"Unsupported vehicle please upgrade to a current Ross-Tech Interface". Slightly annoying!
TJD123
C?ID=150899
Hi -
I've just been to check out a car I'm looking to buy, plugged it in and got the scan below, questions -
1- is the only way to scan this car with a latest interface i.e. the one I have is useless on this age vehicle? It works well on my MK6 Golf
2 - I know it isn't the latest version software but will this make a difference?
3 - Can I get any useful information from this scan, I can see the modules with faults but that's as far as the useful scan goes, can I use these fault codes on the Wiki here?
Any pointers much appreciated as I don't want the car to sell but can't/won't part with cash until I know what the faults are!!
(apologies if posted in the wrong place)
Sunday,16,March,2025,14:38:17:61373
VCDS Version: 24.7.1.0 (x64)
VIN: WVWZZZAUZKW131903   License Plate:
Chassis Type: AU (3Q0)
Scan: 01 02 03 08 09 10 13 15 17 19 42 44 52 5F 75
Address 01: Engine (J623-DFGA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 NF    HW: 04L 907 309 P
   Component: R4 2.0l TDI   H25 6380
   Revision: B4H25---    CVN: EC4069A55D3F3C3E5D3F3C3E
   Coding: 01250412036405082000
   ASAM Dataset: EV_ECM20TDI01104L906026NF 004007
   ROD: N/A
   VCID: 7BFE8C88F20ADD4E9E-802E
   VINID: 9E69EAAAA465A9B9C10C12400C74795351
Unsupported vehicle.Please upgrade to a current Ross-Tech interface.
No ASAM data for: "EV_ECM20TDI01104L906026NF" ()
   Part No SW: 0GC 300 044 E    HW: 0GC 927 711 H
   Component: GSG DQ381     H06 2403
   Revision: 00H06V07    CVN: 27291857
   ROD: N/A
   VCID: 2A5079CC4D1094C6B5-807E
No ASAM data for: "EV_TCMDQ381061" ()
   Part No SW: 5Q0 614 517 EF    HW: 5Q0 614 517 BP
   Component: ESC           H35 0107
   Revision: 00000000    Serial number: 60369000003264
   Coding: 01FA8AA12023096D4780060060C62980510490E26006947338625078D2024B0B0000000012121212B835351919323200
   ROD: N/A
   VCID: 79F29680F836EF5E8C-802C
No ASAM data for: "EV_Brake1UDSContiMK100IPB" ()
32830 - ROD - Unknown Error Code
          - 00 [00001000]
                    Reset counter: 162
                    Mileage: 69766 km
                    Date: 2025.03.12
                    Time: 17:36:40
32900 - ROD - Unknown Error Code
          - 00 [00001000]
                    Reset counter: 162
                    Mileage: 69766 km
32901 - ROD - Unknown Error Code
          - 00 [00001000]
                    Reset counter: 162
                    Mileage: 69766 km
                    Date: 2025.03.12
                    Time: 17:37:39
Address 08: Auto HVAC (J301)       Labels:. 5G0-907-426.clb
   Part No SW: 5G0 907 426 AQ    HW: 5G0 907 426 AQ
   Component: AC Manuell    H03 1801
   Revision: 00001K06    Dataset Number: 0000
   Coding: 00120104202110001000000000000002
   ROD: N/A
   VCID: 7AF0898CFD30E44685-802E
No ASAM data for: "EV_ACManueBHBVW37X" ()
   Part No SW: 5Q0 937 084 DB    HW: 5Q0 937 084 CE
   Component: BCM MQBAB M   H38 0273
   Serial number: 00001904400352 Dataset Number: V03935292FD 0001
   ROD: N/A
   Component: WWS    190120  042 0551
   Serial number:         190129233620
   Subsystem 2 - Part No SW: 5Q0 955 559 B    HW: 5Q0 955 559 B  Labels: 5Q0-955-547.CLB
   Component: RLS  050 0105
   Serial number: S7Y19M02D13H19M38S29
   Coding: 00A8DD
   Serial number: 000000000ZY190023WBV
   Serial number: 00000000000046370254
   Subsystem 5 - Part No SW: 5Q1 953 507     HW: 5Q1 953 549
   Component: J527 SMLS MQB  004 0060
   Serial number: 00000008021920240315
No ASAM data for: "EV_BCMMQB" ()
197904 - ROD - Unknown Error Code
          - 00 [00001000]
