2018 Audi Q7 Prestige - SOS Malfunction (but it actually works)
harley909
MJ, SK, Canada
C?ID=612616
New to the Forum. New to VCDS. Old school Air Cooled VW Guy. Appreciate any help I can get.
Just bought a "used" Audi Q7 with 120,000km. Well maintained with records.
Has one weird history issue....previous Owner may have punctured the wiring for the cellular antenna when they pushed a Remembrance Day poppy pin into the headliner and dealer really discouraged investigating repair due to complications pulling headliner/sunroof etc apart. (as the story goes). SOS malfunction code showed up after I got it, however everything functions fine. SOS call works and no other MMI/Multimedia issues at all. It makes me a bit skeptical about the wiring being damaged...but again that's just part of the story.
I'm looking at any option to delete or program out the warning from the dash/display.
When I run the scan it shows the antenna issue on module 19
I've tried a few things to clear the warning based on similar issues Audi had on other models with the 3G/LTE and Telematics module lockups/software isues with no success. After googling for days I have found that it may be possible to disable the warning in the Telematics module 75. The problem is, I am unable to access module 75 using the HEX-V2 and VCDS. Maybe it is protected/secured or maybe there is something I am doing incorrectly.
The only thing I haven't tried is to disconnect the battery to reset the Telematics module (if that's even a good idea) or to pull the fuse for the module (which does not even seem to be in the fuse block (x 2 locations) - "Telephone" according to my Owners manual.
Looking for some help
Thursday,20,March,2025,16:07:41:32426
VCDS Version: 25.3.0.4 (x64)  HEX-V2 CB: 0.4660.5
Data version: 20250318 DS365.0
VIN: WA1VAAF71JD01*****   License Plate:
Mileage: 120709km-75005mi   Repair Order:
Chassis Type: F7-AU73 (8W6)
Scan: 01 02 03 08 09 15 16 17 19 28 29 36 39 3C 42 44 46 47 50 52
          5F 69 6C 6D 81 BB BC CA CF D6 D7
VIN: WA1VAAF71JD016757   Mileage: 120709km-75005miles
50-Seat Adj. 3rd row -- Status: OK 0000
CA-Sunroof -- Status: OK 0000
   Part No SW: 8W6 907 468 E    HW: 8W6 907 468 E
   Component: Gateway       H42 0118
   Revision: 6B030003    Serial number: 0386B763717928 Dataset Number: 4M0909515L  0080
   Coding: 03010001000006405407000000590030CC1A0000100000000175078E10000000
   Shop #: WSC 31414 790 00001
   GVL: 01503C0408000000C05C08000002C800100C2000000000000000000000000000
   ASAM Dataset: EV_CGateCONTIAU491 003092
   VCID: 4CC6BA23E64CFDCA23F-8018
   Subsystem 1 - Part No SW: 4M0 951 523 A    HW: 4M0 951 523 A
   Component: J453 MFL  H06 0002
   Serial number: 20170919012803 00058
   Serial number: 5000055104
2563 - Cellular Antenna
          B1053 13 [00001001] - Open Circuit
          [GSM/UMTS_Breakdown]
                    Reset counter: 170
                    Mileage: 120705 km
                    Date: 2025.03.20
                    Time: 12:23:24
                    Voltage terminal 30: 13.20 V
Address 5F: Information Electr. (J794)       Labels:* 4M0-035-MIB-HGH2.clb
   Part No SW: 4M1 035 880 A    HW: 4M1 035 880
   Component: MU-P-LNS-US   034 1118
   Serial number: A724I0HB033098 Dataset Number: 4M0909545K  0042
   Coding: 013706020000000053220002041A00002F001BE401700104FE
   VCID: 2B04D9BF4382DAF20A5-807E
                    Reset counter: 170
                    Mileage: 120705 km
                    Date: 2025.03.20
                    Time: 13:15:05
                    Voltage terminal 30: 12.5 V
                    Satellite radio tuner status-Satellite radio tuner: pre-activation status: 00
                    Satellite radio tuner status-Satellite radio tuner: pre-activation value: 00
   Part No SW: 4M0 959 795 H    HW: 4M0 959 795 F
   Component: TSG HBFS      005 0125
   Serial number: 0000279940282  Dataset Number: 4M0909896G  0032
   Coding: 004D9B0000001080400020A0
   ROD: EV_DCU2RearPasseMAXHCONT_VW37.rod
   VCID: 45D08F07C5260C82FC1-8010
196888 - Lamp for Ambient Speaker Illumination
          B13C8 13 [00001001] - Open Circuit
                    Reset counter: 170
                    Mileage: 120707 km
                    Date: 2025.03.20
                    Time: 14:41:28
End----------(Elapsed Time: 02:31, VBatt start/end: 14.9V/14.8V)-----------
------------------------------3 Faults Found-------------------------------
It does not look like you have a separate 75-Telematics module.
