Audi R8 ESP/ASR Re-Enables After 105mph/160kph
boostedeuro
C?ID=139364
Retractable wing was removed and disabled with coding via VCDS. I cant find the byte change to disable the auto re-enable of esp/asr after 105mph/160kph.
It keeps kicking it back on which is interfering with track events.
Thursday,13,March,2025,14:56:09:10041
VCDS Version: 25.3.0.3 (x64)  HEX-NET CB: 0.4660.4
Data version: 20250301 DS365.0
VIN: WUAZZZFX3H7904825   License Plate:
Chassis Type: FX-AU72 (4S0)
Scan: 01 02 03 05 06 08 09 11 31 14 15 16 17 19 20 22 30 36 3B 42
          44 46 52 53 55 5F 65 6C 81 A6 C2
VIN: WUAZZZFX3H7904825   Mileage: 17500km-10873miles
11-Engine II -- Status: Malfunction 0010
31-Engine other -- Status: Malfunction 0010
A6-Microphone -- Status: OK 0000
C2-Auto Trans 2 -- Status: OK 0000
Address 01: Engine (------CSPB)       Labels:. 07L-907-552-V1.clb
   Part No SW: 4S0 907 552 L    HW: 4T0 907 552 A
   Component: 5.2l V10HDZ / X56 0003
   Revision: NHX56---    CVN: C453C0C5
   Coding: 1A2500320526010B3000
   Shop #: WSC 65535 000 00000
   ASAM Dataset: EV_ECM52FSI1114S0907552L 001003
   ROD: EV_ECM52FSI1114S0907552L.rod
   VCID: 3FCE8F5EA65A8563F9-806A
VINID: 9E546AAAA5A80D81C9004202141DC250E7
17158 - Databus
          U1123 00 [00100111] - Received Error Message
                    Mileage: 17500 km
                    Date: 2025.03.13
                    Time: 14:49:22
                    Engine speed: 0.00 /min
                    Coolant temperature: 49 °C
                    Intake air temperature: 31 °C
                    Voltage terminal 30: 12.510 V
                    Drivetrain coordinator: brake fault status-Bits 0-7: 5
                    Drivetrain coordinator: brake function status-Bits 0-7: 32
                    Acceleration: 0.000 m/s²
4729 - Steering Effort Control Module
          U0130 00 [00100111] - No Communications
                    Mileage: 17500 km
                    Date: 2025.03.13
                    Time: 14:49:22
                    selected gear-Bits 0-7: 0
                    Cruise control switch actuation-Bits 0-7: 49
                    Cruise control switch actuation-Bits 0-7: 1
Readiness: 0110 0001
Address 02: Auto Trans (J217)       Labels:. 0BH-927-711.clb
   Part No SW: 4S0 927 155 F    HW: 0BH 927 711 F
   Component: AU 6E SB  RdW H10 3913
   Revision: 00H10V01    CVN: DC4F6100
   Coding: 0018
   ASAM Dataset: EV_TCMDL800041 001013
   ROD: EV_TCMDL800041_AU72.rod
   VCID: 3A38FE4ABD78A04BCE-806E
   Part No SW: 4S0 907 379 D    HW: 4S0 907 379 D
   Component: ESP PREMIUM   H09 0300
   Coding: 01A1C10B808583D04B00
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ESPPremiAU57X 004048
   ROD: EV_ESPPremiAU57X_AU72.rod
   VCID: 3E30F25AA1508C6BF2-806A
0089 - Function Restricted due to Missing Message(s)
          U1111 00 [10001001] - -
          [ComScl_PDU_SCU_01_Timeout]
                    Reset counter: 103
                    Mileage: 17500 km
                    Date: 2025.03.13
                    Time: 14:53:42
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 02
                    Bit Info 3: 22
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: 97
                    Uz: A1
29198 - Function Restriction due to Faults in Other Modules
          U1113 00 [00001001] - -
          [Scl_Allrad_04_LB_ALR_ESP_akt]
                    Reset counter: 103
                    Mileage: 17500 km
                    Date: 2025.03.13
                    Time: 14:53:42
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 02
                    Bit Info 3: 22
                    Bit Info 4: 1F
                    F-Path: 02
                    F-Type: 3E
                    Uz: A1
   Part No SW: 4H0 907 064 HB    HW: 4H0 907 064 HB
   Component: BCM2 2.0      H61 0825
   Coding: 05A06F06000000000000
   VCID: 70AC1C62A3842A1B30-8024
   Serial number: 3217000050520006
