E-up steering calibration help
Matt@reflex
Northamptonshire, UK
C?ID=108766
Hi guys . I’ve messed up trying to calibrate the steering settings on my 2023 e-up. Can anyone confirm that the car will need to go to the dealer to have its control unit coded.
I have the latest hex net professional cables.
Thanks in advance,
Matt.
Friday,28,February,2025,14:58:22:03903
VCDS Version: 24.7.1.0 (x64)  HEX-NET2 CB: 0.4643.5
VIN: WVWZZZAA9RD900829   License Plate: YL73FXE
Mileage: 5980km-3715mi   Repair Order: up gte
Chassis Type: AA-VW12 (1S0)
Scan: 01 03 08 09 10 15 17 19 23 25 44 51 5F 61 75 8C A5 BD C0 C6
VIN: WVWZZZAA9RD900829   Mileage: 5980km-3715miles
BD-Hi Volt. Batt. Charg. -- Status: OK 0000
Address 01: Engine (J623-EBMA)       Labels:. 0EA-907-309-V1.clb
   Part No SW: 0EA 906 016 M    HW: 0EA 907 309 B
   Component: E-Vehicle     H24 7453
   Revision: WLH24---    CVN: AE522C9D
   Coding: 000D0012002400000000
   Shop #: WSC 31414 195 00001
   ASAM Dataset: EV_VCU00XXX0110EA906016M 003001
   ROD: GV_VCU00XXX011VW120.rod
   VCID: 39244000D9D96132585-806C
   VINID: 9E69EAAAA45126250900020224DCA7B8BE
Address 03: ABS Brakes (J104)       Labels: 1S0-614-517.clb
   Part No SW: 12E 614 517 G    HW: 12E 614 517 G
   Component: EBC 460 ESP   H19 0014
   Serial number: A027PZE Dataset Number: V03935308RM 0001
   Coding: 44BF247199AD00F1220224F799B200815F0800
   Shop #: WSC 31414 134 00001
   ASAM Dataset: EV_Brake1ESPTRWPQ12E 006016
   ROD: EV_Brake1ESPTRWPQ12E_006.rod
   VCID: 270096783F6DE7C23E1-8072
0360 - Steering angle sensor
          B1168 54 [10001001] - Missing Calibration / Basic Setting
   Part No SW: 12E 907 044 E    HW: 12E 907 044 E
   Component: Climatronic   H08 0111
   Revision: V0000000
   VCID: 251C9C7045E1F5D20CD-8070
   Subsystem 1 - Part No SW: 12E 963 231 K    HW: 12E 963 231 K
   Component: J848 HV-PTC  H09 0211
   Serial number: LE231643013303000069
   Subsystem 2 - Part No SW: 3GD 816 803 D    HW: 3GD 816 803 D
   Component: J842 eKK  H01 0002
Address 09: Cent. Elect. (J519)       Labels:. 1S0-937-09x-V2.clb
   Part No SW: 1S0 937 090 M    HW: 1S0 937 090 M
   Component: BCM PQ25 1MX4 H84 0780
   Revision: BW084001    Serial number: 5203 166231163
   Coding: 64B82B000001000021080FD42CEB0EF07180726C604325602101000B0810
   VCID: 3D2C5410CD715D1274D-8068
   Subsystem 1 - Part No: 5K7 955 547
   Component: RLHS 050623 0  50  0107
   Coding: 0228DD
   Subsystem 2 - Part No SW: 2H0 959 442     HW: 2H0 959 442
   Component: E221__MFL-MD9  H02 0103
   Serial number: 29230000905810083255
   Coding: A4FFFF
Address 10: Park/Steer Assist (J446)       Labels:| 1Sx-919-475.clb
   Part No SW: 1S0 919 475 C    HW: 1Q0 919 475
   Component: PARKHILFE 3K  H03 0014
   Revision: --------    Serial number: 32932316801250
   Coding: 308106
   ASAM Dataset: EV_EPHVA14VW1200000 001011
   ROD: EV_EPHVA14VW1200000.rod
   VCID: 3A265F0CDCDF6A2A51F-806E
Address 15: Airbags (J234)       Labels:| 6C0-959-655.clb
   Part No SW: 6C0 959 655 AQ    HW: 6C0 959 655 AQ
   Component: Airbag VW12   002 0609
   Revision: --------    Serial number: 00301BDA5USYHN Dataset Number: V03935361LG 0001
   Coding: 88CCC0C000200000545000CF008000500065
   Shop #: WSC 31414 124 00001
   ASAM Dataset: EV_AirbaVW12TS6VW25X 001510
   ROD: EV_AirbaVW12TS6VW25X_VW12.rod
   VCID: 0256E7ECF48FE2EA49F-8056
   Serial number: 34900100607C11322008
   Serial number: 350001005FEDE7D22008