Can we get a complete Auto-Scan for better context, please?
harley909
MJ, SK, Canada
C?ID=612616
Here is the full scan.
Maybe I just made the assumption that it has a 75-Telematics module....
I guess I may as well ask a few questions
Is there anyway to program out that cellular antenna warning via the 19 CAN Gateway module?
Is it possible that the 75 Module is just locked up and that's why I can't communicate with it?
Is it worth disconnecting the battery to reset everything and/or is that something that going to create more issues?
VIN: WA1VAAF71JD016757   License Plate:
Address 01: Engine (J623-CREC)       Labels:. 06E-907-551-CGW.clb
   Part No SW: 4M0 907 551 A    HW: 06E 907 425
   Component: 3.0l V6 TFSI  H10 0005
   Revision: --H10---    CVN: 08BDF7A0
   Coding: 2A2A00320536010D74280000000000000000000000000000
   Shop #: WSC 92650 999 00000
   ASAM Dataset: EV_ECM30TFS0214M0907551A 001007
   ROD: EV_ECM30TFS021_AU73.rod
   VCID: 2D00D7A77D96D4C2141-8078
   VINID: 9D106645158705A5000461C51CCDBBA9CF
Readiness: 0000 0100
Address 02: Auto Trans        Labels:| 0BK-927-156.clb
   Part No SW: 4M0 927 158 L    HW: 0D5 927 156 H
   Component: 0D5  30TSIUSA H05 1006
   Revision: --H05---    CVN: 228D7428
   Coding: 100000
   ASAM Dataset: EV_TCMALX52011 002010
   ROD: EV_TCMALX52011.rod
   VCID: 3D20E7E7ADF64442A41-8068
Address 03: ABS Brakes (J104)       Labels: 4M0-907-379-V1.clb
   Part No SW: 4M0 907 379 Q    HW: 4M0 907 379 N
   Component: ESP9 Premium  H09 0657
   Dataset Number: 4M0909504M  0003 CVN: ACFBEF4F
   Coding: 28AA149C30A30A9C91A5589600845292E6268814280C50891A004A49676411
   ASAM Dataset: EV_ESP9BOSCHAU536K 012013
   ROD: EV_ESP9BOSCHAU536K_AU73.rod
   Part No SW: 4M0 820 043 AB    HW: 4M0 820 043 AB
   Component: Klima Zone 4  H52 0100
   Coding: 6608090C5548001110680280800000000000000000000000000000000000
   ASAM Dataset: EV_AirCondiFrontBHTCAU736 001013
   ROD: EV_AirCondiFrontBHTCAU736.rod
   VCID: 65906F8765E62C821C1-8030
   Subsystem 1 - Part No SW: 4M1 820 021 A    HW: 4M1 820 021 A
   Component: J126 FLuftV  H08 0003
   Serial number: 00000000000001665662
   Humidity sensor: exterior:
   Serial number: 9541DCC800PAG0MUFU02
Address 09: Cent. Elect. (J519)       Labels:* Redir Fail!
