3.0L 2012 Audi Q7 TDI_No Start in 35 Miles Does Not Go Away.
RossTechLG
Naperville, USA
C?ID=607138
Good morning!
I followed your directions. It seems like I do not see any error codes for the engine module any more. but "no start in 35 miles" still there on the display. How do I get rid of that warning of "No start in 35 miles"?
I replaced the Adblue pump and Adblue Injector. I believe I did the adaptation and cleared the codes in the right way as pe the directions in https://forums.ross-tech.com/index.php?threads/18568/#post-164199. I cleared the error codes, but I can still see "No start in 35 miles" on the display.
I also topped off the AdBlue solution. Here is the new scan report below. I believe other error codes should probably be due to the low battery voltage since the car hasn't been driven for some time.
Should I drive the car on the high way for some miles so see if the sytems reactivates and helps the mileage warning of 35 go away ?. but I'm scared to do so if it will do the reduction of reamaing drivable mileage without fixing the issue.
Any help would be really appreciated.
Sunday,16,March,2025,15:25:12:09215
VCDS Version: 25.3.0.2 (x64)  HEX-V2 CB: 0.4660.5
Data version: 20250228 DS364.1
VIN: WA1WMAFE7CD000804   License Plate: AG-20415
Mileage: 207590km-128990mi   Repair Order: March 16 2025
Chassis Type: FE-AU56 (4F0)
Scan: 01 02 03 05 08 09 15 16 17 19 28 36 3C 42 46 47 4C 4F 52 55
          56 5F 62 69 6C 6D 6F 72 76
VIN: WA1WMAFE7CD000804   Mileage: 207590km-128990miles
4C-Tire Pressure II -- Status: Malfunction 0010
6F-Centr. Conv. II -- Status: Malfunction 0010
Address 01: Engine (J623-CATA)       Labels:. 059-907-401-V2.clb
   Part No SW: 4L2 910 401     HW: 4L0 907 401 D
   Component: 3.0TDI FSA    H18 0009
   Revision: 54H18---    Serial number:                CVN: 5B6F114C5C3E0D0438D3FF82
   Coding: 2A2A4012253600050000
   Shop #: WSC 44012 001 1048576
   ASAM Dataset: EV_ECM30TDI0114L2910401 002008
   ROD: EV_ECM30TDI0114L2910401_002.rod
   VCID: 61987AFB91CB95F2E0F-8034
   VINID: 9D10677515951D3500000200100B4CA558
Readiness: 0 0 0 1 1
Address 02: Auto Trans (J217)       Labels:| 0C8-927-7XX-V1.clb
   Part No SW: 0C8 927 750 S    HW: 0C8 927 750 S
   Component: AL1000 AISIN  001 3408
   Serial number:                CVN: 44BD1086
   Coding: 001378
   Shop #: WSC 99999 999 83333
   ROD: EV_TCMAL991031_002.rod
   VCID: 3C26EB8F56E9981A939-8068
   Part No SW: 4L0 910 517 M    HW: 4L0 614 517 L
   Revision: 00H02001
   Coding: 0099473
   Shop #: WSC 31414 790 00001
   VCID: 3436C3AF7239505A5B9-8060
                    Reset counter: 243
                    Mileage: 207588 km
                    Date: 2011.06.30
                    Time: 02:40:36
                    Count: 64
                    Count: 2113
                    Count: 128
                    Count: 34048
                    Reset counter: 199
                    Mileage: 207588 km
                    Date: 2011.05.09
                    Time: 02:50:23
                    Count: 128
                    Count: 8517
                    Count: 297
                    Count: 50688
   Part No SW: 4F0 910 852 B    HW: 4F0 905 852 H
   Component: FBSAUDIC6 ELV   H08 0210
   Revision: 00H08000    Serial number: 10603902217196
   Coding: 0000143
   Shop #: WSC 50535 001 1048576
   VCID: 25102EEBC9E339D2DC7-8070
   Subsystem 1 - Part No: 4F0 910 132 L
   Component: FBSAUDIC6 EZS   H03 0020
   Component: FBSAUDIC6 KSG   H03 0020
   Component: FBSAUDIC6 IDG   H01 0053
00191 - Passenger's Door Handle Touch Sensor (G416)
            007 - Short to Ground
                    Fault Status: 01110111
                    Reset counter: 199
                    Mileage: 207588 km
                    Date: 2011.05.11
                    Time: 04:19:32
00193 - Rear Right Door Handle Touch Sensor (G418)
                    Reset counter: 199
                    Mileage: 207588 km
                    Date: 2011.05.11
                    Time: 04:19:32
                    Reset counter: 239
                    Mileage: 207588 km
                    Date: 2011.06.30
                    Time: 02:43:42
                    Fault Frequency: 8
                    Reset counter: 239
                    Mileage: 207588 km
                    Date: 2011.06.30
                    Time: 02:40:34
00955 - Key 1
                    Fault Status: 00110010
                    Mileage: 207589 km
                    Date: 2011.07.14
                    Time: 19:33:45
                    Fault Status: 00100001
                    Reset counter: 239
                    Mileage: 207588 km
                    Date: 2011.07.07
                    Time: 09:05:47
Address 08: Auto HVAC (J255)       Labels: 4L0-910-043.clb
   Part No SW: 4L0 910 043 D    HW: 4L0 820 043 AJ
   Revision: 00---026    Serial number: 00000000283129
   Coding: 0004A036
   VCID: 25102EEBC5E339D2DC7-8070
   Subsystem 1 - Part No SW: 8K0 959 772 D    HW: 8K0 959 772
   Component: SLR-B8  H05 0006
   Serial number:           0006183755
   Coding: 070000
02874 - Control Module 2 for Central Convenience (J773)
                    Fault Status: 01101000
                    Reset counter: 202
                    Mileage: 207588 km
                    Date: 2011.07.14
                    Time: 17:38:57
   Part No SW: 4F0 910 279 AG    HW: 4F0 907 279 C
   Component: ILM Fahrer      H31 0400
