Error: service not supported in active session
stephen1998
C?ID=610426 (NAC)
Hi everyone,
I'm a new user, I've tried to calibrate the synchro points on my audi rsq3 and this error has come up. I can bassic reset the transmission but not the synchro points. Can anyone shed any light on why this is coming up.
stephen1998
C?ID=610426 (NAC)
Yes I have vcds. I'll scan it tomorrow. But that's not the issue, there are no faults on the transmission, but I cannot calibrate the synchro points.
OK, but we'll still need too see all the details of the transmission in order have an understanding what might be going on here.
stephen1998
C?ID=610426 (NAC)
Wednesday,19,March,2025,09:26:23:38746
VCDS Version: 25.3.0.4 (x64)  HEX-V2 CB: 0.4660.5
Data version: 20250311 DS365.0
VIN: WUAZZZ8U5GR901110   License Plate: V20STE
Mileage: 97120km-60347mi   Repair Order:
Chassis Type: 8U-AU21 (8U0)
Scan: 01 02 03 08 09 10 14 15 16 17 19 22 25 42 44 46 52 55 56 5F
          62 6C 6D 72 A5
VIN: WUAZZZ8U5GR901110   Mileage: 97120km-60347miles
04-Steering Angle -- Status: Sporadic communication error 1000
17-Instruments -- Status: Malfunction 1010
25-Immobilizer -- Status: Malfunction 1010
44-Steering Assist -- Status: Sporadic communication error 1000
Address 01: Engine (------CZGA)       Labels:. 07K-907-309-V1.clb
   Part No SW: 8U0 907 404 B    HW: 07K 907 309 D
   Component: 2.5l R5/4V TF H54 0005
   Revision: NIH54---    CVN: DAE38E1F
   Coding: 32250032252601032620
   Shop #: WSC 00049 770 00119
   ASAM Dataset: EV_ECM25TFS0118U0907404B 001006
   ROD: EV_ECM25TFS0118U0907404B.rod
   VCID: 372CF412CFC4F1127ED-8062
   VINID: 9E546AAAA225157889001041007619138E
7249 - No Communications with Steering Angle Sender (G85)
          U0126 00 [00100000] - -
                    Mileage: 96744 km
                    Date: 2025.03.10
                    Time: 08:20:07
                    Engine speed: 0.00 /min
                    Coolant temperature: 5 °C
                    Intake air temperature: 6 °C
                    Voltage terminal 30: 11.680 V
                    Unlearning counter according OBD: 23
                    selected gear-Bits 0-7: 0
                    Cruise control switch actuation-Bits 0-7: 0
                    Cruise control switch actuation-Bits 0-7: 1
4729 - Steering Effort Control Module
          U0130 00 [00100000] - No Communications
                    Mileage: 96744 km
                    Date: 2025.03.10
                    Time: 08:20:07
   Part No SW: 0BH 300 012 S    HW: 0BH 927 711 G
   Component: DSG DQ500-7A  H11 5201
   Revision: 00H11V01    CVN: 2AB76A05
   ROD: EV_TCMDQ500021.rod
   VCID: 3334C002DBBC1D32425-8066
Address 03: ABS Brakes (J104)       Labels: 5N0-614-109-V1.clb
   Part No SW: 8U0 614 109 H    HW: 8U0 614 109 G
   Component: ESC-EBC460iV1 H10 0513
   Serial number: A00VF8L
   Coding: 21F124A1EC20E36D2078840124C337C704364700508B4881
   Shop #: WSC 00049 770 00151
   ASAM Dataset: EV_Brake1ESCEPBTRW 006353
   ROD: EV_Brake1ESCEPBTRW_006.rod
   VCID: 3A2AED26FCD6EC7A813-806E
0286 - Databus
          [MSG_LW_1_TIMEOUT]
                    Reset counter: 17
                    Mileage: 96744 km
                    Additional_Codes: 00 00 00 0B 58 7F 00 0F 0A
                    DTC: 00 01 1E
                    Additional2: 00 00 00 05 05 00 46 00 46 00
0533 - Databus
          [MSG_LENKHILFE_3_TIMEOUT]
                    Reset counter: 17
                    Mileage: 96744 km
                    Additional_Codes: 00 00 00 0B A3 7F 00 0F 0A
                    DTC: 00 02 15
