Resolved 00778 Steering Angle Sensor
Resolved
SmokeandFire
Fortuna, MO, USA
C?ID=581884
I inherited a 2009 Jetta TDI DSG from my son after a mech unit failure. In the meanwhile, the ABS module failed. It is the MK60EC1 system. I replaced the 1K0 907 379 AE with a new OEM 1K0 907 379 AJ from ECS (with assurances, by VIN, that it was the correct one :rolleyes:)
It accepted the old coding with the addition of the two zeros. I "mostly" followed the steps in the Wiki, I might have swapped some steps, had some emergent situations come up.
to the point: I have the following DTCs 01486 System Function Test Activated, and 00778 Steering Angle Sensor 005 - No or Incorrect Basic Setting / Adaptation.
What I am looking for is some "this is how I did it" advice, because I am not at all sure I was doing it correctly. And if I understood correctly, the 01486 wont go away until I can get the 00778 resolved.
Following is my auto-scan when I received the car,
Friday,15,November,2024,16:40:32:25123
VIN: 3VWRL71K19M059721   License Plate:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 56 62 65 72
VIN: 3VWRL71K19M059721   Mileage: 172210km-107006miles
Address 01: Engine (CBE)       Labels: 03L-906-022-CBE.clb
   Part No SW: 03L 997 030 H    HW: 03L 906 022 J
   Component: R4 2.0l TDI G001AG  9983
   Revision: 12H01---    Serial number: VWX7Z0H824G01P
   Coding: 0050078
   Shop #: WSC 26214 051 00000
   VCID: 33330828B7334AA2929-8066
   VINID: 0E69E270705B0497401491C20436E7AA8D
005070 - Cylinder 1 Internal Pressure Sensor
               P13CE - 000 - Short to Plus - MIL ON
                    Fault Status: 11100000
                    Mileage: 165058 km
                    Time: 14:20:16
                    RPM: 828 /min
                    Bin. Bits: 00001000
                    Absolute Pres.: 0.0 bar
                    (no units): -12.80
                    Ign. Timing: 0.0  BTDC
                    (no units): 6.80
Readiness: 1 1 0 X X
   Part No SW: 02E 300 052     HW: 02E 927 770 AJ
   Component: GSG DSG AG6     431 8938
   Revision: 04843012    Serial number: 00000807171102
   Shop #: WSC 00066 000 00000
   VCID: 51FF62A02DEF18B2805-8004
17252 - Transmission Fluid Pressure Adaptation at Limit
            P0868 - 001 -  - Intermittent
                    Fault Status: 00100001
                    Fault Frequency: 255
                    Reset counter: 2
                    Mileage: 169258 km
19143 - Unexpected / Implausible Mechanical Gear Disengagement
            P2711 - 004 -  - Intermittent
                    Reset counter: 35
                    Mileage: 172110 km
   Part No SW: 1K0 907 379 CE    HW: 1K0 907 379 AE
   Revision: 00H35001
   Coding: 113B400D49270003881202E6921A0042B100
   Shop #: WSC 43395 001 1048576
   VCID: 77ABFC38EFCB66826E1-8022
01130 - ABS Operation
                    Fault Status: 01101000
                    Reset counter: 254
                    Mileage: 169258 km
                    Count: 4608
                    Count: 125
                    Count: 49934
                    Count: 65280
   Part No SW: 1K0 820 047 JM    HW: 1K0 820 047 JM
   Component: Climatic PQ35   142 1212
   Revision: 00142032    Serial number: 00000000000000
   VCID: 78A9FF04EED569FA67B-802C
   Part No SW: 3C8 937 049 D    HW: 3C8 937 049 D
   Revision: 00H54000    Serial number: 00000001048470
   Coding: 14018E234004150007140000001400000008730B5C000120000000000000
   VCID: 323D0D2C482943AA99F-8066
   Component: Wischer 021008 021  0501
   Coding: 00038805
   Shop #: WSC 00066
01495 - Bulb for High-Beams; Left (M30)
                    Fault Status: 00101010
                    Fault Frequency: 125
                    Reset counter: 182
                    Mileage: 169258 km
                    Voltage: 11.75 V
                    Reset counter: 182
                    Mileage: 169258 km
                    Voltage: 14.15 V
   Part No SW: 8E0 035 593 M    HW: 8E0 035 593 M
   Component: SDAR SIRIUS     H07 0150
   Revision: 00000000    Serial number: AUZ4Z7H0423027
   Coding: 0000100
00003 - Control Module
                    Fault Status: 00101110
                    Reset counter: 161
                    Mileage: 160316 km
                    Time: 04:17:30
                    Reset counter: 22
                    Mileage: 169763 km
                    Time: 10:27:53
   Component: 6A AIRBAG VW8R  034 8000
   Revision: 05034000    Serial number: 003B6M071TE7
   Coding: 0013889
   VCID: 6C81D354AA8DD55A933-8038
   Subsystem 1 - Part No: 1K0 959 339 H
   Component: BF-Gewichtsens. 007 0006
   Subsystem 2 - Serial number: 6332MSME3E634137C
   Subsystem 3 - Serial number: 6342MSME3E13011A5
   Subsystem 4 - Serial number: 6351HSME18192C1AB
   Subsystem 5 - Serial number: 6361HSME181825643
   Subsystem 6 - Serial number: 63727SME17591164.
