Hi, I'm working on a Touareg CR7 - Roll Control, Auxiliary heating, garage door opener and TMPS. I'm currently having trouble coding the ABS. Probably due to TMPS and Roll Control. Could someone please help me with the coding? I found a post here with the same ABS on a towbar. I'm sending a copy of my car. Thank you.
Wednesday,12,March,2025,13:43:51:62624
VCDS Version: 25.3.0.3 (x64) HEX-V2 CB: 0.4660.5
Data version: 20250301 DS365.0
VIN: WVGZZZCRZLD004477 License Plate:
Mileage: 176858km-109894mi Repair Order:
Chassis Type: CR-VW53 (4N2)
Scan: 01 02 03 06 09 13 15 16 17 19 29 2B 36 39 3C 42 44 46 47 52
5F 61 65 69 6D 74 81 82 84 A5 AC BB BC C4 CA CB CF D4 D5 D6
D7 DB DC DE 8107
VIN: WVGZZZCRZLD004477 Mileage: 176858km-109894miles
06-Seat Mem. Pass -- Status: Cannot be reached 0100
74-Chassis Control -- Status: Malfunction 0010
C4-DC/DC Converter -- Status: OK 0000
CA-Sunroof -- Status: OK 0000
CB-Rear Axle Steering -- Status: OK 0000
D4-Roll Control 1 -- Status: Cannot be reached 0100
D5-Roll Control 2 -- Status: Malfunction 0010
DB-Frt Corner Rdar 1 -- Status: OK 0000
DC-Frt Corner Rdar 2 -- Status: OK 0000
8107-Antenna -- Status: OK 0000
Address 01: Engine (J623-DENA) Labels: None
Part No SW: 760 907 401 N HW: 059 907 309 L
Component: 3.0l V6 TDI H26 0002
Revision: CAH26--- CVN: 9CCCCE8FFA9EEAC78947E11D8947E11D00000000D6C3ECFE
Coding: 292A4012057E050335280000000400000000000000000000
Shop #: WSC 21138 005 1048576
ASAM Dataset: EV_ECM30TDI011760907401N 001002
ROD: EV_ECM30TDI011760907401M.rod
VCID: 201D2DE4CA4CA90AAF0-8074
VINID: 9E65EAAAA4E2A9C5000041071C11BB99DB
34193 - Implausible Data Received from ESP Control Module
U0416 00 [00100111] - -
Mileage: 176858 km
Date: 2025.03.10
Time: 00:07:07
Engine speed: 0.00 /min
Coolant temperature: 13 °C
Intake air temperature: 14 °C
Voltage terminal 30: 12.040 V
Drivetrain coordinator: brake function status-Bits 0-7: 32
Acceleration: 0.000 m/s˛
Engine status: COENG_READY
Part No SW: 760 927 158 B HW: 0D5 927 156 N
Component: 0D5 30TDIRdW H05 1003
Revision: --H05--- CVN: 4559B166
Coding: 100000
Shop #: WSC 31414 037 00001
ASAM Dataset: EV_TCMALX52011 002014
ROD: EV_TCMALX52011.rod
VCID: 1F1F2E18F73296F296A-804A
Address 03: ABS Brakes (J104) Labels: 4M0-907-379-V1.clb
Part No SW: 4M6 907 379 AC HW: 4M6 907 379
Component: ESP9 Premium H06 0856
Dataset Number: V03935301KU 0001 CVN: 426EF7A1
Coding: 1DA732B730A20B9AD6A24D98188456EEE93AE9B84C0CD06BB2186A77975C97
ROD: EV_ESP9BOSCHCMP_004_VW53.rod
VCID: 7EA1339C10783FFAFDC-802A
13636625 - Control Module Incorrectly Coded
U1014 00 [10100111] - -
[Variant_Coding_eAWS_and_eABC_does_not_comply_with_messages_received_on_CAN]
Mileage: 176858 km
Date: 2025.03.10
Time: 00:07:31
78 00 00 00 C2 03 00 00 00 00
Unlearning counter according OBD-OBD unlearning counter: 28
Address 06: Seat Mem. Pass
Address 09: Cent. Elect. (J519) Labels:* 4N0-907-063-V2.clb
Part No SW: 4N0 907 063 DG HW: 4N0 907 063 AG
Component: BCM1 MLBevo H10 0652
Dataset Number: V03935284QQ 0001
Coding: 07501940E13B0009574F170858FF9C40800B36110020009301100A00FB35F6019BC5011B1417C8170000030100D3221B5D02040144010104000000000000000000
Shop #: WSC 31414 044 00001
ASAM Dataset: EV_BCM1BOSCHAU651 014010
ROD: EV_BCM1BOSCHAU651_014.rod
VCID: 76B12BBC384877BAA5C-8022
Subsystem 1 - Part No SW: 761 955 113 HW: 761 955 113
Component: WIPER 170719 011 0420
Serial number: VZ1SKA 1001113170719
Serial number: 23373987X81A955555A0
Coding: 0200FE
