Thursday,20,March,2025,17:05:35:11359
VCDS Version: 25.3.0.4 (x64) HEX-V2 CB: 0.4660.4
Data version: 20250311 DS365.0
VIN: WAUZZZ4MXGD025146 License Plate:
Mileage: 108672km-67525mi Repair Order: nick
Chassis Type: 4M-AU73 (8W7)
Scan: 01 02 03 06 08 09 13 15 16 17 18 19 23 29 36 39 3C 42 44 46
51 52 5F 69 6C 6D 74 81 82 84 8B 8C A5 AC BA BB BC C5 C6 CA
CF D6 D7
VIN: WAUZZZ4MXGD025146 Mileage: 108672km-67525miles
74-Chassis Control -- Status: Malfunction 0010
84-Night Vision -- Status: Malfunction 0010
C5-Therm. mgt. -- Status: Malfunction 0010
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CVZA) Labels: None
Part No SW: 4M0 997 401 HW: 059 907 309 F
Component: 3.0TDI MD1 H21 1002
Revision: C7H21--- CVN: 8C077414A1C78D2B31AEE35031AEE350
Coding: 2A2A403A057E050335382B00000000000000000000000000
Shop #: WSC 62327 005 1048576
ASAM Dataset: EV_ECM30TDI0114M0997401 001002
ROD: EV_ECM30TDI0114M0997401.rod
VCID: 6FBBDC12971FC98266D-803A
VINID: 9D196AAAA11DA1750008504418F744052C
Active accelerator pedal:
Subsystem 1 - Part No SW: 4M1 723 523 HW: 4M1 723 523
Component: J1115 - FFP H15 0007
Serial number: 123456789ABCDEFGHIJK
Starter generator:
Clutch electronics 1:
Subsystem 3 - Part No SW: 0D7 142 057 D HW: 0D7 142 057 D
Component: J1128 CCU H03 0022
5380 - Valve for Air Filter Bypass Flap (N275)
P1016 00 [00100111] - Open Circuit
Mileage: 108672 km
Date: 2025.03.20
Time: 16:38:43
Engine speed: 837.50 /min
Normed load value: 99.6 %
Coolant temperature: 36 °C
Intake air temperature: 23 °C
Voltage terminal 30: 14.140 V
Engine status: COENG_RUNNING
10065 - Mass Air Flow Sensor (G70)
P0104 00 [00100111] - Intermittent
Mileage: 108672 km
Date: 2025.03.20
Time: 16:38:43
Intake air temperature: 22 °C
Voltage terminal 30: 14.160 V
Mean injection quantity: 14.51 mg/stroke
Control Module temperature: 23.9 °C
EGR_governor_deviation: 178.7 mg/stroke
Inj Ctl q Curr: 14.51 mg/stroke
Standardized air flow ratio: 3.9999
Air mass at air mass meter 1: 80.9 kg/h
Actual charge pressure: 1056 hPa
Part No SW: 4M0 997 749 HW: 0D7 927 156 B
Component: 0D7 30TDIRdW H03 0006
Revision: --H03--- CVN: DFCCE705
Coding: 100000
Shop #: WSC 22475 001 1048576
ASAM Dataset: EV_TCMALX52011 002011
ROD: EV_TCMALX52011.rod
VCID: 7EA5F156C075B00AFDB-802A
ATF pump:
Subsystem 1 - Part No SW: 4M0 927 154 A HW: 0D7 321 281
Component: V552 ATFP D.3 0001
Serial number: 00011038
Address 03: ABS Brakes (J104) Labels: 4M0-907-379-V1.clb
Part No SW: 4M0 907 379 P HW: 4M0 907 379 P
Component: ESP9 Premium H09 0649
Dataset Number: 4M0909504H 0029 CVN: 9E814F6B
Coding: 2C9830B232A40A9BD19F1895188352AEF6A6DA340C4C508B18184A756F655B
Shop #: WSC 35400 002 1048576
ASAM Dataset: EV_ESP9BOSCHAU536P 011013
ROD: EV_ESP9BOSCHAU536P_AU73.rod
VCID: 44D143BEEE191ADAEBF-8010
Address 06: Seat Mem. Pass (J521) Labels:* None
Part No SW: 4M0 959 760 B HW: 4M0 959 760 B
Component: MEM-BFS 008 0015
Serial number: 00000167710719
Coding: 00183B000001B2A10060210101010000110000171700171700000000000000
Shop #: WSC 52744 002 1048576
ASAM Dataset: EV_SCMPasseSideCONTIAU736 006007
ROD: EV_SCMPasseSideCONTIAU736_AU49.rod
VCID: 372B2472AFCF41427ED-8062
Valve block 1 in front seat passenger side:
Subsystem 1 - Part No SW: 4M0 907 182 HW: 4M0 907 182
Component: N477 VB1 BFSv H06 0030
Serial number: SJ800118091501100043
Coding: BF2F00
Valve block 2 in front seat passenger side:
Subsystem 2 - Part No SW: 4M0 907 182 A HW: 4M0 907 182 A
Component: N478 VB2 BFSv H06 0030
Serial number: SJ80010909150110008D
Address 08: Auto HVAC (E87) Labels:* None
Part No SW: 4M0 820 043 AE HW: 4M0 820 043 AE
Component: Klima Zone 3 H52 0085
Coding: 661A48084548410D022C0280800000000000000000000000000000000000
ASAM Dataset: EV_AirCondiFrontBHTCAU736 001013
ROD: EV_AirCondiFrontBHTCAU736.rod
VCID: 6889B70EB2F11EBA277-803C
Subsystem 1 - Part No SW: 4M1 820 021 HW: 4M1 820 021
Component: J216 FLuftV H05 0003
Serial number: 00000000000000621025
Humidity sensor: exterior:
Subsystem 2 - Part No SW: 4H0 907 658 A HW: 4H0 907 658 A
Component: AQ_Hum_Sensor H01 0003
Serial number: 36384AC7000000000001
Subsystem 3 - Part No SW: 8W0 919 158 A HW: 8W0 919 158 A
Component: Klima Heck H34 0073
263425 - Temperature Sensor for Rear Right Seat
B1114 01 [00001001] - Electrical Failure
Reset counter: 130
Mileage: 108672 km
Date: 2025.03.20
Time: 16:24:23
Voltage terminal 30: 12.73 V
Outside temperature: 20.00 °C
459027 - Databus
Reset counter: 130
Mileage: 108672 km
Date: 2025.03.20
Time: 16:24:23
Address 09: Cent. Elect. (J519) Labels:* Redir Fail!
