A8L W12 (D4) jerking under sudden acceleration
horrgakx
C?ID=610814
This has been going on now for about 3 months. At first I thought it was a mechanical issue because when I bought the car last year I knew that lower front arm bushes were shot so it's a reasonable assumption that the arms were moving under load. Anyway, the local (independent) garage changed out these two lower arms but there is no difference at all.
So it was back into the garage today, they got a pry bar all over the underside of the car and nothing is obvious. I sat in the passenger seat and asked the boss to take it for a spin, this snippet of video illustrates the problem.
He thinks its actually not a mechanical issue but is actually the engine is cutting power. The only thing he could think of is the tyre tread on the rear axle are about 4mm different (7mm on the near-side, 3mm on the off-side) and the car thinks the wheels are slipping. Would this really be the problem??
There's no error code to speak of, pasted below (the exhaust flap is a red-herring, the solenoid for both sides is not connected leaving the butterfly valve in the default open position. I just need to get that fixed but it needs to go into my exhaust guy).
So, any thoughts please? What about logging a session? Like recording torque output, wheel speeds, etc. If this would help then how do I do it in the VCDS software?
Thursday,06,March,2025,16:43:30:31183
VCDS Version: 25.3.0.2 (x64)  HEX-V2 CB: 0.4660.5
Data version: 20250228 DS364.1
VIN: WAUZZZ4H5FN0*****   License Plate:
Mileage: 120237km-74711mi   Repair Order:
Chassis Type: 4H-AU64 (4H0)
Scan: 01 02 03 05 06 08 09 0E 10 11 31 13 15 16 17 19 28 30 34 36
          3B 3C 42 44 46 47 48 52 53 55 56 57 5B 5F 62 69 6C 6D 6F 72
          81 84 85 88 89 8A 8B 8D 8E 8F 90
VIN: WAUZZZ4H5FN0*****   Mileage: 120237km-74711miles
11-Engine II -- Status: Malfunction 0010
31-Engine other -- Status: Malfunction 0010
48-Seat, Rear, DS -- Status: OK 0000
5B-Seat,Rear,PS -- Status: OK 0000
8A-Multicont. Seat Rear,DS -- Status: OK 0000
8D-Multicont. Seat Rear,PS -- Status: OK 0000
Address 01: Engine (J623-CTNA)       Labels:. 07P-906-023-V1.clb
   Part No SW: 07P 906 027 A    HW: 07P 907 309
   Component: W12 6.3 EU6   H22 8556
   Revision: 41H22000    CVN: 077AE0AA
   Coding: 002A0012256601000800
   Shop #: WSC 23485 002 1048576
   ASAM Dataset: EV_ECM63FSI11107P906027A 001011
   ROD: EV_ECM63FSI07P906027A.rod
   VCID: 303ECF06AAA4CF7A3F1-8064
   VINID: 9D196AAAA1181567800890472095894A27
16672 - Please Check DTC Memory of ECU Number 2
          P1923 00 [00100111] - -
                    Mileage: 120237 km
                    Date: 2025.03.06
                    Time: 16:38:06
                    Engine speed: 0.00 /min
                    Coolant temperature: 90  C
                    Intake air temperature: 51  C
                    Voltage terminal 30: 12.133 V
                    Unlearning counter according OBD: 0
                    Relative load value: 52.99 %
                    Engine torque: 0.0 Nm
                    Fuel level: 28.00 l
                    Oxygen sensor bank 1 sensor 1: specified value: 1.0000
                    Intake camshaft B1 active operating state: 0
19302 - Exhaust Pressure Control Valve
          P0478 00 [00100111] - Short to Plus
                    Mileage: 120237 km
                    Date: 2025.03.06
                    Time: 16:38:05
                    Voltage terminal 30: 12.180 V
                    Fuel level: 28.00 l
Readiness: 1110 1001
   Part No SW: 4H1 927 158 CG    HW: 0BK 927 156 AD
   Component: 0BK 63 FSIRdW H19 1004
   Revision: --H19---    CVN: 70C58982
   VCID: 77AC341A0F4AD842BEB-8022
Address 03: ABS Brakes (J104)       Labels: 4H0-907-379.clb
   Part No SW: 4H0 907 379 AA    HW: 4H0 907 379 AA
   Component: ESP PREMIUM   H10 0665
   Coding: A2E5EBA045A7D705E300
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ESPPremi 005024
   ROD: EV_ESPPremi_005_AU64.rod
   VCID: 71B80A02612E867270F-8024
   Part No SW: 4H0 907 064 FB    HW: 4H0 907 064 EB
   Component: BCM2 2.0      H36 0560
   Coding: 05B76F4E000000000000
   VCID: 6E82117E7090998A6DD-803A
   Serial number: 3214000146951005
   Part No SW: 4H0 959 760 E    HW: 4H0 959 760 E
   Component: MEM-BFS       H08 0156
   Revision: AA000000    Serial number: 00000127663944
   Coding: C038B60085047201010001010101112131313333283333
   VCID: 3530FE125546EA526C7-8060
Address 08: Auto HVAC (J255)       Labels:| 4H0-820-043.clb
   Part No SW: 4H0 820 043 P    HW: 4H0 820 043 P