Subsystem 3 - Part No SW: 761 941 633 HW: 761 941 633
Component: E1 - LTM H06 0054
Serial number: 14S02.08.1900140234
Subsystem 4 - Part No SW: 4N0 907 410 C HW: 4M0 907 410 A
Component: USHL5 GX1 H12 0300
Serial number: 0000009600373Z00PA02
Coding: 350000
Subsystem 5 - Part No SW: 3G0 857 511 AL HW: 3G0 857 511 AL
Component: Y7_Innenspieg H09 0002
Serial number: GX1CE109051920810447
Coding: 030000
Interior Light Module:
Subsystem 6 - Part No SW: 760 947 105 S HW: 760 947 105 S
Component: Dachelektroni H32 0057
Serial number: 00000784820000000000
Subsystem 7 - Part No SW: 4N0 963 575 A HW: 4N0 963 575 A
Component: V512 LLR1SLvL H01 0012
Serial number: Q98BJ21028378
Subsystem 8 - Part No SW: 4N0 963 575 A HW: 4N0 963 575 A
Component: V514 LLR1SKvL H01 0012
Serial number: Q98BJ21262026
327698 - Databus
[ESP: received error value in signal ESP_system-status]
Reset counter: 73
Mileage: 176858 km
Date: 2025.03.10
Time: 00:07:06
average_Voltage_terminals: 12.10 V
Outside air temperature sensor-Outside air temperature on CAN: 13.50 °C
interior_temperature: 14.50 °C
Vehicle speed: 0.00 km/h
U1101 00 [00001001] - Active
Reset counter: 73
Mileage: 176858 km
Date: 2025.03.10
Time: 00:07:05
66138 - Control Module for Steering Column Adjustment
U113E 00 [00001001] - No Communications
Reset counter: 73
Mileage: 176858 km
Date: 2025.03.10
Time: 00:07:09
66581 - Fan 1 for Right Seat Backrest
B14CD 31 [00001001] - No Signal
Reset counter: 73
Mileage: 176858 km
Date: 2025.03.10
Time: 00:07:09
66609 - Fan 1 for Right Seat Cushion
B14CF 31 [00001001] - No Signal
Reset counter: 73
Mileage: 176858 km
Date: 2025.03.10
Time: 00:07:09
67174 - Databus
[STH_01: parking heater control module: data bus missing message]
Reset counter: 73
Mileage: 176858 km
Date: 2025.03.10
Time: 00:07:07
System run time-Engine running time: 65535 s
System run time-Terminal 15 on: 0 s
Address 13: Auto Dist. Reg (J428) Labels:* Redir Fail!
Part No SW: 760 907 561 C HW: 760 907 561
Component: LRR4R H04 0333
Dataset Number: V03935301K 0001
Coding: 32657FDC78000400000020A000000014051246484401009E00
ASAM Dataset: EV_ACCBOSCHAU65X 002023
ROD: EV_ACCBOSCHAU65X_VW53.rod
VCID: 1C651914E6248DEA738-8048
2101 - Databus
[FAULT_ESP_STATUS_SYSTEM]
Reset counter: 73
Mileage: 176858 km
Date: 2025.03.10
Time: 00:07:05
Control Module temperature: 28 °C
Voltage terminal 15: 12.0 V
Vehicle speed: 0.00 m/s
Longitudinal acceleration: 0.00 m/s˛
Adaptive distance regulation: status: ACC_reversible_error
Steering_angle-Data: -30.700 °
Yaw_rate-Data: 0.000 rad/s
adjustment_calculation: On
Misalignment angle: horiz: 0.154 °
Misalignment angle: horiz: fast algorithm: 0.269 °
Congestion pilot: status: OFF
Outside temperature: 13.50 °C
Sensor blindness: radar: no blindness detected
2115 - Databus
[FAULT_HMS_FAILURESTATE]
Reset counter: 73
Mileage: 176858 km
Date: 2025.03.10
Time: 00:07:05
Address 15: Airbags (J234) Labels:| 80A-959-655.clb
Part No SW: 4M0 959 655 J HW: 4M0 959 655 J
Component: AirbagVW31 H07 2720
Serial number: 003YQM021HYA Dataset Number: V03935282PM 0001
Coding: 99FCC0C00C800000585400EF301D41A80065
Shop #: WSC 31414 029 00001
ASAM Dataset: EV_AirbaVW31SMEAU65x 001032
VCID: 42D9876C24009B1AD94-8016
Left seat belt tensioner:
Subsystem 1 - Part No SW: 4N0 980 945 B HW: 4N0 980 945 B
Component: BeltPretRevFL H21 0115
Serial number: 00AI2019189340400000
Coding: 04F001
Right seat belt tensioner:
Subsystem 2 - Part No SW: 4N0 980 946 B HW: 4N0 980 946 B