   Coding: 0133123
   VCID: 6E8211C75C953A8A6DD-803A
   Subsystem 1 - Part No: 4L1 910 113   Labels: 1KX-955-119.CLB
   Component: Wischer AU716   H17 0100
   Coding: 00064792
   Shop #: WSC 31414
   Coding: 00150059
   Shop #: WSC 31414
                    Reset counter: 239
                    Mileage: 207588 km
                    Date: 2011.06.30
                    Time: 02:43:00
                    Reset counter: 239
                    Mileage: 207588 km
                    Date: 2011.06.30
                    Time: 02:43:00
Address 15: Airbags        Labels: 4L0-910-655.clb
   Part No SW: 4L0 910 655 A    HW: 4L0 959 655 B
   Component: 73 AIRBAG AUDI8RH43 0230
   Revision: 07H43000    Serial number: 0038QD09TAHT
   Coding: 0014131
   VCID: 2B04D8D3AF070FA20A3-807E
   Subsystem 1 - Part No: 4L0 910 339 A
   Component: BF-Gewichtsens. H03 0030
   Subsystem 2 - Serial number: 6332QSME6B1E5354O
   Subsystem 3 - Serial number: 6342QSME400C1C5CM
   Subsystem 4 - Serial number: 6352QSME130F3272A
   Subsystem 5 - Serial number: 6362QSME400C196EO
   Subsystem 6 - Serial number: 63734SME5B1E317AA
   Subsystem 7 - Serial number: 63834SME20041974T
   Part No SW: 4F0 910 549 B    HW: 4F0 953 549 E
   Component: J0527               0830
   Revision: 00H07000    Serial number: 90025111330209
   Coding: 0012142
   VCID: 280E27DFBEF124BAE71-807C
   Component: E0221           H03 0030
                    Reset counter: 239
                    Mileage: 207588 km
                    Date: 2011.06.30
                    Time: 02:42:30
                    Reset counter: 239
                    Mileage: 207588 km
                    Date: 2011.06.30
                    Time: 02:49:27
Address 17: Instruments (J285)       Labels:. 4L0-920-KOM-V3.clb
   Part No SW: 4L0 920 984 R    HW: 4L0 920 984 R
   Component: KOMBIINSTR.   H11 0306
   Revision: 00000000    Serial number: JKJ50KF6C
   Coding: 8BD664040900CF05020205
   VCID: 42DA9577348DEEEAD95-8016
   Part No SW: 4F0 907 468 Q    HW: 4F0 907 468 G
   Component: GW-BEM 5CAN-M H06 0047
   Revision: MB300033    Serial number: 3300M115180334
   Coding: 00C303
   Shop #: WSC 09112 444 195015
   VCID: 3D20E68B4D739112A47-8068
   Component: J367-BDM  H07 0125
   Serial number: 00000000002790612262
                    Fault Frequency: 11
                    Reset counter: 239
                    Mileage: 207588 km
                    Date: 2011.05.25
                    Time: 11:47:00
                    Bin. Bits:    00000
                    Voltage: 11.70 V
                    Count: 18
                    Reset counter: 239
                    Mileage: 207588 km
                    Date: 2011.06.30
                    Time: 02:49:07
                    Bin. Bits:    00000
                    Voltage: 7.20 V
                    Count: 12
   Part No SW: 4L0 910 158     HW: 4L0 919 158 AB
   Revision: 00---010    Serial number: 00000000283396
   Coding: 0000006
   VCID: 688E67DF7E71E4BA271-803C
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 202
                    Mileage: 207588 km
                    Date: 2011.05.09
                    Time: 02:47:37
                    Reset counter: 199
                    Mileage: 207588 km
                    Date: 2011.05.09
                    Time: 02:47:37
                    Reset counter: 239
                    Mileage: 207588 km
                    Date: 2011.06.30
                    Time: 02:20:45
                    Voltage: 9.00 V
   Part No SW: 4F0 959 760 D    HW: 4F0 959 760 D
   Component: MEM-FS        H08 0064
   Revision: AA000000    Serial number: 00000006242237
   Coding: 00581B00000011110000
   VCID: 323AC5B7842D5E6A495-8066
                    Reset counter: 239
                    Mileage: 207588 km
                    Date: 2011.06.30
                    Time: 02:44:37
                    Reset counter: 239
                    Mileage: 207588 km
                    Date: 2011.06.30
                    Time: 02:58:03
   Part No SW: 4L0 910 566 C    HW: 4L0 907 566 B
   Revision: 00H01000    Serial number: 6PZ 009 014-10
   Coding: 0010001
   VCID: 2E02D1C79C157A8A2DD-807A
   Subsystem 3 - Serial number: 5F09.06.1100H010003C910071
   Subsystem 4 - Serial number: 910071
   Part No SW: 4F0 959 793 T    HW: 8K0 959 793 M
   Component: TSG FA        H12 0362
   Revision:             Serial number: 0000006288189
   Coding: 011F57205E40440004
   VCID: 48CE875F12B1C4BA071-801C
                    Reset counter: 239
                    Mileage: 207588 km
                    Date: 2011.06.30
                    Time: 02:42:31
                    Reset counter: 239
                    Mileage: 207588 km
                    Date: 2011.06.30
                    Time: 02:49:08
                    Reset counter: 239
                    Mileage: 207588 km
                    Date: 2011.07.07
                    Time: 09:05:53
   Part No SW: 4L0 910 289 H    HW: 4L0 907 289 H
   Component: Komfortgeraet   H10 0110
   Revision: 0110 ---    Serial number: 01510250970000
   Coding: 3569693
   VCID: 3530FEAB794349526C7-8060
                    Reset counter: 239
                    Mileage: 207588 km
                    Date: 2011.06.30
                    Time: 02:53:13
   Part No SW: 4L0 035 223 H    HW: 4L0 035 223 G
   Component: BOSE G3 Q7    H03 0130
   Revision: CH003000    Serial number: 00000000033338
