- Aug 22, 2014
- 519
- 235
- Maryland, USA
- C?ID=66650
I did oil filter housing replacement work on this car so i R&R the intake manifold, used new gasket, new throttle body gasket as well but car records intake system air leak. I also have this beetle which misfires only in cylinder #4. I have checked vacuum leaks, non found but the pcv diaphragm looked so old and tiny holes so i replaced it but still. I removed and rechecked intake manifold again but all gaskets look fine. No carbon deposit found on valves! No cracks found in intake air hose. I did carry out smoke test but nothing significant found. Also the misfire in cylinder 4 occurs only when at vehicle station and idling mode with gear in Park but no misfire occurs while driving. I replaced spark plug and coil for Cyl #4 but no change. MVB 032 shows 0.0% idle self adaption but 10.2% Lambda self partial adaptation.
My next move will be to check compression and test the #4 injector, but strangely car still accelerates well during the 6 mile test drive. Any leads will be appreciated!
Thursday,13,March,2025,16:13:40:46890
VCDS Version: 24.7.1.0 (x64)
VIN: License Plate: MY BEETLE
Address 01: Engine (07K 906 032 BS)
16:13:31 Group 016: Misfire Recognition
37 Cylinder 4
0 Cylinder 5
Enabled
Address 01: Engine Labels: 06A-906-032-BGP.LBL
Control Module Part Number: 07K 906 032 BS HW: 07K 906 032 AA
Component and/or Version: NB R5 AT G 1355
Software Coding: 0000003
Work Shop Code: WSC 00066 000 00000
VCID: 7BFE3EF539524A4E9E-5120
008825 - Leak in Air Intake System
P2279 - 008 - - Intermittent
Mileage: 193038 km
RPM: 645 /min
Load: 22.3 %
Temperature: 101.0 C
Temperature: 20.0 C
Absolute Pres.: 990.0 mbar
Voltage: 12.827 V
Readiness: 0110 1101
16:14:27 Group 015: Misfire Recognition
0 Cylinder 1
0 Cylinder 2
0 Cylinder 3
Enabled Malfunction Recognition
16:14:27 Group 032
0.0 % Lambda (Idle) Self-Adaptation
10.2 % Lambda (Partial) Self-Adaptation
16:14:27 Group 033
25.0 % Bank 1 Lambda Control
2.000 V Bank 1 Voltage of Oxygen Sensors
16:14:35 Group 016: Misfire Recognition
1 Cylinder 4
0 Cylinder 5
Enabled
16:14:35 Group 032
16:14:35 Group 033
1.980 V Bank 1 Voltage of Oxygen Sensors
16:15:12 Group 016: Misfire Recognition
44 Cylinder 4
0 Cylinder 5
Enabled
16:15:12 Group 032
16:15:12 Group 033
16:15:18 Group 015: Misfire Recognition
0 Cylinder 1
0 Cylinder 2
0 Cylinder 3
16:15:18 Group 032
16:15:18 Group 033
16:16:05 Group 016: Misfire Recognition
4 Cylinder 4
0 Cylinder 5
Enabled
16:16:05 Group 032
16:16:05 Group 001
640 /min Engine Speed
99.0 C Coolant Temperature
25.0 % Lambda Controller
01111111 Basic Setting Requirements
16:16:54 Group 016: Misfire Recognition
53 Cylinder 4
0 Cylinder 5
Enabled
16:16:54 Group 032
16:16:54 Group 001
680 /min Engine Speed
98.0 C Coolant Temperature
16:17:24 Group 016: Misfire Recognition
0 Cylinder 4
0 Cylinder 5
Disabled
16:17:24 Group 032
16:17:24 Group 001
2520 /min Engine Speed
97.0 C Coolant Temperature
9.4 % Lambda Controller
01111001 Basic Setting Requirements
