18 VW Atlas VR6 4Motion ACC / Lane assist error
striper405
NYC, USA
C?ID=376645
Hi all having an error with ACC / Lane assist started up in the AM and came on right away. I have this scan I did dont lnow how to send it properly but this is it. The front sensor is clean I am thinking its the camera on the rearview.
VCDSWindows Based VAG/VAS Emulator Running on Windows 10 x64VCDS Version: Release 25.3.0(x64) Data version: 20250301 DS365.0www.Ross-Tech.comDealer/Shop Name: Workshop Code: 000 00000 000000Self-Diagnosis LogSunday,16,March,2025,16:22:42:13904VIN: 1V2LR2CA7JC535134 License Plate: DADMileage: 121431km-75453mi Repair Order: Chassis Type: CA-VW41 (3Q0)Scan: 01 02 03 05 08 09 13 15 16 17 19 22 2B 3C 42 44 4B 52 5F 6C 6D 75 A5 D6 D7VIN: 1V2LR2CA7JC535134 Mileage: 121431km-75453miles01-Engine -- Status: OK 000002-Auto Trans -- Status: OK 000003-ABS Brakes -- Status: Malfunction 001005-Acc/Start Auth. -- Status: OK 000008-Auto HVAC -- Status: OK 000009-Cent. Elect. -- Status: OK 000013-Auto Dist. Reg -- Status: Malfunction 001015-Airbags -- Status: OK 000016-Steering wheel -- Status: OK 000017-Instruments -- Status: OK 000019-CAN Gateway -- Status: OK 000022-AWD -- Status: OK 00002B-Steer. Col. Lock -- Status: OK 00003C-Lane Change -- Status: OK 000042-Door Elect, Driver -- Status: Malfunction 001044-Steering Assist -- Status: OK 00004B-Multifunc. Module -- Status: OK 000052-Door Elect, Pass. -- Status: Malfunction 00105F-Information Electr. -- Status: OK 00006C-Back-up Cam. -- Status: OK 00006D-Trunk Elect. -- Status: OK 000075-Telematics -- Status: OK 0000A5-Frt Sens. Drv. Assist -- Status: Malfunction 0010D6-Light Ctrl Left 2 -- Status: OK 0000D7-Light Ctrl Right 2 -- Status: OK 0000-------------------------------------------------------------------------------VCDSSelf-Diagnosis LogSunday,16,March,2025,16:22:42:13904Page 2VIN: 1V2LR2CA7JC535134 License Plate: DADAddress 01: Engine (J623-CDVC) Labels:. 03H-907-309-V1.clb Part No SW: 03H 906 026 F HW: 03H 907 309 K Component: VR6 3.6l FSI H21 9970 Revision: 52H21000 CVN: 4FBCC745 Coding: 012A001244640108F0000000000000000000000000000000 Shop #: WSC 08381 444 00000 ASAM Dataset: EV_ECM36FSI01103H906026F 001009 ROD: EV_ECM36FSI01103H906026E.rod VCID: 2809F8CCF2707E4AE70-807C VINID: 06609C8824D11DA4C50C5043104CE4D722 Center armrest control head 1: 15 Faults Found:42451 - Voltage Supply 1 for Control Module U3501 00 [01100000] - Too Low Intermittent - Not Confirmed - Tested Since Memory Clear42450 - Voltage Supply 1 for Control Module U3501 00 [01100000] - Too Low Intermittent - Not Confirmed - Tested Since Memory Clear17156 - Databus U1123 00 [00100000] - Received Error Message Intermittent - Not Confirmed - Tested Since Memory Clear17158 - Implausible Data Received from ESP Control Module U0416 00 [00100000] - - Intermittent - Not Confirmed - Tested Since Memory Clear20558 - Heater Support Pump P16C6 00 [00100000] - Running Dry [Heater support pumpDry run] Intermittent - Not Confirmed - Tested Since Memory Clear4675 - Implausible Data Received from ABS Control Module U0415 00 [00100000] - - [Invalid Data Received FromAnti-Lock Brake System Control Module] Intermittent - Not Confirmed - Tested Since Memory Clear4714 - Steering Column Control Module U0212 00 [00100000] - No Communications Intermittent - Not Confirmed - Tested Since Memory Clear10540 - Camshaft Adj. Bank 1 Intake P052A 00 [01100000] - Cold-Start Timing not Reached Intermittent - Not Confirmed - Tested Since Memory Clear10203 - Random/Multiple Cylinder Misfire Detected P0300 00 [00100000] - - Intermittent - Not Confirmed - Tested Since Memory ClearVCDSSelf-Diagnosis LogSunday,16,March,2025,16:22:42:13904Page 3VIN: 1V2LR2CA7JC535134 License Plate: DAD10595 - Cylinder 5 P0305 00 [00100000] - Misfire Detected Intermittent - Not Confirmed - Tested Since Memory Clear10593 - Cylinder 3 P0303 00 [00100000] - Misfire Detected Intermittent - Not Confirmed - Tested Since Memory Clear10596 - Cylinder 6 P0306 00 [00100000] - Misfire Detected Intermittent - Not