Part No SW: 8W0 907 063 AG HW: 8W0 907 063 G
Component: BCM1 MLBevo H12 0228
Dataset Number: 4M0909514M 0047
Coding: 07501B43C12900CD4103571958BF8CF9130331019000000000000000E00016810A4502AB32B71A
Shop #: WSC 06443 128 28888
ASAM Dataset: EV_BCM1BOSCHAU736 015005
ROD: EV_BCM1BOSCHAU736_015.rod
VCID: 00598FAEBA81C6FA8F7-8054
Subsystem 1 - Part No SW: 8U0 955 559 C HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0004
Serial number: 20660305
Coding: 0200FF
Subsystem 2 - Part No SW: 4M0 941 531 R HW: 4M0 941 531 R
Component: E1 - LDS H05 0007
Serial number: 22 08 2015 00077128
Subsystem 3 - Part No SW: 4M0 857 511 A HW: 4M0 857 511 A
Component: Y7_Innenspieg H08 0002
Serial number: GX1CE115091511520090
Coding: 030000
Interior Light Module:
Subsystem 4 - Part No SW: 4M0 947 135 AE HW: 4M0 947 135
Component: J528-Dachele H13 0080
Serial number: Q00042095
Subsystem 5 - Part No SW: 4M0 907 705 A HW: 4M0 907 705 A
Component: J866-EVLS-SG H03 0060
Serial number: WA121275000014401284
Coding: 020100
Subsystem 6 - Part No SW: 4M0 925 301 H HW: 4M0 925 301 H
Component: SL-Q7NF/AU736 H09 0006
Serial number: 00000000000000001213
Subsystem 7 - Part No SW: 4M0 963 575 HW: 4M0 963 575
Component: V512 LLR1SLvL H03 0012
Serial number: L14CF16800804
Subsystem 8 - Part No SW: 4M0 963 575 HW: 4M0 963 575
Component: V514 LLR1SKvL H03 0012
Serial number: L14CF17500848
Subsystem 9 - Part No SW: 4M0 963 575 HW: 4M0 963 575
Component: V516 LLR1SLvR H03 0012
Serial number: L14CF16800785
Subsystem 10 - Part No SW: 4M0 963 575 HW: 4M0 963 575
Component: V518 LLR1SKvR H03 0012
Serial number: L14CF17500841
65801 - Outside temperature sensor
B103F 15 [00001000] - Open or Short to Plus
Reset counter: 170
Mileage: 108672 km
Date: 2025.03.20
Time: 11:16:47
average_Voltage_terminals: 14.30 V
Outside air temperature sensor-Resistance: 120.32 kOhm
Outside air temperature sensor-Outside air temperature on CAN: Malfunction
interior_temperature: 21.50 °C
Vehicle speed: 0.00 km/h
65940 - Control Module for Wiper Motor
U10A3 00 [00001001] - No Communications
Fault Frequency: 18
Reset counter: 130
Mileage: 108672 km
Date: 2025.03.18
Time: 13:48:43
average_Voltage_terminals: 12.50 V
Outside air temperature sensor-Outside air temperature on CAN: 17.50 °C
interior_temperature: 21.00 °C
Terminal activation-Terminal 75 status: OFF
Terminal activation-Terminal 15 status signal: OFF
Terminal activation-Terminal 15 via CAN: OFF
196913 - Databus
Reset counter: 170
Mileage: 108672 km
Date: 2025.03.20
Time: 11:16:46
327704 - Databus
Reset counter: 170
Mileage: 108672 km
Date: 2025.03.20
Time: 11:16:47
Address 13: Auto Dist. Reg (J428) Labels:* Redir Fail!
