2015 s3 sedan scan
C?ID=255798
audi
s3
2015
sedan
scan.
need help know whats wrong and possible fixes.
these items just popped up one day. not sure exactly when as i have the car mapped with cobb accessport so the cel is always on.
how i found this, i did a scan for another issue and fixt it. but then i saw these items come up. didn't think much about them till i started getting actual issues that randomly come up now.
- second key fob is not working correctly. it can lock and unlock but will not be recognized by the car to start up engine or even ACC functions.
- noticed engine start is now weaker than before. Occasionally, it will be hard to start up, but does start up. battery is full.
*13.6v - overnight, then tested in the morning. same reading on batt even before this issue. battery is still good.
*replaced alternator for new higher output alternator. tested charging state. puts out at idle 13.8-14.5 volts.
- The rear camera flickers randomly when in reverse. had issues before with it but fixed known broken cables. new cables are installed and reduced issues. from 8/10 occurrences down to only 1.5/10 occurrences with fixed cables in the trunk.
- transmission seems to feel weaker when shifting. not as crisp.
- other key fob works but is weak. initially i thought the fob batt needed replacing but its been replaced multiple times in a couple of months. door touch lock and unlock is weak. may work or not work at times. pressing buttons on fob works but seems to lag a little longer than before.
- can not initialize the HVAC system after replacing the motors affected with issues. motor works perfectly and HVAC flap works now. before it wouldn't fully open certain ports but not it does. i just cant do the simple initialization through vcds or obd11. i have both systems to work on this.
i have attempted to remove cobb while doing all this and it doesn't make a difference.
i have a clue on what it might be but its a wide assumption. i would like to see if i can get help here with more a direct reason it might be something rather than my guessing. I'm limited on knowledge on how to test but i am willing to learn with guidance.
thanks.
Mileage: 159487km-99100mi   Repair Order:
Chassis Type: FF-AU37 (5Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 2B 3C 42 44 47 52
          55 5F 6C A5 A9 BB BC
VIN: WAUFFGFF4F1112359   Mileage: 159487km-99100miles
Address 01: Engine (J623-CYFB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8V0 9C0 BB0 1    HW: 06K 907 425 E
   Component: 2.0l R4 TFSI  H13 0001
   Revision: --H13---    CVN: 2EA6E527
   Coding: 0A1D00322466000E3004
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_ECM20TFS0208V09C0BB01 001002
   ROD: EV_ECM20TFS0208V09C0BB01.rod
   VCID: 4FAD25CB161CA7EE02-801A
   VINID: 9D19565975961160410420C5246E0356A0
No ASAM data for: "EV_ECM20TFS0208V09C0BB01" (AU37)
18933 - ROD - Unknown Error Code
          - 00 [11101101]
                    Mileage: 157941 km
                    Date: 2025.02.01
                    Time: 11:28:43
   Part No SW: 0D9 300 012 L    HW: 02E 927 770 AQ
   Component: DQ250-6A MQB  H54 4932
   Revision: 06454104    Serial number: TFK02307210304 CVN: 00000725
   Shop #: WSC 04940 001 00001
   ROD: EV_TCMDQ250021.rod
   VCID: 1F4DB58B067C576ED2-804A
   Part No SW: 3Q0 907 379 R    HW: 3Q0 907 379 G
   Component: ESC           H42 0711
   Revision: 00000000    Serial number: 60235000000540