Confirmed - Tested Since Memory Clear10592 - Cylinder 2 P0302 00 [00100000] - Misfire Detected Intermittent - Not Confirmed - Tested Since Memory Clear37073 - Engine Misfires Detected on Startup (First 1000 Revolutions) P0316 00 [00100000] - - Intermittent - Not Confirmed - Tested Since Memory Clear37682 - Internal Control Module P060C 00 [00100000] - Main Processor Performance Intermittent - Not Confirmed - Tested Since Memory ClearReadiness: 0000 0000------------------------------------------------------------------------------- Address 02: Auto Trans (J217) Labels: 09P-927-749-V1.clb Part No SW: 09G 927 158 A HW: 09G 927 158 Component: AISIN AQ8 206 3387 CVN: 52C19C90 Coding: 0000000100000000000000000000000000000000 Shop #: WSC 09003 957 00200 ASAM Dataset: EV_TCMAQ450031 001001 ROD: EV_TCMAQ450031_VW37.rod VCID: 313F15A8C1AA3F8230E-80642 Faults Found:28267 - No Communications with Control Module for Electric Steering Column Lock U0236 00 [00100000] - - Intermittent - Not Confirmed - Tested Since Memory Clear25554 - Implausible Data Received from ABS Control Module U0415 00 [00100000] - - Intermittent - Not Confirmed - Tested Since Memory Clear-------------------------------------------------------------------------------VCDSSelf-Diagnosis LogSunday,16,March,2025,16:22:42:13904Page 4VIN: 1V2LR2CA7JC535134 License Plate: DADAddress 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb Part No SW: 5Q0 614 517 CF HW: 5Q0 614 517 AD Component: ESC H25 0513 Revision: 00000000 Serial number: 52737000000481 Coding: 44FC6B8D84231A71C5780303A2C76922D62158A3C045967E18415058C2AA4200002F641C12141A118DDB45506CC8CF Shop #: WSC 09003 957 00200 ASAM Dataset: EV_Brake1UDSContiMK100IPB 036010 ROD: EV_Brake1UDSContiMK100IPB_036_VW37.rod VCID: 77ABEBB06F4E21B2BEA-80225 Faults Found:32830 - Parking Brake Motors C10E1 29 [00001000] - Signal Implausible [IPB-Actuator: Actuator state UNKNOWN] Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 2 Fault Frequency: 1 Reset counter: 120 Mileage: 79238 km32837 - Lamp in Switch for Electronic Parking Brake C1145 13 [00001000] - Open Circuit Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 2 Fault Frequency: 1 Reset counter: 40 Mileage: 112320 km Date: 2024.10.29 Time: 16:20:1032900 - Left Parking Brake Motor Voltage Supply C100D 13 [00001000] - Electrical Malfunction Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 2 Fault Frequency: 1 Reset counter: 120 Mileage: 79238 km Date: 2022.10.06 Time: 16:50:2032901 - Right Parking Brake Motor Voltage Supply C100E 13 [00001000] - Electrical Malfunction Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 2 Fault Frequency: 1 Reset counter: 120 Mileage: 79238 km Date: 2022.10.06VCDSSelf-Diagnosis LogSunday,16,March,2025,16:22:42:13904Page 5VIN: 1V2LR2CA7JC535134 License Plate: DAD Time: 17:17:5432930 - Supply voltage U1011 00 [00001000] - Voltage too Low [IPB: Supply Voltage below low voltage threshold] Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 2 Fault Frequency: 1 Reset counter: 100 Mileage: 103724 km Date: 2024.03.06 Time: 12:04:06------------------------------------------------------------------------------- Address 05: Acc/Start Auth. (J518) Labels:| 5Q0-959-435.clb Part No SW: 3Q0 959 435 G HW: 3Q0 959 435 G Component: VWKESSYMQB 037 0906 Revision: 00037000 Serial number: 0453629999 Dataset Number: V03935266PW 0001 Coding: 1F20000723 Shop #: WSC 09003 957 00200 ASAM Dataset: EV_KessyHellaMQBAB 004041 ROD: EV_KessyHellaMQBAB_004_VW37.rod VCID: 3E253E9400F4D0FABDC-806A Rear lid opener control module: No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels:| 5G0-907-044.clb Part No SW: 3CN 907 044 G HW: 3CN 907 044 G Component: Climatronic H04 2009 Revision: 00001K01 Coding: 1602060620001C00110421001210140C Shop #: WSC 65108 002 1048576 ASAM Dataset: EV_ACClimaBHBVW416 002012 ROD: EV_ACClimaBHBVW416.rod VCID: 43D34F606B16BD12D22-8016 Fresh air blower control module (front): Fresh air blower control module (rear): A/C pressure/coolant temperature sensor: No fault code found. -------------------------------------------------------------------------------VCDSSelf-Diagnosis LogSunday,16,March,2025,16:22:42:13904Page 6VIN: 1V2LR2CA7JC535134 License Plate: DADAddress 09: Cent. Elect. (J519) Labels:. 