   Part No SW: 8W0 907 063 CG    HW: 8W0 907 063 BG
   Component: BCM1 MLBevo   H13 0267
   Dataset Number: 4M0909514AA 0055
   Coding: 07501563E0081CCD050F571958BF9CB911033D01900000000000000020001A0108630122025709
   VCID: 025A541B9488FBBA993-8056
   Subsystem 1 - Part No SW: 4M1 955 119 A    HW: 4H2 955 119 C  Labels: 1KX-955-119.CLB
   Component: WWS536 170815  044 0893
   Serial number: 90115300401722700405
   Coding: 1BC7F7
   Serial number: 20504145X81A955547A0
   Coding: 02006E
   Subsystem 3 - Part No SW: 4M0 941 531 AA    HW: 4M0 941 531 AA
   Component: E1 - LDS  H06 0008
   Serial number: 12 08 2017  01080064
   Subsystem 4 - Part No SW: 4M0 907 410 A    HW: 4M0 907 410 A
   Component: USHL5  H08 0050
   Serial number: 0000009600363Z005H02
   Coding: 350000
   Garage door opener control head:
   Subsystem 5 - Part No SW: 4M0 959 719 A    HW: 4M0 959 719 A
   Component: GTO BF  H01 0010
   Serial number: 20170906230346 00658
   Subsystem 6 - Part No SW: 8W0 857 511 B    HW: 8W0 857 511 B
   Component: Y7_Innenspieg  H01 0002
   Serial number: GX1CE114071723310914
   Coding: 030000
   Interior Light Module:
   Subsystem 7 - Part No SW: 4M0 947 135 CP    HW: 4M0 947 135
   Component: J528-Dachele  H14 0130
   Serial number: Q00486471
   Subsystem 8 - Part No SW: 80A 907 705     HW: 80A 907 705
   Component: J866-EVLS-SG  H03 0080
   Serial number: WA129274000038882942
   Coding: 0A0100
   Subsystem 9 - Part No SW: 4M0 925 301 K    HW: 4M0 925 301 K
   Component: SL-Q7NF/AU736  H10 0013
   Serial number: 00000000000000147802
   Subsystem 10 - Part No SW: 4M0 963 575     HW: 4M0 963 575
   Component: V512 LLR1SLvL  H03 0012
   Serial number: L14DH20501236
   Subsystem 11 - Part No SW: 4M0 963 575     HW: 4M0 963 575
   Component: V514 LLR1SKvL  H03 0012
   Serial number: L14DH24800763
   Subsystem 12 - Part No SW: 4M0 963 575     HW: 4M0 963 575
   Component: V516 LLR1SLvR  H03 0012
   Serial number: L14DH20501239
   Subsystem 13 - Part No SW: 4M0 963 575     HW: 4M0 963 575
   Component: V518 LLR1SKvR  H03 0012
   Serial number: L14DH24800753
   Part No SW: 4M0 959 655 F    HW: 4M0 959 655 F
   Component: Airbag10.44   H02 0106
   Serial number: 003UM0017HWQ Dataset Number: 4M0909602AK 0001
   Coding: AECCFCC000800000A0F00033D24C00000000
   ASAM Dataset: EV_AirbaAU10BPAAU736 006015
   ROD: EV_AirbaAU10BPAAU736_006.rod
   VCID: 3E22E0EBA0F05F5ABDB-806A
   Left seat belt tensioner:
   Subsystem 1 - Part No SW: 4M0 980 945     HW: 4M0 980 945
   Component: BeltPretRevFL  205 2033
   Serial number: 4M0857705K0266R00187
   Coding: 88001B
   Right seat belt tensioner:
   Subsystem 2 - Part No SW: 4M0 980 946     HW: 4M0 980 946
   Component: BeltPretRevFR  205 2033
   Serial number: 4M0857706K0268R00452
   Coding: 88001B
   Component: BF-Gewichtss.  H11 0022
   Serial number: IBH0000J1700080S070U
   Subsystem 4 - Part No SW: -----------    HW: 442 060 108 17
   Serial number: 3577Y00BD2474D4210B%
   Subsystem 5 - Part No SW: -----------    HW: 442 060 108 17
   Serial number: 3587Y00B524FCA3362CD
   Subsystem 6 - Part No SW: -----------    HW: 442 0B1 109 17
   Serial number: 3517700A12864453A2A2
   Subsystem 7 - Part No SW: -----------    HW: 442 0B1 109 17
   Serial number: 3527700C3279CC45D1CU
   Subsystem 8 - Part No SW: -----------    HW: 442 0C2 007 17
   Serial number: 3557500B527778139032
   Subsystem 9 - Part No SW: -----------    HW: 442 0C2 007 17
