- Jan 8, 2024
- 16
- 1
- Redding, CA, USA
- C?ID=512328
Hello everyone, hope your having a great week. I have a intermittent puzzle I can't crack!
A short little backstory. I replaced my turbo/DPF because of a broken turbo shaft and oil coming out the exhaust. It all went well but it wasn't 2 weeks later a light came on and put the car into limp mode. The fault codes that came back were
• P1440 EGR Valve (N18) Open Circuit
• P0403 EGR Valve (N18) Malfunction intermittent
I need to get a couple things understood. It's possible I had this issue before the turbo went out but I was just assuming it was something I messed up when replacing Turbo/DPF.
The thing I can't find any FOR SURE evidence on is what EGR valve is the N18 Valve! There is 2 EGR systems and I believe the N18 is the on bolted on the intake and NOT the one on the EGR cooler.
1. Am I correct on this?
Thus far I have checked all wiring from the EGR valve in the intake 5 pin connector to the ECM. All circuits had great continuity and passed a load test. I replaced the EGR valve on the intake because when I ran a actuator test in VCDS it sounded horrible and when using a borescope it appeared that the valve was jittery and not opening or closing smoothly. The new valve did the same thing. After clearing codes and driving the car for a couple weeks I thought the issue was fixed but all symptoms came back.
After fiddling with it some more and clearing codes a third time. I got the same codes plus P2463. DPF Excessive soot accumulation. I monitored soot load and actual was 0.0 and calculated was 49.0.
If anyone has some trouble shooting advice or any kind of help I would appreciate it. I'm trying my best to figure this one out. Thank you much!!
I will upload the fault code freeze frame and data.
Monday,10,March,2025,19:07:37:53028
VCDS Version: 25.3.0.3 (x64) HEX-V2 CB: 0.4660.4
Data version: 20250301 DS365.0
VIN: 3VWLL7AJ6DM390770 License Plate: CHAD
Mileage: 150141 Repair Order: Chad 2013 VW Jetta 2.0 TDI
Address 01: Engine Labels: 03L-906-022-CBE.clb
Control Module Part Number: 03L 997 030 M HW: 03L 907 309 AA
Component and/or Version: R4 2.0l TDI G000AG 9983
Software Coding: 0050078
Work Shop Code: WSC 26214 051 00000
VCID: 382926A3FE5F798A770-806C
005184 - EGR Valve (N18)
P1440 - 000 - Open Circuit - MIL ON
Fault Status: 11100000
Fault Frequency: 22
Mileage: 237261 km
Date: 2063.14.31
Time: 00:46:30
Load: 100.0 %
Lambda: 97.8 %
Mass Air / Rev.: 0.0 mg/str
Temperature: 86.4°C
001027 - EGR Valve (N18)
P0403 - 000 - Malfunction - Intermittent
Fault Frequency: 143
Mileage: 238387 km
Date: 2063.14.31
Time: 19:42:45
RPM: 2484 /min
Speed: 125.0 km/h
Load: 45.1 %
Load: 98.4 %
Lambda: 100.2 %
Mass Air / Rev.: 435.0 mg/str
Temperature: 87.3°C
009315 - Particle Filter
P2463 - 000 - Excessive Soot Accumulation - MIL ON
Mileage: 241593 km
Date: 2063.14.31
Time: 05:56:12
RPM: 1863 /min
Speed: 94.0 km/h
Pressure: 28 mbar
Hex Value: 0xFF01
Temperature: 288.0°C
(no units): 224.4
Mileage: 900 km