                    Additional2: 00 01 00 05 05 00 46 00 46 00
0799 - Databus
          [MSG_LH3_LM_INVALID]
                    Reset counter: 21
                    Mileage: 95999 km
                    Date: 2025.03.05
                    Time: 20:19:16
                    Additional_Codes: 00 00 00 09 C2 7F 40 08 0A
                    DTC: 00 03 1F
                    Additional2: 02 03 00 05 05 00 32 00 32 00
   Part No SW: 8U0 820 043 G    HW: 8U0 820 043 G
   Component: E87  Klimavoll      0210
   Revision: 00H05000    Serial number: 8U0820043G
   VCID: 3530FE1AD94803026C1-8060
   Part No SW: 8X0 907 063 AK    HW: 8X0 907 063 AB
   Component: BCM PQ35  M   113 0827
   Revision: AC113817
   Coding: 0E000A2CA805F1C0201849C82184014C53F327AA016F812BE408878400C5
   Shop #: WSC 22859 002 1048576
   VCID: 05504EDAC5285382BC1-8050
   Subsystem 1 - Part No SW: 8U2 955 119     HW: 8U2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS316 150629  H38 0090
   Serial number:         150731025411
   Coding: 0047F7
   Serial number: 20778037
   Coding: 02006E
   Subsystem 3 - Part No: 8X0 951 177 A
   Component: Sensor, DWA 0  005 0002
                    Reset counter: 17
                    Mileage: 96744 km
                    Date: 2025.03.10
                    Time: 08:20:09
                    Voltage: 11.25 V
                        Term 50 On
                    Reset counter: 17
                    Mileage: 96744 km
                    Date: 2025.03.10
                    Time: 08:20:09
                    Voltage: 11.25 V
                        Term 50 On
Address 10: Park/Steer Assist (J446)       Labels:| 8X0-919-475.clb
   Part No SW: 8X0 919 475 AD    HW: 4H0 919 475 AG
   Component: PARKHILFE 8K  H01 0070
   Revision: 11001001    Serial number: 61031529305230
   Coding: A8C30B
   ASAM Dataset: EV_EPHVA18AU21X0000 003008
   ROD: EV_EPHVA18AU21X0000_003.rod
   VCID: 084E47EEF2BA4EEAC77-805C
13638929 - Databus
          [Steuergerät für Lenkhilfe-J500 - mLenkhilfe_3 - kein Signal/keine Kommunikation]
                    Reset counter: 17
Address 14: Susp. Elect. (J250)       Labels: None
   Part No SW: 5N0 907 376     HW: 5N0 907 376
   Component: DAEMPFUNGS-SG H07 0071
   Revision: 00000000    Serial number: 09061502600001
   Coding: 010180
   Shop #: WSC 00049 770 00132
   VCID: 73B400029BBC5D32825-8026
                    Reset counter: 17
                    Mileage: 96744 km
                    Date: 2025.03.10
                    Time: 08:20:09
                    Bin. Bits: 00000000 00000000
                    Bin. Bits: 00000000 00000001
   Part No SW: 8U0 959 655 D    HW: 8U0 959 655 D
   Component: AirbagVW-AU10 H10 0910
   Serial number: 003S0R0CRS3%   Dataset Number: 8U0909602C  0007
   Coding: 31353232343030303030554A305238553053
   ASAM Dataset: EV_AirbaAU10SMEAU316 001010
   ROD: EV_AirbaAU10SMEAU316_001.rod
   VCID: 48CE87EEB23A8EEA077-801C
   Subsystem 1 - Part No SW: 5K0 959 351 A    HW: 5K0 959 351 A
   Serial number: 3496KSME261D093AZZZ/
   Subsystem 2 - Part No SW: 5K0 959 351 A    HW: 5K0 959 351 A
   Serial number: 3506KSME06026939ZZZN
   Serial number: 3516KSME3326093AZZZP
   Serial number: 3526KSME1C3B093AZZZ$
   Subsystem 5 - Part No SW: 8U0 959 651     HW: 8U0 959 651
   Serial number: 3555USME576D453AZZZC
12658176 - No Communications with Steering Angle Sender (G85)
          U0126 00 [00001000] - -
          [Steer Angle Control Unit no signal/communication]
                    Reset counter: 17
                    Mileage: 96744 km