   Coding: 31FF6B9254210A6E017A030541CC698CD62A5080C08296B6184150D88204
   Shop #: WSC 42927 001 104857
   ROD: EV_Brake1UDSContiMK100IPB_034_AU37.rod
   VCID: 49990BD3E87889DE5C-801C
   Revision: 00021000    Serial number: 0358576375 Dataset Number: 8V0909577C  0009
   Coding: 030C0C
   VCID: 3A7B641FBD9E1246C5-806E
   Component: AC Automat    H13 0060
   Revision: 20027000    Serial number: 00000000561678
   Coding: 03000014010000000000000000001400
   VCID: 3365493B9AF4E30E06-8066
   Humidity sensor: exterior:
   Serial number: F188CE87000000000001
329989 - Motor for Defroster Flap
          B1090 54 [00001001] - Missing Calibration / Basic Setting
                    Reset counter: 83
                    Mileage: 157895 km
                    Date: 2025.01.31
                    Time: 11:24:27
                    Voltage terminal 30: 13.0 V
                    Inside temperature: 22.8  C
                    Outside temperature: 17.5  C
                    Defrost door - Specified value: 258
                    Defroster flap: actual value: 256
                    Defroster flap: actual value: 20.5 %
   Part No SW: 5Q0 937 085 AC    HW: 5Q0 937 085 AC
   Component: BCM MQBAB HNA H18 0137
   Serial number: 01011502600303 Dataset Number: 8V0909514L  0083
   Coding: 04151C46C04106FD45C04004510003A00800000000000000000000000000
   Shop #: WSC 12345 123 61029
   ROD: EV_BCMBOSCH_013.rod
   VCID: 7AFBA41FFD1ED24685-802E
   Component: WWS371 150126  042 0585
   Serial number:         150130064653
   Coding: 0A47F7
   Serial number: 23684779
   Coding: 00006C
   Serial number: 04 12 2014  00000016
   Serial number: 00000000000061570698
   Sunroof control module:
   Component: J245 PS73.404  H03 0004
   Serial number: 0000FST0004HHUW00000
   Coding: 101F00
   Part No SW: 5Q0 919 294 J    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0051
   Revision: --------    Serial number: 39391502709595 Dataset Number: 8V0909526D  0040
   Coding: 0070150011
   ROD: EV_EPHVA18AU3700000_VW26.rod
   VCID: 428B1CFFD54E5A869D-8016
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-567.clb
   Part No SW: 5Q0 907 567 N    HW: 5Q0 907 567 N
   Component: ACC3          H10 0400
   Serial number: 29011503033504 Dataset Number: 8V0909863C  0015
   Coding: 01261701FE0309
   ASAM Dataset: EV_ACCBoschMQB 001024
   ROD: EV_ACCBoschMQB_AU37.rod
   VCID: 468300EFF96666A6B1-8012
0049 - Sensor for Automatic Distance Control
          C110B F0 [00101000] - Limited Visibility
Address 14: Susp. Elect. (J250)       Labels: 8V0-907-376.clb
   Part No SW: 8V0 907 376 E    HW: 8V0 907 376 E
   Component: DAEMPFUNGS-SG H09 0072
   Serial number:       280115002 Dataset Number: 8V0909554D  0013
   ASAM Dataset: EV_AudiMagneRide 002003
   ROD: EV_AudiMagneRide.rod
   VCID: 438519FBCA54538E96-8016
   Serial number: 003GCR01BWV4 Dataset Number: 8V0909602F  0005
   VCID: 479D0DEBFE6C7FAE4A-8012
   Left seat belt tensioner:
   Serial number: 34178311B02021541509
   Coding: 333135
   Right seat belt tensioner:
   Serial number: 34178312B02021541326
   Coding: 333135
   Subsystem 3 - Part No SW: 5C6 959 339 C    HW: 5C6 959 339 C
   Component: BF-Gewichtss.  H10 0047
   Serial number: 6940000Y140001A5F508
   Coding: 303436
   Subsystem 4 - Part No SW: -----------    HW: 480 002 901 15
   Serial number: 35700000000ABA3D721T
   Subsystem 5 - Part No SW: -----------    HW: 480 002 901 15
   Serial number: 35800000000BEA3D721Y