5Q0-937-08X-V2.clb Part No SW: 5Q0 937 085 BN HW: 5Q0 937 085 BF Component: BCM MQBAB MNA H36 0253 Serial number: 7265021301ÿÿÿÿ Dataset Number: V03935268H0001 Coding: 000000000000000000000000000000000000000000000000000000000000 Shop #: WSC 09003 957 00200 ASAM Dataset: EV_BCMMQB 018001 ROD: EV_BCMBOSCH_018.rod VCID: 0655967418A4483AB5C-8052 Rain/Light Recognition Sensor: Subsystem 1 - Part No SW: 5Q0 955 555 HW: 5Q0 955 555 Component: RLHSS 046 0120 Serial number: S6Y17M09D20H12M23S25 Coding: 00382DNo fault code found. ------------------------------------------------------------------------------- Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V2.clb Part No SW: 5Q0 907 572 J HW: 3QF 907 572 Component: ACC BOSCH MQB H10 0654 Dataset Number: V03935261LE 0001 Coding: 320007C111FFC728949C810530401600000000000000000000 Shop #: WSC 09003 957 00200 ASAM Dataset: EV_ACCBOSCHVW416 002006 ROD: EV_ACCBOSCHVW416_002_VW41.rod VCID: 3E253E9400F4D0FABDC-806A1 Fault Found:0803 - Databus U1123 00 [00001001] - Received Error Message [FAULT_BV1_FEHLER] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 4 Fault Frequency: 14 Reset counter: 54 Mileage: 119431 km Date: 2025.03.14 Time: 05:15:54 Control Module temperature: 31 °C Voltage terminal 15: 13.1 V Velocity_vehicle_reference: 22.33 m/s Longitudinal_acceleration_vehicle_reference: 0.15 m/s² Status_ACC_System: ACC_StandBy-------------------------------------------------------------------------------VCDSSelf-Diagnosis LogSunday,16,March,2025,16:22:42:13904Page 7VIN: 1V2LR2CA7JC535134 License Plate: DADAddress 15: Airbags (J234) Labels:| 5Q0-959-655.clb Part No SW: 3Q0 959 655 BN HW: 3Q0 959 655 BN Component: Airbag VW21 006 0713 Revision: -------- Serial number: 003SUMGEXQAA Dataset Number: V03935267DH 0001 Coding: 8CCCDC00000000005000001A420800000065 Shop #: WSC 131071 1023 2097151 ASAM Dataset: EV_AirbaVW21TS6VW48X 001014 ROD: EV_AirbaVW21TS6VW48X_VW37.rod VCID: 0B43A74003C63552EA2-805E Seat occupied recognition passenger side: Subsystem 1 - Part No SW: 4M0 959 339 B HW: 4M0 959 339 B Component: Occ.Detection H13 0022 Serial number: IBH0000J170007SO6U0$ Coding: 303030 Crash sensor for side airbag: driver side: Subsystem 2 - Part No SW: ----------- HW: 454 001 008 17 Component: SideSensor_Df 008 0887 Serial number: 35700000000D52F4982U Coding: 2D2D2D Crash sensor for side airbag: passenger side: Subsystem 3 - Part No SW: ----------- HW: 454 001 008 17 Component: SideSensor_Pf 008 0887 Serial number: 3580000000068B51462G Coding: 2D2D2D Rear Side Airbag Crash Sensor (on driver's side): Subsystem 4 - Part No SW: ----------- HW: 454 802 208 17 Component: SideSensor_Dr 301 0148 Serial number: 351007B6EDD11000000W Coding: 2D2D2D Passenger side rear thorax airbag crash sensor: Subsystem 5 - Part No SW: ----------- HW: 454 802 208 17 Component: SideSensor_Pr 301 0148 Serial number: 35200B4EBDE11000000- Coding: 2D2D2D Crash sensor for front airbag: driver side: Subsystem 6 - Part No SW: ----------- HW: 454 802 208 17 Component: FrontSensor_D 304 0149 Serial number: 35500F98C8410000000R Coding: 2D2D2D Crash sensor for front airbag: passenger side: Subsystem 7 - Part No SW: ----------- HW: 454 802 208 17 Component: FrontSensor_P 304 0149 Serial number: 35600DBE2C710000000V Coding: 2D2D2DVCDSSelf-Diagnosis LogSunday,16,March,2025,16:22:42:13904Page 8VIN: 1V2LR2CA7JC535134 License Plate: DADNo fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel (J527) Labels:| 5Q0-953-549.clb Part No SW: 5Q0 953 507 HN HW: 5Q0 953 549 E Component: Lenks. Modul 003 0140 Revision: -------- Serial number: 23091708490119 Coding: 0C10 Shop #: WSC 09003 957 00200 ASAM Dataset: EV_SMLSKLOMQB 020002 ROD: EV_SMLSKLOMQB_018_VW37.rod VCID: 094F9D4809BA2742D8E-805CNo fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3 Part No