AD BLUE INDICATOR ON INSTRUMENT
thanosxx
Greece
C?ID=298538
Hello On this car ,we haven't indication of adblue on display on instrument cluster ,we have -----
Thursday,13,March,2025,10:21:10:57658
VCDS Version: 25.3.0.3 (x64)  HEX-V2 CB: 0.4660.4
Data version: 20250301 DS365.0
VIN: TMBJG7NU5L5020675   License Plate:
Chassis Type: NU-SK37 (3Q0)
Scan: 01 03 08 09 13 15 17 19 42 44 52 5F BB BC
VIN: TMBJG7NU5L5020675   Mileage: 156336km-97142miles
Address 01: Engine (J623-DGTE)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 056 TH    HW: 04L 907 445 G
   Component: R4 1.6l TDI   H01 6987
   Revision: 22102001
   Coding: 01194012432415092000
   Shop #: WSC 00033 790 00176
   ASAM Dataset: EV_ECM16TDI03004L906056TH 004001
   ROD: EV_ECM16TDI03004L906056TH_SK37.rod
   VCID: 06569CC078A93E9AB5C-8052
   VINID: 91D49A5C77A515C14008018714DF135742
39804 - Cylinder 3 Pressure too Low
          P03AE 00 [11101100] - -
                    Mileage: 156260 km
                    Date: 2025.03.11
                    Time: 19:00:16
                    Engine speed: 2421.75 /min
                    Vehicle speed: 114 km/h
                    Coolant temperature: 87 °C
                    Intake air temperature: 18 °C
                    Voltage terminal 30: 14.859 V
                    Cylinder head: pressure sensor 3 bank 1: raw value: 34.9 bar
27167 - Heater support pump
          P16C7 00 [00100011] - locked
                    Mileage: 156336 km
                    Date: 2025.03.13
                    Time: 09:30:22
                    Engine speed: 0.00 /min
                    Coolant temperature: 48 °C
                    Intake air temperature: 29 °C
                    Voltage terminal 30: 12.289 V
                    Heater support pump 1 bank 1 second.circuit: activat.: 94.17 %
                    Heater support pump 1 bank 1 primary circuit: activation: 5.00 %
                    Heater supp.pump 1 bank 1 charg.air cool.circuit: activat.: 10.00 %
Readiness: N/A
   Part No SW: 5Q0 614 517 ER    HW: 5Q0 614 517 BN
   Component: ESC           H35 0190
   Revision: 00000000    Serial number: 62949000001524
   Coding: 1F076AA120220C6C477D060762C825F8560430E26046A4731043F078D0024A0B00000C6212120B095A35351919323200
   Shop #: WSC 00033 790 00116
   ROD: EV_Brake1UDSContiMK100IPB_038.rod
   VCID: 05549BCC45AF3582BC6-8050
0040 - Front Left Wheel Speed Sensor
          C101A 01 [00001000] - Electrical Failure
                    Reset counter: 136
                    Mileage: 155861 km
16401 - Tire Pressure Warning
          C102D 00 [00001000] - -
                    Reset counter: 150
                    Mileage: 156111 km
                    Date: 2025.03.04
                    Time: 12:58:29
32993 - Control Module for Electric Parking Brake
          C10E2 F0 [00001000] - RPM Sensor Implausble Signal
                    Reset counter: 137
                    Mileage: 155861 km
Address 08: Auto HVAC (J301)       Labels:* None
   Part No SW: 565 820 047 D    HW: 565 820 047 D
   Component: AC Manuell    H07 2201
   Revision: 00001K00
   Coding: 06010104000114001000000000400002
   ASAM Dataset: EV_ACManueBHBVW37X 004136
   ROD: EV_ACManueBHBVW37X_004_VW37.rod
   VCID: 196CC7BCD917A16268E-804C
   Part No SW: 5Q0 937 084 DE    HW: 5Q0 937 084 CD
   Component: BCM MQBAB B   H40 0312
   Serial number: 01001926600112 Dataset Number: V03935312FR 0001
   ASAM Dataset: EV_BCMMQB 020001
   ROD: EV_BCMBOSCH_020_VW27.rod
   VCID: 7EA6F4202079665AFDC-802A
   Steering Column Switch:
   Subsystem 1 - Part No SW: 5Q1 953 521 B    HW: 5Q1 953 569 A
   Component: Lenks.Modul  H13  0170
   Serial number: 0100101020190C303015
   Part No SW: 2Q0 907 572 R    HW: 2Q0 907 572 B
   Component: ACCCONTIMQB   H03 0372
   Dataset Number: V03935304GB 0001
   Coding: 2A04600110FF8728749C814500408700000000000000000004
   ROD: EV_ACCMRRCONTIVW376_003_VW37.rod
   VCID: 43D045D40B1BCBB2D22-8016
   Part No SW: 3Q0 959 655 CM    HW: 3Q0 959 655 CM
   Component: Airbag VW21   006 0720
   Revision: --------    Serial number: 003Z2PLEE5F5 Dataset Number: V03935285KD 0001
   Coding: 98CCC0C0000000005C5400CF000800000065
   VCID: 0B40ADF463CB43F2EA2-805E
   Subsystem 1 - Part No SW: -----------    HW: 454 000 810 19
   Serial number: 35700000000400947F3E
   Subsystem 2 - Part No SW: -----------    HW: 454 000 510 19
   Serial number: 3580000000042328FF3P
   Subsystem 3 - Part No SW: -----------    HW: 454 800 610 19