   Subsystem 6 - Part No SW: -----------    HW: 480 402 801 15
   Serial number: 3510002C9192BC713350
   Subsystem 7 - Part No SW: -----------    HW: 480 402 601 15
   Serial number: 35200029B19121A3828Y
   Subsystem 8 - Part No SW: -----------    HW: 480 403 110 14
   Serial number: 3550002A91860BA303F5
   Subsystem 9 - Part No SW: -----------    HW: 480 403 110 14
   Serial number: 3560002A91860BA1517%
Address 16: Steering wheel (J527)       Labels:. 5Q0-953-549.clb
   Part No SW: 8V0 953 521 ED    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 27011508490397
   Coding: E818
   ROD: EV_SMLSKLOMQB_010_VW37.rod
   VCID: 000FD6F79BC28896CB-8054
No ASAM data for: "EV_SMLSKLOMQB" (AU37)
   Part No SW: 8V0 920 970 S    HW: 8V0 920 970 S
   Component: KOMBI         H02 4292
   Coding: 03CD181B7F88CF050289FA041800000200000000
   VCID: 4C9732C7E70A9CF667-8018
9456681 - Key
          B104C 29 [00001000] - Implausible Signal
                    Mileage: 158707 km
                    Date: 2025.02.18
                    Time: 06:24:29
   Revision: --------    Serial number: 31011510802262 Dataset Number: 8V0909515F  0060
   Coding: 0101000830085A005B00023C980B00000001010000000000000000000000
   GVL: 01D43C100000060040CC90000002CC0000000000000000000000000000000000
   ROD: EV_GatewConti_011.rod
   VCID: 72EB8C3FA56EAA06CD-8026
   Generator:
   Subsystem 2 - Part No SW: 8U0 951 528 C    HW: 8U0 951 528 C
   Serial number: 17 01 2015  D0050847
   Part No SW: 0CQ 907 554 D    HW: 0CQ 525 130
   Component: Haldex4Motion H52 7082
   Serial number: HA1-00019.11.14 Dataset Number: v1260x015G0 0000
   Coding: 0001
   ASAM Dataset: EV_AllWheelContrHA1VW37X 002013
   ROD: EV_AllWheelContrHA1VW37X_002_VW36.rod
   Revision: 00000000    Serial number: 15000016664003
   Coding: 5D00000000000000
   VCID: 34674A279FFAE4361F-8060
   Part No SW: 5Q0 907 566 A    HW: 8T0 907 566 B
   Serial number: 0355372304 Dataset Number: 8V0909535E  0033
   Coding: 030211
   ROD: EV_LaneChangAssis_VW52.rod
   VCID: 387F7E178392005633-806C
   Subsystem 1 - Part No SW: 5Q0 907 568 A    HW: 8T0 907 568 B
   Component: SWA Slave  H05 0071
   Serial number: 0357648676
   Coding: 030211
   Serial number: 250115BAP05331 Dataset Number: 8V0909872F  0032
   Coding: 005D1F205C00048000000003
   ROD: EV_DCUDriveSideEWMAXKLO.rod
   Part No SW: 3Q0 909 144 H    HW: 3Q0 909 144 H
   Component: EPS_MQB_ZFLS  505 5061
   Dataset Number: 8V0909852K  0022
   Coding: 9102
   VCID: 377D7D2B8E8C0F2E3A-8062
   Part No SW: 8V0 035 465 C    HW: 8V0 035 465
   Component: MIBAMP1ALPINE H11 0410
   Serial number: AUZ8ZAEN90108U+ Dataset Number: 8V0909510B  0017
   Coding: 01030300AAAA2AAA01
   ASAM Dataset: EV_AMPMst16C1ALPI 004024
   ROD: EV_AMPMst16C1ALPI_004_AU37.rod
   Serial number: 220115BAL11867 Dataset Number: 8V0909873F  0032
   Coding: 005D17205E00048000000003
   ROD: EV_DCUPasseSideEWMAXKLO.rod
   VCID: 418913F3D048419E84-8014
   Component: AFS-ECU       H01 0091
   Revision: --------    Serial number: -------------- Dataset Number: 8V0909865L  0038
   Coding: 0122000123200400
   VCID: 3F8D150BA6BC376EF2-806A
   Coding: E00100
   Coding: E00100
   Subsystem 3 - Part No SW: 7PP 941 329 M    HW: 7PP 941 329 M  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 7050
   Coding: E00100
   Subsystem 4 - Part No SW: 7PP 941 329 M    HW: 7PP 941 329 M  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 7050
   Coding: E00100
5545009 - LED Headlamp Power Output Stage; Left