Component: BeltPretRevFR H21 0115
Serial number: 00AI2019176024400000
Coding: 04F001
Subsystem 3 - Part No SW: ----------- HW: 480 002 907 19
Serial number: 357000000005E5819E3V
Subsystem 4 - Part No SW: ----------- HW: 480 002 907 19
Serial number: 3580000000023D797E3V
Subsystem 5 - Part No SW: ----------- HW: 480 032 607 19
Component: SideSensor_Dr 002 0149
Serial number: 351001C24B9841E0894A
Subsystem 6 - Part No SW: ----------- HW: 480 032 607 19
Component: SideSensor_Pr 002 0149
Serial number: 352001C244EBC210DDFS
Subsystem 7 - Part No SW: ----------- HW: 480 030 606 19
Component: FrontSensor_D 002 0189
Serial number: 355001C20C1CA6004EFG
Subsystem 8 - Part No SW: ----------- HW: 480 030 606 19
Component: FrontSensor_P 002 0189
Serial number: 356001C20C1CEDB00BCT
Subsystem 9 - Part No SW: ----------- HW: 480 031 807 19
Component: PedP_Sensor_D 002 014A
Serial number: 228001C24628C1101D9+
Subsystem 10 - Part No SW: ----------- HW: 480 031 807 19
Component: PedP_Sensor_P 002 014A
Serial number: 229001C2462A01F11C3/
Subsystem 11 - Part No SW: ----------- HW: 480 033 107 19
Component: PedP_Sensor_C 002 014A
Serial number: 230001C1C32A09B07D33
Subsystem 12 - Part No SW: ----------- HW: 480 001 806 19
Serial number: I0M00000000766C8CCBS
Subsystem 13 - Part No SW: ----------- HW: 480 001 806 19
Serial number: I0N00000000B0C79CCBT
B13BC F2 [10001001] - No function
Reset counter: 73
Mileage: 176858 km
Date: 2025.03.10
Time: 00:07:05
9441563 - Rear; driver's side; side-airbag igniter
B1011 1B [10001001] - Resistance Too High
Mileage: 176858 km
Date: 2025.03.10
Time: 00:07:06
9441307 - Rear; passenger's side; side-airbag igniter
B1010 1B [10001001] - Resistance Too High
Mileage: 176858 km
Date: 2025.03.10
Time: 00:07:06
9439771 - Front Passenger's Side Airbag Igniter
B100A 1B [10001001] - Resistance Too High
Mileage: 176858 km
Date: 2025.03.10
Time: 00:07:06
9699072 - Igniter for 2nd Battery Disconnect
B13FF 00 [10001001] - -
Mileage: 176858 km
Date: 2025.03.10
Time: 00:07:06
9447187 - Seat Occupied Sensor; Passenger's Side
B1027 13 [10001001] - Open Circuit
Mileage: 176858 km
Date: 2025.03.10
Time: 00:07:07
Address 16: Steering wheel (J527) Labels: None
Part No SW: 760 953 507 B HW: 760 953 507 B
Component: Lenks.Modul H03 0006
ROD: EV_SMLSKLOAU736_VW53.rod
Address 17: Instruments (J285) Labels:* None-SRI2
Part No SW: 761 920 790 A HW: 761 920 790 A
Component: FBenRDW H12 0208
Coding: 85AC30E27F8C000800A87F2EF0F07818F40002A0
ROD: EV_DashBoardAU65X_VW53.rod
VCID: 1A691F0CEC10F3DA614-804E
Control head driving profile:
Subsystem 1 - Part No SW: 760 927 531 G HW: 760 927 531 G
Component: E881 BedieFPA 001 0460
Serial number: 000000091171SGG000EU
Level control system control head:
Subsystem 2 - Part No SW: 760 927 135 B HW: 760 927 135 B
Component: E281 BedieNiv 001 0110
Serial number: 000000091171SG400153
Part No SW: 4N2 907 468 BB HW: 4N2 907 468 AB
Component: Gateway H16 0052
Revision: BD000001 Serial number: 018BD768319726 Dataset Number: V03935305QN 0001
Coding: 0703000700880E407F07000000DB053A5E9E00073C000000037D078E10000100
GVL: F1593C088804020082FC88000100C800110C0070000000040000000000000000
ASAM Dataset: EV_CGateCONTIAU491 004190
ROD: EV_CGateCONTIAU491_004_VW53.rod
VCID: 7AA93F8C0C5013DAC14-802E
Subsystem 1 - Part No SW: 3G0 959 442 AF HW: 3G0 959 442 A
Component: MFL_VW_MLB_21 H26 0021
Serial number: 17038312061402000192
Coding: AF40D1
Subsystem 2 - Part No SW: 8S0 915 181 C HW: 8S0 915 181 C