   Subsystem 7 - Serial number: 63827SME17590554/
   Part No SW: 1K0 953 549 BS    HW: 1K0 953 549 BS
   Coding: 0012021
   VCID: 04519BF4A21D3D1A7B3-8050
   Part No SW: 1K0 920 974 N    HW: 1K0 920 974 N
   Component: KOMBIINSTRUMENT 3HL 2418
   Revision: V0003000    Serial number: VWX7Z0H824G01P
   Coding: 0023203
   Shop #: WSC 12345 111 45725
   VCID: 392F3A00955FB0F2585-806C
   Component: J533  Gateway   H07 5063
   Revision:   H07 01    Serial number: 130808F1001444
   Coding: ED807F070013021002
   VCID: 35373630B9475492BCD-8060
   Part No SW: 1K5 919 965 A    HW: 1K5 919 965 A
   Component: Kompass         005 0004
   Revision: 00005000    Serial number: 1293324T3AHE04
   Coding: 0000003
   Component: IMMO            3HL 2418
   Part No SW: 1K0 959 701 AC    HW: 1K0 959 793 N
   Component: J386  TUER-SG FT    1519
   Revision: 72009005    Serial number: 00000646888919
   Coding: 0001205
   VCID: 6FBBC4589B9B2E42B61-803A
   Part No: 1K0 909 144 C
   Component: EPS_ZFLS Kl. 70     2301
   Revision: 00H15000
   Shop #: WSC 02069 000 90108
   VCID: 2A0D154C60F90B6A21F-807E
00750 - Warning Lamp
                    Fault Status: 00101101
                    Reset counter: 50
                    Mileage: 171133 km
                    Time: 12:20:22
                    Voltage: 11.88 V
                        DU
                    Temperature: 18.0 C
   Coding: 13900F880186083F2D04058FB0880F0488DC00
   Part No SW: 1K0 959 702 AC    HW: 1K0 959 792 N
   Component: J387  TUER-SG BT    1519
   Revision: 72009005    Serial number: 08072208190901
   Coding: 0001204
   VCID: 70B9C72486A531BAAFB-8024
Address 56: Radio        Labels:
   VCID: 55F796B01C0774925CD-FFFE
   Part No SW: 1K0 959 703 AH    HW: 1K0 959 795 T
   Component: J388   TUER-SG HL   1401
   Revision: 12006001    Serial number: 00000003487097
   Coding: 0001168
   VCID: 76B5F13CE4C11F8A757-8022
00934 - Electric Window Motor; Rear Left (V26)
                    Fault Status: 01100101
                    Fault Frequency: 40
                    Reset counter: 142
                    Mileage: 169258 km
   Coding: 0100101
   Part No SW: 1K0 959 704 AH    HW: 1K0 959 794 T
   Component: J389   TUER-SG HR   1401
   Revision: 12006001    Serial number: 00000003465537
   Coding: 0001168
   VCID: 77ABFC38E3CB66826E1-8022
                    Fault Frequency: 164
                    Reset counter: 142
                    Mileage: 169258 km
00935 - Electric Window Motor; Rear Right (V27)
                    Fault Status: 00100101
                    Fault Frequency: 42
                    Reset counter: 182
                    Mileage: 169287 km
                    Fault Status: 01101100
                    Reset counter: 142
                    Mileage: 169258 km
End----------(Elapsed Time: 01:43, VBatt start/end: 12.2V/12.2V)-----------
And the most recent:
Tuesday,11,March,2025,18:31:20:25123
VCDS Version: 25.3.0.3 (x64)  HEX-V2 CB: 0.4660.4
Data version: 20250301 DS365.0
VIN: 3VWRL71K19M059721   Mileage: 172310km-107068miles
   Coding: 0050078
   VCID: 33330828B7334AA2422-8066
                    Mileage: 172310 km
                    Time: 15:57:22
                    RPM: 943 /min
                    Bin. Bits: 00001000
                    (no units): -12.80
                    (no units): 6.80
   Part No SW: 02E 300 052 T    HW: 02E 927 770 AT
   Component: GSG DSG AG6     541 9037
   Revision:    54104    Serial number: 00002309200076
   Shop #: WSC 04940 001 00001
   VCID: 2517E67009E72412DC6-8070
   Part No SW: 1K0 907 379 AJ    HW: 1K0 907 379 AJ
   Component: ESP MK60EC1   H31 0107
   Revision: 00H31001
   Coding: 113B400D49270003881202E6921A0042B10000
   VCID: 7AADE50CDCD97BEAC14-802E
01486 - System Function Test Activated
                    Reset counter: 151
                    Mileage: 172312 km
                    Count: 3
                    Count: 14
                    Count: 4096
                    Count: 320
                    Count: 45056
                    Count: 65024
                    Count: 65532
                    Reset counter: 151
