A8 (D3) Control Head coding support please
bdiocee
C?ID=52893
Hi all. New to the forum but a long time user of HEX+CAN USB interface for basic stuff and diagnostics.
I need a bit of support with my Audi A8 (D3) 4.0TDI 2003MY. The car has a couple of issues, but the most critical seems to be with the Control Head (address 07). I am getting "Component Protection - No or Incorrect Basic Setting/Adaptation". It has had this issue since I bought the car 4 years ago, but I really need to fix it before it kills another battery. Full scan included below.
I have attempted to code the Control Head - and it keeps the coding while the engine is switched on. However, after switching off - it seems to revert back to no coding after a short period of time. This results in the climate control thinking that the car is LHD, and all language settings reverting to default (German/Deutsch), amongst other things. In addition, I think it also results in a large drain on the battery - although I havent been able to confirm. Coding attempted is 0000002 with shop#: WSC 02313 785 00200. I have then added some of the fitted options via adaptation and they all work - until I switch off the engine - although the component protection DTC remains throughout, even after clearing DTCs for this module.
Do I need to access the "Security Access" option to code this module when it is in this condition? I have tried security access codes 08108 & 01850 based on some info found on the web and the serial number of the Control Head - but neither worked.
Any assistance greatly appreciated.
Thursday,01,May,2014,22:40:16:18626
VCDS Version: 12.12.2.0
Data version: 20140212
VIN: WAUZZZ4E84N007999   License Plate: D10 CEE
Mileage: 187250km-116351mi   Repair Order:
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 11 31 13 15 16 17 18 19 1D 1E 25 28
          34 36 37 38 42 46 47 4F 52 53 55 56 57 61 62 65 67 72 76 77
VIN: WAUZZZ4E84N007999   Mileage: 187250km/116351miles
1D-Driver Ident. -- Status: Malfunction 0010
38-Roof Electronics -- Status: OK 0000
57-TV Tuner -- Status: Malfunction 0010
   Part No SW: 4E0 910 409 C    HW: 4E0 907 409 B
   Component: 4.0L 4V/TDI A000AGMª0020
   Revision:    <>       Serial number: AUX3Z0C7320871
   Coding: 0010773
   Shop #: WSC 02313 785 00200
   VCID: 234E57C1E29D3A06A65-8076
19591 - Intake Manifold Runner Control
            P3135 - 000 - Lower Stop not Reached
                    Torque: 19.5 Nm
                    Duty Cycle: 88.3 %
                    Duty Cycle: 20.3 %
                    Duty Cycle: 0.4 %
                    Temperature: 91.8°C
18284 - Valve for Torque Support Mount
            P1876 - 000 - Open Circuit - Intermittent
                    RPM: 126 /min
                    Torque: 19.5 Nm
                    Bin. Bits:        0
                    Bin. Bits:        0
                    Bin. Bits:        0
                    Temperature: 89.1°C
Readiness: 0 0 X X X
Address 02: Auto Trans        Labels: 09E-927-156.lbl
   Part No SW: 4E0 910 156 J    HW: 09E 927 156 A
   Component: AG6 09E 4,0LTDI RdW 0040
   Revision: 00000001    Serial number:        0018770
   Coding: 0000001
   Shop #: WSC 00515 210 88537
   VCID: 295245E980B1E056EC9-807C
Address 03: ABS Brakes        Labels: 4E0-910-517.lbl
   Part No SW: 4E0 910 517 A    HW: 4E0 614 517 A
   Component: ESP 5.7 allrad  H29 0420
   Coding: 0008557
   Shop #: WSC 02313 000 00000
   VCID: 21425DC9F8812816B49-8074
00003 - Control Module
            014 - Defective
Address 05: Acc/Start Auth.        Labels: 4E0-910-131.lbl
   Part No SW: 4E0 910 131     HW: 4E0 909 131 C
