2016 A7 Matrix led headlight is broken
caviation
Japan
C?ID=66615
Hi
I'm new of this forum.
#And sorry that my english is very poor and strange...
I had set some coding DRL and other to my car(2016 A7SB).
After that, matrix led lights error appear on the console.
And error detected module09 and module55.
It may be resetted Matrix Led Headlight setting to zero.
I'd like to know reset this setting to basic setting and not to apear error message on the console.
Please let me know how.
#Do you understand my poor english?
#Thanks
Your English is OK. But please post an Auto-Scan so people can see how the car is equipped and configured, and any faults that may be present.
caviation
Japan
C?ID=66615
Thanks for your reply.
And below is full scan of my car.
Saturday,05,December,2015,11:26:42:63270
VCDS Version: 15.7.2.0 (x64)
Data version: 20151124
VIN: WAUZZZ4G9Gxxxxxxx   License Plate:
Mileage: 392km-243mi   Repair Order:
Chassis Type: 4G (4G8)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 28 36 3B 3C 42 44 46 52
          53 55 5F 62 6C 6D 72 82 84 85 8B 8E 8F 90
VIN: WAUZZZxxxxxxxxxxx   Mileage: 392km-243miles
Address 01: Engine (J623-CREC)       Labels: None
   Part No SW: 4G2 907 551 B    HW: 4H2 907 551 A
   Component: 3.0l V6 TFSI  H10 0001
   Revision: --H10---
   Coding: 1A2500340567010B3000
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM30TFS0214G2907551B 002001
   ROD: EV_ECM30TFS0214G2907551B.rod
   VCID: 2A50CBB04D080F6E15-807E
Address 02: Auto Trans (J217)       Labels: 0B5-927-156.clb
   Part No SW: 4G0 927 166 D    HW: 0B5 927 156 K
   Component: 0B5 30TFSIRdW H03 0009
   Revision: --H03---
   Coding: 100001
   ASAM Dataset: EV_TCMDL501021 001021
   ROD: EV_TCMDL501021.rod
   VCID: 2E58C7A071E0634EC9-807A
Address 03: ABS Brakes (J104)       Labels: Redir Fail!
   Part No SW: 4G0 907 379 S    HW: 4G0 907 379 S
   Component: ESP9 Premium  H01 0530
   Coding: 44A68F4B2265F1D29B00
   ROD: EV_ESP9BOSCHAU57X.rod
   VCID: 41828C1CD07EEC3624-8014
   Part No SW: 4H0 907 064 GR    HW: 4H0 907 064 GR
   Component: BCM2 2.0      H37 0572
   Coding: 059A6F0E000000000000
   VCID: 7F06CAE4EE0A5AC612-802A
   Part No SW: 4G0 820 043 CD    HW: 4G0 820 043 CD
   Serial number: 28071500041353
   Coding: 662371B8350000
   ROD: EV_AirCondiComfoUDS.rod
   VCID: 63CE66946AA29E2616-8036
Address 09: Cent. Elect. (J519)       Labels: Redir Fail!
