d4s8
I have a 2015 s8 and I would like the MMI screen to stay down on engine startup. All other MMI functionality to stay the same.
Does anyone know the code to do this or where to start looking?
The interior has such a clean design I don't like the lines being ruined by a screen!
Thank you in advance
DYOR -- Chat GPT says..
I want the MMI system to start but the screen not to raise. What bit will do this?
For your vehicle, the setting to control the screen's automatic raising (while still allowing the MMI to start) is typically found in Byte 18 of the 5F - Infotainment System module.
Here's the exact process to disable the screen from raising:
ChatGPT said:
To have the MMI system start up while preventing the screen from raising automatically on a 2015 Audi S8 (D4), you will need to modify a specific setting in the 5F control module through VAG-COM (VCDS).For your vehicle, the setting to control the screen's automatic raising (while still allowing the MMI to start) is typically found in Byte 18 of the 5F - Infotainment System module.
Steps:
- Connect your VAG-COM (VCDS) tool to the OBD-II port and open the VAG-COM software.
- In the software, go to "Select Control Module".
- Choose "5F - Information Electr." (Infotainment system).
- Click on "Coding".
- Open the "Long Coding Helper".
- Locate Byte 18 in the list of available bytes.
- Look for Bit 2in Byte 18 — this bit controls the automatic raising of the screen.
- Bit 2 = 1: The screen will raise automatically when the MMI system starts.
- Bit 2 = 0: The screen will not raise automatically when the MMI system starts, but the MMI itself will still turn on.
- Change Bit 2 to 0 (this disables the automatic screen raising).
- Save the coding and exit the Long Coding Helper.
Final Note:
- After making this change, the MMI system will still power on automatically when the engine is started, but the screen will stay down, requiring you to manually raise it if desired.