   Serial number: 35100A60FE419000000P
   Subsystem 4 - Part No SW: -----------    HW: 454 800 310 19
   Serial number: 3520035C3CB19000000N
   Subsystem 5 - Part No SW: -----------    HW: 454 801 909 19
   Serial number: 355002C83CB19000000S
   Part No SW: 565 920 741 C    HW: 565 920 741 C
   Component: KOMBI         203 6700
   Coding: 07A40C062380000801882A011000000080000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009069
   VCID: 1A6ED8B0DC11AA7A614-804E
   Part No SW: 3Q0 907 530 AC    HW: 3Q0 907 530 C
   Component: GW MQB High   521 5388
   Serial number: 29101910800503 Dataset Number: V03935300AP 0001
   Coding: 030100045F08730021100040000F00010001070000000000000000000000
   Shop #: WSC 00033 790 00114
   GVL: 01403C0000000000400C80000000480000000000000000000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 70BADA186A2D002A7F0-8024
   Generator:
   Component: 4-01-13-01-04
   Subsystem 2 - Part No SW: 3V0 919 719 E    HW: 3V0 919 719 E
   Component: E221__MFL-PR6  H03 0180
   Serial number: 000000000C0101191019
   Serial number: 758860030019102217F2
   Part No SW: 5Q4 959 393 K    HW: 5Q4 959 393 K
   Component: TSG FS        007 0485
   Serial number: 0000391502185  Dataset Number: V03935310LN 0001
   Coding: 001001208000020000001100
   VCID: 4BC06DF4234B03F22A2-801E
   Subsystem 1 - Part No SW: 5Q0 959 407 A    HW: 5Q0 959 163   Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_DRV  007 0010
   Serial number: 00000000000034920092
   Coding: 010200
          B1487 54 [00001000] - Missing Calibration / Basic Setting
                    Reset counter: 135
                    Mileage: 155816 km
                    Date: 2024.10.21
                    Time: 00:19:12
196665 - Switch for Central Locking
          B122D 29 [00001000] - Signal Implausible
                    Reset counter: 151
                    Mileage: 155868 km
                    Date: 2025.02.27
                    Time: 10:17:32
Address 44: Steering Assist (J500)       Labels:| 5Q0-910-143.clb
   Part No SW: 5Q0 910 143 C    HW: 5Q0 910 143
   Component: MQB_VWBS_GEN2 212 2211
   Serial number: 958040 00  Dataset Number: V03935289RG 0001
   Coding: 0100001000400010
   ASAM Dataset: EV_SteerAssisVWBSMQBGen2 002119
   ROD: EV_SteerAssisVWBSMQBGen2.rod
   VCID: 2B000D74838B23F20A2-807E
   Part No SW: 5Q4 959 392 K    HW: 5Q4 959 392 K
   Component: TSG BFS       007 0485
   Serial number: 0000391554789  Dataset Number: V03935310LV 0001
   VCID: 4ACE68F02C311AFA114-801E
   Subsystem 1 - Part No SW: 5Q0 959 408 A    HW: 5Q0 959 164   Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_PSG  007 0010
   Serial number: 00000000000035084866
   Coding: 190200
                    Reset counter: 135
                    Mileage: 155816 km
                    Date: 2024.10.21
                    Time: 00:19:14
          B122D 29 [00001001] - Signal Implausible
                    Fault Frequency: 8
                    Reset counter: 103
                    Mileage: 155833 km
                    Date: 2024.11.07
                    Time: 16:05:20
   Part No SW: 565 035 840     HW: 565 035 840
   Component: MU-S--ER      H41 0478
   Serial number: SKZAZ2W1089224 Dataset Number: V03935311CH 0001
   Coding: 03230600FF0000000111000100080A002F0208C40120050003
   ROD: EV_MUStd4CTSAT_VW37.rod
   VCID: 54F27688FE755C0A7B8-8000
   Subsystem 1 - Part No SW: 565 919 605 C    HW: 565 919 605 C
   Component: ABT_Std-2  H53 8130
   Serial number: SKZ6ZHW3024588
End----------(Elapsed Time: 01:16, VBatt start/end: 12.3V/12.2V)-----------
------------------------------9 Faults Found-------------------------------
You might want to translate what you're showing on the cluster.
thanosxx
Greece
C?ID=298538
autonomy adblue
Boki Ar
Arandjelovac, Serbia
C?ID=57300
If everything is in order, it is enough to add Adblue.
However, if there is a fault in the reductant delivery/injection system, such as pump, it is necessary to fix, repair the fault.
autonomy adblue
Very interesting.... what's the owner's manual suggest you do when the cluster says that. I've never heard of that expression being prompted by a cluster on this side of the pond.
thanosxx
Greece
C?ID=298538
The adblue is until up level,and I haven't error code about adblue The customer bought this car before a few week (used) so we don't know the previous history
Does it still start\run?
Boki Ar
C?ID=57300
It wouldn't be strange if someone did ADblue elimination, I know people do so.
