Aftermarket Parking Light Not Working VW Passat B6 2008 TDI
ZTV
C?ID=206766
Hi,
Can someone help with these fault codes. I have tried multiple CANBUS 'error free' parking lights and headlights and they seem to work when I unlock the car, but once I start the car and drive an error comes up for the left parking light (Daytime Running) and it does not work.
I get a similar issue with my left headlight too. It works buts flickers about 5 times when the car is started. The right one always works.
I also have this fault code 005714 - Please check DTC Memory of Transmission Controller - unsure what it is.
Lights I am using:
Headlights:
https://www.amazon.com.au/dp/B07HD79TCT/
Parking light:
Radio is an aftermarket Pioneer touch-screen CarPlay one but works without issue.
If the lights are an issue I am open to alternative LED ones.
VCDS Version: 25.3.0.3 (x64)
Chassis Type: 3C (3C0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 53 56 62 72 76
Mileage: 195100km-121229miles
Address 01: Engine        Labels: 03G-906-018-BMN.clb
   Part No SW: 03G 906 018 AS    HW: 03G 906 018 AS
   Component: R4 2.0l PPD1.2 G    9925
   Revision: --H52---    Serial number: VWZCZ000000000
   Coding: 0000078
   Shop #: WSC 00028 028 00001
   VCID: 76E3E3990168262BEA-8022
   VINID: 9E69EAAAA0D3A88801009048142B11EFD3
               P1652 - 008 -
                    Fault Status: 01001000
                    Mileage: 195102 km
                    Date: 2025.03.11
                    Time: 12:52:12
                    Torque: 0.0 Nm
                        0.00 %
                    Voltage: 11.64 V
                    Bin. Bits: 00000001
                    Bin. Bits: 00000000
Readiness: N/A
   Revision: 00H54000    Serial number: 01000005560589
   Coding: E1808F0700041A00470A00000F00000000085D435C000100000000000000
   VCID: 71E9D085680601133F-8024
   Subsystem 1 - Part No: 3C2 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer 150208 022  0601
   Coding: 00046997
   Shop #: WSC 00028
   Component: RLS     110308 046  0204
   Coding: 00208933
   Shop #: WSC 00028
                    Fault Status: 00101100
                    Reset counter: 113
                    Mileage: 183514 km
                    Date: 2024.05.06
                    Time: 17:31:00
                    Voltage: 13.75 V
                    Fault Status: 01101100
                    Reset counter: 73
                    Mileage: 183514 km
                    Date: 2024.05.06
                    Time: 17:31:00
                    Voltage: 13.85 V
01117 - Generator Terminal DF Load Signal
                    Reset counter: 113
                    Mileage: 194629 km
                    Date: 2025.02.26
                    Time: 14:16:00
                    Voltage: 12.75 V
                    Fault Status: 00101010
                    Reset counter: 113
                    Mileage: 190891 km
                    Date: 2024.11.28
                    Time: 19:56:00
                    Voltage: 13.35 V
                    Reset counter: 109
                    Mileage: 195001 km
                    Date: 2025.03.07
                    Time: 19:39:00
                    Voltage: 13.50 V
Address 56: Radio
Thank you
Derek
UK (ilexa)
C?ID=56983
Is that the full autoscan after VCDS has finished?
Please run another scan and see if the rest of the modules show up and post that
For the lights, I'd first put all the original bulbs back in and clear the fault codes in 09, then recheck for fault codes to see if there's a problem with the car
Best regards
Derek
ZTV
C?ID=206766
Best regards
Derek
Hey Derek,
Thanks for your reply.
Below is the full scan, I repaired the Auto Trans fault and cleared it after posting the original message.
I replaced the lights with the original halogen bulbs and they functioned normally.