   Serial number: 3510010060205402200V
   Serial number: 3520010061A938E2200N
   Serial number: 355001005A288922300K
Address 17: Instruments (J285)       Labels:| 1Sx-920-xxx-17.clb-SRI1
   Part No SW: 12E 920 960 J    HW: 12E 920 960 J
   Component: KOMBI         H50 0403
   Revision: X0050002    Serial number: 00000000000000
   Coding: 410A010000
   ASAM Dataset: EV_KombiUDSMM9RM10 A05811
   ROD: EV_KombiUDSMM9RM10_A05_VW12.rod
   VCID: 2C0A6954268BC49AD33-8078
   Part No SW: 1S0 909 901     HW: 1S0 937 090 M
   Component: GW-K-CAN TP20 H84 0780
   Revision: BW084001
   Coding: 002301
   VCID: 70B2BD24CAA3E07AAFB-8024
Address 23: Brake Booster (J539)       Labels:| 5QE-909-059.clb
   Part No SW: 12E 909 059 A    HW: 12E 909 059
   Component: EBKV          H12 0123
   Serial number:   085460010535 Dataset Number: V03935167FW 0001
   Coding: 00700134010101
   ASAM Dataset: EV_BrakeBoostEBKVBosch 004025
   ROD: EV_BrakeBoostEBKVBosch_VW12.rod
   VCID: 290490402979D1B2285-807C
   Brake pressure reservoir:
   Subsystem 1 - Part No SW: 12E 614 307 B    HW: 12E 614 307 A
   Component: V545BrakeAssi  H04 0115
   Serial number: 05802861220623084616
   Part No SW: 5K0 953 234     HW: 12E 920 960 J
   Component: IMMO          H50 0403
   ASAM Dataset: EV_ImmoUDSMM9RM10 A01702
   VCID: 6A86AF4CECFF1AAAE1F-803E
Address 44: Steering Assist (J792)       Labels:* None
   Part No SW: 2Q2 909 144 AG    HW: 2Q2 909 144 AC
   Component: TRW_G4L_MQBA0 623 6220
   Serial number: 03745108CB2P151
   Coding: 000000000000000000000201010001010000010001
   ASAM Dataset: EV_SteerAssisZFGen1PQ12PA 002002
   ROD: EV_SteerAssisZFGen1PQ12PA.rod
   VCID: 78A28504A253B83A67B-802C
10531840 - Steering angle sensor
                    Reset counter: 149
                    Mileage: 5984 km
                    Date: 2025.02.28.
                    Time: 02:23:17
                    Engine RPM: 0 /min
                    Terminal 15 status: On
                    Voltage terminal 30: 14.91 V
                    Power steering current consumption: 0.5 A
                    max.value: 0.5 A
                    End stage temperature: 20 °C
                    Steering assistance: engine output: 100 %
                    Engine angle: 0 °
                    Electric motor speed: 0 /min
                    Steering assistance: target engine torque: 0.0 Nm
                    Steering torque: 0.0 Nm
10552064 - Control Module Incorrectly Coded
          U1014 00 [00001001] - -
          [DEM_CODING_HCA_FAULT]
                    Reset counter: 149
                    Mileage: 5984 km
                    Date: 2025.02.28.
                    Time: 02:23:17
                    Engine RPM: 0 /min
                    max.value: 0.5 A
                    Engine angle: 0 °
10532608 - No End-of-Line Programming
          B2013 00 [00001001] - -
          [DEM_NO_VW_EOL_PROGRAMMING_FAULT]
                    Reset counter: 149
                    Mileage: 5984 km
                    Date: 2025.02.28.
                    Time: 02:23:17
                    Engine RPM: 0 /min
                    max.value: 0.5 A
                    Engine angle: 0 °
10512640 - Steering End Stops Not Learned
          C10AC F0 [10001001] - Unknown Error Elaboration
          [DEM_BOTH_ENDSTOP_NOT_KNOWN]
                    Reset counter: 149
                    Mileage: 5984 km
                    Date: 2025.02.28.
