2017 A6 Allroad Air Suspension Failure
Stef G
Bedfordshire, UK
C?ID=525709
Hi guys, since you were all so helpful with my Touareg woes, I am hoping someone may be able to give us a steer on pinpointing the new issue on my A6.
This issue appeared randomly a few weeks ago, started with a couple of warnings like "Vehicle too high, controlling level" which would sort itself out, but since then the latest issue has been that it is stuck in Car Jack mode, on maximum height and stiffness, with a warning to not drive above 35mph. This is also giving an adaptive headlight warning.
When plugged into VCDS - seemed that the only functionality I had was to test the compressor relay (which came on OK), but no control over ventilating the shocks. Feels a bit mad that it won't pinpoint the failure item that is stopping it.
Looking at the measured values I could see that whilst the absolute ride height values wouldnt change when manipulating the level sensors, the sensor PWM% would, and can confirm all sensors moved appropriately.
Here's where I think I messed up - I tried to do the re-calibration of ride height, and got as far as clearing the stored ride height values, but now any further steps in that process won't work on VCDS including Set Reference Level. So now that has given the additional error, but also seems to have dropped the rear right considerably (but not to the floor) so the car is completely unusable now.
Autoscan attached - would really appreciate any advice on what I'm looking at especially in the ABS errors would be appreciated!
Thursday,06,March,2025,17:26:23:21606
VCDS Version: 24.7.1.0 (x64)  HEX-NET2 CB: 0.4643.5
VIN: WAUZZZ4G9JN033413   License Plate: XOO70L
Mileage: 116897km-72636mi   Repair Order: 1
Chassis Type: 4G-AU57 (4G8)
Scan: 01 02 03 05 08 09 15 16 17 19 20 28 34 36 3B 42 44 46 52 53
          55 5F 62 69 6D 72 82 A9 AC C0 47
VIN: WAUZZZ4G9JN033413   Mileage: 116897km-72636miles
Address 01: Engine (J623-CVUA)       Labels:. 059-907-401-V2.clb
   Part No SW: 4G0 907 589 F    HW: 4G0 907 589 B
   Component: 3.0BTD EDC17  H23 0010
   Revision: 54H23---    CVN: 4CD98C95C19C7771B866C2ADB866C2AD9B0058CB
   Coding: 322A403225360B030000
   Shop #: WSC 07504 005 104857
   ASAM Dataset: EV_ECM30BTD0114G0907589F 002009
   ROD: EV_ECM30BTD011_AU57.rod
   VCID: 372044307FC8C2D2AE1-8062
   VINID: 9D196AAAA11725A7800C31010C771241D6
15731 - Reductant Level Sensor 1
          P21C5 00 [01100000] - Stuck
                    Mileage: 116416 km
                    Date: 2025.02.22
                    Time: 20:00:30
                    Engine RPM: 1440.50 /min
                    Normed load value: 98.4 %
                    Vehicle speed: 112 km/h
                    Coolant temperature: 91  C
                    Intake air temperature: 24  C
                    Voltage terminal 30: 12.760 V
                    Unlearning counter according OBD: 31
                    Outside temperature: 10.0  C
                    Pressure sensor for reducing agent: measured pressure: 4998 hPa
                    Pump for reducing agent: speed: 1340.0 /min
                    Sensor for reducing agent tank temperature: temperature: 16.0  C
                    Reducing agent pump: activation: 50.00 %
   Part No SW: 4G0 927 158 BC    HW: 0BK 927 156 AM
   Component: 0BK 30RTDIRdW H22 1014
   Revision: --H22---    CVN: 34221744
   VCID: 70B2BF2C5A2655EAAFB-8024
   Part No SW: 4G0 907 379 S    HW: 4G0 907 379 S
   Component: ESP9 Premium  H01 0530
   Coding: 49A7DE4592E57BA2BB00
   Shop #: WSC 02391 785 00200
   ROD: EV_ESP9BOSCHAU57X_004_AU57.rod
   VCID: 41D42AE8210C8C62105-8014
14 Faults Found:
154624 - Tire Pressure Warning
          C102D 00 [00101000] - -
                    Mileage: 116699 km
