2011 Jetta TDI Cluster Swap TO a 2012 GLI Cluster. Is this possible?
Billyska
Canada
C?ID=603240
Hi all I've been wanting too add a GLI Cluster to my 2011 Jetta TDI because id like the Temperature Gauge and Gas Gauge Needles, instead of the digital Gas. also the Screen is much bigger on the GLI. I've seen around people doing this, but I'm unsure about the immobilizer part and how to retrieve the Pin Numbers from each cluster. I already have the steering Wheel Upgraded with Paddle Shift Buttons and the left and right Controls. I did try installing the cluster to test it and it seems to work with a few coding errors obviously but the main one which is immobilizer is deactivated therefore not allowing the car to start. are there any clear instructions on how to recode all this with VCDS.. Ive searched the forum but most is for Older MOdels like 2008.
Thanks!
2kaa52
Ceska Republica, Praha
C?ID=319193
It is possible, But Not with VCDS.
Pin Method dont Work any more for this Type of Cluster.
You need Special Tool or Dealer visit.
