- Nov 24, 2022
- 12
- 0
- Bend, OR, USA
- C?ID=527017
My partner was driving to work in my car and suddenly (according to his story) the car lost pressure and all the dash lights came on and he had to pull over because the car would barely drive. He said prior to that it seemed to be operating with less power than usual - similar to the way it was driving when I previously had to have a new DPF installed a year or so ago. When I went to check the car it would not start, tried to jump it and still no start. Ran auto scan on VCDS prior to having it towed home. Since I got it home I have briefly tried to check for cracked hoses and what not but was unable to get it into a shop bay until this weekend. I checked the oil and there was NONE on the dipstick. I had bought oil and filter right before the car broke down to change it. It had just came time but there was no indication of oil leak or any oil (or engine for that matter) problems. I am wondering if the oil is related or a separate issue? I have read and watched the videos on wastegate actuator arm, jacks cheap fix, the tech bulletin from VW and god knows what else. I am unsure where to begin other than getting it on jackstands so I can get under it but thought I would start with posting here. TIA for any advice/tips!
Sunday,01,December,2024,15:31:28:05035
VCDS Version: 24.7.0.0 (x64) HEX-V2 CB: 0.4643.4
VIN: 3VWML7AJ9BM627687 License Plate:
Mileage: 210820km-130997mi Repair Order:
Chassis Type: AJ-VW36 (7N0)
Scan: 01 03 08 09 15 16 17 19 1C 25 42 44 46 4F 52 56 62 72 77
VIN: 3VWML7AJ9BM627687 Mileage: 210820km-130997miles
Part No SW: 03L 997 030 C HW: 03L 906 019 DA
Component: R4 2.0l TDI G000SG 9983
Revision: 12H08--- Serial number:
Coding: 0050072
Shop #: WSC 61049 004 1048576
VCID: 2E050352AC167FCAFDF-807A
VINID: 0E69DD70745A2527460871881CB3158A7D
P0299 - 000 - Control Range Not Reached
Mileage: 210788 km
Date: 2019.04.24.
Time: 13:45:48
RPM: 2530 /min
Speed: 68.0 km/h
Load: 89.8 %
Pressure: 2323.2 mbar
Pressure: 834.9 mbar
Lambda: 94.7 %
Lambda: 94.7 %
P0299 - 001 - Control Range Not Reached - MIL ON
Fault Status: 11100001
Mileage: 210788 km
Date: 2019.04.24.
Time: 13:45:48
RPM: 2530 /min
Speed: 68.0 km/h
Load: 89.8 %
Lambda: 94.7 %
Lambda: 94.7 %
000618 - Charge Air Cooler
P026A - 000 - Efficiency Below Threshold
Mileage: 210816 km
Date: 2019.04.24.
Time: 14:09:52
RPM: 2668 /min
Speed: 104.0 km/h
Temperature: 8.1 C
Temperature: 6.3 C
(no units): 102.0
Temperature: 66.0 C
(no units): 40.0
Readiness: 1 1 0 0 0
Part No SW: 1K0 907 379 BC HW: 1K0 907 379 BC
Component: ESP MK60EC1 H30 0106
Revision: 00H30001
Coding: 114B600C49240001881106EC92200042B70000
Shop #: WSC 00066 000 00000
VCID: 74B1D13A0EBA151A4BB-8020
02214 - Tire Pressure Warning
002 - Lower Limit Exceeded
Fault Status: 01100010
Reset counter: 82
Mileage: 208710 km
Date: 2019.04.24.
Time: 13:47:58
Count: 32768
Count: 4608
Count: 16401
Count: 50433
Count: 768
Part No SW: 7N0 907 426 AN HW: 7N0 907 426 AN
Component: AC Manuell H19 0304
Revision: 00001015
Coding: 0000001002
Shop #: WSC 00066 000 00120
VCID: 00598DEA4A8239BA5F3-8054
9477141 - Position Sensor for Air Distribution Flap Motor
B109C 15 [00001000] - Open or Short to Plus
Reset counter: 121
Mileage: 209014 km
Date: 2024.12.01.
