Lithium 12v battery coding
SeattleMatt
C?ID=282387
2018 Q7 attempting to replace the OEM AGM with a Lithium 69AH battery with a LifePo4 (from BMW F80). The battery is basically a drop in for a similar AGM.
The problem I am having:
When I set the coding to "Lithium FeP" as well as other parameters 69ah, random serial #, etc. the car starts up and reports "electrical system" malfunction. Checking the charge parameters shows the battery is not receiving any charge and is discharging at 30A while the car is running, indicating that the alternator is not charging at all.
If I simply change coding to "Fleece" without changing the battery, then I do not get any errors, however I read the alternator charge circuit running at 160A when the battery is full, this concerns me that the system is not using a Lithium charge curve obviously.
Thursday,13,March,2025,13:57:40:10308
VCDS Version: 24.7.0.0 (x64)
Mileage: 172200km-107000mi   Repair Order:
Chassis Type  F7-AU73 (8W8)
Scan: 01 02 03 08 09 13 15 16 17 19 28 29 36 39 3C 42 44 46 47 50
          52 5F 69 6C 6D 81 82 8B A5 BB BC CA CF D6 D7
29-Left Light -- Status: INTERFACE NOT COMPATIBLE
39-Right Light -- Status: INTERFACE NOT COMPATIBLE
50-Seat Adj. 3rd row -- Status: OK 0000
CA-Sunroof -- Status: OK 0000
D6-Light Ctrl Left 2 -- Status: INTERFACE NOT COMPATIBLE
D7-Light Ctrl Right 2 -- Status: INTERFACE NOT COMPATIBLE
Address 01: Engine (J623-CREC)       Labels:. 06E-907-551-CGW.clb
   Part No SW: 4M0 907 551 A    HW: 06E 907 425
   Component: 3.0l V6 TFSI  H10 0005
   Revision: --H10---    CVN: 08BDF7A0
   Coding: 2A2A00320576010D74280000000000000000000000000000
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_ECM30TFS0214M0907551A 001007
   ROD: EV_ECM30TFS021_AU73.rod
   VCID: 2D5175A27C397AFE58-8078
   VINID: 9D106645158701A500042146208587D823
Address 02: Auto Trans        Labels:| 0BK-927-156.clb
   Part No SW: 4M0 927 158 L    HW: 0D5 927 156 H
   Component: 0D5  30TSIUSA H05 1006
   Revision: --H05---    CVN: 228D7428
   Coding: 100000
   ASAM Dataset: EV_TCMALX52011 002010
   ROD: EV_TCMALX52011.rod
   VCID: 3D7145E2AC59EA7EE8-8068
Address 03: ABS Brakes (J104)       Labels: 4M0-907-379-V1.clb
   Part No SW: 4M0 907 379 Q    HW: 4M0 907 379 N
   Component: ESP9 Premium  H09 0657
   Dataset Number: 4M0909504M  0003 CVN: ACFBEF4F
   Coding: 28AA149C30A30A9891A35897008552A2E6269A14280C50891A004A45676459
   ASAM Dataset: EV_ESP9BOSCHAU536K 012013
   ROD: EV_ESP9BOSCHAU536K_AU73.rod
   VCID: 45812D02C489A2BEB0-8010
420352 - TPMS Warning; Front Left Tire
          C1054 00 [00100000] - Pressure too Low
416768 - TPMS Warning; Front Right Tire
          C1056 00 [00100000] - Pressure too Low
420096 - TPMS Warning; Rear Left Tire
          C1058 00 [00100000] - Pressure too Low
417024 - TPMS Warning; Rear Right Tire
          C105A 00 [00100000] - Pressure too Low
   Part No SW: 4M0 820 043 AB    HW: 4M0 820 043 AB
   Component: Klima Zone 4  H52 0100
   Coding: 6608090C5548011110680180800000000000000000000000000000000000
   Shop #: WSC 01945 004 1048576
   ASAM Dataset: EV_AirCondiFrontBHTCAU736 001013
   ROD: EV_AirCondiFrontBHTCAU736.rod
   VCID: 65C1CD82644982BE50-8030
   Subsystem 1 - Part No SW: 4M1 820 021 A    HW: 4M1 820 021 A
   Component: J126 FLuftV  H08 0003
   Serial number: 00000000000001866339
   Humidity sensor: exterior:
   Serial number: FD41D3C800PAG0MUFU02
Address 09: Cent. Elect. (J519)       Labels:* Redir Fail!
