Media Player fault code on 2011 Octavia
Sofo
West Midlands, UK
C?ID=407038
Hi Guys,
I have a small query regarding a fault code on my 2011 Octavia Amundsen Radio.
When I first got my VCDS (back in 2020) I did an autoscan which showed a fault code on the Media Player.
As it appeared to be working fine and always has (and I was a VCDS noob) I didn't think anything of it (assuming it might relate to the "Non-Skoda" SD card that I am using in the Radio to listen to MP3's).
In between then and now I cleared all the DTC's but my most recent autoscan showed the same fault on the Media Player.
Digging into a little via this post by DrPeter where he explains the anatomy of a fault code he indicates that the Fault Priority of 6 has " a long term influence on drivability".
Yikes !! :eek:
As I have covered >25,000 miles since the original scan I am not unduly worried about the driveability of my car but would be grateful if anyone could shed some light on what the fault is or how to clear it up?
Here's the relevant Fault code scan results.
I do have the full autoscans available if required.
*** Autoscan on 10/09/2020 ***
Address 2E: Media Player 3       Labels: 5N0-035-342.lbl
Control Module Part Number: 5N0 035 342 D    HW: 5N0 035 342 D
  Component and/or Version: SG EXT.PLAYER H13 0150
           Software Coding: 020000
            Work Shop Code: WSC 73430 790 00079
                      VCID: 2809FD3102F8E1AB3A3-807C
                    Reset counter: 48
                    Mileage: 33965 km
                    Date: 2015.02.01
                    Time: 16:14:04
*** Autoscan on 05/03/2025 ***
   Part No SW: 5N0 035 342 D    HW: 5N0 035 342 D
   Revision: A1001003    Serial number: 7669701401
   Coding: 020000
   Shop #: WSC 73430 790 00079
   VCID: 2809FD3102F8E1AAE71-807C
                    Reset counter: 27
                    Mileage: 74212 km
                    Date: 2019.07.27.
                    Time: 13:27:08
Sofo
West Midlands, UK
C?ID=407038
Hi,
Here are the full Scans.
2020
Thursday,10,September,2020,16:50:29:49070
VCDS Version: 20.4.2.0  HEX-V2 CB: 0.4513.4
Mileage: 33960km-21101mi   Repair Order:
Chassis Type: 1Z-SK35 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 2E 37 42 44 46 52 56 62 72 77
VIN: TMBHJ21Z4B214XXXX   Mileage: 33960km-21101miles
Address 01: Engine (CAX)       Labels: 03C-906-016-CAX.clb
   Part No SW: 03C 906 016 AK    HW: 03C 906 016 C
   Component: MED17.5.5           5295
   Revision: LCH12---    Serial number:
   Coding: 0000072
   Shop #: WSC 73430 790 00066
   VCID: 6889BD31CE7821ABFA3-803C
Readiness: 0000 0001
Address 03: ABS Brakes        Labels:. 1K0-907-379-MK70M.clb
   Part No SW: 1K0 907 379 AK    HW: 1K0 907 379 AK
   Component: MK70 M MASR         0105
   Revision: 00H35001
   Coding: 0017665
   VCID: 7BA3F27DAFEE9A33071-802E
   Part No SW: 3T0 820 047 R    HW: 3T0 820 047 R
   Component: AC Manuell    H16 0401
   Revision: 00007001
   Coding: 0000000002
   ROD: EV_ACManueBHBVW36X_VW46.rod
   VCID: 3E253B69F0FC4F1B60F-806A
   Part No SW: 1K0 937 084 D    HW: 1K0 937 084 D
   Component: BCM PQ35  B   103 0615
   Revision: 00103 AE
   Coding: 48000AB8A05BB1C04008008011000024430000AE524D89605CC540000040
   VCID: 2F3B162D2716B693FB9-807A
   Subsystem 1 - Part No: 1Z2 955 119 D  Labels: 1KX-955-119.CLB
   Component: Wischer 22031  26  0601
   Coding: 00D7B7
   Subsystem 2 - Part No: 1Z0 951 171
   Component: Innenraumuebe  008 5101
   Subsystem 3 - Part No: 1K8 951 605 B
Address 10: Park/Steer Assist (J446)       Labels:| 5J0-919-475.clb
   Part No SW: 5J0 919 475 A    HW: 5J0 919 475 A
   Component: PARKHILFE 4K  H11 0005
   Revision: --H11---    Serial number: 32901108401243
   Coding: 10800E
   Shop #: WSC 13765 790 00066
   ASAM Dataset: EV_EPHVA14SKxxx0000 001001
   ROD: EV_EPHVA14SKxxx0000_001.rod
   VCID: 33331A5DCBBE92739F1-8066
   Component: Q4 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PC24ZT8/
   Coding: 0020788
   VCID: 3D273C65F17A5403795-8068
   Subsystem 1 - Serial number: 6332MSME5C747435I
   Subsystem 2 - Serial number: 6342MSME5C520465B
   Part No SW: 5K0 953 521 BM    HW: 5K0 953 569 D
   Revision: FF010040    Serial number: 20110318300064
   Coding: 108A040000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 78A9ED719258B12B6A3-802C
   Subsystem 1 - Part No SW: 3T0 959 537     HW: 3T0 959 537   Labels: 3C8-959-537.CLB
   Component: E221__MFL-URO  H07 0012
   Coding: 820000
   Part No SW: 1Z0 920 943 K    HW: 1Z0 920 943 K
