Headlights Basic Settings (2015 A6)
Tim N
County Durham, UK
C?ID=555194
Tuesday,15,August,2023,16:41:35:45195
VCDS Version: 23.3.1.0 (x64)  HEX-V2 CB: 0.4631.4
VIN: WAUZZZ4G6FN092569   License Plate: TN09SEP
Mileage: 213624km-132739mi   Repair Order:
Chassis Type: 4G-AU57 (4G8)
Scan: 01 02 03 05 08 09 15 16 17 19 28 30 36 3B 42 44 46 52 53 55
          5F 62 69 6D 72 82 85 AC 47
VIN: WAUZZZ4G6FN092569   Mileage: 213624km-132739miles
Address 01: Engine (J623-CRTD)       Labels:. 059-907-401-V2.clb
   Part No SW: 4G2 907 401 B    HW: 4G2 907 401
   Component: 3.0TDI EDC17  H34 0007
   Revision: 92H34---    CVN: F2CCE87515D91B8D92F1EF3C
   Coding: 1A254012053601030800
   Shop #: WSC 65535 000 00000
   ASAM Dataset: EV_ECM30TDI0114G2907401B 001007
   ROD: EV_ECM30TDI011_AU57.rod
   VCID: 2411FE655E50F79A4B3-8070
   VINID: 9D196AAAA117196780242146246CA004D0
7039 - Thermostat for Mapped Engine Cooling (F265)
          P0598 00 [047] - Short to Plus
                    Mileage: 213624 km
                    Date: 2023.08.11
                    Time: 01:11:10
                    Engine RPM: 0.00 /min
                    Coolant temperature: 54 °C
                    Intake air temperature: 28 °C
                    Voltage terminal 30: 11.940 V
                    Shut-off timer: last engine shut-off time: 2 s
                    Control module temp.: max. value: 54.0 °C
                    Mean injection quantity: 0.00 mg/stroke
                    Ambient temperature: 25.0 °C
                    Control Module temperature: 28.3 °C
   Part No SW: 4G0 927 166 C    HW: 0B5 927 156 K
   Component: 0B5 30 TDIRdW H03 0009
   Revision: --H03---    CVN: 000092A8
   Coding: 100001
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_TCMDL501021 001021
   ROD: EV_TCMDL501021.rod
   VCID: 2D071B410D9A36D294D-8078
   Part No SW: 4G0 907 379 S    HW: 4G0 907 379 S
   Component: ESP9 Premium  H01 0530
   Coding: 17A69E43E86579C2BB00
   ROD: EV_ESP9BOSCHAU57X.rod
   VCID: 41DF57F1A102C2B2405-8014
   Part No SW: 4H0 907 064 FN    HW: 4H0 907 064 EN
   Component: BCM2 2.0      H36 0560
   Coding: 01BA704E000000000000
   VCID: 7AADE01D8CD4516A41F-802E
   Serial number: 3215000067716005
   Part No SW: 4G0 820 043 CD    HW: 4G0 820 043 CD
   Serial number: 23041500111122
   Coding: 36231178350000
   VCID: 6393BD791BDEB0A2729-8036
0193 - Position Sensor in Left Center Vent
          B10E1 11 [008] - Short to Ground
                    Reset counter: 118
                    Mileage: 213624 km
                    Date: 2023.08.11
                    Time: 01:11:08
                    Voltage terminal 30: 11.99 V
                    Terminal 15 status: Terminal 15 on
                    Supply voltage for external components: 5.00 V
0276 - Engine Off Timer Performance
          P150A 00 [008] - -
                    Reset counter: 118
                    Mileage: 213624 km
                    Date: 2023.08.11
                    Time: 01:11:08
   Part No SW: 4H0 907 063 DH    HW: 4H0 907 063 AH
   Component: BCM1 2.0      H20 0311
   Revision: 15020001    Serial number: 00001052665301
   Coding: 0105C01440349FE041014083800018000F9DE30A2F080201000008946100130200400024030000
   VCID: 71BFC731D1A21232F05-8024
   Subsystem 1 - Part No SW: 4G2 955 119     HW: 4G8 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS57X 150319  H37 0080
   Serial number:         150326214802
   Coding: 0045F7
   Serial number: 23911531
   Coding: 02006E
   Subsystem 3 - Part No SW: 4G0 941 531 BG    HW: 4G0 941 531 BG
   Component: E1 - LDS  H07 0044
   Serial number: 15 04 2015  00000765
   Serial number: 0B0883A7000000000001
00496 - Sensor for Vehicle Leveling; Front
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 78
