-IDE03100-Multi contour seat driver's side-Characteristics for seat adjustment using memory,Open circuit ,5
IDE09378-IDE00761-Multicontour seat passenger side-Run-on time,600 s,5
IDE09378-IDE03006-Multicontour seat passenger side-Running time of massage function,0 s,5
IDE09378-IDE03007-Multicontour seat passenger side-Component location,Front passenger side ,5
IDE09378-IDE03099-Multicontour seat passenger side-Characteristics for manual seat adjustment,Open circuit ,5
IDE09378-IDE03100-Multicontour seat passenger side-Characteristics for seat adjustment using memory,Open circuit ,5
IDE09546-Multicontour seat on driver's side: reset compressor counter,Activate ,1
IDE09547-Multicontour seat on frt. pass. side: reset compressor counter,Activate ,1
IDE09548-Multicontour seat on driver's side: reset adaptation,Activate ,1
IDE09549-Multicontour seat on frt. pass. side: reset adaptation,Exhaust Malfunction Indicator Lamp (MIL) (OBD) ,1
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz,25 %,12
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz,25 %,12
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne,58 %,12
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz,53 %,12
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne,58 %,12
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz,53 %,12
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne,85 %,12
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz,80 %,12
IDE10298-Alternating park position 1,0.000000 °,2
IDE10299-Alternating park position 2,0.000000 °,2
IDE10308-Garage door opener: support door name,No Response From Subnet Component,2
IDE10349-MAS10436-Garage door opener: Default/Fix kit mode-Default mode,No Response From Subnet Component,2
IDE10349-MAS10437-Garage door opener: Default/Fix kit mode-Fixkit mode: button 1,No Response From Subnet Component,2
IDE10349-MAS10438-Garage door opener: Default/Fix kit mode-Fixkit mode: button 2,No Response From Subnet Component,2
IDE10349-MAS10439-Garage door opener: Default/Fix kit mode-Fixkit mode: button 3,No Response From Subnet Component,2
IDE10350-Garage door opener: programming antenna,No Response From Subnet Component,2
IDE12119-Garage door opener: frequency range of bi-directional communication,No Response From Subnet Component,2
IDE12120-Garage door opener: piloted parking,No Response From Subnet Component,2
IDE12121-Garage door opener: vehicle variant,No Response From Subnet Component,2
IDE12122-Garage door opener: continuous transmission mode for level measurement,No Response From Subnet Component,2
IDE12302-SFT00022-Identification of sub-bus participant-Steering Column Electronics,old ,6
IDE12302-SFT271873-Identification of sub-bus participant-Wiper motor control module,old ,6
IDE12302-SFT271874-Identification of sub-bus participant-Rain/Light Recognition Sensor,old ,6
IDE12302-SFT271875-Identification of sub-bus participant-Light switch,old ,6
IDE12302-SFT271876-Identification of sub-bus participant-Garage door opener control module,old ,6
IDE12302-SFT271894-Identification of sub-bus participant-Anti-theft alarm system sensor,old ,6
IDE12302-SFT271896-Identification of sub-bus participant-Alarm horn,old ,6
IDE12302-SFT271909-Identification of sub-bus participant-left tail lamp 1,old ,6
IDE12302-SFT271910-Identification of sub-bus participant-Roof electronics control module,old ,6
IDE12302-SFT271947-Identification of sub-bus participant-Humidity sensor: interior,old ,6
IDE12302-SFT271948-Identification of sub-bus participant-Rear Driver Side Door Control Module,old ,6
IDE12302-SFT271949-Identification of sub-bus participant-Rear Passenger Door Control Module,old ,6
IDE12302-SFT271950-Identification of sub-bus participant-Rear lid opener control module,New ,6
IDE12302-SFT271966-Identification of sub-bus participant-Left head area heater,old ,6
IDE12302-SFT271967-Identification of sub-bus participant-Right head area heater,old ,6
IDE12302-SFT272014-Identification of sub-bus participant-Control head for driving and comfort functions,New ,6
IDE12302-SFT272057-Identification of sub-bus participant-Valve block 1 in front seat driver side,old ,6
IDE12302-SFT272061-Identification of sub-bus participant-Valve block 1 in front seat passenger side,old ,6
IDE12302-SFT272065-Identification of sub-bus participant-Blower 1 for left front backrest,old ,6
IDE12302-SFT272067-Identification of sub-bus participant-Blower 1 for left front seat cushion,old ,6
IDE12302-SFT272069-Identification of sub-bus participant-Blower 1 for right front backrest,old ,6
IDE12302-SFT272071-Identification of sub-bus participant-Blower 1 for right front seat cushion,old ,6
IDE12302-SFT272121-Identification of sub-bus participant-Control unit 2 for driving and convenience functions,old ,6
IDE12302-SFT272142-Identification of sub-bus participant-left tail lamp 2,old ,6
IDE12302-SFT272143-Identification of sub-bus participant-Right rear tail lamp 1,old ,6
IDE12302-SFT272144-Identification of sub-bus participant-Right rear tail lamp 2,old ,6
IDE12302-SFT272221-Identification of sub-bus participant-Radio receiver for remote start,old ,6
IDE12302-SFT272238-Identification of sub-bus participant-Wiper motor control unit 2,old ,6
IDE12302-SFT272272-Identification of sub-bus participant-Virtual pedal door opening: rear driver side,old ,6
IDE12302-SFT272286-Identification of sub-bus participant-Virtual pedal door opening: rear passenger side,old ,6
IDE15901-Direct entry keys,installed ,2
IDE18030-Charging socket flap collision protection,active ,4
IDE19169-Adaptation for Over-the-Air Update guard function,not active ,2
IDE80007-ENG125682-Analysis 7-s_GrobleckerkennungDauer,255 s,5
IDE80007-ENG125680-Analysis 7-s_LatenzzeitHaengenderTaster,60 s,5
IDE80007-ENG125681-Analysis 7-s_Leckageerkennung,255 ,5
IDE80007-ENG125678-Analysis 7-s_UeberspannungsSschwelle,16 V,5
IDE80007-ENG125679-Analysis 7-s_UnterspannungsSchwelle,9 V,5
IDE80008-ENG125684-Analysis 8-s_DruckschwelleNachlauf,3 hPa,30
IDE80008-ENG126855-Analysis 8-s_Maximaldruck_LRD_m,270 hPa,30
IDE80008-ENG126854-Analysis 8-s_Maximaldruck_LRD_o,280 hPa,30
IDE80008-ENG126856-Analysis 8-s_Maximaldruck_LRD_u,240 hPa,30
IDE80008-ENG126857-Analysis 8-s_Maximaldruck_Sitzlehnenwangen,65535 hPa,30
IDE80008-ENG126863-Analysis 8-s_Maximaldruck_Ueberlastschutz,65535 hPa,30
IDE80008-ENG126862-Analysis 8-s_Maximaler_Differenzdruck_LRD_Vor_Zurueck,10 hPa,30
IDE80008-ENG126859-Analysis 8-s_Minimaldruck_LRD_m,0 hPa,30
IDE80008-ENG126858-Analysis 8-s_Minimaldruck_LRD_o,0 hPa,30
IDE80008-ENG126860-Analysis 8-s_Minimaldruck_LRD_u,0 hPa,30
IDE80008-ENG259691-Analysis 8-s_Minimaldruck_LRD_vertikal,65535 hPa,30
IDE80008-ENG126864-Analysis 8-s_Minimaldruck_Massage,0 hPa,30
IDE80008-ENG126861-Analysis 8-s_MinimaldruckSitzlehnenwangen,65535 hPa,30
IDE80008-ENG125683-Analysis 8-s_ZieldruckDerSitzlehnenwangenBeiPreCrash,65535 hPa,30
IDE80012-ENG125693-Analysis 12-s_DauerFuerGrobleckerkennung,255 s,5
IDE80012-ENG125680-Analysis 12-s_LatenzzeitHaengenderTaster,60 s,5
IDE80012-ENG125681-Analysis 12-s_Leckageerkennung,255 ,5
IDE80012-ENG125678-Analysis 12-s_UeberspannungsSschwelle,16 V,5
IDE80012-ENG125679-Analysis 12-s_UnterspannungsSchwelle,9 V,5
IDE80013-ENG126871-Analysis 13-s_Druckschwelle_Nachlauf,3 hPa,30
IDE80013-ENG126855-Analysis 13-s_Maximaldruck_LRD_m,270 hPa,30
IDE80013-ENG126854-Analysis 13-s_Maximaldruck_LRD_o,280 hPa,30
IDE80013-ENG126856-Analysis 13-s_Maximaldruck_LRD_u,240 hPa,30
IDE80013-ENG126857-Analysis 13-s_Maximaldruck_Sitzlehnenwangen,65535 hPa,30
IDE80013-ENG126863-Analysis 13-s_Maximaldruck_Ueberlastschutz,65535 hPa,30
IDE80013-ENG126870-Analysis 13-s_Maximaler_Differenzdruck_LRD_VorZurueck,10 hPa,30
IDE80013-ENG126859-Analysis 13-s_Minimaldruck_LRD_m,0 hPa,30
IDE80013-ENG126858-Analysis 13-s_Minimaldruck_LRD_o,0 hPa,30
IDE80013-ENG126860-Analysis 13-s_Minimaldruck_LRD_u,0 hPa,30
IDE80013-ENG259691-Analysis 13-s_Minimaldruck_LRD_vertikal,65535 hPa,30
IDE80013-ENG126864-Analysis 13-s_Minimaldruck_Massage,0 hPa,30
IDE80013-ENG126869-Analysis 13-s_Minimaldruck_Sitzlehnenwangen,65535 hPa,30
IDE80013-ENG125683-Analysis 13-s_ZieldruckDerSitzlehnenwangenBeiPreCrash,65535 hPa,30
IDE80015-ENG126865-Analysis 15-s_Kompressorleistung_Manuelle_Befuellung_LRD,100 %,6
IDE80015-ENG126867-Analysis 15-s_Kompressorleistung_Manueller_Befuellung_Seitenwangen,255 %,6
IDE80015-ENG126866-Analysis 15-s_Kompressorleistung_Memorisierte_Befuellung_LRD,80 %,6
IDE80015-ENG126868-Analysis 15-s_Kompressorleistung_Memorisierte_Befuellung_Seitenwangen,255 %,6
IDE80015-ENG125690-Analysis 15-s_VerzoegerungszeitKompressoranlauf,65535 ms,6
IDE80016-Analysis 16,10 s,1
IDE80017-ENG133471-Analysis 17-Offset_PB1_LM,0 hPa,64
IDE80017-ENG133470-Analysis 17-Offset_PB1_LO,0 hPa,64
IDE80017-ENG133472-Analysis 17-Offset_PB1_LU,0 hPa,64
IDE80017-ENG133473-Analysis 17-Offset_PB1_SH,0 hPa,64
IDE80017-ENG133475-Analysis 17-Offset_PB2_LM,0 hPa,64
IDE80017-ENG133474-Analysis 17-Offset_PB2_LO,0 hPa,64
IDE80017-ENG133476-Analysis 17-Offset_PB2_LU,0 hPa,64
IDE80017-ENG133477-Analysis 17-Offset_PB2_SH,0 hPa,64
IDE80017-ENG289601-Analysis 17-Offset_PP1,0 %,64
IDE80017-ENG289602-Analysis 17-Offset_PP2,0 %,64
IDE80017-ENG133483-Analysis 17-Offset_PV1_LM,0 ms,64
IDE80017-ENG133482-Analysis 17-Offset_PV1_LO,0 ms,64
IDE80017-ENG133484-Analysis 17-Offset_PV1_LU,0 ms,64
IDE80017-ENG133485-Analysis 17-Offset_PV1_SH,0 ms,64
IDE80017-ENG133486-Analysis 17-Offset_PV2_LO,0 ms,64
IDE80017-ENG133488-Analysis 17-Offset_PV2_LU,0 ms,64
IDE80017-ENG133489-Analysis 17-Offset_PV2_SH,0 ms,64
IDE80017-ENG289603-Analysis 17-Offset_T1,0 °C,64
IDE80017-ENG289604-Analysis 17-Offset_T2,0 °C,64
IDE80017-ENG133487-Analysis 17-OffsetPV2_LMy,0 ms,64
IDE80017-ENG133490-Analysis 17-p_function_feedback_timeout,0 ms,64
IDE80017-ENG133491-Analysis 17-p_longpush_time,0 ms,64
IDE80017-ENG133497-Analysis 17-p_stoesselSchaltschwelle_eins,255 %,64
IDE80017-ENG133498-Analysis 17-p_stoesselSchaltschwelle_zwei,255 %,64
IDE80017-ENG133494-Analysis 17-p_tasterSchaltschwelle_drei,45 %,64
IDE80017-ENG133492-Analysis 17-p_tasterSchaltschwelle_eins,66 %,64
IDE80017-ENG133496-Analysis 17-p_tasterSchaltschwelle_fuenf,20 %,64
IDE80017-ENG133495-Analysis 17-p_tasterSchaltschwelle_vier,24 %,64
IDE80017-ENG133493-Analysis 17-p_tasterSchaltschwelle_zwei,46 %,64
IDE80017-ENG133458-Analysis 17-s_Beruhigungszeit_Befuellen,65535 ms,64
IDE80017-ENG133460-Analysis 17-s_Beruhigungszeit_Druckmessung,65535 ms,64
IDE80017-ENG133459-Analysis 17-s_Beruhigungszeit_Entlueften,65535 ms,64
IDE80017-ENG133469-Analysis 17-s_Faktor_Druck_Entlueftung_Seitenhalt,255 ,64
IDE80017-ENG133464-Analysis 17-s_IntervallUmgebungsbedingungen,255 min,64
IDE80017-ENG133465-Analysis 17-s_MaxIntervall,255 min,64
IDE80017-ENG133461-Analysis 17-s_Messdauer_Initialisierung,255 ms,64
IDE80017-ENG133462-Analysis 17-s_Messdauer_Kurzzeitmessung,255 min,64
IDE80017-ENG133463-Analysis 17-s_Messdauer_Langzeitmessung,255 min,64
IDE80017-ENG133468-Analysis 17-s_Sitzvariante,variant_2 ,64
IDE80017-ENG133467-Analysis 17-s_Timeout_Befuell_Linearbereich,255 s,64
IDE80017-ENG133466-Analysis 17-s_Timeout_Befuell_Startbereich,255 s,64
IDE80017-ENG133457-Analysis 17-s_Uebernahmedruck_P_u,60 %,64
IDE80017-ENG133456-Analysis 17-s_Uebernahmedruck_PUe_o,60 %,64
IDE80018-ENG133471-Analysis 18-Offset_PB1_LM,0 hPa,64
IDE80018-ENG133472-Analysis 18-Offset_PB1_LU,0 hPa,64
IDE80018-ENG133473-Analysis 18-Offset_PB1_SH,0 hPa,64
IDE80018-ENG133475-Analysis 18-Offset_PB2_LM,0 hPa,64
IDE80018-ENG133474-Analysis 18-Offset_PB2_LO,0 hPa,64
IDE80018-ENG133476-Analysis 18-Offset_PB2_LU,0 hPa,64
IDE80018-ENG133477-Analysis 18-Offset_PB2_SH,0 hPa,64
IDE80018-ENG289601-Analysis 18-Offset_PP1,0 %,64
IDE80018-ENG289602-Analysis 18-Offset_PP2,0 %,64
IDE80018-ENG133483-Analysis 18-Offset_PV1_LM,0 ms,64
IDE80018-ENG133482-Analysis 18-Offset_PV1_LO,0 ms,64
IDE80018-ENG133484-Analysis 18-Offset_PV1_LU,0 ms,64
IDE80018-ENG133485-Analysis 18-Offset_PV1_SH,0 ms,64
IDE80018-ENG133486-Analysis 18-Offset_PV2_LO,0 ms,64
IDE80018-ENG133488-Analysis 18-Offset_PV2_LU,0 ms,64
IDE80018-ENG133489-Analysis 18-Offset_PV2_SH,0 ms,64
IDE80018-ENG289603-Analysis 18-Offset_T1,0 °C,64
IDE80018-ENG289604-Analysis 18-Offset_T2,0 °C,64
IDE80018-ENG133534-Analysis 18-OffsetPB1_LO,0 hPa,64
IDE80018-ENG133487-Analysis 18-OffsetPV2_LMy,0 ms,64
IDE80018-ENG133490-Analysis 18-p_function_feedback_timeout,0 ms,64
IDE80018-ENG133491-Analysis 18-p_longpush_time,0 ms,64
IDE80018-ENG133497-Analysis 18-p_stoesselSchaltschwelle_eins,255 %,64
IDE80018-ENG133498-Analysis 18-p_stoesselSchaltschwelle_zwei,255 %,64
IDE80018-ENG133494-Analysis 18-p_tasterSchaltschwelle_drei,45 %,64
IDE80018-ENG133492-Analysis 18-p_tasterSchaltschwelle_eins,66 %,64
IDE80018-ENG133496-Analysis 18-p_tasterSchaltschwelle_fuenf,20 %,64
IDE80018-ENG133495-Analysis 18-p_tasterSchaltschwelle_vier,24 %,64
IDE80018-ENG133493-Analysis 18-p_tasterSchaltschwelle_zwei,46 %,64
IDE80018-ENG133458-Analysis 18-s_Beruhigungszeit_Befuellen,65535 ms,64
IDE80018-ENG133460-Analysis 18-s_Beruhigungszeit_Druckmessung,65535 ms,64
IDE80018-ENG133459-Analysis 18-s_Beruhigungszeit_Entlueften,65535 ms,64
IDE80018-ENG133469-Analysis 18-s_Faktor_Druck_Entlueftung_Seitenhalt,255 ,64
IDE80018-ENG133464-Analysis 18-s_IntervallUmgebungsbedingungen,255 min,64
IDE80018-ENG133465-Analysis 18-s_MaxIntervall,255 min,64
IDE80018-ENG133461-Analysis 18-s_Messdauer_Initialisierung,255 ms,64
IDE80018-ENG133462-Analysis 18-s_Messdauer_Kurzzeitmessung,255 min,64
IDE80018-ENG133463-Analysis 18-s_Messdauer_Langzeitmessung,255 min,64
IDE80018-ENG133468-Analysis 18-s_Sitzvariante,variant_2 ,64
IDE80018-ENG133467-Analysis 18-s_Timeout_Befuell_Linearbereich,255 s,64
IDE80018-ENG133466-Analysis 18-s_Timeout_Befuell_Startbereich,255 s,64
IDE80018-ENG133532-Analysis 18-s_Uebernahmedruck_PUe_u,60 %,64
IDE80018-ENG133533-Analysis 18-s_UebernahmedruckP_u,60 %,64
MAS05055-lower turn position,18.395586 °,2
MAS05056-upper turn position,156.999844 °,2
MAS05807-ENG264052-Coding-Abparken nach Stop Haubenkontak (1bit),On ,3
MAS05807-ENG264068-Coding-adaptive Nachwischzyklen SRA (1bit),OFF ,3
MAS05807-ENG264069-Coding-APS bei Abparken (1bit),On ,3
MAS05807-ENG264070-Coding-APS bei Klemme 15 Wechsel (1bit),OFF ,3
MAS05807-ENG264071-Coding-APS für 100 Zyklen deaktiv (1bit),On ,3
MAS05807-ENG264072-Coding-APS2 Verlassen bei Geschwindigkeit (1bit),On ,3
MAS05807-ENG264178-Coding-geräusch optimierte Wischkennlinie (1bit),OFF ,3
MAS05807-ENG264181-Coding-langsames Abparken (1bit),OFF ,3
MAS05807-ENG264190-Coding-Produktionsmodus möglich (1bit),On ,3
MAS05807-ENG264192-Coding-Regensensoraktivierung über Fahrfreigabe (1bit),On ,3
MAS05807-ENG264194-Coding-Schleppfunktion Poti (1bit),On ,3
MAS05807-ENG264195-Coding-schnelles Tippwischen (1bit),On ,3
MAS05807-ENG264271-Coding-softe Geschwindigkeitsrückschaltung (1bit),OFF ,3
MAS05807-ENG264272-Coding-Start bei Klemme 15 EIN (1bit),OFF ,3
MAS05807-ENG264274-Coding-Stop bei Haubenkontakt (1bit),OFF ,3
MAS05807-ENG264275-Coding-Stop bei Klemme 15 AUS (1bit),On ,3
MAS05807-ENG264276-Coding-Tränenwischen (1bit),On ,3
MAS05807-ENG264279-Coding-v-abhängige Wischstufenrückschaltung (1bit),On ,3
MAS05807-ENG264280-Coding-variable Intervallwischgeschwindigkeit (1bit),On ,3
MAS05807-ENG273819-Coding-Wischer abparken über Öffnen Beifahrertür (1bit),On ,3
MAS05807-ENG273753-Coding-Wischer abparken über Öffnen Fahrertür (1bit),OFF ,3
MAS05807-ENG273652-Coding-Zyklisches Wecken in Parkposition (1bit),On ,3
ENG253311-IDE01058-604 UGDO Sender-Country coding,No Response From Subnet Component,3
ENG253311-MAS07183-604 UGDO Sender-Oper. concept,No Response From Subnet Component,3
ENG253311-MAS07186-604 UGDO Sender-Multimedia system,No Response From Subnet Component,3
ENG302676-SFT00022-abfrage_hashwert_subsysteme-Steering Column Electronics,No ,6
ENG302676-SFT271873-abfrage_hashwert_subsysteme-Wiper motor control module,Yes ,6
ENG302676-SFT271874-abfrage_hashwert_subsysteme-Rain/Light Recognition Sensor,Yes ,6
ENG302676-SFT271875-abfrage_hashwert_subsysteme-Light switch,No ,6
ENG302676-SFT271876-abfrage_hashwert_subsysteme-Garage door opener control module,No ,6
ENG302676-SFT271894-abfrage_hashwert_subsysteme-Anti-theft alarm system sensor,No ,6
ENG302676-SFT271896-abfrage_hashwert_subsysteme-Alarm horn,No ,6
ENG302676-SFT271909-abfrage_hashwert_subsysteme-left tail lamp 1,No ,6
ENG302676-SFT271910-abfrage_hashwert_subsysteme-Roof electronics control module,No ,6
ENG302676-SFT271947-abfrage_hashwert_subsysteme-Humidity sensor: interior,Yes ,6
ENG302676-SFT271948-abfrage_hashwert_subsysteme-Rear Driver Side Door Control Module,No ,6
ENG302676-SFT271949-abfrage_hashwert_subsysteme-Rear Passenger Door Control Module,No ,6
ENG302676-SFT271950-abfrage_hashwert_subsysteme-Rear lid opener control module,Yes ,6
ENG302676-SFT271966-abfrage_hashwert_subsysteme-Left head area heater,No ,6
ENG302676-SFT271967-abfrage_hashwert_subsysteme-Right head area heater,No ,6
ENG302676-SFT272014-abfrage_hashwert_subsysteme-Control head for driving and comfort functions,Yes ,6
ENG302676-SFT272057-abfrage_hashwert_subsysteme-Valve block 1 in front seat driver side,No ,6
ENG302676-SFT272061-abfrage_hashwert_subsysteme-Valve block 1 in front seat passenger side,No ,6
ENG302676-SFT272065-abfrage_hashwert_subsysteme-Blower 1 for left front backrest,No ,6
ENG302676-SFT272067-abfrage_hashwert_subsysteme-Blower 1 for left front seat cushion,No ,6
ENG302676-SFT272069-abfrage_hashwert_subsysteme-Blower 1 for right front backrest,No ,6
ENG302676-SFT272071-abfrage_hashwert_subsysteme-Blower 1 for right front seat cushion,No ,6
ENG302676-SFT272121-abfrage_hashwert_subsysteme-Control unit 2 for driving and convenience functions,No ,6
ENG302676-SFT272142-abfrage_hashwert_subsysteme-left tail lamp 2,No ,6
ENG302676-SFT272143-abfrage_hashwert_subsysteme-Right rear tail lamp 1,No ,6
ENG302676-SFT272144-abfrage_hashwert_subsysteme-Right rear tail lamp 2,No ,6
ENG302676-SFT272221-abfrage_hashwert_subsysteme-Radio receiver for remote start,No ,6
ENG302676-SFT272238-abfrage_hashwert_subsysteme-Wiper motor control unit 2,Yes ,6
ENG302676-SFT272272-abfrage_hashwert_subsysteme-Virtual pedal door opening: rear driver side,No ,6
ENG302676-SFT272286-abfrage_hashwert_subsysteme-Virtual pedal door opening: rear passenger side,No ,6
ENG153709-ENG154714-Aktivierung_Entwicklungsdiagnose-Reaktion_LOG-DTC,0 ,9
ENG253358-ENG263564-Anpassungen_Exterior_Light-BahnkurvenAktiv,active ,270
ENG253358-ENG258212-Anpassungen_Exterior_Light-Delay_Max,100 ms,270
ENG253358-ENG259279-Anpassungen_Exterior_Light-Events_Szene_1,06 07 08 FF 00 01 02 FF ,270
ENG253358-ENG260085-Anpassungen_Exterior_Light-Events_Szene_10,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG260997-Anpassungen_Exterior_Light-Events_Szene_11,FF FF FF FF 12 13 14 FF ,270
ENG253358-ENG258638-Anpassungen_Exterior_Light-Events_Szene_12,12 13 14 FF 0F 10 11 FF ,270
ENG253358-ENG259456-Anpassungen_Exterior_Light-Events_Szene_13,12 13 14 FF FF FF FF FF ,270
ENG253358-ENG260535-Anpassungen_Exterior_Light-Events_Szene_14,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG259560-Anpassungen_Exterior_Light-Events_Szene_15,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG259132-Anpassungen_Exterior_Light-Events_Szene_16,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG260337-Anpassungen_Exterior_Light-Events_Szene_17,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG259462-Anpassungen_Exterior_Light-Events_Szene_18,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG258627-Anpassungen_Exterior_Light-Events_Szene_19,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG260067-Anpassungen_Exterior_Light-Events_Szene_2,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG259484-Anpassungen_Exterior_Light-Events_Szene_20,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG260587-Anpassungen_Exterior_Light-Events_Szene_21,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG260042-Anpassungen_Exterior_Light-Events_Szene_22,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG259549-Anpassungen_Exterior_Light-Events_Szene_23,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG260635-Anpassungen_Exterior_Light-Events_Szene_24,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG258179-Anpassungen_Exterior_Light-Events_Szene_25,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG259599-Anpassungen_Exterior_Light-Events_Szene_26,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG260140-Anpassungen_Exterior_Light-Events_Szene_27,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG258932-Anpassungen_Exterior_Light-Events_Szene_28,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG258855-Anpassungen_Exterior_Light-Events_Szene_29,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG259951-Anpassungen_Exterior_Light-Events_Szene_3,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG259306-Anpassungen_Exterior_Light-Events_Szene_30,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG260976-Anpassungen_Exterior_Light-Events_Szene_31,14 3E 6E 3E 08 00 00 00 ,270
ENG253358-ENG260284-Anpassungen_Exterior_Light-Events_Szene_32,00 01 FF FF FF FF FF FF ,270
ENG253358-ENG260168-Anpassungen_Exterior_Light-Events_Szene_4,FF FF FF FF 18 19 1A FF ,270
ENG253358-ENG259646-Anpassungen_Exterior_Light-Events_Szene_5,0C 0D 0E FF 0C 0D 0E FF ,270
ENG253358-ENG260432-Anpassungen_Exterior_Light-Events_Szene_6,09 0A 0B FF 0C 0D 0E FF ,270
ENG253358-ENG259181-Anpassungen_Exterior_Light-Events_Szene_7,03 04 05 FF FF FF FF FF ,270
ENG253358-ENG258154-Anpassungen_Exterior_Light-Events_Szene_8,15 16 17 FF FF FF FF FF ,270
ENG253358-ENG260860-Anpassungen_Exterior_Light-Events_Szene_9,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG259092-Anpassungen_Exterior_Light-MappingArray,238 ,270
ENG253358-ENG263521-Anpassungen_Exterior_Light-MappingArray_Umfeld,238 ,270
ENG253358-ENG258812-Anpassungen_Exterior_Light-p_Abstand_IDG_Inszenierung,25.5 m,270
ENG253358-ENG258950-Anpassungen_Exterior_Light-p_Kessy_ID,active ,270
ENG253358-ENG259215-Anpassungen_Exterior_Light-pa_ambExtLight_Installation,active ,270
ENG253358-ENG258160-Anpassungen_Exterior_Light-pa_ext_Ambiente,active ,270
ENG253358-ENG260968-Anpassungen_Exterior_Light-Passive_Timeout,600.00 s,270
ENG253358-ENG258460-Anpassungen_Exterior_Light-PSO_active_participant_ambient_lighting_exterieur_enabled,active ,270
ENG253358-ENG260987-Anpassungen_Exterior_Light-Schlusslichtsignatur,01 ,270
ENG253358-ENG261089-Anpassungen_Exterior_Light-Verzoegerung_Blinken,active ,270
ENG253358-ENG403619-Anpassungen_Exterior_Light-VIP30_Dimmzeit,0 ms,270
ENG253358-ENG403620-Anpassungen_Exterior_Light-VIP30_Umfeld-SALR,00 ,270
ENG253358-ENG403621-Anpassungen_Exterior_Light-VIP30_Umfeld-TSG,00 ,270
ENG253146-ENG345149-Aussenlicht-SG-Architektur-Abschaltung Redundanzpfad Prüfung Bremslicht,not active ,8
ENG253146-ENG259743-Aussenlicht-SG-Architektur-Lichtfunktion_OL_Diagnose_LT55_1,FF ,8
ENG253146-ENG260787-Aussenlicht-SG-Architektur-Lichtfunktion_OL_Diagnose_LT55_2,FF ,8
ENG253146-ENG259890-Aussenlicht-SG-Architektur-Lichtfunktion_OL_Diagnose_LT55_3,FF ,8
ENG253146-ENG260564-Aussenlicht-SG-Architektur-Lichtfunktion_OL_Diagnose_LT56_1,FF ,8
ENG253146-ENG258294-Aussenlicht-SG-Architektur-Lichtfunktion_OL_Diagnose_LT56_2,FF ,8
ENG253146-ENG259373-Aussenlicht-SG-Architektur-Lichtfunktion_OL_Diagnose_LT56_3,FF ,8
ENG125611-ENG125698-Blower_1_Backrest_Left-Counter_For_Blockage_Validation,No Response From Subnet Component,8
ENG125611-ENG125700-Blower_1_Backrest_Left-Critical_Temperature_Treshold,No Response From Subnet Component,8
ENG125611-ENG125697-Blower_1_Backrest_Left-Hysteresis_Treshold_For_Undervoltage,No Response From Subnet Component,8
ENG125611-ENG125699-Blower_1_Backrest_Left-Latency_For_Blockage_Validation,No Response From Subnet Component,8
ENG125611-ENG125701-Blower_1_Backrest_Left-Maximum_Blower_Rotation_Speed,No Response From Subnet Component,8
ENG125611-ENG134731-Blower_1_Backrest_Left-Minimum_Blower_Rotation_Speed,No Response From Subnet Component,8
ENG125611-ENG125695-Blower_1_Backrest_Left-Overvoltage_treshold,No Response From Subnet Component,8
ENG125611-ENG125696-Blower_1_Backrest_Left-Undervoltage_treshold,No Response From Subnet Component,8
ENG125612-ENG125698-Blower_1_Backrest_Right-Counter_For_Blockage_Validation,No Response From Subnet Component,8
ENG125612-ENG125700-Blower_1_Backrest_Right-Critical_Temperature_Treshold,No Response From Subnet Component,8
ENG125612-ENG125697-Blower_1_Backrest_Right-Hysteresis_Treshold_For_Undervoltage,No Response From Subnet Component,8
ENG125612-ENG125699-Blower_1_Backrest_Right-Latency_For_Blockage_Validation,No Response From Subnet Component,8
ENG125612-ENG125701-Blower_1_Backrest_Right-Maximum_Blower_Rotation_Speed,No Response From Subnet Component,8
ENG125612-ENG134731-Blower_1_Backrest_Right-Minimum_Blower_Rotation_Speed,No Response From Subnet Component,8
ENG125612-ENG125695-Blower_1_Backrest_Right-Overvoltage_treshold,No Response From Subnet Component,8
ENG125612-ENG125696-Blower_1_Backrest_Right-Undervoltage_treshold,No Response From Subnet Component,8
ENG125609-ENG125698-Blower_1_Cushion_Left-Counter_For_Blockage_Validation,No Response From Subnet Component,8
ENG125609-ENG125700-Blower_1_Cushion_Left-Critical_Temperature_Treshold,No Response From Subnet Component,8
ENG125609-ENG125697-Blower_1_Cushion_Left-Hysteresis_Treshold_For_Undervoltage,No Response From Subnet Component,8
ENG125609-ENG125699-Blower_1_Cushion_Left-Latency_For_Blockage_Validation,No Response From Subnet Component,8
ENG125609-ENG125701-Blower_1_Cushion_Left-Maximum_Blower_Rotation_Speed,No Response From Subnet Component,8
ENG125609-ENG134731-Blower_1_Cushion_Left-Minimum_Blower_Rotation_Speed,No Response From Subnet Component,8
ENG125609-ENG125695-Blower_1_Cushion_Left-Overvoltage_treshold,No Response From Subnet Component,8
ENG125609-ENG125696-Blower_1_Cushion_Left-Undervoltage_treshold,No Response From Subnet Component,8
ENG125610-ENG125698-Blower_1_Cushion_Right-Counter_For_Blockage_Validation,No Response From Subnet Component,8
ENG125610-ENG125700-Blower_1_Cushion_Right-Critical_Temperature_Treshold,No Response From Subnet Component,8
ENG125610-ENG125697-Blower_1_Cushion_Right-Hysteresis_Treshold_For_Undervoltage,No Response From Subnet Component,8
ENG125610-ENG125699-Blower_1_Cushion_Right-Latency_For_Blockage_Validation,No Response From Subnet Component,8
ENG125610-ENG125701-Blower_1_Cushion_Right-Maximum_Blower_Rotation_Speed,No Response From Subnet Component,8
ENG125610-ENG134731-Blower_1_Cushion_Right-Minimum_Blower_Rotation_Speed,No Response From Subnet Component,8
ENG125610-ENG125695-Blower_1_Cushion_Right-Overvoltage_treshold,No Response From Subnet Component,8
ENG125610-ENG125696-Blower_1_Cushion_Right-Undervoltage_treshold,No Response From Subnet Component,8
ENG253229-ENG258467-Define_Const-Dimm2Bin,1 %,4
ENG253229-ENG259386-Define_Const-Dimmzeit_SAL_Umfeld,1.00 s,4
ENG253229-ENG253468-Define_Const-Gamma,2.0 ,4
ENG253197-ENG260990-Diebstahlschutz Schnittstelle-DWA_HSB_HSK_ueberwachung_aktiv,not active ,6
ENG253197-ENG258293-Diebstahlschutz Schnittstelle-DWA_mit_Einfachhorn,not installed ,6
ENG253197-ENG258890-Diebstahlschutz Schnittstelle-DWA_mit_NGS,not active ,6
ENG253197-ENG258731-Diebstahlschutz Schnittstelle-DWA_ohne_Thatcham,Emergency closing only ,6
ENG253197-ENG258944-Diebstahlschutz Schnittstelle-DWA_Scheinwerferueberwachung_aktiv,not active ,6
ENG253197-ENG258663-Diebstahlschutz Schnittstelle-DWA_verbaut,installed ,6
ENG253197-ENG258162-Diebstahlschutz Schnittstelle-IRUE_NGS_Deaktivierung_via_MMI,not active ,6
ENG253197-ENG261022-Diebstahlschutz Schnittstelle-Irue_verbaut,not installed ,6
ENG253197-ENG261072-Diebstahlschutz Schnittstelle-Sirene_alarmzahl,10_Alarme ,6
ENG253197-ENG260442-Diebstahlschutz Schnittstelle-Verbau_Deaktivierungstaster_DWA_Sensor,not active ,6
ENG253244-MAS10115-Diebstahlschutz.Modulsoftware-Anti-theft blinkers by inter. door handle activ.,OFF ,6
ENG253244-MAS31160-Diebstahlschutz.Modulsoftware-OBD monitoring,active ,6
ENG253244-ENG258423-Diebstahlschutz.Modulsoftware-Akustischer Alarm ueber Hupe,active ,6
ENG253244-ENG258401-Diebstahlschutz.Modulsoftware-Anhaengerueberwachung_aktiv,not active ,6
ENG253244-ENG146510-Diebstahlschutz.Modulsoftware-beeptime,5_ms ,6
ENG253244-ENG260066-Diebstahlschutz.Modulsoftware-dwa_alarm_ton,frequency_modulated ,6
ENG253244-ENG258606-Diebstahlschutz.Modulsoftware-DWA_campermode,not active ,6
ENG253244-ENG260322-Diebstahlschutz.Modulsoftware-DWA_Verdeckoeffnungsueberwachung_aktiv,not active ,6
ENG253244-ENG261182-Diebstahlschutz.Modulsoftware-IRUE_NGS_bewusst_entschaerfen,not active ,6
ENG253144-ENG259520-Dimmung (der Suchbeleuchtung Kl. 58)-p_delta_KL58D_min,3.0 %,21
ENG253144-ENG253461-Dimmung (der Suchbeleuchtung Kl. 58)-p_Fehlerwert_Kl_58xd,80 %,21
ENG253144-ENG253462-Dimmung (der Suchbeleuchtung Kl. 58)-p_Fehlerwert_Kl_58xs,80 %,21
ENG253144-ENG253463-Dimmung (der Suchbeleuchtung Kl. 58)-p_Fehlerwert_Kl_58xt,80 %,21
ENG253144-ENG259127-Dimmung (der Suchbeleuchtung Kl. 58)-p_Kl_58xk_Schrittanzahl_kurzer_Tastendruck,10 ,21
ENG253144-ENG261206-Dimmung (der Suchbeleuchtung Kl. 58)-p_kl58d_poti_uin_max,90.0 %,21
ENG253144-ENG258780-Dimmung (der Suchbeleuchtung Kl. 58)-p_kl58d_poti_uin_min,10.0 %,21
ENG253144-ENG259198-Dimmung (der Suchbeleuchtung Kl. 58)-p_kl58d_poti_uin_tol,5.0 %,21
ENG253144-ENG261308-Dimmung (der Suchbeleuchtung Kl. 58)-p_langer_Tastendruck,1.0 s,21
ENG253144-ENG260197-Dimmung (der Suchbeleuchtung Kl. 58)-p_timer_Kl_58xs_Nachlauf_lang,900 s,21
ENG253144-ENG261144-Dimmung (der Suchbeleuchtung Kl. 58)-p_timer_Kl_58xt_Nachlauf_kurz,30 s,21
ENG253144-ENG258180-Dimmung (der Suchbeleuchtung Kl. 58)-p_timer_Netz_Nachlauf_Master,0 min,21
ENG253144-ENG253464-Dimmung (der Suchbeleuchtung Kl. 58)-p_timer_Netz_Nachlauf_Slave,12 min,21
ENG125597-ENG126865-Driver_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Manuelle_Befuellung_LRD,100 %,6
ENG125597-ENG126867-Driver_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Manueller_Befuellung_Seitenwangen,255 %,6
ENG125597-ENG126866-Driver_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Memorisierte_Befuellung_LRD,80 %,6
ENG125597-ENG126868-Driver_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Memorisierte_Befuellung_Seitenwangen,255 %,6
ENG125597-ENG125690-Driver_compressor_parameter_multi-contour_seat-s_VerzoegerungszeitKompressoranlauf,65535 ms,6
ENG133364-ENG133507-Driver_multi-contour_seat_Error_Mask-ERROR_CODE_PIN,00000000 00000000  ,66
ENG133364-ENG133526-Driver_multi-contour_seat_Error_Mask-ERROR_EEPROM,11111111 11111111  ,66
ENG133364-ENG133528-Driver_multi-contour_seat_Error_Mask-ERROR_HW_VERSION,11111101 00011110  ,66
ENG133364-ENG133500-Driver_multi-contour_seat_Error_Mask-ERROR_LUMB1_CTRL_LEAK,00000000 00000000  ,66
ENG133364-ENG133499-Driver_multi-contour_seat_Error_Mask-ERROR_LUMB1_LEAK,00000000 00000000  ,66
ENG133364-ENG133502-Driver_multi-contour_seat_Error_Mask-ERROR_LUMB2_CTRL_LEAK,00000000 00000000  ,66
ENG133364-ENG133501-Driver_multi-contour_seat_Error_Mask-ERROR_LUMB2_LEAK,00000000 00000000  ,66
ENG133364-ENG133504-Driver_multi-contour_seat_Error_Mask-ERROR_LUMB3_CTRL_LEAK,00000000 00000000  ,66
ENG133364-ENG133503-Driver_multi-contour_seat_Error_Mask-ERROR_LUMB3_LEAK,00000000 00000000  ,66
ENG133364-ENG133511-Driver_multi-contour_seat_Error_Mask-ERROR_PUMP_BLOCK,11111101 00011110  ,66
ENG133364-ENG133508-Driver_multi-contour_seat_Error_Mask-ERROR_PUMP_OPEN,11111101 00011110  ,66
ENG133364-ENG133509-Driver_multi-contour_seat_Error_Mask-ERROR_PUMP_SHORT_GND,11111101 00011110  ,66
ENG133364-ENG133510-Driver_multi-contour_seat_Error_Mask-ERROR_PUMP_SHORT_UB,11111101 00011110  ,66
ENG133364-ENG133524-Driver_multi-contour_seat_Error_Mask-ERROR_RAM,11111101 00011110  ,66
ENG133364-ENG133525-Driver_multi-contour_seat_Error_Mask-ERROR_ROM,11111101 00011110  ,66
ENG133364-ENG133506-Driver_multi-contour_seat_Error_Mask-ERROR_SIDE_CTRL_LEAK,00000000 00000000  ,66
ENG133364-ENG133505-Driver_multi-contour_seat_Error_Mask-ERROR_SIDE_LEAK,00000000 00000000  ,66
ENG133364-ENG133531-Driver_multi-contour_seat_Error_Mask-ERROR_SIG_RESPONSE,00000000 00000000  ,66
ENG133364-ENG133512-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_1,00000000 00000000  ,66
ENG133364-ENG133515-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_2,00000000 00000000  ,66
ENG133364-ENG133518-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_3,00000000 00000000  ,66
ENG133364-ENG133521-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_4,00000000 00000000  ,66
ENG133364-ENG133513-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_1,00000000 00000000  ,66
ENG133364-ENG133516-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_2,00000000 00000000  ,66
ENG133364-ENG133519-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_3,00000000 00000000  ,66
ENG133364-ENG133522-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_4,00000000 00000000  ,66
ENG133364-ENG133514-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_1,00000000 00000000  ,66
ENG133364-ENG133517-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_2,00000000 00000000  ,66
ENG133364-ENG133520-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_3,00000000 00000000  ,66
ENG133364-ENG133523-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_4,00000000 00000000  ,66
ENG133364-ENG133529-Driver_multi-contour_seat_Error_Mask-ERROR_VOLTAGE_HIGH,11111111 11111111  ,66
ENG133364-ENG133530-Driver_multi-contour_seat_Error_Mask-ERROR_VOLTAGE_LOW,11111111 11111111  ,66
ENG133364-ENG133527-Driver_multi-contour_seat_Error_Mask-ERROR_WDT,11111111 11111111  ,66
ENG252014-ENG252049-Driver_seat_perso_1-Hoehe_Lordose_Perso,0 ,4
ENG252014-ENG252081-Driver_seat_perso_1-Perso_Lehnenwangen,0 ,4
ENG252014-ENG252087-Driver_seat_perso_1-Perso_letztes_Massageprogramm,1 ,4
ENG252014-ENG252064-Driver_seat_perso_1-Perso_Massageintensitaet,1 ,4
ENG252014-ENG252088-Driver_seat_perso_1-Weite_Lordose_Perso,0 ,4
ENG252015-ENG252049-Driver_seat_perso_2-Hoehe_Lordose_Perso,0 ,4
ENG252015-ENG252081-Driver_seat_perso_2-Perso_Lehnenwangen,0 ,4
ENG252015-ENG252087-Driver_seat_perso_2-Perso_letztes_Massageprogramm,1 ,4
ENG252015-ENG252064-Driver_seat_perso_2-Perso_Massageintensitaet,1 ,4
ENG252015-ENG252088-Driver_seat_perso_2-Weite_Lordose_Perso,0 ,4
ENG252016-ENG252049-Driver_seat_perso_3-Hoehe_Lordose_Perso,0 ,4
ENG252016-ENG252081-Driver_seat_perso_3-Perso_Lehnenwangen,0 ,4
ENG252016-ENG252087-Driver_seat_perso_3-Perso_letztes_Massageprogramm,1 ,4
ENG252016-ENG252064-Driver_seat_perso_3-Perso_Massageintensitaet,1 ,4
ENG252016-ENG252088-Driver_seat_perso_3-Weite_Lordose_Perso,0 ,4
ENG252017-ENG252049-Driver_seat_perso_4-Hoehe_Lordose_Perso,0 ,4
ENG252017-ENG252081-Driver_seat_perso_4-Perso_Lehnenwangen,0 ,4
ENG252017-ENG252087-Driver_seat_perso_4-Perso_letztes_Massageprogramm,1 ,4
ENG252017-ENG252064-Driver_seat_perso_4-Perso_Massageintensitaet,1 ,4
ENG252017-ENG252088-Driver_seat_perso_4-Weite_Lordose_Perso,0 ,4
ENG252018-ENG252049-Driver_seat_perso_5-Hoehe_Lordose_Perso,0 ,4
ENG252018-ENG252081-Driver_seat_perso_5-Perso_Lehnenwangen,0 ,4
ENG252018-ENG252087-Driver_seat_perso_5-Perso_letztes_Massageprogramm,1 ,4
ENG252018-ENG252064-Driver_seat_perso_5-Perso_Massageintensitaet,1 ,4
ENG252018-ENG252088-Driver_seat_perso_5-Weite_Lordose_Perso,0 ,4
ENG252019-ENG252049-Driver_seat_perso_6-Hoehe_Lordose_Perso,0 ,4
ENG252019-ENG252081-Driver_seat_perso_6-Perso_Lehnenwangen,0 ,4
ENG252019-ENG252087-Driver_seat_perso_6-Perso_letztes_Massageprogramm,1 ,4
ENG252019-ENG252064-Driver_seat_perso_6-Perso_Massageintensitaet,1 ,4
ENG252019-ENG252088-Driver_seat_perso_6-Weite_Lordose_Perso,0 ,4
ENG252020-ENG252049-Driver_seat_perso_7-Hoehe_Lordose_Perso,0 ,4
ENG252020-ENG252081-Driver_seat_perso_7-Perso_Lehnenwangen,0 ,4
ENG252020-ENG252087-Driver_seat_perso_7-Perso_letztes_Massageprogramm,1 ,4
ENG252020-ENG252064-Driver_seat_perso_7-Perso_Massageintensitaet,1 ,4
ENG252020-ENG252088-Driver_seat_perso_7-Weite_Lordose_Perso,0 ,4
ENG122934-erase_error_table,00 00 00 ,3
ENG122933-error_mask,00 00 ,2
ENG141682-ENG260711-Front_wiper-cp_tipwischen_Kl_15_aus,OFF ,6
ENG141682-ENG133394-Front_wiper-Frontwischer_Abtauposition,keine Abtaupostition ,6
ENG141682-ENG260480-Front_wiper-Frontwischer_typ,LIN ,6
ENG141682-ENG116615-Front_wiper-Menuesteuerung Frontwischer,active ,6
ENG141682-ENG258360-Front_wiper-pa_2_Motorsystem,active ,6
ENG141682-ENG259770-Front_wiper-Regensensor aktiv Fahrfreigabe,not active ,6
ENG141682-ENG115771-Front_wiper-Regensensor aktivieren,active ,6
ENG141682-ENG260083-Front_wiper-Spannungsanforderung_konfig_Frontwischer,Keine_Spannungsanforderung ,6
ENG141682-ENG259232-Front_wiper-tipwischen_Kl_15_aus,not active ,6
ENG141682-ENG126844-Front_wiper-Washer_Tipwiping_Variant,active ,6
ENG141682-ENG122991-Front_wiper-Wischer stop bei Motorstart,kein Wischerstopp ,6
ENG117283-ENG122998-Frontwaschfunktion-factor_washing_delay,10 ,2
ENG117283-ENG263535-Frontwaschfunktion-Waschfrequenz_bei_LSS_aus,40 ,2
ENG253288-ENG126955-Grundparameter SPN-duration_to_ZAT_continuous_actuation_detection,1000 ms,30
ENG253288-ENG129005-Grundparameter SPN-duration_to_ZAT_multi_actuation_detection,3000 ms,30
ENG253288-ENG126950-Grundparameter SPN-duration_ZAT_debounce,50 ms,30
ENG253288-ENG260569-Grundparameter SPN-Speed_ threshold_for_start_wish_plausibilisation,10 km/h,30
ENG253288-ENG129008-Grundparameter SPN-Speed_threshold_for_terminal_15_emergency_shutoff,7.0 km/h,30
ENG253288-ENG126954-Grundparameter SPN-time_to_ZAT_Open_circuit_detection,1000 ms,30
ENG253288-ENG126951-Grundparameter SPN-time_to_ZAT_Short_circuit_fault_detection,60 s,30
ENG253288-ENG126952-Grundparameter SPN-time_ZAT_lock_after emergency_shutoff,1000 ms,30
ENG253288-ENG126953-Grundparameter SPN-time_ZAT_lock_after_normal_shutoff,500 ms,30
ENG253288-ENG253449-Grundparameter SPN-time_ZAT_one_switch_actuation_detection,3000 ms,30
ENG141645-ENG298112-HW_Verbau-ICAS_luefter_verbaut,not installed ,8
ENG141645-ENG260128-HW_Verbau-Kontaktfritten,OFF ,8
ENG141645-ENG152427-HW_Verbau-Rear window defogger,installed ,8
ENG141645-ENG298164-HW_Verbau-Zweiter_Kontaktschalter_fuer_Motorhaube,not installed ,8
ENG302679-HW_Verbau_ASIL,umsortieren_CRC_BZ ,4
ENG253265-ENG260602-Interior_light_default_values-Default_value_active_profile,03 ,96
ENG253265-ENG258400-Interior_light_default_values-Default_value_ambient_color,11 ,96
ENG253265-ENG259067-Interior_light_default_values-Default_value_ambient_color_fod,01 ,96
ENG253265-ENG258906-Interior_light_default_values-Default_value_brightness_profile_1,50 %,96
ENG253265-ENG260896-Interior_light_default_values-Default_value_brightness_profile_2,50 %,96
ENG253265-ENG259361-Interior_light_default_values-Default_value_brightness_profile_3,50 %,96
ENG253265-ENG259248-Interior_light_default_values-Default_value_brightness_profile_4,50 %,96
ENG253265-ENG259191-Interior_light_default_values-Default_value_brightness_profile_5,50 %,96
ENG253265-ENG259315-Interior_light_default_values-Default_value_brightness_profile_6,50 %,96
ENG253265-ENG260148-Interior_light_default_values-Default_value_brightness_profile_7,50 %,96
ENG253265-ENG259491-Interior_light_default_values-Default_value_brightness_profile_8,0 %,96
ENG253265-ENG258409-Interior_light_default_values-Default_value_brightness_set_1,50 %,96
ENG253265-ENG260620-Interior_light_default_values-Default_value_brightness_set_2,50 %,96
ENG253265-ENG259395-Interior_light_default_values-Default_value_brightness_set_3,50 %,96
ENG253265-ENG260548-Interior_light_default_values-Default_value_brightness_set_4,50 %,96
ENG253265-ENG261071-Interior_light_default_values-Default_value_brightness_set_5,50 %,96
ENG253265-ENG259147-Interior_light_default_values-Default_value_brightness_set_6,50 %,96
ENG253265-ENG259714-Interior_light_default_values-Default_value_brightness_set_7,50 %,96
ENG253265-ENG260350-Interior_light_default_values-Default_value_brightness_set_8,50 %,96
ENG253265-ENG260494-Interior_light_default_values-Default_value_contour_color,01 ,96
ENG253265-ENG259828-Interior_light_default_values-Default_value_contour_color_fod,1C ,96
ENG253265-ENG258473-Interior_light_default_values-Default_value_door_contact,active ,96
ENG253265-ENG261059-Interior_light_default_values-Default_value_functional_ambient_lighting,not active ,96
ENG253265-ENG258185-Interior_light_default_values-Default_value_play_of_colors,00 ,96
ENG253265-ENG260118-Interior_light_default_values-Status_functional_ambient_lighting_function_0,00 ,96
ENG253265-ENG260033-Interior_light_default_values-Status_functional_ambient_lighting_function_1,00 ,96
ENG253265-ENG260515-Interior_light_default_values-Status_functional_ambient_lighting_function_10,00 ,96
ENG253265-ENG261126-Interior_light_default_values-Status_functional_ambient_lighting_function_11,00 ,96
ENG253265-ENG260982-Interior_light_default_values-Status_functional_ambient_lighting_function_12,00 ,96
ENG253265-ENG258716-Interior_light_default_values-Status_functional_ambient_lighting_function_13,00 ,96
ENG253265-ENG258745-Interior_light_default_values-Status_functional_ambient_lighting_function_14,00 ,96
ENG253265-ENG258773-Interior_light_default_values-Status_functional_ambient_lighting_function_15,00 ,96
ENG253265-ENG261349-Interior_light_default_values-Status_functional_ambient_lighting_function_16,00 ,96
ENG253265-ENG258101-Interior_light_default_values-Status_functional_ambient_lighting_function_17,00 ,96
ENG253265-ENG258275-Interior_light_default_values-Status_functional_ambient_lighting_function_18,00 ,96
ENG253265-ENG258192-Interior_light_default_values-Status_functional_ambient_lighting_function_19,00 ,96
ENG253265-ENG260897-Interior_light_default_values-Status_functional_ambient_lighting_function_2,00 ,96
ENG253265-ENG260194-Interior_light_default_values-Status_functional_ambient_lighting_function_20,00 ,96
ENG253265-ENG258332-Interior_light_default_values-Status_functional_ambient_lighting_function_21,00 ,96
ENG253265-ENG259651-Interior_light_default_values-Status_functional_ambient_lighting_function_22,00 ,96
ENG253265-ENG261294-Interior_light_default_values-Status_functional_ambient_lighting_function_23,00 ,96
ENG253265-ENG259414-Interior_light_default_values-Status_functional_ambient_lighting_function_24,00 ,96
ENG253265-ENG258573-Interior_light_default_values-Status_functional_ambient_lighting_function_25,00 ,96
ENG253265-ENG258495-Interior_light_default_values-Status_functional_ambient_lighting_function_26,00 ,96
ENG253265-ENG260792-Interior_light_default_values-Status_functional_ambient_lighting_function_27,00 ,96
ENG253265-ENG261350-Interior_light_default_values-Status_functional_ambient_lighting_function_28,00 ,96
ENG253265-ENG259636-Interior_light_default_values-Status_functional_ambient_lighting_function_29,00 ,96
ENG253265-ENG259360-Interior_light_default_values-Status_functional_ambient_lighting_function_3,00 ,96
ENG253265-ENG260163-Interior_light_default_values-Status_functional_ambient_lighting_function_30,00 ,96
ENG253265-ENG260013-Interior_light_default_values-Status_functional_ambient_lighting_function_31,00 ,96
ENG253265-ENG260816-Interior_light_default_values-Status_functional_ambient_lighting_function_32,00 ,96
ENG253265-ENG258823-Interior_light_default_values-Status_functional_ambient_lighting_function_33,00 ,96
ENG253265-ENG258362-Interior_light_default_values-Status_functional_ambient_lighting_function_34,00 ,96
ENG253265-ENG258252-Interior_light_default_values-Status_functional_ambient_lighting_function_35,00 ,96
ENG253265-ENG261196-Interior_light_default_values-Status_functional_ambient_lighting_function_36,00 ,96
ENG253265-ENG260391-Interior_light_default_values-Status_functional_ambient_lighting_function_37,00 ,96
ENG253265-ENG259418-Interior_light_default_values-Status_functional_ambient_lighting_function_38,00 ,96
ENG253265-ENG259523-Interior_light_default_values-Status_functional_ambient_lighting_function_39,00 ,96
ENG253265-ENG258165-Interior_light_default_values-Status_functional_ambient_lighting_function_4,00 ,96
ENG253265-ENG259088-Interior_light_default_values-Status_functional_ambient_lighting_function_40,00 ,96
ENG253265-ENG258142-Interior_light_default_values-Status_functional_ambient_lighting_function_41,00 ,96
ENG253265-ENG259166-Interior_light_default_values-Status_functional_ambient_lighting_function_42,00 ,96
ENG253265-ENG258220-Interior_light_default_values-Status_functional_ambient_lighting_function_43,00 ,96
ENG253265-ENG259935-Interior_light_default_values-Status_functional_ambient_lighting_function_44,00 ,96
ENG253265-ENG260916-Interior_light_default_values-Status_functional_ambient_lighting_function_45,00 ,96
ENG253265-ENG258884-Interior_light_default_values-Status_functional_ambient_lighting_function_46,00 ,96
ENG253265-ENG260167-Interior_light_default_values-Status_functional_ambient_lighting_function_47,00 ,96
ENG253265-ENG259709-Interior_light_default_values-Status_functional_ambient_lighting_function_48,00 ,96
ENG253265-ENG258367-Interior_light_default_values-Status_functional_ambient_lighting_function_49,00 ,96
ENG253265-ENG261268-Interior_light_default_values-Status_functional_ambient_lighting_function_5,00 ,96
ENG253265-ENG260926-Interior_light_default_values-Status_functional_ambient_lighting_function_50,00 ,96
ENG253265-ENG258790-Interior_light_default_values-Status_functional_ambient_lighting_function_51,00 ,96
ENG253265-ENG259976-Interior_light_default_values-Status_functional_ambient_lighting_function_52,00 ,96
ENG253265-ENG260404-Interior_light_default_values-Status_functional_ambient_lighting_function_53,00 ,96
ENG253265-ENG258371-Interior_light_default_values-Status_functional_ambient_lighting_function_54,00 ,96
ENG253265-ENG259284-Interior_light_default_values-Status_functional_ambient_lighting_function_55,00 ,96
ENG253265-ENG260285-Interior_light_default_values-Status_functional_ambient_lighting_function_56,00 ,96
ENG253265-ENG258600-Interior_light_default_values-Status_functional_ambient_lighting_function_57,00 ,96
ENG253265-ENG260626-Interior_light_default_values-Status_functional_ambient_lighting_function_58,00 ,96
ENG253265-ENG260773-Interior_light_default_values-Status_functional_ambient_lighting_function_59,00 ,96
ENG253265-ENG259316-Interior_light_default_values-Status_functional_ambient_lighting_function_6,00 ,96
ENG253265-ENG261109-Interior_light_default_values-Status_functional_ambient_lighting_function_60,00 ,96
ENG253265-ENG258106-Interior_light_default_values-Status_functional_ambient_lighting_function_61,00 ,96
ENG253265-ENG260286-Interior_light_default_values-Status_functional_ambient_lighting_function_62,00 ,96
ENG253265-ENG260233-Interior_light_default_values-Status_functional_ambient_lighting_function_63,00 ,96
ENG253265-ENG260974-Interior_light_default_values-Status_functional_ambient_lighting_function_7,00 ,96
ENG253265-ENG259492-Interior_light_default_values-Status_functional_ambient_lighting_function_8,00 ,96
ENG253265-ENG260578-Interior_light_default_values-Status_functional_ambient_lighting_function_9,00 ,96
ENG253069-ENG259642-Interior_light_external_events-External_event_activation_69,not active ,16
ENG253069-ENG403530-Interior_light_external_events-External_event_activation_atmospheres,not active ,16
ENG253069-ENG403531-Interior_light_external_events-External_event_activation_door_scenario,not active ,16
ENG253069-ENG259453-Interior_light_external_events-External_event_activation_of_ready_to_drive_visualization,not active ,16
ENG253069-ENG403532-Interior_light_external_events-External_event_activation_wellbeing,not active ,16
ENG253069-ENG258384-Interior_light_external_events-External_event_ready_to_drive_visualization_with_sound,not active ,16
ENG253344-ENG253469-Interior_light_functions_1_to_70-Light_function_1,active ,9
ENG253344-ENG260993-Interior_light_functions_1_to_70-Light_function_10,active ,9
ENG253344-ENG261210-Interior_light_functions_1_to_70-Light_function_11,not active ,9
ENG253344-ENG259885-Interior_light_functions_1_to_70-Light_function_12,not active ,9
ENG253344-ENG258428-Interior_light_functions_1_to_70-Light_function_13,not active ,9
ENG253344-ENG260468-Interior_light_functions_1_to_70-Light_function_14,not active ,9
ENG253344-ENG259544-Interior_light_functions_1_to_70-Light_function_15,active ,9
ENG253344-ENG261129-Interior_light_functions_1_to_70-Light_function_16,active ,9
ENG253344-ENG259775-Interior_light_functions_1_to_70-Light_function_17,not active ,9
ENG253344-ENG259446-Interior_light_functions_1_to_70-Light_function_18,not active ,9
ENG253344-ENG259229-Interior_light_functions_1_to_70-Light_function_19,not active ,9
ENG253344-ENG253470-Interior_light_functions_1_to_70-Light_function_2,not active ,9
ENG253344-ENG259487-Interior_light_functions_1_to_70-Light_function_20,not active ,9
ENG253344-ENG259385-Interior_light_functions_1_to_70-Light_function_21,not active ,9
ENG253344-ENG259785-Interior_light_functions_1_to_70-Light_function_22,not active ,9
ENG253344-ENG258581-Interior_light_functions_1_to_70-Light_function_23,not active ,9
ENG253344-ENG260265-Interior_light_functions_1_to_70-Light_function_24,not active ,9
ENG253344-ENG261256-Interior_light_functions_1_to_70-Light_function_25,not active ,9
ENG253344-ENG260361-Interior_light_functions_1_to_70-Light_function_26,not active ,9
ENG253344-ENG259100-Interior_light_functions_1_to_70-Light_function_27,not active ,9
ENG253344-ENG260930-Interior_light_functions_1_to_70-Light_function_28,not active ,9
ENG253344-ENG259955-Interior_light_functions_1_to_70-Light_function_29,not active ,9
ENG253344-ENG253471-Interior_light_functions_1_to_70-Light_function_3,active ,9
ENG253344-ENG259370-Interior_light_functions_1_to_70-Light_function_30,active ,9
ENG253344-ENG261130-Interior_light_functions_1_to_70-Light_function_31,active ,9
ENG253344-ENG258748-Interior_light_functions_1_to_70-Light_function_32,not active ,9
ENG253344-ENG260955-Interior_light_functions_1_to_70-Light_function_33,not active ,9
ENG253344-ENG259496-Interior_light_functions_1_to_70-Light_function_34,not active ,9
ENG253344-ENG258588-Interior_light_functions_1_to_70-Light_function_35,not active ,9
ENG253344-ENG259600-Interior_light_functions_1_to_70-Light_function_36,not active ,9
ENG253344-ENG259095-Interior_light_functions_1_to_70-Light_function_37,active ,9
ENG253344-ENG260346-Interior_light_functions_1_to_70-Light_function_38,active ,9
ENG253344-ENG259274-Interior_light_functions_1_to_70-Light_function_39,active ,9
ENG253344-ENG260499-Interior_light_functions_1_to_70-Light_function_4,not active ,9
ENG253344-ENG258529-Interior_light_functions_1_to_70-Light_function_40,active ,9
ENG253344-ENG258505-Interior_light_functions_1_to_70-Light_function_41,not active ,9
ENG253344-ENG258603-Interior_light_functions_1_to_70-Light_function_42,not active ,9
ENG253344-ENG259158-Interior_light_functions_1_to_70-Light_function_43,not active ,9
ENG253344-ENG260244-Interior_light_functions_1_to_70-Light_function_44,not active ,9
ENG253344-ENG260634-Interior_light_functions_1_to_70-Light_function_45,not active ,9
ENG253344-ENG258174-Interior_light_functions_1_to_70-Light_function_46,not active ,9
ENG253344-ENG260984-Interior_light_functions_1_to_70-Light_function_47,not active ,9
ENG253344-ENG258949-Interior_light_functions_1_to_70-Light_function_48,not active ,9
ENG253344-ENG259994-Interior_light_functions_1_to_70-Light_function_49,not active ,9
ENG253344-ENG258326-Interior_light_functions_1_to_70-Light_function_5,not active ,9
ENG253344-ENG259724-Interior_light_functions_1_to_70-Light_function_50,not active ,9
ENG253344-ENG259989-Interior_light_functions_1_to_70-Light_function_51,not active ,9
ENG253344-ENG259580-Interior_light_functions_1_to_70-Light_function_52,not active ,9
ENG253344-ENG258381-Interior_light_functions_1_to_70-Light_function_53,not active ,9
ENG253344-ENG259438-Interior_light_functions_1_to_70-Light_function_54,not active ,9
ENG253344-ENG261290-Interior_light_functions_1_to_70-Light_function_55,not active ,9
ENG253344-ENG259516-Interior_light_functions_1_to_70-Light_function_56,not active ,9
ENG253344-ENG261086-Interior_light_functions_1_to_70-Light_function_57,not active ,9
ENG253344-ENG260704-Interior_light_functions_1_to_70-Light_function_58,not active ,9
ENG253344-ENG258566-Interior_light_functions_1_to_70-Light_function_59,not active ,9
ENG253344-ENG261278-Interior_light_functions_1_to_70-Light_function_6,not active ,9
ENG253344-ENG260248-Interior_light_functions_1_to_70-Light_function_60,not active ,9
ENG253344-ENG260845-Interior_light_functions_1_to_70-Light_function_61,not active ,9
ENG253344-ENG258817-Interior_light_functions_1_to_70-Light_function_62,not active ,9
ENG253344-ENG260488-Interior_light_functions_1_to_70-Light_function_63,not active ,9
ENG253344-ENG259000-Interior_light_functions_1_to_70-Light_function_64,not active ,9
ENG253344-ENG260181-Interior_light_functions_1_to_70-Light_function_65,not active ,9
ENG253344-ENG259146-Interior_light_functions_1_to_70-Light_function_66,not active ,9
ENG253344-ENG258530-Interior_light_functions_1_to_70-Light_function_67,not active ,9
ENG253344-ENG261172-Interior_light_functions_1_to_70-Light_function_68,not active ,9
ENG253344-ENG258454-Interior_light_functions_1_to_70-Light_function_69,not active ,9
ENG253344-ENG259680-Interior_light_functions_1_to_70-Light_function_7,not active ,9
ENG253344-ENG260506-Interior_light_functions_1_to_70-Light_function_70,not active ,9
ENG253344-ENG258912-Interior_light_functions_1_to_70-Light_function_8,active ,9
ENG253344-ENG258633-Interior_light_functions_1_to_70-Light_function_9,not active ,9
ENG253391-ENG258190-Interior_light_general_settings-Automatic_ambiance_lighting_with_fpa,active ,14
ENG253391-ENG403484-Interior_light_general_settings-Automatic_intensity_adjustment,not active ,14
ENG253391-ENG259555-Interior_light_general_settings-Crash_color,01 ,14
ENG253391-ENG259741-Interior_light_general_settings-Door_warning_light,not active ,14
ENG253391-ENG258939-Interior_light_general_settings-Door_warning_light_brightness,100 %,14
ENG253391-ENG258181-Interior_light_general_settings-Door_warning_light_color,01 ,14
ENG253391-ENG259296-Interior_light_general_settings-Innenlicht_durch_Fahrerassistenz,active ,14
ENG253391-ENG261240-Interior_light_general_settings-Interior_light_activation_by_opening_trunk,active ,14
ENG253391-ENG261275-Interior_light_general_settings-Interior_light_alternative_clamp_control_entry,not active ,14
ENG253391-ENG260888-Interior_light_general_settings-Interior_light_alternative_clamp_control_exit,not active ,14
ENG253391-ENG258268-Interior_light_general_settings-interior_light_color,01 ,14
ENG253391-ENG260936-Interior_light_general_settings-Interior_light_dependency_on_key_or_belt_buckle,02 ,14
ENG253391-ENG259666-Interior_light_general_settings-Interior_light_function,active ,14
ENG253391-ENG260600-Interior_light_general_settings-Interior_light_trunk_light,active ,14
ENG253391-ENG259259-Interior_light_general_settings-Kl30alm,active ,14
ENG253391-ENG259746-Interior_light_general_settings-Kl30G_activation_by_opening_trunk,active ,14
ENG253391-ENG260275-Interior_light_general_settings-Kl30G_wake_up_behaviour,not active ,14
ENG253391-ENG259384-Interior_light_general_settings-Kl30G_without_pwm,not active ,14
ENG253391-ENG258730-Interior_light_general_settings-Kl58_color,01 ,14
ENG253391-ENG260492-Interior_light_general_settings-Mapping_fpa_profile_1,1 ,14
ENG253391-ENG261042-Interior_light_general_settings-Mapping_fpa_profile_2,5 ,14
ENG253391-ENG258453-Interior_light_general_settings-Mapping_fpa_profile_3,3 ,14
ENG253391-ENG260820-Interior_light_general_settings-Mapping_fpa_profile_4,4 ,14
ENG253391-ENG258889-Interior_light_general_settings-Mapping_fpa_profile_5,2 ,14
ENG253391-ENG260732-Interior_light_general_settings-Mapping_fpa_profile_6,7 ,14
ENG253391-ENG260062-Interior_light_general_settings-Mfg_interior_light_color,01 ,14
ENG253391-ENG403552-Interior_light_general_settings-Overvoltage_deactivation,active ,14
ENG253391-ENG260638-Interior_light_general_settings-Pso_active_participant_ambient_lighting_interior_enabled,active ,14
ENG253391-ENG258979-Interior_light_general_settings-roof_console_installed,active ,14
ENG253391-ENG258685-Interior_light_general_settings-Trunk_light_brightness,100 %,14
ENG253391-ENG260452-Interior_light_general_settings-Trunk_light_color,01 ,14
ENG253391-ENG403611-Interior_light_general_settings-Undervoltage_deactivation,active ,14
ENG253223-ENG260423-Interior_light_hmi_config-Bytes 25-60,00 10 00 00 00 04 00 00 00 08 00 00 0C 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,100
ENG253223-ENG259513-Interior_light_hmi_config-Hmi_adaption_customer_wish_IlluminationSet_1,64 ,100
ENG253223-ENG260783-Interior_light_hmi_config-Hmi_adaption_customer_wish_IlluminationSet_2,64 ,100
ENG253223-ENG260290-Interior_light_hmi_config-Hmi_adaption_customer_wish_IlluminationSet_3,64 ,100
ENG253223-ENG258130-Interior_light_hmi_config-Hmi_adaption_customer_wish_IlluminationSet_4,64 ,100
ENG253223-ENG259034-Interior_light_hmi_config-Hmi_adaption_customer_wish_IlluminationSet_5,64 ,100
ENG253223-ENG259728-Interior_light_hmi_config-Hmi_adaption_customer_wish_IlluminationSet_6,64 ,100
ENG253223-ENG258649-Interior_light_hmi_config-Hmi_adaption_customer_wish_IlluminationSet_7,64 ,100
ENG253223-ENG258756-Interior_light_hmi_config-Hmi_adaption_customer_wish_IlluminationSet_8,64 ,100
ENG253223-ENG260831-Interior_light_hmi_config-Hmi_ambient_color,active ,100
ENG253223-ENG258324-Interior_light_hmi_config-Hmi_ambient_colors_bitmask,3F FF FF FF ,100
ENG253223-ENG258789-Interior_light_hmi_config-Hmi_ambient_colors_fod_bitmask,3F FF FF FF ,100
ENG253223-ENG260180-Interior_light_hmi_config-Hmi_ambient_profile_1,active ,100
ENG253223-ENG258163-Interior_light_hmi_config-Hmi_ambient_profile_2,active ,100
ENG253223-ENG258800-Interior_light_hmi_config-Hmi_ambient_profile_3,active ,100
ENG253223-ENG258761-Interior_light_hmi_config-Hmi_ambient_profile_4,active ,100
ENG253223-ENG259948-Interior_light_hmi_config-Hmi_ambient_profile_5,active ,100
ENG253223-ENG261117-Interior_light_hmi_config-Hmi_ambient_profile_6,active ,100
ENG253223-ENG258601-Interior_light_hmi_config-Hmi_ambient_profile_7,active ,100
ENG253223-ENG259615-Interior_light_hmi_config-Hmi_ambient_profile_8,active ,100
ENG253223-ENG258875-Interior_light_hmi_config-Hmi_config_fixed_color_play_of_colors,01 ,100
ENG253223-ENG260154-Interior_light_hmi_config-Hmi_config_hmi_preview,active ,100
ENG253223-ENG258806-Interior_light_hmi_config-Hmi_config_linked_zone_illumination_set_1,00 ,100
ENG253223-ENG260370-Interior_light_hmi_config-Hmi_config_linked_zone_illumination_set_2,00 ,100
ENG253223-ENG261327-Interior_light_hmi_config-Hmi_config_linked_zone_illumination_set_3,00 ,100
ENG253223-ENG260102-Interior_light_hmi_config-Hmi_config_linked_zone_illumination_set_4,00 ,100
ENG253223-ENG259550-Interior_light_hmi_config-Hmi_config_linked_zone_illumination_set_5,00 ,100
ENG253223-ENG258870-Interior_light_hmi_config-Hmi_config_linked_zone_illumination_set_6,00 ,100
ENG253223-ENG260001-Interior_light_hmi_config-Hmi_config_linked_zone_illumination_set_7,00 ,100
ENG253223-ENG259068-Interior_light_hmi_config-Hmi_config_linked_zone_illumination_set_8,00 ,100
ENG253223-ENG259772-Interior_light_hmi_config-Hmi_config_member_bottom_color_scheme_1,03 ,100
ENG253223-ENG259687-Interior_light_hmi_config-Hmi_config_member_bottom_color_scheme_2,02 ,100
ENG253223-ENG259129-Interior_light_hmi_config-Hmi_config_member_bottom_color_scheme_3,02 ,100
ENG253223-ENG260699-Interior_light_hmi_config-Hmi_config_member_bottom_color_scheme_4,02 ,100
ENG253223-ENG259317-Interior_light_hmi_config-Hmi_config_member_bottom_color_scheme_5,03 ,100
ENG253223-ENG258480-Interior_light_hmi_config-Hmi_config_member_bottom_color_scheme_6,00 ,100
ENG253223-ENG261090-Interior_light_hmi_config-Hmi_config_member_bottom_color_scheme_7,00 ,100
ENG253223-ENG258664-Interior_light_hmi_config-Hmi_config_member_bottom_color_scheme_8,00 ,100
ENG253223-ENG261119-Interior_light_hmi_config-Hmi_config_member_center_bottom_color_scheme_1,03 ,100
ENG253223-ENG259685-Interior_light_hmi_config-Hmi_config_member_center_bottom_color_scheme_2,02 ,100
ENG253223-ENG260690-Interior_light_hmi_config-Hmi_config_member_center_bottom_color_scheme_3,02 ,100
ENG253223-ENG259252-Interior_light_hmi_config-Hmi_config_member_center_bottom_color_scheme_4,03 ,100
ENG253223-ENG258904-Interior_light_hmi_config-Hmi_config_member_center_bottom_color_scheme_5,02 ,100
ENG253223-ENG260909-Interior_light_hmi_config-Hmi_config_member_center_bottom_color_scheme_6,00 ,100
ENG253223-ENG258840-Interior_light_hmi_config-Hmi_config_member_center_bottom_color_scheme_7,00 ,100
ENG253223-ENG260828-Interior_light_hmi_config-Hmi_config_member_center_bottom_color_scheme_8,00 ,100
ENG253223-ENG259535-Interior_light_hmi_config-Hmi_config_member_center_color_scheme_1,03 ,100
ENG253223-ENG259249-Interior_light_hmi_config-Hmi_config_member_center_color_scheme_2,02 ,100
ENG253223-ENG258349-Interior_light_hmi_config-Hmi_config_member_center_color_scheme_3,03 ,100
ENG253223-ENG260458-Interior_light_hmi_config-Hmi_config_member_center_color_scheme_4,02 ,100
ENG253223-ENG258285-Interior_light_hmi_config-Hmi_config_member_center_color_scheme_5,02 ,100
ENG253223-ENG258936-Interior_light_hmi_config-Hmi_config_member_center_color_scheme_6,00 ,100
ENG253223-ENG260143-Interior_light_hmi_config-Hmi_config_member_center_color_scheme_7,00 ,100
ENG253223-ENG259986-Interior_light_hmi_config-Hmi_config_member_center_color_scheme_8,00 ,100
ENG253223-ENG260694-Interior_light_hmi_config-Hmi_config_member_center_top_color_scheme_1,03 ,100
ENG253223-ENG259604-Interior_light_hmi_config-Hmi_config_member_center_top_color_scheme_2,02 ,100
ENG253223-ENG258410-Interior_light_hmi_config-Hmi_config_member_center_top_color_scheme_3,03 ,100
ENG253223-ENG261012-Interior_light_hmi_config-Hmi_config_member_center_top_color_scheme_4,02 ,100
ENG253223-ENG259932-Interior_light_hmi_config-Hmi_config_member_center_top_color_scheme_5,02 ,100
ENG253223-ENG260104-Interior_light_hmi_config-Hmi_config_member_center_top_color_scheme_6,00 ,100
ENG253223-ENG260125-Interior_light_hmi_config-Hmi_config_member_center_top_color_scheme_7,00 ,100
ENG253223-ENG259125-Interior_light_hmi_config-Hmi_config_member_center_top_color_scheme_8,00 ,100
ENG253223-ENG260419-Interior_light_hmi_config-Hmi_config_member_top_color_scheme_1,03 ,100
ENG253223-ENG261132-Interior_light_hmi_config-Hmi_config_member_top_color_scheme_2,03 ,100
ENG253223-ENG260056-Interior_light_hmi_config-Hmi_config_member_top_color_scheme_3,03 ,100
ENG253223-ENG259330-Interior_light_hmi_config-Hmi_config_member_top_color_scheme_4,03 ,100
ENG253223-ENG258990-Interior_light_hmi_config-Hmi_config_member_top_color_scheme_5,03 ,100
ENG253223-ENG259936-Interior_light_hmi_config-Hmi_config_member_top_color_scheme_6,00 ,100
ENG253223-ENG258422-Interior_light_hmi_config-Hmi_config_member_top_color_scheme_7,00 ,100
ENG253223-ENG258463-Interior_light_hmi_config-Hmi_config_member_top_color_scheme_8,00 ,100
ENG253223-ENG258418-Interior_light_hmi_config-Hmi_config_timer_hmi_preview,5 s,100
ENG253223-ENG259957-Interior_light_hmi_config-Hmi_contour_color,active ,100
ENG253223-ENG259365-Interior_light_hmi_config-Hmi_contour_colors_bitmask,3F FF FF FF ,100
ENG253223-ENG259211-Interior_light_hmi_config-Hmi_contour_colors_fod_bitmask,3F FF FF FF ,100
ENG253223-ENG260051-Interior_light_hmi_config-Hmi_Display_Color_light_function,01 ,100
ENG253223-ENG258352-Interior_light_hmi_config-Hmi_door_contact,not active ,100
ENG253223-ENG258250-Interior_light_hmi_config-Hmi_fpa_dependency,active ,100
ENG253223-ENG260229-Interior_light_hmi_config-Hmi_functional_ambiance_lighting_list,not active ,100
ENG253223-ENG258930-Interior_light_hmi_config-Hmi_functional_ambience_lighting,not active ,100
ENG253223-ENG258483-Interior_light_hmi_config-Hmi_menu_ambient_lighting,active ,100
ENG253223-ENG261116-Interior_light_hmi_config-Hmi_play_of_colors,active ,100
ENG253223-ENG260969-Interior_light_hmi_config-Hmi_setup_set_1,06 ,100
ENG253223-ENG260367-Interior_light_hmi_config-Hmi_setup_set_2,07 ,100
ENG253223-ENG259030-Interior_light_hmi_config-Hmi_setup_set_3,13 ,100
ENG253223-ENG260913-Interior_light_hmi_config-Hmi_setup_set_4,05 ,100
ENG253223-ENG258666-Interior_light_hmi_config-Hmi_setup_set_5,FF ,100
ENG253223-ENG259988-Interior_light_hmi_config-Hmi_setup_set_6,FF ,100
ENG253223-ENG258907-Interior_light_hmi_config-Hmi_setup_set_7,FF ,100
ENG253223-ENG258492-Interior_light_hmi_config-Hmi_setup_set_8,FF ,100
ENG253223-ENG259126-Interior_light_hmi_config-roof_console_door_contact,active ,100
ENG253355-Interior_light_interface_function,No_voltage_requirement ,1
ENG253312-ENG259098-Interior_light_lin_slaves_config-Failure_location_lin10_slave_1,00 ,51
ENG253312-ENG261000-Interior_light_lin_slaves_config-Failure_location_lin10_slave_10,00 ,51
ENG253312-ENG260844-Interior_light_lin_slaves_config-Failure_location_lin10_slave_11,00 ,51
ENG253312-ENG260815-Interior_light_lin_slaves_config-Failure_location_lin10_slave_12,00 ,51
ENG253312-ENG260672-Interior_light_lin_slaves_config-Failure_location_lin10_slave_13,00 ,51
ENG253312-ENG260204-Interior_light_lin_slaves_config-Failure_location_lin10_slave_14,00 ,51
ENG253312-ENG258398-Interior_light_lin_slaves_config-Failure_location_lin10_slave_15,00 ,51
ENG253312-ENG258994-Interior_light_lin_slaves_config-Failure_location_lin10_slave_2,00 ,51
ENG253312-ENG258883-Interior_light_lin_slaves_config-Failure_location_lin10_slave_3,00 ,51
ENG253312-ENG259653-Interior_light_lin_slaves_config-Failure_location_lin10_slave_4,11 ,51
ENG253312-ENG261303-Interior_light_lin_slaves_config-Failure_location_lin10_slave_5,00 ,51
ENG253312-ENG259057-Interior_light_lin_slaves_config-Failure_location_lin10_slave_6,00 ,51
ENG253312-ENG260484-Interior_light_lin_slaves_config-Failure_location_lin10_slave_7,00 ,51
ENG253312-ENG260881-Interior_light_lin_slaves_config-Failure_location_lin10_slave_8,22 ,51
ENG253312-ENG260091-Interior_light_lin_slaves_config-Failure_location_lin10_slave_9,23 ,51
ENG253312-ENG259183-Interior_light_lin_slaves_config-Failure_location_lin5_slave_1,00 ,51
ENG253312-ENG258660-Interior_light_lin_slaves_config-Failure_location_lin5_slave_10,00 ,51
ENG253312-ENG260169-Interior_light_lin_slaves_config-Failure_location_lin5_slave_11,00 ,51
ENG253312-ENG261201-Interior_light_lin_slaves_config-Failure_location_lin5_slave_12,00 ,51
ENG253312-ENG259253-Interior_light_lin_slaves_config-Failure_location_lin5_slave_13,00 ,51
ENG253312-ENG259633-Interior_light_lin_slaves_config-Failure_location_lin5_slave_14,00 ,51
ENG253312-ENG258313-Interior_light_lin_slaves_config-Failure_location_lin5_slave_15,00 ,51
ENG253312-ENG260266-Interior_light_lin_slaves_config-Failure_location_lin5_slave_2,00 ,51
ENG253312-ENG259102-Interior_light_lin_slaves_config-Failure_location_lin5_slave_3,00 ,51
ENG253312-ENG259003-Interior_light_lin_slaves_config-Failure_location_lin5_slave_4,08 ,51
ENG253312-ENG260961-Interior_light_lin_slaves_config-Failure_location_lin5_slave_5,00 ,51
ENG253312-ENG259969-Interior_light_lin_slaves_config-Failure_location_lin5_slave_6,00 ,51
ENG253312-ENG258881-Interior_light_lin_slaves_config-Failure_location_lin5_slave_7,00 ,51
ENG253312-ENG260157-Interior_light_lin_slaves_config-Failure_location_lin5_slave_8,19 ,51
ENG253312-ENG258637-Interior_light_lin_slaves_config-Failure_location_lin5_slave_9,1A ,51
ENG253312-ENG259033-Interior_light_lin_slaves_config-Failure_location_lin9_slave_1,00 ,51
ENG253312-ENG260297-Interior_light_lin_slaves_config-Failure_location_lin9_slave_10,00 ,51
ENG253312-ENG259053-Interior_light_lin_slaves_config-Failure_location_lin9_slave_11,00 ,51
ENG253312-ENG260470-Interior_light_lin_slaves_config-Failure_location_lin9_slave_12,00 ,51
ENG253312-ENG259540-Interior_light_lin_slaves_config-Failure_location_lin9_slave_13,00 ,51
ENG253312-ENG258446-Interior_light_lin_slaves_config-Failure_location_lin9_slave_14,00 ,51
ENG253312-ENG260819-Interior_light_lin_slaves_config-Failure_location_lin9_slave_15,00 ,51
ENG253312-ENG260376-Interior_light_lin_slaves_config-Failure_location_lin9_slave_2,2A ,51
ENG253312-ENG260700-Interior_light_lin_slaves_config-Failure_location_lin9_slave_3,2B ,51
ENG253312-ENG259312-Interior_light_lin_slaves_config-Failure_location_lin9_slave_4,00 ,51
ENG253312-ENG260870-Interior_light_lin_slaves_config-Failure_location_lin9_slave_5,00 ,51
ENG253312-ENG259978-Interior_light_lin_slaves_config-Failure_location_lin9_slave_6,00 ,51
ENG253312-ENG260092-Interior_light_lin_slaves_config-Failure_location_lin9_slave_7,00 ,51
ENG253312-ENG260166-Interior_light_lin_slaves_config-Failure_location_lin9_slave_8,00 ,51
ENG253312-ENG259286-Interior_light_lin_slaves_config-Failure_location_lin9_slave_9,00 ,51
ENG253312-ENG261097-Interior_light_lin_slaves_config-Lin10_slave_1,not installed ,51
ENG253312-ENG261248-Interior_light_lin_slaves_config-Lin10_slave_10,not installed ,51
ENG253312-ENG260250-Interior_light_lin_slaves_config-Lin10_slave_11,not installed ,51
ENG253312-ENG260843-Interior_light_lin_slaves_config-Lin10_slave_12,not installed ,51
ENG253312-ENG258140-Interior_light_lin_slaves_config-Lin10_slave_13,not installed ,51
ENG253312-ENG260746-Interior_light_lin_slaves_config-Lin10_slave_14,not installed ,51
ENG253312-ENG259479-Interior_light_lin_slaves_config-Lin10_slave_15,not installed ,51
ENG253312-ENG259817-Interior_light_lin_slaves_config-Lin10_slave_2,not installed ,51
ENG253312-ENG258374-Interior_light_lin_slaves_config-Lin10_slave_3,not installed ,51
ENG253312-ENG259748-Interior_light_lin_slaves_config-Lin10_slave_4,installed ,51
ENG253312-ENG261167-Interior_light_lin_slaves_config-Lin10_slave_5,not installed ,51
ENG253312-ENG260490-Interior_light_lin_slaves_config-Lin10_slave_6,not installed ,51
ENG253312-ENG260905-Interior_light_lin_slaves_config-Lin10_slave_7,not installed ,51
ENG253312-ENG259342-Interior_light_lin_slaves_config-Lin10_slave_8,installed ,51
ENG253312-ENG260924-Interior_light_lin_slaves_config-Lin10_slave_9,installed ,51
ENG253312-ENG260567-Interior_light_lin_slaves_config-Lin5_slave_1,not installed ,51
ENG253312-ENG260991-Interior_light_lin_slaves_config-Lin5_slave_10,not installed ,51
ENG253312-ENG260074-Interior_light_lin_slaves_config-Lin5_slave_11,not installed ,51
ENG253312-ENG260190-Interior_light_lin_slaves_config-Lin5_slave_12,not installed ,51
ENG253312-ENG258636-Interior_light_lin_slaves_config-Lin5_slave_13,not installed ,51
ENG253312-ENG261344-Interior_light_lin_slaves_config-Lin5_slave_14,not installed ,51
ENG253312-ENG259457-Interior_light_lin_slaves_config-Lin5_slave_15,not installed ,51
ENG253312-ENG258488-Interior_light_lin_slaves_config-Lin5_slave_2,not installed ,51
ENG253312-ENG259073-Interior_light_lin_slaves_config-Lin5_slave_3,not installed ,51
ENG253312-ENG258217-Interior_light_lin_slaves_config-Lin5_slave_4,installed ,51
ENG253312-ENG259044-Interior_light_lin_slaves_config-Lin5_slave_5,not installed ,51
ENG253312-ENG258512-Interior_light_lin_slaves_config-Lin5_slave_6,not installed ,51
ENG253312-ENG261216-Interior_light_lin_slaves_config-Lin5_slave_7,not installed ,51
ENG253312-ENG259326-Interior_light_lin_slaves_config-Lin5_slave_8,installed ,51
ENG253312-ENG258818-Interior_light_lin_slaves_config-Lin5_slave_9,installed ,51
ENG253312-ENG261286-Interior_light_lin_slaves_config-Lin9_slave_1,not installed ,51
ENG253312-ENG260287-Interior_light_lin_slaves_config-Lin9_slave_10,not installed ,51
ENG253312-ENG259769-Interior_light_lin_slaves_config-Lin9_slave_11,not installed ,51
ENG253312-ENG258599-Interior_light_lin_slaves_config-Lin9_slave_12,not installed ,51
ENG253312-ENG261101-Interior_light_lin_slaves_config-Lin9_slave_13,not installed ,51
ENG253312-ENG258193-Interior_light_lin_slaves_config-Lin9_slave_14,not installed ,51
ENG253312-ENG260653-Interior_light_lin_slaves_config-Lin9_slave_15,not installed ,51
ENG253312-ENG258200-Interior_light_lin_slaves_config-Lin9_slave_2,installed ,51
ENG253312-ENG260161-Interior_light_lin_slaves_config-Lin9_slave_3,installed ,51
ENG253312-ENG258186-Interior_light_lin_slaves_config-Lin9_slave_4,not installed ,51
ENG253312-ENG260052-Interior_light_lin_slaves_config-Lin9_slave_5,not installed ,51
ENG253312-ENG259941-Interior_light_lin_slaves_config-Lin9_slave_6,not installed ,51
ENG253312-ENG259228-Interior_light_lin_slaves_config-Lin9_slave_7,not installed ,51
ENG253312-ENG260950-Interior_light_lin_slaves_config-Lin9_slave_8,not installed ,51
ENG253312-ENG260524-Interior_light_lin_slaves_config-Lin9_slave_9,not installed ,51
ENG253400-ENG259423-Interior_light_router_config-Output_bcm_amb1_light_function,00 ,93
ENG253400-ENG258209-Interior_light_router_config-Output_bcm_amb2_light_function,00 ,93
ENG253400-ENG261174-Interior_light_router_config-Output_bcm_amb3_light_function,00 ,93
ENG253400-ENG259810-Interior_light_router_config-Output_bcm_amb4_light_function,00 ,93
ENG253400-ENG261141-Interior_light_router_config-Output_bcm_frl_light_function,03 ,93
ENG253400-ENG258669-Interior_light_router_config-Output_BCM_interiorlight,00 ,93
ENG253400-ENG260789-Interior_light_router_config-Output_bcm_krl_light_function,FE ,93
ENG253400-ENG263574-Interior_light_router_config-Output_interior_light_master_door_warning_lights_front_left,00 ,93
ENG253400-ENG263530-Interior_light_router_config-Output_interior_light_master_door_warning_lights_front_right,00 ,93
ENG253400-ENG263557-Interior_light_router_config-Output_interior_light_master_door_warning_lights_rear_left,00 ,93
ENG253400-ENG263579-Interior_light_router_config-Output_interior_light_master_door_warning_lights_rear_right,00 ,93
ENG253400-ENG259911-Interior_light_router_config-Output_lin10_light_function_slave_1,00 ,93
ENG253400-ENG261157-Interior_light_router_config-Output_lin10_light_function_slave_10,00 ,93
ENG253400-ENG259627-Interior_light_router_config-Output_lin10_light_function_slave_11,00 ,93
ENG253400-ENG260063-Interior_light_router_config-Output_lin10_light_function_slave_12,00 ,93
ENG253400-ENG260392-Interior_light_router_config-Output_lin10_light_function_slave_13,00 ,93
ENG253400-ENG261033-Interior_light_router_config-Output_lin10_light_function_slave_14,00 ,93
ENG253400-ENG260756-Interior_light_router_config-Output_lin10_light_function_slave_15,00 ,93
ENG253400-ENG259504-Interior_light_router_config-Output_lin10_light_function_slave_2,00 ,93
ENG253400-ENG259442-Interior_light_router_config-Output_lin10_light_function_slave_3,00 ,93
ENG253400-ENG260805-Interior_light_router_config-Output_lin10_light_function_slave_4,0A ,93
ENG253400-ENG258266-Interior_light_router_config-Output_lin10_light_function_slave_5,00 ,93
ENG253400-ENG259364-Interior_light_router_config-Output_lin10_light_function_slave_6,00 ,93
ENG253400-ENG258390-Interior_light_router_config-Output_lin10_light_function_slave_7,00 ,93
ENG253400-ENG259292-Interior_light_router_config-Output_lin10_light_function_slave_8,27 ,93
ENG253400-ENG258719-Interior_light_router_config-Output_lin10_light_function_slave_9,28 ,93
