MK7 virtual cluster retrofit question
C?ID=313143
I know purchasing a shiny new one from VW is preferred, but $1200 is a lot of swallow. I've seen people swapping to used ones which are considerably less (I've seen as low as $500). I've read the cluster can only have miles increased to it would have to have less miles on it when purchased than the car. Has anyone done this? I'm assuming ODIS would be required for CP, cloning, and IMMO then VCDS for all the other coding. Any insight?
Here's an auto scan from 2 weeks ago (I'm not at home)
Friday,28,February,2025,20:31:09:41190
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 arm64(arm64 CPU)(VMWare)
VCDS Version 25.3.0.2 (arm64)  HEX-V2 CB: 0.4660.4
Data version: 20250228 DS364.1
VIN: 3VW447AU6GM023920   License Plate:
Mileage: 152140km-94535mi   Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 14 15 16 17 19 2B 32 42 44 47 52 55 5F 75
          A9
VIN: 3VW447AU6GM023920   Mileage: 152140km-94535miles
Address 01: Engine (J623-CXCB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 D    HW: 06K 907 425 B
   Revision: --H13---    CVN: 5E75E924
   Coding: 091D00124424002F1000
   Shop #: WSC 00066 790 00060
   ASAM Dataset: EV_ECM20TFS0205G0906259D 001003
   ROD: EV_ECM20TFS0205G0906259D.rod
   VCID: 2F381BEDF797421226B-807B
   VINID: 0E69C4107465197740083242000181A378
   Part No SW: 0D9 300 020 J    HW: 02E 927 770 AQ
   Component: DQ250-6V MQB  H53 4902
   Revision: 06253104    Serial number: TFK01507291364 CVN: 0000EE8B
   ROD: EV_TCMDQ250021.rod
   VCID: 1C62DC219621C98A739-8049
          P1734 00 [00000010] - -
   Part No SW: 3Q0 907 379 T    HW: 3Q0 907 379 C
   Component: ESC           H32 0393
   Revision: 00000000    Serial number: 52285000001036
   Coding: 01FA6BA15422096F0080020241C36880D62A9000408216B6004300D1C009
   Shop #: WSC 01383 790 50316
   VCID: 4BC06F7D634F1E322A3-801F
   Revision: 00021000    Serial number: 0375865515 Dataset Number: V03935226DW 0001
   Coding: 030C0C
   ROD: EV_KessyHellaMQBAB_002_VW37.rod
   VCID: 3A2E3AB93CD597BA815-806F
   Part No SW: 5GM 907 044 A    HW: 5GM 907 044 A
   Revision: 00001K01
   Coding: 00020014200100000005000012111402
   VCID: 42DE42595405DF7AD95-8017
   Air quality sensor:
   Part No SW: 5Q0 937 087 AA    HW: 5Q0 937 087 AA
   Revision: --------    Serial number: 86580408150376 Dataset Number: 5GM063v____ 0061
   Coding: 00111A464041A2E969E44000001407201800000000000000000000000000
   Shop #: WSC 00066 790 00150
   ROD: EV_BCMBOSCH_015.rod
   VCID: 7AAEFAB97C5557BAC15-802F
   Component: WWS    150715  043 0581
   Serial number:         150928122341
   Component: RLHS  037 0059
   Serial number: S5Y15M08D05H10M53S07
   Coding: 90A8DD
   Sunroof control module:
   Subsystem 3 - Part No SW: 5GD 959 591     HW: 5GD 959 591
   Component: J245 PS60.036  H06 0150
   Serial number: 03694800381503150622
   Coding: 181803
   Humidity sensor: interior:
   Part No SW: 5Q0 907 376 A    HW: 5Q0 907 376 A
   Component: DAEMPFUNGS-SG H16 0120
   Serial number: 30071541350619 Dataset Number: V03935209LD 0002
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 3728238D0FC78AD27EB-8063
   Serial number: 003GCR02X4HS Dataset Number: 5GM003V____ 0046
   VCID: 47C8534D7F27FA520EB-8013
   Component: BF-Gewichtss.  H11 0021
   Serial number: IBH0000000000039P5SU
   Coding: 303131
   Subsystem 2 - Part No SW: -----------    HW: 480 002 607 15
   Serial number: 35700000000340F4751B
   Subsystem 3 - Part No SW: -----------    HW: 480 001 607 15
   Serial number: 3580000000068C09651K
   Subsystem 4 - Part No SW: -----------    HW: 480 402 907 15
   Serial number: 3510002A31B7E8E48229
   Subsystem 5 - Part No SW: -----------    HW: 480 402 907 15
   Serial number: 35200029B1B7E8E142BJ