                    Mileage: 213624 km
                    Date: 2023.08.11
                    Time: 01:11:06
03455 - Function Restriction due to Faults in Other Modules
                    Reset counter: 78
                    Mileage: 213624 km
                    Date: 2023.08.11
                    Time: 01:11:09
   Component: Airbag10.43   H82 0086
   Revision: --------    Serial number: 003P10049MR5 Dataset Number: 4G8909602J  0001
   Coding: 30333046313130313235554A305234473853
   VCID: 3B232519C3EEA8621A9-806E
   Serial number: 3575HRB400Q5312U58SF
   Serial number: 3585HRB400Q5312UK9DH
   Serial number: 3515JRB404P36F9SGPH8
   Serial number: 3525JRB405P36F9QP18R
   Serial number: 3554VRB400454Q469P34
   Serial number: 3564VRB400454Q46JPS/
   Part No SW: 4H0 953 568 K    HW: 4H0 953 568 K
   Component: Lenks.Modul   H06 0005
   Revision: C0068538    Serial number: 90862ODI000EP
   Coding: 000034
   VCID: 3B232519C36EA8621A9-806E
   Subsystem 1 - Part No SW: 4G0 951 528 A    HW: 4G0 951 528 A
   Serial number: 01 04 2015  10004371
   Part No SW: 4G8 920 985 L    HW: 4G8 920 985 L
   Component: TDieGb        H08 0043
   Revision: 04001037    Serial number: 658160415596062
   Coding: 33A702020B432600010100
   ASAM Dataset: EV_RBD4K 004048
   ROD: EV_RBD4K_AU57.rod
   VCID: 40D952F5AA08CBBA4FB-8014
   Part No SW: 4G8 907 468     HW: 4G8 907 468
   Revision: --------    Serial number: 00000001818260 Dataset Number: 4G8909515H  0017
   Coding: C0CD078118
   GVL: FD81C858DCA5680300040000
   VCID: 75B7F321A54A3E122CD-8020
   Serial number: 8004946203
   Voltage stabilizer:
   Serial number: 15020800000000000065
   Part No SW: 4G0 919 158 Q    HW: 4G0 919 158 Q
   Component: KLIMA FOND    H08 0112
   Serial number: 24041500111777
   Coding: 22
   VCID: 3D272B01DDFAA65224D-8068
Address 30: Special Function II (J843)       Labels: 8K0-907-440.clb
   Part No SW: 4H0 907 440     HW: 4H0 907 440
   Component: STS           H06 0030
   Revision: S0H06000    Serial number: 00000000077312
   Coding: 01010101000000000001000202
   VCID: 6491BE651E50B79A8B3-8030
   Revision: AA000000    Serial number: 00000143507884
   Coding: 0078130000006001000001010101102030303232203232
   VCID: 77ABF929BFC64C023E1-8022
   Part No SW: 4G0 907 637 K    HW: 4G0 907 637 F
   Component: SARA 6D       H04 0056
   Revision: --------    Serial number: EJ1BPA8209CC60 Dataset Number: 4G8909573A  0001
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 3635342DF8CC750AE57-8062
   Component: TSG FA        H03 0507
   Coding: 011C56034E21620002080402
   VCID: 47CB49E98FA6FC828E1-8012
   Part No SW: 4G0 909 144 S    HW: 4G0 909 144 G
   Component: RCEPS         H43 0012
   Revision: 00001000    Serial number: 0028564115 Dataset Number: 4G8909852P  0032
   Coding: 101000010001
   ASAM Dataset: EV_RCEPS 009013
   ROD: EV_RCEPS_009.rod
   VCID: 392F3F11C9D29A72085-806C
   Revision: 00002001    Serial number: 0366296705
   Coding: 013F0622A0B9B800C3200A0420010D470000000000000000000000000000
   Subsystem 1 - Part No: 4G0 951 177
   Component: DWA-Sensor  H01 0010
   Subsystem 3 - Part No SW: 4G8 959 252     HW: 4G8 959 252
   Component: HSP-SG  H11 0029
   Serial number: WA120634000012834788
   Component: TSG BF        H03 0507
   VCID: 46D544ED88ACE58A757-8012
   Part No SW: 4H0 907 801 H    HW: 4H0 907 801 A
   Component: EPB-4         H04 0015
   Revision: --------    Serial number: 00000001443298 Dataset Number: 4G8909522D  0007
   ROD: EV_ParkiBrake_VW51.rod
   Revision: --------    Serial number: -------------- Dataset Number: 4G8909865D  0019
   Coding: 05F602202A130200
   Shop #: WSC 12345 123 61029
   VCID: 34310E25EEB0671ADB3-8060
   Coding: E02100
   Coding: E02100
   Power module 1 for left matrix headlamp:
   Subsystem 3 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
   Component: MxB LeiMo li.  H03 0031
   Coding: E02100
   Power module 1 for right matrix headlamp:
   Subsystem 4 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
   Component: MxB LeiMo re.  H03 0031
   Coding: E02100
13705473 - Databus
          U1121 00 [137] - Missing Message
          [Timeout CAN-Message Fahrwerk_01_FR (0x108)]
                    Reset counter: 78
                    Mileage: 213624 km
                    Date: 2023.08.13
                    Time: 03:18:43
5275220 - Headlight
          C107E 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 78
                    Mileage: 213624 km
                    Date: 2023.08.13
                    Time: 03:18:44
5350720 - Left Matrix High Beam
          C1175 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 78
                    Mileage: 213624 km
                    Date: 2023.08.13
                    Time: 03:18:44
5350976 - Right Matrix High Beam
          C1176 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 78
                    Mileage: 213624 km
                    Date: 2023.08.13
                    Time: 03:18:44
Address 5F: Information Electr. (J794)       Labels:| 4G1-035-MIB-HGH2.clb
   Part No SW: 4G1 035 021 D    HW: 4G1 035 021
   Component: MU-H-LND-EU   041 0389
   Serial number: A588D0F7511230 Dataset Number: 4G9909545D  0028
   Coding: 017503010000000013111102000A00132F000CE7F1700100DF
   VCID: 1B63C599632EC862FA9-804E
   Subsystem 1 - Part No SW: V03 959 801 ET    HW: -----------
   Component: ECE 2015  --- 0105
   Multimedia System 1:
   Subsystem 2 - Part No SW: 4G1 919 605 A    HW: 4G1 919 605 A
   Component: DU8 C7 SV  H63 0007
   Serial number: AUZ8Z9FY8018Q9
   Subsystem 3 - Part No SW: 4G2 919 610 F    HW: 4G2 919 610 F
   Serial number: 90349ODL0002C
   Compact disc data bank:
   Component: Gracenote2  --- 1012
3084 - GSM antenna 2
          B1533 13 [009] - Open Circuit
                    Reset counter: 78
                    Mileage: 213624 km
                    Date: 2023.08.13
                    Time: 03:16:46
                    Voltage terminal 30: 14.6 V
3086 - Antenna for Telephone Mount
          B1564 01 [009] - Electrical Failure
                    Reset counter: 78
                    Mileage: 213624 km
                    Date: 2023.08.13
                    Time: 03:16:45
                    Voltage terminal 30: 14.4 V
                    Status of telephone-Antenna diagnostic: OK
                    Status of telephone-Telephone baseplate diagnostic: not connected
                    Status of telephone-Handset in handset holder (cradle): not selected
                    Status of telephone-Handset holder (cradle): not connected
   Component: TSG HL        H03 0507
   Coding: 010814024021620002080002
   VCID: 49CF4FD199B20AF2985-801C
Address 69: Trailer (J345)       Labels:| 4H0-907-383-V2.clb
   Part No SW: 4G8 907 383 B    HW: 4G8 907 383 B
   Component: Anhaenger     H14 0137
   Revision: 7B001001    Serial number: 0365071595 Dataset Number: 4G8909527B  0009
   Coding: 0100000202000000
   VCID: 33330D39EBBE6022C29-8066
   Part No SW: 4G8 959 107 S    HW: 4G8 959 107 H
   Component: HDSG-Modul    H14 0049
   Revision: 11014001    Serial number: 106501250 Dataset Number: 4G8909541G  0001
   Coding: 0A3305C003
   ASAM Dataset: EV_HDSGAu573 001022
   ROD: EV_HDSGAu571.rod
   VCID: 45D743E1B52AEE927CD-8010
   Component: TSG HR        H03 0507
Address 82: Head Up Display (J898)       Labels:| 4G0-919-604.clb
   Part No SW: 4G8 919 604 N    HW: 4G8 919 604 N
   Component: HeadUpDisplay H07 0304
   Coding: A20000
   ASAM Dataset: EV_HUDContiC7 001025