   Part No SW: 8W0 907 063 CG    HW: 8W0 907 063 BG
   Component: BCM1 MLBevo   H13 0267
   Dataset Number: 4M0909514AA 0054
   Coding: 07500363E0691CCD050F5719583E1CB911033D01900000000000000020001A010863012B025709
   VCID: 020BF61E95275586D5-8056
   Subsystem 1 - Part No SW: 4M1 955 119 A    HW: 4H2 955 119 C  Labels: 1KX-955-119.CLB
   Component: WWS536 170718  044 0893
   Serial number: 90115300401719900449
   Coding: 1BC7F7
   Serial number: 20389819X81A955547A0
   Coding: 02006E
   Subsystem 3 - Part No SW: 4M0 941 531 AB    HW: 4M0 941 531 AB
   Component: E1 - LDS  H06 0008
   Serial number: 29 07 2017  01059529
   Subsystem 4 - Part No SW: 4M0 907 410 A    HW: 4M0 907 410 A
   Component: USHL5  H08 0050
   Serial number: 0000009600363Z000Z02
   Coding: 350000
   Garage door opener control head:
   Subsystem 5 - Part No SW: 4M0 959 719 A    HW: 4M0 959 719 A
   Component: GTO BF  H01 0010
   Serial number: 20170817095031 00288
   Subsystem 6 - Part No SW: 8W0 857 511 B    HW: 8W0 857 511 B
   Component: Y7_Innenspieg  H01 0002
   Serial number: GX1CE109061723510533
   Coding: 030000
   Interior Light Module:
   Subsystem 7 - Part No SW: 4M0 947 135 CP    HW: 4M0 947 135
   Component: J528-Dachele  H14 0130
   Serial number: Q00476461
   Subsystem 8 - Part No SW: 80A 907 705     HW: 80A 907 705
   Component: J866-EVLS-SG  H03 0080
   Serial number: WA128783000037025150
   Coding: 0A0100
   Subsystem 9 - Part No SW: 4M0 925 301 K    HW: 4M0 925 301 K
   Component: SL-Q7NF/AU736  H10 0013
   Serial number: 00000000000000140827
   Subsystem 10 - Part No SW: 4M0 963 575     HW: 4M0 963 575
   Component: V512 LLR1SLvL  H03 0012
   Serial number: L14DH17500681
   Subsystem 11 - Part No SW: 4M0 963 575     HW: 4M0 963 575
   Component: V514 LLR1SKvL  H03 0012
   Serial number: L14DH16701281
   Subsystem 12 - Part No SW: 4M0 963 575     HW: 4M0 963 575
   Component: V516 LLR1SLvR  H03 0012
   Serial number: L14DH17500686
   Subsystem 13 - Part No SW: 4M0 963 575     HW: 4M0 963 575
   Component: V518 LLR1SKvR  H03 0012
   Serial number: L14DH16701282
Address 13: Auto Dist. Reg (J428)       Labels:* Redir Fail!