   Component:     FBS AUDID3  H03 0120
   Revision: 01203603    Serial number: AUX3Z0C7320871
   Coding: 0411648
   Shop #: WSC 02311 785 00200
   VCID: D8B4B02D6B5B29DE037-808D
Address 06: Seat Mem. Pass        Labels: None
   Part No SW: 4E0 910 760 C    HW: 4E0 959 760
   Component: Sitzmemory BFS H06  0060
   Revision: 00000000    Serial number: 5DS 008 795-03
   Coding: 4063456
Address 07: Control Head        Labels: 4E0-910-7xx-07.lbl
   Part No SW: 4E0 910 729 F    HW: 4E0 035 729 A
   Component: Interfacebox    H43 0350
   Revision: 00000000    Serial number: 300EH037518580
   Coding: 0000000
   VCID: 2B5EBFE18A4DF2461E5-807E
   Subsystem 1 - Part No: 4E0 910 609
   Component: Bedienteil MMI  H41 0010
   Subsystem 2 - Serial number: 318GT037504757
   Subsystem 3 - Serial number: ÿÿ29.07.03ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
   Subsystem 4 - Serial number: ÿÿÿÿÿÿÿ
02084 - Component Protection
                    Fault Status: 01100101
                    Reset counter: 146
                    Mileage: 175054 km
                    Date: 2013.06.22
                    Time: 14:25:19
                    Fault Status: 00100101
                    Reset counter: 146
                    Mileage: 185622 km
                    Date: 2014.03.13
                    Time: 15:31:28
                    Reset counter: 147
                    Mileage: 185625 km
                    Date: 2014.03.14
                    Time: 15:33:18
   Part No SW: 4E0 910 043     HW: 4E0 820 043 B
   Component: KLIMAAUTOMAT    015 0240
   Revision: 00000018    Serial number: 00000000022716
   Coding: 0088185
   VCID: DAB0AA2515573BCE353-808F
   Subsystem 1 - Part No: 4E0 910 772
   Component: Sitzluefter  FS H05  010
   Subsystem 2 - Part No: 4E0 910 772
   Component: Sitzluefter BFS H05  010
   Subsystem 3 - Serial number: 898053000
   Subsystem 4 - Serial number: HO08082003065A000000000066ÿ†89
   Subsystem 5 - Serial number: 000066ÿ†898053000      000-SHO
   Subsystem 6 - Serial number:     000-SHO08082003065A00000000
   Subsystem 7 - Serial number: 65A000000000047ÿ
Address 09: Cent. Elect.        Labels: 4E0-910-279.lbl
   Part No SW: 4E0 910 279 E    HW: 4E0 907 279 E
   Component: ILM Fahrer      H11 0100
   Coding: 0111111
   VCID: 2A50BAE585B7EB4EE53-807F
   Subsystem 1 - Part No: 4E2 910 113 B
   Component: Wischer WWS D3  H40 0400
   Coding: 00000044
   Shop #: WSC 02311
Address 11: Engine II        Labels: Redir Fail!
   Component: 4.0L 4V/TDI A000AGSª0020
   Coding: 0010773
Address 13: Auto Dist. Reg        Labels: None
   Part No SW: 4E0 910 561 D    HW: 4E0 907 561 D
   Component: ABSTANDSREGELUNG    0010
   Coding: 0011154
Address 15: Airbags        Labels: 4E0-910-655-84.lbl
   Part No SW: 4E0 910 655     HW: 4E0 959 655
   Component: Airbag 8.4E+    H09 0940
   Coding: 0431707
   VCID: E3CE97C1221DFA06665-80B6
Address 16: Steering wheel        Labels: 4E0-910-549.lbl
   Part No SW: 4E0 910 549     HW: 4E0 953 549 A
   Component: Lenksäulenmodul H09 0030
   Coding: 0112351
   VCID: E5CA89D92C298436881-80B0
   Component: Lenkradmodul    H02 0050
Address 17: Instruments        Labels: 4E0-910-xxx-17.lbl
   Part No SW: 4E0 910 930     HW: 4E0 920 980 A
   Component: KOMBIINSTR. VDO H49 0070
   Revision: D08         Serial number: AUDID3C5000286
   Coding: 0000413
   Shop #: WSC 00011 000 00000
   VCID: DFC69B310E75DEE642D-808A
Address 18: Aux. Heat        Labels: None
   Part No SW: 4E0 910 105     HW: 4E0 815 069 D
   Component: Heizgeraet      H06 0290
   Revision: 0000000F    Serial number: 00000009001484
