Envynot
I'm not verified so I hope this is the right place to post this
I have a returning problem I thought I had fixed, and I'm at a loss for how to proceed with troubleshooting. Around a year ago I started having fueling issues with my 2015 Audi A3 Quattro (Stage 1 IE ECU, DSG tune, intake, and turbo inlet). At around 53k mi on odometer I would be driving at low speeds between 2nd and 3rd gear, and the car would lose throttle response and start bucking like it was about to stall. At first there were no codes but after a few occasions of the car bogging down, it threw a "P0087 - Fuel Rail/System Pressure Too Low". It happened dozens of times only while driving, and my car even stalled out a few of those times. Never had issues with turning the car over either hot or cold. I did a lot of digging online and found a lot of conflicting information but the consensus was that it was most likely the HPFP or LPFP. Long story short, I threw parts at it to fix the issue since I wasn't sure how to diagnose it. I replaced the HPFP (06L127025T), still problems. I replaced the LPFP (5Q0919087AH), and Fuel Pump Control Module (5Q0906093C) and the issue seemed to go away for a while. All new OEM parts from FCP Euro. After about 5.5k miles of driving it's having the same problem again. Like the first time, it loses power for 3-10 seconds before it stops and I regain throttle response. The only difference between this time and when it first started happening is when I open the drivers door I am no longer hearing the fuel pump prime, and there are a few new codes I've never seen before that don't look related to the fueling issue. I have been taking live logs on my way to work every day trying to catch it happening with no luck so far. Do I have an injector dying/leaking? Is something else in my fuel system killing my LPFP quickly? Carbon buildup? I need advice. What measuring blocks would you guys monitor to identify the issue more accurately? Are there VCDS tests I can do that could identify a faulty pump? Any help is appreciated!
.I have a returning problem I thought I had fixed, and I'm at a loss for how to proceed with troubleshooting. Around a year ago I started having fueling issues with my 2015 Audi A3 Quattro (Stage 1 IE ECU, DSG tune, intake, and turbo inlet). At around 53k mi on odometer I would be driving at low speeds between 2nd and 3rd gear, and the car would lose throttle response and start bucking like it was about to stall. At first there were no codes but after a few occasions of the car bogging down, it threw a "P0087 - Fuel Rail/System Pressure Too Low". It happened dozens of times only while driving, and my car even stalled out a few of those times. Never had issues with turning the car over either hot or cold. I did a lot of digging online and found a lot of conflicting information but the consensus was that it was most likely the HPFP or LPFP. Long story short, I threw parts at it to fix the issue since I wasn't sure how to diagnose it. I replaced the HPFP (06L127025T), still problems. I replaced the LPFP (5Q0919087AH), and Fuel Pump Control Module (5Q0906093C) and the issue seemed to go away for a while. All new OEM parts from FCP Euro. After about 5.5k miles of driving it's having the same problem again. Like the first time, it loses power for 3-10 seconds before it stops and I regain throttle response. The only difference between this time and when it first started happening is when I open the drivers door I am no longer hearing the fuel pump prime, and there are a few new codes I've never seen before that don't look related to the fueling issue. I have been taking live logs on my way to work every day trying to catch it happening with no luck so far. Do I have an injector dying/leaking? Is something else in my fuel system killing my LPFP quickly? Carbon buildup? I need advice. What measuring blocks would you guys monitor to identify the issue more accurately? Are there VCDS tests I can do that could identify a faulty pump? Any help is appreciated!