                    Date: 2025.02.25
                    Time: 18:14:36
                    VzRef: 53
                    Bit Info 1: 00
                    Bit Info 2: 40
                    Bit Info 3: 26
                    Bit Info 4: 1F
                    Uz: BB
                    Unlearning counter according OBD: 34
154880 - Tire Pressure Warning
          C102D 00 [00100000] - -
155136 - Tire Pressure Warning
155392 - Tire Pressure Warning
179712 - Function Restriction due to Faults in Other Modules
          U1113 00 [01101101] - -
          [SCL_FA_Niveau_Druck_HL_Error]
                    Mileage: 116032 km
                    Date: 2025.02.19
                    Time: 19:34:45
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 00
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    Uz: 96
179968 - Function Restriction due to Implausible Message(s)
          U1112 00 [01100001] - -
          [SCL_FA_Niveau_Druck_HL_Invalid]
180224 - Function Restriction due to Faults in Other Modules
          U1113 00 [01100001] - -
          [SCL_FA_Niveau_Druck_HR_Error]
180480 - Function Restriction due to Implausible Message(s)
          [SCL_FA_Niveau_Druck_HR_Invalid]
180736 - Function Restriction due to Faults in Other Modules
          U1113 00 [00100000] - -
          [SCL_FA_Niveau_Druck_VL_Error]
180992 - Function Restriction due to Implausible Message(s)
          U1112 00 [00100000] - -
          [SCL_FA_Niveau_Druck_VL_Invalid]
181248 - Function Restriction due to Faults in Other Modules
          [SCL_FA_Niveau_Druck_VR_Error]
181504 - Function Restriction due to Implausible Message(s)
          [SCL_FA_Niveau_Druck_VR_Invalid]
200448 - Function Restriction due to Faults in Other Modules
          U1113 00 [00101111] - -
          [SCL_LWR_Hoehenwert_HL_Error]
                    Mileage: 116032 km
                    Date: 2025.02.19
                    Time: 19:34:47
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 00
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    Uz: 96
200192 - Function Restriction due to Implausible Message(s)
          U1112 00 [00100011] - -
          [SCL_LWR_Hoehenwert_HL_Invalid]
   Part No SW: 4H0 907 064 HN    HW: 4H0 907 064 HN
   Component: BCM2 2.0      H61 0825
   Coding: 01B9704E000000000000
   VCID: 7CAA9B1C06EE218A033-8028
   Serial number: 3217000155808001
00955 - Key 1
            002 - Lower Limit Exceeded
                    Fault Status: 01100010
                    Reset counter: 209
                    Mileage: 116508 km
                    Date: 2025.02.23
                    Time: 14:30:15
   Part No SW: 4G0 820 043 CD    HW: 4G0 820 043 CD
   Serial number: 31081700041016
   Coding: 36221178390000
   VCID: 6398C0609BD0FE72229-8036
   Part No SW: 4H0 907 063 GH    HW: 4H0 907 063 AH
   Component: BCM1 2.0      H20 0368
   Revision: 1502003S    Serial number: 00001762198002
   Coding: 0105001450349FE0490140C3800018000F9D67082F08020100000894E100170200400024030000
   VCID: 74BAB33C2EBE69CA4B3-8020
   Subsystem 1 - Part No SW: 4G2 955 119     HW: 4G8 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS57X 170704  H38 0080
   Serial number:         170727024636
   Coding: 0045F7
   Serial number: 20384591X81A955547A0
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 BG    HW: 4G0 941 531 BG
   Component: E1 - LDS  H07 0044
   Serial number: 17 07 2017  00000988
   Subsystem 4 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
   Serial number: 5CC093C800PAG0MUFU03
00471 - Control Module for Elect. Regulated Dampers (J250)
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 208
                    Mileage: 116336 km
                    Date: 2025.02.22
                    Time: 18:04:12