                    Reset counter: 162
                    Mileage: 69343 km
                    Date: 2025.02.08
                    Time: 22:59:50
Address 10: Park/Steer Assist (J446)       Labels:. 5Q0-919-294.clb
   Part No SW: 5QA 919 294 C    HW: 5QA 919 294
   Component: PDC 8 KanalH07 0050
   Serial number: 000308418019031 Dataset Number: V03935287MF 0001
   Coding: 0471051811
   ASAM Dataset: EV_EPHVA18AU3700000 009039
   ROD: N/A
   VCID: 4C9C1F54E724AAF667-8018
No ASAM data for: "EV_EPHVA18AU3700000" ()
13637120 - ROD - Unknown Error Code
          - 00 [00001000]
                    Reset counter: 162
                    Mileage: 69766 km
                    Date: 2025.03.12
                    Time: 17:33:48
Address 13: Auto Dist. Reg (J428)       Labels:. 5Q0-907-572-V2.clb
   Part No SW: 5Q0 907 572 P    HW: 3QF 907 572 A
   Dataset Number: V03935282JS 0001
   Coding: 3300678151FFC728949C810580400600000000000000000004
   Shop #: WSC 12345 123 61029
   ROD: N/A
   VCID: 448C3774CF7462B6AF-8010
No ASAM data for: "EV_ACCBOSCHVW416" ()
2086 - ROD - Unknown Error Code
          - 00 [00001000]
                    Reset counter: 162
                    Mileage: 69766 km
                    Date: 2025.03.12
                    Time: 17:33:48
0836 - ROD - Unknown Error Code
          - 00 [00001000]
                    Reset counter: 153
                    Mileage: 69573 km
                    Date: 2025.02.12
                    Time: 16:41:49
Address 15: Airbags (J234)       Labels:. 5Q0-959-655.clb
   Part No SW: 5Q0 959 655 BT    HW: 5Q0 959 655 BT
   Component: AirbagVW21    007 0403
   Serial number: 003FNR4YYS73 Dataset Number: V03935279BC 0001
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002164
   ROD: N/A
   VCID: 132EC428FA9A350E66-8046
   Serial number: 34169677E15021930174
   Coding: 333135
   Serial number: 34169676E15021951281
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 001 302 19
   Serial number: 3570000000085678993R
   Subsystem 4 - Part No SW: -----------    HW: 480 001 402 19
   Serial number: 358000000004FC69193W
   Subsystem 5 - Part No SW: -----------    HW: 480 401 902 19
   Component: SideSensor_Dr  003 6149
   Serial number: 3510001A32EE4F41D4BJ
   Subsystem 6 - Part No SW: -----------    HW: 480 400 702 19
   Component: SideSensor_Pr  004 6149
   Serial number: 3520001222BF5A83637%
   Subsystem 7 - Part No SW: -----------    HW: 480 401 102 19
   Serial number: 3550001322C0A8D4E7BE
No ASAM data for: "EV_AirbaVW20SMEVW37X" ()
Address 17: Instruments (J285)       Labels:. 5G0-920-XXX-17.clb
   Part No SW: 5G1 920 941 D    HW: 5G1 920 941 D
   Component: KOMBI         202 3610
   Coding: 27A529082780060001887B011401000800000000
   ASAM Dataset: EV_DashBoardJCIMQBAB 009009
   ROD: N/A
No ASAM data for: "EV_DashBoardJCIMQBAB" ()
Address 19: CAN Gateway (J533)       Labels:. 3Q0-907-530-V1.clb
   Serial number: 05011911601622 Dataset Number: V03935293G  0001
   Coding: 030100045F087300FB00005C1C0F00010001070000000000000000000000
   GVL: 01443C0000000000400C80008000C80000000000000000000000000000000000
   ROD: N/A
   VCID: 6ED8B5DCB178B8E629-803A
   Component: 0-00-03-00-04
   Subsystem 2 - Part No SW: 5G0 959 442 AE    HW: 5G0 959 442 AE  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H11 0052
   Serial number: 29190000216000099052
   Coding: 2DFFFF
   Serial number: 6379930405
No ASAM data for: "EV_GatewNF" ()
Address 42: Door Elect, Driver (J386)       Labels:. 5QX-959-X93-42.clb
   Part No SW: 5Q0 959 593 F    HW: 5Q0 959 593 F
   Component: TSG FS001 0287
   Serial number: YE007SAV11634 Dataset Number: V03935290SS 0001
