2017 Tiguan 2.0 TDI G28 / G40 Correlation Mystery
Kopon
Armagh, UK
C?ID=389405
So this 2017 Tiguan 2.0 TDI seems to start and run fine every day.
But, at around 75 degrees on the temperature clock the MIL appears and the attached VCDS scan indicates P0016, a malfunction with the G28 Crank Speed Sensor correlation to the G40 Cam Speed Sensor.
Naturally this DTC cannot be cleared until the engine temperature falls below 75 degrees at which point I can clear the code. Once above 75 degrees the MIL will appear again.
Most of the obvious causes of P0016, e.g. timing belt alignment, faulty sensors, worn drives etc. are bound to be constantly present regardless of temperature so I am wondering about the possibility of a problem with a VVT solenoid or valve which is oil driven. My thinking being that the operating valve is possibly less effective when the oil is warmer.
My question is: Does this particular engine have VVT? And, if not, does anyone have any experience of clearing this P0016 code under similar circumstances?
I don't have access to the vehicle today but I'm hoping to visit it in the next few days at which point I will attempt to diagnose further.
Monday,10,March,2025,13:31:13:22976
VCDS Version: 25.3.0.3 (x64)  HEX-V2 CB: 0.4660.4
Data version: 20250301 DS365.0
VIN: WVGZZZ5NZJW318942   License Plate:
Chassis Type: 5N-VW37 (3Q0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 42 44 52 5F 6D A5
VIN: WVGZZZ5NZJW318942   Mileage: 149179km-92695miles
Address 01: Engine (J623-DFGA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 HR    HW: 04L 907 309 P
   Component: R4 2.0l TDI   H25 5174
   Revision: B4H25---    CVN: 24BCA3A64C6C0C4B
   Coding: 0125001203641D082000
   ASAM Dataset: EV_ECM20TDI01104L906026HR 004005
   ROD: EV_ECM20TDI01104L906026HR_004.rod
   VCID: 015F82C1018C960280E-8054
   VINID: 9E65EAAAA15EA9A9C304824408EEA19B8A
4096 - Bank 1: CMP Sensor (G40) / Engine Speed Sensor (G28)
          P0016 00 [10100111] - Incorrect Correlation
                    Mileage: 149179 km
                    Date: 2025.03.10
                    Time: 13:25:10
                    Engine speed: 839.50 /min
                    Normed load value: 21.6 %
                    Coolant temperature: 70 °C
                    Intake air temperature: 47 °C
                    Voltage terminal 30: 13.240 V
                    Engine start: start synchronization: EPM_MODE_OK
                    Engine start: start synchronization-Test_Program_Epm st Op Mode State t UBYTE: 48
   Part No SW: 0DL 300 045 R    HW: 0GC 927 711 G
   Component: GSG DQ500     H06 2001
   Revision: 00H06V07    CVN: 3B64A4F2
   ROD: EV_TCMDQ500021.rod
   VCID: 3E25393D30F229FABDC-806A
   Revision: 00000000    Serial number: 61787000001483
   Coding: 0AEE929A34210B744780060462C54950492CD0E2604692713862F078C2224200002E64121A03102F35351919323200
   VCID: 77ABEC195F48D8B2BEA-8022
Address 08: Auto HVAC (E87)       Labels:| 5G0-907-044.clb
   Part No SW: 5NA 907 044 M    HW: 5NA 907 044 M
   Component: AC Automat    H35 4301
   Revision: 20K08000    Serial number: 00000E00588294
   Coding: 00120104202110011105100000101022
   ASAM Dataset: EV_ACClimaPrehVW37X 002023
   VCID: 49CF5AE1793C9E4218E-801C
   Humidity sensor: exterior:
   Subsystem 2 - Part No SW: 3G0 907 049 D    HW: 3G0 907 049 D
   Component: E265KlimaHeck  H02 0201
   Serial number:       04031501850571
263425 - Air Quality Sensor
          B10AF 04 [00001001] - Internal System Fault
                    Reset counter: 53
                    Mileage: 149179 km
                    Date: 2025.03.10
                    Time: 13:17:45
                    Outside temperature: 10.5 °C
                    Voltage terminal 30: 13.1 V
                    System run time-Engine running time: 253 s
