Thursday,20,March,2025,19:36:00:39142
VCDS Version: 25.3.0.4 (x64) HEX-V2 CB: 0.4660.5
Data version: 20250311 DS365.0
VIN: WAUBGAFL6GA003787 License Plate:
Mileage: 185410km-115208mi Repair Order:
Chassis Type: FL-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 22 36 3C 42 44 46 47 52 53 56
5F 62 6C 72 A9
VIN: WAUBGAFL6GA003787 Mileage: 185410km-115208miles
Address 01: Engine (J623-CTUB) Labels:. 06E-907-551-CGW.clb
Part No SW: 8K5 907 551 G HW: 4G0 907 551 A
Component: 3.0l V6 TFSIH07 0007
Revision: --H07--- CVN: AC625E4A
Coding: 0A250034052600060000
Shop #: WSC 06208 000 00000
ASAM Dataset: EV_ECM30TFS0218K5907551G 001007
ROD: EV_ECM30TFS021_AU48.rod
VCID: 3A2AECE95CD617BA813-806E
VINID: 9D19525D159C1974400031C81CCE15BD13
20136 - PCV Valve Malfunction
P052E 00 [01100101] - -
Mileage: 185416 km
Date: 2025.03.20
Time: 19:23:12
Engine speed: 705.00 /min
Normed load value: 8.6 %
Coolant temperature: 96 °C
Intake air temperature: 54 °C
Voltage terminal 30: 14.015 V
Engine speed: actual: 672 /min
MAF_ENVD: 114.38823 mg/stroke
Coolant temperature (unfiltered): 96.75 °C
Engine: operating status: IS
Engine load: 8.593750 %
Vehicle speed: actual: 0 km/h
Readiness: 1110 1101
Part No SW: 8K5 927 156 D HW: 0B5 927 156 K
Component: 0B5 30TFSINAR H03 0005
Revision: --H03--- CVN: 0000D444
Shop #: WSC 06325 000 00000
ASAM Dataset: EV_TCMDL501021 001025
ROD: EV_TCMDL501021.rod
Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V2.clb
Part No SW: 8K0 907 379 CP HW: 8K0 907 379 CP
Component: ESP8 quattro H09 0020
Coding: 291D1A01
VCID: 094843254930CC22D89-805C
Fault Frequency: 74
Reset counter: 23
Mileage: 184948 km
Date: 2025.03.09
Time: 15:46:10
Hex Value: 0x0000
Hex Value: 0x0722
Hex Value: 0x0015
Hex Value: 0x1098
Hex Value: 0x0000
Part No SW: 8K0 907 064 KM HW: 8K0 907 064 KM
Component: BCM2 2.0 H15 0711
Coding: 0D814040000000000000
VCID: 05504F156528A842BC1-8050
Subsystem 1 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
Serial number: 3215000110917009
Address 08: Auto HVAC (J255) Labels:. 8Kx-820-043-3Z.clb
Part No SW: 8K1 820 043 AQ HW: 8K1 820 043 AQ
Revision: C1000000 Serial number: 01300620150224
Coding: 6600228000
VCID: 77AC35DD2FC4CAD2BED-8022
Part No SW: 8K0 907 063 DH HW: 8K0 907 063 DH
Component: BCM1 1.0 H16 0103
Revision: 08016001 Serial number: 00001101388901
Coding: 26000091863CAFE0210048C300003D0D4F9CD308A2090221000008004000030100000030000000
Shop #: WSC 06325 123 12345
VCID: 78AE36E122DAC5AAB77-802C
Subsystem 1 - Part No SW: 8K1 955 119 B HW: 8K1 955 119 B Labels: 1KX-955-119.CLB
Component: MITSUBA210515 H19 0461
Serial number: 1505190600584
Coding: 004577
Component: G397_RLFS H06 0004
Serial number: 20394789
Coding: 02005D
Component: E1 - LDS H03 0031
Serial number: 00000000001106150117
Component: USHL4.2 H30 0030
Serial number: 00000000095Z01FC5556
Subsystem 5 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: BF2946B7000000000001
Part No SW: 8K0 959 655 Q HW: 8K0 959 655 Q
Component: AirbagVW-AU10 H51 0812
Serial number: 003NDD13DKJM Dataset Number: 8K0909602S 0001
Coding: 303844354730383131304A55304C384B3053
ASAM Dataset: EV_AirbaECUVWAUDI010 003114
VCID: 4BC4B92D034C9E322A5-801E
Subsystem 1 - Part No SW: 8K0 959 339 C HW: 8K0 959 339 C
Component: BF-Gewichtss. H02 0040
Serial number: 5810000R150000QD52
Serial number: 6334MSME523D4852F
Serial number: 6344MSME526E270BL
Serial number: 6352QSME7F56327E-
Serial number: 6362QSME6C58267C-
Serial number: 63732SME3850165A.