Part No SW: 4M0 907 561 E HW: 4M0 907 561
Component: LRR4 H10 0220
Dataset Number: 4M0909863J 0022
Coding: 5477FFFB58FFEC08949C80E4
ASAM Dataset: EV_ACCBOSCHAU736 002018
ROD: EV_ACCBOSCHAU49X_002.rod
VCID: 323D156644ADA46A493-8066
0795 - Databus
[FAULT_APS_RELEVANT_ERROR]
Reset counter: 170
Mileage: 108672 km
Date: 2025.03.20
Time: 11:16:47
Control Module temperature: 57 °C
Voltage terminal 15: 14.1 V
2153 - Databus
[FAULT_HC_STA_FAIL]
Reset counter: 130
Mileage: 108672 km
Date: 2025.03.19
Time: 21:17:59
Control Module temperature: 37 °C
Voltage terminal 15: 12.7 V
1392 - Databus
U1122 00 [00001000] - Implausible Message
[FAULT_LRRS_SELFDIAG]
Reset counter: 170
Mileage: 108672 km
Date: 2025.03.20
Time: 11:16:45
Voltage terminal 15: 14.2 V
1395 - Databus
[FAULT_TEMP_FAIL]
Reset counter: 170
Mileage: 108672 km
Date: 2025.03.20
Time: 11:16:45
Address 15: Airbags (J234) Labels:| 80A-959-655.clb
Part No SW: 4M0 959 655 HW: 4M0 959 655
Component: Airbag10.44 H50 0086
Serial number: 003L1000V1HV Dataset Number: 4M0909602K 0002
Coding: AAFCF0C00CA0000098F600F3C04C00000000
ASAM Dataset: EV_AirbaAU10BPAAU736 005012
ROD: EV_AirbaAU10BPAAU736_005.rod
VCID: 78A9E74EE2518E3AB77-802C
Left seat belt tensioner:
Subsystem 1 - Part No SW: 4M0 980 945 HW: 4M0 980 945
Component: BeltPretRevFL 205 2033
Serial number: 4M0857705D0269P00465
Coding: 88001B
Right seat belt tensioner:
Subsystem 2 - Part No SW: 4M0 980 946 HW: 4M0 980 946
Component: BeltPretRevFR 205 2033
Serial number: 4M0857706D0269P00240
Coding: 88001B
Subsystem 3 - Part No SW: ----------- HW: 442 062 609 15
Serial number: 3577Y00A51A537D4331Z
Subsystem 4 - Part No SW: ----------- HW: 442 062 609 15
Serial number: 3587Y00A51A537D1443.
Subsystem 5 - Part No SW: ----------- HW: 442 0B2 009 15
Serial number: 3517700C71C81BC3E2AU
Subsystem 6 - Part No SW: ----------- HW: 442 0B2 009 15
Serial number: 352770016293A8296824
Subsystem 7 - Part No SW: ----------- HW: 442 0C2 708 15
Component: FrontSensor_D 1C5 014A
Serial number: 3557500C11C3DEC372EX
Subsystem 8 - Part No SW: ----------- HW: 442 0C2 708 15
Component: FrontSensor_P 1C5 014A
Serial number: 3567500C11C3DEC5910N
Subsystem 9 - Part No SW: ----------- HW: 442 0C3 108 15
Component: PedP_Sensor_C 1C5 014A
Serial number: 2307500C91C4D052433%
Subsystem 10 - Part No SW: ----------- HW: 442 422 808 15
Component: PedPSensor_D2 21E 0887
Serial number: I0M8U00C91A3894513FT
Subsystem 11 - Part No SW: ----------- HW: 442 422 808 15
Component: PedPSensor_P2 21E 0887
Serial number: I0N8U00C71A38941A46P
Central crash sensor X/Y:
Subsystem 12 - Part No SW: ----------- HW: 410 201 308 15
Component: CentrSensorXY 1C8 0108
Serial number: I0O7800C71A580C5316+
7 Faults Found:
9445397 - Key switch for deactivation of passenger-side airbag
B1020 15 [10001001] - Open or Short to Plus
Mileage: 108672 km
Date: 2025.03.19
Time: 21:21:41
9446677 - Redundant signal path for airbag shut-off; passenger side
B1025 15 [10001001] - Open or Short to Plus
Mileage: 108672 km
Date: 2025.03.19
Time: 21:21:41
1061381 - Databus
[NWD: 0x5E1 Klima_Sensor_02 error value BCM1_Aussen_Temp_ungef]
Reset counter: 170
Mileage: 108672 km
Date: 2025.03.20
Time: 11:16:45
1060613 - Databus
[NWD: 0xTBD SDF_PSF_01 error value SDF_PSF_Objektstatus]
Reset counter: 170
Mileage: 108672 km
Date: 2025.03.20
Time: 11:16:46
1060614 - Databus
[NWD: 0xTBD SDF_PSF_01 error value SDF_PSF_Time_To_Collision]
Reset counter: 170
Mileage: 108672 km
Date: 2025.03.20
Time: 11:16:46
1060615 - Databus
[NWD: 0xTBD SDF_PSF_01 error value SDF_PSF_v_rel]
Reset counter: 170
Mileage: 108672 km
Date: 2025.03.20
Time: 11:16:46
1060617 - Databus
[NWD: 0xTBD SDF_PSF_01 error value SDF_PSF_CW]
Reset counter: 170
Mileage: 108672 km
Date: 2025.03.20
Time: 11:16:46
Part No SW: 4M0 907 129 JE HW: 4M0 907 129 JE
Component: Lenks.Modul H11 0009
ROD: EV_SMLSKLOAU736_006.rod
VCID: 7CA1FB5ED669A21AD3F-8028
Address 17: Instruments (J285) Labels:* Redir Fail!-SRI2
Part No SW: 4M0 920 794 B HW: 4M0 920 794 B
Component: FHybRDW H16 0306
Coding: 040401C07C98000800A669703204600000000000