                    Date: 2025.03.10
                    Time: 08:20:09
   Part No SW: 5K0 953 569 AL    HW: 5K0 953 569 AL
   Revision: --X01---    Serial number: 20220921100205
   Coding: 3894204000
   Shop #: WSC 14297 006 1048576
   ASAM Dataset: EV_SMLSNGVOLWS A01004
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 025A55C6D48664BA993-8056
   Subsystem 1 - Part No SW: 8U0 951 528 H    HW: 8U0 951 528 H
   Serial number: 24 09 2015  F0068325
Address 17: Instruments (J285)       Labels:| 8X0-920-KOM-V1.clb-SRI1
   Part No SW: 8U0 920 990 J    HW: 8U0 920 990 J
   Component: KOMBI_COLOUR  H01 0370
   Coding: 44CF45
   ASAM Dataset: EV_Kombi_UDS_VDD_AU10 A04399
   VCID: 44D693DE8E12AA8AEBF-8010
7 Faults Found:
9453074 - Fuel Level Sensor 1
          B103E 1B [00001000] - Resistance Too High
9459739 - Fuel Level Sensor 2
          B1058 1B [00001000] - Resistance Too High
9453330 - Outside temperature sensor
          B103F 1B [00001000] - Resistance Too High
9453842 - Oil Level Thermal Sensor
          B1041 35 [00001000] - Signal High Time > Maximum
                    Reset counter: 20
12604672 - Combination / Chassis CAN Bus (SAE Bus D)
          U0055 00 [00001000] - Malfunction
          [Datenbus Kombi/Fahrwerk defekt]
12604928 - Combination / Chassis CAN Bus (SAE Bus D)
          U0056 00 [00001000] - Performance
          [Datenbus Kombi/Fahrwerk: keine Kommunikation]
                    Reset counter: 20
13638912 - Function Restricted due to Missing Message(s)
          U1111 00 [00001000] - -
          [Steuergerät für Lenkhilfe: keine Kommunikation]
                    Reset counter: 17
                    Mileage: 96744 km
                    Date: 2025.03.10
                    Time: 08:20:09
Address 19: CAN Gateway (J533)       Labels:. 8X0-907-468.clb
   Part No SW: 8U0 907 468 BA    HW: 8U0 907 468 L
   Component: GAT 5CAN 2L M H13 0090
   Revision: 1U190041    Serial number: 4141U15A160996
   Coding: FBCF1060000108610353
   Shop #: WSC 51368 002 1048576
   VCID: 025A55C6D40664BA993-8056
   Subsystem 1 - Part No SW: 8U0 915 181 A    HW: 8U0 915 181 A
   Component: J367-BDM  H08 0190
   Serial number: 62264218302981678713
   Serial number: 15288000818011200181
                    Reset counter: 29
                    Mileage: 95989 km
                    Date: 2025.03.02
                    Time: 22:37:01
                    Bin. Bits:    00000
                    Voltage: 12.00 V
                    Count: 19
                    Reset counter: 17
                    Mileage: 96744 km
                    Date: 2025.03.10
                    Time: 08:20:08
                    Bin. Bits:    10111
                    Voltage: 11.50 V
                    Count: 6
                    Bin. Bits:    10000
                    Time: 0.40 s
                    Reset counter: 17
                    Mileage: 96744 km
                    Date: 2025.03.10
                    Time: 08:20:08
                    Bin. Bits:    10111
                    Voltage: 11.50 V
                    Count: 6
                    Bin. Bits:    10000
                    Time: 0.40 s
                    Reset counter: 20
                    Mileage: 96810 km
                    Date: 2025.03.10
                    Time: 15:17:56
                    Bin. Bits:    10000
                    Voltage: 11.60 V
                    Count: 11
                    Bin. Bits:    10000
                    Time: 4.20 s
                    Reset counter: 20
                    Mileage: 96810 km