                    Reset counter: 208
                    Mileage: 116336 km
                    Date: 2025.02.22
                    Time: 18:04:12
   Component: Airbag10.43   H82 0092
   Revision: --------    Serial number: 003P100EEUZ- Dataset Number: 4G0909602M  0003
   Coding: 30333130313730323737554A305234473053
   VCID: 3B28580043E0E6B24A9-806E
   Serial number: 3575HRB401859P4AE9PH
   Serial number: 3585HRB400O59P4AEPJ0
   Serial number: 3515JRB400A5BEP4G9TQ
   Serial number: 3525JRB40045BEP8DH45
   Serial number: 3554VRB400Q5BGIMB981
   Serial number: 3564VRB400Q5BGIMMI7L
   Part No SW: 4H0 953 568 K    HW: 4H0 953 568 K
   Component: Lenks.Modul   H06 0005
   Revision: C0068538    Serial number: 91560QHD000UX
   Coding: 000035
   VCID: 3B2858004360E6B24A9-806E
   Subsystem 1 - Part No SW: 4G0 951 528 A    HW: 4G0 951 528 A
   Serial number: 11 07 2017  C0013321
   Part No SW: 4G9 920 951 M    HW: 4G9 920 951 M
   Component: TDieGb    Nv  H17 0225
   Revision: 18001312    Serial number: 658070817592014
   Coding: 33AF25081B412600010600
   ASAM Dataset: EV_RBD4K 004060
   ROD: EV_RBD4K_AU57.rod
   Part No SW: 4G8 907 468 K    HW: 4G8 907 468
   Component: J533--Gateway H15 0110
   Revision: --------    Serial number: 00000002708129 Dataset Number: 4G0909515M  0026
   Coding: C0CD078118
   GVL: FD83C948DC25680330040000
   ASAM Dataset: EV_GatewPkoUDS 002011
   VCID: 40D22FEC2A06856A1FB-8014
   Subsystem 1 - Part No SW: 8S0 915 181 B    HW: 8S0 915 181 B
   Serial number: 0572825004
   Voltage stabilizer:
   Serial number: 1705220000000000008F
   Part No SW: 4H0 857 511     HW: 4H0 857 511
   Component: FLA           H04 0021
   Revision: AA001002
   Coding: 04028264747464545425363E00
   VCID: 6780D4706F689252FE1-8032
   Part No SW: 4G0 919 158 Q    HW: 4G0 919 158 Q
   Component: KLIMA FOND    H08 0113
   Serial number: 01091700040562
   Coding: 22
   VCID: 3D2C56185DF4E88274D-8068
   Dataset Number: 4G0909553H  0037
   Coding: 008001
   ROD: EV_AirSuspe_003_AU64.rod
   VCID: 2F307C5087980A12F61-807A
677123 - Ride-Height System
          C1047 07 [00001001] - Mechanical Failure
                    Fault Frequency: 44
                    Reset counter: 219
                    Mileage: 116336 km
                    Date: 2025.02.22
                    Time: 18:01:57
677388 - Ride-Height System; Plausibility Error
          C1046 00 [00001000] - -
                    Fault Frequency: 16
                    Reset counter: 4
                    Mileage: 116368 km
                    Date: 2025.02.22
                    Time: 19:18:44
677389 - Ride-Height System; Plausibility Error
                    Fault Frequency: 15
                    Reset counter: 4
                    Mileage: 116368 km
                    Date: 2025.02.22
                    Time: 19:18:44
          C10C8 00 [00001001] - -
                    Fault Frequency: 36
                    Reset counter: 219
                    Mileage: 116336 km
                    Date: 2025.02.22
                    Time: 17:59:56
367877 - Ride Height Not Learned
          C1044 00 [00001001] - -
                    Reset counter: 208
                    Mileage: 116336 km
                    Date: 2025.02.22
                    Time: 17:59:56
677125 - Ride-Height System
          C1047 07 [00001000] - Mechanical Failure
                    Reset counter: 4
                    Mileage: 116336 km
                    Date: 2025.02.22
                    Time: 18:04:44
   Revision: AA000000    Serial number: 00000272227502
   Coding: 0078130000006001000001010101102030303232203232
   VCID: 77A084303FC802D26E1-8022
   Part No SW: 4G0 907 637 K    HW: 4G0 907 637 F
   Component: SARA 6D       H04 0056
