2022 Volkwagen Virtus 1.5 TSI Steering Assist Error
vrpram
India
C?ID=550004
Human curiosity got the best of me. Reset the basic settings of my 44-Steering Assist to factory settings and now I have multiple fault codes in the same. Why I did it? Stupid human curiosity of meddling with things I didn't understand. If someone can shed light on what should be done to rectify this, it would be much appreciated.
Tuesday,18,March,2025,22:16:15:43458
VCDS Version: 25.3.0.4 (x64)  HEX-V2 CB: 0.4660.4
Data version: 20250311 DS365.0
VIN: MEXH22D28NT010227   License Plate: STEER ENG
Mileage: 25045km-15562mi   Repair Order:
Chassis Type: D2-VW27 (2Q0)
Scan: 01 02 03 05 08 09 15 17 19 2B 44 5F
VIN: MEXH22D28NT010227   Mileage: 25045km-15562miles
Address 01: Engine (J623-DUMA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 05E 906 018 DM    HW: 05E 907 309 BC
   Component: R4 1.5l TFS   H80 3846
   Revision: 8EH80000    CVN: 0C5625E4
   Coding: 012500122324090810000000000000000000000000000000
   Shop #: WSC 56880 004 1048576
   ASAM Dataset: EV_ECM15TFS01105E906018DM 004004
   ROD: EV_ECM15TFS01105E906018DM_VW27.rod
   VCID: 73B3CD963B3FB4B2825-8026
   VINID: 755A1808250221E9000400821CE72D8A06
34193 - Implausible Data Received from ESP Control Module
          U0416 00 [00100111] - -
                    Mileage: 25045 km
                    Date: 2025.03.18
                    Time: 22:05:29
                    Engine speed: 923.50 /min
                    Normed load value: 17.3 %
                    Coolant temperature: 102  C
                    Intake air temperature: 39  C
                    Voltage terminal 30: 13.060 V
                    Drive train coordinator irreversible switch off conditions: 0
                    Drive train coordinator reversible switch off conditions: 2147516416
                    Drivetrain coordinator: brake fault status: 4
          U0428 00 [00100111] - -
                    Mileage: 25045 km
                    Date: 2025.03.18
                    Time: 22:05:30
                    Engine speed: 928.50 /min
                    Voltage terminal 30: 13.020 V
                    Outside temperature: 29  C
                    Absolute intake pressure: 27 kPa abs
                    Engine torque: 23.4 Nm
                    Fuel: tank fill level: 24.0 l
                    Oxygen sensor bank 1 sensor 1: specified value: 1.0000
                    Particulate filter: loading stage: 0
                    Overrun cut-off-Bits 0-7: 0
Readiness: 1110 0001
   Part No SW: 0CW 300 020 L    HW: 0AM 927 769 N
   Component: GSG DQ200G2_M H07 2202
   Revision: 00007009    Serial number: CU502205125255 CVN: F001930C
   Shop #: WSC 17734 418 534600
   ROD: EV_TCMDQ200021.rod
   VCID: 3B2325B653EF3CF29A5-806E
   Part No SW: 5QP 614 517     HW: 2Q0 614 517 L
   Component: ESC_base      H13 0201
   Serial number: 36901445220628
   Coding: 3A068B3F5B425CADD1FEDA1852E162A649D4D106336A262424541254454A4665922B8B60CC566424242A482AA231D6431F8C6BC2F84CE47032270E
   Shop #: WSC 00793 648 00200
   ASAM Dataset: EV_Brake1BOSCHESPMQBA0 005001
   ROD: EV_Brake1BOSCHESPMQBA0_005_VW27.rod
   VCID: 0E45BC6230DDF95A0DB-805A
1272 - Tire Pressure Warning
          C102D 00 [10001001] - -
                    Reset counter: 149
                    Mileage: 25045 km
                    Date: 2025.03.18
                    Time: 21:54:52
0266 - Steering angle sensor
          B1168 29 [10001001] - Signal Implausible
                    Reset counter: 149
                    Mileage: 25045 km
                    Date: 2025.03.18
                    Time: 22:05:30
   Part No SW: 3Q0 959 435 Q    HW: 3Q0 959 435 Q
   Component: VWKESSYMQB    037 1400
   Revision: 00037000    Serial number: 0597601346 Dataset Number: V03935342GU 0001
   Coding: 032C0C0723
   ASAM Dataset: EV_KessyHellaMQBAB 004055
   ROD: EV_KessyHellaMQBAB_VW27.rod
   VCID: 48C94A7A1239676A077-801C
Address 08: Auto HVAC (J255)       Labels:* None
   Part No SW: 6JM 907 057 A    HW: 6JM 907 057 A
   Component: Climatronic   035 0207
   Coding: 212100000400003101000401034011050101350000000000000000000000
   ASAM Dataset: EV_ACClimaBHBMQBA0Touch 001003
   ROD: EV_ACClimaBHBMQBA0Touch.rod
   VCID: 4ACD70720C35957A113-801E
   Part No SW: 2Q0 937 089 D    HW: 2Q0 937 089 C
   Component: BCM A0 Std    H12 0954
   Serial number: 014260622A0032 Dataset Number: V03935381DG 0001
   ASAM Dataset: EV_BCMA0 207001
   ROD: EV_BCMA0_207_VW27.rod
   Subsystem 1 - Part No SW: 5Q0 955 559 C    HW: 5Q0 955 559 C  Labels: 5Q0-955-547.CLB
   Component: RLS  054 0206
   Serial number: SBY22M06D23H10M13S48
   Coding: 00184D
   Driver door control module:
   Subsystem 2 - Part No SW: 5QR 959 801 C    HW: 5QR 959 801 A
   Component: FHSG_DRV  003 0012
   Serial number: AP0883RHNA2722073682
   Coding: 0D2203
Address 15: Airbags (J234)       Labels:| 2Q0-959-655.clb
   Part No SW: 2Q0 959 655 AP    HW: 2Q0 959 655 AP
   Component: VW22Airbag    020 0511
   Revision: --------    Dataset Number: V03935371KB 0001
   Coding: 88CCC000000000007C000000008800000065
   ASAM Dataset: EV_AirbaVW22BPAVW27X 001036
   ROD: EV_AirbaVW22BPAVW27X.rod
   VCID: 0B43B57643CFCC72EA5-805E
   Subsystem 1 - Part No SW: -----------    HW: 442 061 204 22
   Serial number: 3577Y50A508A6EE1B28L
   Subsystem 2 - Part No SW: -----------    HW: 442 061 204 22
   Serial number: 3587Y509B08DB2D5018E
   Subsystem 3 - Part No SW: -----------    HW: 442 0B2 904 22
   Serial number: 3517710AD0940044018Y
   Subsystem 4 - Part No SW: -----------    HW: 442 0B2 904 22
   Serial number: 3527710AB0940044205V
   Subsystem 5 - Part No SW: -----------    HW: 442 130 302 22
   Component: FrontSensor_D  290 118A
   Serial number: 355AG23C2C785F72D0A8
   Part No SW: 2GP 920 310 A    HW: 2GP 920 310 A
   Component: KOMBI         030 3092
   Coding: 252400182180000C02083A001000000000001407
   ASAM Dataset: EV_DashBoardJCIMQBAB 010005
   ROD: EV_DashBoardJCIMQBAB_010_VW27.rod
   VCID: 392F3FBE59D30EE2889-806C
Address 19: CAN Gateway (J533)       Labels:* Redir Fail!
   Part No SW: 2Q0 909 901 E    HW: 2Q0 937 089 C
   Component: GW MQB A0     H12 0954
   Serial number: 014260622A0032 Dataset Number: V03935352Y0001
   Coding: 030100042F00570000000000000F00010001070000000000000000000000
   GVL: 01403C0000000600400000000000C80000000000000000000000000000000000
   ASAM Dataset: EV_GatewA0 013026
   ROD: EV_GatewA0_VW27.rod
   VCID: 34310E8A7EB1F38A5BF-8060
   Generator:
   Component: 4-00-12-00-04
   Subsystem 2 - Part No SW: 3G0 959 442 AH    HW: 3G0 959 442 AH  Labels: 3C8-959-537.CLB
   Component: E221__MFL-PR6  H50 0500
   Serial number: PR6-0440071019220470
   Coding: 290C00
   Subsystem 3 - Part No SW: 2Q0 915 181 B    HW: 2Q0 915 181 B
   Component: J367-BDMBOSCH  H02 2012
   Serial number: 101A854B
   Part No SW: 2Q0 905 861 A    HW: 2Q0 905 861 A
   Component: ELV-MQBB      H10 0021
   Serial number: 22000044558002
   Coding: 0800000000000000
   ROD: EV_ELVMarqMQBA0_VW27.rod
   VCID: 313F079E81A3C6A2309-8064
Address 44: Steering Assist (J500)       Labels:. 2Qx-909-144-V3.clb
   Part No SW: 5QR 909 144 C    HW: 5QR 909 144 A
   Component: EPS_ECU       430 4250
   Serial number: 000025.04.22000
   Coding: 00000000000000000000020101000100000001000100
   ASAM Dataset: EV_SteerAssisNSKGEN3MQB 004008
   ROD: EV_SteerAssisNSKGEN3MQB.rod
   VCID: 56F59402C88DC19A85B-8002
0054 - Steering angle sensor
          B1168 54 [10001001] - Missing Calibration / Basic Setting
                    Mileage: 25045 km
                    Date: 2025.03.18
                    Time: 22:08:53
                    Single Additional Freeze Frame: 2
0047 - Steering End Stops Not Learned
          C10AC F0 [10001001] -
          [Both end positon calibration state diagnosis]
                    Mileage: 25045 km
                    Date: 2025.03.18
                    Time: 22:08:53
0117 - No End-of-Line Programming
          B2013 00 [00001001] - -
          [Coding and DatasetDownload diagnosis ( not tuned )]
                    Mileage: 25045 km
                    Date: 2025.03.18
                    Time: 22:08:53
                    Single Additional Freeze Frame: 7
Address 5F: Information Electr. (J794)       Labels:| 2GM-035-MIB-REG.clb
   Part No SW: 6JR 035 180     HW: 6JR 035 180
   Component: MU-R--R2      H04 0576
   Serial number: VWZ7Z2A7300975  Dataset Number: V03935382F  0001
   Coding: 22711608000000000000000000000000000000000000000000
   ASAM Dataset: EV_MUREGIO 001010
   ROD: EV_MUREGIO.rod
   VCID: 03539D566B9F8432925-8056
End----------(Elapsed Time: 00:50, VBatt start/end: 12.7V/12.7V)-----------
------------------------------7 Faults Found-------------------------------
Didn't you see the caution balloon warning you not to do this? As TTT mentioned above and from what I have seen here on the forum , when this occurs, you will need to go to the Dealer for a manufacturer server plug in.
  • Agree
vrpram
India
C?ID=550004
No, there was no pop up balloon warning. Anyway, the car is at the service center and I called aside the technician and explained everything to him. Hopefully the issue gets fixed soon. A lesson learnt the hard way. Any sources as to how exactly they go about fixing this issue are welcome.
vrpram
India
C?ID=550004
Just a quick update: The issue was fixed around 2 weeks back with no significant dent to the pocket as labour charges. Haven't done any autoscan till now but all errors seemed to have disappeared and has not returned in 300 kilometres. Thanks for the assist in immediately pointing out that a dealer visit is a must.
Cheers!