                    Date: 2025.03.10
                    Time: 15:17:56
                    Bin. Bits:    10000
                    Voltage: 11.60 V
                    Count: 11
                    Bin. Bits:    10000
                    Time: 5.10 s
00384 - Optical Databus
                    Fault Status: 00101011
                    Reset counter: 24
                    Mileage: 96877 km
                    Date: 2025.03.13
                    Time: 12:34:11
                    Bin. Bits:    00000
                    Voltage: 11.90 V
                    Count: 11
                    Bin. Bits:    00000
   Part No SW: 0AY 907 554 M    HW: 0CQ 525 130
   Component: Haldex4Motion H52 7542
   Serial number: HA1-00006.07.15 Dataset Number: v1260x015G0 0000
   Coding: 0001
   ROD: EV_AllWheelContrHA1VW37X_002_VW36.rod
   VCID: 55F05E9A758823028C1-8000
16653 - Databus
          [Lenkwinkelsensor -TO -- LWL_01]
                    Reset counter: 17
                    Mileage: 96744 km
                    Date: 2025.03.10
                    Time: 08:20:07
   Component: IMMO          H01 0370
   Coding: 000002
   ROD: EV_Immo_UDS_VDD_AU10.rod
   Part No SW: 8X0 959 793 H    HW: 8X0 959 793 H
   Component: TSG FA        H11 0415
   Coding: 011E06205C01000000
   Shop #: WSC 12345 123 61029
   VCID: 52FAA58644E6343A693-8006
   Part No: 5N0 909 144 R
   Component: EPS_ZFLS Kl. 301    3501
   Revision: 00H22000
   VCID: 40DE9FCE968AB6AACF7-8014
   Part No SW: 8X0 959 792 H    HW: 8X0 959 792 H
   Component: TSG BF        H11 0415
   Coding: 011E06205E01000000
   VCID: 51F8AA8A41E04F22509-8004
Address 55: Headlight Range (J745)       Labels:| 5M0-907-357-V3.clb
   Part No SW: 5M0 907 357 G    HW: 7P6 907 357 B
   Component: AFS-ECU       H01 0031
   Revision: --------    Serial number: -------------- Dataset Number: 8U1909865A  0005
   Coding: 08A602102B230200
   ASAM Dataset: EV_HeadlRegulLEDAFSPt 001001
   ROD: EV_HeadlRegulLEDAFSPt_AU21.rod
   VCID: 382EF72EC2DAFE6A777-806C
   Subsystem 1 - Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
   Component: LED LeiMo li.  H09 0003
   Coding: E02500
   Subsystem 2 - Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
   Component: LED LeiMo re.  H09 0003
   Coding: E02500
   Subsystem 3 - Part No SW: 7PP 941 329 M    HW: 7PP 941 329 M  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 7050
   Coding: E02500
   Subsystem 4 - Part No SW: 7PP 941 329 M    HW: 7PP 941 329 M  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 7050
   Coding: E02500
13705474 - Databus
          [Timeout mLW_1]
                    Reset counter: 17
                    Mileage: 96744 km
                    Date: 2025.03.10
                    Time: 08:20:09
   Part No SW: 4G0 035 061 Q    HW: 4G0 035 061
   Component: Radio U DAB   H60 0150
   Revision: AB001007    Serial number: 109J/0F2509832
   Coding: 010105020100000002
   VCID: 2B04D862030C45F20A5-807E
   Part No SW: 8U1 035 670 B    HW: 8U1 035 670
   Component: H-BNT-EU      H41 0947
   Revision: --------    Serial number: 486J+0FB001235
   Coding: 21010106030AE0EB0DA0433600000001080000000000000000
   VCID: 3530FE1AD54803026C1-8060
   Subsystem 1 - Part No: 8R0 060 884 DF
   Component: EUR 2016  2204
   Subsystem 2 - Part No SW: 8U0 919 604 A    HW: 8U0 919 604 A
   Component: DU High AU316  H43 0018
   Serial number: AUZ8ZDFCR005LMI
   Subsystem 3 - Part No: 8R0 060 961 G
   Component: CD-Database  6890
                    Reset counter: 24
                    Mileage: 96877 km
                    Date: 2025.03.13