   VCID: D9B2B529105130D63C9-808C
Address 19: CAN Gateway        Labels: 4E0-910-468.lbl
   Part No SW: 4E0 910 468     HW: 4E0 907 468 B
   Component: Gateway         H07 0050
   Revision: 07          Serial number: 12004036220069
   Coding: FEFFFFDF2B7504
   Shop #: WSC 00000 128 00289
Address 1D: Driver Ident.        Labels: 4E0-910-218.lbl
   Part No SW: 4E0 910 218     HW: 4E2 905 218
   Component: FPI_1           H04 0060
   Revision: 06000104    Serial number: 23052003152755
   VCID: DEB8A635097FD7EE49B-808B
02540 - Driver Identification Sensor Defective or Dirty (G455)
                    Reset counter: 171
                    Mileage: 187248 km
                    Date: 2014.05.01
                    Time: 22:26:50
Address 1E: Media Player 2        Labels: 4E0-910-111.lbl
   Part No SW: 4E0 910 111     HW: 4E0 035 111
   Component: CD-Changer      H43 0220
   Revision: 00000501    Serial number: AUZ5ZBC1021872
   VCID: D6A8BE15614F1FAE11B-8083
Address 25: Immobilizer        Labels: 4E0-910-131.lbl
   Coding: 0411648
   XXXXXXXXXXX ELV                 XXXX
   Part No SW: 4E0 910 158     HW: 4E0 919 158 A
   Component: KLIMA-STG. FOND 015 0200
   Revision: 00000013    Serial number: 00000000009292
   Coding: 0000000
   VCID: E1C29DC93801E816749-80B4
01866 - Rear Right Air Outlet Motor Position Sensor (G350)
Address 34: Level Control        Labels: 4E0-910-553.lbl
   Part No SW: 4E0 910 553 E    HW: 4E0 907 553 E
   Component: LUFTFDR.-CDC    H05 4290
   Coding: 0015510
   VCID: 254A49D9ECA9C436C81-8070
   Component: Sitzmemory FS  H06  0060
   Coding: 4063470
   Part No SW: 4E0 910 887 T    HW: 4E0 919 887 C
   Component: MNS ECE         H41 1030
   Revision: 00000000    Serial number: 305HX037537794
   VCID: 3E7886B5693F77EEA9B-806B
Address 38: Roof Electronics        Labels: 4E0-910-135.lbl
   Part No SW: 4E0 910 135 A    HW: 4E0 907 135 A
   Component: Dachknoten D3   H01 0090
   Serial number: 00000404300044
   Coding: 0036572
   Shop #: WSC 00337 210 09666
   VCID: 1D3A6139C4F90CF6901-8048
Address 42: Door Elect, Driver        Labels: 4E1-910-802-42.lbl
   Part No SW: 4E1 910 802     HW: 4E2 959 802
   Component: Türsteuer.FS BRM005 0100
   Coding: 0028463
Address 46: Central Conv.        Labels: 4E0-910-289.lbl
   Part No SW: 4E0 910 289 A    HW: 4E0 907 289
   Component: Komfortgeraet   H03 0030
   Revision: 00300003    Serial number:  W040307300026
   Coding: 0004857
   VCID: 275643D196A5D626FAD-8072
   Subsystem 1 - Part No: 4E0 910 853
   Component: Heckdeckel      H06 0060
   Subsystem 2 - Part No: 4E0 907 719
   Component: Neigungssensor  H02 0020
00892 - Switch for Trunk Closing Cylinder (F248)
                    Fault Status: 00100111
                    Reset counter: 209
                    Mileage: 186824 km
                    Date: 2014.04.29
                    Time: 19:34:40
Address 47: Sound System        Labels: 4E0-910-223.lbl
   Part No SW: 4E0 910 223 E    HW: 4E0 035 223 A
   Component: DSP-Amp.-High   H13 0210
   Revision: PROD_01     Serial number: 00000000261852
   Coding: 0000023
   VCID: 1F465B31CEF51EE682D-804A
Address 4F: Centr. Electr. II        Labels: None
   Part No SW: 4E0 910 280     HW: 4E0 907 280 A
   Component: ILM Beifahrer   H07 0070
   Revision:             Serial number: 00000000020137
   Coding: 0010101
   VCID: DDBAA1390479CCF6501-8088
Address 52: Door Elect, Pass.        Labels: 4E1-910-802-52.lbl
   Part No SW: 4E1 910 802     HW: 4E2 959 801
   Component: Türsteuer.BF BRM005 0100
   Coding: 0028463
                    Reset counter: 210
                    Mileage: 187040 km