Chassis Type: FF-AU37 (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 22 3C 42 44 52 55 5F 6C BB BC
VIN: WAUBFGFF0F1055611 Mileage: 94437km-58680miles
Address 01: Engine (J623-CNTC) Labels:. 06K-907-425-V1.clb
Part No SW: 5G0 906 259 L HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0002
Revision: --H13--- CVN: C11F1776
Coding: 0A1D00324426000F2000
Shop #: WSC 06385 790 00016
ASAM Dataset: EV_ECM20TFS0205G0906259L 001004
ROD: EV_ECM20TFS0205G0906259L.rod
VCID: 372B25092FC0F7027EA-8062
VINID: 9D1952597596016040145181049F554EC5
15059 - Fuel Rail/System Pressure
P0087 00 [01100000] - Too Low
Mileage: 94401 km
Date: 2025.03.05
Time: 17:30:02
Engine speed: 1256.75 /min
Normed load value: 6.7 %
Vehicle speed: 27 km/h
Coolant temperature: 94 C
Intake air temperature: 45 C
Voltage terminal 30: 14.179 V
Unlearning counter according OBD: 29
Engine: operating status: PL
STATE_LS_SAE[1]: CL
T_AST_SAE: 20 s
MAP_MES_SAE: 35 kPa
Lambda probe voltage: bank 1: probe 1 (broadband probe): 2.422 V
FAC_TPS_1_SAE: 15.234375 %
FUP_H_SAE: 530.0 kPa
Readiness: 1010 0101
Part No SW: 0D9 300 012 K HW: 02E 927 770 AQ
Component: DQ250-6A MQB H53 4513
Revision: 03253104 Serial number: TFK01407261467 CVN: 00006FC7
Shop #: WSC 04742 780 00200
ROD: EV_TCMDQ250021.rod
VCID: 1E65D0ADA03AA64A9DC-804A
P1734 00 [00000010] - -
Part No SW: 5Q0 907 379 L HW: 5Q0 907 379 G
Component: ESC H31 0471
Revision: 00000000 Serial number: 62264000002335
Coding: 13FF6A9234250A71017D030181C429C8562C5080C08194B4024100588608
VCID: 45D75FC1652C9592FC6-8010
8210 - Databus
[FCAN: Allrad_03 message is not received]
Fault Frequency: 73
Reset counter: 84
Date: 2025.02.08
Time: 16:10:30
Part No SW: 8V0 820 043 D HW: 8V0 820 043 D
Component: AC Automat H13 0052
Revision: 20026000 Serial number: 00000000409363
Coding: 03000014010000000000000000001400
VCID: 333311193BB81B22422-8066
Humidity sensor: exterior:
Subsystem 1 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: A488C147000000000001
329476 - Motor for Fresh Air / Recirculated Air Flap
B108B 71 [00001000] - Actuator Stuck
Reset counter: 55
Mileage: 94241 km
Date: 2025.02.22
Time: 15:18:21
Voltage terminal 30: 11.7 V
Inside temperature: 35.6 C
Outside temperature: 22 C
Fresh air/recirculating air/back pressure door specified value: 891
Actual value for fresh air/recirculation air flow flap: 768
Actual value for fresh air/recirculation air flow flap: 100.0 %
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 085 AB HW: 5Q0 937 085 AB
Component: BCM MQBAB MNA H18 0134
Serial number: 01011422300324 Dataset Number: 8V0909514G 0080
Coding: 04141A46C04122F541C04004511007000000000000000000000000000000
ROD: EV_BCMBOSCH_013.rod
VCID: 79AFE33159542172C8E-802C
Subsystem 1 - Part No SW: 8V1 955 119 C HW: 8V1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS371 140805 042 0585
Serial number: 140818104910
Coding: 0A47F7
Component: G397_RLFS H06 0002
Serial number: 23066549
Coding: 00006C
Subsystem 3 - Part No SW: 8V0 941 531 K HW: 8V0 941 531 K