   Coding: 030000
   VCID: 270C24E3BFEF2BC2EEB-8072
Address 4C: Tire Pressure II        Labels: 4F0-910-274.clb
   Part No SW: 4F0 910 274 B    HW: 4F0 907 274
   Component: J793  RKA+      H04 0110
   Revision: 00000519    Serial number: 00005191120278
   Coding: 0758477
   VCID: 231430F3C7D7C7E2B23-8076
02214 - Tire Pressure Warning
            000 - - - MIL ON
                    Fault Status: 11100000
                    Reset counter: 199
                    Mileage: 207588 km
                    Date: 2011.05.09
                    Time: 02:50:50
                    Hex Value: 0x00F4
                    Hex Value: 0x0000
                    Hex Value: 0x0005
                    Voltage: 14.10 V
                    Temperature: -1.0 C
                    (no units): 0.0
                    Fault Status: 00101101
                    Reset counter: 243
                    Mileage: 207588 km
                    Date: 2011.05.09
                    Time: 02:50:51
                    Hex Value: 0x00F4
                    Hex Value: 0x0000
                    Hex Value: 0x0005
                    Voltage: 14.10 V
                    Temperature: -1.0 C
                    (no units): 0.0
                    Reset counter: 243
                    Mileage: 207588 km
                    Date: 2011.05.09
                    Time: 02:50:51
                    Hex Value: 0x00F4
                    Hex Value: 0x0000
                    Hex Value: 0x0005
                    Voltage: 14.10 V
                    Temperature: -1.0 C
                    (no units): 0.0
   Part No SW: 4F0 910 280     HW: 4F0 907 280 D
   Component: ILM Beifahrer   H14 0100
   Revision:             Serial number: 00000000091783
   Coding: 0012001
   VCID: 5EE24107AC35AA0ADDD-800A
                    Reset counter: 239
                    Mileage: 207588 km
                    Date: 2011.06.30
                    Time: 02:49:00
                    Voltage: 7.200 V
                    Temperature: 77.0 C
                    Reset counter: 239
                    Mileage: 207588 km
                    Date: 2011.06.30
                    Time: 02:42:00
                    Voltage: 7.600 V
                    Temperature: 11.0 C
                    Reset counter: 239
                    Mileage: 207588 km
                    Date: 2011.07.07
                    Time: 09:05:00
                    Voltage: 15.500 V
                    Temperature: 77.0 C
   Part No SW: 4F0 959 792 T    HW: 8K0 959 792 M
   Component: TSG BF        H12 0362
   Revision:             Serial number: 0000006302664
   VCID: 47CC84631FAFCBC20EB-8012
                    Reset counter: 239
                    Mileage: 207588 km
                    Date: 2011.06.30
                    Time: 02:42:31
                    Reset counter: 239
                    Mileage: 207588 km
                    Date: 2011.07.07
                    Time: 09:05:53
   Part No SW: 4L0 910 357 B    HW: 4L0 907 357 B
   Coding: 0000031
                    Reset counter: 199
                    Mileage: 207588 km
                    Date: 2011.06.30
                    Time: 02:40:35
   Part No SW: 4G0 035 082 B    HW: 4G0 035 082
   Component: Radio U SIRIU H51 0076
   Revision: AB001007    Serial number: 156F$0B7514377
   Coding: 020007010000000000
   VCID: 1F1C3C03E7BFE30296B-804A
                    Reset counter: 239
                    Mileage: 207588 km
                    Date: 2011.06.30
                    Time: 02:49:18
                    Voltage: 7.30 V
                    Reset counter: 239
                    Mileage: 207588 km
                    Date: 2011.06.30
                    Time: 02:42:54
                    Voltage: 9.00 V
   Part No SW: 4L2 035 746     HW: 4L2 035 746
   Component: H-BNT-NA      H42 0385
   Revision: --------    Serial number: 097FX0B7500714
   Coding: 180200060004E3EF51002345EF632003140000000100000000
   VCID: 6B8418D36387CFA24A3-803E
   Component: NAR 2011  0505
   Subsystem 2 - Part No SW: 8F0 919 604     HW: 8F0 919 604
   Component: DU7 High  H43 0084
   Serial number: 9466D30B0563899
   Subsystem 3 - Part No SW: 4L0 919 614 C    HW: 4L0 919 614 C
   Component: E0380 Bedient  H01 0060
   Serial number: 00000001849151
   Component: CD-Database  3371
                    Reset counter: 239
                    Mileage: 207588 km
                    Date: 2011.06.30
                    Time: 02:49:08
                    Voltage: 7.40 V
03367 - Supply Voltage for Display Module
                    Reset counter: 239
                    Mileage: 207588 km
                    Date: 2011.06.30
                    Time: 02:42:56
                    Voltage: 9.00 V
   Part No SW: 4F0 959 795 P    HW: 4F0 959 795 P
   Component: TSG HL        H11 0362
   Revision:             Serial number: 0000006362455
   Coding: 010E57204040230004
   VCID: 46D2896718A5D2CAF5D-8012
                    Reset counter: 239
                    Mileage: 207588 km
                    Date: 2011.06.30
                    Time: 02:42:31
                    Reset counter: 239
                    Mileage: 207588 km
                    Date: 2011.06.30
                    Time: 02:58:52
                    Reset counter: 239
                    Mileage: 207588 km
                    Date: 2011.07.07
                    Time: 09:05:52
Address 69: Trailer (J345)       Labels:. 4E0-907-383.clb