Serial number: 2622251905
Inverter for electrical outlet:
Subsystem 3 - Part No SW: 3F0 907 155 HW: 3F0 907 155
Component: U13 DCAC H14 0017
Serial number: 00000000000003009789
Subsystem 4 - Part No SW: ----------- HW: -----------
Component: Emulator KLR H26 0021
Serial number: 3131681AA20303062201
9502742 - Databus
[eAWS_No_Component_Function]
Reset counter: 73
Mileage: 176858 km
Date: 2025.03.10
Time: 00:07:05
48V activation restriction-Airbag control module: not active
48V activation restriction-Engine Electronics: not active
48V activation restriction-Roll stabilization: not active
48V activation restriction-48 V activation restriction due to open circuit: not active
48V activation restriction-48 V activation restriction due to deactivation: not active
48V activation restriction-Battery management 2: not active
48V activation restriction-Voltage converter: not active
48V activation restriction-Auxiliary Air Heater Control Module/PTC: not active
48V activation restriction-Electrical compressor: not active
9502781 - Databus
[MVK_AwsVA_voltage_failure]
Reset counter: 73
Mileage: 176858 km
Date: 2025.03.10
Time: 00:07:05
[KS_Active_1]
Reset counter: 73
Mileage: 176858 km
Date: 2025.03.10
Time: 00:07:05
131661 - Seat/Mirror Postion Control Passenger - Driver
U0209 00 [00001001] - No Communications
[Timeout_Node_0x4D_DiagAdress_06_SitzMem_BFS]
Reset counter: 73
Mileage: 176858 km
Date: 2025.03.10
Time: 00:07:05
Address 29: Left Light (J1018) Labels: 8S0-907-397.clb
Part No SW: 80A 907 397 D HW: 80A 907 397 D
Component: LCM_MLBevo H07 0022
ROD: EV_LCMLeftCONTIAU426_VW53.rod
VCID: 303DDDA49AAC198A3F0-8064
Address 2B: Steer. Col. Lock (J764) Labels:| 1EA-905-861.clb
Part No SW: 3Q0 905 861 C HW: 3Q0 905 861 C
Component: ELV-MLBevo H05 0020
Serial number: 19000210239006
Coding: 8800000000000000
ROD: EV_ELVMarqMQBA0_VW53.rod
VCID: 3435D1B46EB425AA5B8-8060
Part No SW: 4M6 959 760 B HW: 4M6 959 760 B
Component: MEM-FS 009 0044
Serial number: 00000381790666 Dataset Number: V03935279EW 0001
Coding: 01189A400000B48188000101210100008900000707008F8F00000000015000
VCID: 3D23F4905DFEE4E2A46-8068
Valve block 1 in front seat driver side:
Subsystem 1 - Part No SW: 4N0 907 182 HW: 4N0 907 182
Component: N475 VB1 FSv H04 0011
Serial number: SJ80012207194025838C
Coding: BF2F00
Address 39: Right Light (J1023) Labels: 8S0-907-397.clb
Address 3C: Lane Change (J769) Labels:* None
Part No SW: 4N0 907 566 F HW: 4N0 907 566 A
Component: MRR_HR H12 0266
Dataset Number: V03935287KE 0001
Coding: 17F400
ASAM Dataset: EV_RearRadarS1DelphAU651 001018
ROD: EV_RearRadarS1DelphAU651_VW53.rod
VCID: 392BE08049D6D8C288E-806C
Part No SW: 4M1 959 793 J HW: 4M1 959 793 D
Component: TSG FS002 0421
Serial number: YE007SFN04583 Dataset Number: V03935305RG 0001
Coding: 003F9A00DE00048200093092
ROD: EV_DCU2DriveSideMAXHKLO_VW27.rod
VCID: 46D19B7C0828A73AF5C-8012
B1487 54 [00001001] - Missing Calibration / Basic Setting
Reset counter: 73
Mileage: 176858 km
Date: 2025.03.10
Time: 00:07:05
Part No SW: 4N0 909 144 E HW: 4N0 909 144 C
Dataset Number: V03935295QY 0001
Coding: B2170301000100
ROD: EV_EPSVWBSAU426_010.rod
VCID: 3239D7AC94A02B9A494-8066
Part No SW: 4N0 907 064 DP HW: 4N0 907 064 P
Component: BCM2 MLBevo H15 0202
Dataset Number: V03935308EW 0001
Coding: 01342A00AFB0004873A9A0067C00480203004004044F47502F0400000508803F001F31D40D0001
ASAM Dataset: EV_BCM2CONTIAU651 010009
ROD: EV_BCM2CONTIAU651_010_VW53.rod
