Chugging FSI 2.0L
richfoub
New Zealand
Hi, new to this forum. I have a 2004 VW Golf GT, with the 2.0L FSI engine. Was running great before Xmas last year when suddenly it started to chug at idle, the whole engine shakes rhythmically. You can see and hear the throttle body flap opening and closing slightly, which as far as I can tell, is what's causing it to not idle properly.
First place I took it said the two engine breather hoses were leaking. They were, so I replaced them. Still chugging.
Then I replaced the cambelt, primarily as the water pump was leaking and I thought while everything is apart I might as well, didn't make any difference to how the car idled.
Then we had it into the local stealership who diagnosed a problem with the timing chain, tensioner or camshaft adjuster unit. Apparently when they turned it over by hand they noticed a fault with the adjuster unit.
I've replaced all of those parts with new and, a new set of coils as it suddenly had two misfires. After all that I'm back where I started with the engine continuing to chug at idle.
The faults it's throwing up now are "map controlled engine cooling thermostat -F265, Short circuit to B+Upper limit exceeded and 17748 Active/static camshaft position sensor -G40, engine speed sensor -G28, incorrect allocation - upper limit exceeded.
Should I swap these parts for new, pretty much impossible to test as far as I can see.
This morning when I started it from cold it actually ran ok for about 20 seconds before reverting to the usual idle problem. I've read the 1.8s have an oil pickup problem, I'm wondering if there might be sludge in the pan that takes a few seconds to get sucked up and kicks off the idle problem??
richfoub
New Zealand
Headed over the a new friend near where I live, he was super helpful and ran the car thru his VCDS, below is the first scan followed by the second after he reset a few things
Friday,21,March,2025,10:17:00:05534
VCDS Version: 25.3.0.4 (x64)
Data version: 20250311 DS365.0
VIN: WVWZZZ1KZ5U005405   License Plate: GJC448
Mileage: 163990km-101898mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 37 42 44 46 52 56 62 72
VIN: WVWZZZ1KZ5U005405   Mileage: 163990km-101898miles
37-Navigation -- Status: Cannot be reached 1100
   Part No SW: 06F 906 056 DH    HW: Hardware No
   Component: MED9.5.10       G00 7000
   Revision: 00000000    Serial number: VWZ7Z0D0327513
   Coding: 0000075
   Shop #: WSC 00046 412 00000
   VCID: 72EB88E36DBABF0BC1-8026
   VINID: 9E69EAAAA05BA85940005100148C9BD924
   Subsystem 1 - Part No: 06F 907 807 D
   Component: NOX  0407160016 006 4109
   06F907807D  NOX  0407160016 006 4109
17701 - Map Controlled Engine Cooling Thermostat (F265)
            P1293 - 001 - Short to Plus - MIL ON
17748 - Camshaft Position Sensor (G40) / Engine Speed Sensor (G28)
            P1340 - 001 - Incor. Correlation - Intermittent - MIL ON
18711 - Leak in Air Intake System
            P2279 - 008 -  - Intermittent
17936 - Camshaft Timing Adj. Bank1 (N205)
            P1528 - 004 - Open Circuit - Intermittent - MIL ON
17808 - EGR Valve (N18)
            P1400 - 001 - Electrical Malfunction
Readiness: 0000 0100
   Part No: 09G 927 750 EF
   Component: AQ 250 6F           0618
   Coding: 0000008
   VCID: 79F9BFCF30CCCC5380-802C
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.clb
   Part No: 1K0 907 379 M
   Component: ESP FRONT MK60      0105
   Coding: 0021122
   VCID: 3C7766DB7F7E397BDB-8068
   Part No: 1K0 907 044 AB
   Component: ClimatronicPQ35 066 0404
   VCID: 67DDE9B756784AA366-8032
01810 - Actuating Motor for Temperature Flap; Right (V159)
00926 - Terminal 30
   Part No SW: 1K0 937 049 T    HW: 1K0 937 049 T*
   Component: Bordnetz-SG 1.0 H30 0704
   Revision: 00030000    Serial number: 00000000776081
   Coding: E58D0F0600041800001400001400000000
   VCID: 408F122B13965D9B87-8014
   Subsystem 1 - Part No: 1K2 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer VW350  012  0401
   Coding: 00049109
   Subsystem 2 - Part No: 1K0 955 559 M  Labels: 1K0-955-559-AF.CLB