   Part No SW: 4E0 907 383 J    HW: 4E0 907 383 J
   Revision: 2A001001    Serial number: 00000150712079
   Coding: 0200000000000000
   VCID: 3138CABB812B657230F-8064
                    Reset counter: 239
   Revision: --H05---    Serial number: 525PA8-J19404V
   Coding: 1030301
                    Fault Frequency: 8
                    Reset counter: 239
                    Mileage: 207588 km
                    Date: 2011.06.30
                    Time: 02:41:18
                        Reverse OFF
                    Count: 3
                    Reset counter: 239
                    Mileage: 207588 km
                    Date: 2011.06.30
                    Time: 02:48:09
                        Reverse OFF
                    Count: 3
   Part No SW: 4L0 910 945     HW: 4L0 827 851 E
   Component: ValeoHeckdeckel H56 0500
   Revision: --H56001    Serial number: E5030000B
   Shop #: WSC 98765 666 38354
   VCID: 6C861BCF6A89C89A439-8038
   Subsystem 3 - Serial number: RD15.06.11--H56001001B0206
   Subsystem 4 - Serial number: 1B0206
                    Mileage: 207588 km
                    Date: 2011.06.30
                    Time: 02:49:07
   Component: ILM HINTEN 2    H07 0080
   Revision: AAH07080    Serial number: 117213372-----
   Coding: 0003595
   VCID: 261229E7B4E532CAD5D-8072
   Component: J_245_EE16_SKB10H11 0220
   Component: J_394_EE16_SKB10H11 0220
   Component: J_392_EE16_SKB10H11 0220
02907 - Control Module for Roof Shade (J394)
                    Fault Status: 01100101
                    Reset counter: 199
                    Mileage: 207588 km
                    Date: 2011.05.09
                    Time: 02:51:17
                    Reset counter: 239
                    Mileage: 207588 km
                    Date: 2011.06.30
                    Time: 02:43:25
   Component: TSG HR        H11 0362
   Revision:             Serial number: 0000006362453
                    Reset counter: 239
                    Mileage: 207588 km
                    Date: 2011.06.30
                    Time: 02:42:31
                    Reset counter: 239
                    Mileage: 207588 km
                    Date: 2011.07.07
                    Time: 09:05:52
   Part No SW: 4L0 910 283 E    HW: 4L0 919 283 E
   Component: Parkhilfe 8-Kan H03 0100
   Revision: 00H03000    Serial number: 37331111301180
   Coding: 0231346
   VCID: 2C06DBCFAA09089A039-8078
01543 - Parking Aid Warning Chime (H15)
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 199
                    Mileage: 207588 km
                    Date: 2011.05.09
                    Time: 02:51:34
                    Reset counter: 239
                    Mileage: 207588 km
                    Date: 2011.06.30
                    Time: 02:42:31
End----(Elapsed Time: 02:26, VBatt start/end: 12.0V/11.9V. VIgn 11.9V)-----
------------------------------51 Faults Found------------------------------
Dr Sheldon
Windsor UK
C?ID=334979
Why is all that Scan in Bold ??
can you put in code tags please
like this
- Remove the bold too - That is hurting my eyes.
Dr Sheldon
Windsor UK
C?ID=334979
I know that on some cars the readiness monitors have to be complete before that adblue error will reset. Ford Transit is one I have come across. These things are all the same !!
Go drive it and get them set. Dont worry, the thing will not die in 35 miles as long as you do not switch it off it will run all day. And then there is likely a way in VCDS to get it going again !
RossTechLG
Naperville, USA
C?ID=607138
Than youfor your replies Dr. Sheldon.
first my apologie for putting them in bold. Now I hav removed bold leters.
Before I read your reponces, as soon as posted mine, I went ahead and played with VCDS basic settungsfor about 30-45 minutes. More imoportanyly, measuring NOx sensor 1 ans 2 values liek teamp, O2 concetrantion etc. and SCR readings. Seems all readings and measures ralated to NOxsensor 1 seems pretty good and within the recommneded ranges. After all, when I looked at instryment cluster that "no start in 35 mines" gone, it is not there any more. Wow, things worked! Ater that I drove the vehicle about 15-20 miles, everything normal.
I really did not know that once I run over that 35 miles, vehicle can still be operational till you shut off the engine. When I saw your responce, wow that is even better and VCDS can fix it too.
However, i should tell this to you about what Audi delaer told me. They said both NOx sensors, AdBlue, pump, and Injector shoudl be replaced to fix issue ( even AdBlue solution was full , the system was not reading it) at a cost of almost 4000$. But I replaced only pump and injector. Everything work out well little under 1000k. VCDS is the magic tool. The Ross Tech Forum is awesome. Thank you for your support and prompt responces!
Dr Sheldon
Windsor UK
C?ID=334979
Does not surprise me !!
RossTechLG
Naperville, USA
C?ID=607138
I surprised me with a frustration after driving the vehicle for like one week (about 7-10 days) without any mileage count down
Yesterday, same "No start in 35 miles" came back again. So, I drove the vehicle in the highway for about 10-15 minutes at about 75-80 mph speed. But it says "No start in 15 miles"
What do you think? why it started again from the same mile of 35 even after drying for about 200 miles during last 7-10 days.
Thank you!
Dr Sheldon
Windsor UK
C?ID=334979
Thank you!