   ROD: EV_HUDContiC7.rod
   VCID: 3E252C0DD0FCBD4A3D7-806A
   Component: DPC-SG        H27 0081
   Revision: --------    Serial number: 262130025421000 Dataset Number: 4G8909547E  0006
   Coding: 60140000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 2C01164536803FDA833-8078
   Part No SW: 4H0 907 355 D    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0012
   Revision: 00000000    Serial number: 150841149 Dataset Number: 4G8909571H  0017
   ROD: EV_RDCMA00100.rod
End-----(Elapsed Time: 02:23, VBatt start/end: 12.2V/0.0V. VIgn 0.0V)------
Sunday,16,March,2025,18:04:41:45195
VCDS Version: Release 25.3.0 (x64) Running on Windows 8.1 x64
Tim Norman VAG DIAGS
                Address 01: Engine       Labels: 059-907-401-V2.clb
Control Module Part Number: 4G2 907 401 B    HW: 4G2 907 401
  Component and/or Version: 3.0TDI EDC17  H34 0007
           Software Coding: 1A254012053601030800
            Work Shop Code: WSC 65535 000 00000
              ASAM Dataset: EV_ECM30TDI0114G2907401B 001007 (AU57)
                      VCID: 2411FE655E50F79ACB8-8070
5211 - Fuel Rail/System Pressure
          P0087 00 [00100000] - Too Low
                    Mileage: 241864 km
                    Date: 2025.03.15
                    Time: 14:44:42
                    Engine speed: 2842.50 /min
                    Normed load value: 100.0 %
                    Vehicle speed: 93 km/h
                    Coolant temperature: 61 °C
                    Intake air temperature: 12 °C
                    Voltage terminal 30: 14.200 V
                    Fuel temperature: 9.7 °C
                    Mean injection quantity: 80.45 mg/stroke
                    Rail press. regulation: operating condition-Bits 0-7: 1
                    Fuel high-pressure: actual value: 1103900 hPa
                    High fuel pressure: specified value: 2040000 hPa
                    Fuel low pressure: actual value: 169.9 kPa
                    Fuel level: 47.00 l
5227 - Fuel Rail/System Pressure
                    Mileage: 241784 km
                    Date: 2025.03.14
                    Time: 12:33:56
                    Engine speed: 2430.50 /min
                    Normed load value: 99.6 %
                    Vehicle speed: 53 km/h
                    Coolant temperature: 46 °C
                    Intake air temperature: 16 °C
                    Voltage terminal 30: 14.220 V
                    Fuel temperature: 8.9 °C
                    Mean injection quantity: 79.18 mg/stroke
                    Rail press. regulation: operating condition-Bits 0-7: 3
                    Fuel high-pressure: actual value: 1031400 hPa
                    High fuel pressure: specified value: 1853300 hPa
                    Fuel low pressure: actual value: 165.8 kPa
                    Fuel level: 66.00 l
          P0598 00 [00101111] - Short to Plus
                    Mileage: 241669 km
                    Date: 2025.03.12
                    Time: 16:59:37
                    Engine speed: 898.00 /min
                    Normed load value: 40.0 %
                    Coolant temperature: 43 °C
                    Voltage terminal 30: 13.340 V
                    Shut-off timer: last engine shut-off time: 2391 s
                    Mean injection quantity: 6.62 mg/stroke
                    Ambient temperature: 8.5 °C
                    Control Module temperature: 13.0 °C
I would sincerely appreciate some help with this, I started having problems with my hex v2 shortly after updating my cable. As you can see I have issues with my car. Thanks guys Tim
TTT
C?ID=547002
Put your auto-scan in quotes </> then we “speak”.
Dr Sheldon
Windsor UK
C?ID=334979
That there is your starting point. That level sensor also reports to headlights.