                    Air quality status: Malfunction
   Part No SW: 5Q0 937 084 CN    HW: 5Q0 937 084 CE
   Component: BCM MQBAB M   H36 0253
   Serial number: 01001717700964 Dataset Number: V03935260WR 0001
   ROD: EV_BCMBOSCH_018.rod
   VCID: 065591DD28A2B13AB5C-8052
   Subsystem 1 - Part No SW: 5NC 955 119     HW: 5NC 955 119   Labels: 1KX-955-119.CLB
   Component: 326 RL 090617  033 0372
   Serial number: 00000001706070306126
   Component: RLHS  042 0105
   Serial number: S6Y17M08D03H03M51S29
   Coding: 00A8DD
   Serial number: 000000000ZY1716327JX
   Serial number: 00000000000069834160
   Part No SW: 3QD 919 294 B    HW: 3QD 919 294
   Component: PDC 8 Kanal   H07 0030
   Serial number: 000906178877030 Dataset Number: V03935261QA 0001
   Coding: 0071051811
   ASAM Dataset: EV_EPHBO18VW481CN00 001008
   ROD: EV_EPHBO18VW4810000_VW37.rod
   VCID: 4CC163F5764E8B6A238-8018
   Component: ACCCONTIMQB   H02 0233
   Dataset Number: V03935266NZ 0001
   Coding: 3200674110FF8728749C8145804087
   ROD: EV_ACCMRRCONTIVW376_002_VW37.rod
   Part No SW: 5Q0 959 655 BJ    HW: 5Q0 959 655 BJ
   Component: AirbagVW21    005 0336
   Serial number: 003VWR366TAI Dataset Number: V03935255DY 0001
   Coding: 98CCC0C00C0000005C5400CF008800000065
   VCID: 094F9AE139BCDE42D8E-805C
   Left seat belt tensioner:
   Serial number: 5NC857705C0201R00854
   Coding: 80000D
   Right seat belt tensioner:
   Serial number: 5NC857706C0196R00435
   Coding: 80000D
   Subsystem 3 - Part No SW: -----------    HW: 480 002 707 17
   Serial number: 3570000000023731162/
   Subsystem 4 - Part No SW: -----------    HW: 480 002 707 17
   Serial number: 35800000000447311621
   Subsystem 5 - Part No SW: -----------    HW: 480 401 507 17
   Serial number: 3510001B325E613383D$
   Subsystem 6 - Part No SW: -----------    HW: 480 401 507 17
   Serial number: 3520001B325E6131951T
   Subsystem 7 - Part No SW: -----------    HW: 480 401 707 17
   Serial number: 3550001C726999C2849H
   Subsystem 8 - Part No SW: -----------    HW: 480 401 807 17
   Component: PedP_Sensor_D  000 6149
   Serial number: 2280001C9249E3C6B56K
   Subsystem 9 - Part No SW: -----------    HW: 480 401 807 17
   Component: PedP_Sensor_P  000 6149
   Serial number: 2290001C9249E3C60335
   Subsystem 10 - Part No SW: -----------    HW: 480 401 807 17
   Component: PedP_Sensor_C  000 6149
   Serial number: 2300001C9249E3C391CA
   Subsystem 11 - Part No SW: -----------    HW: 480 002 707 17
   Serial number: I0M00000000118ACD526
   Subsystem 12 - Part No SW: -----------    HW: 480 002 707 17
   Serial number: I0N00000000BF7ACD52U
   Part No SW: 5Q0 953 521 R    HW: 5Q0 953 569 A
   Revision: FF033033    Serial number: 20170719200172
   Coding: 0C10
   ASAM Dataset: EV_SMLSVALEOMQB 001016
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 41DF42C1410C5602C0E-8014
   Part No SW: 5NA 920 951 B    HW: 5NA 920 951 B
   Component: KOMBI         302 0310
   Coding: 27A401086780060001882A031401000000000000
   VCID: 40D947C54A065F0ACF0-8014
   Part No SW: 3Q0 907 530 G    HW: 3Q0 907 530 C
   Component: GW MQB High   433 4303
   Revision: --------    Serial number: 0006599634 Dataset Number: V03935258SJ 0001
   Coding: 030100045F087300FA00025C1C0F00010001070000000000000000000000
   GVL: 01543C0008000000408C80000000C80000000000000000000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 333318090BB0F492422-8066
   Generator:
   Subsystem 2 - Part No SW: 5TA 959 442 B    HW: 5TA 959 442 B  Labels: 3C8-959-537.CLB
   Serial number: 1891704292000494AS2B
   Coding: 2D0000
   Serial number: 4315644404
   Serial number: 290617EFS33168 Dataset Number: V03935247WD 0001
   Coding: 00310A20D001048000001000
   VCID: 43D348C95B104412D22-8016
   Subsystem 1 - Part No SW: 5Q0 959 812 E    HW: 5Q0 959 812 E  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_DRV  005 0007