   Coding: 003B0220D001048000001000
   ROD: N/A
   Subsystem 1 - Part No SW: 5Q0 959 812 D    HW: 5Q0 959 812 D  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000027573649
   Coding: 0D0000
No ASAM data for: "EV_DCU2DriveSideMAXHKLO" ()
196665 - ROD - Unknown Error Code
          - 00 [00001000]
                    Reset counter: 165
                    Mileage: 69654 km
                    Date: 2025.02.22
                    Time: 13:22:36
Address 44: Steering Assist (J500)       Labels:. 5Q0-909-144.clb
   Part No SW: 5Q0 909 144 AB    HW: 5Q0 909 144 AA
   Component: EPS_MQB_ZFLS  131 1082
   Dataset Number: V03935288GZ 0001
   Coding: 81170000
   ROD: N/A
   VCID: 74ECA7B4DF549236DF-8020
No ASAM data for: "EV_SteerAssisMQB" ()
Address 52: Door Elect, Pass. (J387)       Labels:. 5QX-959-X92-52.clb
   Part No SW: 5Q0 959 592 F    HW: 5Q0 959 592 F
   Component: TSG BFS001 0287
   Serial number: YE007SB223232 Dataset Number: V03935290SY 0001
   Coding: 003B0020DC01048000001000
   ROD: N/A
   VCID: 438E3468CA7A658E96-8016
   Subsystem 1 - Part No SW: 5Q0 959 811 D    HW: 5Q0 959 811 D  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000027498401
   Coding: 150000
No ASAM data for: "EV_DCU2PasseSideMAXHKLO" ()
Address 5F: Information Electr. (J794)       Labels:. 5G0-035-MIB-STD2.clb
   Part No SW: 3Q0 035 874 C    HW: 3Q0 035 874 C
   Component: MU-S-ND-ER    853 0891
   Serial number:                Dataset Number: V03935282VN 0001
   Coding: 02731001FF00000041110101008808001F0506C601200100CE
   ROD: N/A
   VCID: 326061AC65C0DC060D-8066
   Subsystem 1 - Part No SW: 5G6 919 605 B    HW: 5G6 919 605 B
   Component: ABT_Std-2_Nav  H52 8130
   Serial number: VWZ6ZHW0423990
   Subsystem 2 - Part No SW: 5NA 919 866     HW: -----------
   Component: ECE1 2018/19  --- 1030
No ASAM data for: "EV_MUStd4CDELP" ()
Address 75: Telematics (J949)       Labels:. 5QE-035-285.clb
   Part No SW: 5NA 035 284 C    HW: 5NA 035 284 C
   Component: OCULowMQBLGE  H19 0825
   Revision: --------    Dataset Number: V03935278EW 0001
   Coding: 02730001EA42180D3F1CBE000045400382E608
   ASAM Dataset: EV_OCULowMQBLGE 004049
   ROD: N/A
   VCID: 3D7A4290AC9E137EE0-8068
No ASAM data for: "EV_OCULowMQBLGE" ()
End-------------------------(Elapsed Time: 03:59)--------------------------
Dr Sheldon
Windsor UK
C?ID=334979
Some codes are in the Wiki. Not all so go have a look !
That there is in your hands - You need a scan tool suitable for that vehicle and are choosing not to own one !!
Alternative is to borrow or rent a man who has one ?
You need a tool compatible with that car.
No it wont make a difference
3 - Can I get any useful information from this scan.
Knowing which modules have no faults. That is something.
We've shouted it far and wide, on the download page, in the installation instructions, and so on, that legacy interfaces like your HEX+CAN have compatibility problems with some cars starting around MY 2016 and aren't supported at all on MY 2019 and newer. The HEX+CAN was introduced in 2004 and in early 2016, when the 16 kB of space it has for firmware was full, no further compatibility enhancements were possible.
"Latest"? No. But a current one. Any HEX-NET (introduced in 2014) or HEX-V2 (that replaced the HEX+CAN at the end of 2016) will work. And discounted, trade-in upgrades are available.
TJD123
C?ID=150899
Thanks for the info, thought as much, just caught out. Upgrading process started. :thumbs:
grant@gendan
This thread has a scan with the same ABS module and some of the same fault codes. Helps with code definitions:
TJD123
C?ID=150899
Thanks!