   Part No SW: 4H0 907 063 DG    HW: 4H0 907 063 AG
   Component: BCM1 2.0      H20 0311
   Revision: 14020001    Serial number: 00001129677002
   Coding: 0105409140309FE2C1014083A0001800CF9DC2082F080201000008946101130200400009090000
   VCID: 70E419D8A35435BE9B-8024
   Subsystem 1 - Part No SW: 4G2 955 119     HW: 4G8 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS57X 150626  H37 0080
   Coding: 004DF7
   Coding: 000023
   Subsystem 3 - Part No SW: 4G0 941 531 BH    HW: 4G0 941 531 BH
   Component: E1 - LDS  H07 0044
03455 - Function Restriction due to Faults in Other Modules
            000 -  -
                    Reset counter: 46
                    Mileage: 334 km
                    Date: 2015.11.29
                    Time: 12:10:59
Address 10: Park/Steer Assist (J791)       Labels: None
   Part No SW: 4G0 919 475 G    HW: 4H0 919 475 E
   Component: PARKHILFE PLA H06 0070
   Revision: --------    Serial number: 56231520200066
   Coding: B83B10
   ASAM Dataset: EV_EPHVA2CAU64X0000 001011
   ROD: EV_EPHVA2CAU57X0000.rod
   VCID: 356AE8CC94B6509688-8060
Address 13: Auto Dist. Reg (J428)       Labels: 4H0-907-561.clb
   Part No SW: 4G0 907 561 B    HW: 4G0 907 561
   Component: ACC3          H21 0053
   Coding: 7E02010201
   ASAM Dataset: EV_AdaptCruisContrAU57X 002014
   ROD: EV_AdaptCruisContrAU57X.rod
   VCID: 295234BC480E04761C-807C
Address 15: Airbags (J234)       Labels: 4H0-959-655.clb
   Component: Airbag10.43   H82 0086
   Revision: --------    Serial number: 003P1005WK66
   Coding: 30333046313130313134554A305234473853
   ROD: EV_AirbaAU10BPAAU64X_AU57.rod
   VCID: 3B7EFEF4B29286E67E-806E
   Serial number: 3575HRB404R3BS605OU2
   Serial number: 3585HRB40553BS62EPCJ
   Serial number: 3515JRB404V3I0AS6058
   Serial number: 3525JRB40573FQH0BHNS
   Serial number: 3554VRB40533IQQ8H1C.
   Serial number: 3564VRB400253408A9DG
Address 16: Steering wheel (J527)       Labels: 4H0-953-568.clb
   Revision: --------    Serial number: 90372OGU000OL
   Coding: 0000FC
   VCID: 3776E2C486BAA2869A-8062
   Subsystem 1 - Part No SW: 4G0 951 528 A    HW: 4G0 951 528 A
Address 17: Instruments (J285)       Labels: 4H0-920-xxx-17.clb
   Part No SW: 4G8 920 934 G    HW: 4G8 920 934 G
   Component: TBenRdwAccNv  H10 0104
   Revision: 06001087    Serial number: 658170715596042
   Coding: 338700020F53000E0F0100
   ASAM Dataset: EV_RBD4K 004055
   ROD: EV_RBD4K.rod
   Part No SW: 4G8 907 468 F    HW: 4G8 907 468
   Component: J533--Gateway H14 0083
   Revision: --------    Serial number: 00000001949361
   Coding: C0CD073018
   ASAM Dataset: EV_GatewPkoUDS 001028
   ROD: EV_GatewPkoUDS.rod
   Serial number: 8393827303
   Voltage stabilizer:
Address 28: HVAC, Rear (E265)       Labels: 4G0-919-158.clb
   Part No SW: 4G0 919 158 R    HW: 4G0 919 158 R
   Component: KLIMA FOND    H08 0112
   Serial number: 25071500040110
   Coding: 22
   ROD: EV_ClimaContrUnitRearUDS.rod
   VCID: 3E78F7E0A18093CE59-806A
   Revision: AA000000    Serial number: 00000158597595
   Coding: 00781B0000006001000001010101102030303232203232
   VCID: 77F622C4C63A62865A-8022
   Part No SW: 4G0 907 637 K    HW: 4G0 907 637 F
   Component: SARA 6D       H04 0056
   Revision: --------    Serial number: EJ1BPA8209Z49I
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2_AU57.rod
   VCID: 3668EFC089B05B8E81-8062
Address 3C: Lane Change (J769)       Labels: 5Q0-907-566.clb
   Part No SW: 4G0 907 566 M    HW: 4H0 907 566 F
   Component: SWA Master    H06 0060
   Serial number: 0374766770
   Coding: 040312
   VCID: 3972E4FCB8AEB4F66C-806C
   Lane Change Assistant 2:
   Part No SW: 4G8 959 793 H    HW: 4G8 959 793 F