   Part No SW: 4M0 907 561 E    HW: 4M0 907 561
   Component: LRR4          H10 0220
   Dataset Number: 4M0909863L  0031
   Coding: B4779FFA58FFEC09949880A1
   ASAM Dataset: EV_ACCBOSCHAU736 002018
   ROD: EV_ACCBOSCHAU49X_002.rod
   VCID: 326B66DE6507250605-8066
   Part No SW: 4M0 959 655 F    HW: 4M0 959 655 F
   Component: Airbag10.44   H02 0106
   Serial number: 003UM0013UBE Dataset Number: 4M0909602AK 0001
   Coding: AECCFCC000800000A0F00033D24C00000000
   ASAM Dataset: EV_AirbaAU10BPAAU736 006015
   ROD: EV_AirbaAU10BPAAU736_006.rod
   VCID: 3E7342EEA15FF166F1-806A
   Left seat belt tensioner:
   Subsystem 1 - Part No SW: 4M0 980 945     HW: 4M0 980 945
   Component: BeltPretRevFL  205 2033
   Serial number: 4M0857705K0243R01029
   Coding: 88001B
   Right seat belt tensioner:
   Subsystem 2 - Part No SW: 4M0 980 946     HW: 4M0 980 946
   Component: BeltPretRevFR  205 2033
   Serial number: 4M0857706K0243R00025
   Coding: 88001B
   Component: BF-Gewichtss.  H11 0022
   Serial number: IBH0000J170007NVYD09
   Subsystem 4 - Part No SW: -----------    HW: 442 062 807 17
   Serial number: 3577Y00C324FCA33A0DE
   Subsystem 5 - Part No SW: -----------    HW: 442 062 807 17
   Serial number: 3587Y00C324FCA33A0CE
   Subsystem 6 - Part No SW: -----------    HW: 442 0B2 407 17
   Serial number: 35177009F2711FF4F25S
   Subsystem 7 - Part No SW: -----------    HW: 442 0B2 407 17
   Serial number: 35277009F2711FF1935L
   Subsystem 8 - Part No SW: -----------    HW: 442 0C1 407 17
   Serial number: 3557500A726657643397
   Subsystem 9 - Part No SW: -----------    HW: 442 0C1 407 17
   Serial number: 3567500A32665760E1BB
   Part No SW: 4M0 907 129 GS    HW: 4M0 907 129 GS
   ROD: EV_SMLSKLOAU736_006.rod
   VCID: 071DE70ABE0570AE82-8052
   Part No SW: 4M0 920 890 C    HW: 4M0 920 890 C
   Component: FBenUSA       H18 0370
   Coding: 09C600C16C88CF0502A369601800600008000000
   ROD: EV_DashBoardAU736_AU73.rod
   VCID: 306F6CD66B0B171673-8064
   Part No SW: 8W8 907 468 E    HW: 8W8 907 468 E
   Component: Gateway       H42 0118
   Revision: 6D030003    Serial number: 0386D839517905 Dataset Number: 4M0909515L  0084
   Coding: 03010001000006405407000000590030DC1A0007100000000150000000000000
   GVL: 01503C0C08000000C0DCC8000002C800100C2000000000000000000000000000
   ASAM Dataset: EV_CGateCONTIAU491 003092
   VCID: 4E93122E11FF61E601-801A
   Subsystem 1 - Part No SW: 4M0 951 523 A    HW: 4M0 951 523 A
   Component: J453 MFL  H06 0002
   Serial number: 20170823174834 01782
   Serial number: 2526235004
Address 28: HVAC, Rear (E265)       Labels:* None
   Part No SW: 4M0 919 158 D    HW: 4M0 919 158 D
   Component: Klima Zone 2  H52 0103
   Coding: 000000000000000100800080000000000000000000000000000000000000
   ASAM Dataset: EV_AirCondiFondBHTCAU736 001013
   ROD: EV_AirCondiFondBHTCAU736.rod
   VCID: 36635ACE896F392629-8062
Address 29: Left Light
Interface not compatible.
Please upgrade to a current Ross-Tech interface.
   Part No SW: 4M1 959 760     HW: 4M1 959 760
   Component: MEM-FS        008 0031
   Serial number: 00000274661458 Dataset Number: 4M0909856C  0018
   Coding: 005C1B000000B0010000010101010000000000000000000000000000000000
   VCID: 76E39ACEC9EF7926E9-8022
Address 39: Right Light
Address 3C: Lane Change (J769)       Labels:| 4M0-907-566.clb
   Part No SW: 4M0 907 566 D    HW: 4M0 907 566
   Component: MRR1Rear      H18 0410
   Revision: --------    Dataset Number: 4M0909535L  0015
   Coding: 1EC002
   ASAM Dataset: EV_RearRadarS1BoschAU736 001022
   Part No SW: 4M0 959 793 H    HW: 4M0 959 793 F
   Component: TSG FS        005 0131
   Serial number: 0000275534158  Dataset Number: 4M0909872J  0036
   Coding: 005D8B005E00108000092030
   Shop #: WSC 63962 001 1048576
   ROD: EV_DCU2DriveSideMAXHCONT_AU37.rod
   VCID: 4385331ACABD9C8E9E-8016
          B1487 54 [00001001] - Missing Calibration / Basic Setting
                    Reset counter: 107
                    Mileage: 172200 km
                    Date: 2025.03.12
                    Time: 00:00:06
   Part No SW: 4M0 909 144 H    HW: 4M0 909 144 B
   Component: EPS_MLBEVO1BS H22 0005
   Serial number: 0000061123 Dataset Number: 4M0909852P  0002
   Coding: B0000101000101
   ASAM Dataset: EV_EPSVWBSAU736 009023
   ROD: EV_EPSVWBSAU736_009.rod
   VCID: 346760C69F132B3617-8060
Address 46: Central Conv.