  • Agree
Tim N
County Durham, UK
C?ID=555194
                    Mileage: 213624 km
                    Date: 2023.08.11
                    Time: 01:11:10
   Coding: 100001
                    Reset counter: 118
                    Mileage: 213624 km
                    Date: 2023.08.11
                    Time: 01:11:08
          P150A 00 [008] - -
                    Reset counter: 118
                    Mileage: 213624 km
                    Date: 2023.08.11
                    Time: 01:11:08
   Coding: 0045F7
   Coding: 02006E
                    Reset counter: 78
                    Mileage: 213624 km
                    Date: 2023.08.11
                    Time: 01:11:06
                    Reset counter: 78
                    Mileage: 213624 km
                    Date: 2023.08.11
                    Time: 01:11:09
   Coding: 000034
   Coding: C0CD078118
   Voltage stabilizer:
   Coding: 22
   ROD: EV_SARA2.rod
   Coding: E02100
   Coding: E02100
   Coding: E02100
   Coding: E02100
13705473 - Databus
                    Reset counter: 78
                    Mileage: 213624 km
                    Date: 2023.08.13
                    Time: 03:18:43
5275220 - Headlight
                    Reset counter: 78
                    Mileage: 213624 km
                    Date: 2023.08.13
                    Time: 03:18:44
                    Reset counter: 78
                    Mileage: 213624 km
                    Date: 2023.08.13
                    Time: 03:18:44
                    Reset counter: 78
                    Mileage: 213624 km
                    Date: 2023.08.13
                    Time: 03:18:44
                    Reset counter: 78
                    Mileage: 213624 km
                    Date: 2023.08.13
                    Time: 03:16:46
                    Reset counter: 78
                    Mileage: 213624 km
                    Date: 2023.08.13
                    Time: 03:16:45
   Coding: 0A3305C003
   Coding: A20000
   Coding: 60140000
                    Mileage: 241864 km
                    Date: 2025.03.15
                    Time: 14:44:42
                    Fuel level: 47.00 l
                    Mileage: 241784 km
                    Date: 2025.03.14
                    Time: 12:33:56
                    Fuel level: 66.00 l
                    Mileage: 241669 km
                    Date: 2025.03.12
                    Time: 16:59:37
Tim N
County Durham, UK
C?ID=555194
Hi I would not have thought that the headlight level sensor failure (left headlight), would stop vcds from adjustment, Thank you for your help
Dr Sheldon
Windsor UK
C?ID=334979
A prerequisite of adjusting Headlamps has always that the car is on a level surface. Now the electronic systems have been taught that by the humans that program these things.
I am not for sure saying that with your level sensor fault cured that that VCDS will adjust the headlamps !!
There may or may not be further issues. What I am saying is that the level sensor is one thing that can be an obstacle ! There are Data Errors in
13705473 - Databus
Perhaps that missing message is the Message for Vehicle level / Ride Height ???
Google translates Fahrwerk to Under Carriage - Not the best translation but Undercarriage could mean Chassis ?? >> Chassis Height ???
Tim N
County Durham, UK
C?ID=555194
yes you are correct and thanks for taking the time to help. I will replace the left level sensor. I also noticed on my previous scans a digit from my central electrics module had somehow changed from a 0 to a 1 ?,not sure how that happened but I will recode that too
Correct.
Tim N
County Durham, UK
C?ID=555194
Correct.
Thank you Uwe. I put my A7 into Vasstech who are timed served techs, they are now saying that the problemwith my car is the reductant pump and needs replacing along with a TPI that requires a software update. I'm distressed by the rising costs of the repairs so Uwe any advice you can offerwill be greatly appreciated
They are now saying that the problemwith my car is the reductant pump and needs replacing along with a TPI that requires a software update.
What does that have to do with the headlight calibration that was the subject matter of this thread?
However, none of the faults in the scans to posted point at a problem with the reductant pump. Thermostat, yes. Fuel pressure problems, maybe. But reductant pump?
As for a software update: Which module are they suggestion you update? I only checked your ECU and version 0007 is the latest for that part number. That said, sometimes VAG changes the part number with an update, in which case it wouldn't show on the resource I checked:
https://vag-flashinfo.de/site/index?partno=4G2+907+401+B
If you're so inclined you can check all your other modules there.
Tim N
County Durham, UK
C?ID=555194
Hi Uwe.I am sorryvI thought I was only replying to your message, now I see it was still on the headlight issue post, Iwill upload a scan relating to this on anew post
(if that is the coorect thing to do). Kind RegardsTim N