                    Date: 2014.04.30
                    Time: 14:17:42
Address 53: Parking Brake        Labels: 4E0-910-801.clb
   Part No SW: 4E0 910 801 A    HW: 4E0 907 801
   Component: EPB  AV1C1010   H01 1010
   Revision: AV1C1010
   Coding: 0000431
02596 - Rear Brake Pads Worn
            002 - Lower Limit Exceeded
                    Fault Status: 01100010
                    Fault Frequency: 20
                    Reset counter: 168
                    Date: 2064.00.00
                    Voltage: 11.39 V
                    Count: 60
Address 55: Xenon Range        Labels: 4E0-910-357.lbl
   Part No SW: 4E0 910 357     HW: 4E0 907 357
   Component: Pre-AFS         H01 0030
   Coding: 0000002
   VCID: E2C092C53D07F30E6D3-80B7
   Part No SW: 4E0 910 541 B    HW: 4E0 035 541
   Component: TUNER EU/US/RDW H41 0220
   Revision: 00000000    Serial number: 304HH037540029
   Coding: 0000001
Address 57: TV Tuner        Labels: 4E0-910-146.clb
   Part No SW: 4E0 910 146 A    HW: 4E0 919 146
   Component: TV analog TUNER H12 0180
   Revision: 00000052    Serial number: 00000000001635
   Coding: 0001003
00866 - Antenna 4 for TV (R58)
                    Fault Status: 00101011
                    Reset counter: 210
                    Mileage: 186824 km
                    Date: 2014.04.29
                    Time: 19:37:13
Address 61: Battery Regul.        Labels: 4E0-910-181.lbl
   Part No SW: 4E0 910 181 B    HW: 4E0 915 181
   Component: ENERGIEMANAGER  H02 0240
   Revision: 00000000    Serial number: 00000000012939
   Subsystem 1 - Part No: 000 GBA 401 9
   Component: von VA0  029APR2014
   Coding: 303030474241343031392056413030323941505232303134
   Shop #: WSC 02313 128 00289
Address 62: Door, Rear Left        Labels: 4E0-910-802.lbl
   Part No SW: 4E0 910 802     HW: 4E0 959 801 A
   Component: Türsteuer.HL BRM004 0090
   Coding: 0028463
Address 65: Tire Pressure        Labels: 4E0-910-273.lbl
   Part No SW: 4E0 910 273     HW: 4E0 907 273
   Component: Reifendruck 2   H01 0210
   Coding: 0202833
01477 - System Switched Off
                    Fault Frequency: 13
                    Reset counter: 171
                    Mileage: 186825 km
                    Date: 2014.04.29
                    Time: 19:57:41
                    Temperature: 16.0°C
                    Error Code: 0
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                    Fault Status: 11100100
                    Reset counter: 170
                    Mileage: 186831 km
                    Date: 2014.04.30
                    Time: 10:07:04
                    Speed: 28.0 km/h
                    Temperature: 14.0°C
                    Error Code: 0
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
   Part No SW: 4E0 910 753 B    HW: 4E0 035 753
   Component: SDS 3502 UK     H43 0190
   Revision: 00000000    Serial number: 00000307100286
   Shop #: WSC 12336 024 394758
   VCID: 244C54DDE7933D3EDFF-8071
Address 72: Door, Rear Right        Labels: 4E0-910-802.lbl
   Part No SW: 4E0 910 802     HW: 4E0 959 802 A
   Component: Türsteuer.HR BRM004 0090
   Coding: 0028463
Address 76: Park Assist        Labels: 4E0-910-283.lbl
   Part No SW: 4E0 910 283     HW: 4E0 919 283 A
   Component: Parkhilfe 8-Kan H07 0030
   Coding: 0101008
   VCID: E0C498CD330BE11E7B7-80B5
Address 77: Telephone        Labels: 4E0-910-333.lbl
   Part No SW: 4E0 910 333 C    HW: 4E0 862 333 B
   Component: TELEFONMODUL EU     0210
   Revision: 00000004    Serial number: T2AUD3080908N2
   Coding: 0000004
jakematic
NC USA
C?ID=129085
Component protection can only be removed by Audi.