   Part No SW: 4S0 959 760     HW: 4S0 959 760
   Component: MEM-BFS       001 0020
   Revision: AA001003    Serial number: 00000186166383
Coding: 00001000000460F1000001210101210000000000000000
   VCID: 7BB63B4EFAC2594395-802E
   Part No SW: 4S0 820 043 K    HW: 4S0 820 043 K
   Component: AC Automat    H08 0040
   Revision: 20012000    Serial number: 96800000006312
   Coding: 4000A00000100010
   ASAM Dataset: EV_AirCondiVAPrehAU72x 003005
   ROD: EV_AirCondiVAPrehAU72x.rod
   VCID: 3326D36E9A1251030D-8066
   Rear A/C Control Head 2:
   Subsystem 1 - Part No SW: 8S0 820 359 A    HW: 8S0 820 359 A
   Component: E775 BuA_2  H07 0020
   Serial number: 00000000000000007699
   Rear A/C Control Head 3:
   Subsystem 2 - Part No SW: 8S0 820 359     HW: 8S0 820 359
   Component: E776 BuA_3  H07 0020
   Rear A/C Control Head 4:
   Subsystem 3 - Part No SW: 8S0 820 359 B    HW: 8S0 820 359 B
   Component: E777 BuA_4  H07 0020
   Part No SW: 4H0 907 063 HK    HW: 4H0 907 063 EK
   Component: BCM1 2.0      H21 0725
   Revision: 2502102S    Serial number: 00001608859202
Coding: 010DC01410349FE06D0140C380001800C59CC28A2E08320100040894E1001100004000340B0000
   VCID: 78BC2442CBF4725BF8-802C
   Subsystem 1 - Part No SW: 4S1 955 119 B    HW: 8V2 955 119 A  Labels: 5QX-955-119-V1.CLB
   Component: WWS624 170221  043 0081
   Serial number: 90248162170308114403
   Coding: 3247FD
   Serial number: 62550949
   Coding: 02005D
   Subsystem 3 - Part No SW: 4S0 941 531     HW: 4S0 941 531
   Component: E1 - LDS  H01 0044
   Serial number: 15 03 2017  00000456
   Subsystem 4 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
   Component: AQ_Hum_Sensor  H01 0006
   Serial number: 4D68C89800PAG0MUFU03
Address 11: Engine II (-----)       Labels:. 07L-907-552-V1.clb
   ASAM Dataset: EV_ECM52FSI2114S0907552L 001003
   ROD: EV_ECM52FSI2114S0907552K.rod
                    Mileage: 17500 km
                    Date: 2025.03.13
                    Time: 14:49:22
                    Voltage terminal 30: 12.533 V
                    Cruise control switch actuation-Bits 0-7: 0
Address 14: Susp. Elect. (J250)       Labels: 8V0-907-376.clb
   Part No SW: 4S0 907 376 D    HW: 4S0 907 376 C
   Component: DAEMPFUNGS-SG H06 0064
   Serial number:       240217024 Dataset Number: 4S0909554D  0009
   ASAM Dataset: EV_AudiMagneRide 002008
   ROD: EV_AudiMagneRide.rod
   VCID: 3B36FB4EB2429943D5-806E
   Part No SW: 4S0 959 655     HW: 4S0 959 655
   Component: Airbag10.43   H62 0204
   Revision: --------    Serial number: 003NJ001651F Dataset Number: 4S0909602C  0019
Coding: 30333845303430303638554A304C34533053
   ASAM Dataset: EV_AirbaAU10BPAAU64X 001036
   VCID: 7EB0325AE1D04C6BB2-802A
   Serial number: 3575HRB405H4CVFID0S7
   Serial number: 3585HRB400E57GU2E949
   Serial number: 3515JRB401259FHC9P1%
   Serial number: 3525JRB401659FHCP11$
   Serial number: 3554VRB4055480F2AH8Z
   Serial number: 3564VRB400K59GF0EGO
1050880 - Databus
          [CAN: 0x085 SCU_01 Timeout]
                    Reset counter: 103
                    Mileage: 17500 km
                    Date: 2025.03.13
                    Time: 14:49:21
          B13BC F2 [10001001] - No function
                    Mileage: 17500 km
                    Date: 2025.03.13
                    Time: 14:49:35
   Part No SW: 4S0 907 129 J    HW: 4S0 907 129 J
   Component: Lenks.Modul   H06 0007
   Revision: C0071527    Serial number: 91335QCC02215-
   Coding: 000034
   VCID: 3D32F556A4569773EB-8068
   Part No SW: 4S0 920 790 A    HW: 4S0 920 790 A
   Component: FBenRDW       H15 0253
Coding: 042D30C0BA8200080020ECC41000001000000000
   ASAM Dataset: EV_DashBoardBOSCHAU724 001022
   ROD: EV_DashBoardBOSCHAU724.rod
   Part No SW: 4S0 907 468 B    HW: 4S0 907 468 A
   Component: J533--Gateway H15 0074
   Revision: --------    Serial number: 00000002566483 Dataset Number: 4S0909515B  0030
   Coding: C02D03161C
   GVL: FF91C998DC08200180740800