   Component: TSG FA        H04 0511
   Coding: 011F57035E01628002080413
   VCID: 458A980CCC56C01618-8010
Address 44: Steering Assist (J500)       Labels: 8K0-909-144.clb
   Part No SW: 4G0 909 144 S    HW: 4G0 909 144 G
   Component: RCEPS         H43 0012
   Revision: 00001000    Serial number: 0013025082
   Coding: 101101010001
   ASAM Dataset: EV_RCEPS 009013
   ROD: EV_RCEPS.rod
Address 46: Central Conv. (J393)       Labels: 4H0-907-064-46.clb
   Revision: 00002001    Serial number: 0374684160
   Coding: 01000E3820B9B081C3300A800C030D400000000000000000000000000000
   Subsystem 1 - Part No SW: 4G0 947 135 B    HW: 4G0 947 135
   Subsystem 2 - Part No SW: 4G8 959 252     HW: 4G8 959 252
   Component: HSP-SG  H11 0029
   Subsystem 3 - Part No SW: 3AA 962 243 D    HW: 3AA 962 243 D
   Component: TSG BF        H03 0511
   Coding: 011F57035E01628002080402
   VCID: 46889F00F150CB0E11-8012
   Part No SW: 4H0 907 801 H    HW: 4H0 907 801 A
   Component: EPB-4         H04 0015
   Revision: --------    Serial number: 00000001556241
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 2D5AC0AC7CE61856F0-8078
Address 55: Headlight Range (J745)       Labels: 4H4-907-357-V2.clb
   Coding: 05FE02202A180200
   ROD: EV_HeadlRegulAUDIMXBAU64X_AU57.rod
   VCID: 346CD5C89FCC499EBF-8060
   Coding: E02100
   Coding: E02100
   Subsystem 3 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
   Component: MxB LeiMo li.  H03 0031
   Coding: E02100
   Subsystem 4 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
   Component: MxB LeiMo re.  H03 0031
   Coding: E02100
5350720 - Left Matrix High Beam
          C1175 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 46
                    Mileage: 334 km
                    Date: 2015.11.29
                    Time: 12:11:10
5350976 - Right Matrix High Beam
          C1176 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 46
                    Mileage: 334 km
                    Date: 2015.11.29
                    Time: 12:11:10
   Part No SW: 4G1 035 034 A    HW: 4G1 035 034
   Component: MU-H-TN-JP    040 0010
   Serial number: K5F AW7H103KA9
   Coding: 017503060000000013330002001200102F000CE6F17001007E
   ASAM Dataset: EV_MUHig6C3Gen2AW7 001290
   ROD: EV_MUHig6C3Gen2AW7_AU37.rod
   VCID: 1C3C1D68175CE1DE97-8048
   Engine Control Module 2:
   Subsystem 1 - Part No SW: V03 959 801 GP    HW: -----------
   Component: JPN 2015/2016  --- 7412
   Seat Adjustment Driver Side:
   Subsystem 2 - Part No SW: 4G1 919 605 A    HW: 4G1 919 605 A
   Component: DU8 C7 SV  H63 0006
   Serial number: AUZ8Z9FY8028JD
   Door Electronics Driver Side:
   Subsystem 3 - Part No SW: 8V0 919 813 B    HW: 8V0 919 813 B
   Component: DSRC UNIT  H06 0002
   Serial number: 502129338735
   Brake Assistance:
   Subsystem 4 - Part No SW: 8V0 035 504 B    HW: 8V0 035 504 B
   Component: VICS Antenna  H06 0001
   Serial number: 503310086703
   Sound System:
   Subsystem 5 - Part No SW: 4G2 919 610 G    HW: 4G2 919 610 G
   Serial number: 90349OGL0004P
   Door Electronics Rear Left:
   Subsystem 6 - Part No SW: V03 959 800 EG    HW: -----------
   Component: Gracenote2  --- 2006
   Component: TSG HL        H03 0511
   Coding: 010F15024001628002080002
   VCID: 4992943CE04E2476FC-801C
Address 6C: Back-up Cam. (J928)       Labels: None
   Part No SW: 4H0 907 428 D    HW: 7P6 907 441 F
   Component: TopView       H07 0330
   Revision: 11001001    Serial number: 82330JF0243224
   Coding: 0216000001000100000102000000
   ASAM Dataset: EV_CamerSysteTopViewAUDI 008027
Address 6D: Trunk Elect. (----)       Labels: Redir Fail!
