Audi A4 P0016 Extended Crank Startup After New Timing Chains
SensorKing
Ontario, Canada
C?ID=611113
I recently had my timing chain replaced on a 2012 Audi A4 with 310,000KM at a local Audi/BMW specialist auto shop and have had the dreaded P0016 Code ever since. The symptoms are CEL, Extended crank 4-7 seconds till it starts, and inconsistent rough idling with it clearing up around 1500rpm+. When the shop replaced the timing chain the Mechanic said he measured exhaust cam at -6.5. After the job was done I picked up the car and drove 35km without any issues. The next morning it threw the P0016 code and would crank but didn't start. I logged and cleared the code for the car to startup no problem, it also drove 35km without an issue but when I went to start the car again it had the P0016 and extended crank issue. I did bring the car back to the same mechanic so he could take it apart again and verify the timing chain was within spec, and it was. We have replaced the Spark Plugs, Ignition coils, Timing Chain, PCV Valve, Fuel Rail Pressure Sensor, Cam and Crank Sensor, VVT Solenoid and Magnet adjuster. Still the same P0016 extended crank and rough idle. The car will start normally after the check engine light is cleared even though the code is still visible on a Auto Scan with the car running (NO Check engine light on the dash).
Looking at the camshaft adaption values in VCDS my mechanic and I are completely stumped, its showing -20.63 with little to no fluctuation. I attempted a Reset of All Adaption Values with no success, I have attempted to enter Security Access Codes with the error Not Available In Active Session. I suspect the ECU is locked out or in safemode.
My theory is the ECU is in SafeMode holding this bad data in it's memory not allowing for it to be fully cleared out. Meaning I need to bring it to Audi so they can use a dealer level scan tool for adaption resets.
The mechanics theory is a bad wire or ground connection. We have inspected the connectors and some of the wiring but no smoking gun yet.
I wanted to post to this form before going to Audi to see if anyone had an idea of what's going on and ways to fix it. Your input is greatly appreciated.
Self-Diagnosis Log
Saturday,15,March,2025,08:56:38:13417
VIN: License Plate:
Mileage: 313220km-194625mi Repair Order:
Chassis Type: FL-AU48 (8T0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 36 3C 42 46 52 53 55 56 5F
 62 6C 6D 72
VIN: WAU4FCFL4CA076335 Mileage: 313220km-194625miles
Self-Diagnosis Log
Page 2
VIN: License Plate:
Address 01: Engine (0-----CAEB) Labels:| 06H-907-115-V1.clb
 Part No SW: 8K2 907 115 AG HW: 8K2 907 115 D
 Component: 2.0l R4/4V TF H20 0004
 Revision: E1H20--- CVN: A31947EA
 Coding: 010C010A290F0160
 Shop #: WSC 16448 032 526344
 ASAM Dataset: EV_ECM20TFS0118K2907115AG 001005
 ROD: EV_ECM20TFS0118K2907115AG.rod
 VCID: 74B60330BE38693A9B8-8020
 VINID: 9D194459359C1134401C60C314D5499AAE
4096 - Bank 1: CMP Sensor (G40) / Engine Speed Sensor (G28)
 P0016 00 [11101101] - Incorrect Correlation
 Mileage: 313224 km
 Date: 2010.01.22
 Time: 14:07:42
 Engine speed: 806.50 /min
 Normed load value: 13.7 %
 Vehicle speed: 11 km/h
 Coolant temperature: 54 °C
 Intake air temperature: 13 °C
 Voltage terminal 30: 14.371 V