   Serial number: 3567500B52777811B1AB
   Part No SW: 4M0 907 129 GM    HW: 4M0 907 129 GM
   ROD: EV_SMLSKLOAU736_006.rod
   VCID: 01585B17918EE0A2809-8054
   Part No SW: 4M0 920 790 C    HW: 4M0 920 790 C
   Component: FBenRDW       H18 0370
   Coding: 08A600C128880008022369401800200000000000
   ROD: EV_DashBoardAU736_AU73.rod
   VCID: 2F3CCDAF779AA6D226D-807A
                    Reset counter: 170
                    Mileage: 120705 km
                    Date: 2025.03.20
                    Time: 12:23:24
Address 28: HVAC, Rear (E265)       Labels:* None
   Part No SW: 4M0 919 158 D    HW: 4M0 919 158 D
   Component: Klima Zone 2  H52 0103
   Coding: 000000000000000100800080000000000000000000000000000000000000
   ASAM Dataset: EV_AirCondiFondBHTCAU736 001013
   ROD: EV_AirCondiFondBHTCAU736.rod
   VCID: 3632F8CB88C0971A65B-8062
   Part No SW: 4M0 907 397 AC    HW: 4M0 907 397 C
   Component: LCM_MLBevoH05 0024
   VCID: 78AE36F3C254A16AB77-802C
   Part No SW: 4M1 959 760     HW: 4M1 959 760
   Component: MEM-FS        008 0031
   Serial number: 00000280526734 Dataset Number: 4M0909856C  0018
   Coding: 005C1B000000B0010000010101010000000000000000000000000000000000
   VCID: 76B238CBC840D71AA5B-8022
Address 3C: Lane Change (J769)       Labels:| 4M0-907-566.clb
   Part No SW: 4M0 907 566 D    HW: 4M0 907 566
   Component: MRR1Rear      H18 0410
   Revision: --------    Dataset Number: 4M0909535L  0015
   Coding: 1E0002
   ASAM Dataset: EV_RearRadarS1BoschAU736 001022
   Part No SW: 4M0 959 793 H    HW: 4M0 959 793 F
   Component: TSG FS        005 0125
   Serial number: 0000280173580  Dataset Number: 4M0909872G  0032
   Coding: 005D9B005E001080000120B0
   VCID: 43D4911FCB1232B2D25-8016
   Part No SW: 4M0 909 144 H    HW: 4M0 909 144 B
   Component: EPS_MLBEVO1BS H22 0005
   Serial number: 0000124490 Dataset Number: 4M0909852P  0002
   Coding: 90000001000100
   ASAM Dataset: EV_EPSVWBSAU736 009023
   ROD: EV_EPSVWBSAU736_009.rod
   VCID: 3436C2C39EBC850A5BF-8060
   Part No SW: 8W0 907 064 DD    HW: 8W0 907 064 DD
   Component: BCM2 MLBevo   019 0366
   Dataset Number: 4M0909501H  0064
   Coding: 01341E00492100C0650BA0006E01580203024000810004502F0400000F04803F001E0001000000
   ASAM Dataset: EV_BCM2HellaAU736 013013
   ROD: EV_BCM2HellaAU736_013_AU73.rod
   Subsystem 1 - Part No SW: 5QD 951 605     HW: 5QD 951 605
   Serial number: 00002856223972362174
   Subsystem 2 - Part No SW: 3AA 962 243 F    HW: 3AA 962 243 F
   Component: GEB.F.Heckoef  H16 0816
   Serial number: 94241608
   Part No SW: 4M0 035 223 C    HW: 4M0 035 223
   Component: MIB2_amp_PD   H03 0440
   Serial number: 00000000053094 Dataset Number: 4M1909510E  0012
   Coding: 0135060A008AF53AAF0000010000
   ASAM Dataset: EV_AMPMst16C4Gen2BOSE 001001
   ROD: EV_AMPMst16C4Gen2BOSE_AU73.rod
   VCID: 2314319F2B5212B2B25-8076
Address 50: Seat Adj. 3rd row (J857)       Labels:* None
   Part No SW: 4M1 959 760 G    HW: 4M1 959 760 G
   Component: MEM-SR3       008 0016
   Serial number: 00000280560747 Dataset Number: 4M0909467C  0015
   Coding: FF041020F1000000000F000000000900000021210900000000000000440000
   ASAM Dataset: EV_SCM3rdRowCONTIAU736 005007
   ROD: EV_SCM3rdRowCONTIAU736_AU73.rod
   Part No SW: 4M0 959 792 H    HW: 4M0 959 792 F
   Component: TSG BFS       005 0125
   Serial number: 0000279635228  Dataset Number: 4M0909873G  0033
   VCID: 42DA941BD4083BBAD93-8016
   Subsystem 1 - Part No SW: V03 959 801 GH    HW: -----------