ENG253400-ENG259289-Interior_light_router_config-Output_lin5_light_function_slave_1,00 ,93
ENG253400-ENG260386-Interior_light_router_config-Output_lin5_light_function_slave_10,00 ,93
ENG253400-ENG259124-Interior_light_router_config-Output_lin5_light_function_slave_11,00 ,93
ENG253400-ENG259695-Interior_light_router_config-Output_lin5_light_function_slave_12,00 ,93
ENG253400-ENG260422-Interior_light_router_config-Output_lin5_light_function_slave_13,00 ,93
ENG253400-ENG261133-Interior_light_router_config-Output_lin5_light_function_slave_14,00 ,93
ENG253400-ENG258921-Interior_light_router_config-Output_lin5_light_function_slave_15,00 ,93
ENG253400-ENG260665-Interior_light_router_config-Output_lin5_light_function_slave_2,00 ,93
ENG253400-ENG260238-Interior_light_router_config-Output_lin5_light_function_slave_3,00 ,93
ENG253400-ENG260068-Interior_light_router_config-Output_lin5_light_function_slave_4,08 ,93
ENG253400-ENG260774-Interior_light_router_config-Output_lin5_light_function_slave_5,00 ,93
ENG253400-ENG258506-Interior_light_router_config-Output_lin5_light_function_slave_6,00 ,93
ENG253400-ENG259536-Interior_light_router_config-Output_lin5_light_function_slave_7,00 ,93
ENG253400-ENG260354-Interior_light_router_config-Output_lin5_light_function_slave_8,25 ,93
ENG253400-ENG261251-Interior_light_router_config-Output_lin5_light_function_slave_9,26 ,93
ENG253400-ENG259104-Interior_light_router_config-Output_lin9_light_function_slave_1,00 ,93
ENG253400-ENG260459-Interior_light_router_config-Output_lin9_light_function_slave_10,00 ,93
ENG253400-ENG259020-Interior_light_router_config-Output_lin9_light_function_slave_11,00 ,93
ENG253400-ENG260441-Interior_light_router_config-Output_lin9_light_function_slave_12,00 ,93
ENG253400-ENG260308-Interior_light_router_config-Output_lin9_light_function_slave_13,00 ,93
ENG253400-ENG258226-Interior_light_router_config-Output_lin9_light_function_slave_14,00 ,93
ENG253400-ENG259889-Interior_light_router_config-Output_lin9_light_function_slave_15,00 ,93
ENG253400-ENG259254-Interior_light_router_config-Output_lin9_light_function_slave_2,0F ,93
ENG253400-ENG258737-Interior_light_router_config-Output_lin9_light_function_slave_3,10 ,93
ENG253400-ENG260120-Interior_light_router_config-Output_lin9_light_function_slave_4,00 ,93
ENG253400-ENG258661-Interior_light_router_config-Output_lin9_light_function_slave_5,00 ,93
ENG253400-ENG260829-Interior_light_router_config-Output_lin9_light_function_slave_6,00 ,93
ENG253400-ENG260402-Interior_light_router_config-Output_lin9_light_function_slave_7,00 ,93
ENG253400-ENG261173-Interior_light_router_config-Output_lin9_light_function_slave_8,00 ,93
ENG253400-ENG260176-Interior_light_router_config-Output_lin9_light_function_slave_9,00 ,93
ENG253400-ENG258236-Interior_light_router_config-Output_roof_console_1,1F ,93
ENG253400-ENG258284-Interior_light_router_config-Output_roof_console_2,1F ,93
ENG253400-ENG260269-Interior_light_router_config-Output_roof_console_3,1F ,93
ENG253400-ENG261203-Interior_light_router_config-Output_roof_console_4,1F ,93
ENG253400-ENG258705-Interior_light_router_config-Output_roof_console_5,1E ,93
ENG253400-ENG258805-Interior_light_router_config-Output_roof_console_6,1E ,93
ENG253400-ENG260327-Interior_light_router_config-Output_tsg_bfs_1,00 ,93
ENG253400-ENG259694-Interior_light_router_config-Output_tsg_bfs_2,00 ,93
ENG253400-ENG261276-Interior_light_router_config-Output_tsg_bfs_3,00 ,93
ENG253400-ENG258178-Interior_light_router_config-Output_tsg_bfs_4,00 ,93
ENG253400-ENG260821-Interior_light_router_config-Output_tsg_bfsh_1,00 ,93
ENG253400-ENG260853-Interior_light_router_config-Output_tsg_bfsh_2,00 ,93
ENG253400-ENG258859-Interior_light_router_config-Output_tsg_bfsh_3,00 ,93
ENG253400-ENG261258-Interior_light_router_config-Output_tsg_bfsh_4,00 ,93
ENG253400-ENG260340-Interior_light_router_config-Output_tsg_fs_1,00 ,93
ENG253400-ENG258105-Interior_light_router_config-Output_tsg_fs_2,00 ,93
ENG253400-ENG260046-Interior_light_router_config-Output_tsg_fs_3,00 ,93
ENG253400-ENG258946-Interior_light_router_config-Output_tsg_fs_4,00 ,93
ENG253400-ENG259611-Interior_light_router_config-Output_tsg_fsh_1,00 ,93
ENG253400-ENG258415-Interior_light_router_config-Output_tsg_fsh_2,00 ,93
ENG253400-ENG260438-Interior_light_router_config-Output_tsg_fsh_3,00 ,93
ENG253400-ENG259398-Interior_light_router_config-Output_tsg_fsh_4,00 ,93
ENG263460-ENG260021-Leuchte 16 BLK SL B42_C31-Dimming Direction DEF 16,maximize ,20
ENG263460-ENG258735-Leuchte 16 BLK SL B42_C31-Dimming Direction GHI 16,maximize ,20
ENG263460-ENG260912-Leuchte 16 BLK SL B42_C31-Dimming Direction JKL 16,maximize ,20
ENG263460-ENG260010-Leuchte 16 BLK SL B42_C31-Dimmwert ABC 16,0 ,20
ENG263460-ENG258276-Leuchte 16 BLK SL B42_C31-Dimmwert DEF 16,0 ,20
ENG263460-ENG259552-Leuchte 16 BLK SL B42_C31-Dimmwert GHI 16,0 ,20
ENG263460-ENG260945-Leuchte 16 BLK SL B42_C31-Dimmwert JKL 16,0 ,20
ENG263460-ENG116178-Leuchte 16 BLK SL B42_C31-Fehlerort mittleres Byte DTC-DFCC 16,0 ,20
ENG263460-ENG116567-Leuchte 16 BLK SL B42_C31-Lampendefektbitposition 16,0 ,20
ENG263460-ENG116176-Leuchte 16 BLK SL B42_C31-Lasttyp 16,not_active ,20
ENG263460-ENG258626-Leuchte 16 BLK SL B42_C31-Lichtansteuerung HD ABC 16,Always ,20
ENG263460-ENG116179-Leuchte 16 BLK SL B42_C31-Lichtfunktion A 16,not active ,20
ENG263460-ENG116180-Leuchte 16 BLK SL B42_C31-Lichtfunktion B 16,not active ,20
ENG263460-ENG116183-Leuchte 16 BLK SL B42_C31-Lichtfunktion C 16,not active ,20
ENG263460-ENG116184-Leuchte 16 BLK SL B42_C31-Lichtfunktion D 16,not active ,20
ENG263460-ENG116187-Leuchte 16 BLK SL B42_C31-Lichtfunktion E 16,not active ,20
ENG263460-ENG116188-Leuchte 16 BLK SL B42_C31-Lichtfunktion F 16,not active ,20
ENG263460-ENG116191-Leuchte 16 BLK SL B42_C31-Lichtfunktion G 16,not active ,20
ENG263460-ENG116192-Leuchte 16 BLK SL B42_C31-Lichtfunktion H 16,not active ,20
ENG263460-ENG261052-Leuchte 16 BLK SL B42_C31-Lichtfunktion I 16,not active ,20
ENG263460-ENG258938-Leuchte 16 BLK SL B42_C31-Lichtfunktion J 16,not active ,20
ENG263460-ENG258710-Leuchte 16 BLK SL B42_C31-Lichtfunktion K 16,not active ,20
ENG263460-ENG259847-Leuchte 16 BLK SL B42_C31-Lichtfunktion L 16,not active ,20
ENG253179-ENG258693-Leuchte 17 BLK_SR B4_A61-Dimming Direction DEF 17,maximize ,20
ENG253179-ENG259225-Leuchte 17 BLK_SR B4_A61-Dimming Direction GHI 17,maximize ,20
ENG253179-ENG260036-Leuchte 17 BLK_SR B4_A61-Dimming Direction JKL 17,maximize ,20
ENG253179-ENG259305-Leuchte 17 BLK_SR B4_A61-Dimmwert ABC 17,0 ,20
ENG253179-ENG260736-Leuchte 17 BLK_SR B4_A61-Dimmwert DEF 17,0 ,20
ENG253179-ENG261209-Leuchte 17 BLK_SR B4_A61-Dimmwert GHI 17,0 ,20
ENG253179-ENG260649-Leuchte 17 BLK_SR B4_A61-Dimmwert JKL 17,0 ,20
ENG253179-ENG116197-Leuchte 17 BLK_SR B4_A61-Fehlerort mittleres Byte DTC-DFCC 17,0 ,20
ENG253179-ENG116568-Leuchte 17 BLK_SR B4_A61-Lampendefektbitposition 17,0 ,20
ENG253179-ENG116195-Leuchte 17 BLK_SR B4_A61-Lasttyp 17,not_active ,20
ENG253179-ENG259860-Leuchte 17 BLK_SR B4_A61-Lichtansteuerung HD ABC 17,Always ,20
ENG253179-ENG116198-Leuchte 17 BLK_SR B4_A61-Lichtfunktion A 17,not active ,20
ENG253179-ENG116569-Leuchte 17 BLK_SR B4_A61-Lichtfunktion B 17,not active ,20
ENG253179-ENG116202-Leuchte 17 BLK_SR B4_A61-Lichtfunktion C 17,not active ,20
ENG253179-ENG116203-Leuchte 17 BLK_SR B4_A61-Lichtfunktion D 17,not active ,20
ENG253179-ENG116206-Leuchte 17 BLK_SR B4_A61-Lichtfunktion E 17,not active ,20
ENG253179-ENG116207-Leuchte 17 BLK_SR B4_A61-Lichtfunktion F 17,not active ,20
ENG253179-ENG116210-Leuchte 17 BLK_SR B4_A61-Lichtfunktion G 17,not active ,20
ENG253179-ENG116211-Leuchte 17 BLK_SR B4_A61-Lichtfunktion H 17,not active ,20
ENG253179-ENG258378-Leuchte 17 BLK_SR B4_A61-Lichtfunktion I 17,not active ,20
ENG253179-ENG259950-Leuchte 17 BLK_SR B4_A61-Lichtfunktion J 17,not active ,20
ENG253179-ENG259363-Leuchte 17 BLK_SR B4_A61-Lichtfunktion K 17,not active ,20
ENG253179-ENG259816-Leuchte 17 BLK_SR B4_A61-Lichtfunktion L 17,not active ,20
ENG263478-ENG260141-Leuchte 18 BLK HL A60-Dimming Direction DEF 18,minimize ,20
ENG263478-ENG258397-Leuchte 18 BLK HL A60-Dimming Direction GHI 18,maximize ,20
ENG263478-ENG259980-Leuchte 18 BLK HL A60-Dimming Direction JKL 18,maximize ,20
ENG263478-ENG261250-Leuchte 18 BLK HL A60-Dimmwert ABC 18,0 ,20
ENG263478-ENG258343-Leuchte 18 BLK HL A60-Dimmwert DEF 18,0 ,20
ENG263478-ENG258799-Leuchte 18 BLK HL A60-Dimmwert GHI 18,0 ,20
ENG263478-ENG259813-Leuchte 18 BLK HL A60-Dimmwert JKL 18,0 ,20
ENG263478-ENG116216-Leuchte 18 BLK HL A60-Fehlerort mittleres Byte DTC-DFCC 18,0 ,20
ENG263478-ENG116570-Leuchte 18 BLK HL A60-Lampendefektbitposition 18,0 ,20
ENG263478-ENG116214-Leuchte 18 BLK HL A60-Lasttyp 18,not_active ,20
ENG263478-ENG258246-Leuchte 18 BLK HL A60-Lichtansteuerung HD ABC 18,Always ,20
ENG263478-ENG116217-Leuchte 18 BLK HL A60-Lichtfunktion A 18,not active ,20
ENG263478-ENG116218-Leuchte 18 BLK HL A60-Lichtfunktion B 18,not active ,20
ENG263478-ENG116221-Leuchte 18 BLK HL A60-Lichtfunktion C 18,not active ,20
ENG263478-ENG116222-Leuchte 18 BLK HL A60-Lichtfunktion D 18,not active ,20
ENG263478-ENG116225-Leuchte 18 BLK HL A60-Lichtfunktion E 18,not active ,20
ENG263478-ENG116226-Leuchte 18 BLK HL A60-Lichtfunktion F 18,not active ,20
ENG263478-ENG116229-Leuchte 18 BLK HL A60-Lichtfunktion G 18,not active ,20
ENG263478-ENG116230-Leuchte 18 BLK HL A60-Lichtfunktion H 18,not active ,20
ENG263478-ENG259904-Leuchte 18 BLK HL A60-Lichtfunktion I 18,not active ,20
ENG263478-ENG260450-Leuchte 18 BLK HL A60-Lichtfunktion J 18,not active ,20
ENG263478-ENG258383-Leuchte 18 BLK HL A60-Lichtfunktion K 18,not active ,20
ENG263478-ENG261100-Leuchte 18 BLK HL A60-Lichtfunktion L 18,not active ,20
ENG263431-ENG258368-Leuchte 19 BLK HR C27-Dimming Direction DEF 19,minimize ,20
ENG263431-ENG260517-Leuchte 19 BLK HR C27-Dimming Direction GHI 19,maximize ,20
ENG263431-ENG260100-Leuchte 19 BLK HR C27-Dimming Direction JKL 19,maximize ,20
ENG263431-ENG259136-Leuchte 19 BLK HR C27-Dimmwert ABC 19,0 ,20
ENG263431-ENG260521-Leuchte 19 BLK HR C27-Dimmwert DEF 19,0 ,20
ENG263431-ENG260131-Leuchte 19 BLK HR C27-Dimmwert GHI 19,0 ,20
ENG263431-ENG259140-Leuchte 19 BLK HR C27-Dimmwert JKL 19,0 ,20
ENG263431-ENG116235-Leuchte 19 BLK HR C27-Fehlerort mittleres Byte DTC-DFCC 19,0 ,20
ENG263431-ENG116571-Leuchte 19 BLK HR C27-Lampendefektbitposition 19,0 ,20
ENG263431-ENG116233-Leuchte 19 BLK HR C27-Lasttyp 19,not_active ,20
ENG263431-ENG258684-Leuchte 19 BLK HR C27-Lichtansteuerung HD ABC 19,Always ,20
ENG263431-ENG116236-Leuchte 19 BLK HR C27-Lichtfunktion A 19,not active ,20
ENG263431-ENG116237-Leuchte 19 BLK HR C27-Lichtfunktion B 19,not active ,20
ENG263431-ENG116240-Leuchte 19 BLK HR C27-Lichtfunktion C 19,not active ,20
ENG263431-ENG116241-Leuchte 19 BLK HR C27-Lichtfunktion D 19,not active ,20
ENG263431-ENG116244-Leuchte 19 BLK HR C27-Lichtfunktion E 19,not active ,20
ENG263431-ENG116245-Leuchte 19 BLK HR C27-Lichtfunktion F 19,not active ,20
ENG263431-ENG116248-Leuchte 19 BLK HR C27-Lichtfunktion G 19,not active ,20
ENG263431-ENG116249-Leuchte 19 BLK HR C27-Lichtfunktion H 19,not active ,20
ENG263431-ENG258386-Leuchte 19 BLK HR C27-Lichtfunktion I 19,not active ,20
ENG263431-ENG261194-Leuchte 19 BLK HR C27-Lichtfunktion J 19,not active ,20
ENG263431-ENG260240-Leuchte 19 BLK HR C27-Lichtfunktion K 19,not active ,20
ENG263431-ENG258090-Leuchte 19 BLK HR C27-Lichtfunktion L 19,not active ,20
ENG263476-ENG258998-Leuchte 20 BR L A71-Dimming Direction DEF 20,maximize ,20
ENG263476-ENG260228-Leuchte 20 BR L A71-Dimming Direction GHI 20,minimize ,20
ENG263476-ENG258824-Leuchte 20 BR L A71-Dimming Direction JKL 20,minimize ,20
ENG263476-ENG261006-Leuchte 20 BR L A71-Dimmwert ABC 20,75 ,20
ENG263476-ENG260784-Leuchte 20 BR L A71-Dimmwert DEF 20,127 ,20
ENG263476-ENG260188-Leuchte 20 BR L A71-Dimmwert GHI 20,75 ,20
ENG263476-ENG258358-Leuchte 20 BR L A71-Dimmwert JKL 20,0 ,20
ENG263476-ENG116254-Leuchte 20 BR L A71-Fehlerort mittleres Byte DTC-DFCC 20,61 ,20
ENG263476-ENG116572-Leuchte 20 BR L A71-Lampendefektbitposition 20,18 ,20
ENG263476-ENG116252-Leuchte 20 BR L A71-Lasttyp 20,kombinierte_LED_Blink_Bremsleuchten ,20
ENG263476-ENG259045-Leuchte 20 BR L A71-Lichtansteuerung HD ABC 20,Always ,20
ENG263476-ENG116255-Leuchte 20 BR L A71-Lichtfunktion A 20,Blinken links aktiv ,20
ENG263476-ENG116256-Leuchte 20 BR L A71-Lichtfunktion B 20,not active ,20
ENG263476-ENG116259-Leuchte 20 BR L A71-Lichtfunktion C 20,not active ,20
ENG263476-ENG116260-Leuchte 20 BR L A71-Lichtfunktion D 20,Brake lamp ,20
ENG263476-ENG116263-Leuchte 20 BR L A71-Lichtfunktion E 20,not active ,20
ENG263476-ENG116264-Leuchte 20 BR L A71-Lichtfunktion F 20,not active ,20
ENG263476-ENG116267-Leuchte 20 BR L A71-Lichtfunktion G 20,Blinken links aktiv ,20
ENG263476-ENG116268-Leuchte 20 BR L A71-Lichtfunktion H 20,not active ,20
ENG263476-ENG259111-Leuchte 20 BR L A71-Lichtfunktion I 20,not active ,20
ENG263476-ENG259768-Leuchte 20 BR L A71-Lichtfunktion J 20,Blinken links Dunkelphase ,20
ENG263476-ENG260741-Leuchte 20 BR L A71-Lichtfunktion K 20,not active ,20
ENG263476-ENG258272-Leuchte 20 BR L A71-Lichtfunktion L 20,not active ,20
ENG263446-ENG259371-Leuchte 21 BR R C8-Dimming Direction DEF 21,maximize ,20
ENG263446-ENG261222-Leuchte 21 BR R C8-Dimming Direction GHI 21,minimize ,20
ENG263446-ENG260449-Leuchte 21 BR R C8-Dimming Direction JKL 21,minimize ,20
ENG263446-ENG260142-Leuchte 21 BR R C8-Dimmwert ABC 21,75 ,20
ENG263446-ENG259169-Leuchte 21 BR R C8-Dimmwert DEF 21,127 ,20
ENG263446-ENG258330-Leuchte 21 BR R C8-Dimmwert GHI 21,75 ,20
ENG263446-ENG260224-Leuchte 21 BR R C8-Dimmwert JKL 21,0 ,20
ENG263446-ENG116273-Leuchte 21 BR R C8-Fehlerort mittleres Byte DTC-DFCC 21,62 ,20
ENG263446-ENG116573-Leuchte 21 BR R C8-Lampendefektbitposition 21,34 ,20
ENG263446-ENG116271-Leuchte 21 BR R C8-Lasttyp 21,kombinierte_LED_Blink_Bremsleuchten ,20
ENG263446-ENG259749-Leuchte 21 BR R C8-Lichtansteuerung HD ABC 21,Always ,20
ENG263446-ENG116274-Leuchte 21 BR R C8-Lichtfunktion A 21,Blinken rechts aktiv ,20
ENG263446-ENG116275-Leuchte 21 BR R C8-Lichtfunktion B 21,not active ,20
ENG263446-ENG116278-Leuchte 21 BR R C8-Lichtfunktion C 21,not active ,20
ENG263446-ENG116279-Leuchte 21 BR R C8-Lichtfunktion D 21,Brake lamp ,20
ENG263446-ENG116282-Leuchte 21 BR R C8-Lichtfunktion E 21,not active ,20
ENG263446-ENG116283-Leuchte 21 BR R C8-Lichtfunktion F 21,not active ,20
ENG263446-ENG116286-Leuchte 21 BR R C8-Lichtfunktion G 21,Blinken rechts aktiv ,20
ENG263446-ENG116287-Leuchte 21 BR R C8-Lichtfunktion H 21,not active ,20
ENG263446-ENG260531-Leuchte 21 BR R C8-Lichtfunktion I 21,not active ,20
ENG263446-ENG258267-Leuchte 21 BR R C8-Lichtfunktion J 21,Blinken rechts Dunkelphase ,20
ENG263446-ENG261265-Leuchte 21 BR R C8-Lichtfunktion K 21,not active ,20
ENG263446-ENG261356-Leuchte 21 BR R C8-Lichtfunktion L 21,not active ,20
ENG263487-ENG261009-Leuchte 22 BR M A57-Dimming Direction DEF 22,maximize ,20
ENG263487-ENG259558-Leuchte 22 BR M A57-Dimming Direction GHI 22,maximize ,20
ENG263487-ENG258098-Leuchte 22 BR M A57-Dimming Direction JKL 22,maximize ,20
ENG263487-ENG260824-Leuchte 22 BR M A57-Dimmwert ABC 22,127 ,20
ENG263487-ENG261330-Leuchte 22 BR M A57-Dimmwert DEF 22,0 ,20
ENG263487-ENG260249-Leuchte 22 BR M A57-Dimmwert GHI 22,0 ,20
ENG263487-ENG260794-Leuchte 22 BR M A57-Dimmwert JKL 22,0 ,20
ENG263487-ENG116292-Leuchte 22 BR M A57-Fehlerort mittleres Byte DTC-DFCC 22,44 ,20
ENG263487-ENG116574-Leuchte 22 BR M A57-Lampendefektbitposition 22,41 ,20
ENG263487-ENG116290-Leuchte 22 BR M A57-Lasttyp 22,LED_dritte_Bremsleuchte ,20
ENG263487-ENG259134-Leuchte 22 BR M A57-Lichtansteuerung HD ABC 22,Always ,20
ENG263487-ENG116293-Leuchte 22 BR M A57-Lichtfunktion A 22,Brake lamp ,20
ENG263487-ENG116294-Leuchte 22 BR M A57-Lichtfunktion B 22,not active ,20
ENG263487-ENG116297-Leuchte 22 BR M A57-Lichtfunktion C 22,not active ,20
ENG263487-ENG116298-Leuchte 22 BR M A57-Lichtfunktion D 22,not active ,20
ENG263487-ENG116301-Leuchte 22 BR M A57-Lichtfunktion E 22,not active ,20
ENG263487-ENG116302-Leuchte 22 BR M A57-Lichtfunktion F 22,not active ,20
ENG263487-ENG116305-Leuchte 22 BR M A57-Lichtfunktion G 22,not active ,20
ENG263487-ENG116306-Leuchte 22 BR M A57-Lichtfunktion H 22,not active ,20
ENG263487-ENG261266-Leuchte 22 BR M A57-Lichtfunktion I 22,not active ,20
ENG263487-ENG259294-Leuchte 22 BR M A57-Lichtfunktion J 22,not active ,20
ENG263487-ENG258164-Leuchte 22 BR M A57-Lichtfunktion K 22,not active ,20
ENG263487-ENG259578-Leuchte 22 BR M A57-Lichtfunktion L 22,not active ,20
ENG263482-ENG259710-Leuchte 23 SL HL C31-Dimming Direction DEF 32,maximize ,20
ENG263482-ENG258905-Leuchte 23 SL HL C31-Dimming Direction GHI 32,maximize ,20
ENG263482-ENG260532-Leuchte 23 SL HL C31-Dimming Direction JKL 32,maximize ,20
ENG263482-ENG259737-Leuchte 23 SL HL C31-Dimmwert ABC 32,50 ,20
ENG263482-ENG259346-Leuchte 23 SL HL C31-Dimmwert DEF 32,0 ,20
ENG263482-ENG260258-Leuchte 23 SL HL C31-Dimmwert GHI 32,0 ,20
ENG263482-ENG260382-Leuchte 23 SL HL C31-Dimmwert JKL 32,0 ,20
ENG263482-ENG116482-Leuchte 23 SL HL C31-Fehlerort mittleres Byte DTC-DFCC 32,0 ,20
ENG263482-ENG116584-Leuchte 23 SL HL C31-Lampendefektbitposition 32,0 ,20
ENG263482-ENG116480-Leuchte 23 SL HL C31-Lasttyp 32,LED_Kleinleistung_ohne_Open_Load_Diagnose ,20
ENG263482-ENG259035-Leuchte 23 SL HL C31-Lichtansteuerung HD ABC 32,Always ,20
ENG263482-ENG116483-Leuchte 23 SL HL C31-Lichtfunktion A 32,Position lamps ,20
ENG263482-ENG116484-Leuchte 23 SL HL C31-Lichtfunktion B 32,not active ,20
ENG263482-ENG116487-Leuchte 23 SL HL C31-Lichtfunktion C 32,not active ,20
ENG263482-ENG116488-Leuchte 23 SL HL C31-Lichtfunktion D 32,not active ,20
ENG263482-ENG116491-Leuchte 23 SL HL C31-Lichtfunktion E 32,not active ,20
ENG263482-ENG116492-Leuchte 23 SL HL C31-Lichtfunktion F 32,not active ,20
ENG263482-ENG116495-Leuchte 23 SL HL C31-Lichtfunktion G 32,not active ,20
ENG263482-ENG116496-Leuchte 23 SL HL C31-Lichtfunktion H 32,not active ,20
ENG263482-ENG258763-Leuchte 23 SL HL C31-Lichtfunktion I 32,not active ,20
ENG263482-ENG259842-Leuchte 23 SL HL C31-Lichtfunktion J 32,not active ,20
ENG263482-ENG258857-Leuchte 23 SL HL C31-Lichtfunktion K 32,not active ,20
ENG263482-ENG260175-Leuchte 23 SL HL C31-Lichtfunktion L 32,not active ,20
ENG263469-ENG260709-Leuchte 24 SL HR A61-Dimming Direction DEF 24,maximize ,20
ENG263469-ENG258518-Leuchte 24 SL HR A61-Dimming Direction GHI 24,maximize ,20
ENG263469-ENG258189-Leuchte 24 SL HR A61-Dimming Direction JKL 24,maximize ,20
ENG263469-ENG259150-Leuchte 24 SL HR A61-Dimmwert ABC 24,127 ,20
ENG263469-ENG259120-Leuchte 24 SL HR A61-Dimmwert DEF 24,127 ,20
ENG263469-ENG259774-Leuchte 24 SL HR A61-Dimmwert GHI 24,0 ,20
ENG263469-ENG259393-Leuchte 24 SL HR A61-Dimmwert JKL 24,0 ,20
ENG263469-ENG116330-Leuchte 24 SL HR A61-Fehlerort mittleres Byte DTC-DFCC 24,0 ,20
ENG263469-ENG116576-Leuchte 24 SL HR A61-Lampendefektbitposition 24,0 ,20
ENG263469-ENG116328-Leuchte 24 SL HR A61-Lasttyp 24,allgemeine_LED_mit_Open_Load_Diagnose 12 W ,20
ENG263469-ENG258842-Leuchte 24 SL HR A61-Lichtansteuerung HD ABC 24,Always ,20
ENG263469-ENG116331-Leuchte 24 SL HR A61-Lichtfunktion A 24,Ambiente Exterior 2 ,20
ENG263469-ENG116332-Leuchte 24 SL HR A61-Lichtfunktion B 24,not active ,20
ENG263469-ENG116335-Leuchte 24 SL HR A61-Lichtfunktion C 24,not active ,20
ENG263469-ENG116336-Leuchte 24 SL HR A61-Lichtfunktion D 24,Ambiente Exterior 4 ,20
ENG263469-ENG116339-Leuchte 24 SL HR A61-Lichtfunktion E 24,not active ,20
ENG263469-ENG116340-Leuchte 24 SL HR A61-Lichtfunktion F 24,not active ,20
ENG263469-ENG116343-Leuchte 24 SL HR A61-Lichtfunktion G 24,not active ,20
ENG263469-ENG116344-Leuchte 24 SL HR A61-Lichtfunktion H 24,not active ,20
ENG263469-ENG260865-Leuchte 24 SL HR A61-Lichtfunktion I 24,not active ,20
ENG263469-ENG260414-Leuchte 24 SL HR A61-Lichtfunktion J 24,not active ,20
ENG263469-ENG260577-Leuchte 24 SL HR A61-Lichtfunktion K 24,not active ,20
ENG263469-ENG260598-Leuchte 24 SL HR A61-Lichtfunktion L 24,not active ,20
ENG263447-ENG260768-Leuchte 25 KZL H A59-Dimming Direction DEF 25,maximize ,20
ENG263447-ENG259422-Leuchte 25 KZL H A59-Dimming Direction GHI 25,maximize ,20
ENG263447-ENG258848-Leuchte 25 KZL H A59-Dimming Direction JKL 25,maximize ,20
ENG263447-ENG258210-Leuchte 25 KZL H A59-Dimmwert ABC 25,127 ,20
ENG263447-ENG260749-Leuchte 25 KZL H A59-Dimmwert DEF 25,127 ,20
ENG263447-ENG258574-Leuchte 25 KZL H A59-Dimmwert GHI 25,0 ,20
ENG263447-ENG259896-Leuchte 25 KZL H A59-Dimmwert JKL 25,0 ,20
ENG263447-ENG116349-Leuchte 25 KZL H A59-Fehlerort mittleres Byte DTC-DFCC 25,48 ,20
ENG263447-ENG116577-Leuchte 25 KZL H A59-Lampendefektbitposition 25,40 ,20
ENG263447-ENG116347-Leuchte 25 KZL H A59-Lasttyp 25,allg_LED_mit_Open_Load_Diagnose_ohne_PWM ,20
ENG263447-ENG259553-Leuchte 25 KZL H A59-Lichtansteuerung HD ABC 25,Always ,20
ENG263447-ENG116350-Leuchte 25 KZL H A59-Lichtfunktion A 25,Ambiente Exterior 2 ,20
ENG263447-ENG116351-Leuchte 25 KZL H A59-Lichtfunktion B 25,not active ,20
ENG263447-ENG116354-Leuchte 25 KZL H A59-Lichtfunktion C 25,not active ,20
ENG263447-ENG116355-Leuchte 25 KZL H A59-Lichtfunktion D 25,Ambiente Exterior 3 ,20
ENG263447-ENG116358-Leuchte 25 KZL H A59-Lichtfunktion E 25,not active ,20
ENG263447-ENG259247-Leuchte 25 KZL H A59-Lichtfunktion F25,not active ,20
ENG263447-ENG116362-Leuchte 25 KZL H A59-Lichtfunktion G 25,not active ,20
ENG263447-ENG116363-Leuchte 25 KZL H A59-Lichtfunktion H 25,not active ,20
ENG263447-ENG260931-Leuchte 25 KZL H A59-Lichtfunktion I 25,not active ,20
ENG263447-ENG258654-Leuchte 25 KZL H A59-Lichtfunktion J 25,not active ,20
ENG263447-ENG260798-Leuchte 25 KZL H A59-Lichtfunktion K 25,not active ,20
ENG263447-ENG258935-Leuchte 25 KZL H A59-Lichtfunktion L 25,not active ,20
ENG263466-ENG259412-Leuchte 26 NSL L C09-Dimming Direction DEF 26,maximize ,20
ENG263466-ENG259883-Leuchte 26 NSL L C09-Dimming Direction GHI 26,maximize ,20
ENG263466-ENG260584-Leuchte 26 NSL L C09-Dimming Direction JKL 26,maximize ,20
ENG263466-ENG261357-Leuchte 26 NSL L C09-Dimmwert ABC 26,0 ,20
ENG263466-ENG260958-Leuchte 26 NSL L C09-Dimmwert DEF 26,0 ,20
ENG263466-ENG258546-Leuchte 26 NSL L C09-Dimmwert GHI 26,0 ,20
ENG263466-ENG259662-Leuchte 26 NSL L C09-Dimmwert JKL 26,0 ,20
ENG263466-ENG116368-Leuchte 26 NSL L C09-Fehlerort mittleres Byte DTC-DFCC 26,0 ,20
ENG263466-ENG116578-Leuchte 26 NSL L C09-Lampendefektbitposition 26,0 ,20
ENG263466-ENG116366-Leuchte 26 NSL L C09-Lasttyp 26,not_active ,20
ENG263466-ENG260640-Leuchte 26 NSL L C09-Lichtansteuerung HD ABC 26,Always ,20
ENG263466-ENG116369-Leuchte 26 NSL L C09-Lichtfunktion A 26,not active ,20
ENG263466-ENG116370-Leuchte 26 NSL L C09-Lichtfunktion B 26,not active ,20
ENG263466-ENG116373-Leuchte 26 NSL L C09-Lichtfunktion C 26,not active ,20
ENG263466-ENG116374-Leuchte 26 NSL L C09-Lichtfunktion D 26,not active ,20
ENG263466-ENG116377-Leuchte 26 NSL L C09-Lichtfunktion E 26,not active ,20
ENG263466-ENG116378-Leuchte 26 NSL L C09-Lichtfunktion F 26,not active ,20
ENG263466-ENG116381-Leuchte 26 NSL L C09-Lichtfunktion G 26,not active ,20
ENG263466-ENG116382-Leuchte 26 NSL L C09-Lichtfunktion H 26,not active ,20
ENG263466-ENG258650-Leuchte 26 NSL L C09-Lichtfunktion I 26,not active ,20
ENG263466-ENG258937-Leuchte 26 NSL L C09-Lichtfunktion J 26,not active ,20
ENG263466-ENG259765-Leuchte 26 NSL L C09-Lichtfunktion K 26,not active ,20
ENG263466-ENG260970-Leuchte 26 NSL L C09-Lichtfunktion L 26,not active ,20
ENG263468-ENG259400-Leuchte 27 NSL R C6-Dimming Direction DEF 27,maximize ,20
ENG263468-ENG260627-Leuchte 27 NSL R C6-Dimming Direction GHI 27,maximize ,20
ENG263468-ENG260547-Leuchte 27 NSL R C6-Dimming Direction JKL 27,maximize ,20
ENG263468-ENG259742-Leuchte 27 NSL R C6-Dimmwert ABC 27,0 ,20
ENG263468-ENG258926-Leuchte 27 NSL R C6-Dimmwert DEF 27,0 ,20
ENG263468-ENG259009-Leuchte 27 NSL R C6-Dimmwert GHI 27,0 ,20
ENG263468-ENG260084-Leuchte 27 NSL R C6-Dimmwert JKL 27,0 ,20
ENG263468-ENG116387-Leuchte 27 NSL R C6-Fehlerort mittleres Byte DTC-DFCC 27,0 ,20
ENG263468-ENG116579-Leuchte 27 NSL R C6-Lampendefektbitposition 27,0 ,20
ENG263468-ENG116385-Leuchte 27 NSL R C6-Lasttyp 27,not_active ,20
ENG263468-ENG258715-Leuchte 27 NSL R C6-Lichtansteuerung HD ABC 27,Always ,20
ENG263468-ENG116388-Leuchte 27 NSL R C6-Lichtfunktion A 27,not active ,20
ENG263468-ENG116389-Leuchte 27 NSL R C6-Lichtfunktion B 27,not active ,20
ENG263468-ENG116392-Leuchte 27 NSL R C6-Lichtfunktion C 27,not active ,20
ENG263468-ENG116393-Leuchte 27 NSL R C6-Lichtfunktion D 27,not active ,20
ENG263468-ENG116396-Leuchte 27 NSL R C6-Lichtfunktion E 27,not active ,20
ENG263468-ENG116397-Leuchte 27 NSL R C6-Lichtfunktion F 27,not active ,20
ENG263468-ENG116400-Leuchte 27 NSL R C6-Lichtfunktion G 27,not active ,20
ENG263468-ENG116401-Leuchte 27 NSL R C6-Lichtfunktion H 27,not active ,20
ENG263468-ENG258753-Leuchte 27 NSL R C6-Lichtfunktion I 27,not active ,20
ENG263468-ENG258206-Leuchte 27 NSL R C6-Lichtfunktion J 27,not active ,20
ENG263468-ENG260268-Leuchte 27 NSL R C6-Lichtfunktion K 27,not active ,20
ENG263468-ENG259071-Leuchte 27 NSL R C6-Lichtfunktion L 27,not active ,20
ENG263493-ENG258565-Leuchte 28 RFL L C06-Dimming Direction DEF 28,maximize ,20
ENG263493-ENG258532-Leuchte 28 RFL L C06-Dimming Direction GHI 28,maximize ,20
ENG263493-ENG259396-Leuchte 28 RFL L C06-Dimming Direction JKL 28,maximize ,20
ENG263493-ENG259919-Leuchte 28 RFL L C06-Dimmwert ABC 28,127 ,20
ENG263493-ENG258647-Leuchte 28 RFL L C06-Dimmwert DEF 28,0 ,20
ENG263493-ENG261179-Leuchte 28 RFL L C06-Dimmwert GHI 28,0 ,20
ENG263493-ENG260446-Leuchte 28 RFL L C06-Dimmwert JKL 28,0 ,20
ENG263493-ENG116406-Leuchte 28 RFL L C06-Fehlerort mittleres Byte DTC-DFCC 28,0 ,20
ENG263493-ENG116580-Leuchte 28 RFL L C06-Lampendefektbitposition 28,0 ,20
ENG263493-ENG116404-Leuchte 28 RFL L C06-Lasttyp 28,allgemeine_LED_mit_Open_Load_Diagnose_12W ,20
ENG263493-ENG258804-Leuchte 28 RFL L C06-Lichtansteuerung HD ABC 28,Always ,20
ENG263493-ENG116407-Leuchte 28 RFL L C06-Lichtfunktion A 28,Rueckfahrlicht ,20
ENG263493-ENG116408-Leuchte 28 RFL L C06-Lichtfunktion B 28,not active ,20
ENG263493-ENG116411-Leuchte 28 RFL L C06-Lichtfunktion C 28,not active ,20
ENG263493-ENG116412-Leuchte 28 RFL L C06-Lichtfunktion D 28,not active ,20
ENG263493-ENG116415-Leuchte 28 RFL L C06-Lichtfunktion E 28,not active ,20
ENG263493-ENG116416-Leuchte 28 RFL L C06-Lichtfunktion F 28,not active ,20
ENG263493-ENG116419-Leuchte 28 RFL L C06-Lichtfunktion G 28,not active ,20
ENG263493-ENG116420-Leuchte 28 RFL L C06-Lichtfunktion H 28,not active ,20
ENG263493-ENG260485-Leuchte 28 RFL L C06-Lichtfunktion I 28,not active ,20
ENG263493-ENG260652-Leuchte 28 RFL L C06-Lichtfunktion J 28,not active ,20
ENG263493-ENG258363-Leuchte 28 RFL L C06-Lichtfunktion K 28,not active ,20
ENG263493-ENG260174-Leuchte 28 RFL L C06-Lichtfunktion L 28,not active ,20
ENG263488-ENG261198-Leuchte 29 RFL R A72-Dimming Direction DEF 29,maximize ,20
ENG263488-ENG259250-Leuchte 29 RFL R A72-Dimming Direction GHI 29,maximize ,20
ENG263488-ENG260299-Leuchte 29 RFL R A72-Dimming Direction JKL 29,maximize ,20
ENG263488-ENG259879-Leuchte 29 RFL R A72-Dimmwert ABC 29,127 ,20
ENG263488-ENG260443-Leuchte 29 RFL R A72-Dimmwert DEF 29,0 ,20
ENG263488-ENG260415-Leuchte 29 RFL R A72-Dimmwert GHI 29,0 ,20
ENG263488-ENG260684-Leuchte 29 RFL R A72-Dimmwert JKL 29,0 ,20
ENG263488-ENG116425-Leuchte 29 RFL R A72-Fehlerort mittleres Byte DTC-DFCC 29,0 ,20
ENG263488-ENG116581-Leuchte 29 RFL R A72-Lampendefektbitposition 29,0 ,20
ENG263488-ENG116423-Leuchte 29 RFL R A72-Lasttyp 29,allgemeine_LED_mit_Open_Load_Diagnose_12W ,20
ENG263488-ENG260077-Leuchte 29 RFL R A72-Lichtansteuerung HD ABC 29,Always ,20
ENG263488-ENG116426-Leuchte 29 RFL R A72-Lichtfunktion A 29,Rueckfahrlicht ,20
ENG263488-ENG116427-Leuchte 29 RFL R A72-Lichtfunktion B 29,not active ,20
ENG263488-ENG116429-Leuchte 29 RFL R A72-Lichtfunktion C 29,not active ,20
ENG263488-ENG116431-Leuchte 29 RFL R A72-Lichtfunktion D 29,not active ,20
ENG263488-ENG116434-Leuchte 29 RFL R A72-Lichtfunktion E 29,not active ,20
ENG263488-ENG116435-Leuchte 29 RFL R A72-Lichtfunktion F 29,not active ,20
ENG263488-ENG116438-Leuchte 29 RFL R A72-Lichtfunktion G 29,not active ,20
ENG263488-ENG116439-Leuchte 29 RFL R A72-Lichtfunktion H 29,not active ,20
ENG263488-ENG260646-Leuchte 29 RFL R A72-Lichtfunktion I 29,not active ,20
ENG263488-ENG259712-Leuchte 29 RFL R A72-Lichtfunktion J 29,not active ,20
ENG263488-ENG259236-Leuchte 29 RFL R A72-Lichtfunktion K 29,not active ,20
ENG263488-ENG259606-Leuchte 29 RFL R A72-Lichtfunktion L 29,not active ,20
ENG263428-ENG260857-Leuchte 30 FR L C72-Dimming Direction DEF 30,maximize ,20
ENG263428-ENG258841-Leuchte 30 FR L C72-Dimming Direction GHI 30,maximize ,20
ENG263428-ENG259433-Leuchte 30 FR L C72-Dimming Direction JKL 30,maximize ,20
ENG263428-ENG259620-Leuchte 30 FR L C72-Dimmwert ABC 30,100 ,20
ENG263428-ENG260960-Leuchte 30 FR L C72-Dimmwert DEF 30,0 ,20
ENG263428-ENG260191-Leuchte 30 FR L C72-Dimmwert GHI 30,0 ,20
ENG263428-ENG259143-Leuchte 30 FR L C72-Dimmwert JKL 30,0 ,20
ENG263428-ENG116444-Leuchte 30 FR L C72-Fehlerort mittleres Byte DTC-DFCC 30,2 ,20
ENG263428-ENG116582-Leuchte 30 FR L C72-Lampendefektbitposition 30,0 ,20
ENG263428-ENG116442-Leuchte 30 FR L C72-Lasttyp 30,LED_Kleinleistung_ohne_Open_Load_Diagnose ,20
ENG263428-ENG261067-Leuchte 30 FR L C72-Lichtansteuerung HD ABC 30,Always ,20
ENG263428-ENG116445-Leuchte 30 FR L C72-Lichtfunktion A 30,Footwell lamp ,20
ENG263428-ENG116446-Leuchte 30 FR L C72-Lichtfunktion B 30,not active ,20
ENG263428-ENG116449-Leuchte 30 FR L C72-Lichtfunktion C 30,not active ,20
ENG263428-ENG116450-Leuchte 30 FR L C72-Lichtfunktion D 30,not active ,20
ENG263428-ENG116453-Leuchte 30 FR L C72-Lichtfunktion E 30,not active ,20
ENG263428-ENG116454-Leuchte 30 FR L C72-Lichtfunktion F 30,not active ,20
ENG263428-ENG116457-Leuchte 30 FR L C72-Lichtfunktion G 30,not active ,20
ENG263428-ENG116458-Leuchte 30 FR L C72-Lichtfunktion H 30,not active ,20
ENG263428-ENG260108-Leuchte 30 FR L C72-Lichtfunktion I 30,not active ,20
ENG263428-ENG260034-Leuchte 30 FR L C72-Lichtfunktion J 30,not active ,20
ENG263428-ENG259668-Leuchte 30 FR L C72-Lichtfunktion K 30,not active ,20
ENG263428-ENG258691-Leuchte 30 FR L C72-Lichtfunktion L 30,not active ,20
ENG263445-ENG260925-Leuchte 31 AMBL 1 C61-Dimming Direction DEF 31,maximize ,20
ENG263445-ENG259991-Leuchte 31 AMBL 1 C61-Dimming Direction GHI 31,maximize ,20
ENG263445-ENG259114-Leuchte 31 AMBL 1 C61-Dimming Direction JKL 31,maximize ,20
ENG263445-ENG261277-Leuchte 31 AMBL 1 C61-Dimmwert ABC 31,100 ,20
ENG263445-ENG259981-Leuchte 31 AMBL 1 C61-Dimmwert DEF 31,0 ,20
ENG263445-ENG260837-Leuchte 31 AMBL 1 C61-Dimmwert GHI 31,0 ,20
ENG263445-ENG258112-Leuchte 31 AMBL 1 C61-Dimmwert JKL 31,0 ,20
ENG263445-ENG116463-Leuchte 31 AMBL 1 C61-Fehlerort mittleres Byte DTC-DFCC 31,0 ,20
ENG263445-ENG116583-Leuchte 31 AMBL 1 C61-Lampendefektbitposition 31,0 ,20
ENG263445-ENG116461-Leuchte 31 AMBL 1 C61-Lasttyp 31,allgemeine_LED_bis_6W ,20
ENG263445-ENG260205-Leuchte 31 AMBL 1 C61-Lichtansteuerung HD ABC 31,Always ,20
ENG263445-ENG116464-Leuchte 31 AMBL 1 C61-Lichtfunktion A 31,Ambientelicht 1 ,20
ENG263445-ENG116465-Leuchte 31 AMBL 1 C61-Lichtfunktion B 31,not active ,20
ENG263445-ENG116468-Leuchte 31 AMBL 1 C61-Lichtfunktion C 31,not active ,20
ENG263445-ENG116469-Leuchte 31 AMBL 1 C61-Lichtfunktion D 31,not active ,20
ENG263445-ENG116472-Leuchte 31 AMBL 1 C61-Lichtfunktion E 31,not active ,20
ENG263445-ENG116473-Leuchte 31 AMBL 1 C61-Lichtfunktion F 31,not active ,20
ENG263445-ENG116476-Leuchte 31 AMBL 1 C61-Lichtfunktion G 31,not active ,20
ENG263445-ENG116477-Leuchte 31 AMBL 1 C61-Lichtfunktion H 31,not active ,20
ENG263445-ENG260861-Leuchte 31 AMBL 1 C61-Lichtfunktion I 31,not active ,20
ENG263445-ENG260553-Leuchte 31 AMBL 1 C61-Lichtfunktion J 31,not active ,20
ENG263445-ENG259999-Leuchte 31 AMBL 1 C61-Lichtfunktion K 31,not active ,20
ENG263445-ENG260353-Leuchte 31 AMBL 1 C61-Lichtfunktion L 31,not active ,20
ENG263449-ENG259710-Leuchte 32 AMBL 2 C35-Dimming Direction DEF 32,maximize ,20
ENG263449-ENG258905-Leuchte 32 AMBL 2 C35-Dimming Direction GHI 32,maximize ,20
ENG263449-ENG260532-Leuchte 32 AMBL 2 C35-Dimming Direction JKL 32,maximize ,20
ENG263449-ENG259737-Leuchte 32 AMBL 2 C35-Dimmwert ABC 32,0 ,20
ENG263449-ENG259346-Leuchte 32 AMBL 2 C35-Dimmwert DEF 32,0 ,20
ENG263449-ENG260258-Leuchte 32 AMBL 2 C35-Dimmwert GHI 32,0 ,20
ENG263449-ENG260382-Leuchte 32 AMBL 2 C35-Dimmwert JKL 32,0 ,20
ENG263449-ENG116482-Leuchte 32 AMBL 2 C35-Fehlerort mittleres Byte DTC-DFCC 32,0 ,20
ENG263449-ENG116584-Leuchte 32 AMBL 2 C35-Lampendefektbitposition 32,0 ,20
ENG263449-ENG116480-Leuchte 32 AMBL 2 C35-Lasttyp 32,not_active ,20
ENG263449-ENG259035-Leuchte 32 AMBL 2 C35-Lichtansteuerung HD ABC 32,Always ,20
ENG263449-ENG116483-Leuchte 32 AMBL 2 C35-Lichtfunktion A 32,not active ,20
ENG263449-ENG116484-Leuchte 32 AMBL 2 C35-Lichtfunktion B 32,not active ,20
ENG263449-ENG116487-Leuchte 32 AMBL 2 C35-Lichtfunktion C 32,not active ,20
ENG263449-ENG116488-Leuchte 32 AMBL 2 C35-Lichtfunktion D 32,not active ,20
ENG263449-ENG116491-Leuchte 32 AMBL 2 C35-Lichtfunktion E 32,not active ,20
ENG263449-ENG116492-Leuchte 32 AMBL 2 C35-Lichtfunktion F 32,not active ,20
ENG263449-ENG116495-Leuchte 32 AMBL 2 C35-Lichtfunktion G 32,not active ,20
ENG263449-ENG116496-Leuchte 32 AMBL 2 C35-Lichtfunktion H 32,not active ,20
ENG263449-ENG258763-Leuchte 32 AMBL 2 C35-Lichtfunktion I 32,not active ,20
ENG263449-ENG259842-Leuchte 32 AMBL 2 C35-Lichtfunktion J 32,not active ,20
ENG263449-ENG258857-Leuchte 32 AMBL 2 C35-Lichtfunktion K 32,not active ,20
ENG263449-ENG260175-Leuchte 32 AMBL 2 C35-Lichtfunktion L 32,not active ,20
ENG263439-ENG258755-Leuchte 33 AMBL 3 C36-Dimming Direction DEF 33,maximize ,20
ENG263439-ENG258237-Leuchte 33 AMBL 3 C36-Dimming Direction GHI 33,maximize ,20
ENG263439-ENG259038-Leuchte 33 AMBL 3 C36-Dimming Direction JKL 33,maximize ,20
ENG263439-ENG259476-Leuchte 33 AMBL 3 C36-Dimmwert ABC 33,0 ,20
ENG263439-ENG260461-Leuchte 33 AMBL 3 C36-Dimmwert DEF 33,0 ,20
ENG263439-ENG261181-Leuchte 33 AMBL 3 C36-Dimmwert GHI 33,0 ,20
ENG263439-ENG258425-Leuchte 33 AMBL 3 C36-Dimmwert JKL 33,0 ,20
ENG263439-ENG116501-Leuchte 33 AMBL 3 C36-Fehlerort mittleres Byte DTC-DFCC 33,0 ,20
ENG263439-ENG116585-Leuchte 33 AMBL 3 C36-Lampendefektbitposition 33,0 ,20
ENG263439-ENG116499-Leuchte 33 AMBL 3 C36-Lasttyp 33,not_active ,20
ENG263439-ENG259471-Leuchte 33 AMBL 3 C36-Lichtansteuerung HD ABC 33,Always ,20
ENG263439-ENG116502-Leuchte 33 AMBL 3 C36-Lichtfunktion A 33,not active ,20
ENG263439-ENG116503-Leuchte 33 AMBL 3 C36-Lichtfunktion B 33,not active ,20
ENG263439-ENG116506-Leuchte 33 AMBL 3 C36-Lichtfunktion C 33,not active ,20
ENG263439-ENG116507-Leuchte 33 AMBL 3 C36-Lichtfunktion D 33,not active ,20
ENG263439-ENG116510-Leuchte 33 AMBL 3 C36-Lichtfunktion E 33,not active ,20
ENG263439-ENG116511-Leuchte 33 AMBL 3 C36-Lichtfunktion F 33,not active ,20
ENG263439-ENG116514-Leuchte 33 AMBL 3 C36-Lichtfunktion G 33,not active ,20
ENG263439-ENG116515-Leuchte 33 AMBL 3 C36-Lichtfunktion H 33,not active ,20
ENG263439-ENG260403-Leuchte 33 AMBL 3 C36-Lichtfunktion I 33,not active ,20
ENG263439-ENG261239-Leuchte 33 AMBL 3 C36-Lichtfunktion J 33,not active ,20
ENG263439-ENG260953-Leuchte 33 AMBL 3 C36-Lichtfunktion K 33,not active ,20
ENG263439-ENG261234-Leuchte 33 AMBL 3 C36-Lichtfunktion L 33,not active ,20
ENG263434-ENG259648-Leuchte 34 AMBL 4 C37-Dimming Direction DEF 34,maximize ,20
ENG263434-ENG259188-Leuchte 34 AMBL 4 C37-Dimming Direction GHI 34,maximize ,20
ENG263434-ENG260464-Leuchte 34 AMBL 4 C37-Dimming Direction JKL 34,maximize ,20
ENG263434-ENG259524-Leuchte 34 AMBL 4 C37-Dimmwert ABC 34,0 ,20
ENG263434-ENG260705-Leuchte 34 AMBL 4 C37-Dimmwert DEF 34,0 ,20
ENG263434-ENG258677-Leuchte 34 AMBL 4 C37-Dimmwert GHI 34,0 ,20
ENG263434-ENG259924-Leuchte 34 AMBL 4 C37-Dimmwert JKL 34,0 ,20
ENG263434-ENG116520-Leuchte 34 AMBL 4 C37-Fehlerort mittleres Byte DTC-DFCC 34,0 ,20
ENG263434-ENG116586-Leuchte 34 AMBL 4 C37-Lampendefektbitposition 34,0 ,20
ENG263434-ENG116518-Leuchte 34 AMBL 4 C37-Lasttyp 34,not_active ,20
ENG263434-ENG259804-Leuchte 34 AMBL 4 C37-Lichtansteuerung HD ABC 34,Always ,20
ENG263434-ENG116521-Leuchte 34 AMBL 4 C37-Lichtfunktion A 34,not active ,20
ENG263434-ENG116522-Leuchte 34 AMBL 4 C37-Lichtfunktion B 34,not active ,20
ENG263434-ENG116525-Leuchte 34 AMBL 4 C37-Lichtfunktion C 34,not active ,20
ENG263434-ENG116526-Leuchte 34 AMBL 4 C37-Lichtfunktion D 34,not active ,20
ENG263434-ENG116529-Leuchte 34 AMBL 4 C37-Lichtfunktion E 34,not active ,20
ENG263434-ENG116530-Leuchte 34 AMBL 4 C37-Lichtfunktion F 34,not active ,20
ENG263434-ENG116533-Leuchte 34 AMBL 4 C37-Lichtfunktion G 34,not active ,20
ENG263434-ENG116534-Leuchte 34 AMBL 4 C37-Lichtfunktion H 34,not active ,20
ENG263434-ENG259061-Leuchte 34 AMBL 4 C37-Lichtfunktion I 34,not active ,20
ENG263434-ENG258125-Leuchte 34 AMBL 4 C37-Lichtfunktion J 34,not active ,20
ENG263434-ENG259670-Leuchte 34 AMBL 4 C37-Lichtfunktion K 34,not active ,20
ENG263434-ENG260771-Leuchte 34 AMBL 4 C37-Lichtfunktion L 34,not active ,20
ENG141657-ENG258314-Leuchte 35 LED Warnblinktaster C48-Dimming Direction DEF 35,maximize ,20
ENG141657-ENG260208-Leuchte 35 LED Warnblinktaster C48-Dimming Direction GHI 35,maximize ,20
ENG141657-ENG260869-Leuchte 35 LED Warnblinktaster C48-Dimming Direction JKL 35,maximize ,20
ENG141657-ENG259780-Leuchte 35 LED Warnblinktaster C48-Dimmwert ABC 35,20 ,20
ENG141657-ENG258175-Leuchte 35 LED Warnblinktaster C48-Dimmwert DEF 35,100 ,20
ENG141657-ENG259257-Leuchte 35 LED Warnblinktaster C48-Dimmwert GHI 35,0 ,20
ENG141657-ENG260977-Leuchte 35 LED Warnblinktaster C48-Dimmwert JKL 35,0 ,20
ENG141657-ENG258758-Leuchte 35 LED Warnblinktaster C48-Fehlerort mittleres Byte DTC-DFCC 35,0 ,20
ENG141657-ENG258551-Leuchte 35 LED Warnblinktaster C48-Lampendefektbitposition 35,0 ,20
ENG141657-ENG259566-Leuchte 35 LED Warnblinktaster C48-Lasttyp 35,LED_Kleinleistung_ohne_Open_Load_Diagnose ,20
ENG141657-ENG260595-Leuchte 35 LED Warnblinktaster C48-Lichtansteuerung HD ABC 35,Always ,20
ENG141657-ENG260217-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion A 35,Warnblink Taster Suchbeleuchtung ,20
ENG141657-ENG259017-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion B 35,not active ,20
ENG141657-ENG259618-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion C 35,not active ,20
ENG141657-ENG259584-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion D 35,not active ,20
ENG141657-ENG259128-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion E 35,not active ,20
ENG141657-ENG258995-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion F 35,not active ,20
ENG141657-ENG258137-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion G 35,not active ,20
ENG141657-ENG259014-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion H 35,not active ,20
ENG141657-ENG258258-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion I 35,not active ,20
ENG141657-ENG260608-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion J 35,not active ,20
ENG141657-ENG260082-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion K 35,not active ,20
ENG141657-ENG261046-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion L 35,not active ,20
ENG253171-ENG259501-Leuchte 39 Sidemarker_H C26-Dimming Direction DEF 39,maximize ,20
ENG253171-ENG260533-Leuchte 39 Sidemarker_H C26-Dimming Direction GHI 39,maximize ,20
ENG253171-ENG259331-Leuchte 39 Sidemarker_H C26-Dimming Direction JKL 39,maximize ,20
ENG253171-ENG259663-Leuchte 39 Sidemarker_H C26-Dimmwert ABC 39,0 ,20
ENG253171-ENG260625-Leuchte 39 Sidemarker_H C26-Dimmwert DEF 39,0 ,20
ENG253171-ENG258607-Leuchte 39 Sidemarker_H C26-Dimmwert GHI 39,0 ,20
ENG253171-ENG259031-Leuchte 39 Sidemarker_H C26-Dimmwert JKL 39,0 ,20
ENG253171-ENG260272-Leuchte 39 Sidemarker_H C26-Fehlerort mittleres Byte DTC-DFCC 39,0 ,20
ENG253171-ENG261342-Leuchte 39 Sidemarker_H C26-Lampendefektbitposition 39,0 ,20
ENG253171-ENG258910-Leuchte 39 Sidemarker_H C26-Lasttyp 39,not_active ,20
ENG253171-ENG261145-Leuchte 39 Sidemarker_H C26-Lichtansteuerung HD ABC 39,Always ,20
ENG253171-ENG259436-Leuchte 39 Sidemarker_H C26-Lichtfunktion A 39,not active ,20
ENG253171-ENG260471-Leuchte 39 Sidemarker_H C26-Lichtfunktion B 39,not active ,20
ENG253171-ENG260554-Leuchte 39 Sidemarker_H C26-Lichtfunktion C 39,not active ,20
ENG253171-ENG258988-Leuchte 39 Sidemarker_H C26-Lichtfunktion D 39,not active ,20
ENG253171-ENG259727-Leuchte 39 Sidemarker_H C26-Lichtfunktion E 39,not active ,20
ENG253171-ENG258355-Leuchte 39 Sidemarker_H C26-Lichtfunktion F 39,not active ,20
ENG253171-ENG261095-Leuchte 39 Sidemarker_H C26-Lichtfunktion G 39,not active ,20
ENG253171-ENG258577-Leuchte 39 Sidemarker_H C26-Lichtfunktion H 39,not active ,20
ENG253171-ENG259902-Leuchte 39 Sidemarker_H C26-Lichtfunktion I 39,not active ,20
ENG253171-ENG260202-Leuchte 39 Sidemarker_H C26-Lichtfunktion J 39,not active ,20
ENG253171-ENG260436-Leuchte 39 Sidemarker_H C26-Lichtfunktion K 39,not active ,20
ENG253171-ENG259237-Leuchte 39 Sidemarker_H C26-Lichtfunktion L 39,not active ,20
ENG263436-ENG260616-Leuchte 40 Zusatz_hecklicht_HL B03-Dimming Direction DEF 40,maximize ,20
ENG263436-ENG259877-Leuchte 40 Zusatz_hecklicht_HL B03-Dimming Direction GHI v,minimize ,20
ENG263436-ENG258734-Leuchte 40 Zusatz_hecklicht_HL B03-Dimming Direction JKL 40,minimize ,20
ENG263436-ENG258702-Leuchte 40 Zusatz_hecklicht_HL B03-Dimmwert ABC 40,75 ,20
ENG263436-ENG259888-Leuchte 40 Zusatz_hecklicht_HL B03-Dimmwert DEF 40,127 ,20
ENG263436-ENG258927-Leuchte 40 Zusatz_hecklicht_HL B03-Dimmwert GHI 40,75 ,20
ENG263436-ENG258852-Leuchte 40 Zusatz_hecklicht_HL B03-Dimmwert JKL 40,0 ,20
ENG263436-ENG260246-Leuchte 40 Zusatz_hecklicht_HL B03-Fehlerort mittleres Byte DTC-DFCC 40,0 ,20
ENG263436-ENG259652-Leuchte 40 Zusatz_hecklicht_HL B03-Lampendefektbitposition 40,0 ,20
ENG263436-ENG260978-Leuchte 40 Zusatz_hecklicht_HL B03-Lasttyp 40,kombinierte_LED_Blink_Bremsleuchten ,20
ENG263436-ENG259185-Leuchte 40 Zusatz_hecklicht_HL B03-Lichtansteuerung HD ABC 40,Always ,20
ENG263436-ENG259008-Leuchte 40 Zusatz_hecklicht_HL B03-Lichtfunktion A 40,Blinken links aktiv ,20
ENG263436-ENG258714-Leuchte 40 Zusatz_hecklicht_HL B03-Lichtfunktion B 40,not active ,20
ENG263436-ENG258586-Leuchte 40 Zusatz_hecklicht_HL B03-Lichtfunktion C 40,not active ,20
ENG263436-ENG258768-Leuchte 40 Zusatz_hecklicht_HL B03-Lichtfunktion D 40,Brake lamp ,20
ENG263436-ENG259573-Leuchte 40 Zusatz_hecklicht_HL B03-Lichtfunktion E 40,not active ,20
ENG263436-ENG258923-Leuchte 40 Zusatz_hecklicht_HL B03-Lichtfunktion F 40,not active ,20
ENG263436-ENG258928-Leuchte 40 Zusatz_hecklicht_HL B03-Lichtfunktion G 40,Blinken links aktiv ,20
ENG263436-ENG259450-Leuchte 40 Zusatz_hecklicht_HL B03-Lichtfunktion H 40,not active ,20
ENG263436-ENG260309-Leuchte 40 Zusatz_hecklicht_HL B03-Lichtfunktion I 40,not active ,20
ENG263436-ENG258499-Leuchte 40 Zusatz_hecklicht_HL B03-Lichtfunktion J 40,Blinken links Dunkelphase ,20
ENG263436-ENG261065-Leuchte 40 Zusatz_hecklicht_HL B03-Lichtfunktion K 40,not active ,20
ENG263436-ENG259658-Leuchte 40 Zusatz_hecklicht_HL B03-Lichtfunktion L 40,not active ,20
ENG263464-ENG259814-Leuchte 41 Zusatz_hecklicht_HR B20-Dimming Direction DEF 41,maximize ,20
ENG263464-ENG259194-Leuchte 41 Zusatz_hecklicht_HR B20-Dimming Direction GHI 41,minimize ,20
ENG263464-ENG258697-Leuchte 41 Zusatz_hecklicht_HR B20-Dimming Direction JKL 41,minimize ,20
ENG263464-ENG260405-Leuchte 41 Zusatz_hecklicht_HR B20-Dimmwert ABC 41,75 ,20
ENG263464-ENG261284-Leuchte 41 Zusatz_hecklicht_HR B20-Dimmwert DEF 41,127 ,20
ENG263464-ENG259351-Leuchte 41 Zusatz_hecklicht_HR B20-Dimmwert GHI 41,75 ,20
ENG263464-ENG258887-Leuchte 41 Zusatz_hecklicht_HR B20-Dimmwert JKL 41,0 ,20
ENG263464-ENG258329-Leuchte 41 Zusatz_hecklicht_HR B20-Fehlerort mittleres Byte DTC-DFCC 41,0 ,20
ENG263464-ENG258960-Leuchte 41 Zusatz_hecklicht_HR B20-Lampendefektbitposition 41,0 ,20
ENG263464-ENG261015-Leuchte 41 Zusatz_hecklicht_HR B20-Lasttyp 41,kombinierte_LED_Blink_Bremsleuchten ,20
ENG263464-ENG260435-Leuchte 41 Zusatz_hecklicht_HR B20-Lichtansteuerung HD ABC 41,Always ,20
ENG263464-ENG260996-Leuchte 41 Zusatz_hecklicht_HR B20-Lichtfunktion A 41,Blinken rechts aktiv ,20
ENG263464-ENG259966-Leuchte 41 Zusatz_hecklicht_HR B20-Lichtfunktion B 41,not active ,20
ENG263464-ENG258450-Leuchte 41 Zusatz_hecklicht_HR B20-Lichtfunktion C 41,not active ,20
ENG263464-ENG259570-Leuchte 41 Zusatz_hecklicht_HR B20-Lichtfunktion D 41,Brake lamp ,20
ENG263464-ENG260906-Leuchte 41 Zusatz_hecklicht_HR B20-Lichtfunktion E 41,not active ,20
ENG263464-ENG260838-Leuchte 41 Zusatz_hecklicht_HR B20-Lichtfunktion F 41,not active ,20
ENG263464-ENG258108-Leuchte 41 Zusatz_hecklicht_HR B20-Lichtfunktion G 41,Blinken rechts aktiv ,20
ENG263464-ENG258430-Leuchte 41 Zusatz_hecklicht_HR B20-Lichtfunktion H 41,not active ,20
ENG263464-ENG260615-Leuchte 41 Zusatz_hecklicht_HR B20-Lichtfunktion I 41,not active ,20
ENG263464-ENG260918-Leuchte 41 Zusatz_hecklicht_HR B20-Lichtfunktion J 41,Blinken rechts Dunkelphase ,20
ENG263464-ENG258150-Leuchte 41 Zusatz_hecklicht_HR B20-Lichtfunktion K 41,not active ,20
ENG263464-ENG258739-Leuchte 41 Zusatz_hecklicht_HR B20-Lichtfunktion L 41,not active ,20
ENG253110-ENG261024-Leuchte 42 Wischblinksignal_li C30_B35-Dimming Direction DEF 42,maximize ,20
ENG253110-ENG258668-Leuchte 42 Wischblinksignal_li C30_B35-Dimming Direction GHI 42,maximize ,20
ENG253110-ENG258123-Leuchte 42 Wischblinksignal_li C30_B35-Dimming Direction JKL 42,maximize ,20
ENG253110-ENG258370-Leuchte 42 Wischblinksignal_li C30_B35-Dimmwert ABC 42,0 ,20
ENG253110-ENG258109-Leuchte 42 Wischblinksignal_li C30_B35-Dimmwert DEF 42,0 ,20
ENG253110-ENG261169-Leuchte 42 Wischblinksignal_li C30_B35-Dimmwert GHI 42,0 ,20
ENG253110-ENG259028-Leuchte 42 Wischblinksignal_li C30_B35-Dimmwert JKL 42,0 ,20
ENG253110-ENG259381-Leuchte 42 Wischblinksignal_li C30_B35-Fehlerort mittleres Byte DTC-DFCC 42,0 ,20
ENG253110-ENG259973-Leuchte 42 Wischblinksignal_li C30_B35-Lampendefektbitposition 42,0 ,20
ENG253110-ENG258662-Leuchte 42 Wischblinksignal_li C30_B35-Lasttyp 42,not_active ,20
ENG253110-ENG258290-Leuchte 42 Wischblinksignal_li C30_B35-Lichtansteuerung HD ABC 42,Always ,20
ENG253110-ENG258895-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion A 42,not active ,20
ENG253110-ENG260384-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion B 42,not active ,20
ENG253110-ENG261085-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion C 42,not active ,20
ENG253110-ENG260667-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion D 42,not active ,20
ENG253110-ENG260232-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion E 42,not active ,20
ENG253110-ENG258671-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion F 42,not active ,20
ENG253110-ENG259243-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion G 42,not active ,20
ENG253110-ENG259518-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion H 42,not active ,20
ENG253110-ENG259526-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion I 42,not active ,20
ENG253110-ENG259239-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion J 42,not active ,20
ENG253110-ENG258327-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion K 42,not active ,20
ENG253110-ENG260944-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion L 42,not active ,20
ENG253212-ENG261135-Leuchte 43 Wischblinksignal_re C33_B36-Dimming Direction DEF 43,maximize ,20
ENG253212-ENG258953-Leuchte 43 Wischblinksignal_re C33_B36-Dimming Direction GHI 43,maximize ,20
ENG253212-ENG260351-Leuchte 43 Wischblinksignal_re C33_B36-Dimming Direction JKL 43,maximize ,20
ENG253212-ENG259567-Leuchte 43 Wischblinksignal_re C33_B36-Dimmwert ABC 43,0 ,20
ENG253212-ENG259435-Leuchte 43 Wischblinksignal_re C33_B36-Dimmwert DEF 43,0 ,20
ENG253212-ENG260024-Leuchte 43 Wischblinksignal_re C33_B36-Dimmwert GHI 43,0 ,20
ENG253212-ENG259623-Leuchte 43 Wischblinksignal_re C33_B36-Dimmwert JKL 43,0 ,20
ENG253212-ENG258411-Leuchte 43 Wischblinksignal_re C33_B36-Fehlerort mittleres Byte DTC-DFCC 43,0 ,20
ENG253212-ENG261311-Leuchte 43 Wischblinksignal_re C33_B36-Lampendefektbitposition 43,0 ,20
ENG253212-ENG259612-Leuchte 43 Wischblinksignal_re C33_B36-Lasttyp 43,not_active ,20
ENG253212-ENG261054-Leuchte 43 Wischblinksignal_re C33_B36-Lichtansteuerung HD ABC 43,Always ,20
ENG253212-ENG258146-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion A 43,not active ,20
ENG253212-ENG258144-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion B 43,not active ,20
ENG253212-ENG258171-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion C 43,not active ,20
ENG253212-ENG259397-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion D 43,not active ,20
ENG253212-ENG260658-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion E 43,not active ,20
ENG253212-ENG260002-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion F 43,not active ,20
ENG253212-ENG260698-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion G 43,not active ,20
ENG253212-ENG261082-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion H 43,not active ,20
ENG253212-ENG260261-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion I 43,not active ,20
ENG253212-ENG259097-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion J 43,not active ,20
ENG253212-ENG260203-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion K 43,not active ,20
ENG253212-ENG258986-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion L 43,not active ,20
ENG253108-ENG258231-Leuchte 44 ALV C70-Dimming Direction DEF 44,maximize ,20
ENG253108-ENG260416-Leuchte 44 ALV C70-Dimming Direction GHI 44,maximize ,20
ENG253108-ENG260409-Leuchte 44 ALV C70-Dimming Direction JKL 44,maximize ,20
ENG253108-ENG261347-Leuchte 44 ALV C70-Dimmwert ABC 44,127 ,20
ENG253108-ENG260630-Leuchte 44 ALV C70-Dimmwert DEF 44,0 ,20
ENG253108-ENG259610-Leuchte 44 ALV C70-Dimmwert GHI 44,0 ,20
ENG253108-ENG261335-Leuchte 44 ALV C70-Dimmwert JKL 44,0 ,20
ENG253108-ENG260566-Leuchte 44 ALV C70-Fehlerort mittleres Byte DTC-DFCC 44,7 ,20
ENG253108-ENG261036-Leuchte 44 ALV C70-Lampendefektbitposition 44,0 ,20
ENG253108-ENG258970-Leuchte 44 ALV C70-Lasttyp 44,LED_Fussraumleuchten ,20
ENG253108-ENG258540-Leuchte 44 ALV C70-Lichtansteuerung HD ABC 44,Always ,20
ENG253108-ENG260079-Leuchte 44 ALV C70-Lichtfunktion A 44,Ambientelichtmodul Versorgung ,20
ENG253108-ENG260296-Leuchte 44 ALV C70-Lichtfunktion B 44,not active ,20
ENG253108-ENG261154-Leuchte 44 ALV C70-Lichtfunktion C 44,not active ,20
ENG253108-ENG259507-Leuchte 44 ALV C70-Lichtfunktion D 44,not active ,20
ENG253108-ENG258260-Leuchte 44 ALV C70-Lichtfunktion E 44,not active ,20
ENG253108-ENG260714-Leuchte 44 ALV C70-Lichtfunktion F 44,not active ,20
ENG253108-ENG260064-Leuchte 44 ALV C70-Lichtfunktion G 44,not active ,20
ENG253108-ENG259720-Leuchte 44 ALV C70-Lichtfunktion H 44,not active ,20
ENG253108-ENG258947-Leuchte 44 ALV C70-Lichtfunktion I 44,not active ,20
ENG253108-ENG260429-Leuchte 44 ALV C70-Lichtfunktion J 44,not active ,20
ENG253108-ENG260305-Leuchte 44 ALV C70-Lichtfunktion K 44,not active ,20
ENG253108-ENG259925-Leuchte 44 ALV C70-Lichtfunktion L 44,not active ,20
ENG253209-ENG259161-Leuchte 45 KRL C56-Dimming Direction DEF 45,maximize ,20
ENG253209-ENG260000-Leuchte 45 KRL C56-Dimming Direction GHI 45,maximize ,20
ENG253209-ENG258382-Leuchte 45 KRL C56-Dimming Direction JKL 45,maximize ,20
ENG253209-ENG258536-Leuchte 45 KRL C56-Dimmwert ABC 45,100 ,20
ENG253209-ENG261049-Leuchte 45 KRL C56-Dimmwert DEF 45,0 ,20
ENG253209-ENG258646-Leuchte 45 KRL C56-Dimmwert GHI 45,0 ,20
ENG253209-ENG258455-Leuchte 45 KRL C56-Dimmwert JKL 45,0 ,20
ENG253209-ENG258548-Leuchte 45 KRL C56-Fehlerort mittleres Byte DTC-DFCC 45,0 ,20
ENG253209-ENG259186-Leuchte 45 KRL C56-Lampendefektbitposition 45,0 ,20
ENG253209-ENG259655-Leuchte 45 KRL C56-Lasttyp 45,allgemeine_Gluehlampe_27W_auch_H15_TFL ,20
ENG253209-ENG259881-Leuchte 45 KRL C56-Lichtansteuerung HD ABC 45,Always ,20
ENG253209-ENG258376-Leuchte 45 KRL C56-Lichtfunktion A 45,Luggage compartment light ,20
ENG253209-ENG260107-Leuchte 45 KRL C56-Lichtfunktion B 45,not active ,20
ENG253209-ENG259696-Leuchte 45 KRL C56-Lichtfunktion C 45,not active ,20
ENG253209-ENG258534-Leuchte 45 KRL C56-Lichtfunktion D 45,not active ,20
ENG253209-ENG258311-Leuchte 45 KRL C56-Lichtfunktion E 45,not active ,20
ENG253209-ENG259561-Leuchte 45 KRL C56-Lichtfunktion F 45,not active ,20
ENG253209-ENG258655-Leuchte 45 KRL C56-Lichtfunktion G 45,not active ,20
ENG253209-ENG258706-Leuchte 45 KRL C56-Lichtfunktion H 45,not active ,20
ENG253209-ENG260201-Leuchte 45 KRL C56-Lichtfunktion I 45,not active ,20
ENG253209-ENG259692-Leuchte 45 KRL C56-Lichtfunktion J 45,not active ,20
ENG253209-ENG259667-Leuchte 45 KRL C56-Lichtfunktion K 45,not active ,20
ENG253209-ENG259221-Leuchte 45 KRL C56-Lichtfunktion L 45,not active ,20
ENG253374-Licht_bedienung,LTM_Zentraltaste ,12
ENG126648-MAS10452-LIN-Mirrormode-Data bus LIN 1,active ,2
ENG126648-MAS10453-LIN-Mirrormode-Data bus LIN 2,active ,2
ENG126648-MAS10454-LIN-Mirrormode-Data bus LIN 3,active ,2
ENG126648-MAS12782-LIN-Mirrormode-Data bus LIN 4,active ,2
ENG126648-MAS12783-LIN-Mirrormode-Data bus LIN 5,active ,2
ENG126648-MAS12784-LIN-Mirrormode-Data bus LIN 6,active ,2
ENG126648-ENG260631-LIN-Mirrormode-LIN10,active ,2
ENG126648-ENG259894-LIN-Mirrormode-LIN11,active ,2
ENG126648-ENG260777-LIN-Mirrormode-LIN12,active ,2
ENG126648-ENG258456-LIN-Mirrormode-LIN13,active ,2
ENG126648-ENG259488-LIN-Mirrormode-LIN14,active ,2
ENG126648-ENG260898-LIN-Mirrormode-LIN7,active ,2
ENG126648-ENG259836-LIN-Mirrormode-LIN8,active ,2
ENG126648-ENG258319-LIN-Mirrormode-LIN9,active ,2
ENG126648-ENG118465-LIN-Mirrormode-mirror_mode_typ,not active ,2
ENG153727-ENG154566-LIN-SMLS_konfig_1-blinker_entprellen,General reject,2
ENG153727-ENG154578-LIN-SMLS_konfig_1-blinker_gra_entprellen,General reject,2
ENG153727-ENG154579-LIN-SMLS_konfig_1-blinker_sperrzeit,General reject,2
ENG153727-ENG154597-LIN-SMLS_konfig_1-erkennung_fahrt,General reject,2
ENG153727-ENG154618-LIN-SMLS_konfig_1-fas_entprellen,General reject,2
ENG153727-ENG154624-LIN-SMLS_konfig_1-grahebel_entprellen,General reject,2
ENG153727-ENG154634-LIN-SMLS_konfig_1-grenze_v,General reject,2
ENG153727-ENG154686-LIN-SMLS_konfig_1-hupe_entprellen,General reject,2
ENG153727-ENG154690-LIN-SMLS_konfig_1-hupe_indien_entprellen,General reject,2
ENG153727-ENG154692-LIN-SMLS_konfig_1-k_i,General reject,2
ENG153727-ENG154693-LIN-SMLS_konfig_1-k_i_offset,General reject,2
ENG153727-ENG154694-LIN-SMLS_konfig_1-k_p,General reject,2
ENG153727-ENG154695-LIN-SMLS_konfig_1-leistung_lrh,General reject,2
ENG153727-ENG154699-LIN-SMLS_konfig_1-lrh_entprellen,General reject,2
ENG153727-ENG154713-LIN-SMLS_konfig_1-pwm_lrh,General reject,2
ENG153727-ENG154773-LIN-SMLS_konfig_1-s_NWDF_spg,General reject,2
ENG153727-ENG154777-LIN-SMLS_konfig_1-soll_0,General reject,2
ENG153727-ENG154778-LIN-SMLS_konfig_1-soll_1,General reject,2
ENG153727-ENG154779-LIN-SMLS_konfig_1-soll_2,General reject,2
ENG153727-ENG154786-LIN-SMLS_konfig_1-speedlimiter_entprellen,General reject,2
ENG153727-ENG154788-LIN-SMLS_konfig_1-temlenkradheizung_aus,General reject,2
ENG153727-ENG154804-LIN-SMLS_konfig_1-verriegelt_entprellen,General reject,2
ENG153727-ENG154811-LIN-SMLS_konfig_1-wischer_entprellen,General reject,2
ENG153727-ENG154823-LIN-SMLS_konfig_1-wischer_intervall_entprellen,General reject,2
ENG153727-ENG154824-LIN-SMLS_konfig_1-wischer_winterstellung,General reject,2
ENG153727-ENG154830-LIN-SMLS_konfig_1-zeit_temperatur_statisch_lrh,General reject,2
ENG153728-IDE00329-LIN-SMLS_konfig_2-Buttons for multi-function display,General reject,2
ENG153728-IDE02694-LIN-SMLS_konfig_2-Signal horn activation,General reject,2
ENG153728-IDE02711-LIN-SMLS_konfig_2-Rear wiper,General reject,2
ENG153728-IDE02745-LIN-SMLS_konfig_2-Ignition Switch Key Lock Solenoid,General reject,2
ENG153728-MAS00128-LIN-SMLS_konfig_2-Distance Regulation,General reject,2
ENG153728-MAS00242-LIN-SMLS_konfig_2-Driver assistance systems button,General reject,2
ENG153728-MAS02790-LIN-SMLS_konfig_2-Diagnosis,General reject,2
ENG153728-MAS03758-LIN-SMLS_konfig_2-Not assigned,General reject,2
ENG153728-MAS05091-LIN-SMLS_konfig_2-CCS Switch,General reject,2
ENG153728-MAS06090-LIN-SMLS_konfig_2-CCS on turn signal switch,General reject,2
ENG153728-MAS06091-LIN-SMLS_konfig_2-Contact bounce suppression for signal horn,General reject,2
ENG153728-MAS08540-LIN-SMLS_konfig_2-reading P locked,General reject,2
ENG153728-ENG154623-LIN-SMLS_konfig_2-gra_grahebel_2_st,General reject,2
ENG253042-IDE03638-LWR Konfiguration-Stationary cornering lamp,Deactivated ,8
ENG253042-IDE03644-LWR Konfiguration-Highway light,not activated ,8
ENG253042-MAS02922-LWR Konfiguration-City light,not activated ,8
ENG253042-MAS07013-LWR Konfiguration-All-weather light,not activated ,8
ENG253042-MAS07933-LWR Konfiguration-Eco mode,not activated ,8
ENG253042-ENG172238-LWR Konfiguration-chassis_unit,Verbundlenkerhinterachse ,8
ENG253042-ENG260425-LWR Konfiguration-Function_activation_LWR,not activated ,8
ENG253042-ENG174374-LWR Konfiguration-LED_Headlight,not activated ,8
ENG253042-ENG259430-LWR Konfiguration-LWR_konfig,not installed ,8
ENG253042-ENG172241-LWR Konfiguration-lwr_sensors,1_sensor ,8
ENG253042-ENG171501-LWR Konfiguration-Market,ECE ,8
ENG253042-ENG173009-LWR Konfiguration-offroad_light,not activated ,8
ENG253042-ENG172245-LWR Konfiguration-rain_light,not activated ,8
ENG253042-ENG174637-LWR Konfiguration-Source_height_value,BCM ,8
ENG253042-ENG172240-LWR Konfiguration-steering_curve,normal ,8
ENG133365-ENG133451-Multikontursitz_BFS_Wildmoser-Differenzdruck_Toleranzband,65535 hPa,12
ENG133365-ENG133447-Multikontursitz_BFS_Wildmoser-Leckage_Fehlerschwelle_Druck,65535 hPa,12
ENG133365-ENG133453-Multikontursitz_BFS_Wildmoser-Nachentlueftzeit_LRD_mitte,60 s,12
ENG133365-ENG133452-Multikontursitz_BFS_Wildmoser-Nachentlueftzeit_LRD_oben,60 s,12
ENG133365-ENG133454-Multikontursitz_BFS_Wildmoser-Nachentlueftzeit_LRD_unten,60 s,12
ENG133365-ENG133455-Multikontursitz_BFS_Wildmoser-Nachentlueftzeit_Seitenwangen,255 s,12
ENG133365-ENG133448-Multikontursitz_BFS_Wildmoser-Nachregelung_PWM_1,255 %,12
ENG133365-ENG133449-Multikontursitz_BFS_Wildmoser-Nachregelung_PWM_2,255 %,12
ENG133365-ENG133450-Multikontursitz_BFS_Wildmoser-Nachregelung_PWM_3,255 %,12
ENG133365-ENG133446-Multikontursitz_BFS_Wildmoser-Schwellwert_Temperaturkompensation,255 °C,12
ENG133362-ENG133451-Multikontursitz_FS_Wildmoser-Differenzdruck_Toleranzband,65535 hPa,12
ENG133362-ENG133447-Multikontursitz_FS_Wildmoser-Leckage_Fehlerschwelle_Druck,65535 hPa,12
ENG133362-ENG133453-Multikontursitz_FS_Wildmoser-Nachentlueftzeit_LRD_mitte,60 s,12
ENG133362-ENG133452-Multikontursitz_FS_Wildmoser-Nachentlueftzeit_LRD_oben,60 s,12
ENG133362-ENG133454-Multikontursitz_FS_Wildmoser-Nachentlueftzeit_LRD_unten,60 s,12
ENG133362-ENG133455-Multikontursitz_FS_Wildmoser-Nachentlueftzeit_Seitenwangen,255 s,12
ENG133362-ENG133448-Multikontursitz_FS_Wildmoser-Nachregelung_PWM_1,255 %,12
ENG133362-ENG133449-Multikontursitz_FS_Wildmoser-Nachregelung_PWM_2,255 %,12
ENG133362-ENG133450-Multikontursitz_FS_Wildmoser-Nachregelung_PWM_3,255 %,12
ENG133362-ENG133446-Multikontursitz_FS_Wildmoser-Schwellwert_Temperaturkompensation,255 °C,12
ENG122979-ENG141953-Networking-Getriebesteuergeraet,Release selector lever ,8
ENG298054-ENG260528-OpenByWire_RBox_Schloss-p_t_ZV_ansteuerzeit_motor,0 ms,9
ENG298054-ENG298139-OpenByWire_RBox_Schloss-p_t_ZV_OBWr_Crash_ansteuerzeit_motor,250 ms,9
ENG298054-ENG298140-OpenByWire_RBox_Schloss-p_t_ZV_OBWr_KiSiSafe_ansteuerzeit_motor,70 ms,9
ENG298054-ENG298141-OpenByWire_RBox_Schloss-p_t_ZV_OBWr_KiSiSafe_ansteuerzeit_motor_max,90 ms,9
ENG298054-ENG298142-OpenByWire_RBox_Schloss-p_t_ZV_OBWr_KiSiSafe_ansteuerzeit_motor_min,60 ms,9
ENG298054-ENG298143-OpenByWire_RBox_Schloss-p_t_ZV_OBWr_KiSiSafe_bremsen_motor,20 ms,9
ENG298054-ENG298144-OpenByWire_RBox_Schloss-p_t_ZV_OBWr_KiSiSafe_verzoegerte_ansteuerung,0 ms,9
ENG298054-ENG298145-OpenByWire_RBox_Schloss-p_t_ZV_OBWr_KiSiSafe_warten_motor,500 ms,9
ENG298055-ENG298136-OpenByWire_Schloss-p_t_ZV_OBW_EOE_ansteuerzeit_motor,500 ms,2
ENG298055-ENG298137-OpenByWire_Schloss-p_t_ZV_OBW_EOE_bremsen_motor,0 ms,2
ENG298056-ENG298124-OpenByWire_Schloss_Teil2-p_t_EOE_kessy_verzoegerung,400 ms,8
ENG298056-ENG298138-OpenByWire_Schloss_Teil2-p_t_ZV_OBW_EOE_wartezeit_motor,0 ms,8
ENG133367-ENG133507-Passenger_multi-contour_seat_Error_Mask-ERROR_CODE_PIN,00000000 00000000  ,66
ENG133367-ENG133526-Passenger_multi-contour_seat_Error_Mask-ERROR_EEPROM,11111111 11111111  ,66
ENG133367-ENG133528-Passenger_multi-contour_seat_Error_Mask-ERROR_HW_VERSION,11111101 00011110  ,66
ENG133367-ENG133500-Passenger_multi-contour_seat_Error_Mask-ERROR_LUMB1_CTRL_LEAK,00000000 00000000  ,66
ENG133367-ENG133499-Passenger_multi-contour_seat_Error_Mask-ERROR_LUMB1_LEAK,00000000 00000000  ,66
ENG133367-ENG133502-Passenger_multi-contour_seat_Error_Mask-ERROR_LUMB2_CTRL_LEAK,00000000 00000000  ,66
ENG133367-ENG133501-Passenger_multi-contour_seat_Error_Mask-ERROR_LUMB2_LEAK,00000000 00000000  ,66
ENG133367-ENG133504-Passenger_multi-contour_seat_Error_Mask-ERROR_LUMB3_CTRL_LEAK,00000000 00000000  ,66
ENG133367-ENG133503-Passenger_multi-contour_seat_Error_Mask-ERROR_LUMB3_LEAK,00000000 00000000  ,66
ENG133367-ENG133511-Passenger_multi-contour_seat_Error_Mask-ERROR_PUMP_BLOCK,11111101 00011110  ,66
ENG133367-ENG133508-Passenger_multi-contour_seat_Error_Mask-ERROR_PUMP_OPEN,11111101 00011110  ,66
ENG133367-ENG133509-Passenger_multi-contour_seat_Error_Mask-ERROR_PUMP_SHORT_GND,11111101 00011110  ,66
ENG133367-ENG133510-Passenger_multi-contour_seat_Error_Mask-ERROR_PUMP_SHORT_UB,11111101 00011110  ,66
ENG133367-ENG133524-Passenger_multi-contour_seat_Error_Mask-ERROR_RAM,11111101 00011110  ,66
ENG133367-ENG133525-Passenger_multi-contour_seat_Error_Mask-ERROR_ROM,11111101 00011110  ,66
ENG133367-ENG133506-Passenger_multi-contour_seat_Error_Mask-ERROR_SIDE_CTRL_LEAK,00000000 00000000  ,66
ENG133367-ENG133505-Passenger_multi-contour_seat_Error_Mask-ERROR_SIDE_LEAK,00000000 00000000  ,66
ENG133367-ENG133531-Passenger_multi-contour_seat_Error_Mask-ERROR_SIG_RESPONSE,00000000 00000000  ,66
ENG133367-ENG133512-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_1,00000000 00000000  ,66
ENG133367-ENG133515-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_2,00000000 00000000  ,66
ENG133367-ENG133518-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_3,00000000 00000000  ,66
ENG133367-ENG133521-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_4,00000000 00000000  ,66
ENG133367-ENG133513-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_1,00000000 00000000  ,66
ENG133367-ENG133516-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_2,00000000 00000000  ,66
ENG133367-ENG133519-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_3,00000000 00000000  ,66
ENG133367-ENG133522-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_4,00000000 00000000  ,66
ENG133367-ENG133514-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_1,00000000 00000000  ,66
ENG133367-ENG133517-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_2,00000000 00000000  ,66
ENG133367-ENG133520-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_3,00000000 00000000  ,66
ENG133367-ENG133523-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_4,00000000 00000000  ,66
ENG133367-ENG133529-Passenger_multi-contour_seat_Error_Mask-ERROR_VOLTAGE_HIGH,11111111 11111111  ,66
ENG133367-ENG133530-Passenger_multi-contour_seat_Error_Mask-ERROR_VOLTAGE_LOW,11111111 11111111  ,66
ENG133367-ENG133527-Passenger_multi-contour_seat_Error_Mask-ERROR_WDT,11111111 11111111  ,66
ENG253210-ENG259841-Personalisierung_2_0-Active_Participant_ExteriorLight_Enabled,activated ,12
ENG253210-ENG260445-Personalisierung_2_0-Active_Participant_InteriorLight_Enabled,activated ,12
ENG253210-ENG298068-Personalisierung_2_0-Active_Participant_SeatPneumatic_Enabled,activated ,12
ENG253210-ENG259827-Personalisierung_2_0-Active_Participant_WiperComfort_Enabled,activated ,12
ENG253150-ENG259099-Praediktiver_Bremsenverschleiß-Bremsbelag_bis_Pille,0 mm,8
ENG253150-ENG259064-Praediktiver_Bremsenverschleiß-Bremsbelagstaerke_neu,0 mm,8
ENG253150-ENG259984-Praediktiver_Bremsenverschleiß-Max_Restlaufleistung,0 km,8
ENG253109-PSI5 Konfiguration,02 ,16
ENG141646-MAS01065-Querschnitts_funktionen-Brand,VW ,8
ENG141646-ENG141980-Querschnitts_funktionen-Bedien_und_Anzeigeprotokoll,active ,8
ENG141646-ENG116624-Querschnitts_funktionen-CAN Wecken bei Softtouchbetaetigung,not active ,8
ENG141646-ENG302723-Querschnitts_funktionen-DTC_compatibilty_ME2,active ,8
ENG141646-ENG142028-Querschnitts_funktionen-Fahrgeschwindigkeit_aus_ESP_21,active ,8
ENG141646-ENG142187-Querschnitts_funktionen-Hardware_Eingang_Drucktankklappenstatus,Pin A31 ,8
ENG141646-ENG154685-Querschnitts_funktionen-Hupe,Sollspannungsanforderung 13.5 ,8
ENG141646-ENG115810-Querschnitts_funktionen-Klemmenfehler auf CAN ausgeben,active ,8
ENG141646-ENG142015-Querschnitts_funktionen-Personalisierungsuebernahme,not_installed ,8
ENG141646-ENG141983-Querschnitts_funktionen-Schnittstelle_TrackingSystem,not active ,8
ENG141646-ENG141964-Querschnitts_funktionen-Steering alignment,Left ,8
ENG141646-ENG141965-Querschnitts_funktionen-Traffic side,Right ,8
ENG141646-ENG302846-Querschnitts_funktionen-ueberwachung_vorgegebene_datensaetze,active ,8
ENG263432-ENG142229-Regensensorik_Verbauund_ABT_Steuerung-HMI_Wiper_Comfort_Rain_Sensor_OFF,active ,3
ENG263432-ENG141956-Regensensorik_Verbauund_ABT_Steuerung-Humidity sensor,installedLIN3 ,3
ENG263432-ENG253444-Regensensorik_Verbauund_ABT_Steuerung-Light sensor,LIN_REGEN_LICHT_SENSOR ,3
ENG263432-ENG253437-Regensensorik_Verbauund_ABT_Steuerung-rain sensor,LIN_REGEN_LICHT_SENSOR ,3
ENG263432-ENG124476-Regensensorik_Verbauund_ABT_Steuerung-Sunlight photo sensor,installed ,3
ENG125614-Reset_Blower_1_Backrest_Left,No Response From Subnet Component,3
ENG125615-Reset_Blower_1_Backrest_Right,No Response From Subnet Component,3
ENG125613-Reset_Blower_1_Cushion_Left,No Response From Subnet Component,3
ENG125616-Reset_Blower_1_Cushion_Right,No Response From Subnet Component,3
ENG264033-ENG264176-RLFS_RLS Codierung (KII05)-Filterleerung bei Poti-Verstellung,On ,3
ENG264033-ENG264051-RLFS_RLS Codierung (KII05)-Licht an bei Regen,Master steuert ,3
ENG264033-ENG264182-RLFS_RLS Codierung (KII05)-Licht an über Geschwindigkeit,Ein / Slave steuert ,3
ENG264033-ENG264183-RLFS_RLS Codierung (KII05)-Lichtschaltschwellen Kalibrierung,0% (Standard) ,3
ENG264033-ENG159332-RLFS_RLS Codierung (KII05)-Parameter set,Parametersatz III ,3
ENG264033-ENG264191-RLFS_RLS Codierung (KII05)-Regenerkennung bei Kl.15 aus,OFF ,3
ENG264033-ENG264193-RLFS_RLS Codierung (KII05)-Regensensorbetrieb,On ,3
ENG264033-ENG264273-RLFS_RLS Codierung (KII05)-Start-Up-Wipe,OFF ,3
ENG264033-ENG264277-RLFS_RLS Codierung (KII05)-Transmission 550nm,75% Transmission ,3
ENG264033-ENG264278-RLFS_RLS Codierung (KII05)-Transmission 880nm,40% Transmission ,3
ENG264033-ENG264282-RLFS_RLS Codierung (KII05)-Wischeranlagentyp,Direct ,3
ENG253157-ENG260114-roof_module-roof_blind_place,Rear ,1
ENG253157-ENG260235-roof_module-roof_module_status,installed ,1
ENG277075-Schalterleiste 2,not installed ,2
ENG253012-ENG298118-Schiebetür-p_n_eRWK_Abbruchblinken_Blinkzyklen,3 ,14
ENG253012-ENG298119-Schiebetür-p_n_eRWK_Mindestanzahl_Oeffnungsblinken,2 ,14
ENG253012-ENG298120-Schiebetür-p_n_Sbt_Crashred_Wdh,10 ,14
ENG253012-ENG298121-Schiebetür-p_t_Abbruchblinken_eRWK_Hellphase,50 %,14
ENG253012-ENG298122-Schiebetür-p_t_Abbruchblinken_eRWK_Periodendauer,1000 ms,14
ENG253012-ENG298123-Schiebetür-p_t_Anf_Entr_Sbt_Timeout,0.5 s,14
ENG253012-ENG298125-Schiebetür-p_t_eRWK_Oeffnungsblinken_Hellphase,50 %,14
ENG253012-ENG298126-Schiebetür-p_t_eRWK_Oeffnungsblinken_max,10 ,14
ENG253012-ENG298127-Schiebetür-p_t_eRWK_Oeffnungsblinken_Periodendauer,1000 ms,14
ENG253012-ENG298128-Schiebetür-p_t_KiSi_Fkt_Bel_Timeout,600 s,14
ENG253012-ENG298130-Schiebetür-p_t_Sbt_Verzoegerung_Nachverriegelung,0 ms,14
ENG253012-ENG298132-Schiebetür-p_t_ZV_eKiSi_gesperrt,300 ms,14
ENG253012-ENG298133-Schiebetür-p_t_ZV_eRWK_Oeffnungsblinken_Mindest_Dauer,1.0 s,14
ENG253012-ENG298134-Schiebetür-p_t_ZV_FFB_Schiebetuer_Verzoegerung,800 ms,14
ENG253118-ENG126944-Schlüsselpositionsnachbildung (SPN)-Display_duration_error_mode_2_SPN,10 s,31
ENG253118-ENG129003-Schlüsselpositionsnachbildung (SPN)-Number_of_Multiple_ZAT_activations_to_emergency_shutoff,2 ,31
ENG253118-ENG253448-Schlüsselpositionsnachbildung (SPN)-Number_of_ZAT_activations_to_fault,10 ,31
ENG253118-ENG258331-Schlüsselpositionsnachbildung (SPN)-Vehicle_activation_Deactivation_via_ZAT,Yes ,31
ENG253264-Seat_cushion_fan,not installed ,1
ENG253224-ENG258215-Seat_pneumatics-Bcm_response_timer,350 ms,8
ENG253224-ENG259532-Seat_pneumatics-Installation_seat_pneumatics,installed ,8
ENG253224-ENG260752-Seat_pneumatics-Installation_side_support,installed ,8
ENG253224-ENG259164-Seat_pneumatics-Massage_intensity_level,3 ,8
ENG253224-ENG259581-Seat_pneumatics-Massage_programs,1 ,8
ENG253224-ENG259920-Seat_pneumatics-occupancy_passenger_side,5 ,8
ENG253224-ENG259260-Seat_pneumatics-Popup_knockout_time,25 min,8
ENG253224-ENG259408-Seat_pneumatics-Seat_pneumatics_adjustment_passenger_side,not installed ,8
ENG253224-ENG259024-Seat_pneumatics-Velocity_limit,10 km/h,8
ENG253224-ENG260841-Seat_pneumatics-Velocity_min,10 km/h,8
ENG253090-ENG261034-Seat_pneumatics_massage_program_allocation-massage_program_allocation_01,1 ,6
ENG253090-ENG258845-Seat_pneumatics_massage_program_allocation-massage_program_allocation_02,2 ,6
ENG253090-ENG258718-Seat_pneumatics_massage_program_allocation-massage_program_allocation_03,5 ,6
ENG253090-ENG260661-Seat_pneumatics_massage_program_allocation-massage_program_allocation_04,1 ,6
ENG253090-ENG258113-Seat_pneumatics_massage_program_allocation-massage_program_allocation_05,2 ,6
ENG253090-ENG259726-Seat_pneumatics_massage_program_allocation-massage_program_allocation_06,5 ,6
ENG253283-ENG258595-Signal_mapping_tsg-verzoegerung_swc_signale,100 ms,4
ENG253283-ENG260734-Signal_mapping_tsg-Zeitbasis_0,50 ms,4
ENG253283-ENG260177-Signal_mapping_tsg-Zeitbasis_1,250 ms,4
ENG153742-ENG154567-SMLS_konfig_entw-blinker_err_el_kurzschluss,General reject,4
ENG153742-ENG154568-SMLS_konfig_entw-blinker_err_el_unterbrechung,General reject,4
ENG153742-ENG154569-SMLS_konfig_entw-blinker_err_fernlicht_haengt_aus,General reject,4
ENG153742-ENG154570-SMLS_konfig_entw-blinker_err_fernlicht_haengt_ein,General reject,4
ENG153742-ENG154571-SMLS_konfig_entw-blinker_err_gra_haengt_aus,General reject,4
ENG153742-ENG154572-SMLS_konfig_entw-blinker_err_gra_haengt_ein,General reject,4
ENG153742-ENG154573-SMLS_konfig_entw-blinker_err_lichthupe_haengt_aus,General reject,4
ENG153742-ENG154574-SMLS_konfig_entw-blinker_err_lichthupe_haengt_ein,General reject,4
ENG153742-ENG154575-SMLS_konfig_entw-blinker_err_unplausibel,General reject,4
ENG153742-ENG154576-SMLS_konfig_entw-blinker_err_weckkontakthaengt_aus,General reject,4
ENG153742-ENG154577-SMLS_konfig_entw-blinker_err_weckkontakthaengt_ein,General reject,4
ENG153742-ENG154594-SMLS_konfig_entw-entprellung_unplausibel,General reject,4
ENG153742-ENG154595-SMLS_konfig_entw-entprellzeit_ueberspannung,General reject,4
ENG153742-ENG154596-SMLS_konfig_entw-entprellzeit_unterspannung,General reject,4
ENG153742-ENG154622-SMLS_konfig_entw-gra_ea_error,General reject,4
ENG153742-ENG154625-SMLS_konfig_entw-grahebel_err_el_kurzschluss,General reject,4
ENG153742-ENG154626-SMLS_konfig_entw-grahebel_err_el_unterbrechung,General reject,4
ENG153742-ENG154627-SMLS_konfig_entw-grahebel_err_gra_haengt_aus,General reject,4
ENG153742-ENG154628-SMLS_konfig_entw-grahebel_err_gra_haengt_ein,General reject,4
ENG153742-ENG154629-SMLS_konfig_entw-grahebel_err_unplausibel,General reject,4
ENG153742-ENG154687-SMLS_konfig_entw-hupe_err_hinweis,General reject,4
ENG153742-ENG154688-SMLS_konfig_entw-hupe_err_hupe_haengt_aus,General reject,4
ENG153742-ENG154689-SMLS_konfig_entw-hupe_err_hupe_haengt_ein,General reject,4
ENG153742-ENG154700-SMLS_konfig_entw-lrh_kurzschluss_entprellen,General reject,4
ENG153742-ENG289599-SMLS_konfig_entw-lrh_taster_haengt_aus,General reject,4
ENG153742-ENG289600-SMLS_konfig_entw-lrh_taster_haengt_ein,General reject,4
ENG153742-ENG154701-SMLS_konfig_entw-lrh_unterbrechung_entprellen,General reject,4
ENG153742-ENG154707-SMLS_konfig_entw-n_fehler_verriegelt,General reject,4
ENG153742-ENG154780-SMLS_konfig_entw-spannung_obere_schwelle,General reject,4
ENG153742-ENG154781-SMLS_konfig_entw-spannung_obere_schwelle_funkt_einschr,General reject,4
ENG153742-ENG154782-SMLS_konfig_entw-spannung_untere_schwelle,General reject,4
ENG153742-ENG154783-SMLS_konfig_entw-spannung_untere_schwelle_funkt_einschr,General reject,4
ENG153742-ENG154805-SMLS_konfig_entw-verriegelt_err_el_kurzschluss,General reject,4
ENG153742-ENG154806-SMLS_konfig_entw-verriegelt_err_unplausibel_aus,General reject,4
ENG153742-ENG154807-SMLS_konfig_entw-verriegelt_err_unplausibel_ein,General reject,4
ENG153742-ENG154808-SMLS_konfig_entw-verriegelt_err_unplausibel_in_parkposition_aus,General reject,4
ENG153742-ENG154809-SMLS_konfig_entw-verriegelt_err_unplausibel_in_parkposition_ein,General reject,4
ENG153742-ENG154812-SMLS_konfig_entw-wischer_err_el_kurzschluss,General reject,4
ENG153742-ENG154813-SMLS_konfig_entw-wischer_err_el_unterbrechung,General reject,4
ENG153742-ENG154814-SMLS_konfig_entw-wischer_err_intervallpoti_haengt_aus,General reject,4
ENG153742-ENG154815-SMLS_konfig_entw-wischer_err_intervallpoti_haengt_ein,General reject,4
ENG153742-ENG154816-SMLS_konfig_entw-wischer_err_mfa_haengt_aus,General reject,4
ENG153742-ENG154817-SMLS_konfig_entw-wischer_err_mfa_haengt_ein,General reject,4
ENG153742-ENG154818-SMLS_konfig_entw-wischer_err_unplausibel,General reject,4
ENG153742-ENG154819-SMLS_konfig_entw-wischer_err_waschen_haengt_aus,General reject,4
ENG153742-ENG154820-SMLS_konfig_entw-wischer_err_waschen_haengt_ein,General reject,4
ENG153742-ENG154821-SMLS_konfig_entw-wischer_err_wischen_haengt_aus,General reject,4
ENG153742-ENG154822-SMLS_konfig_entw-wischer_err_wischen_haengt_ein,General reject,4
ENG253011-MAS10520-Special_function-Special function 1,not installed ,4
ENG253011-SFT00048-Special_function-Special Function 2,not enabled ,4
ENG253011-ENG260472-Special_function-Blinkerueberwachug_Sonderfunktions_SG,not installed ,4
ENG253125-ENG260641-SRA-p_sra_bcm_temperaturgrenze,0 °C,8
ENG253125-ENG260115-SRA-p_sra_geschwindigkeitsgrenze,0 km/h,8
ENG253125-ENG259607-SRA-p_sra_nach_t_frontwaschendauer,0 ms,8
ENG253125-ENG259677-SRA-p_sra_obere_aussentemperaturgrenze,-100 °C,8
ENG253125-ENG261148-SRA-p_sra_untere_aussentemperaturgrenze,-100 °C,8
ENG253125-ENG260015-SRA-p_t_sra_ueberlast,0 s,8