   Serial number: 00000000000015598246
   Coding: 0D0000
   Component: EPS_MQB_ZFLS  128 1072
   Dataset Number: V03935255HX 0001
   Coding: 1107
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 45D756D155247A22FC6-8010
   Serial number: 300617EFU06737 Dataset Number: V03935248NH 0001
   Coding: 00310020DE01048000001000
   VCID: 42DD4DCD440A4D1AD94-8016
   Subsystem 1 - Part No SW: 5Q0 959 811 E    HW: 5Q0 959 811 E  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_PSG  005 0007
   Serial number: 00000000000015574477
   Coding: 050000
   Part No SW: 3Q0 035 842 C    HW: 3Q0 035 842 C
   Component: MU-S-D-ER     721 0842
   Serial number:                Dataset Number: V03935257WW 0001
   Coding: 02730600FF00000051110101008808001F0500C60120010003
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: 2D070E71ED94A262146-8078
   Subsystem 1 - Part No SW: 5G6 919 605 A    HW: 5G6 919 605 A
   Component: ABT_Std-2  H50 8130
   Serial number: VWZ6ZJT1946211
   Part No SW: 5Q0 959 107 L    HW: 5Q0 959 107 J
   Component: HDSG-Modul    H13 0261
   Revision: --------    Serial number: 31446954700000 Dataset Number: V03935261RZ 0001
   Coding: 0A00
   Part No SW: 3Q0 980 654 H    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H07 0272
   Serial number: 18071712K23115 Dataset Number: V03935265P  0001
   Coding: 0003070600000401000200448140A90084000E000020
   VCID: 3C21333526EE3BEA938-8068
End----------(Elapsed Time: 01:31, VBatt start/end: 14.2V/13.3V)-----------
------------------------------2 Faults Found-------------------------------
DrPeter
16.4905° S, 151.7375° W
Does this particular 2017 Tiguan 2.0 TDI engine have a Variable Valve Timing (VVT) system?
After some research, it appears this engine does not have a variable valve timing system.
ref: www.PartsLink24.com and https://volkswagen.erwin-store.com
I have not personally seen this issue where the fault code will not clear until the engine temperature drops below 75 degrees.
With 92,695 miles, I would be prepared to replace the timing belt and check for any play or wear between the cams.
PartsLink24.com says the "Camshaft module" part number drops and has been superseded, maybe this is an indication there is a concern with the cams?
Hope this helps,
drpeter
Jef
HQ
Pretty much any time I've come across P0016, it is a mechanical issue. With this being a "simple" timing belt, I would agree with Peter that replacing the timing belt is very on the table. Note that there are some special tools needed for doing the timing belt on this car... please purchase factory repair information via the "erwin" link Peter provided.
Kopon
Armagh, UK
C?ID=389405
Thanks for the replies and advice.
The timing belt was replaced about 8,000 miles ago but, in exasperation, we have checked it again and found all as it should be. In any case, as stated, the engine starts and runs fine until the temperature reaches 75 degrees, consistently. My contention is that if there were any issue with the belt then the problem would arise immediately upon start up. Similarly with wear between the cam drives.
The temperature trigger leads me to suspect an oil issue so I'm going to begin with an oil service including filter. However, the absence of VVT dampens my faith somewhat in this being a cure. I'm also at a loss to understand how the valve timing can adjust in the absence of VVT given that VVT is incorporated into so many engines.
Not being as adept as I would wish to be with my VCDS are there any tests or measurements I can run so as to monitor what is going on with the correlation between crankshaft and camshaft as the engine temperature increases until it triggers the MIL? Presumably I can select certain readings or outputs that are relevant to the correlation?