   Component: Klima 4 Zonen H20 0210
   Coding: 4CE10BBEBC0000
   ASAM Dataset: EV_AirCondiFront 003001
   ROD: EV_AirCondiFront_002.rod
   VCID: 2D00D672BD96A292147-8078
   Part No SW: 4H0 907 063 DB    HW: 4H0 907 063 AB
   Component: BCM1 2.0      H20 0311
   Revision: 19020001    Serial number: 00000950283401
   Coding: 0105001440349FE2C9014084A0001800009DC30A2F080201800008946100170000400009090000
   VCID: 6B84186A43826CA24A3-803E
   Subsystem 1 - Part No SW: 4H2 955 119 C    HW: 4H2 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS641 140603  H36 0090
   Serial number:         140618061852
   Coding: 0045F7
   Serial number: 23544642
   Coding: 0200FF
   Subsystem 3 - Part No SW: 4H0 941 531 C    HW: 4H0 941 531 C
   Component: E1 - LDS  H07 0044
   Serial number: 21 02 2014  00001174
   Component: EVLS-SG  H08 0300
   Serial number: WA109401000010289539
   Coding: 020300
   Serial number: 92288167000000000001
Address 0E: Media Player 1 (R161)       Labels: None
   Part No SW: 4H0 035 108 F    HW: 4H0 035 108
   Component: DVDCAlpine    H42 0200
   Revision: AA001001
   VCID: 2314304AEBD264E2B23-8076
Address 10: Park/Steer Assist (J791)       Labels:| 4H0-919-475-7X5.clb
   Part No SW: 4G0 919 475 G    HW: 4H0 919 475 E
   Component: PARKHILFE PLA H06 0070
   Revision: --------    Serial number: 56261434300122
   Coding: B93B07
   ASAM Dataset: EV_EPHVA2CAU64X0000 001011
   ROD: EV_EPHVA2CAU64X0000_AU64.rod
   VCID: 3530FE1255C6EA526C7-8060
Address 11: Engine II (J624)       Labels:. 07P-906-023-V1.clb
   ASAM Dataset: EV_ECM63FSI21107P906027A 001011
   ROD: EV_ECM63FSI07P906027.rod
24749 - Exhaust Pressure Control Valve 2
          P04A2 00 [00100111] - Short to Plus
                    Mileage: 120237 km
                    Date: 2025.03.06
                    Time: 16:38:05
                    Intake air temperature: 45  C
                    Voltage terminal 30: 12.203 V
                    Fuel level: 28.00 l
   Part No SW: 4H0 907 561 C    HW: 4H0 907 561
   Component: ACC3          H21 0032
   Serial number: 00000000000000 Dataset Number: 4H0909863E  0037
   Coding: 7F04020201
   ASAM Dataset: EV_AdaptCruisContrAU64X 002024
   ROD: EV_AdaptCruisContrAU64X_002_AU64.rod
   VCID: 2B04D86A8382ACA20A3-807E
   Component: Airbag10.43   H82 0086
   Revision: --------    Serial number: 003P1002BELY Dataset Number: 4H0909602J  0017
   Coding: 30333045313430303037554A305234483053
   VCID: 3B24E82A73E23C229A3-806E
   Serial number: 3575HRB40532OSCEAPD0
   Serial number: 3585HRB40552QMKACPB3
   Serial number: 3515JRB405932I4ODG2%
   Serial number: 3525JRB405932I4OH82$
   Serial number: 3554VRB405F34GNSF8D5
   Serial number: 3564VRB405F34GNSF0D+
   Part No SW: 4H0 953 568 H    HW: 4H0 953 568 H
   Revision: --------    Serial number: 01335NKT0019U
   Coding: 0004FC
   VCID: 382EF7264254173A771-806C
   Subsystem 1 - Part No SW: 4H0 951 528 A    HW: 4H0 951 528 A
   Serial number: 15 10 2014  C0042916
   Part No SW: 4H0 920 850 R    HW: 4H0 920 850 R
   Component: TBenGB-ACCNV- H53 0707
   Revision: 37081202    Serial number: 658041214592070
   Coding: 338608001F552600010200
   ASAM Dataset: EV_RBD4K 004050
   ROD: EV_RBD4K_AU64.rod
   VCID: 3632F91E48C0E14A65D-8062
   Analog_clock:
   Subsystem 1 - Part No SW: 4H0 919 204 Q    HW: 4H0 919 204 Q
   Component: Analoguhr D4  H05 0225
   Serial number: 2141112000585
   Part No SW: 4H0 907 468 AF    HW: 4H0 907 468 AC
   Revision: --------    Serial number: 00000001662604 Dataset Number: 4H0909515L  0087
   Coding: C0CD075C08
   GVL: FFFFE85CFFE7E7FDC0000000
   VCID: 75B03E121546AA52AC7-8020
   Subsystem 1 - Part No SW: 4H0 915 181 F    HW: 4H0 915 181 F
   Component: J367-BDM  H08 0181
   Serial number: 61323F46171911098926
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 8K0 959 663 C    HW: 8K0 959 663 C
   Serial number: 14342000404021200410
Address 28: HVAC, Rear (E265)       Labels:| 4H0-919-158.clb
   Part No SW: 4H0 919 158 K    HW: 4H0 919 158 K
   Component: Klima Fond    H17 0200
   Coding: 2800000000
   ASAM Dataset: EV_AirCondiHeck 002001
   ROD: EV_AirCondiHeck_AU64.rod
   VCID: 382EF72642D4173A771-806C
Address 30: Special Function II (J843)       Labels: 8K0-907-440.clb
   Part No SW: 4H0 907 440     HW: 4H0 907 440
   Component: STS           H06 0030
   Revision: S0H06000    Serial number: 00000000071746
   Coding: 01010101000000000001000102
   VCID: 64967356AE5C23DA0B9-8030
   Dataset Number: 4H0909553H  0038
   Coding: 008003
   ROD: EV_AirSuspe_003_AU64.rod