   Part No SW: 4M0 035 223 C    HW: 4M0 035 223
   Component: MIB2_amp_PD   H03 0440
   Serial number: 00000000048084 Dataset Number: 4M1909510E  0012
   Coding: 0135060A008AF53AAF0000010000
   ASAM Dataset: EV_AMPMst16C4Gen2BOSE 001001
   ROD: EV_AMPMst16C4Gen2BOSE_AU73.rod
   VCID: 2345939A2AFDBC8EFE-8076
Address 50: Seat Adj. 3rd row
   Part No SW: 4M0 959 792 H    HW: 4M0 959 792 F
   Component: TSG BFS       005 0131
   Serial number: 0000275002342  Dataset Number: 4M0909873J  0036
   ROD: EV_DCU2PasseSideMAXHCONT_AU37.rod
   VCID: 428B361ED5A7958695-8016
                    Reset counter: 107
                    Mileage: 172200 km
                    Date: 2025.03.12
                    Time: 00:00:06
Address 5F: Information Electr. (J794)       Labels:* 4M0-035-MIB-HGH2.clb
   Part No SW: 4M1 035 880 A    HW: 4M1 035 880
   Component: MU-P-LNS-US   034 1118
   Serial number: A724H0HB029400 Dataset Number: 4M0909545K  0043
   Coding: 013706020000000013220002041A00102F001BE501700904BE
   VCID: 2B557BBA422D74CE46-807E
   Subsystem 1 - Part No SW: V03 959 802 DK    HW: -----------
   Component: NAR 2018/2019  --- 0066
   Multimedia System 1:
   Subsystem 2 - Part No SW: 4M0 919 605     HW: 4M0 919 605
   Component: AU536_DU_HIGH  H43 0008
   Serial number: AUZ8Z9HJ404X68
   Subsystem 3 - Part No SW: 4M0 919 615 H    HW: 4M0 919 615 H
   Component: ControlUnit_P  H15 0209
   Serial number: 29081700000000000353
   Compact disc data bank:
   Component: Gracenote2  --- 3012
   Part No SW: 4M0 907 383 E    HW: 4M0 907 383
   Revision: 9C001003    Serial number: 0452534347 Dataset Number: 4M0909527C  0024
   Coding: 0210000200000000
   Part No SW: 4M0 907 428 F    HW: 4M0 907 428
   Component: Areaview 2    H13 0318
   Serial number: C854607JG020925 Dataset Number: 4M1909460H  0022
   Coding: 02350602BB0FA10038404004
   ASAM Dataset: EV_CamSysRVAV2CE2MLBEv 005015
   ROD: EV_CamSysRVAV2CE2MLBEv_005_AU49.rod
   VCID: 35615DC29469323E20-8060
   Part No SW: 8W8 959 107 B    HW: 8W8 959 107
   Component: HDSG-Modul    H13 0163
   Revision: --------    Serial number: 31521757600000 Dataset Number: 4M0909541G  0025
   Coding: 00B0
   ASAM Dataset: EV_DeckLidCONTIAU736 001015
   VCID: 489F2436F39BBFD64B-801C
   Part No SW: 4M1 713 041 E    HW: 4M1 713 041 F
   Component: GSM-LL        H09 0077
   Revision: 0L0D5012    Serial number: 17081043677780
   ROD: EV_GSMWaehlZFAU736_AU72.rod
   VCID: 275D878A5EC550AEA2-8072
Address 82: Head Up Display (J898)       Labels:| 4M0-919-617-V1.clb
   Part No SW: 4M0 919 617 B    HW: 4M0 919 617 B
   Component: HeadUpDisplay H29 1640
   Coding: 4F01E0
   ASAM Dataset: EV_HudNSEIKAU736 001017
   ROD: EV_HudNSEIKAU736_AU73.rod
Address 8B: Adaptive Cruise 2 (J850)       Labels: 4M0-907-541.clb
   Part No SW: 4M0 907 541 E    HW: 4M0 907 541
   Dataset Number: 4M0909885H  0023
   ASAM Dataset: EV_ACC2BOSCHAU736 002018
   ROD: EV_ACC2BOSCHAU736_002_AU73.rod
   Part No SW: 4M0 907 217 E    HW: 4M0 907 217 E
   Component: BVS           H16 0050
   Dataset Number: 4M0909466M  0044
   Coding: 0407030600000201022023A7A50000B4B0F0C020C020
   ROD: EV_BVSMLBevKOSTAAU736_AU73.rod
   Part No SW: 4M0 959 795 H    HW: 4M0 959 795 F
   Component: TSG HFS       005 0131
   Serial number: 0000273650562  Dataset Number: 4M0909897J  0036
   Coding: 004D8B000000108040082020
   ROD: EV_DCU2RearDriveMAXHCONT_VW37.rod
   Component: TSG HBFS      005 0131
   Serial number: 0000273650560  Dataset Number: 4M0909896J  0036
   ROD: EV_DCU2RearPasseMAXHCONT_VW37.rod