VCID: 005D4D646A8C490A8F0-8054
ID - sensor:
Subsystem 2 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Serial number: 000000000ZY191803ECD
Subsystem 3 - Part No SW: 5Q0 951 605 B HW: 5Q0 951 605 B
Component: Sirene, DWA 004 0007
Serial number: 00000000000000494300
Heated Windshield Control Module:
Subsystem 4 - Part No SW: 4N0 907 133 A HW: 4N0 907 133 A
Component: J505-FSH H20 0600
Serial number: 19210000798011120081
Subsystem 5 - Part No SW: 3G0 962 243 C HW: 3G0 962 243 C
Component: GEB.F.Heckoef H17 0906
Serial number: 11850287
Rear spoiler control module:
Address 47: Sound System (J525) Labels:| 3Q0-035-466.clb
Part No SW: 3Q0 035 466 E HW: 3Q0 035 466 E
Component: MIB2_amp_P_VW H55 0340
Revision: 00000001 Serial number: VWZ8Z1KMB00GF0B Dataset Number: V03935299FV 0001
Coding: 1235060001AAAA2AAA0000000000
ASAM Dataset: EV_AMPMst16CFGen2ALPI 001001
ROD: EV_AMPMst16CFGen2ALPI_VW53.rod
VCID: 313BD8A091A6108230E-8064
Part No SW: 4M1 959 792 J HW: 4M1 959 792 D
Component: TSG BFS002 0421
Serial number: YE007SFM11287 Dataset Number: V03935305RK 0001
Coding: 003F9A00DE00048200093090
ROD: EV_DCU2PasseSideMAXHKLO_VW27.rod
VCID: 45D39C70352EAC22FC6-8010
Address 5F: Information Electr. (J794) Labels:* 4M0-035-MIB-HGH2.clb
Part No SW: 760 035 064 A HW: 760 035 064 A
Component: MU-H-LN-EU 049 2648
Dataset Number: V03935301RP 0001
Coding: 023506010000000043110002000808301F0100E401A004009F
ROD: EV_MUHigGen2pALPI_VW53.rod
VCID: 107D7D243AEC398A1F0-8044
Subsystem 1 - Part No SW: 761 919 618 HW: 761 919 618
Component: ABT_Prem_L H40 5211
Serial number: VWZ6ZGW2200079
Subsystem 2 - Part No: V03 959 809
Component: MIB2P_EU_Q222 0610
Compact disc data bank:
Component: Gracenote2 1010
Volume Control 1:
Subsystem 4 - Part No SW: 761 927 341 HW: 761 927 341
Component: VW536LLB H06 0109
Serial number: 2019061300000114
Media socket:
Subsystem 5 - Part No SW: 5G0 035 953 D HW: 0
H08 0014
U1111 00 [00001001] - -
[Tire pressure monitoring (0x07) - function restriction due to communication error - BapErr_retry not successful]
Fault Frequency: 19
Reset counter: 73
Mileage: 176858 km
Date: 2025.03.10
Time: 00:07:06
Voltage terminal 30: 12.0 V
BAP-BAP_Function_ID: 01
7200 - Function Restricted due to Missing Message(s)
[Seat adjustment/seat memory 2 (0x20) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 73
Mileage: 176858 km
Date: 2025.03.10
Time: 00:07:13
Voltage terminal 30: 12.1 V
BAP-BAP_Function_ID: 10
Address 61: Battery Regul. (J1120) Labels: None
Part No SW: 4M0 915 169 F HW: 4M0 915 169 E
Component: BMS_48V_SCAP H07 0114
Serial number: 180090013300111
ASAM Dataset: EV_SCAP0213061 001004
ROD: EV_SCAP0213061.rod
VCID: 3631EBBC78C837BA65C-8062
Address 65: Tire Pressure (J502) Labels: None
Part No SW: 3F0 907 273 HW: 4M0 907 273 B
Component: RDKHUFVW536 H05 0003
Serial number: 30000000007795 Dataset Number: V03935282HC 0001
ASAM Dataset: EV_RDKHUFVW536 002002
ROD: EV_RDKHUFVW536.rod
VCID: 65937CF095EE8C221C6-8030
Part No SW: 4M0 907 383 G HW: 4M0 907 383 B
Component: Anhaenger H33 0273
Revision: 9A001003 Serial number: 0522815804 Dataset Number: V03935278YR 0001
Coding: 0110000202000000
ROD: EV_TrailFunctGener2Hella_VW27.rod
Part No SW: 4M0 959 107 E HW: 4M0 959 107 C
Component: HDSG-Modul H14 0171
Revision: -------- Serial number: A2-C756-6240-7 Dataset Number: V03935273HC 0001
Coding: 17F8
VCID: 3533ECB065CE3CA26C6-8060
Address 74: Chassis Control (J775) Labels:* Redir Fail!