Dont know - That is strange !!
Can we see a fresh Scan ?
RossTechLG
Naperville, USA
C?ID=607138
Here is the fresh scan I just took.
Sunday,23,March,2025,15:46:23:09215
VCDS Version: 25.3.0.4 (x64)  HEX-V2 CB: 0.4660.5
Data version: 20250311 DS365.0
Mileage: 207790km-129114mi   Repair Order:
VIN: WA1WMAFE7CD000804   Mileage: 207790km-129114miles
   VCID: 61987AFB91CB95F2E09-8034
31037 - NOx Sensor 1 Bank 1
          P2203 00 [01101000] - Signal too High
                    Fault Frequency: 9
                    Mileage: 207602 km
                    Date: 2011.07.18
                    Time: 18:23:11
                    Engine speed: 1361.00 /min
                    Normed load value: 36.5 %
                    Vehicle speed: 68 km/h
                    Coolant temperature: 87  C
                    Intake air temperature: 12  C
                    Voltage terminal 30: 14.640 V
                    Accelerator pedal travel: 7.68 %
                    Accelerator pedal: sensor voltage 1: 1104.4 mV
                    Accelerator pedal: sensor voltage 2: 542.4 mV
                    Accelerator pedal: switch positions-Bits 0-7: 0
                    Starter control: Interlock- or P/N-signal-Bits 0-7: 0
                    Limitation: torque: 152.9 Nm
                    Control Module temperature: 31.5  C
9954 - NOx Reductant Consumption too Low
          P20F4 00 [10101111] - -
                    Mileage: 207764 km
                    Date: 2011.07.24
                    Time: 14:30:38
                    Engine speed: 780.50 /min
                    Normed load value: 28.2 %
                    Coolant temperature: 86  C
                    Intake air temperature: 20  C
                    Voltage terminal 30: 14.620 V
                    Long-term adaptation of reduction agent dosage: 1.81
                    Measured NOx conversion range 1: 0.000
                    Efficiency threshold of NOx conversion range 1: 0.000
                    Mean temperature of SCR catalyst: 237.5  C
                    NOx sensor 1: NOx concentration: 482 ppm
                    NOx sensor 2: NOx concentration: 558 ppm
9567 - NOx Sensor 2 Bank 1
          P229F 00 [01100101] - Implausible Signal
                    Mileage: 207795 km
                    Date: 2011.07.25
                    Time: 11:37:04
                    Engine speed: 1050.50 /min
                    Normed load value: 4.7 %
                    Vehicle speed: 53 km/h
                    Voltage terminal 30: 14.660 V
                    NOx sensor 2: feed voltage: 14080 mV
                    EGR Solen.val.: actual value: 14.82 %
                    Air mass to enable NOx sensor 2 offset test: 371.7 g
                    Exh r N Ox Pres Comp No Cat2 Ds: 240 ppm
                    Measured NOx conversion: 0.000
                    NOx sensor 2: NOx concentration: 240 ppm
                    Target value of heating temperature of NOx sensor 2-Bits 0-7: 1
9690 - Sensor for NOx (G295)
          P1032 00 [11101101] - Signal too High
          [Sensor for NOXSignal too high]
                    Mileage: 207633 km
                    Date: 2011.07.20
                    Time: 13:04:43
                    Engine speed: 1389.00 /min
                    Normed load value: 62.0 %
                    Vehicle speed: 69 km/h
                    Intake air temperature: 26  C
                    Air mass: actual value (mg/stroke): 278.7 mg/stroke
                    EGR Vacuum Regulator Solen.val.: activation: 57.54 %
                    NOx Emission NOx-Sensor 2: 403 ppm
                    NOx Emission NOx Sensor: 1789 ppm
                    Mean injection quantity: 12.56 mg/stroke
                    Exhaust gas temperature sensor 1: 387.2  C
9953 - Reductant Quality Performance
          P207F 00 [11101101] - -
                    Mileage: 207764 km
                    Date: 2011.07.24
                    Time: 14:30:38
                    Engine speed: 781.00 /min
                    NOx sensor 1: NOx concentration: 468 ppm
Readiness: 1 4 0 1 0
Dr Sheldon
Windsor UK
C?ID=334979
There are 5 faults in there to help and guide.
That one jumped off the screen at me !!
Not sure what it is telling me ? Is it not liking the Quality of the AdBlue ??
I would not move on until this was resolved !!
Intermittent - Confirmed - Tested Since Memory Clea
These 3 point at faulty Nox sensors - They are expensive and I would be a bit slow pulling the trigger on them !!
Pump - Pressure - Injector - Blockage ?
That needs some research ? I guess it knows from the tank level sensor how much Reductant has been used ? It will have a formula to calculate what should have been used.
RossTechLG
Naperville, USA
C?ID=607138
Yes can be the quality of adblue solution that I purcased online from USP. The brand is "Febi Bilstein Diesel Exhaust Fluid".
I had filled it with galoons of Audi addble solution. since that was not enough to top it off I added about 1.5 L of Febi adblue solution. Maybe, That caused all of these issues. Because I zero number of fault code when it was fixed last time. I ahd repplaced both injector and pump.
At the same time, on my Cayenne Porsche gave me a warning that said "Check Perticulate Filter" - maybe because I added that remailning amount of Febi adblue into that Cayenne. But it went away after dryving few mile. Not sure wheather it wil come back or not again. Very sad if that is the case.
However, what should I do, Shoudl I drain all the addblue off of the vehicle and refill with adblue from Audi?