Shop #: WSC 05843 007 1048576
ASAM Dataset: EV_DashBoardAU736 001022
ROD: EV_DashBoardAU736_AU73.rod
U1014 00 [00001001] - -
[ECU incorrectly coded]
Fault Frequency: 14
Reset counter: 130
Mileage: 108672 km
Date: 2025.03.19
Time: 11:40:12
13639936 - Databus
[ECU for body control modul error error value recieved]
Reset counter: 170
Mileage: 108672 km
Date: 2025.03.20
Time: 11:16:46
Address 18: Aux. Heat (J364) Labels:| 4M0-265-105.clb
Part No SW: 4M0 265 105 E HW: 4M0 265 105 E
Component: HSG H09 0060
Dataset Number: 4M0909858C 0015
Coding: 0D0803
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_AuxilParkHeateEBEAU736 001016
ROD: EV_AuxilParkHeateEBEAU736.rod
VCID: 290FF20A697BE7B2F89-807C
1048611 - Databus
[Klima_Sensor_02 - BCM1 databus received error value: Klima_Sensor_02 - BCM1 Datenbus empfangener Fehlerwert]
Reset counter: 170
Mileage: 108672 km
Date: 2025.03.20
Time: 11:16:45
Coolant temperature of parking heater: 26 °C
Coolant temperature of auxiliary heater_Textual: numerical value: no text
Engine_coolant_temperature: 25.50 °C
Engine_coolant_temperature_Textual: numerical value: no text
Voltage terminal 30: 14.20 V
System condition: 10
Auxiliary heater operating status: OFF
Outside_Temperature_Additional_Heating: 20.50 °C
Engine_Speed: 0.00 /min
Fuel_Level_Input_Heater: 32 l
337161 - Databus
[Kombi_02 - Schalttafeleinsatz databus received error value: Kombi_02 - Schalttafeleinsatz Datenbus empfangener Fehlerwert "KBI_Aussen_temp_gef"]
Reset counter: 170
Mileage: 108672 km
Date: 2025.03.20
Time: 11:16:46
Outside_Temperature_Additional_Heating: 77.00 °C
315659 - Coolant Shut-Off Valve
B10C8 13 [00001000] - Open Circuit
Reset counter: 170
Mileage: 108672 km
Date: 2025.03.20
Time: 11:35:19
Coolant temperature of parking heater: 28 °C
Engine_coolant_temperature: 48.75 °C
Voltage terminal 30: 14.30 V
Outside_Temperature_Additional_Heating: 20.00 °C
Part No SW: 8W7 907 468 B HW: 8W7 907 468
Component: Gateway H12 0089
Revision: 3M130046 Serial number: 4683M320118512 Dataset Number: 4M0909515H 0055
Coding: 0201010100020EC08C82010000590032DCD20007180000000175079E00000000
Shop #: WSC 12273 002 1048576
GVL: 09503C0888440008D4FCC8000006C818110C0000000000000000000000000000
ASAM Dataset: EV_CGateCONTIAU491 002027
ROD: EV_CGateCONTIAU491_002_AU49.rod
VCID: 4ACD6D86CC3DCCAA113-801E
Subsystem 1 - Part No SW: 4M0 951 523 A HW: 4M0 951 523 A
Component: J453 MFL H06 0002
Serial number: 20150918080708 00383
Subsystem 2 - Part No SW: 8S0 915 181 HW: 8S0 915 181
Serial number: 8657867803
8531970 - Quiescent Current
U1406 00 [00001001] - Too High
[Electric_current_Upper_Limit_Value_Exceeded]
Reset counter: 130
Mileage: 108672 km
Date: 2025.03.20
Time: 11:03:38
Total static current-current total quiescent current: 178 mA
Total static current-Total time quiescent current exceeded: 6.0 H
EM_vehicle_state: 02 14
6291457 - Control Module Blocked
B2017 00 [00001001] - -
[Immobilizer_Locked]
Reset counter: 130
Address 23: Brake Booster (J539) Labels: None
Part No SW: 4M0 909 059 C HW: 4M0 909 059
Component: J539 EBKV H11 0194
Serial number: 085430010616 Dataset Number: 4M0909524G 0001
ASAM Dataset: EV_BrakeBoostBOSCHAU736 001001
ROD: EV_BrakeBoostBOSCHAU736.rod
VCID: 3431137EBEB9AA5A5BF-8060
Brake pressure reservoir:
Subsystem 1 - Part No SW: 4M0 909 057 A HW: 4M0 909 057
Component: VX70BrakeAssi H04 0153
Serial number: 05802861210715064755
Address 29: Left Light (J1018) Labels: 4M0-907-397.clb
Part No SW: 4M0 907 397 AD HW: 4M0 907 397 D
Component: LCM_MLBevoH05 0024
Dataset Number: 4M0909519B 0001
VCID: 79AFE24AD95B9732C89-802C
Component: MEM-FS 008 0015
Serial number: 00000167710535
Coding: 00183B000001B2A10000210101010000110000171700171700000000000000
ASAM Dataset: EV_SCMDriveSideCONTIAU736 006007
Valve block 1 in front seat driver side:
Component: N475 VB1 FSv ÿÿÿ 0030
Serial number: ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
Coding: BF2F00
Valve block 2 in front seat driver side:
Component: N476 VB2 FSv H06 0030
Serial number: SJ80010909150110009A
Address 39: Right Light (J1023) Labels: 4M0-907-397.clb