   Subsystem 1 - Part No SW: 4S0 915 181     HW: 4S0 915 181
   Component: J367-BDM  H08 0270
   Serial number: 54061K39382871283187
Address 20: High Beam Assist. (J844)       Labels:| 8X0-857-511.clb
   Part No SW: 81A 857 511 C    HW: 81A 857 511 A
   Component: FLA           H10 0003
   Revision: AA001001
   Coding: 0404001D00000000000001
   ASAM Dataset: EV_HighBeamAssisAU724 001007
   ROD: EV_HighBeamAssisAU724_AU72.rod
   VCID: 281C340253D422DBA8-807C
Address 22: AWD (J492)       Labels: 4T0-907-160.clb
   Part No SW: 4S0 907 160     HW: 4S0 907 160
   Component: 4 Wheel Drive H07 0207
   Revision: 00001002    Serial number: BBQCFZS        Dataset Number: 4S0909104C  0001
   ASAM Dataset: EV_AllWheelContrBORGLB724 006012
   ROD: EV_AllWheelContrBORGLB724.rod
   VCID: 6E90021AB1B03CEB22-803A
0440 - Databus
          U1121 00 [10001101] - Missing Message
          [DTC_FCAN_SCU_01_Timeout]
                    Reset counter: 103
                    Mileage: 17500 km
                    Date: 2025.03.13
                    Time: 14:49:19
                    Vehicle speed: 0.28 km/h
                    Steering angle: 4.00 °
                    Outside temperature: 17.40 °C
                    Torque specifications: front axle: 0.00 Nm
                    Torque: front axle: 0 Nm
                    Coolant pump: not active
                    ESP status: active
                    Hydraulic pressure sensor 1: 0.00 bar
                    Hydraulic temperature sensor: 19 °C
                    Cooling fin temperature: 18 °C
                    Haldex clutch pump: current: 0.00 A
                    Haldex clutch pump: voltage: 0.00 V
                    Voltage terminal 30: 12.70 V
Address 30: Special Function II (J843)       Labels: 8K0-907-440.clb
   Part No SW: 4H0 907 440     HW: 4H0 907 440
   Component: STS           H06 0030
   Revision: S0H06000    Serial number: 00000000001760
   Coding: 01010101000000000001000102
   VCID: 64846032677C86BB44-8030
   Component: MEM-FS        001 0020
   Revision: AA001003    Serial number: 00000186166380
Coding: 00181900000460F1C00001210101210000000000000000
   Component: SARA 6D red   H04 0056
   Revision: --------    Serial number: EJ1BPA7E02PGBQ Dataset Number: 4S0909573A  0002
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 373EE77E8E6ABD2331-8062
   Component: TSG FA        H03 0511
   Coding: 011C52425020000300080402
   VCID: 47DE97BEF68ACDA341-8012
Address 44: Steering Assist (J500)       Labels:| 4S0-909-144.clb
   Part No SW: 4S0 909 144 H    HW: 4S0 909 144 B
   Component: EPS           H13 0905
   Revision: 00000000    Serial number:      L00195344
   Coding: 0803
   ASAM Dataset: EV_EPSZFAU72X 003010
   ROD: EV_EPSZFAU72X_003_AU72.rod
131073 - Control Module
          C109F 00 [00101111] - Incorrect Version Installed
          [Cross_swap]
                    Reset counter: 103
                    Mileage: 17500 km
                    Date: 2025.03.13
                    Time: 14:49:20
                    Expanded ambient data 1-Terminal 30 voltage filtered: 12.60 V
                    Expanded ambient data 1-Internal voltage supply 5V: 0.00 V
                    Expanded ambient data 1-Vehicle speed: 0 km/h
                    Expanded ambient data 1-Control module temp: internal sensor: 27 °C
                    Expanded ambient data 1-Speed source: CAN ESP speed
                    Expanded ambient data 1-Combustion engine: status: Engine not running
                    Expanded ambient data 1-AD converter reference voltage: 1.50 V
                    Expanded ambient data 1-Voltage terminal 30 unfiltered: 12.75 V
                    Expanded ambient data 1-AD converter reference voltage 2: 1.50 V
                    Expanded ambient data 1-Switched voltage terminal 30 unfiltered: 12.64 V
                    Expanded ambient data 1-KFA: 00 00
                    Expanded ambient data 1-KFC: 00 46