   Component: NAR 2017/2018  --- 0060
   Multimedia display unit 1:
   Subsystem 2 - Part No SW: 4M0 919 605     HW: 4M0 919 605
   Component: AU536_DU_HIGH  H43 0008
   Serial number: AUZ8Z9HJ40538G
   Subsystem 3 - Part No SW: 4M0 919 615 H    HW: 4M0 919 615 H
   Component: ControlUnit_P  H15 0209
   Serial number: 20091700000000000756
   Compact disc data bank:
   Component: Gracenote2  --- 3012
                    Reset counter: 170
                    Mileage: 120705 km
                    Date: 2025.03.20
                    Time: 13:15:05
   Part No SW: 4M0 907 383 F    HW: 4M0 907 383 B
   Revision: 9A001003    Serial number: 0450633077 Dataset Number: 4M0909527B  0020
   Coding: 0210000200000000
   VCID: 3530FFC795C69C026C1-8060
   Part No SW: 4M0 907 428 F    HW: 4M0 907 428
   Component: Areaview 2    H13 0318
   Serial number: C854607JG022404 Dataset Number: 4M1909460H  0022
   Coding: 02350602BB0FA10038404004
   ASAM Dataset: EV_CamSysRVAV2CE2MLBEv 005015
   ROD: EV_CamSysRVAV2CE2MLBEv_005_AU49.rod
   Part No SW: 8W8 959 107 B    HW: 8W8 959 107
   Component: HDSG-Modul    H13 0163
   Revision: --------    Serial number: 31496051800000 Dataset Number: 4M0909541G  0025
   Coding: 0030
   ASAM Dataset: EV_DeckLidCONTIAU736 001015
   VCID: 48CE8633F23411EA077-801C
   Part No SW: 4M1 713 041 E    HW: 4M1 713 041 F
   Component: GSM-LL        H09 0077
   Revision: 0L0D5012    Serial number: 17090443963561
   ROD: EV_GSMWaehlZFAU736.rod
   VCID: 270C258F5F6AFE92EED-8072
   Component: TSG HFS       005 0125
   Serial number: 0000279939691  Dataset Number: 4M0909897G  0032
   ROD: EV_DCU2RearDriveMAXHCONT_VW37.rod
                    Reset counter: 170
                    Mileage: 120707 km
                    Date: 2025.03.20
                    Time: 14:41:28
   Part No SW: 4M0 907 594 G    HW: 4M0 907 594
   Component: SAD_STG_1     014 0005
   Dataset Number: 4M0909469G  0015
   Coding: 2A8000053602
   ROD: EV_SunRoofCONTIAU736_006_VW37.rod
   VCID: 3A2AECFBBCD8737A813-806E
Address CF: Lane Chge Asst 2 (J770)       Labels:. 4M0-907-566.clb
   Part No SW: 4M0 907 590 D    HW: 4M0 907 590
   Revision: --------
   Coding: 1E0002
   ASAM Dataset: EV_RearRadarS2BoschAU736 001022
   VCID: 3334C1DF9BB28232425-8066
   Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A
   Component: LED1L         H09 0003
   Dataset Number: 4M0909471D  0012
   ROD: EV_LEDModLeftMELCOAU736_AU73.rod
   VCID: 1672184BE800771A45B-8042
   Component: LED1R         H09 0003
   Dataset Number: 4M0909472D  0012
This is interesting. Most MLBevo cars have a 75-Telematics (J949) specific control module and those are known for going offline where you have to follow a TBS to get it to communicate when it malfunctions. The summary of that is remove the 75 control module, remove the internal battery, say a prayer and reconnect it hoping it will function correctly. Those cars look like this in a scan:
   Part No SW: 80A 907 468 F    HW: 80A 907 468 B
   Component: Gateway       H05 0207
   Serial number: 1JF03024234001 Dataset Number: 4M0909515Q  0093
   Coding: 03010001000006405407000000590032DC1A0007100000000175078E10000000
   GVL: 01503C0C8800000040DCC8008002C800100C2000000000000000000000000100
   ASAM Dataset: EV_Gatew31xAU65x 003170
   Part No SW: 4K1 035 283 C    HW: 4K1 035 283 B
   Component: ConBox        H09 0233
   Serial number: 005CCA12F120368 Dataset Number: 4M0909612C  0012