Readiness: 1110 0101
------------------------------------------------------------------------------- Address 02: Auto Trans (J217) Labels:| 0BK-927-156.clb
 Part No SW: 8K0 927 158 S HW: 0BK 927 156 R
 Component: 0BK 20TFSIUSA H17 1003
 Revision: --H17--- CVN: E30475B4
 Coding: 000002
 ASAM Dataset: EV_TCMAL551211 002018
 VCID: 46D289F89824ABAAF5C-8012
No fault code found. -------------------------------------------------------------------------------
Self-Diagnosis Log
Page 3
VIN: License Plate:
Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V1.clb
 Part No SW: 8K0 907 379 BG HW: 8K0 907 379 BG
 Component: ESP8 quattro H04 0020
 Coding: 1D0500
 Shop #: WSC 06334 000 00000
 VCID: 7F5CDC1C87FE3A62F6A-802A
 Reset counter: 30
 Mileage: 313224 km
 Date: 2010.01.22
 Time: 23:39:28
 Hex Value: 0x0000
 Hex Value: 0x0082
 Hex Value: 0x0027
 Hex Value: 0xB99D
 Hex Value: 0x00FF
 Fault Status: 00101101
 Reset counter: 30
 Mileage: 313224 km
 Date: 2010.01.22
 Time: 23:39:28
 Hex Value: 0x0000
 Hex Value: 0x0082
 Hex Value: 0x0026
 Hex Value: 0x259D
 Hex Value: 0x00FF
Self-Diagnosis Log
Page 4
VIN: License Plate:
 Reset counter: 30
 Mileage: 313224 km
 Date: 2010.01.22
 Time: 23:39:28
 Hex Value: 0x0000
 Hex Value: 0x2282
 Hex Value: 0x002E
 Hex Value: 0x029C
 Hex Value: 0x00FF
------------------------------------------------------------------------------- Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
 Part No SW: 8K0 907 064 CH HW: 8K0 907 064 CH
 Component: BCM2 2.0 H05 0435
 Coding: 0D0200
 Shop #: WSC 06335 000 00000
 VCID: 78AE3700A2D00D5AB70-802C
 Subsystem 1 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
 Component: J764 ELV MLB H37 0042
 Serial number: 2311000214153008
 Reset counter: 30
 Mileage: 313224 km
 Date: 2010.01.22
 Time: 23:39:28
Self-Diagnosis Log
Page 5
VIN: License Plate:
Address 08: Auto HVAC (J255) Labels:. 8Tx-820-043-3Z.clb
 Part No SW: 8T1 820 043 AQ HW: 8T1 820 043 AQ
 Revision: C1000000 Serial number: 01021020110853
 Coding: 64102000
 VCID: 005E5FE0FA00459A8F0-8054
 Reset counter: 31
 Mileage: 313214 km
 Date: 2010.01.22
 Time: 00:02:42
 Reset counter: 31
 Mileage: 313224 km
 Date: 2010.01.22
 Time: 23:39:27
Self-Diagnosis Log
Page 6
VIN: License Plate:
 Part No SW: 8K0 907 063 P HW: 8K0 907 063 P
 Component: BCM1 1.0 H30 0392
 Revision: 10030001 Serial number: 00000001236486
 Coding: 260810B7403CAF010000080300003D0D0F1C470802010161000000
 Shop #: WSC 12345 123 61029
 VCID: 3C26EB10D668E17A938-8068
 Subsystem 1 - Part No SW: 8K1 955 119 A HW: 8T1 955 119 Labels: 1KX-955-119.CLB Component: WWS 031011 H07 0070
 Serial number: SWF11100035199
 Coding: 00FD11
 Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB Component: RLS H04 0003
 Serial number: 11697420
 Coding: 025028
 Component: E1 - LDS H03 0031
 Serial number: 00000000002709111471
 Reset counter: 31
 Mileage: 313224 km
 Date: 2010.01.22
 Time: 23:39:00
02258 - Door Opener Transmitter
 Reset counter: 243
 Mileage: 313214 km
 Date: 2010.01.23
 Time: 09:26:00
Self-Diagnosis Log
Page 7
VIN: License Plate:
Address 10: Park/Steer Assist (J446) Labels:. 8K0-919-475.clb
 Part No SW: 8K0 919 475 T HW: 8P0 919 475 M
 Component: PARKHILFE 4K H01 0081
 Revision: 11001001 Serial number: 36861127100623