Dataset Number: 4M0909520B 0001
Address 3C: Lane Change (J769) Labels:| 4M0-907-566.clb
Part No SW: 4M0 907 566 B HW: 4M0 907 566
Component: MRR1Rear H13 0230
Revision: -------- Dataset Number: 4M0909535K 0012
Coding: 1EC002
ASAM Dataset: EV_RearRadarS1BoschAU736 001015
Part No SW: 4M0 959 793 E HW: 4M0 959 793 C
Component: TSG FS 009 0055
Serial number: 0000166892786 Dataset Number: 4M0909872E 0024
Coding: 005D9B015E000082000930B2
VCID: 40D94FAEFA0106FACF7-8014
B1487 54 [00001001] - Missing Calibration / Basic Setting
Reset counter: 129
Mileage: 108634 km
Date: 2025.03.17
Time: 11:00:16
Part No SW: 4N0 909 144 G HW: 4N0 909 144 C
Component: EPS_MLBEVO2BS H22 0507
Dataset Number: 4M0909852VB 0001
Coding: B0150101010001
Shop #: WSC 36386 004 1048576
ROD: EV_EPSVWBSAU426_010.rod
Part No SW: 8W0 907 064 CD HW: 4M0 907 064 D
Component: BCM2 MLBevo 015 0344
Dataset Number: 4M0909501VF 0001
Coding: 01741E006F0000E06309A0006E00580203004000004F02502F0400000504803F001F0001000000
ASAM Dataset: EV_BCM2HellaAU736 012013
ROD: EV_BCM2HellaAU736_012_AU73.rod
Subsystem 1 - Part No SW: 5Q0 951 177 HW: 5Q0 951 172
Serial number: 000000000ZY162041QYF
Subsystem 2 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Component: Sirene, DWA 004 0310
Serial number: 00000000000010003213
Subsystem 3 - Part No SW: 3AA 962 243 F HW: 3AA 962 243 F
Component: GEB.F.Heckoef H16 0816
Serial number: 94022592
640001 - Bulb for Left Brake Lamp / Tail Lamp
B133A 13 [00001001] - Open Circuit
Reset counter: 130
Mileage: 108672 km
Date: 2025.03.20
Time: 11:31:53
Supply voltages-Terminal 30 power supply: 12.120 V
Supply voltages-Supply voltage Terminal 30 - 2: 12.147 V
Supply voltages-Supply voltage Terminal 30 - 3: 12.120 V
general_additional_freeze_frame-terminal_control_intern_status: 1B 01 0A 10 04 E0
light_freeze_frame: 11111111 11111111 11111111 11111111
Address 51: Electric Drive (J841) Labels: None
Part No SW: 4M1 907 080 A HW: 4M1 907 080 A
Component: A73P7827S1000 H02 0018
Revision: --H02--- CVN: 7D0183D6
Coding: 01000000000000000000
ASAM Dataset: EV_DMCM08530214M1907080A 001011
ROD: EV_DMCM08530214M2907080.rod
VCID: 2B0308026387F5A20A5-807E
Part No SW: 4M0 959 792 E HW: 4M0 959 792 C
Component: TSG BFS 009 0055
Serial number: 0000167816457 Dataset Number: 4M0909873E 0024
Coding: 005D9B015E000082000930B0
VCID: 3FDB4C5287FF7902B6D-806A
Address 5F: Information Electr. (J794) Labels:* 4M0-035-MIB-HGH2.clb
Part No SW: 4M0 035 035 Q HW: 4M0 035 035 A
Component: MU-P-LND-EU 050 0442
Serial number: A649I0F7501941 Dataset Number: 4M0909545G 0035
Coding: 013796010000000053111102000A00332F001DE5017001009E
Shop #: WSC 00052 666 28888
Subsystem 1 - Part No SW: V03 959 801 PR HW: -----------
Component: ECE 2018 --- 0166
Multimedia display unit 1:
Subsystem 2 - Part No SW: 4M0 919 605 HW: 4M0 919 605
Component: AU536_DU_HIGH H43 0008
Serial number: AUZ8Z9FJ400VSJ
Subsystem 3 - Part No SW: 4M0 919 615 D HW: 4M0 919 615 D
Component: ControlUnit_P H14 0165
Serial number: 24091500000000000273
Compact disc data bank:
Component: Gracenote2 --- 1011
Part No SW: 4M0 907 383 D HW: 4M0 907 383 B
Component: Anhaenger H18 0214
Revision: 9A001002 Serial number: 0368193018 Dataset Number: 4M0909527C 0021
Coding: 0110000202010000
VCID: 33331062BBB7AD62425-8066
Bend angle sensor for trailer:
Subsystem 1 - Part No SW: 4M0 907 811 HW: 4M0 907 811
Component: G820 KNWINSEN H18 0019
Serial number: 12082
Part No SW: 4M0 907 428 D HW: 4M0 907 428
Component: Areaview 2 H11 0311
Serial number: C854606JG001381 Dataset Number: 4M1909460F 0018
Coding: 02350601BF0FA10008404500
ASAM Dataset: EV_CamSysRVAV2CE2MLBEv 004015
ROD: EV_CamSysRVAV2CE2MLBEv_004.rod
Part No SW: 4M0 959 107 A HW: 4M0 959 107
Component: HDSG-Modul H12 0155
Revision: -------- Serial number: 30242383700000 Dataset Number: 4M0909541F 0023
Coding: 00F0
ASAM Dataset: EV_DeckLidCONTIAU736 001012
VCID: 313F1A6A41AB9F72309-8064
0066 - Databus
Reset counter: 170
Mileage: 108672 km
Date: 2025.03.20
Time: 11:16:49
Address 74: Chassis Control (J775) Labels:* Redir Fail!