                    Time: 02:23:17
                    Engine RPM: 0 /min
                    max.value: 0.5 A
                    Engine angle: 0 °
   Part No SW: 12E 907 080 L    HW: 12E 907 080 L
   Component: Inverter Gen3 H23 2175
   Revision: 00H23000    CVN: 29E191D0
   Coding: C0020000000000000000
   ASAM Dataset: EV_DMCM100301112E907080L 001002
   ROD: EV_DMCM100301112E907080L.rod
   Part No SW: 1S0 035 869 B    HW: 1S0 035 869 B
   Component: MU-E-D-EU     080 7388
   Serial number: 22062300022597 Dataset Number: V03935393HL 0001
   Coding: 02210000BE00000041111101018002001F0003D60001010001
   ROD: EV_MUEnt4CGen2LGE_VW12.rod
   VCID: 353C4C30F5C18552BCD-8060
   Part No SW: 1S0 907 534     HW: 1S0 937 090 M
   Component: Batt.regelung H84 0780
   Coding: 1682081C
   Shop #: WSC 31414 790 00001
   Subsystem 1 - Part No SW: 6Z3 915 181 A    HW: 6Z3 915 181 A
   Component: J367-BDM  H07 0270
   Serial number: 4A117B53299182063487
   Part No SW: 12E 035 284 B    HW: 12E 035 284 B
   Component: OCULowEMobil  029 0183
   Serial number: 000003560590514 Dataset Number: V03935394BE 0001
   Coding: 02217001101612F000F800000000
   ASAM Dataset: EV_OCULow 002010
   ROD: EV_OCULow_002.rod
   VCID: 20128D645A4310FA7FB-8074
Address 8C: HV Battery (J840)       Labels: 5QE-915-227.clb
   Part No SW: 12E 915 227 AA    HW: 12E 915 227 Q
   Component: K8C           H14 2730
   Serial number: 288 VWAPOFR00T CVN: 4DF7B637
   ASAM Dataset: EV_BECM084202112E915227AA 009010
   ROD: EV_BECM084202112E915227AA.rod
   VCID: 649AC1740EDB4CDADB3-8030
   Part No SW: 3Q0 980 654 P    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H15 0821
   Serial number: 19062312P21355 Dataset Number: V03935343D  0001
   Coding: 00020706000004010006004081D0440084000E00000000
   ROD: EV_MFKBoschMQBB_002.rod
   VCID: 44DA21F4AE1B2CDA3B3-8010
0659 - Steering
          C10AC F2 [00001001] - Lane-Holding Assistance Not Coded
          [HC_interface_at_the_steering_not_activated]
                    Reset counter: 149
                    Mileage: 5984 km
                    Date: 2025.02.28.
                    Time: 02:23:18
                    Control Module temperature: 30 °C
                    Outside temperature: 8.5 °C
                    Vehicle speed: 0.00 km/h
                    System run time: 142.6 s
                    Voltage terminal 15: 14.7 V
                    mid: 02 A6
                    Status of camera: operational
                    Engine_Running_Info: 1
                    Software_Info_4: 1
                    Software_Info_3: 2
                    Software_Info_2: 8
                    Software_Info_1: 0
Address BD: Hi Volt. Batt. Charg. (J966)       Labels:| 5QE-915-022-V2.clb
   Part No SW: 12E 915 022 AC    HW: 12E 915 022 C
   Component: LMSG          H11 0089
   Serial number: 01987032220276 Dataset Number: V03935330TG 0001
   Coding: CA0D04040000
   ASAM Dataset: EV_HVChargManagVW 006008
   ROD: EV_HVChargManagVW_006.rod
   VCID: 5F90CE9827BD6F02061-800A
Address C0: Act. for Ext. Noise (J943)       Labels: 4G0-907-160.clb
   Part No SW: 12E 035 335 C    HW: 4H0 907 159 A
   Component: SAS-GEN 2 AGA H07 0010
   Serial number: 230607290694
   ASAM Dataset: EV_ActuaForExterNoiseUDS 003013
   ROD: EV_ActuaForExterNoiseUDS.rod
   VCID: 1E6EB39C6037260A4D7-804A
Address C6: Batt. Chrg. (J1050)       Labels: 5QE-915-681.clb
   Part No SW: 5QE 915 681 BT    HW: 5QE 915 681 BT
   Component: OBC KOSTAL    H36 2118
   Serial number: ---------------
   ASAM Dataset: EV_OBC2PhaseKLOPQ2515B 001001
   ROD: EV_OBC2PhaseKLOPQ2515B.rod
   VCID: 1F108E98673D2F02461-804A
End----------(Elapsed Time: 01:23, VBatt start/end: 14.8V/14.9V)-----------
Warren333
Hull, UK
C?ID=604450
This shows you how
Matt@reflex
C?ID=108766
Thanks. I did try to view that but the video keeps auto playing every time I open the link
I’ll scan again on the new laptop so I can send the scan from there rather than the emailed version on my phone.
Which of the Basic Settings that produce a warning telling you that you probably shouldn't to do that did you run? ;)
Not for coding, but to have the end-of-line programming ("parameterization") put back in.
PS: WVWZZZAA9RD900829 is a 2024 model, not 2023.
Matt@reflex
C?ID=108766
Sorry, yes it’s a December 23 car.
I tried to put the steering angle settings back to factory settings 🫣
It’s cool. I just wanted to check that it couldn’t be done by myself ( with tutorials) or an independent.
I’ll get it booked in at the dealer.
Thanks for the reply and yes, lesson learned 😁
An independent can do it if he has (legitimate!) ODIS and access to VW's servers.