   Part No SW: 4G8 959 107 S    HW: 4G8 959 107 H
   Component: HDSG-Modul    H14 0049
   Revision: 11014001    Serial number: 202501689
   Coding: 0A3305C022
   ASAM Dataset: EV_HDSGAu573 001022
   ROD: EV_HDSGAu571.rod
   VCID: 458A980CC456C01618-8010
   Component: TSG HR        H03 0511
Address 82: Heads Up Display (J898)       Labels: None
   Part No SW: 4G8 919 604 N    HW: 4G8 919 604 N
   Component: HeadUpDisplay H07 0305
   Coding: D60000
   ASAM Dataset: EV_HUDContiC7 001027
   ROD: EV_HUDContiC7.rod
Address 84: Night Vision (J853)       Labels: None
   Part No SW: 4G0 907 547 A    HW: 4G0 907 547
   Component: NV-ECU-Gen3   H08 0107
   Serial number: 622352400201505
   Coding: 401100
   ASAM Dataset: EV_NightVisioGen3AE4AU64X 001001
   ROD: EV_NightVisioGen3AE4AU64X.rod
   VCID: 2C5CCDA847FC115EE7-8078
   Subsystem 2 - Part No SW: 4G0 980 552     HW: 4G0 980 552
   Component: NV-CAM-Gen3  H03 0006
   Serial number: 623466500F1518100177
Address 85: On Board Cam. (J852)       Labels: None
   Component: DPC-SG        H27 0081
   Coding: 6A160000
   ROD: EV_OnBoardCamerDPC.rod
Address 8B: Adaptive Cruise 2 (J428)       Labels: 4H0-907-561.clb
   Part No SW: 4G0 907 541 B    HW: 4G0 907 541
   Coding: 7E02010201
   ASAM Dataset: EV_AdaptCruisContr2AU57X 002012
   ROD: EV_AdaptCruisContr2AU57X.rod
   VCID: 275632845E1A32060A-8072
Address 8E: Image Processing (J851)       Labels: None
   Part No SW: 4H0 907 107 H    HW: 4H0 907 107
   Component: BV-SG         H33 0090
   Serial number: 005000622907157
   Coding: 03C338180111
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7.rod
   Coding: 0066E608031F0376070308004240C2010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 3162DCDC60DE7CB6D4-8064
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
   VCID: 3260D3D065D847AEAD-8066
End-------------------------(Elapsed Time: 06:10)--------------------------
caviation
Japan
C?ID=66615
Yes I saved an archive autoscan.
But I don't know how can I go back.
And I don't know security access number to module#55 of my A7.
Au07
C?ID=231702
didn't work for me. also manual is for xenon.
any procedure for matrix led?
Sunday,10,November,2019,22:29:51:31877
VCDS Version: Release 19.6.2 (x64) Running on Windows 7 x64
Address 55: Headlight Range Labels: 4H4-907-357-V2.CLB
Control Module Part Number: 4H4 907 357 E HW: 7P6 907 357 B
Component and/or Version: MxB-ECU 001 0100
Software Coding: 05FE02202A170200
Work Shop Code: WSC 02391 785 00200
ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005009 (AU57)
VCID: 346730BB9F47EAEF73-8060
Fault Codes have been Erased
Reset counter: 26
Mileage: 49656 km
Date: 2019.11.10
Time: 22:26:36
Reset counter: 26
Mileage: 49656 km
Date: 2019.11.10
Time: 22:26:36