                    Reset counter: 107
                    Mileage: 172200 km
                    Date: 2025.03.12
                    Time: 00:00:06
Address CA: Sunroof
Address CF: Lane Chge Asst 2
Address D6: Light Ctrl Left 2
Address D7: Light Ctrl Right 2
End-------------------------(Elapsed Time: 07:10)--------------------------
I don't think Audi ever shipped any of these cars with an LFP battery, so just because the Gateway has an option that's so-labelled does not mean it actually works. The fact that it reports an electrical system malfunction leads me to suspect that the Gateway doesn't have any parameters to match this option.
I'm sure you're aware, "Fleece" is the German term for an AGM battery, so I'm not exactly surprised that it's not using an LFP curve there.
MasterTommy
Amsterdam
C?ID=295586
As far as I know, Lithium batteries purpose built for vehicles have an integrated BMS and most of the ones built are not supplied as factory-fitted parts but as drop-in replacements for lead-acid, EFB or AGM batteries and are therefore happiest when being paired with a charging strategy of the battery type it is intended to replace. Now, since I assume this is a factory fitted lithium battery (does it have a built in extra connector for communication?) the above may not apply, and I agree with what Uwe said. But the best source of info may be to try and find out how the charging system of the F80 is configured, both physically and what its charging strategy (min/max voltages, charging current, target SOC range, etc) is. I suspect its not that different from an AGM battery (again, mostly because of the integrated BMS).
SeattleMatt
C?ID=282387
Thank you, at this point I suspect my best option is to ditch the Lithium battery (maybe I can sell it on mrkplc for $800 :o) and go buy an old fashioned AGM.
The BMW Lithium battery does have a 2 pin management plug. As I write this it makes me wonder if redirecting the Audi LIN to this port would change anything.
That said, I did some further testing and recorded the data below for informational purposes.
With the Lithium battery and Lithium FeP selected the charge data is as follows at idle. Dashboard reports electrical system malfunction and charge system is disabled.
Battery version-Rated battery capacity: 69 Ah
Battery version-Battery technology: Lithium FeP
Battery voltage: 13.892 V
Battery current: -29.296 A
Battery charge level: 98%
Usable battery charge: 51 Ah
Battery voltage at rest: 12.8V
With the Lithium battery and AGM (Fleece) selected the charge system has no errors, however the charge current is way overdriving. This is a typical issue with Lithium batteries connected to standard charging systems. This is one of the reasons my van build outs have DC-DC chargers between the alternator charge system and the Lithium battery banks.
Battery version-Battery technology: Fleece
Battery voltage: 13.985 V
Battery current: 126.800 A
Battery charge level: 96%
Usable battery charge: 55 Ah
With a standard AGM battery (2016) and correct adaptation set.
Battery version-Rated battery capacity: 92 Ah
Battery voltage: 14.745V
Battery current: 11.683A
Battery charge level: 65%
Usable battery charge: 45 Ah
Battery voltage at rest: 12.3V
MasterTommy
Amsterdam
C?ID=295586
If it has an extra 2-wire connection, then all bets are off. There is no telling what is happening on the battery side (= what the BMS is doing) without it connected or what its expecting, or if its an integral component (control unit) of the charging system of the BMW.