   Subsystem 6 - Part No SW: -----------    HW: 480 401 209 19
   Component: FrontSensor_D  005 6149
   Serial number: 3550001B2F20D052F0D6
   Subsystem 7 - Part No SW: -----------    HW: 480 401 612 20
   Component: FrontSensor_P  004 6149
   Serial number: 356000126638A6B27583
   Part No SW: 5Q0 953 569 A    HW: 5Q0 953 569 A
   Revision: --------    Serial number: 20180913400575
   Coding: 0410
   Shop #: WSC 34557 003 1048576
   ASAM Dataset: EV_SMLSVALEOMQB 001016
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 3C223CA136E1A98A939-8069
   Part No SW: 5G1 920 856 A    HW: 5G1 920 856 A
   Component: KOMBI         342 6420
   Coding: 0BAD091AB980CF0502086A001000000000000000
   Shop #: WSC 00066 790 00219
   VCID: 2C020CE1C681390A039-8079
   Part No SW: 5Q0 907 530 AF    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2223
   Revision: --------    Serial number: 18081510801186 Dataset Number: 5G0067V____ 2214
   Coding: 0101000830085900FB00022B9C0F00000001050000000000000000000000
   Shop #: WSC 00066 790 07027
   GVL: 01503C5000000600400C10008000CC0000000000000000000000000000000000
   ROD: EV_GatewConti_013_VW37.rod
   VCID: 75B4E985554B38C2AC7-8021
   Generator:
   Subsystem 2 - Part No SW: 5G0 959 442 Q    HW: 5G0 959 442 Q  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H11 0103
   Serial number: 29160000919640076195
   Coding: 31FFFF
   Revision: 00000000    Serial number: 15000177777008
   Coding: 5D00000000000000
   VCID: 343214811EB161CA5B9-8061
Address 32: Differential Locks (J492)       Labels:| 0CQ-907-554-V2.clb
   Part No SW: 0CQ 907 554 E    HW: 0CQ 907 554 E
   Component: Quersperre    H52 8042
   Serial number: HA1-00014.07.15 Dataset Number: v1260x015G0 0000
   Coding: 0001
   ASAM Dataset: EV_LockElectHA1VW37X 001007
   ROD: EV_LockElectHA1VW37X.rod
   Serial number: 260815060500DI Dataset Number: V03935214VB 0007
   Coding: 003F13205000040000000000
   VCID: 43D0475D4B1FD672D23-8017
   Serial number: 00000000000001871160
   Coding: 011000
   Part No SW: 3Q0 909 144 J    HW: 3Q0 909 144 H
   Component: EPS_MQB_ZFLS  505 5063
   Dataset Number: 5GM074V____ 0418
   Coding: 8102
   VCID: 392C25B539D39CA288F-806D
   Component: MIB2_lite_amp H20 0110
   Revision: 00000001    Serial number: VWZ8Z1FBA00NTFU Dataset Number: 5GM050v____ 0212
   Coding: 2200000000AAAAAA000000000000
   ROD: EV_AMPMst12C1Gen2ALPI_VW37.rod
   VCID: 6D84C1E53D1BF002547-8039
   Serial number: 24061506050D5T Dataset Number: V03935214VC 0007
   Serial number: 00000000000001876615
   Coding: 091000
   Revision: --------    Serial number: -------------- Dataset Number: V03935205NP 0021
   Coding: 021203010B000400
   ROD: EV_HeadlRegulVWAFS_VW37.rod
   VCID: 40DA48515A09CD6ACF1-8015
   Subsystem 1 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
   Coding: 2E0000
   Subsystem 2 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
   Coding: 2E0000
   Part No SW: 3Q0 035 876 B    HW: 3Q0 035 876 B
   Component: MU-S-NS-US    851 0842
   Serial number:                Dataset Number: V03935262VW 0001
   Coding: 027300020000000051220002001808009F0003F401200405C6
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: 3330179D1BBF66F2423-8067
   Subsystem 1 - Part No SW: 5G6 919 605 B    HW: 5G6 919 605 B
   Component: ABT_Std-2_Nav  H50 8130
   Serial number: VWZ6ZHT2851154
   Subsystem 2 - Part No SW: 5NA 919 866 BF    HW: -----------
   Component: NAR 2021  --- 1510
                    Reset counter: 187
                    Mileage: 151202 km
                    Date: 2025.02.18
                    Time: 10:46:31
                    Voltage terminal 30: 11.7 V
                    SDARS_tuner_status_2-Satellite radio antenna status: electrically OK