SW: 3CN 920 850 A HW: 3CN 920 850 A Component: KOMBI 370 0310 Coding: 0BA4171DEF88CF0502886B0B50000000A0000000 Shop #: WSC 65108 002 1048576 ASAM Dataset: EV_DashBoardVDDMQBAB 009060 ROD: EV_DashBoardVDDMQBAB_009_VW26.rod VCID: 3D2739980DF2CBE2A46-8068No fault code found. -------------------------------------------------------------------------------VCDSSelf-Diagnosis LogSunday,16,March,2025,16:22:42:13904Page 9VIN: 1V2LR2CA7JC535134 License Plate: DADAddress 19: CAN Gateway (J533) Labels:| 3Q0-907-530-V1.clb Part No SW: 3Q0 907 530 G HW: 3Q0 907 530 C Component: GW MQB High 518 5304 Serial number: 18091700841811 Dataset Number: V03935269GD 0001 Coding: 030500347F087300FB0322581E0F00010001070000000000000000000000 Shop #: WSC 09003 957 00200 GVL: 01D23C000800060040CC80008002C80000000000000200000000000000000000 ASAM Dataset: EV_GatewNF 013023 ROD: EV_GatewNF_VW41.rod VCID: 33331FA03BB60D92422-8066 Generator: Multifunction steering wheel control module: Subsystem 2 - Part No SW: 5G0 959 442 R HW: 5G0 959 442 R Labels: 3C8-959-537.CLB Component: E221__MFL-DC1 H17 0040 Serial number: 33170001906430121439 Coding: 34FFFF Battery Monitoring Control Module: Subsystem 3 - Part No SW: 5QA 915 181 D HW: 5QA 915 181 D Component: J367-BDMHella H10 9070 Serial number: 4857814404 No fault code found. ------------------------------------------------------------------------------- Address 22: AWD (J492) Labels:| 0CQ-907-554-V1.clb Part No SW: 0CQ 907 554 H HW: 0CQ 525 130 Component: Haldex4Motion H52 7083 Serial number: HA1-00001.08.17 Dataset Number: v1260x015G0 0000 Coding: 0301 Shop #: WSC 09003 957 00200 ASAM Dataset: EV_AllWheelContrHA1VW37X 004013 ROD: EV_AllWheelContrHA1VW37X_004_VW41.rod VCID: 4ACD62444C3C6C5A114-801ENo fault code found. -------------------------------------------------------------------------------VCDSSelf-Diagnosis LogSunday,16,March,2025,16:22:42:13904Page 10VIN: 1V2LR2CA7JC535134 License Plate: DADAddress 2B: Steer. Col. Lock (J764) Labels:| 1EA-905-861.clb Part No SW: 3Q0 905 861 HW: 3Q0 905 861 Component: ELV-MQBB H05 0032 Serial number: 17000210033018 Coding: 0800000000000000 Shop #: WSC 09003 957 00200 ASAM Dataset: EV_ELVMarquMQBB 001007 ROD: EV_ELVMarquMQBB_VW41.rod VCID: 71BFD5A8012A7F8270E-8024No fault code found. ------------------------------------------------------------------------------- Address 3C: Lane Change (J1086) Labels:| 5Q0-907-686.clb Part No SW: 5Q0 907 686 C HW: 5Q0 907 686 C Component: HRE_Master H12 0080 Serial number: 0453177511 Dataset Number: V03935256RC 0001 Coding: 01011103 Shop #: WSC 09003 957 00200 ASAM Dataset: EV_HREntryHella 001028 ROD: EV_HREntryHella_VW41.rod VCID: 3D2739980DF2CBE2A46-8068 Lane change assistance control module 2: Subsystem 1 - Part No SW: 5Q0 907 685 C HW: 5Q0 907 685 C Component: HRE_Slave H12 0080 Serial number: 0455443961 Coding: 010111No fault code found. -------------------------------------------------------------------------------VCDSSelf-Diagnosis LogSunday,16,March,2025,16:22:42:13904Page 11VIN: 1V2LR2CA7JC535134 License Plate: DADAddress 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb Part No SW: 5Q0 959 593 E HW: 5Q0 959 593 B Component: TSG FS 020 0041 Serial number: 030817A0080BO3 Dataset Number: V03935256NC 0001 Coding: 00341B200000020000000000 Shop #: WSC 09003 957 00200 ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003 ROD: EV_DCUDriveSideEWMAXKLO_VW41.rod VCID: 43D34F606B16BD12D22-8016 Rear Driver Side Door Control Module: Subsystem 1 - Part No SW: 5Q4 959 812 D HW: 5Q4 959 812 D Labels: 5QX-959-81X-V1.CLB Component: Fond FHSG DRV 007 0002 Serial number: 00000000000007079481 Coding: 0110001 Fault Found:589829 - Window Regulator; Rear Driver side B131F F5 [00001000] - Supply Voltage too Low Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 2 Fault Frequency: 1 Mileage: 103724 km Date: 2024.03.06 Time: 12:03:57------------------------------------------------------------------------------- Address 44: Steering Assist (J500) Labels:| 5Q0-909-143.clb Part No SW: 5Q0 909 