          B149C 31 [00001000] - No Signal
                    Reset counter: 195
                    Mileage: 158887 km
                    Date: 2025.02.21
                    Time: 06:58:51
5544753 - LED Headlamp Power Output Stage; Right
          B149B 31 [00001000] - No Signal
                    Reset counter: 175
                    Mileage: 158988 km
                    Date: 2025.02.22
                    Time: 18:34:05
Address 5F: Information Electr. (J794)       Labels:| 8V0-035-MIB-HGH1.clb
   Part No SW: 8V0 035 038 G    HW: 8V0 035 038 B
   Component: MU-H-LNS-US   H43 0394
   Serial number: A302B0FB009458 Dataset Number: 8V2909545F  0045
   Coding: 017301020000000021220002041A00102F000225010001047E
   ROD: EV_MUHig6C3HBAS_VW48.rod
   Subsystem 1 - Part No SW: V03 959 800 SS    HW: -----------
   Component: NAR 2015  --- 0035
   Multimedia System 1:
   Component: DU High  H49 0014
   Serial number: AUZ8Z9EY202HEF
   Subsystem 3 - Part No SW: 8V0 919 614 L    HW: 8V0 919 614 L
   Component: ControlUnit_H  H81 0816
   Serial number: C1000029111400020188
   Compact disc data bank:
   Component: Gracenote  --- 3006
   Dataset Number: 8V0909460C  0017
   Coding: 027300010201000300
   ROD: EV_2CamSysRearPASE_AU37.rod
   VCID: 306F46376BE2D8167B-8064
   Part No SW: 5Q0 980 653 F    HW: 5Q0 980 653
   Component: MQB_MFK       H06 0052
   Serial number: 00000277395    Dataset Number: 8V0909466K  0039
   Coding: 0100000000010303000500010100000100
   ROD: EV_MFKBoschAU370.rod
   VCID: 3B75611BB2A42B4EDE-806E
   Part No SW: 8V0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0012
   Serial number: 150109200749
   VCID: 7DF1AF03EC30E57EA0-8028
   Part No SW: 5Q0 959 395 D    HW: 5Q0 959 395 B
   Component: TSG HFS       020 0028
   Serial number: 140115CAD07887 Dataset Number: 8V0909897D  0018
   Coding: 004D17204000048000000002
   ROD: EV_DCURearDriveMAXKLO.rod
   Component: TSG HBFS      020 0028
   Serial number: 140115CAD07353 Dataset Number: 8V0909896D  0018
   ROD: EV_DCURearPasseMAXKLO.rod
Can you put it back to stock? Due to Cobb's insistence on changing the ECU's software part number and ASAM ID, VCDS doesn't know what data to load for it.
battery is full.
*13.6v - overnight,
Huh? What kind of battery is in this? A battery should read at most ~12.8V after being allowed to rest overnight, no matter how "full" it is. Or perhaps your volt meter is not accurate?
C?ID=255798
need to remove the a/p today and run the car for a little. so ill get back with a new scan.
braille lithium battery. love this type of battery. i got another lithium, brand antigravity, for my other audi. trying different brands to see who is really better. so far both brands works as it should.
tested it this morning just for proof. this has sat over night. its been very consistent anytime i tested it. i have done testing with the car sitting over 8 days before without any charging assistant. same voltage.
OK, that explains it. :thumbs:
Assuming that's a 4S LFP battery, 13.64 V is 3.41 volts per cell, which seems entirely reasonable.
C?ID=255798
so i got to scan it today.
not sure how long issues would normally need to register but i did notice some of the past items did not show up on this scan. the other items were consistent with coming up after a while. since its only been a short drive i dont know it will come up again or was it just a fluke.
ignore the o2 sensor issue since i have a downpipe.