   VCID: 2F3CCC7AB79AD08226B-807A
   Component: MEM-FS        H08 0156
   Revision: AA000000    Serial number: 00000127663111
   Coding: C038BF8085857201030001010101112131313333203333
   Part No SW: 4H0 907 637 K    HW: 4H0 907 637 F
   Component: SARA 6D       H04 0056
   Revision: --------    Serial number: EJ1BPA7702C3TB
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 372CF41A4FCA18427EB-8062
   Part No SW: 4H0 907 566 F    HW: 4H0 907 566 F
   Component: SWA Master    H06 0030
   Serial number: 0351694540 Dataset Number: 4H0909535D  0017
   Coding: 040312
   ROD: EV_LaneChangAssis_VW52.rod
   VCID: 3334C00A5BB2F462423-8066
   Subsystem 1 - Part No SW: 4H0 907 568 F    HW: 4H0 907 568 F
   Component: SWA Slave  H06 0030
   Serial number: 0352225009
   Coding: 040312
   Part No SW: 4H0 959 793 R    HW: 4H0 959 793 G
   Component: TSG FA        H07 0280
   Revision: --------    Serial number: 0000127890478
   Coding: 011F1E015E0162C202083017
   VCID: 48CE87E632B467BA071-801C
   Part No SW: 4G0 909 144 M    HW: 4G0 909 144 G
   Component: RCEPS         H40 0011
   Revision: 00001000    Serial number: 0002650065 Dataset Number: 4H0909852J  0023
   Coding: 101101010001
   ASAM Dataset: EV_RCEPS 009010
   ROD: EV_RCEPS_009.rod
   Revision: 00002001    Serial number: 0354490037
   Coding: 011B0E2280B93985FB30C7C40E0316470000000000000000000000000000
   Subsystem 1 - Part No: 4H0 951 177
   Component: DWA-Sensor  H01 0010
   Subsystem 3 - Part No SW: 4H0 959 591     HW: 4H0 959 591
   Component: J245 PS50.030  H08 0006
   Serial number:     WOO33926478
   Coding: 901F00
   Subsystem 4 - Part No SW: 4H0 907 133 A    HW: 4H0 907 133 A
   Component: J505-FSH  H06 0046
   Serial number: 00000000000000010606
   Subsystem 5 - Part No SW: 4H0 947 135 G    HW: 4H0 947 135 G
   Component: Dachelektroni  H13 0080
   Serial number: A2014000000000829295
   Subsystem 6 - Part No SW: 4H0 959 591 A    HW: 4H0 959 591 A
   Component: V252 PS014  H06 0005
   Serial number:     WOO10008DNJ
   Subsystem 7 - Part No SW: 3AA 962 243 D    HW: 3AA 962 243 D
   Serial number: 93351668
   Part No SW: 4G1 035 223 A    HW: 4G1 035 223 A
   Component: BOSE-G3C7-ANC H02 0540
   Revision: CJ002700    Serial number: 00000000011986
   Coding: 030000
   VCID: 1C660BB6D6AC5B1A739-8048
Address 48: Seat, Rear, DS (J876)       Labels: None
   Part No SW: 4H0 959 860     HW: 4H0 959 860
   Component: MEM-FS-Fond   H06 0158
   Revision: AA000000    Serial number: 00000122570039
   Coding: 003892800000700D0A00392038193A2039203B3B202020
   VCID: 71B80A0261AE867270F-8024
   Part No SW: 4H0 959 792 G    HW: 4H0 959 792 G
   Component: TSG BF        H07 0280
   Revision: --------    Serial number: 0000126798159
   Coding: 011F1E015E0162C202083006
   VCID: 3C26EB36766C3B1A939-8068
   Part No SW: 4H0 907 801 H    HW: 4H0 907 801 A
   Component: EPB-4         H04 0015
   Revision: --------    Serial number: 00000001294340 Dataset Number: 4H0909522D  0017
   ROD: EV_ParkiBrake_VW51.rod
   Part No SW: 4H4 907 357 B    HW: 7P6 907 357 B
   Component: MxB-ECU       001 0049
   Revision: --------    Serial number: -------------- Dataset Number: 4H0909865C  0018
   Coding: 02F60220221B0200
   ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 004002
   ROD: EV_HeadlRegulAUDIMXBAU64X_004_AU64.rod
   VCID: 3138CA02A1AEC67230F-8064
   Subsystem 1 - Part No SW: 7PP 941 472 G    HW: 7PP 941 472 G  Labels: 3D0-941-329.CLB
   Component: LED LeiMo li.  H07 7540
   Coding: E00300
   Subsystem 2 - Part No SW: 7PP 941 472 G    HW: 7PP 941 472 G  Labels: 3D0-941-329.CLB
   Component: LED LeiMo re.  H07 7540
   Coding: E00300
   Power module 1 for left matrix headlamp:
   Subsystem 3 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
   Component: MxB LeiMo li.  H03 0031
   Coding: E00300
   Power module 1 for right matrix headlamp:
   Subsystem 4 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
   Component: MxB LeiMo re.  H03 0031
   Coding: E00300
   Part No SW: 4G0 035 061 S    HW: 4G0 035 061
   Component: Radio U DAB   H60 0154
   Revision: AB001007    Serial number: 109L50E7996311
   Coding: 010103010000000001
   VCID: 2D00D672BD16A292147-8078
Address 57: TV Tuner (R78)       Labels: None
   Part No SW: 4G0 919 129 C    HW: 4G0 919 129
   Component: NGTV-DVB      H04 0690
   Revision: R0043000    Serial number: 06801301739701
   Coding: 03000000
Address 5B: Seat,Rear,PS (J877)       Labels: None
   Component: MEM-BFS-Fond  H06 0158
   Revision: AA000000    Serial number: 00000122569710