143 P HW: 5Q0 909 143 E Component: MQB_PP_APA 204 2051 Revision: 00000000 Serial number: 0002024418 Dataset Number: V03935260G0001 Coding: 01000311004001 Shop #: WSC 09003 957 00200 ASAM Dataset: EV_SteerAssisVWBSMQBA 009129 ROD: EV_SteerAssisVWBSMQBA_009.rod VCID: 40D9406C7A00A60ACF0-8014No fault code found. -------------------------------------------------------------------------------VCDSSelf-Diagnosis LogSunday,16,March,2025,16:22:42:13904Page 12VIN: 1V2LR2CA7JC535134 License Plate: DADAddress 4B: Multifunc. Module (J745) Labels:| 3Q0-907-338-V1.clb Part No SW: 3Q0 907 338 HW: 3Q0 907 338 Component: FCM MQB Low 002 0286 Serial number: 18091700840742 Dataset Number: V03935262KW 0001 Coding: 000000070100135200010000000000000000000000000000000000000000 Shop #: WSC 09003 957 00200 ASAM Dataset: EV_MultiModulContiVW48X 001010 ROD: EV_MultiModulContiVW48X_001_VW41.rod VCID: 72BDDAA4042C449A894-8026No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb Part No SW: 5Q0 959 592 E HW: 5Q0 959 592 B Component: TSG BFS 020 0041 Serial number: 290717A0080503 Dataset Number: V03935256ND 0001 Coding: 003413200000020000000000 Shop #: WSC 09003 957 00200 ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003 ROD: EV_DCUPasseSideEWMAXKLO_VW41.rod VCID: 42DD4A64740CB41AD94-8016 Rear Passenger Door Control Module: Subsystem 1 - Part No SW: 5Q4 959 811 D HW: 5Q4 959 811 D Labels: 5QX-959-81X-V1.CLB Component: Fond FHSG PSG 007 0002 Serial number: 00000000000007068904 Coding: 0910001 Fault Found:589845 - Window Regulator; Front Passenger side B1320 F5 [00001000] - Supply Voltage too Low Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 2 Fault Frequency: 1 Mileage: 103724 km Date: 2024.03.06 Time: 12:04:00-------------------------------------------------------------------------------VCDSSelf-Diagnosis LogSunday,16,March,2025,16:22:42:13904Page 13VIN: 1V2LR2CA7JC535134 License Plate: DADAddress 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD2.clb Part No SW: 3Q0 035 844 B HW: 3Q0 035 844 B Component: MU-S-S-US 721 0842 Serial number: Dataset Number: V03935265CM 0001 Coding: 02140600FF00000051220001001808001F0500C40120050002 Shop #: WSC 09003 957 00200 ASAM Dataset: EV_MUStd4CDELP 001001 ROD: EV_MUStd4CDELP_VW26.rod VCID: 2E050ED4D094207A2DC-807A Display and control head 1 for information electronics: Subsystem 1 - Part No SW: 5G6 919 605 C HW: 5G6 919 605 C Component: ABT_Std-2 H50 8130 Serial number: VWZ6ZJT2465446 No fault code found. ------------------------------------------------------------------------------- Address 6C: Back-up Cam. (J772) Labels:| 5Q0-980-556.clb Part No SW: 5Q0 980 556 B HW: 5Q0 980 556 B Component: RVC Compact H12 0231 Dataset Number: V03935258VA 0001 Coding: 01150602A0002017300040 Shop #: WSC 09003 957 00200 ASAM Dataset: EV_CamSysRVRVCPANAMQBAB 006009 ROD: EV_CamSysRVRVCPANAMQBAB.rod VCID: 392F2D8819DAF7C288E-806CNo fault code found. ------------------------------------------------------------------------------- Address 6D: Trunk Elect. (J605) Labels:| 5Q0-959-107.clb Part No SW: 5Q0 959 107 L HW: 5Q0 959 107 J Component: HDSG-Modul H13 0261 Revision: -------- Serial number: ÿÿÿÿÿÿÿÿÿÿÿÿÿÿ Dataset Number: V03935260HB 0001 Coding: 0908 Shop #: WSC 09003 957 00200 ASAM Dataset: EV_DeckLidCONTIAU736 001014 ROD: EV_DeckLidCONTIAU736_VW37.rod VCID: 41DF4568710AAF02C0E-8014No fault code found. -------------------------------------------------------------------------------VCDSSelf-Diagnosis LogSunday,16,March,2025,16:22:42:13904Page 14VIN: 1V2LR2CA7JC535134 License Plate: DADAddress 75: Telematics (J949) Labels:| 5QE-035-285.clb Part No SW: 5QE 035 285 A HW: 5QE 035 285 A Component: OCULowMQBUS 009 0570 Dataset Number: V03935268PZ 0001 Coding: 02140602C2821A017F1E06020000 Shop #: WSC 09003 957 00200 ASAM Dataset: EV_OCULowMQB 001006 ROD: EV_OCULowMQB_VW32.rod VCID: 43D34F606B16BD12D22-8016No fault code found. ------------------------------------------------------------------------------- Address A5: Frt Sens. Drv. Assist (R242) Labels:| 