Which was the reason why I asked if it had an extra connector. :)
I don’t really see an issue in using a lithium battery, but use one intended to replace a conventional battery. Your lithium battery is designed as part of a larger system and will probably never function as intended without comms to the rest of the vehicle (and the rest of the vehicle being able to talk the same language and be configured for it, which the car isn’t). It also makes any readings you check on the car side useless for multiple reasons; unable to know what the BMS does or doesn’t do and why, how the gateway determines its values, charging strategy and why, etc.
Cuzoe
C?ID=279487
For what it's worth I ran a Braille lithium battery, which is a designed drop in replacement for "standard" battery, in my Golf TDI. I had no issues (eventually went back to AGM for the standby power).
I did code for Lithium, although my car does not have the battery monitoring module. And the Brailles do not have internal BMS so no extra connector. They use an internal cutoff device (per their FAQ) to prevent damage.
SeattleMatt
C?ID=282387
Agreed on the extra connector point. However it is very unlikely that any 12v lithium battery would exist without an internal BMS, These batteries appear to be build with 4x leV60F cells. All lithium batteries require a BMS to balance power within the cells. However in this case I would guess that you are referring to an external DC-DC converter which would manage the voltage load from the alternator.
MasterTommy
Amsterdam
C?ID=295586
True, as in all lithium batteries for vehicles that I have ever seen have an integrated BMS. However, the difference is that OP’s battery sourced from a BMW is not designed as a standalone component, but needs comms with the rest of the vehicle.
Dr Sheldon
Windsor UK
C?ID=334979
Will probably shit its pants and go berserk !
Go try it and report back.
^^^^ Exactly that !!
Cuzoe
C?ID=279487
I won't pretend to know what they have going on inside their battery though I'm not sure there's any reason for them to lie in their FAQ. In any case I had no issues with the battery.
There are a few people in the GolfMk7 form running it in their gassers.
MasterTommy
Amsterdam
C?ID=295586
I’m not debating that, however OP’s battery is a different type sourced from a vehicle that came with one from the factory that is not a standalone component, but is an active part of the charging system with communication to the rest of the car.
MattR72
Minnesota, USA
C?ID=538270
So with my 2022 Tiguan. I have been using it since match of 2023 without any issues. The coding options that I went with were Battery type lithium ion, brand of battery xs power, serial number #whatever, and the correct 40ah of lithium. The battery I used for under the hood is a XS power pwr-s5 4800. This is a 10ah lithium battery that has met my need to just run the car by itself. I have 3 more in the trunk to support my audio system upgrades. I don't know if Audi has an option for lithium ion in 2018 and I don't have any experience with Audi vehicles.
Cuzoe
C?ID=279487
Gotcha. And I guess I should have included @SeattleMatt in my response about. Completely in agreement that the battery op was trying to use needs to communicate with the car. I was just noting that there are automotive lithium batteries that do not have built in BMS. Granted I think the XS Power units with BMS are probably a better choice than the Braille for a daily driver.
If they truly have no BMS at all, how do they balance the cells?
How do they prevent over-charging? Anything over 14.4V on a 4S LFP battery is bad news.
How do they prevent over-discharge? Rechargeable lithium cells take lots of damage points if the spend much time at less than 2.5V per cell.
Cuzoe
C?ID=279487
This is directly from their FAQ, answering a question about BMS...
A Battery Management System, or BMS, keeps a battery operating within normal parameters. Braille Battery does not use a BMS because it is another possible point of failure in batteries, thereby reducing overall reliability. Plus adding a BMS, increases the weight of a battery and can increase the size of the battery case.
Instead, all our cells have a current interrupt device (CID) integrated into the top of the cell to mechanically disconnect the current flow through the cell if it experiences abnormal operating conditions.
That said, I don't have any more answers 😁😁😁
And so that I'm not accused of making this up... https://braillebattery.com/faq/#1676468163899-87bdd44e-adfe
  • Informative
Sure, a BMS is a potential point of failure, but it's a trade-off against the failures that might occur due to over-voltage during charging, the pack going out of balance, your car charging the battery at below-freezing temperatures, or over-discharge, the latter of which they clearly admit:
Can I Over-Discharge A Lithium Battery?
Yes. As our batteries do not include a BMS system, you can over-discharge the battery and cause permanent damage, and possibly make the battery inoperable....
Anyway, running a multi-cell LFP battery without a BMS strikes me as, "A bold strategy, Cotton..."