Part No SW: 4M0 907 777 E HW: 4M0 907 777 C
Component: Fahrwerk-SG H10 0104
Serial number: 2508150468 Dataset Number: 4M0909576P 0043
Coding: 98587080F8
ASAM Dataset: EV_ChassContrContiAU736 002013
ROD: EV_ChassContrContiAU736.rod
VCID: 3B23384293E765229A5-806E
Air Suspension Compressor:
Subsystem 1 - Part No SW: 4M0 907 778 A HW: 4M0 907 778
Component: V66LFKompOLV H06 0015
Serial number: 00000000004133453289
Coding: 303030
4456450 - Diagnostic Gateway Module
U0447 00 [00001000] - Implausible Signal
[Function_restriction_due_to_communication_interruption_AmbientTemperature]
Reset counter: 170
Mileage: 108672 km
Date: 2025.03.20
Time: 11:16:47
4456460 - Diagnostic Gateway Module
[Function_restriction_due_to_communication_interruption_AmbientTemperatureFiltered]
Reset counter: 170
Mileage: 108672 km
Date: 2025.03.20
Time: 11:16:51
Address 81: Gear Shift (J587) Labels: 4MX-713-041-81.clb
Part No SW: 4M1 713 041 D HW: 4M1 713 041 D
Component: GSM-LL H07 0073
Revision: 0L0D5012 Serial number: 20150829001819
ASAM Dataset: EV_GSMWaehlZFAU736 001016
ROD: EV_GSMWaehlZFAU736.rod
VCID: 2615F9367865C8CAD5B-8072
Address 82: Head Up Display (J898) Labels:| 4M0-919-617-V1.clb
Part No SW: 4M0 919 617 HW: 4M0 919 617
Component: HeadUpDisplay H26 1553
Coding: 5F00C0
ASAM Dataset: EV_HudNSEIKAU736 001015
ROD: EV_HudNSEIKAU736_AU73.rod
VCID: 72BDD566842DE46A893-8026
Address 84: Night Vision (J853) Labels:* 4M0-907-547.clb
Part No SW: 4M0 907 547 A HW: 4M0 907 547
Component: NV-ECU-Gen3 H08 0027
Serial number: 629228400201525
Coding: 200111
ASAM Dataset: EV_NightVisioG3AUTOLAU736 001001
ROD: EV_NightVisioG3AUTOLAU736_AU73.rod
Night vision system camera:
Subsystem 1 - Part No SW: 4G0 980 552 HW: 4G0 980 552
Component: NV-CAM-Gen3 H03 0006
Serial number: 623466500F1522200347
9730 - Databus
[Kombi (Instrument Cluster): outer temperature: defective]
Reset counter: 170
Mileage: 108672 km
Date: 2025.03.20
Time: 11:16:47
Address 8B: Adaptive Cruise 2 (J850) Labels: 4M0-907-541.clb
Part No SW: 4M0 907 541 E HW: 4M0 907 541
Dataset Number: 4M0909885G 0020
ASAM Dataset: EV_ACC2BOSCHAU736 002018
ROD: EV_ACC2BOSCHAU736_002_AU73.rod
VCID: 30391F6E4AA1967A3F7-8064
1395 - Databus
[FAULT_TEMP_FAIL]
Reset counter: 170
Mileage: 108672 km
Date: 2025.03.20
Time: 11:16:45
Control Module temperature: 56 °C
Address 8C: HV Battery (J840) Labels: None
Part No SW: 4M0 915 233 E HW: 4M0 915 233 E
Component: BMC_PHEV_PL73 H07 0195
Dataset Number: 4M0909107VA 0001
ASAM Dataset: EV_BECM0842071 001004
ROD: EV_BECM0842071_AU49.rod
VCID: 2D07061A5D93FB92141-8078
Battery interrupt switch:
Subsystem 1 - Part No SW: 4M0 915 253 E HW: 4M0 915 253 E
Component: J990 H17 0200
Cell module control module 1:
Subsystem 2 - Part No SW: 4M0 915 115 A HW: 4M0 915 115 A
Component: J991 H08 0105
Cell module control module 2:
Subsystem 3 - Part No SW: 4M0 915 115 A HW: 4M0 915 115 A
Component: J992 H08 0105
Cell module control module 3:
Subsystem 4 - Part No SW: 4M0 915 115 A HW: 4M0 915 115 A
Component: J993 H08 0105
Cell module control module 4:
Subsystem 5 - Part No SW: 4M0 915 115 A HW: 4M0 915 115 A
Component: J994 H08 0105
Cell module control module 5:
Subsystem 6 - Part No SW: 4M0 915 115 A HW: 4M0 915 115 A
Component: J995 H08 0105
Cell module control module 6:
Subsystem 7 - Part No SW: 4M0 915 115 A HW: 4M0 915 115 A
Component: J996 H08 0105
Cell module control module 7:
Subsystem 8 - Part No SW: 4M0 915 115 A HW: 4M0 915 115 A
Component: J997 H08 0105
Cell module control module 8:
Subsystem 9 - Part No SW: 4M0 915 115 A HW: 4M0 915 115 A
Component: J998 H08 0105
Cell module control module 9:
Subsystem 10 - Part No SW: 4M0 915 115 A HW: 4M0 915 115 A
Component: J999 H08 0105
Cell module control module 10:
Subsystem 11 - Part No SW: 4M0 915 115 A HW: 4M0 915 115 A
Component: J1000 H08 0105
Cell module control module 11:
Subsystem 12 - Part No SW: 4M0 915 115 A HW: 4M0 915 115 A
Component: J1001 H08 0105
Cell module control module 12:
Subsystem 13 - Part No SW: 4M0 915 115 A HW: 4M0 915 115 A
Component: J1002 H08 0105
Cell module control module 13:
Subsystem 14 - Part No SW: 4M0 915 115 A HW: 4M0 915 115 A
Component: J1045 H08 0105
Cell module control module 14:
Subsystem 15 - Part No SW: 4M0 915 115 A HW: 4M0 915 115 A
Component: J1046 H08 0105
Address A5: Frt Sens. Drv. Assist (R242) Labels:* None