Serial number: 63832SME38502750U
Part No SW: 8K0 953 568 M HW: 8K0 953 568 M
Revision: -------- Serial number: 90372OFR00041
Coding: 000036
VCID: 44D692112E92514AEBF-8010
Part No SW: 8K0 920 983 HW: 8K0 920 983
Component: KOMBIINSTR. H35 0567
Revision: 00100000 Serial number: 63-65ET6G
Coding: 8BBF09008301D705020000
VCID: 72BA04C944A6AFFA893-8026
Part No SW: 8R0 907 468 AA HW: 8R0 907 468 D
Component: GW-BEM 5CAN-M H11 0070
Revision: 1Z130032 Serial number: 3241Z15603069E
Coding: 80C303FF00
VCID: 7EA220F900FEFB9AFDB-802A
Serial number: 0315037003
Address 22: AWD (J492) Labels: 8K0-907-163.clb
Part No SW: 8K0 907 163 B HW: 8K0 907 163 A
Component: 4 Wheel Drive H15 0100
Serial number: 001106150001014 Dataset Number: 8K0909104D 0025
VCID: 2F3CCDBD9794C21226D-807A
Address 36: Seat Mem. Drvr (J136) Labels:. 8T0-959-760.clb
Part No SW: 8K0 959 760 D HW: 8K0 959 760 D
Component: MEM-FS H06 0077
Revision: AA000000 Serial number: 00000154249841
Coding: 00581B00000000000000
VCID: 3B24E9ED536C2EB29A5-806E
Part No SW: 8T0 907 566 B HW: 8T0 907 566 B
Component: SWA Master H05 0071
Serial number: 0372597038 Dataset Number: 8K0909535J 0029
Coding: 010211
Shop #: WSC 06324 000 00000
ROD: EV_LaneChangAssis_AU48.rod
VCID: 3FDC9DFD47F43292B6D-806A
Subsystem 1 - Part No SW: 8T0 907 568 B HW: 8T0 907 568 B
Component: SWA Slave H05 0071
Serial number: 0371444861
Coding: 010211
Part No SW: 8T0 959 793 P HW: 8T0 959 793 G
Component: TSG FA H10 0305
Coding: 011C13204E00410001
VCID: 56F25859C80ED3DA85B-8002
Part No SW: 8K0 909 144 P HW: 8K0 909 144 B
Component: RCEPS H43 0510
Revision: 00001000 Serial number: 0007912351 Dataset Number: 8K0909852L 0026
Coding: 000000010001
Shop #: WSC 06324 123 12345
ASAM Dataset: EV_RCEPSAU48X 008018
ROD: EV_RCEPSAU48X_008.rod
VCID: 3E22E0F940FE3B9ABDB-806A
Revision: 00002001 Serial number: 0372785056
Coding: 0106063A00FE400582B0013200000000
Component: GTO BF H01 0080
Serial number: 00000000000001018720
Subsystem 3 - Part No SW: 8K0 959 591 C HW: 8K0 959 591
Component: J245 PS051 H08 0043
Part No SW: 8T1 035 223 A HW: 8T1 035 223 A
Component: DSP Prem H05 0030
Revision: 00005001 Serial number: 94813046057006
VCID: 2D00D7B59D18B002141-8078
Part No SW: 8T0 959 792 P HW: 8T0 959 792 G
Component: TSG BF H10 0305
VCID: 55F05F55D508D8C28C1-8000
Part No SW: 8K0 907 801 N HW: 8K0 907 801 J
Component: EPB-4 H02 0005
Revision: -------- Serial number: 00000001685464
ROD: EV_ParkiBrake_AU48.rod
Component: Radio U SIRIU H66 0133
Revision: AB001007 Serial number: 156F$0F8286402
Coding: 020007010000000001
VCID: 24163291CED2714ACBF-8070
Part No SW: 8R1 035 746 H HW: 8R1 035 746 G
Component: H-BNT-NA H43 0937
Revision: -------- Serial number: 523F%0F7570646
Coding: 110200000206A1EF55028B5E00000403140000000000000000
VCID: 3C26EAF15662298A93F-8068
Subsystem 1 - Part No: 8R0 060 884 CS
Component: NAR 2015 1201
Component: DU7 High H42 0104
Serial number: A130FT0F3393190
Subsystem 3 - Part No SW: 8T0 919 611 L HW: 8T0 919 611 C
Serial number: 00000002287322
Component: CD-Database 6208
Part No SW: 8T0 959 795 Q HW: 8T0 959 795 H
Component: TSG HL H08 0305
Coding: 010C13204000210001
VCID: 59E85365B910FCA2A89-800C
Address 6C: Back-up Cam. Labels: 8T0-907-441.clb
Part No SW: 8T0 907 441 C HW: 4L0 907 441 B
Revision: --H09--- Serial number: 525PA8-JA492MR
Coding: 1000006
VCID: 382EF6E16E5A05AA777-806C
Component: TSG HR H08 0305
Part No SW: 8K0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0006
Serial number: 150527200206
VCID: 72BA04C94426AFFA893-8026
End----------(Elapsed Time: 02:01, VBatt start/end: 12.4V/12.2V)-----------
------------------------------2 Faults Found-------------------------------