12652551 - Databus
          U1121 00 [00101111] - Missing Message
          [SCU_CAN_Timeout]
                    Reset counter: 103
                    Mileage: 17500 km
                    Date: 2025.03.13
                    Time: 14:49:20
                    Expanded ambient data 1-KFC: 00 37
   Revision: 00002001    Serial number: 0435241828
Coding: 011A0E8000B10881E330CA04000500470000000000000000000000000000
   Subsystem 1 - Part No: 4S0 951 177
   Component: Sensor, DWA  005 0002
   Component: TSG BF        H03 0511
   Coding: 011C52425E20000300080400
   VCID: 46C09ABAF180D4ABBA-8012
   Part No SW: 4S0 907 801     HW: 8K0 907 801 J
   Component: EPB-4         H03 0001
   Revision: --------    Serial number: 00000000003305
   ROD: EV_ParkiBrake_AU72.rod
   VCID: 70AC1C62AB842A1B30-8024
   Part No SW: 4H4 907 357 G    HW: 7P6 907 357 B
   Component: MxB-ECU       001 0115
   Revision: --------    Serial number: -------------- Dataset Number: 4S0909865D  0013
   Coding: 07FA001022630200
   ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005011
   VCID: 3620EA7A8960442B2A-8062
   Subsystem 1 - Part No SW: 7PP 941 572 AC    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
   Component: LED LeiMo li.  H09 0008
   Coding: E02200
   Subsystem 2 - Part No SW: 7PP 941 572 AC    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
   Component: LED LeiMo re.  H09 0008
   Coding: E02200
Address 5F: Information Electr. (J794)       Labels:* 8W0-035-MIB-HGH2.clb
   Part No SW: 4S0 035 021 C    HW: 4S0 035 021 B
   Component: MU-H-LND-EU   053 0909
   Serial number: A725C0HB000950 Dataset Number: 4S0909545F  0030
Coding: 012704010000000013111102000A00332F0000E100700000DE
   ASAM Dataset: EV_MUHig6C8Gen2HBAS 001182
   ROD: EV_MUHig6C8Gen2HBAS.rod
   VCID: 25023D3624C63FB393-8070
   Subsystem 1 - Part No SW: V03 959 801 FC    HW: -----------
   Component: ECE 2017  --- 0157
   Subsystem 2 - Part No SW: 4S1 919 614 D    HW: 4S1 919 614 D
   Component: ControlUnit_H  H30 0206
   Serial number: APVAK130011700010179
   Compact disc data bank:
   Component: Gracenote2---  --- 1015
Address 65: Tire Pressure (-----)       Labels: 3Y0-907-273.clb
   Part No SW: 4H0 907 273 D    HW: 4H0 907 273 B
   Component: RDKBERU25     H10 0900
   Serial number: 10000000038516 Dataset Number: 4S0909850A  0006
   ASAM Dataset: EV_RDKBERU25 003014
   ROD: EV_RDKBERU25_AU64.rod
   VCID: 2C14C812472C0EFB4C-8078
Address 6C: Back-up Cam. (J772)       Labels:| 4S0-980-556.clb
   Part No SW: 4S0 980 556 A    HW: 95B 980 551 L
   Component: RVC Compact   H12 0201
   Dataset Number: 4S0909460B  0010
   Coding: 0275040102000001000040
   ASAM Dataset: EV_CamSysRVRVCPANAAU57X 002003
ROD: EV_CamSysRVRVCPANAAU57X_002.rod
   VCID: 393AE146B87EAB53C7-806C
   Part No SW: 4S1 713 041 E    HW: 4M1 713 041 F
   Component: GSM-LL        H09 0073
   Revision: 0L0D5012    Serial number: 20170307003178
   ASAM Dataset: EV_GSMWaehlZFAU736 001016
   ROD: EV_GSMWaehlZFAU736.rod
   VCID: 2D12C5167C3607F35B-8078
Address A6: Microphone (J886)       Labels:. 420-907-394.clb
   Part No SW: 420 907 394 B    HW: 420 907 394
   Component: BELTMICBOX    H10 0820
   Coding: 0101030202
   ASAM Dataset: EV_BeltMicPARAGAU335 003011
   ROD: EV_BeltMicPARAGAU335.rod
   VCID: 187C04C2E3B4925B18-804C
Address C2: Auto Trans 2 (J217)       Labels:. 0BH-927-711-C2.clb
   Part No SW: 4S0 927 109     HW: 4S0 927 109
   Component: DL800 ZSG     H12 0002
   Revision: --H12---    Serial number: 0000000138 CVN: 0000CB9C
   ASAM Dataset: EV_TCMDL800421 001024
   ROD: EV_TCMDL800.rod
   VCID: 73A6136EDA921103CD-8026
End----------(Elapsed Time: 01:57, VBatt start/end: 12.7V/12.6V)-----------
------------------------------10 Faults Found------------------------------
AMB
Canada
C?ID=519756
Did you find a solution for this? I am having the same issue on track with it re-enabling at high speed.