   Coding: 01C020FE4040800000
   ROD: EV_ConBoxAU651_002.rod
I did not realize this but there is a different type and you appear to have it: EV_CGateCONTIAU491
Address 19: CAN Gateway (J533) Labels:* None​
Part No SW: 8W6 907 468 E HW: 8W6 907 468 E​
Component: Gateway H42 0118​
Revision: 6B030003 Serial number: 0386B763717928 Dataset Number: 4M0909515L 0080​
Coding: 03010001000006405407000000590030CC1A0000100000000175078E10000000​
Shop #: WSC 31414 790 00001​
GVL: 01503C0408000000C05C08000002C800100C2000000000000000000000000000​
ASAM Dataset: EV_CGateCONTIAU491 003092​
We have several scans like yours with that alternative CAN Gateway type and no #75 unit. I do not believe you have any control modules offline.
I'm going to do some more digging and report back if I spot a way to disable the malfunctioning antenna DTC.
This is experimental at best but please open the hood and then connect to address 19. Check Adaptation channel: [*IDE01996-SFT08107*] Installation list: specified installations - Antenna module
I think that's going to show Coded. If so, try changing it to Not coded. If it complains Error; Security Access Required try using 20103 first and repeat the attempt to change that channel.
Assuming it wasn't already set to Not Coded and you were able to make a change that might fix it? I suppose it is also possible that you will need to exit and lock the car with the remote so it can take a CAN nap before anything is conclusive.
harley909
MJ, SK, Canada
C?ID=612616
Really appreciate the response and idea, thank you!
So when I checked the adaptation channel there was no IDE01996-SFT08107.
There was IDE01996-SFT33031 specified installations - Antenna module. It was showing Not Coded.
I did not bother trying to change it from Not Coded to Coded...the question is...should I have?
I searched the rest of the list for anything about antennas and found nothing.
The only thing that worries me about "antennas" vs "cellular antenna" is that there are probably 3 antennas..correct? (Cellular, GPS and Satellite radio)...not sure how it would know one from the other but I guess it must as it specifically has a cellular antenna DTC.
PS
I did open the hood as instructed, I never realized that the hood had to be open before this...is that supposed to be done everytime the scan tool/vcds is done or just for adaptation reasons...or?
I also have the engine running when I run the scan tool and vcds....is that correct?
Only necessary if you're making when "writing" stuff; not when reading.
Depends. Some modules, particularly engine and transmission won't allow changes when the engine is running. Personally, I prefer to use a battery charger when spending more than a couple of minutes with a scan tool.
But then again, there can be a few things here and there for which the engine really should or even must be running.
harley909
MJ, SK, Canada
C?ID=612616
Great info and good to know. I’m new at vcds and there’s tons to learn and tons to read.
I’m struggling with understanding the logic when the cellular communication via SOS seems to work yet the antenna supposedly is throwing an open circuit code/error. Like the dealer, I have no interest in tearing the headliner out to change the harness if that’s even possible….. especially if it works. I just want the DTC to be gone.
With the 75 Telematics module there is a way you can disable the DTC, but it seems that not an option in my case.