   Revision: --------    Serial number: EJ1BPA820E2PCE Dataset Number: 4G0909573C  0006
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 363E493478C23BDAB57-8062
   Component: TSG FA        H03 0511
   Coding: 011C16015E01620002080002
   VCID: 47C034F00FA8B252DE1-8012
   Component: RCevo         H54 0202
   Revision: 00000002    Serial number: 0000045176 Dataset Number: 4G0909852L  0038
   Coding: 101000010001
   ASAM Dataset: EV_RCEPS 106007
   ROD: EV_RCEPS_106.rod
   VCID: 3A265D044CDADFBA51F-806E
   Revision: 00002001    Serial number: 0452591039
   Coding: 013B0622A0B93094C320098420010F470000000000000000000000000000
   Subsystem 1 - Part No: 4G0 951 177 B
   Component: Sensor, DWA  005 0002
   Subsystem 2 - Part No: 1K0 951 605 F
   Subsystem 3 - Part No SW: 4G9 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS20.403  H03 0004
   Serial number: 0000FST001QDCJZ00000
   Coding: 901E00
   Subsystem 4 - Part No SW: 4G0 947 135 K    HW: 4G0 947 135
   Serial number: 0000000AP00036576108
   Subsystem 5 - Part No SW: 4G9 959 591 A    HW: 8V3 959 591 A
   Component: J394 PS20.403  H03 0004
   Serial number: 0000FST001QHLVO00000
   Coding: 801E00
   Component: TSG BF        H03 0511
   VCID: 46DE39F408A2AB5A257-8012
   Part No SW: 4H0 907 801 M    HW: 4H0 907 801 M
   Component: EPB-4         H01 0018
   Revision: --------    Serial number: 00000002283962 Dataset Number: 4G0909522G  0001
   ASAM Dataset: EV_ParkiBrake 001033
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 3236752494AA27FA99F-8066
   Revision: --------    Serial number: -------------- Dataset Number: 4G0909865D  0019
   Coding: 04FE02102A630200
   VCID: 343A733C6EBE29CA8B3-8060
   Coding: E01E00
   Coding: E01E00
Address 5F: Information Electr. (J794)       Labels:| 4G1-035-MIB-HGH2.clb
   Part No SW: 4G1 035 021 P    HW: 4G1 035 021 D
   Component: MU-H-LND-EU   054 1425
   Serial number: A733H0HS017096 Dataset Number: 4G1909545J  0043
   Coding: 017542010000000013111102000A00332F000AE7F1700100DF
   VCID: 27009470AF6852523E1-8072
   Subsystem 1 - Part No SW: V03 959 801 FD    HW: -----------
   Component: ECE 2017/2018  --- 0161
   Multimedia System 1:
   Subsystem 2 - Part No SW: 4G1 919 605 B    HW: 4G1 919 605 B
   Component: DU8 C7 SV  H63 0007
   Serial number: AUZ8Z9HY808J2Q
   Subsystem 3 - Part No SW: 4G2 919 610 F    HW: 4G2 919 610 F
   Serial number: 90349QHP00130
   Compact disc data bank:
   Subsystem 4 - Part No SW: V03 959 800 GG    HW: -----------
   Component: Gracenote2  --- 1021
          B201A 00 [00001001] - -
                    Reset counter: 202
                    Mileage: 116032 km
                    Date: 2025.02.19
                    Time: 19:34:52
                    Voltage terminal 30: 11.9 V
                    Status_Software_Version_Management-module_name: MDUA009/Front
   Component: TSG HL        H03 0511
   Coding: 010814004001620002080002
   VCID: 49C432C819BC4422C85-801C
Address 69: Trailer (J345)       Labels:. 4H0-907-383-V2.clb
   Part No SW: 4G8 907 383 B    HW: 4G8 907 383 B
   Component: ConWys Trailer H07 0072
   Revision: 7B001002    Serial number: 00000133243642
   Coding: 0100000000000000
   VCID: 333870206B302EF2929-8066
   Part No SW: 4G9 959 107 C    HW: 4G9 959 107 B
   Component: HDSG-Modul    H05 0152
   Revision: 14005001    Serial number: 215700212 Dataset Number: 4G0909541E  0005
   Coding: 093205C011
   ROD: EV_HDSGAu571_AU57.rod
   Component: TSG HR        H03 0511
Address 82: Head Up Display (J898)       Labels:| 4G0-919-604.clb
   Part No SW: 4G0 919 604 N    HW: 4G0 919 604 N
   Component: HeadUpDisplay H10 0306
   Coding: A20000
   ASAM Dataset: EV_HUDContiC7 001027
   ROD: EV_HUDContiC7_AU57.rod
   Part No SW: 4G0 907 159 D    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H07 0007