                    Time: 13:15:11
                    Voltage: 11.90 V
00658 - Control Head
                    Fault Frequency: 79
                    Reset counter: 36
                    Time Indication: 15
                    Voltage: 12.10 V
                    Fault Status: 00101100
                    Reset counter: 24
                    Mileage: 96877 km
                    Date: 2025.03.13
                    Time: 13:15:11
                    Voltage: 11.90 V
                    Bin. Bits:      011
02244 - Button in Control Head is Stuck
                    Reset counter: 35
                    Mileage: 96976 km
                    Date: 2025.03.15
                    Time: 12:48:15
                    Voltage: 13.00 V
                    Hex Value: 0x0006
                        not available
Address 62: Door, Rear Left (J388)       Labels:. 8X0-959-795.clb
   Part No SW: 8X0 959 795 C    HW: 8X0 959 795 C
   Component: TSG HL        H08 0415
   Coding: 010E06200001000000
   VCID: 4FFCACF257D459D246D-801A
Address 6C: Back-up Cam.        Labels: 4H0-907-441.clb
   Part No SW: 8U0 907 441     HW: 8U0 907 441
   Component: SG Rueckfahrkamera  0031
   Revision: --H09---    Serial number: 525 PA8JA8H26S
   Coding: 1080015
   Shop #: WSC 02391 785 00012
   VCID: 76B2391684CE481AA5B-8022
                    Reset counter: 17
                    Mileage: 96744 km
                    Date: 2025.03.10
                    Time: 08:20:08
                        Reverse OFF
                    Count: 3
   Part No SW: 8U0 959 107     HW: 8U0 959 107
   Component: HDSG-Modul    H01 0549
   Revision: 15001001    Serial number: 277500047 Dataset Number: 8U0909541A  0007
   Coding: 183307C002
   ASAM Dataset: EV_HDSGAU316 001001
   ROD: EV_HDSGAU316.rod
   VCID: 7CA62B3EB662124AD3F-8028
Address 72: Door, Rear Right (J389)       Labels:. 8X0-959-795.clb
   Component: TSG HR        H08 0415
Address A5: Frt Sens. Drv. Assist (R242)       Labels:| 3AA-980-654.clb
   Part No SW: 3AA 980 654 E    HW: 3AA 980 654 A
   Component: MFK_Gen1      H09 0302
   Serial number: 0367770076 Dataset Number: 8U0909466D  0029
   Coding: 01010100010102050100050000000100
   ASAM Dataset: EV_47X 001639
   ROD: EV_47X.rod
2228224 - Databus
          [ERR_CAN_MLENKHILFE_2_TIMEOUT]
                    Reset counter: 17
                    Mileage: 96744 km
                    Date: 2025.03.10
                    Time: 08:20:09
2293760 - Databus
          [ERR_CAN_MLENKHILFE_3_TIMEOUT]
                    Reset counter: 17
                    Mileage: 96744 km
                    Date: 2025.03.10
                    Time: 08:20:09
2359296 - Databus
          [ERR_CAN_MLW_1_TIMEOUT]
                    Reset counter: 17
                    Mileage: 96744 km
                    Date: 2025.03.10
                    Time: 08:20:09
5570560 - Windscreen Heater for Front Sensors
          B11CE 15 [00001001] - Open or Short to Plus
                    Reset counter: 227
                    Mileage: 95989 km
                    Date: 2025.03.02
                    Time: 15:23:42
End----(Elapsed Time: 01:51, VBatt start/end: 11.7V/11.6V. VIgn 11.5V)-----
------------------------------35 Faults Found------------------------------
grant@gendan
Looking at the scan, you have ABS faults which may prevent the Transmission calibration.
Is there a history to this car? There are lots of CAN communication errors. Is it a crash repair?
Try fixing the G85 (Steering Angle Sender) fault and then see which faults persist.
Westbury, UK
Many of the faults are intermittent, I think a Clear All Faults could be helpful followed by a new Auto-Scan.
stephen1998
C?ID=610426 (NAC)
          62 6C 6D 72 A5
                    Mileage: 96744 km
                    Date: 2025.03.10
                    Time: 08:20:07
                    Mileage: 96744 km
                    Date: 2025.03.10
                    Time: 08:20:07
0286 - Databus
          [MSG_LW_1_TIMEOUT]
                    Reset counter: 17
                    Mileage: 96744 km
                    DTC: 00 01 1E
0533 - Databus
                    Reset counter: 17
                    Mileage: 96744 km
                    DTC: 00 02 15
0799 - Databus
                    Reset counter: 21
                    Mileage: 95999 km
                    Date: 2025.03.05
                    Time: 20:19:16
                    DTC: 00 03 1F
   Revision: AC113817
   Coding: 0047F7
   Coding: 02006E
                    Reset counter: 17
                    Mileage: 96744 km
                    Date: 2025.03.10
                    Time: 08:20:09
                    Voltage: 11.25 V
                        Term 50 On
                    Reset counter: 17
                    Mileage: 96744 km
                    Date: 2025.03.10
                    Time: 08:20:09
                    Voltage: 11.25 V
                        Term 50 On
   Coding: A8C30B
13638929 - Databus
                    Reset counter: 17
   Coding: 010180
                    Reset counter: 17
                    Mileage: 96744 km
                    Date: 2025.03.10
                    Time: 08:20:09
                    Reset counter: 17
                    Mileage: 96744 km
                    Date: 2025.03.10
                    Time: 08:20:09
   Coding: 3894204000
   Coding: 44CF45
7 Faults Found:
                    Reset counter: 20
                    Reset counter: 20
                    Reset counter: 17
                    Mileage: 96744 km
                    Date: 2025.03.10
                    Time: 08:20:09
                    Reset counter: 29
                    Mileage: 95989 km
                    Date: 2025.03.02
                    Time: 22:37:01
                    Bin. Bits:    00000
                    Voltage: 12.00 V
                    Count: 19
                    Reset counter: 17
                    Mileage: 96744 km
                    Date: 2025.03.10
                    Time: 08:20:08
                    Bin. Bits:    10111
                    Voltage: 11.50 V
                    Count: 6
                    Bin. Bits:    10000
                    Time: 0.40 s
                    Reset counter: 17
                    Mileage: 96744 km
                    Date: 2025.03.10
                    Time: 08:20:08
                    Bin. Bits:    10111
                    Voltage: 11.50 V
                    Count: 6
                    Bin. Bits:    10000
                    Time: 0.40 s
                    Reset counter: 20
                    Mileage: 96810 km
                    Date: 2025.03.10
                    Time: 15:17:56
                    Bin. Bits:    10000
                    Voltage: 11.60 V
                    Count: 11
                    Bin. Bits:    10000
                    Time: 4.20 s
                    Reset counter: 20
                    Mileage: 96810 km
                    Date: 2025.03.10
                    Time: 15:17:56
                    Bin. Bits:    10000
                    Voltage: 11.60 V
                    Count: 11
                    Bin. Bits:    10000
                    Time: 5.10 s
                    Reset counter: 24
                    Mileage: 96877 km
                    Date: 2025.03.13
                    Time: 12:34:11
                    Bin. Bits:    00000
                    Voltage: 11.90 V
                    Count: 11
                    Bin. Bits:    00000
   Coding: 0001
16653 - Databus
                    Reset counter: 17
                    Mileage: 96744 km
                    Date: 2025.03.10
                    Time: 08:20:07
   Coding: 000002
   Revision: 00H22000
   Coding: E02500
   Coding: E02500
   Coding: E02500
   Coding: E02500
13705474 - Databus
          [Timeout mLW_1]
                    Reset counter: 17
                    Mileage: 96744 km
                    Date: 2025.03.10
                    Time: 08:20:09
                    Reset counter: 24
                    Mileage: 96877 km
                    Date: 2025.03.13
                    Time: 13:15:11
                    Voltage: 11.90 V
                    Fault Frequency: 79
                    Reset counter: 36
                    Time Indication: 15
                    Voltage: 12.10 V
                    Reset counter: 24
                    Mileage: 96877 km
                    Date: 2025.03.13
                    Time: 13:15:11
                    Voltage: 11.90 V
                    Bin. Bits:      011
                    Reset counter: 35
                    Mileage: 96976 km
                    Date: 2025.03.15
                    Time: 12:48:15
                    Voltage: 13.00 V
                    Hex Value: 0x0006
                        not available
   Coding: 1080015
                    Reset counter: 17
                    Mileage: 96744 km
                    Date: 2025.03.10
                    Time: 08:20:08
                        Reverse OFF
                    Count: 3
   Coding: 183307C002
   ROD: EV_47X.rod
2228224 - Databus
                    Reset counter: 17
                    Mileage: 96744 km
                    Date: 2025.03.10
                    Time: 08:20:09
2293760 - Databus
                    Reset counter: 17
                    Mileage: 96744 km
                    Date: 2025.03.10
                    Time: 08:20:09
2359296 - Databus
                    Reset counter: 17
                    Mileage: 96744 km
                    Date: 2025.03.10
                    Time: 08:20:09
                    Reset counter: 227
                    Mileage: 95989 km
                    Date: 2025.03.02
                    Time: 15:23:42
Wednesday,19,March,2025,11:21:28:38746
          62 6C 6D 72 A5
Readiness: 1110 0001
   Shop #: WSC 54321 321 54321
   Revision: AC113817
   Coding: 0047F7
   Coding: 02006E
   Coding: A8C30B
   Coding: 010180
   Coding: 3894204000
   Coding: 44CF45
   Coding: 0001
   Coding: 000002
   Revision: 00H22000
   Coding: E02500
   Coding: E02500
   Coding: E02500
   Coding: E02500
   Coding: 1080015
   Coding: 183307C002
   ROD: EV_47X.rod
2228224 - Databus
                    Reset counter: 17
                    Mileage: 96744 km
                    Date: 2025.03.10
                    Time: 08:20:09
2293760 - Databus
                    Reset counter: 17
                    Mileage: 96744 km
                    Date: 2025.03.10
                    Time: 08:20:09
2359296 - Databus
                    Reset counter: 17
                    Mileage: 96744 km
                    Date: 2025.03.10
                    Time: 08:20:09
                    Reset counter: 227
                    Mileage: 95989 km
                    Date: 2025.03.02
                    Time: 15:23:42
End----------(Elapsed Time: 01:41, VBatt start/end: 15.0V/15.0V)-----------
------------------------------4 Faults Found-------------------------------
stephen1998
C?ID=610426 (NAC)
All done, with the fault codes gone it still will not carry out calibration of synchro points.
stephen1998
C?ID=610426 (NAC)
I think it needs a security access code to calibrate the trans. Does anyone know what this is?
Mike@Gendan
Swansea, UK
C?ID=57030
It's been cleared and I have re tried the calibration with no success
It looks like you've not driven the car since the codes were cleared:
If you drive it, what codes come back?
stephen1998
C?ID=610426 (NAC)
62 6C 6D 72 A5
Readiness: 0010 0001
Coding: A8C30B
Coding: 010180
Coding: 3894204000
Coding: 44CF45
Coding: 0001
Coding: 000002
Revision: 00H22000
Address 46: Central Conv.
Coding: E02500
Coding: E02500
Coding: E02500
Coding: E02500
Reset counter: 37
Mileage: 97126 km
Date: 2025.03.19
Time: 11:36:11
Voltage: 12.10 V
Coding: 1080015
Coding: 183307C002
ROD: EV_47X.rod
Reset counter: 252
Mileage: 97126 km
Date: 2025.03.19
Time: 11:33:30
End----------(Elapsed Time: 02:03, VBatt start/end: 14.9V/14.9V)-----------
------------------------------2 Faults Found-------------------------------
stephen1998
C?ID=610426 (NAC)
it has, I cant attach the image here but the car is currently on 60352 miles but when scanned it shows as 60347. clearly an issue with vcds not updating.
No, it's an issue of the last digit being missing from the channel that VCDS reads to get the mileage from. The value in that channel is 9712 for 97120 km. Drive it a bit more and VCDS will get 9713 for 97130 km. VCDS converts that to miles, so it can be a few miles less than the actual reading.
stephen1998
C?ID=610426 (NAC)
There we go, as stated, vcds issue
VCDS can only show what the car is willing to tell us. If the car is unwilling to divulge the least significant digit of the mileage, that's an issue with the car, not VCDS. :p
I'm a bit confused with what we have for this one. @Dana ?
