Keep radio/Bluetooth going after turning ignition off
danorner
C?ID=581179
Hi,
Any tweak(s) to keep radio/Bluetooth going after I turn off the ignition on my Golf R MK6?
I know I can turn it all back on right after I cut ignition, but I'd like to avoid the part where everything cuts out for 10-15 seconds (it takes about that long for Bluetooth to reconnect).
And I am a-okay with the risk of me having to remember to turn everything off or battery goes dead.
Thanks!
Derek
UK (ilexa)
C?ID=56983
Please post an autoscan as there are many different module combinations that could be on your car
Best regards
Derek
danorner
C?ID=581179
Friday,03,January,2025,18:05:56:32025
VIN: WVWPF7AJ7DW073639   License Plate:
Mileage: 123510km-76745mi   Repair Order:
Chassis Type: AJ-VW36 (7N0)
Scan: 01 03 05 08 09 15 16 17 19 22 25 2B 2E 37 42 44 46 47 52 55
          56 62 72
VIN: WVWPF7AJ7DW073639   Mileage: 123510km-76745miles
Address 01: Engine (CRZ)       Labels:. 06F-907-115-CDL.clb
   Part No SW: 5K0 907 115 M    HW: 8P0 907 115 B
   Component: 2.0l R4/4V TFSI     0030
   Revision: 5BH21---    Serial number:
   Coding: 0403010A180F0160
   VCID: 34310B04023CBE3A8B3-8060
   VINID: 9E69E058745A1D49C01C3183248A02EFAA
               P0300 - 008 -  - Intermittent
                    Mileage: 122841 km
                    Date: 2019.05.27.
                    Time: 07:48:36
                    RPM: 1154 /min
                    Load: 38.8 %
                    Temperature: 9.0°C
                    Temperature: 10.0°C
                    Absolute Pres.: 860.0 mbar
                    Voltage: 14.224 V
000771 - Cylinder 3
               P0303 - 008 - Misfire Detected - Intermittent
                    Mileage: 122841 km
                    Date: 2019.05.27.
                    Time: 07:49:47
                    RPM: 2792 /min
                    Load: 36.8 %
                    Speed: 52.0 km/h
                    Temperature: 26.0°C
                    Temperature: 7.0°C
                    Voltage: 14.097 V
000772 - Cylinder 4
               P0304 - 008 - Misfire Detected - Intermittent
                    Mileage: 122841 km
                    Date: 2019.05.27.
                    Time: 07:49:47
                    RPM: 2792 /min
                    Load: 36.8 %
                    Speed: 52.0 km/h
                    Temperature: 26.0°C
                    Temperature: 7.0°C
                    Voltage: 14.097 V
000770 - Cylinder 2
               P0302 - 008 - Misfire Detected - Intermittent
                    Mileage: 122841 km
                    Date: 2019.05.27.
                    Time: 07:49:47
                    RPM: 2792 /min
                    Load: 36.8 %
                    Speed: 52.0 km/h
                    Temperature: 26.0°C
                    Temperature: 7.0°C
                    Voltage: 14.097 V
   Revision: 00H31001
   Coding: 144BE00C492900FD281107E792220041B70000
   VCID: 7DA7EE207DF6BF7234D-8028
   Part No SW: 5K0 959 434 B    HW: 5K0 959 434
   Component: VWKESSYPQ35GP 085 0902
   Revision: 00085000    Serial number: 0182373623 Dataset Number: 5K0116v____ 5K0C
   Coding: 030C0C
   ROD: EV_KESSYPQ35G_A02_VW32.rod
   VCID: 34310B040EBCBE3A8B3-8060
   Part No SW: 5K0 907 044 GP    HW: 5K0 907 044 GP
   Component: Climatronic   H19 1212
   Revision: 00001004
   Coding: 0010002002
   VCID: 7F5B1428777AAD62261-802A
   Part No SW: 1K0 937 084 J    HW: 1K0 937 084 J
   Component: BCM PQ35  B   111 0709
   Revision: AB111709
   Coding: 6F180A1A90232AC4108800C170000CC448852086770D8DB0E48420248040
   VCID: 353736000546A732BCD-8060