Part No SW: 4M0 907 217 D HW: 4M0 907 217 A
Component: BVS H12 0042
Dataset Number: 4M0909466J 0038
Coding: 040703060000040202202397CD0000B4B0F0C020F280
ROD: EV_BVSMLBevKOSTAAU736_AU73.rod
VCID: 2F3B1C12579F898226D-807A
1123714 - Databus
[Airbag_01_AB_Systemfehler]
Reset counter: 130
Mileage: 108672 km
Date: 2025.03.19
Time: 21:16:22
Control Module temperature: 28 °C
Voltage terminal 15: 12.80 V
1123735 - Databus
[APS_Master_US_relevanter_Fehler]
Reset counter: 170
Mileage: 108672 km
Date: 2025.03.20
Time: 11:16:47
Control Module temperature: 38 °C
Voltage terminal 15: 14.40 V
Address AC: Reductant Control (J880) Labels: 4M0-907-355.clb
Part No SW: 4M0 907 355 HW: 4M0 907 355
Component: SCR-Stg-G3H10 0003
Dataset Number: 4M0909571E 0012
ASAM Dataset: EV_RDCMINERGAU736 005009
ROD: EV_RDCMINERGAU736.rod
VCID: 6E85C1169015C08A6DB-803A
Address BA: Motor Mounts (J931) Labels: None
Part No SW: 4M0 907 145 D HW: 4M0 907 145 B
Component: AEMevo H09 0111
Dataset Number: 4M0909578G 0015
ASAM Dataset: EV_AEMZFAU736 006012
ROD: EV_AEMZFAU736_006.rod
Part No SW: 4M0 959 795 E HW: 4M0 959 795 C
Component: TSG HFS 009 0055
Serial number: 0000167623545 Dataset Number: 4M0909897E 0025
Coding: 004D990000000082000830A0
ROD: EV_DCU2RearDriveMAXHCONT_VW37.rod
VCID: 42DD45A6F40D14EAD93-8016
Component: TSG HBFS 009 0055
Serial number: 0000167623541 Dataset Number: 4M0909896E 0025
ROD: EV_DCU2RearPasseMAXHCONT_VW37.rod
Address C5: Therm. mgt. (J1024) Labels:* None
Part No SW: 4M0 965 429 D HW: 4M0 965 429 B
Component: TME-Max H04 0021
Serial number: 0012470
Coding: 01
ASAM Dataset: EV_ThermContrVISAU49X 001023
ROD: EV_ThermContrVISAU49X_VW37.rod
VCID: 3829274EA2D14E3A777-806C
Subsystem 1 - Part No SW: 4M0 959 603 C HW: 4M0 959 603 C
Component: G395 pT-Sens1 H11 0010
Subsystem 2 - Part No SW: 12E 963 231 F HW: 12E 963 231 F
Component: J848 HV-PTC H09 0206
Serial number: LM152293003807000116
A/C compressor sub:
Subsystem 3 - Part No SW: 4M0 816 797 A HW: 4M0 816 797 A
Component: J842 EKK es33 H02 0012
Serial number: 00000000015070200251
A/C pressure/coolant temperature sensor 2:
Subsystem 4 - Part No SW: 4M0 959 603 C HW: 4M0 959 603 C
Component: G826 pT-Sens2 H11 0010
A/C pressure/coolant temperature sensor 3:
Subsystem 5 - Part No SW: 4M0 959 603 C HW: 4M0 959 603 C
Component: G827 pT-Sens3 H11 0010
Expansion valve 1 for refrigerant:
Subsystem 6 - Part No SW: 4M0 816 682 B HW: 4M0 816 682 B
Component: N636 EV1_KaMi H09 0102
Serial number: 00000000000050071963
Shut-off valve 2 for refrigerant:
Subsystem 7 - Part No SW: 4M0 816 702 HW: 4M0 816 702
Component: N640 AV2_KaMi H09 0102
Serial number: 00000000000030066306
Shut-off valve 3 for refrigerant:
Subsystem 8 - Part No SW: 4M0 816 702 HW: 4M0 816 702
Component: N641 AV3_KaMi H09 0102
Serial number: 00000000000030066345
Shut-off valve 4 for refrigerant:
Subsystem 9 - Part No SW: 4M0 816 702 HW: 4M0 816 702
Component: N642 AV4_KaMi H09 0102
Serial number: 00000000000030066347
Shut-off valve 5 for refrigerant:
Subsystem 10 - Part No SW: 4M0 816 702 HW: 4M0 816 702
Component: N643 AV5_KaMi H09 0102
Serial number: 00000000000030066352
54016 - HV Electronics Coolant Pump Control
P0CEA 00 [00101100] - Implausible Signal
Mileage: 108672 km
Date: 2025.03.20
Time: 16:39:10
Expanded ambient data 1-Voltage terminal 30: 0.000 V
Expanded ambient data 1-Vehicle speed: 0 km/h
Expanded ambient data 1-System status: Control module in after-run
Expanded ambient data 1-Power quota setting by energy management: 00
Expanded ambient data 1-Status of drive readiness hybrid: Engine off or drive is not ready
Expanded ambient data 1-Ambient temperature: 21.00 °C
Expanded ambient data 1-current state of low temp.circ.: 00
Expanded ambient data 1-previous state low-temp.circ.: 00
Expanded ambient data 1-Operating time in the current state of the low temp.circ.: 00
Expanded ambient data 1-current state of high-temp.circ.: 00
Expanded ambient data 1-previous state of high-temp.circ.: 00
Expanded ambient data 1-Operating time in the current state of the high temp.circ.: 00
Expanded ambient data 1-current state of battery low temp.circ.: 00
Expanded ambient data 1-previous state of battery low temp.circ.: 07
Expanded ambient data 1-Operating time in current state of the battery low temp.circ.: 02
Expanded ambient data 1-current state of battery cold circuit: 00