 Coding: 300103
 VCID: 4ACABDC88CBC4FCA114-801E
Self-Diagnosis Log
Page 8
VIN: License Plate:
 Part No SW: 8K0 959 655 K HW: 8K0 959 655 K
 Component: AirbagVW-AU10 H44 0610
 Serial number: 003GLD0P4747 Dataset Number: 8K0909602J 0001
 Coding: 30453735423030303030554A304C384B3053
 VCID: 45D08EF4A522A0B2FC6-8010
 Serial number: 6334MSME63524F5AN
 Serial number: 6344MSME64556767K
 Serial number: 6352QSME6E664B56Z
 Serial number: 6362QSME7E62586C
 Serial number: 63732SME22635174T
 Serial number: 63832SME4765225A+
9440027 - Driver's side; side-airbag igniter
 B100B 1B [10001001] - Resistance Too High
 Mileage: 313224 km
 Date: 2010.01.22
 Time: 23:39:17
9439771 - Front Passenger's Side Airbag Igniter
 B100A 1B [10001001] - Resistance Too High
 Mileage: 313224 km
 Date: 2010.01.22
 Time: 23:39:17
Self-Diagnosis Log
Page 9
VIN: License Plate:
 Part No SW: 8R0 953 568 K HW: 8R0 953 568 K
 Component: Lenks.Modul H07 0156
 Revision: 00000000 Serial number: 20111005000748
 Coding: 000017
 VCID: 49C882C489BA44D218E-801C
 Component: E221 - MFL H02 0010
No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels:. 8T0-920-xxx-17.clb
 Part No SW: 8K0 920 930 M HW: 8K0 920 930 M
 Component: KOMBIINSTR. H31 0258
 Revision: 00000000 Serial number: EJ850G0AC
 Coding: 8B0F110002000008020002
 VCID: 372CF43CEF4EC2227EA-8062
 Reset counter: 30
 Mileage: 313224 km
 Date: 2010.01.22
 Time: 23:39:28
Self-Diagnosis Log
Page 10
VIN: License Plate:
 Part No SW: 8T0 907 468 AE HW: 8T0 907 468 L
 Component: GW-BEM 5CAN-M H10 0117
 Revision: FC100058 Serial number: 5800F11922041B
 Coding: 00C303
 VCID: 045653F0EE1859BAAB8-8050
 Subsystem 1 - Part No SW: 8K0 915 181 E HW: 8K0 915 181 E
 Component: J367-BDM H07 0170
 Serial number: 1103978D160911
 Reset counter: 243
 Mileage: 313214 km
 Date: 2010.01.23
 Time: 09:28:22
 Bin. Bits: 10111
 Voltage: 12.30 V
 Count: 6
 Text: FFF1746D04020100
 Raw, Index/Key Err.: 241 116 109
 Ign. Timing: 2.5 °BTDC
 Fault Status: 00101100
 Reset counter: 31
 Mileage: 313224 km
 Date: 2010.01.22
 Time: 00:00:02
 Bin. Bits: 10000
 Voltage: 12.30 V
 Count: 7
 Bin. Bits: 10000
Self-Diagnosis Log
Page 11
VIN: License Plate:
02256 - Quiescent Current
 Fault Status: 00100001
 Reset counter: 31
 Mileage: 313224 km
 Date: 2010.01.22
 Time: 01:31:00
 Reset counter: 31
 Mileage: 313224 km
 Date: 2010.01.22
 Time: 05:31:00
 Bin. Bits: 00000
 Voltage: 12.20 V
 Count: 17
Self-Diagnosis Log
Page 12
VIN: License Plate:
Address 36: Seat Mem. Drvr (J136) Labels:. 8T0-959-760.clb
 Part No SW: 8K0 959 760 D HW: 8K0 959 760 D
 Component: MEM-FS H06 0074
 Revision: AA000000 Serial number: 00001010152014
 Coding: 00581300000000000000
 VCID: 3B24E80CD366E6429A2-806E
 Fault Frequency: 20
 Reset counter: 246
 Mileage: 313214 km
 Date: 2010.01.23
 Time: 09:26:35
Self-Diagnosis Log
Page 13
VIN: License Plate:
Address 3C: Lane Change Labels: 8K0-907-566.clb
 Part No SW: 8K0 907 566 B HW: 4L0 907 566 B
 Revision: 00H01000 Serial number: 6PZ 009 014-13
 Coding: 0000002
 VCID: 3632F938E4443B2A65C-8062
 Subsystem 1 - Part No: 8K0 907 568 B
 Subsystem 2 - Serial number: 6PZ 009 014-33
 Subsystem 3 - Serial number: 5F15.11.0800H010003CD10785ÿ
 Subsystem 4 - Serial number: D10785ÿ
02850 - Control Module 2 for Lane Change Assistance (J770)