   Coding: 003896800000700D0A00392038193A2039203B3B382020
   Part No SW: 4H0 035 654 E    HW: 4H0 035 670 T
   Component: H-BNT-EU      H48 1072
   Revision: --------    Serial number: 449L80E7500866
   Coding: 04010100000BF9EF7DB4C31600000003080001000000000000
   VCID: 280E276692F487BAE71-807C
   Subsystem 1 - Part No: 8R0 060 884 KL
   Component: EUR 2023  3600
   Subsystem 2 - Part No SW: 4F0 910 393 AH    HW: 4F0 862 393 E
   Component: BTHS  H25 0750
   Serial number: P14004026934
   Subsystem 3 - Part No SW: 4H2 919 600 L    HW: 4H2 919 600
   Component: E380 BDT D4  H11 0110
   Serial number: 00000000180608
   Component: CD-Database  5950
                    Reset counter: 55
                    Mileage: 120237 km
                    Date: 2025.03.06
                    Time: 16:32:06
                    Text: KBD_FD4,TPE,M,0,0,6
02259 - Information Display and Control Head (Front) (J685)
                    Reset counter: 55
                    Mileage: 120237 km
                    Date: 2025.03.06
                    Time: 16:32:07
                    Voltage: 11.50 V
03623 - Invalid Security/Release Code
                    Reset counter: 55
                    Mileage: 120237 km
                    Date: 2025.03.06
                    Time: 16:32:04
                    Hex Value: 0x0004
                    Hex Value: 0x0009
                    Count: 7
03787 - Rotation Mechanism for Display Module Front
                    Reset counter: 55
                    Mileage: 120237 km
                    Date: 2025.03.06
                    Time: 16:32:03
                    Voltage: 11.50 V
   Part No SW: 4H0 959 795 D    HW: 4H0 959 795 D
   Component: TSG HL        H07 0280
   Revision: --------    Serial number: 0000128623205
   Coding: 010F1E01420062C202083006
Address 69: Trailer (J345)       Labels:| 4H0-907-383-V2.clb
   Part No SW: 4H0 907 383 N    HW: 4H0 907 383 L
   Component: Anhaenger     H20 0160
   Revision: 7A001003    Serial number: 0417008171
   Coding: 0100000202000000
   Part No SW: 4H0 907 428 D    HW: 7P6 907 441 F
   Component: TopView       H07 0330
   Revision: 11001001    Serial number: 82330JF0192857
   Coding: 020D000001000000010102000000
   ASAM Dataset: EV_CamerSysteTopViewAUDI 008027
   VCID: 2E02D17EB090D98A2DD-807A
   Part No SW: 4H0 959 107 AC    HW: 4H0 959 107 AC
   Component: HDSG-Modul    H12 0049
   Revision: 10012001    Serial number: 344400055 Dataset Number: 4H0909541F  0008
   Coding: 021004C021
   ASAM Dataset: EV_DeckLidContrUnit 001032
   ROD: EV_DeckLidContrUnit.rod
   VCID: 6FBC0C7A771A908266B-803A
Address 6F: Centr. Conv. II (J773)       Labels:* None
   Part No SW: 4H0 907 412     HW: 4H0 907 412
   Component: ALM           H05 0004
   Revision: --------    Serial number: 000000171871 Dataset Number: 4F0000000__ U001
   Coding: 220000
   ASAM Dataset: EV_Ambie 001008
   ROD: EV_Ambie.rod
   VCID: 6394704AABD224E2F23-8036
   Component: TSG HR        H07 0280
   Revision: --------    Serial number: 0000128623206
Address 81: Gear Shift (J587)       Labels: 3Y0-927-731.clb
   Part No SW: 4H2 927 731 A    HW: 4H2 927 731 A
   Component: GSM-RL        H09 0083
   Revision: 0R0D5015    Serial number: SN141104  0165
   ROD: EV_GSM2x3Mono_AU64.rod
   VCID: 2C06DB76868CAB9A039-8078
Address 84: Night Vision (J853)       Labels:* None
   Part No SW: 4G0 907 547 A    HW: 4G0 907 547
   Component: NV-ECU-Gen3   H08 0107
   Serial number: 622352400201445
   Coding: 201100
   ASAM Dataset: EV_NightVisioGen3AE4AU64X 001001
   ROD: EV_NightVisioGen3AE4AU64X_AU64.rod
   Night vision system camera:
   Subsystem 1 - Part No SW: 4G0 980 552     HW: 4G0 980 552
   Component: NV-CAM-Gen3  H03 0006
   Serial number: 623466500F1606000255
   Component: DPC-SG        H27 0081
   Revision: --------    Serial number: 262130025421000 Dataset Number: 4H0909547F  0046
   Coding: EA160000
   ROD: EV_OnBoardCamerDPC.rod
Address 88: Multicont. Seat Driver (J873)       Labels:* None
   Part No SW: 4H0 907 182 H    HW: 4H0 907 182 H
   Component: IVB           H07 0042
   Serial number: 00019307143601 Dataset Number: 4H0909880D  0019
   Coding: 776FF2
   ROD: EV_IVBDriveSideFrnt_AU64.rod
Address 89: Multicont. Seat Pass. (J872)       Labels:* None
   Serial number: 00019138111001 Dataset Number: 4H0909881D  0019
   Coding: 376FF2
Address 8A: Multicont. Seat Rear,DS (J875)       Labels:* None
   Part No SW: 4H0 907 182 G    HW: 4H0 907 182 G
   Component: IVB           H08 0042
   Serial number: 00019139006901 Dataset Number: 4H0909882D  0014