3Q0-980-65X-A5.clb Part No SW: 3Q0 980 654 H HW: 3Q0 980 654 A Component: MQB_B_MFK H08 0272 Serial number: 29081711P14479 Dataset Number: V03935265PQ 0001 Coding: 0004010600010201002200548150490084000E200100 Shop #: WSC 09003 957 00200 ASAM Dataset: EV_MFKBoschMQBB 001001 ROD: EV_MFKBoschMQBB_001_VW27.rod VCID: 3C21349C16E8C2EA938-80681 Fault Found:0662 - Dynamic Calibration C1106 F0 [00001001] - Limit Exceeded [Online_calibration_out_of_range] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 4 Fault Frequency: 1 Reset counter: 54 Mileage: 119431 km Date: 2025.03.14 Time: 05:15:54 Control Module temperature: 23 °C Outside temperature: 17.5 °C Vehicle speed: 80.83 km/h System run time: 272.0 s Voltage terminal 15: 13.0 V mid: 00 1D Status of camera: operational Engine_Running_Info: 1 Software_Info_4: 2 Software_Info_3: 7 Software_Info_2: 2 Software_Info_1: 0-------------------------------------------------------------------------------VCDSSelf-Diagnosis LogSunday,16,March,2025,16:22:42:13904Page 15VIN: 1V2LR2CA7JC535134 License Plate: DADAddress D6: Light Ctrl Left 2 (A31) Labels: 7P5-941-591.clb Part No SW: 7P5 941 591 AA HW: 7P5 941 591 A Component: LED1L H06 0003 ASAM Dataset: EV_LED_PLUS_L_KEBODAVW416 001003 ROD: EV_LED_PLUS_L_KEBODAVW416_VW41.rod VCID: 7BA3F780536605D2DA2-802E3 Faults Found:0257 - Databus U1201 00 [01101000] - No Communications [can data bus - no communication] Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 6 Fault Frequency: 20 Reset counter: 0 Mileage: 112320 km Date: 2024.10.29 Time: 16:20:090774 - Light Bulb for Low Beam C1198 29 [00101000] - Signal Implausible Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 2 Fault Frequency: 4 Reset counter: 0 Mileage: 81467 km Date: 2022.12.26 Time: 09:59:400800 - Bulb for Low-Beam Headlamp C1198 F6 [00101000] - Over-Temp Protection Active Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 2 Fault Frequency: 26 Reset counter: 0 Mileage: 39033 km Date: 2020.10.07 Time: 13:15:48-------------------------------------------------------------------------------VCDSSelf-Diagnosis LogSunday,16,March,2025,16:22:42:13904Page 16VIN: 1V2LR2CA7JC535134 License Plate: DADAddress D7: Light Ctrl Right 2 (A27) Labels: 7P5-941-591.clb Part No SW: 7P5 941 591 AA HW: 7P5 941 591 A Component: LED1R H06 0003 ASAM Dataset: EV_LED_PLUS_R_KEBODAVW416 001003 ROD: EV_LED_PLUS_L_KEBODAVW416_VW41.rod VCID: 7BA3F780536605D2DA2-802E5 Faults Found:0257 - Databus U1201 00 [01101000] - No Communications [can data bus - no communication] Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 6 Fault Frequency: 20 Reset counter: 0 Mileage: 112320 km Date: 2024.10.29 Time: 16:20:090774 - Light Bulb for Low Beam C1198 29 [00101000] - Signal Implausible Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 2 Fault Frequency: 4 Reset counter: 0 Mileage: 81467 km Date: 2022.12.26 Time: 09:59:400787 - Light Bulb for Low Beam C1198 98 [00101000] - Component or System over Temperature Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 2 Fault Frequency: 1 Reset counter: 0 Mileage: 39935 km Date: 2020.10.10 Time: 11:06:510800 - Bulb for Low-Beam Headlamp C1198 F6 [00101000] - Over-Temp Protection Active Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 2 Fault Frequency: 34 Reset counter: 0 Mileage: 39033 km Date: 2020.10.07 Time: 13:19:27VCDSSelf-Diagnosis LogSunday,16,March,2025,16:22:42:13904Page 17VIN: 1V2LR2CA7JC535134 License Plate: DAD1121 - Voltage Supply for DRL C11B4 13 [00101000] - Open Circuit Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 2 Fault Frequency: 1 Reset counter: 0 Mileage: 103724 km Date: 2024.03.06 Time: 11:52:26End----(Elapsed Time: 02:00, VBatt start/end: 12.9V/13.0V. VIgn 10.7V)-----------------------------------34 Faults Found------------------------------
I'm not sure what you did, but it seems most or possibly all the newlines and white space are missing from the scan you posted. That makes it effectively illegible. Please open the file with Notepad, and copy & paste the contents here directly.