Serial number: 20 06 2014 00000750
Serial number: 00000000000060361655
Sunroof control module:
Subsystem 5 - Part No SW: 8V3 959 591 HW: 8V3 959 591
Component: J245 PS73.014 H02 0007
Serial number: WOO31556767
Coding: 101F00
B1263 01 [00001000] - Electrical Failure
Fault Frequency: 69
Reset counter: 84
Mileage: 94148 km
Date: 2025.02.08
Time: 16:15:41
Terminal 15 status: OFF
Terminal 50 status: OFF
CAN-Bus_aktiv: On
OFF: Not operated
Position lamps: Not operated
Low beam: Not operated
Voltage: 11.7 V
Outside temperature: 18.5 C
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-294.clb
Part No SW: 5Q0 919 294 J HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0051
Revision: -------- Serial number: 39331422507555 Dataset Number: 8V0909526D 0039
Coding: 0010150011
ROD: EV_EPHVA18AU3700000_002_AU37.rod
VCID: 42DD44DD7402A2AAD94-8016
Part No SW: 5Q0 959 655 J HW: 5Q0 959 655 J
Component: AirbagVW20 009 0825
Serial number: 003GCR00M8MO Dataset Number: 8V0909602F 0004
VCID: 47CB55C95F2087820EA-8012
Left seat belt tensioner:
Component: BeltPretRevFL H35 0341
Serial number: 34178311B26081440118
Coding: 333135
Right seat belt tensioner:
Component: BeltPretRevFR H35 0341
Serial number: 34178312B26081440029
Coding: 333135
Subsystem 3 - Part No SW: 5C6 959 339 B HW: 5C6 959 339 B
Serial number: 6940000Y14000172050U
Coding: 303139
Subsystem 4 - Part No SW: ----------- HW: 480 001 208 14
Serial number: 3570000000001C75B019
Subsystem 5 - Part No SW: ----------- HW: 480 001 208 14
Serial number: 358000000001C24C901E
Subsystem 6 - Part No SW: ----------- HW: 480 401 408 14
Serial number: 35100029D16DB811B155
Subsystem 7 - Part No SW: ----------- HW: 480 401 408 14
Serial number: 3520002B116DB812C394
Subsystem 8 - Part No SW: ----------- HW: 480 400 207 14
Serial number: 3550002BF1656B8132B9
Subsystem 9 - Part No SW: ----------- HW: 480 400 207 14
Component: FrontSensor_P 001 6149
Serial number: 3560002BF1656B827024
Part No SW: 8V0 953 521 CB HW: 5Q0 953 549 C
Component: Lenks. Modul 002 0110
Revision: -------- Serial number: 27081408490171
Coding: A018
ROD: EV_SMLSKLOMQB_017.rod
VCID: 7CA1FA255666145AD38-8028
Part No SW: 8V0 920 960 H HW: 8V0 920 960 H
Component: KOMBI H01 4291
Coding: 0BF518092B88D7050201AA001800000000000000
VCID: 40D94ED57A0EB0BACF0-8014
Part No SW: 5Q0 907 530 T HW: 5Q0 907 530 M
Component: GW MQB High 212 2186
Revision: -------- Serial number: 16081410802036 Dataset Number: 8V0909515G 0056
Coding: 0101000820085A005B00020C180B00000001010000000000000000000000
GVL: 01D43C0000000000404C10000002C80000000000000000000000000000000000
ASAM Dataset: EV_GatewConti 011017
ROD: EV_GatewConti_011.rod
Generator:
Subsystem 2 - Part No SW: 8U0 951 528 A HW: 8U0 951 528 A
Component: E221 - MFL H02 0014
Serial number: 06 08 2014 D0018677
Address 22: AWD (J492) Labels:| 0CQ-907-554-V1.clb
Part No SW: 0CQ 907 554 D HW: 0CQ 907 554 D
Component: Haldex4Motion H52 7076
Serial number: HA1-00021.07.14 Dataset Number: v1260x015G0 0000
Coding: 0001