   Coding: 212F00
   ASAM Dataset: EV_IVBDriveSideRear 001003
   Part No SW: 4H0 907 541 C    HW: 4H0 907 541
   Coding: 7F04020201
   ASAM Dataset: EV_AdaptCruisContr2AU64X 002021
   ROD: EV_AdaptCruisContr2AU64X_002_AU64.rod
   VCID: 29082262897EBEB2F8F-807C
Address 8D: Multicont. Seat Rear,PS (J874)       Labels:* None
   Serial number: 00019139060601 Dataset Number: 4H0909883D  0014
   Coding: 212F00
   ASAM Dataset: EV_IVBPasseSideRear 001003
   Part No SW: 4H0 907 107 H    HW: 4H0 907 107
   Component: BV-SG         H33 0090
   Serial number: 005000620112147 Dataset Number: 4H0909548K  0035
   Coding: 02C23B041111
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7.rod
   Dataset Number: 4H0909614C  0003
   Coding: 0066F609031F0376070308004240C2010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   Dataset Number: 4H0909615C  0003
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
   VCID: 323AC50EA4A8FD6A495-8066
End----(Elapsed Time: 03:38, VBatt start/end: 12.2V/11.9V. VIgn 11.9V)-----
------------------------------7 Faults Found-------------------------------
Dr Sheldon
Windsor UK
C?ID=334979
jerking under sudden acceleration​
Problem here that the verb "Jerking" has multiple meanings and VERY open to interpretation !
horrgakx
C?ID=610814
Yeh I know, and I took a risk, hoping nobody would have the same sense of humour as me. But it describes the issue perfectly.
Also, that word can be used in the UK without too much sniggering, we use other terms.
Dr Sheldon
Windsor UK
C?ID=334979
Does it Spit or ...........
Sounds like a plausible theory to me, but then I would think there would be a yellow blinking traction control icon or similar in the dash when it happens...?
horrgakx
C?ID=610814
No warning lights at all, no traction control light.
About data logging or charting then. If I wanted to find out what the car was doing regarding cutting power in this situation, what parameters would I need, and how do I go about it please?
Ziddywerks
Northern NJ USA
C?ID=208579
I would rule out the ovious. Shit fuel? are the plugs due based on interval? coils? Log misfire counter to see if it's a misfire under load of not. Usually misfire under heavy load can be coils, plugs or injectors as well. Verify the basic's.
horrgakx
C?ID=610814
The fuel I use is BP 95RON. I can try a tank of Esso Super which is 98RON, which I've not done for a few months, but I'm not so sure because this issue happens at lower engine speeds, under partial throttle, but with a sharp application of the throttle. If I smoothly apply the throttle all the way then it can go to the redline smoothly and pull strongly as normal.
Plugs were changed within the required interval, though I'll need to check for the date.
Looking at misfire is a great idea, is that an actual parameter? Is there a guide which can walk me through how to do it pls? Along with suggestions of any other sensors which would be relevant.
dareckim11
Glasgow Scotland
C?ID=404683
Address 01: Engine
I would start with these errors. EPCV affects the operation of the EGR valve and the operation of the injectors.
horrgakx
C?ID=610814
Thanks, but that's one of the flaps in the rear exhaust system which I mentioned it in my original post. It has been like that since last summer. I had disconnected the flaps in favour of some blanking plugs which were meant to let the ECU know all was well. But one of them does seem to be not right - but because the butterfly valves are disconnected and therefore are open permanently do you really think it's the reason for the error message? And would it cause this issue which has only been apparent within the last 3 months??
dareckim11
Glasgow Scotland
C?ID=404683
What blanking plugs are you writing about? Do you have any upgrades? Or maybe some stage?
Delete the errors, start the engine and check what errors come back.
horrgakx
C?ID=610814
Blanking plugs because the valve bodies are disconnected. Long story but I'll be having it fixed this summer.
horrgakx
C?ID=610814
I see that according to this page, for vehicles with dual ECU's I need to go into "31 Engine Other" and look at the Measuring Blocks in there. Does anyone have experience of looking for issues like this and can advise on what I need to do for the best capture results please? ie. getting the best Groups etc.
It is possible to look at a single MVB from both ECUs at the same time, which is useful under certain circumstances, but applicable in your case since all misfire data is in ECU #2 on your engine.