                    SDARS_tuner_status_2-Audio Signal: Not available
                    SDARS_tuner_status_2-Antenna current: 139 mA
                    SDARS_tuner_status_2-Reception quality: No_signal
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: 07
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: 07
   Component: OCULowMQBUS   007 0568
   Dataset Number: 561098V____ 0409
   ROD: EV_OCULowMQB_VW37.rod
   Component: SAS-GEN 2     H06 0014
   Serial number: 150723200470
   VCID: 6B80CFFD030FFE324A3-803F
End----------(Elapsed Time: 01:43, VBatt start/end: 12.6V/12.4V)-----------
------------------------------2 Faults Found-------------------------------
Mileage on a used cluster cannot be changed up or down using a scan-tool.
downtime
Finland
C?ID=280813
Actually it can :) with v1 VCDS and suitable program that ”drives” the car 300km/h. Takes a long time if you need to run more miles to the cluster but is doable.
I think there’s a solution in those notorious dashboard tools now for VCs as well. So no driving needed
Waxing pedantic here: The interface cable is not VCDS. VCDS is software. So no, you can't do it with VCDS. ;)
Cuzoe
C?ID=279487
I added something like 25k to my VC on the bench, using one of those "programs" mentioned. First I should say that my VC was new and the dealer installed it but they didn't really know what they were doing they didn't match my odometer. I finished the coding and adaptations at home but because I had cruise control selected I didn't see the odometer until the next time I had to fill up. And I had driven over 100 km so it could not be changed ☹️.
Anyway, these programs claim they will work with an older interface in dumb mode. I tried it with my HEX-CAN and never got it to work. It obviously didn't work with the HEX-V2. I ended up buying a knock off (please don't kill me @Uwe) interface and that did work.
You have to build a little bench set up that can't really be used for anything else... OBD port, cluster plug, power, ground and can bus. The program sends the wake up signal and then as mentioned by @downtime it simulates wheel speed sensor input. The program will read the current odometer and you can set the target. And anything more than about 300 kmh won't work for more than a couple hours but anything lower can run indefinitely to your target mileage.
The little dongle doesn't have any other modules connected so using it doesn't trigger component protection or cause any immo issues. You could do it the dumbest way possible like I did, while daily driving the car. I would pull the dash out (meaning disconnect, I wasn't clipping it back, left the trim uninstalled) when I got to work and let it run on a workbench all day. Connect to drive home, get home and take it out again and let it run overnight, repeat... For almost 2 weeks, lol.
downtime
Finland
C?ID=280813
Thanks for the clarification. Yes exactly. Older v1 interface works, let's leave VCDS out of this :) I meant to put VCDS dongle but evening, using mobile to write a reply, not a good combination.
And the process goes exactly like @Cuzoe wrote. It is really slow process. I ran 80k kilometers and it took 1,5 weeks non-stop to run it. 300km/h is the max you can use reliably. That works no issues, anything higher will knock the system off at some point.
The biggest challenge is to get the approval for IMMO adaptation to used part. You cannot adapt the part anymore without approval from VW and if it gets accepted or not, you won't know until you try.
C?ID=313143
SO I'm guessing my only option here would to just buy it and then have the dealer/shop submit for approval to VoA (and hope for the best)?
downtime
Finland
C?ID=280813
Yes, exactly like that.
Reactions: 801