                    Mileage: 172312 km
                    Count: 3
                    Count: 14
                    Count: 4096
                    Count: 295
                    Count: 45056
                    Count: 65024
                    Count: 65532
   VCID: 78A9FF04EED569FAB70-802C
   VCID: 323D0D2C482943AA494-8066
   Coding: 00038805
   Shop #: WSC 00066
                    Reset counter: 189
                    Mileage: 172305 km
                    Voltage: 12.05 V
                    Fault Frequency: 23
                    Reset counter: 191
                    Mileage: 172303 km
                    Voltage: 14.30 V
   Coding: 0000100
                    Reset counter: 161
                    Mileage: 160316 km
                    Time: 04:17:30
                    Reset counter: 148
                    Mileage: 172303 km
                    Time: 00:16:07
   Coding: 0013889
   VCID: 6C81D354AA8DD55A438-8038
   Coding: 0012021
   VCID: 04519BF4A21D3D1AAB8-8050
   Coding: 0023203
   VCID: 392F3A00955FB0F288E-806C
   VCID: 35373630B94754926C6-8060
   Coding: 0000003
   Coding: 0001205
   VCID: 6FBBC4589B9B2E4266A-803A
   Revision: 00H15000
   VCID: 2A0D154C60F90B6AF14-807E
   Coding: 0001204
   VCID: 70B9C72486A531BA7F0-8024
   VCID: 55F796B01C0774928C6-FFFE
   Coding: 0001168
   VCID: 76B5F13CE4C11F8AA5C-8022
                    Reset counter: 151
                    Mileage: 172310 km
                    Reset counter: 151
                    Mileage: 172310 km
   Coding: 0100101
   Coding: 0001168
   VCID: 77ABFC38E3CB6682BEA-8022
                    Reset counter: 151
                    Mileage: 172303 km
                    Reset counter: 151
                    Mileage: 172303 km
                    Reset counter: 151
                    Mileage: 172303 km
End----------(Elapsed Time: 01:38, VBatt start/end: 12.5V/12.5V)-----------
------------------------------12 Faults Found------------------------------
The glow plug is on order.
Any help/insight would be greatly appreciated, as time is becoming a factor in this matter.
SmokeandFire
Fortuna, MO, USA
C?ID=581884
Steering Angle Sensor Calibration is here:
If it doesn't work for you, please tell us exactly where how/where it fails.
PS: If it was easy, everyone would do it. :D
This was the instruction that I intended to follow. I did the coding, then I had to leave, I came back and did the Basic settting for the Hydraulic intake valves (quite the challenge for a 63 year old with a cane!), then set about clearing the other ABS codes.
The SAS Calibration was attempted as written. Several attempts landed the value in field #1 at -1.49 or less(closer to 0), but I never got the "OK" in field #2.
Did I do the operations in a "fatal" wrong order?
Many thanks for the reply, also!
SmokeandFire
Fortuna, MO, USA
C?ID=581884
Also, what might they consider "a short distance"? Then the question of "level"....
I think with the only fault being the steering angle sensor calibration, it should be possible to do that calibration stand-alone.
Have you looked at MVB 004.1? Start the engine. Turn the steering wheel all the way one way, then all the way the other way while observing / checking steering angle readings for plausibility.
SmokeandFire
Fortuna, MO, USA
C?ID=581884
Just for my own information, how would I determine plausibility?
SmokeandFire
Fortuna, MO, USA
C?ID=581884
After several more unsuccessful attempts, the calibration came in okay! The only difference in my methodology was several "angry" taps on the steering wheel. Turned the wheel to full lock in both directions and held for a long count of 10. Centered the steering wheel at 0 degrees using 03-Brake Electronics Measuring Blocks-08 Group 004. Held it there while I drove the car forward approximately 40 feet. Stopped the car and in around 20 seconds it said OK.
I completed the ESP System Function Test, now all is well and good, except for the glow plug (which my tracking# shows has flown/driven past my hous for the third time today:mad:)
I believe we can mark this one resolved, for me at least!
Thank you, Uwe, for the "hand-holding"!