 014 - Defective
 Fault Status: 01101110
 Reset counter: 243
 Mileage: 313214 km
 Date: 2010.01.23
 Time: 09:26:35
------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels:. 8K0-959-793.clb
 Part No SW: 8K0 959 793 M HW: 8K0 959 793 M
 Component: TSG FA H12 0357
 Revision: Serial number: 0000120337151
 Coding: 011C13204E00410001
Self-Diagnosis Log
Page 14
VIN: License Plate:
 Revision: 00002001 Serial number: 0159146670
 Coding: 0126063A20BA741580B0023200000000
 Component: GTO BF H01 0070
 Serial number: 00000000000000441130
 Subsystem 3 - Part No SW: 8K0 959 591 B HW: 8K0 959 591
 Component: J245 PS150 H08 0043
 Subsystem 4 - Part No SW: 8K0 959 591 B HW: 8K0 959 591
 Component: J394 PS240 H08 0043
 Reset counter: 30
 Mileage: 313224 km
 Date: 2010.01.22
 Time: 23:39:28
------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels:. 8K0-959-792.clb
 Part No SW: 8K0 959 792 M HW: 8K0 959 792 M
 Component: TSG BF H12 0357
 Revision: Serial number: 0000014901888
Self-Diagnosis Log
Page 15
VIN: License Plate:
Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
 Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
 Component: EPB Audi B8 H09 0100
 Revision: 00000003 Serial number: 20000000117015
 VCID: 3436C330FE38293A5B8-8060
 Reset counter: 30
 Mileage: 313224 km
 Date: 2010.01.22
 Time: 23:39:28
 Voltage: 12.90 V
 Count: 64
 Hex Value: 0x0260
 Hex Value: 0x0001
 Hex Value: 0x0101
Self-Diagnosis Log
Page 16
VIN: License Plate:
Address 55: Headlight Range Labels: 8K0-907-357.clb
 Part No: 8K5 907 357 B
 Component: Dynamische LWR H01 0010
 Coding: 0000004
 VCID: 3928F204D55AD45288E-806C
 Reset counter: 31
 Mileage: 313224 km
 Date: 2010.01.22
 Time: 23:39:27
------------------------------------------------------------------------------- Address 56: Radio (R) Labels:. 4F0-035-0xx-56.clb
 Part No SW: 4G0 035 082 B HW: 4G0 035 082
 Component: Radio U SIRIU H53 0076
 Revision: AB001007 Serial number: 156J60B7557475
 Coding: 020007020100000001
 VCID: 1F1C3C9C67BE9A6296A-804A
Self-Diagnosis Log
Page 17
VIN: License Plate:
 Part No SW: 8T1 035 664 D HW: 8T1 035 664 B
 Component: H-BN-NA H52 0165
 Revision: -------- Serial number: 490I.0B7642028
 Coding: 010200010306C1EF51000F0E000000030000
 VCID: 3928F204D95AD45288E-806C
 Component: NAR 2011 0505
 Subsystem 2 - Part No SW: 8T0 919 609 G HW: 8T0 919 609 G
 Component: E0380 Bedient H08 0100
 Serial number: 00000000952064
 Subsystem 3 - Part No: 8R0 060 961 A
 Component: CD-Database 2712
00658 - Control Head
 Reset counter: 31
 Mileage: 313215 km
 Date: 2010.01.22
 Time: 00:14:03
 Voltage: 12.90 V
 Reset counter: 31
 Mileage: 313219 km
 Date: 2010.01.22
 Time: 14:31:18
 Voltage: 12.80 V
 Bin. Bits: 001
02244 - Button in Control Head is Stuck
Self-Diagnosis Log
Page 18
VIN: License Plate:
 Reset counter: 31
 Mileage: 313215 km
 Date: 2010.01.22
 Time: 14:06:24
 Voltage: 12.10 V
 Bin. Bits: 10000000 00000000
 Bin. Bits: 00000000 00000000
 Reset counter: 243
 Mileage: 313214 km
 Date: 2010.01.23
 Time: 09:26:41
 Bin. Bits: 00000001 00000000
02259 - Information Display and Control Head (Front) (J685)
 Reset counter: 243
 Mileage: 313214 km
 Date: 2010.01.23
 Time: 09:26:41
 Voltage: 12.80 V
Self-Diagnosis Log
Page 19
VIN: License Plate:
 Reset counter: 31
 Mileage: 313224 km
 Date: 2010.01.22
 Time: 23:39:32
 Bin. Bits: 00010000 00000000
------------------------------------------------------------------------------- Address 62: Door, Rear Left (J388) Labels:. 8K0-959-795.clb
 Part No SW: 8K0 959 795 F HW: 8K0 959 795 F
 Component: TSG HL H11 0357
 Revision: Serial number: 0000015105842
 Coding: 010C13204000210001
 VCID: 45D08EF4A5A2A0B2FC6-8010
No fault code found. ------------------------------------------------------------------------------- Address 6C: Back-up Cam. Labels: 8T0-907-441.clb
 Part No SW: 8T0 907 441 C HW: 4L0 907 441 B
 Revision: --H05--- Serial number: 525PA8-J139213
 Coding: 1000007
 VCID: 382EF700EE50CD5A770-806C
No fault code found. ------------------------------------------------------------------------------- Address 6D: Trunk Elect. (J605) Labels: 8K9-827-851.clb
 Part No SW: 8K9 827 851 A HW: 8K9 827 851 A
 Component: J605 Master H52 0330
 Revision: -------- Serial number: 8K9827851A
 Subsystem 1 - Part No SW: 8K9 827 852 A HW: 8K9 827 852 A
 Component: J756 Slave H52 0330
 Serial number: 8K9827852A
Self-Diagnosis Log
Page 20
VIN: License Plate:
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-795.clb
 Component: TSG HR H11 0357
 Revision: Serial number: 0000015105986
End----------(Elapsed Time: 01:55, VBatt start/end: 12.8V/12.4V)-----------
------------------------------27 Faults Found------------------------------
Ziddywerks
Northern NJ USA
C?ID=208579
Out of time. How was timing verified? Please describe the process exactly as it was performed. Good help is very hard to find. Also I would question if everything was done to spec.
As noted above in post #3,
-20.3 degrees ! (it should be near or close to zero)
SensorKing
Ontario, Canada
C?ID=611113
I did bring the car back to the same shop right after the P0016 code happened and talked with the mechanic, we both wanted to verify his work. He put the bumper in the service position and took the timing covers off. I was not there to watch the whole job as it was 8 hours but he did facetime to show me the distance between the camgear markers was 124mm, also that the chain didn't slip. He reassembled and replaced the tensioner, crank pully bolt and the upper timing cover.
We used this timing chain kit
NEW UPDATE
I was recommended to try a battery reset to reset the ECU. Removed the negative terminal, pressed the brake to drain all remaining power and waited 20 minutes before attaching the negative terminal back onto the battery. Went into VCDS, looked at camshaft adaption values, started the car and boom -19.58 degrees with less than .5 degree of fluctuation while under load. I did drive the car for 10km and didn't see the value go over -19.68. The car drives the same as before. I will attach a few videos of startup and idle.
Ziddywerks
Northern NJ USA
C?ID=208579
That test that he performed where it's 124mm from cam to cam don't mean jack shit. It's a cam crank correlation code. Meaning cam timing in correlation to crank position is off or the adjustment is not possible. Please ask if everything was torqued to spec. Also ask them to provide those specs. I have a strange suspicion something is over torqued or the engine is out of time as stated previously.