Part No SW: 4M0 907 777 S HW: 4M0 907 777 B
Component: Fahrwerk-SG H37 1253
Serial number: 2407190502 Dataset Number: V03935305FX 0001
Coding: B2505150F8
Shop #: WSC 00046 000 00000
ASAM Dataset: EV_ChassContrContiAU426 001004
ROD: EV_ChassContrContiAU426.rod
VCID: 49CB90401936484218E-801C
Air Suspension Compressor:
Subsystem 1 - Part No SW: 4M0 907 778 HW: 4M0 907 778
Component: V66LFKompOLV H06 0013
Serial number: 00000000004130670476
Coding: 303030
11 Faults Found:
3407876 - Databus
[Internal_communication_error_ESP_Systemstatus]
Reset counter: 73
Mileage: 176858 km
Date: 2025.03.10
Time: 00:07:04
Internal DTC: 84
4456458 - Implausible Data Received from ABS Control Module
U0415 00 [00001001] - -
[Function_restriction_due_to_communication_interruption_EspOverSteer]
Reset counter: 73
Mileage: 176858 km
Date: 2025.03.10
Time: 00:07:04
Internal DTC: 130
4456531 - Implausible Data Received from ABS Control Module
[Function_restriction_due_to_communication_interruption_EspUnderSteer]
Reset counter: 73
Mileage: 176858 km
Date: 2025.03.10
Time: 00:07:04
Internal DTC: 138
9764864 - Data Set Missing
U1118 00 [00001001] - -
[Data_set_missing_central_drving_state]
Reset counter: 73
Mileage: 176858 km
Date: 2025.03.10
Time: 00:07:04
Internal DTC: 291
10813440 - Data Set Missing
[Data_set_missing_active_roll_stabilizer]
Reset counter: 73
Mileage: 176858 km
Date: 2025.03.10
Time: 00:07:04
Internal DTC: 292
10747907 - Function Limitation due to Malfunction in Roll Stabilization
C1297 00 [00001001] - -
[Function restriction due to functional error eAWS RA]
Reset counter: 73
Mileage: 176858 km
Date: 2025.03.10
Time: 00:07:04
Internal DTC: 299
10747908 - Databus
[Function restriction due to invalid signal minimum roll torque distribution]
Reset counter: 73
Mileage: 176858 km
Date: 2025.03.10
Time: 00:07:04
Internal DTC: 300
10747909 - Databus
[Function restriction due to invalid signal maximum roll torque distribution]
Reset counter: 73
Mileage: 176858 km
Date: 2025.03.10
Time: 00:07:04
Internal DTC: 301
327680 - invalid data record
B2005 00 [00001001] - -
Reset counter: 73
Mileage: 176858 km
Date: 2025.03.10
Time: 00:07:04
Internal DTC: 304
262401 - Databus
[Timeout_Error_eAWS_VA_01]
Reset counter: 73
Mileage: 176858 km
Date: 2025.03.10
Time: 00:07:04
Internal DTC: 554
262402 - Databus
[Timeout_Error_eAWS_VA_02]
Reset counter: 73
Mileage: 176858 km
Date: 2025.03.10
Time: 00:07:04
Internal DTC: 555
Address 81: Gear Shift (J587) Labels: 4MX-713-041-81.clb
Part No SW: 761 713 041 B HW: 4M1 713 041 G
Component: GSM-LL H10 0077
Revision: 0L0D5012 Serial number: 19071253793456
ROD: EV_GSMWaehlZFAU736.rod
Address 82: Head Up Display (J898) Labels:| 4Nx-919-617-V1.clb
Part No SW: 761 919 608 A HW: 761 919 608 A
Component: HeadupDisplay H13 0197
Coding: DF40C0
ASAM Dataset: EV_HeadUpDisplAU65X 001010
ROD: EV_HeadUpDisplAU65X_VW53.rod
Address 84: Night Vision (J853) Labels:* None
Part No SW: 760 907 547 A HW: 4M0 907 547
Component: NV-ECU-Gen3 H13 0084
Serial number: 645976300201931
Coding: 200111
ASAM Dataset: EV_NightVisioG3AUTOLVW536 001003
ROD: EV_NightVisioG3AUTOLVW536.rod
VCID: 1E61131CF0389FFA9DC-804A
Night vision system camera:
Subsystem 1 - Part No SW: 4G0 980 552 A HW: 4G0 980 552
Component: NV-CAM-Gen3 H06 0007
Serial number: 639589400B1917100369
Address A5: Frt Sens. Drv. Assist (J1121) Labels:* 4N0-907-107-V2.clb
Part No SW: 4KE 907 107 AM HW: 4N0 907 107 H
Component: zFAS Var C H09 0293
Dataset Number: V03935307WE 0001
Coding: 040284000000000000FBD60000F8C71E5B9F5200000000000000000000961403E4BBBA000000200000000080C00000000000000000008000F9C040000000000000001C90000000700000008000000000008040000020
Shop #: WSC 31414 047 00001
ASAM Dataset: EV_ZFASAU516 001003
ROD: EV_ZFASAU516_001.rod
VCID: 0A496F4C5CB0035AD14-805E
8 Faults Found:
16395 - Left Surroundings Camera
B127E 54 [00001001] - Missing Calibration / Basic Setting
Reset counter: 73
Mileage: 176858 km