Wednesday,12,March,2025,05:56:23:44827
   Coding: 0000078
               P1652 - 008 -
                    Mileage: 195102 km
                    Date: 2025.03.11
                    Time: 12:52:12
                    Torque: 0.0 Nm
                        0.00 %
                    Voltage: 11.64 V
                    Bin. Bits: 00000001
                    Bin. Bits: 00000000
Readiness: N/A
   Part No SW: 02E 300 050 C    HW: 02E 927 770 AE
   Component: GSG DSG         082 1403
   Revision: 04708020    Serial number: 00000802070467
   VCID: 122BBF090DC09A0B66-8046
                    Fault Status: 00101101
                    Fault Frequency: 255
                    Mileage: 195102 km
                    Date: 2025.03.11
                    Time: 12:52:12
Address 03: ABS Brakes        Labels:. 3C0-614-109-C4.clb
   Part No SW: 3C0 614 109 D    HW: 3C0 614 109 D
   Component: J104    C4 440 V2   0003
   Revision: --020---    Serial number: 00000785309313
   Coding: 0003357
   VCID: 1F4DE63DCE12C763D9-804A
Address 08: Auto HVAC        Labels: 3C0-907-044.clb
   Part No SW: 3C0 907 044 DA    HW: 3C0 907 044 DA
   Component: ClimatronicPQ46 132 0811
   Revision: 00132023    Serial number: 00000000000000
   VCID: 63C5AACDA2FAA383BD-8036
   Coding: 00046997
   Shop #: WSC 00028
   Coding: 00208933
   Shop #: WSC 00028
                    Reset counter: 113
                    Mileage: 183514 km
                    Date: 2024.05.06
                    Time: 17:31:00
                    Voltage: 13.75 V
                    Reset counter: 73
                    Mileage: 183514 km
                    Date: 2024.05.06
                    Time: 17:31:00
                    Voltage: 13.85 V
                    Reset counter: 113
                    Mileage: 194629 km
                    Date: 2025.02.26
                    Time: 14:16:00
                    Voltage: 12.75 V
                    Reset counter: 113
                    Mileage: 190891 km
                    Date: 2024.11.28
                    Time: 19:56:00
                    Voltage: 13.35 V
                    Reset counter: 109
                    Mileage: 195001 km
                    Date: 2025.03.07
                    Time: 19:39:00
                    Voltage: 13.50 V
   Part No SW: 5N0 959 655     HW: 5N0 959 655
   Component: J234__00R VW10 HI   1815
   Revision: 19013000    Serial number: 0039BP3YC5BR
   Coding: 0012370
   VCID: 7AFBF7A93570424B8E-802E
   Subsystem 1 - Serial number: 6333FTS649570438
   Subsystem 2 - Serial number: 6343FTS618600538
   Subsystem 3 - Serial number: 6353ETS6K5HJSVNP
   Subsystem 4 - Serial number: 6363ETS6H7LJSVNP
   Part No SW: 3C0 953 549 AC    HW: 3C0 953 549 AC
   Component: J0527               0020
   Revision: 00026000    Serial number: 3C5953507AR
   Coding: 0001111
   VCID: 6DD1CCF5743EE5F31B-8038
   Part No SW: 3C0 920 871 E    HW: 3C0 920 871 E
   Component: KOMBIINSTRUMENT VD1 1216
   Revision: V0002000    Serial number: 00000000000000
   Coding: 0007105
   Shop #: WSC 30114 959 98466
   VCID: 2643F3D9914816AB9A-8072
Address 19: CAN Gateway        Labels:. 3C0-907-530-V2.clb
   Part No SW: 3C0 907 530 E    HW: 3C0 907 951
   Component: J533__Gateway   H10 0080
   Revision:   H10       Serial number: 1200P083030DA3
   Coding: FD807F0E0002021003
   VCID: 2345EACDE27AE383FD-8076
   Part No SW: 3C0 959 433 R    HW: 3C0 959 433 R
   Component:    IMMO         042 0383
   VCID: 397928A570F68953C7-806C
   Component:    ELV          027 0380
   3C0905861G     ELV          027 0380
   Component: J386  TUER-SG FT    1132
   Revision: 32008001    Serial number: 00000039888227
   Coding: 0000693
   VCID: 3B7532AD7ACABB43D5-806E
   Part No: 1K2 909 144 M
   Component: EPS_ZFLS Kl.135 H08 1901
   Shop #: WSC 40386 002 1048576
   VCID: 3663239941E8662B2A-8062
   Component:    KSG PQ46 ELV 042 0472
   Coding: 00910A0001860E763004941570085F0B007801
   Component: J387  TUER-SG BT    1132
   Revision: 32008001    Serial number: 00000639488225
   Coding: 0000692
   VCID: 3C7731B17FC4BC7BDC-8068
   Part No SW: 3C0 907 801 J    HW: 3C0 907 801 J
   Component: J540 EPB3  VW-09393 0009
   Revision:   008       Serial number: 00000000372942
   Coding: 0000057
   VCID: 2959F8E5805639D3B7-807C
Address 56: Radio
   Part No SW: 1K0 959 703 AB    HW: 1K0 959 795 L
   Component: J388   TUER-SG HL   0308
   Revision: 41004101    Serial number: 00000000254393
   Coding: 0000144
   VCID: 70EFD581630C081B30-8024
   Part No SW: 1K0 959 704 AB    HW: 1K0 959 794 L
   Component: J389   TUER-SG HR   0308
   Revision: 41004101    Serial number: 00000000262802
   Coding: 0000144
Address 76: Park Assist        Labels: 3C0-919-283.lbl
   Part No SW: 3C0 919 283 C    HW: 3C0 919 283 C
   Component: Parkhilfe 8-Kan 004 0013
   Revision: 00004000    Serial number: 90640806004149
   Coding: 0001014
End
-------------------------(Elapsed Time: 02:11)--------------------------
------------------------------7 Faults Found----------------------------------
CANBUS 'error free'
I'm not aware of any that really emulate the characteristics of an incandescent/halogen bulb, which have a really big temperature coefficient; much lower resistance when off than when lit.
You can try turning off Cold Lamp Diagnosis (Byte 2, Bit 2) in your CECM at address 09, and also have a look at the individual Cold Diagnosis bits in Bytes 18 and 19, but I don't have much confidence that this will really fix things for you.
ZTV
C?ID=206766
I'm sorry for delay Uwe. Thank you for your help