Expanded ambient data 1-previous state of battery cold circuit: 10
Expanded ambient data 1-Operating time in the current state of the cold circuit: 02
Coolant fan 1: activation: 10.00 %
Coolant fan 2: activation: 10.00 %
Engine Coolant Temperature Sensor 1: 23.20 °C
Engine Coolant Temperature Sensor 5: 24.20 °C
Coolant pump for low-temperature circuit-Act.val.: 0
Coolant pump for low-temperature circuit-Specified value: 10
Coolant recirculation pump-Act.val.: 0
Coolant recirculation pump-Specified value: 10
Coolant circulation pump 2-Act.val.: 0
Coolant circulation pump 2-Specified value: 0
HV heater temperature-Temperature 1: 65.00 °C
HV heater temperature-Temperature 2: 38.00 °C
60006 - Refrigerant Pressure for Heating of Passenger Compartment
B16A3 85 [01101101] - Signal Above Allowable Range
Mileage: 108672 km
Date: 2025.03.20
Time: 16:38:57
Expanded ambient data 1-System status: Drive readiness
Expanded ambient data 1-Power quota setting by energy management: 15
Expanded ambient data 1-Status of drive readiness hybrid: Hybrid driving
Expanded ambient data 1-current state of battery low temp.circ.: 07
Expanded ambient data 1-previous state of battery low temp.circ.: 05
Expanded ambient data 1-Operating time in current state of the battery low temp.circ.: 00
Expanded ambient data 1-current state of battery cold circuit: 10
Expanded ambient data 1-Operating time in the current state of the cold circuit: 39
A/C pressure/temperature sensor 1-Refrigerant pressure: 27.17 bar
A/C pressure/temperature sensor 1-Communication: OK
A/C pressure/temperature sensor 1-Malfunction status: OK
A/C pressure/temperature sensor 1-Response error: OK
A/C pressure/temperature sensor 1-Inside temperature: 52.70 °C
A/C pressure/temperature sensor 1-Test Result: Tested in current operating cycle
A/C pressure/temperature sensor 1-Refrigerant temperature: 76.90 °C
A/C pressure/temperature sensor 2-Refrigerant pressure: 4.91 bar
A/C pressure/temperature sensor 2-Communication: OK
A/C pressure/temperature sensor 2-Malfunction status: OK
A/C pressure/temperature sensor 2-Response error: OK
A/C pressure/temperature sensor 2-Inside temperature: 24.00 °C
A/C pressure/temperature sensor 2-Test Result: Tested in current operating cycle
A/C pressure/temperature sensor 2-Refrigerant temperature: 16.90 °C
A/C pressure/temperature sensor 3-Refrigerant pressure: 4.97 bar
A/C pressure/temperature sensor 3-Communication: OK
A/C pressure/temperature sensor 3-Malfunction status: OK
A/C pressure/temperature sensor 3-Response error: OK
A/C pressure/temperature sensor 3-Inside temperature: 22.30 °C
A/C pressure/temperature sensor 3-Test Result: Tested in current operating cycle
A/C pressure/temperature sensor 3-Refrigerant temperature: 17.80 °C
Refrigerant pressure: 4.90 bar
60016 - Interior Pre-Conditioning
P13F1 00 [00101111] - Not Started
Mileage: 108672 km
Date: 2025.03.20
Time: 16:38:45
Expanded ambient data 1-current state of battery low temp.circ.: 05
Expanded ambient data 1-Operating time in current state of the battery low temp.circ.: 2D
Expanded ambient data 1-Operating time in the current state of the cold circuit: 2E
Address C6: Batt. Chrg. (AX4) Labels:* 5QE-915-681.clb
Part No SW: 5QE 915 681 AA HW: 5QE 915 681 AA
Component: OBC Delta-ES H57 0721
Dataset Number: 4M0909811E 0013
Coding: 11508B207004
Shop #: WSC 00222 211 00000
ASAM Dataset: EV_OBCTwoPhaseDT2AU736 006011
ROD: EV_OBCTwoPhaseDT2AU736.rod
VCID: 0B43A88283C795A2EA5-805E
Part No SW: 4M0 907 594 HW: 4M0 907 594
Component: SAD_STG_1 011 0003
Dataset Number: 4M0909469E 0013
Coding: 608000053602
VCID: 73B3D062FB37ED62825-8026
Address CF: Lane Chge Asst 2 (J770) Labels:. 4M0-907-566.clb
Part No SW: 4M0 907 590 B HW: 4M0 907 590
Revision: --------
Coding: 1EC002
ASAM Dataset: EV_RearRadarS2BoschAU736 001015
Address D6: Light Ctrl Left 2 (A31) Labels: 7PP-941-592.clb
Part No SW: 7PP 941 592 CB HW: 7PP 941 592 C
Component: LED1L H10 2003
Dataset Number: 4M0909471D 0012
ROD: EV_LEDModLeftMELCOAU736_AU73.rod
VCID: 1A6DDDC63C1D7C2A613-804E
Address D7: Light Ctrl Right 2 (A27) Labels: 7PP-941-592.clb
Component: LED1R H10 2003
Dataset Number: 4M0909472D 0012
End----------(Elapsed Time: 03:43, VBatt start/end: 11.8V/12.9V)-----------
------------------------------38 Faults Found------------------------------