striper405
NYC, USA
C?ID=376645
 Dealer/Shop Name:
 Self-Diagnosis Log
          6D 75 A5 D6 D7
 Self-Diagnosis Log
 Page 2
15 Faults Found:
 17156 - Databus
 Self-Diagnosis Log
 Page 3
 10595 - Cylinder 5
 10593 - Cylinder 3
 10596 - Cylinder 6
 10592 - Cylinder 2
   CVN: 52C19C90
 Self-Diagnosis Log
 Page 4
                Reset counter: 120
                Mileage: 79238 km
                Mileage: 112320 km
                Date: 2024.10.29
                Time: 16:20:10
                Reset counter: 120
                Mileage: 79238 km
                Date: 2022.10.06
                Time: 16:50:20
                Reset counter: 120
                Mileage: 79238 km
                Date: 2022.10.06
 Self-Diagnosis Log
 Page 5
                Time: 17:17:54
                Reset counter: 100
                Mileage: 103724 km
                Date: 2024.03.06
   Coding: 1F20000723
No fault code found.------------------------------------------------------------------------------
   Revision: 00001K01
 Self-Diagnosis Log
 Page 6
   Coding: 00382D
 0803 - Databus
          [FAULT_BV1_FEHLER]
                Fault Frequency: 14
                Reset counter: 54
                Mileage: 119431 km
                Date: 2025.03.14
                Time: 05:15:54
 Self-Diagnosis Log
 Page 7
   Coding: 303030
 Self-Diagnosis Log
 Page 8
 Coding: 0C10
 Component: KOMBI
370 0310
 Self-Diagnosis Log
 Page 9
   Generator:
   Coding: 34FFFF
   Coding: 0301
 Self-Diagnosis Log
 Page 10
   Coding: 01011103
   Coding: 010111
 Self-Diagnosis Log
 Page 11
   Coding: 011000
                Mileage: 103724 km
                Date: 2024.03.06
 Self-Diagnosis Log
 Page 12
   Coding: 091000
                Mileage: 103724 km
                Date: 2024.03.06
 Self-Diagnosis Log
 Page 13
   Coding: 0908
 Self-Diagnosis Log
 Page 14
                Reset counter: 54
                Mileage: 119431 km
                Date: 2025.03.14
                Time: 05:15:54
                mid: 00 1D
                Software_Info_4: 2
                Software_Info_3: 7
                Software_Info_2: 2
 Self-Diagnosis Log
 Page 15
 0257 - Databus
                Fault Frequency: 20
                Reset counter: 0
                Mileage: 112320 km
                Date: 2024.10.29
                Time: 16:20:09
                Reset counter: 0
                Mileage: 81467 km
                Date: 2022.12.26
                Time: 09:59:40
                Fault Frequency: 26
                Reset counter: 0
                Mileage: 39033 km
                Date: 2020.10.07
 Self-Diagnosis Log
 Page 16
 0257 - Databus
                Fault Frequency: 20
                Reset counter: 0
                Mileage: 112320 km
                Date: 2024.10.29
                Time: 16:20:09
                Reset counter: 0
                Mileage: 81467 km
                Date: 2022.12.26
                Time: 09:59:40
                Reset counter: 0
                Mileage: 39935 km
                Date: 2020.10.10
                Time: 11:06:51
                Fault Frequency: 34
                Reset counter: 0
                Mileage: 39033 km
                Date: 2020.10.07
                Time: 13:19:27
 Self-Diagnosis Log
 Page 17
                Reset counter: 0
                Mileage: 103724 km
                Date: 2024.03.06
                Time: 11:52:26
Westbury, UK
@striper405 What you have done is to use the Print function in VCDS, not what Uwe asked which is to open the text file that VCDS saves in C:\Ross-Tech\VCDS\Scans in NOtepad and paste that here - it's MUCH more readable :thumbs:
striper405
NYC, USA
C?ID=376645
Ahhhhh ok, I’ll redo it today.