   Component: RegenLichtSens 005  0605
   Coding: 00217125
02385 - Rain / Light Recognition Sensor Function Restricted due to Under-Voltage
01049 - Supply Voltage Term 50
            006 - Short to Plus - Intermittent
   Part No SW: 1K0 909 605 F    HW: 1K0 909 605 F
   Component: 02 AIRBAG VW8R  023 5600
   Revision: 07023000    Serial number: 0037RD04E6B%
   Coding: 0012338
   VCID: 2F6D4197BE08D2E36E-807A
   Subsystem 1 - Serial number: 6332MSME044B3C76I
   Subsystem 2 - Serial number: 6342MSME041E181EF
   Subsystem 3 - Serial number: 6351HSME00324601Q
   Subsystem 4 - Serial number: 6361HSME02460B24/
01217 - Side Airbag Igniter; Driver Side (N199)
            001 - Upper Limit Exceeded - Intermittent - MIL ON
            002 - Lower Limit Exceeded - Intermittent - MIL ON
   Part No SW: 1K0 953 549 A    HW: 1K0 953 549 A
   Component: Lenksäulenmodul 012 0030
   Coding: 0010042
   VCID: 306F42EBA336CD1B77-8064
   Part No: 1K0 920 871 A
   Component: KOMBIINSTRUMENT VDD 0812
   Coding: 0003503
   Shop #: WSC 86784 311 715944
   VCID: 285FAA8B9BE685DBAF-807C
   Part No SW: 1K0 907 530 E    HW: 1K0 907 951
   Component: Gateway         H09 0110
   Revision: 09          Serial number: 2700104606029A
   Coding: 3F3F0348070003
   VCID: 2959AF8F80ECBCD3B0-807C
                    Reset counter: 122
                    Mileage: 163945 km
                    Time: 23:37:29
                    Reset counter: 122
                    Mileage: 163945 km
                    Time: 23:37:32
01304 - Radio
                    Reset counter: 122
                    Mileage: 163945 km
                    Time: 23:37:32
   Component: IMMO            VDD 0812
01176 - Key
Address 37: Navigation
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX1.lbl
   Part No: 1K0 959 701 G
   Component: Tuersteuergeraet 09 0148
   Coding: 0000054
   VCID: 326B48E3AD3AFF0B01-8066
00131 - Outside Door Handle Illumination/mirror Light Driver Side
   Part No: 1K2 909 144 G
   Component: EPS_ZFLS Kl.0       1301
                    Temperature: 26.0°C
                    Voltage: 4.40 V
                    Voltage: 5.20 V
   Part No SW: 1K0 959 433 L    HW: 1K0 959 433 L
   Component: 01 KSG PQ35 G2  032 0308
   Revision: 00032000    Serial number: 00000000000000
   Coding: 80C802087F2D8404085F01E000
   VCID: 39797FCF704C0C53C0-806C
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX1.lbl
   Part No: 1K0 959 702 G
   Coding: 0000054
   VCID: 33654DE75220F6030A-8066
00097 - Front Passengers Central Locking (Safe) Motor (V162)
Address 56: Radio
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN1.lbl
   Part No: 1K0 959 703 C
   Component: Tuersteuergeraet 06 0213
   Coding: 0000016
01813 - Supply Voltage for Door Controller; Rear Left (J388)
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN1.lbl
   Part No: 1K0 959 704 C
   Coding: 0000016
   VCID: 316947EFA83CC41378-8064
01814 - Supply Voltage for Door Controller; Rear Right (J389)
End-------------------------(Elapsed Time: 01:53)--------------------------
------------------------------29 Faults Found------------------------------
Second scan
Friday,21,March,2025,10:55:44:05534
VIN: WVWZZZ1KZ5U005405   License Plate: GJC4482
   Coding: 0000075
Readiness: 1010 0001
   Coding: 0000008
   Coding: 0021122
   Coding: 00049109
   Coding: 00217125
   Coding: 0012338
   Coding: 0010042
   Coding: 0003503
                    Reset counter: 123
                    Mileage: 163999 km
                    Time: 23:06:30
                    Reset counter: 123
                    Mileage: 163999 km
                    Time: 23:06:34
01304 - Radio
                    Reset counter: 123
                    Mileage: 163999 km
                    Time: 23:06:34
   Coding: 0000054
   Coding: 0000054
Address 56: Radio
   Coding: 0000016
   Coding: 0000016
End-------------------------(Elapsed Time: 01:51)--------------------------
------------------------------6 Faults Found-------------------------------
Check timing, and then check compression.
