After a team effort the Security Access code is: S11820
The next version of VCDS will have that code shown in a help balloon.
This has not worked, I still get the error when this code has been put in and trying to calibrate the synchro pointsAfter a team effort the Security Access code is: S11820
Are you entering it exactly has Dana has posted it, including the leading 'S' ?This has not worked, I still get the error when this code has been put in and trying to calibrate the synchro points
Yes I've done that, then moving to calibration of synchro points leads to the error out of range.OK. Are these the instructions and prerequisites you are following?
Yes, copied and pasted into vcdsAre you entering it exactly has Dana has posted it, including the leading 'S' ?
Just to check - do you mean the error code has changed?Yes I've done that, then moving to calibration of synchro points leads to the error out of range.
Id rather use the conventional ways as described in the ross tech forumsHello
Performing any adaptions without regular werkshopcode, will that work?
Part No SW: 0BH 300 012 S HW: 0BH 927 711 G
Component: DSG DQ500-7A H11 5201
Revision: 00H11V01 CVN: 2AB76A05
OK, that procedure involving [*IDE02903*] Basic setting of transmission is the only tested procedure we have to offer.Yes I've done that, then moving to calibration of synchro points leads to the error out of range.
Would be nice if we knew exactly what ODIS did.odis reset the transmission as needed and issue is gone.