VCDS Version: 25.3.0.3 (x64)
Data version: 20250301 DS365.0
Mileage: 159660km-99208mi   Repair Order:
   Part No SW: 8V0 906 259 E    HW: 06K 907 425 E
   Revision: --H13---    CVN: BEF084D4
   ASAM Dataset: EV_ECM20TFS0208V0906259E 001003
   ROD: EV_ECM20TFS0208V0906259E.rod
   VCID: 428B1CFFD54E5A8B96-8016
18933 - Oxygen (Lambda) Sensor Signal B1 S2
          P2270 00 [11101101] - too Lean
                    Mileage: 159492 km
                    Date: 2025.03.15
                    Time: 11:12:10
                    Engine speed: 2711.00 /min
                    Normed load value: 27.1 %
                    Vehicle speed: 68 km/h
                    Coolant temperature: 102  C
                    Intake air temperature: 24  C
                    Voltage terminal 30: 14.082 V
                    Engine: operating status: PL
                    STATE_LS_SAE[1]: CL
                    VLS_DOWN_SAE[1]: 0.940 V
                    Lambda probe heater: resistance: bank 1: probe 2: 333 Ohm
                    LAMB_DELTA_I_LAM_ADJ[1]: 0.00000
                    Lambda probe correction: duty cycle offset: bank 1: 0.00000
                    TEG_DYN_LS_DOWN[1]: 566.5375  C
Readiness: 0000 0101
   Revision: 06454104    Serial number: TFK02307210304 CVN: 0000D5C0
   VCID: 1F4DB58B067C5763D9-804A
   VCID: 49990BD3E87889D357-801C
   Coding: 030C0C
   ROD: EV_KessyHellaMQBAB_002_VW37.rod
   VCID: 3A7B641FBD9E124BCE-806E
   VCID: 3365493B9AF4E3030D-8066
                    Reset counter: 158
                    Mileage: 159487 km
                    Date: 2025.03.13
                    Time: 21:54:22
                    Voltage terminal 30: 12.5 V
                    Inside temperature: 23.8  C
                    Outside temperature: 19  C
   VCID: 7AFBA41FFD1ED24B8E-802E
   Coding: 0A47F7
   Coding: 00006C
   Coding: 101F00
   Coding: 0070150011
   ROD: EV_EPHVA18AU3700000_002_AU37.rod
   VCID: 468300EFF96666ABBA-8012
   VCID: 438519FBCA5453839D-8016
   VCID: 479D0DEBFE6C7FA341-8012
   Coding: 333135
   Coding: 333135
   Coding: 303436
   Coding: E818
   ROD: EV_SMLSKLOMQB_017.rod
   VCID: 000FD6F79BC2889BC0-8054
   VCID: 4C9732C7E70A9CFB6C-8018
   VCID: 72EB8C3FA56EAA0BC6-8026
   Generator:
   Coding: 0001
   ROD: EV_AllWheelContrHA1VW37X_002_VW37.rod
   VCID: 34674A279FFAE43B14-8060
   Coding: 030211
   ROD: EV_LaneChangAssis_AU37.rod
   VCID: 387F7E178392005B38-806C
   Coding: 030211
   Coding: 9102
   VCID: 377D7D2B8E8C0F2331-8062
   VCID: 418913F3D04841938F-8014
   ROD: EV_HeadlRegulAFSMQBMLB_VW48.rod
   VCID: 3F8D150BA6BC3763F9-806A
   Coding: E00100
   Coding: E00100
   Coding: E00100
   Coding: E00100
                    Reset counter: 200
                    Mileage: 159564 km
                    Date: 2025.03.15
                    Time: 14:21:01
                    Reset counter: 201
                    Mileage: 159656 km
                    Date: 2025.03.16
                    Time: 12:50:50
   Multimedia display unit 1:
   ROD: EV_2CamSysRearPASE.rod
   VCID: 306F46376BE2D81B70-8064
   VCID: 3B75611BB2A42B43D5-806E
   VCID: 7DF1AF03EC30E573AB-8028
End-------------------------(Elapsed Time: 06:57)--------------------------
------------------------------4 Faults Found-------------------------------
C?ID=255798
if you need another scan after another drive i can do that next week. since i dont drive it much lately. i dont know why the car doesn't throw the codes like before quickly.
C?ID=255798
for some reason i cant seem to reset the fault I'm getting.
I just did a replacement on the malfunctioning motor flap and I did perform the basic setting calibration. a few times when the first few times didn't work. i did some research and I found that it might be either the cable or the software is not working right. i don't know for sure tho. is there something else I can try at this point?
during this resetting I did attempt to reset other items as well. i noticed that vcds didn't reset very well with these other modules. i had to do it a couple of times and also I had to drive the car to help reset the modules. Weird, I would say. i never had these issues before.