ROD: EV_AllWheelContrHA1VW37X_002_VW37.rod
VCID: 46D558CD582A9E8AF5C-8012
Part No SW: 5Q0 907 566 A HW: 8T0 907 566 B
Component: SWA Master H05 0071
Serial number: 0344289466 Dataset Number: 8V0909535D 0032
Coding: 030211
ROD: EV_LaneChangAssis_AU37.rod
VCID: 3829263522DEF87A770-806C
Subsystem 1 - Part No SW: 5Q0 907 568 A HW: 8T0 907 568 B
Component: SWA Slave H05 0071
Serial number: 0341763675
Coding: 030211
Part No SW: 5Q0 959 393 B HW: 5Q0 959 393 B
Component: TSG FS 020 0025
Serial number: 12081403110348 Dataset Number: 8V0909872E 0030
Coding: 00100F200000048000000002
VCID: 3E25302D00FAC64ABDC-806A
Part No SW: 5Q0 909 144 P HW: 5Q0 909 144 P
Component: EPS_MQB_ZFLS 123 1043
Dataset Number: 8V0909852J 0020
Coding: 0102
ROD: EV_SteerAssisMQB_010.rod
VCID: 41DF4BD17104B9B2C0E-8014
Part No SW: 5Q0 959 392 B HW: 5Q0 959 392 B
Component: TSG BFS 020 0025
Serial number: 15081406070975 Dataset Number: 8V0909873E 0029
Coding: 001007204400048000000002
VCID: 3D2737210DFCDD52A46-8068
Address 55: Headlight Range (J431) Labels:| 5Q0-907-357.clb
Part No SW: 5Q0 907 357 HW: 6R0 907 357 A
Component: LWR-ECU 005 0080
Revision: -------- Serial number: -------------- Dataset Number: 8V0909865L 0038
Coding: 012A000101000000
ROD: EV_HeadlRegulVWLWRMQB_VW37.rod
VCID: 75B7EF01754C4512AC6-8020
Address 5F: Information Electr. (J794) Labels:| 8V0-035-MIB-STD1.clb
Part No SW: 8V0 035 844 HW: 8V0 035 844
Component: MU-S-S-US 013 0626
Serial number: A7A02508142576 Dataset Number: 8V1909545D 0039
Coding: 01730100FF0A000021220001001A00002F0003040100010002
ASAM Dataset: EV_MUStd6C3PASE 002020
ROD: EV_MUStd6C3PASE.rod
VCID: 76B5E80D684A4E0AA5C-8022
Multimedia display unit 1:
Subsystem 1 - Part No SW: 8V0 919 603 C HW: 8V0 919 603 C
Component: DU Std H49 0013
Serial number: AUZ8Z9EY305LAE
Subsystem 2 - Part No SW: 8V0 919 614 P HW: 8V0 919 614 P
Component: ControlUnit_B H41 0054
Serial number: C1000014071400030060
Reset counter: 4
Mileage: 94148 km
Date: 2025.02.08
Time: 16:10:53
Voltage terminal 30: 11.5 V
Satellite radio tuner status-SDARS Flash Regional code: US_Audio_Traffic_Travellink
0010 - Antenna for Satellite Radio
B10F4 11 [00001000] - Short to Ground
Reset counter: 79
Mileage: 94148 km
Date: 2025.02.08
Time: 16:10:30
Satellite radio tuner status-SDARS Flash Regional code: Delivery_State_for_FPO
Part No SW: 5Q0 907 441 A HW: 5Q0 907 441 A
Component: MQB RVC Mid H07 0140
Dataset Number: 8V0909460C 0017
Coding: 027300010201000300
ROD: EV_2CamSysRearPASE.rod
VCID: 30391E15CAAE203A3F0-8064
Part No SW: 5Q0 959 395 B HW: 5Q0 959 395 B
Component: TSG HFS 020 0025
Serial number: 05081406070631 Dataset Number: 8V0909897C 0017
Coding: 000007204000048000000002
ROD: EV_DCURearDriveMAXKLO.rod
Component: TSG HBFS 020 0025
Serial number: 05081404080625 Dataset Number: 8V0909896C 0017
ROD: EV_DCURearPasseMAXKLO.rod
End----(Elapsed Time: 01:42, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
------------------------------7 Faults Found-------------------------------