Once that is done it may be coded.
See also wiki entry on 02084
Special Notes
At the present time the Component Protection can only be learned/disabled using the Factory Tool in Combination with an online Connection. Every Audi Dealer/Service should be able to perform this Procedure.
bdiocee
C?ID=52893
Thanks Jakematic. Bit of a bummer - was hoping that wouldn't be the answer. Have searched around and it looks like removing component protection is possible, but it works out cheaper just to get Audi to do it, unless you are looking to make a business out of retro-fitting and upgrading.
What gets me is this - how did the car get into such a state - and am I looking at a faulty module?
My local stealership want to charge 140GBP just for a diagnostic - but I have heard mention of dealers removing CP for £20 or less and cleaning the car as well for free! might ring around a few local dealerships to see if the charge varies.
jakematic
NC USA
C?ID=129085
Possibly, but I seen a lot of D3 scans and have yet to see a faulty module trigger CP.
Usually it's an hour worth of labour depending on the dealer, some require proof of ownership if module replaced.
Other things I notice in your Auto-scan:
- one or both intake actuator arms may be broken
-- check visually, manipulate manually to determine if cleaning is required
-- metal replacements are available
-- see this thread for additional info
- ABS module is showing defective
- rear brakes likely need replacing, good thing you have VCDS and can do this :cool:
-- showing very low voltage - flat battery or recently replaced ?
-- the vehicle is conservative on this, but your fault frequency is 20
-- replace rotors every other pad change, cheaper than turning
-- inspect front pad thickness
PanEuropean
Toronto, Canada
C?ID=11844
Bal:
This is a "shot in the dark", but, have you tried recoding the CAN Gateway controller with the same code it already has (assuming, of course, that the code it already has is the correct code)?
We Phaeton owners have discovered that occasionally the car loses track of some of the installed controllers (usually as a result of the controller being momentarily unplugged from the car), and when the car does lose track of a controller, the only way to get the car to 're-discover' the installed controller is to re-code the CAN Gateway controller (using the same code that was already there). It seems that when the CAN Gateway is re-coded, the car carries out a new inventory of what is connected to it, and that often clears problems such as the one you have reported.
For more background information, see this post in the Vortex Phaeton forum: Requirement to Refresh the CAN gateway (Controller 19) after Controller Retrofits or Controller Removal.
Michael
Given that the D3 A8 has a "real" (stand-alone) gateway in which individual components can be coded (unlike the Phaeton which has a virtual gateway that's part of the instrument cluster) I doubt that will work, but then again, recoding it with the same value that's already there isn't likely to hurt anything either.
bdiocee
C?ID=52893
wow! thanks guys.
Jakematic - i removed one of my actuator arms as a couple of my swirl flaps are faulty - and this was causing the actuator not to function correctly. took it out to prevent it breaking till I get round to attacking the manifold job. ABS module - need to get a new one I guess, and the rear brakes is a long story. I replaced the discs and pads without using VCDS and now am unable to clear the DTC. stealership master tech suggested I could do something through the adaptation channels, but I have cycled through all the options. only thing I didnt do was specify pad thickness - will try that next. simply not enough time to get round to all the jobs!!
the car is on its third battery since I have had it (4 years) and the suspicion is that the uncoded Control Head is the cause of a battery drain. the new battery is coded in. hoping that coding the Control Head will take one issue off my list!
I wil try the suggestion of re-coding the CAN gateway - as Uwe says - it cant hurt. if that fails then I have secured the services of a local independent who can remove component protection at rates much preferable to paying a stealership for an hours labour. I have been ringing around and am astounded with some of the responses I have had. Three have not even bothered to call me back, one said they would not code a part they didn't install, and the others all want to charge around 140GBP. no doubt they will tell me lots of things I already know, and present me with a bill for my trouble without actually removing CP. seeing as most of them didnt even know what it was.... :(
If you got that route, I'd be curious to know what tool he uses to do that with and whether he actually succeeds -- and doesn't bugger up something else in the process. ;)