I can’t help but be tempted to disconnect the battery just to try resetting the 19 CAN Gateway module just to see if it does anything.
Can anyone tell me what actually happens and what I’ll have to reprogram for the vehicle if I disconnect the battery?
I can see losing the radio presets, but what else? I don’t want to have to get it towed to the Dealer as that’s hours away.
The car should recover reasonably gracefully from having the battery disconnected. Should.
But if everything works, and the only issues are a spurious fault code and a warning message at start-up, why mess with it?
harley909
MJ, SK, Canada
C?ID=612616
Uwe, thank you again for the reply/info. I should probably heed your advice and count myself lucky that the issue is very minor. If or when I get it resolved I’ll share….hopefully to help anyone else that might run across the same issue. I know I’ll continue to appreciate the scan tool and VCDS for my Audi.
Thanks for that feedback. Since it was not enabled this must not be the answer.
I agree. I took a look at the component locators/overview and this car has several antennas! They make it clear as mud but this was the short summary of the config I believe you have:
Depending on the equipment, the following antennas may be included in the Roof Antenna - R216- :​
♦ GPS Antenna - R50-​
♦ Telephone Antenna - R65-​
♦ Satellite Antenna - R170-​
♦ Auxiliary Heater Antenna - R182-​
♦ Emergency Call Module Antenna - R263-​
♦ LTE Antenna 1 - R297-​
♦ Emergency Call Module Antenna 2 - R322-​
Then I looked at a few wiring diagrams and despite all of the possible configurations I think the one J533 is complaining about is: R263 Emergency Call Module Antenna
If I'm on the right path that leaves J533, has a TIM Coupling Point in Interior, Center connection point and then the final connection is at the roof antenna. That would explain why the dealer talked about pulling the headliner, etc.
In conclusion, you could leave it alone but I noticed your Extended DTC info includes GSM. The experimental coding in address 19 includes this Byte 25 option: External_GSM_Antenna - installed
My final suggestion is to connect to address 19 once more, make sure the hood is open and try coding it to:
03010001000006405407000000590030CC1A0000100000000171078E10000000
You would have the same end result if you clicked on Coding, clicked Yes when prompted to use experimental coding, scrolled over to Byte 25, un-ticked the External_GSM_Antenna box, exited the coding helper and clicked Do It.
If that corrects the DTC make sure basic bluetooth cell phone calls are still possible, that navigation still works, etc. If it creates new problems or does not mask the DTC after a CAN nap I'd restore the coding back to original.
harley909
MJ, SK, Canada
C?ID=612616
Thanks again for the great info. Before I give it a try I do have a new bit of info to add. I actually placed an SOS call with the vehicle and let it go all the way though. I talked to the Audi person and told them it was a malfunction check and to disregard. So that would indicate that the Emergency Call antenna must actually work….correct?
That being said it shouldn’t mean I can’t try your suggestion….right?
All it would mean is that if it works I’d just never get a DTC for that even though it works….which would be fine with me.
I think there are 2 total antennas; One inside the unit and one external.
We could dig through SSPs and similar but assuming this is correct that would explain how you can use it despite having the electrical (open circuit) DTC.
Keep in mind that bore scopes have really come down in price and there are many varieties . You could explore , under the headliner, with one of these. Preferably one with articulation (up to 180 degrees movement). They are a very versatile and useful tool, so its not like you could only use it for this project.
There are however metal roof braces that you will have to navigate ; so you may have to enter at several places along the sides. Locations above the front and rear door frames.
harley909
MJ, SK, Canada
C?ID=612616
Can someone please let me know what the "CAN nap" is? I made the coding changes and didn't notice any changes, still have the DTC and bluetooth etc still works.....just not sure if it's gone through the "CAN nap" yet.
harley909
MJ, SK, Canada
C?ID=612616
WooHoo....it worked!! Waited about 30 mins or so then restarted the Q7....DTC is gone and everything works just fine (fingers crossed).
Many thanks to Dana...and the Forum:)
For posterity:
- Ignition off
- Exit the vehicle & lock it from outside.
- Leave it alone for 20-30 minutes or longer.
In principle, this should make all the control modules shut down or at least go into sleep mode. Hence the term "nap".