I'm really sorry but whoever told you that resetting the ecm by disconnecting the battery was going to solve this issue should get their head examined. If this is a recommendation from someone at that shop well then we already know you threw your money down the drain.
Not trying to be a dick but thats the cold hard truth.
453de548bcf423287ac627a0ee38fc3a2ffd5a98.gifv
SensorKing
Ontario, Canada
C?ID=611113
I will ask for thoes specs and go to another shop for further services.
The shop believes it's something electrical because when you clear the code and start the car it operates perfectly normally, no extended crank and no shaking idle. Only on the next startup poor preformance is noted. Your right, time to find a new mechanic or deal with Audi directly. I'm already way over what I wanted to spend on this.
Ziddywerks
Northern NJ USA
C?ID=208579
I will ask for those specs and go to another shop for further services.
The shop believes it's something electrical because when you clear the code and start the car it operates perfectly normally, no extended crank and no shaking idle. Only on the next startup poor performance is noted. Your right, time to find a new mechanic or deal with Audi directly. I'm already way over what I wanted to spend on this.
The shop can believe whatever they want. It does not mean they are correct and correlation faults are usually not related to other sensors unless you don't have a signal from a cam position sensor or crank. However if that were the case you would have hard faults for those sensors either implausible signal short or open to ground or vcc . I ask for specifics because I have seen many so called "special" "ists" fuck something very simple like timing on a 2.0T engine up. This is my suspicion I may be wrong as I am not perfect either but based on what I've seen are these factors and common fuck ups by independent shops as well as dealer technicians. The spool valve on the front of the intake cam is over torqued. This valve needs to be torqued to exactly 35nm. If it's too tight the valve itself will not be able to advance the timing as needed to may be in a state that is advanced and retarded if it's over torqued. I have also seen the actuator that has a metal plunger that actuates this valve either get jammed or hung up due to debris floating in the oil as it sits in front of this spool valve and gets bolted to the cam bridge. The next thing that I have seen is the wrong oil or low oil level causing lower hydraulic pressure to be available at the cam therefore resulting in a similar situation cannot be advanced or retarded because there is a lack of hydraulic pressure due to either wrong oil and low oil level. Next is the lower crank timing gear. This gear literally floats on the end of the crank shaft. It only fits one way and is only secured when the vibration dampner and its bolt is torqued and fastened to 150nm plus 90degrees, essentially locking it all together. This is a common occurrence, because this gear can slip and move ever so slightly and be just a few degrees off and is often overlooked during disassembly, in most cases in order to keep this gear from moving you want to secure it with a bolt and shim within 5minutes of removing the original otherwise it may move. Many just run this bolt home during assembly and check their marks. Just because the vibration dampner timing mark matches up with the lower engine cover timing mark does not mean the gear inside the engine is in time. This results in a false positive that the engine is in time when in reality the bottom crank gear is out of time with the top/ camshafts. This is simple easy shit. Then again I have done these timing chains and engine overhauls in the thousands at this point so to me I can probably do them blind If I needed to. These are the most common mistakes that shops make this is why good help is hard to find. Many corners cut and subpar quality of work or lack of adherence to factory repair manual and policies and procedures.
I am curious on what it costs you in CDN or USD if you would like to share or not share I totally understand.
SensorKing
Ontario, Canada
C?ID=611113
Looking back at the service records the shop noted the VVT solenoid was clogged with debris. I start with inspecting that. I wonder if that debris got in the Cam bridge oil passages.
I paid $4500 CAD for my car a year ago in running condition but needing a timing chain. The car is a 2012 Audi A4 Avant just under 300,000km. The previous owner had installed a Big Brake kit, CTS Cat and exhaust, upgrated info screens, and every aftermarket carbon accessory you can think of. I thought I scored pretty good on the deal.
I added a stage 1 IE tune $700
First timing chain service with labour $2750
Second look at timing chain $1280
Miscellaneous service items $800
About $11,000 CAD/$7650 USD total into the car.
Clean stock example sells for around 6-10k in Canada.