   Serial number: 170705200289
   VCID: 2E0E61548092031AFD7-807A
   Part No SW: 4G0 907 355 G    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0013
   Revision: 00000000    Serial number: 172160032 Dataset Number: 4G0909571H  0017
   ROD: EV_RDCMA00100.rod
Address C0: Act. for Ext. Noise (J943)       Labels: 4G0-907-160.clb
   Part No SW: 4G0 907 160 E    HW: 4G0 907 160 B
   Component: SAS-GEN 2 AGA H09 0011
   Serial number: 170706201992
   ASAM Dataset: EV_ActuaForExterNoiseUDS 003013
   ROD: EV_ActuaForExterNoiseUDS.rod
   Part No SW: 4G5 035 223 E    HW: 4G5 035 223
   Component: MIB2_amp_P    H03 0440
   Serial number: 00000000068974 Dataset Number: 4G1909510Q  0013
   Coding: 01758208018AF02A5A0000010000
   ASAM Dataset: EV_AMPMst16C4Gen2BOSE 001001
   ROD: EV_AMPMst16C4Gen2BOSE_AU57.rod
   VCID: 241A837CDE5EB94A1B3-8070
End----(Elapsed Time: 02:45, VBatt start/end: 11.5V/11.4V. VIgn 11.6V)-----
The faults in 34-Level Control make me think there's something wonky with one of more of the ride-height sensors. Check measuring Values for height to see if one of the four corners is out-of-whack.
Stef G
Bedfordshire, UK
C?ID=525709
Thanks Uwe. Before I started messing around, there was one that was a few % out compared to the rest, but they all seemed within 5% of each other. Now the car has started to droop, they are all kind of all over the place, which makes sense? They all respond to movement as expected.
Now that I've annoyingly deleted the calibration for level control - all heights in measured values are static, and it's only the Level Sensor PWM% value that moves.
Out of interest, if a failed component is blocking a VCDS function from happening, why doesn't it specify which conditions have not been met?
It's not VCDS that's blocking a function, it's the control module in the car, and it's not all all unusual for that to happen without any fault codes. Yet you have several...
Stef G
Bedfordshire, UK
C?ID=525709
Yeah I know, I'm just thinking how nice it would be if everything was pinpointed specifically for smooth brains like mine :D
How best to identify the "mechanical failure" then, disconnect the level sensors and move them through the range of motion to see which if any aren't playing ball? I have been underneath and none of them are disconnected or damaged.
Sure, you can do that, but personally I would start by having somebody rock each corner of the car up and down while watching the values and only go to what you're suggesting if that doesn't turn up anything obvious.
davisev5225
C?ID=263265
Given the "mechanical failure" codes and the fact that the car won't air down, I suspect your valve block is at fault here. If you're slow and careful, you can "crack" open the air fittings just enough to let the pressure slowly escape in a controlled manner without actually popping them out of the valve block entirely. Once you've depressurized all (4) wheels and any other pressure vessels (such as auxiliary air tank?), you should be able to remove the valve block.
You can try 1-2 drops (NO MORE!) of air tool oil (NO SUBSTITUTES!) in each opening in the valve block, then re-install to see if that helps free anything up. Some percussive maintenance with a rubber mallet could also help. Ultimately, though, you're probably going to have to replace it.
Stef G
Bedfordshire, UK
C?ID=525709
Thank you sir - good logic, I tried this but still no joy. Car fully deflated (which makes me assume that the Residual Pressure Valves in the struts are ok?), no visible signs of damage to the valve block or any lines to it, and once reconnected and ignition turned on the compressor would run and start to raise the car before stopping once the fault come on.