   Coding: 710A00
   Shop #: WSC 73430 031 00066
   ROD: EV_Kombi_UDS_VDD_RM09_004_SK35.rod
   VCID: 41DF4095810230E31DD-8014
   Part No SW: 7N0 907 530 C    HW: 1K0 907 951
   Component: J533  Gateway H37 0614
   Revision:   H37       Serial number: 010411F2000149
   Coding: 352303
   VCID: 303915513A28A96BE23-8064
   Component: IMMO          H20 0420
   VCID: 6A8DC739DCF413BBEC7-803E
   Coding: 020000
                    Reset counter: 48
                    Mileage: 33965 km
                    Date: 2015.02.01
                    Time: 16:14:04
Address 37: Navigation
   Part No SW: 1T0 959 701 T    HW: 1T0 959 701 T
   Component: Tuer-SG         009 2120
   Coding: 0000756
   VCID: 48C95DB1AEB801ABDA3-801C
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 68     3201
   Revision: 00H20000
   VCID: 34311941C230954B86B-8060
   Part No SW: 1T0 959 702 R    HW: 1T0 959 702 R
   Coding: 0000756
   VCID: 47CB5E8DA3A60ED3D39-8012
Address 56: Radio
   Part No SW: 5K0 959 703 A    HW: 5K0 959 703 A
   Coding: 0000144
   Shop #: WSC 73430 790 1012546
   VCID: 323D1F5938249B7B947-8066
   Part No SW: 5K0 959 704 A    HW: 5K0 959 704 A
   Coding: 0000144
   VCID: 33331A5DC73E92739F1-8066
   Part No SW: 5K0 035 730     HW: 5K0 035 730
   Component: TELEFON       H09 1020
   Revision: 1B001001    Serial number: 00007669638693
   Coding: 0200000000010110
   ASAM Dataset: UHVNA A01009
   ROD: UHVNA.rod
   VCID: 629DAF1924C44BFB247-8036
End----------(Elapsed Time: 01:25, VBatt start/end: 12.7V/12.6V)-----------
2025
Saturday,01,March,2025,13:45:32:49070
VCDS Version: 25.3.0.2  HEX-V2 CB: 0.4660.4
Data version: 20250228 DS364.1
VIN: TMBHJ21Z4B214XXXX   License Plate:
Mileage: 74210km-46111mi   Repair Order:
VIN: TMBHJ21Z4B2145333   Mileage: 74210km-46111miles
   Coding: 0000072
   VCID: 6889BD31CE7821AA271-803C
   VINID: 91D49868206A1120811050C30C429AE5C2
   Revision: 00H35001
   Coding: 0017665
   VCID: 7BA3F27DAFEE9A32DA3-802E
   Revision: 00007001
   Coding: 0000000002
   ROD: EV_ACManueBHBVW36X_SK35.rod
   VCID: 3E253B69F0FC4F1ABDD-806A
   Revision: 00103 AE
   VCID: 2F3B162D2716B69226B-807A
   Coding: 00DFB7
   Coding: 10800E
   ROD: EV_EPHVA14SKxxx0000_001_SK35.rod
   VCID: 33331A5DCBBE9272423-8066
   Coding: 0020788
   VCID: 3D273C65F17A5402A47-8068
   Coding: 108A040000
   ROD: EV_SMLSNGVOLWS_SK35.rod
   VCID: 78A9ED719258B12AB71-802C
   Coding: 820000
   Coding: 710A00
   VCID: 41DF4095810230E2C0F-8014
   Coding: 352303
   VCID: 303915513A28A96A3F1-8064
   ROD: EV_Immo_UDS_VDD_RM09_SK35.rod
   VCID: 6A8DC739DCF413BA315-803E
   Coding: 020000
                    Reset counter: 27
                    Mileage: 74212 km
                    Date: 2019.07.23.
                    Time: 13:27:08
Address 37: Navigation (J794)       Labels:| 3C0-035-270.clb
   Part No SW: 3T0 035 191 A    HW: 3T0 035 191
   Component: RNS310        H19 0353
   Revision: 11000000    Serial number: SKZ1Z2L0687516
   Coding: 040004010401000000000000
   ASAM Dataset: SK_RNS310 A02007
   ROD: EV_SKRNS310UDS_SK35.rod
   VCID: 2B03023D138ECAB20A3-807E
   Coding: 0000756
   VCID: 48C95DB1AEB801AA071-801C
   Revision: 00H20000
   VCID: 34311941C230954A5B9-8060
   Coding: 0000756
   VCID: 47CB5E8DA3A60ED20EB-8012
   Coding: 0000144
   VCID: 323D1F5938249B7A495-8066
   Coding: 0000144
   VCID: 33331A5DC73E9272423-8066
   Revision: 1B001001    Serial number: 00007669638693 Dataset Number: 5K0035730   0001
   ROD: EV_UHVNA_A01_SK35.rod
   VCID: 629DAF1924C44BFAF95-8036
End----(Elapsed Time: 01:24, VBatt start/end: 11.7V/11.7V. VIgn 11.7V)-----
-------------------------------1 Fault Found-------------------------------
I'm keen to increase my knowlege of VCDS so how will seeing the whole scans (as opposed to seeing just the relevant module fault codes as I specified) help with solving the issue?
I know that very often things are interlinked but to me (as a still fairly noob VCDS user) I can't see how a fault with the Media Player can be diagnosed bv seeing scans of the whole vehicle.
Thanks for getting back to me BTW. :thumbs:
Sofo
West Midlands, UK
C?ID=407038
Can anyone else offer any guidance?
As I mentioned, I have cleared the code once but it popped back up.
Westbury, UK
1 Fault Found: 01044 - Control Module Incorrectly Coded 000 - - - Intermittent
To me this suggests an intermittent connection to the Media Player, maybe worth checking that all the connectors to/from it are fully latched?
Sofo
West Midlands, UK
C?ID=407038
I'll do that.
Thanks. :)