Meh. Personally, I would not pay the Audi markup for a fluid that is completely standardized. Buy some "Blue DEF" in the 2.5 gallon "cube" or even get 2.5 gallon "Super Tech" DEF from Walmart (in my experience the least expensive packaged DEF). The catch with it is the shelf life. Learn to read the date codes and make sure it's fresh (no more than one year old). The stuff does degrade, and the rate of degradation increases with temperature.
Dr Sheldon
Windsor UK
C?ID=334979
I would want evidence, well my customer deserves that, so I would use a refractometer to confirm or condemn the AdBlue quality.
Refractometers - Good ones are not cheap so you may not go down that road.
As for buying online, that is a dangerous game now !! God knows what counterfeit shit they sent you. So yes drain it out and fill fresh with good stuff !!
RossTechLG
Naperville, USA
C?ID=607138
Yes! I think it is better to have a good refractometer any ways to check right DEF parameter any kind of DEF fluid before pour it in.
1. Is there a specific value of reading via refractometer defined for Audis or it is standard value reading across European diesel vehicles?
2. what is the good refractometer that you would recommend?
3. Where should DEF be drained from in Q7 2012? is it from the active DEF tank under the vehicle where the DEF pump was replaced? is there any easy method to do that?
Thank you!
Dr Sheldon
Windsor UK
C?ID=334979
1. Ad Blue is standard across all VM's
2. Sealey - Facom
3. Lowest point - Remove tank ! We DO NOT need an EASY METHOD - We use the best effective method !!
RossTechLG
Naperville, USA
C?ID=607138
Good morning!
I drained all Adblue solution and filled with Audi's Adblue. But two DTCs still there with new one on Nox Sensor 1 with remaining 15 miles to drive. very frustrated what to do?
Here is the new scan results that was done doe today.
Sunday,06,April,2025,12:53:34:09215
                    Mileage: 207799 km
                    Date: 2011.08.07
                    Time: 18:35:14
                    Engine speed: 0.00 /min
                    Coolant temperature: 81 °C
                    Intake air temperature: 45 °C
                    Voltage terminal 30: 12.120 V
                    Long-term adaptation of reduction agent dosage: 2.49
                    Mean temperature of SCR catalyst: 49.9 °C
                    NOx sensor 1: NOx concentration: 0 ppm
                    NOx sensor 2: NOx concentration: 0 ppm
9879 - Sense Circuit for Heater for NOx Sensor 1 Bank 1
          P2209 00 [01100101] - Implausible Signal
                    Mileage: 207799 km
                    Date: 2011.08.08
                    Time: 11:00:35
                    Engine speed: 779.00 /min
                    Normed load value: 27.5 %
                    Coolant temperature: 50 °C
                    Intake air temperature: 18 °C
                    Voltage terminal 30: 14.520 V
                    NOx sensor 1: NOx concentration: 1111 ppm
                    Target value of heating temperature of NOx sensor 2-Bits 0-7: 0
                    NOx sensor 2: feed voltage: 0 mV
                    NOx sensor 1: feed voltage: 13760 mV
                    Outside temperature: 13.5 °C
                    Mean injection quantity: 6.96 mg/stroke
          P207F 00 [01100101] - -
                    Mileage: 207799 km
                    Date: 2011.08.07
                    Time: 18:35:14
Readiness: 1 1 0 1 1
   Coding: 001378
   VCID: 3C26EB8F56E9981A93F-8068
   Revision: 00H02001
   Coding: 0099473
   VCID: 3436C3AF7239505A5BF-8060
                    Reset counter: 243
                    Mileage: 207588 km
                    Date: 2011.06.30
                    Time: 02:40:36
                    Count: 64
                    Count: 2113
                    Count: 128
                    Count: 34048
                    Reset counter: 245
                    Mileage: 207588 km
                    Date: 2011.05.09
                    Time: 02:50:23
                    Count: 128
                    Count: 8517
                    Count: 297
                    Count: 50688
   Coding: 0000143
   VCID: 25102EEBC9E339D2DC1-8070
                    Reset counter: 199
                    Mileage: 207588 km
                    Date: 2011.05.11
                    Time: 04:19:32
                    Reset counter: 199
                    Mileage: 207588 km
                    Date: 2011.05.11
                    Time: 04:19:32
                    Reset counter: 239
                    Mileage: 207588 km
                    Date: 2011.06.30
                    Time: 02:43:42
                    Fault Frequency: 8
                    Reset counter: 239
                    Mileage: 207588 km
                    Date: 2011.06.30
                    Time: 02:40:34
00955 - Key 1
                    Mileage: 207589 km
                    Date: 2011.07.14
                    Time: 19:33:45
                    Reset counter: 239
                    Mileage: 207588 km
                    Date: 2011.07.07
                    Time: 09:05:47
   Coding: 0004A036
   VCID: 25102EEBC5E339D2DC1-8070
   Coding: 070000
   Subsystem 2 - Part No SW: 8K0 959 772 D    HW: 8K0 959 772
   Serial number:           0006183307
   Coding: 070000
                    Reset counter: 246
                    Mileage: 207588 km
                    Date: 2011.07.14
                    Time: 17:38:57
   Coding: 0133123
   VCID: 6E8211C75C953A8A6DB-803A
   Coding: 00064792
   Shop #: WSC 31414
   Coding: 00150059
   Shop #: WSC 31414
                    Reset counter: 239
                    Mileage: 207588 km
                    Date: 2011.06.30
                    Time: 02:43:00
                    Reset counter: 239
                    Mileage: 207588 km
                    Date: 2011.06.30
                    Time: 02:43:00
   Coding: 0014131
   VCID: 2B04D8D3AF070FA20A5-807E
   Coding: 0012142
   VCID: 280E27DFBEF124BAE77-807C
                    Reset counter: 239
                    Mileage: 207588 km
                    Date: 2011.06.30
                    Time: 02:42:30