Besides, your ECUs use the newer UDS protocol and don't support the Measuring Blocks function at all, which is why I said, "Go to Adv. Meas. Values"...
horrgakx
C?ID=610814
While I was out this morning and had some time to spare I thought I would attempt to record a log while this was happening. The actual issue manifested itself in a fairly mild manner, I've seen a lot worse. However the car threw out a shed-load of errors which I managed to save. Could they be a clue to what's happening? However many of the errors appear to be as a result of some weird communication messages.
For completeness the entire log before this occurred is here. I wanted to highlight some text by using strikethrough and bold tags but it seems you can't use these tags within the [ code ] tags. I was going to highlight the current issues which I already know about but don't have an impact on the main issue - these include;
  • 16672 - Please Check DTC Memory of ECU Number 2 (as a result of the exhaust flap being unplugged)
  • 19302 - Exhaust Pressure Control Valve (as a result of the flap being unplugged, leaving the butterfly in the open position)
  • 24416 - Linear Oxygen (Lambda) Sensor B3 S1; Pump Current Wire (I need to have this replaced)
  • 01403 - Glass-Break Sensors; Rear
  • 02615 - Fuel Tank Cap; Lock (faulty motor)
  • 02616 - Fuel Tank Cap; Unlock (faulty motor)
  • 5x faults in; Address 5F: Information Electr. (J794) (due to the original centre display being upgraded)
Wednesday,02,April,2025,08:57:24:31183
VCDS Version: 25.3.0.4 (x64)  HEX-V2 CB: 0.4660.5
Data version: 20250311 DS365.0
VIN: WAUZZZ4H5FN0*****   Mileage: 121008km-75190miles
   VCID: 303ECF06AAA4CF7A3F7-8064
          P1923 00 [00101111] - -
                    Mileage: 120816 km
                    Date: 2025.03.26
                    Time: 16:32:55
                    Engine speed: 527.00 /min
                    Normed load value: 19.6 %
                    Coolant temperature: 94  C
                    Intake air temperature: 55  C
                    Voltage terminal 30: 13.829 V
                    Relative load value: 14.51 %
                    Engine torque: 77.2 Nm
                    Fuel level: 61.00 l
          P0478 00 [00101111] - Short to Plus
                    Mileage: 120816 km
                    Date: 2025.03.26
                    Time: 16:32:55
                    Engine speed: 550.50 /min
                    Normed load value: 19.2 %
                    Voltage terminal 30: 13.994 V
                    Relative load value: 14.27 %
                    Fuel level: 61.00 l
   VCID: 77AC341A0F4AD842BED-8022
   VCID: 71B80A02612E8672709-8024
   VCID: 6E82117E7090998A6DB-803A
   VCID: 3530FE125546EA526C1-8060
   VCID: 2D00D672BD96A292141-8078
   Coding: 0105801440349FE2C9014084A0001800009DC30A2F080201800008946100170000400009090000
   VCID: 6B84186A43826CA24A5-803E
   Coding: 0045F7
   Coding: 0200FF
   Coding: 020300
   Revision: AA001001
   VCID: 2314304AEBD264E2B25-8076
   Coding: B93B07
   VCID: 3530FE1255C6EA526C1-8060
          P3164 00 [10101100] - Open Circuit
                    Fault Frequency: 21
                    Mileage: 120816 km
                    Date: 2025.03.26
                    Time: 16:33:05
                    Engine speed: 578.00 /min
                    Normed load value: 27.5 %
                    Vehicle speed: 4 km/h
                    Coolant temperature: 93  C
                    Intake air temperature: 12  C
                    Voltage terminal 30: 13.617 V
                    Engine torque: 102.6 Nm
                    Fuel level: 53.00 l
                    Intake camshaft B1 active operating state: 1
          P04A2 00 [00101111] - Short to Plus
                    Mileage: 120816 km
                    Date: 2025.03.26
                    Time: 16:32:55
                    Engine speed: 545.50 /min
                    Normed load value: 18.4 %
                    Intake air temperature: 48  C
                    Voltage terminal 30: 14.229 V
                    Engine torque: 73.3 Nm
                    Fuel level: 61.00 l
   Coding: 7F04020201
   VCID: 2B04D86A8382ACA20A5-807E
   VCID: 3B24E82A73E23C229A5-806E
   Coding: 0004FC
   VCID: 382EF7264254173A777-806C
01426 - Controls in Steering Wheel (E221)
                    Reset counter: 150
01747 - Sensor for Heated Steering Wheel (Z36)
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Fault Frequency: 12
                    Reset counter: 111
   Coding: 338708001F552600010200
   VCID: 3632F91E48C0E14A65B-8062
   Analog_clock:
   Coding: C0CD075C08
   VCID: 75B03E121546AA52AC1-8020
   Voltage stabilizer:
   Coding: 2800000000
   VCID: 382EF72642D4173A777-806C
   VCID: 64967356AE5C23DA0BF-8030
   Coding: 008003
   VCID: 2F3CCC7AB79AD08226D-807A
   ROD: EV_SARA2.rod
   VCID: 372CF41A4FCA18427ED-8062
   Coding: 040312
   VCID: 3334C00A5BB2F462425-8066
   Coding: 040312
   VCID: 48CE87E632B467BA077-801C
   Coding: 013B0E2280B93985FB30C7C40E0316470000000000000000000000000000
   Coding: 901F00
                    Reset counter: 99
                    Mileage: 120816 km
                    Date: 2025.03.26
                    Time: 16:32:50
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 99
                    Mileage: 120816 km
                    Date: 2025.03.26
                    Time: 16:39:14
                    Reset counter: 99
                    Mileage: 120816 km
                    Date: 2025.03.26