ENG153700-ENG154803-Steering Column Switch-Verbauort_Lenkstockschalter,CAN ,10
ENG302681-ENG260527-Störungsmeldungen_Licht_Wischwasch-p_Lichtrouter_meldung_ausmaskiert,00 ,15
ENG302681-ENG260368-Störungsmeldungen_Licht_Wischwasch-p_t_LDS_defekt_meldung,10 s,15
ENG302681-ENG260726-Störungsmeldungen_Licht_Wischwasch-p_t_RLS_Meldung,2000 ms,15
ENG141663-ENG142240-Suchbeleuchtung_allgemein-Daempfung Abdimmen KL 58xd PWM,0.04 s,21
ENG141663-ENG154582-Suchbeleuchtung_allgemein-Daempfung_Abdimmen_KL_58xs_PWM,0.04 s,21
ENG141663-ENG154583-Suchbeleuchtung_allgemein-Daempfung_Abdimmen_KL_58xt_PWM,0.04 s,21
ENG141663-ENG154584-Suchbeleuchtung_allgemein-Daempfung_Aufdimmen_KL_58xd_PWM,0.08 s,21
ENG141663-ENG154585-Suchbeleuchtung_allgemein-Daempfung_Aufdimmen_KL_58xt_PWM,0.08 s,21
ENG141663-ENG154712-Suchbeleuchtung_allgemein-PWM_Daempfung_Aufdimmen_KL58xs_PWM,0.08 s,21
ENG141663-ENG115820-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Grundwert,6.0 ,21
ENG141677-ENG115659-Suchbeleuchtung_KL_58xd_PWM-y0,3.0 %,12
ENG141677-ENG99777-Suchbeleuchtung_KL_58xd_PWM-Y1,3.0 %,12
ENG141677-ENG100480-Suchbeleuchtung_KL_58xd_PWM-Y2,11.0 %,12
ENG141677-ENG100773-Suchbeleuchtung_KL_58xd_PWM-Y3,40.0 %,12
ENG141677-ENG100631-Suchbeleuchtung_KL_58xd_PWM-Y4,82.0 %,12
ENG153970-ENG115658-Suchbeleuchtung_KL_58xs_PWM-x0,0.0 ,6
ENG153970-ENG101574-Suchbeleuchtung_KL_58xs_PWM-X1,50.0 ,6
ENG153970-ENG99557-Suchbeleuchtung_KL_58xs_PWM-X2,100.0 ,6
ENG153970-ENG115659-Suchbeleuchtung_KL_58xs_PWM-y0,0.0 %,6
ENG153970-ENG99777-Suchbeleuchtung_KL_58xs_PWM-Y1,50.0 %,6
ENG153970-ENG100480-Suchbeleuchtung_KL_58xs_PWM-Y2,100.0 %,6
ENG141676-ENG115658-Suchbeleuchtung_KL_58xt_PWM-x0,0.0 ,6
ENG141676-ENG101574-Suchbeleuchtung_KL_58xt_PWM-X1,50.0 ,6
ENG141676-ENG99557-Suchbeleuchtung_KL_58xt_PWM-X2,100.0 ,6
ENG141969-ENG249827-UGDO-Anlernblinken,not active ,3
ENG141969-ENG172987-UGDO-ugdo_transmitter,not installed ,3
ENG141969-ENG172966-UGDO-ugdo_via_mmi_configurable,not active ,3
ENG116971-ENG116537-Vernetzungs- Diagnosefunktionen-can msg 1,00 00 00 00 ,28
ENG116971-ENG116538-Vernetzungs- Diagnosefunktionen-can msg 2,00 00 00 00 ,28
ENG116971-ENG116539-Vernetzungs- Diagnosefunktionen-can msg 3,00 00 00 00 ,28
ENG116971-ENG116540-Vernetzungs- Diagnosefunktionen-can msg 4,00 00 00 00 ,28
ENG116971-ENG116541-Vernetzungs- Diagnosefunktionen-lin msg 1,00 00 ,28
ENG116971-ENG116542-Vernetzungs- Diagnosefunktionen-lin msg 2,00 00 ,28
ENG116971-ENG116543-Vernetzungs- Diagnosefunktionen-lin msg 3,00 00 ,28
ENG116971-ENG116544-Vernetzungs- Diagnosefunktionen-lin msg 4,00 00 ,28
ENG116971-ENG116545-Vernetzungs- Diagnosefunktionen-lin msg 5,00 00 ,28
ENG116971-ENG116546-Vernetzungs- Diagnosefunktionen-lin msg 6,00 00 ,28
ENG253214-ENG286384-Virtuelles_Pedal_Global-Virtuelles_Pedal_HBFS_Verbau,installed ,4
ENG253214-ENG286385-Virtuelles_Pedal_Global-Virtuelles_Pedal_HFS_Verbau,installed ,4
ENG154424-IDE05534-Waschen-Headlamp washer system,not installed ,8
ENG154424-ENG154706-Waschen-Mindestwaschzeit_Frontwischer,0 ms,8
ENG154424-ENG249933-Waschen-RVC_Speed_Hysteresis,5 km/h,8
ENG154424-ENG249934-Waschen-RVC_Speed_max,50 km/h,8
ENG154424-ENG260022-Waschen-RVC_Waschen,not installed ,8
ENG154424-ENG249936-Waschen-RVC_Waschen_HMI,not active ,8
ENG154424-ENG260162-Waschen-Time_RVC_cleaning_Pumpe_active_BCM,1.5 s,8
ENG154424-ENG281090-Waschen-Transportmodus_SRA,not active ,8
ENG154424-ENG258116-Waschen-Waschen_ohne_KL15,not active ,8
ENG154424-ENG260669-Waschen-Wiederstart_Restfunktionen,not active ,8
ENG249803-ENG249921-Waschen_Parameter-N_RVC_Activation,5 ,8
ENG249803-ENG261175-Waschen_Parameter-pa_t_wasch_min_heck,1200 ms,8
ENG249803-ENG249941-Waschen_Parameter-T1_RVC_Treshold,30 s,8
ENG249803-ENG249942-Waschen_Parameter-T2_RVC_Deactivation,180 s,8
ENG253306-ENG259934-Wascher_pumpe-p_n_Spielschutz_Wascherpumpen,10 ,4
ENG253306-ENG258230-Wascher_pumpe-p_t_Delay_Frontwaschen,1500 ms,4
ENG253306-ENG260892-Wascher_pumpe-p_t_DWP_Blockiererkennung,100 ms,4
ENG253306-ENG259530-Wascher_pumpe-p_t_Wascherpumpe_max,10 s,4
ENG302687-IDE05557-Window_regulator_rear_installation-Rear drivers side window regulator,installed ,1
ENG302687-IDE05741-Window_regulator_rear_installation-Rear passenger side window regulator,installed ,1
ENG302687-MAS09704-Window_regulator_rear_installation-Steering alignment,Left hand steering ,1
ENG302687-ENG302847-Window_regulator_rear_installation-Window_regulator_rear_installation_control,Window_regulator_driver_side_rear_normal_installation ,1
ENG117302-ENG148862-Window_Regulator_Supplier_Settings_Driver_Side_Rear_1-Parameter_1,82 FB 00 00 EC FF BA FF 00 00 24 FF 15 FF 70 FE E0 FC A2 FE 98 FE EC FF 5E 01 40 06 58 02 58 02 00 00 B0 04 00 14 BA D8 00 FB 00 C1 00 00 00 00 32 00 0A 04 23 01 00 07 01 02 1E 50 8C DC 01 02 08 01 06 05 0B 03 05 64 3C 00 05 09 19 30 AF 28 0F 00 00 DC 05 2C 01 B8 0B C4 09 00 08 0A 0C 10 10 12 14 16 18 18 1B 1E 21 24 27 2A 2D 30 33 36 39 3C 3F 42 45 48 4B 4E 51 54 00 00 00 00 ,128
ENG117302-ENG148865-Window_Regulator_Supplier_Settings_Driver_Side_Rear_1-Parameter_2,27 6D ,128
ENG117303-ENG148862-Window_Regulator_Supplier_Settings_Driver_Side_Rear_2-Parameter_1,00 18 FC 18 FC 18 FC 5A 00 00 00 32 00 AA AA 99 99 88 00 00 00 00 00 00 00 00 00 00 00 3C 00 60 FF 06 0A 05 06 20 1C 20 03 01 01 00 CC 4D B0 04 03 FB FA F9 F7 1E 7F 0A 01 02 03 04 08 46 70 1E 32 0D 1B 05 0C 00 04 41 B4 05 28 00 28 B8 0B 01 9A 58 4E 64 0A 37 4B 55 5F 69 5D 60 62 65 00 5A 01 01 00 3C 50 5A 28 05 00 58 02 70 FE 0C FE C8 00 14 00 00 00 00 7F 00 07 00 00 00 00 00 ,128
ENG117303-ENG148865-Window_Regulator_Supplier_Settings_Driver_Side_Rear_2-Parameter_2,C8 D4 ,128
ENG117306-ENG148862-Window_Regulator_Supplier_Settings_Passenger_Side_Rear_1-Parameter_1,82 FB 00 00 EC FF BA FF 00 00 24 FF 15 FF 70 FE E0 FC A2 FE 98 FE EC FF 5E 01 40 06 58 02 58 02 00 00 B0 04 00 14 BA D8 00 FB 00 C1 00 00 00 00 32 00 0A 04 23 01 00 07 01 02 1E 50 8C DC 01 02 08 01 06 05 0B 03 05 64 3C 00 05 09 19 30 AF 28 0F 00 00 DC 05 2C 01 B8 0B C4 09 00 08 0A 0C 10 10 12 14 16 18 18 1B 1E 21 24 27 2A 2D 30 33 36 39 3C 3F 42 45 48 4B 4E 51 54 00 00 00 00 ,128
ENG117306-ENG148865-Window_Regulator_Supplier_Settings_Passenger_Side_Rear_1-Parameter_2,27 6D ,128
ENG117307-ENG148862-Window_Regulator_Supplier_Settings_Passenger_Side_Rear_2-Parameter_1,00 18 FC 18 FC 18 FC 5A 00 00 00 32 00 AA AA 99 99 88 00 00 00 00 00 00 00 00 00 00 00 3C 00 60 FF 06 0A 05 06 20 1C 20 03 01 01 00 CD 4D B0 04 03 FB FA F9 F7 1F 7F 0A 01 02 03 04 08 46 70 1E 32 0D 1B 05 0C 00 04 41 B4 05 28 00 28 B8 0B 01 9A 58 4E 64 0A 37 4B 55 5F 69 5D 60 62 65 00 5A 01 01 00 3C 50 5A 28 05 00 58 02 70 FE 0C FE C8 00 14 00 00 00 00 7F 00 07 01 00 00 00 00 ,128
ENG117307-ENG148865-Window_Regulator_Supplier_Settings_Passenger_Side_Rear_2-Parameter_2,8C A2 ,128
ENG117301-Window_Regulator_VW_Settings_Driver_Side_Rear,0F 14 00 14 00 19 0F 64 00 0F 98 08 2D 58 78 05 F4 01 B0 04 1E 0A 00 4B 4B 00 4B 4C 00 00 00 00 00 00 00 00 00 A6 A6 00 05 3C 14 20 4E 58 4D 0B 0A 0A 05 4B A3 55 9E 64 14 05 01 05 48 B7 52 AD 64 14 05 01 05 02 00 00 35 37 32 32 FF 00 00 00 00 00 00 00 00 00 B6 EC ,88
ENG117305-Window_Regulator_VW_Settings_Passenger_Side_Rear,0F 14 00 14 00 19 0F 64 00 0F 98 08 2D 58 78 05 F4 01 B0 04 1E 0A 00 4B 4B 00 4B 4C 00 00 00 00 00 00 00 00 00 A6 A6 00 05 3C 14 20 4E 58 4D 0B 00 00 05 4B A3 55 9E 64 14 05 01 05 48 B7 52 AD 64 14 05 01 05 02 00 00 35 37 32 32 FF 00 00 00 00 00 00 00 00 00 96 4B ,88
ENG253279-ENG126852-Wisch_geschwindigkeiten-Dauerwischen Stufe_1 Zyklen pro Minute,40 ,3
ENG253279-ENG126853-Wisch_geschwindigkeiten-Dauerwischen Stufe_2 Zyklen pro Minute,60 ,3
ENG253279-ENG116699-Wisch_geschwindigkeiten-Reduzierte Wischgeschwindigkeit Zyklen pro Minute,30 ,3
ENG124901-Wischer_Fehlermaske_Mitsuba_Entw,00 00 00 00 ,4
ENG263491-ENG263568-ZV NFZ - Tueren HBFS-Schiebetuer HBFS,Electrical ,2
ENG263491-ENG258359-ZV NFZ - Tueren HBFS-Schlosstyp HBFS,OBWr_Schloss ,2
ENG263491-ENG263538-ZV NFZ - Tueren HBFS-Tuerkontaktmodul HBFS,No ,2
ENG263438-ENG263586-ZV NFZ - Tueren HFS-Schiebetuer HFS,Electrical ,2
ENG263438-ENG258315-ZV NFZ - Tueren HFS-Schlosstyp HFS,OBWr_Schloss ,2
ENG263438-ENG263572-ZV NFZ - Tueren HFS-Tuerkontaktmodul HFS,No ,2
ENG141652-ENG258598-ZV Türkonfiguration-Fzg_mit_Vier_Tueren,No ,2
ENG141652-ENG260173-ZV Türkonfiguration-Schloesser_direkt_gesteuert,vordere via CAN angeschlossen: hinten diskre ,2
ENG141652-ENG142000-ZV Türkonfiguration-Schlosstyp_NAR,Yes ,2
ENG141652-ENG258913-ZV Türkonfiguration-ZV Schlosstyp,Einmotorenschloss ohne Safe ,2
ENG298061-MAS19656-ZV_allgemein_Parameter-Actuation time 1 for double-actuation,5100 ms,38
ENG298061-MAS19657-ZV_allgemein_Parameter-Actuation time 2 for double-actuation,5100 ms,38
ENG298061-MAS19658-ZV_allgemein_Parameter-Time window for double-actuation,1.4 s,38
ENG298061-ENG258286-ZV_allgemein_Parameter-p_t_FFB_Sperrzeit,2000 ms,38
ENG298061-ENG260848-ZV_allgemein_Parameter-p_t_Freigabe_Softtouch,45 s,38
ENG298061-ENG258282-ZV_allgemein_Parameter-p_t_freigabe_Softtouch_ohne_ZV_nach_Kl15_aus,10.0 ,38
ENG298061-ENG298129-ZV_allgemein_Parameter-p_t_max_SRA_Aktivierung,10000 ms,38
ENG298061-ENG258328-ZV_allgemein_Parameter-p_t_maxzeit_wiederentriegelung,30 s,38
ENG298061-ENG258353-ZV_allgemein_Parameter-p_t_Notschliessen_Verzoegerung,2000 ms,38
ENG298061-ENG261011-ZV_allgemein_Parameter-p_t_tankklappensteuerung,400 ms,38
ENG298061-ENG298131-ZV_allgemein_Parameter-p_t_timeout_ORU_status,120 ,38
ENG298061-ENG258808-ZV_allgemein_Parameter-p_t_v_Autolock_Mindestzeit,500 ms,38
ENG298061-ENG259413-ZV_allgemein_Parameter-p_t_zeitabstand_wiederentriegelung,1000 ms,38
ENG298061-ENG258635-ZV_allgemein_Parameter-p_t_zeitfenster_nach_verriegeln,45000 ms,38
ENG298061-ENG260528-ZV_allgemein_Parameter-p_t_ZV_ansteuerzeit_motor,150 ms,38
ENG298061-ENG260542-ZV_allgemein_Parameter-p_t_ZV_bremsen_motor,50 ms,38
ENG298061-ENG258149-ZV_allgemein_Parameter-p_t_ZV_delay_safeLatch,10 ms,38
ENG298061-ENG258507-ZV_allgemein_Parameter-p_t_ZV_FFB_Mindestverzoegerung_zweiter_Befehl,100 ms,38
ENG298061-ENG258894-ZV_allgemein_Parameter-p_t_ZV_Freigabenachlauf_Heck_nach_Einzeloeffnung,30 s,38
ENG298061-ENG298135-ZV_allgemein_Parameter-p_t_ZV_LU_zweite_Anf_verwerfen,800 ms,38
ENG298061-ENG258535-ZV_allgemein_Parameter-p_t_ZV_Timeout_Front_TSG_Botschaft,200 ms,38
ENG298061-ENG258675-ZV_allgemein_Parameter-p_t_ZV_Verzögerung_Funkaktivierung,3000 ms,38
ENG298061-ENG260802-ZV_allgemein_Parameter-p_t_ZV_Wiederveriegelung,45000 ms,38
ENG298061-ENG258197-ZV_allgemein_Parameter-p_t_ZV_Zeitfenster_bew_entsafen,2000 ms,38
ENG298061-ENG259545-ZV_allgemein_Parameter-p_t_ZV_Zeitfenster_global_entriegeln,5000 ms,38
ENG298061-ENG259704-ZV_allgemein_Parameter-p_v_Autolock,15 km/h,38
ENG298061-ENG260516-ZV_allgemein_Parameter-p_v_ZVsperren,4 km/h,38
ENG253027-ENG173641-ZV_Crash-central_locking_system_emergency_assist,active ,2
ENG253027-ENG259575-ZV_Crash-Verzoegerung_ZV_Entriegelung_bei_Seitencrash,active ,2
ENG263427-ENG263506-zv_router_global-Elektrischer_SBT_Feststeller_verbaut,installed ,5
ENG263427-ENG263563-zv_router_global-Elektronische_Kindersicherung_eKiSi,Yes ,5
ENG263427-ENG263551-zv_router_global-FFB_Schiebetuer_entriegelt,No ,5
ENG263427-ENG248688-zv_router_global-Freischaltung_der_Kisi_Auswurffunktion,active ,5
ENG263427-ENG248689-zv_router_global-Freischaltung_KiSi_Taster_bei_extern_verriegeltem_Fahrzeug,not active ,5
ENG263427-ENG248698-zv_router_global-HD_Innentaster_im_Heck,not installed ,5
ENG263427-ENG263582-zv_router_global-Laderaumtaster_verbaut,not installed ,5
ENG263427-ENG248768-zv_router_global-NFZ_Schliessung,not active ,5
ENG263427-ENG302829-zv_router_global-pa_Fahrzeug_typ,People ,5
ENG263427-ENG302830-zv_router_global-pa_NNS_mit_Kessy_verbaut,Yes ,5
ENG263427-ENG263555-zv_router_global-Schiebetuer_Auswurffunkion_bei_intern_verriegelt,active ,5
ENG263427-ENG263553-zv_router_global-Schiebetuertaste_Armaturentafel_bei extern_verriegelt,not active ,5
ENG263427-ENG133390-zv_router_global-Wiederverriegelung_Laderaum,not installed ,5
ENG253134-ENG260874-ZV_SAM-Elektrische_Laderaumabdeckung_Aktiviert,not installed ,2
ENG253134-ENG259349-ZV_SAM-Heck_ohne_softtouch,not active ,2
ENG253134-ENG260581-ZV_SAM-Heckschloss_mit_VR,Yes ,2
ENG253134-ENG98873-ZV_SAM-safe,No ,2
ENG253134-ENG273833-ZV_SAM-Schlosstyp_ HFS,OBWr_Schloss ,2
ENG253134-ENG259683-ZV_SAM-Schlosstyp_HBFS,OBWr_Schloss ,2
ENG253134-ENG260040-ZV_SAM-Schlosstyp_Heck,Federsteller ,2
Elapsed Time: 02:56
adpmap-10-1EE-919-300-B_WVG5WVEB2SH017765-20250325-1225.CSV
;SW:1EE-919-300-B   HW:1EE-919-300 ---  Park/Steer Assist
;Component:RPA12K        H01 0630, Coding:0230026041
;EV_EPHBO3CVW4130000,001014,EV_EPHBO3CVW4130000_VWE3.rod
;Tuesday,25,March,2025,12:25:45:58926
;VCDS Version: Release 25.3.0 (x64)  Data version: 20250311 DS365.0
;VCID: 333871DA0BBB0A72424-8066-R
IDE01165-Park assist activation tone,OFF ,1
IDE01167-Convertible offset for volume level 1,1 ,1
IDE07159-MAS01155-Control module switch-off: counter-Control module,0 ,2
IDE07159-MAS05583-Control module switch-off: counter-Data bus,0 ,2
IDE07160-IDE15110-Control module switch-off: switch-off time-Coupling shut-off time: data bus with low-voltage energy management,Low-voltage energy management: coupling not available ,2
IDE07160-MAS00478-Control module switch-off: switch-off time-Reserved,0 ,2
IDE07160-MAS01155-Control module switch-off: switch-off time-Control module,15 min ,2
IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,15 min ,2
IDE07160-ENG99458-Control module switch-off: switch-off time-Reserved_2,0 ,2
IDE16364-IDE16536-List of identifiers and data record numbers-Identifier,00 00 ,2
IDE16364-MAS25708-List of identifiers and data record numbers-Number Of Identifiers,0 ,2
Elapsed Time: 00:05
adpmap-13-1EA-907-567-B_WVG5WVEB2SH017765-20250325-1226.CSV
;SW:1EA-907-567-B   HW:1EA-907-819 ---  Auto Dist. Reg
;Component:ARS512VW13    H05 0232, Coding:06230AE24071C04412574000008040052F4020000000000000000000000000
;EV_FRONTRADARCONTIVW310,004013,EV_FRONTRADARCONTIVW310_004_VWE3.rod
;Tuesday,25,March,2025,12:26:17:58926
;VCID: 3B2859FA23EBC2329A4-806E-R SFD+SFD2
IDE00820-ENG132029-Activating and deactivating all development messages-Development Message ECU specific,OFF ,1
IDE00820-ENG102778-Activating and deactivating all development messages-development message S100,OFF ,1
IDE00820-ENG101934-Activating and deactivating all development messages-development message S101,OFF ,1
IDE00820-ENG103391-Activating and deactivating all development messages-development message S102,OFF ,1
IDE00820-ENG132030-Activating and deactivating all development messages-XCP on FlexRay,OFF ,1
IDE01949-Distance basic setting option,OFF ,1
IDE09564-Distance change via speed adjustment,On ,1
IDE09565-Prioritized target object display,OFF ,1
IDE11924-MAS13429-Correction angle-Horizontal correction angle: currently,0.210 °,4
IDE11924-MAS13430-Correction angle-Vertical correction angle: currently,-0.230 °,4
IDE11926-MAS04910-Static calibration: preparation-Driving axis angle,-120 ,7
IDE11926-MAS13433-Static calibration: preparation-Lateral displacement of front axle,-400.00 mm,7
IDE11926-MAS13434-Static calibration: preparation-Lateral displacement of rear axle,-400.00 mm,7
IDE11926-MAS13435-Static calibration: preparation-Vertical lead angle,-5.00 °,7
IDE12516-Predictive speed limit regulation,activated ,1
IDE13334-Reduced radar performance,38 ,1
IDE14161-MAS04910-Static calibration: follow-up-Driving axis angle,-120 ,7
IDE14161-MAS13433-Static calibration: follow-up-Lateral displacement of front axle,-400.00 mm,7
IDE14161-MAS13434-Static calibration: follow-up-Lateral displacement of rear axle,-400.00 mm,7
IDE14161-MAS13435-Static calibration: follow-up-Vertical lead angle,-5.00 °,7
IDE14987-IDE15024-Correction angle last event-Horizontal correction angle last event,0.210 °,4
IDE14987-IDE15025-Correction angle last event-Vertical correction angle last result,-0.230 °,4
MAS19336-Active participant function activated,activated ,1
ENG253321-ENG276166-Monitoring_and_FRKL_masking-Error_response_masking,Conditions not correct or request sequence error,1
ENG253321-ENG276167-Monitoring_and_FRKL_masking-Monitoring_masking,Conditions not correct or request sequence error,1
Elapsed Time: 00:04
adpmap-15-3WA-959-655-AA_WVG5WVEB2SH017765-20250325-1226.CSV
;SW:3WA-959-655-AA   HW:3WA-959-655-AA ---  Airbags
;Component:Airbag VW50   006 0151, Coding:8CCC0C0000FCC0000000002000000000A15450008100A200830036F8102B0065
;EV_AirbaVW50TS6VW49X,001001,EV_AirbaVW50TS6VW49X_VWE3.rod
;Tuesday,25,March,2025,12:26:50:58926
;VCID: 147AD2466EF5ED4A3BE-8040-R SFD+SFD2
IDE06314-Calibration data: pre-crash,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,42
IDE06527-IDE06311-Adaptation pre-crash-Left seat belt tensioner,not defined ,4
IDE06527-IDE06312-Adaptation pre-crash-Right seat belt tensioner,not defined ,4
IDE06527-IDE07271-Adaptation pre-crash-Belt tensioner second row right,not defined ,4
IDE06527-IDE07274-Adaptation pre-crash-Belt tensioner second row left,not defined ,4
IDE06527-IDE12159-Adaptation pre-crash-Belt feed control module for 2nd row left,not defined ,4
IDE06527-IDE12160-Adaptation pre-crash-Belt feed control module for 2nd row right,not defined ,4
IDE07160-MAS01155-Control module switch-off: switch-off time-Control module,15 min,3
IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,15 min,3
IDE07160-ENG258305-Control module switch-off: switch-off time-BusKnockOut_Tmr_NVEM,0 min,3
IDE09601-IDE03311-Adaptation PreCrash functions-Emergency braking display,not defined ,16
IDE09601-IDE03633-Adaptation PreCrash functions-Close sunroof,not defined ,16
IDE09601-IDE03634-Adaptation PreCrash functions-Close windows,not defined ,16
IDE09601-IDE09602-Adaptation PreCrash functions-Locale hazard warning,not defined ,16
IDE09601-IDE09603-Adaptation PreCrash functions-RECAS,not defined ,16
IDE09601-IDE09604-Adaptation PreCrash functions-Seat adjustment - backrest,not defined ,16
IDE09601-IDE09605-Adaptation PreCrash functions-Seat adjust. - side bolster,not defined ,16
IDE09601-IDE09606-Adaptation PreCrash functions-Seat adjustment - headrests,not defined ,16
IDE09601-IDE09607-Adaptation PreCrash functions-PreCrash Front,not defined ,16
IDE09601-IDE09608-Adaptation PreCrash functions-Seat belt slack reduction: left,not defined ,16
IDE09601-IDE09609-Adaptation PreCrash functions-Seat belt slack reduction: right,not defined ,16
IDE09601-IDE09610-Adaptation PreCrash functions-Seat belt slack reduction: 2nd row left,not defined ,16
IDE09601-IDE09611-Adaptation PreCrash functions-Seat belt slack reduction: 2nd row right,not defined ,16
IDE09601-IDE09612-Adaptation PreCrash functions-Seat belt slack reduction: 2nd row ctr.,not defined ,16
IDE09601-IDE09613-Adaptation PreCrash functions-Seat belt slack reduction: 3rd row left,not defined ,16
IDE09601-IDE09614-Adaptation PreCrash functions-Seat belt slack reduction: 3rd row right,not defined ,16
IDE09601-IDE09615-Adaptation PreCrash functions-Seat belt slack reduction: 3rd row ctr.,not defined ,16
IDE09601-IDE09616-Adaptation PreCrash functions-Reversible belt tensioning left,not defined ,16
IDE09601-IDE09617-Adaptation PreCrash functions-Reversible belt tensioning right,not defined ,16
IDE09601-IDE09618-Adaptation PreCrash functions-Reversible belt tensioning: act. code of seat belt tightenert,not defined ,16
IDE09601-IDE09619-Adaptation PreCrash functions-Reversible belt tensioning: 2nd row right,not defined ,16
IDE09601-IDE09620-Adaptation PreCrash functions-Reversible belt tensioning: 2nd row ctr.,not defined ,16
IDE09601-IDE09621-Adaptation PreCrash functions-Reversible belt tensioning: 3rd row left,not defined ,16
IDE09601-IDE09622-Adaptation PreCrash functions-Reversible belt tensioning: 3rd row right,not defined ,16
IDE09601-IDE09623-Adaptation PreCrash functions-Reversible belt tensioning: 3rd row ctr.,not defined ,16
IDE09601-IDE16527-Adaptation PreCrash functions-PreCrash door locking,not defined ,16
IDE09601-IDE16528-Adaptation PreCrash functions-PreCrash seat adjustment: driver's seat,not defined ,16
IDE09601-IDE16529-Adaptation PreCrash functions-PreCrash seat adjustment: passenger seat,not defined ,16
IDE09601-IDE16530-Adaptation PreCrash functions-PreCrash seat adjustment: 2nd seat row,not defined ,16
IDE09601-MAS00478-Adaptation PreCrash functions-Reserved,2 ,16
IDE09601-MAS03834-Adaptation PreCrash functions-Emergency signal flashing,not defined ,16
IDE09601-MAS09950-Adaptation PreCrash functions-LED bar activation,not defined ,16
IDE09601-MAS15067-Adaptation PreCrash functions-Belt parking 1st row,not defined ,16
IDE09601-MAS15068-Adaptation PreCrash functions-Belt parking 2nd row,not defined ,16
IDE09601-MAS15069-Adaptation PreCrash functions-Measurement recording,not defined ,16
IDE09601-MAS15070-Adaptation PreCrash functions-BAP resistance PreSense system,not defined ,16
IDE09601-MAS15071-Adaptation PreCrash functions-BAP resistance PreSense warning,not defined ,16
IDE09601-MAS15072-Adaptation PreCrash functions-BAP resistance: distance warning,not defined ,16
IDE09601-MAS15073-Adaptation PreCrash functions-BAP resistance: turning assistance,not defined ,16
IDE09601-MAS15074-Adaptation PreCrash functions-BAP resistance proactive passenger cover,not defined ,16
IDE09601-MAS15107-Adaptation PreCrash functions-Drivetrain actuation,not defined ,16
IDE12055-IDE12056-Adaptation airbag 2-Igniter for interaction airbag 2nd row: driver side,not defined ,8
IDE12055-IDE12057-Adaptation airbag 2-Igniter for interaction airbag 2nd row: driver side,not defined ,8
IDE12055-IDE12258-Adaptation airbag 2-Assistance system monitor,activated ,8
IDE12055-IDE14239-Adaptation airbag 2-Igniter for high-voltage battery 2 open circuit,not defined ,8
IDE12055-IDE14240-Adaptation airbag 2-Driver side seat occupancy detection,activated ,8
IDE12055-IDE14841-Adaptation airbag 2-Seat Belt Tensioner Igniter: center 3rd row,not defined ,8
IDE12055-IDE15776-Adaptation airbag 2-Deactivation igniter: DC/DC converter,not defined ,8
IDE12055-IDE16063-Adaptation airbag 2-Igniter for high-voltage battery 3 open circuit,not defined ,8
IDE12055-IDE17275-Adaptation airbag 2-Igniter for deactivation of A/C system 3,not defined ,8
IDE12055-MAS00478-Adaptation airbag 2-Reserved,2 ,8
IDE12055-MAS29851-Adaptation airbag 2-Igniter for seat ramp airbag 2nd row: passenger's side,not defined ,8
IDE12055-MAS29852-Adaptation airbag 2-Igniter for seat ramp airbag 2nd row: driver's side,not defined ,8
IDE15773-MAS05774-Wireless belt request/seat occupancy detection-2nd Row Left,FF FF FF FF FF FF ,72
IDE15773-MAS05775-Wireless belt request/seat occupancy detection-2nd Row Right,FF FF FF FF FF FF ,72
IDE15773-MAS14174-Wireless belt request/seat occupancy detection-2nd Row Center,FF FF FF FF FF FF ,72
IDE15773-MAS20986-Wireless belt request/seat occupancy detection-1st Row Center,FF FF FF FF FF FF ,72
IDE15773-MAS20987-Wireless belt request/seat occupancy detection-3rd Row Center,FF FF FF FF FF FF ,72
IDE15773-MAS20988-Wireless belt request/seat occupancy detection-4th Row Center,FF FF FF FF FF FF ,72
IDE15773-MAS25344-Wireless belt request/seat occupancy detection-3rd Row Left,C6 F6 16 4E DC 94 ,72
IDE15773-MAS25345-Wireless belt request/seat occupancy detection-4th Row Left,FF FF FF FF FF FF ,72
IDE15773-MAS25346-Wireless belt request/seat occupancy detection-4th Row Right,FF FF FF FF FF FF ,72
IDE15773-MAS25347-Wireless belt request/seat occupancy detection-3rd Row Right,31 19 17 4E DC 94 ,72
IDE15773-MAS25348-Wireless belt request/seat occupancy detection-1st Row Right,FF FF FF FF FF FF ,72
IDE15773-MAS25349-Wireless belt request/seat occupancy detection-1st Row Left,FF FF FF FF FF FF ,72
IDE15819-Exchange protection,01 ,1
IDE18988-Type-version-variant data for accident data recorder,---------------------------------------------------------------------------------------------------- ,100
MAS00975-IDE00947-Airbag adaptations-Driver side rear curtain airbag igniter,not defined ,8
MAS00975-IDE00948-Airbag adaptations-Frt.passenger side rear curtain airbag igniter,not defined ,8
MAS00975-IDE02852-Airbag adaptations-Battery Interrupt Igniter High-Voltage Battery,activated ,8
MAS00975-IDE07190-Airbag adaptations-Igniter for battery open circuit 2nd battery,not defined ,8
MAS00975-IDE07192-Airbag adaptations-Thorax airbag igniter,not defined ,8
MAS00975-IDE08436-Airbag adaptations-Driver side seat belt tensioner igniter 3,not defined ,8
MAS00975-IDE08437-Airbag adaptations-Front passenger side third row seat belt tensioner igniter,not defined ,8
MAS00975-IDE12208-Airbag adaptations-Igniter for deactivation of A/C system 1,not defined ,8
MAS00975-IDE12209-Airbag adaptations-Igniter for deactivation of A/C system 2,not defined ,8
MAS00975-MAS00003-Airbag adaptations-Front passenger airbag igniter,activated ,8
MAS00975-MAS00011-Airbag adaptations-Driver knee airbag igniter,not defined ,8
MAS00975-MAS00020-Airbag adaptations-Passenger side rear seat belt tensioner igniter,activated ,8
MAS00975-MAS00021-Airbag adaptations-Center rear seat belt tensioner igniter,not defined ,8
MAS00975-MAS00022-Airbag adaptations-Battery Interrupt Igniter,not defined ,8
MAS00975-MAS00023-Airbag adaptations-Driver side active head restraint igniter,not defined ,8
MAS00975-MAS00024-Airbag adaptations-Igniter for active head restraint on frt. passenger side,not defined ,8
MAS00975-MAS00079-Airbag adaptations-Key switch,Airbag deactivation key switch not parameterized ,8
MAS00975-MAS00231-Airbag adaptations-Seat occupied recognition passenger side,activated ,8
Elapsed Time: 00:14
adpmap-16-1EE-953-507-CH_WVG5WVEB2SH017765-20250325-1227.CSV
;SW:1EE-953-507-CH   HW:1EE-953-507-CH ---  Steering wheel
;Component:GSMMEB        005 0067, Coding:
;EV_SMLSKLOGEN2,009005,EV_SMLSKLOGEN2_009_VW41.rod
;Tuesday,25,March,2025,12:27:13:58926
;VCID: 0358E11A1B9B7AF2924-8056-R SFD
IDE02694-Signal horn activation,Always ,1
IDE07159-ENG273891-Control module switch-off: counter-Bus KnockOut_Ctr,01 ,2
IDE07159-ENG273843-Control module switch-off: counter-ECU KnockOut_Ctr,00 ,2
IDE07160-ENG273602-Control module switch-off: switch-off time-Bus KnockOut_Tmr,15 min,3
IDE07160-ENG302713-Control module switch-off: switch-off time-Bus KnockOut_Tmr NVEM,not active ,3
IDE07160-ENG273618-Control module switch-off: switch-off time-ECU KnockOut_Tmr,30 min,3
IDE17782-ENG302794-Fault voltages and fault times-P_t_overvoltage_debounce_time,90000 ms,4
IDE17782-ENG302820-Fault voltages and fault times-P_t_undervoltage_debounce_time,90000 ms,4
IDE17782-ENG302827-Fault voltages and fault times-P_v_overvoltage_limit_value,16.5 V,4
IDE17782-ENG302828-Fault voltages and fault times-P_v_undervoltage_limit_value,8.5 V,4
IDE17784-ENG302756-Gear change actuator: debounce times-P_t_gearshifter_clockwise_1_debounce_time,40 ms,7
IDE17784-ENG302757-Gear change actuator: debounce times-P_t_gearshifter_clockwise_2_debounce_time,40 ms,7
IDE17784-ENG302758-Gear change actuator: debounce times-P_t_gearshifter_counter_clockwise_1_debounce_time,40 ms,7
IDE17784-ENG302759-Gear change actuator: debounce times-P_t_gearshifter_counter_clockwise_2_debounce_time,40 ms,7
IDE17784-ENG302760-Gear change actuator: debounce times-P_t_gearshifter_error_debounce_time,40 ms,7
IDE17784-ENG302761-Gear change actuator: debounce times-P_t_gearshifter_init_debounce_time,40 ms,7
IDE17784-ENG302762-Gear change actuator: debounce times-P_t_gearshifter_steady_debounce_time,40 ms,7
IDE17785-Selector mechanism: selector lever storage time parameters,1000 ms,1
IDE17788-ENG302785-Selector mechanism: holding phase time parameters-P_t_illumination_after_n_holding_phase,500 ms,2
IDE17788-ENG302793-Selector mechanism: holding phase time parameters-P_t_n_hold_duration,30 min,2
IDE17789-ENG302749-Selector mechanism: parking button time parameters-P_n_p_button_one_open,50 units,6
IDE17789-ENG302795-Selector mechanism: parking button time parameters-P_t_p_button_debounce,40 ms,6
IDE17789-ENG302797-Selector mechanism: parking button time parameters-P_t_p_button_event_short,20 ms,6
IDE17789-ENG302798-Selector mechanism: parking button time parameters-P_t_p_button_open_circuit,1000 ms,6
IDE17789-ENG302799-Selector mechanism: parking button time parameters-P_t_p_button_short_circuit,200 ms,6
IDE17789-ENG302801-Selector mechanism: parking button time parameters-P_t_p_button_stuck,60 s,6
IDE17790-Gear change actuator: switch request limit,100 ms,1
IDE17791-ENG302719-Selector mechanism: output of driver request time parameters-Cp_display_drivelevel,not installed ,4
IDE17791-ENG302720-Selector mechanism: output of driver request time parameters-Cp_wh_variant,variant_7 ,4
IDE17791-ENG302791-Selector mechanism: output of driver request time parameters-P_t_min_display,100 ms,4
IDE17791-ENG302792-Selector mechanism: output of driver request time parameters-P_t_min_display_p,1000 ms,4
IDE17793-ENG302763-Gear change actuator: fault times-P_t_gearshifter_stuck_debounce_time,300 s,2
IDE17793-ENG302764-Gear change actuator: fault times-P_t_gearshifter_unstuck_debounce_time,5000 ms,2
IDE17794-Selector mechanism: CAN protocol counter,03 ,1
IDE17795-Windshield wiper: interval 1,Intervall_2 ,1
IDE17796-Selector mechanism: CAN protocol time parameters,5000 ms,1
IDE17797-Selector mechanism: CAN protocol,Classic CAN ,1
IDE17798-Windshield wiper: interval 2,Intervall_4 ,1
IDE17799-ENG302782-Horn: fault times-P_t_horn_notification_time,2000 ms,3
IDE17799-ENG302783-Horn: fault times-P_t_horn_stuck_debounce_time,60 s,3
IDE17799-ENG302784-Horn: fault times-P_t_horn_unstuck_debounce_time,5000 ms,3
IDE17800-ENG302780-Horn: debounce times-P_t_horn_debounce_activation_value,30 ms,2
IDE17800-ENG302781-Horn: debounce times-P_t_horn_debounce_deactivation_value,50 ms,2
IDE17801-Windshield wiper: winter settings time,60 s,1
IDE17802-Read in horn,SMLS ,1
IDE17803-Turn signal switch: lockout time,100 ms,1
IDE17804-ENG302775-Turn signal switch: debounce times-P_t_highbeam_debounce_time,40 ms,3
IDE17804-ENG302786-Turn signal switch: debounce times-P_t_lighthorn_debounce_time,40 ms,3
IDE17804-ENG302814-Turn signal switch: debounce times-P_t_turnindicator_debounce_time,40 ms,3
IDE17805-ENG302754-Windshield wiper rotary knob: debounce times-P_t_frontwiper_debounce_time,40 ms,2
IDE17805-ENG302804-Windshield wiper rotary knob: debounce times-P_t_rearwiper_debounce_time,200 ms,2
IDE17806-ENG324788-Windshield wiper button: debounce times-Cp_wiper_button_prio,Prio_off ,3
IDE17806-ENG325089-Windshield wiper button: debounce times-P_t_wiper_button_debounce_time_position_1,40 ms,3
IDE17806-ENG325090-Windshield wiper button: debounce times-P_t_wiper_button_debounce_time_position_2,40 ms,3
IDE17807-ENG302776-Turn signal switch: fault times-P_t_highbeam_invalid_dequalification_time,100 ms,13
IDE17807-ENG302777-Turn signal switch: fault times-P_t_highbeam_invalid_qualification_time,100 ms,13
IDE17807-ENG302778-Turn signal switch: fault times-P_t_highbeam_stuck_debounce_time,300 s,13
IDE17807-ENG302779-Turn signal switch: fault times-P_t_highbeam_unstuck_debounce_time,5000 ms,13
IDE17807-ENG302787-Turn signal switch: fault times-P_t_lighthorn_invalid_dequalification_time,100 ms,13
IDE17807-ENG302788-Turn signal switch: fault times-P_t_lighthorn_invalid_qualification_time,100 ms,13
IDE17807-ENG302789-Turn signal switch: fault times-P_t_lighthorn_stuck_debounce_time,300 s,13
IDE17807-ENG302790-Turn signal switch: fault times-P_t_lighthorn_unstuck_debounce_time,5000 ms,13
IDE17807-ENG302815-Turn signal switch: fault times-P_t_turnindicator_invalid_dequalification_time,100 ms,13
IDE17807-ENG302816-Turn signal switch: fault times-P_t_turnindicator_invalid_qualification_time,100 ms,13
IDE17807-ENG302817-Turn signal switch: fault times-P_t_turnindicator_stuck_debounce_time,300 s,13
IDE17807-ENG302818-Turn signal switch: fault times-P_t_turnindicator_unplausible_debounce_time,100 ms,13
IDE17807-ENG302819-Turn signal switch: fault times-P_t_turnindicator_unstuck_debounce_time,5000 ms,13
IDE17808-ENG302823-Windshield wiper rotary knob: fault times-P_t_wiper_thumbwheel_implausible,200 ms,3
IDE17808-ENG302824-Windshield wiper rotary knob: fault times-P_t_wiper_thumbwheel_open_circuit,1000 ms,3
IDE17808-ENG302825-Windshield wiper rotary knob: fault times-P_t_wiper_thumbwheel_short_circuit,200 ms,3
IDE17809-ENG302809-Windshield wiper button: fault times-P_t_tipwipewash_open_circuit,1000 ms,4
IDE17809-ENG302810-Windshield wiper button: fault times-P_t_tipwipewash_short_circuit,200 ms,4
IDE17809-ENG302811-Windshield wiper button: fault times-P_t_tipwipewash_stuck,60 s,4
IDE17809-ENG302812-Windshield wiper button: fault times-P_t_tipwipewash_unstuck,5000 ms,4
IDE17810-Steering wheel heating installed,installed ,1
IDE17811-Steering wheel heating: output,110 W,1
IDE17812-Steering wheel heating: pulse width modulation frequency,25 Hz,1
IDE17813-ENG302807-Steering wheel heating: fault times-P_t_swh_open_load_debounce_time,1000 ms,2
IDE17813-ENG302808-Steering wheel heating: fault times-P_t_swh_short_circuit_debounce_time,200 ms,2
IDE17815-ENG302752-Electronic parking brake: lighting fault times-P_t_epb_search_illumination_open_circuit_debounce_time,1000 ms,2
IDE17815-ENG302753-Electronic parking brake: lighting fault times-P_t_epb_search_illumination_short_circuit_debounce_time,200 ms,2
IDE17816-Attenuation dimming down,1 units,1
IDE17817-ENG302765-CCS lever: debounce times and fault times-P_t_gra_err_gra_stuck,300 s,9
IDE17817-ENG302766-CCS lever: debounce times and fault times-P_t_gra_err_gra_unstuck,5000 ms,9
IDE17817-ENG302768-CCS lever: debounce times and fault times-P_t_gra_err_open_circuit,1000 ms,9
IDE17817-ENG302769-CCS lever: debounce times and fault times-P_t_gra_err_short_circuit,200 ms,9
IDE17817-ENG302770-CCS lever: debounce times and fault times-P_t_gralever_adr_set_debounce,40 ms,9
IDE17817-ENG302771-CCS lever: debounce times and fault times-P_t_gralever_err_gra_stuck,300 s,9
IDE17817-ENG302772-CCS lever: debounce times and fault times-P_t_gralever_err_gra_unstuck,5000 ms,9
IDE17817-ENG302773-CCS lever: debounce times and fault times-P_t_gralever_invalid_dequalification_time,100 ms,9
IDE17817-ENG302774-CCS lever: debounce times and fault times-P_t_gralever_invalid_qualification_time,100 ms,9
IDE17818-Attenuation dimming up,2 units,1
IDE17819-ENG101574-Parking symbol function lighting: dimming curve-X1,0 units,21
IDE17819-ENG99557-Parking symbol function lighting: dimming curve-X2,10 units,21
IDE17819-ENG102140-Parking symbol function lighting: dimming curve-X3,50 units,21
IDE17819-ENG102936-Parking symbol function lighting: dimming curve-X4,100 units,21
IDE17819-ENG103548-Parking symbol function lighting: dimming curve-X5,150 units,21
IDE17819-ENG113992-Parking symbol function lighting: dimming curve-X6,220 units,21
IDE17819-ENG115661-Parking symbol function lighting: dimming curve-x7,253 units,21
IDE17819-ENG99777-Parking symbol function lighting: dimming curve-Y1,22 units,21
IDE17819-ENG100480-Parking symbol function lighting: dimming curve-Y2,22 units,21
IDE17819-ENG100773-Parking symbol function lighting: dimming curve-Y3,50 units,21
IDE17819-ENG100631-Parking symbol function lighting: dimming curve-Y4,111 units,21
IDE17819-ENG102174-Parking symbol function lighting: dimming curve-Y5,200 units,21
IDE17819-ENG113993-Parking symbol function lighting: dimming curve-Y6,700 units,21
IDE17819-ENG115665-Parking symbol function lighting: dimming curve-y7,1000 units,21
IDE17820-ENG101574-Function lighting: dimming curve-X1,0 units,21
IDE17820-ENG99557-Function lighting: dimming curve-X2,10 units,21
IDE17820-ENG102140-Function lighting: dimming curve-X3,50 units,21
IDE17820-ENG102936-Function lighting: dimming curve-X4,100 units,21
IDE17820-ENG103548-Function lighting: dimming curve-X5,150 units,21
IDE17820-ENG113992-Function lighting: dimming curve-X6,220 units,21
IDE17820-ENG115661-Function lighting: dimming curve-x7,253 units,21
IDE17820-ENG99777-Function lighting: dimming curve-Y1,10 units,21
IDE17820-ENG100480-Function lighting: dimming curve-Y2,10 units,21
IDE17820-ENG100773-Function lighting: dimming curve-Y3,25 units,21
IDE17820-ENG100631-Function lighting: dimming curve-Y4,50 units,21
IDE17820-ENG102174-Function lighting: dimming curve-Y5,500 units,21
IDE17820-ENG113993-Function lighting: dimming curve-Y6,850 units,21
IDE17820-ENG115665-Function lighting: dimming curve-y7,1000 units,21
IDE17821-ENG101574-Search lighting: dimming curve-X1,0 units,21
IDE17821-ENG99557-Search lighting: dimming curve-X2,6 units,21
IDE17821-ENG102140-Search lighting: dimming curve-X3,20 units,21
IDE17821-ENG102936-Search lighting: dimming curve-X4,50 units,21
IDE17821-ENG103548-Search lighting: dimming curve-X5,70 units,21
IDE17821-ENG113992-Search lighting: dimming curve-X6,85 units,21
IDE17821-ENG115661-Search lighting: dimming curve-x7,100 units,21
IDE17821-ENG99777-Search lighting: dimming curve-Y1,0 units,21
IDE17821-ENG100480-Search lighting: dimming curve-Y2,60 units,21
IDE17821-ENG100773-Search lighting: dimming curve-Y3,200 units,21
IDE17821-ENG100631-Search lighting: dimming curve-Y4,500 units,21
IDE17821-ENG102174-Search lighting: dimming curve-Y5,700 units,21
IDE17821-ENG113993-Search lighting: dimming curve-Y6,850 units,21
IDE17821-ENG115665-Search lighting: dimming curve-y7,1000 units,21
IDE17823-Terminal 58xd: error value,80 %,1
IDE17824-Network run-on timer,12 min,1
IDE20117-P display shut-down delay,4 s,1
IDE20118-ENG395174-Rear window wiper rotary knob: fault times-P_t_rearwiper_ring_open_circuit,1000 ms,4
IDE20118-ENG395175-Rear window wiper rotary knob: fault times-P_t_rearwiper_ring_short_circuit,200 ms,4
IDE20118-ENG395176-Rear window wiper rotary knob: fault times-P_t_rearwiper_ring_stuck,300 s,4
IDE20118-ENG395177-Rear window wiper rotary knob: fault times-P_t_rearwiper_ring_unstuck,5000 ms,4
IDE20119-ENG395170-Rear window wiper button: fault times-P_t_rearwiper_button_open_circuit,1000 ms,4
IDE20119-ENG395171-Rear window wiper button: fault times-P_t_rearwiper_button_short_circuit,200 ms,4
IDE20119-ENG395172-Rear window wiper button: fault times-P_t_rearwiper_button_stuck,60 s,4
IDE20119-ENG395173-Rear window wiper button: fault times-P_t_rearwiper_button_unstuck,1000 ms,4
IDE20120-ENG395168-Rear window wiper button: debounce times-P_t_rear_wiper_button_debounce_time_position_1,40 ms,2
IDE20120-ENG395169-Rear window wiper button: debounce times-P_t_rear_wiper_button_debounce_time_position_2,40 ms,2
IDE20121-Windshield wiper: interval 3,Unknown (0),1
ENG153885-Knockout_test_mode,00 ,1
Elapsed Time: 00:13
adpmap-19-1EE-937-012-A_WVG5WVEB2SH017765-20250325-1215.CSV
;SW:1EE-937-012-A   HW:1EE-937-012 ---  CAN Gateway
;Component:ICAS1 Host-SG 031 0254, Coding:
;EV_GatewICAS1MEBUNECE,001004,EV_GatewICAS1MEBUNECE_VWE3.rod
;Tuesday,25,March,2025,12:15:54:58926
;VCID: 323674DEF4A1037A492-8066 SFD+SFD2
IDE00001-IDE05142-Production mode-Access control,Deactivating ,3
IDE00001-IDE11421-Production mode-Leaving concept,Deactivating ,3
IDE00001-IDE15050-Production mode-Occupant Detection,Deactivating ,3
IDE00001-MAS01490-Production mode-Energy management,Deactivating ,3
IDE00001-MAS07983-Production mode-Virtual pedal,Deactivating ,3
IDE00001-MAS20915-Production mode-Driver warning suppression,Deactivating ,3
IDE00001-MAS20920-Production mode-Shut-off suppression terminal 15 with vehicle abandoned,Deactivating ,3
IDE00001-MAS20958-Production mode-Outside light,Deactivating ,3
IDE00001-MAS20960-Production mode-Power train activation suppression,Deactivating ,3
IDE00001-MAS21169-Production mode-Parking coordinator,Deactivating ,3
IDE00001-MAS26515-Production mode-P mode for high-voltage energy management: electrical equipment approval,Deactivating ,3
IDE00001-ENG258641-Production mode-p_mode_obd,Deactivating ,3
IDE00001-ENG281971-Production mode-p_mode_suppression_vehicleactivation_via_brakepedal,Deactivating ,3
IDE00820-ENG369190-Activating and deactivating all development messages-ADA,not active ,8
IDE00820-ENG369191-Activating and deactivating all development messages-AlcoLock,not active ,8
IDE00820-ENG259915-Activating and deactivating all development messages-BAP-Debug_Cmd_CAN-Messages,not active ,8
IDE00820-ENG260674-Activating and deactivating all development messages-ComServ_QM,not active ,8
IDE00820-ENG253417-Activating and deactivating all development messages-Dimming,not active ,8
IDE00820-ENG258733-Activating and deactivating all development messages-DWA_Sensor,not active ,8
IDE00820-ENG258665-Activating and deactivating all development messages-DWA_Sirene,not active ,8
IDE00820-ENG166045-Activating and deactivating all development messages-EASYCLOSE,not active ,8
IDE00820-ENG260343-Activating and deactivating all development messages-EasyOpen,not active ,8
IDE00820-ENG130820-Activating and deactivating all development messages-Ehr,not active ,8
IDE00820-ENG260863-Activating and deactivating all development messages-EMHLR,not active ,8
IDE00820-ENG369544-Activating and deactivating all development messages-EMHLR_SAFE,not active ,8
IDE00820-ENG260715-Activating and deactivating all development messages-EML,not active ,8
IDE00820-ENG260055-Activating and deactivating all development messages-FoD-Master,not active ,8
IDE00820-ENG257325-Activating and deactivating all development messages-fpa,not active ,8
IDE00820-ENG98593-Activating and deactivating all development messages-Gateway,not active ,8
IDE00820-ENG253446-Activating and deactivating all development messages-HID,not active ,8
IDE00820-ENG259440-Activating and deactivating all development messages-HVEM,not active ,8
IDE00820-ENG258749-Activating and deactivating all development messages-HVLM_CMS,not active ,8
IDE00820-ENG260609-Activating and deactivating all development messages-HVLM_CTM,not active ,8
IDE00820-ENG261044-Activating and deactivating all development messages-HVLM_DCP,not active ,8
IDE00820-ENG258652-Activating and deactivating all development messages-HVLM_ECM,not active ,8
IDE00820-ENG260096-Activating and deactivating all development messages-HVLM_HLC,not active ,8
IDE00820-ENG259226-Activating and deactivating all development messages-HVLM_HVLSF,not active ,8
IDE00820-ENG369584-Activating and deactivating all development messages-IAA_Recognition Manager,not active ,8
IDE00820-ENG141948-Activating and deactivating all development messages-Kessy,not active ,8
IDE00820-ENG259441-Activating and deactivating all development messages-KLS,not active ,8
IDE00820-ENG246512-Activating and deactivating all development messages-KS-master,not active ,8
IDE00820-ENG369607-Activating and deactivating all development messages-MDK_CCC,not active ,8
IDE00820-ENG369609-Activating and deactivating all development messages-MDK_ZuKo,not active ,8
IDE00820-ENG107608-Activating and deactivating all development messages-MFL,not active ,8
IDE00820-ENG257428-Activating and deactivating all development messages-mke,not active ,8
IDE00820-ENG257481-Activating and deactivating all development messages-paco,not active ,8
IDE00820-ENG369639-Activating and deactivating all development messages-PrDet2,not active ,8
IDE00820-ENG369642-Activating and deactivating all development messages-PSO_AM,not active ,8
IDE00820-ENG278469-Activating and deactivating all development messages-RLU_Master,not active ,8
IDE00820-ENG158175-Activating and deactivating all development messages-RTM,not active ,8
IDE00820-ENG257559-Activating and deactivating all development messages-rwb,not active ,8
IDE00820-ENG261038-Activating and deactivating all development messages-SAL,not active ,8
IDE00820-ENG261094-Activating and deactivating all development messages-SOK-FM,not active ,8
IDE00820-ENG259368-Activating and deactivating all development messages-SPN,not active ,8
IDE00820-ENG369675-Activating and deactivating all development messages-SWaP-SF,not active ,8
IDE00820-ENG258858-Activating and deactivating all development messages-TM_Base,not active ,8
IDE00820-ENG259876-Activating and deactivating all development messages-USS,not active ,8
IDE00820-ENG253467-Activating and deactivating all development messages-VKMS,not active ,8
IDE00820-ENG261313-Activating and deactivating all development messages-VLK,not active ,8
IDE00820-ENG246809-Activating and deactivating all development messages-WFS-Master,not active ,8
IDE00820-ENG257657-Activating and deactivating all development messages-wum,not active ,8
IDE00820-ENG260086-Activating and deactivating all development messages-ZVBasis,not active ,8
IDE00820-ENG258143-Activating and deactivating all development messages-ZV-Lib,not active ,8
IDE01996-ENG151565-Installation list: specified installations-ECU coded Bit 0,Yes ,32
IDE01996-ENG176508-Installation list: specified installations-ECU coded Bit 1,No ,32
IDE01996-ENG176493-Installation list: specified installations-ECU coded Bit 2,Yes ,32
IDE01996-ENG176430-Installation list: specified installations-ECU coded Bit 3,Yes ,32
IDE01996-ENG176439-Installation list: specified installations-ECU coded Bit 4,No ,32
IDE01996-ENG176505-Installation list: specified installations-ECU coded Bit 5,Yes ,32
IDE01996-ENG176473-Installation list: specified installations-ECU coded Bit 6,No ,32
IDE01996-ENG176498-Installation list: specified installations-ECU coded Bit 7,No ,32
IDE02455-MAS28776-Light function "Coming/Leaving Home"-Coming Home light: installation status,Enabled ,2
IDE02455-MAS28799-Light function "Coming/Leaving Home"-Leaving Home light: default value for activation via BAP,active ,2
IDE02455-MAS28801-Light function "Coming/Leaving Home"-Leaving Home light: installation status,automatic ,2
IDE02455-MAS28805-Light function "Coming/Leaving Home"-Display of Leaving Home light history,not active ,2
IDE02455-MAS28890-Light function "Coming/Leaving Home"-Leaving Home and Coming Home light menu settings,Changing the Leaving Home and Coming Home light time via BAP ,2
IDE02455-MAS28898-Light function "Coming/Leaving Home"-Display of Coming Home light history,not active ,2
IDE02455-MAS28918-Light function "Coming/Leaving Home"-Coming Home light: default value for activation via BAP,active ,2
IDE03256-MAS06105-Battery adaptation-Rated battery capacity,58 Ah,15
IDE03256-MAS06106-Battery adaptation-Battery technology,Fleece ,15
IDE03256-MAS06107-Battery adaptation-Battery manufacturer,JCB ,15
IDE03256-MAS06108-Battery adaptation-Battery Serial Number,241112C05W ,15
IDE03471-ENG369552-Vehicle configuration-Fahrzeugplattform,MEB ,16
IDE03471-ENG369585-Vehicle configuration-Innenraumsuche_SmartDevices_Freigeben_bei_Remotestart,not activated ,16
IDE03471-ENG369594-Vehicle configuration-Ladetankklappe_bereich,Entry_bereich_gesamt ,16
IDE03471-ENG369608-Vehicle configuration-MDK_System_aktiv,not activated ,16
IDE03471-ENG369637-Vehicle configuration-PassiveEntry_FK_aktiv,not activated ,16
IDE03471-ENG369638-Vehicle configuration-PassiveGo_Startberechtigter_Innenraum,ohne Kofferraum ,16
IDE03471-ENG259357-Vehicle configuration-PassiveKomfortTogglen_aktiv,not activated ,16
IDE03471-ENG369646-Vehicle configuration-Reichweitenueberpruefung_fuer_RPA_aktiv,not activated ,16
IDE03471-ENG369649-Vehicle configuration-Rke_fenster_sad_komfortlauf,not activated ,16
IDE03471-ENG369650-Vehicle configuration-Rke_frontdeckel_entriegeln,not activated ,16
IDE03471-ENG369651-Vehicle configuration-Rke_fzg_entriegeln_aktiv,not activated ,16
IDE03471-ENG369652-Vehicle configuration-Rke_heckdeckel_entriegeln,not activated ,16
IDE03471-ENG369653-Vehicle configuration-Rke_heckdeckel_komfortlauf,not activated ,16
IDE03471-ENG369654-Vehicle configuration-Rke_panic_alarm,not activated ,16
IDE03471-ENG369655-Vehicle configuration-Rke_verdeck_komfortlauf,not activated ,16
IDE03471-ENG369657-Vehicle configuration-RSAD_Kanal_A_aktiv,not activated ,16
IDE03471-ENG369658-Vehicle configuration-RSAD_Kanal_B_aktiv,not activated ,16
IDE03471-ENG369686-Vehicle configuration-UWB_BT_HR_verbaut,not activated ,16
IDE03471-ENG369687-Vehicle configuration-UWB_BT_IN_H_KR_verbaut,not activated ,16
IDE03471-ENG369688-Vehicle configuration-UWB_BT_IN_H_verbaut,not activated ,16
IDE03471-ENG369689-Vehicle configuration-UWB_BT_VL verbaut,not activated ,16
IDE03471-ENG369690-Vehicle configuration-UWB_HL_verbaut,not activated ,16
IDE03471-ENG369691-Vehicle configuration-UWB_IN_V_KR_verbaut,not activated ,16
IDE03471-ENG369692-Vehicle configuration-UWB_IN_V_verbaut,not activated ,16
IDE03471-ENG369693-Vehicle configuration-UWB_Kanal_5_aktiv,not activated ,16
IDE03471-ENG369694-Vehicle configuration-UWB_Kanal_6_aktiv,not activated ,16
IDE03471-ENG369695-Vehicle configuration-UWB_Kanal_8_aktiv,not activated ,16
IDE03471-ENG369696-Vehicle configuration-UWB_Kanal_9_aktiv,not activated ,16
IDE03471-ENG369697-Vehicle configuration-UWB_VR_verbaut,not activated ,16
IDE03471-ENG369746-Vehicle configuration-WAL_beim_Timeout_aktiv,not activated ,16
IDE03471-ENG369747-Vehicle configuration-WAL_beim_Verschwinden_aktiv,not activated ,16
IDE03471-ENG369748-Vehicle configuration-WAL_mit _Schluessel_im_Innenraum_aktiv,not activated ,16
IDE03903-Production process data 1,00 55 ,2
IDE05145-IDE03311-Light configuration-Emergency braking display,not active ,4
IDE05145-IDE07470-Light configuration-After-run for park light,Shut-off due to energy management or after-run time ,4
IDE05145-IDE11943-Light configuration-Signature lamp,not installed ,4
IDE05145-IDE13732-Light configuration-Animation signature light,not active ,4
IDE05145-MAS00798-Light configuration-Transmission Control Module (TCM),installed ,4
IDE05145-MAS07013-Light configuration-All-weather light,installed ,4
IDE05145-MAS09704-Light configuration-Steering alignment,Left ,4
IDE05145-SFT272138-Light configuration-Sunlight photo sensor,not installed ,4
IDE05145-ENG278534-Light configuration-Animationsfreigabe_Audi,not installed ,4
IDE06274-MAS05958-Light functions for special-purpose vehicle-intermittent low beam,Low beam ,4
IDE06274-MAS05960-Light functions for special-purpose vehicle-intermittent high beam,High Beam ,4
IDE06425-Dynamometer mode: functional-,not activated ,1
IDE06425-ENG98891-Dynamometer mode: functional-Reserved,0 ,1
IDE06530-Distance left for deactivation of static current measuring mode,4 km,1
IDE06541-Distance left for deactivation of transport mode,52 km,1
IDE07161-temporary VIN,Conditions not correct or request sequence error,1
IDE08220-Vehicle production mode,not active ,1
IDE09767-MAS28778-Position lamps-Two-sided parking light availability,24 s,7
IDE09767-MAS28828-Position lamps-Two-sided parking light reduction,not active ,7
IDE09767-MAS28897-Position lamps-Parking light activated via steering-column switch,not active ,7
IDE09767-MAS28901-Position lamps-Distinction between light warning for campers and passenger cars,Terminal-dependent ,7
IDE09767-MAS28902-Position lamps-Condition for two-sided parking light limitation/deactivation,Switch-off due to energy management ,7
IDE09767-MAS28903-Position lamps-Conditions for parking light limitation,not active ,7
IDE09767-MAS28904-Position lamps-Factor for availability timer,Availability up to 24 hours of operation  five minutes ,7
IDE09767-MAS28931-Position lamps-Two-sided parking light OFF with dipped beam switch: S contact OFF,active ,7
IDE09797-IDE10294-Adaptation of range calculation-Initialization of LPG range consumption,0.0 l/100km,48
IDE09797-MAS09198-Adaptation of range calculation-Init. value of average speed electrical trip,0 km/h,48
IDE09797-MAS09199-Adaptation of range calculation-Init. value absolute forecast deviation air-condition. interior,0 W,48
IDE09797-MAS09200-Adaptation of range calculation-Init. value average performance A/C components,0 W,48
IDE09797-MAS09201-Adaptation of range calculation-Init. value average perf. low voltage basic consumer,0 W,48
IDE09797-MAS09202-Adaptation of range calculation-Init. value RWDS load profile,0 A,48
IDE09797-MAS09203-Adaptation of range calculation-Init. value of elec. average consumption on street class 0,0.0 kWh/100 km,48
IDE09797-MAS09204-Adaptation of range calculation-Init. value of elec. average consumption on street class 1,0.0 kWh/100 km,48
IDE09797-MAS09205-Adaptation of range calculation-Init. value of elec. average consumption on street class 2,0.0 kWh/100 km,48
IDE09797-MAS09206-Adaptation of range calculation-Init. value of elec. average consumption on street class 3,0.0 kWh/100 km,48
IDE09797-MAS09207-Adaptation of range calculation-Init. value of elec. average consumption on street class 4,0.0 kWh/100 km,48
IDE09797-MAS09208-Adaptation of range calculation-Init. value of elec. average consumption on street class 5,0.0 kWh/100 km,48
IDE09797-MAS09209-Adaptation of range calculation-Init. value average consumption BMS electric (forecast horizon),0.0 kWh/100 km,48
IDE09797-MAS09210-Adaptation of range calculation-Init. value cons. eng. range cons.,0.0 l/100km,48
IDE09797-MAS09211-Adaptation of range calculation-Init. value average range consumption: electric traction,0.0 kWh/100 km,48
IDE09797-MAS09212-Adaptation of range calculation-Init. value of elec. average consumption on street class 6,0.0 kWh/100 km,48
IDE09797-MAS10126-Adaptation of range calculation-Initialization of CNG range consumption,0.0 kg/100 km,48
IDE09797-MAS10294-Adaptation of range calculation-Initial value of average fuel consumption on street class 0,0.0 l/100km,48
IDE09797-MAS10295-Adaptation of range calculation-Initial value of average fuel consumption on street class 1,0.0 l/100km,48
IDE09797-MAS10296-Adaptation of range calculation-Initial value of average fuel consumption on street class 2,0.0 l/100km,48
IDE09797-MAS10297-Adaptation of range calculation-Initial value of average fuel consumption on street class 3,0.0 l/100km,48
IDE09797-MAS10298-Adaptation of range calculation-Initial value of average fuel consumption on street class 4,0.0 l/100km,48
IDE09797-MAS10299-Adaptation of range calculation-Initial value of average fuel consumption on street class 5,0.0 l/100km,48
IDE09797-MAS10300-Adaptation of range calculation-Initial value of average fuel consumption on street class 6,0.0 l/100km,48
IDE10283-Key identification: transponder ID,Conditions not correct or request sequence error,48
IDE10351-MAS03173-Message mirroring-Powertrain data bus,not active ,21
IDE10351-MAS03174-Message mirroring-Comfort data bus,not active ,21
IDE10351-MAS03176-Message mirroring-Display and control head databus,not active ,21
IDE10351-MAS03178-Message mirroring-Suspension data bus,not active ,21
IDE10351-MAS03179-Message mirroring-Local data bus 2,not active ,21
IDE10351-MAS03180-Message mirroring-Local data bus,not active ,21
IDE10351-MAS05686-Message mirroring-Data bus diagnostics,not active ,21
IDE10351-MAS05767-Message mirroring-port,00 00 ,21
IDE10351-MAS05972-Message mirroring-Local data bus 3,not active ,21
IDE10351-MAS06525-Message mirroring-Local data bus 4,not active ,21
IDE10351-MAS09111-Message mirroring-IP address,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,21
IDE10351-MAS10460-Message mirroring-Target bus,not active ,21
IDE10351-MAS12186-Message mirroring-AFS/From light data bus,not active ,21
IDE10351-MAS16909-Message mirroring-Data bus driver assistance systems,not active ,21
IDE10351-MAS17153-Message mirroring-Data bus connect,not active ,21
IDE10351-MAS20475-Message mirroring-Data bus multifunction steering wheel,not active ,21
IDE10351-MAS20476-Message mirroring-Data bus electrification,not active ,21
IDE10844-Control module rear lid opening: duration status query,4960 ms,2
IDE10845-ENG258964-Control module rear lid opening: vehicle type-p_a_p_mode_aktivieren_vip,00 ,12
IDE10845-ENG259328-Control module rear lid opening: vehicle type-p_t_delay_VIP_Freigabe_ZV_Ansteuerung,1 s,12
IDE10845-ENG260538-Control module rear lid opening: vehicle type-p_t_VIP_Bremslicht_hell,0 ms,12
IDE10845-ENG259913-Control module rear lid opening: vehicle type-p_t_VIP_Bremslicht_hell_offen,0 ms,12
IDE10845-ENG260941-Control module rear lid opening: vehicle type-p_t_VIP_Sperrzeit_Schlüsselsuche,0 s,12
IDE10845-ENG259196-Control module rear lid opening: vehicle type-p_t_VIP_Verzoegerung,500 ms,12
IDE10845-ENG259996-Control module rear lid opening: vehicle type-p_v_VIP_aktiv,0 km/h,12
IDE10845-ENG261214-Control module rear lid opening: vehicle type-p_v_VIP_deaktiv,2 km/h,12
IDE10845-ENG121904-Control module rear lid opening: vehicle type-Rear_Lid_Opening_Sender_vehicle_type,00 ,12
IDE12986-IDE18243-BAP configuration-Switch-on and off effect 1,15 ,8
IDE12986-IDE18244-BAP configuration-Switch-on and off effect 2,0 ,8
IDE12986-ENG278492-BAP configuration-Bap_fc_list_exterior_light,FF FF FF F7 FF FF ,8
IDE13391-IDE17779-BAP function status-Exit/entry lighting: brightness detection,New ,16
IDE13391-IDE17826-BAP function status-Switchable light signature: front added,not installed ,16
IDE13391-IDE17827-BAP function status-Light signature: front,not installed ,16
IDE13391-IDE17828-BAP function status-Light signature: rear,not installed ,16
IDE13391-IDE17848-BAP function status-Switchable light signature: rear added,not installed ,16
IDE13391-IDE18239-BAP function status-Daytime running light timer: delay,0 ms,16
IDE13391-IDE18240-BAP function status-Low beam headlight timer: delay,0 ms,16
IDE13391-IDE18241-BAP function status-Default value for operating and display log for taillight animation,0 ,16
IDE13391-IDE18242-BAP function status-Default value for operating and display log for turn signal animation,1 ,16
IDE13391-MAS28779-BAP function status-Leaving Home lights,Low beam ,16
IDE13391-MAS28797-BAP function status-Leaving Home light: default value for time setting via BAP,10 seconds ,16
IDE13391-MAS28798-BAP function status-Leaving Home light: default value for time setting during the day,10 seconds ,16
IDE13391-MAS28800-BAP function status-Leaving Home light: switch-on event,Ignition On ,16
IDE13391-MAS28803-BAP function status-Leaving Home and Coming Home light: run-on,0 ms,16
IDE13391-MAS28804-BAP function status-Daytime running light with Leaving Home light during the day in AUTO position,not active ,16
IDE13391-MAS28816-BAP function status-Daytime running light with Coming Home light during the day in AUTO position,not active ,16
IDE13391-MAS28833-BAP function status-Switchable signatures,not installed ,16
IDE13391-MAS28891-BAP function status-Coming Home light: default value for time setting during the day,10 seconds ,16
IDE13391-MAS28892-BAP function status-Coming Home light: default value for time setting via BAP,10 seconds ,16
IDE13391-MAS28915-BAP function status-Switchable signatures: selection of light functions for switching,00 ,16
IDE13391-MAS28916-BAP function status-Switchable signatures: operating mode (ECE: NAR: RoW),0 ,16
IDE13391-MAS28920-BAP function status-Default value for operating and display log headlight signature,0 ,16
IDE13391-ENG419178-BAP function status-Defaultwert_BAP_LightSignatures_RearlightDefault,0 ,16
IDE13391-ENG419219-BAP function status-Fehlerbehandlung_Umschaltbare_Signaturen,not installed ,16
IDE13391-ENG345676-BAP function status-FSG_Setup2_LightSignatures,0 ,16
IDE13391-ENG116608-BAP function status-Helligkeitsschwelle Forward-Messung,600 lx,16
IDE13391-ENG116605-BAP function status-Helligkeitsschwelle Infrarot-Messung,1200 lx,16
IDE13748-IDE17293-Coding low voltage energy management-Autonomous inverter for socket,Not coded ,6
IDE13748-IDE17294-Coding low voltage energy management-Battery architecture,1 ,6
IDE13748-MAS23870-Coding low voltage energy management-Battery installation point,5 ,6
IDE13748-MAS23871-Coding low voltage energy management-Additional memory control,Not coded ,6
IDE13844-Distance left for deactivation of production mode,100 km,1
IDE14154-MAS17900-Route-based range calculation adjustment-Classified consumption,12.0 kWh/100 km,40
IDE14154-MAS17901-Route-based range calculation adjustment-Classified consumption 2,12.0 kWh/100 km,40
IDE14154-MAS17902-Route-based range calculation adjustment-Classified consumption 3,12.0 kWh/100 km,40
IDE14154-MAS17903-Route-based range calculation adjustment-Classified consumption 4,12.0 kWh/100 km,40
IDE14154-MAS17904-Route-based range calculation adjustment-Classified consumption 5,12.0 kWh/100 km,40
IDE14154-MAS17905-Route-based range calculation adjustment-Classified consumption 6,12.0 kWh/100 km,40
IDE14154-MAS17906-Route-based range calculation adjustment-Classified consumption 7,12.0 kWh/100 km,40
IDE14154-MAS17907-Route-based range calculation adjustment-Classified consumption 8,12.0 kWh/100 km,40
IDE14154-MAS17908-Route-based range calculation adjustment-Classified consumption 9,12.0 kWh/100 km,40
IDE14154-MAS17909-Route-based range calculation adjustment-Classified consumption 10,12.0 kWh/100 km,40
IDE14154-MAS17910-Route-based range calculation adjustment-Calculated consumption,12.0 kWh/100 km,40
IDE14154-MAS17911-Route-based range calculation adjustment-Calculated consumption 2,12.0 kWh/100 km,40
IDE14154-MAS17912-Route-based range calculation adjustment-Calculated consumption 3,12.0 kWh/100 km,40
IDE14154-MAS17913-Route-based range calculation adjustment-Calculated consumption 4,12.0 kWh/100 km,40
IDE14154-MAS17914-Route-based range calculation adjustment-Calculated consumption 5,12.0 kWh/100 km,40
IDE14154-MAS17915-Route-based range calculation adjustment-Calculated consumption 6,12.0 kWh/100 km,40
IDE14154-MAS17916-Route-based range calculation adjustment-Calculated consumption 7,12.0 kWh/100 km,40
IDE14154-MAS17917-Route-based range calculation adjustment-Calculated consumption 8,12.0 kWh/100 km,40
IDE14154-MAS17918-Route-based range calculation adjustment-Calculated consumption 9,12.0 kWh/100 km,40
IDE14154-MAS17919-Route-based range calculation adjustment-Calculated consumption 10,12.0 kWh/100 km,40
IDE14952-MAS03173-Wakeup Cluster Databus CAN-Powertrain data bus,00 00 01 ,39
IDE14952-MAS03174-Wakeup Cluster Databus CAN-Comfort data bus,00 00 10 ,39
IDE14952-MAS03176-Wakeup Cluster Databus CAN-Display and control head databus,00 00 A0 ,39
IDE14952-MAS03178-Wakeup Cluster Databus CAN-Suspension data bus,00 00 04 ,39
IDE14952-MAS05686-Wakeup Cluster Databus CAN-Data bus diagnostics,00 00 00 ,39
IDE14952-MAS12183-Wakeup Cluster Databus CAN-Comfort CAN bus 2,00 00 10 ,39
IDE14952-MAS12186-Wakeup Cluster Databus CAN-AFS/From light data bus,00 80 00 ,39
IDE14952-MAS16909-Wakeup Cluster Databus CAN-Data bus driver assistance systems,00 00 08 ,39
IDE14952-MAS17153-Wakeup Cluster Databus CAN-Data bus connect,00 00 40 ,39
IDE14952-MAS20475-Wakeup Cluster Databus CAN-Data bus multifunction steering wheel,00 00 B0 ,39
IDE14952-MAS20476-Wakeup Cluster Databus CAN-Data bus electrification,00 00 02 ,39
IDE14952-MAS22817-Wakeup Cluster Databus CAN-Data bus driver assistance systems 2,00 00 08 ,39
IDE14952-MAS28451-Wakeup Cluster Databus CAN-Virtual remote control vehicle key data bus,00 02 00 ,39
IDE14953-MAS16912-Wakeup Cluster Databus Ethernet-VLAN_FAS,00 04 00 ,27
IDE14953-MAS16913-Wakeup Cluster Databus Ethernet-VLAN_Infotainment,00 20 00 ,27
IDE14953-MAS18934-Wakeup Cluster Databus Ethernet-VLAN Connect,00 10 00 ,27
IDE14953-MAS18936-Wakeup Cluster Databus Ethernet-VLAN_Internet,00 00 00 ,27
IDE14953-MAS20472-Wakeup Cluster Databus Ethernet-VLAN Connect 2,00 10 00 ,27
IDE14953-MAS20957-Wakeup Cluster Databus Ethernet-VLAN_charging,00 40 00 ,27
IDE14953-MAS21728-Wakeup Cluster Databus Ethernet-VLAN_light,00 80 00 ,27
IDE15050-ENG258767-Occupant Detection-central locking system deactivation_ComfortReadyStatus,true ,20
IDE15050-ENG261091-Occupant Detection-ComfortReadyStatus_Klemme_S,false ,20
IDE15050-ENG260007-Occupant Detection-deactivation_ComfortReadyStatus,Driver_Exit ,20
IDE15050-ENG258901-Occupant Detection-DriverSBE_Out,true ,20
IDE15050-ENG260692-Occupant Detection-HV_Fahreranwesenheit_aktiv,true ,20
IDE15050-ENG259960-Occupant Detection-HV_Fahreranwesenheit_deactivation_via_Kl15,false ,20
IDE15050-ENG259613-Occupant Detection-nm_cluster_ComfortReadyStatus,Stage 2 ,20
IDE15050-ENG261255-Occupant Detection-nm_cluster_tuer,Stage 1 ,20
IDE15050-ENG259794-Occupant Detection-nm_timeout_tuer,90 s,20
IDE15050-ENG260195-Occupant Detection-OccupantSBE_Out,true ,20
IDE15050-ENG258604-Occupant Detection-timeout_ComfortReadyStatus,1800 s,20
IDE15050-ENG260437-Occupant Detection-timeout_DriverExitIntent,1 s,20
IDE15051-Electronic horizon reconstructor,installed ,1
IDE15100-ENG364596-Parking coordinator coding-HMI Concept,no_HMI ,8
IDE15100-ENG257916-Parking coordinator coding-PaCo_APS,APS ,8
IDE15100-ENG258621-Parking coordinator coding-PaCo_Automatic_Emergency_Brake-Pedestrian_Rear,not installed ,8
IDE15100-ENG257808-Parking coordinator coding-PaCo_Car_HardKeyFAS,not installed ,8
IDE15100-ENG258084-Parking coordinator coding-PaCo_Car_trailer_assistant,not installed ,8
IDE15100-ENG257790-Parking coordinator coding-PaCo_Collision_assist,RBF ,8
IDE15100-ENG258085-Parking coordinator coding-PaCo_Country,North America ,8
IDE15100-ENG258080-Parking coordinator coding-PaCo_Drive_type,Electric drive ,8
IDE15100-ENG257807-Parking coordinator coding-PaCo_Electrical_Hand_Brake,installed ,8
IDE15100-ENG257799-Parking coordinator coding-PaCo_Intersection_assistant,not installed ,8
IDE15100-ENG257842-Parking coordinator coding-PaCo_Park_assist,intelligent parking assistant ,8
IDE15100-ENG257781-Parking coordinator coding-PaCo_Parking_Hardkey,not installed ,8
IDE15100-ENG257890-Parking coordinator coding-PaCo_PDC_Automatic_Activation,automatic ,8
IDE15100-ENG257858-Parking coordinator coding-PaCo_Personalisation,active ,8
IDE15100-ENG260081-Parking coordinator coding-PaCo_Rear_Cross_Traffic_Alert,installed ,8
IDE15100-ENG257870-Parking coordinator coding-PaCo_Rear_view_mode_bumper_protection,not installed ,8
IDE15100-ENG257792-Parking coordinator coding-PaCo_Rear_view_mode_crossing_traffic,installed ,8
IDE15100-ENG257873-Parking coordinator coding-PaCo_Rear_view_mode_parallel_to_road,not installed ,8
IDE15100-ENG257899-Parking coordinator coding-PaCo_Rear_view_mode_park_box,installed ,8
IDE15100-ENG257915-Parking coordinator coding-PaCo_Rear_view_mode_trailer_hitch,not installed ,8
IDE15100-ENG302831-Parking coordinator coding-PaCo_RemoteFunctions,not installed ,8
IDE15100-ENG258079-Parking coordinator coding-PaCo_Traffic_side,Right hand driv. ,8
IDE15100-ENG258081-Parking coordinator coding-PaCo_Trailer_hitch,without trailer hitch ,8
IDE15100-ENG261093-Parking coordinator coding-PaCo_Trailer_Hitch_Assist,not installed ,8
IDE15100-ENG257851-Parking coordinator coding-PaCo_Trained_Parking,installed ,8
IDE15100-ENG258082-Parking coordinator coding-PaCo_Transmission,automatic ,8
IDE15100-ENG258078-Parking coordinator coding-PaCo_Video_Parksystem,TV_entry ,8
IDE15100-ENG258087-Parking coordinator coding-PaCo_Visual_Indicator,installed ,8
IDE15100-ENG258083-Parking coordinator coding-PaCo_Wheel_rotation_direction_sensor,installed ,8
IDE15331-Multifunction steering wheel extended adaptation,Configuration 4 ,3
IDE15489-MAS10460-Port mirroring-Target bus,not active ,4
IDE15489-MAS16912-Port mirroring-VLAN_FAS,not active ,4
IDE15489-MAS16913-Port mirroring-VLAN_Infotainment,not active ,4
IDE15489-MAS16917-Port mirroring-VLAN_Diagnose,not active ,4
IDE15489-MAS18934-Port mirroring-VLAN Connect,not active ,4
IDE15489-MAS18935-Port mirroring-VLAN_Gateway,not active ,4
IDE15489-MAS20472-Port mirroring-VLAN Connect 2,not active ,4
IDE15489-ENG261029-Port mirroring-Switch_port_chorus_rx,not active ,4
IDE15489-ENG259884-Port mirroring-Switch_port_chorus_tx,not active ,4
IDE15489-ENG261204-Port mirroring-Switch_port_rcar_rx,not active ,4
IDE15489-ENG261107-Port mirroring-Switch_port_rcar_tx,not active ,4
IDE15489-ENG277126-Port mirroring-vlan_diagnose_2,not active ,4
IDE15489-ENG277127-Port mirroring-vlan_eb_rcar_access,not active ,4
IDE15489-ENG277128-Port mirroring-vlan_gateway_udp_exchange,not active ,4
IDE15489-ENG277129-Port mirroring-vlan_ids_marvell,not active ,4
IDE15489-ENG277130-Port mirroring-vlan_switch_control,not active ,4
IDE15489-ENG277131-Port mirroring-vlan_udp_tunnel,not active ,4
IDE15901-Direct entry keys,installed ,2
IDE15902-MAS10541-rotary light switch-Light rotary switch with fog light,Yes ,4
IDE15902-MAS10542-rotary light switch-Light rotary switch with fog tail light,No ,4
IDE15902-MAS10543-rotary light switch-Light rotary sw. with AFL,Yes ,4
IDE15902-MAS10544-rotary light switch-Light rotary switch with park. light pos.,Yes ,4
IDE16364-MAS25708-List of identifiers and data record numbers-Number Of Identifiers,00 00 ,2
IDE16533-Range calculation resetting,No Reset ,1
IDE16611-Diagnosis filter: temporary deactivation,active ,1
IDE19100-ENG413852-Virtual remote control vehicle key: access control parameters-Apu_entry_schwelle,150 cm,48
IDE19100-ENG413853-Virtual remote control vehicle key: access control parameters-Apuactivation_schwelle,200 cm,48
IDE19100-ENG413860-Virtual remote control vehicle key: access control parameters-Bereichsueberwachung_PiloPark_Timeout,120 s,48
IDE19100-ENG413868-Virtual remote control vehicle key: access control parameters-Confirm_packet_loss_limit,2 ,48
IDE19100-ENG413875-Virtual remote control vehicle key: access control parameters-Dauer_autoVerr_ Schluesselsuche,0 s,48
IDE19100-ENG413930-Virtual remote control vehicle key: access control parameters-Ecl_schwelle_mdk,0 cm,48
IDE19100-ENG413931-Virtual remote control vehicle key: access control parameters-Ergebnis_timeout,0 s,48
IDE19100-ENG413934-Virtual remote control vehicle key: access control parameters-Event_Button_press,100 ms,48
IDE19100-ENG413946-Virtual remote control vehicle key: access control parameters-Id_geber_suche_timeout,1000 ms,48
IDE19100-ENG413948-Virtual remote control vehicle key: access control parameters-Interval_rke_confirmation_request,500 ms,48
IDE19100-ENG413950-Virtual remote control vehicle key: access control parameters-komfort_schwelle,600 cm,48
IDE19100-ENG413951-Virtual remote control vehicle key: access control parameters-KY_MDK_Meldung_Timer,150 ms,48
IDE19100-ENG413964-Virtual remote control vehicle key: access control parameters-long_Button_press,0.90 s,48
IDE19100-ENG413966-Virtual remote control vehicle key: access control parameters-Max_dauer_ungueltige_position_sd_nicht_verbunden,10 s,48
IDE19100-ENG413967-Virtual remote control vehicle key: access control parameters-Max_dauer_ungueltige_position_sd_verbunden,50 s,48
IDE19100-ENG395155-Virtual remote control vehicle key: access control parameters-Max_sd_zone_age,3000 ms,48
IDE19100-ENG413968-Virtual remote control vehicle key: access control parameters-MDKCCC_response_timeout,100 ms,48
IDE19100-ENG413969-Virtual remote control vehicle key: access control parameters-MDKSD_response_timeout,1 s,48
IDE19100-ENG413994-Virtual remote control vehicle key: access control parameters-Reichweitenueberpruefung_fuer_RPA_Schwelle,40 cm,48
IDE19100-ENG413995-Virtual remote control vehicle key: access control parameters-Rke_continuation_confirmation_timeout,120 ms,48
IDE19100-ENG413996-Virtual remote control vehicle key: access control parameters-Rke_status_change_timeout,250 ms,48
IDE19100-ENG413998-Virtual remote control vehicle key: access control parameters-Rsad_massnahme_schwelle,600 cm,48
IDE19100-ENG413999-Virtual remote control vehicle key: access control parameters-Sd_verschwinden_zeitfenster,5000 ms,48
IDE19100-ENG414006-Virtual remote control vehicle key: access control parameters-Stk_schwelle_mdk,0 cm,48
IDE19100-ENG414008-Virtual remote control vehicle key: access control parameters-Suchunterdrueckung,3 s,48
IDE19100-ENG414054-Virtual remote control vehicle key: access control parameters-Unterdrueckung_ZV_Anforderung,3 s,48
IDE19100-ENG414055-Virtual remote control vehicle key: access control parameters-Uptime_low_mode,30 s,48
IDE19100-ENG414056-Virtual remote control vehicle key: access control parameters-Uptime_normal_mode,60 s,48
IDE19100-ENG360458-Virtual remote control vehicle key: access control parameters-uwb_pwr_mdk,00000111  ,48
IDE19100-ENG360459-Virtual remote control vehicle key: access control parameters-uwb_pwr_rad,00000111  ,48
IDE19100-ENG414059-Virtual remote control vehicle key: access control parameters-Verschwinden_SmartDevice_Dauer,3 s,48
IDE19100-ENG414098-Virtual remote control vehicle key: access control parameters-Wal_exit_schwelle,350 cm,48
IDE19100-ENG414099-Virtual remote control vehicle key: access control parameters-Walactivation_schwelle,300 cm,48
IDE19100-ENG414100-Virtual remote control vehicle key: access control parameters-Wel_schwelle_mdk,0 cm,48
IDE19100-ENG414105-Virtual remote control vehicle key: access control parameters-Zeittoleranz,10.00 ms,48
IDE19100-ENG414106-Virtual remote control vehicle key: access control parameters-ZyklischeOrtung_Schwelle_FahrendesFzg,20 km/h,48
IDE19100-ENG414107-Virtual remote control vehicle key: access control parameters-ZyklischeOrtung_SchwelleStehendesFzg,10 km/h,48
IDE19169-Adaptation for Over-the-Air Update guard function,not active ,2
IDE19867-ENG369288-Specification for routing diagnostic and bus address for CAN control modules-ECU1_Busaddr_CAN,23 ,192
IDE19867-ENG369290-Specification for routing diagnostic and bus address for CAN control modules-ECU1_Diagnosisaddr_CAN,81 1E ,192
IDE19867-ENG369292-Specification for routing diagnostic and bus address for CAN control modules-ECU10_Busaddr_CAN,00 ,192
IDE19867-ENG369294-Specification for routing diagnostic and bus address for CAN control modules-ECU10_Diagnosisaddr_CAN,00 00 ,192
IDE19867-ENG369296-Specification for routing diagnostic and bus address for CAN control modules-ECU11_Busaddr_CAN,00 ,192
IDE19867-ENG369298-Specification for routing diagnostic and bus address for CAN control modules-ECU11_Diagnosisaddr_CAN,00 00 ,192
IDE19867-ENG369300-Specification for routing diagnostic and bus address for CAN control modules-ECU12_Busaddr_CAN,00 ,192
IDE19867-ENG369302-Specification for routing diagnostic and bus address for CAN control modules-ECU12_Diagnosisaddr_CAN,00 00 ,192
IDE19867-ENG369304-Specification for routing diagnostic and bus address for CAN control modules-ECU13_Busaddr_CAN,00 ,192
IDE19867-ENG369306-Specification for routing diagnostic and bus address for CAN control modules-ECU13_Diagnosisaddr_CAN,00 00 ,192
IDE19867-ENG369308-Specification for routing diagnostic and bus address for CAN control modules-ECU14_Busaddr_CAN,00 ,192
IDE19867-ENG369310-Specification for routing diagnostic and bus address for CAN control modules-ECU14_Diagnosisaddr_CAN,00 00 ,192
IDE19867-ENG369312-Specification for routing diagnostic and bus address for CAN control modules-ECU15_Busaddr_CAN,00 ,192
IDE19867-ENG369314-Specification for routing diagnostic and bus address for CAN control modules-ECU15_Diagnosisaddr_CAN,00 00 ,192
IDE19867-ENG369316-Specification for routing diagnostic and bus address for CAN control modules-ECU16_Busaddr_CAN,00 ,192
IDE19867-ENG369318-Specification for routing diagnostic and bus address for CAN control modules-ECU16_Diagnosisaddr_CAN,00 00 ,192
IDE19867-ENG369320-Specification for routing diagnostic and bus address for CAN control modules-ECU17_Busaddr_CAN,00 ,192
IDE19867-ENG369322-Specification for routing diagnostic and bus address for CAN control modules-ECU17_Diagnosisaddr_CAN,00 00 ,192
IDE19867-ENG369324-Specification for routing diagnostic and bus address for CAN control modules-ECU18_Busaddr_CAN,00 ,192
IDE19867-ENG369326-Specification for routing diagnostic and bus address for CAN control modules-ECU18_Diagnosisaddr_CAN,00 00 ,192
IDE19867-ENG369328-Specification for routing diagnostic and bus address for CAN control modules-ECU19_Busaddr_CAN,00 ,192
IDE19867-ENG369330-Specification for routing diagnostic and bus address for CAN control modules-ECU19_Diagnosisaddr_CAN,00 00 ,192
IDE19867-ENG369332-Specification for routing diagnostic and bus address for CAN control modules-ECU2_Busaddr_CAN,23 ,192
IDE19867-ENG369334-Specification for routing diagnostic and bus address for CAN control modules-ECU2_Diagnosisaddr_CAN,81 1F ,192
IDE19867-ENG369336-Specification for routing diagnostic and bus address for CAN control modules-ECU20_Busaddr_CAN,00 ,192
IDE19867-ENG369338-Specification for routing diagnostic and bus address for CAN control modules-ECU20_Diagnosisaddr_CAN,00 00 ,192
IDE19867-ENG369340-Specification for routing diagnostic and bus address for CAN control modules-ECU21_Busaddr_CAN,00 ,192
IDE19867-ENG369342-Specification for routing diagnostic and bus address for CAN control modules-ECU21_Diagnosisaddr_CAN,00 00 ,192
IDE19867-ENG369344-Specification for routing diagnostic and bus address for CAN control modules-ECU22_Busaddr_CAN,00 ,192
IDE19867-ENG369346-Specification for routing diagnostic and bus address for CAN control modules-ECU22_Diagnosisaddr_CAN,00 00 ,192
IDE19867-ENG369348-Specification for routing diagnostic and bus address for CAN control modules-ECU23_Busaddr_CAN,00 ,192
IDE19867-ENG369350-Specification for routing diagnostic and bus address for CAN control modules-ECU23_Diagnosisaddr_CAN,00 00 ,192
IDE19867-ENG369352-Specification for routing diagnostic and bus address for CAN control modules-ECU24_Busaddr_CAN,00 ,192
IDE19867-ENG369354-Specification for routing diagnostic and bus address for CAN control modules-ECU24_Diagnosisaddr_CAN,00 00 ,192
IDE19867-ENG369356-Specification for routing diagnostic and bus address for CAN control modules-ECU25_Busaddr_CAN,00 ,192
IDE19867-ENG369358-Specification for routing diagnostic and bus address for CAN control modules-ECU25_Diagnosisaddr_CAN,00 00 ,192
IDE19867-ENG369360-Specification for routing diagnostic and bus address for CAN control modules-ECU26_Busaddr_CAN,00 ,192
IDE19867-ENG369362-Specification for routing diagnostic and bus address for CAN control modules-ECU26_Diagnosisaddr_CAN,00 00 ,192
IDE19867-ENG369364-Specification for routing diagnostic and bus address for CAN control modules-ECU27_Busaddr_CAN,00 ,192
IDE19867-ENG369366-Specification for routing diagnostic and bus address for CAN control modules-ECU27_Diagnosisaddr_CAN,00 00 ,192
IDE19867-ENG369368-Specification for routing diagnostic and bus address for CAN control modules-ECU28_Busaddr_CAN,00 ,192
IDE19867-ENG369370-Specification for routing diagnostic and bus address for CAN control modules-ECU28_Diagnosisaddr_CAN,00 00 ,192
IDE19867-ENG369372-Specification for routing diagnostic and bus address for CAN control modules-ECU29_Busaddr_CAN,00 ,192
IDE19867-ENG369374-Specification for routing diagnostic and bus address for CAN control modules-ECU29_Diagnosisaddr_CAN,00 00 ,192
IDE19867-ENG369376-Specification for routing diagnostic and bus address for CAN control modules-ECU3_Busaddr_CAN,23 ,192
IDE19867-ENG369378-Specification for routing diagnostic and bus address for CAN control modules-ECU3_Diagnosisaddr_CAN,81 20 ,192
IDE19867-ENG369380-Specification for routing diagnostic and bus address for CAN control modules-ECU30_Busaddr_CAN,00 ,192
IDE19867-ENG369382-Specification for routing diagnostic and bus address for CAN control modules-ECU30_Diagnosisaddr_CAN,00 00 ,192
IDE19867-ENG369384-Specification for routing diagnostic and bus address for CAN control modules-ECU31_Busaddr_CAN,00 ,192
IDE19867-ENG369386-Specification for routing diagnostic and bus address for CAN control modules-ECU31_Diagnosisaddr_CAN,00 00 ,192
IDE19867-ENG369388-Specification for routing diagnostic and bus address for CAN control modules-ECU32_Busaddr_CAN,00 ,192
IDE19867-ENG369390-Specification for routing diagnostic and bus address for CAN control modules-ECU32_Diagnosisaddr_CAN,00 00 ,192
IDE19867-ENG369392-Specification for routing diagnostic and bus address for CAN control modules-ECU33_Busaddr_CAN,00 ,192
IDE19867-ENG369394-Specification for routing diagnostic and bus address for CAN control modules-ECU33_Diagnosisaddr_CAN,00 00 ,192
IDE19867-ENG369396-Specification for routing diagnostic and bus address for CAN control modules-ECU34_Busaddr_CAN,00 ,192
IDE19867-ENG369398-Specification for routing diagnostic and bus address for CAN control modules-ECU34_Diagnosisaddr_CAN,00 00 ,192
IDE19867-ENG369400-Specification for routing diagnostic and bus address for CAN control modules-ECU35_Busaddr_CAN,00 ,192
IDE19867-ENG369402-Specification for routing diagnostic and bus address for CAN control modules-ECU35_Diagnosisaddr_CAN,00 00 ,192
IDE19867-ENG369404-Specification for routing diagnostic and bus address for CAN control modules-ECU36_Busaddr_CAN,00 ,192
IDE19867-ENG369406-Specification for routing diagnostic and bus address for CAN control modules-ECU36_Diagnosisaddr_CAN,00 00 ,192
IDE19867-ENG369408-Specification for routing diagnostic and bus address for CAN control modules-ECU37_Busaddr_CAN,00 ,192
IDE19867-ENG369410-Specification for routing diagnostic and bus address for CAN control modules-ECU37_Diagnosisaddr_CAN,00 00 ,192
IDE19867-ENG369412-Specification for routing diagnostic and bus address for CAN control modules-ECU38_Busaddr_CAN,00 ,192
IDE19867-ENG369414-Specification for routing diagnostic and bus address for CAN control modules-ECU38_Diagnosisaddr_CAN,00 00 ,192
IDE19867-ENG369416-Specification for routing diagnostic and bus address for CAN control modules-ECU39_Busaddr_CAN,00 ,192
IDE19867-ENG369418-Specification for routing diagnostic and bus address for CAN control modules-ECU39_Diagnosisaddr_CAN,00 00 ,192
IDE19867-ENG369420-Specification for routing diagnostic and bus address for CAN control modules-ECU4_Busaddr_CAN,23 ,192
IDE19867-ENG369422-Specification for routing diagnostic and bus address for CAN control modules-ECU4_Diagnosisaddr_CAN,81 21 ,192
IDE19867-ENG369424-Specification for routing diagnostic and bus address for CAN control modules-ECU40_Busaddr_CAN,00 ,192
IDE19867-ENG369426-Specification for routing diagnostic and bus address for CAN control modules-ECU40_Diagnosisaddr_CAN,00 00 ,192
IDE19867-ENG369428-Specification for routing diagnostic and bus address for CAN control modules-ECU41_Busaddr_CAN,00 ,192
IDE19867-ENG369430-Specification for routing diagnostic and bus address for CAN control modules-ECU41_Diagnosisaddr_CAN,00 00 ,192
IDE19867-ENG369432-Specification for routing diagnostic and bus address for CAN control modules-ECU42_Busaddr_CAN,00 ,192
IDE19867-ENG369434-Specification for routing diagnostic and bus address for CAN control modules-ECU42_Diagnosisaddr_CAN,00 00 ,192
IDE19867-ENG369436-Specification for routing diagnostic and bus address for CAN control modules-ECU43_Busaddr_CAN,00 ,192
IDE19867-ENG369438-Specification for routing diagnostic and bus address for CAN control modules-ECU43_Diagnosisaddr_CAN,00 00 ,192
IDE19867-ENG369440-Specification for routing diagnostic and bus address for CAN control modules-ECU44_Busaddr_CAN,00 ,192
IDE19867-ENG369442-Specification for routing diagnostic and bus address for CAN control modules-ECU44_Diagnosisaddr_CAN,00 00 ,192
IDE19867-ENG369444-Specification for routing diagnostic and bus address for CAN control modules-ECU45_Busaddr_CAN,00 ,192
IDE19867-ENG369446-Specification for routing diagnostic and bus address for CAN control modules-ECU45_Diagnosisaddr_CAN,00 00 ,192
IDE19867-ENG369448-Specification for routing diagnostic and bus address for CAN control modules-ECU46_Busaddr_CAN,00 ,192
IDE19867-ENG369450-Specification for routing diagnostic and bus address for CAN control modules-ECU46_Diagnosisaddr_CAN,00 00 ,192
IDE19867-ENG369452-Specification for routing diagnostic and bus address for CAN control modules-ECU47_Busaddr_CAN,00 ,192
IDE19867-ENG369454-Specification for routing diagnostic and bus address for CAN control modules-ECU47_Diagnosisaddr_CAN,00 00 ,192
IDE19867-ENG369456-Specification for routing diagnostic and bus address for CAN control modules-ECU48_Busaddr_CAN,00 ,192
IDE19867-ENG369458-Specification for routing diagnostic and bus address for CAN control modules-ECU48_Diagnosisaddr_CAN,00 00 ,192
IDE19867-ENG369460-Specification for routing diagnostic and bus address for CAN control modules-ECU49_Busaddr_CAN,00 ,192
IDE19867-ENG369462-Specification for routing diagnostic and bus address for CAN control modules-ECU49_Diagnosisaddr_CAN,00 00 ,192
IDE19867-ENG369464-Specification for routing diagnostic and bus address for CAN control modules-ECU5_Busaddr_CAN,23 ,192
IDE19867-ENG369466-Specification for routing diagnostic and bus address for CAN control modules-ECU5_Diagnosisaddr_CAN,81 22 ,192
IDE19867-ENG369468-Specification for routing diagnostic and bus address for CAN control modules-ECU50_Busaddr_CAN,00 ,192
IDE19867-ENG369470-Specification for routing diagnostic and bus address for CAN control modules-ECU50_Diagnosisaddr_CAN,00 00 ,192
IDE19867-ENG369472-Specification for routing diagnostic and bus address for CAN control modules-ECU51_Busaddr_CAN,00 ,192
IDE19867-ENG369474-Specification for routing diagnostic and bus address for CAN control modules-ECU51_Diagnosisaddr_CAN,00 00 ,192
IDE19867-ENG369476-Specification for routing diagnostic and bus address for CAN control modules-ECU52_Busaddr_CAN,00 ,192
IDE19867-ENG369478-Specification for routing diagnostic and bus address for CAN control modules-ECU52_Diagnosisaddr_CAN,00 00 ,192
IDE19867-ENG369480-Specification for routing diagnostic and bus address for CAN control modules-ECU53_Busaddr_CAN,00 ,192
IDE19867-ENG369482-Specification for routing diagnostic and bus address for CAN control modules-ECU53_Diagnosisaddr_CAN,00 00 ,192
IDE19867-ENG369484-Specification for routing diagnostic and bus address for CAN control modules-ECU54_Busaddr_CAN,00 ,192
IDE19867-ENG369486-Specification for routing diagnostic and bus address for CAN control modules-ECU54_Diagnosisaddr_CAN,00 00 ,192
IDE19867-ENG369488-Specification for routing diagnostic and bus address for CAN control modules-ECU55_Busaddr_CAN,00 ,192
IDE19867-ENG369490-Specification for routing diagnostic and bus address for CAN control modules-ECU55_Diagnosisaddr_CAN,00 00 ,192
IDE19867-ENG369492-Specification for routing diagnostic and bus address for CAN control modules-ECU56_Busaddr_CAN,00 ,192
IDE19867-ENG369494-Specification for routing diagnostic and bus address for CAN control modules-ECU56_Diagnosisaddr_CAN,00 00 ,192
IDE19867-ENG369496-Specification for routing diagnostic and bus address for CAN control modules-ECU57_Busaddr_CAN,00 ,192
IDE19867-ENG369498-Specification for routing diagnostic and bus address for CAN control modules-ECU57_Diagnosisaddr_CAN,00 00 ,192
IDE19867-ENG369500-Specification for routing diagnostic and bus address for CAN control modules-ECU58_Busaddr_CAN,00 ,192
IDE19867-ENG369502-Specification for routing diagnostic and bus address for CAN control modules-ECU58_Diagnosisaddr_CAN,00 00 ,192
IDE19867-ENG369504-Specification for routing diagnostic and bus address for CAN control modules-ECU59_Busaddr_CAN,00 ,192
IDE19867-ENG369506-Specification for routing diagnostic and bus address for CAN control modules-ECU59_Diagnosisaddr_CAN,00 00 ,192
IDE19867-ENG369508-Specification for routing diagnostic and bus address for CAN control modules-ECU6_Busaddr_CAN,19 ,192
IDE19867-ENG369510-Specification for routing diagnostic and bus address for CAN control modules-ECU6_Diagnosisaddr_CAN,00 DE ,192
IDE19867-ENG369512-Specification for routing diagnostic and bus address for CAN control modules-ECU60_Busaddr_CAN,00 ,192
IDE19867-ENG369514-Specification for routing diagnostic and bus address for CAN control modules-ECU60_Diagnosisaddr_CAN,00 00 ,192
IDE19867-ENG369516-Specification for routing diagnostic and bus address for CAN control modules-ECU61_Busaddr_CAN,00 ,192
IDE19867-ENG369518-Specification for routing diagnostic and bus address for CAN control modules-ECU61_Diagnosisaddr_CAN,00 00 ,192
IDE19867-ENG369520-Specification for routing diagnostic and bus address for CAN control modules-ECU62_Busaddr_CAN,00 ,192
IDE19867-ENG369522-Specification for routing diagnostic and bus address for CAN control modules-ECU62_Diagnosisaddr_CAN,00 00 ,192
IDE19867-ENG369524-Specification for routing diagnostic and bus address for CAN control modules-ECU63_Busaddr_CAN,00 ,192
IDE19867-ENG369526-Specification for routing diagnostic and bus address for CAN control modules-ECU63_Diagnosisaddr_CAN,00 00 ,192
IDE19867-ENG369529-Specification for routing diagnostic and bus address for CAN control modules-ECU64_Bussaddr_CAN,00 ,192
IDE19867-ENG369530-Specification for routing diagnostic and bus address for CAN control modules-ECU64_Diagnosisaddr_CAN,00 00 ,192
IDE19867-ENG369532-Specification for routing diagnostic and bus address for CAN control modules-ECU7_Busaddr_CAN,00 ,192
IDE19867-ENG369534-Specification for routing diagnostic and bus address for CAN control modules-ECU7_Diagnosisaddr_CAN,00 00 ,192
IDE19867-ENG369536-Specification for routing diagnostic and bus address for CAN control modules-ECU8_Busaddr_CAN,00 ,192
IDE19867-ENG369538-Specification for routing diagnostic and bus address for CAN control modules-ECU8_Diagnosisaddr_CAN,00 00 ,192
IDE19867-ENG369540-Specification for routing diagnostic and bus address for CAN control modules-ECU9_Busaddr_CAN,00 ,192
IDE19867-ENG369542-Specification for routing diagnostic and bus address for CAN control modules-ECU9_Diagnosisaddr_CAN,00 00 ,192
MAS08072-ENG172204-Driving profile selection-FPA_BAP_Display,active ,5
MAS08072-ENG172364-Driving profile selection-FPA_BAP_Start_aktiv,active ,5
MAS08072-ENG172201-Driving profile selection-FPA_Funktion,active ,5
MAS08072-ENG172220-Driving profile selection-FPA_Funktion_ACC,active ,5
MAS08072-ENG172217-Driving profile selection-FPA_Funktion_AFS,active ,5
MAS08072-ENG172366-Driving profile selection-FPA_Funktion_AGA,not active ,5
MAS08072-ENG173595-Driving profile selection-FPA_Funktion_AGK,not active ,5
MAS08072-ENG172224-Driving profile selection-FPA_Funktion_ALR,not active ,5
MAS08072-ENG172223-Driving profile selection-FPA_Funktion_AMB,active ,5
MAS08072-ENG172229-Driving profile selection-FPA_Funktion_DR,not active ,5
MAS08072-ENG172590-Driving profile selection-FPA_Funktion_eBKV,not active ,5
MAS08072-ENG173592-Driving profile selection-FPA_Funktion_EDS,not active ,5
MAS08072-ENG172219-Driving profile selection-FPA_Funktion_EPS,active ,5
MAS08072-ENG258261-Driving profile selection-FPA_Funktion_ESH,not active ,5
MAS08072-ENG172225-Driving profile selection-FPA_Funktion_ESP,active ,5
MAS08072-ENG174239-Driving profile selection-FPA_Funktion_FMA,not active ,5
MAS08072-ENG172226-Driving profile selection-FPA_Funktion_Freilauf,not active ,5
MAS08072-ENG246827-Driving profile selection-FPA_Funktion_Freilauf_DefaultON,not active ,5
MAS08072-ENG172228-Driving profile selection-FPA_Funktion_GE,not active ,5
MAS08072-ENG172522-Driving profile selection-FPA_Funktion_HDC,not active ,5
MAS08072-ENG173593-Driving profile selection-FPA_Funktion_HHC,not active ,5
MAS08072-ENG172519-Driving profile selection-FPA_Funktion_HSP,not active ,5
MAS08072-ENG172214-Driving profile selection-FPA_Funktion_IVB,not active ,5
MAS08072-ENG172215-Driving profile selection-FPA_Funktion_KL,active ,5
MAS08072-ENG246828-Driving profile selection-FPA_Funktion_mFDR,active ,5
MAS08072-ENG172227-Driving profile selection-FPA_Funktion_MO,active ,5
MAS08072-ENG172523-Driving profile selection-FPA_Funktion_MO_BZS,not active ,5
MAS08072-ENG172222-Driving profile selection-FPA_Funktion_MO_StSt,not active ,5
MAS08072-ENG173594-Driving profile selection-FPA_Funktion_PDC,not active ,5
MAS08072-ENG172218-Driving profile selection-FPA_Funktion_RGS,not active ,5
MAS08072-ENG172521-Driving profile selection-FPA_Funktion_RWB,active ,5
MAS08072-ENG172221-Driving profile selection-FPA_Funktion_SAK,not active ,5
MAS08072-ENG259013-Driving profile selection-FPA_Funktion_ToS_L,not active ,5
MAS08072-ENG260985-Driving profile selection-FPA_Funktion_ToS_Q,not active ,5
MAS08072-ENG172365-Driving profile selection-FPA_Funktion_VAQ,not active ,5
MAS08072-ENG172205-Driving profile selection-FPA_Kombi_Anzeige,not active ,5
MAS08072-ENG273644-Driving profile selection-FPA_Kombi_Status_Unterdruecken,not active ,5
MAS08072-ENG172202-Driving profile selection-FPA_Personalisierung,active ,5
MAS08072-ENG172206-Driving profile selection-FPA_Taster_Auswertung,Rising slope ,5
MAS09325-IDE13878-Daytime running lights-Activation: daytime running lights,Daytime running lights ,8
MAS09325-MAS09335-Daytime running lights-Daytime running lights/parking light,not active ,8
MAS09325-MAS16273-Daytime running lights-Speed warning active: rear fog lamps,0 km/h,8
MAS09325-MAS21314-Daytime running lights-Daytime running indicator lamp,not active ,8
MAS09325-MAS28806-Daytime running lights-Daytime running light: speed-dependent,0 km/h,8
MAS09325-MAS28807-Daytime running lights-Daytime running light: deactivation via speed,not active ,8
MAS09325-MAS28808-Daytime running lights-Daytime running light: switchover of standard output value,active ,8
MAS09325-MAS28812-Daytime running lights-Deactivate daytime/continuous running light with handbrake active,active ,8
MAS09325-MAS28813-Daytime running lights-Daytime/continuous running light also activates two-sided parking light,not active ,8
MAS09325-MAS28814-Daytime running lights-Daytime running light activation possible via BAP or operating sequence,not active ,8
MAS09325-MAS28815-Daytime running lights-Daytime running light only in AUTO switch position,active ,8
MAS09325-ENG387560-Daytime running lights-DRL_activates_tail_light,not active ,8
MAS12382-MAS06760-Dynamic turn signal control-Emergency flashers in roll mode,not active ,8
MAS12382-MAS07029-Dynamic turn signal control-Crash flashing,not active ,8
MAS12382-MAS07032-Dynamic turn signal control-Emergency flashing,not active ,8
MAS12382-MAS07033-Dynamic turn signal control-Panic flashing,not active ,8
MAS12382-MAS07034-Dynamic turn signal control-Theft flashing,not active ,8
MAS12382-MAS07036-Dynamic turn signal control-Garage door opener adaptation flashing,not active ,8
MAS12382-MAS07041-Dynamic turn signal control-Taxi alarm flashing,not active ,8
MAS12382-MAS07044-Dynamic turn signal control-Rear lid opening angle adaptation flashing,not active ,8
MAS12382-MAS12781-Dynamic turn signal control-Telematic blinking or blinking by positioning assistant,not active ,8
MAS12382-MAS14169-Dynamic turn signal control-Confirmation flashing of the central locking system when unlocking,not active ,8
MAS12382-MAS14170-Dynamic turn signal control-Confirmation flashing of the central locking system when locking,not active ,8
MAS12382-MAS28788-Dynamic turn signal control-Multi-collision indication,not active ,8
MAS12382-MAS28820-Dynamic turn signal control-Side Assist: left turn signal,not active ,8
MAS12382-MAS28821-Dynamic turn signal control-Side Assist: right turn signal,not active ,8
MAS12382-MAS28825-Dynamic turn signal control-Hazard warning lights with ignition off,not active ,8
MAS12382-MAS28826-Dynamic turn signal control-Hazard warning lights with ignition on,not active ,8
MAS12382-MAS28829-Dynamic turn signal control-Emergency warning signal: emergency brake display: phase 2,not active ,8
MAS12382-MAS28831-Dynamic turn signal control-Turn signal: left,not active ,8
MAS12382-MAS28832-Dynamic turn signal control-Turn signal: right,not active ,8
MAS12382-MAS28912-Dynamic turn signal control-Park Assist/Park Assist Plus with remote control: turn signal confirmation,not active ,8
MAS12382-MAS28913-Dynamic turn signal control-Park Assist/Park Assist Plus with remote control: turn signal left,not active ,8
MAS12382-MAS28914-Dynamic turn signal control-Park Assist/Park Assist Plus with remote control: turn signal right,not active ,8
MAS12382-ENG122206-Dynamic turn signal control-DWA_Schaerfungsquittung,not active ,8
MAS12382-ENG142195-Dynamic turn signal control-Dynamische_Blink_Delay,60 ms,8
MAS13921-IDE00047-Control module rear lid opening: dataset-Parameter set version,0 ,37
MAS13921-IDE80001-Control module rear lid opening: dataset-Analysis 1,1 ,37
MAS13921-IDE80002-Control module rear lid opening: dataset-Analysis 2,1 ,37
MAS13921-IDE80003-Control module rear lid opening: dataset-Analysis 3,1 ,37
MAS13921-IDE80004-Control module rear lid opening: dataset-Analysis 4,0 ,37
MAS13921-IDE80005-Control module rear lid opening: dataset-Analysis 5,35 ,37
MAS13921-IDE80006-Control module rear lid opening: dataset-Analysis 6,35 ,37
MAS13921-IDE80007-Control module rear lid opening: dataset-Analysis 7,30 ,37
MAS13921-IDE80008-Control module rear lid opening: dataset-Analysis 8,30 ,37
MAS13921-IDE80009-Control module rear lid opening: dataset-Analysis 9,2 ,37
MAS13921-IDE80010-Control module rear lid opening: dataset-Analysis 10,31 ,37
MAS13921-IDE80011-Control module rear lid opening: dataset-Analysis 11,2 ,37
MAS13921-IDE80012-Control module rear lid opening: dataset-Analysis 12,31 ,37
MAS13921-IDE80013-Control module rear lid opening: dataset-Analysis 13,224 ,37
MAS13921-IDE80014-Control module rear lid opening: dataset-Analysis 14,10 ,37
MAS13921-IDE80015-Control module rear lid opening: dataset-Analysis 15,10 ,37
MAS13921-IDE80016-Control module rear lid opening: dataset-Analysis 16,0 ,37
MAS13921-IDE80017-Control module rear lid opening: dataset-Analysis 17,0 ,37
MAS13921-IDE80018-Control module rear lid opening: dataset-Analysis 18,0 ,37
MAS13921-IDE80019-Control module rear lid opening: dataset-Analysis 19,0 ,37
MAS13921-IDE80020-Control module rear lid opening: dataset-Analysis 20,active ,37
MAS13921-IDE80021-Control module rear lid opening: dataset-Analysis 21,not active ,37
MAS13921-IDE80022-Control module rear lid opening: dataset-Analysis 22,not active ,37
MAS13921-IDE80023-Control module rear lid opening: dataset-Analysis 23,Bottom ,37
MAS13921-IDE80024-Control module rear lid opening: dataset-Analysis 24,static ,37
MAS13921-IDE80025-Control module rear lid opening: dataset-Analysis 25,3 ,37
MAS13921-IDE80026-Control module rear lid opening: dataset-Analysis 26,not active ,37
MAS13921-IDE80027-Control module rear lid opening: dataset-Analysis 27,Dynamic ,37
MAS13921-IDE80028-Control module rear lid opening: dataset-Analysis 28,10 ,37
MAS13921-IDE80029-Control module rear lid opening: dataset-Analysis 29,10 ,37
MAS13921-IDE80030-Control module rear lid opening: dataset-Analysis 30,active ,37
MAS13921-IDE80031-Control module rear lid opening: dataset-Analysis 31,40 ,37
MAS13921-IDE80032-Control module rear lid opening: dataset-Analysis 32,2 ,37
MAS13921-IDE80033-Control module rear lid opening: dataset-Analysis 33,12 ,37
MAS13921-IDE80034-Control module rear lid opening: dataset-Analysis 34,4 ,37
MAS13921-IDE80035-Control module rear lid opening: dataset-Analysis 35,Do not reset ,37
MAS13921-IDE80036-Control module rear lid opening: dataset-Analysis 36,16 ,37
MAS13921-IDE80037-Control module rear lid opening: dataset-Analysis 37,16 ,37
MAS13921-IDE80038-Control module rear lid opening: dataset-Analysis 38,16 ,37
MAS13921-IDE80039-Control module rear lid opening: dataset-Analysis 39,16 ,37
MAS13921-IDE80040-Control module rear lid opening: dataset-Analysis 40,2 ,37
MAS13921-IDE80041-Control module rear lid opening: dataset-Analysis 41,31 ,37
MAS13921-IDE80042-Control module rear lid opening: dataset-Analysis 42,2 ,37
MAS13921-IDE80043-Control module rear lid opening: dataset-Analysis 43,31 ,37
MAS13921-IDE80044-Control module rear lid opening: dataset-Analysis 44,224 ,37
MAS13921-IDE80045-Control module rear lid opening: dataset-Analysis 45,10 ,37
MAS13921-IDE80046-Control module rear lid opening: dataset-Analysis 46,10 ,37
MAS13921-IDE80047-Control module rear lid opening: dataset-Analysis 47,0 ,37
MAS13921-IDE80048-Control module rear lid opening: dataset-Analysis 48,0 ,37
MAS13921-IDE80049-Control module rear lid opening: dataset-Analysis 49,0 ,37
MAS13921-IDE80050-Control module rear lid opening: dataset-Analysis 50,0 ,37
MAS13921-IDE80051-Control module rear lid opening: dataset-Analysis 51,6 ,37
MAS13921-IDE80052-Control module rear lid opening: dataset-Analysis 52,25 ,37
MAS13921-IDE80053-Control module rear lid opening: dataset-Analysis 53,255 ,37
MAS13921-IDE80054-Control module rear lid opening: dataset-Analysis 54,5 ,37
MAS13921-IDE80055-Control module rear lid opening: dataset-Analysis 55,60 ,37
MAS13921-IDE80056-Control module rear lid opening: dataset-Analysis 56,248 ,37
MAS13921-MAS01078-Control module rear lid opening: dataset-Vehicle model,0 ,37
MAS13921-MAS14087-Control module rear lid opening: dataset-time delay activation,not active ,37
MAS14140-IDE15905-Flashing function-Travel Assist,active ,4
MAS14140-IDE18029-Flashing function-Rush Hour Pilot,not active ,4
MAS14140-IDE20494-Flashing function-Installation coding: flashing request for rush hour pilot,not active ,4
MAS14140-MAS28783-Flashing function-Driving assistance system: flashing function,Hazard warning lights permitted ,4
MAS14140-MAS28895-Flashing function-Hazard warning lights by means of driver assist system,active ,4
MAS14140-MAS28928-Flashing function-Horn via driver assist system,active ,4
MAS18824-MAS21301-Light button module-Reactivation limit light,95 m,12
MAS18824-ENG246963-Light button module-Anzeigezeit_LTM_PopUp1,4.0 s,12
MAS18824-ENG246964-Light button module-Anzeigezeit_LTM_PopUp1_lang,10 s,12
MAS18824-ENG246965-Light button module-Beleuchtung_Auto_LED_bei_Nebelfunktion,active ,12
MAS18824-ENG246966-Light button module-Beleuchtung_LTM_Auto_LED_58xt_logik,active ,12
MAS18824-ENG246978-Light button module-Licht_anforderung_FAS,not installed ,12
MAS18824-ENG246979-Light button module-Licht_anforderung_Pilopark,active ,12
MAS18824-ENG246982-Light button module-LTM_Anzeige_Config,02 ,12
MAS18824-ENG246983-Light button module-LTM_Beleuchtung_Geschwindigkeits_Schwelle,10 km/h,12
MAS18824-ENG246985-Light button module-LTM_BGL_Geschwindigkeitsabhängig_Parameter,active ,12
MAS18824-ENG246986-Light button module-LTM_BGL_Wegabhängig,active ,12
MAS18824-ENG246988-Light button module-LTM_GlobalOFF_Geschwindigkeitsabhängig_Parameter,active ,12
MAS18824-ENG246989-Light button module-LTM_GlobalOFF_Wegabhängig,active ,12
MAS18824-ENG246990-Light button module-LTM_GlobalOFF_Zündungsabhängig,not active ,12
MAS20279-WFS transponder gateway coding,Transponder GW in Kessy OK box ,4
MAS23116-Production mode: 12 V recharging,15 min,1
MAS23693-MAS18081-Drowsiness and attention detection-Test Mode,00 ,22
MAS23693-MAS20954-Drowsiness and attention detection-Function coding,00 ,22
MAS23693-ENG101808-Drowsiness and attention detection-Bytes 1-16,00 20 00 00 00 02 40 00 00 20 00 00 00 00 00 00 ,22
SFT00061-MAS10520-Special Function-Special function 1,not installed ,4
SFT00061-SFT00048-Special Function-Special Function 2,not enabled ,4
SFT00061-ENG260472-Special Function-Blinkerueberwachug_Sonderfunktions_SG,not installed ,4
SFT00061-ENG259314-Special Function-Luechtenmaskierung fuer Hinterwagen,4 ,4
SFT00061-ENG258537-Special Function-Luechtenmaskierung fuer Vorderwagen,16 ,4
SFT271921-IDE02583-Multifunction steering wheel control module-Steering wheel Tiptronic switch,not installed ,3
SFT271921-IDE07856-Multifunction steering wheel control module-Terminal status,active with terminal 58 ,3
SFT271921-MAS02311-Multifunction steering wheel control module-Steering wheel heating button,active ,3
SFT271921-MAS04733-Multifunction steering wheel control module-Two-stage,not active ,3
SFT271921-MAS06614-Multifunction steering wheel control module-Variant,ACC ,3
SFT271921-MAS09758-Multifunction steering wheel control module-Temperature sensor,installed ,3
SFT271921-MAS10720-Multifunction steering wheel control module-Speed limiter,not active ,3
SFT271921-MAS13892-Multifunction steering wheel control module-Platform,MQB2020 ,3
SFT271921-MAS19104-Multifunction steering wheel control module-Alarm horn wake-up function,not active ,3
SFT271921-MAS21171-Multifunction steering wheel control module-Distance regulation function query (FoD),activated ,3
SFT271921-MAS21172-Multifunction steering wheel control module-Travel Assist function query (FoD),automatic ,3
SFT271921-ENG262857-Multifunction steering wheel control module-Kombi_02_gueltig,invalid ,3
SFT272190-Steering Wheel Touch Recognition Control Module,Data record 2 ,3
UNK00000-TNF 167462,2_Basis ,3
ENG253278-Activation_DLT,not active ,1
ENG253044-Activation_Ethernet_Routing,not active ,1
ENG344785-ENG345280-Alco_lock_coding-Alco_lock_installed,No ,2
ENG344785-ENG413863-Alco_lock_coding-Comf_ortR_eady_debo_unce,No ,2
ENG344785-ENG345664-Alco_lock_coding-Eval_com_fort_ready,Yes ,2
ENG344785-ENG345665-Alco_lock_coding-Eval_drivr_presence,Yes ,2
ENG344785-ENG413932-Alco_lock_coding-Eval_ext_LIN_acti_vity_from_LIN_bus_mast_er,No ,2
ENG344785-ENG413933-Alco_lock_coding-Eval_unpl_ausi_ble_valu_es_from_Alco_hol_inte_rloc,No ,2
ENG344785-ENG413963-Alco_lock_coding-LIN_send_dely,No ,2
ENG344785-ENG414057-Alco_lock_coding-USS_debo_unce,No ,2
ENG344785-ENG346084-Alco_lock_coding-Vehicle_state_change_mode_set_mode2_shut_down_via_time_out,Yes ,2
ENG344786-ENG413877-Alco_lock_parameter-Debo_ounc_Comf_Rdy_sign_al,0.0 s,21
ENG344786-ENG413878-Alco_lock_parameter-Debo_ounc_USS_sign_als,0.0 s,21
ENG344786-ENG413962-Alco_lock_parameter-LIN_data_dely,0.0 s,21
ENG344786-ENG413965-Alco_lock_parameter-Max_coun_ter_unpl_ausi_ble_data_rece_ived,0 s,21
ENG344786-ENG413992-Alco_lock_parameter-Qual_time_delay_DTC_104,0.0 s,21
ENG344786-ENG345929-Alco_lock_parameter-Rpm_threshold_engine_run,100 /min,21
ENG344786-ENG345957-Alco_lock_parameter-Speed_threshold_vehicle_stand_still,7.0 km/h,21
ENG344786-ENG345959-Alco_lock_parameter-State_change_set_mode2_unset_mode_via_term_15,Condition_terminal_15_active ,21
ENG344786-ENG414014-Alco_lock_parameter-Time_delay_switchoff_LIN_activity_bit,0.0 s,21
ENG344786-ENG346038-Alco_lock_parameter-Time_out_automatic_transition_set_mode2_shut_down,5 min,21
ENG344786-ENG346039-Alco_lock_parameter-Time_out_automatic_transition_unset_mode2_set_mode,1 s,21
ENG344786-ENG346040-Alco_lock_parameter-Time_out_proto_col_vali_dation,5 s,21
ENG344786-ENG414015-Alco_lock_parameter-Time_out_switchoff_alkohol_interlock_after_idle_followup_time,0.0 min,21
ENG344786-ENG346064-Alco_lock_parameter-Used_LIN_version,LIN_2_0 ,21
ENG344786-ENG346065-Alco_lock_parameter-Used_prot_col_version,Norm_version_2022 ,21
ENG253146-ENG141986-Aussenlicht-SG-Architektur-Abblendlicht_Leuchtentyp,H7 ,8
ENG253146-ENG258089-Aussenlicht-SG-Architektur-Abschaltung Redundanzpfad Prüfung,active ,8
ENG253146-ENG115861-Aussenlicht-SG-Architektur-Lichthupe bei Zuendung aus moeglich,not active ,8
ENG253146-ENG115832-Aussenlicht-SG-Architektur-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht,not active ,8
ENG253146-ENG115860-Aussenlicht-SG-Architektur-Zahl der aktiven Scheinwerfer auf 2 limitieren,in Betrieb lassen ,8
ENG253356-ENG258933-Automatische_Funktionen-Automatik_Funktionen_Warnungen_aktiv,activated ,4
ENG253356-ENG258835-Automatische_Funktionen-Automatik_Funktionen_WarnungWenn_AusserhalbExitBereich_aktiv,not activated ,4
ENG253356-ENG260748-Automatische_Funktionen-AutomatikFunktionen_WarnungWenn_VerlassenBeiHautNichtGeschlossen_aktiv,activated ,4
ENG253356-ENG281101-Automatische_Funktionen-AutomatikFunktionen_WarnungWennIDGeberImInnenraum_aktiv,activated ,4
ENG253356-ENG258145-Automatische_Funktionen-AutomatischeFunktionen_Beschleunigtes_Entry_aktiv,activated ,4
ENG253356-ENG260562-Automatische_Funktionen-Automatisches_Entriegeln_aktiv,activated ,4
ENG253356-ENG260693-Automatische_Funktionen-Automatisches_Verriegeln_aktiv,activated ,4
ENG307652-ENG331129-Child Presence Detection-p_CPD_warnton_aktiv,active ,2
ENG307652-ENG331130-Child Presence Detection-p_t_Delta_Timer,10 ,2
ENG307652-ENG331133-Child Presence Detection-p_ZV_child_presence_detection,active ,2
ENG253018-Clamp_Control,All doors ,1
ENG253221-ENG259820-Clamp_Coordinator-Clamp_Coordinator_priority_AAA,10 ,40
ENG253221-ENG260325-Clamp_Coordinator-Clamp_Coordinator_priority_DIAG,10 ,40
ENG253221-ENG260088-Clamp_Coordinator-Clamp_Coordinator_priority_MWS,10 ,40
ENG253221-ENG259040-Clamp_Coordinator-Clamp_Coordinator_priority_ORU,1 ,40
ENG253221-ENG259149-Clamp_Coordinator-Clamp_Coordinator_priority_PHP,10 ,40
ENG253221-ENG261099-Clamp_Coordinator-Clamp_Coordinator_priority_RPA,10 ,40
ENG253221-ENG258680-Clamp_Coordinator-Clamp_Coordinator_priority_RWK,100 ,40
ENG253221-ENG260388-Clamp_Coordinator-Clamp_Coordinator_priority_SPN,10 ,40
ENG253221-ENG259706-Clamp_Coordinator-Clamp_Coordinator_priority_ZAS,10 ,40
ENG253142-ENG258099-Design_switching-Display_Nachtdesign-Umschaltung,Standlicht/Fahrlicht_u_RLS ,5
ENG253142-ENG261004-Design_switching-RLS_Nachtdesign_Schwelle,20 ,5
ENG253142-ENG260371-Design_switching-RLS_Tagdesign_Schwelle,100 ,5
ENG253142-ENG258254-Design_switching-Werteanzahl_Mittelwert,100 ,5
ENG253142-ENG260585-Design_switching-Werteanzahl_Mittelwert_Start-,05 ,5
ENG253216-MAS18908-DevCod_Automatische_Verriegelung-Terminal 15: behavior of the automatic locking function,Function only allowed for terminal 15 on or off ,6
ENG253216-ENG261088-DevCod_Automatische_Verriegelung-AutomatikFunktionen_HVLaden_EigenerBereich_aktiv,not activated ,6
ENG253216-ENG258169-DevCod_Automatische_Verriegelung-AutomatikFunktionen_Sonderfall_ZyklischeSucheBeiKlemme15_aktiv,activated ,6
ENG253216-ENG302712-DevCod_Automatische_Verriegelung-Automatische_FunktionenBeiAnnaeherung_Entfernung_aktiv,activated ,6
ENG253195-IDE04159-DevCod_Dienste_Byte1-Deactivation of start/stop function,not active ,6
ENG253195-ENG281096-DevCod_Dienste_Byte1-Entry_Deaktivierung_aktiv,activated ,6
ENG253195-ENG258846-DevCod_Dienste_Byte1-Entry_GoDeaktivierung_Aktivierungs_Variante,not activated ,6
ENG253195-ENG258351-DevCod_Dienste_Byte1-ErkennungFahrzeug_Verlassen_aktiv,activated ,6
ENG253195-ENG261030-DevCod_Dienste_Byte1-ErkennungFahrzeug_Zugang_aktiv,activated ,6
ENG253195-ENG260255-DevCod_Dienste_Byte1-ErkennungFahrzeugZugang_bei_Remotestart,activated ,6
ENG253195-ENG259070-DevCod_Dienste_Byte1-ErkennungFahrzeugZugangVerlassen_Triggerung_aktiv,activated ,6
ENG253102-ENG258819-DevCod_Dienste_Byte2-BereichsueberwachungPilotiertesParken_Variante,not activated ,6
ENG253102-ENG259756-DevCod_Dienste_Byte2-BewussteGesamtEntriegelung_aktiv,activated ,6
ENG253102-ENG261309-DevCod_Dienste_Byte2-Paketbotenmodus_aktiv,not activated ,6
ENG253102-ENG277103-DevCod_Dienste_Byte2-RSAD_Krypto_Checks_aktivieren,activated ,6
ENG253102-ENG259641-DevCod_Dienste_Byte2-RSADMassnahme_aussen_aktiv,not activated ,6
ENG253102-ENG259949-DevCod_Dienste_Byte2-RSADMassnahme_innen_aktiv,not activated ,6
ENG253102-ENG260061-DevCod_Dienste_Byte2-ScanFuerPersonalisierungUndSitzmemory_aktiv,not activated ,6
ENG253102-ENG259459-DevCod_Dienste_Byte2-ScanFuerPersonalisierungUndSitzmemory_NichtKessyEntr_aktiv,not activated ,6
ENG253102-ENG259282-DevCod_Dienste_Byte2-ScanFuerPersonalisierungUndSitzmemory_OeffnenFT_aktiv,activated ,6
ENG253202-ENG259475-DevCod_Dienste_Byte3-VIT_close,not activated ,6
ENG253202-ENG259049-DevCod_Dienste_Byte3-VIT_KESSY_Inversbit,not activated ,6
ENG253296-ENG259208-DevCod_Fahrzeugkonfiguration_Byte1-BEM_verbaut,activated ,6
ENG253296-ENG174999-DevCod_Fahrzeugkonfiguration_Byte1-Convertible,not activated ,6
ENG253296-ENG259388-DevCod_Fahrzeugkonfiguration_Byte1-HBFS_Schiebetuer,activated ,6
ENG253296-ENG259603-DevCod_Fahrzeugkonfiguration_Byte1-HFS_Schiebetuer,activated ,6
ENG253296-ENG260764-DevCod_Fahrzeugkonfiguration_Byte1-NFZ_mit_2Zonen,not activated ,6
ENG253183-ENG259579-DevCod_Fahrzeugkonfiguration_Byte2-Softtouch_verbaut,installed ,6
ENG253183-ENG277104-DevCod_Fahrzeugkonfiguration_Byte2-Sonderfunktion_1_aktiv,not activated ,6
ENG253183-ENG277105-DevCod_Fahrzeugkonfiguration_Byte2-Sonderfunktion_2_aktiv,not activated ,6
ENG253183-ENG277106-DevCod_Fahrzeugkonfiguration_Byte2-Sonderfunktion_3_aktiv,not activated ,6
ENG253183-ENG277107-DevCod_Fahrzeugkonfiguration_Byte2-Sonderfunktion_4_aktiv,not activated ,6
ENG253183-ENG277108-DevCod_Fahrzeugkonfiguration_Byte2-Sonderfunktion_5_aktiv,not activated ,6
ENG253183-ENG141964-DevCod_Fahrzeugkonfiguration_Byte2-Steering alignment,Left ,6
ENG253369-ENG260810-DevCod_IDGeber_Suche-Innenraumsuche_Kl15_bei_Fahrertuer,activated ,6
ENG253369-ENG258777-DevCod_IDGeber_Suche-Innenraumsuche_Kl15_bei_Verdeck_offen,not activated ,6
ENG253369-ENG258088-DevCod_IDGeber_Suche-Innenraumsuche_Wiederentriegelung_Heck_Schließverhinderung,activated ,6
ENG253369-ENG258863-DevCod_IDGeber_Suche-InnenraumsucheMitEEAuth_Variante,not activated ,6
ENG253369-ENG281080-DevCod_IDGeber_Suche-Unterdrueckung_zyklischer _Suchen_bei_entriegeltem_Fahrzeug_aktiv,not activated ,6
ENG253170-ENG281102-DevCod_Nutzerkonfigurationen-HMIMenue_Aktivierung_Nah_Mittel_Fern_aktiv,not activated ,6
ENG253170-ENG259272-DevCod_Nutzerkonfigurationen-HMIMenue_Keyless_Advanced_aktiv,activated ,6
ENG253170-ENG258478-DevCod_Nutzerkonfigurationen-HMIMenue_Keyless_aktiv,activated ,6
ENG253170-ENG281078-DevCod_Nutzerkonfigurationen-HMIMenue_Nutzer_Warnung_AutomatikFunktion_aktiv,activated ,6
ENG253247-IDE02474-DevCod_Passive_EntryExit_Toggle-Terminal 15 characteristics of passive entry exit function,Function only allowed for terminal 15 on or off ,7
ENG253247-MAS18909-DevCod_Passive_EntryExit_Toggle-Terminal 15: behavior of the unlock/lock button function,not activated ,7
ENG253247-MAS18910-DevCod_Passive_EntryExit_Toggle-Terminal 15 characteristics of passive exit function,Function only allowed for terminal 15 on or off ,7
ENG253247-ENG260696-DevCod_Passive_EntryExit_Toggle-FunkkommunikationFuerPassiveEntryExit_Wiederholung_aktiv,not activated ,7
ENG253247-ENG261245-DevCod_Passive_EntryExit_Toggle-Passive_Exit_bei_offenen_Tueren,activated ,7
ENG253247-ENG261070-DevCod_Passive_EntryExit_Toggle-Passive_Exit_bei_offener_Zugangstuer,not activated ,7
ENG253247-ENG258791-DevCod_Passive_EntryExit_Toggle-Passive_Toggle_bei_offenen_Tueren,not activated ,7
ENG253247-ENG260751-DevCod_Passive_EntryExit_Toggle-PassiveEntryExit_aktiv,activated ,7
ENG253117-ENG260289-DevCod_Passive_Go-Innenraumsuche_IDGeberFreigeben_bei_Remotestart,not activated ,6
ENG253117-ENG259313-DevCod_Passive_Go-PassiveGo_bei_offener_Heckklappe,activated ,6
ENG253117-ENG261220-DevCod_Passive_Go-PassiveGo_bei_offener_Schiebetür,activated ,6
ENG253073-Diagnostic_filter_permanent_deactivation,activated ,1
ENG253197-ENG260990-Diebstahlschutz Schnittstelle-DWA_HSB_HSK_ueberwachung_aktiv,not active ,6
ENG253197-ENG258293-Diebstahlschutz Schnittstelle-DWA_mit_Einfachhorn,not installed ,6
ENG253197-ENG258890-Diebstahlschutz Schnittstelle-DWA_mit_NGS,not active ,6
ENG253197-ENG258731-Diebstahlschutz Schnittstelle-DWA_ohne_Thatcham,limited ,6
ENG253197-ENG258944-Diebstahlschutz Schnittstelle-DWA_Scheinwerferueberwachung_aktiv,not active ,6
ENG253197-ENG258663-Diebstahlschutz Schnittstelle-DWA_verbaut,installed ,6
ENG253197-ENG258162-Diebstahlschutz Schnittstelle-IRUE_NGS_Deaktivierung_via_MMI,not active ,6
ENG253197-ENG261022-Diebstahlschutz Schnittstelle-Irue_verbaut,not installed ,6
ENG253197-ENG261072-Diebstahlschutz Schnittstelle-Sirene_alarmzahl,10_Alarme ,6
ENG253197-ENG260442-Diebstahlschutz Schnittstelle-Verbau_Deaktivierungstaster_DWA_Sensor,not active ,6
ENG253244-MAS10115-Diebstahlschutz.Modulsoftware-Anti-theft blinkers by inter. door handle activ.,OFF ,6
ENG253244-MAS31160-Diebstahlschutz.Modulsoftware-OBD monitoring,not active ,6
ENG253244-ENG258423-Diebstahlschutz.Modulsoftware-Akustischer Alarm ueber Hupe,active ,6
ENG253244-ENG258401-Diebstahlschutz.Modulsoftware-Anhaengerueberwachung_aktiv,not active ,6
ENG253244-ENG146510-Diebstahlschutz.Modulsoftware-beeptime,5_ms ,6
ENG253244-ENG260066-Diebstahlschutz.Modulsoftware-dwa_alarm_ton,frequency_modulated ,6
ENG253244-ENG258606-Diebstahlschutz.Modulsoftware-DWA_campermode,not active ,6
ENG253244-ENG260322-Diebstahlschutz.Modulsoftware-DWA_Verdeckoeffnungsueberwachung_aktiv,not active ,6
ENG253244-ENG261182-Diebstahlschutz.Modulsoftware-IRUE_NGS_bewusst_entschaerfen,active ,6
ENG253365-ENG260723-Dienste-BeeinflussungStartStopp_aktiv,According to function requirements ,4
ENG253365-ENG258656-Dienste-BereichsueberwachungPilotiertesParken_aktiv,not activated ,4
ENG253365-ENG259029-Dienste-EntryGoDeaktivierung_Nutzerkonfiguration_aktiv,activated ,4
ENG253365-ENG260489-Dienste-EntryGoDeaktivierung_Quittierung_aktiv,not activated ,4
ENG253365-ENG260124-Dienste-Keyfinder_Aussen_aktiv,not activated ,4
ENG253365-ENG259116-Dienste-Keyfinder_Innen_aktiv,not activated ,4
ENG253144-ENG259520-Dimmung (der Suchbeleuchtung Kl. 58)-p_delta_KL58D_min,0.0 %,21
ENG253144-ENG253461-Dimmung (der Suchbeleuchtung Kl. 58)-p_Fehlerwert_Kl_58xd,0 %,21
ENG253144-ENG253462-Dimmung (der Suchbeleuchtung Kl. 58)-p_Fehlerwert_Kl_58xs,0 %,21
ENG253144-ENG253463-Dimmung (der Suchbeleuchtung Kl. 58)-p_Fehlerwert_Kl_58xt,0 %,21
ENG253144-ENG259127-Dimmung (der Suchbeleuchtung Kl. 58)-p_Kl_58xk_Schrittanzahl_kurzer_Tastendruck,0 ,21
ENG253144-ENG261206-Dimmung (der Suchbeleuchtung Kl. 58)-p_kl58d_poti_uin_max,0.0 %,21
ENG253144-ENG258780-Dimmung (der Suchbeleuchtung Kl. 58)-p_kl58d_poti_uin_min,0.0 %,21
ENG253144-ENG259198-Dimmung (der Suchbeleuchtung Kl. 58)-p_kl58d_poti_uin_tol,0.0 %,21
ENG253144-ENG261308-Dimmung (der Suchbeleuchtung Kl. 58)-p_langer_Tastendruck,0.0 s,21
ENG253144-ENG260197-Dimmung (der Suchbeleuchtung Kl. 58)-p_timer_Kl_58xs_Nachlauf_lang,900 s,21
ENG253144-ENG261144-Dimmung (der Suchbeleuchtung Kl. 58)-p_timer_Kl_58xt_Nachlauf_kurz,30 s,21
ENG253144-ENG258180-Dimmung (der Suchbeleuchtung Kl. 58)-p_timer_Netz_Nachlauf_Master,10 min,21
ENG253144-ENG253464-Dimmung (der Suchbeleuchtung Kl. 58)-p_timer_Netz_Nachlauf_Slave,0 min,21
ENG394997-ENG395060-DLI_AFS_BAP_Configuration-BAP_Brand,VW ,2
ENG394997-ENG395061-DLI_AFS_BAP_Configuration-BAP_DKL_Menu,Enabled ,2
ENG394997-ENG395062-DLI_AFS_BAP_Configuration-BAP_LWR_Menu,CAN_automatic ,2
ENG394997-ENG395063-DLI_AFS_BAP_Configuration-BAP_Market,NAR ,2
ENG394997-ENG395064-DLI_AFS_BAP_Configuration-BAP_Touristlight_Menu,not_enabled ,2
ENG394997-ENG403476-DLI_AFS_BAP_Configuration-BAP_Traffic_Side,right_hand_traffic ,2
ENG394998-ENG395106-DLI_FLA-DLA_BAP_Configuration-FLA_DLA_Delay,800 ms,6
ENG394998-ENG403533-DLI_FLA-DLA_BAP_Configuration-FLA_DLA_Lastmode_Deactivation,not_active ,6
ENG394998-ENG395108-DLI_FLA-DLA_BAP_Configuration-FLA_DLA_Menu,not_active ,6
ENG394998-ENG403534-DLI_FLA-DLA_BAP_Configuration-FLA_DLA_Menu_Default_Setting,active ,6
ENG286143-IDE00047-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Parameter set version,0 ,37
ENG286143-IDE80001-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 1,1 ,37
ENG286143-IDE80002-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 2,1 ,37
ENG286143-IDE80003-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 3,0 ,37
ENG286143-IDE80004-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 4,1 ,37
ENG286143-IDE80005-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 5,25 ,37
ENG286143-IDE80006-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 6,40 ,37
ENG286143-IDE80007-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 7,16 ,37
ENG286143-IDE80008-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 8,125 ,37
ENG286143-IDE80009-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 9,3 ,37
ENG286143-IDE80010-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 10,2 ,37
ENG286143-IDE80011-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 11,4 ,37
ENG286143-IDE80012-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 12,2 ,37
ENG286143-IDE80013-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 13,120 ,37
ENG286143-IDE80014-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 14,5 ,37
ENG286143-IDE80015-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 15,5 ,37
ENG286143-IDE80016-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 16,0 ,37
ENG286143-IDE80017-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 17,0 ,37
ENG286143-IDE80018-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 18,0 ,37
ENG286143-IDE80019-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 19,0 ,37
ENG286143-IDE80020-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 20,active ,37
ENG286143-IDE80021-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 21,not active ,37
ENG286143-IDE80022-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 22,not active ,37
ENG286143-IDE80023-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 23,Bottom ,37
ENG286143-IDE80024-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 24,static ,37
ENG286143-IDE80025-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 25,3 ,37
ENG286143-IDE80026-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 26,not active ,37
ENG286143-IDE80027-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 27,Dynamic ,37
ENG286143-IDE80028-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 28,7 ,37
ENG286143-IDE80029-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 29,6 ,37
ENG286143-IDE80030-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 30,active ,37
ENG286143-IDE80031-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 31,25 ,37
ENG286143-IDE80032-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 32,2 ,37
ENG286143-IDE80033-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 33,12 ,37
ENG286143-IDE80034-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 34,0 ,37
ENG286143-IDE80035-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 35,Do not reset ,37
ENG286143-IDE80036-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 36,16 ,37
ENG286143-IDE80037-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 37,16 ,37
ENG286143-IDE80038-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 38,16 ,37
ENG286143-IDE80039-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 39,16 ,37
ENG286143-IDE80040-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 40,2 ,37
ENG286143-IDE80041-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 41,31 ,37
ENG286143-IDE80042-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 42,2 ,37
ENG286143-IDE80043-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 43,31 ,37
ENG286143-IDE80044-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 44,224 ,37
ENG286143-IDE80045-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 45,10 ,37
ENG286143-IDE80046-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 46,10 ,37
ENG286143-IDE80047-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 47,0 ,37
ENG286143-IDE80048-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 48,0 ,37
ENG286143-IDE80049-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 49,0 ,37
ENG286143-IDE80050-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 50,0 ,37
ENG286143-IDE80051-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 51,6 ,37
ENG286143-IDE80052-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 52,25 ,37
ENG286143-IDE80053-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 53,255 ,37
ENG286143-IDE80054-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 54,5 ,37
ENG286143-IDE80055-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 55,60 ,37
ENG286143-IDE80056-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 56,238 ,37
ENG286143-MAS01078-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Vehicle model,0 ,37
ENG286143-MAS14087-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-time delay activation,not active ,37
ENG118777-ENG118708-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Request_Repetition_Time_Adaptation,255000 ms,12
ENG118777-ENG118703-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Toogle_Time_Adaptation,500 ms,12
ENG253243-ENG286261-Easy Open-p_a_Schiebetürentriegelung_durch_VIP_bei_Tankklappe_offen,not active ,4
ENG253243-ENG258420-Easy Open-p_a_VIP_Freigabeentzug_bei_Anhaenger,active ,4
ENG253243-ENG258644-Easy Open-Virtuelles_Pedal_Aktiv_Kl_15,not active ,4
ENG253243-ENG259016-Easy Open-Virtuelles_Pedal_Aktiv_Kl_S,active ,4
ENG253243-ENG260097-Easy Open-Virtuelles_Pedal_Aktiv_Motorlauf,not active ,4
ENG253243-ENG286386-Easy Open-Virtuelles_Pedal_Schiebetüren_Aktiv_Kl_15,not active ,4
ENG253243-ENG286387-Easy Open-Virtuelles_Pedal_Schiebetüren_Aktiv_Kl_S,active ,4
ENG253243-ENG286388-Easy Open-Virtuelles_Pedal_Schiebetüren_Aktiv_Motorlauf,not active ,4
ENG129029-ENG258264-Easy_close_alignment-delta_rssi_hysterese,5 ,15
ENG129029-ENG260847-Easy_close_alignment-min_HD_Oeffungswinkel,70 %,15
ENG129029-ENG259133-Easy_close_alignment-min_HD_Oeffungswinkel_Rev,10 %,15
ENG129029-ENG259801-Easy_close_alignment-VIT_AktivTasteB,2.0 s,15
ENG129029-ENG259762-Easy_close_alignment-VIT_RSSI_Verlassensscans,20.0 s,15
ENG129029-ENG260687-Easy_close_alignment-VIT_RSSI_Wiedereintrittscans,7.0 s,15
ENG166045-ENG258452-EASYCLOSE-EasyCloseAktiv,activated ,4
ENG166045-ENG260520-EASYCLOSE-ECL_ext_verriegeln,not activated ,4
ENG166045-ENG248655-EASYCLOSE-ECL_Start_ueber_ViP,activated ,4
ENG253250-ENG130581-Fahrlichthinweis-Fahrlicht_Hinweis_mehrfach,not active ,4
ENG253250-ENG126818-Fahrlichthinweis-Fahrlichtwarnung_Hinweis_Konfig,Hinweis_in_LDS-Stellung_Null_und_SL ,4
ENG171911-ENG263558-Funk-FFB Batteriewarnung unterdruecken,not active ,4
ENG171911-ENG141957-Funk-Radio freq.,MQB37w: 434 MHz RdW + NAR (2-kanalig) ,4
ENG253288-Grundparameter SPN-,10000 ms,30
ENG253288-ENG126955-Grundparameter SPN-duration_to_ZAT_continuous_actuation_detection,1000 ms,30
ENG253288-ENG129005-Grundparameter SPN-duration_to_ZAT_multi_actuation_detection,3000 ms,30
ENG253288-ENG129008-Grundparameter SPN-Speed_threshold_for_terminal_15_emergency_shutoff,7.0 km/h,30
ENG253288-ENG126952-Grundparameter SPN-time_ZAT_lock_after emergency_shutoff,1000 ms,30
ENG253288-ENG126953-Grundparameter SPN-time_ZAT_lock_after_normal_shutoff,500 ms,30
ENG253271-ENG259280-GW_Content_list-Bus_ID,00 ,96
ENG253271-ENG253458-GW_Content_list-Node_address,00 00 ,96
ENG253173-ENG259645-IDGeber_Suche-Innenraumsuche_Kl15_aktiv,activated ,4
ENG253173-ENG261236-IDGeber_Suche-Innenraumsuche_Kl15_Triggerung_aktiv,activated ,4
ENG253173-ENG260685-IDGeber_Suche-Innenraumsuche_Kl15_TuerenKlappenFenster_auch_vor_erstem_Anfahren,activated ,4
ENG253173-ENG258195-IDGeber_Suche-Innenraumsuche_Wiederentriegelung_Heck_aktiv,activated ,4
ENG253173-ENG260525-IDGeber_Suche-Innenraumsuche_Wiederentriegelung_Komfortschliessen_aktiv,activated ,4
ENG253173-ENG258977-IDGeber_Suche-Innenraumsuche_Wiederentriegelung_NFZ_aktiv,activated ,4
ENG253173-ENG258651-IDGeber_Suche-Innenraumsuche_Wiederentriegelung_TriggerVariante,activated ,4
ENG253173-ENG261351-IDGeber_Suche-Innenraumsuche_Wiederentriegelung_Tueren_aktiv,activated ,4
ENG253070-MAS14172-Intelligente Heckleuchte-Parametierung-Brake light larger area,not active ,23
ENG253070-MAS14173-Intelligente Heckleuchte-Parametierung-Brake light smaller area,not active ,23
ENG253070-MAS30817-Intelligente Heckleuchte-Parametierung-Minimum duration of activity for brake light reduction,0 ms,23
ENG253070-ENG259403-Intelligente Heckleuchte-Parametierung-p_Abstand_BRL_Aktivierung,0.00 m,23
ENG253070-ENG260952-Intelligente Heckleuchte-Parametierung-p_Abstand_BRL_Deaktivierung,0.00 m,23
ENG253070-ENG259366-Intelligente Heckleuchte-Parametierung-p_adaptive_helligkeitsanpassung,not active ,23
ENG253070-ENG260454-Intelligente Heckleuchte-Parametierung-p_beschleunigung_BRL_dauer,0 ms,23
ENG253070-ENG260199-Intelligente Heckleuchte-Parametierung-p_beschleunigung_BRL_schwelle,-16.00000 m/s²,23
ENG253070-ENG260962-Intelligente Heckleuchte-Parametierung-p_CHO_LHO_statisch,not active ,23
ENG253070-ENG259731-Intelligente Heckleuchte-Parametierung-p_LH_Diag_LED_def_inaktiv,not active ,23
ENG253070-ENG259241-Intelligente Heckleuchte-Parametierung-p_LH_Diag_Status_def_inaktiv,not active ,23
ENG253070-ENG260043-Intelligente Heckleuchte-Parametierung-p_LH_zusatzschlussl_def_deaktiv,not active ,23
ENG253070-ENG260406-Intelligente Heckleuchte-Parametierung-p_LS_helligkeit_schwelle_dunkel,0 lx,23
ENG253070-ENG260839-Intelligente Heckleuchte-Parametierung-p_LS_helligkeit_schwelle_hoch,0 lx,23
ENG253070-ENG258451-Intelligente Heckleuchte-Parametierung-p_SHL_Anim_LTM_Auto,not active ,23
ENG253070-ENG259407-Intelligente Heckleuchte-Parametierung-p_SHL_AnimDimm_Freigabe_KL15aus,0 ,23
ENG253070-ENG260457-Intelligente Heckleuchte-Parametierung-p_SHL_AnimDimm_Freigabe_KL15ein,0 ,23
ENG253070-ENG259766-Intelligente Heckleuchte-Parametierung-p_SHL_dynamisch,not active ,23
ENG253070-ENG258437-Intelligente Heckleuchte-Parametierung-p_v_BRL_Aktivierung,0 km/h,23
ENG253070-ENG258439-Intelligente Heckleuchte-Parametierung-p_v_BRL_Deaktivierung,0 km/h,23
ENG253070-ENG261315-Intelligente Heckleuchte-Parametierung-p_v_SHL_dynamisch_level_aus,0 km/h,23
ENG253070-ENG259510-Intelligente Heckleuchte-Parametierung-p_v_SHL_dynamisch_level_ein,0 km/h,23
ENG253039-MAS06614-Intelligente Heckleuchte-Verbau-Variant,0 ,4
ENG253039-MAS21321-Intelligente Heckleuchte-Verbau-Audi parking system installed,not installed ,4
ENG253039-ENG345762-Intelligente Heckleuchte-Verbau-LIN_SBBR_full_e2e,not active ,4
ENG253039-ENG261019-Intelligente Heckleuchte-Verbau-pa_Deaktivierung_KZL_iSBBR,active ,4
ENG253039-ENG260486-Intelligente Heckleuchte-Verbau-pa_Deaktivierung_NSL_iSBBR,active ,4
ENG253039-ENG260357-Intelligente Heckleuchte-Verbau-pa_Deaktivierung_RFL_iSBBR,not active ,4
ENG369149-ENG369628-Kessy_MDK_Automatikfunktion_Quittierung-p_n_beep_time_auto_ver_abbruchquittierung,60_ms ,8
ENG369149-ENG369629-Kessy_MDK_Automatikfunktion_Quittierung-p_n_beep_typ_auto_ver_abbruchquittierung,2 ,8
ENG369149-ENG369630-Kessy_MDK_Automatikfunktion_Quittierung-p_t_Kessy_auto_ver_abbruchquittierung_Anzeit_Einfachhorn,10 ms,8
ENG369149-ENG369631-Kessy_MDK_Automatikfunktion_Quittierung-p_t_Kessy_auto_ver_abbruchquittierung_Auszeit_Einfachhorn,490 ms,8
ENG253388-ENG174170-Kessyfunktion-central_locking_system_selective_sigle_door_kessy_NAR,active ,4
ENG253388-ENG259401-Kessyfunktion-Gesamtoeffnung_ueber_Kessy,active ,4
ENG253388-ENG258623-Kessyfunktion-Heck_wiederentriegelung_ohne_Auswurf,active ,4
ENG253388-ENG259486-Kessyfunktion-Komfortbedienung_fh_oeffnen_ueber_kessy,not active ,4
ENG253388-ENG258699-Kessyfunktion-Komfortbedienung_fh_schliessen_ueber_kessy,active ,4
ENG253388-ENG259448-Kessyfunktion-Verriegeln_ueber_Toggle_nur_bei_Aussenhaut_geschlossen,not active ,4
ENG253388-ENG259117-Kessyfunktion-Wiederentriegelung_komplett,not_active ,4
ENG253388-ENG260947-Kessyfunktion-ZV_Kessy_Toggle_Taster_aktiv,not active ,4
ENG253050-Kundendienstparameter,800 ms,8
ENG174381-IDE14618-light_control-Intersection assistant function status,not active ,4
ENG174381-IDE18362-light_control-Park Assist plus / with remote control  activating the turn signal: status,active ,4
ENG174381-MAS07990-light_control-Comfort flasher,active ,4
ENG174381-MAS07991-light_control-Comfort flasher set point,3 ,4
ENG174381-MAS12415-light_control-Parking lamp indicator lamp,integriert in Suchbeleuchtung ,4
ENG174381-MAS14253-light_control-Confirmation flashing,active ,4
ENG174381-MAS21313-light_control-Blinker signature,active ,4
ENG174381-MAS21315-light_control-Convenience flashing cancellation,active ,4
ENG174381-ENG259632-light_control-Abschaltung_Designlicht_bei Eco-Mode,not active ,4
ENG174381-ENG258976-light_control-Abschaltung_Designlicht2_bei_BAP-Abschaltung,not active ,4
ENG174381-ENG278462-light_control-Auswahl_FPA_Eco_Mode,0 ,4
ENG174381-ENG142188-light_control-bewusstes Standlicht,Aktive Begrenzung ,4
ENG174381-ENG289597-light_control-Designlicht_2_ist_PO-Licht,not active ,4
ENG174381-ENG259892-light_control-Designlicht_ist_PO-Licht,not active ,4
ENG174381-ENG154711-light_control-PreCrash_RECAS,not active ,4
ENG174381-ENG259815-light_control-TravelAssist,active ,4
ENG174381-ENG126817-light_control-Umfeldleuchte als Manoevrierleuchte,not active ,4
ENG253274-ENG260814-Lock Unlock Taster-Lock_Unlock_Taster_diskret,not active ,2
ENG253274-ENG258303-Lock Unlock Taster-Lock_Unlock_Taster_Logik,Toggletaster ,2
ENG253274-ENG278453-Lock Unlock Taster-Lock_Unlock_Toggle_Taster_2,active ,2
ENG369156-ENG369620-MDK Automatikfunktionen-p_auto_ZV_Reak_nicht_in_Front_Heck_Zone,not active ,1
ENG369156-ENG369621-MDK Automatikfunktionen-p_auto_ZV_Reak_nicht_nur_in_personalisierter_Zone,not active ,1
ENG369156-ENG369622-MDK Automatikfunktionen-p_auto_ZV_Reak_Tueren_nicht_bei_Front_Heck_Zone,not active ,1
ENG369156-ENG369623-MDK Automatikfunktionen-p_auto_ZV_Reak_ver_mit_SAFE,not active ,1
ENG369156-ENG369624-MDK Automatikfunktionen-p_FBS_Kessy_MDK_auto_entr_quittierung,not active ,1
ENG369156-ENG369625-MDK Automatikfunktionen-p_FBS_Kessy_MDK_auto_ver_Abbruchquittierung,active ,1
ENG369156-ENG369626-MDK Automatikfunktionen-p_FBS_kessy_MDK_auto_ver_ohne_SAFE_quittierung,not active ,1
ENG369156-ENG369627-MDK Automatikfunktionen-p_FBS_Kessy_MDK_auto_ver_quittierung,not active ,1
ENG344857-mdk_funktionaktivierung,not activated ,1
ENG309781-NVEM_function_variant,0 ,1
ENG253051-ENG258966-Par_AutomatikFKT-AutomatikFunktion_Entfernungsschwelle_Wechsel_Zyklus_IDGeberAbwesenheit_Beschleunigtes_Entry,45 dB,27
ENG253051-ENG260817-Par_AutomatikFKT-AutomatikFunktion_Gueltigkeitsdauer_IDGeber_Authentifizierungsstatus_Beschleunigtes_Entry,5.00 s,27
ENG253051-ENG260526-Par_AutomatikFKT-AutomatikFunktionen_Spielschutz_Inkrement,1 ,27
ENG253051-ENG261190-Par_AutomatikFKT-AutomatikFunktionen_Spielschutz_Schwelle,6.0 m,27
ENG253051-ENG258545-Par_AutomatikFKT-AutomatikFunktionen_Spielschutz_Schwelle_Offset,5 ,27
ENG253051-ENG258184-Par_AutomatikFKT-AutomatikFunktionen_Spielschutz_Timeout_Dekrement,60 s,27
ENG253051-ENG260053-Par_AutomatikFKT-AutomatikFunktionen_Spielschutz_Timeout_Inkrement,10 s,27
ENG253051-ENG258738-Par_AutomatikFKT-AutomatikFunktionen_WechselBeiIDGebernInRuhe_Timeout,30 s,27
ENG253051-ENG258350-Par_AutomatikFKT-Automatisches_Verriegeln_Schwelle_FahrendesFzg,20 km/h,27
ENG253051-ENG260570-Par_AutomatikFKT-Automatisches_Verriegeln_Schwelle_StehendesFzg,10 km/h,27
ENG253051-ENG259977-Par_AutomatikFKT-TemporaereSperrungFuerAutomatikFunktionen_Dauer,0 s,27
ENG253220-Par_Bedienstellen,2 ,7
ENG253257-ENG259939-Par_Dienste-Beeinflussung_StartStopp_DauerWiederstart,500 ms,18
ENG253257-ENG259005-Par_Dienste-Beeinflussung_StartStopp_Timeout,500 ms,18
ENG253257-ENG259811-Par_Dienste-Bereichsueberwachung_Pilotiertes_Parken_Timeout,120 s,18
ENG253257-ENG261028-Par_Dienste-EntryGoDeaktivierung_ZweiteBedienhandlung_Timeout,5 s,18
ENG253257-ENG261102-Par_Dienste-Innenraumsuche_GueltigkeitFuerExterneFunktionen,10 s,18
ENG253257-ENG258558-Par_Dienste-Paketbotenmodus_Timeout,15 min,18
ENG253257-ENG259702-Par_Dienste-Signalisierungsdauer_Ergebnis_IDGebersuche_ext_Funktionen,500 ms,18
ENG253257-ENG260866-Par_Dienste-SpielschutzFuerDienste_Dekrement_Timeout,60 s,18
ENG253257-ENG260031-Par_Dienste-SpielschutzFuerDienste_Schwelle,10 ,18
ENG253257-ENG258560-Par_Dienste-VIT_Mindest_Empfangs_Dauer_Betaetigt_Start_Suche,10 ms,18
ENG253386-ENG259497-Par_IDGeberSuche-Innenraumsuche_Kl15_Pause,5000 ms,26
ENG253386-ENG258238-Par_IDGeberSuche-Innenraumsuche_Kl15_Schwelle_FahrendesFzg,20 km/h,26
ENG253386-ENG260811-Par_IDGeberSuche-Innenraumsuche_Kl15_Schwelle_FensterGeschlossen,5.0 %,26
ENG253386-ENG258295-Par_IDGeberSuche-Innenraumsuche_Kl15_Schwelle_SADGeschlossen,1 %,26
ENG253386-ENG259267-Par_IDGeberSuche-Innenraumsuche_Kl15_Schwelle_StehendesFzg,10 km/h,26
ENG253386-ENG261289-Par_IDGeberSuche-Innenraumsuche_Kl15_Wiederholungen,5 ,26
ENG253386-ENG260801-Par_IDGeberSuche-Innenraumsuche_verzoegertFFBKomfortschließen,3200 ms,26
ENG253386-ENG260447-Par_IDGeberSuche-Innenraumsuche_Wiederentriegelung_Heck_ZeitfensterFuerRasten,500 ms,26
ENG253386-ENG260184-Par_IDGeberSuche-Innenraumsuche_Wiederentriegelung_Komfortschliessen_SchwelleFuer_FensterOffen,100.0 %,26
ENG253386-ENG260557-Par_IDGeberSuche-Innenraumsuche_Wiederentriegelung_Komfortschliessen_SchwelleFuer_SADOffen,5.0 %,26
ENG253386-ENG258851-Par_IDGeberSuche-SignalisierungFunkkommunikation_Vorlauf,0 ms,26
ENG253236-ENG260747-Par_Passive_EntryExit_Toggle-BewussteGesamtEntriegelung,5000 ms,6
ENG253236-ENG281088-Par_Passive_EntryExit_Toggle-TemporaereSperrungFuerExit_Dauer,0.0 s,6
ENG253236-ENG281089-Par_Passive_EntryExit_Toggle-Verriegelungskontrolle_Dauer,2.0 s,6
ENG253347-ENG258202-Par_RSAD-Box2Box_Zuordnung_RSAD_HL,3 ,20
ENG253347-ENG259350-Par_RSAD-Box2Box_Zuordnung_RSAD_HR,3 ,20
ENG253347-ENG260315-Par_RSAD-Box2Box_Zuordnung_RSAD_IN,1 ,20
ENG253347-ENG260967-Par_RSAD-Box2Box_Zuordnung_RSAD_VL,1 ,20
ENG253347-ENG260395-Par_RSAD-Box2Box_Zuordnung_RSAD_VR,1 ,20
ENG253347-ENG259213-Par_RSAD-maxAbstand_RSAD_innen_Referenzbox,600 cm,20
ENG253347-ENG258615-Par_RSAD-maxAbstand_RSAD_links_rechts,345 cm,20
ENG253347-ENG260439-Par_RSAD-maxAbstand_RSAD_vorne_hinten,600 cm,20
ENG253347-ENG281104-Par_RSAD-minAbstand_RSAD_innen_Referenzbox,210 cm,20
ENG253347-ENG281079-Par_RSAD-minAbstand_RSAD_links_rechts,105 cm,20
ENG253347-ENG281105-Par_RSAD-minAbstand_RSAD_vorne_hinten,210 cm,20
ENG253347-ENG259498-Par_RSAD-RSAD_UWB_aussen_Entfernung,600 cm,20
ENG253347-ENG260842-Par_RSAD-RSAD_UWB_innen_Entfernung,0 cm,20
ENG253347-ENG289610-Par_RSAD-RSAD_UWB_maxAbweichung,45 cm,20
ENG253398-ENG261340-Par_ScanStrat_RetryHandling-anz_GesamtRetries,1 ,18
ENG253398-ENG260989-Par_ScanStrat_RetryHandling-anz_RetriesAuthentifizierung,2 ,18
ENG253398-ENG260903-Par_ScanStrat_RetryHandling-Dynamischer_Anteil_Registering,7 ms,18
ENG253398-ENG259602-Par_ScanStrat_RetryHandling-RetryAuthentifizierung_Entry_UWB,104 ms,18
ENG253398-ENG258787-Par_ScanStrat_RetryHandling-Timeout_Go_Authentifizierungsphase,160 ms,18
ENG253398-ENG260198-Par_ScanStrat_RetryHandling-Wartezeit_Challenge_Retry_Challenge_Entry,6 ms,18
ENG253398-ENG259374-Par_ScanStrat_RetryHandling-Wartezeit_Registering_Challenge_Entry,4 ms,18
ENG253398-ENG261047-Par_ScanStrat_RetryHandling-Wartezeit_Registering_Challenge_Go,35 ms,18
ENG286147-IDE00047-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Parameter set version,0 ,37
ENG286147-IDE80001-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 1,1 ,37
ENG286147-IDE80002-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 2,1 ,37
ENG286147-IDE80003-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 3,0 ,37
ENG286147-IDE80004-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 4,1 ,37
ENG286147-IDE80005-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 5,25 ,37
ENG286147-IDE80006-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 6,40 ,37
ENG286147-IDE80007-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 7,16 ,37
ENG286147-IDE80008-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 8,125 ,37
ENG286147-IDE80009-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 9,3 ,37
ENG286147-IDE80010-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 10,2 ,37
ENG286147-IDE80011-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 11,4 ,37
ENG286147-IDE80012-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 12,2 ,37
ENG286147-IDE80013-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 13,120 ,37
ENG286147-IDE80014-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 14,5 ,37
ENG286147-IDE80015-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 15,5 ,37
ENG286147-IDE80016-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 16,0 ,37
ENG286147-IDE80017-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 17,0 ,37
ENG286147-IDE80018-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 18,0 ,37
ENG286147-IDE80019-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 19,0 ,37
ENG286147-IDE80020-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 20,active ,37
ENG286147-IDE80021-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 21,not active ,37
ENG286147-IDE80022-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 22,not active ,37
ENG286147-IDE80023-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 23,Bottom ,37
ENG286147-IDE80024-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 24,static ,37
ENG286147-IDE80025-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 25,3 ,37
ENG286147-IDE80026-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 26,not active ,37
ENG286147-IDE80027-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 27,Dynamic ,37
ENG286147-IDE80028-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 28,7 ,37
ENG286147-IDE80029-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 29,6 ,37
ENG286147-IDE80030-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 30,active ,37
ENG286147-IDE80031-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 31,25 ,37
ENG286147-IDE80032-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 32,2 ,37
ENG286147-IDE80033-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 33,12 ,37
ENG286147-IDE80034-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 34,0 ,37
ENG286147-IDE80035-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 35,Do not reset ,37
ENG286147-IDE80036-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 36,16 ,37
ENG286147-IDE80037-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 37,16 ,37
ENG286147-IDE80038-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 38,16 ,37
ENG286147-IDE80039-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 39,16 ,37
ENG286147-IDE80040-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 40,2 ,37
ENG286147-IDE80041-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 41,31 ,37
ENG286147-IDE80042-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 42,2 ,37
ENG286147-IDE80043-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 43,31 ,37
ENG286147-IDE80044-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 44,224 ,37
ENG286147-IDE80045-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 45,10 ,37
ENG286147-IDE80046-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 46,10 ,37
ENG286147-IDE80047-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 47,0 ,37
ENG286147-IDE80048-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 48,0 ,37
ENG286147-IDE80049-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 49,0 ,37
ENG286147-IDE80050-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 50,0 ,37
ENG286147-IDE80051-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 51,6 ,37
ENG286147-IDE80052-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 52,25 ,37
ENG286147-IDE80053-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 53,255 ,37
ENG286147-IDE80054-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 54,5 ,37
ENG286147-IDE80055-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 55,60 ,37
ENG286147-IDE80056-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 56,238 ,37
ENG286147-MAS01078-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Vehicle model,0 ,37
ENG286147-MAS14087-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-time delay activation,not active ,37
ENG253136-IDE02456-Passive_EntryExit_Toggle-Passive entry right rear door handle,activated ,8
ENG253136-IDE02457-Passive_EntryExit_Toggle-Passive entry left rear door handle,activated ,8
ENG253136-IDE02458-Passive_EntryExit_Toggle-Passive entry frt.pass. door handle,activated ,8
ENG253136-IDE02459-Passive_EntryExit_Toggle-Passive entry driver door handle,activated ,8
ENG253136-IDE02460-Passive_EntryExit_Toggle-Passive exit right rear door handle,not activated ,8
ENG253136-IDE02461-Passive_EntryExit_Toggle-Passive exit left rear door handle,not activated ,8
ENG253136-IDE02462-Passive_EntryExit_Toggle-Passive exit frt. pass. door handle,activated ,8
ENG253136-IDE02463-Passive_EntryExit_Toggle-Passive exit driver door handle,activated ,8
ENG253136-IDE03178-Passive_EntryExit_Toggle-Unlocking by electr. sliding door,activated ,8
ENG253136-MAS18905-Passive_EntryExit_Toggle-Passive entry via control section rear,not activated ,8
ENG253136-MAS18906-Passive_EntryExit_Toggle-Passive entry by rear sensor,activated ,8
ENG253136-MAS18907-Passive_EntryExit_Toggle-Monitoring of locking by pulling door handle,activated ,8
ENG253136-MAS18912-Passive_EntryExit_Toggle-Passive exit door handle control section rear,not activated ,8
ENG253136-MAS18913-Passive_EntryExit_Toggle-Lock/unlock button on driver door active,not activated ,8
ENG253136-MAS18914-Passive_EntryExit_Toggle-Lock/unlock button on front passenger door active,not activated ,8
ENG253136-MAS18915-Passive_EntryExit_Toggle-Lock/unlock button on rear driver side active,not activated ,8
ENG253136-MAS18916-Passive_EntryExit_Toggle-Lock/unlock button on front passenger side active,not activated ,8
ENG253136-MAS18917-Passive_EntryExit_Toggle-Lock/unlock button control section rear active,not activated ,8
ENG253136-ENG259242-Passive_EntryExit_Toggle-TemporaerSperrungFuerExit_aktiv,not activated ,8
ENG253136-ENG260214-Passive_EntryExit_Toggle-Verriegelungskontrolle_Heck_aktiv,not activated ,8
ENG129043-PASSIVE_GO,activated ,4
ENG253336-MAS10512-Schiebedach_ZV-Sunroof module MD1,not installed ,6
ENG253336-ENG260428-Schiebedach_ZV-dachrollo_2_verbaut,not installed ,6
ENG253336-ENG258762-Schiebedach_ZV-dachrollo_verbaut,installed ,6
ENG253336-ENG261040-Schiebedach_ZV-Komfortbedienung_reichweitenbegrenzung_verdeck,not active ,6
ENG253336-ENG259091-Schiebedach_ZV-Komfortbedienung_verdecktaste_aktiv,not active ,6
ENG253336-ENG116647-Schiebedach_ZV-SAD Komfort oeffnen,not active ,6
ENG253336-ENG289611-Schiebedach_ZV-SAD Komfort_oeffnungs_modus,Open ,6
ENG253336-ENG149216-Schiebedach_ZV-SAD_Komfort_schliessen,not active ,6
ENG253336-ENG259548-Schiebedach_ZV-SAD_MD3,not active ,6
ENG253336-ENG259227-Schiebedach_ZV-SAD_t_Freigabe_eFH,600 s,6
ENG253336-ENG258522-Schiebedach_ZV-schiebedach_2_verbaut,not installed ,6
ENG253238-ENG258554-Schluesselkonfiguration-Fahrzeugplattform_MEB_aktiv,activated ,1
ENG253238-ENG258470-Schluesselkonfiguration-Kessy_UWB_Frequenzband_a_aktiv,activated ,1
ENG253238-ENG259650-Schluesselkonfiguration-Kessy_UWB_Frequenzband_b_aktiv,activated ,1
ENG253238-ENG261161-Schluesselkonfiguration-Kessy_UWB_Frequenzband_c_aktiv,activated ,1
ENG253118-IDE02851-Schlüsselpositionsnachbildung (SPN)-S-contact shut-off after timeout,Yes ,31
ENG253118-ENG126943-Schlüsselpositionsnachbildung (SPN)-Display_duration_emergency_off,3000 ms,31
ENG253118-ENG126944-Schlüsselpositionsnachbildung (SPN)-Display_duration_error_mode_2_SPN,10 s,31
ENG253118-ENG277093-Schlüsselpositionsnachbildung (SPN)-Evaluation_Klemmenkoordinator,Yes ,31
ENG253118-ENG260573-Schlüsselpositionsnachbildung (SPN)-Evaluation_Trigger_FZE,Yes ,31
ENG253118-ENG277094-Schlüsselpositionsnachbildung (SPN)-Evaluation_Trigger_FZE_For_Terminal_S_Deactivation,Yes ,31
ENG253118-ENG281075-Schlüsselpositionsnachbildung (SPN)-Max_Number_Of_Startrequests_per_Terminal15_Cycle,5 ,31
ENG253118-ENG126945-Schlüsselpositionsnachbildung (SPN)-min_time_for_Terminal_50_request,200 ms,31
ENG253118-ENG129003-Schlüsselpositionsnachbildung (SPN)-Number_of_Multiple_ZAT_activations_to_emergency_shutoff,2 ,31
ENG253118-ENG261165-Schlüsselpositionsnachbildung (SPN)-send_duration_virtual_ZAT_actuation,0.10 s,31
ENG253118-ENG126946-Schlüsselpositionsnachbildung (SPN)-Terminal_S_Timeout,30 min,31
ENG253118-ENG258251-Schlüsselpositionsnachbildung (SPN)-time_to_ignore_clampcoordinator_trigger,1000 ms,31
ENG253118-ENG126947-Schlüsselpositionsnachbildung (SPN)-time_to_ignore_ignition_trigger,35 s,31
ENG253118-ENG281067-Schlüsselpositionsnachbildung (SPN)-time_to_shutoff_clamp15_automatically,30 min,31
ENG253118-ENG277121-Schlüsselpositionsnachbildung (SPN)-Vehicle Deactivation after Timeout,Yes ,31
ENG253118-ENG261202-Schlüsselpositionsnachbildung (SPN)-Vehicle_activation_Deactivation_via_Hybrid,Yes ,31
ENG253118-ENG258331-Schlüsselpositionsnachbildung (SPN)-Vehicle_activation_Deactivation_via_ZAT,No ,31
ENG253118-ENG277122-Schlüsselpositionsnachbildung (SPN)-Vehicle_Deactivation_Brake_Evaluation,Yes ,31
ENG253118-ENG277123-Schlüsselpositionsnachbildung (SPN)-Vehicle_Deactivation_Trigger_Belt_DrivingPositionP_Active,Yes ,31
ENG141635-ENG260621-Spiegelverstellung-cp_Komfortbedienung_Spiegel_anklappen,not active ,3
ENG141635-ENG149222-Spiegelverstellung-Menuesteuerung_Funk_Spiegel_anklappen,active ,3
ENG141635-ENG258306-Spiegelverstellung-Menuesteuerung_Spiegelabsenkung,active ,3
ENG141635-ENG259505-Spiegelverstellung-Menuesteuerung_synchrone_Spiegelverstellung,active ,3
ENG141635-ENG149218-Spiegelverstellung-Spiegelabsenkung_bei_Rueckwaertsfahrt,active ,3
ENG141635-ENG260424-Spiegelverstellung-Spiegelanklappen_bei_Verriegelung,active ,3
ENG141635-ENG260252-Spiegelverstellung-Spiegelverstellung_Synchron,active ,3
ENG141663-ENG258796-Suchbeleuchtung_allgemein-Eingabemedium Suchbeleuchtung von ALM,not active ,21
ENG141663-ENG142242-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Abdimmen,8.0 s,21
ENG141663-ENG142241-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Aufdimmen,9.6 s,21
ENG141663-ENG142243-Suchbeleuchtung_allgemein-pa_Hysterese_RLS,11 ,21
ENG141663-ENG260116-Suchbeleuchtung_allgemein-Suchbeleuchtung PSO2.0 Teilnehmer,active ,21
ENG141663-ENG142234-Suchbeleuchtung_allgemein-Umgebungs_helligkeit_auswahl,Fotosensor_RLS ,21
ENG141667-ENG100773-Suchbeleuchtung_Fotosensor-Y3,200 lx,22
ENG141667-ENG100631-Suchbeleuchtung_Fotosensor-Y4,500 lx,22
ENG141667-ENG102174-Suchbeleuchtung_Fotosensor-Y5,0 lx,22
ENG141674-ENG115658-Suchbeleuchtung_KL_58xd_log_Bus-x0,0.0 ,12
ENG141674-ENG101574-Suchbeleuchtung_KL_58xd_log_Bus-X1,6.0 ,12
ENG141674-ENG99557-Suchbeleuchtung_KL_58xd_log_Bus-X2,16.0 ,12
ENG141674-ENG102140-Suchbeleuchtung_KL_58xd_log_Bus-X3,30.0 ,12
ENG141674-ENG102936-Suchbeleuchtung_KL_58xd_log_Bus-X4,60.0 ,12
ENG141674-ENG103548-Suchbeleuchtung_KL_58xd_log_Bus-X5,100.0 ,12
ENG153969-ENG115658-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-x0,0.0 ,10
ENG153969-ENG101574-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-X1,8.0 ,10
ENG153969-ENG99557-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-X2,50.0 ,10
ENG153969-ENG102140-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-X3,80.0 ,10
ENG153969-ENG102936-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-X4,100.0 ,10
ENG153969-ENG115659-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-y0,6.0 %,10
ENG153969-ENG99777-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-Y1,6.0 %,10
ENG153969-ENG100480-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-Y2,20.0 %,10
ENG153969-ENG100773-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-Y3,50.0 %,10
ENG153969-ENG100631-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-Y4,100.0 %,10
ENG253155-ENG115658-Suchbeleuchtung_KL_58xs_max-x0,0 lx,8
ENG253155-ENG101574-Suchbeleuchtung_KL_58xs_max-X1,8 lx,8
ENG253155-ENG99557-Suchbeleuchtung_KL_58xs_max-X2,50 lx,8
ENG253155-ENG102140-Suchbeleuchtung_KL_58xs_max-X3,500 lx,8
ENG253155-ENG115659-Suchbeleuchtung_KL_58xs_max-y0,100.0 ,8
ENG253155-ENG99777-Suchbeleuchtung_KL_58xs_max-Y1,100.0 ,8
ENG253155-ENG100480-Suchbeleuchtung_KL_58xs_max-Y2,100.0 ,8
ENG253155-ENG100773-Suchbeleuchtung_KL_58xs_max-Y3,100.0 ,8
ENG253251-ENG115658-Suchbeleuchtung_KL_58xs_min-x0,0 lx,8
ENG253251-ENG101574-Suchbeleuchtung_KL_58xs_min-X1,8 lx,8
ENG253251-ENG99557-Suchbeleuchtung_KL_58xs_min-X2,50 lx,8
ENG253251-ENG102140-Suchbeleuchtung_KL_58xs_min-X3,500 lx,8
ENG253251-ENG115659-Suchbeleuchtung_KL_58xs_min-y0,6.0 ,8
ENG253251-ENG99777-Suchbeleuchtung_KL_58xs_min-Y1,6.0 ,8
ENG253251-ENG100480-Suchbeleuchtung_KL_58xs_min-Y2,100.0 ,8
ENG253251-ENG100773-Suchbeleuchtung_KL_58xs_min-Y3,100.0 ,8
ENG153971-ENG115658-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-x0,0.0 ,10
ENG153971-ENG101574-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-X1,8.0 ,10
ENG153971-ENG99557-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-X2,50.0 ,10
ENG153971-ENG102140-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-X3,80.0 ,10
ENG153971-ENG102936-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-X4,100.0 ,10
ENG153971-ENG115659-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-y0,6.0 %,10
ENG153971-ENG99777-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-Y1,6.0 %,10
ENG153971-ENG100480-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-Y2,20.0 %,10
ENG153971-ENG100773-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-Y3,50.0 %,10
ENG153971-ENG100631-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-Y4,100.0 %,10
ENG253314-ENG115658-Suchbeleuchtung_KL_58xt_min-x0,0 lx,8
ENG253314-ENG101574-Suchbeleuchtung_KL_58xt_min-X1,8 lx,8
ENG253314-ENG99557-Suchbeleuchtung_KL_58xt_min-X2,50 lx,8
ENG253314-ENG102140-Suchbeleuchtung_KL_58xt_min-X3,500 lx,8
ENG253314-ENG115659-Suchbeleuchtung_KL_58xt_min-y0,6.0 ,8
ENG253314-ENG99777-Suchbeleuchtung_KL_58xt_min-Y1,6.0 ,8
ENG253314-ENG100480-Suchbeleuchtung_KL_58xt_min-Y2,100.0 ,8
ENG253314-ENG100773-Suchbeleuchtung_KL_58xt_min-Y3,100.0 ,8
ENG141680-ENG115658-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-x0,0 lx,24
ENG141680-ENG101574-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X1,200 lx,24
ENG141680-ENG99557-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X2,400 lx,24
ENG141680-ENG102140-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X3,600 lx,24
ENG141680-ENG102936-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X4,800 lx,24
ENG141680-ENG103548-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X5,1021 lx,24
ENG141680-ENG115659-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-y0,0 ,24
ENG141680-ENG99777-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y1,160 ,24
ENG141680-ENG100480-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y2,300 ,24
ENG141680-ENG100773-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y3,380 ,24
ENG141680-ENG100631-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y4,440 ,24
ENG141680-ENG102174-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y5,500 ,24
ENG252991-Vehicle configuration,activated ,1
ENG159625-ENG142259-Virtual pedal-Kick_and_close,not installed ,8
ENG159625-ENG286258-Virtual pedal-Kick_and_close_HBFS,installed ,8
ENG159625-ENG286259-Virtual pedal-Kick_and_close_HFS,installed ,8
ENG159625-ENG115869-Virtual pedal-Virtuelles_Pedal,active ,8
ENG159625-ENG259761-Virtual pedal-Virtuelles_Pedal_HMI_Auswahl,active ,8
ENG159625-ENG126611-Virtual pedal-virtuelles_pedal_HMI_einstellbar,active ,8
ENG253214-ENG261193-Virtuelles_Pedal_Global-Bremslichtquittierung,not active ,4
ENG253214-ENG261115-Virtuelles_Pedal_Global-Bremslichtquittierung bei offenem Heckdeckel bzw. -klappe,not active ,4
ENG253214-ENG259151-Virtuelles_Pedal_Global-Quittierungslicht_Max,5000 ms,4
ENG253214-ENG273673-Virtuelles_Pedal_Global-Sperrzeit_Bewertung_Spotlight,0 ms,4
ENG253214-ENG286384-Virtuelles_Pedal_Global-Virtuelles_Pedal_HBFS_Verbau,installed ,4
ENG253214-ENG286385-Virtuelles_Pedal_Global-Virtuelles_Pedal_HFS_Verbau,installed ,4
ENG253214-ENG142257-Virtuelles_Pedal_Global-Virtuelles_Pedal_Verbau,installed ,4
ENG253137-ENG258992-VLK_parameter-activation lock reasonability,active ,15
ENG253137-ENG282034-VLK_parameter-activation of warning workshop in failure state for roll away prevention,active ,15
ENG253137-ENG260782-VLK_parameter-automatic ignition deactivation by energy management,Available ,15
ENG253137-ENG260050-VLK_parameter-delay to reset lock trigger for automatic turn off by door lock,1 s,15
ENG253137-ENG258700-VLK_parameter-Delay until automatic switch off over Energymanagement occurs,60 s,15
ENG253137-ENG259502-VLK_parameter-delay until parking light is turned off,15.0 min,15
ENG253137-ENG260648-VLK_parameter-maximum duration to recognize stasis,1.0 s,15
ENG253137-ENG259353-VLK_parameter-maximum vehicle speed to recognize stasis,3.0 km/h,15
ENG253137-ENG260633-VLK_parameter-Posible reset for parking light delay,not_active ,15
ENG253137-ENG281985-VLK_parameter-rollabillity warning,not active ,15
ENG253137-ENG277111-VLK_parameter-time to show LiNa message,10 s,15
ENG253137-ENG277112-VLK_parameter-time to show message no driver detected,10 s,15
ENG253137-ENG259083-VLK_parameter-vehicle speed to detect vehicle movement,3.0 km/h,15
ENG253024-ENG259059-VLK_parameter_2-button delay until rollmode is active,10.0 s,15
ENG253024-ENG259075-VLK_parameter_2-delay to debounce shifter position N,1.0 s,15
ENG253024-ENG277088-VLK_parameter_2-delay until reaction of failure state for input signal of rolling away protection,2.0 s,15
ENG253024-ENG277089-VLK_parameter_2-delay until reaction while HMS failure state,1.0 s,15
ENG253024-ENG282011-VLK_parameter_2-delay until rollingabillity will be reset in VLK production mode,0.5 s,15
ENG253024-ENG277090-VLK_parameter_2-delay until vehicle leaving warning is active,1.0 s,15
ENG253024-ENG259787-VLK_parameter_2-minimum delay until rangier mode ist active,0.2 s,15
ENG253024-ENG277098-VLK_parameter_2-number of allowed changes from popup,2 ,15
ENG253024-ENG277102-VLK_parameter_2-restriction of state change of popup,not active ,15
ENG253024-ENG258435-VLK_parameter_2-rollmode in use,active ,15
ENG253024-ENG258826-VLK_parameter_2-vehiclespeed to confirm N,1.0 km/h,15
ENG278396-MAS03179-Wakeup_cluster_databus_LIN-Local data bus 2,00 00 A0 ,18
ENG278396-MAS03180-Wakeup_cluster_databus_LIN-Local data bus,00 00 00 ,18
ENG278396-MAS05972-Wakeup_cluster_databus_LIN-Local data bus 3,00 00 10 ,18
ENG278396-MAS06525-Wakeup_cluster_databus_LIN-Local data bus 4,00 00 10 ,18
ENG278396-MAS06526-Wakeup_cluster_databus_LIN-Local data bus 5,00 00 00 ,18
ENG278396-MAS06527-Wakeup_cluster_databus_LIN-Local data bus 6,00 00 10 ,18
ENG253287-ENG261269-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_defined_rpm,500.00 /min,11
ENG253287-ENG258373-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_MOSignal_Timer1,3000 ms,11
ENG253287-ENG258259-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_MOsignal_Timer2,3000 ms,11
ENG141651-ENG258596-ZV allgemein-abgesichertes_Safen_aktiv,not active ,6
ENG141651-ENG260901-ZV allgemein-Bedienstellen_tankklappenentriegelung,via_ZV ,6
ENG141651-ENG173067-ZV allgemein-central_locking_system_deadlock_mechanism,safe_function_not_active ,6
ENG141651-ENG259465-ZV allgemein-Funk_bei_Kl15_ein,not active ,6
ENG141651-ENG260878-ZV allgemein-kein_Safe_bei_IRUE_Abwahl,not active ,6
ENG141651-ENG116633-ZV allgemein-Menuesteuerung Tuerentriegelung,active ,6
ENG141651-ENG115755-ZV allgemein-Notschließfunktion,active ,6
ENG141651-ENG261270-ZV allgemein-rollsicherung_ZV_plausibilisierung,not active ,6
ENG141651-ENG260049-ZV allgemein-Rueckmeldung_TKL,not active ,6
ENG141651-ENG116623-ZV allgemein-ZV Tuerentriegelung,Globale_Entriegelung ,6
ENG141651-ENG258274-ZV allgemein-ZV_Verriegelung_ueber_SZ_bei_offener_FT_zulassen,not active ,6
ENG141653-ENG258843-ZV Heck-Direktauswurf_heckdeckel,active ,6
ENG141653-ENG258544-ZV Heck-eingeschränkte_Freigabe_HD_Innentaste,active ,6
ENG141653-ENG260874-ZV Heck-Elektrische_Laderaumabdeckung_Aktiviert,not installed ,6
ENG141653-ENG259200-ZV Heck-Elektrische_Laderaumabdeckung_verbaut,not installed ,6
ENG141653-ENG263593-ZV Heck-HD_Innentaster_bei_ext_verriegelt,not active ,6
ENG141653-ENG259391-ZV Heck-HDF_IT_direkt,via_CAN ,6
ENG141653-ENG260877-ZV Heck-Heck_autolock,active ,6
ENG141653-ENG259349-ZV Heck-Heck_ohne_softtouch,not active ,6
ENG141653-ENG260581-ZV Heck-Heckschloss_mit_VR,Yes ,6
ENG141653-ENG260712-ZV Heck-Heckschloss_rastengesteuert,contact_control_with_least_active_time ,6
ENG141653-ENG259467-ZV Heck-Heckschloss_Typ,1 or 2 notch rear actuator ,6
ENG141653-ENG137162-ZV Heck-Mindestbetaetigung_HDF_Innentaster,0.0 s,6
ENG141653-ENG248302-ZV Heck-unlocking_trunk_lid_via_double_actuation,not active ,6
ENG141653-ENG140934-ZV Heck-valet_parking,not active ,6
ENG141653-ENG258713-ZV Heck-ZV_entriegelt_heckdeckel,active ,6
ENG253049-ENG260834-ZV Komfort_Fensterheber-Ausstiegspanel_Automatiklauf,not active ,8
ENG253049-ENG261010-ZV Komfort_Fensterheber-BAP_komfortschließen_brasilien,not active ,8
ENG253049-ENG259807-ZV Komfort_Fensterheber-el_fh_hinten,installed ,8
ENG253049-ENG116663-ZV Komfort_Fensterheber-Fahrertuerbedienung Fensterheber oeffnen,active ,8
ENG253049-ENG259968-ZV Komfort_Fensterheber-Fensterheber_freigabnachlauf_busruhe,active ,8
ENG253049-ENG258141-ZV Komfort_Fensterheber-Freigabenachlauf_abbruch_bei_tueroeffnen,active ,8
ENG253049-ENG260611-ZV Komfort_Fensterheber-KL_15_aus_fh_freigabenachlauf,active ,8
ENG253049-ENG159639-ZV Komfort_Fensterheber-Komfort_oeffnen,not active ,8
ENG253049-ENG273538-ZV Komfort_Fensterheber-Komfort_schließen,active ,8
ENG253049-ENG258991-ZV Komfort_Fensterheber-Komfortbedienung_ffb_aktiv,active ,8
ENG253049-ENG258982-ZV Komfort_Fensterheber-Komfortbedienung_fh_oeffnen_ueber_funk,active ,8
ENG253049-ENG260329-ZV Komfort_Fensterheber-Komfortbedienung_fh_oeffnen_ueber_sz,active ,8
ENG253049-ENG259463-ZV Komfort_Fensterheber-Komfortbedienung_fh_schliessen_ueber_fh_taster,active ,8
ENG253049-ENG259865-ZV Komfort_Fensterheber-Komfortbedienung_fh_schliessen_ueber_funk,not active ,8
ENG253049-ENG149198-ZV Komfort_Fensterheber-Komfortbedienung_global,active ,8
ENG253049-ENG260481-ZV Komfort_Fensterheber-komfortbedienung_global_hmi,adjustable ,8
ENG253049-ENG259275-ZV Komfort_Fensterheber-Komfortfunktion_im_Transportmodus,not active ,8
ENG253049-ENG116642-ZV Komfort_Fensterheber-Komfortoeffnen nur FH Fahrertuer,not active ,8
ENG253049-ENG155244-ZV Komfort_Fensterheber-Komfortschliessen_Brasilien,not active ,8
ENG263451-ENG252093-ZV NFZ - Elektronische Rueckwandklappe-eRWK_Abbruchblinken_Heck,active ,7
ENG263451-ENG248659-ZV NFZ - Elektronische Rueckwandklappe-eRWK_Abstand_Umfeld_frei,120 cm,7
ENG263451-ENG248660-ZV NFZ - Elektronische Rueckwandklappe-eRWK_Abstand_Umfeld_Nahbereich,20 cm,7
ENG263451-ENG248661-ZV NFZ - Elektronische Rueckwandklappe-eRWK_bei_eingeschraenkter_Oeffnungsweite,not active ,7
ENG263451-ENG248662-ZV NFZ - Elektronische Rueckwandklappe-eRWK_Heck_sperren_bei_Hindernis,active ,7
ENG263451-ENG263534-ZV NFZ - Elektronische Rueckwandklappe-eRWK_Oeffnungsblinken_Heckauswurf,active ,7
ENG263451-ENG248664-ZV NFZ - Elektronische Rueckwandklappe-eRWK_ohne_FFB_HDF,not active ,7
ENG263451-ENG252079-ZV NFZ - Elektronische Rueckwandklappe-eRWK_Pruefung_Umfelderkennung,1.6 s,7
ENG263451-ENG252068-ZV NFZ - Elektronische Rueckwandklappe-eRWK_Start_Umfelderkennung,2.0 s,7
ENG263451-ENG281092-ZV NFZ - Elektronische Rueckwandklappe-pa_eRWK_KST_Sonderzustand_Anf,not active ,7
ENG263491-ENG263568-ZV NFZ - Tueren HBFS-Schiebetuer HBFS,Electrical ,2
ENG263491-ENG258359-ZV NFZ - Tueren HBFS-Schlosstyp HBFS,Unknown (4),2
ENG263491-ENG263538-ZV NFZ - Tueren HBFS-Tuerkontaktmodul HBFS,No ,2
ENG263438-ENG263586-ZV NFZ - Tueren HFS-Schiebetuer HFS,Electrical ,2
ENG263438-ENG258315-ZV NFZ - Tueren HFS-Schlosstyp HFS,Unknown (4),2
ENG263438-ENG263572-ZV NFZ - Tueren HFS-Tuerkontaktmodul HFS,No ,2
ENG252999-ENG260270-ZV Quittierungen-Akustische Quittierungsdauer Einfachhorn,normal ,6
ENG252999-ENG258724-ZV Quittierungen-Komfort_quittung,active ,6
ENG252999-ENG260606-ZV Quittierungen-Quittierton_beim_zweiten_ZV_AUF_Befehl,not active ,6
ENG252999-ENG258550-ZV Quittierungen-Quittierton_beim_zweiten_ZV_ZU_Befehl,active ,6
ENG252999-ENG260511-ZV Quittierungen-Quittierton_global,active ,6
ENG252999-ENG258336-ZV Quittierungen-Quittierungston_bei_entriegeln,not active ,6
ENG252999-ENG263543-ZV Quittierungen-Quittungs_blinken_bei_verriegeln,DELAY ,6
ENG252999-ENG263595-ZV Quittierungen-Quittungs_ton_bei_verriegeln,active ,6
ENG252999-ENG259470-ZV Quittierungen-Quittungston_hmi_einstellbar,active ,6
ENG252999-ENG260257-ZV Quittierungen-Quittungston_ueber_hupe,active ,6
ENG141652-ENG258598-ZV Türkonfiguration-Fzg_mit_Vier_Tueren,No ,2
ENG141652-ENG260173-ZV Türkonfiguration-Schloesser_direkt_gesteuert,Alle Türen via CAN vernetzt ,2
ENG141652-ENG142000-ZV Türkonfiguration-Schlosstyp_NAR,Yes ,2
ENG141652-ENG258913-ZV Türkonfiguration-ZV Schlosstyp,Einmotorenschloss ohne Safe ,2
ENG253276-ENG173074-ZV_Autolock-automatic_unlock_nar,active ,2
ENG253276-ENG116621-ZV_Autolock-automatisches Entriegeln,active ,2
ENG253276-ENG115756-ZV_Autolock-automatisches Verriegeln bei Geschwindigkeit,active ,2
ENG253276-ENG260929-ZV_Autolock-ZV_autolock_autounlock_hmi,not active ,2
ENG253027-ENG173641-ZV_Crash-central_locking_system_emergency_assist,active ,2
ENG253027-ENG259575-ZV_Crash-Verzoegerung_ZV_Entriegelung_bei_Seitencrash,active ,2
ENG278406-IDE05739-zv_icas1-Footwell lamp,installed ,10
ENG278406-ENG278455-zv_icas1-AAG_Fahrradtraeger_Hinweis,not active ,10
ENG278406-ENG278517-zv_icas1-Aktivierung_des_Bedien_und_Anzeigeprotokolls,active ,10
ENG278406-ENG179106-zv_icas1-Autolock_nur_bei_Motorlauf,not installed ,10
ENG278406-ENG171452-zv_icas1-Brand,VW ,10
ENG278406-ENG278498-zv_icas1-can_wakeup_bei_softtouch,active ,10
ENG278406-ENG174170-zv_icas1-central_locking_system_selective_sigle_door_kessy_NAR,not active ,10
ENG278406-ENG278479-zv_icas1-Digital_Key_ZV,NichtUnterstuetzt ,10
ENG278406-ENG278531-zv_icas1-dwa_alarm_delay_quelle,immidiat_driver_door_contact_thatcham ,10
ENG278406-ENG146414-zv_icas1-ffb_kessy_active_for_piloted_parking,not active ,10
ENG278406-ENG278476-zv_icas1-freigabenachlauf_heck_nach_einzeloffnung,not active ,10
ENG278406-ENG147129-zv_icas1-Gearbox,shift_by_wire_gearbox ,10
ENG278406-ENG258623-zv_icas1-Heck_wiederentriegelung_ohne_Auswurf,installed ,10
ENG278406-ENG173162-zv_icas1-keyless_entry_installed,installed ,10
ENG278406-ENG278540-zv_icas1-Kl15_abschaltung_schliesszylinder,not active ,10
ENG278406-ENG259486-zv_icas1-Komfortbedienung_fh_oeffnen_ueber_kessy,not active ,10
ENG278406-ENG258699-zv_icas1-Komfortbedienung_fh_schliessen_ueber_kessy,not active ,10
ENG278406-ENG278494-zv_icas1-komfortbedienung_fh_schliessen_ueber_sz,not active ,10
ENG278406-ENG278490-zv_icas1-komfortbedienung_kessy_aktiv,not active ,10
ENG278406-ENG278475-zv_icas1-komfortbedienung_sz_aktiv,not active ,10
ENG278406-ENG278443-zv_icas1-Lenkerseite,Left ,10
ENG278406-ENG278537-zv_icas1-ocu_unit,installed ,10
ENG278406-ENG278547-zv_icas1-quittungston_bei_entriegeln,not active ,10
ENG278406-ENG278513-zv_icas1-quittungston_global,not active ,10
ENG278406-ENG278521-zv_icas1-rf_in_transport_mode,active ,10
ENG278406-ENG278523-zv_icas1-schlosssteuerung_hinten_sam,active ,10
ENG278406-ENG278496-zv_icas1-schlosssteuerung_hinten_tsg,not active ,10
ENG278406-ENG278465-zv_icas1-Servoheck_Reichweitenbegrenzung_beim_Schliessen,active ,10
ENG278406-ENG278481-zv_icas1-trailer_connection_device,not installed ,10
ENG278406-ENG126564-zv_icas1-virtual_pedal,not active ,10
ENG278406-ENG259117-zv_icas1-Wiederentriegelung_komplett,active ,10
ENG278406-ENG258878-zv_icas1-ZV_Pilopar_aktiv,not active ,10
ENG263427-ENG252063-zv_router_global-Deaktivierung_LS_mit_ext_Ver_Entriegelung,not active ,5
ENG263427-ENG263506-zv_router_global-Elektrischer_SBT_Feststeller_verbaut,not installed ,5
ENG263427-ENG263563-zv_router_global-Elektronische_Kindersicherung_eKiSi,Yes ,5
ENG263427-ENG263551-zv_router_global-FFB_Schiebetuer_entriegelt,No ,5
ENG263427-ENG248688-zv_router_global-Freischaltung_der_Kisi_Auswurffunktion,active ,5
ENG263427-ENG248689-zv_router_global-Freischaltung_KiSi_Taster_bei_extern_verriegeltem_Fahrzeug,not active ,5
ENG263427-ENG248698-zv_router_global-HD_Innentaster_im_Heck,not installed ,5
ENG263427-ENG263588-zv_router_global-Laderaumschliessung_Taster_togglen,not active ,5
ENG263427-ENG263582-zv_router_global-Laderaumtaster_verbaut,not installed ,5
ENG263427-ENG248768-zv_router_global-NFZ_Schliessung,not active ,5
ENG263427-ENG263555-zv_router_global-Schiebetuer_Auswurffunkion_bei_intern_verriegelt,active ,5
ENG263427-ENG263553-zv_router_global-Schiebetuertaste_Armaturentafel_bei extern_verriegelt,not active ,5
ENG263427-ENG133390-zv_router_global-Wiederverriegelung_Laderaum,not installed ,5
Elapsed Time: 01:56
Jef
HQ
adpmap-23-1N3-909-059-AA_WVG5WVEB2SH017765-20250325-1227.CSV
;SW:1N3-909-059-AA   HW:1N3-909-059 ---  Brake Booster
;Component:EBB-ZF-Gen1   H47 0853, Coding:A0404080600028
;EV_BrakeBoostZFMEBUNECE,001034,EV_BrakeBoostZFMEBUNECE.rod
;Tuesday,25,March,2025,12:27:37:58926
;VCDS Version: Release 25.3.0 (x64)  Data version: 20250311 DS365.0
;VCID: 74BAB2C64E354D4A9BE-8020-R SFD+SFD2
IDE00001-IDE09543-Production mode-Vehicle holding function,Deactivating ,3
IDE00001-Production mode-,not active ,3
IDE00820-ENG376444-Activating and deactivating all development messages-Activation of Development Message BKV_00,not activated ,2
IDE00820-ENG376445-Activating and deactivating all development messages-Activation of Development Message BKV_01,not activated ,2
IDE00820-ENG376447-Activating and deactivating all development messages-Activation of Development Message BKV_03,not activated ,2
IDE00820-ENG376448-Activating and deactivating all development messages-Activation of Development Message BKV_04,not activated ,2
IDE00820-ENG376449-Activating and deactivating all development messages-Activation of Development Message BKV_05,not activated ,2
IDE00820-ENG376450-Activating and deactivating all development messages-Activation of Development Message Dynamischer Inhalt_1,not activated ,2
IDE00820-ENG376451-Activating and deactivating all development messages-Activation of Development Message Dynamischer Inhalt_2,not activated ,2
IDE00820-ENG376452-Activating and deactivating all development messages-Activation of Development Message Dynamischer Inhalt_3,not activated ,2
IDE00820-ENG395055-Activating and deactivating all development messages-Activation of Development Message EPB_03,not activated ,2
IDE07159-MAS01155-Control module switch-off: counter-Control module,0 ,2
IDE07159-MAS05583-Control module switch-off: counter-Data bus,1 ,2
IDE07160-IDE15110-Control module switch-off: switch-off time-Coupling shut-off time: data bus with low-voltage energy management,Low-voltage energy management: coupling not available ,2
IDE07160-MAS01155-Control module switch-off: switch-off time-Control module,15 min ,2
IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,15 min ,2
IDE11985-Expected OBD requirements,NO OBD ,1
IDE14698-Parameters of leak test-,13.000000 ,20
IDE14698-Parameters of leak test-,40.000000 ,20
IDE14698-Parameters of leak test-,25 ,20
IDE14698-Parameters of leak test-,0.20 ,20
IDE14698-Parameters of leak test-,0.90 ,20
IDE14698-Parameters of leak test-,3.000000 ,20
IDE14698-Parameters of leak test-,20.00 ,20
IDE14698-Parameters of leak test-,10.00 ,20
IDE14698-Parameters of leak test-,36.000000 ,20
IDE14698-Parameters of leak test-,50 ,20
IDE14698-Parameters of leak test-,4.00 ,20
IDE14698-Parameters of leak test-,12.00 ,20
IDE14699-Parameters of heaviness test-,0.101563 ,13
IDE14699-Parameters of heaviness test-,3.000000 ,13
IDE14699-Parameters of heaviness test-,0 ,13
IDE14699-Parameters of heaviness test-,0.50 ,13
IDE14699-Parameters of heaviness test-,1.299805 ,13
IDE14699-Parameters of heaviness test-,5.000000 ,13
IDE14699-Parameters of heaviness test-,50.000000 ,13
IDE14700-Parameters of ventilation routine-,511.992188 ,18
IDE14700-Parameters of ventilation routine-,255 ,18
IDE14700-Parameters of ventilation routine-,25.50 ,18
IDE16364-IDE16536-List of identifiers and data record numbers-Identifier,00 00 ,2
IDE16364-MAS25708-List of identifiers and data record numbers-Number Of Identifiers,0 ,2
IDE80125-Analysis 125-,Security access required,2
MAS02080-XCP calibration protocol,activated ,1
MAS14035-Precondition,Security access required,1
ENG264022-Developer_Function_01,00 00 ,2
ENG264025-Developer_Function_04,5 ,1
ENG264029-Dynamic_Developer_Function_01,General reject,1
ENG264027-Dynamic_Developer_Function_02,General reject,1
ENG264028-Dynamic_Developer_Function_03,General reject,1
ENG153885-MAS21993-Knockout_test_mode-Return value idle bus,not active ,1
ENG153885-MAS21994-Knockout_test_mode-Veto,not active ,1
ENG153885-MAS21995-Knockout_test_mode-Suppress veto,not active ,1
Elapsed Time: 00:06
adpmap-2B-3WA-905-861_WVG5WVEB2SH017765-20250325-1227.CSV
;SW:3WA-905-861   HW:3WA-905-861 ---  Steer. Col. Lock
;Component:ELV-MQB_UNECE H05 0063, Coding:8880000000000000
;EV_ELVMarqUNECE,003006,EV_ELVMarqUNECE_003_VW27.rod
;Tuesday,25,March,2025,12:27:54:58926
;VCID: 0842F63622BD59AAC76-805C-R SFD+SFD2
IDE00820-Activating and deactivating all development messages,operated ,1
IDE07566-Steering column lock unlocked,unlock ,1
ENG128823-functional_check_manufacturer,tested ,1
ENG128824-functional_check_steering_column_supplier,not tested ,1
Elapsed Time: 00:01
adpmap-36-1N3-959-760-H_WVG5WVEB2SH017765-20250325-1228.CSV
;SW:1N3-959-760-H   HW:1N3-959-760-H ---  Seat Mem. Drvr
;Component:MEM-FS        011 0571, Coding:0118BA4000013A008803010121010000000000000000000000000000215000
;EV_SCMDriveSideCONTIAU736,006013,EV_SCMDriveSideCONTIAU736_VW42.rod
;Tuesday,25,March,2025,12:28:26:58926
;VCID: 3E2E50EE30F9D71ABDA-806A-R
IDE00001-MAS10850-Production mode-Deactivate massage function,not active ,3
IDE00001-MAS18842-Production mode-Assembly mode,not active ,3
IDE00820-MAS02165-Activating and deactivating all development messages-Group 1,not active ,1
IDE00820-MAS02166-Activating and deactivating all development messages-Group 2,not active ,1
IDE00820-MAS05859-Activating and deactivating all development messages-Group 3,not active ,1
IDE00820-MAS05860-Activating and deactivating all development messages-Group 4,not active ,1
IDE00820-MAS05861-Activating and deactivating all development messages-Group 5,not active ,1
IDE00820-MAS05862-Activating and deactivating all development messages-Group 6,not active ,1
IDE00820-MAS05863-Activating and deactivating all development messages-Group 7,not active ,1
IDE00820-MAS05864-Activating and deactivating all development messages-Group 8,not active ,1
IDE02854-Reset standardization,all ,3
IDE03066-Reset counter for compressor for multicontour seat,Activate ,1
IDE06869-installation position,Memory seat driver side ,1
ENG309783-slp_logging,not active ,1
ENG123066-vehicle_velocity_monitoring,active ,1
Elapsed Time: 00:18
adpmap-3C-2Q0-907-686-H_WVG5WVEB2SH017765-20250325-1229.CSV
;SW:2Q0-907-686-H   HW:2Q0-907-686-H ---  Lane Change
;Component:HRE_Master    H26 0320, Coding:5A954750
;EV_HREHellaGen3MstrUNECE,001001,EV_HREHellaGen3MstrUNECE_VW27.rod
;Tuesday,25,March,2025,12:29:01:58926
;VCID: 3FD02DEA37F3DE12B6C-806A-R
Elapsed Time: 00:03
adpmap-42-1EA-959-593-F_WVG5WVEB2SH017765-20250325-1229.CSV
;SW:1EA-959-593-F   HW:1EA-959-593-F ---  Door Elect, Driver
;Component:TSG FS        009 0563, Coding:0035DB20D200028044000020
;EV_DCU3DriveSideMAXHCONT,001004,EV_DCU3DriveSideMAXHCONT_VWE3.rod
;Tuesday,25,March,2025,12:29:21:58926
;VCID: 45DC3F02552F84C2FC0-8010-R
IDE07160-IDE15110-Control module switch-off: switch-off time-Coupling shut-off time: data bus with low-voltage energy management,0 ,2
IDE07160-MAS01155-Control module switch-off: switch-off time-Control module,52 min,2
IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,63 min,2
MAS19336-Active participant function activated,activated ,1
ENG153885-Knockout_test_mode,00000000  ,1
ENG117304-ENG148862-Patch_Code_Driver_Side_Rear-Parameter_1,No Response From Subnet Component,1
ENG117304-ENG148865-Patch_Code_Driver_Side_Rear-Parameter_2,No Response From Subnet Component,1
ENG117302-ENG148862-Window_Regulator_Supplier_Settings_Driver_Side_Rear_1-Parameter_1,No Response From Subnet Component,1
ENG117302-ENG148865-Window_Regulator_Supplier_Settings_Driver_Side_Rear_1-Parameter_2,No Response From Subnet Component,1
ENG117303-ENG148862-Window_Regulator_Supplier_Settings_Driver_Side_Rear_2-Parameter_1,No Response From Subnet Component,1
ENG117303-ENG148865-Window_Regulator_Supplier_Settings_Driver_Side_Rear_2-Parameter_2,No Response From Subnet Component,1
ENG117301-Window_Regulator_VW_Settings_Driver_Side_Rear,No Response From Subnet Component,1
Elapsed Time: 00:04
adpmap-44-1N3-907-144-Q_WVG5WVEB2SH017765-20250325-1229.CSV
;SW:1N3-907-144-Q   HW:1N3-907-144-L ---  Steering Assist
;Component:BASGEN1MQB37  131 7341, Coding:00000000000002010000020101000100000001000101
;EV_SteerAssisBASGEN1MQB37,017078,EV_SteerAssisBASGEN1MQB37.rod
;Tuesday,25,March,2025,12:29:41:58926
;VCID: 3C2A5AE626E5C50A93E-8068-R SFD+SFD2
IDE03724-Straight line running,Active: with learned value ,1
IDE04130-Characteristic curve of steering assistance,Driving profile selection button ,1
IDE06419-Driving profile switchover,Incremental: controlled over time ,1
IDE06678-Pull compensation,Active: without learned value ,1
IDE09571-RPM monitoring,active ,1
IDE14345-Lateral assistant coordinator: parking assist,active ,1
IDE14346-Lateral assistant coordinator: reduced stopping distance,active ,1
IDE14347-Lateral assistance coordinator: lane assist,active ,1
IDE14348-Lateral assistant coordination: counter-steering assist,active ,1
IDE15619-Maneuvering assistant lateral control coordinator,not active ,1
MAS06373-Vehicle variant,E3_1_1_UNECE ,1
MAS09008-Plausibility check,active ,1
Elapsed Time: 00:06
adpmap-47-3G0-035-466-F_WVG5WVEB2SH017765-20250325-1230.CSV
;SW:3G0-035-466-F   HW:3G0-035-466-F ---  Sound System
;Component:AMPeth16CDoIP H03 7012, Coding:24090100000000000000000000000000000000000000000000
;EV_AMPEthMQB37w,001005,EV_AMPEthMQB37w_VW38.rod
;Tuesday,25,March,2025,12:30:01:58926
;VCID: 280296B6C27D79AAE76-807C-R SFD+SFD2
IDE00001-ENG148862-Production mode-Parameter_1,not activated ,3
IDE00001-ENG253433-Production mode-Parameter_10,not activated ,3
IDE00001-ENG253434-Production mode-Parameter_11,not activated ,3
IDE00001-ENG253426-Production mode-Parameter_12,not activated ,3
IDE00001-ENG253427-Production mode-Parameter_13,not activated ,3
IDE00001-ENG253432-Production mode-Parameter_14,not activated ,3
IDE00001-ENG253423-Production mode-Parameter_15,not activated ,3
IDE00001-ENG253430-Production mode-Parameter_16,not activated ,3
IDE00001-ENG253450-Production mode-Parameter_17,not activated ,3
IDE00001-ENG253451-Production mode-Parameter_18,not activated ,3
IDE00001-ENG248484-Production mode-Parameter_19,not activated ,3
IDE00001-ENG253452-Production mode-Parameter_20,not activated ,3
IDE00001-ENG248485-Production mode-Parameter_21,not activated ,3
IDE00001-ENG248486-Production mode-Parameter_22,not activated ,3
IDE00001-ENG248487-Production mode-Parameter_23,not activated ,3
IDE00001-ENG253453-Production mode-Parameter_24,not activated ,3
IDE00001-ENG253428-Production mode-Parameter_3,not activated ,3
IDE00001-ENG253429-Production mode-Parameter_4,not activated ,3
IDE00001-ENG253431-Production mode-Parameter_5,not activated ,3
IDE00001-ENG253420-Production mode-Parameter_6,not activated ,3
IDE00001-ENG253424-Production mode-Parameter_7,not activated ,3
IDE00001-ENG253425-Production mode-Parameter_8,not activated ,3
IDE00001-ENG253422-Production mode-Parameter_9,not activated ,3
IDE00001-ENG168106-Production mode-volume_control,not activated ,3
IDE02476-MAS03001-Electrical test of speakers-Mode,automatic ,121
IDE02476-ENG248529-Electrical test of speakers-channel_1_lower_threshold,18 ,121
IDE02476-ENG248531-Electrical test of speakers-channel_1_upper_threshold,22 ,121
IDE02476-ENG248533-Electrical test of speakers-channel_10_lower_threshold,18 ,121
IDE02476-ENG248535-Electrical test of speakers-channel_10_upper_threshold,22 ,121
IDE02476-ENG248537-Electrical test of speakers-channel_11_lower_threshold,18 ,121
IDE02476-ENG248539-Electrical test of speakers-channel_11_upper_threshold,22 ,121
IDE02476-ENG248541-Electrical test of speakers-channel_12_lower_threshold,18 ,121
IDE02476-ENG248543-Electrical test of speakers-channel_12_upper_threshold,22 ,121
IDE02476-ENG248545-Electrical test of speakers-channel_13_lower_threshold,18 ,121
IDE02476-ENG248547-Electrical test of speakers-channel_13_upper_threshold,22 ,121
IDE02476-ENG248549-Electrical test of speakers-channel_14_lower_threshold,18 ,121
IDE02476-ENG248551-Electrical test of speakers-channel_14_upper_threshold,22 ,121
IDE02476-ENG248553-Electrical test of speakers-channel_15_lower_threshold,18 ,121
IDE02476-ENG248555-Electrical test of speakers-channel_15_upper_threshold,22 ,121
IDE02476-ENG248557-Electrical test of speakers-channel_16_lower_threshold,18 ,121
IDE02476-ENG248559-Electrical test of speakers-channel_16_upper_threshold,22 ,121
IDE02476-ENG248561-Electrical test of speakers-channel_17_lower_threshold,18 ,121
IDE02476-ENG248563-Electrical test of speakers-channel_17_upper_threshold,22 ,121
IDE02476-ENG248565-Electrical test of speakers-channel_18_lower_threshold,18 ,121
IDE02476-ENG248567-Electrical test of speakers-channel_18_upper_threshold,22 ,121
IDE02476-ENG248569-Electrical test of speakers-channel_19_lower_threshold,18 ,121
IDE02476-ENG248570-Electrical test of speakers-channel_19_upper_threshold,22 ,121
IDE02476-ENG248573-Electrical test of speakers-channel_2_lower_threshold,18 ,121
IDE02476-ENG248575-Electrical test of speakers-channel_2_upper_threshold,22 ,121
IDE02476-ENG248577-Electrical test of speakers-channel_20_lower_threshold,18 ,121
IDE02476-ENG248579-Electrical test of speakers-channel_20_upper_threshold,22 ,121
IDE02476-ENG248581-Electrical test of speakers-channel_21_lower_threshold,18 ,121
IDE02476-ENG248583-Electrical test of speakers-channel_21_upper_threshold,22 ,121
IDE02476-ENG248585-Electrical test of speakers-channel_22_lower_threshold,18 ,121
IDE02476-ENG248587-Electrical test of speakers-channel_22_upper_threshold,22 ,121
IDE02476-ENG248589-Electrical test of speakers-channel_23_lower_threshold,18 ,121
IDE02476-ENG248591-Electrical test of speakers-channel_23_upper_threshold,22 ,121
IDE02476-ENG248593-Electrical test of speakers-channel_24_lower_threshold,18 ,121
IDE02476-ENG248595-Electrical test of speakers-channel_24_upper_threshold,22 ,121
IDE02476-ENG248599-Electrical test of speakers-channel_3_lower_threshold,18 ,121
IDE02476-ENG248601-Electrical test of speakers-channel_3_upper_threshold,22 ,121
IDE02476-ENG248603-Electrical test of speakers-channel_4_lower_threshold,18 ,121
IDE02476-ENG248605-Electrical test of speakers-channel_4_upper_threshold,22 ,121
IDE02476-ENG248607-Electrical test of speakers-channel_5_lower_threshold,18 ,121
IDE02476-ENG248609-Electrical test of speakers-channel_5_upper_threshold,22 ,121
IDE02476-ENG248611-Electrical test of speakers-channel_6_lower_threshold,18 ,121
IDE02476-ENG248613-Electrical test of speakers-channel_6_upper_threshold,22 ,121
IDE02476-ENG248615-Electrical test of speakers-channel_7_lower_threshold,18 ,121
IDE02476-ENG248617-Electrical test of speakers-channel_7_upper_threshold,22 ,121
IDE02476-ENG248619-Electrical test of speakers-channel_8_lower_threshold,18 ,121
IDE02476-ENG248621-Electrical test of speakers-channel_8_upper_threshold,22 ,121
IDE02476-ENG248623-Electrical test of speakers-channel_9_lower_threshold,18 ,121
IDE02476-ENG248625-Electrical test of speakers-channel_9_upper_threshold,22 ,121
IDE02476-ENG117360-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_1_Test_Frequency,19000 Hz,121
IDE02476-ENG117361-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume,29 ,121
IDE02476-ENG117378-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_10_Test_Frequency,19000 Hz,121
IDE02476-ENG117379-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume,29 ,121
IDE02476-ENG117380-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_11_Test_Frequency,19000 Hz,121
IDE02476-ENG117381-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume,29 ,121
IDE02476-ENG117382-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_12_Test_Frequency,19000 Hz,121
IDE02476-ENG117383-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume,29 ,121
IDE02476-ENG117384-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_13_Test_Frequency,19000 Hz,121
IDE02476-ENG117385-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume,29 ,121
IDE02476-ENG117386-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_14_Test_Frequency,19000 Hz,121
IDE02476-ENG117387-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume,29 ,121
IDE02476-ENG117388-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_15_Test_Frequency,19000 Hz,121
IDE02476-ENG117389-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume,29 ,121
IDE02476-ENG117390-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_16_Test_Frequency,19000 Hz,121
IDE02476-ENG117391-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume,29 ,121
IDE02476-ENG126164-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_17_Test_Frequency,19000 Hz,121
IDE02476-ENG126165-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_17_Test_Volume,29 ,121
IDE02476-ENG126166-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_18_Test_Frequency,19000 Hz,121
IDE02476-ENG126167-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_18_Test_Volume,29 ,121
IDE02476-ENG126168-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_19_Test_Frequency,19000 Hz,121
IDE02476-ENG126169-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_19_Test_Volume,29 ,121
IDE02476-ENG117362-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_2_Test_Frequency,19000 Hz,121
IDE02476-ENG117363-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume,29 ,121
IDE02476-ENG126170-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_20_Test_Frequency,19000 Hz,121
IDE02476-ENG126171-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_20_Test_Volume,29 ,121
IDE02476-ENG126172-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_21_Test_Frequency,19000 Hz,121
IDE02476-ENG126173-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_21_Test_Volume,29 ,121
IDE02476-ENG126174-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_22_Test_Frequency,19000 Hz,121
IDE02476-ENG126175-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_22_Test_Volume,29 ,121
IDE02476-ENG126176-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_23_Test_Frequency,19000 Hz,121
IDE02476-ENG126177-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_23_Test_Volume,29 ,121
IDE02476-ENG126178-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_24_Test_Frequency,19000 Hz,121
IDE02476-ENG126179-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_24_Test_Volume,29 ,121
IDE02476-ENG117364-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_3_Test_Frequency,19000 Hz,121
IDE02476-ENG117365-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume,29 ,121
IDE02476-ENG117366-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_4_Test_Frequency,19000 Hz,121
IDE02476-ENG117367-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume,29 ,121
IDE02476-ENG117368-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_5_Test_Frequency,19000 Hz,121
IDE02476-ENG117369-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume,29 ,121
IDE02476-ENG117370-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_6_Test_Frequency,19000 Hz,121
IDE02476-ENG117371-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume,29 ,121
IDE02476-ENG117372-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_7_Test_Frequency,19000 Hz,121
IDE02476-ENG117373-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume,29 ,121
IDE02476-ENG117374-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_8_Test_Frequency,19000 Hz,121
IDE02476-ENG117375-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume,29 ,121
IDE02476-ENG117376-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_9_Test_Frequency,19000 Hz,121
IDE02476-ENG117377-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume,29 ,121
IDE06698-MAS00839-Audio management input gain-TV Tuner,-128 dB,35
IDE06698-MAS00846-Audio management input gain-Satellite radio,-128 dB,35
IDE06698-MAS01984-Audio management input gain-Radio (FM),-128 dB,35
IDE06698-MAS01985-Audio management input gain-Radio (AM),-128 dB,35
IDE06698-MAS01986-Audio management input gain-Digital radio (DAB),-128 dB,35
IDE06698-ENG125854-Audio management input gain-Exbox_DMB,-128 dB,35
IDE06698-ENG117430-Audio management input gain-HFP,-128 dB,35
IDE06698-ENG125846-Audio management input gain-Media_Airplay,-128 dB,35
IDE06698-ENG125837-Audio management input gain-Media_AUX_Adapter,-128 dB,35
IDE06698-ENG125836-Audio management input gain-Media_AUXIN,-128 dB,35
IDE06698-ENG125843-Audio management input gain-Media_Bluray,-128 dB,35
IDE06698-ENG125841-Audio management input gain-Media_BTDevice,-128 dB,35
IDE06698-ENG125838-Audio management input gain-Media_CDA,-128 dB,35
IDE06698-ENG125848-Audio management input gain-Media_Cloud,-128 dB,35
IDE06698-ENG125839-Audio management input gain-Media_DVD,-128 dB,35
IDE06698-ENG125844-Audio management input gain-Media_HDMI,-128 dB,35
IDE06698-ENG125840-Audio management input gain-Media_MFP,-128 dB,35
IDE06698-ENG125847-Audio management input gain-Media_UPNP,-128 dB,35
IDE06698-ENG125855-Audio management input gain-Mirrorlink,-128 dB,35
IDE06698-ENG125859-Audio management input gain-Phone_Ringer_MFP,-128 dB,35
IDE06698-ENG125860-Audio management input gain-Phone_Ringer_OB,-128 dB,35
IDE06698-ENG125858-Audio management input gain-Phone_Voice,-128 dB,35
IDE06698-ENG125842-Audio management input gain-TA_Tuner_FM,-128 dB,35
IDE06698-ENG125850-Audio management input gain-Tone_Beep,-128 dB,35
IDE06698-ENG125853-Audio management input gain-Tone_Messaging,-128 dB,35
IDE06698-ENG125852-Audio management input gain-Tone_Touchscreen,-128 dB,35
IDE06698-ENG125851-Audio management input gain-Tone_Warning,-128 dB,35
IDE06698-ENG251556-Audio management input gain-touch_screen_player,-128 dB,35
IDE06698-ENG125856-Audio management input gain-TTS_Nav,-128 dB,35
IDE06698-ENG125857-Audio management input gain-TTS_SDS,-128 dB,35
IDE06698-ENG125845-Audio management input gain-Tuner_Online,-128 dB,35
IDE06698-ENG125849-Audio management input gain-Tuner_Personal,-128 dB,35
IDE06698-ENG125835-Audio management input gain-Tuner_TI,-128 dB,35
IDE06698-ENG125861-Audio management input gain-TV_AV_IN,-128 dB,35
ENG282437-Ethernet_configuration_extended,01 ,5
ENG248428-ENG248528-function_configuration_audio-channel_1_HT,not installed ,10
ENG248428-ENG248530-function_configuration_audio-channel_1_TT,installed ,10
ENG248428-ENG248532-function_configuration_audio-channel_10_HT,not installed ,10
ENG248428-ENG248534-function_configuration_audio-channel_10_TT,installed ,10
ENG248428-ENG248536-function_configuration_audio-channel_11_HT,not installed ,10
ENG248428-ENG248538-function_configuration_audio-channel_11_TT,installed ,10
ENG248428-ENG248540-function_configuration_audio-channel_12_HT,not installed ,10
ENG248428-ENG248542-function_configuration_audio-channel_12_TT,installed ,10
ENG248428-ENG248544-function_configuration_audio-channel_13_HT,not installed ,10
ENG248428-ENG248546-function_configuration_audio-channel_13_TT,installed ,10
ENG248428-ENG248548-function_configuration_audio-channel_14_HT,not installed ,10
ENG248428-ENG248550-function_configuration_audio-channel_14_TT,installed ,10
ENG248428-ENG248552-function_configuration_audio-channel_15_HT,not installed ,10
ENG248428-ENG248554-function_configuration_audio-channel_15_TT,installed ,10
ENG248428-ENG248556-function_configuration_audio-channel_16_HT,not installed ,10
ENG248428-ENG248558-function_configuration_audio-channel_16_TT,installed ,10
ENG248428-ENG248560-function_configuration_audio-channel_17_HT,not installed ,10
ENG248428-ENG248562-function_configuration_audio-channel_17_TT,not installed ,10
ENG248428-ENG248564-function_configuration_audio-channel_18_HT,not installed ,10
ENG248428-ENG248566-function_configuration_audio-channel_18_TT,not installed ,10
ENG248428-ENG248568-function_configuration_audio-channel_19_HT,not installed ,10
ENG248428-ENG248571-function_configuration_audio-channel_19TT,not installed ,10
ENG248428-ENG248572-function_configuration_audio-channel_2_HT,not installed ,10
ENG248428-ENG248574-function_configuration_audio-channel_2_TT,installed ,10
ENG248428-ENG248576-function_configuration_audio-channel_20_HT,not installed ,10
ENG248428-ENG248578-function_configuration_audio-channel_20_TT,not installed ,10
ENG248428-ENG248580-function_configuration_audio-channel_21_HT,not installed ,10
ENG248428-ENG248582-function_configuration_audio-channel_21_TT,not installed ,10
ENG248428-ENG248584-function_configuration_audio-channel_22_HT,not installed ,10
ENG248428-ENG248586-function_configuration_audio-channel_22_TT,not installed ,10
ENG248428-ENG248588-function_configuration_audio-channel_23_HT,not installed ,10
ENG248428-ENG248590-function_configuration_audio-channel_23_TT,not installed ,10
ENG248428-ENG248592-function_configuration_audio-channel_24_HT,not installed ,10
ENG248428-ENG248594-function_configuration_audio-channel_24_TT,not installed ,10
ENG248428-ENG248596-function_configuration_audio-channel_25_HT,not installed ,10
ENG248428-ENG248597-function_configuration_audio-channel_25_TT,not installed ,10
ENG248428-ENG248598-function_configuration_audio-channel_3_HT,not installed ,10
ENG248428-ENG248600-function_configuration_audio-channel_3_TT,installed ,10
ENG248428-ENG248602-function_configuration_audio-channel_4_HT,not installed ,10
ENG248428-ENG248604-function_configuration_audio-channel_4_TT,installed ,10
ENG248428-ENG248606-function_configuration_audio-channel_5_HT,not installed ,10
ENG248428-ENG248608-function_configuration_audio-channel_5_TT,not installed ,10
ENG248428-ENG248610-function_configuration_audio-channel_6_HT,not installed ,10
ENG248428-ENG248612-function_configuration_audio-channel_6_TT,not installed ,10
ENG248428-ENG248614-function_configuration_audio-channel_7_HT,not installed ,10
ENG248428-ENG248616-function_configuration_audio-channel_7_TT,installed ,10
ENG248428-ENG248618-function_configuration_audio-channel_8_HT,not installed ,10
ENG248428-ENG248620-function_configuration_audio-channel_8_TT,installed ,10
ENG248428-ENG248622-function_configuration_audio-channel_9_HT,not installed ,10
ENG248428-ENG248624-function_configuration_audio-channel_9_TT,installed ,10
ENG248428-ENG248653-function_configuration_audio-Early_engine_sound,OFF ,10
ENG248428-ENG248491-function_configuration_audio-microphone_1,not installed ,10
ENG248428-ENG248492-function_configuration_audio-microphone_2,not installed ,10
ENG248428-ENG248763-function_configuration_audio-microphone_3,not installed ,10
ENG248428-ENG248764-function_configuration_audio-microphone_4,not installed ,10
ENG248428-ENG252056-function_configuration_audio-microphones_ANC,not installed ,10
ENG248428-ENG248818-function_configuration_audio-Signal_flow_topology,00 ,10
ENG248428-ENG248483-function_configuration_audio-Sound_system,external_ethernet ,10
ENG248428-ENG248830-function_configuration_audio-welcome_sound,OFF ,10
ENG248438-function_configuration_sound,harman_kardon ,2
Elapsed Time: 00:07
adpmap-51-0ET-907-121-G_WVG5WVEB2SH017765-20250325-1230.CSV
;SW:0ET-907-121-G   HW:0ET-907-121-G ---  Electric Drive
;Component:MEB INV6.0    H10 7260, Coding:
;EV_DMCM21000110ET907121G,001001,EV_DMCM21000110ET907121G.rod
;Tuesday,25,March,2025,12:30:34:58926
;VCID: 44DA22065E15BDCAEBE-8010-R SFD+SFD2
IDE13778-Electric drive assembly: serial number,9144P01520132K241120 ,20
IDE13779-Electric drive: engine code,Conditions not correct or request sequence error,20
IDE13780-Transmission: serial number,0BXWDM 520132K241120 ,20
IDE13781-Electric drive motor: serial number,0BWECN 030458KK24473 ,20
IDE15766-Expected OBD requests and variant management,1 ,1
ENG376347-Electric_drive_engine_code_letter_V2,1 ,1
Elapsed Time: 00:15
adpmap-52-1EA-959-592-F_WVG5WVEB2SH017765-20250325-1231.CSV
;SW:1EA-959-592-F   HW:1EA-959-592-F ---  Door Elect, Pass.
;Component:TSG BFS       009 0563, Coding:00355320DE00028040800020
;EV_DCU3PasseSideMAXHCONT,001004,EV_DCU3PasseSideMAXHCONT_VWE3.rod
;Tuesday,25,March,2025,12:31:03:58926
ENG117308-ENG148862-Patch_Code_Passenger_Side_Rear-Parameter_1,No Response From Subnet Component,1
ENG117308-ENG148865-Patch_Code_Passenger_Side_Rear-Parameter_2,No Response From Subnet Component,1
ENG117306-ENG148862-Window_Regulator_Supplier_Settings_Passenger_Side_Rear_1-Parameter_1,No Response From Subnet Component,1
ENG117306-ENG148865-Window_Regulator_Supplier_Settings_Passenger_Side_Rear_1-Parameter_2,No Response From Subnet Component,1
ENG117307-ENG148862-Window_Regulator_Supplier_Settings_Passenger_Side_Rear_2-Parameter_1,No Response From Subnet Component,1
ENG117307-ENG148865-Window_Regulator_Supplier_Settings_Passenger_Side_Rear_2-Parameter_2,No Response From Subnet Component,1
ENG117305-Window_Regulator_VW_Settings_Passenger_Side_Rear,No Response From Subnet Component,1
Elapsed Time: 00:04
adpmap-5F-10C-035-842-A_WVG5WVEB2SH017765-20250325-1231.CSV
;SW:10C-035-842-A   HW:10C-035-842 ---  Information Electr.
;Component:IC3GSF--US    H09 3626, Coding:64101030000000000000000000000000000000000000000000
;EV_MUICASSAFEPart,002001,EV_MUICASSAFEPart_002_VNE4.rod
;Tuesday,25,March,2025,12:31:27:58926
;VCID: 1B68B97A832BA2327A4-804E-R SFD+SFD2
IDE00820-MAS03180-Activating and deactivating all development messages-Local data bus,OFF ,1
IDE00820-MAS05583-Activating and deactivating all development messages-Data bus,OFF ,1
IDE01996-SFT00095-Installation list: specified installations-Information electronics 1,Yes ,1
IDE01996-SFT33061-Installation list: specified installations-Application server 3 system 1 infotainment,Yes ,1
IDE01996-ENG273603-Installation list: specified installations-ECU_coded Bit 2,No ,1
IDE01996-ENG273895-Installation list: specified installations-ECU_coded Bit 3,No ,1
IDE01996-ENG273746-Installation list: specified installations-ECU_coded Bit 4,No ,1
IDE01996-ENG273679-Installation list: specified installations-ECU_coded Bit 5,No ,1
IDE01996-ENG273754-Installation list: specified installations-ECU_coded Bit 6,No ,1
IDE01996-ENG273757-Installation list: specified installations-ECU_coded Bit 7,No ,1
IDE02502-Confirmation of installation change,4F 69 ,2
IDE04307-ENG117700-Vehicle function list BAP-ACC_0x05,not activated ,256
IDE04307-ENG117701-Vehicle function list BAP-ACC_0x05_msg_bus,not activated ,256
IDE04307-ENG117702-Vehicle function list BAP-air_suspension_0x06,not activated ,256
IDE04307-ENG117703-Vehicle function list BAP-air_suspension_0x06_msg_bus,not activated ,256
IDE04307-ENG117764-Vehicle function list BAP-Amplifier_0x2D,not activated ,256
IDE04307-ENG117765-Vehicle function list BAP-Amplifier_0x2D_msg_bus,not activated ,256
IDE04307-ENG122334-Vehicle function list BAP-Angle_Of_Slope_0x24,not activated ,256
IDE04307-ENG122335-Vehicle function list BAP-Angle_Of_Slope_0x24_msg_bus,not activated ,256
IDE04307-ENG117696-Vehicle function list BAP-auxilary_heating_0x03,not activated ,256
IDE04307-ENG117697-Vehicle function list BAP-auxilary_heating_0x03_msg_bus,not activated ,256
IDE04307-ENG117744-Vehicle function list BAP-AWV_0x1B,not activated ,256
IDE04307-ENG117745-Vehicle function list BAP-AWV_0x1B_msg_bus,not activated ,256
IDE04307-ENG122336-Vehicle function list BAP-Battery_Management_0x25,not activated ,256
IDE04307-ENG122337-Vehicle function list BAP-Battery_Management_0x25_msg_bus,not activated ,256
IDE04307-ENG117758-Vehicle function list BAP-BCmE_0x23,not activated ,256
IDE04307-ENG117759-Vehicle function list BAP-BCmE_0x23_msg_bus,not activated ,256
IDE04307-ENG117760-Vehicle function list BAP-Brake_0x26,not activated ,256
IDE04307-ENG117761-Vehicle function list BAP-Brake_0x26_msg_bus,not activated ,256
IDE04307-ENG297672-Vehicle function list BAP-BSMOIS_0x76,not activated ,256
IDE04307-ENG297673-Vehicle function list BAP-BSMOIS_0x76_msg_bus,not activated ,256
IDE04307-ENG297674-Vehicle function list BAP-BSMOIS2_0x7A,not activated ,256
IDE04307-ENG297675-Vehicle function list BAP-BSMOIS2_0x7A_msg_bus,not activated ,256
IDE04307-ENG297676-Vehicle function list BAP-BSMOIS3_0x7B,not activated ,256
IDE04307-ENG297677-Vehicle function list BAP-BSMOIS3_0x7B_msg_bus,not activated ,256
IDE04307-ENG324690-Vehicle function list BAP-California_0x81,not activated ,256
IDE04307-ENG331873-Vehicle function list BAP-California_0x81_msg_bus,not activated ,256
IDE04307-ENG248526-Vehicle function list BAP-Car2X_0x61,not activated ,256
IDE04307-ENG248527-Vehicle function list BAP-Car2X_0x61_msg_bus,not activated ,256
IDE04307-ENG117717-Vehicle function list BAP-central_locking_0x0D,not activated ,256
IDE04307-ENG117716-Vehicle function list BAP-central_locking_0x0D_msg_bus,not activated ,256
IDE04307-ENG117736-Vehicle function list BAP-charisma_0x17,not activated ,256
IDE04307-ENG117737-Vehicle function list BAP-charisma_0x17_msg_bus,not activated ,256
IDE04307-ENG282048-Vehicle function list BAP-ChassisControl_0x57,not activated ,256
IDE04307-ENG282008-Vehicle function list BAP-ChassisControl_0x57_msg_bus,not activated ,256
IDE04307-ENG117734-Vehicle function list BAP-clima_slave_2_0x16,not activated ,256
IDE04307-ENG117735-Vehicle function list BAP-clima_slave_2_0x16_msg_bus,not activated ,256
IDE04307-ENG248490-Vehicle function list BAP-climate_master_0x42,not activated ,256
IDE04307-ENG248630-Vehicle function list BAP-climate_master_0x42_msg_bus,not activated ,256
IDE04307-ENG117692-Vehicle function list BAP-climatic_master_0x01,not activated ,256
IDE04307-ENG117693-Vehicle function list BAP-climatic_master_0x01_msg_bus,not activated ,256
IDE04307-ENG117694-Vehicle function list BAP-climatic_slave_0x02,not activated ,256
IDE04307-ENG117695-Vehicle function list BAP-climatic_slave_0x02_msg_bus,not activated ,256
IDE04307-ENG117724-Vehicle function list BAP-clock_0x11,not activated ,256
IDE04307-ENG117725-Vehicle function list BAP-clock_0x11_msg_bus,not activated ,256
IDE04307-ENG117732-Vehicle function list BAP-compass_0x15,not activated ,256
IDE04307-ENG117733-Vehicle function list BAP-compass_0x15_msg_bus,not activated ,256
IDE04307-ENG142158-Vehicle function list BAP-connection_manager_0x47,not activated ,256
IDE04307-ENG142159-Vehicle function list BAP-connection_manager_0x47_msg_bus,not activated ,256
IDE04307-ENG152529-Vehicle function list BAP-daf_profile_0x51,not activated ,256
IDE04307-ENG152530-Vehicle function list BAP-daf_profile_0x51_msg_bus,not activated ,256
IDE04307-ENG137043-Vehicle function list BAP-display_configuration_0x45,not activated ,256
IDE04307-ENG137044-Vehicle function list BAP-display_configuration_0x45_msg_bus,not activated ,256
IDE04307-ENG297681-Vehicle function list BAP-Doorlocking_2nd_0x79,not activated ,256
IDE04307-ENG297682-Vehicle function list BAP-Doorlocking_2nd_0x79_msg_bus,not activated ,256
IDE04307-ENG117722-Vehicle function list BAP-driver_seat_0x10,not activated ,256
IDE04307-ENG117723-Vehicle function list BAP-driver_seat_0x10_msg_bus,not activated ,256
IDE04307-ENG302721-Vehicle function list BAP-DrivingDynamics_0x7E,not activated ,256
IDE04307-ENG302722-Vehicle function list BAP-DrivingDynamics_0x7E_msg_bus,not activated ,256
IDE04307-ENG125039-Vehicle function list BAP-Ecall_0x33,not activated ,256
IDE04307-ENG125828-Vehicle function list BAP-eCall_0x33_msg_bus,not activated ,256
IDE04307-ENG127500-Vehicle function list BAP-efficiency_assis_msg_bus_0x3C,not activated ,256
IDE04307-ENG127499-Vehicle function list BAP-efficiency_assist_0x3C,not activated ,256
IDE04307-ENG248657-Vehicle function list BAP-EngineFunctions_0x5D,not activated ,256
IDE04307-ENG248658-Vehicle function list BAP-EngineFunctions_0x5D_msg_bus,not activated ,256
IDE04307-ENG125829-Vehicle function list BAP-ENI_0x37,activated ,256
IDE04307-ENG125830-Vehicle function list BAP-ENI_0x37_msg_bus,CAN_AB ,256
IDE04307-ENG264168-Vehicle function list BAP-ENI2_0x58,not activated ,256
IDE04307-ENG264169-Vehicle function list BAP-ENI2_0x58_msg_bus,not activated ,256
IDE04307-ENG264170-Vehicle function list BAP-ENI3_0x6E,not activated ,256
IDE04307-ENG264171-Vehicle function list BAP-ENI3_0x6E_msg_bus,not activated ,256
IDE04307-ENG264172-Vehicle function list BAP-ENI4_0x6F,activated ,256
IDE04307-ENG264173-Vehicle function list BAP-ENI4_0x6F_msg_bus,CAN_AB ,256
IDE04307-ENG117708-Vehicle function list BAP-exterieur_light_0x09,not activated ,256
IDE04307-ENG117709-Vehicle function list BAP-exterieur_light_0x09_msg_bus,not activated ,256
IDE04307-ENG252073-Vehicle function list BAP-exterieur_light_2_0x6B,activated ,256
IDE04307-ENG252076-Vehicle function list BAP-exterieur_light_2_0x6B_msg_bus,Comfort data bus ,256
IDE04307-ENG142168-Vehicle function list BAP-fas_profile_0x4D,not activated ,256
IDE04307-ENG142169-Vehicle function list BAP-fas_profile_0x4D_msg_bus,not activated ,256
IDE04307-ENG142154-Vehicle function list BAP-front_traffic_assist_0x41,not activated ,256
IDE04307-ENG142155-Vehicle function list BAP-front_traffic_assist_0x41_msg_bus,not activated ,256
IDE04307-ENG117698-Vehicle function list BAP-headup_displ_0x04,not activated ,256
IDE04307-ENG117699-Vehicle function list BAP-headup_displ_0x04_msg_bus,not activated ,256
IDE04307-ENG117746-Vehicle function list BAP-Hybrid_0x1D,not activated ,256
IDE04307-ENG117747-Vehicle function list BAP-Hybrid_0x1D_msg_bus,not activated ,256
IDE04307-ENG248711-Vehicle function list BAP-IAA_PSO_0x52,not activated ,256
IDE04307-ENG248712-Vehicle function list BAP-IAA_PSO_0x52_msg_bus,not activated ,256
IDE04307-ENG152535-Vehicle function list BAP-infotainmentsettings_profile_0x50,activated ,256
IDE04307-ENG152536-Vehicle function list BAP-infotainmentsettings_profile_0x50_msg_bus,not activated ,256
IDE04307-ENG117706-Vehicle function list BAP-interieur_light_0x08,not activated ,256
IDE04307-ENG117707-Vehicle function list BAP-interieur_light_0x08_msg_bus,not activated ,256
IDE04307-ENG252052-Vehicle function list BAP-interieur_light_2_0x6A,activated ,256
IDE04307-ENG252047-Vehicle function list BAP-interieur_light_2_0x6A_msg_bus,Comfort data bus ,256
IDE04307-ENG248719-Vehicle function list BAP-ITM_0x65,not activated ,256
IDE04307-ENG248720-Vehicle function list BAP-ITM_0x65_msg_bus,not activated ,256
IDE04307-ENG117740-Vehicle function list BAP-LDW_HCA_0x19,not activated ,256
IDE04307-ENG117741-Vehicle function list BAP-LDW_HCA_0x19_msg_bus,not activated ,256
IDE04307-ENG249902-Vehicle function list BAP-lift_0x64,not activated ,256
IDE04307-ENG249903-Vehicle function list BAP-lift_0x64_msg_bus,not activated ,256
IDE04307-ENG281905-Vehicle function list BAP-LLCC_0x78,not activated ,256
IDE04307-ENG281994-Vehicle function list BAP-LLCC_0x78_msg_bus,not activated ,256
IDE04307-ENG248726-Vehicle function list BAP-Mascot_0x53,not activated ,256
IDE04307-ENG248727-Vehicle function list BAP-Mascot_0x53_msg_bus,not activated ,256
IDE04307-ENG117720-Vehicle function list BAP-MFA_0x0F,not activated ,256
IDE04307-ENG117721-Vehicle function list BAP-MFA_0x0F_msg_bus,not activated ,256
IDE04307-ENG117767-Vehicle function list BAP-MFL_Jocker_0x34,not activated ,256
IDE04307-ENG117766-Vehicle function list BAP-MFL_Jocker_msg_bus_0x34,not activated ,256
IDE04307-ENG117719-Vehicle function list BAP-mirror_0x0E,not activated ,256
IDE04307-ENG117718-Vehicle function list BAP-mirror_0x0E_msg_bus,not activated ,256
IDE04307-ENG345841-Vehicle function list BAP-MobDevKey_0x77,not activated ,256
IDE04307-ENG345842-Vehicle function list BAP-MobDevKey_0x77_msg_bus,not activated ,256
IDE04307-ENG117738-Vehicle function list BAP-Night_Vision_0x18,not activated ,256
IDE04307-ENG117739-Vehicle function list BAP-Night_Vision_0x18_msg_bus,not activated ,256
IDE04307-ENG248788-Vehicle function list BAP-PaCo_0x55,not activated ,256
IDE04307-ENG248789-Vehicle function list BAP-PaCo_0x55_msg_bus,not activated ,256
IDE04307-ENG117710-Vehicle function list BAP-parking_assist_0x0A,not activated ,256
IDE04307-ENG117711-Vehicle function list BAP-parking_assist_0x0A_msg_bus,not activated ,256
IDE04307-ENG117752-Vehicle function list BAP-Passenger_Seat_0x20,not activated ,256
IDE04307-ENG117753-Vehicle function list BAP-Passenger_Seat_0x20_msg_bus,not activated ,256
IDE04307-ENG125831-Vehicle function list BAP-Pedestrian_Assist_0x3A,not activated ,256
IDE04307-ENG125832-Vehicle function list BAP-Pedestrian_Assist_msg_bus_0x3A,not activated ,256
IDE04307-ENG325104-Vehicle function list BAP-Plug_and_charge_0x80,not activated ,256
IDE04307-ENG395187-Vehicle function list BAP-Plug_and_Charge_0x80_msg_bus,not activated ,256
IDE04307-ENG122333-Vehicle function list BAP-Range_Data_0x39,not activated ,256
IDE04307-ENG125827-Vehicle function list BAP-Range_Data_msg_bus_0x39,not activated ,256
IDE04307-ENG122327-Vehicle function list BAP-RearSeatEntertainment_0x2E,not activated ,256
IDE04307-ENG122328-Vehicle function list BAP-RearSeatEntertainment_0x2E_msg_bus,not activated ,256
IDE04307-ENG248801-Vehicle function list BAP-remote_services_0x4E,not activated ,256
IDE04307-ENG248802-Vehicle function list BAP-remote_services_0x4E_msg_bus,not activated ,256
IDE04307-ENG117750-Vehicle function list BAP-Reversible_Seat_Belt_Tightener_0x1F,not activated ,256
IDE04307-ENG117751-Vehicle function list BAP-Reversible_Seat_Belt_Tightener_0x1F_msg_bus,not activated ,256
IDE04307-ENG316850-Vehicle function list BAP-RollingAbility_0x75,not activated ,256
IDE04307-ENG316851-Vehicle function list BAP-RollingAbility_0x75_msg_bus,not activated ,256
IDE04307-ENG297722-Vehicle function list BAP-RushhourPilot_0x7C,not activated ,256
IDE04307-ENG297723-Vehicle function list BAP-RushhourPilot_0x7C_msg_bus,not activated ,256
IDE04307-ENG125833-Vehicle function list BAP-Seat_Pneumatic_0x3B,not activated ,256
IDE04307-ENG125834-Vehicle function list BAP-Seat_Pneumatic_msg_bus_0x3B,not activated ,256
IDE04307-ENG139200-Vehicle function list BAP-Seatmemory_codriver_rear_0x3F,not activated ,256
IDE04307-ENG139201-Vehicle function list BAP-Seatmemory_codriver_rear_msg_bus_0x3F,not activated ,256
IDE04307-ENG139198-Vehicle function list BAP-Seatmemory_driver_rear_0x3E,not activated ,256
IDE04307-ENG139199-Vehicle function list BAP-Seatmemory_driver_rear_msg_bus_0x3E,not activated ,256
IDE04307-ENG395209-Vehicle function list BAP-SecurityEvent_0x82,not activated ,256
IDE04307-ENG395210-Vehicle function list BAP-SecurityEvent_0x82_msg_bus,not activated ,256
IDE04307-ENG117726-Vehicle function list BAP-service_interval_display_0x12,not activated ,256
IDE04307-ENG117727-Vehicle function list BAP-service_interval_display_0x12_msg_bus,not activated ,256
IDE04307-ENG117748-Vehicle function list BAP-SideView_0x1E,not activated ,256
IDE04307-ENG117749-Vehicle function list BAP-SideView_0x1E_msg_bus,not activated ,256
IDE04307-ENG139202-Vehicle function list BAP-Soundcontrol_0x44,not activated ,256
IDE04307-ENG139203-Vehicle function list BAP-Soundcontrol_0x44_msg_bus,not activated ,256
IDE04307-ENG248819-Vehicle function list BAP-SoundControl2_0x66,not activated ,256
IDE04307-ENG248820-Vehicle function list BAP-SoundControl2_0x66_msg_bus,not activated ,256
IDE04307-ENG122329-Vehicle function list BAP-Special_Functions_0x35,not activated ,256
IDE04307-ENG122330-Vehicle function list BAP-Special_Functions_msg_bus_0x35,not activated ,256
IDE04307-ENG127678-Vehicle function list BAP-spoiler_0x40,not activated ,256
IDE04307-ENG127679-Vehicle function list BAP-spoiler_0x40_msg_bus,not activated ,256
IDE04307-ENG117762-Vehicle function list BAP-Start_Stop_reasons_0x27,not activated ,256
IDE04307-ENG117763-Vehicle function list BAP-Start_Stop_reasons_0x27_msg_bus,not activated ,256
IDE04307-ENG142162-Vehicle function list BAP-statistic_0x4A,not activated ,256
IDE04307-ENG142163-Vehicle function list BAP-statistic_0x4A_msg_bus,not activated ,256
IDE04307-ENG142164-Vehicle function list BAP-sunroof_front_0x4B,not activated ,256
IDE04307-ENG142165-Vehicle function list BAP-sunroof_front_0x4B_msg_bus,not activated ,256
IDE04307-ENG142166-Vehicle function list BAP-sunroof_rear_0x4C,not activated ,256
IDE04307-ENG142167-Vehicle function list BAP-sunroof_rear_0x4C_msg_bus,not activated ,256
IDE04307-ENG117742-Vehicle function list BAP-SWA_0x1A,not activated ,256
IDE04307-ENG117743-Vehicle function list BAP-SWA_0x1A_msg_bus,not activated ,256
IDE04307-ENG117704-Vehicle function list BAP-tire_pressure_system_0x07,not activated ,256
IDE04307-ENG117705-Vehicle function list BAP-tire_pressure_system_0x07_msg_bus,not activated ,256
IDE04307-ENG117754-Vehicle function list BAP-traffic_sign_recognition_0x21,not activated ,256
IDE04307-ENG117755-Vehicle function list BAP-traffic_sign_recognition_0x21_msg_bus,not activated ,256
IDE04307-ENG122331-Vehicle function list BAP-Trailer_Assistant_0x36,not activated ,256
IDE04307-ENG122332-Vehicle function list BAP-Trailer_Assistant_msg_bus_0x36,not activated ,256
IDE04307-ENG260744-Vehicle function list BAP-Trained_Park_Assist_0x5F,not activated ,256
IDE04307-ENG258630-Vehicle function list BAP-Trained_Park_Assist_0x5F_msg_bus,not activated ,256
IDE04307-ENG122325-Vehicle function list BAP-TV_tuner_0x2C,not activated ,256
IDE04307-ENG122326-Vehicle function list BAP-TV_tuner_0x2C_msg_bus,not activated ,256
IDE04307-ENG117730-Vehicle function list BAP-UGDO_0x14,not activated ,256
IDE04307-ENG117731-Vehicle function list BAP-UGDO_0x14_msg_bus,not activated ,256
IDE04307-ENG117728-Vehicle function list BAP-unit_master_0x13,not activated ,256
IDE04307-ENG117729-Vehicle function list BAP-unit_master_0x13_msg_bus,not activated ,256
IDE04307-ENG185817-Vehicle function list BAP-vas_0x54,not activated ,256
IDE04307-ENG185818-Vehicle function list BAP-vas_0x54_msg_bus,not activated ,256
IDE04307-ENG117712-Vehicle function list BAP-VPS_0x0B,not activated ,256
IDE04307-ENG117713-Vehicle function list BAP-VPS_0x0B_msg_bus,not activated ,256
IDE04307-ENG117756-Vehicle function list BAP-weariness_rcognition_0x22,not activated ,256
IDE04307-ENG117757-Vehicle function list BAP-weariness_rcognition_0x22_msg_bus,not activated ,256
IDE04307-ENG117714-Vehicle function list BAP-wiper_comfort_0x0C,not activated ,256
IDE04307-ENG117715-Vehicle function list BAP-wiper_comfort_0x0C_msg_bus,not activated ,256
IDE04307-ENG142160-Vehicle function list BAP-wireless_charging_0x48,not activated ,256
IDE04307-ENG142161-Vehicle function list BAP-wireless_charging_0x48_msg_bus,not activated ,256
IDE12978-Inspection: distance until next inspection,16093 km,2
IDE12979-Inspection: time until next inspection,365 d,2
IDE12980-Inspection: distance driven since the last inspection,0 km,2
IDE12981-Inspection: time since the last inspection,0 d,2
IDE13607-MAS16700-Lock display contents-Lock MFA displays,No ,6
IDE13607-MAS16701-Lock display contents-Dynamic image lock,No ,6
IDE13607-MAS16702-Lock display contents-Lock functional animation,No ,6
IDE13607-MAS16703-Lock display contents-lock,No ,6
IDE13607-MAS16704-Lock display contents-Lock system status animation,No ,6
IDE13607-MAS16705-Lock display contents-Lock operating support animation,No ,6
IDE13607-MAS16706-Lock display contents-List time out,72000 s,6
IDE14875-MAS19483-Activation of views-View 1,not active ,2
IDE14875-MAS19484-Activation of views-View 2,not active ,2
IDE14875-MAS19485-Activation of views-View 3,not active ,2
IDE14875-MAS19486-Activation of views-View 4,not active ,2
IDE14875-MAS19487-Activation of views-View 5,not active ,2
IDE14875-MAS19488-Activation of views-View 6,not active ,2
IDE14875-MAS19489-Activation of views-View 7,not active ,2
IDE14875-MAS19490-Activation of views-View 8,not active ,2
IDE17913-Inspection: time until next inspection service ex works,365 d,2
IDE17914-Inspection: distance until next inspection service ex works,16093 km,2
MAS01083-IDE12211-Country Variant-China variant,No ,2
MAS01083-IDE14114-Country Variant-USA Variant,No ,2
MAS01083-IDE14115-Country Variant-Asian variant,No ,2
ENG128731-MAS01129-designvariant_activation-Variant 1,not active ,2
ENG128731-MAS01130-designvariant_activation-Variant 2,not active ,2
ENG128731-MAS01131-designvariant_activation-Variant 3,not active ,2
ENG128731-MAS03101-designvariant_activation-Variant 4,not active ,2
ENG128731-MAS03102-designvariant_activation-Variant 5,not active ,2
ENG128731-MAS03103-designvariant_activation-Variant 6,not active ,2
ENG128731-MAS03104-designvariant_activation-Variant 7,not active ,2
ENG128731-MAS03105-designvariant_activation-Variant 8,not active ,2
ENG117916-ENG101574-Dimming_Illumination_for_Display_Unit-X1,0 ,18
ENG117916-ENG99557-Dimming_Illumination_for_Display_Unit-X2,10 ,18
ENG117916-ENG102140-Dimming_Illumination_for_Display_Unit-X3,50 ,18
ENG117916-ENG102936-Dimming_Illumination_for_Display_Unit-X4,100 ,18
ENG117916-ENG103548-Dimming_Illumination_for_Display_Unit-X5,150 ,18
ENG117916-ENG113992-Dimming_Illumination_for_Display_Unit-X6,253 ,18
ENG117916-ENG99777-Dimming_Illumination_for_Display_Unit-Y1,1.0 %,18
ENG117916-ENG100480-Dimming_Illumination_for_Display_Unit-Y2,1.0 %,18
ENG117916-ENG100773-Dimming_Illumination_for_Display_Unit-Y3,3.0 %,18
ENG117916-ENG100631-Dimming_Illumination_for_Display_Unit-Y4,6.0 %,18
ENG117916-ENG102174-Dimming_Illumination_for_Display_Unit-Y5,44.0 %,18
ENG117916-ENG113993-Dimming_Illumination_for_Display_Unit-Y6,100.0 %,18
ENG253228-ENG101574-Dimming_Illumination_for_Display_Unit_day_design-X1,0 ,18
ENG253228-ENG99557-Dimming_Illumination_for_Display_Unit_day_design-X2,10 ,18
ENG253228-ENG102140-Dimming_Illumination_for_Display_Unit_day_design-X3,50 ,18
ENG253228-ENG102936-Dimming_Illumination_for_Display_Unit_day_design-X4,100 ,18
ENG253228-ENG103548-Dimming_Illumination_for_Display_Unit_day_design-X5,150 ,18
ENG253228-ENG113992-Dimming_Illumination_for_Display_Unit_day_design-X6,253 ,18
ENG253228-ENG99777-Dimming_Illumination_for_Display_Unit_day_design-Y1,0.6 %,18
ENG253228-ENG100480-Dimming_Illumination_for_Display_Unit_day_design-Y2,0.6 %,18
ENG253228-ENG100773-Dimming_Illumination_for_Display_Unit_day_design-Y3,1.0 %,18
ENG253228-ENG100631-Dimming_Illumination_for_Display_Unit_day_design-Y4,3.0 %,18
ENG253228-ENG102174-Dimming_Illumination_for_Display_Unit_day_design-Y5,30.0 %,18
ENG253228-ENG113993-Dimming_Illumination_for_Display_Unit_day_design-Y6,100.0 %,18
ENG253188-ENG258678-display_manager_configuration-abt_display_type,3 ,4
ENG253188-ENG259576-display_manager_configuration-driver_display_type,1 ,4
ENG253188-ENG260129-display_manager_configuration-hud_display_type,0 ,4
ENG253112-ENG273821-Display_speed-driver_distraction_prevention_moderate_threshold,0 km/h,51
ENG253112-ENG259163-Display_speed-driverDistractionPrevention_hys_off,0 km/h,51
ENG253112-ENG258670-Display_speed-driverDistractionPrevention_hys_on,0 km/h,51
ENG253112-ENG273881-Display_speed-driverDistractionPreventionStrict_iscoded,false ,51
ENG253112-ENG273864-Display_speed-driverDistractionPreventionStrict_threshold,0 km/h,51
ENG253112-ENG258868-Display_speed-maxThreshold_kmh,240 km/h,51
ENG253112-ENG258519-Display_speed-maxThreshold_mph,150 mph,51
ENG253112-ENG261235-Display_speed-minThreshold_kmh,30 km/h,51
ENG253112-ENG259639-Display_speed-minThreshold_mph,20 mph,51
ENG253112-ENG261151-Display_speed-safe_time,2000 ms,51
ENG253112-ENG259868-Display_speed-speed_display_damping,20.00 ms,51
ENG253112-ENG259859-Display_speed-speed_warning_AGCC_isActive,false ,51
ENG253112-ENG260027-Display_speed-speed_warning_india_isActive,false ,51
ENG253112-ENG256370-Display_speed-speed_warning_tire_isActive,false ,51
ENG253112-ENG256371-Display_speed-speed_warning_tire_threshold,30 km/h,51
ENG253112-ENG256372-Display_speed-speed_warning_user_isActive,false ,51
ENG253112-ENG259262-Display_speed-speed_warning_user_isCoded,false ,51
ENG253112-ENG256373-Display_speed-speed_warning_user_threshold,30 km/h,51
ENG253112-ENG256374-Display_speed-speed_warning_user2_isActive,false ,51
ENG253112-ENG259036-Display_speed-speed_warning_user2_isCoded,false ,51
ENG253112-ENG256375-Display_speed-speed_warning_user2_threshold,30 km/h,51
ENG253112-ENG258572-Display_speed-threshold_AGCC_hysterese,3 km/h,51
ENG253112-ENG259113-Display_speed-threshold_India_hysterese,3 km/h,51
ENG253112-ENG258204-Display_speed-threshold_max_displaySpeed,0 km/h,51
ENG253112-ENG260076-Display_speed-threshold_min_displaySpeed,2 km/h,51
ENG253112-ENG260440-Display_speed-velocity_secondary,true ,51
ENG253112-ENG259383-Display_speed-warning_entry,1 km/h,51
ENG253112-ENG258434-Display_speed-warning_hysterese,4 km/h,51
ENG253112-ENG261027-Display_speed-warning_hysterese_off,10 km/h,51
ENG253112-ENG258521-Display_speed-warning_waiting_time_India_1,12 s,51
ENG253180-ENG256370-Display_speed_da-speed_warning_tire_isActive,false ,9
ENG253180-ENG256371-Display_speed_da-speed_warning_tire_threshold,30 km/h,9
ENG253180-ENG256372-Display_speed_da-speed_warning_user_isActive,false ,9
ENG253180-ENG256373-Display_speed_da-speed_warning_user_threshold,30 km/h,9
ENG253180-ENG256374-Display_speed_da-speed_warning_user2_isActive,false ,9
ENG253180-ENG256375-Display_speed_da-speed_warning_user2_threshold,30 km/h,9
ENG253231-IDE00301-function_configuration_kombi-Distance,miles ,12
ENG253231-IDE06005-function_configuration_kombi-Time format,12h AM_PM ,12
ENG253231-MAS01230-function_configuration_kombi-Date,mm_dd_yy ,12
ENG253231-MAS01456-function_configuration_kombi-Speed,Miles per hour ,12
ENG253231-MAS02201-function_configuration_kombi-Temperature,Degrees Fahrenheit ,12
ENG253231-MAS03032-function_configuration_kombi-Volume,gallons (US) ,12
ENG253231-MAS03034-function_configuration_kombi-Pressure,psi ,12
ENG253231-MAS05637-function_configuration_kombi-Operating range consumption: CNG (compressed natural gas),mpg equivalent (US) ,12
ENG253231-MAS05638-function_configuration_kombi-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Miles per gallon (US) ,12
ENG253231-MAS13665-function_configuration_kombi-Trailer/support load ground,Pounds (lbs) ,12
ENG253231-ENG258372-function_configuration_kombi-consumption_electric,Miles_per_kWh ,12
ENG253231-ENG147310-function_configuration_kombi-Personalization,Deactivated ,12
ENG253105-function_configuration_kombi_hmi,OFF ,1
ENG248435-ENG251555-function_configuration_pso-iaa_function,Deactivated ,2
ENG248435-ENG297696-function_configuration_pso-iaa_function_new,activated ,2
ENG248435-ENG248795-function_configuration_pso-pso_function,activated ,2
ENG253393-ENG126143-function_configuration_safe_part-RVC_video_input,Ethernet ,1
ENG253393-ENG260501-function_configuration_safe_part-smartlight_sg,installed ,1
ENG253308-IDE15905-Longitudinal_control_coordinator-Travel Assist,Available ,1
ENG253308-MAS00506-Longitudinal_control_coordinator-Adaptive Cruise Control,Available ,1
ENG253308-MAS01891-Longitudinal_control_coordinator-Lane assist,Available ,1
ENG253308-MAS10720-Longitudinal_control_coordinator-Speed limiter,Not available ,1
ENG273497-market_variant,market_NAR ,2
ENG253300-nearby_detection_room,0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 29 00 00 00 91 00 00 00 0B ,60
ENG273498-parkingsystem_video_input,not_active ,3
ENG253258-ENG253440-Safety_belt_warning-belt warning,us_iihs ,4
ENG253258-ENG260400-Safety_belt_warning-optical_delay,250 ,4
ENG253258-ENG259823-Safety_belt_warning-output_as_per_dnh,0 ,4
ENG253258-ENG259235-Safety_belt_warning-sound_delay,250 ,4
ENG253230-slider_parameter,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,20
ENG253322-sound_setting_safe,external_ethernet ,3
ENG98971-ENG258399-Temperature-dz_blocking_time_after_v_bigger_0,15 s,17
ENG98971-ENG260251-Temperature-dz_ice_warning_entry_temperature,4 °C,17
ENG98971-ENG260054-Temperature-dz_ice_warning_exit_temperature,6 °C,17
ENG98971-ENG260680-Temperature-dz_kmt_at_delta,50 °C,17
ENG98971-ENG259162-Temperature-dz_mileage_after_v_bigger_0,5.00 km,17
ENG98971-ENG260943-Temperature-dz_outside_temperature_raw_value,10 °C,17
ENG98971-ENG258861-Temperature-dz_speed_threshold,20 km/h,17
ENG98971-ENG259046-Temperature-dz_storage_time_engine_off,180 min,17
ENG98971-ENG258672-Temperature-dz_tendency_damping,15 s,17
ENG98971-ENG260226-Temperature-dz_tendency_threshold,1.00 °C,17
ENG98971-ENG258728-Temperature-dz_time_constant_pt1,40 s,17
ENG98971-ENG259647-Temperature-dz_time_constant_slow_damping,2.00 ,17
ENG253399-ENG259170-Trip_computer-bc_overflow_reset_distance,10000 km,24
ENG253399-ENG259852-Trip_computer-bc_overflow_reset_longDistance,100000 km,24
ENG253399-ENG259063-Trip_computer-bc_overflow_reset_longTime,364 d,24
ENG253399-ENG261363-Trip_computer-bc_overflow_reset_time,29 d,24
ENG253399-ENG259723-Trip_computer-consumption_kmh_hysterese_over_threshold,5 km/h,24
ENG253399-ENG258320-Trip_computer-consumption_kmh_hysterese_under_threshold,3 km/h,24
ENG253399-ENG258334-Trip_computer-e1_reset_server_answer,1000 ms,24
ENG253399-ENG258984-Trip_computer-e2_reset_server_answer,200 ms,24
ENG253399-ENG260666-Trip_computer-e3_reset_server_answer,1000 ms,24
ENG253399-ENG260753-Trip_computer-e4_reset_server_answer,200 ms,24
ENG253399-ENG253454-Trip_computer-MFA3_Reset_automatic_electric,automatic ,24
ENG253399-ENG253443-Trip_computer-MFA3_Reset_automatic_gas,automatic ,24
ENG253399-ENG253442-Trip_computer-MFA3_Reset_automatic_otto_diesel,automatic ,24
ENG253399-ENG258310-Trip_computer-show_old_values_meter,2 m,24
ENG253399-ENG259908-Trip_computer-standing_time_cycleTerm,120 ,24
ENG253277-IDE00301-unit_master_da-Distance,Kilometers ,4
ENG253277-IDE06005-unit_master_da-Time format,24h ,4
ENG253277-MAS01230-unit_master_da-Date,dd_mm_yy ,4
ENG253277-MAS01456-unit_master_da-Speed,Kilometers per hour ,4
ENG253277-MAS02201-unit_master_da-Temperature,Degrees Celsius ,4
ENG253277-MAS03032-unit_master_da-Volume,Liters ,4
ENG253277-MAS03034-unit_master_da-Pressure,bar ,4
ENG253277-MAS05637-unit_master_da-Operating range consumption: CNG (compressed natural gas),kg per 100 km ,4
ENG253277-MAS05638-unit_master_da-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Liters per 100 km ,4
ENG253277-ENG258372-unit_master_da-consumption_electric,kwh_per_100_km ,4
ENG253277-ENG253460-unit_master_da-Towing_capacity_mass,kilogram (kg) ,4
Elapsed Time: 00:26
adpmap-6C-1EE-907-556-A_WVG5WVEB2SH017765-20250325-1232.CSV
;SW:1EE-907-556-A   HW:5WA-907-556-D ---  Back-up Cam.
;Component:TV eEntry     H32 0605, Coding:060300003F140000
;EV_CamSysTVFicosUNECE,002004,EV_CamSysTVFicosUNECE_VWE3.rod
;Tuesday,25,March,2025,12:32:38:58926
;VCDS Version: Release 25.3.0 (x64)  Data version: 20250311 DS365.0
IDE07159-MAS01155-Control module switch-off: counter-Control module,255 ,2
IDE07159-MAS05583-Control module switch-off: counter-Data bus,255 ,2
IDE07160-MAS01155-Control module switch-off: switch-off time-Control module,14 min ,2
IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,Unknown (0),2
Elapsed Time: 00:02
adpmap-6D-4KE-959-107-B_WVG5WVEB2SH017765-20250325-1232.CSV
;SW:4KE-959-107-B   HW:4KE-959-107-B ---  Trunk Elect.
;Component:HDSG-Modul    H08 0342, Coding:6208
;EV_DeckLidCONTIAU536,001006,EV_DeckLidCONTIAU536_001_VWE3.rod
;Tuesday,25,March,2025,12:32:54:58926
IDE00001-IDE03415-Production mode-Tone sensor,not active ,3
IDE00001-IDE10408-Production mode-Opening height in production mode,not active ,3
IDE00001-MAS10733-Production mode-Activation due to excessive pressure on rear lid,not active ,3
IDE00001-MAS10734-Production mode-Activation of rear lid with reduced speed,not active ,3
IDE00001-MAS10735-Production mode-Calibration,not active ,3
IDE00001-MAS10736-Production mode-Checking the rear lid button,not active ,3
IDE00001-MAS10738-Production mode-Opening and closing rear lid,not active ,3
IDE02158-Program opening stop,4717 ,2
IDE03435-Detection area upper,80 ,2
IDE03776-Offset for maximum programmable opening stop,45 ,2
IDE07160-MAS01155-Control module switch-off: switch-off time-Control module,15 min,2
IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,15 min,2
IDE09510-IDE02111-Tailgate reverse path-Reverse path when opening,453 ,4
IDE09510-IDE02113-Tailgate reverse path-Reverse path when closing,0 ,4
IDE09511-Minimum opening height of tailgate,1200 ,2
IDE09512-Deactivation of tailgate,active ,1
IDE09514-MAS01871-Deactivation of tailgate while in trailer operation-Rear lid lock button in luggage compartment,active ,2
IDE09514-MAS06265-Deactivation of tailgate while in trailer operation-Release button in rear lid handle,active ,2
IDE09514-MAS09010-Deactivation of tailgate while in trailer operation-Sensor for rear lid opening,active ,2
IDE09514-MAS09042-Deactivation of tailgate while in trailer operation-Using button to close lock. mechanism in tailgate handle,active ,2
IDE09514-MAS09043-Deactivation of tailgate while in trailer operation-Remote ctrl: opening with button for tailgate unlock. mechan.,not active ,2
IDE09514-MAS09044-Deactivation of tailgate while in trailer operation-Remote ctrl: closing with button for tailgate unlock. mechan.,not active ,2
IDE09514-MAS09045-Deactivation of tailgate while in trailer operation-Using sensor to open tailgate,not active ,2
IDE09514-MAS09046-Deactivation of tailgate while in trailer operation-Using sensor to close tailgate,not active ,2
IDE09514-MAS09063-Deactivation of tailgate while in trailer operation-Opening with button for remote unlocking of tailgate,not active ,2
IDE09514-MAS09064-Deactivation of tailgate while in trailer operation-Closing with remote unl.button of tailgate when using a trailer,not active ,2
IDE09514-MAS11625-Deactivation of tailgate while in trailer operation-Button for opening rear lid in luggage compartment,active ,2
IDE09514-MAS13754-Deactivation of tailgate while in trailer operation-Opening with button 2 for remote unlocking of rear lid,not active ,2
IDE09514-MAS13755-Deactivation of tailgate while in trailer operation-Closing with remote unlock.butt.2 of rear lid when using trail.,not active ,2
IDE09514-MAS27006-Deactivation of tailgate while in trailer operation-Actuations for the rear lid opener in the virtual remote control vehicle key,active ,2
IDE09514-MAS27007-Deactivation of tailgate while in trailer operation-Actuations for the rear lid closure in the virtual remote control vehicle key,active ,2
IDE09520-Offset for opening height after basic setting,0 ,2
IDE10408-Opening height in production mode,0 %,2
IDE10695-Dectivation of the luggage compartment cover,not active ,1
IDE10703-Luggage compartment cover: tolerance of the block counter,80 ,2
IDE10704-Luggage compartment cover: maximum no. of block drives,7 ,2
IDE10705-Luggage compartment cover: number bloom drives,100 ,2
IDE10706-MAS01875-Luggage compartment cover: reverse path after obstacle recogn.-Open,8 ,4
IDE10706-MAS01876-Luggage compartment cover: reverse path after obstacle recogn.-Close,8 ,4
IDE10707-IDE03434-Luggage compartment cover: detection area-Detection area lower,120 ,4
IDE10707-IDE03435-Luggage compartment cover: detection area-Detection area upper,120 ,4
IDE10708-Luggage compartment cover: adjust. track tolerance,352 ,2
IDE10709-Luggage compartment cover: excess limitation in exclusion area,not active ,1
ENG131232-MAS01911-Ausstattungen aktivieren-Tone sensor,active ,2
ENG131232-MAS01947-Ausstattungen aktivieren-Clamping strip 1,not active ,2
ENG131232-MAS01948-Ausstattungen aktivieren-Clamping strip 2,not active ,2
ENG131232-MAS01949-Ausstattungen aktivieren-Clamping strip 3,not active ,2
ENG131232-MAS01950-Ausstattungen aktivieren-Clamping strip 4,not active ,2
ENG131232-MAS04266-Ausstattungen aktivieren-Temperature sensor 1,not active ,2
ENG131232-MAS04267-Ausstattungen aktivieren-Temperature sensor 2,not active ,2
ENG131232-MAS08212-Ausstattungen aktivieren-Motor 2,active ,2
ENG131232-MAS09001-Ausstattungen aktivieren-Closing Assist Motor,active ,2
ENG131232-MAS11624-Ausstattungen aktivieren-Motor 2: sensor system,active ,2
Elapsed Time: 00:06
adpmap-75-14A-035-285-A_WVG5WVEB2SH017765-20250325-1233.CSV
;SW:14A-035-285-A   HW:14A-035-285 ---  Telematics
;Component:OCU4MEB_UNECE H11 0554, Coding:06020700010000000000010013000000101112111012000010
;EV_OCUGen4UNECE,001050,EV_OCUGen4UNECE_VWE3.rod
;Tuesday,25,March,2025,12:33:30:58926
;VCID: 1E6EB06E9039B71A9DA-804A-R SFD+SFD2
IDE00608-MAS00713-Fuel type-Petrol,not installed ,1
IDE00608-MAS00716-Fuel type-Diesel,not installed ,1
IDE00608-MAS00717-Fuel type-Petroleum gas,not installed ,1
IDE00608-MAS00718-Fuel type-Natural gas,not installed ,1
IDE00608-MAS00720-Fuel type-Battery / electric,installed ,1
IDE00608-MAS03131-Fuel type-Hydrogen,not installed ,1
IDE00761-MAS08397-Run-on time-Long term energy budget,3600 mAh,5
IDE00761-MAS08398-Run-on time-Short term energy budget,1000 mAh,5
IDE00761-MAS08399-Run-on time-Waiting period from sleep to standby mode,5 min,5
IDE00765-Delay of audio output,1.0 s,1
IDE00769-Call number 1 for info call,empty ,5
IDE00770-Number 1 for roadside assistance,empty ,5
IDE00820-Activating and deactivating all development messages-,not activated ,1
IDE00820-ENG263580-Activating and deactivating all development messages-gnss_position_debug_traces,On ,1
IDE01718-Crash signal,10 ms ,1
IDE02330-Call number 2 for info call,empty ,5
IDE02331-Number 2 for roadside assistance,empty ,5
IDE03581-MAS00478-Vehicle function list CAN-Reserved,0 ,3
IDE03581-ENG183857-Vehicle function list CAN-brakes,activated ,3
IDE03581-ENG252060-Vehicle function list CAN-Central_Electrics,activated ,3
IDE03581-ENG252042-Vehicle function list CAN-Engine,activated ,3
IDE03581-ENG98593-Vehicle function list CAN-Gateway,activated ,3
IDE04307-MAS02444-Vehicle function list BAP-Central locking,activated ,11
IDE04307-MAS23900-Vehicle function list BAP-BAP distance IAA_PSO_0x52,activated ,11
IDE07159-MAS01155-Control module switch-off: counter-Control module,0 ,2
IDE07159-MAS05583-Control module switch-off: counter-Data bus,0 ,2
IDE07160-IDE15110-Control module switch-off: switch-off time-Coupling shut-off time: data bus with low-voltage energy management,1 ,2
IDE07160-MAS01155-Control module switch-off: switch-off time-Control module,3 ,2
IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,48 ,2
IDE07699-Mobile network operator,info.m2mcubic.com ,21
IDE08814-MAS07829-Navigation receiver GNSS configuration-Glonass,OFF ,1
IDE08814-MAS14301-Navigation receiver GNSS configuration-external GPS receiver via bus,OFF ,1
IDE08814-ENG244944-Navigation receiver GNSS configuration-Beidou,OFF ,1
IDE08814-ENG244974-Navigation receiver GNSS configuration-Dead_reckoning_position_transmission,On ,1
IDE08814-ENG245012-Navigation receiver GNSS configuration-GPS_output_on_CAN,On ,1
IDE13547-ENG101574-Dimming curve of the red functional lighting in case of various colors at the same time-X1,0 ,12
IDE13547-ENG99557-Dimming curve of the red functional lighting in case of various colors at the same time-X2,20 ,12
IDE13547-ENG102140-Dimming curve of the red functional lighting in case of various colors at the same time-X3,50 ,12
IDE13547-ENG102936-Dimming curve of the red functional lighting in case of various colors at the same time-X4,100 ,12
IDE13547-ENG103548-Dimming curve of the red functional lighting in case of various colors at the same time-X5,150 ,12
IDE13547-ENG113992-Dimming curve of the red functional lighting in case of various colors at the same time-X6,253 ,12
IDE13547-ENG99777-Dimming curve of the red functional lighting in case of various colors at the same time-Y1,0 %,12
IDE13547-ENG100480-Dimming curve of the red functional lighting in case of various colors at the same time-Y2,1 %,12
IDE13547-ENG100773-Dimming curve of the red functional lighting in case of various colors at the same time-Y3,2 %,12
IDE13547-ENG100631-Dimming curve of the red functional lighting in case of various colors at the same time-Y4,3 %,12
IDE13547-ENG102174-Dimming curve of the red functional lighting in case of various colors at the same time-Y5,40 %,12
IDE13547-ENG113993-Dimming curve of the red functional lighting in case of various colors at the same time-Y6,50 %,12
IDE13548-ENG101574-Dimming curve of the green functional lighting in case of various colors at the same time-X1,0 ,12
IDE13548-ENG99557-Dimming curve of the green functional lighting in case of various colors at the same time-X2,20 ,12
IDE13548-ENG102140-Dimming curve of the green functional lighting in case of various colors at the same time-X3,50 ,12
IDE13548-ENG102936-Dimming curve of the green functional lighting in case of various colors at the same time-X4,100 ,12
IDE13548-ENG103548-Dimming curve of the green functional lighting in case of various colors at the same time-X5,150 ,12
IDE13548-ENG113992-Dimming curve of the green functional lighting in case of various colors at the same time-X6,253 ,12
IDE13548-ENG99777-Dimming curve of the green functional lighting in case of various colors at the same time-Y1,0 %,12
IDE13548-ENG100480-Dimming curve of the green functional lighting in case of various colors at the same time-Y2,1 %,12
IDE13548-ENG100773-Dimming curve of the green functional lighting in case of various colors at the same time-Y3,2 %,12
IDE13548-ENG100631-Dimming curve of the green functional lighting in case of various colors at the same time-Y4,3 %,12
IDE13548-ENG102174-Dimming curve of the green functional lighting in case of various colors at the same time-Y5,40 %,12
IDE13548-ENG113993-Dimming curve of the green functional lighting in case of various colors at the same time-Y6,50 %,12
IDE15074-MAS13668-Broadband audio-Emergency call,not activated ,1
IDE15074-MAS20714-Broadband audio-Breakdown assistance/information call,not activated ,1
IDE16311-MAS22303-Voice amplification for call services-Radio voice amplification: voice services,20 00 ,8
IDE16311-MAS22305-Voice amplification for call services-Emergency call speaker voice amplification: normal state,20 00 ,8
IDE16311-MAS22306-Voice amplification for call services-Emergency call speaker voice amplification: emergency battery,20 00 ,8
IDE16311-MAS22307-Voice amplification for call services-Emergency call speaker voice amplification: low temperature,20 00 ,8
IDE16364-IDE16536-List of identifiers and data record numbers-Identifier,00 00 ,2
IDE16364-MAS25708-List of identifiers and data record numbers-Number Of Identifiers,0 ,2
MAS01078-Vehicle model,Passenger car (category M1) ,1
MAS08170-User profile name,blank ,5
MAS08171-User profile password,blank ,5
MAS08172-Mobile Online services: first host name-,https://api.csa.na.dp15.vwg-connect.com/ ,86
MAS08172-MAS17438-Mobile Online services: first host name-Preselection of host names,free ,86
MAS08172-ENG247627-Mobile Online services: first host name-Online_Service_Backend_Type,AERIS ,86
MAS08175-IDE02634-Mobile Online services: activation threshold-Lock time during deactivation,0 min,3
MAS08175-MAS07123-Mobile Online services: activation threshold-Distance for activation,0 km,3
MAS08366-MAS01487-Keypad-LED,Direct ,1
MAS08366-MAS10536-Keypad-Keys,Normal/Hybrid ,1
MAS08981-ENG101574-Dimming charac. curve of red function illumination-X1,0 ,12
MAS08981-ENG99557-Dimming charac. curve of red function illumination-X2,10 ,12
MAS08981-ENG102140-Dimming charac. curve of red function illumination-X3,50 ,12
MAS08981-ENG102936-Dimming charac. curve of red function illumination-X4,100 ,12
MAS08981-ENG103548-Dimming charac. curve of red function illumination-X5,150 ,12
MAS08981-ENG113992-Dimming charac. curve of red function illumination-X6,253 ,12
MAS08981-ENG99777-Dimming charac. curve of red function illumination-Y1,1 %,12
MAS08981-ENG100480-Dimming charac. curve of red function illumination-Y2,1 %,12
MAS08981-ENG100773-Dimming charac. curve of red function illumination-Y3,2 %,12
MAS08981-ENG100631-Dimming charac. curve of red function illumination-Y4,4 %,12
MAS08981-ENG102174-Dimming charac. curve of red function illumination-Y5,80 %,12
MAS08981-ENG113993-Dimming charac. curve of red function illumination-Y6,100 %,12
MAS08982-ENG101574-Dimming charac. curve of green function illumination-X1,0 ,12
MAS08982-ENG99557-Dimming charac. curve of green function illumination-X2,10 ,12
MAS08982-ENG102140-Dimming charac. curve of green function illumination-X3,50 ,12
MAS08982-ENG102936-Dimming charac. curve of green function illumination-X4,100 ,12
MAS08982-ENG103548-Dimming charac. curve of green function illumination-X5,150 ,12
MAS08982-ENG113992-Dimming charac. curve of green function illumination-X6,253 ,12
MAS08982-ENG99777-Dimming charac. curve of green function illumination-Y1,1 %,12
MAS08982-ENG100480-Dimming charac. curve of green function illumination-Y2,1 %,12
MAS08982-ENG100773-Dimming charac. curve of green function illumination-Y3,2 %,12
MAS08982-ENG100631-Dimming charac. curve of green function illumination-Y4,4 %,12
MAS08982-ENG102174-Dimming charac. curve of green function illumination-Y5,80 %,12
MAS08982-ENG113993-Dimming charac. curve of green function illumination-Y6,100 %,12
MAS13840-Gnss data transmission rate,10 Hz ,2
MAS13841-Gnss min height,5 °,2
MAS16952-ENG101574-Dimming characteristics of pushbutton module-X1,0 ,6
MAS16952-ENG99557-Dimming characteristics of pushbutton module-X2,50 ,6
MAS16952-ENG102140-Dimming characteristics of pushbutton module-X3,100 ,6
MAS16952-ENG99777-Dimming characteristics of pushbutton module-Y1,0 %,6
MAS16952-ENG100480-Dimming characteristics of pushbutton module-Y2,50 %,6
MAS16952-ENG100773-Dimming characteristics of pushbutton module-Y3,100 %,6
MAS17119-ENG245041-Fault memory mobile online service threshold-Step_00,100 ,32
MAS17119-ENG244993-Fault memory mobile online service threshold-Step_01,100 ,32
MAS17119-ENG244984-Fault memory mobile online service threshold-Step_02,100 ,32
MAS17119-ENG245001-Fault memory mobile online service threshold-Step_03,100 ,32
MAS17119-ENG245016-Fault memory mobile online service threshold-Step_04,100 ,32
MAS17119-ENG245017-Fault memory mobile online service threshold-Step_05,100 ,32
MAS17119-ENG245042-Fault memory mobile online service threshold-Step_06,100 ,32
MAS17119-ENG245043-Fault memory mobile online service threshold-Step_07,100 ,32
MAS17119-ENG244962-Fault memory mobile online service threshold-Step_08,0 ,32
MAS17119-ENG245032-Fault memory mobile online service threshold-Step_09,0 ,32
MAS17119-ENG245002-Fault memory mobile online service threshold-Step_10,0 ,32
MAS17119-ENG245003-Fault memory mobile online service threshold-Step_11,0 ,32
MAS17119-ENG245018-Fault memory mobile online service threshold-Step_12,0 ,32
MAS17119-ENG244967-Fault memory mobile online service threshold-Step_13,0 ,32
MAS17119-ENG244985-Fault memory mobile online service threshold-Step_14,0 ,32
MAS17119-ENG244968-Fault memory mobile online service threshold-Step_15,0 ,32
MAS17439-Wifi hotspot mobile phone connection: network operator,wifi.m2mcubic.com ,17
MAS17460-Wifi hotspot mobile phone connection: user profile name,blank ,5
MAS17461-Wifi hotspot mobile phone connection: password,blank ,5
MAS17562-Query interval for Real Time Monitoring,1 s,1
MAS18271-Acoustic return message for breakdown assistance call system,activated ,1
MAS18272-Breakdown assistance call: protocol version,Generation_20 ,1
MAS18603-ENG247383-Damping factor for dimming up and down-Ambient_Light_Illumination_Damping_Down,0.1 s,4
MAS18603-ENG247384-Damping factor for dimming up and down-Ambient_Light_Illumination_Damping_Up,0.2 s,4
MAS18603-ENG247607-Damping factor for dimming up and down-Functional_Illumination_Damping_Down,0.1 s,4
MAS18603-ENG247608-Damping factor for dimming up and down-Functional_Illumination_Damping_Up,0.2 s,4
MAS25498-MAS16261-Privacy mode: vehicle setting-Flight mode,not active ,1
MAS25498-MAS25501-Privacy mode: vehicle setting-Fleet mode,not active ,1
ENG253242-ENG259195-a2b_data_streams-Emergency_mic_transducer_selection,mic_transducer_3 ,10
ENG253242-ENG260060-a2b_data_streams-Multi_Center_Speaker_via_Connectivity_Unit,Not_present ,10
ENG253242-ENG113413-a2b_data_streams-reserved_01,0 ,10
ENG253242-ENG261390-a2b_data_streams-reserved_02,0 ,10
ENG253242-ENG261450-a2b_data_streams-reserved_03,0 ,10
ENG253242-ENG261451-a2b_data_streams-reserved_04,0 ,10
ENG253242-ENG261386-a2b_data_streams-Reserved_05,0 ,10
ENG253242-ENG261387-a2b_data_streams-Reserved_06,0 ,10
ENG253242-ENG261388-a2b_data_streams-Reserved_07,0 ,10
ENG253242-ENG259380-a2b_data_streams-Transducer_amount_mic_front_module_node,3 ,10
ENG253242-ENG260344-a2b_data_streams-Transducer_amount_mic_module_rear_left_node,0 ,10
ENG253242-ENG259983-a2b_data_streams-Transducer_amount_mic_module_rear_right_node,0 ,10
ENG253218-ENG260862-function_configuration_a2b_topology-a2b_topology,Infotainment_Unit_with_external_mic ,5
ENG253218-ENG253474-function_configuration_a2b_topology-connectivity_unit,present ,5
ENG253218-ENG376637-function_configuration_a2b_topology-Emergency_Mic_uses_I2S,false ,5
ENG253218-ENG259051-function_configuration_a2b_topology-Infotainment_Mic_Unit,Not_present ,5
ENG253218-ENG253475-function_configuration_a2b_topology-infotainment_unit,present ,5
ENG253218-ENG258377-function_configuration_a2b_topology-MIC_MOD_rear_L,Not_present ,5
ENG253218-ENG259527-function_configuration_a2b_topology-MIC_MOD_rear_R,Not_present ,5
ENG253218-ENG258542-function_configuration_a2b_topology-Mic_Module_Roof,present ,5
ENG253218-ENG113413-function_configuration_a2b_topology-reserved_01,0 ,5
ENG253218-ENG261390-function_configuration_a2b_topology-reserved_02,0 ,5
ENG253218-ENG261450-function_configuration_a2b_topology-reserved_03,0 ,5
ENG244879-function_configuration_sw_update,General reject,5
ENG153885-MAS21993-Knockout_test_mode-Return value idle bus,OFF ,1
ENG153885-MAS21994-Knockout_test_mode-Veto,OFF ,1
ENG153885-ENG413847-Knockout_test_mode-Supress_veto,OFF ,1
ENG422523-ENG252007-Privacy_markets-Privacy_mode,connected ,1
ENG422523-ENG403571-Privacy_markets-Privacy_sim_mode,dormant ,1
ENG123198-ENG123365-Voice_Connection_Timeouts-Call_Failed_Timer,30 s,6
ENG123198-ENG123367-Voice_Connection_Timeouts-Redial_Attempts,0 ,6
ENG123198-ENG123369-Voice_Connection_Timeouts-Redial_Timer,2 s,6
ENG123198-ENG123370-Voice_Connection_Timeouts-Voice_Data_Transfer_Failed_Timer,20 s,6
ENG123198-ENG123366-Voice_Connection_Timeouts-Wait_Tone_Timer,30 s,6
Elapsed Time: 00:16
adpmap-7E-10A-920-320-D_WVG5WVEB2SH017765-20250325-1233.CSV
;SW:10A-920-320-D   HW:10A-920-320-D ---  Ctrl Head Dash
;Component:FAHRERDISPLAY 031 0650, Coding:267001
;EV_DashBoardLGMEB,002032,EV_DashBoardLGMEB_002_VWE3.rod
;Tuesday,25,March,2025,12:33:55:58926
;VCID: 167EA84E7809FF5A45A-8042-R SFD
IDE07159-MAS01155-Control module switch-off: counter-Control module,00 ,2
IDE07159-MAS05583-Control module switch-off: counter-Data bus,00 ,2
IDE07160-IDE15110-Control module switch-off: switch-off time-Coupling shut-off time: data bus with low-voltage energy management,NVEM coupling not active or not implemented ,2
IDE07160-MAS01155-Control module switch-off: switch-off time-Control module,15 ,2
IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,15 ,2
ENG119877-ENG98401-Configuration of Development CAN-Messages-Block 1,OUT ,8
ENG119877-ENG98402-Configuration of Development CAN-Messages-Block 10,OUT ,8
ENG119877-ENG98445-Configuration of Development CAN-Messages-Block 11,OUT ,8
ENG119877-ENG98403-Configuration of Development CAN-Messages-Block 12,OUT ,8
ENG119877-ENG98446-Configuration of Development CAN-Messages-Block 13,OUT ,8
ENG119877-ENG98452-Configuration of Development CAN-Messages-Block 2,OUT ,8
ENG119877-ENG98408-Configuration of Development CAN-Messages-Block 3,OUT ,8
ENG119877-ENG98410-Configuration of Development CAN-Messages-Block 4,OUT ,8
ENG119877-ENG98460-Configuration of Development CAN-Messages-Block 5,OUT ,8
ENG119877-ENG98461-Configuration of Development CAN-Messages-Block 6,OUT ,8
ENG119877-ENG98462-Configuration of Development CAN-Messages-Block 7,OUT ,8
ENG119877-ENG98411-Configuration of Development CAN-Messages-Block 8,OUT ,8
ENG119877-ENG98463-Configuration of Development CAN-Messages-Block 9,OUT ,8
ENG278391-ENG101574-dimming_characteristic_curve_adjustment_functional_lighting_indicator_lights_green-X1,00 ,18
ENG278391-ENG99557-dimming_characteristic_curve_adjustment_functional_lighting_indicator_lights_green-X2,0A ,18
ENG278391-ENG102140-dimming_characteristic_curve_adjustment_functional_lighting_indicator_lights_green-X3,32 ,18
ENG278391-ENG102936-dimming_characteristic_curve_adjustment_functional_lighting_indicator_lights_green-X4,64 ,18
ENG278391-ENG103548-dimming_characteristic_curve_adjustment_functional_lighting_indicator_lights_green-X5,96 ,18
ENG278391-ENG113992-dimming_characteristic_curve_adjustment_functional_lighting_indicator_lights_green-X6,FD ,18
ENG278391-ENG99777-dimming_characteristic_curve_adjustment_functional_lighting_indicator_lights_green-Y1,00 0A ,18
ENG278391-ENG100480-dimming_characteristic_curve_adjustment_functional_lighting_indicator_lights_green-Y2,00 0A ,18
ENG278391-ENG100773-dimming_characteristic_curve_adjustment_functional_lighting_indicator_lights_green-Y3,00 14 ,18
ENG278391-ENG100631-dimming_characteristic_curve_adjustment_functional_lighting_indicator_lights_green-Y4,00 28 ,18
ENG278391-ENG102174-dimming_characteristic_curve_adjustment_functional_lighting_indicator_lights_green-Y5,01 F4 ,18
ENG278391-ENG113993-dimming_characteristic_curve_adjustment_functional_lighting_indicator_lights_green-Y6,03 E8 ,18
ENG278408-ENG101574-dimming_characteristic_curve_adjustment_functional_lighting_indicator_lights_red-X1,00 ,18
ENG278408-ENG99557-dimming_characteristic_curve_adjustment_functional_lighting_indicator_lights_red-X2,0A ,18
ENG278408-ENG102140-dimming_characteristic_curve_adjustment_functional_lighting_indicator_lights_red-X3,32 ,18
ENG278408-ENG102936-dimming_characteristic_curve_adjustment_functional_lighting_indicator_lights_red-X4,64 ,18
ENG278408-ENG103548-dimming_characteristic_curve_adjustment_functional_lighting_indicator_lights_red-X5,96 ,18
ENG278408-ENG113992-dimming_characteristic_curve_adjustment_functional_lighting_indicator_lights_red-X6,FD ,18
ENG278408-ENG99777-dimming_characteristic_curve_adjustment_functional_lighting_indicator_lights_red-Y1,00 0A ,18
ENG278408-ENG100480-dimming_characteristic_curve_adjustment_functional_lighting_indicator_lights_red-Y2,00 0A ,18
ENG278408-ENG100773-dimming_characteristic_curve_adjustment_functional_lighting_indicator_lights_red-Y3,00 19 ,18
ENG278408-ENG100631-dimming_characteristic_curve_adjustment_functional_lighting_indicator_lights_red-Y4,00 32 ,18
ENG278408-ENG102174-dimming_characteristic_curve_adjustment_functional_lighting_indicator_lights_red-Y5,01 F4 ,18
ENG278408-ENG113993-dimming_characteristic_curve_adjustment_functional_lighting_indicator_lights_red-Y6,03 E8 ,18
ENG278390-ENG101574-dimming_characteristic_curve_adjustment_functional_lighting_indicator_lights_white-X1,00 ,18
ENG278390-ENG99557-dimming_characteristic_curve_adjustment_functional_lighting_indicator_lights_white-X2,0A ,18
ENG278390-ENG102140-dimming_characteristic_curve_adjustment_functional_lighting_indicator_lights_white-X3,32 ,18
ENG278390-ENG102936-dimming_characteristic_curve_adjustment_functional_lighting_indicator_lights_white-X4,64 ,18
ENG278390-ENG103548-dimming_characteristic_curve_adjustment_functional_lighting_indicator_lights_white-X5,96 ,18
ENG278390-ENG113992-dimming_characteristic_curve_adjustment_functional_lighting_indicator_lights_white-X6,FD ,18
ENG278390-ENG99777-dimming_characteristic_curve_adjustment_functional_lighting_indicator_lights_white-Y1,00 0A ,18
ENG278390-ENG100480-dimming_characteristic_curve_adjustment_functional_lighting_indicator_lights_white-Y2,00 0A ,18
ENG278390-ENG100773-dimming_characteristic_curve_adjustment_functional_lighting_indicator_lights_white-Y3,00 19 ,18
ENG278390-ENG100631-dimming_characteristic_curve_adjustment_functional_lighting_indicator_lights_white-Y4,00 32 ,18
ENG278390-ENG102174-dimming_characteristic_curve_adjustment_functional_lighting_indicator_lights_white-Y5,01 F4 ,18
ENG278390-ENG113993-dimming_characteristic_curve_adjustment_functional_lighting_indicator_lights_white-Y6,03 E8 ,18
ENG278401-ENG101574-dimming_characteristic_curve_adjustment_functional_lighting_indicator_lights_yellow-X1,00 ,18
ENG278401-ENG99557-dimming_characteristic_curve_adjustment_functional_lighting_indicator_lights_yellow-X2,0A ,18
ENG278401-ENG102140-dimming_characteristic_curve_adjustment_functional_lighting_indicator_lights_yellow-X3,32 ,18
ENG278401-ENG102936-dimming_characteristic_curve_adjustment_functional_lighting_indicator_lights_yellow-X4,64 ,18
ENG278401-ENG103548-dimming_characteristic_curve_adjustment_functional_lighting_indicator_lights_yellow-X5,96 ,18
ENG278401-ENG113992-dimming_characteristic_curve_adjustment_functional_lighting_indicator_lights_yellow-X6,FD ,18
ENG278401-ENG99777-dimming_characteristic_curve_adjustment_functional_lighting_indicator_lights_yellow-Y1,00 0A ,18
ENG278401-ENG100480-dimming_characteristic_curve_adjustment_functional_lighting_indicator_lights_yellow-Y2,00 0A ,18
ENG278401-ENG100773-dimming_characteristic_curve_adjustment_functional_lighting_indicator_lights_yellow-Y3,00 19 ,18
ENG278401-ENG100631-dimming_characteristic_curve_adjustment_functional_lighting_indicator_lights_yellow-Y4,00 32 ,18
ENG278401-ENG102174-dimming_characteristic_curve_adjustment_functional_lighting_indicator_lights_yellow-Y5,01 F4 ,18
ENG278401-ENG113993-dimming_characteristic_curve_adjustment_functional_lighting_indicator_lights_yellow-Y6,03 E8 ,18
ENG105836-ENG101574-dimming_characteristic_curve_adjustment_middle_display_main_field-X1,00 ,18
ENG105836-ENG99557-dimming_characteristic_curve_adjustment_middle_display_main_field-X2,0A ,18
ENG105836-ENG102140-dimming_characteristic_curve_adjustment_middle_display_main_field-X3,32 ,18
ENG105836-ENG102936-dimming_characteristic_curve_adjustment_middle_display_main_field-X4,64 ,18
ENG105836-ENG103548-dimming_characteristic_curve_adjustment_middle_display_main_field-X5,96 ,18
ENG105836-ENG113992-dimming_characteristic_curve_adjustment_middle_display_main_field-X6,FD ,18
ENG105836-ENG99777-dimming_characteristic_curve_adjustment_middle_display_main_field-Y1,00 0A ,18
ENG105836-ENG100480-dimming_characteristic_curve_adjustment_middle_display_main_field-Y2,00 0A ,18
ENG105836-ENG100773-dimming_characteristic_curve_adjustment_middle_display_main_field-Y3,00 1E ,18
ENG105836-ENG100631-dimming_characteristic_curve_adjustment_middle_display_main_field-Y4,00 3C ,18
ENG105836-ENG102174-dimming_characteristic_curve_adjustment_middle_display_main_field-Y5,01 B8 ,18
ENG105836-ENG113993-dimming_characteristic_curve_adjustment_middle_display_main_field-Y6,03 E8 ,18
ENG278404-ENG101574-dimming_characteristic_curve_adjustment_search_lighting_for_gear_selection-X1,00 ,18
ENG278404-ENG99557-dimming_characteristic_curve_adjustment_search_lighting_for_gear_selection-X2,0A ,18
ENG278404-ENG102140-dimming_characteristic_curve_adjustment_search_lighting_for_gear_selection-X3,32 ,18
ENG278404-ENG102936-dimming_characteristic_curve_adjustment_search_lighting_for_gear_selection-X4,64 ,18
ENG278404-ENG103548-dimming_characteristic_curve_adjustment_search_lighting_for_gear_selection-X5,96 ,18
ENG278404-ENG113992-dimming_characteristic_curve_adjustment_search_lighting_for_gear_selection-X6,FD ,18
ENG278404-ENG99777-dimming_characteristic_curve_adjustment_search_lighting_for_gear_selection-Y1,00 06 ,18
ENG278404-ENG100480-dimming_characteristic_curve_adjustment_search_lighting_for_gear_selection-Y2,00 06 ,18
ENG278404-ENG100773-dimming_characteristic_curve_adjustment_search_lighting_for_gear_selection-Y3,00 0C ,18
ENG278404-ENG100631-dimming_characteristic_curve_adjustment_search_lighting_for_gear_selection-Y4,00 28 ,18
ENG278404-ENG102174-dimming_characteristic_curve_adjustment_search_lighting_for_gear_selection-Y5,01 90 ,18
ENG278404-ENG113993-dimming_characteristic_curve_adjustment_search_lighting_for_gear_selection-Y6,03 E8 ,18
ENG153811-ENG154946-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_X1,14 ,24
ENG153811-ENG154947-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_X2,28 ,24
ENG153811-ENG154948-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_X3,3C ,24
ENG153811-ENG154949-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_X4,50 ,24
ENG153811-ENG154950-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_X5,64 ,24
ENG153811-ENG154951-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_X6,78 ,24
ENG153811-ENG154952-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_Y1,A0 ,24
ENG153811-ENG154953-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_Y2,78 ,24
ENG153811-ENG154954-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_Y3,50 ,24
ENG153811-ENG154955-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_Y4,32 ,24
ENG153811-ENG154956-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_Y5,18 ,24
ENG153811-ENG154957-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_Y6,00 ,24
ENG153811-ENG155080-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_X1,14 ,24
ENG153811-ENG155081-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_X2,28 ,24
ENG153811-ENG155082-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_X3,3C ,24
ENG153811-ENG155083-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_X4,50 ,24
ENG153811-ENG155084-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_X5,64 ,24
ENG153811-ENG155085-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_X6,78 ,24
ENG153811-ENG155086-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_Y1,50 ,24
ENG153811-ENG155087-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_Y2,78 ,24
ENG153811-ENG155088-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_Y3,96 ,24
ENG153811-ENG155089-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_Y4,AA ,24
ENG153811-ENG155090-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_Y5,BE ,24
ENG153811-ENG155091-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_Y6,C8 ,24
ENG277060-ENG101574-dimming_characteristic_curve_day_adjustment_middle_display_main_field-X1,00 ,18
ENG277060-ENG99557-dimming_characteristic_curve_day_adjustment_middle_display_main_field-X2,0A ,18
ENG277060-ENG102140-dimming_characteristic_curve_day_adjustment_middle_display_main_field-X3,32 ,18
ENG277060-ENG102936-dimming_characteristic_curve_day_adjustment_middle_display_main_field-X4,64 ,18
ENG277060-ENG103548-dimming_characteristic_curve_day_adjustment_middle_display_main_field-X5,96 ,18
ENG277060-ENG113992-dimming_characteristic_curve_day_adjustment_middle_display_main_field-X6,FD ,18
ENG277060-ENG99777-dimming_characteristic_curve_day_adjustment_middle_display_main_field-Y1,00 06 ,18
ENG277060-ENG100480-dimming_characteristic_curve_day_adjustment_middle_display_main_field-Y2,00 06 ,18
ENG277060-ENG100773-dimming_characteristic_curve_day_adjustment_middle_display_main_field-Y3,00 0A ,18
ENG277060-ENG100631-dimming_characteristic_curve_day_adjustment_middle_display_main_field-Y4,00 1E ,18
ENG277060-ENG102174-dimming_characteristic_curve_day_adjustment_middle_display_main_field-Y5,01 2C ,18
ENG277060-ENG113993-dimming_characteristic_curve_day_adjustment_middle_display_main_field-Y6,03 E8 ,18
ENG153885-MAS00478-Knockout_test_mode-Reserved,0 ,1
ENG153885-MAS21993-Knockout_test_mode-Return value idle bus,not active ,1
ENG153885-MAS21994-Knockout_test_mode-Veto,not active ,1
ENG153885-MAS21995-Knockout_test_mode-Suppress veto,not active ,1
Elapsed Time: 00:07
adpmap-8C-0Z1-915-184-AE_WVG5WVEB2SH017765-20250325-1235.CSV
;SW:0Z1-915-184-AE   HW:0Z1-915-184-D ---  HV Battery
;Component:J840 K8C  BMC 010 1141, Coding:
;EV_BMCeVWBSMEB,003018,EV_BMCeVWBSMEB_003_VWE3.rod
;Tuesday,25,March,2025,12:35:19:58926
;VCID: 7DAC97E27D7F0C02E40-8028-R
IDE05417-Serial number of H-V / hybrid battery,288 VWHT4BI034X ,15
IDE05963-ASSY part number,1EB915914DJ  ,12
IDE14477-Traction battery: China serial number,ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ ,26
MAS15017-Service mode,not active ,1
MAS29854-Specified installation date,30062025 ,8
Elapsed Time: 00:20
adpmap-A5-1EA-980-653-E_WVG5WVEB2SH017765-20250325-1236.CSV
;SW:1EA-980-653-E   HW:1EA-980-653-A ---  Frt Sens. Drv. Assist
;Component:MEB MFK 4.1   H08 5556, Coding:010A302E1F4500F83724301C4000000000000000000000000000000000000000
;EV_MFK41ValeoMEB,001080,EV_MFK41ValeoMEB_VWE3.rod
;Tuesday,25,March,2025,12:36:43:58926
;VCID: 3B2859FA23EBC2329A4-806E-R SFD+SFD2
IDE04733-Road sign detection fusion mode,Road sign fusion ,1
IDE07159-MAS05583-Control module switch-off: counter-Data bus,7 ,2
IDE07160-IDE15110-Control module switch-off: switch-off time-Coupling shut-off time: data bus with low-voltage energy management,0 ,2
IDE07358-Distance to calibration field,1500.0000 mm,2
IDE09375-IDE05717-Axle offset-Front axle transverse position,-0.1 mm,4
IDE09375-IDE05718-Axle offset-Rear axle transverse position,4.7 mm,4
IDE09376-IDE02001-Body height wheel house edge-Body height left front wheel house edge,808.000 mm,8
IDE09376-IDE02002-Body height wheel house edge-Body height right front wheel house edge,807.000 mm,8
IDE09376-IDE02003-Body height wheel house edge-Body height left rear wheel house edge,807.000 mm,8
IDE09376-IDE02004-Body height wheel house edge-Body height right rear wheel house edge,806.000 mm,8
IDE09391-MAS08824-Calibration target position-Target 1: calibration mark 1: x-coordinate,2400.0000 mm,24
IDE09391-MAS08825-Calibration target position-Target 1: calibration mark 1: y-coordinate,642.5000 mm,24
IDE09391-MAS08826-Calibration target position-Target 1: calibration mark 1: z-coordinate,1456.0000 mm,24
IDE09391-MAS08827-Calibration target position-Target 1: calibration mark 2: x-coordinate,2400.0000 mm,24
IDE09391-MAS08828-Calibration target position-Target 1: calibration mark 2: y-coordinate,-642.5000 mm,24
IDE09391-MAS08829-Calibration target position-Target 1: calibration mark 2: z-coordinate,1456.0000 mm,24
IDE09391-MAS08830-Calibration target position-Target 1: calibration mark 3: x-coordinate,2400.0000 mm,24
IDE09391-MAS08831-Calibration target position-Target 1: calibration mark 3: y-coordinate,642.5000 mm,24
IDE09391-MAS08832-Calibration target position-Target 1: calibration mark 3: z-coordinate,944.0000 mm,24
IDE09391-MAS08833-Calibration target position-Target 1: calibration mark 4: x-coordinate,2400.0000 mm,24
IDE09391-MAS08834-Calibration target position-Target 1: calibration mark 4: y-coordinate,-642.5000 mm,24
IDE09391-MAS08835-Calibration target position-Target 1: calibration mark 4: z-coordinate,944.0000 mm,24
IDE10407-Personalization of intervention moment at T. 15 on,Last setting ,1
IDE10870-Switch-on condition: lane depart. warn.,on (setting via menu) ,1
IDE10873-BAP personalization,activated ,1
IDE10924-MAS02479-Initial calibration: result-Yaw angle,0.6540 °,8
IDE10924-MAS05286-Initial calibration: result-Roll angle,-0.0100 °,8
IDE10924-MAS05287-Initial calibration: result-Pitch angle,-0.9360 °,8
IDE10924-MAS10678-Initial calibration: result-Camera height,1286 mm,8
IDE12097-Menu for roadside fusion persistency,activated ,1
ENG185678-Activation_OCAL,activated ,1
ENG261734-ENG130919-Activation_of_development_messages-Activation_of_development_messages_EHR,not active ,3
ENG261734-ENG185756-Activation_of_development_messages-Activation_of_development_messages_HCA_01,not active ,3
ENG261734-ENG185757-Activation_of_development_messages-Activation_of_development_messages_HCA_02,not active ,3
ENG261734-ENG185758-Activation_of_development_messages-Activation_of_development_messages_lane_1,not active ,3
ENG261734-ENG185759-Activation_of_development_messages-Activation_of_development_messages_lane_2,not active ,3
ENG261734-ENG130915-Activation_of_development_messages-Activation_of_development_messages_reserved,not active ,3
ENG261734-ENG185760-Activation_of_development_messages-Activation_of_development_messages_RFD,not active ,3
ENG261734-ENG278486-Activation_of_development_messages-Activation_of_development_messages_TPA,not_active ,3
ENG261734-ENG185761-Activation_of_development_messages-Activation_of_development_messages_TSF,not_active ,3
ENG261734-ENG185762-Activation_of_development_messages-Activation_of_development_messages_VZF_TSR1,not_active ,3
ENG261734-ENG185763-Activation_of_development_messages-Activation_of_development_messages_VZF_TSR2,not active ,3
ENG261734-ENG130917-Activation_of_development_messages-Activation_of_development_messages_WLA,not active ,3
ENG261734-ENG185770-Activation_of_development_messages-Dev_messages_vd_deaktivation,not active ,3
ENG261734-ENG261744-Activation_of_development_messages-Fge_messages_vd_deaktivation,not active ,3
ENG261735-Activation_PCAL,not_activated ,1
ENG261736-Adaptation_vze_vzf_rsr-,0 ,3
ENG261736-ENG185767-Adaptation_vze_vzf_rsr-country_code_RSR,0 ,3
ENG261736-ENG185809-Adaptation_vze_vzf_rsr-relevance_mode,active ,3
ENG185690-ENG185780-HCA_Development-HCA_Development_1,00 00 00 00 ,24
ENG185690-ENG185781-HCA_Development-HCA_Development_2,00 00 00 00 ,24
ENG185690-ENG185782-HCA_Development-HCA_Development_3,00 00 00 00 ,24
ENG185690-ENG185783-HCA_Development-HCA_Development_4,00 00 00 00 ,24
ENG185690-ENG185784-HCA_Development-HCA_Development_5,00 00 00 00 ,24
ENG185690-ENG185785-HCA_Development-HCA_Development_6,00 00 00 00 ,24
ENG369146-HCA_PSD_Support,not_active ,1
ENG185698-HiL_Funktionsdeaktivierung,4294967295 ,4
ENG153885-Knockout_test_mode,0 ,1
ENG120319-Mask_error_reactions_for_development,not_activated ,1
ENG107577-ENG185789-Masked_fault_classes-Masked_fault_classes_1,255 ,4
ENG107577-ENG185790-Masked_fault_classes-Masked_fault_classes_2,255 ,4
ENG107577-ENG185791-Masked_fault_classes-Masked_fault_classes_3,255 ,4
ENG107577-ENG185792-Masked_fault_classes-Masked_fault_classes_4,255 ,4
ENG261739-sec_switch_port_mirroring,255 ,2
ENG130779-Xcp_interface,not_activated ,1
Elapsed Time: 00:11
adpmap-BE-1N3-959-244-B_WVG5WVEB2SH017765-20250325-1237.CSV
;SW:1N3-959-244-B   HW:1N3-959-244-B ---  Slid. Door Rear Left
;Component:Slidingdoor_d H04 0028, Coding:D600
;EV_SlideDoorDriveHufIDBuz,002110,EV_SlideDoorDriveHufIDBuz_002.rod
;Tuesday,25,March,2025,12:37:08:58926
;VCID: 353C4FC205CF14426C0-8060-R
IDE00001-MAS16327-Production mode-Production mode 1,not active ,3
IDE00001-MAS16328-Production mode-Production mode 2,not active ,3
IDE06000-ENG264179-Customer service mode-KD Mode Bit0,not active ,6
IDE06000-ENG264180-Customer service mode-KD Mode Bit1,not active ,6
MAS21732-ENG264174-Deactivate factory mode-F_Mode_Bit0,not active ,7
MAS21732-ENG264175-Deactivate factory mode-F_Mode_Bit1,not active ,7
ENG276126-Sound,active ,1
Elapsed Time: 00:02
adpmap-BF-1N3-959-244-B_WVG5WVEB2SH017765-20250325-1237.CSV
;SW:1N3-959-244-B   HW:1N3-959-244-B ---  Slid. Door Rear Right
;Component:Slidingdoor_p H04 0028, Coding:D600
;EV_SlideDoorPasseHufIDBuz,002110,EV_SlideDoorPasseHufIDBuz_002.rod
;Tuesday,25,March,2025,12:37:25:58926
IDE00001-MAS16327-Production mode-Production mode 1,active ,3
IDE00001-MAS16328-Production mode-Production mode 2,active ,3
Elapsed Time: 00:02
adpmap-C0-1T3-035-335-A_WVG5WVEB2SH017765-20250325-1237.CSV
;SW:1T3-035-335-A   HW:1EA-035-335 ---  Act. for Ext. Noise
;Component:E_SOUND_SG    H06 0006, Coding:
;EV_ESounHarmaMEBUNECE,001006,EV_ESounHarmaMEBUNECE_VWE3.rod
;Tuesday,25,March,2025,12:37:34:58926
;VCID: 2C0A6AA6D685558A03E-8078-R
IDE07159-MAS05583-Control module switch-off: counter-Data bus,1 ,2
IDE07160-IDE15110-Control module switch-off: switch-off time-Coupling shut-off time: data bus with low-voltage energy management,Low-voltage energy management: coupling not available ,3
IDE07160-MAS00478-Control module switch-off: switch-off time-Reserved,0 ,3
IDE07160-MAS01155-Control module switch-off: switch-off time-Control module,15 min ,3
IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,15 min ,3
IDE07160-ENG99458-Control module switch-off: switch-off time-Reserved_2,0 ,3
Elapsed Time: 00:02
adpmap-C6-1EK-915-692-J_WVG5WVEB2SH017765-20250325-1237.CSV
;SW:1EK-915-692-J   HW:1EK-915-692-H ---  Batt. Chrg.
;Component:OCDC Gen4+    H03 2207, Coding:308010
;EV_OCDCXPHASERB8MEBB,002001,EV_OCDCXPHASERB8MEBB_002_VWE3.rod
;Tuesday,25,March,2025,12:37:53:58926
;VCID: 4BC8093A734B72B22A4-801E-R SFD+SFD2
IDE07160-IDE15110-Control module switch-off: switch-off time-Coupling shut-off time: data bus with low-voltage energy management,Low-voltage energy management: coupling not available ,2
IDE07160-MAS00478-Control module switch-off: switch-off time-Reserved,0 ,2
IDE07160-MAS01155-Control module switch-off: switch-off time-Control module,15 min ,2
IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,15 min ,2
IDE07160-ENG99458-Control module switch-off: switch-off time-Reserved_2,0 ,2
IDE16363-IDE16579-Writing generic data to subsystem-Data record for identifier (target),00 ,5
IDE16363-MAS25934-Writing generic data to subsystem-Node address of the subsystem (destination),Unknown (0),5
IDE16363-MAS25935-Writing generic data to subsystem-Identifier (destination),Unknown (0),5
IDE16554-Status XCP,OFF ,1
MAS19898-MAS01877-Charging socket LED displays-Red,16711680 ,10
MAS19898-MAS01878-Charging socket LED displays-Green,65280 ,10
MAS19898-MAS07987-Charging socket LED displays-Light intensity,0 %,10
MAS19898-MAS11237-Charging socket LED displays-White,255 ,10
MAS22094-MAS03001-LED display of charging socket: searchlight plugged in-Mode,inverse flashing ,2
MAS22094-MAS10898-LED display of charging socket: searchlight plugged in-color,White ,2
MAS22095-MAS03001-LED display of charging socket: search light active-Mode,On ,2
MAS22095-MAS10898-LED display of charging socket: search light active-color,White ,2
MAS22096-MAS03001-LED Display of charging socket: initialization-Mode,Blinking ,2
MAS22096-MAS10898-LED Display of charging socket: initialization-color,White ,2
MAS22097-MAS03001-LED display of charging socket: charging error-Mode,On ,2
MAS22097-MAS10898-LED display of charging socket: charging error-color,Red ,2
MAS22098-MAS03001-LED display of charging socket: no mains voltage-Mode,OFF ,2
MAS22098-MAS10898-LED display of charging socket: no mains voltage-color,OFF ,2
MAS22099-MAS03001-LED display of charging socket: optimized charging imminent-Mode,flashing ,2
MAS22099-MAS10898-LED display of charging socket: optimized charging imminent-color,Green ,2
MAS22100-MAS03001-LED display of charging socket: timer charging imminent-Mode,flashing ,2
MAS22100-MAS10898-LED display of charging socket: timer charging imminent-color,Green ,2
MAS22101-MAS03001-LED display of charging socket: optimized charging active-Mode,Pulsation ,2
MAS22101-MAS10898-LED display of charging socket: optimized charging active-color,Green ,2
MAS22102-MAS03001-LED display of charging socket: instant charging active-Mode,Pulsation ,2
MAS22102-MAS10898-LED display of charging socket: instant charging active-color,Green ,2
MAS22103-MAS03001-LED display of charging socket: timer charging active-Mode,Pulsation ,2
MAS22103-MAS10898-LED display of charging socket: timer charging active-color,Green ,2
MAS22104-MAS03001-LED display of the charging socket: optimized charging completed-Mode,On ,2
MAS22104-MAS10898-LED display of the charging socket: optimized charging completed-color,Green ,2
MAS22105-MAS03001-LED display of charging socket: instant charging completed-Mode,On ,2
MAS22105-MAS10898-LED display of charging socket: instant charging completed-color,Green ,2
MAS22106-MAS03001-LED display of charging socket: timer charging completed-Mode,On ,2
MAS22106-MAS10898-LED display of charging socket: timer charging completed-color,Green ,2
MAS22107-MAS03001-LED display of charging socket: emergency charging active-Mode,Pulsating and lighting ,2
MAS22107-MAS10898-LED display of charging socket: emergency charging active-color,Green ,2
MAS22108-MAS03001-LED display of charging socket: interlocking error-Mode,OFF ,2
MAS22108-MAS10898-LED display of charging socket: interlocking error-color,OFF ,2
Elapsed Time: 00:07
adpmap-CA-14A-907-594-A_WVG5WVEB2SH017765-20250325-1238.CSV
;SW:14A-907-594-A   HW:4K0-907-594 ---  Sunroof
;Component:SAD_STG_1     011 0030, Coding:01000374180F
;EV_SunRoofCONTIPO513,002004,EV_SunRoofCONTIPO513.rod
;Tuesday,25,March,2025,12:38:09:58926
;VCID: 290493B2D97740A2F88-807C-R
IDE17776-PDLC standalone operation,not active ,1
ENG146366-Applikationmode deactivate,Deactivating ,1
Elapsed Time: 00:02
adpmap-D6-992-941-572-AG_WVG5WVEB2SH017765-20250325-1238.CSV
;SW:992-941-572-AG   HW:992-941-572-A ---  Light Ctrl Left 2
;Component:LED1L         H17 9104, Coding:
;EV_LLPGen3LKEBODPO68X,002003,EV_LLPGen3LKEBODPO68X_002_VW27.rod
;Tuesday,25,March,2025,12:38:29:58926
;VCID: 6882D6B602FDB9AA276-803C-R
IDE00820-Activating and deactivating all development messages,No ,1
Elapsed Time: 00:00
adpmap-D7-992-941-572-AG_WVG5WVEB2SH017765-20250325-1238.CSV
;SW:992-941-572-AG   HW:992-941-572-A ---  Light Ctrl Right 2
;Component:LED1R         H17 9104, Coding:
;EV_LLPGen3RKEBODPO68X,002003,EV_LLPGen3RKEBODPO68X_002_VW27.rod
;Tuesday,25,March,2025,12:38:47:58926
Elapsed Time: 00:01
adpmap-DE-3P0-035-502-B_WVG5WVEB2SH017765-20250325-1238.CSV
;SW:3P0-035-502-B   HW:3P0-035-502 ---  Charger 1 for mobile dev
;Component:COUPLING BOX  004 0170, Coding:400080
;EV_DualCouplBoxSK336,001006,EV_DualCouplBoxSK336.rod
;Tuesday,25,March,2025,12:38:56:58926
;VCID: 241A8286BE559DCACBE-8070-R SFD+SFD2
IDE00001-MAS16893-Production mode-Contactless charging,not active ,3
IDE00001-ENG376492-Production mode-Antenna_coupling,not active ,3
IDE12489-ENG387563-Antenna 2 for short-range communication-EcpTci_1,1 ,51
IDE12489-ENG387564-Antenna 2 for short-range communication-EcpTci_2,1 ,51
IDE12489-ENG387565-Antenna 2 for short-range communication-EcpTci_3,3 ,51
IDE12489-ENG321400-Antenna 2 for short-range communication-number_retry_authentication_request,3 ,51
IDE12489-ENG321402-Antenna 2 for short-range communication-number_retry_nfc_detection,1 ,51
IDE12489-ENG321433-Antenna 2 for short-range communication-routing_timer,6000 ,51
IDE12489-ENG321445-Antenna 2 for short-range communication-time_retry_authentication_request,100 ,51
IDE12489-ENG321446-Antenna 2 for short-range communication-time_waiting_communication_error,250 ,51
IDE12489-ENG405757-Antenna 2 for short-range communication-Time_Waiting_Owner_Pairing,30 s,51
IDE12489-ENG376991-Antenna 2 for short-range communication-WaitingApduSelectResponse,500 ,51
IDE15288-Mobile device charger: transferable power,15.00 W,1
IDE15296-Fan power adjustment,100 %,1
IDE15297-Fan characteristic curves,Characteristic curve 1 ,1
MAS19184-Production move for test activated,Productionmode_for_development_use_not_active ,1
Elapsed Time: 00:02
adpmap-8116-1T3-035-335-B_WVG5WVEB2SH017765-20250325-1239.CSV
;SW:1T3-035-335-B   HW:1EA-035-335 ---  Snd enhanct 2
;Component:E_SOUND_SG    H06 0007, Coding:
;EV_ESoun2HarmaMEBUNECE,001003,EV_ESoun2HarmaMEBUNECE.rod
;Tuesday,25,March,2025,12:39:05:58926
;VCID: 2D0C67A2ED9F5C82140-8078-R
IDE07159-MAS05583-Control module switch-off: counter-Data bus,62 ,2
Elapsed Time: 00:02
adpmap-8123-V04-007-003-LE_WVG5WVEB2SH017765-20250325-1239.CSV
;SW:V04-007-003-LE   HW: ---  App server 1 system 1 adaptive
;Component:ICAS1 Sys_Ada 0254, Coding:
;EV_AppServ1Sys1ICAS1UNECE,001002,EV_AppServ1Sys1ICAS1UNECE_VWE3.rod
;Tuesday,25,March,2025,12:39:26:58926
;VCID: 75BC8FC2454F5442AC0-8020-R SFD+SFD2
ENG253278-Activation_DLT,not active ,1
Elapsed Time: 00:05
adpmap-8124-V04-007-003-LF_WVG5WVEB2SH017765-20250325-1240.CSV
;SW:V04-007-003-LF   HW: ---  App server 1 system 2 Java
;Component:ICAS1 Sys_Jav 0254, Coding:
;EV_AppServ1Sys2ICAS1UNECE,001002,EV_AppServ1Sys2ICAS1UNECE_VWE3.rod
;Tuesday,25,March,2025,12:40:12:58926
;VCID: 76BE88CE58495F5AA5A-8022-R SFD+SFD2
Elapsed Time: 00:10
adpmap-8125-V04-007-003-RH_WVG5WVEB2SH017765-20250325-1241.CSV
;SW:V04-007-003-RH   HW: ---  App server 3 system 1 infotaint.
;Component:IC3GIVI-S--US 3626, Coding:64101030000000000000000000000000000000000000000000
;EV_MUICASIVIPart,003001,EV_MUICASIVIPart_003_VWE3.rod
;Tuesday,25,March,2025,12:41:07:58926
;VCID: 7EAE90EE7079171AFDA-802A-R SFD+SFD2
IDE00001-ENG248499-Production mode-air_condition_operation,not activated ,1096
IDE00001-ENG154175-Production mode-Bluetooth,not activated ,1096
IDE00001-ENG248636-Production mode-display_1_move,not activated ,1096
IDE00001-ENG248637-Production mode-display_1_on_off,not activated ,1096
IDE00001-ENG248638-Production mode-display_2_move,not activated ,1096
IDE00001-ENG248639-Production mode-display_2_on_off,not activated ,1096
IDE00001-ENG251560-Production mode-display_3_on_off,not activated ,1096
IDE00001-ENG282031-Production mode-Display_4_on_off,not activated ,1096
IDE00001-ENG252053-Production mode-early_audio,not activated ,1096
IDE00001-ENG248670-Production mode-extendible_tweeters,not activated ,1096
IDE00001-ENG175909-Production mode-FPK,not activated ,1096
IDE00001-ENG248687-Production mode-fpk_display,not activated ,1096
IDE00001-ENG248690-Production mode-frequency_modification,not activated ,1096
IDE00001-ENG146079-Production mode-Operation,not activated ,1096
IDE00001-ENG248771-Production mode-p_mode_id_13,not activated ,1096
IDE00001-ENG248772-Production mode-p_mode_id_14,not activated ,1096
IDE00001-ENG248485-Production mode-Parameter_21,not activated ,1096
IDE00001-ENG248486-Production mode-Parameter_22,not activated ,1096
IDE00001-ENG248487-Production mode-Parameter_23,not activated ,1096
IDE00001-ENG248791-Production mode-paramter_24,not activated ,1096
IDE00001-ENG248796-Production mode-radio_link_esim,not activated ,1096
IDE00001-ENG248480-Production mode-SDS,not activated ,1096
IDE00001-ENG168106-Production mode-volume_control,not activated ,1096
IDE00001-ENG248489-Production mode-Wifi,not activated ,1096
IDE00768-Country identification: country of sale, ,795
IDE00769-Call number 1 for info call,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,23
IDE02125-MAS08233-Voice operation for telephone-other,installed ,1
IDE02125-MAS18502-Voice operation for telephone-Apple device,not installed ,1
IDE02330-Call number 2 for info call,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,23
IDE02476-MAS03001-Electrical test of speakers-Mode,automatic ,121
IDE02476-ENG248529-Electrical test of speakers-channel_1_lower_threshold,15 ,121
IDE02476-ENG248531-Electrical test of speakers-channel_1_upper_threshold,25 ,121
IDE02476-ENG248533-Electrical test of speakers-channel_10_lower_threshold,15 ,121
IDE02476-ENG248535-Electrical test of speakers-channel_10_upper_threshold,25 ,121
IDE02476-ENG248537-Electrical test of speakers-channel_11_lower_threshold,15 ,121
IDE02476-ENG248539-Electrical test of speakers-channel_11_upper_threshold,25 ,121
IDE02476-ENG248541-Electrical test of speakers-channel_12_lower_threshold,15 ,121
IDE02476-ENG248543-Electrical test of speakers-channel_12_upper_threshold,25 ,121
IDE02476-ENG248545-Electrical test of speakers-channel_13_lower_threshold,15 ,121
IDE02476-ENG248547-Electrical test of speakers-channel_13_upper_threshold,25 ,121
IDE02476-ENG248549-Electrical test of speakers-channel_14_lower_threshold,15 ,121
IDE02476-ENG248551-Electrical test of speakers-channel_14_upper_threshold,25 ,121
IDE02476-ENG248553-Electrical test of speakers-channel_15_lower_threshold,15 ,121
IDE02476-ENG248555-Electrical test of speakers-channel_15_upper_threshold,25 ,121
IDE02476-ENG248557-Electrical test of speakers-channel_16_lower_threshold,15 ,121
IDE02476-ENG248559-Electrical test of speakers-channel_16_upper_threshold,25 ,121
IDE02476-ENG248561-Electrical test of speakers-channel_17_lower_threshold,15 ,121
IDE02476-ENG248563-Electrical test of speakers-channel_17_upper_threshold,25 ,121
IDE02476-ENG248565-Electrical test of speakers-channel_18_lower_threshold,15 ,121
IDE02476-ENG248567-Electrical test of speakers-channel_18_upper_threshold,25 ,121
IDE02476-ENG248569-Electrical test of speakers-channel_19_lower_threshold,15 ,121
IDE02476-ENG248570-Electrical test of speakers-channel_19_upper_threshold,25 ,121
IDE02476-ENG248573-Electrical test of speakers-channel_2_lower_threshold,15 ,121
IDE02476-ENG248575-Electrical test of speakers-channel_2_upper_threshold,25 ,121
IDE02476-ENG248577-Electrical test of speakers-channel_20_lower_threshold,15 ,121
IDE02476-ENG248579-Electrical test of speakers-channel_20_upper_threshold,25 ,121
IDE02476-ENG248581-Electrical test of speakers-channel_21_lower_threshold,15 ,121
IDE02476-ENG248583-Electrical test of speakers-channel_21_upper_threshold,25 ,121
IDE02476-ENG248585-Electrical test of speakers-channel_22_lower_threshold,15 ,121
IDE02476-ENG248587-Electrical test of speakers-channel_22_upper_threshold,25 ,121
IDE02476-ENG248589-Electrical test of speakers-channel_23_lower_threshold,15 ,121
IDE02476-ENG248591-Electrical test of speakers-channel_23_upper_threshold,25 ,121
IDE02476-ENG248593-Electrical test of speakers-channel_24_lower_threshold,15 ,121
IDE02476-ENG248595-Electrical test of speakers-channel_24_upper_threshold,25 ,121
IDE02476-ENG248599-Electrical test of speakers-channel_3_lower_threshold,15 ,121
IDE02476-ENG248601-Electrical test of speakers-channel_3_upper_threshold,25 ,121
IDE02476-ENG248603-Electrical test of speakers-channel_4_lower_threshold,15 ,121
IDE02476-ENG248605-Electrical test of speakers-channel_4_upper_threshold,25 ,121
IDE02476-ENG248607-Electrical test of speakers-channel_5_lower_threshold,15 ,121
IDE02476-ENG248609-Electrical test of speakers-channel_5_upper_threshold,25 ,121
IDE02476-ENG248611-Electrical test of speakers-channel_6_lower_threshold,15 ,121
IDE02476-ENG248613-Electrical test of speakers-channel_6_upper_threshold,25 ,121
IDE02476-ENG248615-Electrical test of speakers-channel_7_lower_threshold,15 ,121
IDE02476-ENG248617-Electrical test of speakers-channel_7_upper_threshold,25 ,121
IDE02476-ENG248619-Electrical test of speakers-channel_8_lower_threshold,15 ,121
IDE02476-ENG248621-Electrical test of speakers-channel_8_upper_threshold,25 ,121
IDE02476-ENG248623-Electrical test of speakers-channel_9_lower_threshold,15 ,121
IDE02476-ENG248625-Electrical test of speakers-channel_9_upper_threshold,25 ,121
IDE02476-ENG117360-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_1_Test_Frequency,19000 Hz,121
IDE02476-ENG117361-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume,27 ,121
IDE02476-ENG117378-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_10_Test_Frequency,19000 Hz,121
IDE02476-ENG117379-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume,27 ,121
IDE02476-ENG117380-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_11_Test_Frequency,19000 Hz,121
IDE02476-ENG117381-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume,27 ,121
IDE02476-ENG117382-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_12_Test_Frequency,19000 Hz,121
IDE02476-ENG117383-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume,27 ,121
IDE02476-ENG117384-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_13_Test_Frequency,19000 Hz,121
IDE02476-ENG117385-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume,27 ,121
IDE02476-ENG117386-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_14_Test_Frequency,19000 Hz,121
IDE02476-ENG117387-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume,27 ,121
IDE02476-ENG117388-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_15_Test_Frequency,19000 Hz,121
IDE02476-ENG117389-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume,27 ,121
IDE02476-ENG117390-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_16_Test_Frequency,19000 Hz,121
IDE02476-ENG117391-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume,27 ,121
IDE02476-ENG126164-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_17_Test_Frequency,19000 Hz,121
IDE02476-ENG126165-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_17_Test_Volume,27 ,121
IDE02476-ENG126166-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_18_Test_Frequency,19000 Hz,121
IDE02476-ENG126167-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_18_Test_Volume,27 ,121
IDE02476-ENG126168-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_19_Test_Frequency,19000 Hz,121
IDE02476-ENG126169-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_19_Test_Volume,27 ,121
IDE02476-ENG117362-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_2_Test_Frequency,19000 Hz,121
IDE02476-ENG117363-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume,27 ,121
IDE02476-ENG126170-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_20_Test_Frequency,19000 Hz,121
IDE02476-ENG126171-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_20_Test_Volume,27 ,121
IDE02476-ENG126172-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_21_Test_Frequency,19000 Hz,121
IDE02476-ENG126173-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_21_Test_Volume,27 ,121
IDE02476-ENG126174-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_22_Test_Frequency,19000 Hz,121
IDE02476-ENG126175-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_22_Test_Volume,27 ,121
IDE02476-ENG126176-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_23_Test_Frequency,19000 Hz,121
IDE02476-ENG126177-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_23_Test_Volume,27 ,121
IDE02476-ENG126178-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_24_Test_Frequency,19000 Hz,121
IDE02476-ENG126179-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_24_Test_Volume,27 ,121
IDE02476-ENG117364-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_3_Test_Frequency,19000 Hz,121
IDE02476-ENG117365-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume,27 ,121
IDE02476-ENG117366-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_4_Test_Frequency,19000 Hz,121
IDE02476-ENG117367-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume,27 ,121
IDE02476-ENG117368-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_5_Test_Frequency,19000 Hz,121
IDE02476-ENG117369-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume,27 ,121
IDE02476-ENG117370-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_6_Test_Frequency,19000 Hz,121
IDE02476-ENG117371-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume,27 ,121
IDE02476-ENG117372-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_7_Test_Frequency,19000 Hz,121
IDE02476-ENG117373-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume,27 ,121
IDE02476-ENG117374-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_8_Test_Frequency,19000 Hz,121
IDE02476-ENG117375-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume,27 ,121
IDE02476-ENG117376-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_9_Test_Frequency,19000 Hz,121
IDE02476-ENG117377-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume,27 ,121
IDE02502-Confirmation of installation change,36 2D ,2
IDE02506-MAS03229-Copy multimedia data-Data carrier,OFF ,1
IDE02506-MAS03230-Copy multimedia data-Optical drive,OFF ,1
IDE02699-Number 1 for roadside assistance,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,23
IDE02701-Number 1 (roaming) for roadside assistance,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,23
IDE03503-Image rotation,-4.0 ,2
IDE04298-MAS01779-Vehicle dimensions-Length,0 mm,6
IDE04298-MAS01780-Vehicle dimensions-Width,0 mm,6
IDE04298-MAS02230-Vehicle dimensions-Height,0 mm,6
IDE04300-ENG331904-Vehicle menu operation-menu_AirHeater,not activated ,256
IDE04300-ENG331905-Vehicle menu operation-menu_AirHeater_after_disclaimer,not activated ,256
IDE04300-ENG331906-Vehicle menu operation-menu_AirHeater_clamp_15_off,not activated ,256
IDE04300-ENG331907-Vehicle menu operation-menu_AirHeater_over_threshold_high,not activated ,256
IDE04300-ENG331908-Vehicle menu operation-menu_AirHeater_standstill,not activated ,256
IDE04300-ENG252089-Vehicle menu operation-menu_ambient_illumination_2,activated ,256
IDE04300-ENG252074-Vehicle menu operation-menu_ambient_illumination_2_after_disclaimer,not activated ,256
IDE04300-ENG252062-Vehicle menu operation-menu_ambient_illumination_2_clamp_15_off,not activated ,256
IDE04300-ENG252061-Vehicle menu operation-menu_ambient_illumination_2_over_threshold_high,activated ,256
IDE04300-ENG252091-Vehicle menu operation-menu_ambient_illumination_2_stillstand,not activated ,256
IDE04300-ENG125811-Vehicle menu operation-menu_auxiliary_climatization,not activated ,256
IDE04300-ENG125814-Vehicle menu operation-menu_auxiliary_climatization_after_disclaimer,not activated ,256
IDE04300-ENG126995-Vehicle menu operation-menu_auxiliary_climatization_clamp_15_off,not activated ,256
IDE04300-ENG125812-Vehicle menu operation-menu_auxiliary_climatization_over_threshold_high,not activated ,256
IDE04300-ENG125813-Vehicle menu operation-menu_auxiliary_climatization_standstill,not activated ,256
IDE04300-ENG152538-Vehicle menu operation-menu_auxiliary_ventilation,not activated ,256
IDE04300-ENG152539-Vehicle menu operation-menu_auxiliary_ventilation_after_disclaimer,not activated ,256
IDE04300-ENG152540-Vehicle menu operation-menu_auxiliary_ventilation_clamp_15_off,not activated ,256
IDE04300-ENG152541-Vehicle menu operation-menu_auxiliary_ventilation_over_threshold_high,not activated ,256
IDE04300-ENG152542-Vehicle menu operation-menu_auxiliary_ventilation_standstill,not activated ,256
IDE04300-ENG297698-Vehicle menu operation-menu_BSIS,not activated ,256
IDE04300-ENG297699-Vehicle menu operation-menu_BSIS_after_disclaimer,not activated ,256
IDE04300-ENG297700-Vehicle menu operation-menu_BSIS_clamp_15_off,not activated ,256
IDE04300-ENG297701-Vehicle menu operation-menu_BSIS_over_threshold_high,not activated ,256
IDE04300-ENG297702-Vehicle menu operation-menu_BSIS_standstill,not activated ,256
IDE04300-ENG248728-Vehicle menu operation-menu_Car2X,not activated ,256
IDE04300-ENG248729-Vehicle menu operation-menu_Car2X_after_disclaimer,not activated ,256
IDE04300-ENG248730-Vehicle menu operation-menu_Car2X_clamp_15_off,not activated ,256
IDE04300-ENG248731-Vehicle menu operation-menu_Car2X_over_threshold_high,not activated ,256
IDE04300-ENG248732-Vehicle menu operation-menu_Car2X_stillstand,not activated ,256
IDE04300-ENG249906-Vehicle menu operation-menu_chassis_control,not activated ,256
IDE04300-ENG249907-Vehicle menu operation-menu_chassis_control_after_disclaimer,not activated ,256
IDE04300-ENG249908-Vehicle menu operation-menu_chassis_control_clamp_15_off,not activated ,256
IDE04300-ENG249909-Vehicle menu operation-menu_chassis_control_over_threshold_high,not activated ,256
IDE04300-ENG282005-Vehicle menu operation-menu_chassis_control_standstill,not activated ,256
IDE04300-ENG152495-Vehicle menu operation-menu_connection_manager,not activated ,256
IDE04300-ENG152499-Vehicle menu operation-menu_connection_manager_after_disclaimer,not activated ,256
IDE04300-ENG152496-Vehicle menu operation-menu_connection_manager_clamp_15_off,not activated ,256
IDE04300-ENG152497-Vehicle menu operation-menu_connection_manager_over_threshold_high,not activated ,256
IDE04300-ENG152498-Vehicle menu operation-menu_connection_manager_standstill,not activated ,256
IDE04300-ENG152543-Vehicle menu operation-menu_crossroad_assistent,not activated ,256
IDE04300-ENG152544-Vehicle menu operation-menu_crossroad_assistent_after_disclaimer,not activated ,256
IDE04300-ENG152545-Vehicle menu operation-menu_crossroad_assistent_clamp_15_off,not activated ,256
IDE04300-ENG152546-Vehicle menu operation-menu_crossroad_assistent_over_threshold_high,not activated ,256
IDE04300-ENG152547-Vehicle menu operation-menu_crossroad_assistent_standstill,not activated ,256
IDE04300-ENG152548-Vehicle menu operation-menu_daf_profile,not activated ,256
IDE04300-ENG152549-Vehicle menu operation-menu_daf_profile_after_disclaimer,not activated ,256
IDE04300-ENG152550-Vehicle menu operation-menu_daf_profile_clamp_15_off,not activated ,256
IDE04300-ENG152551-Vehicle menu operation-menu_daf_profile_over_threshold_high,not activated ,256
IDE04300-ENG152552-Vehicle menu operation-menu_daf_profile_stillstand,not activated ,256
IDE04300-ENG251562-Vehicle menu operation-menu_DCC_monitor,not activated ,256
IDE04300-ENG251561-Vehicle menu operation-menu_DCC_monitor_after_disclaimer,not activated ,256
IDE04300-ENG251559-Vehicle menu operation-menu_DCC_monitor_clamp_15_off,not activated ,256
IDE04300-ENG251557-Vehicle menu operation-menu_DCC_monitor_over_threshold_high,not activated ,256
IDE04300-ENG251558-Vehicle menu operation-menu_DCC_monitor_stillstand,not activated ,256
IDE04300-ENG117486-Vehicle menu operation-menu_display_ACC,activated ,256
IDE04300-ENG117490-Vehicle menu operation-menu_display_ACC_after_disclaimer,not activated ,256
IDE04300-ENG117487-Vehicle menu operation-menu_display_ACC_operation_clamp_15_off,not activated ,256
IDE04300-ENG117488-Vehicle menu operation-menu_display_ACC_over_threshold_high,activated ,256
IDE04300-ENG117489-Vehicle menu operation-menu_display_ACC_standstill,not activated ,256
IDE04300-ENG117646-Vehicle menu operation-menu_display_adaptive_key,not activated ,256
IDE04300-ENG117650-Vehicle menu operation-menu_display_adaptive_key_after_disclaimer,not activated ,256
IDE04300-ENG117647-Vehicle menu operation-menu_display_adaptive_key_clamp_15_off,not activated ,256
IDE04300-ENG117648-Vehicle menu operation-menu_display_adaptive_key_over_threshold_high,not activated ,256
IDE04300-ENG117649-Vehicle menu operation-menu_display_adaptive_key_standstill,not activated ,256
IDE04300-ENG126152-Vehicle menu operation-menu_display_Adblue,not activated ,256
IDE04300-ENG126155-Vehicle menu operation-menu_display_Adblue_after_disclaimer,not activated ,256
IDE04300-ENG127002-Vehicle menu operation-menu_display_Adblue_clamp_15_off,not activated ,256
IDE04300-ENG126153-Vehicle menu operation-menu_display_Adblue_over_threshold_high,not activated ,256
IDE04300-ENG126154-Vehicle menu operation-menu_display_Adblue_standstill,not activated ,256
IDE04300-ENG117591-Vehicle menu operation-menu_display_air_damper,not activated ,256
IDE04300-ENG117595-Vehicle menu operation-menu_display_air_damper_after_disclaimer,not activated ,256
IDE04300-ENG117592-Vehicle menu operation-menu_display_air_damper_clamp_15_off,not activated ,256
IDE04300-ENG117593-Vehicle menu operation-menu_display_air_damper_over_threshold_high,not activated ,256
IDE04300-ENG117594-Vehicle menu operation-menu_display_air_damper_standstill,not activated ,256
IDE04300-ENG117491-Vehicle menu operation-menu_display_ambient_illumination,activated ,256
IDE04300-ENG117495-Vehicle menu operation-menu_display_ambient_illumination_after_disclaimer,not activated ,256
IDE04300-ENG117492-Vehicle menu operation-menu_display_ambient_illumination_clamp_15_off,not activated ,256
IDE04300-ENG117493-Vehicle menu operation-menu_display_ambient_illumination_over_threshold_high,activated ,256
IDE04300-ENG117494-Vehicle menu operation-menu_display_ambient_illumination_standstill,not activated ,256
IDE04300-ENG122296-Vehicle menu operation-menu_display_angle_of_slope,not activated ,256
IDE04300-ENG122300-Vehicle menu operation-menu_display_angle_of_slope_after_disclaimer,not activated ,256
IDE04300-ENG122297-Vehicle menu operation-menu_display_angle_of_slope_clamp_15_off,not activated ,256
IDE04300-ENG122298-Vehicle menu operation-menu_display_angle_of_slope_over_threshold_high,not activated ,256
IDE04300-ENG122299-Vehicle menu operation-menu_display_angle_of_slope_standstill,not activated ,256
IDE04300-ENG117641-Vehicle menu operation-menu_display_attention_identification,not activated ,256
IDE04300-ENG117645-Vehicle menu operation-menu_display_attention_identification_after_disclaimer,not activated ,256
IDE04300-ENG117642-Vehicle menu operation-menu_display_attention_identification_clamp_15_off,not activated ,256
IDE04300-ENG117643-Vehicle menu operation-menu_display_attention_identification_over_threshold_high,not activated ,256
IDE04300-ENG117644-Vehicle menu operation-menu_display_attention_identification_standstill,not activated ,256
IDE04300-ENG117531-Vehicle menu operation-menu_display_auxiliary_heating,activated ,256
IDE04300-ENG117535-Vehicle menu operation-menu_display_auxiliary_heating_after_disclaimer,not activated ,256
IDE04300-ENG117532-Vehicle menu operation-menu_display_auxiliary_heating_clamp_15_off,activated ,256
IDE04300-ENG117533-Vehicle menu operation-menu_display_auxiliary_heating_over_threshold_high,activated ,256
IDE04300-ENG117534-Vehicle menu operation-menu_display_auxiliary_heating_standstill,not activated ,256
IDE04300-ENG117501-Vehicle menu operation-menu_display_awv,activated ,256
IDE04300-ENG117505-Vehicle menu operation-menu_display_awv_after_disclaimer,not activated ,256
IDE04300-ENG117502-Vehicle menu operation-menu_display_awv_clamp_15_off,not activated ,256
IDE04300-ENG117503-Vehicle menu operation-menu_display_awv_over_threshold_high,activated ,256
IDE04300-ENG117504-Vehicle menu operation-menu_display_awv_standstill,not activated ,256
IDE04300-ENG122301-Vehicle menu operation-menu_display_battery_management,activated ,256
IDE04300-ENG122305-Vehicle menu operation-menu_display_battery_management_after_disclaimer,not activated ,256
IDE04300-ENG122302-Vehicle menu operation-menu_display_battery_management_clamp_15_off,not activated ,256
IDE04300-ENG122303-Vehicle menu operation-menu_display_battery_management_over_threshold_high,activated ,256
IDE04300-ENG122304-Vehicle menu operation-menu_display_battery_management_standstill,not activated ,256
IDE04300-ENG117666-Vehicle menu operation-menu_display_BCmE,not activated ,256
IDE04300-ENG117670-Vehicle menu operation-menu_display_BCmE_after_disclaimer,not activated ,256
IDE04300-ENG117667-Vehicle menu operation-menu_display_BCmE_clamp_15_off,not activated ,256
IDE04300-ENG117668-Vehicle menu operation-menu_display_BCmE_over_threshold_high,not activated ,256
IDE04300-ENG117669-Vehicle menu operation-menu_display_BCmE_standstill,not activated ,256
IDE04300-ENG117536-Vehicle menu operation-menu_display_board_computer,activated ,256
IDE04300-ENG117540-Vehicle menu operation-menu_display_board_computer_after_disclaimer,not activated ,256
IDE04300-ENG117537-Vehicle menu operation-menu_display_board_computer_clamp_15_off,not activated ,256
IDE04300-ENG117538-Vehicle menu operation-menu_display_board_computer_over_threshold_high,activated ,256
IDE04300-ENG117539-Vehicle menu operation-menu_display_board_computer_standstill,not activated ,256
IDE04300-ENG117671-Vehicle menu operation-menu_display_Brake_Function,activated ,256
IDE04300-ENG117675-Vehicle menu operation-menu_display_Brake_Function_after_disclaimer,not activated ,256
IDE04300-ENG117672-Vehicle menu operation-menu_display_Brake_Function_clamp_15_off,not activated ,256
IDE04300-ENG117673-Vehicle menu operation-menu_display_Brake_Function_over_threshold_high,activated ,256
IDE04300-ENG117674-Vehicle menu operation-menu_display_Brake_Function_standstill,not activated ,256
IDE04300-ENG117651-Vehicle menu operation-menu_display_car_mirror,activated ,256
IDE04300-ENG117655-Vehicle menu operation-menu_display_car_mirror_after_disclaimer,not activated ,256
IDE04300-ENG117652-Vehicle menu operation-menu_display_car_mirror_clamp_15_off,not activated ,256
IDE04300-ENG117653-Vehicle menu operation-menu_display_car_mirror_over_threshold_high,activated ,256
IDE04300-ENG117654-Vehicle menu operation-menu_display_car_mirror_standstill,not activated ,256
IDE04300-ENG117561-Vehicle menu operation-menu_display_central_locking,activated ,256
IDE04300-ENG117565-Vehicle menu operation-menu_display_central_locking_after_disclaimer,not activated ,256
IDE04300-ENG117562-Vehicle menu operation-menu_display_central_locking_clamp_15_off,not activated ,256
IDE04300-ENG117563-Vehicle menu operation-menu_display_central_locking_over_threshold_high,activated ,256
IDE04300-ENG117564-Vehicle menu operation-menu_display_central_locking_standstill,not activated ,256
IDE04300-ENG117601-Vehicle menu operation-menu_display_central_unit_master,activated ,256
IDE04300-ENG117605-Vehicle menu operation-menu_display_central_unit_master_after_disclaimer,not activated ,256
IDE04300-ENG117602-Vehicle menu operation-menu_display_central_unit_master_clamp_15_off,not activated ,256
IDE04300-ENG117603-Vehicle menu operation-menu_display_central_unit_master_over_threshold_high,activated ,256
IDE04300-ENG117604-Vehicle menu operation-menu_display_central_unit_master_standstill,not activated ,256
IDE04300-ENG117571-Vehicle menu operation-menu_display_charisma,activated ,256
IDE04300-ENG117575-Vehicle menu operation-menu_display_charisma_after_disclaimer,not activated ,256
IDE04300-ENG117572-Vehicle menu operation-menu_display_charisma_clamp_15_off,not activated ,256
IDE04300-ENG117573-Vehicle menu operation-menu_display_charisma_over_threshold_high,activated ,256
IDE04300-ENG117574-Vehicle menu operation-menu_display_charisma_standstill,not activated ,256
IDE04300-ENG117526-Vehicle menu operation-menu_display_clima_configuration,activated ,256
IDE04300-ENG117530-Vehicle menu operation-menu_display_clima_configuration_after_disclaimer,not activated ,256
IDE04300-ENG117527-Vehicle menu operation-menu_display_clima_configuration_clamp_15_off,activated ,256
IDE04300-ENG117528-Vehicle menu operation-menu_display_clima_configuration_over_threshold_high,activated ,256
IDE04300-ENG117529-Vehicle menu operation-menu_display_clima_configuration_standstill,not activated ,256
IDE04300-ENG117586-Vehicle menu operation-menu_display_clock,activated ,256
IDE04300-ENG117590-Vehicle menu operation-menu_display_clock_after_disclaimer,not activated ,256
IDE04300-ENG117587-Vehicle menu operation-menu_display_clock_clamp_15_off,not activated ,256
IDE04300-ENG117588-Vehicle menu operation-menu_display_clock_over_threshold_high,activated ,256
IDE04300-ENG117589-Vehicle menu operation-menu_display_clock_standstill,not activated ,256
IDE04300-ENG117566-Vehicle menu operation-menu_display_compass,not activated ,256
IDE04300-ENG117570-Vehicle menu operation-menu_display_compass_after_disclaimer,not activated ,256
IDE04300-ENG117567-Vehicle menu operation-menu_display_compass_clamp_15_off,not activated ,256
IDE04300-ENG117568-Vehicle menu operation-menu_display_compass_over_threshold_high,not activated ,256
IDE04300-ENG117569-Vehicle menu operation-menu_display_compass_standstill,not activated ,256
IDE04300-ENG125823-Vehicle menu operation-menu_display_Curve_Assist,not activated ,256
IDE04300-ENG125826-Vehicle menu operation-menu_display_Curve_Assist_after_disclaimer,not activated ,256
IDE04300-ENG126998-Vehicle menu operation-menu_display_Curve_Assist_clamp_15_off,not activated ,256
IDE04300-ENG125824-Vehicle menu operation-menu_display_Curve_Assist_over_threshold_high,not activated ,256
IDE04300-ENG125825-Vehicle menu operation-menu_display_Curve_Assist_standstill,not activated ,256
IDE04300-ENG142087-Vehicle menu operation-menu_display_Display_Configuration,not activated ,256
IDE04300-ENG142091-Vehicle menu operation-menu_display_Display_Configuration_after_disclaimer,not activated ,256
IDE04300-ENG142088-Vehicle menu operation-menu_display_Display_Configuration_clamp_15_off,not activated ,256
IDE04300-ENG142089-Vehicle menu operation-menu_display_Display_Configuration_over_threshold_high,not activated ,256
IDE04300-ENG142090-Vehicle menu operation-menu_display_Display_Configuration_standstill,not activated ,256
IDE04300-ENG117656-Vehicle menu operation-menu_display_driving_school,not activated ,256
IDE04300-ENG117660-Vehicle menu operation-menu_display_driving_school_after_disclaimer,not activated ,256
IDE04300-ENG117657-Vehicle menu operation-menu_display_driving_school_clamp_15_off,not activated ,256
IDE04300-ENG117658-Vehicle menu operation-menu_display_driving_school_over_threshold_high,not activated ,256
IDE04300-ENG117659-Vehicle menu operation-menu_display_driving_school_standstill,not activated ,256
IDE04300-ENG125034-Vehicle menu operation-menu_display_Ecall,activated ,256
IDE04300-ENG125038-Vehicle menu operation-menu_display_Ecall_after_disclaimer,not activated ,256
IDE04300-ENG126999-Vehicle menu operation-menu_display_eCall_clamp_15_off,not activated ,256
IDE04300-ENG125036-Vehicle menu operation-menu_display_Ecall_over_threshold_high,activated ,256
IDE04300-ENG125037-Vehicle menu operation-menu_display_Ecall_standstill,not activated ,256
IDE04300-ENG126160-Vehicle menu operation-menu_display_Efficiency_Assist,activated ,256
IDE04300-ENG126163-Vehicle menu operation-menu_display_Efficiency_Assist_after_disclaimer,not activated ,256
IDE04300-ENG127004-Vehicle menu operation-menu_display_Efficiency_Assist_clamp_15_off,not activated ,256
IDE04300-ENG126161-Vehicle menu operation-menu_display_Efficiency_Assist_over_threshold_high,activated ,256
IDE04300-ENG126162-Vehicle menu operation-menu_display_Efficiency_Assist_standstill,not activated ,256
IDE04300-ENG126144-Vehicle menu operation-menu_display_ENI,activated ,256
IDE04300-ENG126147-Vehicle menu operation-menu_display_ENI_after_disclaimer,not activated ,256
IDE04300-ENG127000-Vehicle menu operation-menu_display_ENI_clamp_15_off,not activated ,256
IDE04300-ENG126145-Vehicle menu operation-menu_display_ENI_over_threshold_high,activated ,256
IDE04300-ENG126146-Vehicle menu operation-menu_display_ENI_standstill,not activated ,256
IDE04300-ENG117516-Vehicle menu operation-menu_display_exterior_illumination,activated ,256
IDE04300-ENG117520-Vehicle menu operation-menu_display_exterior_illumination_after_disclaimer,not activated ,256
IDE04300-ENG117517-Vehicle menu operation-menu_display_exterior_illumination_clamp_15_off,not activated ,256
IDE04300-ENG117518-Vehicle menu operation-menu_display_exterior_illumination_over_threshold_high,activated ,256
IDE04300-ENG117519-Vehicle menu operation-menu_display_exterior_illumination_standstill,not activated ,256
IDE04300-ENG117596-Vehicle menu operation-menu_display_headup_display,not activated ,256
IDE04300-ENG117600-Vehicle menu operation-menu_display_headup_display_after_disclaimer,not activated ,256
IDE04300-ENG117597-Vehicle menu operation-menu_display_headup_display_clamp_15_off,not activated ,256
IDE04300-ENG117598-Vehicle menu operation-menu_display_headup_display_over_threshold_high,not activated ,256
IDE04300-ENG117599-Vehicle menu operation-menu_display_headup_display_standstill,not activated ,256
IDE04300-ENG117606-Vehicle menu operation-menu_display_hybrid,not activated ,256
IDE04300-ENG117610-Vehicle menu operation-menu_display_hybrid_after_disclaimer,not activated ,256
IDE04300-ENG117607-Vehicle menu operation-menu_display_hybrid_clamp_15_off,not activated ,256
IDE04300-ENG117608-Vehicle menu operation-menu_display_hybrid_over_threshold_high,not activated ,256
IDE04300-ENG117609-Vehicle menu operation-menu_display_hybrid_standstill,not activated ,256
IDE04300-ENG125805-Vehicle menu operation-menu_display_lane_assistant,activated ,256
IDE04300-ENG125809-Vehicle menu operation-menu_display_lane_assistant_after_disclaimer,not activated ,256
IDE04300-ENG125806-Vehicle menu operation-menu_display_lane_assistant_clamp_15_off,not activated ,256
IDE04300-ENG125807-Vehicle menu operation-menu_display_lane_assistant_over_threshold_high,activated ,256
IDE04300-ENG125808-Vehicle menu operation-menu_display_lane_assistant_standstill,not activated ,256
IDE04300-ENG117506-Vehicle menu operation-menu_display_Lane_Departure_Warning,activated ,256
IDE04300-ENG117510-Vehicle menu operation-menu_display_Lane_Departure_Warning_after_disclaimer,not activated ,256
IDE04300-ENG117507-Vehicle menu operation-menu_display_Lane_Departure_Warning_clamp_15_off,not activated ,256
IDE04300-ENG117508-Vehicle menu operation-menu_display_Lane_Departure_Warning_over_threshold_high,activated ,256
IDE04300-ENG117509-Vehicle menu operation-menu_display_Lane_Departure_Warning_standstill,not activated ,256
IDE04300-ENG117631-Vehicle menu operation-menu_display_MFL_jocker,not activated ,256
IDE04300-ENG117635-Vehicle menu operation-menu_display_MFL_jocker_after_disclaimer,not activated ,256
IDE04300-ENG117632-Vehicle menu operation-menu_display_MFL_jocker_clamp_15_off,not activated ,256
IDE04300-ENG117633-Vehicle menu operation-menu_display_MFL_jocker_over_threshold_high,not activated ,256
IDE04300-ENG117634-Vehicle menu operation-menu_display_MFL_jocker_standstill,not activated ,256
IDE04300-ENG117616-Vehicle menu operation-menu_display_night_vision,not activated ,256
IDE04300-ENG117620-Vehicle menu operation-menu_display_night_vision_after_disclaimer,not activated ,256
IDE04300-ENG117617-Vehicle menu operation-menu_display_night_vision_clamp_15_off,not activated ,256
IDE04300-ENG117618-Vehicle menu operation-menu_display_night_vision_over_threshold_high,not activated ,256
IDE04300-ENG117619-Vehicle menu operation-menu_display_night_vision_standstill,not activated ,256
IDE04300-ENG117576-Vehicle menu operation-menu_display_oil_level,not activated ,256
IDE04300-ENG117580-Vehicle menu operation-menu_display_oil_level_after_disclaimer,not activated ,256
IDE04300-ENG117577-Vehicle menu operation-menu_display_oil_level_clamp_15_off,not activated ,256
IDE04300-ENG117578-Vehicle menu operation-menu_display_oil_level_over_threshold_high,not activated ,256
IDE04300-ENG117579-Vehicle menu operation-menu_display_oil_level_standstill,not activated ,256
IDE04300-ENG117496-Vehicle menu operation-menu_display_pdc,not activated ,256
IDE04300-ENG117500-Vehicle menu operation-menu_display_pdc_after_disclaimer,not activated ,256
IDE04300-ENG117497-Vehicle menu operation-menu_display_pdc_clamp_15_off,not activated ,256
IDE04300-ENG117498-Vehicle menu operation-menu_display_pdc_over_threshold_high,not activated ,256
IDE04300-ENG117499-Vehicle menu operation-menu_display_pdc_standstill,not activated ,256
IDE04300-ENG125815-Vehicle menu operation-menu_display_Pedestrian_Assist,not activated ,256
IDE04300-ENG125818-Vehicle menu operation-menu_display_Pedestrian_Assist_after_disclaimer,not activated ,256
IDE04300-ENG126996-Vehicle menu operation-menu_display_Pedestrian_Assist_clamp_15_off,not activated ,256
IDE04300-ENG125816-Vehicle menu operation-menu_display_Pedestrian_Assist_over_threshold_high,not activated ,256
IDE04300-ENG125817-Vehicle menu operation-menu_display_Pedestrian_Assist_standstill,not activated ,256
IDE04300-ENG117541-Vehicle menu operation-menu_display_rdk,activated ,256
IDE04300-ENG117545-Vehicle menu operation-menu_display_rdk_after_disclaimer,not activated ,256
IDE04300-ENG117542-Vehicle menu operation-menu_display_rdk_clamp_15_off,not activated ,256
IDE04300-ENG117543-Vehicle menu operation-menu_display_rdk_over_threshold_high,activated ,256
IDE04300-ENG117544-Vehicle menu operation-menu_display_rdk_standstill,not activated ,256
IDE04300-ENG122306-Vehicle menu operation-menu_display_RearSeatEntertainment,not activated ,256
IDE04300-ENG122310-Vehicle menu operation-menu_display_RearSeatEntertainment_after_disclaimer,not activated ,256
IDE04300-ENG122307-Vehicle menu operation-menu_display_RearSeatEntertainment_clamp_15_off,not activated ,256
IDE04300-ENG122308-Vehicle menu operation-menu_display_RearSeatEntertainment_over_threshold_high,not activated ,256
IDE04300-ENG122309-Vehicle menu operation-menu_display_RearSeatEntertainment_standstill,not activated ,256
IDE04300-ENG117626-Vehicle menu operation-menu_display_reversible_belt_pre_load,not activated ,256
IDE04300-ENG117630-Vehicle menu operation-menu_display_reversible_belt_pre_load_after_disclaimer,not activated ,256
IDE04300-ENG117627-Vehicle menu operation-menu_display_reversible_belt_pre_load_clamp_15_off,not activated ,256
IDE04300-ENG117628-Vehicle menu operation-menu_display_reversible_belt_pre_load_over_threshold_high,not activated ,256
IDE04300-ENG117629-Vehicle menu operation-menu_display_reversible_belt_pre_load_standstill,not activated ,256
IDE04300-ENG117636-Vehicle menu operation-menu_display_road_sign_identification,activated ,256
IDE04300-ENG117640-Vehicle menu operation-menu_display_road_sign_identification_after_disclaimer,not activated ,256
IDE04300-ENG117637-Vehicle menu operation-menu_display_road_sign_identification_clamp_15_off,not activated ,256
IDE04300-ENG117638-Vehicle menu operation-menu_display_road_sign_identification_over_threshold_high,activated ,256
IDE04300-ENG117639-Vehicle menu operation-menu_display_road_sign_identification_standstill,not activated ,256
IDE04300-ENG117556-Vehicle menu operation-menu_display_seat_configuration,activated ,256
IDE04300-ENG117560-Vehicle menu operation-menu_display_seat_configuration_after_disclaimer,not activated ,256
IDE04300-ENG117557-Vehicle menu operation-menu_display_seat_configuration_clamp_15_off,not activated ,256
IDE04300-ENG117558-Vehicle menu operation-menu_display_seat_configuration_over_threshold_high,activated ,256
IDE04300-ENG117559-Vehicle menu operation-menu_display_seat_configuration_standstill,not activated ,256
IDE04300-ENG125819-Vehicle menu operation-menu_display_Seat_Pneumatic,not activated ,256
IDE04300-ENG125822-Vehicle menu operation-menu_display_Seat_Pneumatic_after_disclaimer,not activated ,256
IDE04300-ENG126997-Vehicle menu operation-menu_display_Seat_Pneumatic_clamp_15_off,not activated ,256
IDE04300-ENG125820-Vehicle menu operation-menu_display_Seat_Pneumatic_over_threshold_high,not activated ,256
IDE04300-ENG125821-Vehicle menu operation-menu_display_Seat_Pneumatic_standstill,not activated ,256
IDE04300-ENG117551-Vehicle menu operation-menu_display_sia,activated ,256
IDE04300-ENG117555-Vehicle menu operation-menu_display_sia_after_disclaimer,not activated ,256
IDE04300-ENG117552-Vehicle menu operation-menu_display_sia_clamp_15_off,not activated ,256
IDE04300-ENG117553-Vehicle menu operation-menu_display_sia_over_threshold_high,activated ,256
IDE04300-ENG117554-Vehicle menu operation-menu_display_sia_standstill,not activated ,256
IDE04300-ENG117621-Vehicle menu operation-menu_display_side_view,not activated ,256
IDE04300-ENG117625-Vehicle menu operation-menu_display_side_view_after_disclaimer,not activated ,256
IDE04300-ENG117622-Vehicle menu operation-menu_display_side_view_clamp_15_off,not activated ,256
IDE04300-ENG117623-Vehicle menu operation-menu_display_side_view_over_threshold_high,not activated ,256
IDE04300-ENG117624-Vehicle menu operation-menu_display_side_view_standstill,not activated ,256
IDE04300-ENG122311-Vehicle menu operation-menu_display_special_functions,not activated ,256
IDE04300-ENG122314-Vehicle menu operation-menu_display_special_functions_after_disclaimer,not activated ,256
IDE04300-ENG125810-Vehicle menu operation-menu_display_special_functions_clamp_15_off,not activated ,256
IDE04300-ENG122312-Vehicle menu operation-menu_display_special_functions_over_threshold_high,not activated ,256
IDE04300-ENG122313-Vehicle menu operation-menu_display_special_functions_standstill,not activated ,256
IDE04300-ENG142082-Vehicle menu operation-menu_display_Spoiler,not activated ,256
IDE04300-ENG142086-Vehicle menu operation-menu_display_Spoiler_after_disclaimer,not activated ,256
IDE04300-ENG142083-Vehicle menu operation-menu_display_Spoiler_clamp_15_off,not activated ,256
IDE04300-ENG142084-Vehicle menu operation-menu_display_Spoiler_over_threshold_high,not activated ,256
IDE04300-ENG142085-Vehicle menu operation-menu_display_Spoiler_standstill,not activated ,256
IDE04300-ENG126148-Vehicle menu operation-menu_display_SportHMI,not activated ,256
IDE04300-ENG126151-Vehicle menu operation-menu_display_SportHMI_after_disclaimer,not activated ,256
IDE04300-ENG127001-Vehicle menu operation-menu_display_SportHMI_clamp_15_off,not activated ,256
IDE04300-ENG126149-Vehicle menu operation-menu_display_SportHMI_over_threshold_high,not activated ,256
IDE04300-ENG126150-Vehicle menu operation-menu_display_SportHMI_standstill,not activated ,256
IDE04300-ENG117676-Vehicle menu operation-menu_display_Start_Stop_reasons,not activated ,256
IDE04300-ENG117680-Vehicle menu operation-menu_display_Start_Stop_reasons_after_disclaimer,not activated ,256
IDE04300-ENG117677-Vehicle menu operation-menu_display_Start_Stop_reasons_clamp_15_off,not activated ,256
IDE04300-ENG117678-Vehicle menu operation-menu_display_Start_Stop_reasons_over_threshold_high,not activated ,256
IDE04300-ENG117679-Vehicle menu operation-menu_display_Start_Stop_reasons_standstill,not activated ,256
IDE04300-ENG122315-Vehicle menu operation-menu_display_trailer_assistant,not activated ,256
IDE04300-ENG122319-Vehicle menu operation-menu_display_trailer_assistant_after_disclaimer,not activated ,256
IDE04300-ENG122316-Vehicle menu operation-menu_display_trailer_assistant_clamp_15_off,not activated ,256
IDE04300-ENG122317-Vehicle menu operation-menu_display_trailer_assistant_over_threshold_high,not activated ,256
IDE04300-ENG122318-Vehicle menu operation-menu_display_trailer_assistant_standstill,not activated ,256
IDE04300-ENG122320-Vehicle menu operation-menu_display_TV_tuner,not activated ,256
IDE04300-ENG122324-Vehicle menu operation-menu_display_TV_tuner_after_disclaimer,not activated ,256
IDE04300-ENG122321-Vehicle menu operation-menu_display_TV_tuner_clamp_15_off,not activated ,256
IDE04300-ENG122322-Vehicle menu operation-menu_display_TV_tuner_over_threshold_high,not activated ,256
IDE04300-ENG122323-Vehicle menu operation-menu_display_TV_tuner_standstill,not activated ,256
IDE04300-ENG117611-Vehicle menu operation-menu_display_ugdo,not activated ,256
IDE04300-ENG117615-Vehicle menu operation-menu_display_ugdo_after_disclaimer,not activated ,256
IDE04300-ENG117612-Vehicle menu operation-menu_display_ugdo_clamp_15_off,not activated ,256
IDE04300-ENG117613-Vehicle menu operation-menu_display_ugdo_over_threshold_high,not activated ,256
IDE04300-ENG117614-Vehicle menu operation-menu_display_ugdo_standstill,not activated ,256
IDE04300-ENG122291-Vehicle menu operation-menu_display_user_eco_rating,not activated ,256
IDE04300-ENG122295-Vehicle menu operation-menu_display_user_eco_rating_after_disclaimer,not activated ,256
IDE04300-ENG122292-Vehicle menu operation-menu_display_user_eco_rating_clamp_15_off,not activated ,256
IDE04300-ENG122293-Vehicle menu operation-menu_display_user_eco_rating_over_threshold_high,not activated ,256
IDE04300-ENG122294-Vehicle menu operation-menu_display_user_eco_rating_standstill,not activated ,256
IDE04300-ENG117581-Vehicle menu operation-menu_display_vin,activated ,256
IDE04300-ENG117585-Vehicle menu operation-menu_display_vin_after_disclaimer,not activated ,256
IDE04300-ENG117582-Vehicle menu operation-menu_display_vin_clamp_15_off,not activated ,256
IDE04300-ENG117583-Vehicle menu operation-menu_display_vin_over_threshold_high,activated ,256
IDE04300-ENG117584-Vehicle menu operation-menu_display_vin_standstill,not activated ,256
IDE04300-ENG117661-Vehicle menu operation-menu_display_weariness_recognition,not activated ,256
IDE04300-ENG117665-Vehicle menu operation-menu_display_weariness_recognition_after_disclaimer,not activated ,256
IDE04300-ENG117662-Vehicle menu operation-menu_display_weariness_recognition_clamp_15_off,not activated ,256
IDE04300-ENG117663-Vehicle menu operation-menu_display_weariness_recognition_over_threshold_high,not activated ,256
IDE04300-ENG117664-Vehicle menu operation-menu_display_weariness_recognition_standstill,not activated ,256
IDE04300-ENG117521-Vehicle menu operation-menu_display_windows,activated ,256
IDE04300-ENG117525-Vehicle menu operation-menu_display_windows_after_disclaimer,not activated ,256
IDE04300-ENG117522-Vehicle menu operation-menu_display_windows_clamp_15_off,not activated ,256
IDE04300-ENG117523-Vehicle menu operation-menu_display_windows_over_threshold_high,activated ,256
IDE04300-ENG117524-Vehicle menu operation-menu_display_windows_standstill,not activated ,256
IDE04300-ENG117546-Vehicle menu operation-menu_display_wiper,activated ,256
IDE04300-ENG117550-Vehicle menu operation-menu_display_wiper_after_disclaimer,not activated ,256
IDE04300-ENG117547-Vehicle menu operation-menu_display_wiper_clamp_15_off,not activated ,256
IDE04300-ENG117548-Vehicle menu operation-menu_display_wiper_over_threshold_high,activated ,256
IDE04300-ENG117549-Vehicle menu operation-menu_display_wiper_standstill,not activated ,256
IDE04300-ENG297703-Vehicle menu operation-menu_Doorlocking_2nd,not activated ,256
IDE04300-ENG297704-Vehicle menu operation-menu_Doorlocking_2nd_after_disclaimer,not activated ,256
IDE04300-ENG297705-Vehicle menu operation-menu_Doorlocking_2nd_clamp_15_off,not activated ,256
IDE04300-ENG297706-Vehicle menu operation-menu_Doorlocking_2nd_over_threshold_high,not activated ,256
IDE04300-ENG297707-Vehicle menu operation-menu_Doorlocking_2nd_standstill,not activated ,256
IDE04300-ENG302732-Vehicle menu operation-menu_DrivingDynamics,not activated ,256
IDE04300-ENG302733-Vehicle menu operation-menu_DrivingDynamics_after_disclaimer,not activated ,256
IDE04300-ENG302734-Vehicle menu operation-menu_DrivingDynamics_clamp_15_off,not activated ,256
IDE04300-ENG302735-Vehicle menu operation-menu_DrivingDynamics_over_threshold_high,not activated ,256
IDE04300-ENG302736-Vehicle menu operation-menu_DrivingDynamics_standstill,not activated ,256
IDE04300-ENG248733-Vehicle menu operation-menu_EngineFunctions,not activated ,256
IDE04300-ENG248734-Vehicle menu operation-menu_EngineFunctions_after_disclaimer,not activated ,256
IDE04300-ENG248735-Vehicle menu operation-menu_EngineFunctions_clamp_15_off,not activated ,256
IDE04300-ENG248736-Vehicle menu operation-menu_EngineFunctions_over_threshold_high,not activated ,256
IDE04300-ENG248737-Vehicle menu operation-menu_EngineFunctions_stillstand,not activated ,256
IDE04300-ENG252067-Vehicle menu operation-menu_exterior_illumination_2,activated ,256
IDE04300-ENG252055-Vehicle menu operation-menu_exterior_illumination_2_after_disclaimer,not activated ,256
IDE04300-ENG252059-Vehicle menu operation-menu_exterior_illumination_2_clamp_15_off,not activated ,256
IDE04300-ENG252069-Vehicle menu operation-menu_exterior_illumination_2_over_threshold_high,activated ,256
IDE04300-ENG252082-Vehicle menu operation-menu_exterior_illumination_2_stillstand,not activated ,256
IDE04300-ENG152515-Vehicle menu operation-menu_fas_profile,not activated ,256
IDE04300-ENG152519-Vehicle menu operation-menu_fas_profile_after_disclaimer,not activated ,256
IDE04300-ENG152516-Vehicle menu operation-menu_fas_profile_clamp_15_off,not activated ,256
IDE04300-ENG152517-Vehicle menu operation-menu_fas_profile_over_threshold_high,not activated ,256
IDE04300-ENG248738-Vehicle menu operation-menu_fas_profile_stillstand,not activated ,256
IDE04300-ENG185798-Vehicle menu operation-menu_fod,not activated ,256
IDE04300-ENG185799-Vehicle menu operation-menu_fod_after_disclaimer,not activated ,256
IDE04300-ENG185800-Vehicle menu operation-menu_fod_clamp_15_off,not activated ,256
IDE04300-ENG185801-Vehicle menu operation-menu_fod_over_threshold_high,not activated ,256
IDE04300-ENG185802-Vehicle menu operation-menu_fod_stillstand,not activated ,256
IDE04300-ENG248739-Vehicle menu operation-menu_IAA_PSO,not activated ,256
IDE04300-ENG248740-Vehicle menu operation-menu_IAA_PSO_after_disclaimer,not activated ,256
IDE04300-ENG248741-Vehicle menu operation-menu_IAA_PSO_clamp_15_off,not activated ,256
IDE04300-ENG248742-Vehicle menu operation-menu_IAA_PSO_over_threshold_high,not activated ,256
IDE04300-ENG248743-Vehicle menu operation-menu_IAA_PSO_stillstand,not activated ,256
IDE04300-ENG248744-Vehicle menu operation-menu_ITM,not activated ,256
IDE04300-ENG248745-Vehicle menu operation-menu_ITM_after_disclaimer,not activated ,256
IDE04300-ENG248746-Vehicle menu operation-menu_ITM_clamp_15_off,not activated ,256
IDE04300-ENG248747-Vehicle menu operation-menu_ITM_over_threshold_high,not activated ,256
IDE04300-ENG248748-Vehicle menu operation-menu_ITM_stillstand,not activated ,256
IDE04300-ENG249916-Vehicle menu operation-menu_lift,not activated ,256
IDE04300-ENG249917-Vehicle menu operation-menu_lift_after_disclaimer,not activated ,256
IDE04300-ENG249918-Vehicle menu operation-menu_lift_clamp_15_off,not activated ,256
IDE04300-ENG249919-Vehicle menu operation-menu_lift_over_threshold_high,not activated ,256
IDE04300-ENG249920-Vehicle menu operation-menu_lift_stillstand,not activated ,256
IDE04300-ENG281916-Vehicle menu operation-menu_LLCC,not activated ,256
IDE04300-ENG281940-Vehicle menu operation-menu_LLCC_after_disclaimer,not activated ,256
IDE04300-ENG282002-Vehicle menu operation-menu_LLCC_clamp_15_off,not activated ,256
IDE04300-ENG281920-Vehicle menu operation-menu_LLCC_over_threshold_high,not activated ,256
IDE04300-ENG281919-Vehicle menu operation-menu_LLCC_standstill,not activated ,256
IDE04300-ENG184478-Vehicle menu operation-menu_mascot,not activated ,256
IDE04300-ENG184479-Vehicle menu operation-menu_mascot_after_disclaimer,not activated ,256
IDE04300-ENG184480-Vehicle menu operation-menu_mascot_clamp_15_off,not activated ,256
IDE04300-ENG184481-Vehicle menu operation-menu_mascot_over_threshold_high,not activated ,256
IDE04300-ENG184482-Vehicle menu operation-menu_mascot_stillstand,not activated ,256
IDE04300-ENG152562-Vehicle menu operation-menu_mobile_device_key_profile,not activated ,256
IDE04300-ENG152563-Vehicle menu operation-menu_mobile_device_key_profile_after_disclaimer,not activated ,256
IDE04300-ENG152564-Vehicle menu operation-menu_mobile_device_key_profile_clamp_15_off,not activated ,256
IDE04300-ENG152565-Vehicle menu operation-menu_mobile_device_key_profile_over_threshold_high,not activated ,256
IDE04300-ENG152566-Vehicle menu operation-menu_mobile_device_key_profile_stillstand,not activated ,256
IDE04300-ENG297708-Vehicle menu operation-menu_MOIS,not activated ,256
IDE04300-ENG297709-Vehicle menu operation-menu_MOIS_after_disclaimer,not activated ,256
IDE04300-ENG297710-Vehicle menu operation-menu_MOIS_clamp_15_off,not activated ,256
IDE04300-ENG297711-Vehicle menu operation-menu_MOIS_over_threshold_high,not activated ,256
IDE04300-ENG297712-Vehicle menu operation-menu_MOIS_standstill,not activated ,256
IDE04300-ENG248749-Vehicle menu operation-menu_PaCo,not activated ,256
IDE04300-ENG248750-Vehicle menu operation-menu_PaCo_after_disclaimer,not activated ,256
IDE04300-ENG248751-Vehicle menu operation-menu_PaCo_clamp_15_off,not activated ,256
IDE04300-ENG248752-Vehicle menu operation-menu_PaCo_over_threshold_high,not activated ,256
IDE04300-ENG248753-Vehicle menu operation-menu_PaCo_stillstand,not activated ,256
IDE04300-ENG405718-Vehicle menu operation-menu_Plug_and_Charge,not activated ,256
IDE04300-ENG405719-Vehicle menu operation-menu_Plug_and_Charge_after_disclaimer,not activated ,256
IDE04300-ENG405720-Vehicle menu operation-menu_Plug_and_Charge_clamp_15_off,not activated ,256
IDE04300-ENG405721-Vehicle menu operation-menu_Plug_and_Charge_over_threshold_high,not activated ,256
IDE04300-ENG405722-Vehicle menu operation-menu_Plug_and_Charge_standstill,not activated ,256
IDE04300-ENG395156-Vehicle menu operation-menu_PowerOnDemand,not activated ,256
IDE04300-ENG395157-Vehicle menu operation-menu_PowerOnDemand_after_disclaimer,not activated ,256
IDE04300-ENG395158-Vehicle menu operation-menu_PowerOnDemand_clamp_15_off,not activated ,256
IDE04300-ENG395159-Vehicle menu operation-menu_PowerOnDemand_over_threshold_high,not activated ,256
IDE04300-ENG395160-Vehicle menu operation-menu_PowerOnDemand_standstill,not activated ,256
IDE04300-ENG302737-Vehicle menu operation-menu_RollingAbility,not activated ,256
IDE04300-ENG302738-Vehicle menu operation-menu_RollingAbility_after_disclaimer,not activated ,256
IDE04300-ENG302739-Vehicle menu operation-menu_RollingAbility_clamp_15_off,not activated ,256
IDE04300-ENG302740-Vehicle menu operation-menu_RollingAbility_over_threshold_high,not activated ,256
IDE04300-ENG302741-Vehicle menu operation-menu_RollingAbility_standstill,not activated ,256
IDE04300-ENG297713-Vehicle menu operation-menu_RushhourPilot,not activated ,256
IDE04300-ENG297714-Vehicle menu operation-menu_RushhourPilot_after_disclaimer,not activated ,256
IDE04300-ENG297715-Vehicle menu operation-menu_RushhourPilot_clamp_15_off,not activated ,256
IDE04300-ENG297716-Vehicle menu operation-menu_RushhourPilot_over_threshold_high,not activated ,256
IDE04300-ENG297717-Vehicle menu operation-menu_RushhourPilot_standstill,not activated ,256
IDE04300-ENG142092-Vehicle menu operation-menu_soundcontrol,not activated ,256
IDE04300-ENG248754-Vehicle menu operation-menu_SoundControl_2,not activated ,256
IDE04300-ENG248755-Vehicle menu operation-menu_SoundControl_2_after_disclaimer,not activated ,256
IDE04300-ENG248756-Vehicle menu operation-menu_SoundControl_2_clamp_15_off,not activated ,256
IDE04300-ENG248757-Vehicle menu operation-menu_SoundControl_2_over_threshold_high,not activated ,256
IDE04300-ENG248758-Vehicle menu operation-menu_SoundControl_2_stillstand,not activated ,256
IDE04300-ENG142096-Vehicle menu operation-menu_soundcontrol_after_disclaimer,not activated ,256
IDE04300-ENG142093-Vehicle menu operation-menu_soundcontrol_clamp_15_off,not activated ,256
IDE04300-ENG142094-Vehicle menu operation-menu_soundcontrol_over_threshold_high,not activated ,256
IDE04300-ENG142095-Vehicle menu operation-menu_soundcontrol_standstill,not activated ,256
IDE04300-ENG152505-Vehicle menu operation-menu_statistic,not activated ,256
IDE04300-ENG152509-Vehicle menu operation-menu_statistic_after_disclaimer,not activated ,256
IDE04300-ENG152506-Vehicle menu operation-menu_statistic_clamp_15_off,not activated ,256
IDE04300-ENG152507-Vehicle menu operation-menu_statistic_over_threshold_high,not activated ,256
IDE04300-ENG248759-Vehicle menu operation-menu_statistic_stillstand,not activated ,256
IDE04300-ENG152510-Vehicle menu operation-menu_sunroof,activated ,256
IDE04300-ENG152514-Vehicle menu operation-menu_sunroof_after_disclaimer,not activated ,256
IDE04300-ENG152511-Vehicle menu operation-menu_sunroof_clamp_15_off,not activated ,256
IDE04300-ENG152512-Vehicle menu operation-menu_sunroof_over_threshold_high,activated ,256
IDE04300-ENG248760-Vehicle menu operation-menu_sunroof_stillstand,not activated ,256
IDE04300-ENG185803-Vehicle menu operation-menu_vas,not activated ,256
IDE04300-ENG185804-Vehicle menu operation-menu_vas_after_disclaimer,not activated ,256
IDE04300-ENG185805-Vehicle menu operation-menu_vas_clamp_15_off,not activated ,256
IDE04300-ENG185806-Vehicle menu operation-menu_vas_over_threshold_high,not activated ,256
IDE04300-ENG185807-Vehicle menu operation-menu_vas_stillstand,not activated ,256
IDE04300-ENG152500-Vehicle menu operation-menu_wireless_charging,not activated ,256
IDE04300-ENG152504-Vehicle menu operation-menu_wireless_charging_after_disclaimer,not activated ,256
IDE04300-ENG152501-Vehicle menu operation-menu_wireless_charging_clamp_15_off,not activated ,256
IDE04300-ENG152502-Vehicle menu operation-menu_wireless_charging_over_threshold_high,not activated ,256
IDE04300-ENG152503-Vehicle menu operation-menu_wireless_charging_standstill,not activated ,256
IDE04307-ENG117700-Vehicle function list BAP-ACC_0x05,activated ,256
IDE04307-ENG117701-Vehicle function list BAP-ACC_0x05_msg_bus,CAN_FAS ,256
IDE04307-ENG117702-Vehicle function list BAP-air_suspension_0x06,not activated ,256
IDE04307-ENG117703-Vehicle function list BAP-air_suspension_0x06_msg_bus,Suspension data bus ,256
IDE04307-ENG117764-Vehicle function list BAP-Amplifier_0x2D,activated ,256
IDE04307-ENG117765-Vehicle function list BAP-Amplifier_0x2D_msg_bus,Ethernet ,256
IDE04307-ENG122334-Vehicle function list BAP-Angle_Of_Slope_0x24,not activated ,256
IDE04307-ENG122335-Vehicle function list BAP-Angle_Of_Slope_0x24_msg_bus,not activated ,256
IDE04307-ENG117696-Vehicle function list BAP-auxilary_heating_0x03,activated ,256
IDE04307-ENG117697-Vehicle function list BAP-auxilary_heating_0x03_msg_bus,CAB_2 ,256
IDE04307-ENG117744-Vehicle function list BAP-AWV_0x1B,activated ,256
IDE04307-ENG117745-Vehicle function list BAP-AWV_0x1B_msg_bus,Terminal 15 ,256
IDE04307-ENG122336-Vehicle function list BAP-Battery_Management_0x25,not activated ,256
IDE04307-ENG122337-Vehicle function list BAP-Battery_Management_0x25_msg_bus,not activated ,256
IDE04307-ENG117758-Vehicle function list BAP-BCmE_0x23,not activated ,256
IDE04307-ENG117759-Vehicle function list BAP-BCmE_0x23_msg_bus,not activated ,256
IDE04307-ENG117760-Vehicle function list BAP-Brake_0x26,activated ,256
IDE04307-ENG117761-Vehicle function list BAP-Brake_0x26_msg_bus,Suspension data bus ,256
IDE04307-ENG297672-Vehicle function list BAP-BSMOIS_0x76,not activated ,256
IDE04307-ENG297673-Vehicle function list BAP-BSMOIS_0x76_msg_bus,not activated ,256
IDE04307-ENG297674-Vehicle function list BAP-BSMOIS2_0x7A,not activated ,256
IDE04307-ENG297675-Vehicle function list BAP-BSMOIS2_0x7A_msg_bus,not activated ,256
IDE04307-ENG297676-Vehicle function list BAP-BSMOIS3_0x7B,not activated ,256
IDE04307-ENG297677-Vehicle function list BAP-BSMOIS3_0x7B_msg_bus,not activated ,256
IDE04307-ENG324690-Vehicle function list BAP-California_0x81,not activated ,256
IDE04307-ENG331873-Vehicle function list BAP-California_0x81_msg_bus,not activated ,256
IDE04307-ENG248526-Vehicle function list BAP-Car2X_0x61,not activated ,256
IDE04307-ENG248527-Vehicle function list BAP-Car2X_0x61_msg_bus,CAN_AB ,256
IDE04307-ENG117717-Vehicle function list BAP-central_locking_0x0D,activated ,256
IDE04307-ENG117716-Vehicle function list BAP-central_locking_0x0D_msg_bus,Comfort CAN bus 2 ,256
IDE04307-ENG117736-Vehicle function list BAP-charisma_0x17,activated ,256
IDE04307-ENG117737-Vehicle function list BAP-charisma_0x17_msg_bus,CAN_AB ,256
IDE04307-ENG282048-Vehicle function list BAP-ChassisControl_0x57,not activated ,256
IDE04307-ENG282008-Vehicle function list BAP-ChassisControl_0x57_msg_bus,not activated ,256
IDE04307-ENG117734-Vehicle function list BAP-clima_slave_2_0x16,not activated ,256
IDE04307-ENG117735-Vehicle function list BAP-clima_slave_2_0x16_msg_bus,not activated ,256
IDE04307-ENG248490-Vehicle function list BAP-climate_master_0x42,activated ,256
IDE04307-ENG248630-Vehicle function list BAP-climate_master_0x42_msg_bus,CAB_2 ,256
IDE04307-ENG117692-Vehicle function list BAP-climatic_master_0x01,activated ,256
IDE04307-ENG117693-Vehicle function list BAP-climatic_master_0x01_msg_bus,CAB_2 ,256
IDE04307-ENG117694-Vehicle function list BAP-climatic_slave_0x02,activated ,256
IDE04307-ENG117695-Vehicle function list BAP-climatic_slave_0x02_msg_bus,CAB_2 ,256
IDE04307-ENG117724-Vehicle function list BAP-clock_0x11,activated ,256
IDE04307-ENG117725-Vehicle function list BAP-clock_0x11_msg_bus,Comfort data bus ,256
IDE04307-ENG117732-Vehicle function list BAP-compass_0x15,not activated ,256
IDE04307-ENG117733-Vehicle function list BAP-compass_0x15_msg_bus,not activated ,256
IDE04307-ENG142158-Vehicle function list BAP-connection_manager_0x47,not activated ,256
IDE04307-ENG142159-Vehicle function list BAP-connection_manager_0x47_msg_bus,not activated ,256
IDE04307-ENG152529-Vehicle function list BAP-daf_profile_0x51,not activated ,256
IDE04307-ENG152530-Vehicle function list BAP-daf_profile_0x51_msg_bus,not activated ,256
IDE04307-ENG137043-Vehicle function list BAP-display_configuration_0x45,not activated ,256
IDE04307-ENG137044-Vehicle function list BAP-display_configuration_0x45_msg_bus,not activated ,256
IDE04307-ENG297681-Vehicle function list BAP-Doorlocking_2nd_0x79,not activated ,256
IDE04307-ENG297682-Vehicle function list BAP-Doorlocking_2nd_0x79_msg_bus,not activated ,256
IDE04307-ENG117722-Vehicle function list BAP-driver_seat_0x10,activated ,256
IDE04307-ENG117723-Vehicle function list BAP-driver_seat_0x10_msg_bus,Comfort data bus ,256
IDE04307-ENG302721-Vehicle function list BAP-DrivingDynamics_0x7E,not activated ,256
IDE04307-ENG302722-Vehicle function list BAP-DrivingDynamics_0x7E_msg_bus,not activated ,256
IDE04307-ENG125039-Vehicle function list BAP-Ecall_0x33,activated ,256
IDE04307-ENG125828-Vehicle function list BAP-eCall_0x33_msg_bus,Ethernet ,256
IDE04307-ENG127500-Vehicle function list BAP-efficiency_assis_msg_bus_0x3C,Powertrain data bus ,256
IDE04307-ENG127499-Vehicle function list BAP-efficiency_assist_0x3C,activated ,256
IDE04307-ENG248657-Vehicle function list BAP-EngineFunctions_0x5D,not activated ,256
IDE04307-ENG248658-Vehicle function list BAP-EngineFunctions_0x5D_msg_bus,Powertrain data bus ,256
IDE04307-ENG125829-Vehicle function list BAP-ENI_0x37,activated ,256
IDE04307-ENG125830-Vehicle function list BAP-ENI_0x37_msg_bus,CAN_AB ,256
IDE04307-ENG264168-Vehicle function list BAP-ENI2_0x58,not activated ,256
IDE04307-ENG264169-Vehicle function list BAP-ENI2_0x58_msg_bus,not activated ,256
IDE04307-ENG264170-Vehicle function list BAP-ENI3_0x6E,not activated ,256
IDE04307-ENG264171-Vehicle function list BAP-ENI3_0x6E_msg_bus,not activated ,256
IDE04307-ENG264172-Vehicle function list BAP-ENI4_0x6F,activated ,256
IDE04307-ENG264173-Vehicle function list BAP-ENI4_0x6F_msg_bus,CAN_AB ,256
IDE04307-ENG117708-Vehicle function list BAP-exterieur_light_0x09,activated ,256
IDE04307-ENG117709-Vehicle function list BAP-exterieur_light_0x09_msg_bus,Comfort CAN bus 2 ,256
IDE04307-ENG252073-Vehicle function list BAP-exterieur_light_2_0x6B,activated ,256
IDE04307-ENG252076-Vehicle function list BAP-exterieur_light_2_0x6B_msg_bus,Comfort CAN bus 2 ,256
IDE04307-ENG142168-Vehicle function list BAP-fas_profile_0x4D,not activated ,256
IDE04307-ENG142169-Vehicle function list BAP-fas_profile_0x4D_msg_bus,CAN_AB ,256
IDE04307-ENG142154-Vehicle function list BAP-front_traffic_assist_0x41,not activated ,256
IDE04307-ENG142155-Vehicle function list BAP-front_traffic_assist_0x41_msg_bus,not activated ,256
IDE04307-ENG117698-Vehicle function list BAP-headup_displ_0x04,not activated ,256
IDE04307-ENG117699-Vehicle function list BAP-headup_displ_0x04_msg_bus,CAN_AB ,256
IDE04307-ENG117746-Vehicle function list BAP-Hybrid_0x1D,not activated ,256
IDE04307-ENG117747-Vehicle function list BAP-Hybrid_0x1D_msg_bus,not activated ,256
IDE04307-ENG248711-Vehicle function list BAP-IAA_PSO_0x52,not activated ,256
IDE04307-ENG248712-Vehicle function list BAP-IAA_PSO_0x52_msg_bus,not activated ,256
IDE04307-ENG152535-Vehicle function list BAP-infotainmentsettings_profile_0x50,activated ,256
IDE04307-ENG152536-Vehicle function list BAP-infotainmentsettings_profile_0x50_msg_bus,not activated ,256
IDE04307-ENG117706-Vehicle function list BAP-interieur_light_0x08,activated ,256
IDE04307-ENG117707-Vehicle function list BAP-interieur_light_0x08_msg_bus,Comfort CAN bus 2 ,256
IDE04307-ENG252052-Vehicle function list BAP-interieur_light_2_0x6A,activated ,256
IDE04307-ENG252047-Vehicle function list BAP-interieur_light_2_0x6A_msg_bus,Comfort CAN bus 2 ,256
IDE04307-ENG248719-Vehicle function list BAP-ITM_0x65,not activated ,256
IDE04307-ENG248720-Vehicle function list BAP-ITM_0x65_msg_bus,not activated ,256
IDE04307-ENG117740-Vehicle function list BAP-LDW_HCA_0x19,activated ,256
IDE04307-ENG117741-Vehicle function list BAP-LDW_HCA_0x19_msg_bus,CAN_FAS ,256
IDE04307-ENG249902-Vehicle function list BAP-lift_0x64,not activated ,256
IDE04307-ENG249903-Vehicle function list BAP-lift_0x64_msg_bus,not activated ,256
IDE04307-ENG281905-Vehicle function list BAP-LLCC_0x78,not activated ,256
IDE04307-ENG281994-Vehicle function list BAP-LLCC_0x78_msg_bus,not activated ,256
IDE04307-ENG248726-Vehicle function list BAP-Mascot_0x53,not activated ,256
IDE04307-ENG248727-Vehicle function list BAP-Mascot_0x53_msg_bus,not activated ,256
IDE04307-ENG117720-Vehicle function list BAP-MFA_0x0F,activated ,256
IDE04307-ENG117721-Vehicle function list BAP-MFA_0x0F_msg_bus,Comfort data bus ,256
IDE04307-ENG117767-Vehicle function list BAP-MFL_Jocker_0x34,not activated ,256
IDE04307-ENG117766-Vehicle function list BAP-MFL_Jocker_msg_bus_0x34,CAN_AB ,256
IDE04307-ENG117719-Vehicle function list BAP-mirror_0x0E,activated ,256
IDE04307-ENG117718-Vehicle function list BAP-mirror_0x0E_msg_bus,Comfort CAN bus 2 ,256
IDE04307-ENG345841-Vehicle function list BAP-MobDevKey_0x77,not activated ,256
IDE04307-ENG345842-Vehicle function list BAP-MobDevKey_0x77_msg_bus,not activated ,256
IDE04307-ENG117738-Vehicle function list BAP-Night_Vision_0x18,not activated ,256
IDE04307-ENG117739-Vehicle function list BAP-Night_Vision_0x18_msg_bus,not activated ,256
IDE04307-ENG248788-Vehicle function list BAP-PaCo_0x55,activated ,256
IDE04307-ENG248789-Vehicle function list BAP-PaCo_0x55_msg_bus,CAN_AB ,256
IDE04307-ENG117710-Vehicle function list BAP-parking_assist_0x0A,activated ,256
IDE04307-ENG117711-Vehicle function list BAP-parking_assist_0x0A_msg_bus,can_fas_2 ,256
IDE04307-ENG117752-Vehicle function list BAP-Passenger_Seat_0x20,not activated ,256
IDE04307-ENG117753-Vehicle function list BAP-Passenger_Seat_0x20_msg_bus,Comfort data bus ,256
IDE04307-ENG125831-Vehicle function list BAP-Pedestrian_Assist_0x3A,not activated ,256
IDE04307-ENG125832-Vehicle function list BAP-Pedestrian_Assist_msg_bus_0x3A,not activated ,256
IDE04307-ENG325104-Vehicle function list BAP-Plug_and_charge_0x80,not activated ,256
IDE04307-ENG395187-Vehicle function list BAP-Plug_and_Charge_0x80_msg_bus,not activated ,256
IDE04307-ENG122333-Vehicle function list BAP-Range_Data_0x39,not activated ,256
IDE04307-ENG125827-Vehicle function list BAP-Range_Data_msg_bus_0x39,not activated ,256
IDE04307-ENG122327-Vehicle function list BAP-RearSeatEntertainment_0x2E,not activated ,256
IDE04307-ENG122328-Vehicle function list BAP-RearSeatEntertainment_0x2E_msg_bus,not activated ,256
IDE04307-ENG248801-Vehicle function list BAP-remote_services_0x4E,not activated ,256
IDE04307-ENG248802-Vehicle function list BAP-remote_services_0x4E_msg_bus,not activated ,256
IDE04307-ENG117750-Vehicle function list BAP-Reversible_Seat_Belt_Tightener_0x1F,not activated ,256
IDE04307-ENG117751-Vehicle function list BAP-Reversible_Seat_Belt_Tightener_0x1F_msg_bus,not activated ,256
IDE04307-ENG316850-Vehicle function list BAP-RollingAbility_0x75,not activated ,256
IDE04307-ENG316851-Vehicle function list BAP-RollingAbility_0x75_msg_bus,not activated ,256
IDE04307-ENG297722-Vehicle function list BAP-RushhourPilot_0x7C,not activated ,256
IDE04307-ENG297723-Vehicle function list BAP-RushhourPilot_0x7C_msg_bus,not activated ,256
IDE04307-ENG125833-Vehicle function list BAP-Seat_Pneumatic_0x3B,activated ,256
IDE04307-ENG125834-Vehicle function list BAP-Seat_Pneumatic_msg_bus_0x3B,Comfort data bus ,256
IDE04307-ENG139200-Vehicle function list BAP-Seatmemory_codriver_rear_0x3F,not activated ,256
IDE04307-ENG139201-Vehicle function list BAP-Seatmemory_codriver_rear_msg_bus_0x3F,not activated ,256
IDE04307-ENG139198-Vehicle function list BAP-Seatmemory_driver_rear_0x3E,not activated ,256
IDE04307-ENG139199-Vehicle function list BAP-Seatmemory_driver_rear_msg_bus_0x3E,not activated ,256
IDE04307-ENG395209-Vehicle function list BAP-SecurityEvent_0x82,not activated ,256
IDE04307-ENG395210-Vehicle function list BAP-SecurityEvent_0x82_msg_bus,not activated ,256
IDE04307-ENG117726-Vehicle function list BAP-service_interval_display_0x12,activated ,256
IDE04307-ENG117727-Vehicle function list BAP-service_interval_display_0x12_msg_bus,Comfort data bus ,256
IDE04307-ENG117748-Vehicle function list BAP-SideView_0x1E,not activated ,256
IDE04307-ENG117749-Vehicle function list BAP-SideView_0x1E_msg_bus,not activated ,256
IDE04307-ENG139202-Vehicle function list BAP-Soundcontrol_0x44,not activated ,256
IDE04307-ENG139203-Vehicle function list BAP-Soundcontrol_0x44_msg_bus,not activated ,256
IDE04307-ENG248819-Vehicle function list BAP-SoundControl2_0x66,not activated ,256
IDE04307-ENG248820-Vehicle function list BAP-SoundControl2_0x66_msg_bus,not activated ,256
IDE04307-ENG122329-Vehicle function list BAP-Special_Functions_0x35,not activated ,256
IDE04307-ENG122330-Vehicle function list BAP-Special_Functions_msg_bus_0x35,not activated ,256
IDE04307-ENG127678-Vehicle function list BAP-spoiler_0x40,not activated ,256
IDE04307-ENG127679-Vehicle function list BAP-spoiler_0x40_msg_bus,not activated ,256
IDE04307-ENG117762-Vehicle function list BAP-Start_Stop_reasons_0x27,not activated ,256
IDE04307-ENG117763-Vehicle function list BAP-Start_Stop_reasons_0x27_msg_bus,not activated ,256
IDE04307-ENG142162-Vehicle function list BAP-statistic_0x4A,not activated ,256
IDE04307-ENG142163-Vehicle function list BAP-statistic_0x4A_msg_bus,not activated ,256
IDE04307-ENG142164-Vehicle function list BAP-sunroof_front_0x4B,activated ,256
IDE04307-ENG142165-Vehicle function list BAP-sunroof_front_0x4B_msg_bus,Comfort data bus ,256
IDE04307-ENG142166-Vehicle function list BAP-sunroof_rear_0x4C,not activated ,256
IDE04307-ENG142167-Vehicle function list BAP-sunroof_rear_0x4C_msg_bus,not activated ,256
IDE04307-ENG117742-Vehicle function list BAP-SWA_0x1A,activated ,256
IDE04307-ENG117743-Vehicle function list BAP-SWA_0x1A_msg_bus,can_fas_2 ,256
IDE04307-ENG117704-Vehicle function list BAP-tire_pressure_system_0x07,activated ,256
IDE04307-ENG117705-Vehicle function list BAP-tire_pressure_system_0x07_msg_bus,Suspension data bus ,256
IDE04307-ENG117754-Vehicle function list BAP-traffic_sign_recognition_0x21,activated ,256
IDE04307-ENG117755-Vehicle function list BAP-traffic_sign_recognition_0x21_msg_bus,CAN_FAS ,256
IDE04307-ENG122331-Vehicle function list BAP-Trailer_Assistant_0x36,not activated ,256
IDE04307-ENG122332-Vehicle function list BAP-Trailer_Assistant_msg_bus_0x36,not activated ,256
IDE04307-ENG260744-Vehicle function list BAP-Trained_Park_Assist_0x5F,activated ,256
IDE04307-ENG258630-Vehicle function list BAP-Trained_Park_Assist_0x5F_msg_bus,CAN_FAS ,256
IDE04307-ENG122325-Vehicle function list BAP-TV_tuner_0x2C,not activated ,256
IDE04307-ENG122326-Vehicle function list BAP-TV_tuner_0x2C_msg_bus,not activated ,256
IDE04307-ENG117730-Vehicle function list BAP-UGDO_0x14,not activated ,256
IDE04307-ENG117731-Vehicle function list BAP-UGDO_0x14_msg_bus,not activated ,256
IDE04307-ENG117728-Vehicle function list BAP-unit_master_0x13,activated ,256
IDE04307-ENG117729-Vehicle function list BAP-unit_master_0x13_msg_bus,Comfort data bus ,256
IDE04307-ENG185817-Vehicle function list BAP-vas_0x54,not activated ,256
IDE04307-ENG185818-Vehicle function list BAP-vas_0x54_msg_bus,not activated ,256
IDE04307-ENG117712-Vehicle function list BAP-VPS_0x0B,activated ,256
IDE04307-ENG117713-Vehicle function list BAP-VPS_0x0B_msg_bus,can_fas_2 ,256
IDE04307-ENG117756-Vehicle function list BAP-weariness_rcognition_0x22,not activated ,256
IDE04307-ENG117757-Vehicle function list BAP-weariness_rcognition_0x22_msg_bus,CAN_AB ,256
IDE04307-ENG117714-Vehicle function list BAP-wiper_comfort_0x0C,activated ,256
IDE04307-ENG117715-Vehicle function list BAP-wiper_comfort_0x0C_msg_bus,Comfort CAN bus 2 ,256
IDE04307-ENG142160-Vehicle function list BAP-wireless_charging_0x48,not activated ,256
IDE04307-ENG142161-Vehicle function list BAP-wireless_charging_0x48_msg_bus,not activated ,256
IDE06698-MAS00839-Audio management input gain-TV Tuner,-128 dB,34
IDE06698-MAS00846-Audio management input gain-Satellite radio,-128 dB,34
IDE06698-MAS01984-Audio management input gain-Radio (FM),-128 dB,34
IDE06698-MAS01985-Audio management input gain-Radio (AM),-128 dB,34
IDE06698-MAS01986-Audio management input gain-Digital radio (DAB),-128 dB,34
IDE06698-ENG125854-Audio management input gain-Exbox_DMB,-128 dB,34
IDE06698-ENG117430-Audio management input gain-HFP,-128 dB,34
IDE06698-ENG125846-Audio management input gain-Media_Airplay,-128 dB,34
IDE06698-ENG125837-Audio management input gain-Media_AUX_Adapter,-128 dB,34
IDE06698-ENG125836-Audio management input gain-Media_AUXIN,-128 dB,34
IDE06698-ENG125843-Audio management input gain-Media_Bluray,-128 dB,34
IDE06698-ENG125841-Audio management input gain-Media_BTDevice,-128 dB,34
IDE06698-ENG125838-Audio management input gain-Media_CDA,-128 dB,34
IDE06698-ENG125848-Audio management input gain-Media_Cloud,-128 dB,34
IDE06698-ENG125839-Audio management input gain-Media_DVD,-128 dB,34
IDE06698-ENG125844-Audio management input gain-Media_HDMI,-128 dB,34
IDE06698-ENG125840-Audio management input gain-Media_MFP,-128 dB,34
IDE06698-ENG125847-Audio management input gain-Media_UPNP,-128 dB,34
IDE06698-ENG125855-Audio management input gain-Mirrorlink,-128 dB,34
IDE06698-ENG125859-Audio management input gain-Phone_Ringer_MFP,-128 dB,34
IDE06698-ENG125860-Audio management input gain-Phone_Ringer_OB,-128 dB,34
IDE06698-ENG125858-Audio management input gain-Phone_Voice,-128 dB,34
IDE06698-ENG125842-Audio management input gain-TA_Tuner_FM,-128 dB,34
IDE06698-ENG125850-Audio management input gain-Tone_Beep,-128 dB,34
IDE06698-ENG125853-Audio management input gain-Tone_Messaging,-128 dB,34
IDE06698-ENG125852-Audio management input gain-Tone_Touchscreen,-128 dB,34
IDE06698-ENG125851-Audio management input gain-Tone_Warning,-128 dB,34
IDE06698-ENG251556-Audio management input gain-touch_screen_player,-128 dB,34
IDE06698-ENG125856-Audio management input gain-TTS_Nav,-128 dB,34
IDE06698-ENG125857-Audio management input gain-TTS_SDS,-128 dB,34
IDE06698-ENG125845-Audio management input gain-Tuner_Online,-128 dB,34
IDE06698-ENG125849-Audio management input gain-Tuner_Personal,-128 dB,34
IDE06698-ENG125835-Audio management input gain-Tuner_TI,-128 dB,34
IDE06698-ENG125861-Audio management input gain-TV_AV_IN,-128 dB,34
IDE08814-IDE04033-Navigation receiver GNSS configuration-Compass,not activated ,2
IDE08814-MAS01570-Navigation receiver GNSS configuration-Default,not activated ,2
IDE08814-MAS02614-Navigation receiver GNSS configuration-GPS,not activated ,2
IDE08814-MAS07828-Navigation receiver GNSS configuration-Galileo,not activated ,2
IDE08814-MAS07829-Navigation receiver GNSS configuration-Glonass,not activated ,2
IDE08814-MAS14301-Navigation receiver GNSS configuration-external GPS receiver via bus,activated ,2
IDE08814-MAS15014-Navigation receiver GNSS configuration-Beidou,not activated ,2
IDE08814-MAS18801-Navigation receiver GNSS configuration-external GPS receiver 2 via bus,not activated ,2
IDE08814-MAS18802-Navigation receiver GNSS configuration-Gnss update rate,10 ,2
IDE08814-ENG259336-Navigation receiver GNSS configuration-GNSS_over_ethernet,not activated ,2
IDE09038-MAS04894-Active correction matrix index-Operating mode,OFF ,3
IDE09038-MAS08163-Active correction matrix index-Memory mode,EEPROM ,3
IDE10604-Menu entries for mobile online services,not activated ,1
IDE11104-MAS18803-FM tuner: mono/stereo setting-lower HF stereo threshold in dBµV,36 ,3
IDE11104-MAS18804-FM tuner: mono/stereo setting-Maximum NF stereo channel separation in dB,40 ,3
IDE11104-MAS18805-FM tuner: mono/stereo setting-lower HF stereo threshold in seconds,15.00 s,3
IDE11122-Country identification: country of sale HMI,US ,2
IDE11502-ENG127601-Locked menu contents-FB_CAR_0,blocked ,23
IDE11502-ENG127602-Locked menu contents-FB_CAR_1,non_blocked ,23
IDE11502-ENG127611-Locked menu contents-FB_CAR_10,blocked ,23
IDE11502-ENG127612-Locked menu contents-FB_CAR_11,blocked ,23
IDE11502-ENG127613-Locked menu contents-FB_CAR_12,blocked ,23
IDE11502-ENG127614-Locked menu contents-FB_CAR_13,non_blocked ,23
IDE11502-ENG127615-Locked menu contents-FB_CAR_14,blocked ,23
IDE11502-ENG127616-Locked menu contents-FB_CAR_15,blocked ,23
IDE11502-ENG127617-Locked menu contents-FB_CAR_16,blocked ,23
IDE11502-ENG127618-Locked menu contents-FB_CAR_17,non_blocked ,23
IDE11502-ENG127619-Locked menu contents-FB_CAR_18,non_blocked ,23
IDE11502-ENG127620-Locked menu contents-FB_CAR_19,non_blocked ,23
IDE11502-ENG127603-Locked menu contents-FB_CAR_2,non_blocked ,23
IDE11502-ENG127621-Locked menu contents-FB_CAR_20,non_blocked ,23
IDE11502-ENG127622-Locked menu contents-FB_CAR_21,non_blocked ,23
IDE11502-ENG127623-Locked menu contents-FB_CAR_22,blocked ,23
IDE11502-ENG127624-Locked menu contents-FB_CAR_23,non_blocked ,23
IDE11502-ENG127604-Locked menu contents-FB_CAR_3,blocked ,23
IDE11502-ENG127605-Locked menu contents-FB_CAR_4,blocked ,23
IDE11502-ENG127606-Locked menu contents-FB_CAR_5,non_blocked ,23
IDE11502-ENG127607-Locked menu contents-FB_CAR_6,blocked ,23
IDE11502-ENG127608-Locked menu contents-FB_CAR_7,blocked ,23
IDE11502-ENG127609-Locked menu contents-FB_CAR_8,non_blocked ,23
IDE11502-ENG127610-Locked menu contents-FB_CAR_9,blocked ,23
IDE11502-ENG248673-Locked menu contents-FB_HELP_0,non_blocked ,23
IDE11502-ENG248674-Locked menu contents-FB_HELP_1,non_blocked ,23
IDE11502-ENG248675-Locked menu contents-FB_HELP_2,non_blocked ,23
IDE11502-ENG248676-Locked menu contents-FB_HELP_3,non_blocked ,23
IDE11502-ENG248677-Locked menu contents-FB_HELP_4,non_blocked ,23
IDE11502-ENG248678-Locked menu contents-FB_HELP_5,non_blocked ,23
IDE11502-ENG248679-Locked menu contents-FB_HELP_6,non_blocked ,23
IDE11502-ENG248680-Locked menu contents-FB_HELP_7,non_blocked ,23
IDE11502-ENG248681-Locked menu contents-FB_HELP_8,non_blocked ,23
IDE11502-ENG248682-Locked menu contents-FB_HELP_9,non_blocked ,23
IDE11502-ENG127521-Locked menu contents-FB_MEDIA_0,non_blocked ,23
IDE11502-ENG127522-Locked menu contents-FB_MEDIA_1,blocked ,23
IDE11502-ENG127531-Locked menu contents-FB_MEDIA_10,non_blocked ,23
IDE11502-ENG127532-Locked menu contents-FB_MEDIA_11,non_blocked ,23
IDE11502-ENG127533-Locked menu contents-FB_MEDIA_12,non_blocked ,23
IDE11502-ENG127534-Locked menu contents-FB_MEDIA_13,non_blocked ,23
IDE11502-ENG127535-Locked menu contents-FB_MEDIA_14,non_blocked ,23
IDE11502-ENG127536-Locked menu contents-FB_MEDIA_15,blocked ,23
IDE11502-ENG127537-Locked menu contents-FB_MEDIA_16,non_blocked ,23
IDE11502-ENG127538-Locked menu contents-FB_MEDIA_17,non_blocked ,23
IDE11502-ENG127539-Locked menu contents-FB_MEDIA_18,non_blocked ,23
IDE11502-ENG127540-Locked menu contents-FB_MEDIA_19,blocked ,23
IDE11502-ENG127523-Locked menu contents-FB_MEDIA_2,non_blocked ,23
IDE11502-ENG127541-Locked menu contents-FB_MEDIA_20,blocked ,23
IDE11502-ENG127542-Locked menu contents-FB_MEDIA_21,blocked ,23
IDE11502-ENG127543-Locked menu contents-FB_MEDIA_22,non_blocked ,23
IDE11502-ENG127544-Locked menu contents-FB_MEDIA_23,non_blocked ,23
IDE11502-ENG127524-Locked menu contents-FB_MEDIA_3,blocked ,23
IDE11502-ENG127525-Locked menu contents-FB_MEDIA_4,blocked ,23
IDE11502-ENG127526-Locked menu contents-FB_MEDIA_5,non_blocked ,23
IDE11502-ENG127527-Locked menu contents-FB_MEDIA_6,non_blocked ,23
IDE11502-ENG127528-Locked menu contents-FB_MEDIA_7,blocked ,23
IDE11502-ENG127529-Locked menu contents-FB_MEDIA_8,blocked ,23
IDE11502-ENG127530-Locked menu contents-FB_MEDIA_9,non_blocked ,23
IDE11502-ENG127625-Locked menu contents-FB_MISC_0,blocked ,23
IDE11502-ENG127626-Locked menu contents-FB_MISC_1,blocked ,23
IDE11502-ENG127635-Locked menu contents-FB_MISC_10,non_blocked ,23
IDE11502-ENG127636-Locked menu contents-FB_MISC_11,non_blocked ,23
IDE11502-ENG127637-Locked menu contents-FB_MISC_12,blocked ,23
IDE11502-ENG127638-Locked menu contents-FB_MISC_13,non_blocked ,23
IDE11502-ENG127639-Locked menu contents-FB_MISC_14,blocked ,23
IDE11502-ENG127640-Locked menu contents-FB_MISC_15,blocked ,23
IDE11502-ENG127641-Locked menu contents-FB_MISC_16,non_blocked ,23
IDE11502-ENG127642-Locked menu contents-FB_MISC_17,non_blocked ,23
IDE11502-ENG127643-Locked menu contents-FB_MISC_18,blocked ,23
IDE11502-ENG127644-Locked menu contents-FB_MISC_19,blocked ,23
IDE11502-ENG127627-Locked menu contents-FB_MISC_2,blocked ,23
IDE11502-ENG127645-Locked menu contents-FB_MISC_20,non_blocked ,23
IDE11502-ENG127646-Locked menu contents-FB_MISC_21,non_blocked ,23
IDE11502-ENG127647-Locked menu contents-FB_MISC_22,non_blocked ,23
IDE11502-ENG127648-Locked menu contents-FB_MISC_23,non_blocked ,23
IDE11502-ENG127649-Locked menu contents-FB_MISC_24,non_blocked ,23
IDE11502-ENG127650-Locked menu contents-FB_MISC_25,blocked ,23
IDE11502-ENG127651-Locked menu contents-FB_MISC_26,blocked ,23
IDE11502-ENG127652-Locked menu contents-FB_MISC_27,blocked ,23
IDE11502-ENG127653-Locked menu contents-FB_MISC_28,non_blocked ,23
IDE11502-ENG127654-Locked menu contents-FB_MISC_29,blocked ,23
IDE11502-ENG127628-Locked menu contents-FB_MISC_3,non_blocked ,23
IDE11502-ENG127655-Locked menu contents-FB_MISC_30,non_blocked ,23
IDE11502-ENG127656-Locked menu contents-FB_MISC_31,blocked ,23
IDE11502-ENG127657-Locked menu contents-FB_MISC_32,blocked ,23
IDE11502-ENG127658-Locked menu contents-FB_MISC_33,non_blocked ,23
IDE11502-ENG127659-Locked menu contents-FB_MISC_34,non_blocked ,23
IDE11502-ENG127660-Locked menu contents-FB_MISC_35,blocked ,23
IDE11502-ENG127661-Locked menu contents-FB_MISC_36,non_blocked ,23
IDE11502-ENG127662-Locked menu contents-FB_MISC_37,non_blocked ,23
IDE11502-ENG127663-Locked menu contents-FB_MISC_38,blocked ,23
IDE11502-ENG127664-Locked menu contents-FB_MISC_39,non_blocked ,23
IDE11502-ENG127629-Locked menu contents-FB_MISC_4,non_blocked ,23
IDE11502-ENG127665-Locked menu contents-FB_MISC_40,blocked ,23
IDE11502-ENG127666-Locked menu contents-FB_MISC_41,blocked ,23
IDE11502-ENG127667-Locked menu contents-FB_MISC_42,blocked ,23
IDE11502-ENG127668-Locked menu contents-FB_MISC_43,blocked ,23
IDE11502-ENG127669-Locked menu contents-FB_MISC_44,non_blocked ,23
IDE11502-ENG127670-Locked menu contents-FB_MISC_45,blocked ,23
IDE11502-ENG127671-Locked menu contents-FB_MISC_46,blocked ,23
IDE11502-ENG127672-Locked menu contents-FB_MISC_47,non_blocked ,23
IDE11502-ENG127630-Locked menu contents-FB_MISC_5,non_blocked ,23
IDE11502-ENG127631-Locked menu contents-FB_MISC_6,non_blocked ,23
IDE11502-ENG127632-Locked menu contents-FB_MISC_7,non_blocked ,23
IDE11502-ENG127633-Locked menu contents-FB_MISC_8,non_blocked ,23
IDE11502-ENG127634-Locked menu contents-FB_MISC_9,blocked ,23
IDE11502-ENG127561-Locked menu contents-FB_NAV_0,non_blocked ,23
IDE11502-ENG127562-Locked menu contents-FB_NAV_1,blocked ,23
IDE11502-ENG127571-Locked menu contents-FB_NAV_10,blocked ,23
IDE11502-ENG127572-Locked menu contents-FB_NAV_11,non_blocked ,23
IDE11502-ENG127573-Locked menu contents-FB_NAV_12,non_blocked ,23
IDE11502-ENG127574-Locked menu contents-FB_NAV_13,blocked ,23
IDE11502-ENG127575-Locked menu contents-FB_NAV_14,blocked ,23
IDE11502-ENG127576-Locked menu contents-FB_NAV_15,non_blocked ,23
IDE11502-ENG127577-Locked menu contents-FB_NAV_16,non_blocked ,23
IDE11502-ENG127578-Locked menu contents-FB_NAV_17,non_blocked ,23
IDE11502-ENG127579-Locked menu contents-FB_NAV_18,non_blocked ,23
IDE11502-ENG127580-Locked menu contents-FB_NAV_19,non_blocked ,23
IDE11502-ENG127563-Locked menu contents-FB_NAV_2,blocked ,23
IDE11502-ENG127581-Locked menu contents-FB_NAV_20,non_blocked ,23
IDE11502-ENG127582-Locked menu contents-FB_NAV_21,blocked ,23
IDE11502-ENG127583-Locked menu contents-FB_NAV_22,non_blocked ,23
IDE11502-ENG127584-Locked menu contents-FB_NAV_23,non_blocked ,23
IDE11502-ENG127585-Locked menu contents-FB_NAV_24,blocked ,23
IDE11502-ENG127586-Locked menu contents-FB_NAV_25,non_blocked ,23
IDE11502-ENG127587-Locked menu contents-FB_NAV_26,non_blocked ,23
IDE11502-ENG127588-Locked menu contents-FB_NAV_27,blocked ,23
IDE11502-ENG127589-Locked menu contents-FB_NAV_28,non_blocked ,23
IDE11502-ENG127590-Locked menu contents-FB_NAV_29,blocked ,23
IDE11502-ENG127564-Locked menu contents-FB_NAV_3,non_blocked ,23
IDE11502-ENG127591-Locked menu contents-FB_NAV_30,blocked ,23
IDE11502-ENG127592-Locked menu contents-FB_NAV_31,non_blocked ,23
IDE11502-ENG127593-Locked menu contents-FB_NAV_32,non_blocked ,23
IDE11502-ENG127594-Locked menu contents-FB_NAV_33,blocked ,23
IDE11502-ENG127595-Locked menu contents-FB_NAV_34,non_blocked ,23
IDE11502-ENG127596-Locked menu contents-FB_NAV_35,non_blocked ,23
IDE11502-ENG127597-Locked menu contents-FB_NAV_36,non_blocked ,23
IDE11502-ENG127598-Locked menu contents-FB_NAV_37,non_blocked ,23
IDE11502-ENG127599-Locked menu contents-FB_NAV_38,non_blocked ,23
IDE11502-ENG127600-Locked menu contents-FB_NAV_39,non_blocked ,23
IDE11502-ENG127565-Locked menu contents-FB_NAV_4,non_blocked ,23
IDE11502-ENG127566-Locked menu contents-FB_NAV_5,non_blocked ,23
IDE11502-ENG127567-Locked menu contents-FB_NAV_6,blocked ,23
IDE11502-ENG127568-Locked menu contents-FB_NAV_7,non_blocked ,23
IDE11502-ENG127569-Locked menu contents-FB_NAV_8,non_blocked ,23
IDE11502-ENG127570-Locked menu contents-FB_NAV_9,non_blocked ,23
IDE11502-ENG127545-Locked menu contents-FB_PHONE_0,blocked ,23
IDE11502-ENG127546-Locked menu contents-FB_PHONE_1,blocked ,23
IDE11502-ENG127555-Locked menu contents-FB_PHONE_10,blocked ,23
IDE11502-ENG127556-Locked menu contents-FB_PHONE_11,non_blocked ,23
IDE11502-ENG127557-Locked menu contents-FB_PHONE_12,blocked ,23
IDE11502-ENG127558-Locked menu contents-FB_PHONE_13,non_blocked ,23
IDE11502-ENG127559-Locked menu contents-FB_PHONE_14,non_blocked ,23
IDE11502-ENG127560-Locked menu contents-FB_PHONE_15,blocked ,23
IDE11502-ENG127547-Locked menu contents-FB_PHONE_2,blocked ,23
IDE11502-ENG127548-Locked menu contents-FB_PHONE_3,non_blocked ,23
IDE11502-ENG127549-Locked menu contents-FB_PHONE_4,blocked ,23
IDE11502-ENG127550-Locked menu contents-FB_PHONE_5,non_blocked ,23
IDE11502-ENG127551-Locked menu contents-FB_PHONE_6,blocked ,23
IDE11502-ENG127552-Locked menu contents-FB_PHONE_7,non_blocked ,23
IDE11502-ENG127553-Locked menu contents-FB_PHONE_8,non_blocked ,23
IDE11502-ENG127554-Locked menu contents-FB_PHONE_9,non_blocked ,23
IDE11502-ENG127505-Locked menu contents-FB_TUNER_0,non_blocked ,23
IDE11502-ENG127506-Locked menu contents-FB_TUNER_1,non_blocked ,23
IDE11502-ENG127515-Locked menu contents-FB_TUNER_10,non_blocked ,23
IDE11502-ENG127516-Locked menu contents-FB_TUNER_11,non_blocked ,23
IDE11502-ENG127517-Locked menu contents-FB_TUNER_12,blocked ,23
IDE11502-ENG127518-Locked menu contents-FB_TUNER_13,blocked ,23
IDE11502-ENG127519-Locked menu contents-FB_TUNER_14,non_blocked ,23
IDE11502-ENG127520-Locked menu contents-FB_TUNER_15,non_blocked ,23
IDE11502-ENG127507-Locked menu contents-FB_TUNER_2,non_blocked ,23
IDE11502-ENG127508-Locked menu contents-FB_TUNER_3,non_blocked ,23
IDE11502-ENG127509-Locked menu contents-FB_TUNER_4,non_blocked ,23
IDE11502-ENG127510-Locked menu contents-FB_TUNER_5,non_blocked ,23
IDE11502-ENG127511-Locked menu contents-FB_TUNER_6,blocked ,23
IDE11502-ENG127512-Locked menu contents-FB_TUNER_7,blocked ,23
IDE11502-ENG127513-Locked menu contents-FB_TUNER_8,non_blocked ,23
IDE11502-ENG127514-Locked menu contents-FB_TUNER_9,non_blocked ,23
IDE11503-Satellite radio tuner: pre-activated subscription,05 ,1
IDE11638-Bluetooth Audio Codec,01 ,1
IDE16364-IDE16536-List of identifiers and data record numbers-Identifier,00 00 ,2
IDE16364-MAS25708-List of identifiers and data record numbers-Number Of Identifiers,0 ,2
IDE16969-Reset fault memory for production process,Yes ,1
MAS00951-Bluetooth,On ,1
MAS01968-Fan,normal ,1
MAS03782-WLAN,On ,1
ENG248412-5_ghz_wlan,OFF ,1
ENG253242-ENG259195-a2b_data_streams-Emergency_mic_transducer_selection,mic_transducer_3 ,10
ENG253242-ENG260060-a2b_data_streams-Multi_Center_Speaker_via_Connectivity_Unit,present ,10
ENG253242-ENG259380-a2b_data_streams-Transducer_amount_mic_front_module_node,3 ,10
ENG253242-ENG260344-a2b_data_streams-Transducer_amount_mic_module_rear_left_node,0 ,10
ENG253242-ENG259983-a2b_data_streams-Transducer_amount_mic_module_rear_right_node,0 ,10
ENG248413-alphabetic_scrollbar,On ,1
ENG253302-ENG260724-audio_zone_configuration-zone_1_direction,Left ,6
ENG253302-ENG259844-audio_zone_configuration-zone_1_position,front_row ,6
ENG253302-ENG260273-audio_zone_configuration-zone_2_direction,Right ,6
ENG253302-ENG259809-audio_zone_configuration-zone_2_position,front_row ,6
ENG253302-ENG261136-audio_zone_configuration-zone_3_direction,none ,6
ENG253302-ENG260623-audio_zone_configuration-zone_3_position,none ,6
ENG253302-ENG259382-audio_zone_configuration-zone_4_direction,none ,6
ENG253302-ENG259681-audio_zone_configuration-zone_4_position,none ,6
ENG278415-ENG278444-battery_type_selection-Battery_Type,48kWh ,2
ENG278415-ENG279975-battery_type_selection-DC_charging_power,50kW_DC ,2
ENG248422-ENG248496-calendar_reminder-acoustic_reminder,OFF ,1
ENG248422-ENG248696-calendar_reminder-haptic_reminder,OFF ,1
ENG248423-channel_band_width_802_11ac,80MHz ,1
ENG253188-ENG258678-display_manager_configuration-abt_display_type,3 ,4
ENG253188-ENG259576-display_manager_configuration-driver_display_type,1 ,4
ENG253188-ENG260129-display_manager_configuration-hud_display_type,0 ,4
ENG248427-ENG248668-exit_screen_configuration-exit_screen,activated ,2
ENG248427-ENG248669-exit_screen_configuration-exit_screen_length_of_time,0 ms,2
ENG387324-ENG387512-function_car_configuration_extended_1-ai_assistant,Not available ,4
ENG387324-ENG387570-function_car_configuration_extended_1-face_id,Not available ,4
ENG387324-ENG387600-function_car_configuration_extended_1-interior_camera_support,Not available ,4
ENG387324-ENG413947-function_car_configuration_extended_1-Internal_camera_position,MIK ,4
ENG344839-ENG345285-function_car_configuration_extended_2-ar_navigator,Not available ,4
ENG344839-ENG345312-function_car_configuration_extended_2-cdi,no_cdi ,4
ENG344839-ENG345645-function_car_configuration_extended_2-dvr,not_install ,4
ENG253218-ENG260862-function_configuration_a2b_topology-a2b_topology,Infotainment_Unit_with_external_mic ,5
ENG253218-ENG253474-function_configuration_a2b_topology-connectivity_unit,present ,5
ENG253218-ENG331821-function_configuration_a2b_topology-External_sound_system,present ,5
ENG253218-ENG259051-function_configuration_a2b_topology-Infotainment_Mic_Unit,Not_present ,5
ENG253218-ENG253475-function_configuration_a2b_topology-infotainment_unit,present ,5
ENG253218-ENG302728-function_configuration_a2b_topology-InnenSound_Unit,Not_present ,5
ENG253218-ENG258377-function_configuration_a2b_topology-MIC_MOD_rear_L,Not_present ,5
ENG253218-ENG259527-function_configuration_a2b_topology-MIC_MOD_rear_R,Not_present ,5
ENG253218-ENG258583-function_configuration_a2b_topology-Mic_Module_Display,Not_present ,5
ENG253218-ENG258542-function_configuration_a2b_topology-Mic_Module_Roof,present ,5
ENG369141-Function_configuration_app_connect,OFF ,1
ENG253272-IDE02702-function_configuration_ar_creator-Voice Control,Not available ,6
ENG253272-IDE04172-function_configuration_ar_creator-Start screen,Not available ,6
ENG253272-IDE09602-function_configuration_ar_creator-Locale hazard warning,Not available ,6
ENG253272-IDE12353-function_configuration_ar_creator-Configuration of traffic light online functions,Not available ,6
ENG253272-MAS00506-function_configuration_ar_creator-Adaptive Cruise Control,Automatic distance regulation ,6
ENG253272-MAS01102-function_configuration_ar_creator-Cruise control system,Not available ,6
ENG253272-MAS01799-function_configuration_ar_creator-Navigation,Available ,6
ENG253272-MAS01891-function_configuration_ar_creator-Lane assist,Available ,6
ENG253272-MAS01938-function_configuration_ar_creator-Road sign detection,Available ,6
ENG253272-MAS03690-function_configuration_ar_creator-Telephone,Not available ,6
ENG253272-MAS04408-function_configuration_ar_creator-Personalization,Not available ,6
ENG253272-MAS05734-function_configuration_ar_creator-Reducing stopping distance: install.,Available ,6
ENG253272-MAS08228-function_configuration_ar_creator-Light sensor,RLS_boost ,6
ENG253272-MAS08940-function_configuration_ar_creator-Collision warning,Available ,6
ENG253272-MAS10719-function_configuration_ar_creator-Efficiency assist.,Not available ,6
ENG253272-MAS10720-function_configuration_ar_creator-Speed limiter,Not available ,6
ENG253272-ENG259818-function_configuration_ar_creator-Bev_display,Not available ,6
ENG253272-ENG260132-function_configuration_ar_creator-Curve_warning,Not available ,6
ENG253272-ENG259483-function_configuration_ar_creator-Media_list,Not available ,6
ENG253272-ENG261017-function_configuration_ar_creator-Range_management,Not available ,6
ENG253272-ENG259697-function_configuration_ar_creator-Short_message_service,Not available ,6
ENG253272-ENG259873-function_configuration_ar_creator-tiredness_detection,Not available ,6
ENG253272-ENG260995-function_configuration_ar_creator-Trafific_jam_warning,Not available ,6
ENG253272-ENG259489-function_configuration_ar_creator-Trained_parking,Not available ,6
ENG253272-ENG247282-function_configuration_ar_creator-Travel_Assist,Available ,6
ENG253272-ENG259341-function_configuration_ar_creator-Wether_info,Not available ,6
ENG248428-ENG248528-function_configuration_audio-channel_1_HT,not installed ,10
ENG248428-ENG248530-function_configuration_audio-channel_1_TT,not installed ,10
ENG248428-ENG248532-function_configuration_audio-channel_10_HT,not installed ,10
ENG248428-ENG248534-function_configuration_audio-channel_10_TT,not installed ,10
ENG248428-ENG248536-function_configuration_audio-channel_11_HT,not installed ,10
ENG248428-ENG248538-function_configuration_audio-channel_11_TT,not installed ,10
ENG248428-ENG248540-function_configuration_audio-channel_12_HT,not installed ,10
ENG248428-ENG248542-function_configuration_audio-channel_12_TT,not installed ,10
ENG248428-ENG248544-function_configuration_audio-channel_13_HT,not installed ,10
ENG248428-ENG248546-function_configuration_audio-channel_13_TT,not installed ,10
ENG248428-ENG248548-function_configuration_audio-channel_14_HT,not installed ,10
ENG248428-ENG248550-function_configuration_audio-channel_14_TT,not installed ,10
ENG248428-ENG248552-function_configuration_audio-channel_15_HT,not installed ,10
ENG248428-ENG248554-function_configuration_audio-channel_15_TT,not installed ,10
ENG248428-ENG248556-function_configuration_audio-channel_16_HT,not installed ,10
ENG248428-ENG248558-function_configuration_audio-channel_16_TT,not installed ,10
ENG248428-ENG248560-function_configuration_audio-channel_17_HT,not installed ,10
ENG248428-ENG248562-function_configuration_audio-channel_17_TT,not installed ,10
ENG248428-ENG248564-function_configuration_audio-channel_18_HT,not installed ,10
ENG248428-ENG248566-function_configuration_audio-channel_18_TT,not installed ,10
ENG248428-ENG248568-function_configuration_audio-channel_19_HT,not installed ,10
ENG248428-ENG248571-function_configuration_audio-channel_19TT,not installed ,10
ENG248428-ENG248572-function_configuration_audio-channel_2_HT,not installed ,10
ENG248428-ENG248574-function_configuration_audio-channel_2_TT,not installed ,10
ENG248428-ENG248576-function_configuration_audio-channel_20_HT,not installed ,10
ENG248428-ENG248578-function_configuration_audio-channel_20_TT,not installed ,10
ENG248428-ENG248580-function_configuration_audio-channel_21_HT,not installed ,10
ENG248428-ENG248582-function_configuration_audio-channel_21_TT,not installed ,10
ENG248428-ENG248584-function_configuration_audio-channel_22_HT,not installed ,10
ENG248428-ENG248586-function_configuration_audio-channel_22_TT,not installed ,10
ENG248428-ENG248588-function_configuration_audio-channel_23_HT,not installed ,10
ENG248428-ENG248590-function_configuration_audio-channel_23_TT,not installed ,10
ENG248428-ENG248592-function_configuration_audio-channel_24_HT,not installed ,10
ENG248428-ENG248594-function_configuration_audio-channel_24_TT,not installed ,10
ENG248428-ENG248596-function_configuration_audio-channel_25_HT,not installed ,10
ENG248428-ENG248597-function_configuration_audio-channel_25_TT,not installed ,10
ENG248428-ENG248598-function_configuration_audio-channel_3_HT,not installed ,10
ENG248428-ENG248600-function_configuration_audio-channel_3_TT,not installed ,10
ENG248428-ENG248602-function_configuration_audio-channel_4_HT,not installed ,10
ENG248428-ENG248604-function_configuration_audio-channel_4_TT,not installed ,10
ENG248428-ENG248606-function_configuration_audio-channel_5_HT,not installed ,10
ENG248428-ENG248608-function_configuration_audio-channel_5_TT,not installed ,10
ENG248428-ENG248610-function_configuration_audio-channel_6_HT,not installed ,10
ENG248428-ENG248612-function_configuration_audio-channel_6_TT,not installed ,10
ENG248428-ENG248614-function_configuration_audio-channel_7_HT,not installed ,10
ENG248428-ENG248616-function_configuration_audio-channel_7_TT,not installed ,10
ENG248428-ENG248618-function_configuration_audio-channel_8_HT,not installed ,10
ENG248428-ENG248620-function_configuration_audio-channel_8_TT,not installed ,10
ENG248428-ENG248622-function_configuration_audio-channel_9_HT,not installed ,10
ENG248428-ENG248624-function_configuration_audio-channel_9_TT,not installed ,10
ENG248428-ENG248653-function_configuration_audio-Early_engine_sound,OFF ,10
ENG248428-ENG248491-function_configuration_audio-microphone_1,installed ,10
ENG248428-ENG248492-function_configuration_audio-microphone_2,not installed ,10
ENG248428-ENG248763-function_configuration_audio-microphone_3,not installed ,10
ENG248428-ENG248764-function_configuration_audio-microphone_4,not installed ,10
ENG248428-ENG252056-function_configuration_audio-microphones_ANC,not installed ,10
ENG248428-ENG248818-function_configuration_audio-Signal_flow_topology,00 ,10
ENG248428-ENG248483-function_configuration_audio-Sound_system,external_ethernet ,10
ENG248428-ENG248830-function_configuration_audio-welcome_sound,On ,10
ENG248430-ENG248504-function_configuration_connectivity-app_connect_over_wifi,No ,6
ENG248430-ENG248506-function_configuration_connectivity-apple_car_play,On ,6
ENG248430-ENG152525-function_configuration_connectivity-Baidu_Car_Life,OFF ,6
ENG248430-ENG152559-function_configuration_connectivity-Baidu_Car_Life_ios,OFF ,6
ENG248430-ENG248518-function_configuration_connectivity-Bluetooth_Audio,Not available ,6
ENG248430-ENG248519-function_configuration_connectivity-Bluetooth_Availability,available_without_low_energy ,6
ENG248430-ENG248520-function_configuration_connectivity-Bluetooth_Headphones,Not available ,6
ENG248430-ENG248521-function_configuration_connectivity-Bluetooth_Multimedia_Functionality,Not available ,6
ENG248430-ENG248522-function_configuration_connectivity-Bluetooth_Phone,Not available ,6
ENG248430-ENG405710-function_configuration_connectivity-Bluetooth_secure_transport_on_ethernet,OFF ,6
ENG248430-ENG183597-function_configuration_connectivity-Bluetooth_visibility,On ,6
ENG248430-ENG248525-function_configuration_connectivity-calendar_via_ctn,OFF ,6
ENG248430-ENG369265-function_configuration_connectivity-Conbox_encrytion,not installed ,6
ENG248430-ENG248672-function_configuration_connectivity-external_wlan_antenna,none ,6
ENG248430-ENG248693-function_configuration_connectivity-google_android_auto,On ,6
ENG248430-ENG248761-function_configuration_connectivity-messaging_pagewise_scrolling,not installed ,6
ENG248430-ENG248762-function_configuration_connectivity-messaging_via_map,installed ,6
ENG248430-ENG138662-function_configuration_connectivity-Mirror_link,OFF ,6
ENG248430-ENG248766-function_configuration_connectivity-mirror_link_country_code,EU ,6
ENG248430-ENG142150-function_configuration_connectivity-MirrorLink_RGB_Preference,RGB565 ,6
ENG248430-ENG127495-function_configuration_connectivity-online_media,OFF ,6
ENG248430-ENG248826-function_configuration_connectivity-viwi_access_mode,no_restriction ,6
ENG248430-ENG248827-function_configuration_connectivity-viwi_function,not installed ,6
ENG248430-ENG252048-function_configuration_connectivity-welink,OFF ,6
ENG248430-ENG248831-function_configuration_connectivity-wifi_client_mode_2_GHz,OFF ,6
ENG248430-ENG248832-function_configuration_connectivity-wifi_client_mode_5GHz,OFF ,6
ENG248430-ENG248833-function_configuration_connectivity-WIFI_Hotspot_2_4GHz,On ,6
ENG248430-ENG248834-function_configuration_connectivity-WIFI_Hotspot_5GHz,On ,6
ENG248430-ENG248835-function_configuration_connectivity-wlan_aps_to_ccu_routing,On ,6
ENG248430-ENG248836-function_configuration_connectivity-wlan_module,not activated ,6
ENG248430-ENG248837-function_configuration_connectivity-wlan_tethering_connection_check_via_disgnosis,On ,6
ENG248431-ENG405716-function_configuration_hmi-Google_search_default,On ,5
ENG248431-ENG248699-function_configuration_hmi-helpcontext_0,OFF ,5
ENG248431-ENG248700-function_configuration_hmi-helpcontext_1,OFF ,5
ENG248431-ENG248701-function_configuration_hmi-helpcontext_2,OFF ,5
ENG248431-ENG248702-function_configuration_hmi-helpcontext_3,OFF ,5
ENG248431-ENG248703-function_configuration_hmi-helpcontext_4,OFF ,5
ENG248431-ENG248704-function_configuration_hmi-helpcontext_5,OFF ,5
ENG248431-ENG248705-function_configuration_hmi-helpcontext_6,OFF ,5
ENG248431-ENG248706-function_configuration_hmi-helpcontext_7,OFF ,5
ENG248431-ENG248707-function_configuration_hmi-helpcontext_8,OFF ,5
ENG248431-ENG248708-function_configuration_hmi-helpcontext_9,OFF ,5
ENG248431-ENG248709-function_configuration_hmi-hmi_initial_disclaimer,OFF ,5
ENG248431-ENG248710-function_configuration_hmi-hmi_legal_disclaimer,OFF ,5
ENG248431-ENG248725-function_configuration_hmi-log_book,not_displayed ,5
ENG248431-ENG369611-function_configuration_hmi-Nav_showing,activated ,5
ENG248431-ENG167525-function_configuration_hmi-Popup_if_GPS_services_in_use,OFF ,5
ENG248431-ENG248811-function_configuration_hmi-screenings,0 ,5
ENG248431-ENG405754-function_configuration_hmi-Show_google_search_default,On ,5
ENG248431-ENG248479-function_configuration_hmi-Skinning,1 ,5
ENG248431-ENG248821-function_configuration_hmi-speller,OFF ,5
ENG248431-ENG332397-function_configuration_hmi-Twin_Wheel,Deactivated ,5
ENG248432-ENG248505-function_configuration_media-app_start_automatically_on_customer_device,OFF ,3
ENG248432-ENG248481-function_configuration_media-aux_in,OFF ,3
ENG248432-ENG248671-function_configuration_media-external_cd_drive,OFF ,3
ENG248432-ENG249899-function_configuration_media-external_tv_tuner,OFF ,3
ENG248432-ENG117850-function_configuration_media-gracenote_local_coverarts,OFF ,3
ENG248432-ENG117851-function_configuration_media-gracenote_local_other,OFF ,3
ENG248432-ENG117848-function_configuration_media-gracenote_online_coverarts,OFF ,3
ENG248432-ENG117849-function_configuration_media-gracenote_online_other,OFF ,3
ENG248432-ENG248713-function_configuration_media-Import_Media_Data,not activated ,3
ENG248432-ENG248769-function_configuration_media-online_media_services,OFF ,3
ENG248432-ENG248770-function_configuration_media-online_tv,OFF ,3
ENG248432-ENG248794-function_configuration_media-picture_viewer,OFF ,3
ENG248432-ENG248804-function_configuration_media-Ripping_Media_Data,not activated ,3
ENG248432-ENG248482-function_configuration_media-USB,usb_ipod ,3
ENG248433-ENG117847-function_configuration_navigation-advanced_range_display,On ,4
ENG248433-ENG173863-function_configuration_navigation-Country_Navigation,NAR ,4
ENG248433-ENG248692-function_configuration_navigation-gnns_antenna_Availability,not activated ,4
ENG248433-ENG127492-function_configuration_navigation-LGI,OFF ,4
ENG248433-ENG142152-function_configuration_navigation-Map_Style,0 ,4
ENG248433-ENG248488-function_configuration_navigation-Navigation_system,activated ,4
ENG248433-ENG103811-function_configuration_navigation-PSD,activated ,4
ENG248433-ENG126994-function_configuration_navigation-TPEG_availability,OFF ,4
ENG248433-ENG248824-function_configuration_navigation-ttraffic_information,On ,4
ENG248433-ENG248828-function_configuration_navigation-vza,not activated ,4
ENG248433-ENG127494-function_configuration_navigation-VZO,On ,4
ENG248434-ENG142146-function_configuration_phone-allow_message_editing,On ,3
ENG248434-ENG125043-function_configuration_phone-Dtmf_without_active_call,OFF ,3
ENG248434-ENG248715-function_configuration_phone-interlink_box_antenna,not installed ,3
ENG248434-ENG345754-function_configuration_phone-interlink_box_CAN,activated ,3
ENG248434-ENG248716-function_configuration_phone-interlink_box_nfc,not installed ,3
ENG248434-ENG248717-function_configuration_phone-interlink_box_pwm,not installed ,3
ENG248434-ENG248718-function_configuration_phone-interlink_box_wireless_charging,installed ,3
ENG248434-ENG142142-function_configuration_phone-map_email_support,On ,3
ENG248434-ENG142143-function_configuration_phone-map_instant_messaging_support,OFF ,3
ENG248434-ENG142141-function_configuration_phone-map_sms_support,On ,3
ENG248434-ENG125044-function_configuration_phone-Support_for_response_and_hold,OFF ,3
ENG248434-ENG125042-function_configuration_phone-Support_of_threeway_calling,OFF ,3
ENG248434-ENG130247-function_configuration_phone-Support_second_phone,none ,3
ENG248434-ENG248825-function_configuration_phone-user_menu_three_way_calling,On ,3
ENG248435-ENG251555-function_configuration_pso-iaa_function,Deactivated ,2
ENG248435-ENG297696-function_configuration_pso-iaa_function_new,activated ,2
ENG248435-ENG248795-function_configuration_pso-pso_function,activated ,2
ENG248436-ENG248497-function_configuration_radio-AF,persistent ,8
ENG248436-ENG248498-function_configuration_radio-af_hmi_switch_default_value,On ,8
ENG248436-ENG248500-function_configuration_radio-AM_disable,activated ,8
ENG248436-ENG248501-function_configuration_radio-am_fm_dab_antenna,not activated ,8
ENG248436-ENG248502-function_configuration_radio-am_hd_hmi_switch_default_value,activated ,8
ENG248436-ENG248508-function_configuration_radio-band_settings_am_tuner,NAR ,8
ENG248436-ENG248509-function_configuration_radio-band_settings_dab_tuner_band_1,OFF ,8
ENG248436-ENG248510-function_configuration_radio-band_settings_fm_tuner,NAR ,8
ENG248436-ENG248633-function_configuration_radio-DAB_Alarm_Announcement,not activated ,8
ENG248436-ENG248634-function_configuration_radio-dab_mode_antenna_mode_1,not activated ,8
ENG248436-ENG248641-function_configuration_radio-drm_plus_fm,Deactivated ,8
ENG248436-ENG248642-function_configuration_radio-drm30_mf,Deactivated ,8
ENG248436-ENG248683-function_configuration_radio-FM_Antenna,Available ,8
ENG248436-ENG248684-function_configuration_radio-fm_hd_hmi_switch_default_value,activated ,8
ENG248436-ENG248685-function_configuration_radio-FM_PTY31_Alarm,OFF ,8
ENG248436-ENG248686-function_configuration_radio-fm_radio_profiles,not_valid ,8
ENG248436-ENG248697-function_configuration_radio-HD_FM_Antenna_Mode,MRC ,8
ENG248436-ENG152533-function_configuration_radio-Hybrid_Radio_additional_online_data,Deactivated ,8
ENG248436-ENG152534-function_configuration_radio-Hybrid_Radio_Range_Extender,Deactivated ,8
ENG248436-ENG248767-function_configuration_radio-multiple_entry_switch,On ,8
ENG248436-ENG152553-function_configuration_radio-online_radio,native_hmi_only ,8
ENG248436-ENG248793-function_configuration_radio-PI_ignore,On ,8
ENG248436-ENG286264-function_configuration_radio-PTy switch default value,OFF ,8
ENG248436-ENG286265-function_configuration_radio-PTy_switch_visibility,OFF ,8
ENG248436-ENG248797-function_configuration_radio-Radio_Text_Plus,not activated ,8
ENG248436-ENG248798-function_configuration_radio-rds_hmi_switch_default_value,On ,8
ENG248436-ENG248799-function_configuration_radio-rds_hmi_switch_visibility,OFF ,8
ENG248436-ENG248812-function_configuration_radio-SDARS_band_activation,activated ,8
ENG248436-ENG249938-function_configuration_radio-SDARS_type,SAT_and_IP ,8
ENG248436-ENG126993-function_configuration_radio-Station_Logo_DB_Mode,0 ,8
ENG248438-ENG248523-function_configuration_sound-brand_sound,harman_kardon ,1
ENG248438-ENG142149-function_configuration_sound-vehicle_leaving_sound,not activated ,1
ENG248438-ENG142147-function_configuration_sound-vehicle_readiness_sound,not activated ,1
ENG248440-function_configuration_swap_fod,swap_active_fod_not_active ,1
ENG263481-ENG288945-function_configuration_unit_extended-AliOS,Deactivated ,2
ENG263481-ENG263516-function_configuration_unit_extended-android_navigation,activated ,2
ENG263481-ENG369207-function_configuration_unit_extended-Bentley_rotating_display,Deactivated ,2
ENG248442-geocoordinate_create,create ,1
ENG248443-geocoordinate_show,Show ,1
ENG297656-ENG297687-HMI_Display_Of_Online_Functionality-HMI_ID_0_OutOfData_Notification,not activated ,5
ENG297656-ENG297688-HMI_Display_Of_Online_Functionality-HMI_ID_1_SoonOutOfData_Notifcation,not activated ,5
ENG297656-ENG297689-HMI_Display_Of_Online_Functionality-HMI_ID_2_ModemStandby_Notification,not activated ,5
ENG297656-ENG297690-HMI_Display_Of_Online_Functionality-HMI_ID_3_OCU_NoConnection_Notification,activated ,5
ENG297656-ENG297691-HMI_Display_Of_Online_Functionality-HMI_ID_4_OCU_Searching_Notification,activated ,5
ENG297656-ENG297692-HMI_Display_Of_Online_Functionality-HMI_ID_5_NoApn2Config_Notification,not activated ,5
ENG297656-ENG297693-HMI_Display_Of_Online_Functionality-HMI_ID_6_NoConnection2WLANAP_Notification,not activated ,5
ENG297656-ENG297694-HMI_Display_Of_Online_Functionality-HMI_ID_7_NoInternetViaWLAN_Notification,not activated ,5
ENG297656-ENG297695-HMI_Display_Of_Online_Functionality-HMI_ID_81_OutOfRegion_Notification,not activated ,5
ENG297656-ENG297718-HMI_Display_Of_Online_Functionality-Menu_System_Setup_Online_Service,not activated ,5
ENG297656-ENG297720-HMI_Display_Of_Online_Functionality-Popup_Confirm_B2C_Switch,not activated ,5
ENG248456-ENG248814-ipv4_address_of_the_wlan_ap-segment_1,10 ,4
ENG248456-ENG248815-ipv4_address_of_the_wlan_ap-segment_2,173 ,4
ENG248456-ENG248816-ipv4_address_of_the_wlan_ap-segment_3,189 ,4
ENG248456-ENG248817-ipv4_address_of_the_wlan_ap-segment_4,1 ,4
ENG248465-ENG248814-ipv6_address_of_the_wlan_ap-segment_1,FD 30 ,8
ENG248465-ENG248815-ipv6_address_of_the_wlan_ap-segment_2,E0 8E ,8
ENG248465-ENG248816-ipv6_address_of_the_wlan_ap-segment_3,C0 31 ,8
ENG248465-ENG248817-ipv6_address_of_the_wlan_ap-segment_4,01 03 ,8
ENG152375-ENG152428-Logging_Configuration-Interface,00 ,3
ENG152375-ENG152494-Logging_Configuration-loglevel,00 ,3
ENG152375-ENG98732-Logging_Configuration-Memory,00 ,3
ENG278389-Market_and_brand_specific_preInstSet_of_webapps,preinstallation_set_2 ,1
ENG253286-mfl_configuration,1 ,4
ENG309780-Minimal_headless_Nav_Ready4ISA,Deactivated ,2
ENG253054-my_car,00 00 ,2
ENG167428-ENG167512-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_text_input,activated ,5
ENG167428-ENG167518-nhtsa_properties-nhtsa_limitation_switches_for_carplay_no_softKeyboard,activated ,5
ENG297659-nominal_range_display,0 ,2
ENG248467-number_to_name_matching_algorithm,detect_numbers ,1
ENG281052-Online_backend_switch,Live ,1
ENG273498-parkingsystem_video_input,1920x1080 ,3
ENG252007-ENG278524-Privacy_mode-privacy_flightmode,not activated ,2
ENG252007-ENG278539-Privacy_mode-privacy_online_markets,activated ,2
ENG252007-ENG252075-Privacy_mode-supress_privacy_mode,activated ,2
ENG252007-ENG98976-Privacy_mode-Timeout,not_active ,2
ENG248469-same_ssid_for_2_4_and_5_ghz,Yes ,1
ENG248470-sortorder,sortorder_4 ,1
ENG117919-Startup_Screen_Sticker_HMI,00 03 ,2
ENG253000-ENG260972-thresholds-quality_threshold_ACC,70 %,6
ENG253000-ENG258287-thresholds-quality_threshold_FA,70 %,6
ENG253000-ENG258942-thresholds-quality_threshold_LA,70 %,6
ENG253000-ENG260279-thresholds-quality_threshold_maneuver,0 %,6
ENG253000-ENG259171-thresholds-quality_threshold_TA,70 %,6
ENG253000-ENG260795-thresholds-quality_threshold_Welcome,70 %,6
ENG244949-ENG248626-wlan_channel_numbers-channel_number_for_2_4GHz,6 ,1
ENG244949-ENG248627-wlan_channel_numbers-channel_number_for_5GHz,1 ,1
ENG253384-WLAN_Country_Code,DE ,2
Elapsed Time: 01:08
adpmap-8128-1T3-919-451-G_WVG5WVEB2SH017765-20250325-1242.CSV
;SW:1T3-919-451-G   HW:1T3-919-451-G ---  Light line display
;Component:ID_Light_GA   033 0074, Coding:
;EV_SmartLight1MEBGA,001014,EV_SmartLight1MEBGA.rod
;Tuesday,25,March,2025,12:42:28:58926
;VCDS Version: Release 25.3.0 (x64)  Data version: 20250311 DS365.0
;VCID: 3C2A5AE626E5C50A93E-8068-R SFD+SFD2
IDE00001-MAS21342-Production mode-LED band: activation via real-time and film interface,not active ,3
IDE00001-MAS21343-Production mode-LED band: activation via internal effects,not active ,3
IDE07159-MAS01155-Control module switch-off: counter-Control module,0 ,2
IDE07159-MAS05583-Control module switch-off: counter-Data bus,1 ,2
IDE07160-IDE15110-Control module switch-off: switch-off time-Coupling shut-off time: data bus with low-voltage energy management,Low-voltage energy management: coupling not available ,2
IDE07160-MAS00478-Control module switch-off: switch-off time-Reserved,0 ,2
IDE07160-MAS01155-Control module switch-off: switch-off time-Control module,15 min ,2
IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,15 min ,2
IDE07160-ENG99458-Control module switch-off: switch-off time-Reserved_2,0 ,2
ENG253378-Dev_Brightness_adjustment,activated ,1
ENG253381-ENG289223-Dev_Movie_configuration-Checksum_comparison_animationdata_active,activated ,2
ENG253381-ENG260153-Dev_Movie_configuration-Early_effect_lock_active,activated ,2
ENG253381-ENG261063-Dev_Movie_configuration-Early_effect_safe_lock_active,activated ,2
ENG253381-ENG261261-Dev_Movie_configuration-Early_effect_shut_off_variant_fade_out_active,not activated ,2
ENG253381-ENG258856-Dev_Movie_configuration-Early_effect_unlock_active,activated ,2
ENG253381-ENG258394-Dev_Movie_configuration-Effect_missing_movie_bundle_active,activated ,2
ENG253381-ENG289227-Dev_Movie_configuration-Eventmemory_incorrect_checksum_movie_bundle_active,activated ,2
ENG253381-ENG289228-Dev_Movie_configuration-Eventmemory_missing_movie_bundle_active,not activated ,2
ENG253381-ENG289232-Dev_Movie_configuration-Movieinterface_active,activated ,2
ENG253381-ENG289233-Dev_Movie_configuration-Realtimeinterface_active,activated ,2
ENG277054-Dev_Vehicle_configuration,not activated ,1
ENG153885-MAS00478-Knockout_test_mode-Reserved,0 ,1
ENG153885-MAS21993-Knockout_test_mode-Return value idle bus,not active ,1
ENG153885-MAS21994-Knockout_test_mode-Veto,not active ,1
ENG153885-MAS21995-Knockout_test_mode-Suppress veto,not active ,1
ENG253067-ENG258139-Par_Movie_configuration-Abschaltzeit_Animation_nach_Busruhe,124 s,35
ENG253067-ENG258955-Par_Movie_configuration-Color_effect_missing_movie_bundle,1258502607 ,35
ENG253067-ENG259589-Par_Movie_configuration-Fade_out_time,5 ms,35
ENG253067-ENG309831-Par_Movie_configuration-Maximum_playtime_early_effects,6.0 s,35
ENG253067-ENG261061-Par_Movie_configuration-Memory_slot_early_effect_lock,3 ,35
ENG253067-ENG258301-Par_Movie_configuration-Memory_slot_early_effect_reserve_1,4 ,35
ENG253067-ENG260818-Par_Movie_configuration-Memory_slot_early_effect_reserve_10,15 ,35
ENG253067-ENG260135-Par_Movie_configuration-Memory_slot_early_effect_reserve_11,16 ,35
ENG253067-ENG259754-Par_Movie_configuration-Memory_slot_early_effect_reserve_2,7 ,35
ENG253067-ENG259857-Par_Movie_configuration-Memory_slot_early_effect_reserve_3,8 ,35
ENG253067-ENG259952-Par_Movie_configuration-Memory_slot_early_effect_reserve_4,9 ,35
ENG253067-ENG258764-Par_Movie_configuration-Memory_slot_early_effect_reserve_5,10 ,35
ENG253067-ENG259628-Par_Movie_configuration-Memory_slot_early_effect_reserve_6,11 ,35
ENG253067-ENG261355-Par_Movie_configuration-Memory_slot_early_effect_reserve_7,12 ,35
ENG253067-ENG258963-Par_Movie_configuration-Memory_slot_early_effect_reserve_8,13 ,35
ENG253067-ENG260522-Par_Movie_configuration-Memory_slot_early_effect_reserve_9,14 ,35
ENG253067-ENG258158-Par_Movie_configuration-Memory_slot_early_effect_safe_lock,2 ,35
ENG253067-ENG258570-Par_Movie_configuration-Memory_slot_early_effect_unlock,1 ,35
ENG253067-ENG260094-Par_Movie_configuration-Memory_slot_showroom_modus_variant_1,5 ,35
ENG253067-ENG258161-Par_Movie_configuration-Memory_slot_showroom_modus_variant_2,6 ,35
ENG253067-ENG259562-Par_Movie_configuration-Pixel_selection_effect_missing_movie_bundle,03 00 00 00 00 00 00 03 00 00 ,35
ENG253067-ENG289234-Par_Movie_configuration-Time_delay_early_effects,0.00 s,35
ENG253067-ENG289235-Par_Movie_configuration-Time_fallback_idle_from_saving,2.5 s,35
ENG253370-ENG260460-Par_Vehicle_configuration-Orientation_central_position_to_led_strip,28 ,3
ENG253370-ENG259777-Par_Vehicle_configuration-Orientation_left_passenger_to_led_strip,10 ,3
ENG253370-ENG258121-Par_Vehicle_configuration-Orientation_right_passenger_to_led_strip,48 ,3
Elapsed Time: 00:05
adpmap-C002-V04-007-003-LG_WVG5WVEB2SH017765-20250325-1243.CSV
;SW:V04-007-003-LG   HW: ---  SW Cluster Embedded
;Component:ICAS1 SWCL_Em 0254, Coding:
;EV_SWCLEmbed1ICAS1UNECE,001002,EV_SWCLEmbed1ICAS1UNECE_VWE3.rod
;Tuesday,25,March,2025,12:43:08:58926
;VCID: 77A085CA5F432652BEC-8022-R SFD+SFD2
IDE00001-MAS10848-Production mode-Deactivate left-/right hand driving switch-over,Deactivating ,3
IDE00001-ENG260572-Production mode-P-Mode_OBD,Deactivating ,3
IDE00820-ENG259915-Activating and deactivating all development messages-BAP-Debug_Cmd_CAN-Messages,not active ,3
IDE00820-ENG144693-Activating and deactivating all development messages-Distance,not active ,3
IDE00820-ENG278544-Activating and deactivating all development messages-DLI,not active ,3
IDE00820-ENG369287-Activating and deactivating all development messages-DRE,not active ,3
IDE00820-ENG278449-Activating and deactivating all development messages-HVLM_ECP,not active ,3
IDE00820-ENG369582-Activating and deactivating all development messages-IAA_Function Master,not active ,3
IDE00820-ENG369583-Activating and deactivating all development messages-IAA_PSO_BAP Proxy,not active ,3
IDE00820-ENG261094-Activating and deactivating all development messages-SOK-FM,not active ,3
IDE00820-ENG278458-Activating and deactivating all development messages-STK,not active ,3
IDE00820-ENG278477-Activating and deactivating all development messages-SWCL Embedded,not active ,3
IDE00820-ENG253467-Activating and deactivating all development messages-VKMS,not active ,3
IDE03641-Presentation run dynamic AFS light,not active ,1
IDE08418-Matrix light: total dimming,100.8 %,1
IDE09568-MAS09833-Bit pattern of individual segment activation: left headlight-LED 1,OFF ,13
IDE09568-MAS09834-Bit pattern of individual segment activation: left headlight-LED 2,OFF ,13
IDE09568-MAS09835-Bit pattern of individual segment activation: left headlight-LED 3,OFF ,13
IDE09568-MAS09836-Bit pattern of individual segment activation: left headlight-LED 4,OFF ,13
IDE09568-MAS09837-Bit pattern of individual segment activation: left headlight-LED 5,OFF ,13
IDE09568-MAS09838-Bit pattern of individual segment activation: left headlight-LED 6,OFF ,13
IDE09568-MAS09839-Bit pattern of individual segment activation: left headlight-LED 7,OFF ,13
IDE09568-MAS09840-Bit pattern of individual segment activation: left headlight-LED 8,OFF ,13
IDE09568-MAS09841-Bit pattern of individual segment activation: left headlight-LED 9,OFF ,13
IDE09568-MAS09842-Bit pattern of individual segment activation: left headlight-LED 10,OFF ,13
IDE09568-MAS09843-Bit pattern of individual segment activation: left headlight-LED 11,OFF ,13
IDE09568-MAS09844-Bit pattern of individual segment activation: left headlight-LED 12,OFF ,13
IDE09568-MAS09845-Bit pattern of individual segment activation: left headlight-LED 13,OFF ,13
IDE09568-MAS09846-Bit pattern of individual segment activation: left headlight-LED 14,OFF ,13
IDE09568-MAS09847-Bit pattern of individual segment activation: left headlight-LED 15,OFF ,13
IDE09568-MAS09848-Bit pattern of individual segment activation: left headlight-LED 16,OFF ,13
IDE09568-MAS09849-Bit pattern of individual segment activation: left headlight-LED 17,OFF ,13
IDE09568-MAS09850-Bit pattern of individual segment activation: left headlight-LED 18,OFF ,13
IDE09568-MAS09851-Bit pattern of individual segment activation: left headlight-LED 19,OFF ,13
IDE09568-MAS09852-Bit pattern of individual segment activation: left headlight-LED 20,OFF ,13
IDE09568-MAS09853-Bit pattern of individual segment activation: left headlight-LED 21,OFF ,13
IDE09568-MAS09854-Bit pattern of individual segment activation: left headlight-LED 22,OFF ,13
IDE09568-MAS09855-Bit pattern of individual segment activation: left headlight-LED 23,OFF ,13
IDE09568-MAS09856-Bit pattern of individual segment activation: left headlight-LED 24,OFF ,13
IDE09568-MAS09857-Bit pattern of individual segment activation: left headlight-LED 25,OFF ,13
IDE09568-MAS09858-Bit pattern of individual segment activation: left headlight-LED 26,OFF ,13
IDE09568-MAS09859-Bit pattern of individual segment activation: left headlight-LED 27,OFF ,13
IDE09568-MAS09860-Bit pattern of individual segment activation: left headlight-LED 28,OFF ,13
IDE09568-MAS09861-Bit pattern of individual segment activation: left headlight-LED 29,OFF ,13
IDE09568-MAS09862-Bit pattern of individual segment activation: left headlight-LED 30,OFF ,13
IDE09568-MAS09863-Bit pattern of individual segment activation: left headlight-LED 31,OFF ,13
IDE09568-MAS09864-Bit pattern of individual segment activation: left headlight-LED 32,OFF ,13
IDE09568-MAS09865-Bit pattern of individual segment activation: left headlight-LED 33,OFF ,13
IDE09568-MAS09866-Bit pattern of individual segment activation: left headlight-LED 34,OFF ,13
IDE09568-MAS09867-Bit pattern of individual segment activation: left headlight-LED 35,OFF ,13
IDE09568-MAS09868-Bit pattern of individual segment activation: left headlight-LED 36,OFF ,13
IDE09568-MAS09869-Bit pattern of individual segment activation: left headlight-LED 37,OFF ,13
IDE09568-MAS09870-Bit pattern of individual segment activation: left headlight-LED 38,OFF ,13
IDE09568-MAS09871-Bit pattern of individual segment activation: left headlight-LED 39,OFF ,13
IDE09568-MAS09872-Bit pattern of individual segment activation: left headlight-LED 40,OFF ,13
IDE09568-MAS09873-Bit pattern of individual segment activation: left headlight-LED 41,OFF ,13
IDE09568-MAS09874-Bit pattern of individual segment activation: left headlight-LED 42,OFF ,13
IDE09568-MAS09875-Bit pattern of individual segment activation: left headlight-LED 43,OFF ,13
IDE09568-MAS09876-Bit pattern of individual segment activation: left headlight-LED 44,OFF ,13
IDE09568-MAS09877-Bit pattern of individual segment activation: left headlight-LED 45,OFF ,13
IDE09568-MAS11516-Bit pattern of individual segment activation: left headlight-LED 46,OFF ,13
IDE09568-MAS11517-Bit pattern of individual segment activation: left headlight-LED 47,OFF ,13
IDE09568-MAS11518-Bit pattern of individual segment activation: left headlight-LED 48,OFF ,13
IDE09568-MAS11519-Bit pattern of individual segment activation: left headlight-LED 49,OFF ,13
IDE09568-MAS11520-Bit pattern of individual segment activation: left headlight-LED 50,OFF ,13
IDE09568-MAS11521-Bit pattern of individual segment activation: left headlight-LED 51,OFF ,13
IDE09568-MAS11522-Bit pattern of individual segment activation: left headlight-LED 52,OFF ,13
IDE09568-MAS11523-Bit pattern of individual segment activation: left headlight-LED 53,OFF ,13
IDE09568-MAS11524-Bit pattern of individual segment activation: left headlight-LED 54,OFF ,13
IDE09568-MAS11525-Bit pattern of individual segment activation: left headlight-LED 55,OFF ,13
IDE09568-MAS11526-Bit pattern of individual segment activation: left headlight-LED 56,OFF ,13
IDE09568-MAS11527-Bit pattern of individual segment activation: left headlight-LED 57,OFF ,13
IDE09568-MAS11528-Bit pattern of individual segment activation: left headlight-LED 58,OFF ,13
IDE09568-MAS11529-Bit pattern of individual segment activation: left headlight-LED 59,OFF ,13
IDE09568-MAS11530-Bit pattern of individual segment activation: left headlight-LED 60,OFF ,13
IDE09568-MAS11531-Bit pattern of individual segment activation: left headlight-LED 61,OFF ,13
IDE09568-MAS11532-Bit pattern of individual segment activation: left headlight-LED 62,OFF ,13
IDE09568-MAS11533-Bit pattern of individual segment activation: left headlight-LED 63,OFF ,13
IDE09568-MAS11534-Bit pattern of individual segment activation: left headlight-LED 64,OFF ,13
IDE09568-MAS11535-Bit pattern of individual segment activation: left headlight-LED 65,OFF ,13
IDE09568-MAS11536-Bit pattern of individual segment activation: left headlight-LED 66,OFF ,13
IDE09568-MAS11537-Bit pattern of individual segment activation: left headlight-LED 67,OFF ,13
IDE09568-MAS11538-Bit pattern of individual segment activation: left headlight-LED 68,OFF ,13
IDE09568-MAS11539-Bit pattern of individual segment activation: left headlight-LED 69,OFF ,13
IDE09568-MAS11540-Bit pattern of individual segment activation: left headlight-LED 70,OFF ,13
IDE09568-MAS11541-Bit pattern of individual segment activation: left headlight-LED 71,OFF ,13
IDE09568-MAS11542-Bit pattern of individual segment activation: left headlight-LED 72,OFF ,13
IDE09568-MAS11543-Bit pattern of individual segment activation: left headlight-LED 73,OFF ,13
IDE09568-MAS11544-Bit pattern of individual segment activation: left headlight-LED 74,OFF ,13
IDE09568-MAS11545-Bit pattern of individual segment activation: left headlight-LED 75,OFF ,13
IDE09568-MAS11546-Bit pattern of individual segment activation: left headlight-LED 76,OFF ,13
IDE09568-MAS11547-Bit pattern of individual segment activation: left headlight-LED 77,OFF ,13
IDE09568-MAS11548-Bit pattern of individual segment activation: left headlight-LED 78,OFF ,13
IDE09568-MAS11549-Bit pattern of individual segment activation: left headlight-LED 79,OFF ,13
IDE09568-MAS11550-Bit pattern of individual segment activation: left headlight-LED 80,OFF ,13
IDE09568-MAS11551-Bit pattern of individual segment activation: left headlight-LED 81,OFF ,13
IDE09568-MAS11552-Bit pattern of individual segment activation: left headlight-LED 82,OFF ,13
IDE09568-MAS11553-Bit pattern of individual segment activation: left headlight-LED 83,OFF ,13
IDE09568-MAS11554-Bit pattern of individual segment activation: left headlight-LED 84,OFF ,13
IDE09568-MAS11555-Bit pattern of individual segment activation: left headlight-LED 85,OFF ,13
IDE09568-MAS11556-Bit pattern of individual segment activation: left headlight-LED 86,OFF ,13
IDE09568-MAS11557-Bit pattern of individual segment activation: left headlight-LED 87,OFF ,13
IDE09568-MAS11558-Bit pattern of individual segment activation: left headlight-LED 88,OFF ,13
IDE09568-MAS11559-Bit pattern of individual segment activation: left headlight-LED 89,OFF ,13
IDE09568-MAS11560-Bit pattern of individual segment activation: left headlight-LED 90,OFF ,13
IDE09569-MAS09833-Bit pattern of individual segment activation: right headlight-LED 1,OFF ,13
IDE09569-MAS09834-Bit pattern of individual segment activation: right headlight-LED 2,OFF ,13
IDE09569-MAS09835-Bit pattern of individual segment activation: right headlight-LED 3,OFF ,13
IDE09569-MAS09836-Bit pattern of individual segment activation: right headlight-LED 4,OFF ,13
IDE09569-MAS09837-Bit pattern of individual segment activation: right headlight-LED 5,OFF ,13
IDE09569-MAS09838-Bit pattern of individual segment activation: right headlight-LED 6,OFF ,13
IDE09569-MAS09839-Bit pattern of individual segment activation: right headlight-LED 7,OFF ,13
IDE09569-MAS09840-Bit pattern of individual segment activation: right headlight-LED 8,OFF ,13
IDE09569-MAS09841-Bit pattern of individual segment activation: right headlight-LED 9,OFF ,13
IDE09569-MAS09842-Bit pattern of individual segment activation: right headlight-LED 10,OFF ,13
IDE09569-MAS09843-Bit pattern of individual segment activation: right headlight-LED 11,OFF ,13
IDE09569-MAS09844-Bit pattern of individual segment activation: right headlight-LED 12,OFF ,13
IDE09569-MAS09845-Bit pattern of individual segment activation: right headlight-LED 13,OFF ,13
IDE09569-MAS09846-Bit pattern of individual segment activation: right headlight-LED 14,OFF ,13
IDE09569-MAS09847-Bit pattern of individual segment activation: right headlight-LED 15,OFF ,13
IDE09569-MAS09848-Bit pattern of individual segment activation: right headlight-LED 16,OFF ,13
IDE09569-MAS09849-Bit pattern of individual segment activation: right headlight-LED 17,OFF ,13
IDE09569-MAS09850-Bit pattern of individual segment activation: right headlight-LED 18,OFF ,13
IDE09569-MAS09851-Bit pattern of individual segment activation: right headlight-LED 19,OFF ,13
IDE09569-MAS09852-Bit pattern of individual segment activation: right headlight-LED 20,OFF ,13
IDE09569-MAS09853-Bit pattern of individual segment activation: right headlight-LED 21,OFF ,13
IDE09569-MAS09854-Bit pattern of individual segment activation: right headlight-LED 22,OFF ,13
IDE09569-MAS09855-Bit pattern of individual segment activation: right headlight-LED 23,OFF ,13
IDE09569-MAS09856-Bit pattern of individual segment activation: right headlight-LED 24,OFF ,13
IDE09569-MAS09857-Bit pattern of individual segment activation: right headlight-LED 25,OFF ,13
IDE09569-MAS09858-Bit pattern of individual segment activation: right headlight-LED 26,OFF ,13
IDE09569-MAS09859-Bit pattern of individual segment activation: right headlight-LED 27,OFF ,13
IDE09569-MAS09860-Bit pattern of individual segment activation: right headlight-LED 28,OFF ,13
IDE09569-MAS09861-Bit pattern of individual segment activation: right headlight-LED 29,OFF ,13
IDE09569-MAS09862-Bit pattern of individual segment activation: right headlight-LED 30,OFF ,13
IDE09569-MAS09863-Bit pattern of individual segment activation: right headlight-LED 31,OFF ,13
IDE09569-MAS09864-Bit pattern of individual segment activation: right headlight-LED 32,OFF ,13
IDE09569-MAS09865-Bit pattern of individual segment activation: right headlight-LED 33,OFF ,13
IDE09569-MAS09866-Bit pattern of individual segment activation: right headlight-LED 34,OFF ,13
IDE09569-MAS09867-Bit pattern of individual segment activation: right headlight-LED 35,OFF ,13
IDE09569-MAS09868-Bit pattern of individual segment activation: right headlight-LED 36,OFF ,13
IDE09569-MAS09869-Bit pattern of individual segment activation: right headlight-LED 37,OFF ,13
IDE09569-MAS09870-Bit pattern of individual segment activation: right headlight-LED 38,OFF ,13
IDE09569-MAS09871-Bit pattern of individual segment activation: right headlight-LED 39,OFF ,13
IDE09569-MAS09872-Bit pattern of individual segment activation: right headlight-LED 40,OFF ,13
IDE09569-MAS09873-Bit pattern of individual segment activation: right headlight-LED 41,OFF ,13
IDE09569-MAS09874-Bit pattern of individual segment activation: right headlight-LED 42,OFF ,13
IDE09569-MAS09875-Bit pattern of individual segment activation: right headlight-LED 43,OFF ,13
IDE09569-MAS09876-Bit pattern of individual segment activation: right headlight-LED 44,OFF ,13
IDE09569-MAS09877-Bit pattern of individual segment activation: right headlight-LED 45,OFF ,13
IDE09569-MAS11516-Bit pattern of individual segment activation: right headlight-LED 46,OFF ,13
IDE09569-MAS11517-Bit pattern of individual segment activation: right headlight-LED 47,OFF ,13
IDE09569-MAS11518-Bit pattern of individual segment activation: right headlight-LED 48,OFF ,13
IDE09569-MAS11519-Bit pattern of individual segment activation: right headlight-LED 49,OFF ,13
IDE09569-MAS11520-Bit pattern of individual segment activation: right headlight-LED 50,OFF ,13
IDE09569-MAS11521-Bit pattern of individual segment activation: right headlight-LED 51,OFF ,13
IDE09569-MAS11522-Bit pattern of individual segment activation: right headlight-LED 52,OFF ,13
IDE09569-MAS11523-Bit pattern of individual segment activation: right headlight-LED 53,OFF ,13
IDE09569-MAS11524-Bit pattern of individual segment activation: right headlight-LED 54,OFF ,13
IDE09569-MAS11525-Bit pattern of individual segment activation: right headlight-LED 55,OFF ,13
IDE09569-MAS11526-Bit pattern of individual segment activation: right headlight-LED 56,OFF ,13
IDE09569-MAS11527-Bit pattern of individual segment activation: right headlight-LED 57,OFF ,13
IDE09569-MAS11528-Bit pattern of individual segment activation: right headlight-LED 58,OFF ,13
IDE09569-MAS11529-Bit pattern of individual segment activation: right headlight-LED 59,OFF ,13
IDE09569-MAS11530-Bit pattern of individual segment activation: right headlight-LED 60,OFF ,13
IDE09569-MAS11531-Bit pattern of individual segment activation: right headlight-LED 61,OFF ,13
IDE09569-MAS11532-Bit pattern of individual segment activation: right headlight-LED 62,OFF ,13
IDE09569-MAS11533-Bit pattern of individual segment activation: right headlight-LED 63,OFF ,13
IDE09569-MAS11534-Bit pattern of individual segment activation: right headlight-LED 64,OFF ,13
IDE09569-MAS11535-Bit pattern of individual segment activation: right headlight-LED 65,OFF ,13
IDE09569-MAS11536-Bit pattern of individual segment activation: right headlight-LED 66,OFF ,13
IDE09569-MAS11537-Bit pattern of individual segment activation: right headlight-LED 67,OFF ,13
IDE09569-MAS11538-Bit pattern of individual segment activation: right headlight-LED 68,OFF ,13
IDE09569-MAS11539-Bit pattern of individual segment activation: right headlight-LED 69,OFF ,13
IDE09569-MAS11540-Bit pattern of individual segment activation: right headlight-LED 70,OFF ,13
IDE09569-MAS11541-Bit pattern of individual segment activation: right headlight-LED 71,OFF ,13
IDE09569-MAS11542-Bit pattern of individual segment activation: right headlight-LED 72,OFF ,13
IDE09569-MAS11543-Bit pattern of individual segment activation: right headlight-LED 73,OFF ,13
IDE09569-MAS11544-Bit pattern of individual segment activation: right headlight-LED 74,OFF ,13
IDE09569-MAS11545-Bit pattern of individual segment activation: right headlight-LED 75,OFF ,13
IDE09569-MAS11546-Bit pattern of individual segment activation: right headlight-LED 76,OFF ,13
IDE09569-MAS11547-Bit pattern of individual segment activation: right headlight-LED 77,OFF ,13
IDE09569-MAS11548-Bit pattern of individual segment activation: right headlight-LED 78,OFF ,13
IDE09569-MAS11549-Bit pattern of individual segment activation: right headlight-LED 79,OFF ,13
IDE09569-MAS11550-Bit pattern of individual segment activation: right headlight-LED 80,OFF ,13
IDE09569-MAS11551-Bit pattern of individual segment activation: right headlight-LED 81,OFF ,13
IDE09569-MAS11552-Bit pattern of individual segment activation: right headlight-LED 82,OFF ,13
IDE09569-MAS11553-Bit pattern of individual segment activation: right headlight-LED 83,OFF ,13
IDE09569-MAS11554-Bit pattern of individual segment activation: right headlight-LED 84,OFF ,13
IDE09569-MAS11555-Bit pattern of individual segment activation: right headlight-LED 85,OFF ,13
IDE09569-MAS11556-Bit pattern of individual segment activation: right headlight-LED 86,OFF ,13
IDE09569-MAS11557-Bit pattern of individual segment activation: right headlight-LED 87,OFF ,13
IDE09569-MAS11558-Bit pattern of individual segment activation: right headlight-LED 88,OFF ,13
IDE09569-MAS11559-Bit pattern of individual segment activation: right headlight-LED 89,OFF ,13
IDE09569-MAS11560-Bit pattern of individual segment activation: right headlight-LED 90,OFF ,13
IDE12645-Matrix headlights: switch-on effect,on engine start ,1
IDE12648-MAS09833-Headlights left: low beam segment actuation-LED 1,OFF ,3
IDE12648-MAS09834-Headlights left: low beam segment actuation-LED 2,OFF ,3
IDE12648-MAS09835-Headlights left: low beam segment actuation-LED 3,OFF ,3
IDE12648-MAS09836-Headlights left: low beam segment actuation-LED 4,OFF ,3
IDE12648-MAS09837-Headlights left: low beam segment actuation-LED 5,OFF ,3
IDE12648-MAS09838-Headlights left: low beam segment actuation-LED 6,OFF ,3
IDE12648-MAS09839-Headlights left: low beam segment actuation-LED 7,OFF ,3
IDE12648-MAS09840-Headlights left: low beam segment actuation-LED 8,OFF ,3
IDE12648-MAS09841-Headlights left: low beam segment actuation-LED 9,OFF ,3
IDE12648-MAS09842-Headlights left: low beam segment actuation-LED 10,OFF ,3
IDE12648-MAS09843-Headlights left: low beam segment actuation-LED 11,OFF ,3
IDE12648-MAS09844-Headlights left: low beam segment actuation-LED 12,OFF ,3
IDE12648-MAS09845-Headlights left: low beam segment actuation-LED 13,OFF ,3
IDE12648-MAS09846-Headlights left: low beam segment actuation-LED 14,OFF ,3
IDE12648-MAS09847-Headlights left: low beam segment actuation-LED 15,OFF ,3
IDE12648-MAS09848-Headlights left: low beam segment actuation-LED 16,OFF ,3
IDE12648-MAS09849-Headlights left: low beam segment actuation-LED 17,OFF ,3
IDE12648-MAS09850-Headlights left: low beam segment actuation-LED 18,OFF ,3
IDE12648-MAS09851-Headlights left: low beam segment actuation-LED 19,OFF ,3
IDE12648-MAS09852-Headlights left: low beam segment actuation-LED 20,OFF ,3
IDE12649-MAS09833-Headlights right: low beam segment actuation-LED 1,OFF ,3
IDE12649-MAS09834-Headlights right: low beam segment actuation-LED 2,OFF ,3
IDE12649-MAS09835-Headlights right: low beam segment actuation-LED 3,OFF ,3
IDE12649-MAS09836-Headlights right: low beam segment actuation-LED 4,OFF ,3
IDE12649-MAS09837-Headlights right: low beam segment actuation-LED 5,OFF ,3
IDE12649-MAS09838-Headlights right: low beam segment actuation-LED 6,OFF ,3
IDE12649-MAS09839-Headlights right: low beam segment actuation-LED 7,OFF ,3
IDE12649-MAS09840-Headlights right: low beam segment actuation-LED 8,OFF ,3
IDE12649-MAS09841-Headlights right: low beam segment actuation-LED 9,OFF ,3
IDE12649-MAS09842-Headlights right: low beam segment actuation-LED 10,OFF ,3
IDE12649-MAS09843-Headlights right: low beam segment actuation-LED 11,OFF ,3
IDE12649-MAS09844-Headlights right: low beam segment actuation-LED 12,OFF ,3
IDE12649-MAS09845-Headlights right: low beam segment actuation-LED 13,OFF ,3
IDE12649-MAS09846-Headlights right: low beam segment actuation-LED 14,OFF ,3
IDE12649-MAS09847-Headlights right: low beam segment actuation-LED 15,OFF ,3
IDE12649-MAS09848-Headlights right: low beam segment actuation-LED 16,OFF ,3
IDE12649-MAS09849-Headlights right: low beam segment actuation-LED 17,OFF ,3
IDE12649-MAS09850-Headlights right: low beam segment actuation-LED 18,OFF ,3
IDE12649-MAS09851-Headlights right: low beam segment actuation-LED 19,OFF ,3
IDE12649-MAS09852-Headlights right: low beam segment actuation-LED 20,OFF ,3
IDE13276-Matrix headlights: driving axis angle (calibration),0 ',1
IDE13611-Cornering lamp in operation,not active ,1
IDE13612-Matrix head lamps: steering angle,-400.0 °,2
IDE13725-Automatic high beam: in operation,not active ,1
IDE14057-MAS17320-Left dipped beam setting-Horizontal dipped beam setting: value,-0.00 ,5
IDE14057-MAS17321-Left dipped beam setting-Vertical dipped beam setting: value,-0.00 ,5
IDE14057-MAS17322-Left dipped beam setting-Dipped beam setting: unit,Degree ,5
IDE14058-MAS17320-Right dipped beam position-Horizontal dipped beam setting: value,-0.00 ,5
IDE14058-MAS17321-Right dipped beam position-Vertical dipped beam setting: value,-0.00 ,5
IDE14058-MAS17322-Right dipped beam position-Dipped beam setting: unit,Degree ,5
IDE15489-MAS16912-Port mirroring-VLAN_FAS,not active ,4
IDE15489-MAS16913-Port mirroring-VLAN_Infotainment,not active ,4
IDE15489-MAS16917-Port mirroring-VLAN_Diagnose,not active ,4
IDE15489-MAS18934-Port mirroring-VLAN Connect,not active ,4
IDE15489-MAS18935-Port mirroring-VLAN_Gateway,not active ,4
IDE15489-MAS20472-Port mirroring-VLAN Connect 2,not active ,4
IDE15489-ENG278538-Port mirroring-Switch_port_adaptive_partition_rx,not active ,4
IDE15489-ENG278497-Port mirroring-Switch_port_adaptive_partition_tx,not active ,4
IDE15489-ENG278500-Port mirroring-Switch_port_housekeeping_rx,not active ,4
IDE15489-ENG278507-Port mirroring-Switch_port_housekeeping_tx,not active ,4
IDE15489-ENG278448-Port mirroring-Switch_port_java_partition_rx,not active ,4
IDE15489-ENG278543-Port mirroring-Switch_port_java_partition_tx,not active ,4
IDE15489-ENG278541-Port mirroring-Switch_port_r7_rx,not active ,4
IDE15489-ENG278474-Port mirroring-Switch_port_r7_tx,not active ,4
IDE15489-ENG277126-Port mirroring-vlan_diagnose_2,not active ,4
IDE15489-ENG277127-Port mirroring-vlan_eb_rcar_access,not active ,4
IDE15489-ENG277128-Port mirroring-vlan_gateway_udp_exchange,not active ,4
IDE15489-ENG277129-Port mirroring-vlan_ids_marvell,not active ,4
IDE15489-ENG277130-Port mirroring-vlan_switch_control,not active ,4
IDE15489-ENG277131-Port mirroring-vlan_udp_tunnel,not active ,4
IDE15895-Reference run switch-on effect order,Follow-up ,1
MAS16167-IDE03632-Dynamic light function-Left-/right hand driving switch-over,Right hand driv. ,10
MAS16167-IDE03638-Dynamic light function-Stationary cornering lamp,ECE R48 ,10
MAS16167-IDE03640-Dynamic light function-Dynamic AFS light,activated ,10
MAS16167-IDE03644-Dynamic light function-Highway light,not activated ,10
MAS16167-IDE03646-Dynamic light function-Intersection light with route data,not activated ,10
MAS16167-MAS01078-Dynamic light function-Vehicle model,1A ,10
MAS16167-MAS02922-Dynamic light function-City light,not activated ,10
MAS16167-MAS03397-Dynamic light function-predictive route data,activated ,10
MAS16167-MAS07013-Dynamic light function-All-weather light,activated ,10
MAS16167-MAS07933-Dynamic light function-Eco mode,not activated ,10
MAS16167-MAS13654-Dynamic light function-Auxiliary high beam,not installed ,10
MAS16167-Dynamic light function-,activated ,10
MAS16167-MAS18121-Dynamic light function-Operating site,NAR ,10
MAS16167-SFT00032-Dynamic light function-High beam assistant,activated ,10
MAS16167-SFT00085-Dynamic light function-Headlamp range control,activated ,10
MAS16167-ENG172757-Dynamic light function-AFS_coding_Light_Assist,Halogen ,10
MAS16167-ENG173235-Dynamic light function-AFS_Curvelight,Deactivated ,10
MAS16167-ENG173233-Dynamic light function-AFS_Led_funktion_frontlight,activated ,10
MAS16167-ENG172238-Dynamic light function-chassis_unit,Mehrlenkerhinterachse Frontantrieb ,10
MAS16167-ENG174204-Dynamic light function-Dynamical_Low_Beam_Light,not activated ,10
MAS16167-ENG261422-Dynamic light function-expressway_light,not activated ,10
MAS16167-ENG172242-Dynamic light function-headlamp_coding_word,00 ,10
MAS16167-ENG259430-Dynamic light function-LWR_konfig,CAN_automatic ,10
MAS16167-ENG172241-Dynamic light function-lwr_sensors,2_sensors ,10
MAS16167-ENG164522-Dynamic light function-Marking_light,not activated ,10
MAS16167-ENG172446-Dynamic light function-Matrix_head_lamp,activated ,10
MAS16167-ENG173009-Dynamic light function-offroad_light,not activated ,10
MAS16167-ENG176177-Dynamic light function-PAHS_online_calibration_activation_mode,OFF ,10
MAS16167-ENG174436-Dynamic light function-PAHS_Porsche_adaptive_headlight_adjustment,not_installed ,10
MAS16167-ENG172449-Dynamic light function-Predictive_afs,not activated ,10
MAS16167-ENG173010-Dynamic light function-race_activiation,not activated ,10
MAS16167-ENG172245-Dynamic light function-rain_light,not activated ,10
MAS16167-ENG174621-Dynamic light function-segmented_cornering_light,not activated ,10
MAS16167-ENG174637-Dynamic light function-Source_height_value,BCM ,10
MAS16167-ENG172240-Dynamic light function-steering_curve,normal ,10
ENG253278-Activation_DLT,not active ,1
ENG261383-Activation_XCP,not active ,1
ENG103979-Reference_Run_Start_Condition,Engine start ,1
Elapsed Time: 00:17
Jef
HQ
adpmap-C003-V04-007-003-LH_WVG5WVEB2SH017765-20250325-1243.CSV
;SW:V04-007-003-LH   HW: ---  SW Cluster Housekeeping
;Component:ICAS1 SWCL_HK 0254, Coding:
;EV_SWCLHouse1ICAS1UNECE,001002,EV_SWCLHouse1ICAS1UNECE.rod
;Tuesday,25,March,2025,12:43:37:58926
;VCID: 78A286F6525D292AB76-802C-R SFD+SFD2
Elapsed Time: 00:01
Jef
HQ
;Address 0x01:Engine SW:0EA-906-014-GG   HW:0EA-907-425-K
;Component:E-Vehicle     H80 3875, Coding:4102000350042C0236000800000000000000000000000000
;EV_VCU00XXX0200EA906014GG,003002,EV_VCU00XXX020_VNE4.rod
;Tuesday,25,March,2025,12:18:39:58926
Advanced Identification/FAZIT
     Identification: SJ8-ASG
     Date: 05.11.24
     Manufacturer number: 0010
     Test stand number: 0065
Flash Status
     Programming Attempts(application): 1/1/1/1/1
     Flash Date-Workshop ID-Status:
     24.11.22 00532 790 00000 (OK) | 24.11.22 00532 790 00000 (OK) | 24.11.22 00532 790 00000 (OK) | 24.11.22 00532 790 00000 (OK)
Misc.
     Hardware number: 0EA 907 425 K
     Workshop System Name: J623
     Workshop ID (Adaptation): 00000 000 00000
     Workshop ID (Coding): 00000 000 00000
     Dataset Number: V03935424SD
     Dataset Version: 0001
     ASAM Dataset: EV_VCU00XXX0200EA906014GG
     ASAM Dataset Revision: 003002
Car Info
     Chassis Number: WVG5WVEB2SH017765
     Engine code: ---B
VCDS Info:
       Labels: None
       Readiness: No script available
       ROD: EV_VCU00XXX020_VNE4.rod
;Address 0x03:ABS Brakes SW:1EA-907-379-BQ   HW:1EA-614-517-M
;Component:ESC-ZF_EBC470 H18 0754, Coding:481044A8004159024217990000B79840250070614000
;EV_BrakeZFESCMEBUNECE,001035,EV_BrakeZFESCMEBUNECE_001_VWE3.rod
;Tuesday,25,March,2025,12:19:15:58926
;VCID: 0D4CC7224DDF3C82F40-8058-R SFD+SFD2
     Serial number: 0000000
     Identification: GNO-KOB
     Date: 28.10.24
     Manufacturer number: 2222
     Test stand number: 4024
Flash Status
     Programming Attempts(application): 0/0/1/1/1/1/1/0/1
     00.01.01 00000 000 00000 (OK) | 00.01.01 00000 000 00000 (OK) | 24.11.22 00532 790 00000 (OK) | 24.11.22 00532 790 00000 (OK)
     24.11.22 00532 790 00000 (OK) | 24.11.22 00532 790 00000 (OK) | 24.11.22 00532 790 00000 (OK) | 00.01.01 00000 000 00000 (nOK:FF)
     Dataset Address-Name-Version-Status:
     7101-P01PBRSXX1EA B065 (07) | 7103-USTIFUXXX1EA B065 (07) | 7104-UMFDREU4BZLH 5B15 (07) | 7105-URKAXXXXXPV7 I014 (07)
     7106-UMONIXXXX1EA B065 (07) | 7107------------- ---- (03) | 7108-UPBC2XXXXXXX A006 (07)
Misc.
     Hardware number: 1EA 614 517 M
     Workshop System Name: J104
     Dataset Number: V03935447PA
     ASAM Dataset: EV_BrakeZFESCMEBUNECE
     ASAM Dataset Revision: 001035
VCDS Info:
       Labels: None
       ROD: EV_BrakeZFESCMEBUNECE_001_VWE3.rod
;Address 0x05:Acc/Start Auth. SW:5WA-959-436-N   HW:5WA-959-436-N
;Component:Kessy IOBOX   122 0757, Coding:
;EV_Kessy37w,005030,EV_Kessy37w.rod
;Tuesday,25,March,2025,12:19:35:58926
;VCID: 5F90CD6AD7B3FE12D6C-800A-R
     Serial number: ---------------
     Identification: HLH-W42
     Date: 18.11.24
     Manufacturer number: 2123
     Test stand number: 0254
Flash Status
     Programming Attempts(application): 1/0/1
     00.01.01 00000 000 00000 (OK) | 00.01.01 00000 000 00000 (OK) | 24.11.22 00176 790 00000 (OK)
     7100-VN41SADXXXXX 6201 (07)
Misc.
     Hardware number: 5WA 959 436 N
     Workshop System Name: J518
     Dataset Number: V03935385FF
     ASAM Dataset: EV_Kessy37w
     ASAM Dataset Revision: 005030
Car Info
VCDS Info:
       Labels: 5WA-959-436.clb
       ROD: EV_Kessy37w.rod
;Address 0x06:Seat Mem. Pass SW:1N3-959-760-H   HW:1N3-959-760-H
;Component:MEM-BFS       011 0571, Coding:0118B24000012A008803010121010000000000000000000000000000211000
;EV_SCMPasseSideCONTIAU736,006013,EV_SCMPasseSideCONTIAU736_VW42.rod
;Tuesday,25,March,2025,12:20:24:58926
;VCID: 3E2E50EE30F9D71ABDA-806A-R
     Serial number: 24B0501KA02040
     Identification: CNK-SCU
     Date: 10.11.24
     Manufacturer number: 0001
     Test stand number: 0A8A
Flash Status
     Programming Attempts(application): 1/0/0/2/0
     00.01.01 00000 000 00000 (OK) | 00.01.01 00000 000 00000 (OK) | 00.01.01 00000 000 00000 (OK) | 24.11.19 00000 008 04304 (OK)
     Flash Tool Code(data): 00000 000 00000
     7100-SCBUZZPEOPLE 2539 (07) | 7180------------- ---- (00)
Misc.
     Hardware number: 1N3 959 760 H
     Workshop System Name: J521
     Workshop ID (Coding): 00032 790 00000
     Equipment/PR Code: 000000000000000000000000
     Dataset Number: V03935362VW
     ASAM Dataset: EV_SCMPasseSideCONTIAU736
     ASAM Dataset Revision: 006013
VCDS Info:
       Labels: *None
       ROD: EV_SCMPasseSideCONTIAU736_VW42.rod
;Address 0x08:Auto HVAC SW:1N3-907-007-D   HW:1N3-907-007-C
;Component:Climatronic   H01 0247, Coding:013022207010120051102110111001102000102100201171000010000000
;EV_ACClimaBHBE3ADV,002051,EV_ACClimaBHBE3ADV_AUE3.rod
;Tuesday,25,March,2025,12:21:32:58926
;VCID: 2D0C67A2ED9F5C82140-8078-R SFD+SFD2
     Serial number: 222102400423250
     Identification: BXH-001
     Date: 24.10.24
     Manufacturer number: 0527
     Test stand number: 7245
Flash Status
     Programming Attempts(application): 0/0/1/0
     00.01.01 00000 000 00000 (OK) | 00.01.01 00000 000 00000 (OK) | 24.11.22 00532 790 00000 (OK) | 00.01.01 00000 000 00000 (OK)
     7100-FB0800001420 VN02 (07)
Misc.
     Hardware number: 1N3 907 007 C
     Workshop System Name: J979
     Dataset Number: V03935439QZ
     ASAM Dataset: EV_ACClimaBHBE3ADV
     ASAM Dataset Revision: 002051
VCDS Info:
       Labels: *Redir Fail!
       ROD: EV_ACClimaBHBE3ADV_AUE3.rod
;Address 0x09:Cent. Elect. SW:1EE-937-089-C   HW:1EE-937-089-A
;Component:SAM_H+        H08 0555, Coding:
;EV_SAMVW31x,006001,EV_SAMVW31x_006_VWE3.rod
;Tuesday,25,March,2025,12:25:34:58926
;VCID: 42D6241E4401B3FAD92-8016-R SFD
     Serial number: 01102422200796-
     Identification: SME-RBG
     Date: 01.09.24
     Manufacturer number: 0043
     Test stand number: 0527
Flash Status
     Programming Attempts(application): 1/1/0/1/0/0/0
     00.00.00 00000 000 00000 (OK) | 00.00.00 00000 000 00000 (OK) | 00.00.00 00000 000 00000 (OK) | 00.00.00 00000 000 00000 (OK)
     7200-SAMFRWISCHER N004 (07) | 7201------------- ---- (03) | 7202------------- ---- (03) | 7203------------- ---- (03)
     7204-PLUB01BP0000 Y00C (03) | 7205------------- ---- (03) | 7206-NEOKK6GB0008 X01N (07) | 7207-NEOKK6GB0009 N002 (07)
     7208-000000000000 Y00F (07) | 7209-NEOKK6GB0006 X00X (03) | 720A-FUREIUAMBVWN N002 (07) | 720B------------- ---- (03)
     720C-SAMWASCHORVC N00A (03) | 720D------------- ---- (03) | 720E------------- ---- (03) | 720F-000000000000 E007 (03)
     7210------------- ---- (03) | 7211------------- ---- (03) | 7212------------- ---- (03) | 7213------------- ---- (03)
     7214------------- ---- (03) | 7215-TPWDEFAULT00 E001 (07) | 7216-RLSROUTING00 E004 (07) | 7217-SAMEXAMB7217 N00I (07)
     7218------------- ---- (03) | 7219------------- ---- (03) | 721A------------- ---- (03) | 721B------------- ---- (03)
     721C------------- ---- (03) | 721D------------- ---- (03) | 721E------------- ---- (03) | 721F------------- ---- (03)
     7220------------- ---- (03) | 7221------------- ---- (03) | 7222------------- ---- (03) | 7223------------- ---- (03)
     7224------------- ---- (03) | 7225------------- ---- (03) | 7226------------- ---- (03) | 7227-SAMHEWISCHER N003 (07)
     7228-201905130000 Z001 (07) | 7229-PLUB01BP0000 Y003 (07) | 722A------------- ---- (03) | 722B-SAMEXAMB722B N00S (07)
     722C------------- ---- (03) | 722D-SPNDEFMEBU00 E001 (03) | 722E------------- ---- (03) | 722F------------- ---- (03)
     7230-201905113000 Z001 (07) | 7231------------- ---- (03) | 7232------------- ---- (03) | 7233------------- ---- (03)
     7234------------- ---- (03) | 7235-202206170000 V001 (03) | 7236-202202140000 V001 (03) | 7237-271020220000 V003 (03)
     7238-SUCHDISPLAY1 E004 (07) | 7239------------- ---- (03) | 723A------------- ---- (03) | 723B------------- ---- (03)
     723C------------- ---- (03) | 723D------------- ---- (03) | 723E------------- ---- (03) | 723F------------- ---- (03)
     7240------------- ---- (03) | 7241------------- ---- (03) | 7242------------- ---- (03) | 7243------------- ---- (03)
     7244------------- ---- (03) | 7245-000000000000 V001 (03) | 7246------------- ---- (03) | 7247------------- ---- (03)
     7248----------- ---- (03) | 0000-x ???? (?) | 2D2D----------rO- ???? (?) | 2D2D----------rP- ???? (?)
     2D2D----------rQ- ???? (?) | 2D2D----------rR- ???? (?) | 2D2D----------rS- ???? (?)
Misc.
     Hardware number: 1EE 937 089 A
     Workshop System Name: J519
     Dataset Number: V03935462MK
     ASAM Dataset: EV_SAMVW31x
     ASAM Dataset Revision: 006001
Car Info
VCDS Info:
       Labels: None
       ROD: EV_SAMVW31x_006_VWE3.rod
;Address 0x10:Park/Steer Assist SW:1EE-919-300-B   HW:1EE-919-300
;Component:RPA12K        H01 0630, Coding:0230026041
;EV_EPHBO3CVW4130000,001014,EV_EPHBO3CVW4130000_VWE3.rod
;Tuesday,25,March,2025,12:25:53:58926
;VCID: 333871DA0BBB0A72424-8066-R
     Serial number: 000020102494630
     Identification: BXJ-53F
     Date: 20.10.24
     Manufacturer number: 9463
     Test stand number: 1310
Flash Status
     00.00.00 00000 000 00000 (OK) | 00.00.00 00000 000 00000 (OK) | 24.11.22 00532 790 00000 (OK)
     7113-BN41S1NABL00 SCU2 (07)
Misc.
     Hardware number: 1EE 919 300
     Workshop System Name: J446
     Dataset Number: V03935447DQ
     ASAM Dataset: EV_EPHBO3CVW4130000
     ASAM Dataset Revision: 001014
VCDS Info:
       Labels: *None
       ROD: EV_EPHBO3CVW4130000_VWE3.rod
;Address 0x13:Auto Dist. Reg SW:1EA-907-567-B   HW:1EA-907-819
;Component:ARS512VW13    H05 0232, Coding:06230AE24071C04412574000008040052F4020000000000000000000000000
;EV_FRONTRADARCONTIVW310,004013,EV_FRONTRADARCONTIVW310_004_VWE3.rod
;Tuesday,25,March,2025,12:26:24:58926
;VCID: 3B2859FA23EBC2329A4-806E-R SFD+SFD2
     Identification: CKL-006
     Date: 04.11.24
     Manufacturer number: 0203
     Test stand number: 6707
Flash Status
     Programming Attempts(application): 1/0/0/1/1
     00.01.01 00000 000 00000 (OK) | 00.01.01 00000 000 00000 (OK) | 00.01.01 00000 000 00000 (OK) | 24.11.22 00532 790 00000 (OK)
     7200-15A1EAL3BMN0 SV05 (07) | 7203------------- ---- (02) | 7100-10A1EAVR0000 S0U6 (07) | 7101-15A1EA00B00N SVG6 (07)
Misc.
     Hardware number: 1EA 907 819
     Workshop System Name: J428
     Dataset Number: V03935436WW
     ASAM Dataset: EV_FRONTRADARCONTIVW310
     ASAM Dataset Revision: 004013
Immobilizer
     Immo Challenge: 98ECD34B
VCDS Info:
       Labels: *None
       ROD: EV_FRONTRADARCONTIVW310_004_VWE3.rod
;Address 0x15:Airbags SW:3WA-959-655-AA   HW:3WA-959-655-AA
;Component:Airbag VW50   006 0151, Coding:8CCC0C0000FCC0000000002000000000A15450008100A200830036F8102B0065
;EV_AirbaVW50TS6VW49X,001001,EV_AirbaVW50TS6VW49X_VWE3.rod
;Tuesday,25,March,2025,12:27:06:58926
;VCID: 147AD2466EF5ED4A3BE-8040-R SFD+SFD2
     Serial number: 003C0T5CNPYJD3
     Identification: CZF-CEC
     Revision: --------
     Date: 29.10.24
     Manufacturer number: AR72
     Test stand number: 1001
Flash Status
     Programming Attempts(application): 0/0/0/0/2/2/2/2/2
     Programming Attempts(data): 2/2/2/2/2
     00.01.01 2097151 1023 131071 (OK) | 00.01.01 2097151 1023 131071 (OK) | 00.01.01 2097151 1023 131071 (OK) | 00.01.01 2097151 1023 131071 (OK)
     24.11.22 00032 790 00000 (OK) | 24.11.22 00032 790 00000 (OK) | 24.11.22 00032 790 00000 (OK) | 24.11.22 00032 790 00000 (OK)
     7100-ZFCRAS15ASER 0241 (07) | 7101-TSPREC15AINE 000F (07) | 7102-TSFLEX15ASER 2412 (07) | 7103-TSEDRZMEBSER 0325 (07)
     7104-TSAUSZ15ASER 031M (07)
Misc.
     Hardware number: 3WA 959 655 AA
     Workshop System Name: J234
     Workshop ID (Adaptation): 00032 790 00000
     Dataset Number: V03935445XP
     ASAM Dataset: EV_AirbaVW50TS6VW49X
     ASAM Dataset Revision: 001001
Car Info
VCDS Info:
       Labels: *3WA-959-655.clb
       ROD: EV_AirbaVW50TS6VW49X_VWE3.rod
;Address 0x16:Steering wheel SW:1EE-953-507-CH   HW:1EE-953-507-CH
;Component:GSMMEB        005 0067, Coding:
;EV_SMLSKLOGEN2,009005,EV_SMLSKLOGEN2_009_VW41.rod
;Tuesday,25,March,2025,12:27:29:58926
;VCID: 0358E11A1B9B7AF2924-8056-R SFD
     Serial number: 000000301024477
     Identification: KOS-KLO
     Date: 30.10.24
     Manufacturer number: 4776
     Test stand number: 1640
Flash Status
     Flash Date: 00.01.01 00000 000 00000 (OK) | 00.01.01 00000 000 00000 (OK)
Misc.
     Hardware number: 1EE 953 507 CH
     Workshop System Name: J527
     ASAM Dataset: EV_SMLSKLOGEN2
     ASAM Dataset Revision: 009005
VCDS Info:
       Labels: 1EE-953-507.clb
       ROD: EV_SMLSKLOGEN2_009_VW41.rod
;Address 0x19:CAN Gateway SW:1EE-937-012-A   HW:1EE-937-012
;Component:ICAS1 Host-SG 031 0254, Coding:
;EV_GatewICAS1MEBUNECE,001004,EV_GatewICAS1MEBUNECE_VWE3.rod
;Tuesday,25,March,2025,12:17:54:58926
;VCID: 323674DEF4A1037A492-8066 SFD+SFD2
     Serial number: SMERBG161024007
     Date: 16.10.24
     Manufacturer number: 0070
     Test stand number: 0078
Flash Status
     Programming Attempts(application): 0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/1/0
     00.01.01 00000 000 00000 (OK) | 00.01.01 00000 000 00000 (OK) | 00.01.01 00000 000 00000 (OK) | 00.01.01 00000 000 00000 (OK)
     7202-0043RWB00003 D13X (07) | 722C-02ECADA00001 0802 (07) | 7206------------- ---- (03) | 7207-0055PACO0003 2402 (07)
     7208-0038FPA00003 4002 (07) | 7215-0133CMS00003 V0AC (07) | 7216-0134HLC00003 V05G (07) | 7217-0066EMLB0003 710J (07)
     7218-0066EMLG0003 710J (07) | 7219-0066EMLI0003 710J (07) | 721A-0066EMLP0003 710J (07) | 721B-0066EMLS0003 710J (07)
     721C-0066EMLV0003 710J (07) | 721D-0066EMLGLO03 710J (07) | 721E-0066EMLRES03 710J (07) | 7220-0061USS00004 040D (07)
     721F-0139ECM00004 V00S (07) | 7203-0135CTM00004 V11D (07) | 7209-0136DCP00004 V003 (07) | 720E-0062KESSY004 6206 (07)
     720F-0083SAL00005 0118 (07) | 7214-0152HVLSF005 V00E (07) | 722F-PMD202AVZUKO D000 (07) | 72D0-MDKCONFIG001 E00M (07)
     7221-0790PRDET207 0302 (07) | 72E0-0065VLK000S4 V006 (07) | 7100-PMD201AVZUKO D000 (07)
RxSWIN
Misc.
     Hardware number: 1EE 937 012
     Workshop System Name: J533
     Dataset Number: V03935446DK
     ASAM Dataset: EV_GatewICAS1MEBUNECE
     ASAM Dataset Revision: 001004
Car Info
Immobilizer
     Transponder ID (Current val.): 00000000
     Transponder ID 1: CD1C9BB1
     Transponder ID 2: E81C9BB1
     General immobilizer info :
          Life status: 2
          Identity counter: 1
          Brand identification: 3
          Power class: 0xE8
          Count of adapted keys: 2
          Count of keys to be adapted by adaptation: 0
          Minutes remaining for Terminal 15 ON: 0
          Configuration status: 23
          Reserved: 0
     Lock times in minutes :
          Lock time password reset: 0
          Lock time login/Terminal 15 ON: 0
          Lock time key adaptation: 0
          Lock time leaving key adaptation: 0
          Lock time login special function: 0
     Immo Challenge: 07BCA36C
VCDS Info:
       Labels: 1EE-937-012.clb
       ROD: EV_GatewICAS1MEBUNECE_VWE3.rod
;Address 0x23:Brake Booster SW:1N3-909-059-AA   HW:1N3-909-059
;Component:EBB-ZF-Gen1   H47 0853, Coding:A0404080600028
;EV_BrakeBoostZFMEBUNECE,001034,EV_BrakeBoostZFMEBUNECE.rod
;Tuesday,25,March,2025,12:27:45:58926
;VCID: 74BAB2C64E354D4A9BE-8020-R SFD+SFD2
     Identification: TBG-GLI
     Date: 12.11.24
     Manufacturer number: AF24
     Test stand number: 0481
Flash Status
     7101-U01PBRSXX1EA B061 (07) | 7106-UMONIXXXX1EA B061 (07)
Misc.
     Hardware number: 1N3 909 059
     Workshop System Name: J539
     Dataset Number: V03935435CY
     ASAM Dataset: EV_BrakeBoostZFMEBUNECE
     ASAM Dataset Revision: 001034
VCDS Info:
       Labels: None
       ROD: EV_BrakeBoostZFMEBUNECE.rod
;Address 0x2B:Steer. Col. Lock SW:3WA-905-861   HW:3WA-905-861
;Component:ELV-MQB_UNECE H05 0063, Coding:8880000000000000
;EV_ELVMarqUNECE,003006,EV_ELVMarqUNECE_003_VW27.rod
;Tuesday,25,March,2025,12:27:58:58926
;VCID: 0842F63622BD59AAC76-805C-R SFD+SFD2
     Serial number: 24000262799015
     Identification: MD9-MSR
     Date: 18.10.24
     Manufacturer number: 2583
     Test stand number: 3455
Flash Status
     00.01.01 00000 000 00000 (OK) | 00.01.01 00000 000 00000 (nOK:01) | 00.01.01 00000 000 00000 (nOK:01)
Misc.
     Hardware number: 3WA 905 861
     Workshop System Name: J764
     Workshop ID (Adaptation): 00532 790 00000
     Workshop ID (Coding): 00532 790 00000
     Dataset Number: V03935384XW
     ASAM Dataset: EV_ELVMarqUNECE
     ASAM Dataset Revision: 003006
Car Info
Immobilizer
          Life status: 2
          Identity counter: 1
          Power class: 0xE8
          Count of adapted keys: 0
          Configuration status: 0
          Reserved: 0
     Immo Challenge: 50912A73
VCDS Info:
       Labels: .3WA-905-861.clb
       ROD: EV_ELVMarqUNECE_003_VW27.rod
;Address 0x36:Seat Mem. Drvr SW:1N3-959-760-H   HW:1N3-959-760-H
;Component:MEM-FS        011 0571, Coding:0118BA4000013A008803010121010000000000000000000000000000215000
;EV_SCMDriveSideCONTIAU736,006013,EV_SCMDriveSideCONTIAU736_VW42.rod
;Tuesday,25,March,2025,12:28:47:58926
     Serial number: 24B0501KA02039
     Date: 10.11.24
     Test stand number: 0A89
Flash Status
     Programming Attempts(application): 1/0/0/3/0
Misc.
     Workshop System Name: J136
     Dataset Number: V03935362VP
     ASAM Dataset: EV_SCMDriveSideCONTIAU736
VCDS Info:
       Labels: *None
       ROD: EV_SCMDriveSideCONTIAU736_VW42.rod
;Address 0x3C:Lane Change SW:2Q0-907-686-H   HW:2Q0-907-686-H
;Component:HRE_Master    H26 0320, Coding:5A954750
;EV_HREHellaGen3MstrUNECE,001001,EV_HREHellaGen3MstrUNECE_VW27.rod
;Tuesday,25,March,2025,12:29:07:58926
;VCID: 3FD02DEA37F3DE12B6C-806A-R
     Serial number: 14520059654591
     Identification: HLV-HLT
     Date: 04.11.24
     Manufacturer number: 6CD3
     Test stand number: 2376
Flash Status
     Programming Attempts(application): 1/1/0/0/1
     7100-VN41S0EUB0BA MH62 (07)
Misc.
     Hardware number: 2Q0 907 686 H
     Workshop System Name: J1086
     Dataset Number: V03935416KP
     ASAM Dataset: EV_HREHellaGen3MstrUNECE
Immobilizer
     Immo Challenge: C5AEEA4A
VCDS Info:
       ROD: EV_HREHellaGen3MstrUNECE_VW27.rod
;Address 0x42:Door Elect, Driver SW:1EA-959-593-F   HW:1EA-959-593-F
;Component:TSG FS        009 0563, Coding:0035DB20D200028044000020
;EV_DCU3DriveSideMAXHCONT,001004,EV_DCU3DriveSideMAXHCONT_VWE3.rod
;Tuesday,25,March,2025,12:29:27:58926
;VCID: 45DC3F02552F84C2FC0-8010-R
     Serial number: 0000542453170
     Identification: CU5-DCM
     Date: 21.10.24
     Manufacturer number: 1010
     Test stand number: 3003
Flash Status
     7200-2V0561VN41S1 0009 (07)
Misc.
     Hardware number: 1EA 959 593 F
     Workshop System Name: J386
     Dataset Number: V03935421ZA
     ASAM Dataset: EV_DCU3DriveSideMAXHCONT
VCDS Info:
       Labels: *None
       ROD: EV_DCU3DriveSideMAXHCONT_VWE3.rod
;Address 0x44:Steering Assist SW:1N3-907-144-Q   HW:1N3-907-144-L
;Component:BASGEN1MQB37  131 7341, Coding:00000000000002010000020101000100000001000101
;EV_SteerAssisBASGEN1MQB37,017078,EV_SteerAssisBASGEN1MQB37.rod
;Tuesday,25,March,2025,12:29:49:58926
     Serial number: 01765164
     Identification: LZE-000
     Date: 30.10.24
     Manufacturer number: 0134
     Test stand number: 0386
Flash Status
     Programming Attempts(application): 0/0/0/1/1/1
     00.01.01 394758 024 12336 (OK) | 00.01.01 394758 024 12336 (OK) | 24.11.22 00532 790 00000 (OK) | 24.11.22 00532 790 00000 (OK)
     24.11.22 00532 790 00000 (OK) | 00.01.01 394758 024 12336 (OK)
     7101-BEA1EU3KR012 4501 (07) | 7102-BEA1EU3KR012 4501 (07) | 7103-BEA1EU3KR012 4501 (07)
Misc.
     Hardware number: 1N3 907 144 L
     Workshop System Name: J500
     Dataset Number: V03935435WK
     ASAM Dataset: EV_SteerAssisBASGEN1MQB37
     ASAM Dataset Revision: 017078
Car Info
     Chassis Number: 00000000000000000
VCDS Info:
       Labels: .*5WA-907-14X-V1.clb
       ROD: EV_SteerAssisBASGEN1MQB37.rod
;Address 0x47:Sound System SW:3G0-035-466-F   HW:3G0-035-466-F
;Component:AMPeth16CDoIP H03 7012, Coding:24090100000000000000000000000000000000000000000000
;EV_AMPEthMQB37w,001005,EV_AMPEthMQB37w_VW38.rod
;Tuesday,25,March,2025,12:30:11:58926
;VCID: 280296B6C27D79AAE76-807C-R SFD+SFD2
     Serial number: A1130N00028514
     Identification: PN9-SLU
     Date: 27.10.24
     Manufacturer number: 0002
     Test stand number: 0053
Flash Status
     00.01.01 00000 000 00000 (OK) | 23.05.04 403014 410 13622 (OK) | 24.11.22 00176 790 00000 (OK)
     7103-ASPARAMETER1 UE65 (07) | 7202-AP0SOUND0ANN U4T0 (07) | 720E-EA0SO0ACO0PS UP09 (07) | 7206-LS0CON001008 0D02 (07)
     7207-LS0CON009016 0D02 (07) | 0000-RESERVED0001 ---- (03) | 0000-RESERVED0002 ---- (03) | 0000-RESERVED0003 ---- (03)
     0000-RESERVED0004 ---- (03) | 0000-RESERVED0005 ---- (03)
Misc.
     Hardware number: 3G0 035 466 F
     Workshop System Name: J525
     Dataset Number: V03935433MB
     ASAM Dataset: EV_AMPEthMQB37w
     ASAM Dataset Revision: 001005
Car Info
     Chassis Number: -----------------
Immobilizer
     Immo Challenge: A4C68C3F
VCDS Info:
       Labels: *None
       ROD: EV_AMPEthMQB37w_VW38.rod
;Address 0x51:Electric Drive SW:0ET-907-121-G   HW:0ET-907-121-G
;Component:MEB INV6.0    H10 7260, Coding:
;EV_DMCM21000110ET907121G,001001,EV_DMCM21000110ET907121G.rod
;Tuesday,25,March,2025,12:30:51:58926
;VCID: 44DA22065E15BDCAEBE-8010-R SFD+SFD2
     Identification: RB8-658
     Date: 06.11.24
     Manufacturer number: 1887
     Test stand number: 0803
Flash Status
     01.01.00 00000 000 00000 (OK) | 01.01.00 00000 000 00000 (OK) | 01.01.00 00000 000 00000 (OK) | 01.01.00 00000 000 00000 (OK)
Misc.
     Hardware number: 0ET 907 121 G
     Workshop System Name: J841
     Dataset Number: V03935396ZE
     ASAM Dataset: EV_DMCM21000110ET907121G
Car Info
     Engine code: ECN-
Immobilizer
          Life status: 2
          Identity counter: 1
          Power class: 0
          Configuration status: 4
          Reserved: 0
     Immo Challenge: 3A07BB95
VCDS Info:
       Labels: 0ET-907-INV-V1.clb
       ROD: EV_DMCM21000110ET907121G.rod
;Address 0x52:Door Elect, Pass. SW:1EA-959-592-F   HW:1EA-959-592-F
;Component:TSG BFS       009 0563, Coding:00355320DE00028040800020
;EV_DCU3PasseSideMAXHCONT,001004,EV_DCU3PasseSideMAXHCONT_VWE3.rod
;Tuesday,25,March,2025,12:31:09:58926
     Serial number: 0000542154577
     Date: 15.10.24
     Manufacturer number: 0910
     Test stand number: 11C4
Flash Status
     7200-2V0561VN41S1 0016 (07)
Misc.
     Hardware number: 1EA 959 592 F
     Workshop System Name: J387
     Dataset Number: V03935435GJ
     ASAM Dataset: EV_DCU3PasseSideMAXHCONT
VCDS Info:
       Labels: *None
       ROD: EV_DCU3PasseSideMAXHCONT_VWE3.rod
;Address 0x5F:Information Electr. SW:10C-035-842-A   HW:10C-035-842
;Component:IC3GSF--US    H09 3626, Coding:64101030000000000000000000000000000000000000000000
;EV_MUICASSAFEPart,002001,EV_MUICASSAFEPart_002_VNE4.rod
;Tuesday,25,March,2025,12:31:57:58926
;VCID: 1B68B97A832BA2327A4-804E-R SFD+SFD2
     Identification: WG8-LGM
     Date: 21.09.24
     Manufacturer number: 0032
     Test stand number: 0660
Flash Status
     Programming Attempts(application): 0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0
     720B-SPRACHE00000 1402 (07) | 720C-MMI0SYSTSPRA 3001 (07) | 7230-RESERVED0001 ---- (03) | 7231-RESERVED0002 ---- (03)
     7232-RESERVED0003 ---- (03) | 7233-RESERVED0004 ---- (03) | 7234-RESERVED0005 ---- (03) | 7235-RESERVED0006 ---- (03)
     7236-RESERVED0007 ---- (03) | 7237-RESERVED0008 ---- (03) | 7238-RESERVED0009 ---- (03) | 7239-RESERVED0010 ---- (03)
     723A-RESERVED0011 ---- (03) | 723B-RESERVED0012 ---- (03) | 723C-RESERVED0013 ---- (03) | 723D-RESERVED0014 ---- (03)
     723E-RESERVED0015 ---- (03) | 723F-RESERVED0016 ---- (03) | 7240-RESERVED0017 ---- (03) | 7241-RESERVED0018 ---- (03)
     7242-RESERVED0019 ---- (03) | 7243-RESERVED0020 ---- (03)
Misc.
     Hardware number: 10C 035 842
     Workshop System Name: J794
     Dataset Number: V03935418SE
     ASAM Dataset: EV_MUICASSAFEPart
     ASAM Dataset Revision: 002001
Car Info
VCDS Info:
       ROD: EV_MUICASSAFEPart_002_VNE4.rod
;Address 0x6C:Back-up Cam. SW:1EE-907-556-A   HW:5WA-907-556-D
;Component:TV eEntry     H32 0605, Coding:060300003F140000
;EV_CamSysTVFicosUNECE,002004,EV_CamSysTVFicosUNECE_VWE3.rod
;Tuesday,25,March,2025,12:32:42:58926
     Serial number: FZ6ESP231024000
     Identification: FZ6-S20
     Date: 23.10.24
     Manufacturer number: 0003
     Test stand number: 7704
Flash Status
     7100-VN1EA907556D 50HI (07)
Misc.
     Hardware number: 5WA 907 556 D
     Workshop System Name: J928
     Dataset Number: V03935441LX
     ASAM Dataset: EV_CamSysTVFicosUNECE
     ASAM Dataset Revision: 002004
VCDS Info:
       Labels: *None
       ROD: EV_CamSysTVFicosUNECE_VWE3.rod
;Address 0x6D:Trunk Elect. SW:4KE-959-107-B   HW:4KE-959-107-B
;Component:HDSG-Modul    H08 0342, Coding:6208
;EV_DeckLidCONTIAU536,001006,EV_DeckLidCONTIAU536_001_VWE3.rod
;Tuesday,25,March,2025,12:33:03:58926
     Serial number: A2-C765-4922-2
     Identification: CU5-SIB
     Revision: --------
     Date: 03.11.24
     Manufacturer number: 1098
     Test stand number: 1566
Flash Status
     Programming Attempts(application): 1/1/2
     Flash Tool Code(data): 00532 790 00000
     7100-VN41SECLNOLE 8FA1 (07)
Misc.
     Hardware number: 4KE 959 107 B
     Workshop System Name: J605
     Dataset Number: V03935420NU
     ASAM Dataset: EV_DeckLidCONTIAU536
     ASAM Dataset Revision: 001006
Car Info
VCDS Info:
       Labels: .*5Q0-959-107.clb
       ROD: EV_DeckLidCONTIAU536_001_VWE3.rod
;Address 0x75:Telematics SW:14A-035-285-A   HW:14A-035-285
;Component:OCU4MEB_UNECE H11 0554, Coding:06020700010000000000010013000000101112111012000010
;EV_OCUGen4UNECE,001050,EV_OCUGen4UNECE_VWE3.rod
;Tuesday,25,March,2025,12:33:49:58926
;VCID: 1E6EB06E9039B71A9DA-804A-R SFD+SFD2
     Serial number: 0000000407VIHJJ
     Identification: LG5-LGH
     Date: 27.07.24
     Manufacturer number: 1006
     Test stand number: 0273
Flash Status
     Programming Attempts(application): 1/2/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/1/0/0/1/1
     7101-AUDIOPARAM01 U140 (07) | 7201-DTCMASKING01 0103 (07) | 7100-MANEMECALL01 0409 (07) | 7203------------- ---- (03)
     7202------------- ---- (03) | 7103------------- ---- (03) | 7102------------- ---- (03) | 7104-BATSOHPARA01 0001 (07)
Misc.
     Hardware number: 14A 035 285
     Workshop System Name: J949
     Dataset Number: V03935436CE
     ASAM Dataset: EV_OCUGen4UNECE
     ASAM Dataset Revision: 001050
Car Info
Immobilizer
          Life status: 2
          Identity counter: 1
          Power class: 0xE8
          Reserved: 0
     Immo Challenge: 58AA0205
VCDS Info:
       Labels: *None
       ROD: EV_OCUGen4UNECE_VWE3.rod
;Address 0x7E:Ctrl Head Dash SW:10A-920-320-D   HW:10A-920-320-D
;Component:FAHRERDISPLAY 031 0650, Coding:267001
;EV_DashBoardLGMEB,002032,EV_DashBoardLGMEB_002_VWE3.rod
;Tuesday,25,March,2025,12:34:05:58926
;VCID: 167EA84E7809FF5A45A-8042-R SFD
     Serial number: 4G1XF446-D05622
     Date: 25.06.24
     Manufacturer number: 1008
     Test stand number: 0314
Flash Status
     Flash Date: 00.01.01 00000 000 00000 (OK) | 00.00.00 00000 000 00000 (OK)
Misc.
     Hardware number: 10A 920 320 D
     Workshop System Name: J1254
     Dataset Number: V03935392XE
     ASAM Dataset: EV_DashBoardLGMEB
     ASAM Dataset Revision: 002032
VCDS Info:
       Labels: .*10A-920-320.clb
       ROD: EV_DashBoardLGMEB_002_VWE3.rod
;Address 0x8116:Snd enhanct 2 SW:1T3-035-335-B   HW:1EA-035-335
;Component:E_SOUND_SG    H06 0007, Coding:
;EV_ESoun2HarmaMEBUNECE,001003,EV_ESoun2HarmaMEBUNECE.rod
;Tuesday,25,March,2025,12:39:09:58926
     Serial number: JTK072291024953
     Identification: JTK-072
     Date: 29.10.24
     Manufacturer number: 9531
     Test stand number: 0B2A
Flash Status
Misc.
     Hardware number: 1EA 035 335
     Workshop System Name: J943
     Dataset Number: -----------
     Dataset Version: ----
     ASAM Dataset: EV_ESoun2HarmaMEBUNECE
     ASAM Dataset Revision: 001003
VCDS Info:
       Labels: None
       ROD: EV_ESoun2HarmaMEBUNECE.rod
;Address 0x8123:App server 1 system 1 adaptive SW:V04-007-003-LE   HW:
;Component:ICAS1 Sys_Ada 0254, Coding:
;EV_AppServ1Sys1ICAS1UNECE,001002,EV_AppServ1Sys1ICAS1UNECE_VWE3.rod
;Tuesday,25,March,2025,12:39:36:58926
;VCID: 75BC8FC2454F5442AC0-8020-R SFD+SFD2
     Date: 16.10.24
Flash Status
     Programming Attempts(application): 1/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0
     7224-0137ECTP0004 V00D (07) | 7225-0059DNHGEN05 0101 (07) | 7226-0059DNHNO105 0101 (07) | 7227-0059DNHNO205 0101 (07)
     7228-0059DNHCHA05 0101 (07) | 7229-0059DNHCLA05 0101 (07) | 722A-0059DNHTRI05 0101 (07)
Misc.
     Hardware number:
     Workshop System Name: SWC4
     Dataset Number: V03935439BB
     ASAM Dataset: EV_AppServ1Sys1ICAS1UNECE
     ASAM Dataset Revision: 001002
Car Info
VCDS Info:
       Labels: V04-007-XXX-SWC4.clb
       ROD: EV_AppServ1Sys1ICAS1UNECE_VWE3.rod
;Address 0x8124:App server 1 system 2 Java SW:V04-007-003-LF   HW:
;Component:ICAS1 Sys_Jav 0254, Coding:
;EV_AppServ1Sys2ICAS1UNECE,001002,EV_AppServ1Sys2ICAS1UNECE_VWE3.rod
;Tuesday,25,March,2025,12:40:26:58926
;VCID: 76BE88CE58495F5AA5A-8022-R SFD+SFD2
     Date: 16.10.24
Flash Status
     Programming Attempts(application): 1/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0
Misc.
     Hardware number:
     Workshop System Name: SWC5
     Dataset Number: V03935439BA
     ASAM Dataset: EV_AppServ1Sys2ICAS1UNECE
Car Info
VCDS Info:
       Labels: V04-007-XXX-SWC5.clb
       ROD: EV_AppServ1Sys2ICAS1UNECE_VWE3.rod
;Address 0x8125:App server 3 system 1 infotaint. SW:V04-007-003-RH   HW:
;Component:IC3GIVI-S--US 3626, Coding:64101030000000000000000000000000000000000000000000
;EV_MUICASIVIPart,003001,EV_MUICASIVIPart_003_VWE3.rod
;Tuesday,25,March,2025,12:42:22:58926
;VCID: 7EAE90EE7079171AFDA-802A-R SFD+SFD2
     Date: 21.09.24
Flash Status
     Programming Attempts(application): 0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0
     Flash Date: 0000.00.00
     7201-AP0SOUND0000 ---- (03) | 7202-AP0SOUND0ANN ---- (03) | 7203-AP0SOUND0CAB ---- (03) | 7204-AP0SOUND0CON ---- (03)
     720E-EA0SO0ACO0PS ---- (03) | 7206-LS0CON001008 DFLT (07) | 720A-DAB0FREQ0TAB ---- (03) | 7210-SPEECHSE0001 U4U0 (07)
     7211-SPEECHSE0002 U4U0 (07) | 7212-SPEECHSE0003 U4U0 (07) | 7213-SPEECHSE0004 U4U0 (07) | 7214-SPEECHSE0005 ---- (07)
     7215-SPEECHSE0006 U4U0 (07) | 7216-SPEECHSE0007 U4U0 (07) | 7217-SPEECHSE0008 ---- (07) | 720D-GESCHWABSCHW US11 (07)
     7221-ARCVEHICLEIN ---- (03) | 7250-RESERVED0001 ---- (03) | 7251-RESERVED0002 ---- (03) | 7252-RESERVED0003 ---- (03)
     7253-RESERVED0004 ---- (03) | 7254-RESERVED0005 ---- (03) | 7255-RESERVED0006 ---- (03) | 7256-RESERVED0007 ---- (03)
     7257-RESERVED0008 ---- (03) | 7258-RESERVED0009 ---- (03) | 7259-RESERVED0010 ---- (03) | 725A-RESERVED0011 ---- (03)
     725B-RESERVED0012 ---- (03) | 725C-RESERVED0013 ---- (03) | 725D-RESERVED0014 ---- (03) | 725E-RESERVED0015 ---- (03)
     725F-RESERVED0016 ---- (03) | 7260-RESERVED0017 ---- (03) | 7261-RESERVED0018 ---- (03) | 7262-RESERVED0019 ---- (03)
Misc.
     Hardware number:
     Workshop System Name: SWC6
     Dataset Number: V03935442BN
     ASAM Dataset: EV_MUICASIVIPart
     ASAM Dataset Revision: 003001
Car Info
Immobilizer
     Immo Challenge: 08101F89
VCDS Info:
       Labels: .*V04-007-XXX-SWC6.clb
       ROD: EV_MUICASIVIPart_003_VWE3.rod
;Address 0x8128:Light line display SW:1T3-919-451-G   HW:1T3-919-451-G
;Component:ID_Light_GA   033 0074, Coding:
;EV_SmartLight1MEBGA,001014,EV_SmartLight1MEBGA.rod
;Tuesday,25,March,2025,12:42:35:58926
;VCDS Version: Release 25.3.0 (x64)  Data version: 20250311 DS365.0
;VCID: 3C2A5AE626E5C50A93E-8068-R SFD+SFD2
     Identification: GAJ-847
     Date: 08.11.24
     Manufacturer number: 6097
     Test stand number: 0259
Flash Status
     24.10.18 00000 000 00000 (OK) | 24.10.18 00000 000 00000 (OK) | 24.10.18 00000 000 00000 (OK)
Misc.
     Hardware number: 1T3 919 451 G
     Workshop System Name: J145
     ASAM Dataset: EV_SmartLight1MEBGA
VCDS Info:
       Labels: 1T3-919-451.clb
       ROD: EV_SmartLight1MEBGA.rod
;Address 0x8C:HV Battery SW:0Z1-915-184-AE   HW:0Z1-915-184-D
;Component:J840 K8C  BMC 010 1141, Coding:
;EV_BMCeVWBSMEB,003018,EV_BMCeVWBSMEB_003_VWE3.rod
;Tuesday,25,March,2025,12:35:42:58926
;VCID: 7DAC97E27D7F0C02E40-8028-R
     Serial number: 000000201024030
     Identification: JCK-V02
     Date: 20.10.24
     Manufacturer number: 0303
     Test stand number: 1231
Flash Status
     Programming Attempts(application): 0/0/0/0/0/0/0/0/7/7/7/7
     24.11.22 00174 790 00000 (OK) | 24.11.22 00174 790 00000 (OK) | 24.11.22 00174 790 00000 (OK) | 24.11.22 00174 790 00000 (OK)
     7100-89K1043CA111 0171 (07) | 7101-HEIZKUEHYYYY 0200 (07) | 7102-C2N091251221 4042 (07) | 7103-EOBDYYYYYYYY 0200 (07)
Misc.
     Hardware number: 0Z1 915 184 D
     Workshop System Name: J840
     Dataset Number: V03935430CT
     ASAM Dataset: EV_BMCeVWBSMEB
     ASAM Dataset Revision: 003018
Immobilizer
     Immo Challenge: B22E16B4
VCDS Info:
       Labels: 0Z1-915-184.clb
       ROD: EV_BMCeVWBSMEB_003_VWE3.rod
;Address 0xA5:Frt Sens. Drv. Assist SW:1EA-980-653-E   HW:1EA-980-653-A
;Component:MEB MFK 4.1   H08 5556, Coding:010A302E1F4500F83724301C4000000000000000000000000000000000000000
;EV_MFK41ValeoMEB,001080,EV_MFK41ValeoMEB_VWE3.rod
;Tuesday,25,March,2025,12:36:56:58926
     Identification: VR6-002
     Date: 21.08.24
     Manufacturer number: FA05
     Test stand number: 0493
Flash Status
     00.01.01 00000 000 00000 (OK) | 00.01.01 00000 000 00000 (OK) | 00.01.01 00000 000 00000 (OK) | 24.11.22 00176 790 00000 (OK)
     7100-VN41S1EUBNAR 3512 (07)
Misc.
     Hardware number: 1EA 980 653 A
     Workshop System Name: R242
     Dataset Number: V03935445AY
     ASAM Dataset: EV_MFK41ValeoMEB
     ASAM Dataset Revision: 001080
Car Info
Immobilizer
     Immo Challenge: 357945AE
VCDS Info:
       Labels: *1EA-980-65X-V2.clb
       ROD: EV_MFK41ValeoMEB_VWE3.rod
;Address 0xBE:Slid. Door Rear Left SW:1N3-959-244-B   HW:1N3-959-244-B
;Component:Slidingdoor_d H04 0028, Coding:D600
;EV_SlideDoorDriveHufIDBuz,002110,EV_SlideDoorDriveHufIDBuz_002.rod
;Tuesday,25,March,2025,12:37:12:58926
;VCID: 353C4FC205CF14426C0-8060-R
     Serial number: 97100269
     Identification: HUF-001
     Date: 04.11.24
     Test stand number: 0090
Flash Status
     00.00.00 00000 000 00000 (OK) | --.--.-- 2097151 1023 131071 (OK) | --.--.-- 2097151 1023 131071 (OK)
     7200------------- 0028 (07) | 7201------------- 1510 (07)
Misc.
     Hardware number: 1N3 959 244 B
     Workshop System Name: J926
     Dataset Number: V03935426PK
     Dataset Version: 1510
     ASAM Dataset: EV_SlideDoorDriveHufIDBuz
     ASAM Dataset Revision: 002110
VCDS Info:
       Labels: .*1N3-959-244.clb
       ROD: EV_SlideDoorDriveHufIDBuz_002.rod
;Address 0xBF:Slid. Door Rear Right SW:1N3-959-244-B   HW:1N3-959-244-B
;Component:Slidingdoor_p H04 0028, Coding:D600
;EV_SlideDoorPasseHufIDBuz,002110,EV_SlideDoorPasseHufIDBuz_002.rod
;Tuesday,25,March,2025,12:37:29:58926
     Serial number: 97100519
     Date: 30.10.24
     Test stand number: 0514
Flash Status
Misc.
     Workshop System Name: J927
     Dataset Number: V03935426PL
     ASAM Dataset: EV_SlideDoorPasseHufIDBuz
VCDS Info:
       ROD: EV_SlideDoorPasseHufIDBuz_002.rod
;Address 0xC0:Act. for Ext. Noise SW:1T3-035-335-A   HW:1EA-035-335
;Component:E_SOUND_SG    H06 0006, Coding:
;EV_ESounHarmaMEBUNECE,001006,EV_ESounHarmaMEBUNECE_VWE3.rod
;Tuesday,25,March,2025,12:37:38:58926
;VCID: 2C0A6AA6D685558A03E-8078-R
     Serial number: JTK072281024953
     Date: 28.10.24
     Test stand number: 0CD0
Flash Status
Misc.
     ASAM Dataset: EV_ESounHarmaMEBUNECE
VCDS Info:
       Labels: 1EA-035-335.clb
       ROD: EV_ESounHarmaMEBUNECE_VWE3.rod
;Address 0xC002:SW Cluster Embedded SW:V04-007-003-LG   HW:
;Tuesday,25,March,2025,12:43:28:58926
     Date: 16.10.24
Flash Status
     Programming Attempts(application): 1/1/1/1/0/0/0/1/1/1/0/0/0/0/0/0/0/0/0/0/1/0
     7210-0087DLIAFS03 W084 (07) | 720A-0087DLIMX104 W030 (07) | 720B-0087DLIMX204 W030 (07) | 720C-0087DLIMX304 W030 (07)
     7212-0138ECP00004 V00A (07)
Misc.
     Hardware number:
     Workshop System Name: SWC2
     Dataset Number: V03935439BG
     ASAM Dataset: EV_SWCLEmbed1ICAS1UNECE
Car Info
VCDS Info:
       VCID: 77A085CA5F432652BEC-8022-R SFD+SFD2
       Labels: V04-007-XXX-SWC2.clb
       ROD: EV_SWCLEmbed1ICAS1UNECE_VWE3.rod
;Address 0xC003:SW Cluster Housekeeping SW:V04-007-003-LH   HW:
;Tuesday,25,March,2025,12:43:42:58926
     Date: 16.10.24
Flash Status
Misc.
     Hardware number:
     Workshop System Name: SWC3
     ASAM Dataset: EV_SWCLHouse1ICAS1UNECE
Car Info
VCDS Info:
       Labels: V04-007-XXX-SWC3.clb
       ROD: EV_SWCLHouse1ICAS1UNECE.rod
;Address 0xC6:Batt. Chrg. SW:1EK-915-692-J   HW:1EK-915-692-H
;Component:OCDC Gen4+    H03 2207, Coding:308010
;EV_OCDCXPHASERB8MEBB,002001,EV_OCDCXPHASERB8MEBB_002_VWE3.rod
;Tuesday,25,March,2025,12:38:02:58926
;VCID: 4BC8093A734B72B22A4-801E-R SFD+SFD2
     Revision: 00H03000
     Date: 17.10.24
     Manufacturer number: 1857
     Test stand number: 1530
Flash Status
Misc.
     Hardware number: 1EK 915 692 H
     Workshop System Name: J1050
     ASAM Dataset: EV_OCDCXPHASERB8MEBB
VCDS Info:
       Labels: .*1EA-915-692.clb
       ROD: EV_OCDCXPHASERB8MEBB_002_VWE3.rod
;Address 0xCA:Sunroof SW:14A-907-594-A   HW:4K0-907-594
;Component:SAD_STG_1     011 0030, Coding:01000374180F
;EV_SunRoofCONTIPO513,002004,EV_SunRoofCONTIPO513.rod
;Tuesday,25,March,2025,12:38:14:58926
;VCID: 290493B2D97740A2F88-807C-R
     Identification: CNK-KAU
     Date: 07.10.24
     Test stand number: 1986
Flash Status
     Programming Attempts(application): 0/0/2
     00.01.01 00000 000 00000 (OK) | 00.01.01 00000 000 00000 (OK) | 24.11.22 00032 790 00000 (OK)
     Flash Tool Code(data): 00032 790 00000
     7100-74180FVN41S0 0420 (07)
Misc.
     Hardware number: 4K0 907 594
     Workshop System Name: J245
     Dataset Number: V03935394MS
     ASAM Dataset: EV_SunRoofCONTIPO513
VCDS Info:
       Labels: *None
       ROD: EV_SunRoofCONTIPO513.rod
;Address 0xD6:Light Ctrl Left 2 SW:992-941-572-AG   HW:992-941-572-A
;Component:LED1L         H17 9104, Coding:
;EV_LLPGen3LKEBODPO68X,002003,EV_LLPGen3LKEBODPO68X_002_VW27.rod
;Tuesday,25,March,2025,12:38:32:58926
;VCID: 6882D6B602FDB9AA276-803C-R
     Identification: A5G-001
     Date: 22.07.24
     Manufacturer number: 7235
     Test stand number: 2296
Flash Status
     24.07.22 00000 000 00000 (OK) | 12.0B.07 394790 281 78901 (OK) | 00.01.01 00000 000 00000 (nOK:01)
     7100-VN41STOPVP28 VP28 (07)
Misc.
     Hardware number: 992 941 572 A
     Workshop System Name: A31
     ASAM Dataset: EV_LLPGen3LKEBODPO68X
     ASAM Dataset Revision: 002003
VCDS Info:
       Labels: 7PP-941-572.clb
       ROD: EV_LLPGen3LKEBODPO68X_002_VW27.rod
;Address 0xD7:Light Ctrl Right 2 SW:992-941-572-AG   HW:992-941-572-A
;Component:LED1R         H17 9104, Coding:
;EV_LLPGen3RKEBODPO68X,002003,EV_LLPGen3RKEBODPO68X_002_VW27.rod
;Tuesday,25,March,2025,12:38:50:58926
     Date: 05.08.24
     Test stand number: 1576
Flash Status
     Programming Attempts(application): 1/0/3
     24.08.05 00000 000 00000 (OK) | 12.0B.07 394790 281 78901 (OK) | 00.01.01 00000 000 00000 (nOK:01)
Misc.
     Workshop System Name: A27
     ASAM Dataset: EV_LLPGen3RKEBODPO68X
VCDS Info:
       ROD: EV_LLPGen3RKEBODPO68X_002_VW27.rod
;Address 0xDE:Charger 1 for mobile dev SW:3P0-035-502-B   HW:3P0-035-502
;Component:COUPLING BOX  004 0170, Coding:400080
;EV_DualCouplBoxSK336,001006,EV_DualCouplBoxSK336.rod
;Tuesday,25,March,2025,12:39:00:58926
;VCID: 241A8286BE559DCACBE-8070-R SFD+SFD2
     Serial number: 324000000000059
     Identification: HBM-028
     Date: 25.10.24
     Manufacturer number: 0071
     Test stand number: 5627
Flash Status
Misc.
     Hardware number: 3P0 035 502
     Workshop System Name: J0000
     Dataset Number: V03935426MT
     ASAM Dataset: EV_DualCouplBoxSK336
VCDS Info:
       Labels: *None
       ROD: EV_DualCouplBoxSK336.rod
