2001 audi tt throttle body relearn
tbedard
So I did the adaptation cal and watched the blade and from what I understand it should go to 8 different opening states.
I hear it tring to move however I only see the tb open to maybe 10% at best.
Is that correct or should I see it move to full open and all the steps in between.
Car will run and drive and go wot, but shortly after it has a fit
Epc lite limp mode and throws a bunch of codes.
tbedard
I will answer my own question since I found out, and someone else might need to know.
the throttle body makes 8 step movements in and out, and it only opens a little bit when opening. at the end of the test if the relearn is good vcds will say test ok.
I assumed that because the tb was not opening all the way during the calibration that something was wrong with it. I tested on another known good tb and it did the same.
Turns out in my case i had a loose wire in my crank position sensor and it would touch the case grounding out and causing the car to go into limp mode.
  • Informative
When you do the Basic Setting, the last field should briefly show "Adp run" and then change to "Adp OK". If so, it's good. If not, there should be a fault code.
tbedard
Correct, thank you I was going to run the test again to get the exact verbiage in vcds.