Date: 2025.03.10
Time: 00:07:05
16396 - Right Surroundings Camera
B127F 54 [00001001] - Missing Calibration / Basic Setting
Reset counter: 73
Mileage: 176858 km
Date: 2025.03.10
Time: 00:07:05
98333 - Databus
[ESP_21_ESP_Systemstatus]
Reset counter: 73
Mileage: 176858 km
Date: 2025.03.10
Time: 00:07:05
Supply voltages-Supply voltage Terminal 30 - internal: 0.00 V
Supply voltages-Terminal 30: 12.10 V
Supply voltages-Terminal 30 local: 12.10 V
Control Module temperature-Printed circuit: 26 °C
Control Module temperature-Average temperature: -50 °C
Control Module temperature-Application service computer: 26 °C
Control Module temperature-Sensor service computer: 23 °C
Control Module temperature-Environment recognition service computer: 32 °C
98334 - Databus
[ESP_15_HMS_Fehlerstatus]
Reset counter: 73
Mileage: 176858 km
Date: 2025.03.10
Time: 00:07:05
98341 - Cancellation of Park/Steering Assist
B187A 00 [00001001] - -
Reset counter: 73
Mileage: 176858 km
Date: 2025.03.10
Time: 00:07:05
Parking assist: discharge reasons (ring memory)-Year: 2000
Parking assist: discharge reasons (ring memory)-Month: 0
Parking assist: discharge reasons (ring memory)-Day: 0
Parking assist: discharge reasons (ring memory)-Hours: 0
Parking assist: discharge reasons (ring memory)-Minutes: 0
Parking assist: discharge reasons (ring memory)-Seconds: 0
Parking assist: discharge reasons (ring memory)-Last reason: Malfunction in the brake
139267 - Speaker for Front Parking Aid
B10F5 14 [00001001] - Open or Short to Ground
Reset counter: 73
Mileage: 176858 km
Date: 2025.03.10
Time: 00:07:06
4107 - Databus
[reversibler_Fehler_im_ACC_System]
Reset counter: 73
Mileage: 176858 km
Date: 2025.03.10
Time: 00:07:05
4157 - Databus
[ESP_Error]
Reset counter: 73
Mileage: 176858 km
Date: 2025.03.10
Time: 00:07:05
Address AC: Reductant Control (J880) Labels: 4M0-907-355.clb
Part No SW: 4M0 907 355 D HW: 4M0 907 355 B
Component: SCR-Stg-G3H05 0006
Dataset Number: V03935263ES 0001
ASAM Dataset: EV_RDCMINERGAU736 005012
ROD: EV_RDCMINERGAU736.rod
Part No SW: 4M1 959 795 J HW: 4M1 959 795 D
Component: TSG HFS004 0421
Serial number: YE007SFU00426 Dataset Number: V03935305RM 0001
Coding: 003E92000000048000093080
VCID: 48CD9544023CB14A070-801C
Component: TSG HBFS004 0421
Serial number: YE007SFU01115 Dataset Number: V03935305RL 0001
Address C4: DC/DC Converter (A7) Labels: 4M0-959-663.clb
Part No SW: 4M0 959 663 G HW: 4M0 959 663 G
Component: PCU10 022 0323
Dataset Number: V03935264LV 0001
ASAM Dataset: EV_DCDC48V210ABOSCHAU736 001008
ROD: EV_DCDC48V210ABOSCHAU736.rod
VCID: 3E21F39C50F8FFFABDC-806A
Part No SW: 4K0 907 594 AA HW: 4K0 907 594
Component: SAD_STG_1 006 0002
Dataset Number: V03935282CP 0001
Coding: 688040753602
VCID: 73B712A82B3A6292822-8026
Address CB: Rear Axle Steering (J1019) Labels:* 4M0-909-145.clb
Part No SW: 4M0 909 145 AA HW: 4M0 909 145 E
Component: HAL_MLBevoH08 0698
Revision: -------- Serial number: CCC_098_B_1122_ Dataset Number: V03935295VZ 0001
Coding: 42248E00
ASAM Dataset: EV_RearAxleSteerZFAU736 010018
ROD: EV_RearAxleSteerZFAU736_010_VW53.rod
VCID: 6FBF1ED84712467266A-803A
Address CF: Lane Chge Asst 2 (J770) Labels:* None
Component: MRR_HL H12 0266
Dataset Number: V03935287KF 0001
Coding: 17F400
ASAM Dataset: EV_RearRadarS2DelphAU651 001018
ROD: EV_RearRadarS2DelphAU651_VW53.rod
Address D4: Roll Control 1
Address D5: Roll Control 2 (----) Labels: None
Part No SW: 971 907 156 Q HW: 971 907 156 L
Component: EAWSH17 0113
Serial number: 00120190804151 Dataset Number: V03935303NA 0001
Shop #: WSC 00083 790 00257
ASAM Dataset: EV_EAWSSchaeRear 008001
ROD: EV_EAWSSchaeFront_008.rod
VCID: 2E01C3DC80980F7A2DC-807A
10 Faults Found:
12664900 - Databus
[eAWS_VA_02_keine Kommunikation]
Reset counter: 73
Mileage: 176858 km
Date: 2025.03.10
Time: 00:07:05
Spannung KL30: 12.0 V
Spannung KL40: 0.00 V
Micro Controller Temperatur: 19 °C
Endstufe-Temperatur: 15 °C
Aktor-Motor-Temperatur: 25 °C
Current: 0 A