I still have some slop in my front passenger suspension and need two rear DWS06+ for 20" rims. Another $1100CAD.
I'm not upset for what I paid. Just frustrated for throwing money at a problem that isn't solved.
Included is the last bill from the shop. They noted P0506 and P0010 codes, both I haven't got before but related to the timing issue. The previous owner did attempt to fix the timing issue (however didn't replace timing chains) installed shitty manufactured parts related to VVT solenoid and magnet adjuster.
After this service they said the car ran perfectly. I got in and restarted the car to have the CEL and P0016 code return. I didn't want to continue throwing money at the car/shop so I got a VCDS and took it on myself to look into the issue.
Ziddywerks
Northern NJ USA
C?ID=208579
@SensorKing thank you for that insight. I would say based on what you've mentioned. This shop is indeed a bunch of "special" "ists". No professional technician would use verbiage like "crap" on a copy of a repair order to the customer. The fact that this is how it was written tells me all I need to know. The story as a whole provides very little details or explanation of what was actually checked to verify timing is on the money. I hope they didn't charge you for the follow up visit after the timing chains were done. If they did well then I am very sorry. I still think this is related to the timing chain job work they did. The fact that they tried throwing a camshaft position sensor at it just proves the point that they are grasping at straws because they are lost and don't know what else to do. Very sad indeed.
In short in comes down to how diligent the tech is and in this case you got "mechanics" because that what these guys are , they are not specialists by any measure or technicians they are regular run of the mill mechanics are just parts changers and parts cannon operators in this case. Based on the stories written they are not technically inclined in terms of diagnostic procedures and basic engine performance logic.
If you want to do a quick and simple TDC check all you would need to do is remove the upper timing cover and cyl#1 spark plug and a long screw driver. Then insert the screw driver into the cyl#1 opening and rotate the engine clockwise until the camshaft marks are in the vertical position and the screw driver is not rising any higher in cyl#1. Then you can look at the mark on the vibration dampner and see if it lines up with the mark on the lower engine cover. This is a 30minute job even for a enthusiast. This is something that shop could of done but again at this point I wouldn't trust them to diagnose their way out of a brown paper bag let alone fix a vehicle.
PS the price on the timing chain is decent if its in CAD I charge 2grand$ USD for such a job but all of my vehicles are test driven prior to pick up with at least 5 to 10 key cycles to ensure the job was done right and to standards. Clearly in your case the vehicle was not driven after completion or they decided to just take the money and kick it down the road.
SensorKing
Ontario, Canada
C?ID=611113
@EuroX Thank you. I did the quick and simple cam timing check you recommend and you're 100% correct. The shop is incompetent and didn't put the engine in time. I checked 5 times to make 100% sure I was doing it correct and every single time the first cylinder would be at TDC and the timing marks on the harmonic balancer don't line up. 1 inch or more off center
TDC
Past TDC, into intake stroke
The shop did charge me both times for diagnosis. Saying both times the work was correct. I'm going to call the owner of the shop once my cars fixed but unfortunately I don't see any refund coming back to me. They're the only "Euro Specialist" in my local area so a negative review would hurt the business a lot more compared to the profit they made from me. Still a shitty feeling though.
At this point I think I will buy the tools to put the engine in time myself.
Ziddywerks
Northern NJ USA
C?ID=208579
TDC
Very sad indeed. Good help is very hard to find. Don't get me wrong there are talented tech's out there that run good shops but frankly based on what I see and the calls I get everyday sometimes from all over the country I can probably count on 1 or 2 hands at most the numbers of euro shops that have a clue and are competent in their field. This totally boggles my mind how a shop can fuck something as simple as this up.
I would present what you've found and ask them how they would like to rebuild your trust in them again with your vehicle. It is clear the work was not done right.
If you need the procedure please reach out i'll be more than happy to provide you with the factory steps to get this sorted out.
hokiehoo
Shenandoah Valley, USA
C?ID=527835
@SensorKing , did you get this situation sorted? I'm facing a very similar situation, shop is pulling the timing cover again today, they're getting about 20 degrees for the camshaft adaptation value, similar to what you had.