   Subsystem 1 - Part No: 5K1 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer 16071  26  0512
   Coding: 009795
   Part No SW: 5C0 959 655 M    HW: 5C0 959 655 M
   Component: AirbagVW10G   014 0726
   Serial number: 003L4R003S66   Dataset Number: 5K0003v__B_ 0076
   Coding: 00004733
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 3C21232426EC767A433-8068
   Subsystem 1 - Part No SW: 5K0 959 339 B    HW: 5K0 959 339 B
   Component: BF-Gewichtss.  006 0001
   Serial number: ---0000R--00004U3P00
   Serial number: 3572MSME7064556FZZZ+
   Serial number: 3582MSME3442536FZZZ-
   Serial number: 3512QSME4E411863ZZZW
   Serial number: 3522QSME663F0F52ZZZ1
   Serial number: 35527SME3D293A2EZZZW
   Serial number: 35627SME29113B2EZZZK
   Part No SW: 5K0 953 521 BR    HW: 5K0 953 569 E
   Revision: FF010041    Serial number: 20120719100406
   Coding: 1002140000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 7DA7EE207D76BF7234D-8028
   Component: E221__MFL-TAS  H31 0033
   Coding: 820000
   Part No SW: 5K6 920 973 E    HW: 5K6 920 973 E
   Component: KOMBI         H05 0705
   Coding: 270D01
   VCID: 392F3A3029DE4352585-806C
   Part No SW: 7N0 907 530 R    HW: 7N0 907 530 H
   Component: J533  Gateway H42 1632
   Revision:   H42       Serial number: 200712F2000782
   Coding: 350002
   VCID: 3FDB5428377A6D62661-806A
                    Fault Status: 01110100
                    Reset counter: 23
                    Mileage: 117223 km
                    Date: 2019.05.27.
                    Time: 12:33:44
   Part No SW: 0BR 907 554 C    HW: 0BR 907 554 C
   Component: Haldex 4Motion      3018
   Coding: 0000005
   VCID: 45D746C059A637B22CD-8010
   Component: IMMO          H05 0705
   Coding: 000007
   VCID: 6A8DD57C1CF838CAE1F-803E
   Part No SW: 5K0 905 861 B    HW: 5K0 905 861 B
   Component: ELV-PQ35      H20 0240
   Revision: 00000000    Serial number: 12000166856004
   Coding: 4100000000000000
   ROD: EV_ELVMarquMPVW36X_VW32.rod
   VCID: 2F3B0468E79A9DE2F61-807A
   Component: SG EXT.PLAYER H18 0530
   Revision: A1001003    Serial number: 7663139832
   Coding: 020100
   VCID: 2A0D157CDCF8F8CA21F-807E
   Part No SW: 1K0 035 274 D    HW: 1K0 035 274 D
   Component: RNS315-NAR    H53 0319
   Serial number: VWZAZ2M4261057
   Coding: 04050001010005000000100A
   ROD: EV_RNS315NARV2UDS_VW36.rod
   VCID: 2517E640B566D7B20CD-8070
   Component: NAR_V3_(0037)  0037
                    Reset counter: 31
                    Mileage: 112697 km
                    Date: 2025.01.03.
                    Time: 13:59:54
   Part No SW: 5K0 959 701 B    HW: 5K0 959 701 B
   Component: Tuer-SG         009 2119
   Coding: 0001204
   VCID: 313F0210FD2E8B12E05-8064
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 251    3305
   Revision: 00H22000
   VCID: 372B3C08134A5522AE1-8062
   Part No SW: 5K0 035 456 B    HW: 5K0 035 456 B
   Component: KonzernAmp 8K H07 0368
   Revision: --------    Serial number: EAA085A0039054 Dataset Number: 1K8050v____ 5K04
   ASAM Dataset: EV_AudioVerst8KanalBNO1 A01003
   ROD: EV_AudioVerst8KanalBNO1.rod
   VCID: 290FEA70D97EF3D2285-807C
   Part No SW: 5K0 959 702 B    HW: 5K0 959 702 B
   Coding: 0001204
   VCID: 323D0D1CF828B00A99F-8066
Address 55: Headlight Range        Labels: 5M0-907-357-V2.clb
   Coding: 1479708
   Component: AFS-Lst.-Modul l    0005
   Coding: 00000022
   Subsystem 2 - Part No: 7L6 941 329 B  Labels: 3D0-941-329.CLB
   Component: AFS-Lst.-Modul r    0005
   Coding: 00000022
   Coding: 0001168
   Shop #: WSC 01357 011 1012552
   VCID: 353736000946A732BCD-8060
   Coding: 0001168
   VCID: 3635310C1440AC2AB57-8062
End----(Elapsed Time: 01:15, VBatt start/end: 11.7V/11.7V. VIgn 11.8V)-----