Any time I try any function involving the compressor or venting of the bags, the mechanical failure code pops up. At least we know the compressor works ok... on advanced measured values it shows "thermal cut-out count: 10", but this has not increased during any of these compressor runs, so dont think that is to blame.
I am a bit at a loss as to what to check next. I suppose I will get under the car and inspect the compressor and test the sensors through the full range of motion since rocking the car doesn't highlight any sticking sensors.
These are the consistent codes now:
Saturday,15,March,2025,19:37:31:21606
                Address 34: Level Control       Labels: 4G0-907-553.CLB
Control Module Part Number: 4G0 907 553 G    HW: 4G0 907 553 F
  Component and/or Version: LUFE-DAEMPFER H19 0783
           Software Coding: 008001
            Work Shop Code: WSC 02391 785 00200
              ASAM Dataset: EV_AirSuspe 003025 (AU57)
                    Reset counter: 220
                    Mileage: 116896 km
                    Date: 2025.03.15
                    Time: 19:29:08
                    Reset counter: 220
                    Mileage: 116896 km
                    Date: 2025.03.15
                    Time: 19:28:47
                    Reset counter: 220
                    Mileage: 116896 km
                    Date: 2025.03.15
                    Time: 19:28:49
Stef G
Bedfordshire, UK
C?ID=525709
Or actually - since this is the code that keeps returning on the ABS module... is this pointing me in the direction of the Rear Left level sensor?
Saturday,22,March,2025,15:29:29:21606
VCDS Version: 25.3.0.4 (x64)  HEX-NET2 CB: 0.4660.5
Data version: 20250311 DS365.0
                Address 03: ABS Brakes       Labels: 4G0-907-379-V2.clb
Control Module Part Number: 4G0 907 379 S    HW: 4G0 907 379 S
  Component and/or Version: ESP9 Premium  H01 0530
           Software Coding: 49A7DE4592E57BA2BB00
              ASAM Dataset: EV_ESP9BOSCHAU57X 004018 (AU57)
                       ROD: EV_ESP9BOSCHAU57X.rod
                      VCID: 41D42AE8210C8C62C09-8014
                    Mileage: 116896 km
                    Date: 2025.03.22
                    Time: 15:24:42
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 00
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    Uz: 99
          U1112 00 [00101111] - -
                    Mileage: 116896 km
                    Date: 2025.03.22
                    Time: 15:24:39
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 00
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    Uz: 99
davisev5225
C?ID=263265
Hmm, that's an unexpected result. I'm not fully versed in the C7 air suspension, but usually the system will absolutely refuse to pressurize only if it believes there's no way to let the air back out. That usually means valve block failure, or in some cases, compressor failure - some systems have the venting valve attached to the compressor instead of the valve block. I'd suggest looking at the compressor next - see if you can find the venting valve and perform the same routine: 1-2 drops air tool oil into it and give it a few whacks with a mallet. Might help to whack it while it's installed and attempting to inflate the car.
That said, doing a bit of Googling around, I did come across this post which may also be applicable to your issues:
This may help also:
or this one, (start at ~4:30)
Stef G
Bedfordshire, UK
C?ID=525709
I think you are onto something with the compressor having it's own valve, I shall investigate, thank you! I did see that last post and the last comment, "shouldnt vent without supporting the rear otherwise replace the rear air springs", scared me! They must be super F'd now if that is true, but I can't see anything else online about it.
This may help also:
These are super helpful in terms of learning the system - thanks for these! Need to find a second person to help listen for the valve block engaging now...
Interestingly...... I tried today & couldnt replicate the compressor starting. Until I accidentally started the car with the valve block unplugged. Compressor started fine, run for a couple of minutes, then returned air system open circuit faults and pressure value errors (expected). Plugged back in, compressor will not run now.
Importantly the C1047 07 [00001001] - Mechanical Failure code does NOT appear with the valve block disconnected, only when it IS connected.
Now, do I bite the bullet and buy myself a new valve block, or go down the rabbit hole of the only remaining/recurring ABS fault (Hoehenwert HL error, translates to Height Level Rear Left)? I am struggling for time and really need to get the car moved and can't really afford to be pissing away money firing up the parts cannon :banghead:
