2023 VW Taigo unable to reset codes after crash and airbag deployment and seat belt tensioners firing.
steviewatt
Scotland
C?ID=610675
Hi my name is Steven i'm from Glasgow in Scotland i need a bit of advice regarding resetting crash data on my VW.
Any help or advice would be greatly appreciated.
car had a front impact and require new seat belts and steering wheel airbag due to them deploying after the crash.
Friday,21,March,2025,19:09:32:43198
VCDS Version: 25.3.0.4 (x64)  HEX-V2 CB: 0.4660.5
Data version: 20250311 DS365.0
VIN: WVGZZZCS8RY025818   License Plate: PY73AOF
Chassis Type: CS-VW27 (2Q0)
Scan: 01 03 08 09 10 13 15 17 19 3C 44 5F 75 A5
VIN: WVGZZZCS8RY025818   Mileage: 4818km-2993miles
13-Auto Dist. Reg -- Status: Cannot be reached 0100
Address 01: Engine (2D2D2-DLAA)       Labels: None
   Part No SW: 05C 906 032 M    HW: 05C 907 394 D
   Component: R3 1.0l TFS   H01 2365
   Revision: 42101001
   Coding: 0119001223440D0800100000000000000000000000000000
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_ECM10TFS03005C906032M 002012
   ROD: EV_ECM10TFS030_VW27.rod
   VCID: 2908227D7973A9A2F89-807C
   VINID: 9E65EAAAA4E3222A4008520120994ACDDF
25812 - No Communications with Cruise Control (Front) Distance Sensor
          U0235 00 [00100111] - -
          [Lost Communication WithCruise Control Front Distance Range Sensor]
                    Mileage: 4818 km
                    Date: 2025.03.18
                    Time: 16:51:58
                    Engine speed: 0.00 /min
                    Coolant temperature: 8 °C
                    Intake air temperature: 10 °C
                    Voltage terminal 30: 13.359 V
                    Ignition timing adjustment cylinder 1: 0.0 Degrees
                    O2 sens. 1 bank 1 upstrm oxi cat: raw value: 1.000 counts
                    Primary injection: quantity setpoint: 0.00 mg/stroke
                    Fuel high pressure sensor: actual value: 4.3 bar
                    O2 sen. bank 1 dwnstrm oxi cat: elec. corrected Urie sen. value: 0.464 V
                    IN_Injection_speed: 0.00 /min
                    Camshaft adjustment: exhaust: bank 1: actual value: 0.0 °
                    Camshaft adjustment intake bank 1: actual value: 0.0 °
                    Throttle valve position (absolute): 17.3 %
                    Setpoint generation interior torque: 0.0 Nm
                    Battery voltage: 13.351 V
                    Accelerator pedal travel: raw value: 0.00 %
                    Control Module temperature: 26.0 °C
                    Engine oil temperature: 6.9 °C
38535 - Implausible Data Received from ESP Control Module
          U0416 00 [00100110] - -
                    Coolant temperature: 10 °C
                    Intake air temperature: 12 °C
                    Voltage terminal 30: 13.476 V
                    Fuel high pressure sensor: actual value: 4.0 bar
                    O2 sen. bank 1 dwnstrm oxi cat: elec. corrected Urie sen. value: 0.468 V
                    Throttle valve position (absolute): 12.9 %
                    Battery voltage: 13.429 V
                    Control Module temperature: 8.7 °C
                    Engine oil temperature: 10.6 °C
Readiness: N/A
Address 03: ABS Brakes (J104)       Labels:. 2Q0-614-517.clb
   Part No SW: 2Q0 614 517 BB    HW: 2Q0 614 517 N
   Component: ESC_base_vFGS H23 0272
   Serial number: 08502683231012 Dataset Number: V03935359BA 0001
   Coding: 89054C603D4391B23204BC1712E211A649344D06224A24484C54625545488865922CB26044522412322A46AAA251D64F7F8A6BF2FE90AC90093509
   ASAM Dataset: EV_Brake1BOSCHESPMQBA0 005001
   ROD: EV_Brake1BOSCHESPMQBA0_005_VW27.rod
   VCID: 6FBC0C658717879266D-803A
1152 - Databus
          [ComScl_ACC_10_Timeout]
                    Reset counter: 107
                    Mileage: 4818 km
                    Date: 2025.03.18
                    Time: 16:51:56
1141 - Implausible Data Received from Steering Angle Sensor Module (G85)
          U0428 00 [10001001] - -
          [Scl_LWI_Lenkradwinkel_Error]
                    Reset counter: 107
                    Mileage: 4818 km
                    Date: 2025.03.18
                    Time: 16:51:56
Address 08: Auto HVAC (E87)       Labels:* Redir Fail!
   Part No SW: 2G2 820 045 P    HW: 2G2 820 045 P
   Component: SG_AC_Manuell H70 0601
   Serial number: 00000000000000 Dataset Number: V03935354NV 0001
   Coding: 012100000800010001000400020000000010000000000000000000000000
   ASAM Dataset: EV_ACManuePrehMQBA0 001013
   ROD: EV_ACManuePrehMQBA0.rod
   VCID: 2E02D161409DCE9A2DB-807A
   Part No SW: 2Q0 937 089 E    HW: 2Q0 937 089 C
   Component: BCM A0 Std    H12 0963
   Serial number: 02102327101164 Dataset Number: V03935379SL 0001
   ASAM Dataset: EV_BCMA0 208001
   ROD: EV_BCMA0_208_VW27.rod
   VCID: 3C26EB2986E12C0A93F-8068
   Subsystem 1 - Part No SW: 5Q0 955 559 C    HW: 5Q0 955 559 C  Labels: 5Q0-955-547.CLB
   Component: RLS  054 0206
   Serial number: SAY23M09D20H14M43S12
   Coding: 0018DD
   Driver door control module:
   Subsystem 2 - Part No SW: 2Q2 959 405 G    HW: 2Q2 959 163 F
   Component: FHSG_DRV  003 0004
   Serial number: 00000000000074679654
   Coding: 1F0047
   Front passenger door control module:
   Subsystem 3 - Part No SW: 2Q2 959 406 G    HW: 2Q2 959 164 F
   Component: FHSG_PSG  003 0004
   Serial number: 00000000000074835119
   Coding: 058047
   Subsystem 4 - Part No SW: 5Q0 951 172 A    HW: 5Q0 951 172 B
   Component: Sensor, DWA  005 0403
   Serial number: 0000000000000JQD51YV
   Serial number: 00000000000051962406
   Subsystem 6 - Part No SW: 5Q0 959 408 D    HW: 5Q0 959 164 C
   Component: FOND_FHSG_DRV  007 0011
   Serial number: 00000000000075102882
   Coding: 1F0000
   Subsystem 7 - Part No SW: 5Q0 959 407 D    HW: 5Q0 959 163 C
   Component: FOND_FHSG_PSG  007 0011
   Serial number: 00000000000075062683
   Coding: 070000
535060 - Databus
          [FLA_01 Datenbus empfangener Fehlerwert]
                    Reset counter: 107
                    Mileage: 4818 km
                    Date: 2025.03.18
                    Time: 16:52:02
                    Zusaetzliche Umgebungsdaten-Terminal 15 status: On
                    Zusaetzliche Umgebungsdaten-Terminal 50 status: OFF
                    Zusaetzliche Umgebungsdaten-Low beam: Not operated
                    Zusaetzliche Umgebungsdaten-OFF: Not operated
                    Zusaetzliche Umgebungsdaten-Outside temperature: -50.0 °C
                    Zusaetzliche Umgebungsdaten-Automatic high beam assist: Not operated
                    Zusaetzliche Umgebungsdaten-Position lamps: Not operated
                    Zusaetzliche Umgebungsdaten-Parking light left: Not operated
                    Zusaetzliche Umgebungsdaten-Parking light right: Not operated
                    Zusaetzliche Umgebungsdaten-CAN-Bus_aktiv: On
                    Zusaetzliche Umgebungsdaten-last wakeup: keine Stoerschutzursache
                    Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (CAN): OFF
                    Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (HW): OFF
                    Zusaetzliche Umgebungsdaten-voltage measurement: 13.1 V
590853 - Window Regulator; Front Drivers Side
          B14D1 54 [00001001] - Missing Calibration / Basic Setting
                    Reset counter: 107
                    Mileage: 4818 km
                    Date: 2025.03.18
                    Time: 16:51:57
                    Zusaetzliche Umgebungsdaten-voltage measurement: 13.2 V
   Part No SW: 5QA 919 298 K    HW: 5QA 919 298 A
   Component: PLA 3.0 12K   H10 0075
   Serial number: 000150057023248 Dataset Number:  V03935362N 0001
   Coding: 8371065841
   ASAM Dataset: EV_EPHVA2CAU3700000 009055
   ROD: EV_EPHVA2CAU3700000_010_VW37.rod
   VCID: 58EE57B91299E02A977-800C
13679372 - Databus
          [Steuergerät für Lenkhilfe-J500 - LWI_01.LWI_Lenkradwinkel - Fehlerspeicher auslesen]
                    Reset counter: 107
                    Mileage: 4818 km
                    Date: 2025.03.18
                    Time: 16:51:56
12727553 - Databus
          [Steuergerät für Abstandsregelung - Gateway_79.ACC_02_alt - kein Signal/keine Kommunikation]
                    Reset counter: 107
                    Mileage: 4818 km
                    Date: 2025.03.18
                    Time: 16:51:58
13637426 - Databus
                    Reset counter: 107
                    Mileage: 4818 km
                    Date: 2025.03.18
                    Time: 16:51:57
13679386 - Databus
          [Steuergerät für Lenkhilfe-J500 - LH_EPS_03. EPS_Berechneter_LW - Fehlerspeicher auslesen]
                    Reset counter: 107
                    Mileage: 4818 km
                    Date: 2025.03.18
                    Time: 16:51:56
13688835 - Databus
          [Steuergerät für Rear Cross Traffic Alert - RCTA_01.RCTA_Status - Fehlerspeicher auslesen]
                    Reset counter: 107
                    Mileage: 4818 km
                    Date: 2025.03.18
                    Time: 16:51:58
Address 13: Auto Dist. Reg
Address 15: Airbags (J234)       Labels:| 2Q0-959-655.clb
   Part No SW: 2Q0 959 655 BJ    HW: 2Q0 959 655 BJ
   Component: VW22Airbag    021 0412
   Revision: --------    Dataset Number: V03935372YS 0001
   Coding: 88CCCCC0800000035C5400CF008C40FC0065
   ASAM Dataset: EV_AirbaVW22BPAVW27X 001036
   ROD: EV_AirbaVW22BPAVW27X.rod
   VCID: 065249C188ADA6DAB5B-8052
   Left seat belt tensioner:
   Component: BeltPretRevFL  106 1062
   Serial number: 2G1857705H0285X01386
   Coding: 802006
   Right seat belt tensioner:
   Component: BeltPretRevFR  106 1062
   Serial number: 2G2857706F0276X01405
   Coding: 802006
   Subsystem 3 - Part No SW: -----------    HW: 442 061 410 23
   Serial number: 3577Y5099124F7D0D19F
   Subsystem 4 - Part No SW: -----------    HW: 442 061 410 23
   Serial number: 3587Y50C5124ACB1A19B
   Subsystem 5 - Part No SW: -----------    HW: 442 0B0 310 23
   Serial number: 35177321466507D60763
   Subsystem 6 - Part No SW: -----------    HW: 442 0B0 310 23
   Serial number: 35277301866507D957CK
   Subsystem 7 - Part No SW: -----------    HW: 442 131 610 23
   Component: FrontSensor_D  290 118A
   Serial number: 355AG13B0ADEE867828F
1050117 - Databus
          [NWD: 0x086 LWI_01 error value LWI_Lenkradwinkel]
                    Reset counter: 107
                    Mileage: 4818 km
                    Date: 2025.03.18
                    Time: 16:51:56
1054464 - Databus
          [NWD: 0x117 ACC_10 Timeout]
                    Reset counter: 107
                    Mileage: 4818 km
                    Date: 2025.03.18
                    Time: 16:51:56
1060608 - Databus
          [NWD: 0xTBD SDF_PSF_01 Timeout]
                    Reset counter: 107
                    Mileage: 4818 km
                    Date: 2025.03.18
                    Time: 16:51:56
Address 17: Instruments (J285)       Labels: 5G0-920-XXX-17.clb-SRI3
   Part No SW: 2GP 920 310 B    HW: 2GP 920 310 B
   Component: KOMBI         066 4848
   Coding: 24A40000658800080188620B1001000000600404
   ASAM Dataset: EV_DashBoardJCIMQBAB 010007
   ROD: EV_DashBoardJCIMQBAB_010_VW27.rod
   VCID: 3A2AED318CD5123A813-806E
No ASAM data for: "EV_DashBoardJCIMQBAB" (VW27)
16776960 - ROD - Unknown Error Code
          - 00 [00001001]
16776961 - ROD - Unknown Error Code
          - 00 [00001001]
16777028 - ROD - Unknown Error Code
          - 00 [00001001]
                    Mileage: 4818 km
                    Date: 2025.03.18
                    Time: 16:51:58
Address 19: CAN Gateway (J533)       Labels:* Redir Fail!
   Part No SW: 2Q0 909 901 F    HW: 2Q0 937 089 C
   Component: GW MQB A0     H12 0963
   Serial number: 02102327101164 Dataset Number: V03935391FG 0001
   Coding: 030900046F0857002200005C080F00010001270000000000000000000000
   GVL: 01443C000000000040C080008000480000000000000000000000000000000000
   ASAM Dataset: EV_GatewA0 013028
   ROD: EV_GatewA0_VW27.rod
   VCID: 3530FE0DA5CBFD426C1-8060
   Generator:
   Component: 5-00-14-00-04
   Subsystem 2 - Part No SW: 3G0 959 442 AE    HW: 3G0 959 442 AE  Labels: 3C8-959-537.CLB
   Component: E221__MFL-PR6  H07 0120
   Serial number: PR6-0440071233233482
   Coding: 2C2F00
   Subsystem 3 - Part No SW: 2Q0 915 181 B    HW: 2Q0 915 181 B
   Component: J367-BDMBOSCH  H03 2012
   Serial number: 103F724B
131671 - No Communications with Cruise Control (Front) Distance Sensor
          U0235 00 [00001001] - -
          [Timeout Knoten 0x57 / 13 - Abstandsdistanzregelung]
                    Reset counter: 107
                    Mileage: 4818 km
                    Date: 2025.03.18
                    Time: 16:51:56
                    Terminal 30 power supply: 13.2 V
                    Terminal 15: On
8526363 - Crash Shut-Down
          B189C F0 [00001001] - Active
                    Reset counter: 107
                    Mileage: 4818 km
                    Date: 2025.03.18
                    Time: 16:51:56
                    Terminal 15: On
Address 3C: Lane Change (J1086)       Labels:* Redir Fail!
   Part No SW: 2Q0 907 686 B    HW: 2Q0 907 686 B
   Component: HRE3_Kl15_Mst H06 0150
   Serial number: 14520031424153  Dataset Number: V03935354HT 0001
   Coding: 92954640
   ASAM Dataset: EV_HREntryHellaGen3Kl15 002001
   ROD: EV_HREntryHellaGen3Kl15_002_VW27.rod
   VCID: 3928F23D89D31922889-806C
   Subsystem 1 - Part No SW: 2Q0 907 685 B    HW: 2Q0 907 685 B
   Component: HRE3_Kl15_Slv  H06 0150
   Serial number: 14520031717492
2240530 - Databus
          [databus error value received - Parkhilfe_01 - PH_Tongeber_H_verfuegbar]
                    Mileage: 4818 km
                    Date: 2025.03.18
                    Time: 16:51:57
2240529 - Databus
          [databus error value received - Parkhilfe_01 - PH_Systemzustand]
                    Mileage: 4818 km
                    Date: 2025.03.18
                    Time: 16:51:57
2236417 - Databus
          [databus unreasonable message - LWI_QBit_Lenkradwinkel]
                    Mileage: 4818 km
                    Date: 2025.03.18
                    Time: 16:51:57
2240527 - Databus
          [databus error value received - LWI_01 - LWI_Lenkradwinkel]
                    Mileage: 4818 km
                    Date: 2025.03.18
                    Time: 16:51:57
Address 44: Steering Assist (J792)       Labels:| 2Qx-909-144-V1.clb
   Part No SW: 2Q2 909 144 AB    HW: 2Q2 909 144 AB
   Component: TRW_G4L_MQBA0 623 6050
   Serial number: 03936904CB4P250 Dataset Number: V03935378L  0001
   Coding: 010001010100000001010201010001000000010101
   ASAM Dataset: EV_SteerAssisTRWG4LMQBA0 011016
   ROD: EV_SteerAssisTRWG4LMQBA0.rod
   VCID: 73B40015EB3FA372825-8026
15788544 - Crash Shut-Down Activated
          P1609 00 [00001000] - -
          [DEM_FRONT_CRASH_FAULT]
                    Mileage: 4818 km
                    Date: 2025.03.18
                    Time: 16:51:56
                    Engine speed: 0 /min
                    System status: Malfunction
                    Voltage terminal 30: 13.14 V
                    Power steering current consumption: 0.5 A
                    max.value: 0.5 A
                    End stage temperature: 10 °C
                    Steering assistance: engine output: 100 %
                    Engine angle: 65535 °
                    Electric motor speed: 45535 /min
                    Steering assistance: target engine torque: 0.0 Nm
                    Steering torque: 0.0 Nm
Address 5F: Information Electr. (J794)       Labels:| 3G5-035-MIB-HGH3.clb
   Part No SW: 3G5 035 820 P    HW: 3G5 035 820 P
   Component: MU-O-ND-EU    H25 0330
   Serial number: VWZAZ2B1195384  Dataset Number: V03935404L  0001
   Coding: 22703008000000000000000000000000000000000000000000
   ASAM Dataset: EV_MUOIMQB 001001
   ROD: EV_MUOIMQB_001_VW27.rod
   VCID: 3138CA1D51A3D162309-8064
   Subsystem 1 - Part No SW: 5NN 919 605 B    HW: 5NN 919 605 B
   Component: ABT_Std-2_Nav  382 8310
   Serial number: VWZ6ZHB2620475
   Subsystem 2 - Part No: V03 959 820 GB
   Component: EUR 2023/24    9085
7173 - Function Restricted due to Interrupted Communications
          U1110 00 [00001001] - -
          [ACC (0x05) - function restriction due to communication error - BapErr_retry not successful]
                    Mileage: 4818 km
                    Date: 2025.03.18
                    Time: 16:51:58
                    BAP: 02
                    Voltage terminal 30: 13.1 V
7195 - Function Restricted due to Interrupted Communications
          [Brake assist system (0x1B) - function restriction due to communication error - BapErr_retry not successful]
                    Mileage: 4818 km
                    Date: 2025.03.18
                    Time: 16:51:58
                    BAP: 02
   Part No SW: 5WA 035 284 G    HW: 5WA 035 284 B
   Component: OCUGen3High   H22 0143
   Serial number: 0000000309VIXFB Dataset Number: V03935417TA 0001
   Coding: 022700001968A8209005460161502607
   ASAM Dataset: EV_OCUGen3High 003007
   ROD: EV_OCUGen3High_003_VW27.rod
   VCID: 4ACABDF1DC3582BA113-801E
7195 - Function Restricted due to Missing Message(s)
          U1111 00 [00001001] - -
          [Brake assist system (0x1B) - Funktionseinschränkung wegen Kommunikationfehler - BapErr_RetryNotSuccessful]
                    Mileage: 4818 km
                    Date: 2025.03.18
                    Time: 16:52:01
                    Voltage terminal 30: 13.0 V
7173 - Function Restricted due to Missing Message(s)
          [ACC (0x05) - Funktionseinschränkung wegen Kommunikationfehler - BapErr_RetryNotSuccessful]
                    Mileage: 4818 km
                    Date: 2025.03.18
                    Time: 16:52:00
0055 - Databus
          [ACC ECU: no communication]
                    Mileage: 4818 km
                    Date: 2025.03.18
                    Time: 16:51:56
   Part No SW: 2Q0 980 653 D    HW: 2Q0 980 653
   Component: MQB MFK 3.0   H19 1421
   Serial number: EB7792602232700 Dataset Number: V03935410YY 0001
   Coding: 00000910116E4020089E00000020002000418000000000000000000000000000
   ASAM Dataset: EV_MFK3ValeoMQB 007042
   VCID: 3632F901B8CDF65A65B-8062
10 Faults Found:
1123077 - Databus
          [LH_EPS_03_EPS_BLW_QBit]
                    Mileage: 4818 km
                    Date: 2025.03.18
                    Time: 16:51:56
1122599 - Local Data Bus
          U1169 00 [00001001] - Missing Message
          [Timeout_RDR1_Obj_02]
                    Mileage: 4818 km
                    Date: 2025.03.18
                    Time: 16:51:56
1124134 - Local Data Bus
          [TIMEOUT_RDR1_Obj_01]
                    Mileage: 4818 km
                    Date: 2025.03.18
                    Time: 16:51:56
1122902 - Databus
          [TIMEOUT_ACC_02]
                    Mileage: 4818 km
                    Date: 2025.03.18
                    Time: 16:51:56
1124193 - Local Data Bus
          [TIMEOUT_RDR1_ObjGegen_02]
                    Mileage: 4818 km
                    Date: 2025.03.18
                    Time: 16:51:56
1124192 - Local Data Bus
          [TIMEOUT_RDR1_ObjGegen_01]
                    Mileage: 4818 km
                    Date: 2025.03.18
                    Time: 16:51:56
1122601 - Local Data Bus
          [Timeout_RDR1_Obj_04]
                    Mileage: 4818 km
                    Date: 2025.03.18
                    Time: 16:51:56
1122600 - Local Data Bus
          [Timeout_RDR1_Obj_03]
                    Mileage: 4818 km
                    Date: 2025.03.18
                    Time: 16:51:56
1122561 - Databus
          [TIMEOUT_ACC_10]
                    Mileage: 4818 km
                    Date: 2025.03.18
                    Time: 16:51:56
1122597 - Local Data Bus
          [Timeout_RDR1_Header]
                    Mileage: 4818 km
                    Date: 2025.03.18
                    Time: 16:51:56
End----------(Elapsed Time: 04:12, VBatt start/end: 13.1V/13.2V)-----------
------------------------------36 Faults Found------------------------------
WVGZZZCS8RY025818 -- That's a 2024.
13-Auto Dist. Reg is completely off-line and there's a cascade of faults in other systems as a result. You need to get that back on-line.
The other thing that seems to be annoying many other modules is the steering angle sensor.
steviewatt
Scotland
C?ID=610675
thanks for the quick reply. i have a replacement distance sensor that sits behind the VW grill badge and ill check the wiring. forgot to mention that the power steering isn't working.
steviewatt
Scotland
C?ID=610675
Tuesday,01,April,2025,11:05:24:43198
VIN: WVGZZZCS8RY025818   Mileage: 4828km-2999miles
   Revision: 42101001
25124 - Databus
          U1123 00 [00100111] - Received Error Message
                    Mileage: 4828 km
                    Date: 2025.04.01
                    Time: 10:50:55
                    Voltage terminal 30: 12.109 V
                    Fuel high pressure sensor: actual value: 5.0 bar
                    O2 sen. bank 1 dwnstrm oxi cat: elec. corrected Urie sen. value: 0.465 V
                    Battery voltage: 12.109 V
                    Control Module temperature: 23.2 °C
                    Engine oil temperature: 8.1 °C
          U0416 00 [00100111] - -
                    Mileage: 4828 km
                    Date: 2025.04.01
                    Time: 10:50:55
Readiness: N/A
1360 - Implausible Data Received from Steering Angle Sensor Module (G85)
          U0428 00 [10011001] - -
          [LWI_SensorNotCalibrated]
          MIL ON - Confirmed - Not Tested Since Memory Clear
                    Reset counter: 107
                    Mileage: 4818 km
                    Date: 2025.03.25
                    Time: 18:10:13
262914 - Refrigerant Pressure
          B10AB F0 [00001001] - Too Low
                    Reset counter: 110
                    Mileage: 4828 km
                    Date: 2025.04.01
                    Time: 10:50:59
                    Refrigerant pressure: 1.0 bar
                    Outside temperature: 14.0 °C
                    Temperature downstream of evaporator: 7.0 °C
   Coding: 0018DD
   Coding: 1F0047
   Coding: 058047
   Coding: 1F0000
   Coding: 070000
535060 - Databus
                    Reset counter: 110
                    Mileage: 4828 km
                    Date: 2025.04.01
                    Time: 10:50:59
                    Zusaetzliche Umgebungsdaten-Automatic high beam assist: operated
                    Zusaetzliche Umgebungsdaten-voltage measurement: 11.9 V
                    Reset counter: 110
                    Mileage: 4828 km
                    Date: 2025.04.01
                    Time: 10:50:53
   Coding: 8371065841
13697025 - Control Module
          U110F 00 [00001001] - I'm sorry Dave; I'm afraid I can't do that!
          [Steuergerät für Lenkhilfe-J500 - LH_EPS_01.EPS_PLA_Status - PLA-Codierung in Lenkhilfe prüfen]
                    Reset counter: 110
                    Mileage: 4828 km
                    Date: 2025.04.01
                    Time: 10:50:53
13637426 - Databus
                    Reset counter: 110
                    Mileage: 4828 km
                    Date: 2025.04.01
                    Time: 10:50:52
13688835 - Databus
                    Reset counter: 110
                    Mileage: 4828 km
                    Date: 2025.04.01
                    Time: 10:50:53
   Part No SW: 2Q0 907 572 AA    HW: 2Q0 907 572 D
   Component: ACCCONTIMQB   H12 0396
   Dataset Number: V03935361ME 0001
   Coding: 2804604308FF8748949C812560508700000000000000000024
   ASAM Dataset: EV_ACCMRRCONTIVW376 003018
   ROD: EV_ACCMRRCONTIVW376_003_VW27.rod
0803 - Databus
          [FAULT_BV1_FEHLER]
                    Reset counter: 110
                    Mileage: 4828 km
                    Date: 2025.04.01
                    Time: 10:50:52
                    Voltage terminal 15: 11.9 V
                    Control Module temperature: 36 °C
                    Vehicle speed: 0.00 m/s
                    Longitudinal acceleration: -0.19 m/s²
                    Adaptive distance regulation: status: ACC_irreversible error
2101 - Databus
          [FAULT_ESP_STATUS_SYSTEM]
                    Reset counter: 110
                    Mileage: 4828 km
                    Date: 2025.04.01
                    Time: 10:50:52
                    Voltage terminal 15: 11.8 V
2055 - Databus
          [FAULT_ALP_STEERINGWHEEL_INIT]
                    Reset counter: 110
                    Mileage: 4828 km
                    Date: 2025.04.01
                    Time: 10:50:52
          U1101 00 [00001001] - Active
          [FAULT_THP_EC_INVALID_IKA]
                    Reset counter: 110
                    Mileage: 4828 km
                    Date: 2025.04.01
                    Time: 10:50:52
   Coding: 802006
   Coding: 802006
1050117 - Databus
                    Reset counter: 110
                    Mileage: 4828 km
                    Date: 2025.04.01
                    Time: 10:50:52
1060614 - Databus
          [NWD: 0xTBD SDF_PSF_01 error value SDF_PSF_Time_To_Collision]
                    Reset counter: 110
                    Mileage: 4828 km
                    Date: 2025.04.01
                    Time: 10:50:52
1060615 - Databus
          [NWD: 0xTBD SDF_PSF_01 error value SDF_PSF_v_rel]
                    Reset counter: 110
                    Mileage: 4828 km
                    Date: 2025.04.01
                    Time: 10:50:52
1060617 - Databus
          [NWD: 0xTBD SDF_PSF_01 error value SDF_PSF_CW]
                    Reset counter: 110
                    Mileage: 4828 km
                    Date: 2025.04.01
                    Time: 10:50:52
   Generator:
   Coding: 2C2F00
                    Reset counter: 110
                    Mileage: 4828 km
                    Date: 2025.04.01
                    Time: 10:50:53
                    Terminal 30 power supply: 11.9 V
                    Terminal 15: On
                    Reset counter: 110
                    Mileage: 4828 km
                    Date: 2025.04.01
                    Time: 10:50:53
                    Terminal 15: On
   Coding: 92954640
2236417 - Databus
                    Mileage: 4828 km
                    Date: 2025.04.01
                    Time: 10:50:53
2236426 - Databus
          [databus unreasonable message - LWI_Lenkradwinkel]
                    Mileage: 4828 km
                    Date: 2025.04.01
                    Time: 10:50:53
   Coding: 000000000000000000000201010001010000010001
10531840 - Steering angle sensor
          B1168 54 [10001001] - Missing Calibration / Basic Setting
                    Reset counter: 110
                    Mileage: 4828 km
                    Date: 2025.04.01
                    Time: 10:50:52
                    Voltage terminal 30: 11.94 V
                    max.value: 0.5 A
                    End stage temperature: 7 °C
                    Engine angle: 0 °
                    Electric motor speed: 0 /min
10551296 - Control Module Incorrectly Coded
          U1014 00 [00001001] - -
          [DEM_CODING_DSR_FAULT]
                    Reset counter: 110
                    Mileage: 4828 km
                    Date: 2025.04.01
                    Time: 10:50:58
                    max.value: 0.5 A
                    Engine angle: 0 °
10551552 - Control Module Incorrectly Coded
          [DEM_CODING_PLA_FAULT]
                    Reset counter: 110
                    Mileage: 4828 km
                    Date: 2025.04.01
                    Time: 10:50:58
                    max.value: 0.5 A
                    Engine angle: 0 °
10552064 - Control Module Incorrectly Coded
          [DEM_CODING_HCA_FAULT]
                    Reset counter: 110
                    Mileage: 4828 km
                    Date: 2025.04.01
                    Time: 10:50:58
                    max.value: 0.5 A
                    Engine angle: 0 °
10532608 - No End-of-Line Programming
          B2013 00 [00001001] - -
          [DEM_NO_VW_EOL_PROGRAMMING_FAULT]
                    Reset counter: 110
                    Mileage: 4828 km
                    Date: 2025.04.01
                    Time: 10:50:52
                    max.value: 0.5 A
                    Engine angle: 0 °
1123187 - Local Data Bus
          U116B 00 [00001001] - Received Malfunction Value
          [RDR1_Header_FGN_Status]
                    Mileage: 4828 km
                    Date: 2025.04.01
                    Time: 10:50:53
1123173 - Databus
          [ESP_21_ESP_Systemstatus]
                    Mileage: 4828 km
                    Date: 2025.04.01
                    Time: 10:50:53
0659 - Steering
          C10AC F2 [00001001] - Lane-Holding Assistance Not Coded
          [HC_interface_at_the_steering_not_activated]
                    Mileage: 4828 km
                    Date: 2025.04.01
                    Time: 10:50:53
End----------(Elapsed Time: 01:19, VBatt start/end: 12.5V/12.5V)-----------
------------------------------29 Faults Found------------------------------
replaced the radar sensor behind the grill badge but still have numerous faults. steering angle sensor is throwing codes/ could it have been damaged due to the airbag going off?
power steering is now working.
does the VW Taigo store the codes in a module that cant be reset and possibly needs replaced? Airbags and all the seat belts have been replaced.
steviewatt
Scotland
C?ID=610675
   Revision: 42101001
25124 - Databus
                    Mileage: 4828 km
                    Date: 2025.04.01
                    Time: 10:50:55
                    Mileage: 4828 km
                    Date: 2025.04.01
                    Time: 10:50:55
Readiness: N/A
                    Reset counter: 107
                    Mileage: 4818 km
                    Date: 2025.03.25
                    Time: 18:10:13
                    Reset counter: 110
                    Mileage: 4828 km
                    Date: 2025.04.01
                    Time: 10:50:59
   Coding: 0018DD
   Coding: 1F0047
   Coding: 058047
   Coding: 1F0000
   Coding: 070000
535060 - Databus
                    Reset counter: 110
                    Mileage: 4828 km
                    Date: 2025.04.01
                    Time: 10:50:59
                    Reset counter: 110
                    Mileage: 4828 km
                    Date: 2025.04.01
                    Time: 10:50:53
   Coding: 8371065841
                    Reset counter: 110
                    Mileage: 4828 km
                    Date: 2025.04.01
                    Time: 10:50:53
13637426 - Databus
                    Reset counter: 110
                    Mileage: 4828 km
                    Date: 2025.04.01
                    Time: 10:50:52
13688835 - Databus
                    Reset counter: 110
                    Mileage: 4828 km
                    Date: 2025.04.01
                    Time: 10:50:53
0803 - Databus
          [FAULT_BV1_FEHLER]
                    Reset counter: 110
                    Mileage: 4828 km
                    Date: 2025.04.01
                    Time: 10:50:52
2101 - Databus
                    Reset counter: 110
                    Mileage: 4828 km
                    Date: 2025.04.01
                    Time: 10:50:52
2055 - Databus
                    Reset counter: 110
                    Mileage: 4828 km
                    Date: 2025.04.01
                    Time: 10:50:52
                    Reset counter: 110
                    Mileage: 4828 km
                    Date: 2025.04.01
                    Time: 10:50:52
   Coding: 802006
   Coding: 802006
1050117 - Databus
                    Reset counter: 110
                    Mileage: 4828 km
                    Date: 2025.04.01
                    Time: 10:50:52
1060614 - Databus
                    Reset counter: 110
                    Mileage: 4828 km
                    Date: 2025.04.01
                    Time: 10:50:52
1060615 - Databus
                    Reset counter: 110
                    Mileage: 4828 km
                    Date: 2025.04.01
                    Time: 10:50:52
1060617 - Databus
                    Reset counter: 110
                    Mileage: 4828 km
                    Date: 2025.04.01
                    Time: 10:50:52
   Generator:
   Coding: 2C2F00
                    Reset counter: 110
                    Mileage: 4828 km
                    Date: 2025.04.01
                    Time: 10:50:53
                    Terminal 15: On
                    Reset counter: 110
                    Mileage: 4828 km
                    Date: 2025.04.01
                    Time: 10:50:53
                    Terminal 15: On
   Coding: 92954640
2236417 - Databus
                    Mileage: 4828 km
                    Date: 2025.04.01
                    Time: 10:50:53
2236426 - Databus
                    Mileage: 4828 km
                    Date: 2025.04.01
                    Time: 10:50:53
                    Reset counter: 110
                    Mileage: 4828 km
                    Date: 2025.04.01
                    Time: 10:50:52
                    max.value: 0.5 A
                    Engine angle: 0 °
                    Reset counter: 110
                    Mileage: 4828 km
                    Date: 2025.04.01
                    Time: 10:50:58
                    max.value: 0.5 A
                    Engine angle: 0 °
                    Reset counter: 110
                    Mileage: 4828 km
                    Date: 2025.04.01
                    Time: 10:50:58
                    max.value: 0.5 A
                    Engine angle: 0 °
                    Reset counter: 110
                    Mileage: 4828 km
                    Date: 2025.04.01
                    Time: 10:50:58
                    max.value: 0.5 A
                    Engine angle: 0 °
                    Reset counter: 110
                    Mileage: 4828 km
                    Date: 2025.04.01
                    Time: 10:50:52
                    max.value: 0.5 A
                    Engine angle: 0 °
                    Mileage: 4828 km
                    Date: 2025.04.01
                    Time: 10:50:53
1123173 - Databus
                    Mileage: 4828 km
                    Date: 2025.04.01
                    Time: 10:50:53
0659 - Steering
                    Mileage: 4828 km
                    Date: 2025.04.01
                    Time: 10:50:53
TTT
C?ID=547002
steviewatt
Scotland
C?ID=610675
8526363 - Crash Shut-Down B189C F0 [00001001] - Active Confirmed - Tested Since Memory Clear
Anyone know how to reset this on a 2024 Taigo? I’m having no joy.
gernster
C?ID=491801
Radar sensor will need coding via odis mate to remove the component protection, it needs to be the exact same part number and from the same make, i.e VW not Audi or anything else
gernster
C?ID=491801
I also think you have tried to reset the power steering by resetting the unit in adaptations, vcds has a bug when you try to do this and it wipes your steering angle sensor basic settings, you need ODIS to revise the steering angle sensor too.
Pay for an ODIS session locally once you have it up and running and that will sort out a lot of your issues.
If you're going to accuse VCDS of having a bug like this, you need to provide more details, since VCDS doesn't do anything the user doesn't explicitly request.
steviewatt
Scotland
C?ID=610675
Thanks for the replies. I’ll get the car booked in with my VW Indy garage. 👍