                    Time: 18:12:50
   Coding: 030000
   VCID: 1C660BB6D6AC5B1A73F-8048
   VCID: 71B80A0261AE8672709-8024
   VCID: 3C26EB36766C3B1A93F-8068
   VCID: 3138CA02A1AEC672309-8064
   Coding: E00300
   Coding: E00300
   Coding: E00300
   Coding: E00300
   VCID: 2D00D672BD16A292141-8078
   Coding: 03000000
   VCID: 280E276692F487BAE77-807C
                    Reset counter: 99
                    Mileage: 120816 km
                    Date: 2025.03.26
                    Time: 16:32:56
00658 - Control Head
                    Fault Frequency: 44
                    Reset counter: 151
                    Mileage: 120816 km
                    Date: 2025.03.26
                    Time: 16:39:47
                    Voltage: 12.50 V
                    Reset counter: 99
                    Mileage: 120816 km
                    Date: 2025.03.26
                    Time: 16:32:57
                    Voltage: 14.60 V
                    Reset counter: 99
                    Mileage: 120816 km
                    Date: 2025.03.26
                    Time: 16:32:54
                    Hex Value: 0x0004
                    Hex Value: 0x0009
                    Count: 7
                    Reset counter: 99
                    Mileage: 120816 km
                    Date: 2025.03.26
                    Time: 16:32:53
                    Voltage: 14.50 V
   VCID: 2E02D17EB090D98A2DB-807A
   Coding: 021004C021
   VCID: 6FBC0C7A771A908266D-803A
   Coding: 220000
   ROD: EV_Ambie.rod
   VCID: 6394704AABD224E2F25-8036
   VCID: 2C06DB76868CAB9A03F-8078
   Coding: 201100
   Coding: EA160000
   Coding: 776FF2
   Coding: 376FF2
   Coding: 212F00
   Coding: 7F04020201
   VCID: 29082262897EBEB2F89-807C
   Coding: 212F00
   ROD: EV_BC7.rod
   ROD: EV_RGS_L.rod
   ROD: EV_RGS_R.rod
   VCID: 323AC50EA4A8FD6A493-8066
End----------(Elapsed Time: 03:45, VBatt start/end: 14.4V/14.7V)-----------
------------------------------14 Faults Found------------------------------
When the problem happened a huge number of warnings appeared and it generated this log below. The new issues were to do with; MAF sensor / 02 Auto Transmission / 03 ABS Brakes / 10 Park & Steer assist / 13 Auto Distance / 34 Level Control (air suspension) / 54 Parking Brake / 8B Adaptive Cruise / 8E Image Processing.
Wednesday,02,April,2025,09:14:53:31183
VIN: WAUZZZ4H5FN0*****   Mileage: 121011km-75192miles
                    Mileage: 121008 km
                    Date: 2025.04.02
                    Time: 08:58:14
                    Engine speed: 583.00 /min
                    Coolant temperature: 72  C
                    Intake air temperature: 31  C
                    Relative load value: 15.77 %
                    Engine torque: 78.8 Nm
                    Fuel level: 32.00 l
                    Mileage: 121008 km
                    Date: 2025.04.02
                    Time: 08:58:14
                    Engine speed: 610.00 /min
                    Relative load value: 14.91 %
                    Engine torque: 77.9 Nm
                    Fuel level: 32.00 l
5668 - Mass Air Flow Sensor (G70)
          P0101 00 [00100111] - Implausible Signal
                    Mileage: 121011 km
                    Date: 2025.04.02
                    Time: 09:09:32
                    Engine speed: 3893.00 /min
                    Normed load value: 96.9 %
                    Vehicle speed: 32 km/h
                    Coolant temperature: 96  C
                    Intake air temperature: 24  C
                    Voltage terminal 30: 13.028 V
                    Leakage air: 1.5 kg/h
                    Long term adaptation of throttle valve for mass air flow sensor: 1.11523
                    Mass flow through throttle valve: 413.5 kg/h
Readiness: 0110 1001
2505 - Torque Management Feedback Signal A
          P2637 00 [00100111] - -
                    Mileage: 121011 km
                    Date: 2025.04.02
                    Time: 09:09:35
                    Voltage terminal 30: 14.051 V
                    Transmission output speed: 965.00 /min
                    Driving position: d
                    M008_Torque Converter Lockup Clutch State-Shift Type / Mode: 0
                    M008_Torque Converter Lockup Clutch State-Torque Converter Lockup Clutch: closed
                    M008_Torque Converter Lockup Clutch State-Traction/Coasting Flag: Coasting
                    Transfer speed from ESP: 40.61 km/h
                    Transfer speed from ESP: valid
0172 - Function Restriction due to Faults in Other Modules
          U1113 00 [10001001] - -
          [Can_Motor_03_QBitMotormomente]
                    Reset counter: 112
                    Mileage: 121011 km
                    Date: 2025.04.02
                    Time: 09:09:33
                    VzRef: 26
                    Bit Info 1: 00
                    Bit Info 2: 40
                    Bit Info 3: 06
                    Bit Info 4: 12
                    F-Path: 29
                    F-Type: 46
                    Uz: B4
   Coding: 0045F7
   Coding: 0200FF
   Coding: 020300
   Revision: AA001001
   Coding: B93B07
13637413 - Databus
          [Bremsensteuerger t - ESP_01.ESP_Systemstatus - Fehlerspeicher auslesen]
                    Reset counter: 112
                    Mileage: 121011 km
                    Date: 2025.04.02
                    Time: 09:09:33
                    Mileage: 121008 km
                    Date: 2025.04.02
                    Time: 08:58:14