striper405
NYC, USA
C?ID=376645
Sunday,16,March,2025,16:22:15:13904
VCDS Version: 25.3.0.3 (x64)  HEX-V2 CB: 0.4660.4
          6D 75 A5 D6 D7
15 Faults Found:
17156 - Databus
10595 - Cylinder 5
10593 - Cylinder 3
10596 - Cylinder 6
10592 - Cylinder 2
   CVN: 52C19C90
                    Reset counter: 120
                    Mileage: 79238 km
                    Mileage: 112320 km
                    Date: 2024.10.29
                    Time: 16:20:10
                    Reset counter: 120
                    Mileage: 79238 km
                    Date: 2022.10.06
                    Time: 16:50:20
                    Reset counter: 120
                    Mileage: 79238 km
                    Date: 2022.10.06
                    Time: 17:17:54
                    Reset counter: 100
                    Mileage: 103724 km
                    Date: 2024.03.06
                    Time: 12:04:06
   Coding: 1F20000723
   Revision: 00001K01
   Coding: 00382D
0803 - Databus
          [FAULT_BV1_FEHLER]
                    Fault Frequency: 14
                    Reset counter: 54
                    Mileage: 119431 km
                    Date: 2025.03.14
                    Time: 05:15:54
   Coding: 303030
   Coding: 0C10
   Generator:
   Coding: 34FFFF
   Coding: 0301
   Coding: 01011103
   Coding: 010111
   Coding: 011000
                    Mileage: 103724 km
                    Date: 2024.03.06
                    Time: 12:03:57
   Coding: 091000
                    Mileage: 103724 km
                    Date: 2024.03.06
                    Time: 12:04:00
   Coding: 0908
                    Reset counter: 54
                    Mileage: 119431 km
                    Date: 2025.03.14
                    Time: 05:15:54
                    mid: 00 1D
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 0
0257 - Databus
                    Fault Frequency: 20
                    Reset counter: 0
                    Mileage: 112320 km
                    Date: 2024.10.29
                    Time: 16:20:09
                    Reset counter: 0
                    Mileage: 81467 km
                    Date: 2022.12.26
                    Time: 09:59:40
                    Fault Frequency: 26
                    Reset counter: 0
                    Mileage: 39033 km
                    Date: 2020.10.07
                    Time: 13:15:48
0257 - Databus
                    Fault Frequency: 20
                    Reset counter: 0
                    Mileage: 112320 km
                    Date: 2024.10.29
                    Time: 16:20:09
                    Reset counter: 0
                    Mileage: 81467 km
                    Date: 2022.12.26
                    Time: 09:59:40
                    Reset counter: 0
                    Mileage: 39935 km
                    Date: 2020.10.10
                    Time: 11:06:51
                    Fault Frequency: 34
                    Reset counter: 0
                    Mileage: 39033 km
                    Date: 2020.10.07
                    Time: 13:19:27
                    Reset counter: 0
                    Mileage: 103724 km
                    Date: 2024.03.06
                    Time: 11:52:26
This car has some kind of electrical issue. Vign sbouldn't be that much lower than Vbatt.
Yep:
But what's the back-story with this car? It's got a lot of fault codes! How about clearing them all (including directly in 01-Engine) and re-scanning afterward to see what remains?
striper405
NYC, USA
C?ID=376645
Yep:
So this is my parents Atlas they were in Florida for few months. Drove back up to NY the day they started to drive up as soon as he started the car in the AM gave him lane assist error thats all. When he got home I scanned it and thats what I got. I just scanned it again cleared all and then went into O1-engine says no faults cleared anyway and scanning again now to see what it says.
Sunday,23,March,2025,14:40:17:13904
          6D 75 A5 D6 D7
VIN: 1V2LR2CA7JC535134   Mileage: 121588km-75551miles
Readiness: 1110 0101
   CVN: 52C19C90
   Coding: 1F20000723
   Revision: 00001K01
   Coding: 00382D
0803 - Databus
          [FAULT_BV1_FEHLER]
                    Fault Frequency: 25
                    Reset counter: 62
                    Mileage: 121431 km
                    Date: 2025.03.16
                    Time: 16:45:57
                    Control Module temperature: 41 °C
                    Voltage terminal 15: 12.9 V
   Coding: 303030
   Coding: 0C10
   Generator:
   Coding: 34FFFF
   Coding: 0301
   Coding: 01011103
   Coding: 010111
   Coding: 011000
   Coding: 091000
   Coding: 0908
                    Reset counter: 62
                    Mileage: 121431 km
                    Date: 2025.03.16
                    Time: 16:48:12
                    Outside temperature: 9.5 °C
                    Vehicle speed: 0.00 km/h
                    System run time: 7.9 s
                    Voltage terminal 15: 12.4 V
                    mid: 00 1D
                    Engine_Running_Info: 0
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 0
End----(Elapsed Time: 02:00, VBatt start/end: 12.8V/13.2V. VIgn 10.9V)-----
------------------------------2 Faults Found-------------------------------
striper405
NYC, USA
C?ID=376645
Camera still needs calibration and this difference still bothers me:
Ok that’s what we figured it was the camera in the rear view mirror. The engine was running when I scanned it.
In that case 12.8V/13.2V is a bit marginal, but that's not my concern; there simply shouldn't be that kind of drop between unswitched power (Vbatt) and switched power (Vign). To me this says there's a problem (a high resistance connection) somewhere.