Time: 13:59:23
Part No SW: 5K0 937 084 E HW: 5K0 937 084 E
Component: BCM PQ35 B 011 1035
Revision: BG011001
Coding: 2D380E1F902F3EC4008800816000004401000086535D8560648020000040
Shop #: WSC 59034 001 1048576
VCID: 3431113A4E3A551A8BB-8060
Subsystem 1 - Part No: 1K1 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer 20091 21 0512
Coding: 009795
Part No SW: 5K0 959 655 B HW: 5K0 959 655 B
Component: AirbagVW10G 021 0706
Serial number: 003C4R00TWDY Dataset Number: 1KM003v__B_ 0027
Coding: 00003044
ASAM Dataset: EV_AirbaVW10SMEVW360 A01012
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 392F200E69D8A87258D-806C
Subsystem 1 - Part No SW: 1KM 959 339 HW: 1KM 959 339
Component: BF-Gewichtss. 007 0001
Serial number: ---0000R--000586BN00
Subsystem 2 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Serial number: 3572MSME270A0655ZZZS
Subsystem 3 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Serial number: 3582MSME58710455ZZZT
Serial number: 3511HSME14321223ZZZ%
Serial number: 3521HSME366C5623ZZZP
Serial number: 35527SME67650523ZZZA
Serial number: 35627SME02400223ZZZX
Part No SW: 5K0 953 507 BC HW: 5K0 953 549 E
Component: Lenks.Modul 007 0080
Revision: -------- Serial number: 90440JGR0004N Dataset Number: 5K0953507BC D005
Coding: 108A140000
Shop #: WSC 00066 000 00185
ROD: EV_SMLSNGKUDS_A05.rod
VCID: 72BDD722742E1B2A597-8026
Subsystem 1 - Part No SW: 5K0 959 542 HW: 5K0 959 542 Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H05 0010
Serial number: 0067716
Coding: 820000
Part No SW: 5K0 920 971 C HW: 5K0 920 971 C
Component: KOMBI H03 0406
Coding: 270F01
VCID: 2F3B1E56A79C76C2F69-807A
Address 19: CAN Gateway Labels:. 7N0-907-530-V1.clb
Part No SW: 7N0 907 530 A HW: 1K0 907 951
Component: J533 Gateway H25 5603
Revision: H25 Serial number: 18091001200382
Coding: E9807F0600160300002002
Part No SW: 5N0 919 879 HW: 5N0 919 879
Component: Kompass 001 0001
Revision: 00001000 Serial number: 1225223R9JCM06
Coding: 0000002
VCID: 7EA5F3123CF64F4A2DF-802A
Component: IMMO H03 0406
VCID: 6A8DCF425CFED3EAE17-803E
Part No SW: 3C0 959 701 B HW: 3C0 959 793
Component: TUER-SG FT 002 0307
Revision: 13101005 Serial number: 0001382837
Coding: 0004B5
Shop #: WSC 01383 790 50316
ROD: EV_DCU42BroseDriveSide_VW32.rod
VCID: 270BF6768F6C2E823E9-8072
Slave Driver:
Subsystem 1 - Part No SW: 1K0 959 703 AH HW: 1K0 959 795 T Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 006 1401
Serial number: 00000005123341
Coding: 000490
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 70 3001
Revision: 00H17000
Shop #: WSC 02069 000 90108
VCID: 313F182EBD286032E0D-8064
Part No SW: 7N0 907 532 HW: 1K0 907 951
Component: EZE_2 H25 5603
Coding: 050B0500
VCID: 6FBBDE56679C36C2B69-803A
Subsystem 1 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J245EE20SKB13 H02 0220
Subsystem 2 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J394EE20SKB13 H02 0220
02071 - Local Databus
Fault Status: 00101100
Fault Frequency: 31
Reset counter: 121
Mileage: 200450 km
Date: 2019.04.24.
Time: 07:54:20
Part No SW: 3C0 959 702 B HW: 3C0 959 792
Component: TUER-SG BT 002 0307
Revision: 15101005 Serial number: 0001354528
Coding: 0004B4
ROD: EV_DCU52BrosePasseSide_VW32.rod
VCID: 2809F54A827221FA373-807C
Slave Passenger:
Subsystem 1 - Part No SW: 1K0 959 704 AH HW: 1K0 959 794 T Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 006 1401
Serial number: 00000005139689
Coding: 000490
Part No SW: 1K0 035 180 AC HW: 1K0 035 180 AC
Component: Radio Prem-8 H10 0046
Revision: -----20S Serial number: VWZ4Z7J3034764
Coding: 0000000001
Shop #: WSC 00066 123 12345
VCID: 619FA86EA14890B230D-8034
Reset counter: 65
Date: 2019.04.24.
Time: 07:38:30
Part No SW: 7P6 035 730 C HW: 7P6 035 730 C
Component: TELEFON H05 0440
Revision: 1B001001 Serial number: 00007668350400 Dataset Number: 7P6035730C 0001
Coding: 0A00000000010100
ASAM Dataset: UHVNA A01007
ROD: UHVNA.rod
VCID: 323D1722B4AE5B2A997-8066
End----(Elapsed Time: 01:25, VBatt start/end: 11.8V/12.0V. VIgn 11.9V)-----