Steller Position: 0 °
Steller Drehzahl: 0 rad/s
Transverse acceleration: -40.95 m/s˛
Derating (Über-/Unterspannnung) niedere Bit (MSB): 00000101
Abstuetzkraft: -10 N
System status: Stoerung
Derating (Über-/Unterspannnung) höhere Bit (MSB): 00000000
Fahrzeuggeschwindigkeit Steller: 0.00 km/h
Fehlerpfad: 00
DTC: C1 40 44
Status HW-KL15: active
MVK_eAWS_Sollmodus: Release
Zeit Nach KL15-Wechsel: 51.0 s
Fahrprogram: Program 1
Batterieabriss: 00
12664834 - Databus
[eAWS_VA_01_keine Kommunikation]
Reset counter: 73
Mileage: 176858 km
Date: 2025.03.10
Time: 00:07:05
Current: 0 A
Fehlerpfad: 00
DTC: C1 40 02
Batterieabriss: 00
12664901 - Databus
[eAWS_01_KZ keine Kommunikation]
Reset counter: 73
Mileage: 176858 km
Date: 2025.03.10
Time: 00:07:04
Current: 0 A
Fehlerpfad: 00
DTC: C1 40 45
Batterieabriss: 00
12669191 - 48V System
C124E 00 [10001001] - -
[Stecker-Ab-Erkennung 48V]
Reset counter: 73
Mileage: 176858 km
Date: 2025.03.10
Time: 00:07:06
Current: 0 A
Fehlerpfad: 00
DTC: C1 51 07
Batterieabriss: 00
12652550 - Initial Adapation Not Performed
U1117 00 [00001001] - -
[Kodierung]
Reset counter: 73
Mileage: 176858 km
Date: 2025.03.10
Time: 00:07:04
Current: 0 A
Fehlerpfad: 00
DTC: C1 10 06
Batterieabriss: 00
Steller-Isttorsion: 0.0000000
Steller-Solltorsion: 0.0000000
StellerTorsion Init: 0.0000000
Externer Verdrehwinkel: 0.0000000
Externe Winkelgeschwindigkeit: 0.0000000
ElektroMotor Istmoment: 0.0000
EawsCrtlActiveStatus: not active
LL-Statemachine (Commutation Task) State: State: Safe Mode
12665858 - Initial Adapation Not Performed
[Funktionsaktivierung: Funktion inaktiv]
Reset counter: 73
Mileage: 176858 km
Date: 2025.03.10
Time: 00:07:04
Current: 0 A
Fehlerpfad: 00
DTC: C1 44 02
Batterieabriss: 00
12668932 - Internal (Master / Slave) CAN Bus (SAE Bus B)
U0038 00 [10001001] - Performance
[Dem_SSB_KeineKommunikation]
Reset counter: 73
Mileage: 176858 km
Date: 2025.03.10
Time: 00:07:04
Current: 0 A
Fehlerpfad: 00
DTC: C1 50 04
Batterieabriss: 00
12681227 - No Basic Setting
B2010 00 [00001001] - -
[Wankprüfung durchführen]
Reset counter: 73
Mileage: 176858 km
Date: 2025.03.10
Time: 00:07:04
Current: 0 A
Fehlerpfad: 00
DTC: C1 80 0B
Batterieabriss: 00
13635841 - 48V System
[Unterspannung 48V]
Reset counter: 73
Mileage: 176858 km
Date: 2025.03.10
Time: 00:07:05
Spannung KL30: 12.2 V
Current: 0 A
Fehlerpfad: 00
DTC: D0 11 01
Batterieabriss: 00
12681226 - VIN
C0545 00 [00001001] - Not stored or incompatible
Reset counter: 73
Mileage: 176858 km
Date: 2025.03.10
Time: 00:07:04
Current: 0 A
Fehlerpfad: 00
DTC: C1 80 0A
Batterieabriss: 00
Address D6: Light Ctrl Left 2 (A31) Labels: 7PP-941-592.clb
Part No SW: 7PP 941 592 AA HW: 7PP 941 592 A
Component: LED1L H09 4002
ROD: EV_LEDModLeftMELCOAU736_VW51.rod
VCID: 176F06381F02EEB25EA-8042
Address D7: Light Ctrl Right 2 (A27) Labels: 7PP-941-592.clb
Component: LED1R H09 4002
Address DB: Frt Corner Rdar 1 (J1089) Labels:* None
Part No SW: 4N0 907 669 F HW: 4N0 907 669 A
Component: MRR_VR H12 0266
Dataset Number: V03935287KH 0001
Coding: 003000
ASAM Dataset: EV_FrontCorneRadarS1AU651 001018
ROD: EV_FrontCorneRadarS1AU651_VW53.rod
Address DC: Frt Corner Rdar 2 (J1088) Labels:* None
Component: MRR_VL H12 0266
Dataset Number: V03935287KJ 0001
Coding: 003000
ASAM Dataset: EV_FrontCorneRadarS2AU651 001018
ROD: EV_FrontCorneRadarS2AU651_VW53.rod
Address DE: Charger 1 for mobile dev (J1146) Labels:| 4N0-035-502.clb
Part No SW: 4N0 035 502 B HW: 4N0 035 502 B
Component: WLC Front H14 0061
Coding: 800000
VCID: 231722E8DB5AB212B22-8076
Address 8107: Antenna (JX3) Labels:* None
Part No SW: 4N0 035 503 J HW: 4N0 035 503 J
Component: DDA_Gen1 H02 0498
Coding: 1B49
ASAM Dataset: EV_DigitRoofAntenAU651 001012
ROD: EV_DigitRoofAntenAU651_001_VW53.rod
VCID: 2C05C9D4B6847D6A038-8078
End----------(Elapsed Time: 03:08, VBatt start/end: 12.1V/12.2V)-----------
------------------------------52 Faults Found------------------------------