                    Reset counter: 239
                    Mileage: 207588 km
                    Date: 2011.06.30
                    Time: 02:49:27
   VCID: 42DA9577348DEEEAD93-8016
   Coding: 00C303
   VCID: 3D20E68B4D739112A41-8068
                    Fault Frequency: 11
                    Reset counter: 239
                    Mileage: 207588 km
                    Date: 2011.05.25
                    Time: 11:47:00
                    Bin. Bits:    00000
                    Voltage: 11.70 V
                    Count: 18
                    Reset counter: 239
                    Mileage: 207588 km
                    Date: 2011.06.30
                    Time: 02:49:07
                    Bin. Bits:    00000
                    Voltage: 7.20 V
                    Count: 12
   Coding: 0000006
   VCID: 688E67DF7E71E4BA277-803C
                    Reset counter: 202
                    Mileage: 207588 km
                    Date: 2011.05.09
                    Time: 02:47:37
                    Reset counter: 246
                    Mileage: 207588 km
                    Date: 2011.05.09
                    Time: 02:47:37
                    Reset counter: 239
                    Mileage: 207588 km
                    Date: 2011.06.30
                    Time: 02:20:45
                    Voltage: 9.00 V
02885 - Potentiometer on Motor for Upper Body Vent; Rear Right (G522)
                    Fault Status: 00101010
                    Reset counter: 251
                    Mileage: 207679 km
                    Date: 2011.07.23
                    Time: 05:10:46
                    Voltage: 13.20 V
                    (no units): 232.0
                    (no units): 255.0
   VCID: 323AC5B7842D5E6A493-8066
                    Reset counter: 239
                    Mileage: 207588 km
                    Date: 2011.06.30
                    Time: 02:44:37
                    Reset counter: 239
                    Mileage: 207588 km
                    Date: 2011.06.30
                    Time: 02:58:03
   Coding: 0010001
   VCID: 2E02D1C79C157A8A2DB-807A
   Subsystem 3 - Serial number: 5F09.06.1100H010003C910071ÿ
   Subsystem 4 - Serial number: 910071ÿ
   VCID: 48CE875F12B1C4BA077-801C
                    Reset counter: 239
                    Mileage: 207588 km
                    Date: 2011.06.30
                    Time: 02:42:31
                    Reset counter: 239
                    Mileage: 207588 km
                    Date: 2011.06.30
                    Time: 02:49:08
                    Reset counter: 239
                    Mileage: 207588 km
                    Date: 2011.07.07
                    Time: 09:05:53
   Coding: 3569693
   VCID: 3530FEAB794349526C1-8060
                    Reset counter: 239
                    Mileage: 207588 km
                    Date: 2011.06.30
                    Time: 02:53:13
   Coding: 030000
   VCID: 270C24E3BFEF2BC2EED-8072
   Coding: 0758477
   VCID: 231430F3C7D7C7E2B25-8076
                    Reset counter: 246
                    Mileage: 207588 km
                    Date: 2011.05.09
                    Time: 02:50:50
                    Hex Value: 0x00F4
                    Hex Value: 0x0000
                    Hex Value: 0x0005
                    Voltage: 14.10 V
                    Temperature: -1.0°C
                    (no units): 0.0
                    Reset counter: 243
                    Mileage: 207588 km
                    Date: 2011.05.09
                    Time: 02:50:51
                    Hex Value: 0x00F4
                    Hex Value: 0x0000
                    Hex Value: 0x0005
                    Voltage: 14.10 V
                    Temperature: -1.0°C
                    (no units): 0.0
                    Reset counter: 243
                    Mileage: 207588 km
                    Date: 2011.05.09
                    Time: 02:50:51
                    Hex Value: 0x00F4
                    Hex Value: 0x0000
                    Hex Value: 0x0005
                    Voltage: 14.10 V
                    Temperature: -1.0°C
                    (no units): 0.0
   Coding: 0012001
   VCID: 5EE24107AC35AA0ADDB-800A
                    Reset counter: 239
                    Mileage: 207588 km
                    Date: 2011.06.30
                    Time: 02:49:00
                    Voltage: 7.200 V
                    Temperature: 77.0°C
                    Reset counter: 239
                    Mileage: 207588 km
                    Date: 2011.06.30
                    Time: 02:42:00
                    Voltage: 7.600 V
                    Temperature: 11.0°C
                    Reset counter: 239
                    Mileage: 207588 km
                    Date: 2011.07.07
                    Time: 09:05:00
                    Voltage: 15.500 V
                    Temperature: 77.0°C
   VCID: 47CC84631FAFCBC20ED-8012
                    Reset counter: 239
                    Mileage: 207588 km
                    Date: 2011.06.30
                    Time: 02:42:31
                    Reset counter: 2
                    Mileage: 207799 km
                    Date: 2011.07.31
                    Time: 09:24:16
   Coding: 0000031
                    Reset counter: 199
                    Mileage: 207588 km
                    Date: 2011.06.30
                    Time: 02:40:35
   VCID: 1F1C3C03E7BFE30296D-804A
                    Reset counter: 239
                    Mileage: 207588 km
                    Date: 2011.06.30
                    Time: 02:49:18
                    Voltage: 7.30 V
                    Reset counter: 239
                    Mileage: 207588 km
                    Date: 2011.06.30
                    Time: 02:42:54
                    Voltage: 9.00 V
   VCID: 6B8418D36387CFA24A5-803E
                    Reset counter: 239
                    Mileage: 207588 km
                    Date: 2011.06.30
                    Time: 02:49:08
                    Voltage: 7.40 V
02244 - Button in Control Head is Stuck
                    Reset counter: 205
                    Mileage: 207608 km
                    Date: 2011.07.18
                    Time: 18:54:42