                    Normed load value: 17.3 %
                    Intake air temperature: 30  C
                    Voltage terminal 30: 14.135 V
                    Engine torque: 77.1 Nm
                    Fuel level: 32.00 l
   Coding: 7F04020201
105472 - Function Restriction due to Faults in Other Modules
          U1113 00 [00001001] - -
          [FAULT_CIS_VDC_FAIL]
                    Reset counter: 112
                    Mileage: 121011 km
                    Date: 2025.04.02
                    Time: 09:09:33
                    Control Module temperature: 24  C
                    Voltage terminal 15: 14.522 V
                    Velocity_vehicle_reference: 11.82 m/s
                    Longitudinal_acceleration_vehicle_reference: 5.17 m/s
   Coding: 0004FC
                    Reset counter: 111
                    Mileage: 121008 km
                    Date: 2025.04.02
                    Time: 08:58:09
   Analog_clock:
   Coding: C0CD075C08
   Voltage stabilizer:
   Coding: 2800000000
   Coding: 008003
0648 - Function Restriction due to Implausible Message(s)
          U1112 00 [00001001] - -
                    Reset counter: 112
                    Mileage: 121011 km
                    Date: 2025.04.02
                    Time: 09:09:33
   ROD: EV_SARA2.rod
   Coding: 040312
   Coding: 040312
   Coding: 901F00
                    Reset counter: 111
                    Mileage: 121008 km
                    Date: 2025.04.02
                    Time: 08:58:09
   Coding: 030000
464384 - Function Restriction due to Faults in Other Modules
          [FC_SIGNAL_MO_QBIT_MOTORMOMENTE_QBIT]
                    Reset counter: 112
                    Mileage: 121011 km
                    Date: 2025.04.02
                    Time: 09:09:33
                    Voltage terminal 30: 14.5 V
                    Internal Fault ID: 188
                    Vehicle speed: 38 km/h
                    Function light in parking brake button: OFF
                    Red operating lamp: OFF
                    Red warning lamp: OFF
                    Green operating lamp: OFF
                    Yellow warning lamp: OFF
                    Terminal 15 status: On
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
                    ACC requested apply: not active
                    Auto Adjust: not active
                    Internal Parking Brake state: Dynamic
                    Status ParkingBrake left: Open
                    Status ParkingBrake right: Open
   Coding: E00300
   Coding: E00300
   Coding: E00300
   Coding: E00300
   Coding: 03000000
                    Reset counter: 111
                    Mileage: 121008 km
                    Date: 2025.04.02
                    Time: 08:58:15
                    Text: NGTV_DVB,H6X,M,0,0,6
                    Reset counter: 111
                    Mileage: 121008 km
                    Date: 2025.04.02
                    Time: 08:58:15
                    Voltage: 14.50 V
                    Reset counter: 111
                    Mileage: 121008 km
                    Date: 2025.04.02
                    Time: 08:58:13
                    Hex Value: 0x0004
                    Hex Value: 0x0009
                    Count: 7
                    Reset counter: 111
                    Mileage: 121008 km
                    Date: 2025.04.02
                    Time: 08:58:11
                    Voltage: 14.50 V
   Coding: 021004C021
   Coding: 220000
   ROD: EV_Ambie.rod
   Coding: 201100
   Coding: EA160000
   Coding: 776FF2
   Coding: 376FF2
   Coding: 212F00
   Coding: 7F04020201
                    Reset counter: 112
                    Mileage: 121011 km
                    Date: 2025.04.02
                    Time: 09:09:33
                    Control Module temperature: 23  C
                    Voltage terminal 15: 14.503 V
                    Velocity_vehicle_reference: 10.86 m/s
                    Longitudinal_acceleration_vehicle_reference: 5.30 m/s
   Coding: 212F00
   ROD: EV_BC7.rod
0028 - Function Restriction due to Faults in Other Modules
          [ESP_ESP_01_Signal_Error]
                    Reset counter: 112
                    Mileage: 121011 km
                    Date: 2025.04.02
                    Time: 09:09:33
                    Outside temperature: 13.5  C
                    Voltage terminal 15: 14.6 V
                    Control Module temperature: 23.0  C
   ROD: EV_RGS_L.rod
   ROD: EV_RGS_R.rod
End----------(Elapsed Time: 03:44, VBatt start/end: 14.6V/14.6V)-----------
------------------------------18 Faults Found------------------------------
So does this tell us something? I'm kind of frightened to take the car to Audi because they'll likely just want to rip everything out and replace it all.
Ziddywerks
Northern NJ USA
C?ID=208579
Why make another thread for the same issue? Why not include all this in the current thread you already have made on this problem? Possible to merge threads @Uwe?
  • Agree
horrgakx
C?ID=610814
Yeh good point, never thought of that. I could re-post in that thread if this one can be deleted?
horrgakx
C?ID=610814
Does anyone know of a specialist in the UK (North West) who could diagnose this for me? I tried a Google search for diagnostic companies and called one but basically they just read fault codes and aren't interested in actually looking for a root cause if there's no warning light on. I have reservations about taking it to my local Audi dealer.