                    Voltage: 13.90 V
                    Hex Value: 0x0018
                        not available
                    Reset counter: 239
                    Mileage: 207588 km
                    Date: 2011.06.30
                    Time: 02:42:56
                    Voltage: 9.00 V
   VCID: 46D2896718A5D2CAF5B-8012
                    Reset counter: 239
                    Mileage: 207588 km
                    Date: 2011.06.30
                    Time: 02:42:31
                    Reset counter: 239
                    Mileage: 207588 km
                    Date: 2011.06.30
                    Time: 02:58:52
                    Reset counter: 239
                    Mileage: 207588 km
                    Date: 2011.07.07
                    Time: 09:05:52
   VCID: 3138CABB812B6572309-8064
                    Reset counter: 239
   Coding: 1030301
                    Fault Frequency: 8
                    Reset counter: 239
                    Mileage: 207588 km
                    Date: 2011.06.30
                    Time: 02:41:18
                        Reverse OFF
                    Count: 3
                    Reset counter: 239
                    Mileage: 207588 km
                    Date: 2011.06.30
                    Time: 02:48:09
                        Reverse OFF
                    Count: 3
   VCID: 6C861BCF6A89C89A43F-8038
   Subsystem 3 - Serial number: RD15.06.11--H56001001B0206ÿ
   Subsystem 4 - Serial number: 1B0206ÿ
                    Mileage: 207588 km
                    Date: 2011.06.30
                    Time: 02:49:07
   Coding: 0003595
   VCID: 261229E7B4E532CAD5B-8072
                    Fault Status: 00100101
                    Reset counter: 246
                    Mileage: 207588 km
                    Date: 2011.05.09
                    Time: 02:51:17
                    Reset counter: 239
                    Mileage: 207588 km
                    Date: 2011.06.30
                    Time: 02:43:25
                    Reset counter: 239
                    Mileage: 207588 km
                    Date: 2011.06.30
                    Time: 02:42:31
   Coding: 0231346
   VCID: 2C06DBCFAA09089A03F-8078
                    Reset counter: 199
                    Mileage: 207588 km
                    Date: 2011.05.09
                    Time: 02:51:34
                    Reset counter: 239
                    Mileage: 207588 km
                    Date: 2011.06.30
                    Time: 02:42:31
End----------(Elapsed Time: 02:29, VBatt start/end: 13.3V/14.4V)-----------
------------------------------55 Faults Found------------------------------
First of all, reset your death countdown.
Although you do have a first gen CATA, it would appear that it's a "late" version and it is a UDS controller.... so use the appropriate instructions.
Also test the SCR injector and reset the SCR adaptation.
Looks like you'll also need to replace NOx Sensor(s) in the near future.... but let's get past the death countdown for starters.
RossTechLG
Naperville, USA
C?ID=607138
Thank you for all details.
I followed your directions for 3.0L TDI Gen 1. but it does not help me to get the death countdown removed.
I also replaced the AdBlue injector (BOSCH OEM) and did the reductant quantity measurement test. I got around 16 ml of AdBlue solution in the container. It is a new OEM injector and new OEM AdBlue pump. Adaptation of those and tank level detection procedure also completed with '"OK"
I saw your recommendation for S34 fuse removal test for VW Touareg TDI. I just check my Audi Q7 in all Fuse boxes but could not find S34 fuse. So, if we do the same test/procedure for the Q&, what fuse number that we would need to look at in Q7?
Or is there any way to get this death countdown removed?
Here are the final scan results with 3 fault codes for the engine/AdBlue system.
Friday,11,April,2025,19:00:05:09215
VCDS Version: 25.3.1.0 (x64)  HEX-V2 CB: 0.4671.5
Data version: 20250408 DS365.0
   VCID: 61987AFB91CB95F2E05-8034
                    Mileage: 207799 km
                    Date: 2011.08.07
                    Time: 18:35:14
                    Coolant temperature: 81  C
                    Intake air temperature: 45  C
                    Mean temperature of SCR catalyst: 49.9  C
          P2209 00 [11101101] - Implausible Signal
                    Mileage: 207799 km
                    Date: 2011.08.08
                    Time: 11:00:35
                    Coolant temperature: 50  C
                    Intake air temperature: 18  C
                    Outside temperature: 13.5  C
                    Mileage: 207799 km
                    Date: 2011.08.07
                    Time: 18:35:14
Readiness: 1 2 0 1 1
JMR
Romania
C?ID=432218
I have a story to tell : had an issurance repair shop call me to verify and diagnose a Q5 after a rear bumper accident , they changed the ad blue tank ( it had a small puncture somewhere on the neck of the tank from the accident ( which by all acounts it could ve been repaired but..they preffered to bill about 3000 euros for a new tank and installation .... .) , with a new one , all hell broke loose. So , i went , they had errors on SCR system. Verified electrical connectors / wireing loom , no dice. When i would plug in the old tank , all was well , with the new tank , full , it wont see level and temperature . So...they took it to the dealer and they updated the ecu and scr system , all good. So , this information i got back from the shop , thought i d share it.
  • Informative
I followed your directions for 3.0L TDI Gen 1.]
Not my directions so I won't take credit, and as I've already said above, you have a UDS controller so you're following the directions for the wrong thing. Use the appropriate directions. Confirm your controller type by seeing what VCDS is reporting.
RossTechLG
Naperville, USA
C?ID=607138
Sorry! I kind a lost with what you are saying.
what is my controller type? do you see it in the results of the scan above? Could you please tell me step wise procedure that I should follow to correct the death count via VCDS scanner?
I really appreciate it!
